[Swift-devel] recent karajan changes causing trouble
    Veronika Nefedova
    nefedova at mcs.anl.gov
    Fri Jul  6 10:13:28 CDT 2007
with the old version of the script (all loops unrolled) it would take
about 1.5 hours to compile (244 molecules). Once compiled it would
start the execution within a minute.
A new swift code (with the main loop done in 'foreach' is under way
(I am testing it right now).
Nika
On Jul 6, 2007, at 9:49 AM, Ben Clifford wrote:
> On my machine that seems to take i) forever to compile (as in I
> gave up
> after it generated the 25mb intermediate xml file but before it had
> made a
> kml file), and ii) forever to get to the stage where it tries to
> execute
> anything (as in I gave up before it gave me an error about not
> being able
> to find the transformations to run).
> What sort of times does it usually take for you to:
>  i) compile
>  ii) run the first executable
> On Thu, 5 Jul 2007, Ben Clifford wrote:
>> what karajan revision? and what swift revision?
>> (type svn info in the cog and dsk directories...)
>> On Thu, 5 Jul 2007, Veronika Nefedova wrote:
>>> you can use my kml file that I compiled today with the latest
>>> karajan (its on
>>> terminable).
>>> On Jul 5, 2007, at 2:57 PM, Ben Clifford wrote:
>>>> ou have your heap set on the 244 molecule workflow? I run out at
>>>> the
>>>> compile stage with default.
