[Swift-devel] dataset marking
Mihael Hategan hategan at mcs.anl.gov
Fri Dec 7 12:28:41 CST 2007
Sounds right then.
On Fri, 2007-12-07 at 16:54 +0000, Ben Clifford wrote:
> On Fri, 7 Dec 2007, Mihael Hategan wrote:
> > There are some special cases. Static mappers. They know how many
> > elements there are in an array, so for those the array can be closed as
> > soon as they are mapped. But this applies to the other problem.
> OK. That should be ok here still. All existing closings still happen
> except for the one that happened at the end of every compound procedure on
> the procedure outputs (which is what is replaced by the stuff I have been
> playing with).
