[Swift-devel] Q about MolDyn
    Ioan Raicu
    iraicu at cs.uchicago.edu
    Mon Aug  6 13:48:52 CDT 2007
So m050 finished OK?  All files associated with this molecule were
created correctly?
We are really working blind without any logs.  Are there any wrapper
logs as Mihael suggested that could point into what happened to this
molecule?
If nothing else, just fix m179, and let's try it again.  We should also
switch over to your temp credentials that you got for ANL/UC.  I can
help you configure Falkon for this run, just let me know when you are ready!
Ioan
Veronika Nefedova wrote:
> On Aug 6, 2007, at 12:19 PM, Mihael Hategan wrote:
>> On Mon, 2007-08-06 at 11:51 -0500, Ioan Raicu wrote:
>>> If there are no leftover directories, it could mean one of two things:
>>> 1) the job submission failed and the job never made it out to a remote
>>> resource to create directories and execute
>>> 2) the job went through to the remote resource, created directories,
>>> executed, finished with an exit code of 0, cleaned up directories, ...
>>> In both instances, there are no directories at the end.  What we are
>>> missing is the logs to determine which of the two cases from above
>>> happened.
>> There would be the wrapper log.
> I checked the log. There were only 243 5th Stage jobs done (not 244):
> nefedova at tg-login1:/disks/scratchgpfs1/iraicu/ModLyn/MolDyn-244-loos-bm66sjz1li5h1>
> grep generator_cat wrapper.log | wc
>     243     243    6561
> The only failures in that log are the last stage jobs (3 repeats) for
> m179. Nothing for m050.
> Nika
