[Swift-devel] recent karajan changes causing trouble
    Mihael Hategan
    hategan at mcs.anl.gov
    Thu Jul  5 17:10:36 CDT 2007
On Thu, 2007-07-05 at 16:33 -0500, Mihael Hategan wrote:
> Tentative fix in SVN. I'm running tests to see if things hold.
Seems to work, as far as the karajan tests can tell.
> On Thu, 2007-07-05 at 16:20 -0500, Mihael Hategan wrote:
> > I might know what it is. Stay tuned.
> > On Thu, 2007-07-05 at 15:45 -0500, Veronika Nefedova wrote:
> > > 1657 for Karajan and 887 for vdsk
> > > On Jul 5, 2007, at 3:13 PM, Ben Clifford wrote:
> > > > what karajan revision? and what swift revision?
> > > > (type svn info in the cog and dsk directories...)
> > > > On Thu, 5 Jul 2007, Veronika Nefedova wrote:
> > > >> you can use my kml file that I compiled today with the latest
> > > >> karajan (its on
> > > >> terminable).
> > > >> On Jul 5, 2007, at 2:57 PM, Ben Clifford wrote:
> > > >>> ou have your heap set on the 244 molecule workflow? I run out at the
> > > >>> compile stage with default.
> > _______________________________________________
> > Swift-devel mailing list
> > Swift-devel at ci.uchicago.edu
> > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
