[Swift-devel] recent karajan changes causing trouble
    Mihael Hategan
    hategan at mcs.anl.gov
    Fri Jul  6 10:16:43 CDT 2007
On Fri, 2007-07-06 at 10:13 -0500, Veronika Nefedova wrote:
> with the old version of the script (all loops unrolled) it would take
> about 1.5 hours to compile (244 molecules). Once compiled it would
> start the execution within a minute.
How can you tell when it's done compiling?
> A new swift code (with the main loop done in 'foreach' is under way
> (I am testing it right now).
> Nika
> On Jul 6, 2007, at 9:49 AM, Ben Clifford wrote:
> > On my machine that seems to take i) forever to compile (as in I
> > gave up
> > after it generated the 25mb intermediate xml file but before it had
> > made a
> > kml file), and ii) forever to get to the stage where it tries to
> > execute
> > anything (as in I gave up before it gave me an error about not
> > being able
> > to find the transformations to run).
> > What sort of times does it usually take for you to:
> >  i) compile
> >  ii) run the first executable
> > On Thu, 5 Jul 2007, Ben Clifford wrote:
> >> what karajan revision? and what swift revision?
> >> (type svn info in the cog and dsk directories...)
> >> On Thu, 5 Jul 2007, Veronika Nefedova wrote:
> >>> you can use my kml file that I compiled today with the latest
> >>> karajan (its on
> >>> terminable).
> >>> On Jul 5, 2007, at 2:57 PM, Ben Clifford wrote:
> >>>> ou have your heap set on the 244 molecule workflow? I run out at
> >>>> the
> >>>> compile stage with default.
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
