[Swift-commit] r8376 - in SwiftApps/ematter: . workflow-run
ketan at ci.uchicago.edu ketan at ci.uchicago.edu
Tue Jan 27 16:12:53 CST 2015
Author: ketan
Date: 2015-01-27 16:12:52 -0600 (Tue, 27 Jan 2015)
New Revision: 8376
Added:
   SwiftApps/ematter/workflow-run/
   SwiftApps/ematter/workflow-run/Hf.psf
   SwiftApps/ematter/workflow-run/Hf.sic.psf
   SwiftApps/ematter/workflow-run/N.psf
   SwiftApps/ematter/workflow-run/N.sic.psf
   SwiftApps/ematter/workflow-run/O.psf
   SwiftApps/ematter/workflow-run/O.sic.psf
   SwiftApps/ematter/workflow-run/Ta.lammps.eam
   SwiftApps/ematter/workflow-run/Ta.psf
   SwiftApps/ematter/workflow-run/Ta.sic.psf
   SwiftApps/ematter/workflow-run/Ti.psf
   SwiftApps/ematter/workflow-run/Ti.sic.psf
   SwiftApps/ematter/workflow-run/TiN-Ta-HfO2-TiN.geo
   SwiftApps/ematter/workflow-run/TiN.meam
   SwiftApps/ematter/workflow-run/apps
   SwiftApps/ematter/workflow-run/cf
   SwiftApps/ematter/workflow-run/genfdf
   SwiftApps/ematter/workflow-run/in.lammps
   SwiftApps/ematter/workflow-run/input_leads.fdf
   SwiftApps/ematter/workflow-run/input_t0.fdf
   SwiftApps/ematter/workflow-run/job.sub
   SwiftApps/ematter/workflow-run/lastlammpsdump2xyz.py
   SwiftApps/ematter/workflow-run/library.meam
   SwiftApps/ematter/workflow-run/pasta
   SwiftApps/ematter/workflow-run/runblues
   SwiftApps/ematter/workflow-run/runlocal
   SwiftApps/ematter/workflow-run/sites.blues.xml
   SwiftApps/ematter/workflow-run/sites.local.xml
   SwiftApps/ematter/workflow-run/smeagol_leadwrap
   SwiftApps/ematter/workflow-run/smeagol_t0wrap
   SwiftApps/ematter/workflow-run/smeagol_tnwrap
   SwiftApps/ematter/workflow-run/workflow.blues.swift
   SwiftApps/ematter/workflow-run/workflow.localblues.swift
Log:
ematter workflow
Added: SwiftApps/ematter/workflow-run/Hf.psf
--- SwiftApps/ematter/workflow-run/Hf.psf	                        (rev 0)
+++ SwiftApps/ematter/workflow-run/Hf.psf	2015-01-27 22:12:52 UTC (rev 8376)
@@ -0,0 +1,3041 @@
+ Hf ca rel nc
+ ATM3       7-OCT-14 Troullier-Martins
+ 6s 2.00r r= 2.89/6p 0.00r r= 2.93/5d 2.00r r= 2.55/5f 0.00r r= 2.55/
+   4  3 1205  0.344271135648E-04  0.125000000000E-01   4.00000000000
+ Radial grid follows
+  0.433039779659E-06  0.871526529201E-06  0.131552876307E-05  0.176511585753E-05
+  0.222035806147E-05  0.268132650740E-05  0.314809322260E-05  0.362073114031E-05
+  0.409931411115E-05  0.458391691471E-05  0.507461527115E-05  0.557148585308E-05
+  0.607460629755E-05  0.658405521815E-05  0.709991221732E-05  0.762225789874E-05
+  0.815117388001E-05  0.868674280532E-05  0.922904835840E-05  0.977817527560E-05
+  0.103342093591E-04  0.108972374904E-04  0.114673476438E-04  0.120446289001E-04
+  0.126291714607E-04  0.132210666615E-04  0.138204069875E-04  0.144272860867E-04
+  0.150417987853E-04  0.156640411021E-04  0.162941102637E-04  0.169321047197E-04
+  0.175781241580E-04  0.182322695206E-04  0.188946430189E-04  0.195653481501E-04
+  0.202444897134E-04  0.209321738259E-04  0.216285079396E-04  0.223336008583E-04
+  0.230475627541E-04  0.237705051850E-04  0.245025411122E-04  0.252437849179E-04
+  0.259943524228E-04  0.267543609048E-04  0.275239291166E-04  0.283031773048E-04
+  0.290922272286E-04  0.298912021787E-04  0.307002269965E-04  0.315194280937E-04
+  0.323489334722E-04  0.331888727439E-04  0.340393771511E-04  0.349005795867E-04
+  0.357726146155E-04  0.366556184945E-04  0.375497291951E-04  0.384550864238E-04
+  0.393718316446E-04  0.403001081006E-04  0.412400608371E-04  0.421918367235E-04
+  0.431555844768E-04  0.441314546845E-04  0.451195998284E-04  0.461201743080E-04
+  0.471333344652E-04  0.481592386084E-04  0.491980470371E-04  0.502499220674E-04
+  0.513150280567E-04  0.523935314300E-04  0.534856007058E-04  0.545914065221E-04
+  0.557111216632E-04  0.568449210870E-04  0.579929819519E-04  0.591554836447E-04
+  0.603326078088E-04  0.615245383721E-04  0.627314615762E-04  0.639535660054E-04
+  0.651910426159E-04  0.664440847660E-04  0.677128882460E-04  0.689976513091E-04
+  0.702985747022E-04  0.716158616971E-04  0.729497181227E-04  0.743003523967E-04
+  0.756679755584E-04  0.770528013018E-04  0.784550460087E-04  0.798749287827E-04
+  0.813126714834E-04  0.827684987609E-04  0.842426380913E-04  0.857353198119E-04
+  0.872467771571E-04  0.887772462953E-04  0.903269663654E-04  0.918961795143E-04
+  0.934851309347E-04  0.950940689036E-04  0.967232448208E-04  0.983729132483E-04
+  0.100043331950E-03  0.101734761933E-03  0.103447467485E-03  0.105181716222E-03
+  0.106937779122E-03  0.108715930574E-03  0.110516448418E-03  0.112339613989E-03
+  0.114185712159E-03  0.116055031386E-03  0.117947863754E-03  0.119864505022E-03
+  0.121805254669E-03  0.123770415942E-03  0.125760295901E-03  0.127775205468E-03
+  0.129815459478E-03  0.131881376724E-03  0.133973280010E-03  0.136091496200E-03
+  0.138236356270E-03  0.140408195358E-03  0.142607352819E-03  0.144834172275E-03
+  0.147089001672E-03  0.149372193332E-03  0.151684104007E-03  0.154025094938E-03
+  0.156395531910E-03  0.158795785309E-03  0.161226230179E-03  0.163687246282E-03
+  0.166179218157E-03  0.168702535180E-03  0.171257591623E-03  0.173844786720E-03
+  0.176464524725E-03  0.179117214977E-03  0.181803271965E-03  0.184523115392E-03
+  0.187277170236E-03  0.190065866826E-03  0.192889640901E-03  0.195748933682E-03
+  0.198644191938E-03  0.201575868060E-03  0.204544420128E-03  0.207550311984E-03
+  0.210594013305E-03  0.213675999676E-03  0.216796752663E-03  0.219956759890E-03
+  0.223156515115E-03  0.226396518306E-03  0.229677275720E-03  0.232999299982E-03
+  0.236363110166E-03  0.239769231873E-03  0.243218197316E-03  0.246710545405E-03
+  0.250246821824E-03  0.253827579125E-03  0.257453376809E-03  0.261124781413E-03
+  0.264842366601E-03  0.268606713255E-03  0.272418409561E-03  0.276278051104E-03
+  0.280186240961E-03  0.284143589795E-03  0.288150715950E-03  0.292208245546E-03
+  0.296316812582E-03  0.300477059030E-03  0.304689634936E-03  0.308955198523E-03
+  0.313274416296E-03  0.317647963140E-03  0.322076522431E-03  0.326560786140E-03
+  0.331101454943E-03  0.335699238329E-03  0.340354854710E-03  0.345069031536E-03
+  0.349842505407E-03  0.354676022188E-03  0.359570337126E-03  0.364526214966E-03
+  0.369544430076E-03  0.374625766562E-03  0.379771018392E-03  0.384980989523E-03
+  0.390256494023E-03  0.395598356202E-03  0.401007410734E-03  0.406484502797E-03
+  0.412030488197E-03  0.417646233506E-03  0.423332616195E-03  0.429090524773E-03
+  0.434920858925E-03  0.440824529653E-03  0.446802459417E-03  0.452855582280E-03
+  0.458984844057E-03  0.465191202455E-03  0.471475627232E-03  0.477839100341E-03
+  0.484282616089E-03  0.490807181287E-03  0.497413815412E-03  0.504103550765E-03
+  0.510877432629E-03  0.517736519438E-03  0.524681882938E-03  0.531714608357E-03
+  0.538835794571E-03  0.546046554281E-03  0.553348014183E-03  0.560741315144E-03
+  0.568227612383E-03  0.575808075649E-03  0.583483889405E-03  0.591256253012E-03
+  0.599126380919E-03  0.607095502847E-03  0.615164863990E-03  0.623335725201E-03
+  0.631609363194E-03  0.639987070741E-03  0.648470156876E-03  0.657059947100E-03
+  0.665757783584E-03  0.674565025382E-03  0.683483048644E-03  0.692513246830E-03
+  0.701657030926E-03  0.710915829668E-03  0.720291089760E-03  0.729784276108E-03
+  0.739396872039E-03  0.749130379543E-03  0.758986319500E-03  0.768966231919E-03
+  0.779071676183E-03  0.789304231289E-03  0.799665496092E-03  0.810157089563E-03
+  0.820780651034E-03  0.831537840458E-03  0.842430338669E-03  0.853459847639E-03
+  0.864628090755E-03  0.875936813074E-03  0.887387781610E-03  0.898982785598E-03
+  0.910723636783E-03  0.922612169694E-03  0.934650241941E-03  0.946839734497E-03
+  0.959182551993E-03  0.971680623022E-03  0.984335900431E-03  0.997150361634E-03
+  0.101012600892E-02  0.102326486975E-02  0.103656899711E-02  0.105004046978E-02
+  0.106368139273E-02  0.107749389736E-02  0.109148014191E-02  0.110564231177E-02
+  0.111998261979E-02  0.113450330668E-02  0.114920664132E-02  0.116409492115E-02
+  0.117917047248E-02  0.119443565091E-02  0.120989284164E-02  0.122554445990E-02
+  0.124139295128E-02  0.125744079214E-02  0.127369048999E-02  0.129014458387E-02
+  0.130680564478E-02  0.132367627604E-02  0.134075911371E-02  0.135805682703E-02
+  0.137557211880E-02  0.139330772581E-02  0.141126641930E-02  0.142945100535E-02
+  0.144786432533E-02  0.146650925636E-02  0.148538871176E-02  0.150450564147E-02
+  0.152386303255E-02  0.154346390964E-02  0.156331133541E-02  0.158340841107E-02
+  0.160375827681E-02  0.162436411236E-02  0.164522913741E-02  0.166635661217E-02
+  0.168774983785E-02  0.170941215717E-02  0.173134695494E-02  0.175355765849E-02
+  0.177604773830E-02  0.179882070849E-02  0.182188012738E-02  0.184522959805E-02
+  0.186887276891E-02  0.189281333425E-02  0.191705503483E-02  0.194160165847E-02
+  0.196645704062E-02  0.199162506499E-02  0.201710966414E-02  0.204291482008E-02
+  0.206904456493E-02  0.209550298150E-02  0.212229420399E-02  0.214942241857E-02
+  0.217689186408E-02  0.220470683268E-02  0.223287167052E-02  0.226139077840E-02
+  0.229026861250E-02  0.231950968504E-02  0.234911856499E-02  0.237909987880E-02
+  0.240945831112E-02  0.244019860550E-02  0.247132556519E-02  0.250284405383E-02
+  0.253475899626E-02  0.256707537924E-02  0.259979825228E-02  0.263293272839E-02
+  0.266648398490E-02  0.270045726427E-02  0.273485787489E-02  0.276969119192E-02
+  0.280496265814E-02  0.284067778478E-02  0.287684215242E-02  0.291346141181E-02
+  0.295054128477E-02  0.298808756512E-02  0.302610611954E-02  0.306460288850E-02
+  0.310358388720E-02  0.314305520651E-02  0.318302301389E-02  0.322349355440E-02
+  0.326447315165E-02  0.330596820877E-02  0.334798520946E-02  0.339053071896E-02
+  0.343361138508E-02  0.347723393928E-02  0.352140519766E-02  0.356613206207E-02
+  0.361142152118E-02  0.365728065156E-02  0.370371661878E-02  0.375073667857E-02
+  0.379834817791E-02  0.384655855618E-02  0.389537534635E-02  0.394480617616E-02
+  0.399485876926E-02  0.404554094648E-02  0.409686062701E-02  0.414882582966E-02
+  0.420144467409E-02  0.425472538210E-02  0.430867627892E-02  0.436330579448E-02
+  0.441862246475E-02  0.447463493308E-02  0.453135195153E-02  0.458878238224E-02
+  0.464693519885E-02  0.470581948784E-02  0.476544445000E-02  0.482581940187E-02
+  0.488695377714E-02  0.494885712818E-02  0.501153912753E-02  0.507500956937E-02
+  0.513927837109E-02  0.520435557481E-02  0.527025134899E-02  0.533697598997E-02
+  0.540453992361E-02  0.547295370692E-02  0.554222802969E-02  0.561237371617E-02
+  0.568340172676E-02  0.575532315975E-02  0.582814925299E-02  0.590189138572E-02
+  0.597656108030E-02  0.605217000400E-02  0.612872997089E-02  0.620625294362E-02
+  0.628475103530E-02  0.636423651142E-02  0.644472179175E-02  0.652621945228E-02
+  0.660874222719E-02  0.669230301082E-02  0.677691485971E-02  0.686259099465E-02
+  0.694934480270E-02  0.703718983932E-02  0.712613983047E-02  0.721620867478E-02
+  0.730741044569E-02  0.739975939364E-02  0.749326994837E-02  0.758795672107E-02
+  0.768383450676E-02  0.778091828653E-02  0.787922322992E-02  0.797876469728E-02
+  0.807955824215E-02  0.818161961375E-02  0.828496475937E-02  0.838960982689E-02
+  0.849557116732E-02  0.860286533734E-02  0.871150910187E-02  0.882151943674E-02
+  0.893291353127E-02  0.904570879102E-02  0.915992284047E-02  0.927557352582E-02
+  0.939267891770E-02  0.951125731409E-02  0.963132724308E-02  0.975290746586E-02
+  0.987601697958E-02  0.100006750204E-01  0.101269010662E-01  0.102547148403E-01
+  0.103841363138E-01  0.105151857090E-01  0.106478835027E-01  0.107822504291E-01
+  0.109183074834E-01  0.110560759248E-01  0.111955772798E-01  0.113368333459E-01
+  0.114798661945E-01  0.116246981749E-01  0.117713519173E-01  0.119198503368E-01
+  0.120702166364E-01  0.122224743112E-01  0.123766471518E-01  0.125327592480E-01
+  0.126908349927E-01  0.128508990854E-01  0.130129765366E-01  0.131770926712E-01
+  0.133432731326E-01  0.135115438868E-01  0.136819312266E-01  0.138544617753E-01
+  0.140291624912E-01  0.142060606715E-01  0.143851839570E-01  0.145665603361E-01
+  0.147502181492E-01  0.149361860932E-01  0.151244932259E-01  0.153151689708E-01
+  0.155082431213E-01  0.157037458457E-01  0.159017076916E-01  0.161021595910E-01
+  0.163051328649E-01  0.165106592283E-01  0.167187707951E-01  0.169295000831E-01
+  0.171428800193E-01  0.173589439447E-01  0.175777256196E-01  0.177992592293E-01
+  0.180235793888E-01  0.182507211485E-01  0.184807199998E-01  0.187136118805E-01
+  0.189494331805E-01  0.191882207473E-01  0.194300118919E-01  0.196748443947E-01
+  0.199227565112E-01  0.201737869784E-01  0.204279750200E-01  0.206853603537E-01
+  0.209459831963E-01  0.212098842706E-01  0.214771048119E-01  0.217476865738E-01
+  0.220216718353E-01  0.222991034071E-01  0.225800246385E-01  0.228644794239E-01
+  0.231525122102E-01  0.234441680028E-01  0.237394923737E-01  0.240385314679E-01
+  0.243413320109E-01  0.246479413158E-01  0.249584072910E-01  0.252727784474E-01
+  0.255911039062E-01  0.259134334063E-01  0.262398173125E-01  0.265703066227E-01
+  0.269049529768E-01  0.272438086638E-01  0.275869266306E-01  0.279343604902E-01
+  0.282861645297E-01  0.286423937193E-01  0.290031037205E-01  0.293683508949E-01
+  0.297381923133E-01  0.301126857640E-01  0.304918897624E-01  0.308758635599E-01
+  0.312646671533E-01  0.316583612938E-01  0.320570074970E-01  0.324606680521E-01
+  0.328694060319E-01  0.332832853026E-01  0.337023705337E-01  0.341267272081E-01
+  0.345564216323E-01  0.349915209470E-01  0.354320931373E-01  0.358782070436E-01
+  0.363299323720E-01  0.367873397056E-01  0.372505005152E-01  0.377194871706E-01
+  0.381943729519E-01  0.386752320610E-01  0.391621396330E-01  0.396551717484E-01
+  0.401544054444E-01  0.406599187272E-01  0.411717905843E-01  0.416901009968E-01
+  0.422149309517E-01  0.427463624547E-01  0.432844785432E-01  0.438293632988E-01
+  0.443811018609E-01  0.449397804397E-01  0.455054863300E-01  0.460783079244E-01
+  0.466583347275E-01  0.472456573696E-01  0.478403676212E-01  0.484425584067E-01
+  0.490523238199E-01  0.496697591378E-01  0.502949608360E-01  0.509280266034E-01
+  0.515690553578E-01  0.522181472614E-01  0.528754037361E-01  0.535409274794E-01
+  0.542148224810E-01  0.548971940381E-01  0.555881487728E-01  0.562877946482E-01
+  0.569962409853E-01  0.577135984803E-01  0.584399792218E-01  0.591754967082E-01
+  0.599202658657E-01  0.606744030660E-01  0.614380261445E-01  0.622112544189E-01
+  0.629942087077E-01  0.637870113490E-01  0.645897862200E-01  0.654026587558E-01
+  0.662257559693E-01  0.670592064713E-01  0.679031404900E-01  0.687576898919E-01
+  0.696229882021E-01  0.704991706250E-01  0.713863740662E-01  0.722847371528E-01
+  0.731944002560E-01  0.741155055125E-01  0.750481968467E-01  0.759926199938E-01
+  0.769489225216E-01  0.779172538544E-01  0.788977652960E-01  0.798906100532E-01
+  0.808959432601E-01  0.819139220020E-01  0.829447053402E-01  0.839884543366E-01
+  0.850453320792E-01  0.861155037073E-01  0.871991364374E-01  0.882963995892E-01
+  0.894074646125E-01  0.905325051132E-01  0.916716968814E-01  0.928252179181E-01
+  0.939932484632E-01  0.951759710239E-01  0.963735704031E-01  0.975862337280E-01
+  0.988141504797E-01  0.100057512523      0.101316514135      0.102591352038
+  0.103882225428      0.105189336006      0.106512888012      0.107853088252
+  0.109210146136      0.110584273706      0.111975685674      0.113384599450
+  0.114811235179      0.116255815777      0.117718566962      0.119199717292
+  0.120699498199      0.122218144028      0.123755892070      0.125312982601
+  0.126889658920      0.128486167385      0.130102757455      0.131739681725
+  0.133397195967      0.135075559172      0.136775033587      0.138495884759
+  0.140238381574      0.142002796300      0.143789404632      0.145598485730
+  0.147430322267      0.149285200471      0.151163410170      0.153065244840
+  0.154991001644      0.156940981488      0.158915489058      0.160914832876
+  0.162939325343      0.164989282791      0.167065025529      0.169166877896
+  0.171295168312      0.173450229325      0.175632397669      0.177842014312
+  0.180079424511      0.182344977865      0.184639028373      0.186961934484
+  0.189314059156      0.191695769915      0.194107438907      0.196549442961
+  0.199022163645      0.201525987325      0.204061305231      0.206628513510
+  0.209228013294      0.211860210759      0.214525517194      0.217224349056
+  0.219957128044      0.222724281159      0.225526240777      0.228363444707
+  0.231236336270      0.234145364360      0.237090983519      0.240073654005
+  0.243093841868      0.246152019018      0.249248663300      0.252384258573
+  0.255559294779      0.258774268024      0.262029680654      0.265326041334
+  0.268663865127      0.272043673575      0.275465994780      0.278931363486
+  0.282440321165      0.285993416097      0.289591203463      0.293234245422
+  0.296923111208      0.300658377213      0.304440627081      0.308270451795
+  0.312148449774      0.316075226963      0.320051396929      0.324077580955
+  0.328154408142      0.332282515503      0.336462548062      0.340695158957
+  0.344981009544      0.349320769495      0.353715116906      0.358164738403
+  0.362670329248      0.367232593450      0.371852243870      0.376530002340
+  0.381266599768      0.386062776257      0.390919281219      0.395836873494
+  0.400816321465      0.405858403181      0.410963906478      0.416133629100
+  0.421368378828      0.426668973602      0.432036241650      0.437471021619
+  0.442974162705      0.448546524784      0.454188978549      0.459902405646
+  0.465687698809      0.471545762001      0.477477510557      0.483483871325
+  0.489565782811      0.495724195326      0.501960071134      0.508274384604
+  0.514668122360      0.521142283436      0.527697879434      0.534335934679
+  0.541057486379      0.547863584792      0.554755293384      0.561733688998
+  0.568799862024      0.575954916565      0.583199970612      0.590536156221
+  0.597964619684      0.605486521716      0.613103037628      0.620815357516
+  0.628624686446      0.636532244641      0.644539267674      0.652647006658
+  0.660856728445      0.669169715818      0.677587267701      0.686110699352
+  0.694741342575      0.703480545926      0.712329674922      0.721290112259
+  0.730363258023      0.739550529911      0.748853363453      0.758273212236
+  0.767811548130      0.777469861520      0.787249661538      0.797152476295
+  0.807179853129      0.817333358836      0.827614579922      0.838025122850
+  0.848566614287      0.859240701364      0.870049051927      0.880993354805
+  0.892075320066      0.903296679289      0.914659185836      0.926164615122
+  0.937814764891      0.949611455505      0.961556530221      0.973651855479
+  0.985899321201      0.998300841076       1.01085835287       1.02357381871
+   1.03644922543       1.04948658483       1.06268793402       1.07605533574
+   1.08959087867       1.10329667778       1.11717487462       1.13122763768
+   1.14545716274       1.15986567319       1.17445542040       1.18922868403
+   1.20418777244       1.21933502302       1.23467280256       1.25020350762
+   1.26592956489       1.28185343162       1.29797759593       1.31430457726
+   1.33083692673       1.34757722757       1.36452809546       1.38169217902
+   1.39907216018       1.41667075459       1.43449071207       1.45253481701
+   1.47080588886       1.48930678250       1.50804038873       1.52700963472
+   1.54621748445       1.56566693919       1.58536103796       1.60530285799
+   1.62549551523       1.64594216484       1.66664600164       1.68761026065
+   1.70883821757       1.73033318932       1.75209853453       1.77413765408
+   1.79645399163       1.81905103415       1.84193231247       1.86510140184
+   1.88856192249       1.91231754015       1.93637196670       1.96072896068
+   1.98539232794       2.01036592217       2.03565364554       2.06125944931
+   2.08718733445       2.11344135223       2.14002560490       2.16694424631
+   2.19420148254       2.22180157260       2.24974882905       2.27804761872
+   2.30670236334       2.33571754027       2.36509768321       2.39484738284
+   2.42497128763       2.45547410450       2.48636059958       2.51763559893
+   2.54930398935       2.58137071908       2.61384079862       2.64671930148
+   2.68001136499       2.71372219112       2.74785704723       2.78242126698
+   2.81742025109       2.85285946823       2.88874445584       2.92508082103
+   2.96187424143       2.99913046609       3.03685531636       3.07505468683
+   3.11373454624       3.15290093838       3.19255998308       3.23271787716
+   3.27338089536       3.31455539137       3.35624779878       3.39846463211
+   3.44121248784       3.48449804540       3.52832806825       3.57270940491
+   3.61764899007       3.66315384562       3.70923108179       3.75588789825
+   3.80313158521       3.85096952460       3.89940919119       3.94845815377
+   3.99812407636       4.04841471935       4.09933794075       4.15090169743
+   4.20311404632       4.25598314571       4.30951725651       4.36372474352
+   4.41861407678       4.47419383287       4.53047269622       4.58745946052
+   4.64516303008       4.70359242119       4.76275676357       4.82266530176
+   4.88332739659       4.94475252665       5.00695028972       5.06993040435
+   5.13370271129       5.19827717511       5.26366388569       5.32987305985
+   5.39691504289       5.46480031026       5.53353946918       5.60314326029
+   5.67362255930       5.74498837876       5.81725186973       5.89042432351
+   5.96451717345       6.03954199672       6.11551051610       6.19243460181
+   6.27032627341       6.34919770162       6.42906121027       6.50992927820
+   6.59181454120       6.67472979401       6.75868799231       6.84370225474
+   6.92978586495       7.01695227368       7.10521510085       7.19458813772
+   7.28508534901       7.37672087508       7.46950903418       7.56346432464
+   7.65860142716       7.75493520712       7.85248071687       7.95125319808
+   8.05126808416       8.15254100263       8.25508777761       8.35892443222
+   8.46406719116       8.57053248320       8.67833694376       8.78749741750
+   8.89803096097       9.00995484526       9.12328655870       9.23804380961
+   9.35424452904       9.47190687359       9.59104922824       9.71169020922
+   9.83384866693       9.95754368889       10.0827946027       10.2096209790
+   10.3380426348       10.4680796361       10.5997523016       10.7330812053
+   10.8680871802       11.0047913212       11.1432149885       11.2833798113
+   11.4253076905       11.5690208027       11.7145416033       11.8618928302
+   12.0110975074       12.1621789484       12.3151607599       12.4700668458
+   12.6269214104       12.7857489625       12.9465743193       13.1094226100
+   13.2743192801       13.4412900949       13.6103611440       13.7815588452
+   13.9549099483       14.1304415399       14.3081810471       14.4881562421
+   14.6703952463       14.8549265350       15.0417789416       15.2309816622
+   15.4225642600       15.6165566702       15.8129892045       16.0118925560
+   16.2132978036       16.4172364174       16.6237402631       16.8328416075
+   17.0445731230       17.2589678931       17.4760594174       17.6958816170
+   17.9184688394       18.1438558644       18.3720779092       18.6031706339
+   18.8371701473       19.0741130122       19.3140362514       19.5569773535
+   19.8029742785       20.0520654638       20.3042898306       20.5596867893
+   20.8182962463       21.0801586099       21.3453147965       21.6138062373
+   21.8856748847       22.1609632187       22.4397142537       22.7219715451
+   23.0077791961       23.2971818648       23.5902247710       23.8869537031
+   24.1874150258       24.4916556866       24.7997232238       25.1116657737
+   25.4275320777       25.7473714908       26.0712339885       26.3991701748
+   26.7312312906       27.0674692211       27.4079365040       27.7526863382
+   28.1017725915       28.4552498093       28.8131732231       29.1755987593
+   29.5425830475       29.9141834298       30.2904579695       30.6714654602
+   31.0572654352       31.4479181765       31.8434847244       32.2440268869
+   32.6496072496       33.0602891853       33.4761368638       33.8972152621
+   34.3235901747       34.7553282234       35.1924968683       35.6351644178
+   36.0834000396       36.5372737715       36.9968565321       37.4622201322
+   37.9334372857       38.4105816215       38.8937276941       39.3829509961
+   39.8783279698       40.3799360187       40.8878535202       41.4021598374
+   41.9229353316       42.4502613751       42.9842203638       43.5248957297
+   44.0723719545       44.6267345824       45.1880702338       45.7564666185
+   46.3320125496       46.9147979572       47.5049139029       48.1024525934
+   48.7075073954       49.3201728499       49.9405446871       50.5687198414
+   51.2047964664       51.8488739505       52.5010529319       53.1614353151
+   53.8301242861       54.5072243289       55.1928412418       55.8870821538
+   56.5900555414       57.3018712458       58.0226404895       58.7524758941
+   59.4914914981       60.2398027740       60.9975266471       61.7647815132
+   62.5416872574       63.3283652729       64.1249384796       64.9315313439
+   65.7482698974       66.5752817572       67.4126961456       68.2606439104
+   69.1192575450       69.9886712096       70.8690207518       71.7604437281
+   72.6630794251       73.5770688815       74.5025549100       75.4396821196
+   76.3885969384       77.3494476363       78.3223843481       79.3075590972
+   80.3051258192       81.3152403858       82.3380606296       83.3737463682
+   84.4224594297       85.4843636776       86.5596250366       87.6484115186
+   88.7508932485       89.8672424915       90.9976336793       92.1422434379
+   93.3012506148       94.4748363074       95.6631838907       96.8664790466
+   98.0849097922       99.3186665099       100.567941977       101.832931394
+   103.113832420       104.410845198       105.724172387       107.054019199
+   108.400593425       109.764105470       111.144768384       112.542797900
+   113.958412463       115.391833265       116.843284281       118.312992303
+   119.801186976
+ Down Pseudopotential follows (l on next line)
+  0
+ -0.215091591172E-06 -0.432888701499E-06 -0.653425362225E-06 -0.876736032651E-06
+ -0.110285560552E-05 -0.133181941248E-05 -0.156366322959E-05 -0.179842328292E-05
+ -0.203613625421E-05 -0.227683928658E-05 -0.252056999038E-05 -0.276736644903E-05
+ -0.301726722497E-05 -0.327031136571E-05 -0.352653840992E-05 -0.378598839358E-05
+ -0.404870185628E-05 -0.431471984755E-05 -0.458408393322E-05 -0.485683620200E-05
+ -0.513301927197E-05 -0.541267629729E-05 -0.569585097496E-05 -0.598258755159E-05
+ -0.627293083034E-05 -0.656692617796E-05 -0.686461953181E-05 -0.716605740708E-05
+ -0.747128690406E-05 -0.778035571547E-05 -0.809331213394E-05 -0.841020505956E-05
+ -0.873108400748E-05 -0.905599911569E-05 -0.938500115285E-05 -0.971814152618E-05
+ -0.100554722895E-04 -0.103970461516E-04 -0.107429164839E-04 -0.110931373294E-04
+ -0.114477634108E-04 -0.118068501392E-04 -0.121704536226E-04 -0.125386306748E-04
+ -0.129114388242E-04 -0.132889363228E-04 -0.136711821555E-04 -0.140582360488E-04
+ -0.144501584807E-04 -0.148470106899E-04 -0.152488546855E-04 -0.156557532562E-04
+ -0.160677699809E-04 -0.164849692379E-04 -0.169074162156E-04 -0.173351769221E-04
+ -0.177683181960E-04 -0.182069077163E-04 -0.186510140136E-04 -0.191007064805E-04
+ -0.195560553823E-04 -0.200171318681E-04 -0.204840079822E-04 -0.209567566748E-04
+ -0.214354518139E-04 -0.219201681967E-04 -0.224109815609E-04 -0.229079685972E-04
+ -0.234112069609E-04 -0.239207752839E-04 -0.244367531873E-04 -0.249592212938E-04
+ -0.254882612400E-04 -0.260239556895E-04 -0.265663883456E-04 -0.271156439646E-04
+ -0.276718083687E-04 -0.282349684599E-04 -0.288052122329E-04 -0.293826287895E-04
+ -0.299673083523E-04 -0.305593422786E-04 -0.311588230748E-04 -0.317658444112E-04
+ -0.323805011361E-04 -0.330028892907E-04 -0.336331061244E-04 -0.342712501101E-04
+ -0.349174209589E-04 -0.355717196363E-04 -0.362342483779E-04 -0.369051107051E-04
+ -0.375844114415E-04 -0.382722567292E-04 -0.389687540455E-04 -0.396740122195E-04
+ -0.403881414491E-04 -0.411112533186E-04 -0.418434608156E-04 -0.425848783490E-04
+ -0.433356217669E-04 -0.440958083744E-04 -0.448655569521E-04 -0.456449877750E-04
+ -0.464342226306E-04 -0.472333848384E-04 -0.480425992693E-04 -0.488619923645E-04
+ -0.496916921560E-04 -0.505318282859E-04 -0.513825320273E-04 -0.522439363044E-04
+ -0.531161757132E-04 -0.539993865431E-04 -0.548937067974E-04 -0.557992762155E-04
+ -0.567162362945E-04 -0.576447303112E-04 -0.585849033447E-04 -0.595369022990E-04
+ -0.605008759257E-04 -0.614769748479E-04 -0.624653515827E-04 -0.634661605662E-04
+ -0.644795581768E-04 -0.655057027598E-04 -0.665447546525E-04 -0.675968762089E-04
+ -0.686622318249E-04 -0.697409879646E-04 -0.708333131858E-04 -0.719393781666E-04
+ -0.730593557318E-04 -0.741934208802E-04 -0.753417508118E-04 -0.765045249553E-04
+ -0.776819249967E-04 -0.788741349070E-04 -0.800813409715E-04 -0.813037318185E-04
+ -0.825414984491E-04 -0.837948342668E-04 -0.850639351078E-04 -0.863489992718E-04
+ -0.876502275525E-04 -0.889678232695E-04 -0.903019922998E-04 -0.916529431100E-04
+ -0.930208867888E-04 -0.944060370803E-04 -0.958086104169E-04 -0.972288259535E-04
+ -0.986669056016E-04 -0.100123074064E-03 -0.101597558870E-03 -0.103090590411E-03
+ -0.104602401976E-03 -0.106133229789E-03 -0.107683313044E-03 -0.109252893945E-03
+ -0.110842217743E-03 -0.112451532772E-03 -0.114081090491E-03 -0.115731145521E-03
+ -0.117401955688E-03 -0.119093782058E-03 -0.120806888982E-03 -0.122541544138E-03
+ -0.124298018568E-03 -0.126076586726E-03 -0.127877526515E-03 -0.129701119336E-03
+ -0.131547650130E-03 -0.133417407420E-03 -0.135310683359E-03 -0.137227773777E-03
+ -0.139168978221E-03 -0.141134600010E-03 -0.143124946275E-03 -0.145140328012E-03
+ -0.147181060128E-03 -0.149247461491E-03 -0.151339854982E-03 -0.153458567541E-03
+ -0.155603930219E-03 -0.157776278236E-03 -0.159975951024E-03 -0.162203292287E-03
+ -0.164458650051E-03 -0.166742376720E-03 -0.169054829131E-03 -0.171396368609E-03
+ -0.173767361024E-03 -0.176168176849E-03 -0.178599191215E-03 -0.181060783974E-03
+ -0.183553339754E-03 -0.186077248021E-03 -0.188632903142E-03 -0.191220704442E-03
+ -0.193841056271E-03 -0.196494368063E-03 -0.199181054403E-03 -0.201901535092E-03
+ -0.204656235210E-03 -0.207445585184E-03 -0.210270020855E-03 -0.213129983547E-03
+ -0.216025920134E-03 -0.218958283113E-03 -0.221927530670E-03 -0.224934126756E-03
+ -0.227978541157E-03 -0.231061249570E-03 -0.234182733672E-03 -0.237343481202E-03
+ -0.240543986033E-03 -0.243784748249E-03 -0.247066274227E-03 -0.250389076709E-03
+ -0.253753674891E-03 -0.257160594497E-03 -0.260610367865E-03 -0.264103534028E-03
+ -0.267640638800E-03 -0.271222234860E-03 -0.274848881840E-03 -0.278521146409E-03
+ -0.282239602366E-03 -0.286004830725E-03 -0.289817419812E-03 -0.293677965350E-03
+ -0.297587070556E-03 -0.301545346235E-03 -0.305553410875E-03 -0.309611890743E-03
+ -0.313721419984E-03 -0.317882640719E-03 -0.322096203146E-03 -0.326362765643E-03
+ -0.330682994866E-03 -0.335057565860E-03 -0.339487162158E-03 -0.343972475894E-03
+ -0.348514207904E-03 -0.353113067844E-03 -0.357769774291E-03 -0.362485054865E-03
+ -0.367259646337E-03 -0.372094294744E-03 -0.376989755509E-03 -0.381946793556E-03
+ -0.386966183429E-03 -0.392048709417E-03 -0.397195165674E-03 -0.402406356341E-03
+ -0.407683095676E-03 -0.413026208177E-03 -0.418436528715E-03 -0.423914902661E-03
+ -0.429462186019E-03 -0.435079245563E-03 -0.440766958965E-03 -0.446526214940E-03
+ -0.452357913380E-03 -0.458262965498E-03 -0.464242293968E-03 -0.470296833067E-03
+ -0.476427528827E-03 -0.482635339178E-03 -0.488921234100E-03 -0.495286195772E-03
+ -0.501731218731E-03 -0.508257310018E-03 -0.514865489346E-03 -0.521556789252E-03
+ -0.528332255260E-03 -0.535192946046E-03 -0.542139933603E-03 -0.549174303406E-03
+ -0.556297154585E-03 -0.563509600096E-03 -0.570812766890E-03 -0.578207796098E-03
+ -0.585695843201E-03 -0.593278078217E-03 -0.600955685878E-03 -0.608729865820E-03
+ -0.616601832767E-03 -0.624572816723E-03 -0.632644063163E-03 -0.640816833228E-03
+ -0.649092403922E-03 -0.657472068311E-03 -0.665957135726E-03 -0.674548931968E-03
+ -0.683248799512E-03 -0.692058097720E-03 -0.700978203055E-03 -0.710010509289E-03
+ -0.719156427728E-03 -0.728417387430E-03 -0.737794835425E-03 -0.747290236948E-03
+ -0.756905075662E-03 -0.766640853891E-03 -0.776499092858E-03 -0.786481332917E-03
+ -0.796589133800E-03 -0.806824074856E-03 -0.817187755299E-03 -0.827681794459E-03
+ -0.838307832034E-03 -0.849067528346E-03 -0.859962564602E-03 -0.870994643153E-03
+ -0.882165487764E-03 -0.893476843883E-03 -0.904930478910E-03 -0.916528182476E-03
+ -0.928271766724E-03 -0.940163066588E-03 -0.952203940083E-03 -0.964396268595E-03
+ -0.976741957171E-03 -0.989242934825E-03 -0.100190115483E-02 -0.101471859503E-02
+ -0.102769725814E-02 -0.104083917207E-02 -0.105414639025E-02 -0.106762099191E-02
+ -0.108126508245E-02 -0.109508079376E-02 -0.110907028452E-02 -0.112323574059E-02
+ -0.113757937529E-02 -0.115210342982E-02 -0.116681017353E-02 -0.118170190434E-02
+ -0.119678094906E-02 -0.121204966378E-02 -0.122751043420E-02 -0.124316567605E-02
+ -0.125901783544E-02 -0.127506938924E-02 -0.129132284547E-02 -0.130778074370E-02
+ -0.132444565546E-02 -0.134132018460E-02 -0.135840696772E-02 -0.137570867460E-02
+ -0.139322800858E-02 -0.141096770702E-02 -0.142893054170E-02 -0.144711931926E-02
+ -0.146553688164E-02 -0.148418610654E-02 -0.150306990783E-02 -0.152219123605E-02
+ -0.154155307884E-02 -0.156115846141E-02 -0.158101044705E-02 -0.160111213753E-02
+ -0.162146667368E-02 -0.164207723580E-02 -0.166294704420E-02 -0.168407935970E-02
+ -0.170547748413E-02 -0.172714476084E-02 -0.174908457522E-02 -0.177130035527E-02
+ -0.179379557209E-02 -0.181657374041E-02 -0.183963841921E-02 -0.186299321220E-02
+ -0.188664176842E-02 -0.191058778281E-02 -0.193483499678E-02 -0.195938719879E-02
+ -0.198424822495E-02 -0.200942195962E-02 -0.203491233600E-02 -0.206072333676E-02
+ -0.208685899467E-02 -0.211332339322E-02 -0.214012066723E-02 -0.216725500355E-02
+ -0.219473064167E-02 -0.222255187441E-02 -0.225072304855E-02 -0.227924856558E-02
+ -0.230813288231E-02 -0.233738051160E-02 -0.236699602309E-02 -0.239698404387E-02
+ -0.242734925922E-02 -0.245809641333E-02 -0.248923031008E-02 -0.252075581375E-02
+ -0.255267784979E-02 -0.258500140558E-02 -0.261773153124E-02 -0.265087334039E-02
+ -0.268443201094E-02 -0.271841278594E-02 -0.275282097436E-02 -0.278766195193E-02
+ -0.282294116197E-02 -0.285866411628E-02 -0.289483639594E-02 -0.293146365222E-02
+ -0.296855160746E-02 -0.300610605596E-02 -0.304413286487E-02 -0.308263797510E-02
+ -0.312162740230E-02 -0.316110723774E-02 -0.320108364929E-02 -0.324156288235E-02
+ -0.328255126089E-02 -0.332405518837E-02 -0.336608114876E-02 -0.340863570756E-02
+ -0.345172551285E-02 -0.349535729625E-02 -0.353953787405E-02 -0.358427414823E-02
+ -0.362957310754E-02 -0.367544182861E-02 -0.372188747704E-02 -0.376891730851E-02
+ -0.381653866992E-02 -0.386475900054E-02 -0.391358583316E-02 -0.396302679527E-02
+ -0.401308961026E-02 -0.406378209859E-02 -0.411511217906E-02 -0.416708786998E-02
+ -0.421971729049E-02 -0.427300866178E-02 -0.432697030837E-02 -0.438161065943E-02
+ -0.443693825008E-02 -0.449296172273E-02 -0.454968982840E-02 -0.460713142813E-02
+ -0.466529549430E-02 -0.472419111208E-02 -0.478382748081E-02 -0.484421391548E-02
+ -0.490535984811E-02 -0.496727482927E-02 -0.502996852955E-02 -0.509345074107E-02
+ -0.515773137900E-02 -0.522282048311E-02 -0.528872821933E-02 -0.535546488130E-02
+ -0.542304089204E-02 -0.549146680550E-02 -0.556075330826E-02 -0.563091122112E-02
+ -0.570195150089E-02 -0.577388524196E-02 -0.584672367816E-02 -0.592047818438E-02
+ -0.599516027844E-02 -0.607078162283E-02 -0.614735402650E-02 -0.622488944675E-02
+ -0.630339999106E-02 -0.638289791895E-02 -0.646339564391E-02 -0.654490573532E-02
+ -0.662744092039E-02 -0.671101408615E-02 -0.679563828143E-02 -0.688132671890E-02
+ -0.696809277711E-02 -0.705595000257E-02 -0.714491211182E-02 -0.723499299360E-02
+ -0.732620671096E-02 -0.741856750348E-02 -0.751208978942E-02 -0.760678816800E-02
+ -0.770267742160E-02 -0.779977251813E-02 -0.789808861326E-02 -0.799764105280E-02
+ -0.809844537507E-02 -0.820051731330E-02 -0.830387279803E-02 -0.840852795962E-02
+ -0.851449913068E-02 -0.862180284861E-02 -0.873045585817E-02 -0.884047511402E-02
+ -0.895187778335E-02 -0.906468124852E-02 -0.917890310973E-02 -0.929456118770E-02
+ -0.941167352646E-02 -0.953025839607E-02 -0.965033429544E-02 -0.977191995517E-02
+ -0.989503434038E-02 -0.100196966537E-01 -0.101459263381E-01 -0.102737430799E-01
+ -0.104031668119E-01 -0.105342177162E-01 -0.106669162273E-01 -0.108012830356E-01
+ -0.109373390898E-01 -0.110751056010E-01 -0.112146040451E-01 -0.113558561665E-01
+ -0.114988839814E-01 -0.116437097809E-01 -0.117903561345E-01 -0.119388458937E-01
+ -0.120892021949E-01 -0.122414484637E-01 -0.123956084174E-01 -0.125517060696E-01
+ -0.127097657331E-01 -0.128698120238E-01 -0.130318698641E-01 -0.131959644873E-01
+ -0.133621214405E-01 -0.135303665890E-01 -0.137007261198E-01 -0.138732265457E-01
+ -0.140478947091E-01 -0.142247577859E-01 -0.144038432897E-01 -0.145851790756E-01
+ -0.147687933442E-01 -0.149547146463E-01 -0.151429718861E-01 -0.153335943264E-01
+ -0.155266115919E-01 -0.157220536742E-01 -0.159199509356E-01 -0.161203341139E-01
+ -0.163232343261E-01 -0.165286830737E-01 -0.167367122463E-01 -0.169473541265E-01
+ -0.171606413946E-01 -0.173766071327E-01 -0.175952848295E-01 -0.178167083850E-01
+ -0.180409121150E-01 -0.182679307558E-01 -0.184977994689E-01 -0.187305538459E-01
+ -0.189662299129E-01 -0.192048641354E-01 -0.194464934234E-01 -0.196911551358E-01
+ -0.199388870854E-01 -0.201897275437E-01 -0.204437152458E-01 -0.207008893953E-01
+ -0.209612896690E-01 -0.212249562219E-01 -0.214919296920E-01 -0.217622512053E-01
+ -0.220359623804E-01 -0.223131053335E-01 -0.225937226835E-01 -0.228778575560E-01
+ -0.231655535890E-01 -0.234568549371E-01 -0.237518062762E-01 -0.240504528084E-01
+ -0.243528402665E-01 -0.246590149184E-01 -0.249690235717E-01 -0.252829135781E-01
+ -0.256007328379E-01 -0.259225298037E-01 -0.262483534850E-01 -0.265782534521E-01
+ -0.269122798398E-01 -0.272504833512E-01 -0.275929152616E-01 -0.279396274213E-01
+ -0.282906722595E-01 -0.286461027868E-01 -0.290059725986E-01 -0.293703358770E-01
+ -0.297392473938E-01 -0.301127625122E-01 -0.304909371889E-01 -0.308738279753E-01
+ -0.312614920188E-01 -0.316539870637E-01 -0.320513714512E-01 -0.324537041201E-01
+ -0.328610446056E-01 -0.332734530389E-01 -0.336909901456E-01 -0.341137172437E-01
+ -0.345416962410E-01 -0.349749896319E-01 -0.354136604938E-01 -0.358577724821E-01
+ -0.363073898254E-01 -0.367625773189E-01 -0.372234003175E-01 -0.376899247284E-01
+ -0.381622170013E-01 -0.386403441192E-01 -0.391243735872E-01 -0.396143734202E-01
+ -0.401104121293E-01 -0.406125587073E-01 -0.411208826123E-01 -0.416354537502E-01
+ -0.421563424553E-01 -0.426836194691E-01 -0.432173559181E-01 -0.437576232885E-01
+ -0.443044934004E-01 -0.448580383781E-01 -0.454183306199E-01 -0.459854427643E-01
+ -0.465594476542E-01 -0.471404182986E-01 -0.477284278311E-01 -0.483235494657E-01
+ -0.489258564496E-01 -0.495354220125E-01 -0.501523193122E-01 -0.507766213777E-01
+ -0.514084010467E-01 -0.520477309011E-01 -0.526946831962E-01 -0.533493297875E-01
+ -0.540117420510E-01 -0.546819908001E-01 -0.553601461966E-01 -0.560462776565E-01
+ -0.567404537500E-01 -0.574427420965E-01 -0.581532092522E-01 -0.588719205926E-01
+ -0.595989401875E-01 -0.603343306694E-01 -0.610781530948E-01 -0.618304667983E-01
+ -0.625913292381E-01 -0.633607958347E-01 -0.641389198002E-01 -0.649257519604E-01
+ -0.657213405667E-01 -0.665257311001E-01 -0.673389660653E-01 -0.681610847759E-01
+ -0.689921231295E-01 -0.698321133730E-01 -0.706810838582E-01 -0.715390587868E-01
+ -0.724060579459E-01 -0.732820964323E-01 -0.741671843674E-01 -0.750613266010E-01
+ -0.759645224059E-01 -0.768767651611E-01 -0.777980420269E-01 -0.787283336083E-01
+ -0.796676136112E-01 -0.806158484883E-01 -0.815729970774E-01 -0.825390102316E-01
+ -0.835138304427E-01 -0.844973914584E-01 -0.854896178935E-01 -0.864904248379E-01
+ -0.874997174605E-01 -0.885173906112E-01 -0.895433284232E-01 -0.905774039151E-01
+ -0.916194785968E-01 -0.926694020787E-01 -0.937270116882E-01 -0.947921320938E-01
+ -0.958645749400E-01 -0.969441384954E-01 -0.980306073153E-01 -0.991237519225E-01
+ -0.100223328508     -0.101329078657     -0.102440729094     -0.103557991468
+ -0.104680562157     -0.105808122115     -0.106940336754     -0.108076855864
+ -0.109217313581     -0.110361328398     -0.111508503221     -0.112658425487
+ -0.113810667325     -0.114964785779     -0.116120323090     -0.117276807038
+ -0.118433751347     -0.119590656160     -0.120747008568     -0.121902283227
+ -0.123055943028     -0.124207439847     -0.125356215372     -0.126501701993
+ -0.127643323775     -0.128780497514     -0.129912633856     -0.131039138509
+ -0.132159413532     -0.133272858705     -0.134378872987     -0.135476856062
+ -0.136566209968     -0.137646340832     -0.138716660686     -0.139776589397
+ -0.140825556691     -0.141863004295     -0.142888388192     -0.143901180993
+ -0.144900874451     -0.145886982096     -0.146859042031     -0.147816619874
+ -0.148759311869     -0.149686748177     -0.150598596352     -0.151494565021
+ -0.152374407785     -0.153237927345     -0.154084979879     -0.154915479685
+ -0.155729404105     -0.156526798749     -0.157307783042     -0.158072556112
+ -0.158821403047     -0.159554701530     -0.160272928893     -0.160976669607
+ -0.161666623231     -0.162343612853     -0.163008594052     -0.163662664406
+ -0.164307073580     -0.164943234028     -0.165572732336     -0.166197341248
+ -0.166819032409     -0.167439989854     -0.168062624297     -0.168689588248
+ -0.169323791999     -0.169968420528     -0.170626951363     -0.171303173448
+ -0.172001207057     -0.172725524806     -0.173480973817     -0.174272799065
+ -0.175106667985     -0.175988696368     -0.176925475607     -0.177924101354
+ -0.178992203623     -0.180137978411     -0.181370220876     -0.182698360140
+ -0.184132495750     -0.185683435873     -0.187362737250     -0.189182746977
+ -0.191156646149     -0.193298495415     -0.195623282474     -0.198146971562
+ -0.200886554947     -0.203860106456     -0.207086837061     -0.210587152522
+ -0.214382713083     -0.218496495219     -0.222952855398     -0.227777595828
+ -0.232998032117     -0.238643062794     -0.244743240573     -0.251330845261
+ -0.258439958153     -0.266106537750     -0.274368496588     -0.283265778952
+ -0.292840439177     -0.303136720237     -0.314201132229     -0.326082530357
+ -0.338832191917     -0.352503891750     -0.367153975569     -0.382841430452
+ -0.399627951766     -0.417578005656     -0.436758886172     -0.457240765980
+ -0.479096739521     -0.502402857345     -0.527238150240     -0.553684641646
+ -0.581827346685     -0.611754256035     -0.643556302682     -0.677327309470
+ -0.713163915157     -0.751165476584     -0.791433944330     -0.834073709115
+ -0.879191415998     -0.926895743294     -0.977297142946      -1.03050753896
+  -1.08663998037      -1.14580824511      -1.20812639104      -1.27370825033
+  -1.34266686346      -1.41511384903      -1.49115870563      -1.57090804236
