[Swift-devel] recent karajan changes causing trouble
    Mihael Hategan
    hategan at mcs.anl.gov
    Fri Jul  6 10:25:32 CDT 2007
On Fri, 2007-07-06 at 10:22 -0500, Veronika Nefedova wrote:
> On Jul 6, 2007, at 10:16 AM, Mihael Hategan wrote:
> > On Fri, 2007-07-06 at 10:13 -0500, Veronika Nefedova wrote:
> >> with the old version of the script (all loops unrolled) it would take
> >> about 1.5 hours to compile (244 molecules). Once compiled it would
> >> start the execution within a minute.
> > How can you tell when it's done compiling?
> When its done compiling, it starts execution  - you right, its hard
> to tell when its all done in one step. But when you already have the
> compiled code and start execution - it takes less then a minute (30
> seconds?) to send the first task out.
That makes sense. We need to speed up compilation?
> Nika
> >> A new swift code (with the main loop done in 'foreach' is under way
> >> (I am testing it right now).
> >> Nika
> >> On Jul 6, 2007, at 9:49 AM, Ben Clifford wrote:
> >>> On my machine that seems to take i) forever to compile (as in I
> >>> gave up
> >>> after it generated the 25mb intermediate xml file but before it had
> >>> made a
> >>> kml file), and ii) forever to get to the stage where it tries to
> >>> execute
> >>> anything (as in I gave up before it gave me an error about not
> >>> being able
> >>> to find the transformations to run).
> >>> What sort of times does it usually take for you to:
> >>>  i) compile
> >>>  ii) run the first executable
> >>> On Thu, 5 Jul 2007, Ben Clifford wrote:
> >>>> what karajan revision? and what swift revision?
> >>>> (type svn info in the cog and dsk directories...)
> >>>> On Thu, 5 Jul 2007, Veronika Nefedova wrote:
> >>>>> you can use my kml file that I compiled today with the latest
> >>>>> karajan (its on
> >>>>> terminable).
> >>>>> On Jul 5, 2007, at 2:57 PM, Ben Clifford wrote:
> >>>>>> ou have your heap set on the 244 molecule workflow? I run out at
> >>>>>> the
> >>>>>> compile stage with default.
> >> _______________________________________________
> >> Swift-devel mailing list
> >> Swift-devel at ci.uchicago.edu
> >> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
