[Swift-devel] Q about MolDyn
    Ben Clifford
    benc at hawaga.org.uk
    Thu Aug  9 15:19:01 CDT 2007
I suspect the new and updated jar! didn't work but that you old old and
not updated jars around in your install too because you weren't running
distclean enough.
On Thu, 9 Aug 2007, Ioan Raicu wrote:
> Is that a problem?  I can certainly expand the two jar files... but I thought
> this worked in Yong's install, where I got this new and updated jar!
> Mihael Hategan wrote:
> > Looks like that jar file contains two other jar files instead of
> > directories and class files.
> > On Thu, 2007-08-09 at 14:52 -0500, Ioan Raicu wrote:
> > > OK, updated this to reflect the new name, still no luck, same errors...
> > > > That's because you didn't change the project.properties file. You need
> > > > to edit that and replace GenericPortal.jar with whatever the new thing
> > > > is.
> > > > On Thu, 2007-08-09 at 14:36 -0500, Ioan Raicu wrote:
> > > > > Now i am trying to compile the provider-deef, and I fails...  it seems
> > > > > that its not finding the stubs I just added... I changed the file name
> > > > > from GenericPortal.jar to FalkonStubs.jar.  I need to do anything
> > > > > special, like to rebuild the classpath with the new jar name so the
> > > > > build can pick it up?
> > > > > Ioan
> > > > > nefedova at viper:~/cogl/modules/provider-deef> ant distclean
> > > > > Buildfile: build.xml
> > > > > distclean:
> > > > > BUILD SUCCESSFUL
> > > > > Total time: 4 seconds
> > > > > -Ddist.dir=/home/nefedova/cogl/modules/vdsk/dist/vdsk-0.2-dev/ dist
> > > > > dist:
> > > > > delete.jar:
> > > > >      [echo] [provider-deef]: DELETE.JAR (cog-provider-deef-1.0.jar)
> > > > >    [delete] Deleting:
> > > > > /home/nefedova/cogl/modules/vdsk/dist/vdsk-0.2-dev/lib/cog-provider-deef-1.0.jar
> > > > > compile:
> > > > >      [echo] [provider-deef]: COMPILE
> > > > >     [mkdir] Created dir:
> > > > > /home/nefedova/cogl/modules/provider-deef/build
> > > > >     [javac] Compiling 8 source files to
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:41:
> > > > > package org.globus.GenericPortal.stubs.GPService_instance does not
> > > > > exist
> > > > >     [javac] import
> > > > > org.globus.GenericPortal.stubs.GPService_instance.*;
> > > > >     [javac] ^
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:42:
> > > > > exist
> > > > >     [javac] import
> > > > > org.globus.GenericPortal.stubs.GPService_instance.GPPortType;
> > > > >     [javac]                                                          ^
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:43:
> > > > > package org.globus.GenericPortal.stubs.GPService_instance.service does
> > > > > not exist
> > > > >     [javac] import
> > > > > org.globus.GenericPortal.stubs.GPService_instance.service.GPServiceAddressingLocator;
> > > > >     [javac]
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:45:
> > > > > package org.globus.GenericPortal.stubs.Factory does not exist
> > > > >     [javac] import
> > > > > org.globus.GenericPortal.stubs.Factory.CreateResource;
> > > > >     [javac]                                               ^
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:46:
> > > > >     [javac] import
> > > > > org.globus.GenericPortal.stubs.Factory.CreateResourceResponse;
> > > > >     [javac]                                               ^
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:47:
> > > > >     [javac] import
> > > > > org.globus.GenericPortal.stubs.Factory.FactoryPortType;
> > > > >     [javac]                                               ^
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:48:
> > > > > package org.globus.GenericPortal.stubs.Factory.service does not exist
> > > > >     [javac] import
> > > > > org.globus.GenericPortal.stubs.Factory.service.FactoryServiceAddressingLocator;
> > > > >     [javac]                                                       ^
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:50:
> > > > > package org.globus.GenericPortal.common does not exist
> > > > >     [javac] import org.globus.GenericPortal.common.Notification;
> > > > >     [javac]                                        ^
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:19:
> > > > >     [javac] import
> > > > >     [javac]                                               ^
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:20:
> > > > >     [javac] import
> > > > >     [javac]                                               ^
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:21:
> > > > >     [javac] import
> > > > >     [javac]                                               ^
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:22:
> > > > >     [javac] import
> > > > >     [javac]                                                       ^
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:24:
> > > > > exist
> > > > >     [javac] import
> > > > > org.globus.GenericPortal.stubs.GPService_instance.UserJob;
> > > > >     [javac]                                                          ^
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:25:
> > > > > exist
> > > > >     [javac] import
> > > > > org.globus.GenericPortal.stubs.GPService_instance.UserJobResponse;
> > > > >     [javac]                                                          ^
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:26:
> > > > > exist
> > > > >     [javac] import
> > > > > org.globus.GenericPortal.stubs.GPService_instance.InitResponse;
> > > > >     [javac]                                                          ^
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:27:
> > > > > exist
> > > > >     [javac] import
> > > > > org.globus.GenericPortal.stubs.GPService_instance.Init;
> > > > >     [javac]                                                          ^
