[Swift-devel] Re: cannot commit to SVN...
    Ti Leggett
    leggett at ci.uchicago.edu
    Wed Aug 15 06:17:25 CDT 2007
There was a typo in the svn authz file. Try now.
On Aug 14, 2007, at 7:59 PM, Ioan Raicu wrote:
> Hi,
> I just tried again, with a clean SVN checkout on
> login.ci.uchicago.edu.  I included the date so you can look it up
> in the logs, if you need to.
> [iraicu at login container]$ date
> Tue Aug 14 19:55:43 CDT 2007
> [iraicu at login container]$ svn status
> A      hello
> [iraicu at login container]$ cd ..
> [iraicu at login falkon]$ svn cleanup
> [iraicu at login falkon]$ cd container/
> [iraicu at login container]$ svn ci hello
> testing
> --This line, and those below, will be ignored--
> A    hello
> "svn-commit.tmp" 4L, 68C written
> Adding         hello
> And then it just hangs there...
> Can you keep looking into this to see what is wrong?
> Thanks,
> Ioan
> Ioan Raicu wrote:
>> Hi,
>> I can't commit to SVN at CI. Here is the output I get from trying
>> to commit a simple test!
>> iraicu at viper:~/java/svn/falkon> svn ci test
>> just testing
>> A    test
>> "svn-commit.5.tmp" 4L, 72C written
>> Adding         test
>> Authentication realm: <https://svn.ci.uchicago.edu:443> SVN Login
>> Password for 'iraicu':
>> svn: Commit failed (details follow):
>> svn: CHECKOUT of '/svn/vdl2/!svn/ver/1075/falkon': 401
>> Authorization Required (https://svn.ci.uchicago.edu)
>> svn: Your commit message was left in a temporary file:
>> svn:    '/home/iraicu/java/svn/falkon/svn-commit.5.tmp'
>> Thanks,
>> Ioan