+  -1.65446473454      -1.74192700177      -1.83338740562      -1.92893176492
+  -2.02863798733      -2.13257481649      -2.24080049515      -2.35336134577
+  -2.47029027137      -2.59160518093      -2.71730734554      -2.84737969310
+  -2.98178505201      -3.12046435640      -3.26333482827      -3.41028815491
+  -3.56118868298      -3.71587165409      -3.87414151038      -4.03577030227
+  -4.20049623429      -4.36802238918      -4.53801567400      -4.71010603610
+  -4.88388600033      -5.05891058228      -5.23469763525      -5.41072869100
+  -5.58645035574      -5.76127632349      -5.93459006833      -6.10574827473
+  -6.27408506140      -6.43891704833      -6.59954930817      -6.75528223255
+  -6.90541932985      -7.04927595399      -7.18618894288      -7.31552712082
+  -7.43670258996      -7.54918270298      -7.65250257078      -7.74627791569
+  -7.83021803213      -7.90413856113      -7.96797372341      -8.02178758502
+  -8.06578384927      -8.10031357593      -8.12588011988      -8.14314045320
+  -8.15290187988      -8.15611307484      -8.15384727677      -8.14727739852
+  -8.13763880891      -8.12617899431      -8.11409040442      -8.10242294229
+  -8.09197172389      -8.08313489634      -8.07573534921      -8.06907988859
+  -8.06294275902      -8.05729109750      -8.05209305702      -8.04731815410
+  -8.04293729541      -8.03892279193      -8.03524836136      -8.03188912023
+  -8.02882156674      -8.02602355582      -8.02347426721      -8.02115416805
+  -8.01904497075      -8.01712958724      -8.01539208048      -8.01381761390
+  -8.01239239967      -8.01110364621      -8.00993950565      -8.00888902161
+  -8.00794207771      -8.00708934716      -8.00632224365      -8.00563287385
+  -8.00501399153      -8.00445895360      -8.00396167805      -8.00351660389
+  -8.00311865306      -8.00276319445      -8.00244600985      -8.00216326193
+  -8.00191146417      -8.00168745267      -8.00148835976      -8.00131158940
+  -8.00115479433      -8.00101585468      -8.00066421518      -8.00043231293
+  -8.00028008133      -8.00018061388      -8.00011592679      -8.00007405720
+  -8.00004708545      -8.00002979393      -8.00001876189      -8.00001175761
+  -8.00000733234      -8.00000455024      -8.00000280984      -8.00000172653
+  -8.00000105560      -8.00000064217      -8.00000038870      -8.00000023409
+  -8.00000014027      -8.00000008362      -8.00000004960      -8.00000002927
+  -8.00000001719      -8.00000001004      -8.00000000583      -8.00000000337
+  -8.00000000194      -8.00000000111      -8.00000000063      -8.00000000036
+  -8.00000000020      -8.00000000011      -8.00000000006      -8.00000000004
+  -8.00000000002      -8.00000000001      -8.00000000001      -8.00000000000
+  -8.00000000000      -8.00000000000      -8.00000000000      -8.00000000000
+  -8.00000000000
+  1
+ -0.267095587790E-05 -0.537550824488E-05 -0.811407969275E-05 -0.108870981289E-04
+ -0.136949968430E-04 -0.165382145750E-04 -0.194171955836E-04 -0.223323897152E-04
+ -0.252842524749E-04 -0.282732450973E-04 -0.312998346185E-04 -0.343644939494E-04
+ -0.374677019492E-04 -0.406099435004E-04 -0.437917095847E-04 -0.470134973595E-04
+ -0.502758102356E-04 -0.535791579563E-04 -0.569240566761E-04 -0.603110290424E-04
+ -0.637406042764E-04 -0.672133182564E-04 -0.707297136009E-04 -0.742903397538E-04
+ -0.778957530702E-04 -0.815465169033E-04 -0.852432016923E-04 -0.889863850519E-04
+ -0.927766518619E-04 -0.966145943593E-04 -0.100500812230E-03 -0.104435912705E-03
+ -0.108420510650E-03 -0.112455228667E-03 -0.116540697189E-03 -0.120677554579E-03
+ -0.124866447229E-03 -0.129108029662E-03 -0.133402964635E-03 -0.137751923239E-03
+ -0.142155585008E-03 -0.146614638023E-03 -0.151129779020E-03 -0.155701713500E-03
+ -0.160331155835E-03 -0.165018829387E-03 -0.169765466614E-03 -0.174571809187E-03
+ -0.179438608107E-03 -0.184366623821E-03 -0.189356626342E-03 -0.194409395368E-03
+ -0.199525720405E-03 -0.204706400888E-03 -0.209952246309E-03 -0.215264076343E-03
+ -0.220642720973E-03 -0.226089020625E-03 -0.231603826292E-03 -0.237187999675E-03
+ -0.242842413313E-03 -0.248567950718E-03 -0.254365506519E-03 -0.260235986594E-03
+ -0.266180308218E-03 -0.272199400203E-03 -0.278294203046E-03 -0.284465669070E-03
+ -0.290714762581E-03 -0.297042460012E-03 -0.303449750078E-03 -0.309937633932E-03
+ -0.316507125318E-03 -0.323159250734E-03 -0.329895049586E-03 -0.336715574358E-03
+ -0.343621890771E-03 -0.350615077949E-03 -0.357696228594E-03 -0.364866449149E-03
+ -0.372126859975E-03 -0.379478595527E-03 -0.386922804529E-03 -0.394460650153E-03
+ -0.402093310202E-03 -0.409821977297E-03 -0.417647859055E-03 -0.425572178288E-03
+ -0.433596173187E-03 -0.441721097516E-03 -0.449948220812E-03 -0.458278828580E-03
+ -0.466714222494E-03 -0.475255720601E-03 -0.483904657529E-03 -0.492662384690E-03
+ -0.501530270498E-03 -0.510509700578E-03 -0.519602077984E-03 -0.528808823418E-03
+ -0.538131375454E-03 -0.547571190758E-03 -0.557129744322E-03 -0.566808529688E-03
+ -0.576609059187E-03 -0.586532864171E-03 -0.596581495256E-03 -0.606756522559E-03
+ -0.617059535950E-03 -0.627492145296E-03 -0.638055980712E-03 -0.648752692820E-03
+ -0.659583953003E-03 -0.670551453667E-03 -0.681656908507E-03 -0.692902052772E-03
+ -0.704288643539E-03 -0.715818459986E-03 -0.727493303670E-03 -0.739314998810E-03
+ -0.751285392569E-03 -0.763406355345E-03 -0.775679781065E-03 -0.788107587474E-03
+ -0.800691716444E-03 -0.813434134270E-03 -0.826336831981E-03 -0.839401825650E-03
+ -0.852631156708E-03 -0.866026892266E-03 -0.879591125433E-03 -0.893325975650E-03
+ -0.907233589015E-03 -0.921316138620E-03 -0.935575824892E-03 -0.950014875937E-03
+ -0.964635547885E-03 -0.979440125246E-03 -0.994430921266E-03 -0.100961027829E-02
+ -0.102498056811E-02 -0.104054419239E-02 -0.105630358295E-02 -0.107226120225E-02
+ -0.108841954368E-02 -0.110478113203E-02 -0.112134852383E-02 -0.113812430776E-02
+ -0.115511110507E-02 -0.117231156999E-02 -0.118972839013E-02 -0.120736428689E-02
+ -0.122522201592E-02 -0.124330436754E-02 -0.126161416713E-02 -0.128015427565E-02
+ -0.129892759003E-02 -0.131793704363E-02 -0.133718560672E-02 -0.135667628693E-02
+ -0.137641212971E-02 -0.139639621884E-02 -0.141663167686E-02 -0.143712166560E-02
+ -0.145786938668E-02 -0.147887808196E-02 -0.150015103409E-02 -0.152169156702E-02
+ -0.154350304650E-02 -0.156558888061E-02 -0.158795252032E-02 -0.161059745998E-02
+ -0.163352723792E-02 -0.165674543696E-02 -0.168025568499E-02 -0.170406165553E-02
+ -0.172816706831E-02 -0.175257568986E-02 -0.177729133407E-02 -0.180231786281E-02
+ -0.182765918653E-02 -0.185331926486E-02 -0.187930210724E-02 -0.190561177354E-02
+ -0.193225237470E-02 -0.195922807336E-02 -0.198654308455E-02 -0.201420167627E-02
+ -0.204220817025E-02 -0.207056694255E-02 -0.209928242429E-02 -0.212835910232E-02
+ -0.215780151994E-02 -0.218761427757E-02 -0.221780203353E-02 -0.224836950471E-02
+ -0.227932146734E-02 -0.231066275772E-02 -0.234239827301E-02 -0.237453297193E-02
+ -0.240707187560E-02 -0.244002006829E-02 -0.247338269822E-02 -0.250716497836E-02
+ -0.254137218728E-02 -0.257600966991E-02 -0.261108283842E-02 -0.264659717309E-02
+ -0.268255822308E-02 -0.271897160739E-02 -0.275584301569E-02 -0.279317820919E-02
+ -0.283098302162E-02 -0.286926336003E-02 -0.290802520582E-02 -0.294727461561E-02
+ -0.298701772218E-02 -0.302726073548E-02 -0.306800994356E-02 -0.310927171357E-02
+ -0.315105249275E-02 -0.319335880942E-02 -0.323619727404E-02 -0.327957458019E-02
+ -0.332349750567E-02 -0.336797291354E-02 -0.341300775315E-02 -0.345860906129E-02
+ -0.350478396327E-02 -0.355153967400E-02 -0.359888349915E-02 -0.364682283630E-02
+ -0.369536517606E-02 -0.374451810327E-02 -0.379428929818E-02 -0.384468653763E-02
+ -0.389571769630E-02 -0.394739074790E-02 -0.399971376645E-02 -0.405269492754E-02
+ -0.410634250958E-02 -0.416066489510E-02 -0.421567057209E-02 -0.427136813529E-02
+ -0.432776628757E-02 -0.438487384125E-02 -0.444269971950E-02 -0.450125295772E-02
+ -0.456054270498E-02 -0.462057822542E-02 -0.468136889972E-02 -0.474292422653E-02
+ -0.480525382400E-02 -0.486836743126E-02 -0.493227490992E-02 -0.499698624567E-02
+ -0.506251154978E-02 -0.512886106071E-02 -0.519604514570E-02 -0.526407430240E-02
+ -0.533295916050E-02 -0.540271048341E-02 -0.547333916989E-02 -0.554485625584E-02
+ -0.561727291592E-02 -0.569060046540E-02 -0.576485036184E-02 -0.584003420694E-02
+ -0.591616374833E-02 -0.599325088140E-02 -0.607130765117E-02 -0.615034625415E-02
+ -0.623037904030E-02 -0.631141851489E-02 -0.639347734051E-02 -0.647656833899E-02
+ -0.656070449349E-02 -0.664589895044E-02 -0.673216502164E-02 -0.681951618633E-02
+ -0.690796609331E-02 -0.699752856306E-02 -0.708821758988E-02 -0.718004734411E-02
+ -0.727303217433E-02 -0.736718660961E-02 -0.746252536176E-02 -0.755906332765E-02
+ -0.765681559153E-02 -0.775579742737E-02 -0.785602430128E-02 -0.795751187392E-02
+ -0.806027600291E-02 -0.816433274534E-02 -0.826969836029E-02 -0.837638931134E-02
+ -0.848442226916E-02 -0.859381411410E-02 -0.870458193886E-02 -0.881674305112E-02
+ -0.893031497627E-02 -0.904531546016E-02 -0.916176247181E-02 -0.927967420632E-02
+ -0.939906908760E-02 -0.951996577135E-02 -0.964238314789E-02 -0.976634034519E-02
+ -0.989185673179E-02 -0.100189519199E-01 -0.101476457683E-01 -0.102779583857E-01
+ -0.104099101337E-01 -0.105435216300E-01 -0.106788137517E-01 -0.108158076384E-01
+ -0.109545246956E-01 -0.110949865982E-01 -0.112372152936E-01 -0.113812330053E-01
+ -0.115270622363E-01 -0.116747257728E-01 -0.118242466874E-01 -0.119756483430E-01
+ -0.121289543965E-01 -0.122841888022E-01 -0.124413758157E-01 -0.126005399979E-01
+ -0.127617062183E-01 -0.129248996596E-01 -0.130901458210E-01 -0.132574705226E-01
+ -0.134268999090E-01 -0.135984604540E-01 -0.137721789642E-01 -0.139480825834E-01
+ -0.141261987969E-01 -0.143065554357E-01 -0.144891806808E-01 -0.146741030677E-01
+ -0.148613514909E-01 -0.150509552083E-01 -0.152429438458E-01 -0.154373474019E-01
+ -0.156341962525E-01 -0.158335211557E-01 -0.160353532563E-01 -0.162397240908E-01
+ -0.164466655926E-01 -0.166562100967E-01 -0.168683903447E-01 -0.170832394902E-01
+ -0.173007911036E-01 -0.175210791778E-01 -0.177441381332E-01 -0.179700028231E-01
+ -0.181987085392E-01 -0.184302910172E-01 -0.186647864422E-01 -0.189022314544E-01
+ -0.191426631552E-01 -0.193861191121E-01 -0.196326373658E-01 -0.198822564350E-01
+ -0.201350153230E-01 -0.203909535239E-01 -0.206501110284E-01 -0.209125283302E-01
+ -0.211782464324E-01 -0.214473068540E-01 -0.217197516358E-01 -0.219956233480E-01
+ -0.222749650957E-01 -0.225578205266E-01 -0.228442338372E-01 -0.231342497800E-01
+ -0.234279136704E-01 -0.237252713937E-01 -0.240263694126E-01 -0.243312547739E-01
+ -0.246399751164E-01 -0.249525786780E-01 -0.252691143036E-01 -0.255896314520E-01
+ -0.259141802046E-01 -0.262428112725E-01 -0.265755760046E-01 -0.269125263959E-01
+ -0.272537150952E-01 -0.275991954137E-01 -0.279490213329E-01 -0.283032475137E-01
+ -0.286619293042E-01 -0.290251227487E-01 -0.293928845967E-01 -0.297652723113E-01
+ -0.301423440783E-01 -0.305241588157E-01 -0.309107761823E-01 -0.313022565874E-01
+ -0.316986612001E-01 -0.321000519590E-01 -0.325064915816E-01 -0.329180435745E-01
+ -0.333347722430E-01 -0.337567427011E-01 -0.341840208820E-01 -0.346166735482E-01
+ -0.350547683019E-01 -0.354983735956E-01 -0.359475587428E-01 -0.364023939290E-01
+ -0.368629502223E-01 -0.373292995847E-01 -0.378015148836E-01 -0.382796699026E-01
+ -0.387638393536E-01 -0.392540988881E-01 -0.397505251092E-01 -0.402531955836E-01
+ -0.407621888536E-01 -0.412775844492E-01 -0.417994629011E-01 -0.423279057525E-01
+ -0.428629955727E-01 -0.434048159693E-01 -0.439534516015E-01 -0.445089881934E-01
+ -0.450715125473E-01 -0.456411125575E-01 -0.462178772234E-01 -0.468018966644E-01
+ -0.473932621329E-01 -0.479920660293E-01 -0.485984019162E-01 -0.492123645331E-01
+ -0.498340498109E-01 -0.504635548873E-01 -0.511009781217E-01 -0.517464191106E-01
+ -0.523999787033E-01 -0.530617590176E-01 -0.537318634555E-01 -0.544103967198E-01
+ -0.550974648302E-01 -0.557931751397E-01 -0.564976363517E-01 -0.572109585368E-01
+ -0.579332531501E-01 -0.586646330484E-01 -0.594052125081E-01 -0.601551072429E-01
+ -0.609144344218E-01 -0.616833126876E-01 -0.624618621753E-01 -0.632502045309E-01
+ -0.640484629303E-01 -0.648567620989E-01 -0.656752283305E-01 -0.665039895076E-01
+ -0.673431751209E-01 -0.681929162899E-01 -0.690533457832E-01 -0.699245980393E-01
+ -0.708068091875E-01 -0.717001170691E-01 -0.726046612593E-01 -0.735205830886E-01
+ -0.744480256650E-01 -0.753871338965E-01 -0.763380545135E-01 -0.773009360919E-01
+ -0.782759290760E-01 -0.792631858026E-01 -0.802628605239E-01 -0.812751094327E-01
+ -0.823000906856E-01 -0.833379644287E-01 -0.843888928220E-01 -0.854530400650E-01
+ -0.865305724220E-01 -0.876216582486E-01 -0.887264680177E-01 -0.898451743459E-01
+ -0.909779520207E-01 -0.921249780280E-01 -0.932864315792E-01 -0.944624941396E-01
+ -0.956533494565E-01 -0.968591835882E-01 -0.980801849325E-01 -0.993165442567E-01
+ -0.100568454727     -0.101836111939     -0.103119713947     -0.104419461297
+ -0.105735557057     -0.107068206848     -0.108417618876     -0.109784003967
+ -0.111167575597     -0.112568549926     -0.113987145833     -0.115423584949
+ -0.116878091691     -0.118350893298     -0.119842219868     -0.121352304391
+ -0.122881382786     -0.124429693939     -0.125997479740     -0.127584985118
+ -0.129192458086     -0.130820149770     -0.132468314457     -0.134137209630
+ -0.135827096008     -0.137538237589     -0.139270901689     -0.141025358986
+ -0.142801883560     -0.144600752935     -0.146422248125     -0.148266653678
+ -0.150134257715     -0.152025351983     -0.153940231892     -0.155879196568
+ -0.157842548895     -0.159830595565     -0.161843647124     -0.163882018021
+ -0.165946026655     -0.168035995430     -0.170152250798     -0.172295123314
+ -0.174464947689     -0.176662062836     -0.178886811929     -0.181139542453
+ -0.183420606257     -0.185730359612     -0.188069163264     -0.190437382491
+ -0.192835387159     -0.195263551778     -0.197722255564     -0.200211882495
+ -0.202732821370     -0.205285465870     -0.207870214621     -0.210487471252
+ -0.213137644460     -0.215821148073     -0.218538401113     -0.221289827862
+ -0.224075857927     -0.226896926303     -0.229753473448     -0.232645945343
+ -0.235574793565     -0.238540475356     -0.241543453693     -0.244584197357
+ -0.247663181009     -0.250780885262     -0.253937796753     -0.257134408217
+ -0.260371218566     -0.263648732963     -0.266967462899     -0.270327926274
+ -0.273730647472     -0.277176157443     -0.280664993785     -0.284197700824
+ -0.287774829697     -0.291396938437     -0.295064592057     -0.298778362633
+ -0.302538829395     -0.306346578811     -0.310202204676     -0.314106308204
+ -0.318059498113     -0.322062390721     -0.326115610037     -0.330219787852
+ -0.334375563836     -0.338583585631     -0.342844508949     -0.347158997666
+ -0.351527723922     -0.355951368221     -0.360430619527     -0.364966175370
+ -0.369558741942     -0.374209034204     -0.378917775986     -0.383685700095
+ -0.388513548417     -0.393402072025     -0.398352031286     -0.403364195966
+ -0.408439345344     -0.413578268315     -0.418781763506     -0.424050639382
+ -0.429385714361     -0.434787816926     -0.440257785734     -0.445796469734
+ -0.451404728281     -0.457083431246     -0.462833459137     -0.468655703210
+ -0.474551065584     -0.480520459365     -0.486564808750     -0.492685049156
+ -0.498882127328     -0.505157001457     -0.511510641302     -0.517944028297
+ -0.524458155678     -0.531054028588     -0.537732664200     -0.544495091830
+ -0.551342353049     -0.558275501795     -0.565295604492     -0.572403740153
+ -0.579601000494     -0.586888490045     -0.594267326248     -0.601738639573
+ -0.609303573611     -0.616963285183     -0.624718944432     -0.632571734925
+ -0.640522853740     -0.648573511558     -0.656724932754     -0.664978355473
+ -0.673335031711     -0.681796227396     -0.690363222447     -0.699037310852
+ -0.707819800716     -0.716712014328     -0.725715288200     -0.734830973115
+ -0.744060434162     -0.753405050766     -0.762866216708     -0.772445340139
+ -0.782143843589     -0.791963163958     -0.801904752510     -0.811970074846
+ -0.822160610878     -0.832477854779     -0.842923314937     -0.853498513882
+ -0.864204988220     -0.875044288532     -0.886017979280     -0.897127638687
+ -0.908374858611     -0.919761244397     -0.931288414722     -0.942958001421
+ -0.954771649295     -0.966731015912     -0.978837771379     -0.991093598110
+  -1.00350019057      -1.01605925500      -1.02877250913      -1.04164168189
+  -1.05466851305      -1.06785475292      -1.08120216196      -1.09471251044
+  -1.10838757799      -1.12222915327      -1.13623903347      -1.15041902391
+  -1.16477093757      -1.17929659463      -1.19399782196      -1.20887645261
+  -1.22393432533      -1.23917328402      -1.25459517717      -1.27020185732
+  -1.28599518051      -1.30197700567      -1.31814919404      -1.33451360859
+  -1.35107211337      -1.36782657294      -1.38477885169      -1.40193081326
+  -1.41928431983      -1.43684123148      -1.45460340553      -1.47257269585
+  -1.49075095213      -1.50914001921      -1.52774173627      -1.54655793616
+  -1.56559044453      -1.58484107908      -1.60431164868      -1.62400395250
+  -1.64391977906      -1.66406090530      -1.68442909552      -1.70502610029
+  -1.72585365534      -1.74691348029      -1.76820727733      -1.78973672986
+  -1.81150350100      -1.83350923191      -1.85575554015      -1.87824401777
+  -1.90097622937      -1.92395370991      -1.94717796249      -1.97065045580
+  -1.99437262158      -2.01834585171      -2.04257149520      -2.06705085499
+  -2.09178518439      -2.11677568348      -2.14202349506      -2.16752970048
+  -2.19329531514      -2.21932128371      -2.24560847504      -2.27215767680
+  -2.29896958971      -2.32604482154      -2.35338388065      -2.38098716922
+  -2.40885497611      -2.43698746924      -2.46538468767      -2.49404653313
+  -2.52297276119      -2.55216297193      -2.58161660011      -2.61133290490
+  -2.64131095900      -2.67154963732      -2.70204760502      -2.73280330503
+  -2.76381494497      -2.79508048341      -2.82659761553      -2.85836375815
+  -2.89037603404      -2.92263125555      -2.95512590753      -2.98785612956
+  -3.02081769735      -3.05400600343      -3.08741603708      -3.12104236341
+  -3.15487910166      -3.18891990272      -3.22315792576      -3.25758581405
+  -3.29219567001      -3.32697902937      -3.36192683449      -3.39702940693
+  -3.43227641919      -3.46765686566      -3.50315903283      -3.53877046881
+  -3.57447795216      -3.61026746005      -3.64612413596      -3.68203225679
+  -3.71797519959      -3.75393540801      -3.78989435844      -3.82583252620
+  -3.86172935159      -3.89756320629      -3.93331136005      -3.96894994788
+  -4.00445393807      -4.03979710116      -4.07495198011      -4.10988986195
+  -4.14458075133      -4.17899334602      -4.21309501497      -4.24685177919
+  -4.28022829580      -4.31318784582      -4.34569232599      -4.37770224524
+  -4.40917672626      -4.44007351273      -4.47034898279      -4.49995816930
+  -4.52885478762      -4.55699127144      -4.58431881743      -4.61078743937
+  -4.63634603243      -4.66094244842      -4.68452358270      -4.70703547347
+  -4.72842341424      -4.74863208019      -4.76760566927      -4.78528805855
+  -4.80162297679      -4.81655419374      -4.83002572691      -4.84198206643
+  -4.85236841857      -4.86113096856      -4.86821716307      -4.87357601304
+  -4.87715841704      -4.87891750584      -4.87880900836      -4.87679163948
+  -4.87282751002      -4.86688255941      -4.85892701135      -4.84893585315
+  -4.83688933933      -4.82277352033      -4.80658079756      -4.78831050582
+  -4.76796952520      -4.74557292426      -4.72114463719      -4.69471817828
+  -4.66633739716      -4.63605727956      -4.60394479855      -4.57007982232
+  -4.53455608487      -4.49748222707      -4.45898291567      -4.41920004841
+  -4.37829405318      -4.33644528911      -4.29385555602      -4.25074971762
+  -4.20737744068      -4.16401504915      -4.12096748689      -4.07857037628
+  -4.03719215095      -3.99723623062      -3.95914319234      -3.92339287672
+  -3.89050634825      -3.86104760716      -3.83562492424      -3.81489164176
+  -3.79954625173      -3.79033152889      -3.78803246004      -3.79347267534
+  -3.80750905232      -3.83102413243      -3.86491596506      -3.91008497970
+  -3.96741748724      -4.03776543182      -4.12192206153      -4.22059326658
+  -4.33436445516      -4.46366300879      -4.60871658787      -4.76950785400
+  -4.94572654457      -5.13672028280      -5.34144603576      -5.55842474368
+  -5.78570232955      -6.02082105030      -6.26080595203      -6.50217202404
+  -6.74095848539      -6.97279757362      -7.19302513331      -7.39684329996
+  -7.57954271235      -7.73679647451      -7.86503687512      -7.96192833012
+  -8.02695244028      -8.06212484794      -8.07286901784      -8.06907949963
+  -8.00000000000
+  2
+ -0.541244073305E-05 -0.108929615896E-04 -0.164424189121E-04 -0.220616798147E-04
+ -0.277516223182E-04 -0.335131354877E-04 -0.393471195715E-04 -0.452544861413E-04
+ -0.512361582353E-04 -0.572930705018E-04 -0.634261693458E-04 -0.696364130764E-04
+ -0.759247720568E-04 -0.822922288559E-04 -0.887397784017E-04 -0.952684281371E-04
+ -0.101879198177E-03 -0.108573121467E-03 -0.115351243947E-03 -0.122214624712E-03
+ -0.129164336180E-03 -0.136201464256E-03 -0.143327108507E-03 -0.150542382329E-03
+ -0.157848413123E-03 -0.165246342471E-03 -0.172737326315E-03 -0.180322535137E-03
+ -0.188003154140E-03 -0.195780383437E-03 -0.203655438235E-03 -0.211629549029E-03
+ -0.219703961789E-03 -0.227879938159E-03 -0.236158755651E-03 -0.244541707848E-03
+ -0.253030104603E-03 -0.261625272245E-03 -0.270328553786E-03 -0.279141309133E-03
+ -0.288064915296E-03 -0.297100766607E-03 -0.306250274935E-03 -0.315514869911E-03
+ -0.324895999145E-03 -0.334395128459E-03 -0.344013742111E-03 -0.353753343028E-03
+ -0.363615453044E-03 -0.373601613132E-03 -0.383713383651E-03 -0.393952344586E-03
+ -0.404320095795E-03 -0.414818257259E-03 -0.425448469339E-03 -0.436212393027E-03
+ -0.447111710207E-03 -0.458148123920E-03 -0.469323358628E-03 -0.480639160484E-03
+ -0.492097297605E-03 -0.503699560349E-03 -0.515447761593E-03 -0.527343737017E-03
+ -0.539389345391E-03 -0.551586468866E-03 -0.563937013268E-03 -0.576442908394E-03
+ -0.589106108316E-03 -0.601928591684E-03 -0.614912362038E-03 -0.628059448118E-03
+ -0.641371904183E-03 -0.654851810332E-03 -0.668501272827E-03 -0.682322424425E-03
+ -0.696317424708E-03 -0.710488460424E-03 -0.724837745826E-03 -0.739367523019E-03
+ -0.754080062310E-03 -0.768977662564E-03 -0.784062651561E-03 -0.799337386360E-03
+ -0.814804253671E-03 -0.830465670223E-03 -0.846324083144E-03 -0.862381970344E-03
+ -0.878641840899E-03 -0.895106235448E-03 -0.911777726587E-03 -0.928658919268E-03
+ -0.945752451213E-03 -0.963060993322E-03 -0.980587250089E-03 -0.998333960027E-03
+ -0.101630389610E-02 -0.103449986613E-02 -0.105292471330E-02 -0.107158131651E-02
+ -0.109047259091E-02 -0.110960148828E-02 -0.112897099756E-02 -0.114858414527E-02
+ -0.116844399602E-02 -0.118855365293E-02 -0.120891625819E-02 -0.122953499349E-02
+ -0.125041308055E-02 -0.127155378162E-02 -0.129296039997E-02 -0.131463628044E-02
+ -0.133658480991E-02 -0.135880941791E-02 -0.138131357705E-02 -0.140410080367E-02
+ -0.142717465832E-02 -0.145053874633E-02 -0.147419671838E-02 -0.149815227109E-02
+ -0.152240914757E-02 -0.154697113798E-02 -0.157184208020E-02 -0.159702586037E-02
+ -0.162252641349E-02 -0.164834772408E-02 -0.167449382678E-02 -0.170096880696E-02
+ -0.172777680139E-02 -0.175492199889E-02 -0.178240864094E-02 -0.181024102238E-02
+ -0.183842349208E-02 -0.186696045361E-02 -0.189585636593E-02 -0.192511574408E-02
+ -0.195474315990E-02 -0.198474324273E-02 -0.201512068015E-02 -0.204588021870E-02
+ -0.207702666461E-02 -0.210856488458E-02 -0.214049980652E-02 -0.217283642033E-02
+ -0.220557977867E-02 -0.223873499776E-02 -0.227230725816E-02 -0.230630180561E-02
+ -0.234072395182E-02 -0.237557907534E-02 -0.241087262233E-02 -0.244661010750E-02
+ -0.248279711489E-02 -0.251943929880E-02 -0.255654238464E-02 -0.259411216985E-02
+ -0.263215452478E-02 -0.267067539363E-02 -0.270968079536E-02 -0.274917682464E-02
+ -0.278916965281E-02 -0.282966552883E-02 -0.287067078027E-02 -0.291219181427E-02
+ -0.295423511859E-02 -0.299680726257E-02 -0.303991489820E-02 -0.308356476113E-02
+ -0.312776367175E-02 -0.317251853622E-02 -0.321783634758E-02 -0.326372418684E-02
+ -0.331018922406E-02 -0.335723871949E-02 -0.340488002472E-02 -0.345312058380E-02
+ -0.350196793441E-02 -0.355142970906E-02 -0.360151363623E-02 -0.365222754166E-02
+ -0.370357934948E-02 -0.375557708353E-02 -0.380822886855E-02 -0.386154293150E-02
+ -0.391552760280E-02 -0.397019131767E-02 -0.402554261742E-02 -0.408159015082E-02
+ -0.413834267539E-02 -0.419580905885E-02 -0.425399828041E-02 -0.431291943228E-02
+ -0.437258172100E-02 -0.443299446892E-02 -0.449416711566E-02 -0.455610921957E-02
+ -0.461883045923E-02 -0.468234063495E-02 -0.474664967034E-02 -0.481176761381E-02
+ -0.487770464017E-02 -0.494447105222E-02 -0.501207728234E-02 -0.508053389414E-02
+ -0.514985158412E-02 -0.522004118329E-02 -0.529111365892E-02 -0.536308011624E-02
+ -0.543595180015E-02 -0.550974009700E-02 -0.558445653636E-02 -0.566011279282E-02
+ -0.573672068783E-02 -0.581429219153E-02 -0.589283942461E-02 -0.597237466026E-02
+ -0.605291032600E-02 -0.613445900570E-02 -0.621703344151E-02 -0.630064653585E-02
+ -0.638531135343E-02 -0.647104112330E-02 -0.655784924093E-02 -0.664574927024E-02
+ -0.673475494579E-02 -0.682488017491E-02 -0.691613903985E-02 -0.700854579998E-02
+ -0.710211489405E-02 -0.719686094242E-02 -0.729279874935E-02 -0.738994330533E-02
+ -0.748830978937E-02 -0.758791357145E-02 -0.768877021486E-02 -0.779089547866E-02
+ -0.789430532011E-02 -0.799901589723E-02 -0.810504357124E-02 -0.821240490919E-02
+ -0.832111668651E-02 -0.843119588962E-02 -0.854265971863E-02 -0.865552558999E-02
+ -0.876981113922E-02 -0.888553422366E-02 -0.900271292528E-02 -0.912136555349E-02
+ -0.924151064801E-02 -0.936316698174E-02 -0.948635356374E-02 -0.961108964215E-02
+ -0.973739470725E-02 -0.986528849445E-02 -0.999479098742E-02 -0.101259224212E-01
+ -0.102587032853E-01 -0.103931543270E-01 -0.105292965546E-01 -0.106671512406E-01
+ -0.108067399250E-01 -0.109480844188E-01 -0.110912068075E-01 -0.112361294541E-01
+ -0.113828750032E-01 -0.115314663840E-01 -0.116819268142E-01 -0.118342798035E-01
+ -0.119885491575E-01 -0.121447589811E-01 -0.123029336822E-01 -0.124630979761E-01
+ -0.126252768888E-01 -0.127894957609E-01 -0.129557802521E-01 -0.131241563446E-01
+ -0.132946503475E-01 -0.134672889009E-01 -0.136420989799E-01 -0.138191078989E-01
+ -0.139983433159E-01 -0.141798332368E-01 -0.143636060198E-01 -0.145496903797E-01
+ -0.147381153925E-01 -0.149289105002E-01 -0.151221055147E-01 -0.153177306232E-01
+ -0.155158163925E-01 -0.157163937740E-01 -0.159194941081E-01 -0.161251491298E-01
+ -0.163333909731E-01 -0.165442521761E-01 -0.167577656864E-01 -0.169739648659E-01
+ -0.171928834960E-01 -0.174145557833E-01 -0.176390163646E-01 -0.178663003122E-01
+ -0.180964431397E-01 -0.183294808073E-01 -0.185654497277E-01 -0.188043867715E-01
+ -0.190463292731E-01 -0.192913150365E-01 -0.195393823411E-01 -0.197905699480E-01
+ -0.200449171057E-01 -0.203024635566E-01 -0.205632495426E-01 -0.208273158122E-01
+ -0.210947036263E-01 -0.213654547646E-01 -0.216396115326E-01 -0.219172167679E-01
+ -0.221983138468E-01 -0.224829466912E-01 -0.227711597756E-01 -0.230629981339E-01
+ -0.233585073664E-01 -0.236577336469E-01 -0.239607237302E-01 -0.242675249591E-01
+ -0.245781852717E-01 -0.248927532096E-01 -0.252112779243E-01 -0.255338091862E-01
+ -0.258603973913E-01 -0.261910935696E-01 -0.265259493931E-01 -0.268650171836E-01
+ -0.272083499211E-01 -0.275560012521E-01 -0.279080254977E-01 -0.282644776624E-01
+ -0.286254134425E-01 -0.289908892349E-01 -0.293609621460E-01 -0.297356900002E-01
+ -0.301151313496E-01 -0.304993454826E-01 -0.308883924334E-01 -0.312823329913E-01
+ -0.316812287102E-01 -0.320851419183E-01 -0.324941357280E-01 -0.329082740451E-01
+ -0.333276215796E-01 -0.337522438554E-01 -0.341822072204E-01 -0.346175788573E-01
+ -0.350584267936E-01 -0.355048199126E-01 -0.359568279642E-01 -0.364145215754E-01
+ -0.368779722617E-01 -0.373472524381E-01 -0.378224354304E-01 -0.383035954869E-01
+ -0.387908077898E-01 -0.392841484667E-01 -0.397836946032E-01 -0.402895242542E-01
+ -0.408017164564E-01 -0.413203512408E-01 -0.418455096451E-01 -0.423772737261E-01
+ -0.429157265730E-01 -0.434609523199E-01 -0.440130361593E-01 -0.445720643553E-01
+ -0.451381242571E-01 -0.457113043124E-01 -0.462916940816E-01 -0.468793842516E-01
+ -0.474744666501E-01 -0.480770342596E-01 -0.486871812324E-01 -0.493050029049E-01
+ -0.499305958129E-01 -0.505640577062E-01 -0.512054875643E-01 -0.518549856118E-01
+ -0.525126533336E-01 -0.531785934916E-01 -0.538529101399E-01 -0.545357086415E-01
+ -0.552270956848E-01 -0.559271793002E-01 -0.566360688767E-01 -0.573538751796E-01
+ -0.580807103671E-01 -0.588166880084E-01 -0.595619231010E-01 -0.603165320891E-01
+ -0.610806328815E-01 -0.618543448700E-01 -0.626377889483E-01 -0.634310875307E-01
+ -0.642343645711E-01 -0.650477455828E-01 -0.658713576577E-01 -0.667053294862E-01
+ -0.675497913778E-01 -0.684048752806E-01 -0.692707148027E-01 -0.701474452326E-01
+ -0.710352035606E-01 -0.719341285001E-01 -0.728443605093E-01 -0.737660418129E-01
+ -0.746993164248E-01 -0.756443301704E-01 -0.766012307091E-01 -0.775701675577E-01
+ -0.785512921137E-01 -0.795447576789E-01 -0.805507194834E-01 -0.815693347097E-01
+ -0.826007625176E-01 -0.836451640686E-01 -0.847027025516E-01 -0.857735432079E-01
+ -0.868578533574E-01 -0.879558024245E-01 -0.890675619646E-01 -0.901933056912E-01
+ -0.913332095026E-01 -0.924874515096E-01 -0.936562120634E-01 -0.948396737836E-01
+ -0.960380215869E-01 -0.972514427160E-01 -0.984801267686E-01 -0.997242657272E-01
+ -0.100984053989     -0.102259688397     -0.103551368269     -0.104859295431
+ -0.106183674247     -0.107524711652     -0.108882617182     -0.110257603011
+ -0.111649883981     -0.113059677635     -0.114487204255     -0.115932686891
+ -0.117396351399     -0.118878426477     -0.120379143699     -0.121898737552
+ -0.123437445472     -0.124995507882     -0.126573168227     -0.128170673017
+ -0.129788271861     -0.131426217508     -0.133084765885     -0.134764176140
+ -0.136464710678     -0.138186635208     -0.139930218777     -0.141695733819
+ -0.143483456194     -0.145293665230     -0.147126643771     -0.148982678216
+ -0.150862058569     -0.152765078479     -0.154692035290     -0.156643230085
+ -0.158618967734     -0.160619556943     -0.162645310299     -0.164696544321
+ -0.166773579510     -0.168876740396     -0.171006355594     -0.173162757850
+ -0.175346284094     -0.177557275496     -0.179796077517     -0.182063039960
+ -0.184358517032     -0.186682867392     -0.189036454210     -0.191419645224
+ -0.193832812799     -0.196276333981     -0.198750590558     -0.201255969121
+ -0.203792861123     -0.206361662940     -0.208962775933     -0.211596606511
+ -0.214263566195     -0.216964071681     -0.219698544904     -0.222467413109
+ -0.225271108912     -0.228110070369     -0.230984741048     -0.233895570094
+ -0.236843012299     -0.239827528176     -0.242849584031     -0.245909652032
+ -0.249008210287     -0.252145742913     -0.255322740119     -0.258539698278
+ -0.261797120003     -0.265095514230     -0.268435396295     -0.271817288012
+ -0.275241717761     -0.278709220562     -0.282220338165     -0.285775619134
+ -0.289375618929     -0.293020899994     -0.296712031848     -0.300449591168
+ -0.304234161886     -0.308066335273     -0.311946710037     -0.315875892412
+ -0.319854496256     -0.323883143143     -0.327962462466     -0.332093091527
+ -0.336275675643     -0.340510868244     -0.344799330975     -0.349141733798
+ -0.353538755099     -0.357991081792     -0.362499409425     -0.367064442292
+ -0.371686893538     -0.376367485275     -0.381106948690     -0.385906024160
+ -0.390765461370     -0.395686019428     -0.400668466980     -0.405713582335
+ -0.410822153584     -0.415994978718     -0.421232865762     -0.426536632890
+ -0.431907108559     -0.437345131637     -0.442851551530     -0.448427228318
+ -0.454073032884     -0.459789847055     -0.465578563733     -0.471440087039
+ -0.477375332448     -0.483385226934     -0.489470709116     -0.495632729397
+ -0.501872250117     -0.508190245699     -0.514587702801     -0.521065620468
+ -0.527625010288     -0.534266896547     -0.540992316385     -0.547802319963
+ -0.554697970617     -0.561680345027     -0.568750533383     -0.575909639550
+ -0.583158781240     -0.590499090184     -0.597931712305     -0.605457807895
+ -0.613078551793     -0.620795133565     -0.628608757685     -0.636520643723
+ -0.644532026526     -0.652644156412     -0.660858299359     -0.669175737198
+ -0.677597767805     -0.686125705305     -0.694760880266     -0.703504639905
+ -0.712358348287     -0.721323386536     -0.730401153043     -0.739593063676
+ -0.748900551990     -0.758325069449     -0.767868085639     -0.777531088488
+ -0.787315584493     -0.797223098936     -0.807255176121     -0.817413379596
+ -0.827699292385     -0.838114517225     -0.848660676801     -0.859339413981
+ -0.870152392061     -0.881101295004     -0.892187827686     -0.903413716144
+ -0.914780707823     -0.926290571830     -0.937945099185     -0.949746103076
+ -0.961695419120     -0.973794905615     -0.986046443811     -0.998451938164
+  -1.01101331660      -1.02373253081      -1.03661155645      -1.04965239349
+  -1.06285706644      -1.07622762464      -1.08976614250      -1.10347471982
+  -1.11735548204      -1.13141058054      -1.14564219288      -1.16005252310
+  -1.17464380200      -1.18941828743      -1.20437826454      -1.21952604609
+  -1.23486397268      -1.25039441311      -1.26611976457      -1.28204245299
+  -1.29816493324      -1.31448968950      -1.33101923544      -1.34775611453
+  -1.36470290035      -1.38186219676      -1.39923663826      -1.41682889018
+  -1.43464164899      -1.45267764250      -1.47093963014      -1.48943040320
+  -1.50815278506      -1.52710963143      -1.54630383057      -1.56573830349
+  -1.58541600421      -1.60533991991      -1.62551307115      -1.64593851208
+  -1.66661933056      -1.68755864838      -1.70875962139      -1.73022543967
+  -1.75195932762      -1.77396454412      -1.79624438263      -1.81880217126
+  -1.84164127288      -1.86476508519      -1.88817704073      -1.91188060695
+  -1.93587928621      -1.96017661578      -1.98477616780      -2.00968154931
+  -2.03489640209      -2.06042440267      -2.08626926219      -2.11243472629
+  -2.13892457494      -2.16574262233      -2.19289271665      -2.22037873987
+  -2.24820460755      -2.27637426852      -2.30489170468      -2.33376093060
+  -2.36298599328      -2.39257097173      -2.42251997662      -2.45283714987
+  -2.48352666419      -2.51459272267      -2.54603955824      -2.57787143318
+  -2.61009263858      -2.64270749375      -2.67572034562      -2.70913556812
+  -2.74295756151      -2.77719075165      -2.81183958929      -2.84690854932
+  -2.88240212989      -2.91832485160      -2.95468125659      -2.99147590759
+  -3.02871338690      -3.06639829534      -3.10453525113      -3.14312888867
+  -3.18218385731      -3.22170481995      -3.26169645166      -3.30216343809
+  -3.34311047388      -3.38454226085      -3.42646350617      -3.46887892029
+  -3.51179321482      -3.55521110018      -3.59913728311      -3.64357646395
+  -3.68853333379      -3.73401257137      -3.78001883968      -3.82655678242
+  -3.87363102016      -3.92124614612      -3.96940672182      -4.01811727223
+  -4.06738228072      -4.11720618354      -4.16759336401      -4.21854814618
+  -4.27007478823      -4.32217747524      -4.37486031159      -4.42812731288
+  -4.48198239720      -4.53642937597      -4.59147194415      -4.64711366981
+  -4.70335798313      -4.76020816467      -4.81766733294      -4.87573843130
+  -4.93442421403      -4.99372723161      -5.05364981518      -5.11419406012
+  -5.17536180869      -5.23715463176      -5.29957380955      -5.36262031125
+  -5.42629477368      -5.49059747876      -5.55552832979      -5.62108682661
+  -5.68727203940      -5.75408258125      -5.82151657931      -5.88957164458
+  -5.95824484023      -6.02753264847      -6.09743093573      -6.16793491645
+  -6.23903911502      -6.31073732617      -6.38302257360      -6.45588706676
+  -6.52932215593      -6.60331828535      -6.67786494454      -6.75295061765
+  -6.82856273096      -6.90468759834      -6.98131036484      -7.05841494824
+  -7.13598397874      -7.21399873667      -7.29243908832      -7.37128341989
+  -7.45050856972      -7.53008975869      -7.61000051910      -7.69021262196
+  -7.77069600295      -7.85141868708      -7.93234671241      -8.01344405282
+  -8.09467254031      -8.17599178685      -8.25735910635      -8.33872943683
+  -8.42005526344      -8.50128654255      -8.58237062749      -8.66325219648
+  -8.74387318329      -8.82417271122      -8.90408703123      -8.98354946485
+  -9.06249035273      -9.14083700974      -9.21851368752      -9.29544154558
+  -9.37153863195      -9.44671987459      -9.52089708489      -9.59397897438
+  -9.66587118621      -9.73647634280      -9.80569411114      -9.87342128734
+  -9.93955190222      -10.0039773493      -10.0665865374      -10.1272660692
+  -10.1859004474      -10.2423723116      -10.2965627053      -10.3483513774
+  -10.3976171177      -10.4442381299      -10.4880924418      -10.5290583560
+  -10.5670149406      -10.6018425624      -10.6334234622      -10.6616423739
+  -10.6863871863      -10.7075496491      -10.7250261208      -10.7387183587
+  -10.7485343492      -10.7543891759      -10.7562059229      -10.7539166111
+  -10.7474631609      -10.7367983792      -10.7218869627      -10.7027065130
+  -10.6792485546      -10.6515195475      -10.6195418869      -10.5833548772
+  -10.5430156712      -10.4986001616      -10.4502038115      -10.3979424105
+  -10.3419527411      -10.2823931396      -10.2194439360      -10.1533077535
+  -10.0842096515      -10.0123970925      -9.93813971325      -9.86172887983
+  -9.78347700690      -9.70371661844      -9.62279912862      -9.54109331976
+  -9.45898349409      -9.37686727518      -9.29515303453      -9.21425691850
+  -9.13459945035      -9.05660168329      -8.98068088104      -8.90724570542
+  -8.83669089441      -8.76939142089      -8.70569613199      -8.64592088338
+  -8.59034120238      -8.53918454105      -8.49262221629      -8.45076118153
+  -8.41363583533      -8.38120015016      -8.35332050142      -8.32976969719
+  -8.31022285601      -8.29425595735      -8.28134810165      -8.27088876857
+  -8.26219165767      -8.25451704237      -8.24710497201      -8.23922212746
+  -8.23022568649      -8.21964820112      -8.20730825381      -8.19345256864
+  -8.17893633969      -8.16503368457      -8.15203207494      -8.13989283873
+  -8.12857651254      -8.11804315349      -8.10825270287      -8.09916536617
+  -8.09074198465      -8.08294436441      -8.07573551565      -8.06907988859
+  -8.00000000000
+  3
+ -0.887445695163E-05 -0.178605408300E-04 -0.269596557289E-04 -0.361732234037E-04
+ -0.455026834930E-04 -0.549494937439E-04 -0.645151302398E-04 -0.742010876307E-04
+ -0.840088793674E-04 -0.939400379371E-04 -0.103996115104E-03 -0.114178682150E-03
+ -0.124489330122E-03 -0.134929670079E-03 -0.145501333348E-03 -0.156205971770E-03
+ -0.167045257968E-03 -0.178020885602E-03 -0.189134569636E-03 -0.200388046607E-03
+ -0.211783074892E-03 -0.223321434988E-03 -0.235004929788E-03 -0.246835384860E-03
+ -0.258814648739E-03 -0.270944593208E-03 -0.283227113595E-03 -0.295664129070E-03
+ -0.308257582942E-03 -0.321009442962E-03 -0.333921701636E-03 -0.346996376530E-03
+ -0.360235510589E-03 -0.373641172454E-03 -0.387215456786E-03 -0.400960484597E-03
+ -0.414878403574E-03 -0.428971388420E-03 -0.443241641193E-03 -0.457691391649E-03
+ -0.472322897591E-03 -0.487138445222E-03 -0.502140349500E-03 -0.517330954504E-03
+ -0.532712633797E-03 -0.548287790798E-03 -0.564058859157E-03 -0.580028303134E-03
+ -0.596198617989E-03 -0.612572330365E-03 -0.629151998689E-03 -0.645940213568E-03
+ -0.662939598194E-03 -0.680152808756E-03 -0.697582534852E-03 -0.715231499914E-03
+ -0.733102461627E-03 -0.751198212367E-03 -0.769521579630E-03 -0.788075426480E-03
+ -0.806862651994E-03 -0.825886191713E-03 -0.845149018105E-03 -0.864654141025E-03
+ -0.884404608189E-03 -0.904403505646E-03 -0.924653958267E-03 -0.945159130224E-03
+ -0.965922225493E-03 -0.986946488349E-03 -0.100823520388E-02 -0.102979169848E-02
+ -0.105161934041E-02 -0.107372154027E-02 -0.109610175159E-02 -0.111876347130E-02
+ -0.114171024036E-02 -0.116494564425E-02 -0.118847331353E-02 -0.121229692446E-02
+ -0.123642019953E-02 -0.126084690805E-02 -0.128558086673E-02 -0.131062594031E-02
+ -0.133598604214E-02 -0.136166513478E-02 -0.138766723065E-02 -0.141399639261E-02
+ -0.144065673467E-02 -0.146765242254E-02 -0.149498767437E-02 -0.152266676133E-02
+ -0.155069400835E-02 -0.157907379474E-02 -0.160781055490E-02 -0.163690877900E-02
+ -0.166637301370E-02 -0.169620786285E-02 -0.172641798821E-02 -0.175700811016E-02
+ -0.178798300848E-02 -0.181934752306E-02 -0.185110655466E-02 -0.188326506571E-02
+ -0.191582808102E-02 -0.194880068865E-02 -0.198218804062E-02 -0.201599535379E-02
+ -0.205022791060E-02 -0.208489105997E-02 -0.211999021808E-02 -0.215553086925E-02
+ -0.219151856679E-02 -0.222795893383E-02 -0.226485766426E-02 -0.230222052358E-02
+ -0.234005334982E-02 -0.237836205443E-02 -0.241715262323E-02 -0.245643111731E-02
+ -0.249620367403E-02 -0.253647650793E-02 -0.257725591171E-02 -0.261854825725E-02
+ -0.266035999656E-02 -0.270269766280E-02 -0.274556787133E-02 -0.278897732069E-02
+ -0.283293279371E-02 -0.287744115852E-02 -0.292250936964E-02 -0.296814446907E-02
+ -0.301435358738E-02 -0.306114394485E-02 -0.310852285256E-02 -0.315649771357E-02
+ -0.320507602404E-02 -0.325426537443E-02 -0.330407345068E-02 -0.335450803541E-02
+ -0.340557700912E-02 -0.345728835144E-02 -0.350965014236E-02 -0.356267056354E-02
+ -0.361635789952E-02 -0.367072053905E-02 -0.372576697641E-02 -0.378150581271E-02
+ -0.383794575726E-02 -0.389509562892E-02 -0.395296435747E-02 -0.401156098501E-02
+ -0.407089466740E-02 -0.413097467563E-02 -0.419181039734E-02 -0.425341133822E-02
+ -0.431578712355E-02 -0.437894749967E-02 -0.444290233552E-02 -0.450766162418E-02
+ -0.457323548440E-02 -0.463963416225E-02 -0.470686803265E-02 -0.477494760103E-02
+ -0.484388350496E-02 -0.491368651582E-02 -0.498436754046E-02 -0.505593762295E-02
+ -0.512840794624E-02 -0.520178983399E-02 -0.527609475226E-02 -0.535133431133E-02
+ -0.542752026756E-02 -0.550466452513E-02 -0.558277913802E-02 -0.566187631177E-02
+ -0.574196840549E-02 -0.582306793373E-02 -0.590518756845E-02 -0.598834014101E-02
+ -0.607253864418E-02 -0.615779623414E-02 -0.624412623255E-02 -0.633154212867E-02
+ -0.642005758140E-02 -0.650968642145E-02 -0.660044265353E-02 -0.669234045847E-02
+ -0.678539419549E-02 -0.687961840443E-02 -0.697502780802E-02 -0.707163731416E-02
+ -0.716946201829E-02 -0.726851720571E-02 -0.736881835401E-02 -0.747038113543E-02
+ -0.757322141938E-02 -0.767735527484E-02 -0.778279897296E-02 -0.788956898953E-02
+ -0.799768200756E-02 -0.810715491995E-02 -0.821800483206E-02 -0.833024906441E-02
+ -0.844390515539E-02 -0.855899086400E-02 -0.867552417261E-02 -0.879352328979E-02
