[Swift-devel] build dependencies
Ioan Raicu iraicu at cs.uchicago.edu
Fri Dec 28 11:54:01 CST 2007
So how can we use the patch?  Do we just update Swift and do ant dist?
Or what other options should we use to build the provider-deef at the
same time we build swift?
Ioan
Mihael Hategan wrote:
> On Fri, 2007-12-28 at 10:49 +0000, Ben Clifford wrote:
>> I've been building provider-deef on my machine recently by having it
>> listed as a dependency of swift in build.xml (a patch in my quilt stack
>> adds that in as part of my local configuration). This seems to solve the
>> 'provider-deef overwriting the log config file' problem for me.
>> It might be interesting to make it possible to specify dependencies like
>> this at build time on the commandline to ant.
>> (this is very similar to the unix world way of saying:
>>> ./configure --enable-ipv6 --disable-sasl
>>> make
>> in order to determine if you want to have dependencies or not on ipv6 and
>> sasl (and hence corresponding features) in some software)
> A similar thing can be done by passing properties to ant and then using
> them to drive certain parts of the build (or not). Though it looks more
> like -Denable-ipv6=true.
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
Ioan Raicu
Ph.D. Candidate
Distributed Systems Laboratory
Computer Science Department
University of Chicago
1100 E. 58th Street, Ryerson Hall
Chicago, IL 60637
Email: iraicu at cs.uchicago.edu
Web:   http://www.cs.uchicago.edu/~iraicu
http://dev.globus.org/wiki/Incubator/Falkon
http://www.ci.uchicago.edu/wiki/bin/view/VDS/DslCS