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:28:
> > > > > exist
> > > > >     [javac] import
> > > > > org.globus.GenericPortal.stubs.GPService_instance.DeInitResponse;
> > > > >     [javac]                                                          ^
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:29:
> > > > > exist
> > > > >     [javac] import
> > > > > org.globus.GenericPortal.stubs.GPService_instance.DeInit;
> > > > >     [javac]                                                          ^
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:30:
> > > > > exist
> > > > >     [javac] import
> > > > >     [javac]                                                          ^
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:31:
> > > > > exist
> > > > >     [javac] import
> > > > > org.globus.GenericPortal.stubs.GPService_instance.Executable;
> > > > >     [javac]                                                          ^
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:32:
> > > > > not exist
> > > > >     [javac] import
> > > > >     [javac]
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:35:
> > > > >     [javac]                                        ^
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:48:
> > > > > cannot resolve symbol
> > > > >     [javac] symbol  : class FactoryPortType
> > > > >     [javac] location: class
> > > > > org.globus.cog.abstraction.impl.execution.deef.ResourcePool
> > > > >     [javac]     private FactoryPortType gpFactory = null;
> > > > >     [javac]             ^
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:54:
> > > > >     [javac] symbol  : class Notification
> > > > >     [javac]     private Notification userNot = null;
> > > > >     [javac]             ^
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/NotificationThread.java:16:
> > > > >     [javac]                                        ^
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/NotificationThread.java:22:
> > > > > org.globus.cog.abstraction.impl.execution.deef.NotificationThread
> > > > >     [javac]             ^
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/NotificationThread.java:31:
> > > > >     [javac]     public NotificationThread(Map tasks, Notification
> > > > > userNot, List completedQueue){
> > > > >     [javac]                                          ^
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:16:
> > > > > exist
> > > > >     [javac] import
> > > > >     [javac]                                                          ^
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:17:
> > > > > exist
> > > > >     [javac] import
> > > > >     [javac]                                                          ^
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:18:
> > > > > exist
> > > > >     [javac] import
> > > > >     [javac]                                                          ^
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:19:
> > > > > exist
> > > > >     [javac] import
> > > > >     [javac]                                                          ^
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:26:
> > > > >     [javac] symbol  : class Executable
> > > > > org.globus.cog.abstraction.impl.execution.deef.SubmissionThread
> > > > >     [javac]     private Executable[] execs = null;
> > > > >     [javac]             ^
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:27:
> > > > >     [javac] symbol  : class UserJob
> > > > >     [javac]     private UserJob job = null;
> > > > >     [javac]             ^
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:97:
> > > > >     [javac]     public void setStatus (Executable execs[]) {
> > > > >     [javac]                            ^
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/StatusThread.java:16:
> > > > > exist
> > > > >     [javac] import
> > > > >     [javac]                                                          ^
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/StatusThread.java:17:
> > > > > exist
> > > > >     [javac] import
> > > > >     [javac]                                                          ^
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/StatusThread.java:18:
> > > > > exist
> > > > >     [javac] import
> > > > >     [javac]                                                          ^
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/StatusThread.java:19:
> > > > > exist
> > > > >     [javac] import
> > > > >     [javac]                                                          ^
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:59:
> > > > >     [javac]             ^
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:60:
> > > > >     [javac]             ^
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:174:
> > > > >     [javac] symbol  : class GPPortType
> > > > >     [javac]     public GPPortType getNextResourcePort() {
> > > > >     [javac]            ^
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:184:
> > > > >     [javac]     public void submit(Task task, Executable exec) {
> > > > >     [javac]                                   ^
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:210:
> > > > >     [javac]     public static String getMachNamePort(Notification
> > > > > userNot){
> > > > >     [javac]                                          ^
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:229:
> > > > >     [javac]     public Executable removeFirstExec() throws
> > > > > NoSuchElementException {
> > > > >     [javac]            ^
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:63:
> > > > > org.globus.cog.abstraction.impl.execution.deef.JobSubmissionTaskHandler
> > > > >     [javac]     private GPPortType gGP = null;
> > > > >     [javac]             ^
