[Swift-devel] dataset marking
Ben Clifford benc at hawaga.org.uk
Fri Dec 7 10:54:12 CST 2007
On Fri, 7 Dec 2007, Mihael Hategan wrote:
> There are some special cases. Static mappers. They know how many
> elements there are in an array, so for those the array can be closed as
> soon as they are mapped. But this applies to the other problem.
OK. That should be ok here still. All existing closings still happen
except for the one that happened at the end of every compound procedure on
the procedure outputs (which is what is replaced by the stuff I have been
playing with).
