[Swift-devel] Re: cannot commit to SVN...
    Ioan Raicu
    iraicu at cs.uchicago.edu
    Wed Aug 15 12:10:05 CDT 2007
It works!
iraicu at viper:~/java/svn/falkon> svn ci test
just testing
--This line, and those below, will be ignored--
A    test
"svn-commit.7.tmp" 4L, 72C
written
Adding         test
Authentication realm: <https://svn.ci.uchicago.edu:443> SVN Login
Password for 'iraicu':
Transmitting file data .
Committed revision 1076.
Ioan
Ti Leggett wrote:
> There was a typo in the svn authz file. Try now.
> On Aug 14, 2007, at 7:59 PM, Ioan Raicu wrote:
>> Hi,
>> I just tried again, with a clean SVN checkout on
>> login.ci.uchicago.edu.  I included the date so you can look it up in
>> the logs, if you need to.
>> [iraicu at login container]$ date
>> Tue Aug 14 19:55:43 CDT 2007
>> [iraicu at login container]$ svn status
>> A      hello
>> [iraicu at login container]$ cd ..
>> [iraicu at login falkon]$ svn cleanup
>> [iraicu at login falkon]$ cd container/
>> [iraicu at login container]$ svn ci hello
>> testing
>> A    hello
>> "svn-commit.tmp" 4L, 68C written
>> Adding         hello
>> And then it just hangs there...
>> Can you keep looking into this to see what is wrong?
>> Thanks,
>> Ioan
>> Ioan Raicu wrote:
>>> Hi,
>>> I can't commit to SVN at CI. Here is the output I get from trying to
>>> commit a simple test!
>>> just testing
>>> A    test
>>> "svn-commit.5.tmp" 4L, 72C written
>>> Adding         test
>>> svn: Commit failed (details follow):
>>> svn: CHECKOUT of '/svn/vdl2/!svn/ver/1075/falkon': 401 Authorization
>>> Required (https://svn.ci.uchicago.edu)
>>> svn: Your commit message was left in a temporary file:
>>> svn:    '/home/iraicu/java/svn/falkon/svn-commit.5.tmp'
>>> Thanks,
>>> Ioan