+ -0.891300665314E-02 -0.903399293217E-02 -0.915650103125E-02 -0.928055009251E-02
+ -0.940615949887E-02 -0.953334887705E-02 -0.966213810065E-02 -0.979254729326E-02
+ -0.992459683156E-02 -0.100583073486E-01 -0.101936997368E-01 -0.103307951517E-01
+ -0.104696150145E-01 -0.106101810163E-01 -0.107525151207E-01 -0.108966395677E-01
+ -0.110425768771E-01 -0.111903498519E-01 -0.113399815818E-01 -0.114914954472E-01
+ -0.116449151224E-01 -0.118002645795E-01 -0.119575680922E-01 -0.121168502396E-01
+ -0.122781359096E-01 -0.124414503037E-01 -0.126068189399E-01 -0.127742676575E-01
+ -0.129438226206E-01 -0.131155103226E-01 -0.132893575900E-01 -0.134653915868E-01
+ -0.136436398187E-01 -0.138241301374E-01 -0.140068907447E-01 -0.141919501974E-01
+ -0.143793374115E-01 -0.145690816666E-01 -0.147612126105E-01 -0.149557602642E-01
+ -0.151527550260E-01 -0.153522276769E-01 -0.155542093849E-01 -0.157587317099E-01
+ -0.159658266091E-01 -0.161755264413E-01 -0.163878639727E-01 -0.166028723815E-01
+ -0.168205852630E-01 -0.170410366354E-01 -0.172642609447E-01 -0.174902930701E-01
+ -0.177191683295E-01 -0.179509224853E-01 -0.181855917495E-01 -0.184232127895E-01
+ -0.186638227343E-01 -0.189074591795E-01 -0.191541601938E-01 -0.194039643249E-01
+ -0.196569106051E-01 -0.199130385577E-01 -0.201723882033E-01 -0.204350000657E-01
+ -0.207009151787E-01 -0.209701750919E-01 -0.212428218779E-01 -0.215188981381E-01
+ -0.217984470101E-01 -0.220815121740E-01 -0.223681378592E-01 -0.226583688516E-01
+ -0.229522505003E-01 -0.232498287251E-01 -0.235511500230E-01 -0.238562614761E-01
+ -0.241652107587E-01 -0.244780461448E-01 -0.247948165155E-01 -0.251155713668E-01
+ -0.254403608174E-01 -0.257692356161E-01 -0.261022471505E-01 -0.264394474541E-01
+ -0.267808892152E-01 -0.271266257848E-01 -0.274767111849E-01 -0.278312001171E-01
+ -0.281901479710E-01 -0.285536108328E-01 -0.289216454944E-01 -0.292943094620E-01
+ -0.296716609650E-01 -0.300537589653E-01 -0.304406631666E-01 -0.308324340234E-01
+ -0.312291327507E-01 -0.316308213334E-01 -0.320375625363E-01 -0.324494199133E-01
+ -0.328664578181E-01 -0.332887414137E-01 -0.337163366827E-01 -0.341493104377E-01
+ -0.345877303318E-01 -0.350316648689E-01 -0.354811834147E-01 -0.359363562073E-01
+ -0.363972543685E-01 -0.368639499144E-01 -0.373365157672E-01 -0.378150257662E-01
+ -0.382995546796E-01 -0.387901782159E-01 -0.392869730361E-01 -0.397900167654E-01
+ -0.402993880053E-01 -0.408151663460E-01 -0.413374323791E-01 -0.418662677095E-01
+ -0.424017549688E-01 -0.429439778280E-01 -0.434930210105E-01 -0.440489703054E-01
+ -0.446119125808E-01 -0.451819357975E-01 -0.457591290228E-01 -0.463435824444E-01
+ -0.469353873841E-01 -0.475346363126E-01 -0.481414228639E-01 -0.487558418494E-01
+ -0.493779892733E-01 -0.500079623474E-01 -0.506458595062E-01 -0.512917804224E-01
+ -0.519458260223E-01 -0.526080985020E-01 -0.532787013426E-01 -0.539577393273E-01
+ -0.546453185570E-01 -0.553415464674E-01 -0.560465318453E-01 -0.567603848460E-01
+ -0.574832170106E-01 -0.582151412829E-01 -0.589562720275E-01 -0.597067250474E-01
+ -0.604666176025E-01 -0.612360684273E-01 -0.620151977501E-01 -0.628041273112E-01
+ -0.636029803825E-01 -0.644118817862E-01 -0.652309579146E-01 -0.660603367501E-01
+ -0.669001478846E-01 -0.677505225401E-01 -0.686115935894E-01 -0.694834955763E-01
+ -0.703663647372E-01 -0.712603390221E-01 -0.721655581160E-01 -0.730821634613E-01
+ -0.740102982791E-01 -0.749501075922E-01 -0.759017382475E-01 -0.768653389392E-01
+ -0.778410602316E-01 -0.788290545829E-01 -0.798294763690E-01 -0.808424819077E-01
+ -0.818682294829E-01 -0.829068793696E-01 -0.839585938585E-01 -0.850235372821E-01
+ -0.861018760397E-01 -0.871937786235E-01 -0.882994156453E-01 -0.894189598629E-01
+ -0.905525862070E-01 -0.917004718087E-01 -0.928627960272E-01 -0.940397404776E-01
+ -0.952314890595E-01 -0.964382279857E-01 -0.976601458113E-01 -0.988974334629E-01
+ -0.100150284269     -0.101418893989     -0.102703460847     -0.104004185557
+ -0.105321271360     -0.106654924052     -0.108005352020     -0.109372766270
+ -0.110757380462     -0.112159410945     -0.113579076789     -0.115016599817
+ -0.116472204646     -0.117946118716     -0.119438572329     -0.120949798682
+ -0.122480033907     -0.124029517105     -0.125598490387     -0.127187198905
+ -0.128795890899     -0.130424817728     -0.132074233915     -0.133744397183
+ -0.135435568498     -0.137148012108     -0.138881995584     -0.140637789864
+ -0.142415669292     -0.144215911666     -0.146038798274     -0.147884613946
+ -0.149753647092     -0.151646189752     -0.153562537636     -0.155502990178
+ -0.157467850575     -0.159457425839     -0.161472026842     -0.163511968369
+ -0.165577569163     -0.167669151977     -0.169787043621     -0.171931575019
+ -0.174103081256     -0.176301901631     -0.178528379713     -0.180782863391
+ -0.183065704930     -0.185377261024     -0.187717892858     -0.190087966157
+ -0.192487851245     -0.194917923107     -0.197378561444     -0.199870150730
+ -0.202393080279     -0.204947744300     -0.207534541960     -0.210153877447
+ -0.212806160034     -0.215491804140     -0.218211229399     -0.220964860720
+ -0.223753128361     -0.226576467987     -0.229435320746     -0.232330133334
+ -0.235261358065     -0.238229452942     -0.241234881731     -0.244278114029
+ -0.247359625340     -0.250479897149     -0.253639416997     -0.256838678558
+ -0.260078181714     -0.263358432637     -0.266679943862     -0.270043234374
+ -0.273448829683     -0.276897261911     -0.280389069872     -0.283924799156
+ -0.287505002216     -0.291130238456     -0.294801074312     -0.298518083348
+ -0.302281846339     -0.306092951367     -0.309951993910     -0.313859576936
+ -0.317816310996     -0.321822814321     -0.325879712918     -0.329987640666
+ -0.334147239419     -0.338359159102     -0.342624057815     -0.346942601935
+ -0.351315466220     -0.355743333915     -0.360226896859     -0.364766855591
+ -0.369363919461     -0.374018806741     -0.378732244737     -0.383504969902
+ -0.388337727951     -0.393231273977     -0.398186372572     -0.403203797942
+ -0.408284334030     -0.413428774640     -0.418637923558     -0.423912594679
+ -0.429253612133     -0.434661810417     -0.440138034520     -0.445683140059
+ -0.451297993412     -0.456983471851     -0.462740463681     -0.468569868380
+ -0.474472596733     -0.480449570984     -0.486501724972     -0.492630004278
+ -0.498835366376     -0.505118780779     -0.511481229193     -0.517923705668
+ -0.524447216753     -0.531052781655     -0.537741432397     -0.544514213977
+ -0.551372184534     -0.558316415514     -0.565347991830     -0.572468012041
+ -0.579677588514     -0.586977847607     -0.594369929834     -0.601854990052
+ -0.609434197635     -0.617108736660     -0.624879806088     -0.632748619954
+ -0.640716407555     -0.648784413641     -0.656953898609     -0.665226138698
+ -0.673602426192     -0.682084069616     -0.690672393943     -0.699368740799
+ -0.708174468671     -0.717090953120     -0.726119586994     -0.735261780644
+ -0.744518962145     -0.753892577516     -0.763384090946     -0.772994985020
+ -0.782726760950     -0.792580938811     -0.802559057770     -0.812662676333
+ -0.822893372579     -0.833252744411     -0.843742409799     -0.854364007035
+ -0.865119194982     -0.876009653335     -0.887037082878     -0.898203205748
+ -0.909509765702     -0.920958528386     -0.932551281607     -0.944289835608
+ -0.956176023352     -0.968211700797     -0.980398747190     -0.992739065349
+  -1.00523458196      -1.01788724788      -1.03069903841      -1.04367195363
+  -1.05680801871      -1.07010928416      -1.08357782623      -1.09721574715
+  -1.11102517552      -1.12500826656      -1.13916720252      -1.15350419294
+  -1.16802147504      -1.18272131401      -1.19760600339      -1.21267786543
+  -1.22793925139      -1.24339254193      -1.25904014746      -1.27488450851
+  -1.29092809608      -1.30717341204      -1.32362298946      -1.34027939302
+  -1.35714521939      -1.37422309760      -1.39151568945      -1.40902568987
+  -1.42675582736      -1.44470886435      -1.46288759764      -1.48129485877
+  -1.49993351447      -1.51880646704      -1.53791665481      -1.55726705250
+  -1.57686067173      -1.59670056136      -1.61678980798      -1.63713153635
+  -1.65772890979      -1.67858513065      -1.69970344077      -1.72108712192
+  -1.74273949620      -1.76466392657      -1.78686381726      -1.80934261421
+  -1.83210380559      -1.85515092219      -1.87848753794      -1.90211727032
+  -1.92604378086      -1.95027077561      -1.97480200558      -1.99964126720
+  -2.02479240283      -2.05025930118      -2.07604589778      -2.10215617548
+  -2.12859416485      -2.15536394468      -2.18246964245      -2.20991543472
+  -2.23770554766      -2.26584425741      -2.29433589060      -2.32318482472
+  -2.35239548859      -2.38197236276      -2.41191997992      -2.44224292534
+  -2.47294583721      -2.50403340707      -2.53551038017      -2.56738155581
+  -2.59965178774      -2.63232598444      -2.66540910948      -2.69890618179
+  -2.73282227596      -2.76716252253      -2.80193210818      -2.83713627599
+  -2.87278032566      -2.90886961362      -2.94540955324      -2.98240561491
+  -3.01986332616      -3.05778827170      -3.09618609344      -3.13506249048
+  -3.17442321907      -3.21427409253      -3.25462098107      -3.29546981168
+  -3.33682656785      -3.37869728932      -3.42108807176      -3.46400506638
+  -3.50745447950      -3.55144257202      -3.59597565892      -3.64106010857
+  -3.68670234207      -3.73290883244      -3.77968610381      -3.82704073047
+  -3.87497933584      -3.92350859138      -3.97263521539      -4.02236597171
+  -4.07270766831      -4.12366715579      -4.17525132573      -4.22746710897
+  -4.28032147374      -4.33382142361      -4.38797399540      -4.44278625683
+  -4.49826530409      -4.55441825921      -4.61125226728      -4.66877449342
+  -4.72699211963      -4.78591234140      -4.84554236407      -4.90588939896
+  -4.96696065931      -5.02876335586      -5.09130469220      -5.15459185980
+  -5.21863203270      -5.28343236191      -5.34899996936      -5.41534194152
+  -5.48246532259      -5.55037710722      -5.61908423278      -5.68859357113
+  -5.75891191983      -5.83004599282      -5.90200241046      -5.97478768892
+  -6.04840822898      -6.12287030395      -6.19818004702      -6.27434343763
+  -6.35136628709      -6.42925422328      -6.50801267440      -6.58764685167
+  -6.66816173108      -6.74956203389      -6.83185220614      -6.91503639673
+  -6.99911843439      -7.08410180321      -7.16998961675      -7.25678459069
+  -7.34448901398      -7.43310471824      -7.52263304558      -7.61307481464
+  -7.70443028471      -7.79669911798      -7.88988033982      -7.98397229690
+  -8.07897261324      -8.17487814387      -8.27168492636      -8.36938812971
+  -8.46798200095      -8.56745980897      -8.66781378583      -8.76903506522
+  -8.87111361812      -8.97403818557      -9.07779620838      -9.18237375385
+  -9.28775543932      -9.39392435252      -9.50086196866      -9.60854806423
+  -9.71696062748      -9.82607576542      -9.93586760753      -10.0463082060
+  -10.1573674326      -10.2690128720      -10.3812097123      -10.4939206315
+  -10.6071056812      -10.7207221676      -10.8347245284      -10.9490642087
+  -11.0636895326      -11.1785455732      -11.2935740211      -11.4087130502
+  -11.5238971831      -11.6390571545      -11.7541197755      -11.8690077968
+  -11.9836397736      -12.0979299311      -12.2117880329      -12.3251192518
+  -12.4378240448      -12.5497980327      -12.6609318862      -12.7711112188
+  -12.8802164879      -12.9881229062      -13.0947003639      -13.1998133644
+  -13.3033209739      -13.4050767879      -13.5049289155      -13.6027199842
+  -13.6982871677      -13.7914622371      -13.8820716398      -13.9699366081
+  -14.0548732984      -14.1366929659      -14.2152021752      -14.2902030508
+  -14.3614935698      -14.4288678987      -14.4921167773      -14.5510279529
+  -14.6053866654      -14.6549761866      -14.6995784161      -14.7389745339
+  -14.7729457128      -14.8012738902      -14.8237426014      -14.8401378728
+  -14.8502491766      -14.8538704444      -14.8508011390      -14.8408473813
+  -14.8238231309      -14.7995514140      -14.7678655960      -14.7286106926
+  -14.6816447122      -14.6268400232      -14.5640847378      -14.4932841030
+  -14.4143618897      -14.3272617692      -14.2319486666      -14.1284100808
+  -14.0166573594      -13.8967269187      -13.7686813987      -13.6326107442
+  -13.4886332051      -13.3368962499      -13.1775773901      -13.0108849146
+  -12.8370585385      -12.6563699732      -12.4691234289      -12.2756560666
+  -12.0763384207      -11.8715748178      -11.6618038222      -11.4474987441
+  -11.2291682458      -11.0073570871      -10.7826470475      -10.5556580608
+  -10.3270495906      -10.0975222648      -9.86781977003      -9.63873098513
+  -9.41109230483      -9.18579006567      -8.96376294276      -8.74600413154
+  -8.53356306580      -8.32754635301      -8.12911752979      -7.93949515859
+  -7.75994870217      -7.59179153226      -7.43637035697      -7.29505029740
+  -7.16919481708      -7.06013971945      -6.96916049433      -6.89743242861
+  -6.84598311779      -6.81563734259      -6.80695472730      -6.82016119293
+  -6.85507597602      -6.91103691566      -6.98682782717      -7.08061308360
+  -7.18988601307      -7.31143938258      -7.44136806702      -7.57511598802
+  -7.70758155871      -7.83329822314      -7.94670932107      -8.04255960459
+  -8.11642955418      -8.16544358851      -8.18918986165      -8.19089819556
+  -8.17893431444      -8.16503368457      -8.15203207494      -8.13989283873
+  -8.00000000000
+ Up Pseudopotential follows (l on next line)
+  1
+ -0.862235281989E-06 -0.173531614869E-05 -0.261937902076E-05 -0.351456203483E-05
+ -0.442100506506E-05 -0.533884974502E-05 -0.626823948981E-05 -0.720931951847E-05
+ -0.816223687666E-05 -0.912714045966E-05 -0.101041810356E-04 -0.110935112691E-04
+ -0.120952857450E-04 -0.131096609926E-04 -0.141367955101E-04 -0.151768497894E-04
+ -0.162299863410E-04 -0.172963697197E-04 -0.183761665500E-04 -0.194695455525E-04
+ -0.205766775697E-04 -0.216977355934E-04 -0.228328947911E-04 -0.239823325337E-04
+ -0.251462284233E-04 -0.263247643209E-04 -0.275181243753E-04 -0.287264950512E-04
+ -0.299500651591E-04 -0.311890258843E-04 -0.324435708170E-04 -0.337138959823E-04
+ -0.350001998712E-04 -0.363026834712E-04 -0.376215502980E-04 -0.389570064273E-04
+ -0.403092605268E-04 -0.416785238890E-04 -0.430650104640E-04 -0.444689368932E-04
+ -0.458905225429E-04 -0.473299895389E-04 -0.487875628007E-04 -0.502634700772E-04
+ -0.517579419818E-04 -0.532712120289E-04 -0.548035166699E-04 -0.563550953305E-04
+ -0.579261904482E-04 -0.595170475097E-04 -0.611279150896E-04 -0.627590448893E-04
+ -0.644106917762E-04 -0.660831138234E-04 -0.677765723503E-04 -0.694913319632E-04
+ -0.712276605967E-04 -0.729858295559E-04 -0.747661135581E-04 -0.765687907764E-04
+ -0.783941428827E-04 -0.802424550920E-04 -0.821140162068E-04 -0.840091186625E-04
+ -0.859280585725E-04 -0.878711357753E-04 -0.898386538804E-04 -0.918309203167E-04
+ -0.938482463799E-04 -0.958909472811E-04 -0.979593421967E-04 -0.100053754317E-03
+ -0.102174510900E-03 -0.104321943316E-03 -0.106496387106E-03 -0.108698182033E-03
+ -0.110927672130E-03 -0.113185205760E-03 -0.115471135668E-03 -0.117785819034E-03
+ -0.120129617533E-03 -0.122502897388E-03 -0.124906029428E-03 -0.127339389149E-03
+ -0.129803356766E-03 -0.132298317281E-03 -0.134824660536E-03 -0.137382781277E-03
+ -0.139973079216E-03 -0.142595959092E-03 -0.145251830735E-03 -0.147941109131E-03
+ -0.150664214485E-03 -0.153421572288E-03 -0.156213613382E-03 -0.159040774030E-03
+ -0.161903495981E-03 -0.164802226542E-03 -0.167737418644E-03 -0.170709530918E-03
+ -0.173719027762E-03 -0.176766379417E-03 -0.179852062036E-03 -0.182976557765E-03
+ -0.186140354812E-03 -0.189343947526E-03 -0.192587836477E-03 -0.195872528527E-03
+ -0.199198536918E-03 -0.202566381343E-03 -0.205976588037E-03 -0.209429689850E-03
+ -0.212926226337E-03 -0.216466743838E-03 -0.220051795568E-03 -0.223681941697E-03
+ -0.227357749443E-03 -0.231079793159E-03 -0.234848654421E-03 -0.238664922122E-03
+ -0.242529192561E-03 -0.246442069539E-03 -0.250404164450E-03 -0.254416096380E-03
+ -0.258478492202E-03 -0.262591986672E-03 -0.266757222534E-03 -0.270974850612E-03
+ -0.275245529922E-03 -0.279569927763E-03 -0.283948719834E-03 -0.288382590329E-03
+ -0.292872232048E-03 -0.297418346509E-03 -0.302021644049E-03 -0.306682843945E-03
+ -0.311402674518E-03 -0.316181873251E-03 -0.321021186904E-03 -0.325921371629E-03
+ -0.330883193090E-03 -0.335907426582E-03 -0.340994857151E-03 -0.346146279719E-03
+ -0.351362499207E-03 -0.356644330658E-03 -0.361992599371E-03 -0.367408141022E-03
+ -0.372891801801E-03 -0.378444438542E-03 -0.384066918855E-03 -0.389760121265E-03
+ -0.395524935344E-03 -0.401362261859E-03 -0.407273012902E-03 -0.413258112040E-03
+ -0.419318494458E-03 -0.425455107103E-03 -0.431668908832E-03 -0.437960870566E-03
+ -0.444331975435E-03 -0.450783218938E-03 -0.457315609094E-03 -0.463930166604E-03
+ -0.470627925005E-03 -0.477409930835E-03 -0.484277243797E-03 -0.491230936923E-03
+ -0.498272096740E-03 -0.505401823445E-03 -0.512621231072E-03 -0.519931447667E-03
+ -0.527333615468E-03 -0.534828891078E-03 -0.542418445649E-03 -0.550103465064E-03
+ -0.557885150124E-03 -0.565764716732E-03 -0.573743396087E-03 -0.581822434873E-03
+ -0.590003095458E-03 -0.598286656085E-03 -0.606674411078E-03 -0.615167671040E-03
+ -0.623767763062E-03 -0.632476030924E-03 -0.641293835312E-03 -0.650222554025E-03
+ -0.659263582193E-03 -0.668418332496E-03 -0.677688235382E-03 -0.687074739293E-03
+ -0.696579310888E-03 -0.706203435276E-03 -0.715948616246E-03 -0.725816376503E-03
+ -0.735808257904E-03 -0.745925821702E-03 -0.756170648785E-03 -0.766544339929E-03
+ -0.777048516045E-03 -0.787684818430E-03 -0.798454909030E-03 -0.809360470693E-03
+ -0.820403207434E-03 -0.831584844705E-03 -0.842907129658E-03 -0.854371831424E-03
+ -0.865980741385E-03 -0.877735673457E-03 -0.889638464374E-03 -0.901690973968E-03
+ -0.913895085471E-03 -0.926252705799E-03 -0.938765765855E-03 -0.951436220831E-03
+ -0.964266050511E-03 -0.977257259581E-03 -0.990411877946E-03 -0.100373196104E-02
+ -0.101721959015E-02 -0.103087687276E-02 -0.104470594283E-02 -0.105870896118E-02
+ -0.107288811583E-02 -0.108724562229E-02 -0.110178372394E-02 -0.111650469240E-02
+ -0.113141082785E-02 -0.114650445941E-02 -0.116178794547E-02 -0.117726367413E-02
+ -0.119293406348E-02 -0.120880156207E-02 -0.122486864923E-02 -0.124113783546E-02
+ -0.125761166286E-02 -0.127429270550E-02 -0.129118356982E-02 -0.130828689507E-02
+ -0.132560535366E-02 -0.134314165165E-02 -0.136089852911E-02 -0.137887876059E-02
+ -0.139708515554E-02 -0.141552055875E-02 -0.143418785078E-02 -0.145308994845E-02
+ -0.147222980523E-02 -0.149161041177E-02 -0.151123479634E-02 -0.153110602527E-02
+ -0.155122720350E-02 -0.157160147499E-02 -0.159223202326E-02 -0.161312207189E-02
+ -0.163427488498E-02 -0.165569376771E-02 -0.167738206682E-02 -0.169934317114E-02
+ -0.172158051215E-02 -0.174409756448E-02 -0.176689784646E-02 -0.178998492068E-02
+ -0.181336239454E-02 -0.183703392083E-02 -0.186100319826E-02 -0.188527397209E-02
+ -0.190985003467E-02 -0.193473522607E-02 -0.195993343463E-02 -0.198544859765E-02
+ -0.201128470190E-02 -0.203744578434E-02 -0.206393593269E-02 -0.209075928608E-02
+ -0.211792003572E-02 -0.214542242554E-02 -0.217327075284E-02 -0.220146936897E-02
+ -0.223002268003E-02 -0.225893514752E-02 -0.228821128909E-02 -0.231785567919E-02
+ -0.234787294981E-02 -0.237826779122E-02 -0.240904495266E-02 -0.244020924314E-02
+ -0.247176553213E-02 -0.250371875038E-02 -0.253607389064E-02 -0.256883600845E-02
+ -0.260201022298E-02 -0.263560171776E-02 -0.266961574153E-02 -0.270405760905E-02
+ -0.273893270193E-02 -0.277424646948E-02 -0.281000442954E-02 -0.284621216937E-02
+ -0.288287534649E-02 -0.291999968962E-02 -0.295759099950E-02 -0.299565514984E-02
+ -0.303419808826E-02 -0.307322583716E-02 -0.311274449470E-02 -0.315276023577E-02
+ -0.319327931290E-02 -0.323430805727E-02 -0.327585287972E-02 -0.331792027170E-02
+ -0.336051680634E-02 -0.340364913942E-02 -0.344732401046E-02 -0.349154824375E-02
+ -0.353632874942E-02 -0.358167252451E-02 -0.362758665407E-02 -0.367407831229E-02
+ -0.372115476358E-02 -0.376882336373E-02 -0.381709156105E-02 -0.386596689756E-02
+ -0.391545701012E-02 -0.396556963166E-02 -0.401631259239E-02 -0.406769382098E-02
+ -0.411972134587E-02 -0.417240329646E-02 -0.422574790441E-02 -0.427976350493E-02
+ -0.433445853806E-02 -0.438984155002E-02 -0.444592119451E-02 -0.450270623408E-02
+ -0.456020554153E-02 -0.461842810123E-02 -0.467738301057E-02 -0.473707948138E-02
+ -0.479752684136E-02 -0.485873453553E-02 -0.492071212771E-02 -0.498346930203E-02
+ -0.504701586443E-02 -0.511136174418E-02 -0.517651699546E-02 -0.524249179891E-02
+ -0.530929646323E-02 -0.537694142679E-02 -0.544543725923E-02 -0.551479466319E-02
+ -0.558502447589E-02 -0.565613767089E-02 -0.572814535976E-02 -0.580105879386E-02
+ -0.587488936605E-02 -0.594964861252E-02 -0.602534821454E-02 -0.610200000034E-02
+ -0.617961594692E-02 -0.625820818191E-02 -0.633778898553E-02 -0.641837079242E-02
+ -0.649996619367E-02 -0.658258793871E-02 -0.666624893737E-02 -0.675096226185E-02
+ -0.683674114877E-02 -0.692359900126E-02 -0.701154939104E-02 -0.710060606053E-02
+ -0.719078292503E-02 -0.728209407484E-02 -0.737455377752E-02 -0.746817648009E-02
+ -0.756297681128E-02 -0.765896958385E-02 -0.775616979684E-02 -0.785459263801E-02
+ -0.795425348611E-02 -0.805516791335E-02 -0.815735168783E-02 -0.826082077596E-02
+ -0.836559134499E-02 -0.847167976554E-02 -0.857910261415E-02 -0.868787667585E-02
+ -0.879801894680E-02 -0.890954663697E-02 -0.902247717278E-02 -0.913682819986E-02
+ -0.925261758578E-02 -0.936986342287E-02 -0.948858403104E-02 -0.960879796062E-02
+ -0.973052399527E-02 -0.985378115495E-02 -0.997858869882E-02 -0.101049661283E-01
+ -0.102329331902E-01 -0.103625098795E-01 -0.104937164430E-01 -0.106265733818E-01
+ -0.107611014552E-01 -0.108973216834E-01 -0.110352553511E-01 -0.111749240108E-01
+ -0.113163494860E-01 -0.114595538746E-01 -0.116045595526E-01 -0.117513891775E-01
+ -0.119000656917E-01 -0.120506123262E-01 -0.122030526043E-01 -0.123574103449E-01
+ -0.125137096669E-01 -0.126719749923E-01 -0.128322310504E-01 -0.129945028815E-01
+ -0.131588158410E-01 -0.133251956030E-01 -0.134936681647E-01 -0.136642598504E-01
+ -0.138369973152E-01 -0.140119075499E-01 -0.141890178843E-01 -0.143683559925E-01
+ -0.145499498963E-01 -0.147338279702E-01 -0.149200189455E-01 -0.151085519148E-01
+ -0.152994563369E-01 -0.154927620409E-01 -0.156884992312E-01 -0.158866984922E-01
+ -0.160873907930E-01 -0.162906074919E-01 -0.164963803422E-01 -0.167047414962E-01
+ -0.169157235107E-01 -0.171293593521E-01 -0.173456824014E-01 -0.175647264596E-01
+ -0.177865257527E-01 -0.180111149372E-01 -0.182385291058E-01 -0.184688037922E-01
+ -0.187019749774E-01 -0.189380790948E-01 -0.191771530362E-01 -0.194192341573E-01
+ -0.196643602838E-01 -0.199125697170E-01 -0.201639012403E-01 -0.204183941246E-01
+ -0.206760881350E-01 -0.209370235366E-01 -0.212012411011E-01 -0.214687821130E-01
+ -0.217396883761E-01 -0.220140022200E-01 -0.222917665068E-01 -0.225730246376E-01
+ -0.228578205596E-01 -0.231461987727E-01 -0.234382043365E-01 -0.237338828774E-01
+ -0.240332805957E-01 -0.243364442729E-01 -0.246434212789E-01 -0.249542595793E-01
+ -0.252690077433E-01 -0.255877149507E-01 -0.259104310002E-01 -0.262372063167E-01
+ -0.265680919594E-01 -0.269031396298E-01 -0.272424016797E-01 -0.275859311193E-01
+ -0.279337816256E-01 -0.282860075510E-01 -0.286426639313E-01 -0.290038064946E-01
+ -0.293694916701E-01 -0.297397765966E-01 -0.301147191318E-01 -0.304943778609E-01
+ -0.308788121063E-01 -0.312680819364E-01 -0.316622481752E-01 -0.320613724116E-01
+ -0.324655170095E-01 -0.328747451170E-01 -0.332891206765E-01 -0.337087084348E-01
+ -0.341335739529E-01 -0.345637836167E-01 -0.349994046469E-01 -0.354405051098E-01
+ -0.358871539278E-01 -0.363394208903E-01 -0.367973766645E-01 -0.372610928063E-01
+ -0.377306417719E-01 -0.382060969287E-01 -0.386875325668E-01 -0.391750239110E-01
+ -0.396686471322E-01 -0.401684793591E-01 -0.406745986909E-01 -0.411870842090E-01
+ -0.417060159892E-01 -0.422314751150E-01 -0.427635436893E-01 -0.433023048479E-01
+ -0.438478427723E-01 -0.444002427026E-01 -0.449595909511E-01 -0.455259749160E-01
+ -0.460994830943E-01 -0.466802050963E-01 -0.472682316595E-01 -0.478636546625E-01
+ -0.484665671394E-01 -0.490770632946E-01 -0.496952385174E-01 -0.503211893966E-01
+ -0.509550137359E-01 -0.515968105692E-01 -0.522466801760E-01 -0.529047240967E-01
+ -0.535710451490E-01 -0.542457474439E-01 -0.549289364013E-01 -0.556207187674E-01
+ -0.563212026306E-01 -0.570304974389E-01 -0.577487140166E-01 -0.584759645817E-01
+ -0.592123627637E-01 -0.599580236211E-01 -0.607130636590E-01 -0.614776008481E-01
+ -0.622517546424E-01 -0.630356459983E-01 -0.638293973930E-01 -0.646331328441E-01
+ -0.654469779287E-01 -0.662710598029E-01 -0.671055072219E-01 -0.679504505598E-01
+ -0.688060218302E-01 -0.696723547066E-01 -0.705495845433E-01 -0.714378483965E-01
+ -0.723372850455E-01 -0.732480350149E-01 -0.741702405957E-01 -0.751040458680E-01
+ -0.760495967234E-01 -0.770070408875E-01 -0.779765279433E-01 -0.789582093540E-01
+ -0.799522384869E-01 -0.809587706373E-01 -0.819779630526E-01 -0.830099749565E-01
+ -0.840549675744E-01 -0.851131041578E-01 -0.861845500102E-01 -0.872694725125E-01
+ -0.883680411492E-01 -0.894804275346E-01 -0.906068054395E-01 -0.917473508182E-01
+ -0.929022418360E-01 -0.940716588964E-01 -0.952557846695E-01 -0.964548041204E-01
+ -0.976689045374E-01 -0.988982755614E-01 -0.100143109215     -0.101403599934
+ -0.102679944592     -0.103972342540     -0.105280995628     -0.106606108241
+ -0.107947887332     -0.109306542448     -0.110682285770     -0.112075332139
+ -0.113485899093     -0.114914206898     -0.116360478585     -0.117824939983
+ -0.119307819749     -0.120809349413     -0.122329763404     -0.123869299090
+ -0.125428196815     -0.127006699935     -0.128605054854     -0.130223511062
+ -0.131862321174     -0.133521740969     -0.135202029426     -0.136903448765
+ -0.138626264488     -0.140370745416     -0.142137163732     -0.143925795023
+ -0.145736918317     -0.147570816129     -0.149427774502     -0.151308083049
+ -0.153212034998     -0.155139927233     -0.157092060339     -0.159068738649
+ -0.161070270284     -0.163096967204     -0.165149145247     -0.167227124182
+ -0.169331227750     -0.171461783715     -0.173619123909     -0.175803584278
+ -0.178015504936     -0.180255230208     -0.182523108678     -0.184819493245
+ -0.187144741166     -0.189499214108     -0.191883278198     -0.194297304073
+ -0.196741666932     -0.199216746586     -0.201722927508     -0.204260598887
+ -0.206830154676     -0.209431993647     -0.212066519442     -0.214734140622
+ -0.217435270725     -0.220170328309     -0.222939737014     -0.225743925606
+ -0.228583328033     -0.231458383476     -0.234369536396     -0.237317236595
+ -0.240301939254     -0.243324104994     -0.246384199922     -0.249482695679
+ -0.252620069488     -0.255796804209     -0.259013388376     -0.262270316251
+ -0.265568087869     -0.268907209075     -0.272288191575     -0.275711552976
+ -0.279177816821     -0.282687512634     -0.286241175951     -0.289839348360
+ -0.293482577529     -0.297171417238     -0.300906427408     -0.304688174122
+ -0.308517229651     -0.312394172469     -0.316319587274     -0.320294064990
+ -0.324318202784     -0.328392604061     -0.332517878471     -0.336694641892
+ -0.340923516426     -0.345205130378     -0.349540118231     -0.353929120617
+ -0.358372784276     -0.362871762014     -0.367426712648     -0.372038300939
+ -0.376707197528     -0.381434078846     -0.386219627026     -0.391064529797
+ -0.395969480369     -0.400935177301     -0.405962324360     -0.411051630363
+ -0.416203809002     -0.421419578653     -0.426699662171     -0.432044786658
+ -0.437455683219     -0.442933086691     -0.448477735350     -0.454090370601
+ -0.459771736625     -0.465522580020     -0.471343649396     -0.477235694948
+ -0.483199467991     -0.489235720465     -0.495345204399     -0.501528671339
+ -0.507786871728     -0.514120554252     -0.520530465131     -0.527017347362
+ -0.533581939911     -0.540224976851     -0.546947186435     -0.553749290113
+ -0.560632001481     -0.567596025156     -0.574642055587     -0.581770775775
+ -0.588982855922     -0.596278951987     -0.603659704148     -0.611125735176
+ -0.618677648694     -0.626316027337     -0.634041430794     -0.641854393730
+ -0.649755423584     -0.657744998223     -0.665823563471     -0.673991530477
+ -0.682249272929     -0.690597124109     -0.699035373772     -0.707564264841
+ -0.716183989913     -0.724894687570     -0.733696438470     -0.742589261225
+ -0.751573108045     -0.760647860143     -0.769813322877     -0.779069220643
+ -0.788415191472     -0.797850781354     -0.807375438244     -0.816988505767
+ -0.826689216579     -0.836476685396     -0.846349901663     -0.856307721845
+ -0.866348861343     -0.876471886001     -0.886675203202     -0.896957052534
+ -0.907315496007     -0.917748407822     -0.928253463651     -0.938828129442
+ -0.949469649720     -0.960175035368     -0.970941050886     -0.981764201110
+ -0.992640717382      -1.00356654316      -1.01453731905      -1.02554836728
+  -1.03659467560      -1.04767088054      -1.05877125018      -1.06988966623
+  -1.08101960564      -1.09215412154      -1.10328582366      -1.11440685823
+  -1.12550888732      -1.13658306768      -1.14762002909      -1.15860985235
+  -1.16954204674      -1.18040552726      -1.19118859149      -1.20187889623
+  -1.21246343403      -1.22292850955      -1.23325971602      -1.24344191175
+  -1.25345919684      -1.26329489030      -1.27293150761      -1.28235073887
+  -1.29153342779      -1.30045955160      -1.30910820210      -1.31745756811
+  -1.32548491940      -1.33316659251      -1.34047797854      -1.34739351331
+  -1.35388667004      -1.35992995498      -1.36549490615      -1.37055209566
+  -1.37507113579      -1.37902068929      -1.38236848418      -1.38508133341
+  -1.38712515978      -1.38846502642      -1.38906517328      -1.38888905981
+  -1.38789941434      -1.38605829043      -1.38332713044      -1.37966683660
+  -1.37503784995      -1.36940023715      -1.36271378549      -1.35493810615
+  -1.34603274564      -1.33595730566      -1.32467157105      -1.31213564573
+  -1.29831009650      -1.28315610420      -1.26663562190      -1.24871153965
+  -1.22934785513      -1.20850984959      -1.18616426835      -1.16227950518
+  -1.13682578953      -1.10977537622      -1.08110273642      -1.05078474960
+  -1.01880089572     -0.985133447470     -0.949767662336     -0.912691974992
+ -0.873898190585     -0.833381680294     -0.791141581061     -0.747181002247
+ -0.701507242814     -0.654132023713     -0.605071741271     -0.554347748667
+ -0.501986673947     -0.448020784483     -0.392488409238     -0.335434431708
+ -0.276910867760     -0.216977543854     -0.155702892061     -0.931648788589E-01
+ -0.294520846861E-01  0.353350495025E-01  0.101082794133      0.167662509686
+  0.234928824818      0.302717612652      0.370843772120      0.439098831658
+  0.507248405722      0.575029550576      0.642148085013      0.708275964026
+  0.773048819157      0.836063807941      0.896877946295      0.955007131033
+   1.00992609393       1.06106956238       1.10783493266       1.14958678739
+   1.18566360601       1.21538702146       1.23807396358       1.25305199440
+   1.25967807652       1.25736091680       1.24558688757       1.22394933952
+   1.19218087996       1.15018789288       1.09808622168       1.03623652350
+  0.965277341363      0.886153436991      0.800136398965      0.708834007789
+  0.614184324929      0.518430000507      0.424067882825      0.333768667742
+  0.250261028723      0.176174362249      0.113833857341      0.650008725343E-01
+  0.305503247694E-01  0.100746499882E-01  0.140057520527E-02  0.287642251351E-06
+   0.00000000000       0.00000000000       0.00000000000       0.00000000000
+   0.00000000000
+  2
+  0.653696258077E-07  0.131561500286E-06  0.198585966050E-06  0.266453495808E-06
+  0.335174694000E-06  0.404760298454E-06  0.475221182061E-06  0.546568354479E-06
+  0.618812963847E-06  0.691966298533E-06  0.766039788894E-06  0.841045009065E-06
+  0.916993678763E-06  0.993897665122E-06  0.107176898455E-05  0.115061980459E-05
+  0.123046244585E-05  0.131130938391E-05  0.139317325125E-05  0.147606683929E-05
+  0.156000310031E-05  0.164499514951E-05  0.173105626710E-05  0.181819990027E-05
+  0.190643966542E-05  0.199578935017E-05  0.208626291561E-05  0.217787449840E-05
+  0.227063841304E-05  0.236456915410E-05  0.245968139842E-05  0.255599000751E-05
+  0.265351002976E-05  0.275225670289E-05  0.285224545627E-05  0.295349191333E-05
+  0.305601189404E-05  0.315982141737E-05  0.326493670375E-05  0.337137417767E-05
+  0.347915047020E-05  0.358828242159E-05  0.369878708396E-05  0.381068172386E-05
+  0.392398382507E-05  0.403871109127E-05  0.415488144882E-05  0.427251304959E-05
+  0.439162427375E-05  0.451223373267E-05  0.463436027182E-05  0.475802297373E-05
+  0.488324116094E-05  0.501003439906E-05  0.513842249977E-05  0.526842552398E-05
+  0.540006378494E-05  0.553335785138E-05  0.566832855078E-05  0.580499697258E-05
+  0.594338447150E-05  0.608351267087E-05  0.622540346601E-05  0.636907902763E-05
+  0.651456180535E-05  0.666187453113E-05  0.681104022290E-05  0.696208218809E-05
+  0.711502402733E-05  0.726988963807E-05  0.742670321840E-05  0.758548927074E-05
+  0.774627260576E-05  0.790907834615E-05  0.807393193067E-05  0.824085911801E-05
+  0.840988599089E-05  0.858103896010E-05  0.875434476863E-05  0.892983049588E-05
+  0.910752356185E-05  0.928745173143E-05  0.946964311878E-05  0.965412619167E-05
+  0.984092977594E-05  0.100300830601E-04  0.102216155996E-04  0.104155573219E-04
+  0.106119385307E-04  0.108107899111E-04  0.110121425339E-04  0.112160278609E-04
+  0.114224777497E-04  0.116315244583E-04  0.118432006509E-04  0.120575394022E-04
+  0.122745742030E-04  0.124943389656E-04  0.127168680287E-04  0.129421961627E-04
+  0.131703585758E-04  0.134013909187E-04  0.136353292908E-04  0.138722102453E-04
+  0.141120707954E-04  0.143549484199E-04  0.146008810688E-04  0.148499071695E-04
+  0.151020656331E-04  0.153573958596E-04  0.156159377450E-04  0.158777316870E-04
+  0.161428185914E-04  0.164112398786E-04  0.166830374900E-04  0.169582538944E-04
+  0.172369320950E-04  0.175191156359E-04  0.178048486087E-04  0.180941756600E-04
+  0.183871419975E-04  0.186837933979E-04  0.189841762135E-04  0.192883373799E-04
+  0.195963244227E-04  0.199081854657E-04  0.202239692376E-04  0.205437250804E-04
+  0.208675029566E-04  0.211953534572E-04  0.215273278093E-04  0.218634778848E-04
+  0.222038562077E-04  0.225485159628E-04  0.228975110039E-04  0.232508958623E-04
+  0.236087257550E-04  0.239710565937E-04  0.243379449932E-04  0.247094482807E-04
+  0.250856245043E-04  0.254665324423E-04  0.258522316124E-04  0.262427822807E-04
+  0.266382454717E-04  0.270386829773E-04  0.274441573667E-04  0.278547319960E-04
+  0.282704710184E-04  0.286914393940E-04  0.291177028998E-04  0.295493281405E-04
+  0.299863825584E-04  0.304289344441E-04  0.308770529472E-04  0.313308080873E-04
+  0.317902707643E-04  0.322555127704E-04  0.327266068005E-04  0.332036264641E-04
+  0.336866462963E-04  0.341757417701E-04  0.346709893077E-04  0.351724662923E-04
+  0.356802510810E-04  0.361944230159E-04  0.367150624377E-04  0.372422506972E-04
+  0.377760701687E-04  0.383166042625E-04  0.388639374382E-04  0.394181552178E-04
+  0.399793441988E-04  0.405475920682E-04  0.411229876160E-04  0.417056207487E-04
+  0.422955825041E-04  0.428929650648E-04  0.434978617731E-04  0.441103671453E-04
+  0.447305768867E-04  0.453585879063E-04  0.459944983320E-04  0.466384075262E-04
+  0.472904161011E-04  0.479506259341E-04  0.486191401846E-04  0.492960633091E-04
+  0.499815010784E-04  0.506755605935E-04  0.513783503025E-04  0.520899800178E-04
+  0.528105609330E-04  0.535402056404E-04  0.542790281483E-04  0.550271438994E-04
+  0.557846697881E-04  0.565517241796E-04  0.573284269275E-04  0.581148993933E-04
+  0.589112644650E-04  0.597176465760E-04  0.605341717254E-04  0.613609674968E-04
+  0.621981630788E-04  0.630458892848E-04  0.639042785738E-04  0.647734650709E-04
+  0.656535845882E-04  0.665447746463E-04  0.674471744952E-04  0.683609251370E-04
+  0.692861693469E-04  0.702230516962E-04  0.711717185748E-04  0.721323182138E-04
+  0.731050007088E-04  0.740899180434E-04  0.750872241130E-04  0.760970747486E-04
+  0.771196277415E-04  0.781550428677E-04  0.792034819129E-04  0.802651086978E-04
+  0.813400891037E-04  0.824285910987E-04  0.835307847631E-04  0.846468423172E-04
+  0.857769381473E-04  0.869212488328E-04  0.880799531749E-04  0.892532322234E-04
+  0.904412693056E-04  0.916442500546E-04  0.928623624387E-04  0.940957967904E-04
+  0.953447458363E-04  0.966094047273E-04  0.978899710689E-04  0.991866449521E-04
+  0.100499628985E-03  0.101829128324E-03  0.103175350706E-03  0.104538506480E-03
+  0.105918808644E-03  0.107316472872E-03  0.108731717551E-03  0.110164763817E-03
+  0.111615835586E-03  0.113085159591E-03  0.114572965417E-03  0.116079485536E-03
+  0.117604955345E-03  0.119149613203E-03  0.120713700464E-03  0.122297461522E-03
+  0.123901143841E-03  0.125524998000E-03  0.127169277731E-03  0.128834239954E-03
+  0.130520144824E-03  0.132227255766E-03  0.133955839521E-03  0.135706166183E-03
+  0.137478509244E-03  0.139273145636E-03  0.141090355775E-03  0.142930423604E-03
+  0.144793636636E-03  0.146680286004E-03  0.148590666499E-03  0.150525076623E-03
+  0.152483818631E-03  0.154467198580E-03  0.156475526378E-03  0.158509115830E-03
+  0.160568284687E-03  0.162653354701E-03  0.164764651667E-03  0.166902505479E-03
+  0.169067250182E-03  0.171259224022E-03  0.173478769498E-03  0.175726233419E-03
+  0.178001966956E-03  0.180306325698E-03  0.182639669704E-03  0.185002363564E-03
+  0.187394776455E-03  0.189817282195E-03  0.192270259307E-03  0.194754091072E-03
+  0.197269165595E-03  0.199815875861E-03  0.202394619798E-03  0.205005800341E-03
+  0.207649825492E-03  0.210327108385E-03  0.213038067351E-03  0.215783125984E-03
+  0.218562713203E-03  0.221377263325E-03  0.224227216130E-03  0.227113016928E-03
+  0.230035116631E-03  0.232993971824E-03  0.235990044834E-03  0.239023803803E-03
+  0.242095722762E-03  0.245206281704E-03  0.248355966662E-03  0.251545269779E-03
+  0.254774689391E-03  0.258044730101E-03  0.261355902860E-03  0.264708725045E-03
+  0.268103720541E-03  0.271541419823E-03  0.275022360039E-03  0.278547085093E-03
+  0.282116145731E-03  0.285730099625E-03  0.289389511462E-03  0.293094953034E-03
+  0.296847003323E-03  0.300646248595E-03  0.304493282490E-03  0.308388706114E-03
+  0.312333128135E-03  0.316327164877E-03  0.320371440417E-03  0.324466586681E-03
+  0.328613243544E-03  0.332812058929E-03  0.337063688910E-03  0.341368797813E-03
+  0.345728058319E-03  0.350142151572E-03  0.354611767284E-03  0.359137603840E-03
+  0.363720368412E-03  0.368360777066E-03  0.373059554875E-03  0.377817436033E-03
+  0.382635163969E-03  0.387513491462E-03  0.392453180761E-03  0.397455003702E-03
+  0.402519741831E-03  0.407648186523E-03  0.412841139108E-03  0.418099410996E-03
+  0.423423823801E-03  0.428815209475E-03  0.434274410432E-03  0.439802279684E-03
+  0.445399680972E-03  0.451067488900E-03  0.456806589075E-03  0.462617878244E-03
+  0.468502264432E-03  0.474460667087E-03  0.480494017220E-03  0.486603257556E-03
+  0.492789342675E-03  0.499053239165E-03  0.505395925775E-03  0.511818393560E-03
+  0.518321646045E-03  0.524906699376E-03  0.531574582480E-03  0.538326337230E-03
+  0.545163018599E-03  0.552085694834E-03  0.559095447615E-03  0.566193372233E-03
+  0.573380577750E-03  0.580658187184E-03  0.588027337676E-03  0.595489180669E-03
+  0.603044882093E-03  0.610695622541E-03  0.618442597456E-03  0.626287017320E-03
+  0.634230107838E-03  0.642273110135E-03  0.650417280946E-03  0.658663892816E-03
+  0.667014234292E-03  0.675469610133E-03  0.684031341510E-03  0.692700766209E-03
+  0.701479238845E-03  0.710368131074E-03  0.719368831803E-03  0.728482747409E-03
+  0.737711301959E-03  0.747055937436E-03  0.756518113956E-03  0.766099310004E-03
+  0.775801022661E-03  0.785624767840E-03  0.795572080521E-03  0.805644514991E-03
+  0.815843645089E-03  0.826171064449E-03  0.836628386752E-03  0.847217245975E-03
+  0.857939296650E-03  0.868796214117E-03  0.879789694793E-03  0.890921456432E-03
+  0.902193238392E-03  0.913606801915E-03  0.925163930390E-03  0.936866429644E-03
+  0.948716128214E-03  0.960714877642E-03  0.972864552755E-03  0.985167051965E-03
+  0.997624297561E-03  0.101023823601E-02  0.102301083828E-02  0.103594410010E-02
+  0.104904004232E-02  0.106230071121E-02  0.107572817878E-02  0.108932454309E-02
+  0.110309192861E-02  0.111703248651E-02  0.113114839504E-02  0.114544185983E-02
+  0.115991511428E-02  0.117457041984E-02  0.118941006645E-02  0.120443637283E-02
+  0.121965168686E-02  0.123505838597E-02  0.125065887750E-02  0.126645559904E-02
+  0.128245101886E-02  0.129864763629E-02  0.131504798207E-02  0.133165461879E-02
+  0.134847014127E-02  0.136549717698E-02  0.138273838641E-02  0.140019646354E-02
+  0.141787413622E-02  0.143577416664E-02  0.145389935171E-02  0.147225252351E-02
+  0.149083654977E-02  0.150965433428E-02  0.152870881736E-02  0.154800297629E-02
+  0.156753982584E-02  0.158732241868E-02  0.160735384586E-02  0.162763723735E-02
+  0.164817576245E-02  0.166897263035E-02  0.169003109061E-02  0.171135443364E-02
+  0.173294599126E-02  0.175480913718E-02  0.177694728757E-02  0.179936390155E-02
+  0.182206248177E-02  0.184504657490E-02  0.186831977226E-02  0.189188571033E-02
+  0.191574807133E-02  0.193991058379E-02  0.196437702315E-02  0.198915121233E-02
+  0.201423702235E-02  0.203963837290E-02  0.206535923298E-02  0.209140362153E-02
+  0.211777560802E-02  0.214447931313E-02  0.217151890933E-02  0.219889862163E-02
+  0.222662272813E-02  0.225469556078E-02  0.228312150600E-02  0.231190500538E-02
+  0.234105055639E-02  0.237056271306E-02  0.240044608670E-02  0.243070534665E-02
+  0.246134522094E-02  0.249237049710E-02  0.252378602286E-02  0.255559670695E-02
+  0.258780751981E-02  0.262042349443E-02  0.265344972709E-02  0.268689137816E-02
+  0.272075367295E-02  0.275504190246E-02  0.278976142427E-02  0.282491766333E-02
+  0.286051611283E-02  0.289656233504E-02  0.293306196223E-02  0.297002069747E-02
+  0.300744431559E-02  0.304533866403E-02  0.308370966382E-02  0.312256331042E-02
+  0.316190567472E-02  0.320174290398E-02  0.324208122274E-02  0.328292693389E-02
+  0.332428641953E-02  0.336616614209E-02  0.340857264523E-02  0.345151255496E-02
+  0.349499258061E-02  0.353901951588E-02  0.358360023994E-02  0.362874171847E-02
+  0.367445100476E-02  0.372073524083E-02  0.376760165850E-02  0.381505758055E-02
+  0.386311042189E-02  0.391176769064E-02  0.396103698938E-02  0.401092601630E-02
+  0.406144256640E-02  0.411259453274E-02  0.416438990762E-02  0.421683678386E-02
+  0.426994335608E-02  0.432371792192E-02  0.437816888341E-02  0.443330474823E-02
+  0.448913413105E-02  0.454566575488E-02  0.460290845241E-02  0.466087116744E-02
+  0.471956295622E-02  0.477899298888E-02  0.483917055088E-02  0.490010504443E-02
+  0.496180598998E-02  0.502428302769E-02  0.508754591895E-02  0.515160454787E-02
