[Swift-devel] Q about MolDyn
    Ioan Raicu
    iraicu at cs.uchicago.edu
    Thu Aug  9 14:52:22 CDT 2007
OK, updated this to reflect the new name, still no luck, same errors...
Mihael Hategan wrote:
> That's because you didn't change the project.properties file. You need
> to edit that and replace GenericPortal.jar with whatever the new thing
> is.
> On Thu, 2007-08-09 at 14:36 -0500, Ioan Raicu wrote:
>> Now i am trying to compile the provider-deef, and I fails...  it seems
>> that its not finding the stubs I just added... I changed the file name
>> from GenericPortal.jar to FalkonStubs.jar.  I need to do anything
>> special, like to rebuild the classpath with the new jar name so the
>> build can pick it up?
>> Ioan
>> nefedova at viper:~/cogl/modules/provider-deef> ant distclean
>> Buildfile: build.xml
>> distclean:
>> BUILD SUCCESSFUL
>> Total time: 4 seconds
>> -Ddist.dir=/home/nefedova/cogl/modules/vdsk/dist/vdsk-0.2-dev/ dist
>> dist:
>> delete.jar:
>>      [echo] [provider-deef]: DELETE.JAR (cog-provider-deef-1.0.jar)
>>    [delete] Deleting:
>> /home/nefedova/cogl/modules/vdsk/dist/vdsk-0.2-dev/lib/cog-provider-deef-1.0.jar
>> compile:
>>      [echo] [provider-deef]: COMPILE
>>     [mkdir] Created dir: /home/nefedova/cogl/modules/provider-deef/build
>>     [javac] Compiling 8 source files to
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:41:
>> package org.globus.GenericPortal.stubs.GPService_instance does not exist
>>     [javac] import org.globus.GenericPortal.stubs.GPService_instance.*;
>>     [javac] ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:42:
>>     [javac] import
>> org.globus.GenericPortal.stubs.GPService_instance.GPPortType;
>>     [javac]                                                          ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:43:
>> package org.globus.GenericPortal.stubs.GPService_instance.service does
>> not exist
>>     [javac] import
>> org.globus.GenericPortal.stubs.GPService_instance.service.GPServiceAddressingLocator;
>> [javac]        ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:45:
>> package org.globus.GenericPortal.stubs.Factory does not exist
>>     [javac] import org.globus.GenericPortal.stubs.Factory.CreateResource;
>>     [javac]                                               ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:46:
>>     [javac] import
>> org.globus.GenericPortal.stubs.Factory.CreateResourceResponse;
>>     [javac]                                               ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:47:
>>     [javac] import org.globus.GenericPortal.stubs.Factory.FactoryPortType;
>>     [javac]                                               ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:48:
>> package org.globus.GenericPortal.stubs.Factory.service does not exist
>>     [javac] import
>> org.globus.GenericPortal.stubs.Factory.service.FactoryServiceAddressingLocator;
>>     [javac]                                                       ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:50:
>> package org.globus.GenericPortal.common does not exist
>>     [javac] import org.globus.GenericPortal.common.Notification;
>>     [javac]                                        ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:19:
>>     [javac]                                               ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:20:
>>     [javac] import
>>     [javac]                                               ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:21:
>>     [javac]                                               ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:22:
>>     [javac] import
>>     [javac]                                                       ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:24:
>>     [javac] import
>> org.globus.GenericPortal.stubs.GPService_instance.UserJob;
>>     [javac]                                                          ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:25:
>>     [javac] import
>> org.globus.GenericPortal.stubs.GPService_instance.UserJobResponse;
>>     [javac]                                                          ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:26:
>>     [javac] import
>> org.globus.GenericPortal.stubs.GPService_instance.InitResponse;
>>     [javac]                                                          ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:27:
>>     [javac] import org.globus.GenericPortal.stubs.GPService_instance.Init;
>>     [javac]                                                          ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:28:
>>     [javac] import
>> org.globus.GenericPortal.stubs.GPService_instance.DeInitResponse;
>>     [javac]                                                          ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:29:
>>     [javac] import org.globus.GenericPortal.stubs.GPService_instance.DeInit;
>>     [javac]                                                          ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:30:
>>     [javac] import
>>     [javac]                                                          ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:31:
>>     [javac] import
>> org.globus.GenericPortal.stubs.GPService_instance.Executable;
>>     [javac]                                                          ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:32:
>> not exist
>>     [javac] import
>> [javac]        ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:35:
>>     [javac]                                        ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:48:
>> cannot resolve symbol
>>     [javac] symbol  : class FactoryPortType
>>     [javac] location: class
>> org.globus.cog.abstraction.impl.execution.deef.ResourcePool
>>     [javac]     private FactoryPortType gpFactory = null;
>>     [javac]             ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:54:
>>     [javac] symbol  : class Notification
>>     [javac]     private Notification userNot = null;
>>     [javac]             ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/NotificationThread.java:16:
>>     [javac]                                        ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/NotificationThread.java:22:
>> org.globus.cog.abstraction.impl.execution.deef.NotificationThread
>>     [javac]             ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/NotificationThread.java:31:
>>     [javac]     public NotificationThread(Map tasks, Notification
>> userNot, List completedQueue){
>>     [javac]                                          ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:16:
>>     [javac] import
>>     [javac]                                                          ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:17:
>>     [javac] import
>>     [javac]                                                          ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:18:
>>     [javac] import
>>     [javac]                                                          ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:19:
>>     [javac] import
>>     [javac]                                                          ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:26:
>>     [javac] symbol  : class Executable
>> org.globus.cog.abstraction.impl.execution.deef.SubmissionThread
