[Swift-devel] hanging workflow
    Ben Clifford
    benc at hawaga.org.uk
    Mon Apr 30 11:27:08 CDT 2007
On Mon, 30 Apr 2007, Yong Zhao wrote:
> We talked about this a couple of times, one (not so intuitive) solution is
> to put the assignments into a procedure, then the array will be closed
> when exiting the procedure.
OK, I just tried that. The workflow runs to completion.
It looks very unpleasant for a tutorial perspective. Putting things into a
procedure shouldn't cause more stuff to happen than if the procedure code
was inlined.
> The other way is to actively figure out when to close the array, which
> is not trivial.
Not trivial, but possibly what needs to happen fairly soon.
