[Swift-devel] Q about MolDyn
    Ioan Raicu
    iraicu at cs.uchicago.edu
    Thu Aug  9 15:01:17 CDT 2007
Is that a problem?  I can certainly expand the two jar files... but I
thought this worked in Yong's install, where I got this new and updated jar!
Mihael Hategan wrote:
> Looks like that jar file contains two other jar files instead of
> directories and class files.
> On Thu, 2007-08-09 at 14:52 -0500, Ioan Raicu wrote:
>> OK, updated this to reflect the new name, still no luck, same errors...
>>> That's because you didn't change the project.properties file. You need
>>> to edit that and replace GenericPortal.jar with whatever the new thing
>>> is.
>>> On Thu, 2007-08-09 at 14:36 -0500, Ioan Raicu wrote:
>>>> Now i am trying to compile the provider-deef, and I fails...  it seems
>>>> that its not finding the stubs I just added... I changed the file name
>>>> from GenericPortal.jar to FalkonStubs.jar.  I need to do anything
>>>> special, like to rebuild the classpath with the new jar name so the
>>>> build can pick it up?
>>>> Ioan
>>>> nefedova at viper:~/cogl/modules/provider-deef> ant distclean
>>>> Buildfile: build.xml
>>>> distclean:
>>>> BUILD SUCCESSFUL
>>>> Total time: 4 seconds
>>>> -Ddist.dir=/home/nefedova/cogl/modules/vdsk/dist/vdsk-0.2-dev/ dist
>>>> dist:
>>>> delete.jar:
>>>>      [echo] [provider-deef]: DELETE.JAR (cog-provider-deef-1.0.jar)
>>>>    [delete] Deleting:
>>>> /home/nefedova/cogl/modules/vdsk/dist/vdsk-0.2-dev/lib/cog-provider-deef-1.0.jar
>>>> compile:
>>>>      [echo] [provider-deef]: COMPILE
>>>>     [mkdir] Created dir: /home/nefedova/cogl/modules/provider-deef/build
>>>>     [javac] Compiling 8 source files to
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:41:
>>>> package org.globus.GenericPortal.stubs.GPService_instance does not exist
>>>>     [javac] import org.globus.GenericPortal.stubs.GPService_instance.*;
>>>>     [javac] ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:42:
>>>>     [javac] import
>>>> org.globus.GenericPortal.stubs.GPService_instance.GPPortType;
>>>>     [javac]                                                          ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:43:
>>>> package org.globus.GenericPortal.stubs.GPService_instance.service does
>>>> not exist
>>>>     [javac] import
>>>> org.globus.GenericPortal.stubs.GPService_instance.service.GPServiceAddressingLocator;
>>>> [javac]        ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:45:
>>>> package org.globus.GenericPortal.stubs.Factory does not exist
>>>>     [javac] import org.globus.GenericPortal.stubs.Factory.CreateResource;
>>>>     [javac]                                               ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:46:
>>>>     [javac] import
>>>> org.globus.GenericPortal.stubs.Factory.CreateResourceResponse;
>>>>     [javac]                                               ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:47:
>>>>     [javac] import org.globus.GenericPortal.stubs.Factory.FactoryPortType;
>>>>     [javac]                                               ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:48:
>>>> package org.globus.GenericPortal.stubs.Factory.service does not exist
>>>>     [javac] import
>>>> org.globus.GenericPortal.stubs.Factory.service.FactoryServiceAddressingLocator;
>>>>     [javac]                                                       ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:50:
>>>> package org.globus.GenericPortal.common does not exist
>>>>     [javac] import org.globus.GenericPortal.common.Notification;
>>>>     [javac]                                        ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:19:
>>>>     [javac]                                               ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:20:
>>>>     [javac] import
>>>>     [javac]                                               ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:21:
>>>>     [javac]                                               ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:22:
>>>>     [javac] import
>>>>     [javac]                                                       ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:24:
>>>>     [javac] import
>>>> org.globus.GenericPortal.stubs.GPService_instance.UserJob;
>>>>     [javac]                                                          ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:25:
>>>>     [javac] import
>>>> org.globus.GenericPortal.stubs.GPService_instance.UserJobResponse;
>>>>     [javac]                                                          ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:26:
>>>>     [javac] import
>>>> org.globus.GenericPortal.stubs.GPService_instance.InitResponse;
>>>>     [javac]                                                          ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:27:
>>>>     [javac] import org.globus.GenericPortal.stubs.GPService_instance.Init;
>>>>     [javac]                                                          ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:28:
>>>>     [javac] import
>>>> org.globus.GenericPortal.stubs.GPService_instance.DeInitResponse;