>>     [javac]     private Executable[] execs = null;
>>     [javac]             ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:27:
>>     [javac] symbol  : class UserJob
>>     [javac]     private UserJob job = null;
>>     [javac]             ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:97:
>>     [javac]     public void setStatus (Executable execs[]) {
>>     [javac]                            ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/StatusThread.java:16:
>>     [javac] import
>>     [javac]                                                          ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/StatusThread.java:17:
>>     [javac] import
>>     [javac]                                                          ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/StatusThread.java:18:
>>     [javac] import
>>     [javac]                                                          ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/StatusThread.java:19:
>>     [javac] import
>>     [javac]                                                          ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:59:
>>     [javac]             ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:60:
>>     [javac]             ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:174:
>>     [javac] symbol  : class GPPortType
>>     [javac]     public GPPortType getNextResourcePort() {
>>     [javac]            ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:184:
>>     [javac]     public void submit(Task task, Executable exec) {
>>     [javac]                                   ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:210:
>>     [javac]     public static String getMachNamePort(Notification userNot){
>>     [javac]                                          ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:229:
>>     [javac]     public Executable removeFirstExec() throws
>> NoSuchElementException {
>>     [javac]            ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:63:
>> org.globus.cog.abstraction.impl.execution.deef.JobSubmissionTaskHandler
>>     [javac]     private GPPortType gGP = null;
>>     [javac]             ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:206:
>>     [javac]     private Executable prepareSpecification(JobSpecification
>> spec)
>>     [javac]             ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:157:
>>     [javac]     Executable job = prepareSpecification(spec);
>>     [javac]         ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:211:
>>     [javac]     Executable exec = new Executable();
>>     [javac]         ^
>>     [javac]
>>     [javac]                               ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:289:
>>     [javac] symbol  : class DeInit
>>     [javac]             DeInit deInit = new DeInit();
>>     [javac]             ^
>>     [javac]
>>     [javac]                                 ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:291:
>>     [javac] symbol  : class DeInitResponse
>>     [javac]             DeInitResponse dr = this.gGP.deInit(deInit);
>>     [javac]             ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:69:
>>     [javac]         rp.userNot = new Notification(SO_TIMEOUT);
>>     [javac]                              ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:110:
>>     [javac] symbol  : class FactoryServiceAddressingLocator
>>     [javac]         FactoryServiceAddressingLocator factoryLocator = new
>> FactoryServiceAddressingLocator();
>>     [javac]             ^
>>     [javac]
>> [javac]        ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:130:
>>     [javac] symbol  : class CreateResourceResponse
>>     [javac]             CreateResourceResponse createResponse = gpFactory
>>     [javac]                 ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:131:
>>     [javac]                 .createResource(new CreateResource());
>>     [javac]                                         ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:137:
>>     [javac] symbol  : class GPServiceAddressingLocator
>>     [javac]             GPServiceAddressingLocator instanceLocator = new
>> GPServiceAddressingLocator();
>>     [javac]                 ^
>>     [javac]
>> [javac]        ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:138:
>>     [javac]             GPPortType gGP =
>> instanceLocator.getGPPortTypePort(instanceEPR);
>>     [javac]                 ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:140:
>>     [javac] symbol  : class Init
>>     [javac]             Init initMsg = new Init();
>>     [javac]                 ^
>>     [javac]
>>     [javac]                                    ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:142:
>>     [javac] symbol  : class InitResponse
>>     [javac]             InitResponse ir = gGP.init(initMsg);
>>     [javac]                 ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:177:
>>     [javac]     return (GPPortType) gptPool.get(next);
>>     [javac]                 ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:230:
>>     [javac]     return (Executable) execQueue.remove(0);
>>     [javac]                 ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:247:
>>     [javac]             ^
>>     [javac]
>>     [javac]                                 ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:252:
>>     [javac]             GPPortType gGP = (GPPortType)gptPool.get(i);
>>     [javac]                 ^
>>     [javac]
>>     [javac]                                   ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:254:
>>     [javac]             DeInitResponse dr = gGP.deInit(deInit);
>>     [javac]                 ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:44:
>>     [javac]     job = new UserJob();
>>     [javac]                   ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:67:
>>     [javac]                 execs = new Executable[num_execs];
>>     [javac]                                 ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:74:
>>     [javac]                 GPPortType gGP = rp.getNextResourcePort();
>>     [javac]                     ^
>>     [javac]
>> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:75:
>>     [javac] symbol  : class UserJobResponse
>>     [javac]                 UserJobResponse jobRP = gGP.userJob(job);
>>     [javac]                     ^
>>     [javac] Note:
>> uses or overrides a deprecated API.
>>     [javac] Note: Recompile with -deprecation for details.
>>     [javac] 74 errors
>> BUILD FAILED
>> /home/nefedova/cogl/modules/provider-deef/build.xml:56: The following
>> error occurred while executing this line:
>> /home/nefedova/cogl/mbuild.xml:463: The following error occurred while
>> /home/nefedova/cogl/mbuild.xml:227: Compile failed; see the compiler
>> error output for details.
>> Total time: 23 seconds
>> Ioan Raicu wrote:
>>> Right!
>>> Ben Clifford wrote:
>>>> On Thu, 9 Aug 2007, Ioan Raicu wrote:
>>>>> Now, I renamed the jar to FalkonStubs.jar and it can be found in
>>>>> /home/nefedova/cogl/modules/provider-deef/lib/
>>>> you need to 'svn rm WhateverTheOldJarWas.jar' and 'svn add
>>>> FalkonStubs.jar' before you commit.
>>> _______________________________________________
>>> Swift-devel mailing list
>>> Swift-devel at ci.uchicago.edu
>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
