[Swift-devel] Q about MolDyn
    Mihael Hategan
    hategan at mcs.anl.gov
    Thu Aug  9 15:00:19 CDT 2007
Looks like that jar file contains two other jar files instead of
directories and class files.
On Thu, 2007-08-09 at 14:52 -0500, Ioan Raicu wrote:
> OK, updated this to reflect the new name, still no luck, same errors...
> Mihael Hategan wrote:
> > That's because you didn't change the project.properties file. You need
> > to edit that and replace GenericPortal.jar with whatever the new thing
> > is.
> > On Thu, 2007-08-09 at 14:36 -0500, Ioan Raicu wrote:
> >> Now i am trying to compile the provider-deef, and I fails...  it seems
> >> that its not finding the stubs I just added... I changed the file name
> >> from GenericPortal.jar to FalkonStubs.jar.  I need to do anything
> >> special, like to rebuild the classpath with the new jar name so the
> >> build can pick it up?
> >> Ioan
> >> nefedova at viper:~/cogl/modules/provider-deef> ant distclean
> >> Buildfile: build.xml
> >> distclean:
> >> BUILD SUCCESSFUL
> >> Total time: 4 seconds
> >> -Ddist.dir=/home/nefedova/cogl/modules/vdsk/dist/vdsk-0.2-dev/ dist
> >> dist:
> >> delete.jar:
> >>      [echo] [provider-deef]: DELETE.JAR (cog-provider-deef-1.0.jar)
> >>    [delete] Deleting:
> >> /home/nefedova/cogl/modules/vdsk/dist/vdsk-0.2-dev/lib/cog-provider-deef-1.0.jar
> >> compile:
> >>      [echo] [provider-deef]: COMPILE
> >>     [mkdir] Created dir: /home/nefedova/cogl/modules/provider-deef/build
> >>     [javac] Compiling 8 source files to
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:41:
> >> package org.globus.GenericPortal.stubs.GPService_instance does not exist
> >>     [javac] import org.globus.GenericPortal.stubs.GPService_instance.*;
> >>     [javac] ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:42:
> >>     [javac] import
> >> org.globus.GenericPortal.stubs.GPService_instance.GPPortType;
> >>     [javac]                                                          ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:43:
> >> package org.globus.GenericPortal.stubs.GPService_instance.service does
> >> not exist
> >>     [javac] import
> >> org.globus.GenericPortal.stubs.GPService_instance.service.GPServiceAddressingLocator;
> >> [javac]        ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:45:
> >> package org.globus.GenericPortal.stubs.Factory does not exist
> >>     [javac] import org.globus.GenericPortal.stubs.Factory.CreateResource;
> >>     [javac]                                               ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:46:
> >>     [javac] import
> >> org.globus.GenericPortal.stubs.Factory.CreateResourceResponse;
> >>     [javac]                                               ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:47:
> >>     [javac] import org.globus.GenericPortal.stubs.Factory.FactoryPortType;
> >>     [javac]                                               ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:48:
> >> package org.globus.GenericPortal.stubs.Factory.service does not exist
> >>     [javac] import
> >> org.globus.GenericPortal.stubs.Factory.service.FactoryServiceAddressingLocator;
> >>     [javac]                                                       ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:50:
> >> package org.globus.GenericPortal.common does not exist
> >>     [javac] import org.globus.GenericPortal.common.Notification;
> >>     [javac]                                        ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:19:
> >>     [javac]                                               ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:20:
> >>     [javac] import
> >>     [javac]                                               ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:21:
> >>     [javac]                                               ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:22:
> >>     [javac] import
> >>     [javac]                                                       ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:24:
> >>     [javac] import
> >> org.globus.GenericPortal.stubs.GPService_instance.UserJob;
> >>     [javac]                                                          ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:25:
> >>     [javac] import
> >> org.globus.GenericPortal.stubs.GPService_instance.UserJobResponse;
> >>     [javac]                                                          ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:26:
> >>     [javac] import
> >> org.globus.GenericPortal.stubs.GPService_instance.InitResponse;
> >>     [javac]                                                          ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:27:
> >>     [javac] import org.globus.GenericPortal.stubs.GPService_instance.Init;
> >>     [javac]                                                          ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:28:
> >>     [javac] import
> >> org.globus.GenericPortal.stubs.GPService_instance.DeInitResponse;
> >>     [javac]                                                          ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:29:
> >>     [javac] import org.globus.GenericPortal.stubs.GPService_instance.DeInit;
> >>     [javac]                                                          ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:30:
> >>     [javac] import
> >>     [javac]                                                          ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:31:
> >>     [javac] import
> >> org.globus.GenericPortal.stubs.GPService_instance.Executable;
> >>     [javac]                                                          ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:32:
> >> not exist
> >>     [javac] import
> >> [javac]        ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:35:
> >>     [javac]                                        ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:48:
> >> cannot resolve symbol
> >>     [javac] symbol  : class FactoryPortType
> >>     [javac] location: class
> >> org.globus.cog.abstraction.impl.execution.deef.ResourcePool
> >>     [javac]     private FactoryPortType gpFactory = null;
> >>     [javac]             ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:54:
> >>     [javac] symbol  : class Notification
> >>     [javac]     private Notification userNot = null;
> >>     [javac]             ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/NotificationThread.java:16:
> >>     [javac]                                        ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/NotificationThread.java:22:
> >> org.globus.cog.abstraction.impl.execution.deef.NotificationThread
> >>     [javac]             ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/NotificationThread.java:31:
> >>     [javac]     public NotificationThread(Map tasks, Notification
> >> userNot, List completedQueue){
> >>     [javac]                                          ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:16:
> >>     [javac] import
> >>     [javac]                                                          ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:17:
> >>     [javac] import
> >>     [javac]                                                          ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:18:
> >>     [javac] import
> >>     [javac]                                                          ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:19:
> >>     [javac] import
> >>     [javac]                                                          ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:26:
> >>     [javac] symbol  : class Executable
> >> org.globus.cog.abstraction.impl.execution.deef.SubmissionThread
> >>     [javac]     private Executable[] execs = null;
> >>     [javac]             ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:27:
> >>     [javac] symbol  : class UserJob
> >>     [javac]     private UserJob job = null;
> >>     [javac]             ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:97:
> >>     [javac]     public void setStatus (Executable execs[]) {
> >>     [javac]                            ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/StatusThread.java:16:
> >>     [javac] import
> >>     [javac]                                                          ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/StatusThread.java:17:
> >>     [javac] import
> >>     [javac]                                                          ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/StatusThread.java:18:
> >>     [javac] import
> >>     [javac]                                                          ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/StatusThread.java:19:
> >>     [javac] import
> >>     [javac]                                                          ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:59:
> >>     [javac]             ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:60:
> >>     [javac]             ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:174:
> >>     [javac] symbol  : class GPPortType
> >>     [javac]     public GPPortType getNextResourcePort() {
> >>     [javac]            ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:184:
> >>     [javac]     public void submit(Task task, Executable exec) {
> >>     [javac]                                   ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:210:
> >>     [javac]     public static String getMachNamePort(Notification userNot){
> >>     [javac]                                          ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:229:
> >>     [javac]     public Executable removeFirstExec() throws
> >> NoSuchElementException {
> >>     [javac]            ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:63:
> >> org.globus.cog.abstraction.impl.execution.deef.JobSubmissionTaskHandler
> >>     [javac]     private GPPortType gGP = null;
> >>     [javac]             ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:206:
> >>     [javac]     private Executable prepareSpecification(JobSpecification
> >> spec)
> >>     [javac]             ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:157:
> >>     [javac]     Executable job = prepareSpecification(spec);
> >>     [javac]         ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:211:
> >>     [javac]     Executable exec = new Executable();
> >>     [javac]         ^
> >>     [javac]
> >>     [javac]                               ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:289:
> >>     [javac] symbol  : class DeInit
> >>     [javac]             DeInit deInit = new DeInit();
> >>     [javac]             ^
> >>     [javac]
> >>     [javac]                                 ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:291:
> >>     [javac] symbol  : class DeInitResponse
> >>     [javac]             DeInitResponse dr = this.gGP.deInit(deInit);
> >>     [javac]             ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:69:
> >>     [javac]         rp.userNot = new Notification(SO_TIMEOUT);
> >>     [javac]                              ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:110:
> >>     [javac] symbol  : class FactoryServiceAddressingLocator
> >>     [javac]         FactoryServiceAddressingLocator factoryLocator = new
> >> FactoryServiceAddressingLocator();
> >>     [javac]             ^
> >>     [javac]
> >> [javac]        ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:130:
> >>     [javac] symbol  : class CreateResourceResponse
> >>     [javac]             CreateResourceResponse createResponse = gpFactory
> >>     [javac]                 ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:131:
> >>     [javac]                 .createResource(new CreateResource());
> >>     [javac]                                         ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:137:
> >>     [javac] symbol  : class GPServiceAddressingLocator
> >>     [javac]             GPServiceAddressingLocator instanceLocator = new
> >> GPServiceAddressingLocator();
> >>     [javac]                 ^
> >>     [javac]
> >> [javac]        ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:138:
> >>     [javac]             GPPortType gGP =
> >> instanceLocator.getGPPortTypePort(instanceEPR);
> >>     [javac]                 ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:140:
> >>     [javac] symbol  : class Init
> >>     [javac]             Init initMsg = new Init();
> >>     [javac]                 ^
> >>     [javac]
> >>     [javac]                                    ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:142:
> >>     [javac] symbol  : class InitResponse
> >>     [javac]             InitResponse ir = gGP.init(initMsg);
> >>     [javac]                 ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:177:
> >>     [javac]     return (GPPortType) gptPool.get(next);
> >>     [javac]                 ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:230:
> >>     [javac]     return (Executable) execQueue.remove(0);
> >>     [javac]                 ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:247:
> >>     [javac]             ^
> >>     [javac]
> >>     [javac]                                 ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:252:
> >>     [javac]             GPPortType gGP = (GPPortType)gptPool.get(i);
> >>     [javac]                 ^
> >>     [javac]
> >>     [javac]                                   ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:254:
> >>     [javac]             DeInitResponse dr = gGP.deInit(deInit);
> >>     [javac]                 ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:44:
> >>     [javac]     job = new UserJob();
> >>     [javac]                   ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:67:
> >>     [javac]                 execs = new Executable[num_execs];
> >>     [javac]                                 ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:74:
> >>     [javac]                 GPPortType gGP = rp.getNextResourcePort();
> >>     [javac]                     ^
> >>     [javac]
> >> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:75:
> >>     [javac] symbol  : class UserJobResponse
> >>     [javac]                 UserJobResponse jobRP = gGP.userJob(job);
> >>     [javac]                     ^
> >>     [javac] Note:
> >> uses or overrides a deprecated API.
> >>     [javac] Note: Recompile with -deprecation for details.
> >>     [javac] 74 errors
> >> BUILD FAILED
> >> /home/nefedova/cogl/modules/provider-deef/build.xml:56: The following
> >> error occurred while executing this line:
> >> /home/nefedova/cogl/mbuild.xml:463: The following error occurred while
> >> /home/nefedova/cogl/mbuild.xml:227: Compile failed; see the compiler
> >> error output for details.
> >> Total time: 23 seconds
> >> Ioan Raicu wrote:
> >>> Right!
> >>> Ben Clifford wrote:
> >>>> On Thu, 9 Aug 2007, Ioan Raicu wrote:
> >>>>> Now, I renamed the jar to FalkonStubs.jar and it can be found in
> >>>>> /home/nefedova/cogl/modules/provider-deef/lib/
> >>>> you need to 'svn rm WhateverTheOldJarWas.jar' and 'svn add
> >>>> FalkonStubs.jar' before you commit.
> >>> _______________________________________________
> >>> Swift-devel mailing list
> >>> Swift-devel at ci.uchicago.edu
> >>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