+  0.521646892285E-02  0.528214917815E-02  0.534865557542E-02  0.541599850536E-02
+  0.548418848929E-02  0.555323618082E-02  0.562315236751E-02  0.569394797252E-02
+  0.576563405634E-02  0.583822181852E-02  0.591172259938E-02  0.598614788180E-02
+  0.606150929299E-02  0.613781860634E-02  0.621508774319E-02  0.629332877474E-02
+  0.637255392389E-02  0.645277556717E-02  0.653400623662E-02  0.661625862181E-02
+  0.669954557172E-02  0.678388009681E-02  0.686927537103E-02  0.695574473379E-02
+  0.704330169216E-02  0.713195992282E-02  0.722173327433E-02  0.731263576912E-02
+  0.740468160580E-02  0.749788516128E-02  0.759226099301E-02  0.768782384125E-02
+  0.778458863132E-02  0.788257047595E-02  0.798178467755E-02  0.808224673064E-02
+  0.818397232420E-02  0.828697734410E-02  0.839127787554E-02  0.849689020554E-02
+  0.860383082542E-02  0.871211643338E-02  0.882176393701E-02  0.893279045592E-02
+  0.904521332437E-02  0.915905009388E-02  0.927431853596E-02  0.939103664480E-02
+  0.950922264005E-02  0.962889496955E-02  0.975007231217E-02  0.987277358064E-02
+  0.999701792443E-02  0.101228247326E-01  0.102502136370E-01  0.103792045146E-01
+  0.105098174913E-01  0.106420729444E-01  0.107759915058E-01  0.109115940653E-01
+  0.110489017733E-01  0.111879360444E-01  0.113287185604E-01  0.114712712733E-01
+  0.116156164092E-01  0.117617764706E-01  0.119097742409E-01  0.120596327866E-01
+  0.122113754615E-01  0.123650259098E-01  0.125206080693E-01  0.126781461755E-01
+  0.128376647644E-01  0.129991886765E-01  0.131627430602E-01  0.133283533754E-01
+  0.134960453969E-01  0.136658452183E-01  0.138377792558E-01  0.140118742514E-01
+  0.141881572769E-01  0.143666557376E-01  0.145473973761E-01  0.147304102758E-01
+  0.149157228651E-01  0.151033639207E-01  0.152933625719E-01  0.154857483042E-01
+  0.156805509627E-01  0.158778007569E-01  0.160775282635E-01  0.162797644311E-01
+  0.164845405833E-01  0.166918884232E-01  0.169018400367E-01  0.171144278965E-01
+  0.173296848660E-01  0.175476442030E-01  0.177683395634E-01  0.179918050048E-01
+  0.182180749906E-01  0.184471843931E-01  0.186791684975E-01  0.189140630053E-01
+  0.191519040378E-01  0.193927281395E-01  0.196365722815E-01  0.198834738645E-01
+  0.201334707223E-01  0.203866011248E-01  0.206429037807E-01  0.209024178406E-01
+  0.211651828996E-01  0.214312389998E-01  0.217006266327E-01  0.219733867415E-01
+  0.222495607228E-01  0.225291904289E-01  0.228123181691E-01  0.230989867111E-01
+  0.233892392819E-01  0.236831195690E-01  0.239806717207E-01  0.242819403462E-01
+  0.245869705155E-01  0.248958077590E-01  0.252084980663E-01  0.255250878850E-01
+  0.258456241190E-01  0.261701541257E-01  0.264987257135E-01  0.268313871383E-01
+  0.271681870993E-01  0.275091747345E-01  0.278543996150E-01  0.282039117393E-01
+  0.285577615257E-01  0.289159998052E-01  0.292786778122E-01  0.296458471751E-01
+  0.300175599055E-01  0.303938683867E-01  0.307748253600E-01  0.311604839111E-01
+  0.315508974543E-01  0.319461197155E-01  0.323462047137E-01  0.327512067408E-01
+  0.331611803401E-01  0.335761802821E-01  0.339962615397E-01  0.344214792599E-01
+  0.348518887344E-01  0.352875453674E-01  0.357285046410E-01  0.361748220781E-01
+  0.366265532024E-01  0.370837534957E-01  0.375464783518E-01  0.380147830271E-01
+  0.384887225880E-01  0.389683518544E-01  0.394537253392E-01  0.399448971839E-01
+  0.404419210894E-01  0.409448502422E-01  0.414537372365E-01  0.419686339897E-01
+  0.424895916532E-01  0.430166605173E-01  0.435498899102E-01  0.440893280894E-01
+  0.446350221273E-01  0.451870177893E-01  0.457453594037E-01  0.463100897240E-01
+  0.468812497824E-01  0.474588787344E-01  0.480430136939E-01  0.486336895577E-01
+  0.492309388206E-01  0.498347913781E-01  0.504452743183E-01  0.510624117010E-01
+  0.516862243238E-01  0.523167294750E-01  0.529539406720E-01  0.535978673840E-01
+  0.542485147402E-01  0.549058832203E-01  0.555699683280E-01  0.562407602469E-01
+  0.569182434762E-01  0.576023964475E-01  0.582931911204E-01  0.589905925560E-01
+  0.596945584680E-01  0.604050387502E-01  0.611219749790E-01  0.618452998900E-01
+  0.625749368281E-01  0.633107991695E-01  0.640527897152E-01  0.648008000535E-01
+  0.655547098924E-01  0.663143863591E-01  0.670796832669E-01  0.678504403466E-01
+  0.686264824439E-01  0.694076186792E-01  0.701936415709E-01  0.709843261195E-01
+  0.717794288534E-01  0.725786868337E-01  0.733818166192E-01  0.741885131898E-01
+  0.749984488271E-01  0.758112719544E-01  0.766266059330E-01  0.774440478165E-01
+  0.782631670628E-01  0.790835042039E-01  0.799045694751E-01  0.807258414029E-01
+  0.815467653546E-01  0.823667520503E-01  0.831851760389E-01  0.840013741418E-01
+  0.848146438661E-01  0.856242417908E-01  0.864293819314E-01  0.872292340849E-01
+  0.880229221640E-01  0.888095225229E-01  0.895880622848E-01  0.903575176766E-01
+  0.911168123810E-01  0.918648159141E-01  0.926003420418E-01  0.933221472437E-01
+  0.940289292409E-01  0.947193256002E-01  0.953919124307E-01  0.960452031913E-01
+  0.966776476273E-01  0.972876308563E-01  0.978734726264E-01  0.984334267703E-01
+  0.989656808807E-01  0.994683562357E-01  0.999395080028E-01  0.100377125753
+  0.100779134320      0.101143395038      0.101467707393      0.101749811138
+  0.101987388894      0.102178069301      0.102319430742      0.102409005703
+  0.102444285810      0.102422727577      0.102341758939      0.102198786591
+  0.101991204204      0.101716401543      0.101371774549      0.100954736419
+  0.100462729725      0.998932396091E-01  0.992438080876E-01  0.985120494818E-01
+  0.976956670024E-01  0.967924704913E-01  0.958003953229E-01  0.947175224534E-01
+  0.935420995950E-01  0.922725634762E-01  0.909075631358E-01  0.894459841797E-01
+  0.878869739093E-01  0.862299672132E-01  0.844747130871E-01  0.826213016271E-01
+  0.806701913137E-01  0.786222363790E-01  0.764787140202E-01  0.742413511980E-01
+  0.719123507261E-01  0.694944163303E-01  0.669907763313E-01  0.644052055714E-01
+  0.617420451859E-01  0.590062197925E-01  0.562032516518E-01  0.533392713361E-01
+  0.504210244271E-01  0.474558737566E-01  0.444517967003E-01  0.414173770348E-01
+  0.383617908792E-01  0.352947862550E-01  0.322266558196E-01  0.291682023574E-01
+  0.261306966429E-01  0.231258273314E-01  0.201656425736E-01  0.172624830944E-01
+  0.144289065238E-01  0.116776028121E-01  0.902130060265E-02  0.647266447442E-02
+  0.404418299756E-02  0.174804756906E-02 -0.403977985241E-03 -0.240069704234E-02
+ -0.423162903346E-02 -0.588716747810E-02 -0.735874712133E-02 -0.863902001457E-02
+ -0.972204023902E-02 -0.106034567376E-01 -0.112807133574E-01 -0.117532546609E-01
+ -0.120227352800E-01 -0.120932295000E-01 -0.119714362842E-01 -0.116668730079E-01
+ -0.111920486637E-01 -0.105626041374E-01 -0.979740324930E-02 -0.891855351394E-02
+ -0.795132993309E-02 -0.692396853740E-02 -0.586728880457E-02 -0.481409548106E-02
+ -0.379830070971E-02 -0.285369669217E-02 -0.201229730751E-02 -0.130215399181E-02
+ -0.744536403556E-03 -0.350351365307E-03 -0.115653402770E-03 -0.160757482035E-04
+  0.192726474779E-07   0.00000000000       0.00000000000       0.00000000000
+   0.00000000000
+  3
+ -0.240524277161E-06 -0.484073977286E-06 -0.730687155513E-06 -0.980402345651E-06
+ -0.123325856621E-05 -0.148929532648E-05 -0.174855263273E-05 -0.201107099445E-05
+ -0.227689143066E-05 -0.254605547635E-05 -0.281860518894E-05 -0.309458315488E-05
+ -0.337403249629E-05 -0.365699687770E-05 -0.394352051287E-05 -0.423364817171E-05
+ -0.452742518724E-05 -0.482489746272E-05 -0.512611147880E-05 -0.543111430079E-05
+ -0.573995358600E-05 -0.605267759118E-05 -0.636933518012E-05 -0.668997583119E-05
+ -0.701464964515E-05 -0.734340735294E-05 -0.767630032364E-05 -0.801338057243E-05
+ -0.835470076880E-05 -0.870031424472E-05 -0.905027500299E-05 -0.940463772571E-05
+ -0.976345778276E-05 -0.101267912405E-04 -0.104946948706E-04 -0.108672261586E-04
+ -0.112444433134E-04 -0.116264052758E-04 -0.120131717283E-04 -0.124048031039E-04
+ -0.128013605958E-04 -0.132029061669E-04 -0.136095025595E-04 -0.140212133051E-04
+ -0.144381027343E-04 -0.148602359871E-04 -0.152876790225E-04 -0.157204986294E-04
+ -0.161587624368E-04 -0.166025389242E-04 -0.170518974326E-04 -0.175069081753E-04
+ -0.179676422486E-04 -0.184341716431E-04 -0.189065692550E-04 -0.193849088973E-04
+ -0.198692653116E-04 -0.203597141797E-04 -0.208563321350E-04 -0.213591967753E-04
+ -0.218683866740E-04 -0.223839813932E-04 -0.229060614956E-04 -0.234347085573E-04
+ -0.239700051804E-04 -0.245120350062E-04 -0.250608827278E-04 -0.256166341039E-04
+ -0.261793759718E-04 -0.267491962610E-04 -0.273261840071E-04 -0.279104293655E-04
+ -0.285020236260E-04 -0.291010592261E-04 -0.297076297665E-04 -0.303218300251E-04
+ -0.309437559719E-04 -0.315735047840E-04 -0.322111748610E-04 -0.328568658403E-04
+ -0.335106786122E-04 -0.341727153363E-04 -0.348430794574E-04 -0.355218757210E-04
+ -0.362092101906E-04 -0.369051902634E-04 -0.376099246879E-04 -0.383235235802E-04
+ -0.390460984416E-04 -0.397777621759E-04 -0.405186291069E-04 -0.412688149968E-04
+ -0.420284370636E-04 -0.427976139997E-04 -0.435764659906E-04 -0.443651147335E-04
+ -0.451636834564E-04 -0.459722969373E-04 -0.467910815237E-04 -0.476201651524E-04
+ -0.484596773693E-04 -0.493097493499E-04 -0.501705139197E-04 -0.510421055750E-04
+ -0.519246605037E-04 -0.528183166067E-04 -0.537232135198E-04 -0.546394926348E-04
+ -0.555672971223E-04 -0.565067719536E-04 -0.574580639235E-04 -0.584213216733E-04
+ -0.593966957141E-04 -0.603843384499E-04 -0.613844042021E-04 -0.623970492329E-04
+ -0.634224317701E-04 -0.644607120319E-04 -0.655120522516E-04 -0.665766167033E-04
+ -0.676545717274E-04 -0.687460857566E-04 -0.698513293420E-04 -0.709704751804E-04
+ -0.721036981404E-04 -0.732511752905E-04 -0.744130859263E-04 -0.755896115988E-04
+ -0.767809361425E-04 -0.779872457041E-04 -0.792087287722E-04 -0.804455762058E-04
+ -0.816979812649E-04 -0.829661396404E-04 -0.842502494845E-04 -0.855505114421E-04
+ -0.868671286817E-04 -0.882003069275E-04 -0.895502544912E-04 -0.909171823049E-04
+ -0.923013039539E-04 -0.937028357100E-04 -0.951219965654E-04 -0.965590082668E-04
+ -0.980140953502E-04 -0.994874851760E-04 -0.100979407964E-03 -0.102490096831E-03
+ -0.104019787825E-03 -0.105568719962E-03 -0.107137135268E-03 -0.108725278809E-03
+ -0.110333398737E-03 -0.111961746323E-03 -0.113610576001E-03 -0.115280145403E-03
+ -0.116970715403E-03 -0.118682550155E-03 -0.120415917138E-03 -0.122171087194E-03
+ -0.123948334571E-03 -0.125747936968E-03 -0.127570175577E-03 -0.129415335125E-03
+ -0.131283703924E-03 -0.133175573909E-03 -0.135091240689E-03 -0.137031003591E-03
+ -0.138995165706E-03 -0.140984033940E-03 -0.142997919056E-03 -0.145037135728E-03
+ -0.147102002589E-03 -0.149192842277E-03 -0.151309981491E-03 -0.153453751038E-03
+ -0.155624485886E-03 -0.157822525218E-03 -0.160048212480E-03 -0.162301895442E-03
+ -0.164583926246E-03 -0.166894661464E-03 -0.169234462153E-03 -0.171603693911E-03
+ -0.174002726936E-03 -0.176431936082E-03 -0.178891700918E-03 -0.181382405786E-03
+ -0.183904439864E-03 -0.186458197226E-03 -0.189044076902E-03 -0.191662482939E-03
+ -0.194313824470E-03 -0.196998515772E-03 -0.199716976334E-03 -0.202469630919E-03
+ -0.205256909638E-03 -0.208079248006E-03 -0.210937087021E-03 -0.213830873225E-03
+ -0.216761058779E-03 -0.219728101530E-03 -0.222732465084E-03 -0.225774618880E-03
+ -0.228855038260E-03 -0.231974204546E-03 -0.235132605113E-03 -0.238330733470E-03
+ -0.241569089328E-03 -0.244848178689E-03 -0.248168513917E-03 -0.251530613820E-03
+ -0.254935003734E-03 -0.258382215602E-03 -0.261872788057E-03 -0.265407266509E-03
+ -0.268986203226E-03 -0.272610157426E-03 -0.276279695358E-03 -0.279995390394E-03
+ -0.283757823121E-03 -0.287567581426E-03 -0.291425260591E-03 -0.295331463386E-03
+ -0.299286800164E-03 -0.303291888953E-03 -0.307347355558E-03 -0.311453833654E-03
+ -0.315611964884E-03 -0.319822398968E-03 -0.324085793792E-03 -0.328402815521E-03
+ -0.332774138699E-03 -0.337200446354E-03 -0.341682430105E-03 -0.346220790272E-03
+ -0.350816235981E-03 -0.355469485283E-03 -0.360181265255E-03 -0.364952312123E-03
+ -0.369783371372E-03 -0.374675197867E-03 -0.379628555964E-03 -0.384644219636E-03
+ -0.389722972590E-03 -0.394865608392E-03 -0.400072930589E-03 -0.405345752837E-03
+ -0.410684899023E-03 -0.416091203401E-03 -0.421565510717E-03 -0.427108676342E-03
+ -0.432721566407E-03 -0.438405057938E-03 -0.444160038991E-03 -0.449987408795E-03
+ -0.455888077888E-03 -0.461862968260E-03 -0.467913013502E-03 -0.474039158945E-03
+ -0.480242361811E-03 -0.486523591364E-03 -0.492883829059E-03 -0.499324068695E-03
+ -0.505845316573E-03 -0.512448591652E-03 -0.519134925706E-03 -0.525905363489E-03
+ -0.532760962896E-03 -0.539702795128E-03 -0.546731944860E-03 -0.553849510411E-03
+ -0.561056603916E-03 -0.568354351497E-03 -0.575743893442E-03 -0.583226384383E-03
+ -0.590802993473E-03 -0.598474904573E-03 -0.606243316436E-03 -0.614109442891E-03
+ -0.622074513036E-03 -0.630139771430E-03 -0.638306478286E-03 -0.646575909668E-03
+ -0.654949357692E-03 -0.663428130727E-03 -0.672013553597E-03 -0.680706967792E-03
+ -0.689509731677E-03 -0.698423220701E-03 -0.707448827615E-03 -0.716587962687E-03
+ -0.725842053928E-03 -0.735212547306E-03 -0.744700906982E-03 -0.754308615529E-03
+ -0.764037174173E-03 -0.773888103021E-03 -0.783862941300E-03 -0.793963247598E-03
+ -0.804190600110E-03 -0.814546596880E-03 -0.825032856054E-03 -0.835651016130E-03
+ -0.846402736218E-03 -0.857289696296E-03 -0.868313597475E-03 -0.879476162259E-03
+ -0.890779134824E-03 -0.902224281282E-03 -0.913813389960E-03 -0.925548271679E-03
+ -0.937430760040E-03 -0.949462711705E-03 -0.961646006690E-03 -0.973982548661E-03
+ -0.986474265228E-03 -0.999123108246E-03 -0.101193105412E-02 -0.102490010413E-02
+ -0.103803228470E-02 -0.105132964776E-02 -0.106479427107E-02 -0.107842825848E-02
+ -0.109223374035E-02 -0.110621287380E-02 -0.112036784310E-02 -0.113470086000E-02
+ -0.114921416406E-02 -0.116391002301E-02 -0.117879073310E-02 -0.119385861949E-02
+ -0.120911603656E-02 -0.122456536831E-02 -0.124020902873E-02 -0.125604946217E-02
+ -0.127208914374E-02 -0.128833057967E-02 -0.130477630771E-02 -0.132142889754E-02
+ -0.133829095117E-02 -0.135536510332E-02 -0.137265402186E-02 -0.139016040824E-02
+ -0.140788699784E-02 -0.142583656049E-02 -0.144401190084E-02 -0.146241585884E-02
+ -0.148105131012E-02 -0.149992116653E-02 -0.151902837651E-02 -0.153837592561E-02
+ -0.155796683691E-02 -0.157780417154E-02 -0.159789102913E-02 -0.161823054828E-02
+ -0.163882590708E-02 -0.165968032361E-02 -0.168079705640E-02 -0.170217940500E-02
+ -0.172383071043E-02 -0.174575435575E-02 -0.176795376659E-02 -0.179043241163E-02
+ -0.181319380323E-02 -0.183624149788E-02 -0.185957909685E-02 -0.188321024667E-02
+ -0.190713863976E-02 -0.193136801499E-02 -0.195590215824E-02 -0.198074490301E-02
+ -0.200590013105E-02 -0.203137177291E-02 -0.205716380857E-02 -0.208328026811E-02
+ -0.210972523226E-02 -0.213650283312E-02 -0.216361725472E-02 -0.219107273377E-02
+ -0.221887356022E-02 -0.224702407803E-02 -0.227552868575E-02 -0.230439183730E-02
+ -0.233361804260E-02 -0.236321186830E-02 -0.239317793851E-02 -0.242352093547E-02
+ -0.245424560035E-02 -0.248535673394E-02 -0.251685919741E-02 -0.254875791308E-02
+ -0.258105786520E-02 -0.261376410070E-02 -0.264688173000E-02 -0.268041592778E-02
+ -0.271437193385E-02 -0.274875505388E-02 -0.278357066032E-02 -0.281882419317E-02
+ -0.285452116088E-02 -0.289066714115E-02 -0.292726778188E-02 -0.296432880199E-02
+ -0.300185599234E-02 -0.303985521662E-02 -0.307833241230E-02 -0.311729359151E-02
+ -0.315674484202E-02 -0.319669232816E-02 -0.323714229181E-02 -0.327810105335E-02
+ -0.331957501268E-02 -0.336157065019E-02 -0.340409452777E-02 -0.344715328988E-02
+ -0.349075366452E-02 -0.353490246434E-02 -0.357960658769E-02 -0.362487301967E-02
+ -0.367070883325E-02 -0.371712119037E-02 -0.376411734305E-02 -0.381170463454E-02
+ -0.385989050044E-02 -0.390868246990E-02 -0.395808816675E-02 -0.400811531074E-02
+ -0.405877171870E-02 -0.411006530579E-02 -0.416200408676E-02 -0.421459617712E-02
+ -0.426784979451E-02 -0.432177325989E-02 -0.437637499893E-02 -0.443166354324E-02
+ -0.448764753178E-02 -0.454433571215E-02 -0.460173694199E-02 -0.465986019035E-02
+ -0.471871453911E-02 -0.477830918438E-02 -0.483865343792E-02 -0.489975672865E-02
+ -0.496162860408E-02 -0.502427873180E-02 -0.508771690101E-02 -0.515195302407E-02
+ -0.521699713797E-02 -0.528285940598E-02 -0.534955011922E-02 -0.541707969823E-02
+ -0.548545869464E-02 -0.555469779278E-02 -0.562480781140E-02 -0.569579970533E-02
+ -0.576768456716E-02 -0.584047362906E-02 -0.591417826443E-02 -0.598880998977E-02
+ -0.606438046641E-02 -0.614090150238E-02 -0.621838505422E-02 -0.629684322889E-02
+ -0.637628828560E-02 -0.645673263778E-02 -0.653818885501E-02 -0.662066966495E-02
+ -0.670418795537E-02 -0.678875677615E-02 -0.687438934131E-02 -0.696109903106E-02
+ -0.704889939395E-02 -0.713780414892E-02 -0.722782718747E-02 -0.731898257585E-02
+ -0.741128455722E-02 -0.750474755391E-02 -0.759938616965E-02 -0.769521519186E-02
+ -0.779224959396E-02 -0.789050453770E-02 -0.798999537556E-02 -0.809073765311E-02
+ -0.819274711146E-02 -0.829603968971E-02 -0.840063152746E-02 -0.850653896729E-02
+ -0.861377855736E-02 -0.872236705397E-02 -0.883232142419E-02 -0.894365884848E-02
+ -0.905639672343E-02 -0.917055266442E-02 -0.928614450840E-02 -0.940319031669E-02
+ -0.952170837776E-02 -0.964171721014E-02 -0.976323556526E-02 -0.988628243041E-02
+ -0.100108770317E-01 -0.101370388371E-01 -0.102647875594E-01 -0.103941431594E-01
+ -0.105251258488E-01 -0.106577560936E-01 -0.107920546174E-01 -0.109280424042E-01
+ -0.110657407020E-01 -0.112051710262E-01 -0.113463551626E-01 -0.114893151710E-01
+ -0.116340733889E-01 -0.117806524345E-01 -0.119290752107E-01 -0.120793649081E-01
+ -0.122315450095E-01 -0.123856392925E-01 -0.125416718341E-01 -0.126996670141E-01
+ -0.128596495187E-01 -0.130216443448E-01 -0.131856768036E-01 -0.133517725246E-01
+ -0.135199574596E-01 -0.136902578870E-01 -0.138627004154E-01 -0.140373119882E-01
+ -0.142141198877E-01 -0.143931517390E-01 -0.145744355151E-01 -0.147579995404E-01
+ -0.149438724956E-01 -0.151320834220E-01 -0.153226617264E-01 -0.155156371850E-01
+ -0.157110399488E-01 -0.159089005476E-01 -0.161092498955E-01 -0.163121192949E-01
+ -0.165175404421E-01 -0.167255454319E-01 -0.169361667626E-01 -0.171494373411E-01
+ -0.173653904882E-01 -0.175840599435E-01 -0.178054798709E-01 -0.180296848637E-01
+ -0.182567099503E-01 -0.184865905993E-01 -0.187193627253E-01 -0.189550626944E-01
+ -0.191937273298E-01 -0.194353939176E-01 -0.196801002127E-01 -0.199278844443E-01
+ -0.201787853225E-01 -0.204328420437E-01 -0.206900942968E-01 -0.209505822698E-01
+ -0.212143466557E-01 -0.214814286586E-01 -0.217518700007E-01 -0.220257129283E-01
+ -0.223030002185E-01 -0.225837751861E-01 -0.228680816896E-01 -0.231559641390E-01
+ -0.234474675017E-01 -0.237426373104E-01 -0.240415196693E-01 -0.243441612618E-01
+ -0.246506093575E-01 -0.249609118197E-01 -0.252751171125E-01 -0.255932743085E-01
+ -0.259154330964E-01 -0.262416437886E-01 -0.265719573288E-01 -0.269064253003E-01
+ -0.272450999335E-01 -0.275880341141E-01 -0.279352813913E-01 -0.282868959860E-01
+ -0.286429327990E-01 -0.290034474196E-01 -0.293684961341E-01 -0.297381359343E-01
+ -0.301124245264E-01 -0.304914203394E-01 -0.308751825347E-01 -0.312637710146E-01
+ -0.316572464314E-01 -0.320556701971E-01 -0.324591044923E-01 -0.328676122755E-01
+ -0.332812572933E-01 -0.337001040892E-01 -0.341242180141E-01 -0.345536652356E-01
+ -0.349885127481E-01 -0.354288283830E-01 -0.358746808187E-01 -0.363261395910E-01
+ -0.367832751031E-01 -0.372461586365E-01 -0.377148623615E-01 -0.381894593476E-01
+ -0.386700235744E-01 -0.391566299426E-01 -0.396493542850E-01 -0.401482733772E-01
+ -0.406534649491E-01 -0.411650076962E-01 -0.416829812907E-01 -0.422074663932E-01
+ -0.427385446640E-01 -0.432762987751E-01 -0.438208124215E-01 -0.443721703331E-01
+ -0.449304582868E-01 -0.454957631184E-01 -0.460681727344E-01 -0.466477761243E-01
+ -0.472346633726E-01 -0.478289256712E-01 -0.484306553318E-01 -0.490399457976E-01
+ -0.496568916565E-01 -0.502815886529E-01 -0.509141337003E-01 -0.515546248939E-01
+ -0.522031615229E-01 -0.528598440830E-01 -0.535247742889E-01 -0.541980550869E-01
+ -0.548797906669E-01 -0.555700864752E-01 -0.562690492267E-01 -0.569767869172E-01
+ -0.576934088353E-01 -0.584190255750E-01 -0.591537490473E-01 -0.598976924921E-01
+ -0.606509704901E-01 -0.614136989740E-01 -0.621859952401E-01 -0.629679779595E-01
+ -0.637597671884E-01 -0.645614843795E-01 -0.653732523915E-01 -0.661951954999E-01
+ -0.670274394058E-01 -0.678701112457E-01 -0.687233396000E-01 -0.695872545015E-01
+ -0.704619874427E-01 -0.713476713839E-01 -0.722444407587E-01 -0.731524314810E-01
+ -0.740717809494E-01 -0.750026280523E-01 -0.759451131709E-01 -0.768993781825E-01
+ -0.778655664616E-01 -0.788438228813E-01 -0.798342938123E-01 -0.808371271212E-01
+ -0.818524721680E-01 -0.828804798015E-01 -0.839213023531E-01 -0.849750936298E-01
+ -0.860420089049E-01 -0.871222049065E-01 -0.882158398052E-01 -0.893230731983E-01
+ -0.904440660927E-01 -0.915789808853E-01 -0.927279813399E-01 -0.938912325628E-01
+ -0.950689009745E-01 -0.962611542782E-01 -0.974681614254E-01 -0.986900925781E-01
+ -0.999271190662E-01 -0.101179413342     -0.102447148931     -0.103730500373
+ -0.105029643170     -0.106344753711     -0.107676009212     -0.109023587632
+ -0.110387667595     -0.111768428298     -0.113166049416     -0.114580711000
+ -0.116012593362     -0.117461876957     -0.118928742255     -0.120413369601
+ -0.121915939065     -0.123436630287     -0.124975622303     -0.126533093364
+ -0.128109220742     -0.129704180518     -0.131318147363     -0.132951294297
+ -0.134603792438     -0.136275810730     -0.137967515655     -0.139679070922
+ -0.141410637147     -0.143162371499     -0.144934427330     -0.146726953783
+ -0.148540095373     -0.150373991538     -0.152228776174     -0.154104577124
+ -0.156001515653     -0.157919705879     -0.159859254178     -0.161820258544
+ -0.163802807922     -0.165806981493     -0.167832847922     -0.169880464556
+ -0.171949876588     -0.174041116158     -0.176154201415     -0.178289135518
+ -0.180445905587     -0.182624481589     -0.184824815174     -0.187046838433
+ -0.189290462599     -0.191555576677     -0.193842045997     -0.196149710696
+ -0.198478384117     -0.200827851129     -0.203197866358     -0.205588152334
+ -0.207998397536     -0.210428254358     -0.212877336955     -0.215345219008
+ -0.217831431365     -0.220335459585     -0.222856741368     -0.225394663863
+ -0.227948560868     -0.230517709902     -0.233101329159     -0.235698574329
+ -0.238308535304     -0.240930232739     -0.243562614501     -0.246204551969
+ -0.248854836218     -0.251512174064     -0.254175183982     -0.256842391898
+ -0.259512226853     -0.262183016549     -0.264852982782     -0.267520236757
+ -0.270182774308     -0.272838471023     -0.275485077284     -0.278120213239
+ -0.280741363715     -0.283345873098     -0.285930940178     -0.288493613010
+ -0.291030783786     -0.293539183767     -0.296015378284     -0.298455761861
+ -0.300856553485     -0.303213792063     -0.305523332115     -0.307780839754
+ -0.309981788989     -0.312121458433     -0.314194928462     -0.316197078892
+ -0.318122587257     -0.319965927755     -0.321721370950     -0.323382984318
+ -0.324944633734     -0.326399985989     -0.327742512452     -0.328965493987
+ -0.330062027227     -0.331025032339     -0.331847262388     -0.332521314443
+ -0.333039642532     -0.333394572591     -0.333578319535     -0.333583006564
+ -0.333400686857     -0.333023367741     -0.332443037483     -0.331651694783
+ -0.330641381075     -0.329404215711     -0.327932434090     -0.326218428768
+ -0.324254793562     -0.322034370639     -0.319550300531     -0.316796074987
+ -0.313765592538     -0.310453216583     -0.306853835768     -0.302962926352
+ -0.298776616213     -0.294291750060     -0.289505955337     -0.284417708264
+ -0.279026399325     -0.273332397481     -0.267337112275     -0.261043052913
+ -0.254453883348     -0.247574472289     -0.240410937024     -0.232970679871
+ -0.225262416034     -0.217296191643     -0.209083390727     -0.200636729950
+ -0.191970239959     -0.183099232350     -0.174040251379     -0.164811009765
+ -0.155430308216     -0.145917938584     -0.136294571019     -0.126581625886
+ -0.116801131786     -0.106975571603     -0.971277191636E-01 -0.872804698197E-01
+ -0.774566690213E-01 -0.676789437398E-01 -0.579695423815E-01 -0.483501895909E-01
+ -0.388419630257E-01 -0.294651997493E-01 -0.202394402784E-01 -0.111834184637E-01
+ -0.231510521419E-02  0.634818650130E-02  0.147896290010E-01  0.229926348604E-01
+  0.309405370964E-01  0.386161952350E-01  0.460015318426E-01  0.530770088882E-01
+  0.598210589932E-01  0.662094931753E-01  0.722149140241E-01  0.778061711672E-01
+  0.829479041533E-01  0.876002260809E-01  0.917186089364E-01  0.952540379978E-01
+  0.981535069741E-01  0.100360926802      0.101818518057      0.102468748468
+  0.102256861724      0.101134020169      0.990610508977E-01  0.960127409644E-01
+  0.919825722295E-01  0.869877194914E-01  0.810740574546E-01  0.743208340085E-01
+  0.668445714242E-01  0.588016564028E-01  0.503889780340E-01  0.418418731961E-01
+  0.334285443157E-01  0.254400246660E-01  0.181746768233E-01  0.119161084771E-01
+  0.690325437132E-02  0.329116946428E-02  0.110076036316E-02  0.155198032270E-03
+  0.649553563952E-07   0.00000000000       0.00000000000       0.00000000000
+   0.00000000000
+ Core charge follows
+   0.00000000000
+ Valence charge follows
+  0.209512359756E-14  0.848623951791E-14  0.193354711160E-13  0.348097172283E-13
+  0.550807815091E-13  0.803255051462E-13  0.110725903045E-12  0.146469303568E-12
+  0.187748491923E-12  0.234761857293E-12  0.287713543802E-12  0.346813605417E-12
+  0.412278164893E-12  0.484329576850E-12  0.563196595104E-12  0.649114544351E-12
+  0.742325496323E-12  0.843078450518E-12  0.951629519644E-12  0.106824211987E-11
+  0.119318716603E-11  0.132674327189E-11  0.146919695565E-11  0.162084285070E-11
+  0.178198392194E-11  0.195293168769E-11  0.213400644726E-11  0.232553751459E-11
+  0.252786345781E-11  0.274133234502E-11  0.296630199655E-11  0.320314024360E-11
+  0.345222519369E-11  0.371394550292E-11  0.398870065531E-11  0.427690124932E-11
+  0.457896929187E-11  0.489533849983E-11  0.522645460942E-11  0.557277569356E-11
+  0.593477248739E-11  0.631292872226E-11  0.670774146827E-11  0.711972148573E-11
+  0.754939358562E-11  0.799729699941E-11  0.846398575835E-11  0.895002908264E-11
+  0.945601178050E-11  0.998253465769E-11  0.105302149374E-10  0.110996866912E-10
+  0.116916012807E-10  0.123066278112E-10  0.129454535961E-10  0.136087846345E-10
+  0.142973460997E-10  0.150118828418E-10  0.157531599013E-10  0.165219630383E-10
+  0.173190992728E-10  0.181453974410E-10  0.190017087647E-10  0.198889074355E-10
+  0.208078912144E-10  0.217595820464E-10  0.227449266912E-10  0.237648973698E-10
+  0.248204924280E-10  0.259127370166E-10  0.270426837893E-10  0.282114136186E-10
+  0.294200363297E-10  0.306696914536E-10  0.319615489994E-10  0.332968102461E-10
+  0.346767085552E-10  0.361025102039E-10  0.375755152396E-10  0.390970583563E-10
+  0.406685097938E-10  0.422912762591E-10  0.439668018726E-10  0.456965691374E-10
+  0.474820999342E-10  0.493249565413E-10  0.512267426808E-10  0.531891045916E-10
+  0.552137321297E-10  0.573023598972E-10  0.594567683992E-10  0.616787852316E-10
+  0.639702862979E-10  0.663331970583E-10  0.687694938100E-10  0.712812050004E-10
+  0.738704125743E-10  0.765392533549E-10  0.792899204603E-10  0.821246647568E-10
+  0.850457963482E-10  0.880556861045E-10  0.911567672281E-10  0.943515368616E-10
+  0.976425577357E-10  0.101032459859E-09  0.104523942252E-09  0.108119774725E-09
+  0.111822799700E-09  0.115635934080E-09  0.119562171168E-09  0.123604582634E-09
+  0.127766320526E-09  0.132050619346E-09  0.136460798162E-09  0.141000262790E-09
+  0.145672508021E-09  0.150481119905E-09  0.155429778105E-09  0.160522258291E-09
+  0.165762434618E-09  0.171154282246E-09  0.176701879941E-09  0.182409412728E-09
+  0.188281174628E-09  0.194321571445E-09  0.200535123646E-09  0.206926469291E-09
+  0.213500367060E-09  0.220261699341E-09  0.227215475404E-09  0.234366834654E-09
+  0.241721049968E-09  0.249283531116E-09  0.257059828269E-09  0.265055635596E-09
+  0.273276794954E-09  0.281729299673E-09  0.290419298433E-09  0.299353099242E-09
+  0.308537173519E-09  0.317978160274E-09  0.327682870401E-09  0.337658291075E-09
+  0.347911590263E-09  0.358450121353E-09  0.369281427895E-09  0.380413248463E-09
+  0.391853521652E-09  0.403610391183E-09  0.415692211154E-09  0.428107551418E-09
+  0.440865203098E-09  0.453974184242E-09  0.467443745626E-09  0.481283376695E-09
+  0.495502811669E-09  0.510112035790E-09  0.525121291741E-09  0.540541086214E-09
+  0.556382196662E-09  0.572655678203E-09  0.589372870721E-09  0.606545406126E-09
+  0.624185215819E-09  0.642304538327E-09  0.660915927151E-09  0.680032258797E-09
+  0.699666741024E-09  0.719832921294E-09  0.740544695437E-09  0.761816316540E-09
+  0.783662404062E-09  0.806097953173E-09  0.829138344344E-09  0.852799353162E-09
+  0.877097160417E-09  0.902048362421E-09  0.927669981611E-09  0.953979477408E-09
+  0.980994757353E-09  0.100873418853E-08  0.103721660929E-08  0.106646134123E-08
+  0.109648820154E-08  0.112731751560E-08  0.115897012997E-08  0.119146742561E-08
+  0.122483133154E-08  0.125908433877E-08  0.129424951463E-08  0.133035051745E-08
+  0.136741161159E-08  0.140545768288E-08  0.144451425447E-08  0.148460750300E-08
+  0.152576427530E-08  0.156801210539E-08  0.161137923203E-08  0.165589461659E-08
+  0.170158796152E-08  0.174848972914E-08  0.179663116102E-08  0.184604429778E-08
+  0.189676199945E-08  0.194881796629E-08  0.200224676018E-08  0.205708382655E-08
+  0.211336551682E-08  0.217112911148E-08  0.223041284371E-08  0.229125592361E-08
+  0.235369856303E-08  0.241778200106E-08  0.248354853016E-08  0.255104152292E-08
+  0.262030545953E-08  0.269138595598E-08  0.276432979286E-08  0.283918494502E-08
+  0.291600061193E-08  0.299482724879E-08  0.307571659844E-08  0.315872172412E-08
+  0.324389704299E-08  0.333129836056E-08  0.342098290599E-08  0.351300936821E-08
+  0.360743793310E-08  0.370433032141E-08  0.380374982789E-08  0.390576136117E-08
+  0.401043148482E-08  0.411782845939E-08  0.422802228549E-08  0.434108474801E-08
+  0.445708946146E-08  0.457611191642E-08  0.469822952719E-08  0.482352168065E-08
+  0.495206978638E-08  0.508395732800E-08  0.521926991585E-08  0.535809534101E-08
+  0.550052363065E-08  0.564664710483E-08  0.579656043472E-08  0.595036070227E-08
+  0.610814746145E-08  0.627002280099E-08  0.643609140873E-08  0.660646063762E-08
+  0.678124057337E-08  0.696054410379E-08  0.714448698998E-08  0.733318793920E-08
+  0.752676867970E-08  0.772535403734E-08  0.792907201428E-08  0.813805386954E-08
+  0.835243420168E-08  0.857235103353E-08  0.879794589914E-08  0.902936393281E-08
+  0.926675396051E-08  0.951026859353E-08  0.976006432452E-08  0.100163016260E-07
+  0.102791450514E-07  0.105487633383E-07  0.108253295152E-07  0.111090210096E-07
+  0.114000197604E-07  0.116985123316E-07  0.120046900302E-07  0.123187490263E-07
+  0.126408904765E-07  0.129713206502E-07  0.133102510598E-07  0.136578985930E-07
+  0.140144856497E-07  0.143802402817E-07  0.147553963357E-07  0.151401936008E-07
+  0.155348779589E-07  0.159397015392E-07  0.163549228768E-07  0.167808070752E-07
+  0.172176259727E-07  0.176656583130E-07  0.181251899211E-07  0.185965138819E-07
+  0.190799307251E-07  0.195757486133E-07  0.200842835363E-07  0.206058595087E-07
+  0.211408087742E-07  0.216894720137E-07  0.222521985597E-07  0.228293466150E-07
+  0.234212834782E-07  0.240283857742E-07  0.246510396904E-07  0.252896412193E-07
+  0.259445964072E-07  0.266163216089E-07  0.273052437490E-07  0.280118005903E-07
+  0.287364410077E-07  0.294796252710E-07  0.302418253328E-07  0.310235251252E-07
+  0.318252208632E-07  0.326474213563E-07  0.334906483276E-07  0.343554367411E-07
+  0.352423351374E-07  0.361519059779E-07  0.370847259975E-07  0.380413865665E-07
+  0.390224940616E-07  0.400286702460E-07  0.410605526597E-07  0.421187950191E-07
+  0.432040676273E-07  0.443170577941E-07  0.454584702675E-07  0.466290276750E-07
+  0.478294709776E-07  0.490605599335E-07  0.503230735753E-07  0.516178106980E-07
+  0.529455903598E-07  0.543072523960E-07  0.557036579452E-07  0.571356899892E-07
+  0.586042539069E-07  0.601102780413E-07  0.616547142818E-07  0.632385386609E-07
+  0.648627519658E-07  0.665283803660E-07  0.682364760562E-07  0.699881179158E-07
+  0.717844121854E-07  0.736264931597E-07  0.755155238987E-07  0.774526969562E-07
+  0.794392351279E-07  0.814763922167E-07  0.835654538191E-07  0.857077381307E-07
+  0.879045967717E-07  0.901574156346E-07  0.924676157520E-07  0.948366541870E-07
+  0.972660249467E-07  0.997572599173E-07  0.102311929825E-06  0.104931645219E-06
+  0.107618057481E-06  0.110372859860E-06  0.113197788534E-06  0.116094623693E-06
+  0.119065190662E-06  0.122111361037E-06  0.125235053862E-06  0.128438236829E-06
+  0.131722927512E-06  0.135091194630E-06  0.138545159341E-06  0.142086996576E-06
+  0.145718936394E-06  0.149443265385E-06  0.153262328099E-06  0.157178528515E-06
+  0.161194331548E-06  0.165312264590E-06  0.169534919097E-06  0.173864952207E-06
+  0.178305088409E-06  0.182858121246E-06  0.187526915067E-06  0.192314406817E-06
+  0.197223607883E-06  0.202257605971E-06  0.207419567049E-06  0.212712737322E-06
+  0.218140445271E-06  0.223706103731E-06  0.229413212035E-06  0.235265358201E-06
+  0.241266221181E-06  0.247419573162E-06  0.253729281933E-06  0.260199313303E-06
+  0.266833733585E-06  0.273636712146E-06  0.280612524012E-06  0.287765552550E-06
+  0.295100292213E-06  0.302621351349E-06  0.310333455094E-06  0.318241448325E-06
+  0.326350298699E-06  0.334665099760E-06  0.343191074130E-06  0.351933576780E-06
+  0.360898098383E-06  0.370090268753E-06  0.379515860369E-06  0.389180791992E-06
+  0.399091132371E-06  0.409253104041E-06  0.419673087226E-06  0.430357623826E-06
+  0.441313421523E-06  0.452547357975E-06  0.464066485127E-06  0.475878033626E-06
+  0.487989417349E-06  0.500408238051E-06  0.513142290118E-06  0.526199565457E-06
+  0.539588258496E-06  0.553316771319E-06  0.567393718928E-06  0.581827934639E-06
+  0.596628475619E-06  0.611804628550E-06  0.627365915459E-06  0.643322099671E-06
+  0.659683191933E-06  0.676459456682E-06  0.693661418477E-06  0.711299868591E-06
+  0.729385871775E-06  0.747930773185E-06  0.766946205498E-06  0.786444096192E-06
+  0.806436675029E-06  0.826936481711E-06  0.847956373743E-06  0.869509534486E-06
+  0.891609481425E-06  0.914270074636E-06  0.937505525473E-06  0.961330405479E-06
+  0.985759655517E-06  0.101080859514E-05  0.103649293218E-05  0.106282877261E-05
+  0.108983263066E-05  0.111752143912E-05  0.114591256000E-05  0.117502379540E-05
+  0.120487339869E-05  0.123548008593E-05  0.126686304762E-05  0.129904196077E-05
+  0.133203700119E-05  0.136586885617E-05  0.140055873748E-05  0.143612839463E-05
+  0.147260012858E-05  0.150999680567E-05  0.154834187203E-05  0.158765936824E-05
+  0.162797394449E-05  0.166931087597E-05  0.171169607882E-05  0.175515612635E-05
+  0.179971826574E-05  0.184541043517E-05  0.189226128135E-05  0.194030017753E-05
+  0.198955724194E-05  0.204006335674E-05  0.209185018740E-05  0.214495020261E-05
+  0.219939669471E-05  0.225522380062E-05  0.231246652327E-05  0.237116075366E-05
+  0.243134329342E-05  0.249305187796E-05  0.255632520022E-05  0.262120293503E-05
+  0.268772576407E-05  0.275593540149E-05  0.282587462020E-05  0.289758727879E-05
+  0.297111834916E-05  0.304651394490E-05  0.312382135030E-05  0.320308905020E-05
+  0.328436676058E-05  0.336770545987E-05  0.345315742117E-05  0.354077624523E-05
+  0.363061689427E-05  0.372273572671E-05  0.381719053277E-05  0.391404057101E-05
+  0.401334660577E-05  0.411517094560E-05  0.421957748269E-05  0.432663173329E-05
+  0.443640087921E-05  0.454895381037E-05  0.466436116844E-05  0.478269539161E-05
+  0.490403076058E-05  0.502844344565E-05  0.515601155508E-05  0.528681518473E-05
+  0.542093646893E-05  0.555845963272E-05  0.569947104543E-05  0.584405927567E-05
+  0.599231514774E-05  0.614433179951E-05  0.630020474185E-05  0.646003191957E-05
+  0.662391377398E-05  0.679195330709E-05  0.696425614753E-05  0.714093061811E-05
+  0.732208780529E-05  0.750784163037E-05  0.769830892266E-05  0.789360949448E-05
+  0.809386621827E-05  0.829920510565E-05  0.850975538864E-05  0.872564960303E-05
+  0.894702367401E-05  0.917401700400E-05  0.940677256297E-05  0.964543698109E-05
+  0.989016064392E-05  0.101410977902E-04  0.103984066122E-04  0.106622493589E-04
+  0.109327924419E-04  0.112102065444E-04  0.114946667327E-04  0.117863525715E-04
+  0.120854482418E-04  0.123921426621E-04  0.127066296133E-04  0.130291078668E-04
+  0.133597813165E-04  0.136988591136E-04  0.140465558068E-04  0.144030914848E-04
+  0.147686919239E-04  0.151435887397E-04  0.155280195424E-04  0.159222280977E-04
+  0.163264644913E-04  0.167409852993E-04  0.171660537623E-04  0.176019399657E-04
+  0.180489210246E-04  0.185072812750E-04  0.189773124698E-04  0.194593139811E-04
+  0.199535930093E-04  0.204604647970E-04  0.209802528513E-04  0.215132891716E-04
+  0.220599144849E-04  0.226204784890E-04  0.231953401027E-04  0.237848677241E-04
+  0.243894394975E-04  0.250094435887E-04  0.256452784693E-04  0.262973532107E-04
+  0.269660877870E-04  0.276519133893E-04  0.283552727491E-04  0.290766204748E-04
+  0.298164233972E-04  0.305751609298E-04  0.313533254392E-04  0.321514226309E-04
+  0.329699719471E-04  0.338095069803E-04  0.346705759011E-04  0.355537419026E-04
+  0.364595836610E-04  0.373886958138E-04  0.383416894563E-04  0.393191926574E-04
+  0.403218509956E-04  0.413503281162E-04  0.424053063112E-04  0.434874871224E-04
+  0.445975919692E-04  0.457363628031E-04  0.469045627893E-04  0.481029770176E-04
+  0.493324132437E-04  0.505937026632E-04  0.518877007196E-04  0.532152879490E-04
+  0.545773708621E-04  0.559748828675E-04  0.574087852377E-04  0.588800681203E-04
+  0.603897515973E-04  0.619388867953E-04  0.635285570505E-04  0.651598791296E-04
+  0.668340045135E-04  0.685521207437E-04  0.703154528390E-04  0.721252647840E-04
+  0.739828610963E-04  0.758895884753E-04  0.778468375395E-04  0.798560446569E-04
+  0.819186938756E-04  0.840363189591E-04  0.862105055363E-04  0.884428933708E-04
+  0.907351787588E-04  0.930891170639E-04  0.955065253987E-04  0.979892854606E-04
+  0.100539346536E-03  0.103158728681E-03  0.105849526091E-03  0.108613910675E-03
+  0.111454135844E-03  0.114372540533E-03  0.117371553467E-03  0.120453697698E-03
+  0.123621595414E-03  0.126877973059E-03  0.130225666776E-03  0.133667628187E-03
+  0.137206930555E-03  0.140846775335E-03  0.144590499145E-03  0.148441581205E-03
+  0.152403651240E-03  0.156480497926E-03  0.160676077875E-03  0.164994525223E-03
+  0.169440161859E-03  0.174017508330E-03  0.178731295487E-03  0.183586476907E-03
+  0.188588242161E-03  0.193742030980E-03  0.199053548386E-03  0.204528780853E-03
+  0.210174013580E-03  0.215995848944E-03  0.222001226232E-03  0.228197442719E-03
+  0.234592176226E-03  0.241193509218E-03  0.248009954598E-03  0.255050483275E-03
+  0.262324553669E-03  0.269842143270E-03  0.277613782398E-03  0.285650590338E-03
+  0.293964313996E-03  0.302567369270E-03  0.311472885331E-03  0.320694752011E-03
+  0.330247670522E-03  0.340147207744E-03  0.350409854343E-03  0.361053086965E-03
+  0.372095434826E-03  0.383556550981E-03  0.395457288618E-03  0.407819782723E-03
+  0.420667537494E-03  0.434025519910E-03  0.447920259880E-03  0.462379957432E-03
+  0.477434597433E-03  0.493116072373E-03  0.509458313741E-03  0.526497432628E-03
+  0.544271870158E-03  0.562822558437E-03  0.582193092745E-03  0.602429915724E-03
+  0.623582514394E-03  0.645703630849E-03  0.668849487579E-03  0.693080028384E-03
+  0.718459175934E-03  0.745055107086E-03  0.772940547141E-03  0.802193084285E-03
+  0.832895505561E-03  0.865136155770E-03  0.899009320799E-03  0.934615636972E-03
+  0.972062528091E-03  0.101146467196E-02  0.105294449823E-02  0.109663271965E-02
+  0.114266889870E-02  0.119120205188E-02  0.124239129407E-02  0.129640652527E-02
+  0.135342916242E-02  0.141365291905E-02  0.147728463553E-02  0.154454516309E-02
+  0.161567030454E-02  0.169091181535E-02  0.177053846815E-02  0.185483718468E-02
+  0.194411423875E-02  0.203869653411E-02  0.213893296169E-02  0.224519584004E-02
+  0.235788244378E-02  0.247741662453E-02  0.260425052906E-02  0.273886641964E-02
+  0.288177860163E-02  0.303353546354E-02  0.319472163490E-02  0.336596026729E-02
+  0.354791544429E-02  0.374129472572E-02  0.394685183205E-02  0.416538947466E-02
+  0.439776233755E-02  0.464488021643E-02  0.490771132051E-02  0.518728574281E-02
+  0.548469910405E-02  0.580111637548E-02  0.613777588530E-02  0.649599351329E-02
+  0.687716707763E-02  0.728278091747E-02  0.771441067417E-02  0.817372827346E-02
+  0.866250710974E-02  0.918262743315E-02  0.973608193854E-02  0.103249815545E-01
+  0.109515614289E-01  0.116181871067E-01  0.123273608920E-01  0.130817283872E-01
+  0.138840851973E-01  0.147373837861E-01  0.156447404696E-01  0.166094425257E-01
+  0.176349553995E-01  0.187249299787E-01  0.198832099087E-01  0.211138389150E-01
+  0.224210680945E-01  0.238093631329E-01  0.252834114018E-01  0.268481288802E-01
+  0.285086668439E-01  0.302704182561E-01  0.321390237899E-01  0.341203774021E-01
+  0.362206313757E-01  0.384462007383E-01  0.408037669555E-01  0.433002807939E-01
+  0.459429642377E-01  0.487393113353E-01  0.516970878472E-01  0.548243295545E-01
+  0.581293390839E-01  0.616206810955E-01  0.653071756727E-01  0.691978897502E-01
+  0.733021264070E-01  0.776294118498E-01  0.821894799072E-01  0.869922538548E-01
+  0.920478253897E-01  0.973664305741E-01  0.102958422575      0.108834241026
+  0.115004377859      0.121479339444      0.128269604920      0.135385580585
+  0.142837550276      0.150635621646      0.158789668335      0.167309268019
+  0.176203636388      0.185481557155      0.195151308221      0.205220584221
+  0.215696415696      0.226585085237      0.237892041002      0.249621808091
+  0.261777898336      0.274362719174      0.287377482321      0.300822113085
+  0.314695161227      0.328993714387      0.343713315142      0.358847882892
+  0.374389641799      0.390329056102      0.406654774168      0.423353582689
+  0.440410372452      0.457808117132      0.475527866520      0.493548755573
+  0.511848030623      0.530401093946      0.549181567820      0.568161379001
+  0.587310864384      0.606598898389      0.625993042339      0.645459715831
+  0.664964389764      0.684471800340      0.703946182994      0.723351524793
+  0.742651833437      0.761811420597      0.780795196860      0.799568975168
+  0.818099779229      0.836356152962      0.854308466752      0.871929215919
+  0.889193306605      0.906078324046      0.922564778112      0.938636320923
+  0.954279931405      0.969486061788      0.984248741263      0.998565632362
+   1.01243803605       1.02587084203       1.03887242153       1.05145446031
+   1.06363173079       1.07542180291       1.08684469445       1.09792246249
+   1.10867873916       1.11913821563       1.12932607996       1.13926741544
+   1.14898656765       1.15850648937       1.16784807434       1.17702949159
+   1.18606553348       1.19496699162       1.20374007564       1.21238589045
+   1.22089998798       1.22927200956       1.23748543446       1.24551744961
+   1.25333895379       1.26091470783       1.26820363955       1.27515930881
