[Swift-devel] build dependencies
Mihael Hategan hategan at mcs.anl.gov
Fri Dec 28 12:08:41 CST 2007
There is no patch yet.
On Fri, 2007-12-28 at 11:54 -0600, Ioan Raicu wrote:
> So how can we use the patch?  Do we just update Swift and do ant dist?
> Or what other options should we use to build the provider-deef at the
> same time we build swift?
> Thanks,
> Ioan
> Mihael Hategan wrote:
> > On Fri, 2007-12-28 at 10:49 +0000, Ben Clifford wrote:
> >> I've been building provider-deef on my machine recently by having it
> >> listed as a dependency of swift in build.xml (a patch in my quilt stack
> >> adds that in as part of my local configuration). This seems to solve the
> >> 'provider-deef overwriting the log config file' problem for me.
> >> It might be interesting to make it possible to specify dependencies like
> >> this at build time on the commandline to ant.
> >> (this is very similar to the unix world way of saying:
> >>> ./configure --enable-ipv6 --disable-sasl
> >>> make
> >> in order to determine if you want to have dependencies or not on ipv6 and
> >> sasl (and hence corresponding features) in some software)
> > A similar thing can be done by passing properties to ant and then using
> > them to drive certain parts of the build (or not). Though it looks more
> > like -Denable-ipv6=true.
> > _______________________________________________
> > Swift-devel mailing list
> > Swift-devel at ci.uchicago.edu
> > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
