[Swift-devel] Re: cannot commit to SVN...
Ioan Raicu
iraicu at cs.uchicago.edu
Tue Aug 14 19:59:19 CDT 2007
I just tried again, with a clean SVN checkout on login.ci.uchicago.edu.
I included the date so you can look it up in the logs, if you need to.
[iraicu at login container]$ date
Tue Aug 14 19:55:43 CDT 2007
[iraicu at login container]$ svn status
A hello
[iraicu at login container]$ cd ..
[iraicu at login falkon]$ svn cleanup
[iraicu at login falkon]$ cd container/
[iraicu at login container]$ svn ci hello
testing
--This line, and those below, will be ignored--
A hello
"svn-commit.tmp" 4L, 68C written
Adding hello
And then it just hangs there...
Can you keep looking into this to see what is wrong?
Ioan
Ioan Raicu wrote:
> Hi,
> I can't commit to SVN at CI. Here is the output I get from trying to
> commit a simple test!
> iraicu at viper:~/java/svn/falkon> svn ci test
> just testing
> A test
> "svn-commit.5.tmp" 4L, 72C
> written
> Adding test
> Authentication realm: <https://svn.ci.uchicago.edu:443> SVN Login
> Password for 'iraicu':
> svn: Commit failed (details follow):
> svn: CHECKOUT of '/svn/vdl2/!svn/ver/1075/falkon': 401 Authorization
> Required (https://svn.ci.uchicago.edu)
> svn: Your commit message was left in a temporary file:
> svn: '/home/iraicu/java/svn/falkon/svn-commit.5.tmp'
> Thanks,
> Ioan
