[Swift-devel] recent karajan changes causing trouble
    Veronika Nefedova
    nefedova at mcs.anl.gov
    Fri Jul  6 10:22:23 CDT 2007
On Jul 6, 2007, at 10:16 AM, Mihael Hategan wrote:
> On Fri, 2007-07-06 at 10:13 -0500, Veronika Nefedova wrote:
>> with the old version of the script (all loops unrolled) it would take
>> about 1.5 hours to compile (244 molecules). Once compiled it would
>> start the execution within a minute.
> How can you tell when it's done compiling?
When its done compiling, it starts execution  - you right, its hard
to tell when its all done in one step. But when you already have the
compiled code and start execution - it takes less then a minute (30
seconds?) to send the first task out.
Nika
>> A new swift code (with the main loop done in 'foreach' is under way
>> (I am testing it right now).
>> Nika
>> On Jul 6, 2007, at 9:49 AM, Ben Clifford wrote:
>>> On my machine that seems to take i) forever to compile (as in I
>>> gave up
>>> after it generated the 25mb intermediate xml file but before it had
>>> made a
>>> kml file), and ii) forever to get to the stage where it tries to
>>> execute
>>> anything (as in I gave up before it gave me an error about not
>>> being able
>>> to find the transformations to run).
>>> What sort of times does it usually take for you to:
>>>  i) compile
>>>  ii) run the first executable
>>> On Thu, 5 Jul 2007, Ben Clifford wrote:
>>>> what karajan revision? and what swift revision?
>>>> (type svn info in the cog and dsk directories...)
>>>> On Thu, 5 Jul 2007, Veronika Nefedova wrote:
>>>>> you can use my kml file that I compiled today with the latest
>>>>> karajan (its on
>>>>> terminable).
>>>>> On Jul 5, 2007, at 2:57 PM, Ben Clifford wrote:
>>>>>> ou have your heap set on the 244 molecule workflow? I run out at
>>>>>> the
>>>>>> compile stage with default.
>> Swift-devel mailing list
>> Swift-devel at ci.uchicago.edu
>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
