[Swift-devel] (no subject)
Ian Foster
foster at mcs.anl.gov
Wed Dec 5 16:41:35 CST 2007
makes sense!
Ben Clifford wrote:
> On Wed, 5 Dec 2007, Ian Foster wrote:
>> It seemed to me that this example is a case of "variable that is never
>> assigned" -- that could perhaps be detected.
> There are some application invocations at the moment that don't explicitly
> indicate file outputs, though.
> For example, some of the fmri apps output a .hdr file and a .img file with
> the same base name and take only a .hdr filename as command-line parameter
> - its 'good' behaviour that an output parameter isn't explicitly
> mentioned.
> There's a bunch of stuff that could be done to the application description
> constructs in SwiftScript. However, as it is so far work-aroundable (as
> in, fix the bug in your swiftscript), its automatically deprioritised.
