[Swift-devel] recent karajan changes causing trouble
    Ben Clifford
    benc at hawaga.org.uk
    Fri Jul  6 09:49:33 CDT 2007
On my machine that seems to take i) forever to compile (as in I gave up
after it generated the 25mb intermediate xml file but before it had made a
kml file), and ii) forever to get to the stage where it tries to execute
anything (as in I gave up before it gave me an error about not being able
to find the transformations to run).
What sort of times does it usually take for you to:
 i) compile
 ii) run the first executable
On Thu, 5 Jul 2007, Ben Clifford wrote:
> what karajan revision? and what swift revision?
> (type svn info in the cog and dsk directories...)
> On Thu, 5 Jul 2007, Veronika Nefedova wrote:
> > you can use my kml file that I compiled today with the latest karajan (its on
> > terminable).
> > On Jul 5, 2007, at 2:57 PM, Ben Clifford wrote:
> > > ou have your heap set on the 244 molecule workflow? I run out at the
> > > compile stage with default.
