[Swift-devel] Q about MolDyn
    Veronika Nefedova
    nefedova at mcs.anl.gov
    Mon Aug  6 12:20:06 CDT 2007
On Aug 6, 2007, at 11:51 AM, Ioan Raicu wrote:
> If there are no leftover directories, it could mean one of two things:
> 1) the job submission failed and the job never made it out to a
> remote resource to create directories and execute
> 2) the job went through to the remote resource, created
> directories, executed, finished with an exit code of 0, cleaned up
> directories, ...
> In both instances, there are no directories at the end.  What we
> are missing is the logs to determine which of the two cases from
> above happened.  Note that there were absolutely no Exceptions
> thrown in the Falkon logs, so I would be cautious to rule out (2)
> from above.
> Just for a sanity check, can you run those two molecules manually,
> just to double check that they work!  Could we do a 2 molecule run
> through Swift with just the two suspect molecules to see if those 2
> molecules complete OK?
I started those 2 molecules via GRAM. I have no trust in m179
finishing completely since I didn't change anything. I hope for m050
to finish though...
You can watch the swift log on viper in ~nefedova/alamines/MolDyn-2-
loops-be9484k93kk21.log
Nika
> Then, let's try another run with 244 molecules soon, as most of ANL/
> UC is free!
> Ioan
> Veronika Nefedova wrote:
>> m050 worked just fine last time we ran 244 molecules. And it
>> doesn't look like an application failure but rather a job
>> submission failure (no leftover directories).
>> m179 failed the last time we ran it but I thought it was fixed?
>> Yuqing - could you please verify that I am using the right
>> antechamber code on tg-uc.
>> Nika
>> On Aug 6, 2007, at 11:34 AM, Ben Clifford wrote:
>>> have you tried running those molecules individually?