>>>>     [javac]                                                          ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:29:
>>>>     [javac] import org.globus.GenericPortal.stubs.GPService_instance.DeInit;
>>>>     [javac]                                                          ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:30:
>>>>     [javac] import
>>>>     [javac]                                                          ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:31:
>>>>     [javac] import
>>>> org.globus.GenericPortal.stubs.GPService_instance.Executable;
>>>>     [javac]                                                          ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:32:
>>>> not exist
>>>>     [javac] import
>>>> [javac]        ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:35:
>>>>     [javac]                                        ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:48:
>>>> cannot resolve symbol
>>>>     [javac] symbol  : class FactoryPortType
>>>>     [javac] location: class
>>>> org.globus.cog.abstraction.impl.execution.deef.ResourcePool
>>>>     [javac]     private FactoryPortType gpFactory = null;
>>>>     [javac]             ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:54:
>>>>     [javac] symbol  : class Notification
>>>>     [javac]     private Notification userNot = null;
>>>>     [javac]             ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/NotificationThread.java:16:
>>>>     [javac]                                        ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/NotificationThread.java:22:
>>>> org.globus.cog.abstraction.impl.execution.deef.NotificationThread
>>>>     [javac]             ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/NotificationThread.java:31:
>>>>     [javac]     public NotificationThread(Map tasks, Notification
>>>> userNot, List completedQueue){
>>>>     [javac]                                          ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:16:
>>>>     [javac] import
>>>>     [javac]                                                          ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:17:
>>>>     [javac] import
>>>>     [javac]                                                          ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:18:
>>>>     [javac] import
>>>>     [javac]                                                          ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:19:
>>>>     [javac] import
>>>>     [javac]                                                          ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:26:
>>>>     [javac] symbol  : class Executable
>>>> org.globus.cog.abstraction.impl.execution.deef.SubmissionThread
>>>>     [javac]     private Executable[] execs = null;
>>>>     [javac]             ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:27:
>>>>     [javac] symbol  : class UserJob
>>>>     [javac]     private UserJob job = null;
>>>>     [javac]             ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:97:
>>>>     [javac]     public void setStatus (Executable execs[]) {
>>>>     [javac]                            ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/StatusThread.java:16:
>>>>     [javac] import
>>>>     [javac]                                                          ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/StatusThread.java:17:
>>>>     [javac] import
>>>>     [javac]                                                          ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/StatusThread.java:18:
>>>>     [javac] import
>>>>     [javac]                                                          ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/StatusThread.java:19:
>>>>     [javac] import
>>>>     [javac]                                                          ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:59:
>>>>     [javac]             ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:60:
>>>>     [javac]             ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:174:
>>>>     [javac] symbol  : class GPPortType
>>>>     [javac]     public GPPortType getNextResourcePort() {
>>>>     [javac]            ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:184:
>>>>     [javac]     public void submit(Task task, Executable exec) {
>>>>     [javac]                                   ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:210:
>>>>     [javac]     public static String getMachNamePort(Notification userNot){
>>>>     [javac]                                          ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:229:
>>>>     [javac]     public Executable removeFirstExec() throws
>>>> NoSuchElementException {
>>>>     [javac]            ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:63:
>>>> org.globus.cog.abstraction.impl.execution.deef.JobSubmissionTaskHandler
>>>>     [javac]     private GPPortType gGP = null;
>>>>     [javac]             ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:206:
>>>>     [javac]     private Executable prepareSpecification(JobSpecification
>>>> spec)
>>>>     [javac]             ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:157:
>>>>     [javac]     Executable job = prepareSpecification(spec);
>>>>     [javac]         ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:211:
>>>>     [javac]     Executable exec = new Executable();
>>>>     [javac]         ^
>>>>     [javac]
>>>>     [javac]                               ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:289:
>>>>     [javac] symbol  : class DeInit
>>>>     [javac]             DeInit deInit = new DeInit();
>>>>     [javac]             ^
>>>>     [javac]
>>>>     [javac]                                 ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:291:
>>>>     [javac] symbol  : class DeInitResponse
>>>>     [javac]             DeInitResponse dr = this.gGP.deInit(deInit);
>>>>     [javac]             ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:69:
>>>>     [javac]         rp.userNot = new Notification(SO_TIMEOUT);
>>>>     [javac]                              ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:110:
>>>>     [javac] symbol  : class FactoryServiceAddressingLocator
>>>>     [javac]         FactoryServiceAddressingLocator factoryLocator = new
>>>> FactoryServiceAddressingLocator();
>>>>     [javac]             ^
>>>>     [javac]
>>>> [javac]        ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:130:
>>>>     [javac] symbol  : class CreateResourceResponse
>>>>     [javac]             CreateResourceResponse createResponse = gpFactory
>>>>     [javac]                 ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:131:
>>>>     [javac]                 .createResource(new CreateResource());
>>>>     [javac]                                         ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:137:
>>>>     [javac] symbol  : class GPServiceAddressingLocator
>>>>     [javac]             GPServiceAddressingLocator instanceLocator = new
>>>> GPServiceAddressingLocator();
>>>>     [javac]                 ^
>>>>     [javac]
>>>> [javac]        ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:138:
>>>>     [javac]             GPPortType gGP =
>>>> instanceLocator.getGPPortTypePort(instanceEPR);
>>>>     [javac]                 ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:140:
>>>>     [javac] symbol  : class Init
>>>>     [javac]             Init initMsg = new Init();
>>>>     [javac]                 ^
>>>>     [javac]
>>>>     [javac]                                    ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:142:
>>>>     [javac] symbol  : class InitResponse
>>>>     [javac]             InitResponse ir = gGP.init(initMsg);
>>>>     [javac]                 ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:177:
>>>>     [javac]     return (GPPortType) gptPool.get(next);
>>>>     [javac]                 ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:230:
>>>>     [javac]     return (Executable) execQueue.remove(0);
>>>>     [javac]                 ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:247:
>>>>     [javac]             ^
>>>>     [javac]
>>>>     [javac]                                 ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:252:
>>>>     [javac]             GPPortType gGP = (GPPortType)gptPool.get(i);
>>>>     [javac]                 ^
>>>>     [javac]
>>>>     [javac]                                   ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:254:
>>>>     [javac]             DeInitResponse dr = gGP.deInit(deInit);
>>>>     [javac]                 ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:44:
>>>>     [javac]     job = new UserJob();
>>>>     [javac]                   ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:67:
>>>>     [javac]                 execs = new Executable[num_execs];
>>>>     [javac]                                 ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:74:
>>>>     [javac]                 GPPortType gGP = rp.getNextResourcePort();
>>>>     [javac]                     ^
>>>>     [javac]
>>>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:75:
>>>>     [javac] symbol  : class UserJobResponse
>>>>     [javac]                 UserJobResponse jobRP = gGP.userJob(job);
>>>>     [javac]                     ^
>>>>     [javac] Note:
>>>> uses or overrides a deprecated API.
>>>>     [javac] Note: Recompile with -deprecation for details.
>>>>     [javac] 74 errors
>>>> BUILD FAILED
>>>> /home/nefedova/cogl/modules/provider-deef/build.xml:56: The following
>>>> error occurred while executing this line:
>>>> /home/nefedova/cogl/mbuild.xml:463: The following error occurred while
>>>> /home/nefedova/cogl/mbuild.xml:227: Compile failed; see the compiler
>>>> error output for details.
>>>> Total time: 23 seconds
>>>> Ioan Raicu wrote:
>>>>> Right!
>>>>> Ben Clifford wrote:
>>>>>> On Thu, 9 Aug 2007, Ioan Raicu wrote:
>>>>>>> Now, I renamed the jar to FalkonStubs.jar and it can be found in
>>>>>>> /home/nefedova/cogl/modules/provider-deef/lib/
>>>>>> you need to 'svn rm WhateverTheOldJarWas.jar' and 'svn add
>>>>>> FalkonStubs.jar' before you commit.
>>>>> _______________________________________________
>>>>> Swift-devel mailing list
>>>>> Swift-devel at ci.uchicago.edu
>>>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
