[Swift-devel] build dependencies
Mihael Hategan
hategan at mcs.anl.gov
Fri Dec 28 12:50:06 CST 2007
As of r1525 there is one.
Use it like this:
ant -Dwith-provider-deef=true dist
provider-deef has to be in cog/modules.
On Fri, 2007-12-28 at 12:08 -0600, Mihael Hategan wrote:
> There is no patch yet.
> On Fri, 2007-12-28 at 11:54 -0600, Ioan Raicu wrote:
> > So how can we use the patch? Do we just update Swift and do ant dist?
> > Or what other options should we use to build the provider-deef at the
> > same time we build swift?
> > Thanks,
> > Ioan
> > > On Fri, 2007-12-28 at 10:49 +0000, Ben Clifford wrote:
> > >> I've been building provider-deef on my machine recently by having it
> > >> listed as a dependency of swift in build.xml (a patch in my quilt stack
> > >> adds that in as part of my local configuration). This seems to solve the
> > >> 'provider-deef overwriting the log config file' problem for me.
> > >> It might be interesting to make it possible to specify dependencies like
> > >> this at build time on the commandline to ant.
> > >> (this is very similar to the unix world way of saying:
> > >>> ./configure --enable-ipv6 --disable-sasl
> > >>> make
> > >> in order to determine if you want to have dependencies or not on ipv6 and
> > >> sasl (and hence corresponding features) in some software)
> > > A similar thing can be done by passing properties to ant and then using
> > > them to drive certain parts of the build (or not). Though it looks more
> > > like -Denable-ipv6=true.
> > > _______________________________________________
> > > Swift-devel mailing list
> > > Swift-devel at ci.uchicago.edu
> > > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