+   1.28173053386       1.28786217522       1.29349606773       1.29857208476
+   1.30302931159       1.30680729725       1.30984734579       1.31209379963
+   1.31349525870       1.31400567051       1.31358521766       1.31220092074
+   1.30982686673       1.30644398932       1.30203951897       1.29660657336
+   1.29014394703       1.28265553904       1.27414975719       1.26463883004
+   1.25413811608       1.24266550937       1.23024106166       1.21688694919
+   1.20262774058       1.18749051808       1.17150466166       1.15470180117
+   1.13711567853       1.11878201066       1.09973834987       1.08002393484
+   1.05967953618       1.03874729666       1.01727056694      0.995293737552
+  0.972862068104      0.950021514480      0.926818554966      0.903300016140
+  0.879512899394      0.855504208963      0.831320782275      0.807009123458
+  0.782615240788      0.758184488840      0.733761416062      0.709389618462
+  0.685111600052      0.660968640636      0.637000671498      0.613246159474
+  0.589741999861      0.566523418537      0.543623883634      0.521075026983
+  0.498906575779      0.477146292829      0.455819936497      0.434951190884
+  0.414561727116      0.394671024650      0.375296561294      0.356453771250
+  0.338155959563      0.320414323970      0.303238003716      0.286634129975
+  0.270607879887      0.255162535329      0.240299546982      0.226018603807
+  0.212317707804      0.199193253735      0.186640113352      0.174651723617
+  0.163220178329      0.152336322531      0.141989849092      0.132169396806
+  0.122862649382      0.114056434700      0.105736823731      0.978892285275E-01
+  0.904984987295E-01  0.835490160590E-01  0.770247863057E-01  0.709095283481E-01
+  0.651867597933E-01  0.598398788623E-01  0.548522421870E-01  0.502072382386E-01
+  0.458883561453E-01  0.418792497086E-01  0.381637964724E-01  0.347261517449E-01
+  0.315507975174E-01  0.286225862679E-01  0.259267796785E-01  0.234490823329E-01
+  0.211756704996E-01  0.190932161359E-01  0.171889062811E-01  0.154504580325E-01
+  0.138661293215E-01  0.124247257276E-01  0.111156035836E-01  0.992866963920E-02
+  0.885437755738E-02  0.788372152781E-02  0.700822727988E-02  0.621994078080E-02
+  0.551141489987E-02  0.487569431459E-02  0.430629892613E-02  0.379720604173E-02
+  0.334283156968E-02  0.293801045895E-02  0.257797660106E-02  0.225834239616E-02
+  0.197507816894E-02  0.172449160327E-02  0.150320734753E-02  0.130814692589E-02
+  0.113650907391E-02  0.985750600640E-03  0.853567863966E-03  0.737878930652E-03
+  0.636806478664E-03  0.548661485985E-03  0.471927737958E-03  0.405247173936E-03
+  0.347406083859E-03  0.297322156264E-03  0.254032371190E-03  0.216681724395E-03
+  0.184512763302E-03  0.156855910017E-03  0.133120542597E-03  0.112786802438E-03
+  0.953980931010E-04  0.805542340977E-04  0.679052319431E-04  0.571456302128E-04
+  0.480094002201E-04  0.402653342774E-04  0.337129042193E-04  0.281785488865E-04
+  0.235123555567E-04  0.195851017865E-04  0.162856257698E-04  0.135184950650E-04
+  0.112019453593E-04  0.926606279965E-05  0.765118527837E-05  0.630649990958E-05
+  0.518881573893E-05  0.426149247936E-05  0.349350774638E-05  0.285864686722E-05
+  0.233480085071E-05  0.190335952462E-05  0.154868817150E-05  0.125767722146E-05
+  0.101935569203E-05  0.824560102840E-06  0.665651539482E-06  0.536274400320E-06
+  0.431151137002E-06  0.345907998270E-06  0.276927413119E-06  0.221223208327E-06
+  0.176335352302E-06  0.140241357339E-06  0.111281860757E-06  0.880982469023E-07
+  0.695804713781E-07  0.548235103061E-07  0.430910851391E-07  0.337855112143E-07
+  0.264226893320E-07  0.206114073139E-07  0.160362455877E-07  0.124434899329E-07
+  0.962954790349E-08  0.743144518498E-08  0.571904604899E-08  0.438869977163E-08
+  0.335806378146E-08  0.256189565288E-08  0.194864094032E-08  0.147767320382E-08
+  0.111706722440E-08  0.841807055634E-09  0.632347815330E-09  0.473464511186E-09
+  0.353333165469E-09  0.262799438971E-09  0.194798180216E-09  0.143894119629E-09
+  0.105919525328E-09  0.776892364731E-10  0.567772595184E-10  0.413421937970E-10
+  0.299912642143E-10  0.216747800681E-10  0.156044932034E-10  0.111906652361E-10
+  0.799373006762E-11  0.568730219171E-11  0.402997291375E-11  0.284388817674E-11
+  0.199854005481E-11  0.139855111886E-11  0.974504780952E-12  0.676090025219E-12
+  0.466997520294E-12  0.321135598732E-12  0.219836732611E-12  0.149804155689E-12
+  0.101609158926E-12  0.685962836199E-13  0.460893011572E-13  0.308179859503E-13
+  0.205062136138E-13  0.135773808180E-13  0.894473991675E-14  0.586289634055E-14
+  0.382314489352E-14  0.248007193157E-14  0.160034409371E-14  0.102716045940E-14
+  0.655705675404E-15  0.416288930641E-15  0.262824126416E-15  0.165001862235E-15
+  0.102999267174E-15  0.639247640112E-16  0.394422321984E-16  0.241923710616E-16
+  0.147498233942E-16  0.893826172387E-17  0.538323306628E-17  0.322197933082E-17
+  0.191627096926E-17  0.113242750239E-17  0.664886454812E-18  0.387821583077E-18
+  0.224712506287E-18  0.129329083013E-18  0.739266928635E-19  0.419666642110E-19
+  0.236574102142E-19  0.132419069575E-19  0.735893480737E-20  0.405994812653E-20
+  0.222344622228E-20  0.120862727737E-20  0.652043027124E-21  0.349089015043E-21
+  0.185451183705E-21  0.977492502798E-22  0.511144882936E-22  0.265141169258E-22
+  0.136416888733E-22  0.696099996829E-23  0.352242511016E-23  0.176738881497E-23
+  0.879216041716E-24  0.433595387147E-24  0.211958597420E-24  0.102694204845E-24
+  0.493082878874E-25  0.234597267432E-25  0.110587067642E-25  0.516431585113E-26
+  0.238889115443E-26  0.109446642771E-26  0.496566923194E-27  0.223084024948E-27
+  0.992247247430E-28  0.436894728740E-28  0.190407131511E-28  0.821263369563E-29
+  0.350523513345E-29  0.148023008833E-29  0.618386284146E-30  0.255534452515E-30
+  0.104433003623E-30  0.422049813767E-31  0.168641895162E-31  0.666162923980E-32
+  0.260102954677E-32  0.100368118754E-32  0.382707501518E-33  0.144176030829E-33
+  0.536546585741E-34  0.197216220060E-34  0.715863710751E-35  0.256567371075E-35
+  0.907790911418E-36  0.317038974080E-36  0.109272301620E-36  0.371625436798E-37
+  0.124688113936E-37  0.412661933512E-38  0.134690821023E-38  0.433490304618E-39
+  0.137543845871E-39  0.430174783799E-40  0.132590178835E-40  0.402679973951E-41
+  0.120478415107E-41  0.355040629490E-42  0.103034352799E-42  0.294379209960E-43
+  0.828141736641E-44  0.230023028575E-44  0.628673744830E-45  0.169035764576E-45
+  0.447035445304E-46
Added: SwiftApps/ematter/workflow-run/Hf.sic.psf
--- SwiftApps/ematter/workflow-run/Hf.sic.psf	                        (rev 0)
+++ SwiftApps/ematter/workflow-run/Hf.sic.psf	2015-01-27 22:12:52 UTC (rev 8376)
@@ -0,0 +1,3041 @@
+ Hf ca rel nc
+ ATM3       7-OCT-14 Troullier-Martins
+ 6s 2.00r r= 2.89/6p 0.00r r= 2.93/5d 2.00r r= 2.55/5f 0.00r r= 2.55/
+   4  3 1205  0.344271135648E-04  0.125000000000E-01   4.00000000000
+ Radial grid follows
+  0.433039779659E-06  0.871526529201E-06  0.131552876307E-05  0.176511585753E-05
+  0.222035806147E-05  0.268132650740E-05  0.314809322260E-05  0.362073114031E-05
+  0.409931411115E-05  0.458391691471E-05  0.507461527115E-05  0.557148585308E-05
+  0.607460629755E-05  0.658405521815E-05  0.709991221732E-05  0.762225789874E-05
+  0.815117388001E-05  0.868674280532E-05  0.922904835840E-05  0.977817527560E-05
+  0.103342093591E-04  0.108972374904E-04  0.114673476438E-04  0.120446289001E-04
+  0.126291714607E-04  0.132210666615E-04  0.138204069875E-04  0.144272860867E-04
+  0.150417987853E-04  0.156640411021E-04  0.162941102637E-04  0.169321047197E-04
+  0.175781241580E-04  0.182322695206E-04  0.188946430189E-04  0.195653481501E-04
+  0.202444897134E-04  0.209321738259E-04  0.216285079396E-04  0.223336008583E-04
+  0.230475627541E-04  0.237705051850E-04  0.245025411122E-04  0.252437849179E-04
+  0.259943524228E-04  0.267543609048E-04  0.275239291166E-04  0.283031773048E-04
+  0.290922272286E-04  0.298912021787E-04  0.307002269965E-04  0.315194280937E-04
+  0.323489334722E-04  0.331888727439E-04  0.340393771511E-04  0.349005795867E-04
+  0.357726146155E-04  0.366556184945E-04  0.375497291951E-04  0.384550864238E-04
+  0.393718316446E-04  0.403001081006E-04  0.412400608371E-04  0.421918367235E-04
+  0.431555844768E-04  0.441314546845E-04  0.451195998284E-04  0.461201743080E-04
+  0.471333344652E-04  0.481592386084E-04  0.491980470371E-04  0.502499220674E-04
+  0.513150280567E-04  0.523935314300E-04  0.534856007058E-04  0.545914065221E-04
+  0.557111216632E-04  0.568449210870E-04  0.579929819519E-04  0.591554836447E-04
+  0.603326078088E-04  0.615245383721E-04  0.627314615762E-04  0.639535660054E-04
+  0.651910426159E-04  0.664440847660E-04  0.677128882460E-04  0.689976513091E-04
+  0.702985747022E-04  0.716158616971E-04  0.729497181227E-04  0.743003523967E-04
+  0.756679755584E-04  0.770528013018E-04  0.784550460087E-04  0.798749287827E-04
+  0.813126714834E-04  0.827684987609E-04  0.842426380913E-04  0.857353198119E-04
+  0.872467771571E-04  0.887772462953E-04  0.903269663654E-04  0.918961795143E-04
+  0.934851309347E-04  0.950940689036E-04  0.967232448208E-04  0.983729132483E-04
+  0.100043331950E-03  0.101734761933E-03  0.103447467485E-03  0.105181716222E-03
+  0.106937779122E-03  0.108715930574E-03  0.110516448418E-03  0.112339613989E-03
+  0.114185712159E-03  0.116055031386E-03  0.117947863754E-03  0.119864505022E-03
+  0.121805254669E-03  0.123770415942E-03  0.125760295901E-03  0.127775205468E-03
+  0.129815459478E-03  0.131881376724E-03  0.133973280010E-03  0.136091496200E-03
+  0.138236356270E-03  0.140408195358E-03  0.142607352819E-03  0.144834172275E-03
+  0.147089001672E-03  0.149372193332E-03  0.151684104007E-03  0.154025094938E-03
+  0.156395531910E-03  0.158795785309E-03  0.161226230179E-03  0.163687246282E-03
+  0.166179218157E-03  0.168702535180E-03  0.171257591623E-03  0.173844786720E-03
+  0.176464524725E-03  0.179117214977E-03  0.181803271965E-03  0.184523115392E-03
+  0.187277170236E-03  0.190065866826E-03  0.192889640901E-03  0.195748933682E-03
+  0.198644191938E-03  0.201575868060E-03  0.204544420128E-03  0.207550311984E-03
+  0.210594013305E-03  0.213675999676E-03  0.216796752663E-03  0.219956759890E-03
+  0.223156515115E-03  0.226396518306E-03  0.229677275720E-03  0.232999299982E-03
+  0.236363110166E-03  0.239769231873E-03  0.243218197316E-03  0.246710545405E-03
+  0.250246821824E-03  0.253827579125E-03  0.257453376809E-03  0.261124781413E-03
+  0.264842366601E-03  0.268606713255E-03  0.272418409561E-03  0.276278051104E-03
+  0.280186240961E-03  0.284143589795E-03  0.288150715950E-03  0.292208245546E-03
+  0.296316812582E-03  0.300477059030E-03  0.304689634936E-03  0.308955198523E-03
+  0.313274416296E-03  0.317647963140E-03  0.322076522431E-03  0.326560786140E-03
+  0.331101454943E-03  0.335699238329E-03  0.340354854710E-03  0.345069031536E-03
+  0.349842505407E-03  0.354676022188E-03  0.359570337126E-03  0.364526214966E-03
+  0.369544430076E-03  0.374625766562E-03  0.379771018392E-03  0.384980989523E-03
+  0.390256494023E-03  0.395598356202E-03  0.401007410734E-03  0.406484502797E-03
+  0.412030488197E-03  0.417646233506E-03  0.423332616195E-03  0.429090524773E-03
+  0.434920858925E-03  0.440824529653E-03  0.446802459417E-03  0.452855582280E-03
+  0.458984844057E-03  0.465191202455E-03  0.471475627232E-03  0.477839100341E-03
+  0.484282616089E-03  0.490807181287E-03  0.497413815412E-03  0.504103550765E-03
+  0.510877432629E-03  0.517736519438E-03  0.524681882938E-03  0.531714608357E-03
+  0.538835794571E-03  0.546046554281E-03  0.553348014183E-03  0.560741315144E-03
+  0.568227612383E-03  0.575808075649E-03  0.583483889405E-03  0.591256253012E-03
+  0.599126380919E-03  0.607095502847E-03  0.615164863990E-03  0.623335725201E-03
+  0.631609363194E-03  0.639987070741E-03  0.648470156876E-03  0.657059947100E-03
+  0.665757783584E-03  0.674565025382E-03  0.683483048644E-03  0.692513246830E-03
+  0.701657030926E-03  0.710915829668E-03  0.720291089760E-03  0.729784276108E-03
+  0.739396872039E-03  0.749130379543E-03  0.758986319500E-03  0.768966231919E-03
+  0.779071676183E-03  0.789304231289E-03  0.799665496092E-03  0.810157089563E-03
+  0.820780651034E-03  0.831537840458E-03  0.842430338669E-03  0.853459847639E-03
+  0.864628090755E-03  0.875936813074E-03  0.887387781610E-03  0.898982785598E-03
+  0.910723636783E-03  0.922612169694E-03  0.934650241941E-03  0.946839734497E-03
+  0.959182551993E-03  0.971680623022E-03  0.984335900431E-03  0.997150361634E-03
+  0.101012600892E-02  0.102326486975E-02  0.103656899711E-02  0.105004046978E-02
+  0.106368139273E-02  0.107749389736E-02  0.109148014191E-02  0.110564231177E-02
+  0.111998261979E-02  0.113450330668E-02  0.114920664132E-02  0.116409492115E-02
+  0.117917047248E-02  0.119443565091E-02  0.120989284164E-02  0.122554445990E-02
+  0.124139295128E-02  0.125744079214E-02  0.127369048999E-02  0.129014458387E-02
+  0.130680564478E-02  0.132367627604E-02  0.134075911371E-02  0.135805682703E-02
+  0.137557211880E-02  0.139330772581E-02  0.141126641930E-02  0.142945100535E-02
+  0.144786432533E-02  0.146650925636E-02  0.148538871176E-02  0.150450564147E-02
+  0.152386303255E-02  0.154346390964E-02  0.156331133541E-02  0.158340841107E-02
+  0.160375827681E-02  0.162436411236E-02  0.164522913741E-02  0.166635661217E-02
+  0.168774983785E-02  0.170941215717E-02  0.173134695494E-02  0.175355765849E-02
+  0.177604773830E-02  0.179882070849E-02  0.182188012738E-02  0.184522959805E-02
+  0.186887276891E-02  0.189281333425E-02  0.191705503483E-02  0.194160165847E-02
+  0.196645704062E-02  0.199162506499E-02  0.201710966414E-02  0.204291482008E-02
+  0.206904456493E-02  0.209550298150E-02  0.212229420399E-02  0.214942241857E-02
+  0.217689186408E-02  0.220470683268E-02  0.223287167052E-02  0.226139077840E-02
+  0.229026861250E-02  0.231950968504E-02  0.234911856499E-02  0.237909987880E-02
+  0.240945831112E-02  0.244019860550E-02  0.247132556519E-02  0.250284405383E-02
+  0.253475899626E-02  0.256707537924E-02  0.259979825228E-02  0.263293272839E-02
+  0.266648398490E-02  0.270045726427E-02  0.273485787489E-02  0.276969119192E-02
+  0.280496265814E-02  0.284067778478E-02  0.287684215242E-02  0.291346141181E-02
+  0.295054128477E-02  0.298808756512E-02  0.302610611954E-02  0.306460288850E-02
+  0.310358388720E-02  0.314305520651E-02  0.318302301389E-02  0.322349355440E-02
+  0.326447315165E-02  0.330596820877E-02  0.334798520946E-02  0.339053071896E-02
+  0.343361138508E-02  0.347723393928E-02  0.352140519766E-02  0.356613206207E-02
+  0.361142152118E-02  0.365728065156E-02  0.370371661878E-02  0.375073667857E-02
+  0.379834817791E-02  0.384655855618E-02  0.389537534635E-02  0.394480617616E-02
+  0.399485876926E-02  0.404554094648E-02  0.409686062701E-02  0.414882582966E-02
+  0.420144467409E-02  0.425472538210E-02  0.430867627892E-02  0.436330579448E-02
+  0.441862246475E-02  0.447463493308E-02  0.453135195153E-02  0.458878238224E-02
+  0.464693519885E-02  0.470581948784E-02  0.476544445000E-02  0.482581940187E-02
+  0.488695377714E-02  0.494885712818E-02  0.501153912753E-02  0.507500956937E-02
+  0.513927837109E-02  0.520435557481E-02  0.527025134899E-02  0.533697598997E-02
+  0.540453992361E-02  0.547295370692E-02  0.554222802969E-02  0.561237371617E-02
+  0.568340172676E-02  0.575532315975E-02  0.582814925299E-02  0.590189138572E-02
+  0.597656108030E-02  0.605217000400E-02  0.612872997089E-02  0.620625294362E-02
+  0.628475103530E-02  0.636423651142E-02  0.644472179175E-02  0.652621945228E-02
+  0.660874222719E-02  0.669230301082E-02  0.677691485971E-02  0.686259099465E-02
+  0.694934480270E-02  0.703718983932E-02  0.712613983047E-02  0.721620867478E-02
+  0.730741044569E-02  0.739975939364E-02  0.749326994837E-02  0.758795672107E-02
+  0.768383450676E-02  0.778091828653E-02  0.787922322992E-02  0.797876469728E-02
+  0.807955824215E-02  0.818161961375E-02  0.828496475937E-02  0.838960982689E-02
+  0.849557116732E-02  0.860286533734E-02  0.871150910187E-02  0.882151943674E-02
+  0.893291353127E-02  0.904570879102E-02  0.915992284047E-02  0.927557352582E-02
+  0.939267891770E-02  0.951125731409E-02  0.963132724308E-02  0.975290746586E-02
+  0.987601697958E-02  0.100006750204E-01  0.101269010662E-01  0.102547148403E-01
+  0.103841363138E-01  0.105151857090E-01  0.106478835027E-01  0.107822504291E-01
+  0.109183074834E-01  0.110560759248E-01  0.111955772798E-01  0.113368333459E-01
+  0.114798661945E-01  0.116246981749E-01  0.117713519173E-01  0.119198503368E-01
+  0.120702166364E-01  0.122224743112E-01  0.123766471518E-01  0.125327592480E-01
+  0.126908349927E-01  0.128508990854E-01  0.130129765366E-01  0.131770926712E-01
+  0.133432731326E-01  0.135115438868E-01  0.136819312266E-01  0.138544617753E-01
+  0.140291624912E-01  0.142060606715E-01  0.143851839570E-01  0.145665603361E-01
+  0.147502181492E-01  0.149361860932E-01  0.151244932259E-01  0.153151689708E-01
+  0.155082431213E-01  0.157037458457E-01  0.159017076916E-01  0.161021595910E-01
+  0.163051328649E-01  0.165106592283E-01  0.167187707951E-01  0.169295000831E-01
+  0.171428800193E-01  0.173589439447E-01  0.175777256196E-01  0.177992592293E-01
+  0.180235793888E-01  0.182507211485E-01  0.184807199998E-01  0.187136118805E-01
+  0.189494331805E-01  0.191882207473E-01  0.194300118919E-01  0.196748443947E-01
+  0.199227565112E-01  0.201737869784E-01  0.204279750200E-01  0.206853603537E-01
+  0.209459831963E-01  0.212098842706E-01  0.214771048119E-01  0.217476865738E-01
+  0.220216718353E-01  0.222991034071E-01  0.225800246385E-01  0.228644794239E-01
+  0.231525122102E-01  0.234441680028E-01  0.237394923737E-01  0.240385314679E-01
+  0.243413320109E-01  0.246479413158E-01  0.249584072910E-01  0.252727784474E-01
+  0.255911039062E-01  0.259134334063E-01  0.262398173125E-01  0.265703066227E-01
+  0.269049529768E-01  0.272438086638E-01  0.275869266306E-01  0.279343604902E-01
+  0.282861645297E-01  0.286423937193E-01  0.290031037205E-01  0.293683508949E-01
+  0.297381923133E-01  0.301126857640E-01  0.304918897624E-01  0.308758635599E-01
+  0.312646671533E-01  0.316583612938E-01  0.320570074970E-01  0.324606680521E-01
+  0.328694060319E-01  0.332832853026E-01  0.337023705337E-01  0.341267272081E-01
+  0.345564216323E-01  0.349915209470E-01  0.354320931373E-01  0.358782070436E-01
+  0.363299323720E-01  0.367873397056E-01  0.372505005152E-01  0.377194871706E-01
+  0.381943729519E-01  0.386752320610E-01  0.391621396330E-01  0.396551717484E-01
+  0.401544054444E-01  0.406599187272E-01  0.411717905843E-01  0.416901009968E-01
+  0.422149309517E-01  0.427463624547E-01  0.432844785432E-01  0.438293632988E-01
+  0.443811018609E-01  0.449397804397E-01  0.455054863300E-01  0.460783079244E-01
+  0.466583347275E-01  0.472456573696E-01  0.478403676212E-01  0.484425584067E-01
+  0.490523238199E-01  0.496697591378E-01  0.502949608360E-01  0.509280266034E-01
+  0.515690553578E-01  0.522181472614E-01  0.528754037361E-01  0.535409274794E-01
+  0.542148224810E-01  0.548971940381E-01  0.555881487728E-01  0.562877946482E-01
+  0.569962409853E-01  0.577135984803E-01  0.584399792218E-01  0.591754967082E-01
+  0.599202658657E-01  0.606744030660E-01  0.614380261445E-01  0.622112544189E-01
+  0.629942087077E-01  0.637870113490E-01  0.645897862200E-01  0.654026587558E-01
+  0.662257559693E-01  0.670592064713E-01  0.679031404900E-01  0.687576898919E-01
+  0.696229882021E-01  0.704991706250E-01  0.713863740662E-01  0.722847371528E-01
+  0.731944002560E-01  0.741155055125E-01  0.750481968467E-01  0.759926199938E-01
+  0.769489225216E-01  0.779172538544E-01  0.788977652960E-01  0.798906100532E-01
+  0.808959432601E-01  0.819139220020E-01  0.829447053402E-01  0.839884543366E-01
+  0.850453320792E-01  0.861155037073E-01  0.871991364374E-01  0.882963995892E-01
+  0.894074646125E-01  0.905325051132E-01  0.916716968814E-01  0.928252179181E-01
+  0.939932484632E-01  0.951759710239E-01  0.963735704031E-01  0.975862337280E-01
+  0.988141504797E-01  0.100057512523      0.101316514135      0.102591352038
+  0.103882225428      0.105189336006      0.106512888012      0.107853088252
+  0.109210146136      0.110584273706      0.111975685674      0.113384599450
+  0.114811235179      0.116255815777      0.117718566962      0.119199717292
+  0.120699498199      0.122218144028      0.123755892070      0.125312982601
+  0.126889658920      0.128486167385      0.130102757455      0.131739681725
+  0.133397195967      0.135075559172      0.136775033587      0.138495884759
+  0.140238381574      0.142002796300      0.143789404632      0.145598485730
+  0.147430322267      0.149285200471      0.151163410170      0.153065244840
+  0.154991001644      0.156940981488      0.158915489058      0.160914832876
+  0.162939325343      0.164989282791      0.167065025529      0.169166877896
+  0.171295168312      0.173450229325      0.175632397669      0.177842014312
+  0.180079424511      0.182344977865      0.184639028373      0.186961934484
+  0.189314059156      0.191695769915      0.194107438907      0.196549442961
+  0.199022163645      0.201525987325      0.204061305231      0.206628513510
+  0.209228013294      0.211860210759      0.214525517194      0.217224349056
+  0.219957128044      0.222724281159      0.225526240777      0.228363444707
+  0.231236336270      0.234145364360      0.237090983519      0.240073654005
+  0.243093841868      0.246152019018      0.249248663300      0.252384258573
+  0.255559294779      0.258774268024      0.262029680654      0.265326041334
+  0.268663865127      0.272043673575      0.275465994780      0.278931363486
+  0.282440321165      0.285993416097      0.289591203463      0.293234245422
+  0.296923111208      0.300658377213      0.304440627081      0.308270451795
+  0.312148449774      0.316075226963      0.320051396929      0.324077580955
+  0.328154408142      0.332282515503      0.336462548062      0.340695158957
+  0.344981009544      0.349320769495      0.353715116906      0.358164738403
+  0.362670329248      0.367232593450      0.371852243870      0.376530002340
+  0.381266599768      0.386062776257      0.390919281219      0.395836873494
+  0.400816321465      0.405858403181      0.410963906478      0.416133629100
+  0.421368378828      0.426668973602      0.432036241650      0.437471021619
+  0.442974162705      0.448546524784      0.454188978549      0.459902405646
+  0.465687698809      0.471545762001      0.477477510557      0.483483871325
+  0.489565782811      0.495724195326      0.501960071134      0.508274384604
+  0.514668122360      0.521142283436      0.527697879434      0.534335934679
+  0.541057486379      0.547863584792      0.554755293384      0.561733688998
+  0.568799862024      0.575954916565      0.583199970612      0.590536156221
+  0.597964619684      0.605486521716      0.613103037628      0.620815357516
+  0.628624686446      0.636532244641      0.644539267674      0.652647006658
+  0.660856728445      0.669169715818      0.677587267701      0.686110699352
+  0.694741342575      0.703480545926      0.712329674922      0.721290112259
+  0.730363258023      0.739550529911      0.748853363453      0.758273212236
+  0.767811548130      0.777469861520      0.787249661538      0.797152476295
+  0.807179853129      0.817333358836      0.827614579922      0.838025122850
+  0.848566614287      0.859240701364      0.870049051927      0.880993354805
+  0.892075320066      0.903296679289      0.914659185836      0.926164615122
+  0.937814764891      0.949611455505      0.961556530221      0.973651855479
+  0.985899321201      0.998300841076       1.01085835287       1.02357381871
+   1.03644922543       1.04948658483       1.06268793402       1.07605533574
+   1.08959087867       1.10329667778       1.11717487462       1.13122763768
+   1.14545716274       1.15986567319       1.17445542040       1.18922868403
+   1.20418777244       1.21933502302       1.23467280256       1.25020350762
+   1.26592956489       1.28185343162       1.29797759593       1.31430457726
+   1.33083692673       1.34757722757       1.36452809546       1.38169217902
+   1.39907216018       1.41667075459       1.43449071207       1.45253481701
+   1.47080588886       1.48930678250       1.50804038873       1.52700963472
+   1.54621748445       1.56566693919       1.58536103796       1.60530285799
+   1.62549551523       1.64594216484       1.66664600164       1.68761026065
+   1.70883821757       1.73033318932       1.75209853453       1.77413765408
+   1.79645399163       1.81905103415       1.84193231247       1.86510140184
+   1.88856192249       1.91231754015       1.93637196670       1.96072896068
+   1.98539232794       2.01036592217       2.03565364554       2.06125944931
+   2.08718733445       2.11344135223       2.14002560490       2.16694424631
+   2.19420148254       2.22180157260       2.24974882905       2.27804761872
+   2.30670236334       2.33571754027       2.36509768321       2.39484738284
+   2.42497128763       2.45547410450       2.48636059958       2.51763559893
+   2.54930398935       2.58137071908       2.61384079862       2.64671930148
+   2.68001136499       2.71372219112       2.74785704723       2.78242126698
+   2.81742025109       2.85285946823       2.88874445584       2.92508082103
+   2.96187424143       2.99913046609       3.03685531636       3.07505468683
+   3.11373454624       3.15290093838       3.19255998308       3.23271787716
+   3.27338089536       3.31455539137       3.35624779878       3.39846463211
+   3.44121248784       3.48449804540       3.52832806825       3.57270940491
+   3.61764899007       3.66315384562       3.70923108179       3.75588789825
+   3.80313158521       3.85096952460       3.89940919119       3.94845815377
+   3.99812407636       4.04841471935       4.09933794075       4.15090169743
+   4.20311404632       4.25598314571       4.30951725651       4.36372474352
+   4.41861407678       4.47419383287       4.53047269622       4.58745946052
+   4.64516303008       4.70359242119       4.76275676357       4.82266530176
+   4.88332739659       4.94475252665       5.00695028972       5.06993040435
+   5.13370271129       5.19827717511       5.26366388569       5.32987305985
+   5.39691504289       5.46480031026       5.53353946918       5.60314326029
+   5.67362255930       5.74498837876       5.81725186973       5.89042432351
+   5.96451717345       6.03954199672       6.11551051610       6.19243460181
+   6.27032627341       6.34919770162       6.42906121027       6.50992927820
+   6.59181454120       6.67472979401       6.75868799231       6.84370225474
+   6.92978586495       7.01695227368       7.10521510085       7.19458813772
+   7.28508534901       7.37672087508       7.46950903418       7.56346432464
+   7.65860142716       7.75493520712       7.85248071687       7.95125319808
+   8.05126808416       8.15254100263       8.25508777761       8.35892443222
+   8.46406719116       8.57053248320       8.67833694376       8.78749741750
+   8.89803096097       9.00995484526       9.12328655870       9.23804380961
+   9.35424452904       9.47190687359       9.59104922824       9.71169020922
+   9.83384866693       9.95754368889       10.0827946027       10.2096209790
+   10.3380426348       10.4680796361       10.5997523016       10.7330812053
+   10.8680871802       11.0047913212       11.1432149885       11.2833798113
+   11.4253076905       11.5690208027       11.7145416033       11.8618928302
+   12.0110975074       12.1621789484       12.3151607599       12.4700668458
+   12.6269214104       12.7857489625       12.9465743193       13.1094226100
+   13.2743192801       13.4412900949       13.6103611440       13.7815588452
+   13.9549099483       14.1304415399       14.3081810471       14.4881562421
+   14.6703952463       14.8549265350       15.0417789416       15.2309816622
+   15.4225642600       15.6165566702       15.8129892045       16.0118925560
+   16.2132978036       16.4172364174       16.6237402631       16.8328416075
+   17.0445731230       17.2589678931       17.4760594174       17.6958816170
+   17.9184688394       18.1438558644       18.3720779092       18.6031706339
+   18.8371701473       19.0741130122       19.3140362514       19.5569773535
+   19.8029742785       20.0520654638       20.3042898306       20.5596867893
+   20.8182962463       21.0801586099       21.3453147965       21.6138062373
+   21.8856748847       22.1609632187       22.4397142537       22.7219715451
+   23.0077791961       23.2971818648       23.5902247710       23.8869537031
+   24.1874150258       24.4916556866       24.7997232238       25.1116657737
+   25.4275320777       25.7473714908       26.0712339885       26.3991701748
+   26.7312312906       27.0674692211       27.4079365040       27.7526863382
+   28.1017725915       28.4552498093       28.8131732231       29.1755987593
+   29.5425830475       29.9141834298       30.2904579695       30.6714654602
+   31.0572654352       31.4479181765       31.8434847244       32.2440268869
+   32.6496072496       33.0602891853       33.4761368638       33.8972152621
+   34.3235901747       34.7553282234       35.1924968683       35.6351644178
+   36.0834000396       36.5372737715       36.9968565321       37.4622201322
+   37.9334372857       38.4105816215       38.8937276941       39.3829509961
+   39.8783279698       40.3799360187       40.8878535202       41.4021598374
+   41.9229353316       42.4502613751       42.9842203638       43.5248957297
+   44.0723719545       44.6267345824       45.1880702338       45.7564666185
+   46.3320125496       46.9147979572       47.5049139029       48.1024525934
+   48.7075073954       49.3201728499       49.9405446871       50.5687198414
+   51.2047964664       51.8488739505       52.5010529319       53.1614353151
+   53.8301242861       54.5072243289       55.1928412418       55.8870821538
+   56.5900555414       57.3018712458       58.0226404895       58.7524758941
+   59.4914914981       60.2398027740       60.9975266471       61.7647815132
+   62.5416872574       63.3283652729       64.1249384796       64.9315313439
+   65.7482698974       66.5752817572       67.4126961456       68.2606439104
+   69.1192575450       69.9886712096       70.8690207518       71.7604437281
+   72.6630794251       73.5770688815       74.5025549100       75.4396821196
+   76.3885969384       77.3494476363       78.3223843481       79.3075590972
+   80.3051258192       81.3152403858       82.3380606296       83.3737463682
+   84.4224594297       85.4843636776       86.5596250366       87.6484115186
+   88.7508932485       89.8672424915       90.9976336793       92.1422434379
+   93.3012506148       94.4748363074       95.6631838907       96.8664790466
+   98.0849097922       99.3186665099       100.567941977       101.832931394
+   103.113832420       104.410845198       105.724172387       107.054019199
+   108.400593425       109.764105470       111.144768384       112.542797900
+   113.958412463       115.391833265       116.843284281       118.312992303
+   119.801186976
+ Down Pseudopotential follows (l on next line)
+  0
+ -0.342307425156E-06 -0.688920547671E-06 -0.103989352655E-05 -0.139528120204E-05
+ -0.175513910418E-05 -0.211952346150E-05 -0.248849120981E-05 -0.286210000105E-05
+ -0.324040821237E-05 -0.362347495520E-05 -0.401136008449E-05 -0.440412420807E-05
+ -0.480182869616E-05 -0.520453569087E-05 -0.561230811600E-05 -0.602520968681E-05
+ -0.644330492003E-05 -0.686665914388E-05 -0.729533850831E-05 -0.772940999536E-05
+ -0.816894142957E-05 -0.861400148862E-05 -0.906465971405E-05 -0.952098652214E-05
+ -0.998305321486E-05 -0.104509319911E-04 -0.109246959578E-04 -0.114044191417E-04
+ -0.118901765003E-04 -0.123820439344E-04 -0.128800982991E-04 -0.133844174165E-04
+ -0.138950800875E-04 -0.144121661041E-04 -0.149357562622E-04 -0.154659323736E-04
+ -0.160027772796E-04 -0.165463748633E-04 -0.170968100628E-04 -0.176541688847E-04
+ -0.182185384176E-04 -0.187900068453E-04 -0.193686634609E-04 -0.199545986807E-04
+ -0.205479040583E-04 -0.211486722988E-04 -0.217569972735E-04 -0.223729740345E-04
+ -0.229966988292E-04 -0.236282691160E-04 -0.242677835791E-04 -0.249153421439E-04
+ -0.255710459926E-04 -0.262349975805E-04 -0.269073006512E-04 -0.275880602535E-04
+ -0.282773827574E-04 -0.289753758711E-04 -0.296821486573E-04 -0.303978115507E-04
+ -0.311224763751E-04 -0.318562563609E-04 -0.325992661627E-04 -0.333516218772E-04
+ -0.341134410616E-04 -0.348848427517E-04 -0.356659474805E-04 -0.364568772974E-04
+ -0.372577557865E-04 -0.380687080869E-04 -0.388898609115E-04 -0.397213425671E-04
+ -0.405632829743E-04 -0.414158136882E-04 -0.422790679183E-04 -0.431531805499E-04
+ -0.440382881648E-04 -0.449345290629E-04 -0.458420432837E-04 -0.467609726281E-04
+ -0.476914606807E-04 -0.486336528321E-04 -0.495876963018E-04 -0.505537401611E-04
+ -0.515319353561E-04 -0.525224347320E-04 -0.535253930562E-04 -0.545409670430E-04
+ -0.555693153780E-04 -0.566105987426E-04 -0.576649798395E-04 -0.587326234179E-04
+ -0.598136962992E-04 -0.609083674033E-04 -0.620168077748E-04 -0.631391906097E-04
+ -0.642756912826E-04 -0.654264873741E-04 -0.665917586983E-04 -0.677716873314E-04
+ -0.689664576395E-04 -0.701762563080E-04 -0.714012723703E-04 -0.726416972376E-04
+ -0.738977247290E-04 -0.751695511011E-04 -0.764573750796E-04 -0.777613978894E-04
+ -0.790818232868E-04 -0.804188575910E-04 -0.817727097162E-04 -0.831435912046E-04
+ -0.845317162593E-04 -0.859373017776E-04 -0.873605673850E-04 -0.888017354697E-04
+ -0.902610312172E-04 -0.917386826453E-04 -0.932349206401E-04 -0.947499789919E-04
+ -0.962840944315E-04 -0.978375066676E-04 -0.994104584240E-04 -0.101003195478E-03
+ -0.102615966697E-03 -0.104249024081E-03 -0.105902622797E-03 -0.107577021225E-03
+ -0.109272480991E-03 -0.110989267016E-03 -0.112727647551E-03 -0.114487894220E-03
+ -0.116270282067E-03 -0.118075089592E-03 -0.119902598801E-03 -0.121753095246E-03
+ -0.123626868070E-03 -0.125524210055E-03 -0.127445417663E-03 -0.129390791088E-03
+ -0.131360634297E-03 -0.133355255083E-03 -0.135374965110E-03 -0.137420079961E-03
+ -0.139490919189E-03 -0.141587806368E-03 -0.143711069140E-03 -0.145861039269E-03
+ -0.148038052693E-03 -0.150242449574E-03 -0.152474574354E-03 -0.154734775806E-03
+ -0.157023407092E-03 -0.159340825815E-03 -0.161687394076E-03 -0.164063478531E-03
+ -0.166469450449E-03 -0.168905685767E-03 -0.171372565152E-03 -0.173870474059E-03
+ -0.176399802791E-03 -0.178960946561E-03 -0.181554305552E-03 -0.184180284983E-03
+ -0.186839295168E-03 -0.189531751582E-03 -0.192258074927E-03 -0.195018691198E-03
+ -0.197814031744E-03 -0.200644533345E-03 -0.203510638272E-03 -0.206412794359E-03
+ -0.209351455074E-03 -0.212327079589E-03 -0.215340132850E-03 -0.218391085655E-03
+ -0.221480414719E-03 -0.224608602758E-03 -0.227776138556E-03 -0.230983517047E-03
+ -0.234231239391E-03 -0.237519813051E-03 -0.240849751873E-03 -0.244221576167E-03
+ -0.247635812786E-03 -0.251092995213E-03 -0.254593663638E-03 -0.258138365049E-03
+ -0.261727653312E-03 -0.265362089260E-03 -0.269042240781E-03 -0.272768682906E-03
+ -0.276541997900E-03 -0.280362775349E-03 -0.284231612259E-03 -0.288149113142E-03
+ -0.292115890116E-03 -0.296132562998E-03 -0.300199759401E-03 -0.304318114832E-03
+ -0.308488272792E-03 -0.312710884877E-03 -0.316986610878E-03 -0.321316118886E-03
+ -0.325700085396E-03 -0.330139195409E-03 -0.334634142547E-03 -0.339185629153E-03
+ -0.343794366407E-03 -0.348461074431E-03 -0.353186482410E-03 -0.357971328696E-03
+ -0.362816360932E-03 -0.367722336163E-03 -0.372690020957E-03 -0.377720191526E-03
+ -0.382813633842E-03 -0.387971143766E-03 -0.393193527169E-03 -0.398481600059E-03
+ -0.403836188707E-03 -0.409258129778E-03 -0.414748270461E-03 -0.420307468600E-03
+ -0.425936592832E-03 -0.431636522718E-03 -0.437408148882E-03 -0.443252373153E-03
+ -0.449170108701E-03 -0.455162280185E-03 -0.461229823892E-03 -0.467373687887E-03
+ -0.473594832162E-03 -0.479894228781E-03 -0.486272862038E-03 -0.492731728605E-03
+ -0.499271837693E-03 -0.505894211207E-03 -0.512599883904E-03 -0.519389903559E-03
+ -0.526265331125E-03 -0.533227240899E-03 -0.540276720695E-03 -0.547414872005E-03
+ -0.554642810179E-03 -0.561961664597E-03 -0.569372578842E-03 -0.576876710884E-03
+ -0.584475233256E-03 -0.592169333242E-03 -0.599960213060E-03 -0.607849090047E-03
+ -0.615837196856E-03 -0.623925781643E-03 -0.632116108264E-03 -0.640409456471E-03
+ -0.648807122116E-03 -0.657310417348E-03 -0.665920670823E-03 -0.674639227908E-03
+ -0.683467450893E-03 -0.692406719203E-03 -0.701458429614E-03 -0.710623996473E-03
+ -0.719904851914E-03 -0.729302446088E-03 -0.738818247385E-03 -0.748453742665E-03
+ -0.758210437490E-03 -0.768089856360E-03 -0.778093542952E-03 -0.788223060359E-03
+ -0.798479991333E-03 -0.808865938539E-03 -0.819382524797E-03 -0.830031393340E-03
+ -0.840814208073E-03 -0.851732653826E-03 -0.862788436626E-03 -0.873983283955E-03
+ -0.885318945026E-03 -0.896797191055E-03 -0.908419815535E-03 -0.920188634518E-03
+ -0.932105486902E-03 -0.944172234713E-03 -0.956390763397E-03 -0.968762982119E-03
+ -0.981290824056E-03 -0.993976246702E-03 -0.100682123217E-02 -0.101982778751E-02
+ -0.103299794502E-02 -0.104633376255E-02 -0.105983732384E-02 -0.107351073884E-02
+ -0.108735614404E-02 -0.110137570280E-02 -0.111557160570E-02 -0.112994607087E-02
+ -0.114450134433E-02 -0.115923970037E-02 -0.117416344187E-02 -0.118927490068E-02
+ -0.120457643800E-02 -0.122007044469E-02 -0.123575934172E-02 -0.125164558050E-02
+ -0.126773164327E-02 -0.128402004350E-02 -0.130051332626E-02 -0.131721406864E-02
+ -0.133412488016E-02 -0.135124840315E-02 -0.136858731317E-02 -0.138614431944E-02
+ -0.140392216527E-02 -0.142192362846E-02 -0.144015152174E-02 -0.145860869326E-02
+ -0.147729802694E-02 -0.149622244302E-02 -0.151538489845E-02 -0.153478838737E-02
+ -0.155443594161E-02 -0.157433063108E-02 -0.159447556437E-02 -0.161487388911E-02
+ -0.163552879256E-02 -0.165644350207E-02 -0.167762128555E-02 -0.169906545206E-02
+ -0.172077935224E-02 -0.174276637891E-02 -0.176502996753E-02 -0.178757359681E-02
+ -0.181040078919E-02 -0.183351511141E-02 -0.185692017511E-02 -0.188061963730E-02
+ -0.190461720105E-02 -0.192891661596E-02 -0.195352167882E-02 -0.197843623417E-02
+ -0.200366417489E-02 -0.202920944284E-02 -0.205507602947E-02 -0.208126797642E-02
+ -0.210778937617E-02 -0.213464437267E-02 -0.216183716200E-02 -0.218937199302E-02
+ -0.221725316801E-02 -0.224548504341E-02 -0.227407203040E-02 -0.230301859568E-02
+ -0.233232926212E-02 -0.236200860948E-02 -0.239206127512E-02 -0.242249195474E-02
+ -0.245330540308E-02 -0.248450643471E-02 -0.251609992473E-02 -0.254809080958E-02
+ -0.258048408778E-02 -0.261328482072E-02 -0.264649813345E-02 -0.268012921549E-02
+ -0.271418332162E-02 -0.274866577272E-02 -0.278358195659E-02 -0.281893732880E-02
+ -0.285473741355E-02 -0.289098780449E-02 -0.292769416565E-02 -0.296486223229E-02
+ -0.300249781181E-02 -0.304060678464E-02 -0.307919510520E-02 -0.311826880277E-02
+ -0.315783398248E-02 -0.319789682624E-02 -0.323846359371E-02 -0.327954062329E-02
+ -0.332113433310E-02 -0.336325122196E-02 -0.340589787046E-02 -0.344908094193E-02
+ -0.349280718353E-02 -0.353708342725E-02 -0.358191659102E-02 -0.362731367980E-02
+ -0.367328178663E-02 -0.371982809374E-02 -0.376695987374E-02 -0.381468449066E-02
+ -0.386300940117E-02 -0.391194215572E-02 -0.396149039973E-02 -0.401166187475E-02
+ -0.406246441971E-02 -0.411390597213E-02 -0.416599456935E-02 -0.421873834980E-02
+ -0.427214555425E-02 -0.432622452712E-02 -0.438098371779E-02 -0.443643168186E-02
+ -0.449257708257E-02 -0.454942869209E-02 -0.460699539292E-02 -0.466528617925E-02
+ -0.472431015842E-02 -0.478407655226E-02 -0.484459469861E-02 -0.490587405272E-02
+ -0.496792418876E-02 -0.503075480128E-02 -0.509437570679E-02 -0.515879684521E-02
+ -0.522402828147E-02 -0.529008020709E-02 -0.535696294172E-02 -0.542468693481E-02
+ -0.549326276722E-02 -0.556270115283E-02 -0.563301294029E-02 -0.570420911464E-02
+ -0.577630079908E-02 -0.584929925667E-02 -0.592321589210E-02 -0.599806225346E-02
+ -0.607385003409E-02 -0.615059107432E-02 -0.622829736339E-02 -0.630698104129E-02
+ -0.638665440067E-02 -0.646732988873E-02 -0.654902010919E-02 -0.663173782424E-02
+ -0.671549595654E-02 -0.680030759123E-02 -0.688618597798E-02 -0.697314453305E-02
+ -0.706119684138E-02 -0.715035665872E-02 -0.724063791375E-02 -0.733205471028E-02
+ -0.742462132946E-02 -0.751835223195E-02 -0.761326206024E-02 -0.770936564088E-02
+ -0.780667798684E-02 -0.790521429982E-02 -0.800498997261E-02 -0.810602059152E-02
+ -0.820832193881E-02 -0.831190999511E-02 -0.841680094194E-02 -0.852301116423E-02
+ -0.863055725289E-02 -0.873945600734E-02 -0.884972443820E-02 -0.896137976987E-02
+ -0.907443944326E-02 -0.918892111851E-02 -0.930484267769E-02 -0.942222222764E-02
+ -0.954107810277E-02 -0.966142886789E-02 -0.978329332115E-02 -0.990669049691E-02
+ -0.100316396688E-01 -0.101581603525E-01 -0.102862723091E-01 -0.104159955478E-01
+ -0.105473503296E-01 -0.106803571696E-01 -0.108150368409E-01 -0.109514103778E-01
+ -0.110894990784E-01 -0.112293245088E-01 -0.113709085057E-01 -0.115142731805E-01
+ -0.116594409220E-01 -0.118064344005E-01 -0.119552765708E-01 -0.121059906763E-01
+ -0.122586002521E-01 -0.124131291290E-01 -0.125696014371E-01 -0.127280416096E-01
+ -0.128884743862E-01 -0.130509248175E-01 -0.132154182688E-01 -0.133819804235E-01
+ -0.135506372877E-01 -0.137214151938E-01 -0.138943408051E-01 -0.140694411191E-01
+ -0.142467434726E-01 -0.144262755452E-01 -0.146080653640E-01 -0.147921413079E-01
+ -0.149785321118E-01 -0.151672668710E-01 -0.153583750461E-01 -0.155518864671E-01
+ -0.157478313383E-01 -0.159462402427E-01 -0.161471441470E-01 -0.163505744062E-01
+ -0.165565627684E-01 -0.167651413798E-01 -0.169763427896E-01 -0.171901999550E-01
+ -0.174067462464E-01 -0.176260154521E-01 -0.178480417840E-01 -0.180728598826E-01
+ -0.183005048224E-01 -0.185310121171E-01 -0.187644177253E-01 -0.190007580557E-01
+ -0.192400699729E-01 -0.194823908031E-01 -0.197277583394E-01 -0.199762108480E-01
+ -0.202277870737E-01 -0.204825262462E-01 -0.207404680854E-01 -0.210016528083E-01
+ -0.212661211343E-01 -0.215339142919E-01 -0.218050740246E-01 -0.220796425974E-01
+ -0.223576628033E-01 -0.226391779694E-01 -0.229242319636E-01 -0.232128692015E-01
+ -0.235051346524E-01 -0.238010738465E-01 -0.241007328818E-01 -0.244041584306E-01
+ -0.247113977469E-01 -0.250224986727E-01 -0.253375096462E-01 -0.256564797079E-01
+ -0.259794585084E-01 -0.263064963157E-01 -0.266376440225E-01 -0.269729531536E-01
+ -0.273124758736E-01 -0.276562649943E-01 -0.280043739825E-01 -0.283568569680E-01
+ -0.287137687507E-01 -0.290751648094E-01 -0.294411013090E-01 -0.298116351089E-01
+ -0.301868237713E-01 -0.305667255687E-01 -0.309513994927E-01 -0.313409052620E-01
+ -0.317353033310E-01 -0.321346548980E-01 -0.325390219135E-01 -0.329484670891E-01
+ -0.333630539061E-01 -0.337828466235E-01 -0.342079102874E-01 -0.346383107394E-01
+ -0.350741146251E-01 -0.355153894035E-01 -0.359622033554E-01 -0.364146255922E-01
+ -0.368727260652E-01 -0.373365755739E-01 -0.378062457758E-01 -0.382818091942E-01
+ -0.387633392283E-01 -0.392509101612E-01 -0.397445971694E-01 -0.402444763316E-01
+ -0.407506246373E-01 -0.412631199961E-01 -0.417820412462E-01 -0.423074681632E-01
+ -0.428394814690E-01 -0.433781628403E-01 -0.439235949169E-01 -0.444758613108E-01
+ -0.450350466138E-01 -0.456012364063E-01 -0.461745172650E-01 -0.467549767711E-01
+ -0.473427035179E-01 -0.479377871182E-01 -0.485403182122E-01 -0.491503884739E-01
+ -0.497680906186E-01 -0.503935184091E-01 -0.510267666621E-01 -0.516679312542E-01
