[Swift-devel] Q about MolDyn
    Ioan Raicu
    iraicu at cs.uchicago.edu
    Thu Aug  9 14:36:05 CDT 2007
Now i am trying to compile the provider-deef, and I fails...  it seems
that its not finding the stubs I just added... I changed the file name
from GenericPortal.jar to FalkonStubs.jar.  I need to do anything
special, like to rebuild the classpath with the new jar name so the
build can pick it up?
Ioan
nefedova at viper:~/cogl/modules/provider-deef> ant distclean
Buildfile: build.xml
distclean:
BUILD SUCCESSFUL
Total time: 4 seconds
-Ddist.dir=/home/nefedova/cogl/modules/vdsk/dist/vdsk-0.2-dev/ dist
dist:
delete.jar:
     [echo] [provider-deef]: DELETE.JAR (cog-provider-deef-1.0.jar)
   [delete] Deleting:
/home/nefedova/cogl/modules/vdsk/dist/vdsk-0.2-dev/lib/cog-provider-deef-1.0.jar
compile:
     [echo] [provider-deef]: COMPILE
    [mkdir] Created dir: /home/nefedova/cogl/modules/provider-deef/build
    [javac] Compiling 8 source files to
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:41:
package org.globus.GenericPortal.stubs.GPService_instance does not exist
    [javac] import org.globus.GenericPortal.stubs.GPService_instance.*;
    [javac] ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:42:
    [javac] import
org.globus.GenericPortal.stubs.GPService_instance.GPPortType;
    [javac]                                                          ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:43:
package org.globus.GenericPortal.stubs.GPService_instance.service does
not exist
    [javac] import
org.globus.GenericPortal.stubs.GPService_instance.service.GPServiceAddressingLocator;
[javac]        ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:45:
package org.globus.GenericPortal.stubs.Factory does not exist
    [javac] import org.globus.GenericPortal.stubs.Factory.CreateResource;
    [javac]                                               ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:46:
    [javac] import
org.globus.GenericPortal.stubs.Factory.CreateResourceResponse;
    [javac]                                               ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:47:
    [javac] import org.globus.GenericPortal.stubs.Factory.FactoryPortType;
    [javac]                                               ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:48:
package org.globus.GenericPortal.stubs.Factory.service does not exist
    [javac] import
org.globus.GenericPortal.stubs.Factory.service.FactoryServiceAddressingLocator;
    [javac]                                                       ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:50:
package org.globus.GenericPortal.common does not exist
    [javac] import org.globus.GenericPortal.common.Notification;
    [javac]                                        ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:19:
    [javac]                                               ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:20:
    [javac] import
    [javac]                                               ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:21:
    [javac]                                               ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:22:
    [javac] import
    [javac]                                                       ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:24:
    [javac] import
org.globus.GenericPortal.stubs.GPService_instance.UserJob;
    [javac]                                                          ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:25:
    [javac] import
org.globus.GenericPortal.stubs.GPService_instance.UserJobResponse;
    [javac]                                                          ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:26:
    [javac] import
org.globus.GenericPortal.stubs.GPService_instance.InitResponse;
    [javac]                                                          ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:27:
    [javac] import org.globus.GenericPortal.stubs.GPService_instance.Init;
    [javac]                                                          ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:28:
    [javac] import
org.globus.GenericPortal.stubs.GPService_instance.DeInitResponse;
    [javac]                                                          ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:29:
    [javac] import org.globus.GenericPortal.stubs.GPService_instance.DeInit;
    [javac]                                                          ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:30:
    [javac] import
    [javac]                                                          ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:31:
    [javac] import
org.globus.GenericPortal.stubs.GPService_instance.Executable;
    [javac]                                                          ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:32:
not exist
    [javac] import
[javac]        ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:35:
    [javac]                                        ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:48:
cannot resolve symbol
    [javac] symbol  : class FactoryPortType
    [javac] location: class
org.globus.cog.abstraction.impl.execution.deef.ResourcePool
    [javac]     private FactoryPortType gpFactory = null;
    [javac]             ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:54:
    [javac] symbol  : class Notification
    [javac]     private Notification userNot = null;
    [javac]             ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/NotificationThread.java:16:
    [javac]                                        ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/NotificationThread.java:22:
org.globus.cog.abstraction.impl.execution.deef.NotificationThread
    [javac]             ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/NotificationThread.java:31:
    [javac]     public NotificationThread(Map tasks, Notification
userNot, List completedQueue){
    [javac]                                          ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:16:
    [javac] import
    [javac]                                                          ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:17:
    [javac] import
    [javac]                                                          ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:18:
    [javac] import
    [javac]                                                          ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:19:
    [javac] import
    [javac]                                                          ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:26:
    [javac] symbol  : class Executable
org.globus.cog.abstraction.impl.execution.deef.SubmissionThread
    [javac]     private Executable[] execs = null;
    [javac]             ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:27:
    [javac] symbol  : class UserJob
    [javac]     private UserJob job = null;
    [javac]             ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:97:
    [javac]     public void setStatus (Executable execs[]) {
    [javac]                            ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/StatusThread.java:16:
    [javac] import
    [javac]                                                          ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/StatusThread.java:17:
    [javac] import
    [javac]                                                          ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/StatusThread.java:18:
    [javac] import
    [javac]                                                          ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/StatusThread.java:19:
    [javac] import
    [javac]                                                          ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:59:
    [javac]             ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:60:
    [javac]             ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:174:
    [javac] symbol  : class GPPortType
    [javac]     public GPPortType getNextResourcePort() {
    [javac]            ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:184:
    [javac]     public void submit(Task task, Executable exec) {
    [javac]                                   ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:210:
    [javac]     public static String getMachNamePort(Notification userNot){
    [javac]                                          ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:229:
    [javac]     public Executable removeFirstExec() throws
NoSuchElementException {
    [javac]            ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:63:
org.globus.cog.abstraction.impl.execution.deef.JobSubmissionTaskHandler
    [javac]     private GPPortType gGP = null;
    [javac]             ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:206:
    [javac]     private Executable prepareSpecification(JobSpecification
spec)
    [javac]             ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:157:
    [javac]     Executable job = prepareSpecification(spec);
    [javac]         ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:211:
    [javac]     Executable exec = new Executable();
    [javac]         ^
    [javac]
    [javac]                               ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:289:
    [javac] symbol  : class DeInit
    [javac]             DeInit deInit = new DeInit();
    [javac]             ^
    [javac]
    [javac]                                 ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:291:
    [javac] symbol  : class DeInitResponse
    [javac]             DeInitResponse dr = this.gGP.deInit(deInit);
    [javac]             ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:69:
    [javac]         rp.userNot = new Notification(SO_TIMEOUT);
    [javac]                              ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:110:
    [javac] symbol  : class FactoryServiceAddressingLocator
    [javac]         FactoryServiceAddressingLocator factoryLocator = new
FactoryServiceAddressingLocator();
    [javac]             ^
    [javac]
[javac]        ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:130:
    [javac] symbol  : class CreateResourceResponse
    [javac]             CreateResourceResponse createResponse = gpFactory
    [javac]                 ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:131:
    [javac]                 .createResource(new CreateResource());
    [javac]                                         ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:137:
    [javac] symbol  : class GPServiceAddressingLocator
    [javac]             GPServiceAddressingLocator instanceLocator = new
GPServiceAddressingLocator();
    [javac]                 ^
    [javac]
[javac]        ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:138:
    [javac]             GPPortType gGP =
instanceLocator.getGPPortTypePort(instanceEPR);
    [javac]                 ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:140:
    [javac] symbol  : class Init
    [javac]             Init initMsg = new Init();
    [javac]                 ^
    [javac]
    [javac]                                    ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:142:
    [javac] symbol  : class InitResponse
    [javac]             InitResponse ir = gGP.init(initMsg);
    [javac]                 ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:177:
    [javac]     return (GPPortType) gptPool.get(next);
    [javac]                 ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:230:
    [javac]     return (Executable) execQueue.remove(0);
    [javac]                 ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:247:
    [javac]             ^
    [javac]
    [javac]                                 ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:252:
    [javac]             GPPortType gGP = (GPPortType)gptPool.get(i);
    [javac]                 ^
    [javac]
    [javac]                                   ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/ResourcePool.java:254:
    [javac]             DeInitResponse dr = gGP.deInit(deInit);
    [javac]                 ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:44:
    [javac]     job = new UserJob();
    [javac]                   ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:67:
    [javac]                 execs = new Executable[num_execs];
    [javac]                                 ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:74:
    [javac]                 GPPortType gGP = rp.getNextResourcePort();
    [javac]                     ^
    [javac]
/home/nefedova/cogl/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/SubmissionThread.java:75:
    [javac] symbol  : class UserJobResponse
    [javac]                 UserJobResponse jobRP = gGP.userJob(job);
    [javac]                     ^
    [javac] Note:
uses or overrides a deprecated API.
    [javac] Note: Recompile with -deprecation for details.
    [javac] 74 errors
BUILD FAILED
/home/nefedova/cogl/modules/provider-deef/build.xml:56: The following
error occurred while executing this line:
/home/nefedova/cogl/mbuild.xml:463: The following error occurred while
/home/nefedova/cogl/mbuild.xml:227: Compile failed; see the compiler
error output for details.
Total time: 23 seconds
Ioan Raicu wrote:
> Right!
> Ben Clifford wrote:
>> On Thu, 9 Aug 2007, Ioan Raicu wrote:
>>> Now, I renamed the jar to FalkonStubs.jar and it can be found in
>>> /home/nefedova/cogl/modules/provider-deef/lib/
>> you need to 'svn rm WhateverTheOldJarWas.jar' and 'svn add
>> FalkonStubs.jar' before you commit.
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
