[Swift-devel] build dependencies
Ioan Raicu iraicu at cs.uchicago.edu
Fri Dec 28 12:53:03 CST 2007
Great, thanks!  We'll give it a try!
Ioan
Mihael Hategan wrote:
> As of r1525 there is one.
> Use it like this:
> ant -Dwith-provider-deef=true dist
> provider-deef has to be in cog/modules.
> On Fri, 2007-12-28 at 12:08 -0600, Mihael Hategan wrote:
>> There is no patch yet.
>> On Fri, 2007-12-28 at 11:54 -0600, Ioan Raicu wrote:
>>> So how can we use the patch?  Do we just update Swift and do ant dist?
>>> Or what other options should we use to build the provider-deef at the
>>> same time we build swift?
>>> Thanks,
>>> Ioan
>>>> On Fri, 2007-12-28 at 10:49 +0000, Ben Clifford wrote:
>>>>> I've been building provider-deef on my machine recently by having it
>>>>> listed as a dependency of swift in build.xml (a patch in my quilt stack
>>>>> adds that in as part of my local configuration). This seems to solve the
>>>>> 'provider-deef overwriting the log config file' problem for me.
>>>>> It might be interesting to make it possible to specify dependencies like
>>>>> this at build time on the commandline to ant.
>>>>> (this is very similar to the unix world way of saying:
>>>>>> ./configure --enable-ipv6 --disable-sasl
>>>>>> make
>>>>> in order to determine if you want to have dependencies or not on ipv6 and
>>>>> sasl (and hence corresponding features) in some software)
>>>> A similar thing can be done by passing properties to ant and then using
>>>> them to drive certain parts of the build (or not). Though it looks more
>>>> like -Denable-ipv6=true.
>>>> _______________________________________________
>>>> Swift-devel mailing list
>>>> Swift-devel at ci.uchicago.edu
>>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
Ioan Raicu
Ph.D. Candidate
Distributed Systems Laboratory
Computer Science Department
University of Chicago
1100 E. 58th Street, Ryerson Hall
Chicago, IL 60637
Email: iraicu at cs.uchicago.edu
Web:   http://www.cs.uchicago.edu/~iraicu
http://dev.globus.org/wiki/Incubator/Falkon
http://www.ci.uchicago.edu/wiki/bin/view/VDS/DslCS