+ -0.523171091275E-01 -0.529743982949E-01 -0.536398978445E-01 -0.543137079445E-01
+ -0.549959298467E-01 -0.556866658899E-01 -0.563860195029E-01 -0.570940952061E-01
+ -0.578109986137E-01 -0.585368364340E-01 -0.592717164697E-01 -0.600157476169E-01
+ -0.607690398638E-01 -0.615317042879E-01 -0.623038530526E-01 -0.630855994026E-01
+ -0.638770576582E-01 -0.646783432083E-01 -0.654895725023E-01 -0.663108630405E-01
+ -0.671423333633E-01 -0.679841030385E-01 -0.688362926470E-01 -0.696990237672E-01
+ -0.705724189571E-01 -0.714566017344E-01 -0.723516965553E-01 -0.732578287896E-01
+ -0.741751246952E-01 -0.751037113888E-01 -0.760437168149E-01 -0.769952697111E-01
+ -0.779584995714E-01 -0.789335366060E-01 -0.799205116975E-01 -0.809195563546E-01
+ -0.819308026612E-01 -0.829543832220E-01 -0.839904311047E-01 -0.850390797769E-01
+ -0.861004630396E-01 -0.871747149551E-01 -0.882619697710E-01 -0.893623618381E-01
+ -0.904760255238E-01 -0.916030951189E-01 -0.927437047399E-01 -0.938979882236E-01
+ -0.950660790167E-01 -0.962481100577E-01 -0.974442136523E-01 -0.986545213417E-01
+ -0.998791637632E-01 -0.101118270503     -0.102371969942     -0.103640389089
+ -0.104923653414     -0.106221886664     -0.107535210671     -0.108863745158
+ -0.110207607527     -0.111566912641     -0.112941772593     -0.114332296475
+ -0.115738590119     -0.117160755847     -0.118598892197     -0.120053093644
+ -0.121523450311     -0.123010047667     -0.124512966221     -0.126032281195
+ -0.127568062200     -0.129120372895     -0.130689270639     -0.132274806135
+ -0.133877023069     -0.135495957733     -0.137131638655     -0.138784086214
+ -0.140453312255     -0.142139319699     -0.143842102152     -0.145561643518
+ -0.147297917605     -0.149050887743     -0.150820506399     -0.152606714805
+ -0.154409442591     -0.156228607433     -0.158064114710     -0.159915857180
+ -0.161783714676     -0.163667553819     -0.165567227757     -0.167482575934
+ -0.169413423884     -0.171359583061     -0.173320850702     -0.175297009734
+ -0.177287828714     -0.179293061823     -0.181312448903     -0.183345715542
+ -0.185392573219     -0.187452719496     -0.189525838277     -0.191611600125
+ -0.193709662636     -0.195819670888     -0.197941257950     -0.200074045464
+ -0.202217644294     -0.204371655254     -0.206535669902     -0.208709271413
+ -0.210892035530     -0.213083531591     -0.215283323636     -0.217490971592
+ -0.219706032546     -0.221928062095     -0.224156615786     -0.226391250641
+ -0.228631526776     -0.230877009105     -0.233127269147     -0.235381886930
+ -0.237640452996     -0.239902570515     -0.242167857516     -0.244435949230
+ -0.246706500567     -0.248979188718     -0.251253715906     -0.253529812279
+ -0.255807238970     -0.258085791328     -0.260365302323     -0.262645646154
+ -0.264926742065     -0.267208558375     -0.269491116761     -0.271774496776
+ -0.274058840657     -0.276344358411     -0.278631333211     -0.280920127130
+ -0.283211187214     -0.285505051933     -0.287802358033     -0.290103847804
+ -0.292410376790     -0.294722921984     -0.297042590516     -0.299370628872
+ -0.301708432673     -0.304057557052     -0.306419727646     -0.308796852254
+ -0.311191033183     -0.313604580323     -0.316040024999     -0.318500134614
+ -0.320987928151     -0.323506692553     -0.326060000042     -0.328651726407
+ -0.331286070309     -0.333967573661     -0.336701143114     -0.339492072702
+ -0.342346067713     -0.345269269805     -0.348268283446     -0.351350203715
+ -0.354522645527     -0.357793774315     -0.361172338251     -0.364667702031
+ -0.368289882293     -0.372049584713     -0.375958242823     -0.380028058620
+ -0.384272044979     -0.388704069950     -0.393338902943     -0.398192262869
+ -0.403280868244     -0.408622489291     -0.414236002059     -0.420141444562
+ -0.426360074953     -0.432914431702     -0.439828395779     -0.447127254794
+ -0.454837769042     -0.462988239397     -0.471608576954     -0.480730374320
+ -0.490386978411     -0.500613564603     -0.511447212039     -0.522926979863
+ -0.535093984135     -0.547991475095     -0.561664914456     -0.576162052302
+ -0.591533003154     -0.607830320677     -0.625109070459     -0.643426900199
+ -0.662844106593     -0.683423698082     -0.705231452593     -0.728335969236
+ -0.752808712887     -0.778724050422     -0.806159277277     -0.835194632869
+ -0.865913303288     -0.898401409529     -0.932747979370     -0.969044900877
+  -1.00738685534      -1.04787122726      -1.09059798892      -1.13566955679
+  -1.18319061692      -1.23326791638      -1.28601001742      -1.34152701118
+  -1.39993018740      -1.46133165651      -1.52584392057      -1.59357938915
+  -1.66464983651      -1.73916579623      -1.81723588968      -1.89896608468
+  -1.98445888109      -2.07381242014      -2.16711951494      -2.26446659978
+  -2.36593259687      -2.47158769944      -2.58149207146      -2.69569446496
+  -2.81423075749      -2.93712241352      -3.06437487522      -3.19597589023
+  -3.33189378573      -3.47207570095      -3.61644579239      -3.76490342943
+  -3.91732140052      -4.07354415394      -4.23338610042      -4.39663000856
+  -4.56302552799      -4.73228787911      -4.90409675199      -5.07809546109
+  -5.25389040622      -5.43105089331      -5.60910937195      -5.78756214896
+  -5.96587063892      -6.14346321362      -6.31973771191      -6.49406466952
+  -6.66579132535      -6.83424645498      -6.99874607464      -7.15860004872
+  -7.31311962058      -7.46162587026      -7.60345908255      -7.73798898557
+  -7.86462579164      -7.98283194029      -8.09213440617      -8.19213739236
+  -8.28253518193      -8.36312486714      -8.43381861457      -8.49465505606
+  -8.54580931697      -8.58760110265      -8.62050015884      -8.64512829696
+  -8.66225702573      -8.67279976092      -8.67779647946      -8.67839065887
+  -8.67579429575      -8.67124031630      -8.66591877401      -8.66089341271
+  -8.65699435650      -8.65468187049      -8.65387520066      -8.65399008755
+  -8.65482188366      -8.65633306445      -8.65848730918      -8.66124984620
+  -8.66458748413      -8.66846862973      -8.67286329318      -8.67774308221
+  -8.68308118614      -8.68885235089      -8.69503284634      -8.70160042692
+  -8.70853428651      -8.71581500868      -8.72342451303      -8.73134599851
+  -8.73956388438      -8.74806374954      -8.75683227063      -8.76585715963
+  -8.77512710117      -8.78463169008      -8.79436136939      -8.80430736919
+  -8.81446164646      -8.82481682605      -8.83536614314      -8.84610338712
+  -8.85702284712      -8.86811925924      -8.87938775553      -8.89082381487
+  -8.90242321562      -8.91418199033      -8.92609638224      -8.93816280387
+  -8.95037779753      -8.96273799785      -8.97524009627      -8.98788080760
+  -9.00065683852      -9.01356485816      -9.02660147062      -9.03976318957
+  -9.05304641472      -9.06644741046      -9.07996228631      -9.09358697945
+  -9.10731723912      -9.12114861307      -9.13507643577      -9.14909581866
+  -9.16320164218      -9.17738854970      -9.19165094318      -9.20598298068
+  -9.22037857558      -9.23483139746      -9.24933487470      -9.26388219859
+  -9.27846632910      -9.29308000201      -9.30771573761      -9.32236585069
+  -9.33702246183      -9.35167751005      -9.36632276651      -9.38094984934
+  -9.39555023960      -9.41011529803      -9.42463628287      -9.43910436830
+  -9.45351066373      -9.46784623366      -9.48210211812      -9.49626935358
+  -9.51033899424      -9.52430213361      -9.53814992635      -9.55187361019
+  -9.56546452790      -9.57891414926      -9.59221409284      -9.60535614759
+  -9.61833229415      -9.63113472574      -9.64375586857      -9.65618840175
+  -9.66842527647      -9.68045973458      -9.69228532622      -9.70389592675
+  -9.71528575256      -9.72644937598      -9.73738173901      -9.74807816595
+  -9.75853437482      -9.76874648741      -9.77871103811      -9.78842498126
+  -9.79788569720      -9.80709099675      -9.81603912422      -9.82472875902
+  -9.83315901560      -9.84132944196      -9.84924001660      -9.85689114394
+  -9.86428364825      -9.87141876609      -9.87829813736      -9.88492379486
+  -9.89129815256      -9.89742399260      -9.90330445103      -9.90894300242
+  -9.91434344338      -9.91950987518      -9.92444668541      -9.92915852888
+  -9.93365030792      -9.93792715198      -9.94199439691      -9.94585756377
+  -9.94952233756      -9.95299454569      -9.95628013658      -9.95938515826
+  -9.96231573729      -9.96507805796      -9.96767834189      -9.97012282825
+  -9.97241775450      -9.97456933795      -9.97658375796      -9.97846713911
+  -9.98022553524      -9.98186491444      -9.98339114509      -9.98480998294
+  -9.98612705926      -9.98734787009      -9.98847776666      -9.98952194679
+  -9.99048544758      -9.99137313903      -9.99218971886      -9.99293970832
+  -9.99362744905      -9.99425710092      -9.99483264076      -9.99535786208
+  -9.99583637554      -9.99627161025      -9.99666681583      -9.99702506505
+  -9.99734925720      -9.99764212192      -9.99790622354      -9.99814396591
+  -9.99835759752      -9.99854921699      -9.99872077881      -9.99887409924
+  -9.99976306279      -9.99995111757      -9.99999011558      -9.99999804152
+  -9.99999961986      -9.99999992774      -9.99999998655      -9.99999999755
+  -9.99999999956      -9.99999999992      -9.99999999999     -10.00000000000
+  -10.0000000000      -10.0000000000      -10.0000000000      -10.0000000000
+  -10.0000000000
+  1
+ -0.289955916762E-05 -0.583559029973E-05 -0.880855215715E-05 -0.118189092712E-04
+ -0.148671320164E-04 -0.179536966836E-04 -0.210790855549E-04 -0.242437869787E-04
+ -0.274482954460E-04 -0.306931116678E-04 -0.339787426532E-04 -0.373057017887E-04
+ -0.406745089184E-04 -0.440856904254E-04 -0.475397793137E-04 -0.510373152916E-04
+ -0.545788448564E-04 -0.581649213792E-04 -0.617961051918E-04 -0.654729636739E-04
+ -0.691960713423E-04 -0.729660099401E-04 -0.767833685279E-04 -0.806487435756E-04
+ -0.845627390561E-04 -0.885259665391E-04 -0.925390452869E-04 -0.966026023512E-04
+ -0.100717272671E-03 -0.104883699172E-03 -0.109102532867E-03 -0.113374432958E-03
+ -0.117700066936E-03 -0.122080110692E-03 -0.126515248616E-03 -0.131006173707E-03
+ -0.135553587683E-03 -0.140158201084E-03 -0.144820733392E-03 -0.149541913136E-03
+ -0.154322478012E-03 -0.159163174991E-03 -0.164064760442E-03 -0.169028000248E-03
+ -0.174053669926E-03 -0.179142554746E-03 -0.184295449857E-03 -0.189513160410E-03
+ -0.194796501682E-03 -0.200146299206E-03 -0.205563388899E-03 -0.211048617192E-03
+ -0.216602841164E-03 -0.222226928672E-03 -0.227921758493E-03 -0.233688220455E-03
+ -0.239527215579E-03 -0.245439656220E-03 -0.251426466209E-03 -0.257488580998E-03
+ -0.263626947804E-03 -0.269842525759E-03 -0.276136286060E-03 -0.282509212120E-03
+ -0.288962299722E-03 -0.295496557173E-03 -0.302113005465E-03 -0.308812678432E-03
+ -0.315596622910E-03 -0.322465898905E-03 -0.329421579755E-03 -0.336464752299E-03
+ -0.343596517048E-03 -0.350817988355E-03 -0.358130294588E-03 -0.365534578310E-03
+ -0.373031996457E-03 -0.380623720515E-03 -0.388310936705E-03 -0.396094846172E-03
+ -0.403976665167E-03 -0.411957625240E-03 -0.420038973433E-03 -0.428221972472E-03
+ -0.436507900968E-03 -0.444898053614E-03 -0.453393741389E-03 -0.461996291760E-03
+ -0.470707048895E-03 -0.479527373866E-03 -0.488458644867E-03 -0.497502257427E-03
+ -0.506659624630E-03 -0.515932177332E-03 -0.525321364389E-03 -0.534828652880E-03
+ -0.544455528339E-03 -0.554203494984E-03 -0.564074075955E-03 -0.574068813551E-03
+ -0.584189269469E-03 -0.594437025051E-03 -0.604813681530E-03 -0.615320860279E-03
+ -0.625960203068E-03 -0.636733372313E-03 -0.647642051346E-03 -0.658687944670E-03
+ -0.669872778227E-03 -0.681198299671E-03 -0.692666278638E-03 -0.704278507022E-03
+ -0.716036799258E-03 -0.727942992603E-03 -0.739998947423E-03 -0.752206547487E-03
+ -0.764567700257E-03 -0.777084337188E-03 -0.789758414029E-03 -0.802591911132E-03
+ -0.815586833756E-03 -0.828745212384E-03 -0.842069103040E-03 -0.855560587609E-03
+ -0.869221774162E-03 -0.883054797288E-03 -0.897061818425E-03 -0.911245026198E-03
+ -0.925606636763E-03 -0.940148894149E-03 -0.954874070616E-03 -0.969784467000E-03
+ -0.984882413083E-03 -0.100017026795E-02 -0.101565042036E-02 -0.103132528911E-02
+ -0.104719732344E-02 -0.106326900338E-02 -0.107954284017E-02 -0.109602137663E-02
+ -0.111270718756E-02 -0.112960288015E-02 -0.114671109440E-02 -0.116403450349E-02
+ -0.118157581423E-02 -0.119933776751E-02 -0.121732313865E-02 -0.123553473791E-02
+ -0.125397541089E-02 -0.127264803898E-02 -0.129155553982E-02 -0.131070086774E-02
+ -0.133008701424E-02 -0.134971700844E-02 -0.136959391757E-02 -0.138972084744E-02
+ -0.141010094292E-02 -0.143073738844E-02 -0.145163340850E-02 -0.147279226812E-02
+ -0.149421727344E-02 -0.151591177215E-02 -0.153787915405E-02 -0.156012285161E-02
+ -0.158264634043E-02 -0.160545313986E-02 -0.162854681352E-02 -0.165193096983E-02
+ -0.167560926261E-02 -0.169958539166E-02 -0.172386310327E-02 -0.174844619091E-02
+ -0.177333849572E-02 -0.179854390718E-02 -0.182406636368E-02 -0.184990985316E-02
+ -0.187607841373E-02 -0.190257613426E-02 -0.192940715508E-02 -0.195657566859E-02
+ -0.198408591994E-02 -0.201194220764E-02 -0.204014888431E-02 -0.206871035729E-02
+ -0.209763108937E-02 -0.212691559948E-02 -0.215656846337E-02 -0.218659431438E-02
+ -0.221699784409E-02 -0.224778380312E-02 -0.227895700185E-02 -0.231052231114E-02
+ -0.234248466314E-02 -0.237484905203E-02 -0.240762053482E-02 -0.244080423211E-02
+ -0.247440532892E-02 -0.250842907550E-02 -0.254288078812E-02 -0.257776584993E-02
+ -0.261308971180E-02 -0.264885789315E-02 -0.268507598283E-02 -0.272174963999E-02
+ -0.275888459496E-02 -0.279648665016E-02 -0.283456168098E-02 -0.287311563673E-02
+ -0.291215454153E-02 -0.295168449530E-02 -0.299171167467E-02 -0.303224233397E-02
+ -0.307328280620E-02 -0.311483950400E-02 -0.315691892071E-02 -0.319952763132E-02
+ -0.324267229351E-02 -0.328635964874E-02 -0.333059652325E-02 -0.337538982912E-02
+ -0.342074656541E-02 -0.346667381920E-02 -0.351317876671E-02 -0.356026867444E-02
+ -0.360795090029E-02 -0.365623289468E-02 -0.370512220179E-02 -0.375462646067E-02
+ -0.380475340645E-02 -0.385551087158E-02 -0.390690678701E-02 -0.395894918345E-02
+ -0.401164619264E-02 -0.406500604859E-02 -0.411903708888E-02 -0.417374775597E-02
+ -0.422914659853E-02 -0.428524227271E-02 -0.434204354360E-02 -0.439955928650E-02
+ -0.445779848836E-02 -0.451677024917E-02 -0.457648378340E-02 -0.463694842140E-02
+ -0.469817361089E-02 -0.476016891844E-02 -0.482294403092E-02 -0.488650875709E-02
+ -0.495087302906E-02 -0.501604690387E-02 -0.508204056507E-02 -0.514886432431E-02
+ -0.521652862293E-02 -0.528504403362E-02 -0.535442126204E-02 -0.542467114853E-02
+ -0.549580466976E-02 -0.556783294051E-02 -0.564076721532E-02 -0.571461889033E-02
+ -0.578939950501E-02 -0.586512074397E-02 -0.594179443882E-02 -0.601943256997E-02
+ -0.609804726854E-02 -0.617765081822E-02 -0.625825565723E-02 -0.633987438025E-02
+ -0.642251974035E-02 -0.650620465104E-02 -0.659094218825E-02 -0.667674559240E-02
+ -0.676362827043E-02 -0.685160379794E-02 -0.694068592128E-02 -0.703088855970E-02
+ -0.712222580755E-02 -0.721471193646E-02 -0.730836139756E-02 -0.740318882377E-02
+ -0.749920903207E-02 -0.759643702580E-02 -0.769488799702E-02 -0.779457732890E-02
+ -0.789552059809E-02 -0.799773357717E-02 -0.810123223713E-02 -0.820603274984E-02
+ -0.831215149058E-02 -0.841960504061E-02 -0.852841018977E-02 -0.863858393907E-02
+ -0.875014350337E-02 -0.886310631407E-02 -0.897749002185E-02 -0.909331249937E-02
+ -0.921059184412E-02 -0.932934638123E-02 -0.944959466633E-02 -0.957135548844E-02
+ -0.969464787294E-02 -0.981949108450E-02 -0.994590463010E-02 -0.100739082621E-01
+ -0.102035219814E-01 -0.103347660402E-01 -0.104676609459E-01 -0.106022274633E-01
+ -0.107384866190E-01 -0.108764597034E-01 -0.110161682753E-01 -0.111576341644E-01
+ -0.113008794750E-01 -0.114459265894E-01 -0.115927981716E-01 -0.117415171704E-01
+ -0.118921068236E-01 -0.120445906610E-01 -0.121989925085E-01 -0.123553364917E-01
+ -0.125136470397E-01 -0.126739488888E-01 -0.128362670864E-01 -0.130006269951E-01
+ -0.131670542963E-01 -0.133355749948E-01 -0.135062154221E-01 -0.136790022411E-01
+ -0.138539624502E-01 -0.140311233871E-01 -0.142105127336E-01 -0.143921585196E-01
+ -0.145760891275E-01 -0.147623332970E-01 -0.149509201289E-01 -0.151418790903E-01
+ -0.153352400190E-01 -0.155310331278E-01 -0.157292890098E-01 -0.159300386429E-01
+ -0.161333133945E-01 -0.163391450267E-01 -0.165475657010E-01 -0.167586079836E-01
+ -0.169723048502E-01 -0.171886896912E-01 -0.174077963173E-01 -0.176296589641E-01
+ -0.178543122981E-01 -0.180817914219E-01 -0.183121318793E-01 -0.185453696615E-01
+ -0.187815412123E-01 -0.190206834339E-01 -0.192628336926E-01 -0.195080298250E-01
+ -0.197563101431E-01 -0.200077134413E-01 -0.202622790018E-01 -0.205200466009E-01
+ -0.207810565150E-01 -0.210453495276E-01 -0.213129669347E-01 -0.215839505521E-01
+ -0.218583427213E-01 -0.221361863165E-01 -0.224175247514E-01 -0.227024019853E-01
+ -0.229908625309E-01 -0.232829514605E-01 -0.235787144135E-01 -0.238781976033E-01
+ -0.241814478246E-01 -0.244885124606E-01 -0.247994394907E-01 -0.251142774977E-01
+ -0.254330756754E-01 -0.257558838366E-01 -0.260827524205E-01 -0.264137325006E-01
+ -0.267488757932E-01 -0.270882346648E-01 -0.274318621407E-01 -0.277798119131E-01
+ -0.281321383496E-01 -0.284888965018E-01 -0.288501421134E-01 -0.292159316297E-01
+ -0.295863222056E-01 -0.299613717151E-01 -0.303411387601E-01 -0.307256826797E-01
+ -0.311150635593E-01 -0.315093422402E-01 -0.319085803287E-01 -0.323128402062E-01
+ -0.327221850388E-01 -0.331366787871E-01 -0.335563862160E-01 -0.339813729052E-01
+ -0.344117052594E-01 -0.348474505184E-01 -0.352886767676E-01 -0.357354529492E-01
+ -0.361878488722E-01 -0.366459352239E-01 -0.371097835805E-01 -0.375794664188E-01
+ -0.380550571269E-01 -0.385366300163E-01 -0.390242603330E-01 -0.395180242695E-01
+ -0.400179989767E-01 -0.405242625759E-01 -0.410368941710E-01 -0.415559738609E-01
+ -0.420815827520E-01 -0.426138029709E-01 -0.431527176771E-01 -0.436984110761E-01
+ -0.442509684328E-01 -0.448104760841E-01 -0.453770214533E-01 -0.459506930632E-01
+ -0.465315805498E-01 -0.471197746768E-01 -0.477153673495E-01 -0.483184516291E-01
+ -0.489291217474E-01 -0.495474731215E-01 -0.501736023684E-01 -0.508076073207E-01
+ -0.514495870414E-01 -0.520996418393E-01 -0.527578732852E-01 -0.534243842273E-01
+ -0.540992788073E-01 -0.547826624771E-01 -0.554746420147E-01 -0.561753255412E-01
+ -0.568848225377E-01 -0.576032438622E-01 -0.583307017673E-01 -0.590673099171E-01
+ -0.598131834059E-01 -0.605684387750E-01 -0.613331940321E-01 -0.621075686687E-01
+ -0.628916836796E-01 -0.636856615813E-01 -0.644896264311E-01 -0.653037038469E-01
+ -0.661280210265E-01 -0.669627067676E-01 -0.678078914877E-01 -0.686637072447E-01
+ -0.695302877576E-01 -0.704077684270E-01 -0.712962863569E-01 -0.721959803753E-01
+ -0.731069910565E-01 -0.740294607428E-01 -0.749635335669E-01 -0.759093554743E-01
+ -0.768670742459E-01 -0.778368395215E-01 -0.788188028228E-01 -0.798131175774E-01
+ -0.808199391425E-01 -0.818394248292E-01 -0.828717339271E-01 -0.839170277294E-01
+ -0.849754695576E-01 -0.860472247875E-01 -0.871324608747E-01 -0.882313473810E-01
+ -0.893440560007E-01 -0.904707605873E-01 -0.916116371811E-01 -0.927668640363E-01
+ -0.939366216487E-01 -0.951210927845E-01 -0.963204625082E-01 -0.975349182119E-01
+ -0.987646496444E-01 -0.100009848941     -0.101270710652     -0.102547431777
+ -0.103840211792     -0.105149252679     -0.106474758965     -0.107816937745
+ -0.109175998720     -0.110552154229     -0.111945619279     -0.113356611584
+ -0.114785351592     -0.116232062527     -0.117696970418     -0.119180304136
+ -0.120682295432     -0.122203178969     -0.123743192362     -0.125302576215
+ -0.126881574155     -0.128480432876     -0.130099402169     -0.131738734971
+ -0.133398687397     -0.135079518782     -0.136781491723     -0.138504872118
+ -0.140249929209     -0.142016935622     -0.143806167412     -0.145617904104
+ -0.147452428738     -0.149310027913     -0.151190991829     -0.153095614337
+ -0.155024192980     -0.156977029044     -0.158954427601     -0.160956697558
+ -0.162984151706     -0.165037106767     -0.167115883446     -0.169220806477
+ -0.171352204677     -0.173510410997     -0.175695762572     -0.177908600773
+ -0.180149271263     -0.182418124049     -0.184715513536     -0.187041798585
+ -0.189397342564     -0.191782513408     -0.194197683677     -0.196643230610
+ -0.199119536187     -0.201626987187     -0.204165975250     -0.206736896933
+ -0.209340153777     -0.211976152368     -0.214645304396     -0.217348026724
+ -0.220084741452     -0.222855875978     -0.225661863070     -0.228503140930
+ -0.231380153260     -0.234293349337     -0.237243184076     -0.240230118102
+ -0.243254617825     -0.246317155506     -0.249418209337     -0.252558263507
+ -0.255737808283     -0.258957340083     -0.262217361553     -0.265518381645
+ -0.268860915692     -0.272245485493     -0.275672619388     -0.279142852344
+ -0.282656726031     -0.286214788911     -0.289817596320     -0.293465710550
+ -0.297159700941     -0.300900143962     -0.304687623303     -0.308522729964
+ -0.312406062342     -0.316338226325     -0.320319835381     -0.324351510656
+ -0.328433881064     -0.332567583383     -0.336753262354     -0.340991570772
+ -0.345283169593     -0.349628728026     -0.354028923638     -0.358484442452
+ -0.362995979054     -0.367564236692     -0.372189927385     -0.376873772026
+ -0.381616500489     -0.386418851739     -0.391281573938     -0.396205424558
+ -0.401191170490     -0.406239588158     -0.411351463630     -0.416527592732
+ -0.421768781168     -0.427075844630     -0.432449608916     -0.437890910054
+ -0.443400594415     -0.448979518832     -0.454628550729     -0.460348568233
+ -0.466140460304     -0.472005126852     -0.477943478869     -0.483956438546
+ -0.490044939404     -0.496209926418     -0.502452356143     -0.508773196847
+ -0.515173428629     -0.521654043559     -0.528216045798     -0.534860451731
+ -0.541588290095     -0.548400602113     -0.555298441615     -0.562282875177
+ -0.569354982246     -0.576515855267     -0.583766599819     -0.591108334738
+ -0.598542192248     -0.606069318087     -0.613690871635     -0.621408026041
+ -0.629221968344     -0.637133899600     -0.645145035004     -0.653256604008
+ -0.661469850442     -0.669786032630     -0.678206423506     -0.686732310723
+ -0.695364996766     -0.704105799054     -0.712956050050     -0.721917097355
+ -0.730990303807     -0.740177047573     -0.749478722236     -0.758896736881
+ -0.768432516167     -0.778087500408     -0.787863145635     -0.797760923656
+ -0.807782322116     -0.817928844539     -0.828202010371     -0.838603355015
+ -0.849134429848     -0.859796802246     -0.870592055582     -0.881521789228
+ -0.892587618542     -0.903791174841     -0.915134105368     -0.926618073245
+ -0.938244757413     -0.950015852565     -0.961933069054     -0.973998132800
+ -0.986212785178     -0.998578782885      -1.01109789780      -1.02377191684
+  -1.03660264174      -1.04959188893      -1.06274148926      -1.07605328783
+  -1.08952914370      -1.10317092965      -1.11698053191      -1.13095984984
+  -1.14511079562      -1.15943529390      -1.17393528149      -1.18861270692
+  -1.20346953008      -1.21850772181      -1.23372926344      -1.24913614636
+  -1.26473037154      -1.28051394905      -1.29648889751      -1.31265724362
+  -1.32902102158      -1.34558227253      -1.36234304398      -1.37930538919
+  -1.39647136662      -1.41384303921      -1.43142247382      -1.44921174051
+  -1.46721291190      -1.48542806247      -1.50385926784      -1.52250860409
+  -1.54137814697      -1.56046997115      -1.57978614949      -1.59932875220
+  -1.61909984605      -1.63910149349      -1.65933575185      -1.67980467239
+  -1.70051029937      -1.72145466913      -1.74263980904      -1.76406773648
+  -1.78574045770      -1.80765996672      -1.82982824405      -1.85224725543
+  -1.87491895045      -1.89784526111      -1.92102810024      -1.94446935988
+  -1.96817090951      -1.99213459415      -2.01636223235      -2.04085561405
+  -2.06561649819      -2.09064661034      -2.11594763994      -2.14152123749
+  -2.16736901152      -2.19349252528      -2.21989329326      -2.24657277747
+  -2.27353238342      -2.30077345588      -2.32829727433      -2.35610504810
+  -2.38419791127      -2.41257691713      -2.44124303238      -2.47019713099
+  -2.49943998758      -2.52897227056      -2.55879453470      -2.58890721344
+  -2.61931061063      -2.65000489189      -2.68099007546      -2.71226602256
+  -2.74383242727      -2.77568880579      -2.80783448529      -2.84026859202
+  -2.87299003895      -2.90599751274      -2.93928946013      -2.97286407354
+  -3.00671927616      -3.04085270624      -3.07526170064      -3.10994327770
+  -3.14489411933      -3.18011055223      -3.21558852846      -3.25132360501
+  -3.28731092266      -3.32354518390      -3.36002063002      -3.39673101726
+  -3.43366959211      -3.47082906564      -3.50820158699      -3.54577871586
+  -3.58355139415      -3.62150991661      -3.65964390070      -3.69794225545
+  -3.73639314952      -3.77498397842      -3.81370133096      -3.85253095485
+  -3.89145772173      -3.93046559151      -3.96953757613      -4.00865570289
+  -4.04780097741      -4.08695334633      -4.12609165989      -4.16519363453
+  -4.20423581568      -4.24319354092      -4.28204090375      -4.32075071808
+  -4.35929448384      -4.39764235388      -4.43576310244      -4.47362409564
+  -4.51119126414      -4.54842907855      -4.58530052783      -4.62176710122
+  -4.65778877416      -4.69332399856      -4.72832969820      -4.76276126953
+  -4.79657258873      -4.82971602539      -4.86214246369      -4.89380133157
+  -4.92464063875      -4.95460702412      -4.98364581351      -5.01170108831
+  -5.03871576589      -5.06463169262      -5.08938975008      -5.11292997548
+  -5.13519169679      -5.15611368359      -5.17563431417      -5.19369175965
+  -5.21022418572      -5.22516997274      -5.23846795448      -5.25005767633
+  -5.25987967305      -5.26787576667      -5.27398938467      -5.27816589866
+  -5.28035298369      -5.28050099825      -5.27856338490      -5.27449709156
+  -5.26826301324      -5.25982645440      -5.24915761160      -5.23623207674
+  -5.22103136095      -5.20354343959      -5.18376331897      -5.16169362579
+  -5.13734522083      -5.11073783872      -5.08190075647      -5.05087349412
+  -5.01770655166      -4.98246218722      -4.94521524286      -4.90605402489
+  -4.86508124715      -4.82241504648      -4.77819008064      -4.73255871983
+  -4.68569234314      -4.63778275187      -4.58904371048      -4.53971262535
+  -4.49005236873      -4.44035325204      -4.39093514763      -4.34214975105
+  -4.29438296697      -4.24805739016      -4.20363483833      -4.16161887593
+  -4.12255724633      -4.08704410477      -4.05572191512      -4.02928284021
+  -4.00846941874      -3.99407428136      -3.98693861644      -3.98794905219
+  -3.99803257967      -4.01814910196      -4.04928116298      -4.09242038810
+  -4.14855016449      -4.21862410674      -4.30353990132      -4.40410820919
+  -4.52101643915      -4.65478739441      -4.80573305149      -4.97390406354
+  -5.15903599717      -5.36049381952      -5.57721675385      -5.80766631472
+  -6.04978111303      -6.30094287189      -6.55795899792      -6.81706798407
+  -7.07397484971      -7.32392483682      -7.56182355320      -7.78241481405
+  -7.98052453372      -8.15138386222      -8.29104353625      -8.39689395755
+  -8.46830812298      -8.50742869367      -8.52012655407      -8.51716654852
+  -8.51183441639      -8.50722018060      -8.50328936636      -8.50000847209
+  -8.49734533961      -8.49526916807      -8.49375051756      -8.49276130355
+  -8.49227478326      -8.49226553503      -8.49270943166      -8.49358360892
+  -8.49486642996      -8.49653744661      -8.49857735837      -8.50096796970
+  -8.50369214632      -8.50673377106      -8.51007769968      -8.51370968387
+  -8.51761635878      -8.52178520080      -8.52620448646      -8.53086325271
+  -8.53575125862      -8.54085894865      -8.54617741738      -8.55169837595
+  -8.55741411988      -8.56331749861      -8.56940188642      -8.57566115464
+  -8.58208964543      -8.58868214660      -8.59543386766      -8.60234041677
+  -8.60939777927      -8.61660229456      -8.62395064351      -8.63143979867
+  -8.63930051496      -8.64780930673      -8.65645896968      -8.66524827772
+  -8.67417616950      -8.68324183269      -8.69244464426      -8.70178416418
+  -8.71126011433      -8.72087236168      -8.73062090051      -8.86359014474
+  -8.95974128884      -9.27784129139      -9.50100357949      -9.65682996604
+  -9.76512234190      -9.84001938538      -9.89156766736      -9.92687125621
+  -9.95092876541      -9.96723978842      -9.97824204700      -9.98562488077
+  -9.99055293276      -9.99382489538      -9.99598558200      -9.99740462212
+  -9.99833142129      -9.99893333315      -9.99932202390      -9.99957157925
+  -9.99973086901      -9.99983194163      -9.99989569011      -9.99993565350
+  -9.99996055216      -9.99997596829      -9.99998545302      -9.99999125115
+  -9.99999477264      -9.99999689738      -9.99999817084      -9.99999892894
+  -9.99999937717      -9.99999964034      -9.99999979378      -9.99999988261
+  -9.99999993366      -9.99999996278      -9.99999997928      -9.99999998855
+  -9.99999999372      -9.99999999658      -9.99999999816      -9.99999999901
+  -9.99999999948      -9.99999999972      -9.99999999986      -9.99999999993
+  -9.99999999996      -9.99999999998      -9.99999999999     -10.00000000000
+ -10.00000000000     -10.00000000000     -10.00000000000      -10.0000000000
+  -10.0000000000
+  2
+ -0.551509801384E-05 -0.110995674208E-04 -0.167542808056E-04 -0.224801217286E-04
+ -0.282779848642E-04 -0.341487761404E-04 -0.400934128801E-04 -0.461128239449E-04
+ -0.522079498801E-04 -0.583797430616E-04 -0.646291678445E-04 -0.709572007141E-04
+ -0.773648304386E-04 -0.838530582231E-04 -0.904228978663E-04 -0.970753759191E-04
+ -0.103811531845E-03 -0.110632418181E-03 -0.117539100706E-03 -0.124532658602E-03
+ -0.131614184627E-03 -0.138784785285E-03 -0.146045580995E-03 -0.153397706272E-03
+ -0.160842309900E-03 -0.168380555115E-03 -0.176013619782E-03 -0.183742696583E-03
+ -0.191568993201E-03 -0.199493732513E-03 -0.207518152774E-03 -0.215643507816E-03
+ -0.223871067243E-03 -0.232202116627E-03 -0.240637957713E-03 -0.249179908616E-03
+ -0.257829304036E-03 -0.266587495456E-03 -0.275455851363E-03 -0.284435757454E-03
+ -0.293528616860E-03 -0.302735850356E-03 -0.312058896594E-03 -0.321499212316E-03
+ -0.331058272592E-03 -0.340737571045E-03 -0.350538620084E-03 -0.360462951144E-03
+ -0.370512114920E-03 -0.380687681617E-03 -0.390991241186E-03 -0.401424403580E-03
+ -0.411988799001E-03 -0.422686078158E-03 -0.433517912523E-03 -0.444485994591E-03
+ -0.455592038148E-03 -0.466837778536E-03 -0.478224972924E-03 -0.489755400585E-03
+ -0.501430863172E-03 -0.513253184999E-03 -0.525224213328E-03 -0.537345818657E-03
+ -0.549619895011E-03 -0.562048360240E-03 -0.574633156316E-03 -0.587376249640E-03
+ -0.600279631345E-03 -0.613345317612E-03 -0.626575349981E-03 -0.639971795671E-03
+ -0.653536747903E-03 -0.667272326230E-03 -0.681180676863E-03 -0.695263973011E-03
+ -0.709524415217E-03 -0.723964231703E-03 -0.738585678722E-03 -0.753391040904E-03
+ -0.768382631616E-03 -0.783562793326E-03 -0.798933897963E-03 -0.814498347296E-03
+ -0.830258573300E-03 -0.846217038544E-03 -0.862376236569E-03 -0.878738692283E-03
+ -0.895306962353E-03 -0.912083635606E-03 -0.929071333430E-03 -0.946272710188E-03
+ -0.963690453630E-03 -0.981327285313E-03 -0.999185961030E-03 -0.101726927123E-02
+ -0.103558004148E-02 -0.105412113286E-02 -0.107289544246E-02 -0.109190590380E-02
+ -0.111115548731E-02 -0.113064720077E-02 -0.115038408981E-02 -0.117036923835E-02
+ -0.119060576911E-02 -0.121109684409E-02 -0.123184566507E-02 -0.125285547408E-02
+ -0.127412955396E-02 -0.129567122882E-02 -0.131748386460E-02 -0.133957086955E-02
+ -0.136193569483E-02 -0.138458183498E-02 -0.140751282851E-02 -0.143073225842E-02
+ -0.145424375281E-02 -0.147805098540E-02 -0.150215767610E-02 -0.152656759164E-02
+ -0.155128454613E-02 -0.157631240163E-02 -0.160165506879E-02 -0.162731650747E-02
+ -0.165330072731E-02 -0.167961178839E-02 -0.170625380189E-02 -0.173323093066E-02
+ -0.176054738994E-02 -0.178820744797E-02 -0.181621542671E-02 -0.184457570245E-02
+ -0.187329270654E-02 -0.190237092608E-02 -0.193181490459E-02 -0.196162924275E-02
+ -0.199181859913E-02 -0.202238769086E-02 -0.205334129443E-02 -0.208468424640E-02
+ -0.211642144417E-02 -0.214855784675E-02 -0.218109847551E-02 -0.221404841499E-02
+ -0.224741281369E-02 -0.228119688486E-02 -0.231540590733E-02 -0.235004522633E-02
+ -0.238512025433E-02 -0.242063647186E-02 -0.245659942842E-02 -0.249301474328E-02
+ -0.252988810641E-02 -0.256722527936E-02 -0.260503209612E-02 -0.264331446410E-02
+ -0.268207836498E-02 -0.272132985571E-02 -0.276107506942E-02 -0.280132021637E-02
+ -0.284207158495E-02 -0.288333554264E-02 -0.292511853703E-02 -0.296742709678E-02
+ -0.301026783270E-02 -0.305364743875E-02 -0.309757269306E-02 -0.314205045905E-02
+ -0.318708768647E-02 -0.323269141246E-02 -0.327886876272E-02 -0.332562695253E-02
+ -0.337297328797E-02 -0.342091516699E-02 -0.346946008061E-02 -0.351861561407E-02
+ -0.356838944803E-02 -0.361878935975E-02 -0.366982322430E-02 -0.372149901585E-02
+ -0.377382480884E-02 -0.382680877927E-02 -0.388045920601E-02 -0.393478447204E-02
+ -0.398979306579E-02 -0.404549358247E-02 -0.410189472540E-02 -0.415900530737E-02
+ -0.421683425202E-02 -0.427539059524E-02 -0.433468348659E-02 -0.439472219070E-02
+ -0.445551608873E-02 -0.451707467986E-02 -0.457940758274E-02 -0.464252453702E-02
+ -0.470643540484E-02 -0.477115017241E-02 -0.483667895154E-02 -0.490303198125E-02
+ -0.497021962931E-02 -0.503825239395E-02 -0.510714090542E-02 -0.517689592768E-02
+ -0.524752836010E-02 -0.531904923915E-02 -0.539146974010E-02 -0.546480117881E-02
+ -0.553905501346E-02 -0.561424284636E-02 -0.569037642577E-02 -0.576746764771E-02
+ -0.584552855785E-02 -0.592457135335E-02 -0.600460838481E-02 -0.608565215819E-02
+ -0.616771533673E-02 -0.625081074298E-02 -0.633495136076E-02 -0.642015033722E-02
+ -0.650642098486E-02 -0.659377678365E-02 -0.668223138311E-02 -0.677179860445E-02
+ -0.686249244274E-02 -0.695432706906E-02 -0.704731683276E-02 -0.714147626369E-02
+ -0.723682007444E-02 -0.733336316268E-02 -0.743112061347E-02 -0.753010770159E-02
+ -0.763033989399E-02 -0.773183285215E-02 -0.783460243454E-02 -0.793866469913E-02
+ -0.804403590585E-02 -0.815073251917E-02 -0.825877121065E-02 -0.836816886155E-02
+ -0.847894256548E-02 -0.859110963106E-02 -0.870468758460E-02 -0.881969417291E-02
+ -0.893614736599E-02 -0.905406535989E-02 -0.917346657953E-02 -0.929436968160E-02
+ -0.941679355745E-02 -0.954075733606E-02 -0.966628038702E-02 -0.979338232355E-02
+ -0.992208300560E-02 -0.100524025429E-01 -0.101843612982E-01 -0.103179798902E-01
+ -0.104532791971E-01 -0.105902803598E-01 -0.107290047850E-01 -0.108694741485E-01
+ -0.110117103991E-01 -0.111557357614E-01 -0.113015727398E-01 -0.114492441214E-01
+ -0.115987729803E-01 -0.117501826806E-01 -0.119034968805E-01 -0.120587395355E-01
+ -0.122159349026E-01 -0.123751075441E-01 -0.125362823307E-01 -0.126994844466E-01
+ -0.128647393923E-01 -0.130320729893E-01 -0.132015113837E-01 -0.133730810506E-01
+ -0.135468087982E-01 -0.137227217718E-01 -0.139008474581E-01 -0.140812136896E-01
+ -0.142638486489E-01 -0.144487808731E-01 -0.146360392582E-01 -0.148256530637E-01
+ -0.150176519171E-01 -0.152120658187E-01 -0.154089251460E-01 -0.156082606587E-01
+ -0.158101035033E-01 -0.160144852182E-01 -0.162214377385E-01 -0.164309934009E-01
+ -0.166431849488E-01 -0.168580455377E-01 -0.170756087399E-01 -0.172959085502E-01
+ -0.175189793907E-01 -0.177448561168E-01 -0.179735740221E-01 -0.182051688443E-01
+ -0.184396767706E-01 -0.186771344432E-01 -0.189175789654E-01 -0.191610479071E-01
+ -0.194075793109E-01 -0.196572116977E-01 -0.199099840731E-01 -0.201659359333E-01
+ -0.204251072713E-01 -0.206875385831E-01 -0.209532708741E-01 -0.212223456656E-01
+ -0.214948050009E-01 -0.217706914524E-01 -0.220500481279E-01 -0.223329186774E-01
+ -0.226193473000E-01 -0.229093787507E-01 -0.232030583476E-01 -0.235004319786E-01
+ -0.238015461089E-01 -0.241064477882E-01 -0.244151846581E-01 -0.247278049592E-01
+ -0.250443575390E-01 -0.253648918596E-01 -0.256894580050E-01 -0.260181066893E-01
+ -0.263508892645E-01 -0.266878577286E-01 -0.270290647336E-01 -0.273745635935E-01
+ -0.277244082935E-01 -0.280786534972E-01 -0.284373545563E-01 -0.288005675185E-01
+ -0.291683491365E-01 -0.295407568768E-01 -0.299178489289E-01 -0.302996842142E-01
+ -0.306863223952E-01 -0.310778238847E-01 -0.314742498557E-01 -0.318756622504E-01
+ -0.322821237903E-01 -0.326936979859E-01 -0.331104491462E-01 -0.335324423896E-01
+ -0.339597436531E-01 -0.343924197035E-01 -0.348305381472E-01 -0.352741674411E-01
+ -0.357233769029E-01 -0.361782367226E-01 -0.366388179727E-01 -0.371051926201E-01
+ -0.375774335366E-01 -0.380556145107E-01 -0.385398102590E-01 -0.390300964381E-01
+ -0.395265496560E-01 -0.400292474844E-01 -0.405382684709E-01 -0.410536921508E-01
+ -0.415755990600E-01 -0.421040707475E-01 -0.426391897878E-01 -0.431810397943E-01
+ -0.437297054320E-01 -0.442852724309E-01 -0.448478275993E-01 -0.454174588374E-01
+ -0.459942551512E-01 -0.465783066660E-01 -0.471697046408E-01 -0.477685414828E-01
+ -0.483749107610E-01 -0.489889072219E-01 -0.496106268033E-01 -0.502401666501E-01
+ -0.508776251288E-01 -0.515231018434E-01 -0.521766976508E-01 -0.528385146763E-01
+ -0.535086563301E-01 -0.541872273227E-01 -0.548743336820E-01 -0.555700827696E-01
+ -0.562745832972E-01 -0.569879453443E-01 -0.577102803748E-01 -0.584417012547E-01
+ -0.591823222696E-01 -0.599322591427E-01 -0.606916290528E-01 -0.614605506527E-01
+ -0.622391440874E-01 -0.630275310133E-01 -0.638258346172E-01 -0.646341796350E-01
+ -0.654526923719E-01 -0.662815007217E-01 -0.671207341868E-01 -0.679705238987E-01
+ -0.688310026382E-01 -0.697023048562E-01 -0.705845666950E-01 -0.714779260091E-01
+ -0.723825223870E-01 -0.732984971733E-01 -0.742259934900E-01 -0.751651562596E-01
+ -0.761161322276E-01 -0.770790699851E-01 -0.780541199922E-01 -0.790414346017E-01
+ -0.800411680825E-01 -0.810534766443E-01 -0.820785184614E-01 -0.831164536976E-01
+ -0.841674445314E-01 -0.852316551812E-01 -0.863092519311E-01 -0.874004031566E-01
+ -0.885052793510E-01 -0.896240531524E-01 -0.907568993701E-01 -0.919039950124E-01
+ -0.930655193139E-01 -0.942416537637E-01 -0.954325821338E-01 -0.966384905075E-01
+ -0.978595673089E-01 -0.990960033321E-01 -0.100347991771     -0.101615728250
+ -0.102899410852     -0.104199240155     -0.105515419258     -0.106848153813
+ -0.108197652061     -0.109564124861     -0.110947785726     -0.112348850853
+ -0.113767539159     -0.115204072313     -0.116658674775     -0.118131573826
+ -0.119622999606     -0.121133185151     -0.122662366427     -0.124210782369
+ -0.125778674915     -0.127366289050     -0.128973872836     -0.130601677459
+ -0.132249957262     -0.133918969787     -0.135608975818     -0.137320239416
+ -0.139053027965     -0.140807612212     -0.142584266309     -0.144383267856
+ -0.146204897946     -0.148049441206     -0.149917185843     -0.151808423690
+ -0.153723450251     -0.155662564745     -0.157626070156     -0.159614273279
+ -0.161627484765     -0.163666019176     -0.165730195028     -0.167820334844
+ -0.169936765205     -0.172079816796     -0.174249824465     -0.176447127269
+ -0.178672068530     -0.180924995890     -0.183206261360     -0.185516221382
+ -0.187855236879     -0.190223673313     -0.192621900744     -0.195050293885
+ -0.197509232164     -0.199999099779     -0.202520285761     -0.205073184033
+ -0.207658193473     -0.210275717977     -0.212926166518     -0.215609953215
+ -0.218327497395     -0.221079223657     -0.223865561942     -0.226686947598
+ -0.229543821448     -0.232436629857     -0.235365824807     -0.238331863963
+ -0.241335210745     -0.244376334402     -0.247455710085     -0.250573818918
+ -0.253731148078     -0.256928190869     -0.260165446797     -0.263443421651
+ -0.266762627580     -0.270123583174     -0.273526813545     -0.276972850406
+ -0.280462232160     -0.283995503979     -0.287573217889     -0.291195932861
+ -0.294864214892     -0.298578637098     -0.302339779802     -0.306148230621
+ -0.310004584565     -0.313909444124     -0.317863419364     -0.321867128021
+ -0.325921195598     -0.330026255465     -0.334182948954     -0.338391925459
+ -0.342653842543     -0.346969366031     -0.351339170123     -0.355763937495
+ -0.360244359402     -0.364781135794     -0.369374975417     -0.374026595929
+ -0.378736724008     -0.383506095467     -0.388335455369     -0.393225558142
+ -0.398177167698     -0.403191057549     -0.408268010931     -0.413408820922
+ -0.418614290569     -0.423885233013     -0.429222471610     -0.434626840065
+ -0.440099182562     -0.445640353889     -0.451251219576     -0.456932656029
+ -0.462685550665     -0.468510802050     -0.474409320038     -0.480382025914
+ -0.486429852535     -0.492553744476     -0.498754658176     -0.505033562086
+ -0.511391436820     -0.517829275305     -0.524348082937     -0.530948877737
+ -0.537632690504     -0.544400564979     -0.551253558007     -0.558192739695
+ -0.565219193581     -0.572334016803     -0.579538320264     -0.586833228805
+ -0.594219881379     -0.601699431225     -0.609273046049     -0.616941908196
+ -0.624707214841     -0.632570178166     -0.640532025548     -0.648593999747
+ -0.656757359098     -0.665023377701     -0.673393345615     -0.681868569060
+ -0.690450370611     -0.699140089399     -0.707939081321     -0.716848719238
+ -0.725870393191     -0.735005510604     -0.744255496504     -0.753621793729
+ -0.763105863154     -0.772709183904     -0.782433253578     -0.792279588476
+ -0.802249723824     -0.812345214004     -0.822567632785     -0.832918573557
+ -0.843399649569     -0.854012494166     -0.864758761032     -0.875640124430
+ -0.886658279454     -0.897814942268     -0.909111850366     -0.920550762817
+ -0.932133460524     -0.943861746479     -0.955737446025     -0.967762407114
+ -0.979938500571     -0.992267620361      -1.00475168386      -1.01739263211
+  -1.03019243010      -1.04315306707      -1.05627655670      -1.06956493750
+  -1.08302027299      -1.09664465204      -1.11044018912      -1.12440902461
+  -1.13855332503      -1.15287528341      -1.16737711949      -1.18206108007
+  -1.19692943924      -1.21198449873      -1.22722858815      -1.24266406530
+  -1.25829331644      -1.27411875660      -1.29014282986      -1.30636800963
+  -1.32279679893      -1.33943173070      -1.35627536806      -1.37333030460
+  -1.39059916465      -1.40808460358      -1.42578930804      -1.44371599628
+  -1.46186741835      -1.48024635644      -1.49885562507      -1.51769807140
+  -1.53677657545      -1.55609405036      -1.57565344261      -1.59545773228
+  -1.61550993325      -1.63581309343      -1.65637029498      -1.67718465448
+  -1.69825932318      -1.71959748710      -1.74120236729      -1.76307721992
+  -1.78522533649      -1.80765004392      -1.83035470469      -1.85334271698
+  -1.87661751471      -1.90018256769      -1.92404138164      -1.94819749824
+  -1.97265449519      -1.99741598623      -2.02248562110      -2.04786708555
