[Swift-devel] Q about MolDyn
    Mihael Hategan
    hategan at mcs.anl.gov
    Thu Aug  9 14:42:35 CDT 2007
That's because you didn't change the project.properties file. You need
to edit that and replace GenericPortal.jar with whatever the new thing
is.
On Thu, 2007-08-09 at 14:36 -0500, Ioan Raicu wrote:
> Now i am trying to compile the provider-deef, and I fails...  it seems
> that its not finding the stubs I just added... I changed the file name
> from GenericPortal.jar to FalkonStubs.jar.  I need to do anything
> special, like to rebuild the classpath with the new jar name so the
> build can pick it up?
> Ioan
> nefedova at viper:~/cogl/modules/provider-deef> ant distclean
> Buildfile: build.xml
> distclean:
> BUILD SUCCESSFUL
> Total time: 4 seconds
> -Ddist.dir=/home/nefedova/cogl/modules/vdsk/dist/vdsk-0.2-dev/ dist
> dist:
> delete.jar:
>      [echo] [provider-deef]: DELETE.JAR (cog-provider-deef-1.0.jar)
>    [delete] Deleting:
> /home/nefedova/cogl/modules/vdsk/dist/vdsk-0.2-dev/lib/cog-provider-deef-1.0.jar
> compile:
>      [echo] [provider-deef]: COMPILE
>     [mkdir] Created dir: /home/nefedova/cogl/modules/provider-deef/build
>     [javac] Compiling 8 source files to
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:41:
> package org.globus.GenericPortal.stubs.GPService_instance does not exist
>     [javac] import org.globus.GenericPortal.stubs.GPService_instance.*;
>     [javac] ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:42:
>     [javac] import
> org.globus.GenericPortal.stubs.GPService_instance.GPPortType;
>     [javac]                                                          ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:43:
> package org.globus.GenericPortal.stubs.GPService_instance.service does
> not exist
>     [javac] import
> org.globus.GenericPortal.stubs.GPService_instance.service.GPServiceAddressingLocator;
> [javac]        ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:45:
> package org.globus.GenericPortal.stubs.Factory does not exist
>     [javac] import org.globus.GenericPortal.stubs.Factory.CreateResource;
>     [javac]                                               ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:46:
>     [javac] import
> org.globus.GenericPortal.stubs.Factory.CreateResourceResponse;
>     [javac]                                               ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:47:
>     [javac] import org.globus.GenericPortal.stubs.Factory.FactoryPortType;
>     [javac]                                               ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:48:
> package org.globus.GenericPortal.stubs.Factory.service does not exist
>     [javac] import
> org.globus.GenericPortal.stubs.Factory.service.FactoryServiceAddressingLocator;
>     [javac]                                                       ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:50:
> package org.globus.GenericPortal.common does not exist
>     [javac] import org.globus.GenericPortal.common.Notification;
>     [javac]                                        ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:19:
>     [javac]                                               ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:20:
>     [javac] import
>     [javac]                                               ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:21:
>     [javac]                                               ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:22:
>     [javac] import
>     [javac]                                                       ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:24:
>     [javac] import
> org.globus.GenericPortal.stubs.GPService_instance.UserJob;
>     [javac]                                                          ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:25:
>     [javac] import
> org.globus.GenericPortal.stubs.GPService_instance.UserJobResponse;
>     [javac]                                                          ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:26:
>     [javac] import
> org.globus.GenericPortal.stubs.GPService_instance.InitResponse;
>     [javac]                                                          ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:27:
>     [javac] import org.globus.GenericPortal.stubs.GPService_instance.Init;
>     [javac]                                                          ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:28:
>     [javac] import
> org.globus.GenericPortal.stubs.GPService_instance.DeInitResponse;
>     [javac]                                                          ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:29:
>     [javac] import org.globus.GenericPortal.stubs.GPService_instance.DeInit;
>     [javac]                                                          ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:30:
>     [javac] import
>     [javac]                                                          ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:31:
>     [javac] import
> org.globus.GenericPortal.stubs.GPService_instance.Executable;
>     [javac]                                                          ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:32:
> not exist
>     [javac] import
> [javac]        ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:35:
>     [javac]                                        ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:48:
> cannot resolve symbol
>     [javac] symbol  : class FactoryPortType
>     [javac] location: class
> org.globus.cog.abstraction.impl.execution.deef.ResourcePool
>     [javac]     private FactoryPortType gpFactory = null;
>     [javac]             ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:54:
>     [javac] symbol  : class Notification
>     [javac]     private Notification userNot = null;
>     [javac]             ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/NotificationThread.java:16:
>     [javac]                                        ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/NotificationThread.java:22:
> org.globus.cog.abstraction.impl.execution.deef.NotificationThread
>     [javac]             ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/NotificationThread.java:31:
>     [javac]     public NotificationThread(Map tasks, Notification
> userNot, List completedQueue){
>     [javac]                                          ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:16:
>     [javac] import
>     [javac]                                                          ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:17:
>     [javac] import
>     [javac]                                                          ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:18:
>     [javac] import
>     [javac]                                                          ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:19:
>     [javac] import
>     [javac]                                                          ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:26:
>     [javac] symbol  : class Executable
> org.globus.cog.abstraction.impl.execution.deef.SubmissionThread
>     [javac]     private Executable[] execs = null;
