[Swift-devel] recent karajan changes causing trouble
    Mihael Hategan
    hategan at mcs.anl.gov
    Thu Jul  5 16:33:42 CDT 2007
In iteratizing the recursive thing that caused the stack overflow, I
ignored the fact that there was a lock on every object in the recursion
steps.
Tentative fix in SVN. I'm running tests to see if things hold.
On Thu, 2007-07-05 at 16:20 -0500, Mihael Hategan wrote:
> I might know what it is. Stay tuned.
> On Thu, 2007-07-05 at 15:45 -0500, Veronika Nefedova wrote:
> > 1657 for Karajan and 887 for vdsk
> > On Jul 5, 2007, at 3:13 PM, Ben Clifford wrote:
> > > what karajan revision? and what swift revision?
> > > (type svn info in the cog and dsk directories...)
> > > On Thu, 5 Jul 2007, Veronika Nefedova wrote:
> > >> you can use my kml file that I compiled today with the latest
> > >> karajan (its on
> > >> terminable).
> > >> On Jul 5, 2007, at 2:57 PM, Ben Clifford wrote:
> > >>> ou have your heap set on the 244 molecule workflow? I run out at the
> > >>> compile stage with default.
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