+  -2.07356410131      -2.09958042598      -2.12591985303      -2.15258621160
+  -2.17958336646      -2.20691521784      -2.23458570122      -2.26259878720
+  -2.29095848125      -2.31966882346      -2.34873388830      -2.37815778434
+  -2.40794465388      -2.43809867266      -2.46862404949      -2.49952502581
+  -2.53080587534      -2.56247090355      -2.59452444727      -2.62697087410
+  -2.65981458194      -2.69305999841      -2.72671158023      -2.76077381262
+  -2.79525120864      -2.83014830849      -2.86546967880      -2.90121991183
+  -2.93740362469      -2.97402545851      -3.01109007750      -3.04860216806
+  -3.08656643777      -3.12498761433      -3.16387044446      -3.20321969276
+  -3.24304014042      -3.28333658389      -3.32411383354      -3.36537671210
+  -3.40713005304      -3.44937869894      -3.49212749958      -3.53538131000
+  -3.57914498840      -3.62342339388      -3.66822138401      -3.71354381220
+  -3.75939552493      -3.80578135872      -3.85270613688      -3.90017466604
+  -3.94819173242      -3.99676209779      -4.04589049516      -4.09558162414
+  -4.14584014603      -4.19667067844      -4.24807778960      -4.30006599230
+  -4.35263973735      -4.40580340665      -4.45956130569      -4.51391765573
+  -4.56887658526      -4.62444212111      -4.68061817881      -4.73740855248
+  -4.79481690402      -4.85284675169      -4.91150145793      -4.97078421653
+  -5.03069803900      -5.09124574017      -5.15242992294      -5.21425296221
+  -5.27671698783      -5.33982386675      -5.40357518400      -5.46797222287
+  -5.53301594381      -5.59870696238      -5.66504552600      -5.73203148950
+  -5.79966428938      -5.86794291691      -5.93686588977      -6.00643122237
+  -6.07663639469      -6.14747831972      -6.21895330931      -6.29105703845
+  -6.36378450793      -6.43713000538      -6.51108706455      -6.58564842284
+  -6.66080597707      -6.73655073744      -6.81287277953      -6.88976119457
+  -6.96720403767      -7.04518827422      -7.12369972428      -7.20272300511
+  -7.28224147173      -7.36223715559      -7.44269070132      -7.52358130175
+  -7.60488663102      -7.68658277604      -7.76864416639      -7.85104350257
+  -7.93375168299      -8.01673772969      -8.09996871297      -8.18340967522
+  -8.26702355412      -8.35077110548      -8.43461082605      -8.51849887657
+  -8.60238900561      -8.68623247434      -8.76997798297      -8.85357159924
+  -8.93695668953      -9.02007385322      -9.10286086105      -9.18525259808
+  -9.26718101220      -9.34857506895      -9.42936071361      -9.50946084163
+  -9.58879527833      -9.66728076920      -9.74483098185      -9.82135652099
+  -9.89676495780      -9.97096087509      -10.0438459298      -10.1153189341
+  -10.1852759576      -10.2536104511      -10.3202133940      -10.3849734686
+  -10.4477772601      -10.5085094870      -10.5670532619      -10.6232903850
+  -10.6771016723      -10.7283673190      -10.7769673018      -10.8227818187
+  -10.8656917698      -10.9055792795      -10.9423282602      -10.9758250192
+  -11.0059589085      -11.0326230170      -11.0557149058      -11.0751373843
+  -11.0907993265      -11.1026165253      -11.1105125824      -11.1144198296
+  -11.1142802792      -11.1100465973      -11.1016830947      -11.0891667307
+  -11.0724881193      -11.0516525337      -11.0266808965      -10.9976107476
+  -10.9644971786      -10.9274137209      -10.8864531758      -10.8417283721
+  -10.7933728364      -10.7415413613      -10.6864104537      -10.6281786478
+  -10.5670666630      -10.5033173888      -10.4371956770      -10.3689879213
+  -10.2990014024      -10.2275633787      -10.1550198978      -10.0817343090
+  -10.0080854497      -9.93446548441      -9.86127736936      -9.78893191861
+  -9.71784444631      -9.64843096016      -9.58110388297      -9.51626728154
+  -9.45431158637      -9.39560779254      -9.34050114198      -9.28930430160
+  -9.24229007175      -9.19968368631      -9.16165480196      -9.12830932092
+  -9.09968125265      -9.07572489637      -9.05630772298      -9.04120445370
+  -9.03009297775      -9.02255292657      -9.01806793129      -9.01603283730
+  -9.01576744107      -9.01653865364      -9.01759339127      -9.01820495352
+  -9.01773618666      -9.01572335878      -9.01198541603      -9.00676417061
+  -9.00090202134      -8.99565476490      -8.99130551428      -8.98781594146
+  -8.98514708408      -8.98325962943      -8.98211425541      -8.98167198995
+  -8.98189456618      -8.98274474144      -8.98418653586      -8.98618547445
+  -8.98870801023      -8.99172236248      -8.99519801766      -8.99910589733
+  -9.00341837725      -9.00810929396      -9.01315393980      -9.01852904778
+  -9.02421276730      -9.03018463195      -9.03642552066      -9.04291761317
+  -9.04964434090      -9.05659033416      -9.06374136656      -9.07108429750
+  -9.07860701321      -9.08629836729      -9.09414812099      -9.10214688389
+  -9.11028605525      -9.11855776655      -9.12695482524      -9.13547066014
+  -9.14409926867      -9.15283516582      -9.16167333533      -9.17060918279
+  -9.17963849096      -9.18875737731      -9.19796225358      -9.20724978768
+  -9.21661686764      -9.22606056768      -9.23557811639      -9.24516686695
+  -9.25482426933      -9.26454784438      -9.27433515981      -9.28418380807
+  -9.29409138589      -9.30405547552      -9.31407362773      -9.32414334626
+  -9.33426207388      -9.34442717994      -9.35463594930      -9.36488557266
+  -9.37517313822      -9.38549562463      -9.39584989514      -9.40623269300
+  -9.41664063791      -9.42707022365      -9.43751781680      -9.44797965635
+  -9.45845185443      -9.46893039788      -9.47941115083      -9.48988985801
+  -9.50036214901      -9.51082354324      -9.52126945569      -9.53169520340
+  -9.54209601255      -9.55246702623      -9.56280331282      -9.57309987483
+  -9.58335165837      -9.59355356300      -9.60370045203      -9.61378716323
+  -9.62380851987      -9.63375934200      -9.64363445807      -9.65342871670
+  -9.66313699863      -9.67275422876      -9.68227538826      -9.69169552675
+  -9.70100977438      -9.71021335384      -9.71930159232      -9.72826993319
+  -9.73711394756      -9.74582934546      -9.75441198686      -9.76285789216
+  -9.77116325238      -9.77932443890      -9.78733801268      -9.79520073293
+  -9.80290956527      -9.81046168924      -9.81785450517      -9.82508564038
+  -9.83215295476      -9.83905454541      -9.84578875082      -9.85235415398
+  -9.85874958499      -9.86497412263      -9.87102709518      -9.87690808058
+  -9.88261690553      -9.88815364399      -9.89351861476      -9.89871237828
+  -9.90373573265      -9.90858970890      -9.91327556554      -9.91779478234
+  -9.92214905349      -9.92634028006      -9.93037056193      -9.93424218905
+  -9.93795763226      -9.94151953360      -9.94493069616      -9.94819407361
+  -9.95131275937      -9.95428997548      -9.95712906130      -9.95983346204
+  -9.96240671711      -9.96485244853      -9.96717434922      -9.96937617145
+  -9.97146171528      -9.97343481730      -9.97529933941      -9.97705915797
+  -9.97871815326      -9.98028019908      -9.98174915300      -9.98312884684
+  -9.98442307762      -9.98563559901      -9.98677011323      -9.98783026355
+  -9.98881962723      -9.98974170902      -9.99059993529      -9.99139764864
+  -9.99213810312      -9.99282445999      -9.99345978406      -9.99404704059
+  -9.99458909270      -9.99508869935      -9.99554851378      -9.99597108255
+  -9.99635884490      -9.99671413273      -9.99703917088      -9.99733607787
+  -9.99760686705      -9.99785344799      -9.99807762835      -9.99828111587
+  -9.99846552076      -9.99892920135      -9.99911267107      -9.99922505159
+  -9.99931458410      -9.99939263628      -9.99987573327      -9.99997508235
+  -9.99999510452      -9.99999905787      -9.99999982244      -9.99999996724
+  -9.99999999408      -9.99999999895      -9.99999999982      -9.99999999997
+  -9.99999999999     -10.00000000000      -10.0000000000      -10.0000000000
+  -10.0000000000
+  3
+ -0.109199404405E-04 -0.219772368227E-04 -0.331736168716E-04 -0.445108300443E-04
+ -0.559906478036E-04 -0.676148638942E-04 -0.793852946236E-04 -0.913037791456E-04
+ -0.103372179748E-03 -0.115592382142E-03 -0.127966295759E-03 -0.140495854050E-03
+ -0.153183014782E-03 -0.166029760351E-03 -0.179038098086E-03 -0.192210060568E-03
+ -0.205547705941E-03 -0.219053118240E-03 -0.232728407713E-03 -0.246575711152E-03
+ -0.260597192226E-03 -0.274795041821E-03 -0.289171478378E-03 -0.303728748246E-03
+ -0.318469126028E-03 -0.333394914938E-03 -0.348508447160E-03 -0.363812084214E-03
+ -0.379308217326E-03 -0.394999267797E-03 -0.410887687386E-03 -0.426975958691E-03
+ -0.443266595537E-03 -0.459762143369E-03 -0.476465179650E-03 -0.493378314263E-03
+ -0.510504189921E-03 -0.527845482576E-03 -0.545404901840E-03 -0.563185191408E-03
+ -0.581189129487E-03 -0.599419529228E-03 -0.617879239170E-03 -0.636571143678E-03
+ -0.655498163401E-03 -0.674663255725E-03 -0.694069415234E-03 -0.713719674180E-03
+ -0.733617102955E-03 -0.753764810575E-03 -0.774165945158E-03 -0.794823694424E-03
+ -0.815741286188E-03 -0.836921988866E-03 -0.858369111987E-03 -0.880086006706E-03
+ -0.902076066333E-03 -0.924342726860E-03 -0.946889467497E-03 -0.969719811218E-03
+ -0.992837325312E-03 -0.101624562194E-02 -0.103994835869E-02 -0.106394923916E-02
+ -0.108825201355E-02 -0.111286047920E-02 -0.113777848125E-02 -0.116300991318E-02
+ -0.118855871746E-02 -0.121442888613E-02 -0.124062446146E-02 -0.126714953657E-02
+ -0.129400825605E-02 -0.132120481663E-02 -0.134874346783E-02 -0.137662851263E-02
+ -0.140486430810E-02 -0.143345526616E-02 -0.146240585420E-02 -0.149172059581E-02
+ -0.152140407148E-02 -0.155146091930E-02 -0.158189583574E-02 -0.161271357629E-02
+ -0.164391895629E-02 -0.167551685166E-02 -0.170751219963E-02 -0.173990999952E-02
+ -0.177271531358E-02 -0.180593326768E-02 -0.183956905222E-02 -0.187362792283E-02
+ -0.190811520131E-02 -0.194303627634E-02 -0.197839660442E-02 -0.201420171068E-02
+ -0.205045718973E-02 -0.208716870656E-02 -0.212434199743E-02 -0.216198287074E-02
+ -0.220009720795E-02 -0.223869096451E-02 -0.227777017076E-02 -0.231734093291E-02
+ -0.235740943397E-02 -0.239798193474E-02 -0.243906477474E-02 -0.248066437325E-02
+ -0.252278723029E-02 -0.256543992766E-02 -0.260862912990E-02 -0.265236158544E-02
+ -0.269664412755E-02 -0.274148367546E-02 -0.278688723546E-02 -0.283286190194E-02
+ -0.287941485853E-02 -0.292655337923E-02 -0.297428482953E-02 -0.302261666756E-02
+ -0.307155644528E-02 -0.312111180961E-02 -0.317129050370E-02 -0.322210036805E-02
+ -0.327354934183E-02 -0.332564546402E-02 -0.337839687477E-02 -0.343181181658E-02
+ -0.348589863564E-02 -0.354066578314E-02 -0.359612181655E-02 -0.365227540099E-02
+ -0.370913531056E-02 -0.376671042976E-02 -0.382500975480E-02 -0.388404239507E-02
+ -0.394381757455E-02 -0.400434463323E-02 -0.406563302858E-02 -0.412769233704E-02
+ -0.419053225551E-02 -0.425416260284E-02 -0.431859332141E-02 -0.438383447866E-02
+ -0.444989626864E-02 -0.451678901364E-02 -0.458452316579E-02 -0.465310930870E-02
+ -0.472255815908E-02 -0.479288056845E-02 -0.486408752485E-02 -0.493619015449E-02
+ -0.500919972356E-02 -0.508312763997E-02 -0.515798545508E-02 -0.523378486559E-02
+ -0.531053771532E-02 -0.538825599704E-02 -0.546695185441E-02 -0.554663758380E-02
+ -0.562732563628E-02 -0.570902861951E-02 -0.579175929976E-02 -0.587553060386E-02
+ -0.596035562124E-02 -0.604624760600E-02 -0.613321997892E-02 -0.622128632962E-02
+ -0.631046041864E-02 -0.640075617962E-02 -0.649218772145E-02 -0.658476933050E-02
+ -0.667851547283E-02 -0.677344079647E-02 -0.686956013368E-02 -0.696688850333E-02
+ -0.706544111315E-02 -0.716523336219E-02 -0.726628084320E-02 -0.736859934506E-02
+ -0.747220485522E-02 -0.757711356228E-02 -0.768334185842E-02 -0.779090634203E-02
+ -0.789982382028E-02 -0.801011131176E-02 -0.812178604910E-02 -0.823486548170E-02
+ -0.834936727847E-02 -0.846530933054E-02 -0.858270975409E-02 -0.870158689317E-02
+ -0.882195932258E-02 -0.894384585076E-02 -0.906726552272E-02 -0.919223762304E-02
+ -0.931878167886E-02 -0.944691746296E-02 -0.957666499680E-02 -0.970804455370E-02
+ -0.984107666199E-02 -0.997578210820E-02 -0.101121819403E-01 -0.102502974711E-01
+ -0.103901502815E-01 -0.105317622236E-01 -0.106751554246E-01 -0.108203522901E-01
+ -0.109673755073E-01 -0.111162480489E-01 -0.112669931765E-01 -0.114196344445E-01
+ -0.115741957032E-01 -0.117307011032E-01 -0.118891750988E-01 -0.120496424518E-01
+ -0.122121282357E-01 -0.123766578391E-01 -0.125432569702E-01 -0.127119516603E-01
+ -0.128827682684E-01 -0.130557334849E-01 -0.132308743361E-01 -0.134082181879E-01
+ -0.135877927507E-01 -0.137696260835E-01 -0.139537465980E-01 -0.141401830635E-01
+ -0.143289646110E-01 -0.145201207380E-01 -0.147136813131E-01 -0.149096765805E-01
+ -0.151081371649E-01 -0.153090940761E-01 -0.155125787140E-01 -0.157186228736E-01
+ -0.159272587496E-01 -0.161385189419E-01 -0.163524364602E-01 -0.165690447297E-01
+ -0.167883775957E-01 -0.170104693296E-01 -0.172353546336E-01 -0.174630686464E-01
+ -0.176936469488E-01 -0.179271255693E-01 -0.181635409892E-01 -0.184029301490E-01
+ -0.186453304537E-01 -0.188907797789E-01 -0.191393164765E-01 -0.193909793809E-01
+ -0.196458078148E-01 -0.199038415959E-01 -0.201651210423E-01 -0.204296869795E-01
+ -0.206975807465E-01 -0.209688442022E-01 -0.212435197322E-01 -0.215216502549E-01
+ -0.218032792289E-01 -0.220884506592E-01 -0.223772091045E-01 -0.226695996838E-01
+ -0.229656680838E-01 -0.232654605658E-01 -0.235690239729E-01 -0.238764057376E-01
+ -0.241876538889E-01 -0.245028170598E-01 -0.248219444954E-01 -0.251450860599E-01
+ -0.254722922448E-01 -0.258036141767E-01 -0.261391036255E-01 -0.264788130120E-01
+ -0.268227954164E-01 -0.271711045867E-01 -0.275237949469E-01 -0.278809216057E-01
+ -0.282425403647E-01 -0.286087077277E-01 -0.289794809090E-01 -0.293549178426E-01
+ -0.297350771914E-01 -0.301200183561E-01 -0.305098014844E-01 -0.309044874807E-01
+ -0.313041380156E-01 -0.317088155352E-01 -0.321185832713E-01 -0.325335052508E-01
+ -0.329536463061E-01 -0.333790720852E-01 -0.338098490617E-01 -0.342460445453E-01
+ -0.346877266925E-01 -0.351349645170E-01 -0.355878279005E-01 -0.360463876040E-01
+ -0.365107152783E-01 -0.369808834755E-01 -0.374569656603E-01 -0.379390362216E-01
+ -0.384271704838E-01 -0.389214447190E-01 -0.394219361583E-01 -0.399287230047E-01
+ -0.404418844446E-01 -0.409615006605E-01 -0.414876528435E-01 -0.420204232058E-01
+ -0.425598949940E-01 -0.431061525016E-01 -0.436592810824E-01 -0.442193671639E-01
+ -0.447864982606E-01 -0.453607629879E-01 -0.459422510758E-01 -0.465310533831E-01
+ -0.471272619111E-01 -0.477309698187E-01 -0.483422714365E-01 -0.489612622815E-01
+ -0.495880390724E-01 -0.502226997442E-01 -0.508653434638E-01 -0.515160706458E-01
+ -0.521749829675E-01 -0.528421833852E-01 -0.535177761504E-01 -0.542018668257E-01
+ -0.548945623017E-01 -0.555959708134E-01 -0.563062019573E-01 -0.570253667084E-01
+ -0.577535774376E-01 -0.584909479293E-01 -0.592375933990E-01 -0.599936305117E-01
+ -0.607591773996E-01 -0.615343536808E-01 -0.623192804783E-01 -0.631140804384E-01
+ -0.639188777501E-01 -0.647337981646E-01 -0.655589690147E-01 -0.663945192352E-01
+ -0.672405793822E-01 -0.680972816544E-01 -0.689647599132E-01 -0.698431497037E-01
+ -0.707325882761E-01 -0.716332146068E-01 -0.725451694205E-01 -0.734685952119E-01
+ -0.744036362680E-01 -0.753504386908E-01 -0.763091504201E-01 -0.772799212564E-01
+ -0.782629028845E-01 -0.792582488971E-01 -0.802661148191E-01 -0.812866581313E-01
+ -0.823200382957E-01 -0.833664167799E-01 -0.844259570824E-01 -0.854988247585E-01
+ -0.865851874459E-01 -0.876852148907E-01 -0.887990789743E-01 -0.899269537401E-01
+ -0.910690154207E-01 -0.922254424652E-01 -0.933964155678E-01 -0.945821176950E-01
+ -0.957827341151E-01 -0.969984524266E-01 -0.982294625878E-01 -0.994759569463E-01
+ -0.100738130269     -0.102016179773     -0.103310305156     -0.104620708628
+ -0.105947594941     -0.107291171423     -0.108651648011     -0.110029237283
+ -0.111424154488     -0.112836617585     -0.114266847274     -0.115715067032
+ -0.117181503144     -0.118666384744     -0.120169943848     -0.121692415389
+ -0.123234037256     -0.124795050331     -0.126375698524     -0.127976228815
+ -0.129596891288     -0.131237939176     -0.132899628894     -0.134582220086
+ -0.136285975658     -0.138011161825     -0.139758048150     -0.141526907588
+ -0.143318016525     -0.145131654826     -0.146968105874     -0.148827656618
+ -0.150710597615     -0.152617223078     -0.154547830921     -0.156502722804
+ -0.158482204182     -0.160486584352     -0.162516176501     -0.164571297757
+ -0.166652269235     -0.168759416090     -0.170893067567     -0.173053557053
+ -0.175241222126     -0.177456404614     -0.179699450640     -0.181970710685
+ -0.184270539636     -0.186599296844     -0.188957346182     -0.191345056096
+ -0.193762799671     -0.196210954682     -0.198689903656     -0.201200033932
+ -0.203741737721     -0.206315412168     -0.208921459412     -0.211560286652
+ -0.214232306206     -0.216937935582     -0.219677597537     -0.222451720146
+ -0.225260736868     -0.228105086616     -0.230985213822     -0.233901568508
+ -0.236854606358     -0.239844788787     -0.242872583013     -0.245938462132
+ -0.249042905191     -0.252186397259     -0.255369429512     -0.258592499299
+ -0.261856110227     -0.265160772239     -0.268507001689     -0.271895321427
+ -0.275326260880     -0.278800356135     -0.282318150019     -0.285880192190
+ -0.289487039218     -0.293139254673     -0.296837409216     -0.300582080683
+ -0.304373854179     -0.308213322171     -0.312101084573     -0.316037748850
+ -0.320023930104     -0.324060251176     -0.328147342739     -0.332285843400
+ -0.336476399799     -0.340719666707     -0.345016307133     -0.349366992425
+ -0.353772402373     -0.358233225319     -0.362750158263     -0.367323906972
+ -0.371955186088     -0.376644719244     -0.381393239173     -0.386201487824
+ -0.391070216480     -0.396000185871     -0.400992166297     -0.406046937745
+ -0.411165290014     -0.416348022834     -0.421595945997     -0.426909879479
+ -0.432290653566     -0.437739108992     -0.443256097062     -0.448842479789
+ -0.454499130027     -0.460226931609     -0.466026779483     -0.471899579856
+ -0.477846250328     -0.483867720042     -0.489964929827     -0.496138832344
+ -0.502390392237     -0.508720586279     -0.515130403531     -0.521620845490
+ -0.528192926252     -0.534847672663     -0.541586124486     -0.548409334559
+ -0.555318368960     -0.562314307177     -0.569398242271     -0.576571281050
+ -0.583834544242     -0.591189166669     -0.598636297422     -0.606177100045
+ -0.613812752714     -0.621544448419     -0.629373395154     -0.637300816102
+ -0.645327949829     -0.653456050475     -0.661686387950     -0.670020248132
+ -0.678458933071     -0.687003761185     -0.695656067472     -0.704417203716
+ -0.713288538697     -0.722271458405     -0.731367366257     -0.740577683314
+ -0.749903848504     -0.759347318847     -0.768909569679     -0.778592094883
+ -0.788396407125     -0.798324038086     -0.808376538701     -0.818555479401
+ -0.828862450359     -0.839299061736     -0.849866943930     -0.860567747835
+ -0.871403145091     -0.882374828351     -0.893484511537     -0.904733930114
+ -0.916124841355     -0.927659024613     -0.939338281604     -0.951164436679
+ -0.963139337114     -0.975264853391     -0.987542879495     -0.999975333199
+  -1.01256415637      -1.02531131527      -1.03821880085      -1.05128862908
+  -1.06452284122      -1.07792350419      -1.09149271085      -1.10523258035
+  -1.11914525842      -1.13323291776      -1.14749775831      -1.16194200764
+  -1.17656792127      -1.19137778301      -1.20637390535      -1.22155862978
+  -1.23693432715      -1.25250339806      -1.26826827320      -1.28423141375
+  -1.30039531174      -1.31676249044      -1.33333550473      -1.35011694152
+  -1.36710942012      -1.38431559265      -1.40173814444      -1.41937979445
+  -1.43724329567      -1.45533143552      -1.47364703634      -1.49219295574
+  -1.51097208707      -1.52998735985      -1.54924174022      -1.56873823138
+  -1.58847987402      -1.60846974681      -1.62871096684      -1.64920669009
+  -1.66996011189      -1.69097446742      -1.71225303215      -1.73379912235
+  -1.75561609559      -1.77770735120      -1.80007633077      -1.82272651869
+  -1.84566144261      -1.86888467398      -1.89239982856      -1.91621056692
+  -1.94032059498      -1.96473366454      -1.98945357381      -2.01448416794
+  -2.03982933954      -2.06549302926      -2.09147922632      -2.11779196904
+  -2.14443534542      -2.17141349368      -2.19873060283      -2.22639091320
+  -2.25439871705      -2.28275835908      -2.31147423704      -2.34055080228
+  -2.36999256031      -2.39980407139      -2.42998995107      -2.46055487080
+  -2.49150355845      -2.52284079890      -2.55457143463      -2.58670036625
+  -2.61923255307      -2.65217301366      -2.68552682640      -2.71929913004
+  -2.75349512425      -2.78812007012      -2.82317929073      -2.85867817167
+  -2.89462216153      -2.93101677242      -2.96786758049      -3.00518022637
+  -3.04296041564      -3.08121391934      -3.11994657434      -3.15916428381
+  -3.19887301762      -3.23907881271      -3.27978777344      -3.32100607197
+  -3.36273994857      -3.40499571185      -3.44777973909      -3.49109847646
+  -3.53495843916      -3.57936621164      -3.62432844771      -3.66985187059
+  -3.71594327299      -3.76260951708      -3.80985753445      -3.85769432598
+  -3.90612696171      -3.95516258060      -4.00480839023      -4.05507166650
+  -4.10595975317      -4.15748006141      -4.20964006917      -4.26244732060
+  -4.31590942526      -4.37003405734      -4.42482895466      -4.48030191774
+  -4.53646080858      -4.59331354946      -4.65086812153      -4.70913256336
+  -4.76811496929      -4.82782348764      -4.88826631882      -4.94945171325
+  -5.01138796910      -5.07408342989      -5.13754648189      -5.20178555134
+  -5.26680910143      -5.33262562908      -5.39924366152      -5.46667175262
+  -5.53491847888      -5.60399243532      -5.67390223088      -5.74465648369
+  -5.81626381593      -5.88873284835      -5.96207219447      -6.03629045437
+  -6.11139620807      -6.18739800850      -6.26430437400      -6.34212378034
+  -6.42086465220      -6.50053535418      -6.58114418111      -6.66269934786
+  -6.74520897845      -6.82868109443      -6.91312360261      -6.99854428192
+  -7.08495076953      -7.17235054602      -7.26075091968      -7.35015900982
+  -7.44058172902      -7.53202576430      -7.62449755715      -7.71800328231
+  -7.81254882532      -7.90813975863      -8.00478131634      -8.10247836745
+  -8.20123538748      -8.30105642847      -8.40194508722      -8.50390447172
+  -8.60693716564      -8.71104519083      -8.81622996771      -8.92249227350
+  -9.02983219809      -9.13824909759      -9.24774154536      -9.35830728041
+  -9.46994315311      -9.58264506817      -9.69640792452      -9.81122555235
+  -9.92709064692      -10.0439946991      -10.1619279225      -10.2808791773
+  -10.4008358906      -10.5217839724      -10.6437077287      -10.7665897700
+  -10.8904109167      -11.0151500990      -11.1407842542      -11.2672882188
+  -11.3946346170      -11.5227937438      -11.6517334451      -11.7814189927
+  -11.9118129545      -12.0428750614      -12.1745620692      -12.3068276161
+  -12.4396220767      -12.5728924114      -12.7065820122      -12.8406305448
+  -12.9749737875      -13.1095434665      -13.2442670892      -13.3790677741
+  -13.5138640802      -13.6485698335      -13.7830939543      -13.9173402831
+  -14.0512074082      -14.1845884942      -14.3173711136      -14.4494370816
+  -14.5806622956      -14.7109165814      -14.8400635457      -14.9679604391
+  -15.0944580279      -15.2194004804      -15.3426252657      -15.4639630703
+  -15.5832377330      -15.7002662007      -15.8148585079      -15.9268177833
+  -16.0359402847      -16.1420154663      -16.2448260818      -16.3441483256
+  -16.4397520162      -16.5314008248      -16.6188525532      -16.7018594635
+  -16.7801686652      -16.8535225608      -16.9216593552      -16.9843136325
+  -17.0412170014      -17.0920988153      -17.1366869676      -17.1747087652
+  -17.2058918833      -17.2299654017      -17.2466609240      -17.2557137806
+  -17.2568643135      -17.2498592426      -17.2344531108      -17.2104098031
+  -17.1775041366      -17.1355235132      -17.0842696280      -17.0235602243
+  -16.9532308835      -16.8731368375      -16.7831547881      -16.6831847187
+  -16.5731516789      -16.4530075218      -16.3227325750      -16.1823372196
+  -16.0318633560      -15.8713857310      -15.7010131013      -15.5208892100
+  -15.3311935518      -15.1321419053      -14.9239866136      -14.7070165978
+  -14.4815570907      -14.2479690889      -14.0066485216      -13.7580251496
+  -13.5025612128      -13.2407498595      -12.9731133984      -12.7002014335
+  -12.4225889502      -12.1408744389      -11.8556781566      -11.5676406373
+  -11.2774215773      -10.9856992283      -10.6931704363      -10.4005514655
+  -10.1085797357      -9.81801659114      -9.52965118584      -9.24430553738
+  -8.96284074329      -8.68616428726      -8.41523827390      -8.15108832543
+  -7.89481274898      -7.64759144005      -7.41069382979      -7.18548501245
+  -6.97342901362      -6.77608798597      -6.59511596037      -6.43224565088
+  -6.28926673127      -6.16799399065      -6.07022386315      -5.99767804057
+  -5.95193324979      -5.93433684154      -5.94590862627      -5.98723043639
+  -6.05832621430      -6.15853703749      -6.28639739562      -6.43952121677
+  -6.61450856752      -6.80688657998      -7.01110092870      -7.22057704006
+  -7.42787313526      -7.62495021327      -7.80358730149      -7.95597402702
+  -8.07551729482      -8.15790536841      -8.20248195852      -8.21399619188
+  -8.20481248277      -8.19229033145      -8.18064360026      -8.16983531569
+  -8.15982664357      -8.15057828748      -8.14205083399      -8.13420511652
+  -8.12700257528      -8.12040558122      -8.11437767980      -8.10888383837
+  -8.10388987480      -8.09936330142      -8.09527283158      -8.09158855357
+  -8.08828195555      -8.08532593823      -8.08269481606      -8.08036430822
+  -8.07831152062      -8.07651492003      -8.07495430162      -8.07361075078
+  -8.07246660052      -8.07150538515      -8.07071179125      -8.07007160669
+  -8.06957166833      -8.06919980908      -8.06894480488      -8.06879631975
+  -8.06874485584      -8.06878170252      -8.06889888673      -8.06908912488
+  -8.06934577648      -8.06966279961      -8.07003470826      -8.07045653176
+  -8.07092377613      -8.07143238762      -8.07197871827      -8.07255949417
+  -8.07317177575      -8.07381293417      -8.07448062689      -8.07517277202
+  -8.07588752452      -8.07662325407      -8.07737852449      -8.07815207455
+  -8.07894280016      -8.07974973774      -8.08057204887      -8.08140900585
+  -8.08225997838      -8.08312442109      -8.08400186182      -8.08489189076
+  -8.08579415007      -8.08670832418      -8.08763413051      -8.08856787979
+  -8.08951609982      -8.09047864735      -8.09145540908      -8.09244629679
+  -8.09345124290      -8.09447019639      -8.09550311914      -8.09654998249
+  -8.09761076415      -8.09868544541      -8.09977400851      -8.10087643432
+  -8.10199270015      -8.10312277782      -8.10426663180      -8.10542421762
+  -8.10659548036      -8.10778035325      -8.10897875644      -8.11019059587
+  -8.11141576220      -8.11265412993      -8.11390555648      -8.11516988143
+  -8.11644692591      -8.11773649184      -8.11903836152      -8.12035229704
+  -8.12167803992      -8.12301531072      -8.12436380873      -8.12572321173
+  -8.12709317580      -8.12847333513      -8.12986330199      -8.13126266663
+  -8.13267099730      -8.13408784031      -8.13551272010      -8.13694513941
+  -8.13838457947      -8.13983050019      -8.14128234048      -8.14273951852
+  -8.14420143214      -8.14566745920      -8.14713695796      -8.14860926751
+  -8.15008370819      -8.15155958198      -8.15303617285      -8.15451274703
+  -8.15598855322      -8.15746282143      -8.15893476510      -8.16040358174
+  -8.16186845382      -8.16332854998      -8.16478303037      -8.16623105120
+  -8.16767177145      -8.16910436191      -8.17052801765      -8.17194197407
+  -8.17334552635      -8.17473805030      -8.17611902010      -8.17748801759
+  -8.17884472891      -8.18018892926      -8.18152046044      -8.18283920697
+  -8.18414507500      -8.18543797560      -8.18671778687      -8.18798439696
+  -8.18923770573      -8.19047762654      -8.19170408797      -8.19291703548
+  -8.19411643319      -8.19530226549      -8.19647453875      -8.19763328291
+  -8.19877855316      -8.19991043142      -8.20102902800      -8.20213448303
+  -8.20322696798      -8.20430668706      -8.20537387858      -8.20642881630
+  -8.20747181066      -8.20850320993      -8.20952340138      -8.21053281225
+  -8.21153191069      -8.21252120657      -8.21350125221      -8.21447264300
+  -8.21543601778      -8.21639205926      -8.21734149413      -8.21828509308
+  -8.21922367068      -8.22015808495      -8.22108923688      -8.22201806964
+  -8.22294556757      -8.22387275504      -8.22480069488      -8.22573048671
+  -8.22666326491      -8.22760019632      -8.22854247764      -8.22949133252
+  -8.23044800831      -8.23141377250      -8.23238990878      -8.23337771272
+  -8.23437848718      -8.23539353724      -8.23642416478      -8.23747166264
+  -8.23853730845      -8.23962235800      -8.24072803818      -8.24185553958
+  -8.24300600864      -8.24418053938      -8.24538016474      -8.24660584752
+  -8.24785847095      -8.24913882884      -8.25044761533      -8.25178541441
+  -8.25315268895      -8.25454976950      -8.25597684277      -8.25743393987
+  -8.25892092423      -8.26043747946      -8.26198309689      -8.26355706311
+  -8.26515844735      -8.26678608896      -8.26843858481      -8.27011427685
+  -8.27181123994      -8.27352726976      -8.27525987132      -8.27700624776
+  -8.27876328974      -8.28052756566      -8.28229531260      -8.28406242827
+  -8.28582446419      -8.28757662017      -8.28931374036      -8.29103031114
+  -8.29272046099      -8.29437796278      -8.29599623870      -8.29756836812
+  -8.29908709899      -8.30054486293      -8.30193379473      -8.30324575669
+  -8.30447236831      -8.30560504217      -8.30663502650      -8.30755345568
+  -8.30835140858      -8.30901997857      -8.30955034636      -8.30995397215
+  -8.31024227943      -8.31042676004      -8.31051907355      -8.31053115277
+  -8.31047531119      -8.31036435307      -8.31021168529      -8.31003143040
+  -8.30983854034      -8.30964890994      -8.30947948949      -8.30934839542
+  -8.30927501832      -8.30928012716      -8.30938596883      -8.30961636217
+  -8.30999678549      -8.31055445702      -8.31131840773      -8.31231954651
+  -8.31359071810      -8.31516675472      -8.31708452366      -8.31938297405
+  -8.32210318795      -8.32528844387      -8.32898430407      -8.33323874327
+  -8.33810234512      -8.34362860825      -8.34987443061      -8.35690089309
+  -8.36477457801      -8.37356993552      -8.38337409897      -8.39429934227
+  -8.40657423006      -8.41978848286      -8.43368845328      -8.44808369068
+  -8.46283130978      -8.47786149999      -8.49311580300      -8.50854793941
+  -8.52412472629      -8.53982711765      -8.55565139959      -8.57161059457
+  -8.58773615070      -8.60408002094      -8.62071727345      -8.63774942269
+  -8.65530873414      -8.67356384467      -8.69272716306      -8.71306469326
+  -8.73490918523      -8.75867791632      -8.78489702691      -8.81423534094
+  -8.84755228847      -8.88596754465      -8.93096551976      -8.98455920929
+  -9.04956163631      -9.13080224659      -9.23530951940      -9.37486930345
+  -9.57487091371
+ Up Pseudopotential follows (l on next line)
+  1
+ -0.871778478399E-06 -0.175452258014E-05 -0.264837023579E-05 -0.355346111087E-05
+ -0.446993662765E-05 -0.539793998731E-05 -0.633761619226E-05 -0.728911206881E-05
+ -0.825257629015E-05 -0.922815939950E-05 -0.102160138337E-04 -0.112162939471E-04
+ -0.122291560353E-04 -0.132547583603E-04 -0.142932611744E-04 -0.153448267459E-04
+ -0.164096193839E-04 -0.174878054645E-04 -0.185795534565E-04 -0.196850339477E-04
+ -0.208044196717E-04 -0.219378855347E-04 -0.230856086432E-04 -0.242477683313E-04
+ -0.254245461886E-04 -0.266161260892E-04 -0.278226942198E-04 -0.290444391091E-04
+ -0.302815516574E-04 -0.315342251659E-04 -0.328026553674E-04 -0.340870404568E-04
+ -0.353875811217E-04 -0.367044805744E-04 -0.380379445830E-04 -0.393881815041E-04
+ -0.407554023148E-04 -0.421398206462E-04 -0.435416528165E-04 -0.449611178649E-04
+ -0.463984375856E-04 -0.478538365627E-04 -0.493275422053E-04 -0.508197847830E-04
+ -0.523307974616E-04 -0.538608163399E-04 -0.554100804866E-04 -0.569788319773E-04
+ -0.585673159325E-04 -0.601757805562E-04 -0.618044771743E-04 -0.634536602738E-04
+ -0.651235875431E-04 -0.668145199115E-04 -0.685267215908E-04 -0.702604601160E-04
+ -0.720160063872E-04 -0.737936347121E-04 -0.755936228487E-04 -0.774162520489E-04
+ -0.792618071022E-04 -0.811305763802E-04 -0.830228518821E-04 -0.849389292796E-04
+ -0.868791079639E-04 -0.888436910917E-04 -0.908329856332E-04 -0.928473024197E-04
+ -0.948869561922E-04 -0.969522656509E-04 -0.990435535046E-04 -0.101161146521E-03
+ -0.103305375579E-03 -0.105476575718E-03 -0.107675086193E-03 -0.109901250525E-03
+ -0.112155416557E-03 -0.114437936508E-03 -0.116749167025E-03 -0.119089469243E-03
+ -0.121459208839E-03 -0.123858756090E-03 -0.126288485930E-03 -0.128748778009E-03
+ -0.131240016752E-03 -0.133762591422E-03 -0.136316896174E-03 -0.138903330125E-03
+ -0.141522297411E-03 -0.144174207249E-03 -0.146859474007E-03 -0.149578517262E-03
+ -0.152331761871E-03 -0.155119638035E-03 -0.157942581363E-03 -0.160801032947E-03
+ -0.163695439426E-03 -0.166626253057E-03 -0.169593931785E-03 -0.172598939316E-03
+ -0.175641745188E-03 -0.178722824847E-03 -0.181842659717E-03 -0.185001737279E-03
+ -0.188200551144E-03 -0.191439601135E-03 -0.194719393360E-03 -0.198040440291E-03
+ -0.201403260851E-03 -0.204808380486E-03 -0.208256331254E-03 -0.211747651903E-03
+ -0.215282887959E-03 -0.218862591812E-03 -0.222487322795E-03 -0.226157647282E-03
+ -0.229874138767E-03 -0.233637377960E-03 -0.237447952875E-03 -0.241306458923E-03
+ -0.245213499001E-03 -0.249169683594E-03 -0.253175630862E-03 -0.257231966745E-03
+ -0.261339325052E-03 -0.265498347566E-03 -0.269709684143E-03 -0.273973992814E-03
+ -0.278291939884E-03 -0.282664200043E-03 -0.287091456463E-03 -0.291574400915E-03
+ -0.296113733866E-03 -0.300710164596E-03 -0.305364411307E-03 -0.310077201236E-03
+ -0.314849270764E-03 -0.319681365537E-03 -0.324574240580E-03 -0.329528660415E-03
+ -0.334545399180E-03 -0.339625240750E-03 -0.344768978861E-03 -0.349977417233E-03
+ -0.355251369694E-03 -0.360591660311E-03 -0.365999123515E-03 -0.371474604232E-03
+ -0.377018958018E-03 -0.382633051190E-03 -0.388317760961E-03 -0.394073975578E-03
+ -0.399902594461E-03 -0.405804528345E-03 -0.411780699418E-03 -0.417832041470E-03
+ -0.423959500034E-03 -0.430164032539E-03 -0.436446608455E-03 -0.442808209448E-03
+ -0.449249829530E-03 -0.455772475219E-03 -0.462377165691E-03 -0.469064932941E-03
+ -0.475836821948E-03 -0.482693890833E-03 -0.489637211026E-03 -0.496667867436E-03
+ -0.503786958616E-03 -0.510995596940E-03 -0.518294908772E-03 -0.525686034645E-03
+ -0.533170129435E-03 -0.540748362550E-03 -0.548421918102E-03 -0.556191995101E-03
+ -0.564059807637E-03 -0.572026585072E-03 -0.580093572231E-03 -0.588262029597E-03
+ -0.596533233507E-03 -0.604908476356E-03 -0.613389066791E-03 -0.621976329921E-03
+ -0.630671607525E-03 -0.639476258257E-03 -0.648391657861E-03 -0.657419199387E-03
+ -0.666560293407E-03 -0.675816368235E-03 -0.685188870151E-03 -0.694679263629E-03
+ -0.704289031561E-03 -0.714019675494E-03 -0.723872715860E-03 -0.733849692216E-03
+ -0.743952163486E-03 -0.754181708201E-03 -0.764539924749E-03 -0.775028431622E-03
+ -0.785648867670E-03 -0.796402892359E-03 -0.807292186025E-03 -0.818318450145E-03
+ -0.829483407593E-03 -0.840788802918E-03 -0.852236402609E-03 -0.863827995379E-03
+ -0.875565392437E-03 -0.887450427775E-03 -0.899484958454E-03 -0.911670864893E-03
+ -0.924010051167E-03 -0.936504445297E-03 -0.949155999558E-03 -0.961966690781E-03
+ -0.974938520664E-03 -0.988073516079E-03 -0.100137372940E-02 -0.101484123881E-02
+ -0.102847814863E-02 -0.104228658966E-02 -0.105626871950E-02 -0.107042672288E-02
+ -0.108476281202E-02 -0.109927922696E-02 -0.111397823592E-02 -0.112886213566E-02
+ -0.114393325181E-02 -0.115919393926E-02 -0.117464658253E-02 -0.119029359612E-02
+ -0.120613742492E-02 -0.122218054455E-02 -0.123842546178E-02 -0.125487471492E-02
+ -0.127153087419E-02 -0.128839654215E-02 -0.130547435410E-02 -0.132276697848E-02
+ -0.134027711729E-02 -0.135800750654E-02 -0.137596091663E-02 -0.139414015282E-02
+ -0.141254805566E-02 -0.143118750140E-02 -0.145006140251E-02 -0.146917270807E-02
+ -0.148852440426E-02 -0.150811951483E-02 -0.152796110154E-02 -0.154805226469E-02
+ -0.156839614356E-02 -0.158899591693E-02 -0.160985480355E-02 -0.163097606266E-02
+ -0.165236299451E-02 -0.167401894084E-02 -0.169594728544E-02 -0.171815145467E-02
+ -0.174063491796E-02 -0.176340118840E-02 -0.178645382327E-02 -0.180979642460E-02
+ -0.183343263970E-02 -0.185736616179E-02 -0.188160073053E-02 -0.190614013262E-02
+ -0.193098820238E-02 -0.195614882239E-02 -0.198162592404E-02 -0.200742348817E-02
+ -0.203354554572E-02 -0.205999617830E-02 -0.208677951888E-02 -0.211389975241E-02
+ -0.214136111649E-02 -0.216916790200E-02 -0.219732445382E-02 -0.222583517146E-02
+ -0.225470450978E-02 -0.228393697967E-02 -0.231353714877E-02 -0.234350964216E-02
+ -0.237385914311E-02 -0.240459039378E-02 -0.243570819600E-02 -0.246721741199E-02
+ -0.249912296513E-02 -0.253142984072E-02 -0.256414308678E-02 -0.259726781481E-02
+ -0.263080920064E-02 -0.266477248516E-02 -0.269916297521E-02 -0.273398604437E-02
+ -0.276924713382E-02 -0.280495175318E-02 -0.284110548136E-02 -0.287771396745E-02
+ -0.291478293162E-02 -0.295231816595E-02 -0.299032553541E-02 -0.302881097873E-02
+ -0.306778050933E-02 -0.310724021628E-02 -0.314719626525E-02 -0.318765489943E-02
+ -0.322862244059E-02 -0.327010528998E-02 -0.331210992938E-02 -0.335464292210E-02
+ -0.339771091401E-02 -0.344132063457E-02 -0.348547889789E-02 -0.353019260378E-02
+ -0.357546873885E-02 -0.362131437760E-02 -0.366773668349E-02 -0.371474291010E-02
+ -0.376234040226E-02 -0.381053659716E-02 -0.385933902557E-02 -0.390875531296E-02
+ -0.395879318073E-02 -0.400946044739E-02 -0.406076502980E-02 -0.411271494442E-02
+ -0.416531830853E-02 -0.421858334150E-02 -0.427251836611E-02 -0.432713180981E-02
+ -0.438243220606E-02 -0.443842819567E-02 -0.449512852813E-02 -0.455254206296E-02
+ -0.461067777116E-02 -0.466954473655E-02 -0.472915215721E-02 -0.478950934692E-02
+ -0.485062573662E-02 -0.491251087586E-02 -0.497517443433E-02 -0.503862620333E-02
+ -0.510287609733E-02 -0.516793415551E-02 -0.523381054333E-02 -0.530051555409E-02
+ -0.536805961060E-02 -0.543645326675E-02 -0.550570720919E-02 -0.557583225899E-02
+ -0.564683937332E-02 -0.571873964721E-02 -0.579154431520E-02 -0.586526475318E-02
+ -0.593991248012E-02 -0.601549915987E-02 -0.609203660301E-02 -0.616953676867E-02
+ -0.624801176640E-02 -0.632747385809E-02 -0.640793545985E-02 -0.648940914397E-02
+ -0.657190764087E-02 -0.665544384112E-02 -0.674003079741E-02 -0.682568172663E-02
+ -0.691241001192E-02 -0.700022920473E-02 -0.708915302701E-02 -0.717919537327E-02
+ -0.727037031281E-02 -0.736269209192E-02 -0.745617513605E-02 -0.755083405211E-02
+ -0.764668363076E-02 -0.774373884869E-02 -0.784201487097E-02 -0.794152705344E-02
+ -0.804229094506E-02 -0.814432229041E-02 -0.824763703209E-02 -0.835225131323E-02
+ -0.845818148004E-02 -0.856544408431E-02 -0.867405588604E-02 -0.878403385606E-02
+ -0.889539517864E-02 -0.900815725421E-02 -0.912233770208E-02 -0.923795436317E-02
+ -0.935502530282E-02 -0.947356881361E-02 -0.959360341819E-02 -0.971514787223E-02
+ -0.983822116727E-02 -0.996284253379E-02 -0.100890314441E-01 -0.102168076155E-01
+ -0.103461910133E-01 -0.104772018539E-01 -0.106098606079E-01 -0.107441880037E-01
+ -0.108802050301E-01 -0.110179329400E-01 -0.111573932538E-01 -0.112986077623E-01
+ -0.114415985307E-01 -0.115863879015E-01 -0.117329984983E-01 -0.118814532295E-01
+ -0.120317752912E-01 -0.121839881717E-01 -0.123381156545E-01 -0.124941818224E-01
+ -0.126522110609E-01 -0.128122280625E-01 -0.129742578302E-01 -0.131383256815E-01
+ -0.133044572522E-01 -0.134726785008E-01 -0.136430157121E-01 -0.138154955018E-01
+ -0.139901448201E-01 -0.141669909563E-01 -0.143460615430E-01 -0.145273845604E-01
+ -0.147109883404E-01 -0.148969015717E-01 -0.150851533034E-01 -0.152757729503E-01
+ -0.154687902972E-01 -0.156642355033E-01 -0.158621391073E-01 -0.160625320322E-01
+ -0.162654455896E-01 -0.164709114853E-01 -0.166789618236E-01 -0.168896291129E-01
+ -0.171029462703E-01 -0.173189466272E-01 -0.175376639338E-01 -0.177591323654E-01
+ -0.179833865267E-01 -0.182104614579E-01 -0.184403926399E-01 -0.186732159999E-01
+ -0.189089679170E-01 -0.191476852280E-01 -0.193894052328E-01 -0.196341657007E-01
+ -0.198820048759E-01 -0.201329614839E-01 -0.203870747371E-01 -0.206443843412E-01
+ -0.209049305012E-01 -0.211687539281E-01 -0.214358958447E-01 -0.217063979925E-01
+ -0.219803026380E-01 -0.222576525792E-01 -0.225384911527E-01 -0.228228622399E-01
+ -0.231108102745E-01 -0.234023802487E-01 -0.236976177210E-01 -0.239965688228E-01
+ -0.242992802656E-01 -0.246057993489E-01 -0.249161739666E-01 -0.252304526154E-01
+ -0.255486844018E-01 -0.258709190503E-01 -0.261972069104E-01 -0.265275989653E-01
+ -0.268621468393E-01 -0.272009028061E-01 -0.275439197968E-01 -0.278912514084E-01
+ -0.282429519121E-01 -0.285990762618E-01 -0.289596801022E-01 -0.293248197785E-01
+ -0.296945523443E-01 -0.300689355708E-01 -0.304480279560E-01 -0.308318887337E-01
+ -0.312205778827E-01 -0.316141561362E-01 -0.320126849915E-01 -0.324162267191E-01
+ -0.328248443730E-01 -0.332386018004E-01 -0.336575636512E-01 -0.340817953889E-01
+ -0.345113633002E-01 -0.349463345055E-01 -0.353867769697E-01 -0.358327595122E-01
+ -0.362843518184E-01 -0.367416244500E-01 -0.372046488563E-01 -0.376734973852E-01
+ -0.381482432947E-01 -0.386289607642E-01 -0.391157249062E-01 -0.396086117778E-01
+ -0.401076983929E-01 -0.406130627340E-01 -0.411247837645E-01 -0.416429414409E-01
+ -0.421676167255E-01 -0.426988915989E-01 -0.432368490728E-01 -0.437815732030E-01
+ -0.443331491025E-01 -0.448916629550E-01 -0.454572020279E-01 -0.460298546865E-01
+ -0.466097104073E-01 -0.471968597923E-01 -0.477913945831E-01 -0.483934076750E-01
+ -0.490029931318E-01 -0.496202462003E-01 -0.502452633255E-01 -0.508781421649E-01
+ -0.515189816047E-01 -0.521678817747E-01 -0.528249440639E-01 -0.534902711364E-01
+ -0.541639669478E-01 -0.548461367609E-01 -0.555368871624E-01 -0.562363260795E-01
+ -0.569445627966E-01 -0.576617079728E-01 -0.583878736586E-01 -0.591231733138E-01
+ -0.598677218250E-01 -0.606216355238E-01 -0.613850322044E-01 -0.621580311427E-01
+ -0.629407531144E-01 -0.637333204138E-01 -0.645358568735E-01 -0.653484878829E-01
+ -0.661713404084E-01 -0.670045430127E-01 -0.678482258755E-01 -0.687025208130E-01
+ -0.695675612991E-01 -0.704434824860E-01 -0.713304212250E-01 -0.722285160883E-01
+ -0.731379073904E-01 -0.740587372097E-01 -0.749911494112E-01 -0.759352896682E-01
+ -0.768913054858E-01 -0.778593462232E-01 -0.788395631173E-01 -0.798321093062E-01