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:206:
> > > > > prepareSpecification(JobSpecification spec)
> > > > >     [javac]             ^
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:157:
> > > > >     [javac]     Executable job = prepareSpecification(spec);
> > > > >     [javac]         ^
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:211:
> > > > >     [javac]     Executable exec = new Executable();
> > > > >     [javac]         ^
> > > > >     [javac]
> > > > >     [javac]                               ^
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:289:
> > > > >     [javac] symbol  : class DeInit
> > > > >     [javac]             DeInit deInit = new DeInit();
> > > > >     [javac]             ^
> > > > >     [javac]
> > > > >     [javac]                                 ^
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:291:
> > > > >     [javac] symbol  : class DeInitResponse
> > > > >     [javac]             DeInitResponse dr = this.gGP.deInit(deInit);
> > > > >     [javac]             ^
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:69:
> > > > >     [javac]         rp.userNot = new Notification(SO_TIMEOUT);
> > > > >     [javac]                              ^
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:110:
> > > > >     [javac] symbol  : class FactoryServiceAddressingLocator
> > > > >     [javac]         FactoryServiceAddressingLocator factoryLocator =
> > > > > new FactoryServiceAddressingLocator();
> > > > >     [javac]             ^
> > > > >     [javac]
> > > > >     [javac]
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:130:
> > > > >     [javac] symbol  : class CreateResourceResponse
> > > > >     [javac]             CreateResourceResponse createResponse =
> > > > > gpFactory
> > > > >     [javac]                 ^
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:131:
> > > > >     [javac]                 .createResource(new CreateResource());
> > > > >     [javac]                                         ^
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:137:
> > > > >     [javac] symbol  : class GPServiceAddressingLocator
> > > > >     [javac]             GPServiceAddressingLocator instanceLocator =
> > > > > new GPServiceAddressingLocator();
> > > > >     [javac]                 ^
> > > > >     [javac]
> > > > >     [javac]
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:138:
> > > > >     [javac]             GPPortType gGP =
> > > > > instanceLocator.getGPPortTypePort(instanceEPR);
> > > > >     [javac]                 ^
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:140:
> > > > >     [javac] symbol  : class Init
> > > > >     [javac]             Init initMsg = new Init();
> > > > >     [javac]                 ^
> > > > >     [javac]
> > > > >     [javac]                                    ^
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:142:
> > > > >     [javac] symbol  : class InitResponse
> > > > >     [javac]             InitResponse ir = gGP.init(initMsg);
> > > > >     [javac]                 ^
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:177:
> > > > >     [javac]     return (GPPortType) gptPool.get(next);
> > > > >     [javac]                 ^
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:230:
> > > > >     [javac]     return (Executable) execQueue.remove(0);
> > > > >     [javac]                 ^
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:247:
> > > > >     [javac]             ^
> > > > >     [javac]
> > > > >     [javac]                                 ^
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:252:
> > > > >     [javac]             GPPortType gGP = (GPPortType)gptPool.get(i);
> > > > >     [javac]                 ^
> > > > >     [javac]
> > > > >     [javac]                                   ^
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:254:
> > > > >     [javac]             DeInitResponse dr = gGP.deInit(deInit);
> > > > >     [javac]                 ^
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:44:
> > > > >     [javac]     job = new UserJob();
> > > > >     [javac]                   ^
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:67:
> > > > >     [javac]                 execs = new Executable[num_execs];
> > > > >     [javac]                                 ^
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:74:
> > > > >     [javac]                 GPPortType gGP = rp.getNextResourcePort();
> > > > >     [javac]                     ^
> > > > >     [javac]
> > > > > /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:75:
> > > > >     [javac] symbol  : class UserJobResponse
> > > > >     [javac]                 UserJobResponse jobRP = gGP.userJob(job);
> > > > >     [javac]                     ^
> > > > >     [javac] Note:
> > > > > uses or overrides a deprecated API.
> > > > >     [javac] Note: Recompile with -deprecation for details.
> > > > >     [javac] 74 errors
> > > > > BUILD FAILED
> > > > > /home/nefedova/cogl/modules/provider-deef/build.xml:56: The following
> > > > > error occurred while executing this line:
> > > > > /home/nefedova/cogl/mbuild.xml:463: The following error occurred while
> > > > > /home/nefedova/cogl/mbuild.xml:227: Compile failed; see the compiler
> > > > > error output for details.
> > > > > Total time: 23 seconds
> > > > > Ioan Raicu wrote:
> > > > > > Right!
> > > > > > > > Now, I renamed the jar to FalkonStubs.jar and it can be found in
> > > > > > > > /home/nefedova/cogl/modules/provider-deef/lib/
> > > > > > > you need to 'svn rm WhateverTheOldJarWas.jar' and 'svn add
> > > > > > > FalkonStubs.jar' before you commit.
> > > > > > _______________________________________________
> > > > > > Swift-devel mailing list
> > > > > > Swift-devel at ci.uchicago.edu
> > > > > > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