>     [javac]             ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:27:
>     [javac] symbol  : class UserJob
>     [javac]     private UserJob job = null;
>     [javac]             ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:97:
>     [javac]     public void setStatus (Executable execs[]) {
>     [javac]                            ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/StatusThread.java:16:
>     [javac] import
>     [javac]                                                          ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/StatusThread.java:17:
>     [javac] import
>     [javac]                                                          ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/StatusThread.java:18:
>     [javac] import
>     [javac]                                                          ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/StatusThread.java:19:
>     [javac] import
>     [javac]                                                          ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:59:
>     [javac]             ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:60:
>     [javac]             ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:174:
>     [javac] symbol  : class GPPortType
>     [javac]     public GPPortType getNextResourcePort() {
>     [javac]            ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:184:
>     [javac]     public void submit(Task task, Executable exec) {
>     [javac]                                   ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:210:
>     [javac]     public static String getMachNamePort(Notification userNot){
>     [javac]                                          ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:229:
>     [javac]     public Executable removeFirstExec() throws
> NoSuchElementException {
>     [javac]            ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:63:
> org.globus.cog.abstraction.impl.execution.deef.JobSubmissionTaskHandler
>     [javac]     private GPPortType gGP = null;
>     [javac]             ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:206:
>     [javac]     private Executable prepareSpecification(JobSpecification
> spec)
>     [javac]             ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:157:
>     [javac]     Executable job = prepareSpecification(spec);
>     [javac]         ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:211:
>     [javac]     Executable exec = new Executable();
>     [javac]         ^
>     [javac]
>     [javac]                               ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:289:
>     [javac] symbol  : class DeInit
>     [javac]             DeInit deInit = new DeInit();
>     [javac]             ^
>     [javac]
>     [javac]                                 ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:291:
>     [javac] symbol  : class DeInitResponse
>     [javac]             DeInitResponse dr = this.gGP.deInit(deInit);
>     [javac]             ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:69:
>     [javac]         rp.userNot = new Notification(SO_TIMEOUT);
>     [javac]                              ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:110:
>     [javac] symbol  : class FactoryServiceAddressingLocator
>     [javac]         FactoryServiceAddressingLocator factoryLocator = new
> FactoryServiceAddressingLocator();
>     [javac]             ^
>     [javac]
> [javac]        ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:130:
>     [javac] symbol  : class CreateResourceResponse
>     [javac]             CreateResourceResponse createResponse = gpFactory
>     [javac]                 ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:131:
>     [javac]                 .createResource(new CreateResource());
>     [javac]                                         ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:137:
>     [javac] symbol  : class GPServiceAddressingLocator
>     [javac]             GPServiceAddressingLocator instanceLocator = new
> GPServiceAddressingLocator();
>     [javac]                 ^
>     [javac]
> [javac]        ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:138:
>     [javac]             GPPortType gGP =
> instanceLocator.getGPPortTypePort(instanceEPR);
>     [javac]                 ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:140:
>     [javac] symbol  : class Init
>     [javac]             Init initMsg = new Init();
>     [javac]                 ^
>     [javac]
>     [javac]                                    ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:142:
>     [javac] symbol  : class InitResponse
>     [javac]             InitResponse ir = gGP.init(initMsg);
>     [javac]                 ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:177:
>     [javac]     return (GPPortType) gptPool.get(next);
>     [javac]                 ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:230:
>     [javac]     return (Executable) execQueue.remove(0);
>     [javac]                 ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:247:
>     [javac]             ^
>     [javac]
>     [javac]                                 ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:252:
>     [javac]             GPPortType gGP = (GPPortType)gptPool.get(i);
>     [javac]                 ^
>     [javac]
>     [javac]                                   ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:254:
>     [javac]             DeInitResponse dr = gGP.deInit(deInit);
>     [javac]                 ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:44:
>     [javac]     job = new UserJob();
>     [javac]                   ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:67:
>     [javac]                 execs = new Executable[num_execs];
>     [javac]                                 ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:74:
>     [javac]                 GPPortType gGP = rp.getNextResourcePort();
>     [javac]                     ^
>     [javac]
> /home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:75:
>     [javac] symbol  : class UserJobResponse
>     [javac]                 UserJobResponse jobRP = gGP.userJob(job);
>     [javac]                     ^
>     [javac] Note:
> uses or overrides a deprecated API.
>     [javac] Note: Recompile with -deprecation for details.
>     [javac] 74 errors
> BUILD FAILED
> /home/nefedova/cogl/modules/provider-deef/build.xml:56: The following
> error occurred while executing this line:
> /home/nefedova/cogl/mbuild.xml:463: The following error occurred while
> /home/nefedova/cogl/mbuild.xml:227: Compile failed; see the compiler
> error output for details.
> Total time: 23 seconds
> Ioan Raicu wrote:
> > Right!
> > Ben Clifford wrote:
> >> On Thu, 9 Aug 2007, Ioan Raicu wrote:
> >>> Now, I renamed the jar to FalkonStubs.jar and it can be found in
> >>> /home/nefedova/cogl/modules/provider-deef/lib/
> >> you need to 'svn rm WhateverTheOldJarWas.jar' and 'svn add
> >> FalkonStubs.jar' before you commit.
> > _______________________________________________
> > Swift-devel mailing list
> > Swift-devel at ci.uchicago.edu
> > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