+ -0.808371398528E-01 -0.818548117695E-01 -0.828852840420E-01 -0.839287176543E-01
+ -0.849852756139E-01 -0.860551229769E-01 -0.871384268739E-01 -0.882353565355E-01
+ -0.893460833192E-01 -0.904707807358E-01 -0.916096244761E-01 -0.927627924384E-01
+ -0.939304647561E-01 -0.951128238258E-01 -0.963100543350E-01 -0.975223432916E-01
+ -0.987498800522E-01 -0.999928563515E-01 -0.101251466332     -0.102525906575
+ -0.103816376130     -0.105123076544     -0.106446211897     -0.107785988828
+ -0.109142616572     -0.110516306989     -0.111907274598     -0.113315736608
+ -0.114741912955     -0.116186026334     -0.117648302232     -0.119128968964
+ -0.120628257709     -0.122146402541     -0.123683640472     -0.125240211482
+ -0.126816358557     -0.128412327731     -0.130028368114     -0.131664731940
+ -0.133321674598     -0.134999454675     -0.136698333993     -0.138418577649
+ -0.140160454055     -0.141924234981     -0.143710195590     -0.145518614487
+ -0.147349773754     -0.149203958996     -0.151081459381     -0.152982567688
+ -0.154907580345     -0.156856797473     -0.158830522935     -0.160829064378
+ -0.162852733278     -0.164901844984     -0.166976718767     -0.169077677865
+ -0.171205049530     -0.173359165076     -0.175540359922     -0.177748973648
+ -0.179985350035     -0.182249837120     -0.184542787240     -0.186864557086
+ -0.189215507747     -0.191596004766     -0.194006418185     -0.196447122599
+ -0.198918497205     -0.201420925853     -0.203954797096     -0.206520504245
+ -0.209118445414     -0.211749023580     -0.214412646626     -0.217109727397
+ -0.219840683754     -0.222605938618     -0.225405920030     -0.228241061195
+ -0.231111800539     -0.234018581758     -0.236961853864     -0.239942071244
+ -0.242959693701     -0.246015186512     -0.249109020469     -0.252241671930
+ -0.255413622870     -0.258625360920     -0.261877379421     -0.265170177461
+ -0.268504259923     -0.271880137527     -0.275298326867     -0.278759350455
+ -0.282263736754     -0.285812020216     -0.289404741315     -0.293042446580
+ -0.296725688619     -0.300455026150     -0.304231024023     -0.308054253240
+ -0.311925290970     -0.315844720568     -0.319813131578     -0.323831119744
+ -0.327899287007     -0.332018241503     -0.336188597555     -0.340410975654
+ -0.344686002445     -0.349014310694     -0.353396539258     -0.357833333044
+ -0.362325342957     -0.366873225844     -0.371477644431     -0.376139267240
+ -0.380858768512     -0.385636828102     -0.390474131373     -0.395371369076
+ -0.400329237215     -0.405348436897     -0.410429674170     -0.415573659839
+ -0.420781109276     -0.426052742200     -0.431389282440     -0.436791457687
+ -0.442259999210     -0.447795641559     -0.453399122238     -0.459071181354
+ -0.464812561236     -0.470624006025     -0.476506261236     -0.482460073279
+ -0.488486188950     -0.494585354884     -0.500758316963     -0.507005819690
+ -0.513328605509     -0.519727414083     -0.526202981517     -0.532756039535
+ -0.539387314590     -0.546097526921     -0.552887389546     -0.559757607183
+ -0.566708875105     -0.573741877915     -0.580857288248     -0.588055765381
+ -0.595337953758     -0.602704481424     -0.610155958352     -0.617692974674
+ -0.625316098795     -0.633025875395     -0.640822823305     -0.648707433254
+ -0.656680165483     -0.664741447210     -0.672891669948     -0.681131186660
+ -0.689460308753     -0.697879302887     -0.706388387610     -0.714987729784
+ -0.723677440823     -0.732457572707     -0.741328113771     -0.750288984267
+ -0.759340031671     -0.768481025733     -0.777711653264     -0.787031512632
+ -0.796440107969     -0.805936843065     -0.815521014949     -0.825191807124
+ -0.834948282463     -0.844789375739     -0.854713885774     -0.864720467203
+ -0.874807621828     -0.884973689550     -0.895216838869     -0.905535056931
+ -0.915926139110     -0.926387678115     -0.936917052596     -0.947511415254
+ -0.958167680423     -0.968882511125     -0.979652305579     -0.990473183163
+  -1.00134096980      -1.01225118280      -1.02319901509      -1.03417931889
+  -1.04518658881      -1.05621494434      -1.06725811177      -1.07830940558
+  -1.08936170917      -1.10040745516      -1.11143860505      -1.12244662844
+  -1.13342248175      -1.14435658645      -1.15523880696      -1.16605842809
+  -1.17680413224      -1.18746397632      -1.19802536846      -1.20847504467
+  -1.21879904545      -1.22898269246      -1.23901056542      -1.24886647927
+  -1.25853346185      -1.26799373207      -1.27722867889      -1.28621884122
+  -1.29494388890      -1.30338260498      -1.31151286959      -1.31931164555
+  -1.32675496593      -1.33381792399      -1.34047466564      -1.34669838476
+  -1.35246132169      -1.35773476524      -1.36248905855      -1.36669360913
+  -1.37031690346      -1.37332652652      -1.37568918664      -1.37737074601
+  -1.37833625725      -1.37855000646      -1.37797556296      -1.37657583626
+  -1.37431314048      -1.37114926648      -1.36704556207      -1.36196302045
+  -1.35586237705      -1.34870421496      -1.34044907890      -1.33105759778
+  -1.32049061567      -1.30870933104      -1.29567544397      -1.28135131079
+  -1.26570010575      -1.24868598910      -1.23027428055      -1.21043163756
+  -1.18912623716      -1.16632796027      -1.14200857734      -1.11614193385
+  -1.08870413447      -1.05967372429      -1.02903186590     -0.996762510938
+ -0.962852564921     -0.927292044391     -0.890074225751     -0.851195785461
+ -0.810656931867     -0.768461529538     -0.724617217786     -0.679135525967
+ -0.632031989279     -0.583326270024     -0.533042290743     -0.481208387226
+ -0.427857491137     -0.373027353861     -0.316760825120     -0.259106201890
+ -0.200117665062     -0.139855823107     -0.783883835201E-01 -0.157909739658E-01
+  0.478518644079E-01  0.112445489257      0.177883753970      0.244047370867
+  0.310802026490      0.377996240996      0.445458972114      0.512996975310
+  0.580391946019      0.647397487368      0.713735968073      0.779095360232
+  0.843126175682      0.905438652232      0.965600376998       1.02313457258
+   1.07751931168       1.12818796531       1.17453122689       1.21590108595
+   1.25161714772       1.28097570354       1.30326194688       1.31776569445
+   1.32380090498       1.32072918230       1.30798729680       1.28511855456
+   1.25180757808       1.20791773518       1.15353005947       1.08898205064
+   1.01490423153      0.932251785109      0.842328015903      0.746795801755
+  0.647672651184      0.547304488202      0.448312873536      0.353510047938
+  0.265775931209      0.187890967550      0.122318349355      0.709284742470E-01
+  0.346572043289E-01  0.130872450473E-01  0.393838929140E-02  0.244729926184E-02
+  0.242993894919E-02  0.241280398770E-02  0.239542962328E-02  0.237783653444E-02
+  0.236005092057E-02  0.234210456140E-02  0.232403488656E-02  0.230588505625E-02
+  0.228770407832E-02  0.226954691256E-02  0.225147462180E-02  0.223355452105E-02
+  0.221586035373E-02  0.219847248688E-02  0.218147812581E-02  0.216497155388E-02
+  0.214905438698E-02  0.213383585547E-02  0.211943311062E-02  0.210597146292E-02
+  0.209358481929E-02  0.208241606235E-02  0.207261745516E-02  0.206435108261E-02
+  0.205778929906E-02  0.205311522872E-02  0.205052327126E-02  0.205021966540E-02
+  0.205242305246E-02  0.205736508680E-02  0.206529108383E-02  0.207646068003E-02
+  0.209114855795E-02  0.210964513843E-02  0.213225754110E-02  0.215930965737E-02
+  0.219114592570E-02  0.222812082599E-02  0.227064423653E-02  0.231900925424E-02
+  0.284085345695E-02  0.285867363628E-02  0.287840323138E-02  0.290006566661E-02
+  0.292387873983E-02  0.295001684538E-02  0.297867104897E-02  0.301003216456E-02
+  0.304429537158E-02  0.308165878492E-02  0.312232370021E-02  0.249335113946
+  0.421642232265      0.292741064111      0.202302047869      0.139145096711
+  0.952489198390E-01  0.648858329680E-01  0.439855622953E-01  0.296697054192E-01
+  0.199127454064E-01  0.132964431370E-01  0.883277646246E-02  0.583696696942E-02
+  0.383685935643E-02  0.250861003018E-02  0.163128078873E-02  0.105494978151E-02
+  0.678439531371E-03  0.433845586037E-03  0.275849289384E-03  0.174376820624E-03
+  0.109585468303E-03  0.684591037962E-04  0.425098673477E-04  0.262358067313E-04
+  0.160920221800E-04  0.980851579394E-05  0.594069065940E-05  0.357499624215E-05
+  0.213738532887E-05  0.126946796897E-05  0.748953728665E-06  0.438878887602E-06
+  0.255418591166E-06  0.147618093157E-06  0.847162245539E-07  0.482718161739E-07
+  0.273073984166E-07  0.153350683263E-07  0.854807543268E-08  0.472918415539E-08
+  0.259655053014E-08  0.141467519181E-08  0.764754778023E-09  0.410156057266E-09
+  0.218219516531E-09  0.115161213898E-09  0.602765245124E-10  0.312863808934E-10
+  0.161020826302E-10  0.821742673907E-11  0.415785924209E-11  0.208425869156E-11
+  0.103620815632E-11  0.510406531854E-12  0.249874195409E-12  0.120792265079E-12
+  0.580276567537E-13  0.284217094304E-13  0.118423789293E-13  0.592118946467E-14
+  0.236847578587E-14  0.118423789293E-14  0.118423789293E-14   0.00000000000
+   0.00000000000       0.00000000000       0.00000000000       0.00000000000
+   0.00000000000
+  2
+  0.677543247807E-07  0.136360894052E-06  0.205830427731E-06  0.276173780572E-06
+  0.347401943868E-06  0.419526047165E-06  0.492557360000E-06  0.566507293665E-06
+  0.641387402986E-06  0.717209388134E-06  0.793985096447E-06  0.871726524288E-06
+  0.950445818911E-06  0.103015528037E-05  0.111086736342E-05  0.119259467950E-05
+  0.127534999866E-05  0.135914625160E-05  0.144399653164E-05  0.152991409682E-05
+  0.161691237193E-05  0.170500495063E-05  0.179420559756E-05  0.188452825050E-05
+  0.197598702256E-05  0.206859620435E-05  0.216237026624E-05  0.225732386063E-05
+  0.235347182420E-05  0.245082918027E-05  0.254941114113E-05  0.264923311041E-05
+  0.275031068549E-05  0.285265965995E-05  0.295629602603E-05  0.306123597711E-05
+  0.316749591028E-05  0.327509242888E-05  0.338404234506E-05  0.349436268249E-05
+  0.360607067894E-05  0.371918378901E-05  0.383371968685E-05  0.394969626893E-05
+  0.406713165683E-05  0.418604420007E-05  0.430645247897E-05  0.442837530756E-05
+  0.455183173655E-05  0.467684105626E-05  0.480342279962E-05  0.493159674532E-05
+  0.506138292078E-05  0.519280160536E-05  0.532587333349E-05  0.546061889791E-05
+  0.559705935288E-05  0.573521601750E-05  0.587511047903E-05  0.601676459627E-05
+  0.616020050296E-05  0.630544061124E-05  0.645250761519E-05  0.660142449433E-05
+  0.675221451721E-05  0.690490124509E-05  0.705950853557E-05  0.721606054637E-05
+  0.737458173905E-05  0.753509688286E-05  0.769763105864E-05  0.786220966267E-05
+  0.802885841070E-05  0.819760334192E-05  0.836847082309E-05  0.854148755258E-05
+  0.871668056463E-05  0.889407723349E-05  0.907370527775E-05  0.925559276466E-05
+  0.943976811452E-05  0.962626010508E-05  0.981509787610E-05  0.100063109339E-04
+  0.101999291559E-04  0.103959827952E-04  0.105945024858E-04  0.107955192467E-04
+  0.109990644872E-04  0.112051700116E-04  0.114138680244E-04  0.116251911350E-04
+  0.118391723631E-04  0.120558451438E-04  0.122752433325E-04  0.124974012107E-04
+  0.127223534910E-04  0.129501353226E-04  0.131807822970E-04  0.134143304532E-04
+  0.136508162835E-04  0.138902767394E-04  0.141327492370E-04  0.143782716632E-04
+  0.146268823813E-04  0.148786202373E-04  0.151335245658E-04  0.153916351959E-04
+  0.156529924582E-04  0.159176371901E-04  0.161856107429E-04  0.164569549880E-04
+  0.167317123236E-04  0.170099256811E-04  0.172916385318E-04  0.175768948939E-04
+  0.178657393393E-04  0.181582170006E-04  0.184543735780E-04  0.187542553465E-04
+  0.190579091634E-04  0.193653824750E-04  0.196767233248E-04  0.199919803604E-04
+  0.203112028414E-04  0.206344406468E-04  0.209617442834E-04  0.212931648928E-04
+  0.216287542603E-04  0.219685648225E-04  0.223126496753E-04  0.226610625828E-04
+  0.230138579851E-04  0.233710910073E-04  0.237328174677E-04  0.240990938870E-04
+  0.244699774964E-04  0.248455262473E-04  0.252257988200E-04  0.256108546328E-04
+  0.260007538515E-04  0.263955573986E-04  0.267953269630E-04  0.272001250095E-04
+  0.276100147886E-04  0.280250603465E-04  0.284453265348E-04  0.288708790209E-04
+  0.293017842984E-04  0.297381096970E-04  0.301799233935E-04  0.306272944222E-04
+  0.310802926857E-04  0.315389889659E-04  0.320034549350E-04  0.324737631669E-04
+  0.329499871480E-04  0.334322012894E-04  0.339204809380E-04  0.344149023884E-04
+  0.349155428952E-04  0.354224806843E-04  0.359357949658E-04  0.364555659462E-04
+  0.369818748406E-04  0.375148038859E-04  0.380544363535E-04  0.386008565618E-04
+  0.391541498903E-04  0.397144027920E-04  0.402817028078E-04  0.408561385794E-04
+  0.414377998634E-04  0.420267775457E-04  0.426231636552E-04  0.432270513786E-04
+  0.438385350744E-04  0.444577102882E-04  0.450846737674E-04  0.457195234764E-04
+  0.463623586117E-04  0.470132796176E-04  0.476723882018E-04  0.483397873514E-04
+  0.490155813489E-04  0.496998757884E-04  0.503927775924E-04  0.510943950281E-04
+  0.518048377247E-04  0.525242166904E-04  0.532526443295E-04  0.539902344604E-04
+  0.547371023330E-04  0.554933646470E-04  0.562591395698E-04  0.570345467554E-04
+  0.578197073626E-04  0.586147440746E-04  0.594197811173E-04  0.602349442794E-04
+  0.610603609319E-04  0.618961600477E-04  0.627424722222E-04  0.635994296933E-04
+  0.644671663625E-04  0.653458178154E-04  0.662355213429E-04  0.671364159632E-04
+  0.680486424427E-04  0.689723433189E-04  0.699076629218E-04  0.708547473969E-04
+  0.718137447283E-04  0.727848047611E-04  0.737680792254E-04  0.747637217600E-04
+  0.757718879359E-04  0.767927352813E-04  0.778264233054E-04  0.788731135244E-04
+  0.799329694855E-04  0.810061567935E-04  0.820928431359E-04  0.831931983099E-04
+  0.843073942481E-04  0.854356050460E-04  0.865780069887E-04  0.877347785789E-04
+  0.889061005644E-04  0.900921559668E-04  0.912931301096E-04  0.925092106475E-04
+  0.937405875954E-04  0.949874533587E-04  0.962500027625E-04  0.975284330828E-04
+  0.988229440769E-04  0.100133738015E-03  0.101461019711E-03  0.102804996555E-03
+  0.104165878547E-03  0.105543878328E-03  0.106939211211E-03  0.108352095222E-03
+  0.109782751126E-03  0.111231402466E-03  0.112698275596E-03  0.114183599720E-03
+  0.115687606920E-03  0.117210532202E-03  0.118752613527E-03  0.120314091846E-03
+  0.121895211145E-03  0.123496218476E-03  0.125117364000E-03  0.126758901025E-03
+  0.128421086044E-03  0.130104178776E-03  0.131808442209E-03  0.133534142636E-03
+  0.135281549703E-03  0.137050936445E-03  0.138842579333E-03  0.140656758314E-03
+  0.142493756857E-03  0.144353861997E-03  0.146237364380E-03  0.148144558306E-03
+  0.150075741778E-03  0.152031216548E-03  0.154011288163E-03  0.156016266013E-03
+  0.158046463379E-03  0.160102197485E-03  0.162183789542E-03  0.164291564804E-03
+  0.166425852615E-03  0.168586986462E-03  0.170775304027E-03  0.172991147238E-03
+  0.175234862325E-03  0.177506799874E-03  0.179807314879E-03  0.182136766800E-03
+  0.184495519620E-03  0.186883941898E-03  0.189302406829E-03  0.191751292305E-03
+  0.194230980968E-03  0.196741860275E-03  0.199284322555E-03  0.201858765074E-03
+  0.204465590093E-03  0.207105204934E-03  0.209778022043E-03  0.212484459052E-03
+  0.215224938849E-03  0.217999889637E-03  0.220809745010E-03  0.223654944011E-03
+  0.226535931211E-03  0.229453156769E-03  0.232407076507E-03  0.235398151981E-03
+  0.238426850553E-03  0.241493645464E-03  0.244599015906E-03  0.247743447099E-03
+  0.250927430367E-03  0.254151463215E-03  0.257416049404E-03  0.260721699032E-03
+  0.264068928614E-03  0.267458261160E-03  0.270890226262E-03  0.274365360170E-03
+  0.277884205883E-03  0.281447313225E-03  0.285055238940E-03  0.288708546774E-03
+  0.292407807564E-03  0.296153599326E-03  0.299946507349E-03  0.303787124281E-03
+  0.307676050227E-03  0.311613892840E-03  0.315601267415E-03  0.319638796988E-03
+  0.323727112431E-03  0.327866852552E-03  0.332058664193E-03  0.336303202334E-03
+  0.340601130192E-03  0.344953119327E-03  0.349359849747E-03  0.353822010012E-03
+  0.358340297343E-03  0.362915417733E-03  0.367548086053E-03  0.372239026167E-03
+  0.376988971043E-03  0.381798662871E-03  0.386668853175E-03  0.391600302931E-03
+  0.396593782689E-03  0.401650072691E-03  0.406769962990E-03  0.411954253582E-03
+  0.417203754522E-03  0.422519286055E-03  0.427901678744E-03  0.433351773598E-03
+  0.438870422207E-03  0.444458486869E-03  0.450116840732E-03  0.455846367925E-03
+  0.461647963698E-03  0.467522534562E-03  0.473470998431E-03  0.479494284764E-03
+  0.485593334713E-03  0.491769101265E-03  0.498022549398E-03  0.504354656226E-03
+  0.510766411151E-03  0.517258816026E-03  0.523832885300E-03  0.530489646186E-03
+  0.537230138817E-03  0.544055416407E-03  0.550966545420E-03  0.557964605735E-03
+  0.565050690811E-03  0.572225907866E-03  0.579491378040E-03  0.586848236579E-03
+  0.594297633006E-03  0.601840731305E-03  0.609478710100E-03  0.617212762841E-03
+  0.625044097990E-03  0.632973939207E-03  0.641003525548E-03  0.649134111651E-03
+  0.657366967938E-03  0.665703380808E-03  0.674144652842E-03  0.682692103008E-03
+  0.691347066861E-03  0.700110896756E-03  0.708984962062E-03  0.717970649367E-03
+  0.727069362703E-03  0.736282523765E-03  0.745611572124E-03  0.755057965467E-03
+  0.764623179809E-03  0.774308709736E-03  0.784116068631E-03  0.794046788914E-03
+  0.804102422279E-03  0.814284539941E-03  0.824594732875E-03  0.835034612071E-03
+  0.845605808780E-03  0.856309974773E-03  0.867148782598E-03  0.878123925841E-03
+  0.889237119389E-03  0.900490099703E-03  0.911884625082E-03  0.923422475945E-03
+  0.935105455105E-03  0.946935388048E-03  0.958914123229E-03  0.971043532348E-03
+  0.983325510648E-03  0.995761977215E-03  0.100835487527E-02  0.102110617248E-02
+  0.103401786126E-02  0.104709195909E-02  0.106033050883E-02  0.107373557901E-02
+  0.108730926422E-02  0.110105368536E-02  0.111497099004E-02  0.112906335285E-02
+  0.114333297576E-02  0.115778208843E-02  0.117241294855E-02  0.118722784223E-02
+  0.120222908433E-02  0.121741901882E-02  0.123280001915E-02  0.124837448864E-02
+  0.126414486084E-02  0.128011359989E-02  0.129628320094E-02  0.131265619052E-02
+  0.132923512695E-02  0.134602260071E-02  0.136302123489E-02  0.138023368555E-02
+  0.139766264217E-02  0.141531082806E-02  0.143318100079E-02  0.145127595260E-02
+  0.146959851087E-02  0.148815153853E-02  0.150693793454E-02  0.152596063429E-02
+  0.154522261012E-02  0.156472687176E-02  0.158447646678E-02  0.160447448110E-02
+  0.162472403944E-02  0.164522830584E-02  0.166599048413E-02  0.168701381843E-02
+  0.170830159369E-02  0.172985713616E-02  0.175168381393E-02  0.177378503746E-02
+  0.179616426011E-02  0.181882497868E-02  0.184177073394E-02  0.186500511121E-02
+  0.188853174091E-02  0.191235429911E-02  0.193647650813E-02  0.196090213712E-02
+  0.198563500261E-02  0.201067896917E-02  0.203603794995E-02  0.206171590735E-02
+  0.208771685359E-02  0.211404485136E-02  0.214070401445E-02  0.216769850841E-02
+  0.219503255116E-02  0.222271041371E-02  0.225073642076E-02  0.227911495142E-02
+  0.230785043987E-02  0.233694737610E-02  0.236641030653E-02  0.239624383479E-02
+  0.242645262243E-02  0.245704138959E-02  0.248801491584E-02  0.251937804081E-02
+  0.255113566505E-02  0.258329275072E-02  0.261585432241E-02  0.264882546792E-02
+  0.268221133901E-02  0.271601715228E-02  0.275024818991E-02  0.278490980055E-02
+  0.282000740012E-02  0.285554647263E-02  0.289153257112E-02  0.292797131844E-02
+  0.296486840817E-02  0.300222960552E-02  0.304006074819E-02  0.307836774733E-02
+  0.311715658843E-02  0.315643333226E-02  0.319620411583E-02  0.323647515335E-02
+  0.327725273716E-02  0.331854323878E-02  0.336035310984E-02  0.340268888313E-02
+  0.344555717363E-02  0.348896467948E-02  0.353291818309E-02  0.357742455218E-02
+  0.362249074083E-02  0.366812379061E-02  0.371433083163E-02  0.376111908370E-02
+  0.380849585742E-02  0.385646855535E-02  0.390504467316E-02  0.395423180076E-02
+  0.400403762356E-02  0.405446992361E-02  0.410553658083E-02  0.415724557426E-02
+  0.420960498329E-02  0.426262298890E-02  0.431630787500E-02  0.437066802964E-02
+  0.442571194638E-02  0.448144822562E-02  0.453788557589E-02  0.459503281525E-02
+  0.465289887266E-02  0.471149278936E-02  0.477082372032E-02  0.483090093561E-02
+  0.489173382187E-02  0.495333188381E-02  0.501570474566E-02  0.507886215264E-02
+  0.514281397256E-02  0.520757019729E-02  0.527314094434E-02  0.533953645846E-02
+  0.540676711320E-02  0.547484341255E-02  0.554377599259E-02  0.561357562311E-02
+  0.568425320931E-02  0.575581979352E-02  0.582828655688E-02  0.590166482112E-02
+  0.597596605029E-02  0.605120185258E-02  0.612738398208E-02  0.620452434067E-02
+  0.628263497984E-02  0.636172810254E-02  0.644181606515E-02  0.652291137932E-02
+  0.660502671398E-02  0.668817489728E-02  0.677236891861E-02  0.685762193055E-02
+  0.694394725103E-02  0.703135836527E-02  0.711986892799E-02  0.720949276544E-02
+  0.730024387760E-02  0.739213644034E-02  0.748518480762E-02  0.757940351367E-02
+  0.767480727533E-02  0.777141099427E-02  0.786922975928E-02  0.796827884868E-02
+  0.806857373261E-02  0.817013007545E-02  0.827296373826E-02  0.837709078120E-02
+  0.848252746601E-02  0.858929025855E-02  0.869739583131E-02  0.880686106598E-02
+  0.891770305605E-02  0.902993910945E-02  0.914358675121E-02  0.925866372615E-02
+  0.937518800157E-02  0.949317777005E-02  0.961265145222E-02  0.973362769957E-02
+  0.985612539732E-02  0.998016366726E-02  0.101057618707E-01  0.102329396115E-01
+  0.103617167387E-01  0.104921133502E-01  0.106241497950E-01  0.107578466769E-01
+  0.108932248575E-01  0.110303054589E-01  0.111691098675E-01  0.113096597369E-01
+  0.114519769911E-01  0.115960838280E-01  0.117420027224E-01  0.118897564296E-01
+  0.120393679888E-01  0.121908607264E-01  0.123442582594E-01  0.124995844989E-01
+  0.126568636540E-01  0.128161202345E-01  0.129773790555E-01  0.131406652401E-01
+  0.133060042236E-01  0.134734217572E-01  0.136429439111E-01  0.138145970790E-01
+  0.139884079814E-01  0.141644036693E-01  0.143426115284E-01  0.145230592826E-01
+  0.147057749982E-01  0.148907870872E-01  0.150781243121E-01  0.152678157888E-01
+  0.154598909915E-01  0.156543797558E-01  0.158513122835E-01  0.160507191460E-01
+  0.162526312884E-01  0.164570800340E-01  0.166640970876E-01  0.168737145400E-01
+  0.170859648718E-01  0.173008809578E-01  0.175184960703E-01  0.177388438840E-01
+  0.179619584794E-01  0.181878743467E-01  0.184166263903E-01  0.186482499323E-01
+  0.188827807166E-01  0.191202549125E-01  0.193607091190E-01  0.196041803680E-01
+  0.198507061285E-01  0.201003243100E-01  0.203530732662E-01  0.206089917982E-01
+  0.208681191586E-01  0.211304950539E-01  0.213961596485E-01  0.216651535674E-01
+  0.219375178993E-01  0.222132941993E-01  0.224925244917E-01  0.227752512724E-01
+  0.230615175113E-01  0.233513666543E-01  0.236448426254E-01  0.239419898282E-01
+  0.242428531473E-01  0.245474779497E-01  0.248559100854E-01  0.251681958879E-01
+  0.254843821745E-01  0.258045162464E-01  0.261286458875E-01  0.264568193641E-01
+  0.267890854230E-01  0.271254932895E-01  0.274660926656E-01  0.278109337263E-01
+  0.281600671161E-01  0.285135439451E-01  0.288714157837E-01  0.292337346574E-01
+  0.296005530396E-01  0.299719238450E-01  0.303479004212E-01  0.307285365394E-01
+  0.311138863846E-01  0.315040045439E-01  0.318989459946E-01  0.322987660905E-01
+  0.327035205466E-01  0.331132654231E-01  0.335280571078E-01  0.339479522963E-01
+  0.343730079711E-01  0.348032813789E-01  0.352388300058E-01  0.356797115504E-01
+  0.361259838950E-01  0.365777050745E-01  0.370349332426E-01  0.374977266359E-01
+  0.379661435349E-01  0.384402422219E-01  0.389200809368E-01  0.394057178285E-01
+  0.398972109033E-01  0.403946179702E-01  0.408979965812E-01  0.414074039686E-01
+  0.419228969773E-01  0.424445319925E-01  0.429723648630E-01  0.435064508188E-01
+  0.440468443836E-01  0.445935992815E-01  0.451467683375E-01  0.457064033714E-01
+  0.462725550854E-01  0.468452729441E-01  0.474246050468E-01  0.480105979923E-01
+  0.486032967349E-01  0.492027444313E-01  0.498089822788E-01  0.504220493427E-01
+  0.510419823739E-01  0.516688156151E-01  0.523025805962E-01  0.529433059162E-01
+  0.535910170138E-01  0.542457359231E-01  0.549074810164E-01  0.555762667314E-01
+  0.562521032831E-01  0.569349963589E-01  0.576249467975E-01  0.583219502486E-01
+  0.590259968150E-01  0.597370706739E-01  0.604551496784E-01  0.611802049371E-01
+  0.619122003711E-01  0.626510922480E-01  0.633968286912E-01  0.641493491633E-01
+  0.649085839235E-01  0.656744534575E-01  0.664468678781E-01  0.672257262969E-01
+  0.680109161645E-01  0.688023125792E-01  0.695997775625E-01  0.704031593011E-01
+  0.712122913529E-01  0.720269918182E-01  0.728470624722E-01  0.736722878614E-01
+  0.745024343593E-01  0.753372491838E-01  0.761764593734E-01  0.770197707229E-01
+  0.778668666767E-01  0.787174071813E-01  0.795710274947E-01  0.804273369538E-01
+  0.812859177001E-01  0.821463233630E-01  0.830080777026E-01  0.838706732115E-01
+  0.847335696785E-01  0.855961927138E-01  0.864579322395E-01  0.873181409461E-01
+  0.881761327192E-01  0.890311810390E-01  0.898825173565E-01  0.907293294513E-01
+  0.915707597757E-01  0.924059037921E-01  0.932338083085E-01  0.940534698218E-01
+  0.948638328760E-01  0.956637884456E-01  0.964521723539E-01  0.972277637392E-01
+  0.979892835800E-01  0.987353932961E-01  0.994646934377E-01  0.100175722483
+  0.100866955761      0.101536804519      0.102183615158      0.102805668662
+  0.103401180236      0.103968299199      0.104505109139      0.105009628378
+  0.105479810771      0.105913546878      0.106308665541      0.106662935914
+  0.106974069969      0.107239725547      0.107457509963      0.107624984247
+  0.107739668031      0.107799045160      0.107800570055      0.107741674877
+  0.107619777553      0.107432290689      0.107176631437      0.106850232339
+  0.106450553204      0.105975094039      0.105421409082      0.104787121943
+  0.104069941892      0.103267681293      0.102378274178      0.101399795977
+  0.100330484351      0.991687611197E-01  0.979132552110E-01  0.965628265844E-01
+  0.951165910252E-01  0.935739457131E-01  0.919345954330E-01  0.901985792771E-01
+  0.883662976611E-01  0.864385394527E-01  0.844165089829E-01  0.823018526821E-01
+  0.800966850564E-01  0.778036136895E-01  0.754257629291E-01  0.729667958882E-01
+  0.704309343657E-01  0.678229762700E-01  0.651483101015E-01  0.624129260394E-01
+  0.596234231569E-01  0.567870122832E-01  0.539115140236E-01  0.510053514511E-01
+  0.480775369870E-01  0.451376530021E-01  0.421958256886E-01  0.392626917770E-01
+  0.363493577029E-01  0.334673508637E-01  0.306285626444E-01  0.278451829337E-01
+  0.251296258944E-01  0.224944467950E-01  0.199522497480E-01  0.175155862389E-01
+  0.151968443586E-01  0.130081286787E-01  0.109611307281E-01  0.906699004731E-02
+  0.733614581630E-02  0.577817908106E-02  0.440164565509E-02  0.321389986353E-02
+  0.222090945027E-02  0.142706221517E-02  0.834965326806E-03  0.445238814495E-03
+  0.256305538664E-03  0.264181037835E-03  0.462268131037E-03  0.841163096879E-03
+  0.138848274745E-02  0.208872485372E-02  0.292317825031E-02  0.386990362945E-02
+  0.490381159644E-02  0.599687104908E-02  0.711848839502E-02  0.823610654446E-02
+  0.931608201649E-02  0.103249088960E-01  0.112308698375E-01  0.120062069965E-01
+  0.126299200016E-01  0.130913144163E-01  0.133944434114E-01  0.135636086567E-01
+  0.136501148890E-01  0.137208045500E-01  0.137917696076E-01  0.138631044673E-01
+  0.139349189402E-01  0.140073181802E-01  0.140804022612E-01  0.141542657644E-01
+  0.142289973781E-01  0.143046795118E-01  0.143813879231E-01  0.144591913605E-01
+  0.145381512245E-01  0.146183212402E-01  0.146997471544E-01  0.147824664472E-01
+  0.148665080645E-01  0.149518921713E-01  0.150386299259E-01  0.151267232735E-01
+  0.152161647675E-01  0.153069374071E-01  0.153990145062E-01  0.154923595796E-01
+  0.155869262582E-01  0.156826582301E-01  0.157794892036E-01  0.158773429037E-01
+  0.159761330851E-01  0.160757635836E-01  0.161761283871E-01  0.162771117390E-01
+  0.163785882665E-01  0.164804231391E-01  0.165824722544E-01  0.166845824535E-01
+  0.167865917634E-01  0.168883296668E-01  0.169896174042E-01  0.170902682983E-01
+  0.171900881085E-01  0.172888754126E-01  0.173864220149E-01  0.174825133774E-01
+  0.175769290813E-01  0.176694433076E-01  0.177598253442E-01  0.178478401145E-01
+  0.179332487287E-01  0.180158090525E-01  0.180952762993E-01  0.181714036355E-01
+  0.182439428064E-01  0.183126447742E-01  0.183772603751E-01  0.184375409739E-01
+  0.184932391496E-01  0.185441093737E-01  0.185899087038E-01  0.186303974730E-01
+  0.186653400035E-01  0.186945052941E-01  0.187176677272E-01  0.187346077642E-01
+  0.187451126422E-01  0.187489770597E-01  0.187460038601E-01  0.187360046990E-01
+  0.187188007041E-01  0.186942231179E-01  0.186621139291E-01  0.186223264799E-01
+  0.185747260602E-01  0.185191904754E-01  0.184556105926E-01  0.183838908610E-01
+  0.183039498033E-01  0.182157204844E-01  0.181191509379E-01  0.180142045706E-01
+  0.179008605242E-01  0.177791140064E-01  0.176489765792E-01  0.175104764090E-01
+  0.173636584774E-01  0.172085847402E-01  0.170453342542E-01  0.168740032442E-01
+  0.166947051321E-01  0.165075705081E-01  0.163127470589E-01  0.161103994370E-01
+  0.159007090808E-01  0.156838739776E-01  0.154601083739E-01  0.152296424293E-01
+  0.149927218112E-01  0.147496072372E-01  0.145005739578E-01  0.142459111830E-01
+  0.139859214528E-01  0.137209199551E-01  0.134512337827E-01  0.131772011443E-01
+  0.128991705185E-01  0.126174997644E-01  0.123325551784E-01  0.120447105104E-01
+  0.117543459413E-01  0.114618470155E-01  0.111676035497E-01  0.108720084960E-01
+  0.105754568261E-01  0.102783442569E-01  0.998106620801E-02  0.968401648668E-02
+  0.938758617654E-02  0.909216237635E-02  0.879812700873E-02  0.850585566324E-02
+  0.821571642999E-02  0.792806876527E-02  0.764326239506E-02  0.736163625421E-02
+  0.708351747049E-02  0.680922037615E-02  0.653904562452E-02  0.627327932706E-02
+  0.601219227226E-02  0.575603920865E-02  0.550505820671E-02  0.525947009553E-02
+  0.501947798617E-02  0.478526687214E-02  0.455700331811E-02  0.433483524027E-02
+  0.411889176247E-02  0.390928317474E-02  0.370610096636E-02  0.350941795415E-02
+  0.331928848675E-02  0.313574873683E-02  0.295881707398E-02  0.278849449930E-02
+  0.262476517541E-02  0.246759699493E-02  0.231694223303E-02  0.217273824968E-02
+  0.203490823779E-02  0.190336202708E-02  0.177799691356E-02  0.165869853771E-02
+  0.154534177744E-02  0.143779166765E-02  0.133590432996E-02  0.123952791614E-02
+  0.114850354769E-02  0.106266625060E-02  0.981845888577E-03  0.905868072414E-03
+  0.834555053257E-03  0.767726587958E-03  0.705200779976E-03  0.646794880004E-03
+  0.592326057233E-03  0.541612121219E-03  0.494472212972E-03  0.450727437283E-03
+  0.410201460863E-03  0.372721052929E-03  0.338116582975E-03  0.306222464656E-03
+  0.276877554779E-03  0.546768578705E-03  0.554834647664E-03  0.508717704217E-03
+  0.455270878643E-03  0.404562396278E-03  0.827740387642E-04  0.165977406603E-04
+  0.326092086027E-05  0.627562322819E-06  0.118273167971E-06  0.218229985194E-07
+  0.394117734004E-08  0.696472568507E-09  0.120400756032E-09  0.203556282941E-10
+  0.336513039656E-11  0.543565192856E-12  0.859756710270E-13  0.135003119794E-13
+  0.213162820728E-14   0.00000000000       0.00000000000       0.00000000000
+   0.00000000000
+  3
+ -0.335824988106E-06 -0.675874134550E-06 -0.102020057270E-05 -0.136885810428E-05
+ -0.172190120771E-05 -0.207938504672E-05 -0.244136547887E-05 -0.280789906434E-05
+ -0.317904307476E-05 -0.355485550213E-05 -0.393539506790E-05 -0.432072123216E-05
+ -0.471089420290E-05 -0.510597494545E-05 -0.550602519198E-05 -0.591110745114E-05
+ -0.632128501787E-05 -0.673662198325E-05 -0.715718324452E-05 -0.758303451524E-05
+ -0.801424233552E-05 -0.845087408248E-05 -0.889299798071E-05 -0.934068311297E-05
+ -0.979399943096E-05 -0.102530177663E-04 -0.107178098415E-04 -0.111884482813E-04
+ -0.116650066240E-04 -0.121475593326E-04 -0.126361818071E-04 -0.131309503958E-04
+ -0.136319424071E-04 -0.141392361222E-04 -0.146529108067E-04 -0.151730467233E-04
+ -0.156997251443E-04 -0.162330283643E-04 -0.167730397131E-04 -0.173198435684E-04
+ -0.178735253695E-04 -0.184341716304E-04 -0.190018699530E-04 -0.195767090415E-04
+ -0.201587787156E-04 -0.207481699249E-04 -0.213449747630E-04 -0.219492864818E-04
+ -0.225611995062E-04 -0.231808094490E-04 -0.238082131255E-04 -0.244435085686E-04
+ -0.250867950448E-04 -0.257381730687E-04 -0.263977444194E-04 -0.270656121565E-04
+ -0.277418806356E-04 -0.284266555249E-04 -0.291200438220E-04 -0.298221538701E-04
+ -0.305330953755E-04 -0.312529794242E-04 -0.319819184995E-04 -0.327200264996E-04
+ -0.334674187555E-04 -0.342242120486E-04 -0.349905246295E-04 -0.357664762360E-04
+ -0.365521881122E-04 -0.373477830272E-04 -0.381533852943E-04 -0.389691207904E-04
+ -0.397951169760E-04 -0.406315029145E-04 -0.414784092930E-04 -0.423359684424E-04
+ -0.432043143580E-04 -0.440835827206E-04 -0.449739109177E-04 -0.458754380649E-04
+ -0.467883050276E-04 -0.477126544432E-04 -0.486486307430E-04 -0.495963801755E-04
+ -0.505560508282E-04 -0.515277926517E-04 -0.525117574827E-04 -0.535080990676E-04
+ -0.545169730869E-04 -0.555385371791E-04 -0.565729509657E-04 -0.576203760761E-04
+ -0.586809761724E-04 -0.597549169757E-04 -0.608423662913E-04 -0.619434940354E-04
+ -0.630584722615E-04 -0.641874751871E-04 -0.653306792214E-04 -0.664882629922E-04
+ -0.676604073744E-04 -0.688472955179E-04 -0.700491128764E-04 -0.712660472362E-04
+ -0.724982887460E-04 -0.737460299459E-04 -0.750094657980E-04 -0.762887937167E-04
+ -0.775842135997E-04 -0.788959278589E-04 -0.802241414523E-04 -0.815690619160E-04
+ -0.829308993967E-04 -0.843098666841E-04 -0.857061792446E-04 -0.871200552551E-04
+ -0.885517156365E-04 -0.900013840885E-04 -0.914692871250E-04 -0.929556541087E-04
+ -0.944607172874E-04 -0.959847118304E-04 -0.975278758649E-04 -0.990904505134E-04
+ -0.100672679931E-03 -0.102274811346E-03 -0.103897095092E-03 -0.105539784656E-03
+ -0.107203136711E-03 -0.108887411159E-03 -0.110592871172E-03 -0.112319783231E-03
+ -0.114068417169E-03 -0.115839046215E-03 -0.117631947033E-03 -0.119447399766E-03
+ -0.121285688084E-03 -0.123147099222E-03 -0.125031924030E-03 -0.126940457016E-03
+ -0.128872996391E-03 -0.130829844119E-03 -0.132811305961E-03 -0.134817691526E-03
+ -0.136849314313E-03 -0.138906491770E-03 -0.140989545333E-03 -0.143098800485E-03
+ -0.145234586801E-03 -0.147397238001E-03 -0.149587092004E-03 -0.151804490980E-03
+ -0.154049781402E-03 -0.156323314100E-03 -0.158625444320E-03 -0.160956531772E-03
+ -0.163316940695E-03 -0.165707039908E-03 -0.168127202867E-03 -0.170577807729E-03
+ -0.173059237406E-03 -0.175571879625E-03 -0.178116126993E-03 -0.180692377053E-03
+ -0.183301032350E-03 -0.185942500491E-03 -0.188617194211E-03 -0.191325531436E-03
+ -0.194067935350E-03 -0.196844834458E-03 -0.199656662657E-03 -0.202503859302E-03
+ -0.205386869271E-03 -0.208306143041E-03 -0.211262136755E-03 -0.214255312293E-03
+ -0.217286137344E-03 -0.220355085481E-03 -0.223462636233E-03 -0.226609275162E-03
+ -0.229795493937E-03 -0.233021790410E-03 -0.236288668696E-03 -0.239596639253E-03
+ -0.242946218958E-03 -0.246337931188E-03 -0.249772305906E-03 -0.253249879740E-03
+ -0.256771196068E-03 -0.260336805103E-03 -0.263947263978E-03 -0.267603136836E-03
+ -0.271304994913E-03 -0.275053416632E-03 -0.278848987692E-03 -0.282692301159E-03
+ -0.286583957558E-03 -0.290524564969E-03 -0.294514739119E-03 -0.298555103481E-03
+ -0.302646289370E-03 -0.306788936043E-03 -0.310983690797E-03 -0.315231209069E-03
+ -0.319532154545E-03 -0.323887199255E-03 -0.328297023683E-03 -0.332762316875E-03
+ -0.337283776540E-03 -0.341862109167E-03 -0.346498030129E-03 -0.351192263798E-03
+ -0.355945543657E-03 -0.360758612418E-03 -0.365632222130E-03 -0.370567134306E-03
+ -0.375564120035E-03 -0.380623960108E-03 -0.385747445133E-03 -0.390935375667E-03
+ -0.396188562333E-03 -0.401507825954E-03 -0.406893997674E-03 -0.412347919094E-03
+ -0.417870442400E-03 -0.423462430498E-03 -0.429124757147E-03 -0.434858307098E-03
+ -0.440663976229E-03 -0.446542671688E-03 -0.452495312033E-03 -0.458522827376E-03
+ -0.464626159528E-03 -0.470806262148E-03 -0.477064100890E-03 -0.483400653553E-03
+ -0.489816910236E-03 -0.496313873494E-03 -0.502892558488E-03 -0.509553993154E-03
+ -0.516299218352E-03 -0.523129288039E-03 -0.530045269426E-03 -0.537048243150E-03
+ -0.544139303439E-03 -0.551319558287E-03 -0.558590129622E-03 -0.565952153487E-03
+ -0.573406780212E-03 -0.580955174598E-03 -0.588598516097E-03 -0.596337998997E-03
+ -0.604174832607E-03 -0.612110241449E-03 -0.620145465447E-03 -0.628281760120E-03
+ -0.636520396782E-03 -0.644862662736E-03 -0.653309861478E-03 -0.661863312899E-03
+ -0.670524353495E-03 -0.679294336570E-03 -0.688174632453E-03 -0.697166628707E-03
+ -0.706271730350E-03 -0.715491360073E-03 -0.724826958461E-03 -0.734279984222E-03
+ -0.743851914408E-03 -0.753544244655E-03 -0.763358489409E-03 -0.773296182164E-03
+ -0.783358875706E-03 -0.793548142351E-03 -0.803865574193E-03 -0.814312783351E-03
+ -0.824891402223E-03 -0.835603083740E-03 -0.846449501624E-03 -0.857432350650E-03
+ -0.868553346910E-03 -0.879814228083E-03 -0.891216753704E-03 -0.902762705440E-03
+ -0.914453887372E-03 -0.926292126268E-03 -0.938279271879E-03 -0.950417197220E-03
+ -0.962707798866E-03 -0.975152997250E-03 -0.987754736959E-03 -0.100051498704E-02
+ -0.101343574131E-02 -0.102651901866E-02 -0.103976686338E-02 -0.105318134547E-02
+ -0.106676456097E-02 -0.108051863230E-02 -0.109444570854E-02 -0.110854796584E-02
+ -0.112282760769E-02 -0.113728686533E-02 -0.115192799805E-02 -0.116675329354E-02
+ -0.118176506829E-02 -0.119696566792E-02 -0.121235746755E-02 -0.122794287220E-02
+ -0.124372431710E-02 -0.125970426814E-02 -0.127588522222E-02 -0.129226970764E-02
+ -0.130886028453E-02 -0.132565954518E-02 -0.134267011451E-02 -0.135989465047E-02
+ -0.137733584442E-02 -0.139499642158E-02 -0.141287914146E-02 -0.143098679826E-02
+ -0.144932222134E-02 -0.146788827566E-02 -0.148668786219E-02 -0.150572391840E-02
+ -0.152499941873E-02 -0.154451737501E-02 -0.156428083695E-02 -0.158429289264E-02
+ -0.160455666900E-02 -0.162507533229E-02 -0.164585208860E-02 -0.166689018432E-02
+ -0.168819290672E-02 -0.170976358437E-02 -0.173160558775E-02 -0.175372232971E-02
+ -0.177611726603E-02 -0.179879389598E-02 -0.182175576282E-02 -0.184500645438E-02
+ -0.186854960365E-02 -0.189238888927E-02 -0.191652803620E-02 -0.194097081621E-02
+ -0.196572104855E-02 -0.199078260048E-02 -0.201615938793E-02 -0.204185537608E-02
+ -0.206787457996E-02 -0.209422106514E-02 -0.212089894830E-02 -0.214791239793E-02
+ -0.217526563492E-02 -0.220296293328E-02 -0.223100862076E-02 -0.225940707956E-02
+ -0.228816274700E-02 -0.231728011621E-02 -0.234676373683E-02 -0.237661821575E-02
+ -0.240684821778E-02 -0.243745846643E-02 -0.246845374461E-02 -0.249983889539E-02
+ -0.253161882277E-02 -0.256379849242E-02 -0.259638293249E-02 -0.262937723435E-02
+ -0.266278655345E-02 -0.269661611004E-02 -0.273087119007E-02 -0.276555714596E-02
+ -0.280067939746E-02 -0.283624343251E-02 -0.287225480804E-02 -0.290871915091E-02
+ -0.294564215875E-02 -0.298302960085E-02 -0.302088731908E-02 -0.305922122878E-02
+ -0.309803731970E-02 -0.313734165694E-02 -0.317714038188E-02 -0.321743971314E-02
+ -0.325824594759E-02 -0.329956546128E-02 -0.334140471047E-02 -0.338377023261E-02
+ -0.342666864743E-02 -0.347010665786E-02 -0.351409105121E-02 -0.355862870011E-02
+ -0.360372656366E-02 -0.364939168849E-02 -0.369563120988E-02 -0.374245235284E-02
+ -0.378986243327E-02 -0.383786885910E-02 -0.388647913141E-02 -0.393570084567E-02
+ -0.398554169287E-02 -0.403600946074E-02 -0.408711203498E-02 -0.413885740045E-02
+ -0.419125364249E-02 -0.424430894810E-02 -0.429803160729E-02 -0.435243001433E-02
+ -0.440751266908E-02 -0.446328817832E-02 -0.451976525708E-02 -0.457695273002E-02
+ -0.463485953280E-02 -0.469349471347E-02 -0.475286743389E-02 -0.481298697118E-02
+ -0.487386271913E-02 -0.493550418970E-02 -0.499792101448E-02 -0.506112294625E-02
+ -0.512511986041E-02 -0.518992175662E-02 -0.525553876031E-02 -0.532198112426E-02
+ -0.538925923022E-02 -0.545738359053E-02 -0.552636484975E-02 -0.559621378635E-02
+ -0.566694131437E-02 -0.573855848510E-02 -0.581107648889E-02 -0.588450665680E-02
+ -0.595886046246E-02 -0.603414952378E-02 -0.611038560483E-02 -0.618758061764E-02
+ -0.626574662409E-02 -0.634489583777E-02 -0.642504062590E-02 -0.650619351125E-02
+ -0.658836717412E-02 -0.667157445430E-02 -0.675582835309E-02 -0.684114203533E-02
+ -0.692752883143E-02 -0.701500223950E-02 -0.710357592743E-02 -0.719326373501E-02
+ -0.728407967615E-02 -0.737603794099E-02 -0.746915289820E-02 -0.756343909715E-02
+ -0.765891127024E-02 -0.775558433516E-02 -0.785347339727E-02 -0.795259375191E-02
+ -0.805296088680E-02 -0.815459048450E-02 -0.825749842481E-02 -0.836170078727E-02
+ -0.846721385369E-02 -0.857405411068E-02 -0.868223825219E-02 -0.879178318219E-02
+ -0.890270601726E-02 -0.901502408928E-02 -0.912875494813E-02 -0.924391636445E-02
+ -0.936052633238E-02 -0.947860307243E-02 -0.959816503427E-02 -0.971923089963E-02
+ -0.984181958526E-02 -0.996595024580E-02 -0.100916422769E-01 -0.102189153180E-01
+ -0.103477892558E-01 -0.104782842270E-01 -0.106104206216E-01 -0.107442190861E-01
+ -0.108797005267E-01 -0.110168861125E-01 -0.111557972789E-01 -0.112964557310E-01
+ -0.114388834467E-01 -0.115831026806E-01 -0.117291359671E-01 -0.118770061240E-01
+ -0.120267362562E-01 -0.121783497590E-01 -0.123318703222E-01 -0.124873219336E-01
+ -0.126447288825E-01 -0.128041157639E-01 -0.129655074820E-01 -0.131289292544E-01
+ -0.132944066157E-01 -0.134619654218E-01 -0.136316318538E-01 -0.138034324222E-01
+ -0.139773939707E-01 -0.141535436807E-01 -0.143319090757E-01 -0.145125180251E-01
+ -0.146953987491E-01 -0.148805798225E-01 -0.150680901798E-01 -0.152579591193E-01
+ -0.154502163079E-01 -0.156448917853E-01 -0.158420159695E-01 -0.160416196608E-01
+ -0.162437340468E-01 -0.164483907076E-01 -0.166556216202E-01 -0.168654591641E-01
+ -0.170779361257E-01 -0.172930857041E-01 -0.175109415155E-01 -0.177315375994E-01
+ -0.179549084229E-01 -0.181810888869E-01 -0.184101143311E-01 -0.186420205397E-01
+ -0.188768437469E-01 -0.191146206426E-01 -0.193553883780E-01 -0.195991845716E-01
+ -0.198460473150E-01 -0.200960151788E-01 -0.203491272187E-01 -0.206054229813E-01
+ -0.208649425107E-01 -0.211277263546E-01 -0.213938155705E-01 -0.216632517320E-01
+ -0.219360769357E-01 -0.222123338075E-01 -0.224920655091E-01 -0.227753157451E-01
+ -0.230621287694E-01 -0.233525493925E-01 -0.236466229882E-01 -0.239443955008E-01
+ -0.242459134523E-01 -0.245512239492E-01 -0.248603746907E-01 -0.251734139753E-01
+ -0.254903907088E-01 -0.258113544117E-01 -0.261363552271E-01 -0.264654439281E-01
+ -0.267986719262E-01 -0.271360912790E-01 -0.274777546985E-01 -0.278237155589E-01
+ -0.281740279054E-01 -0.285287464623E-01 -0.288879266413E-01 -0.292516245509E-01
+ -0.296198970040E-01 -0.299928015276E-01 -0.303703963714E-01 -0.307527405168E-01
+ -0.311398936861E-01 -0.315319163517E-01 -0.319288697456E-01 -0.323308158688E-01
+ -0.327378175007E-01 -0.331499382092E-01 -0.335672423604E-01 -0.339897951281E-01
+ -0.344176625046E-01 -0.348509113105E-01 -0.352896092047E-01 -0.357338246955E-01
+ -0.361836271507E-01 -0.366390868083E-01 -0.371002747874E-01 -0.375672630993E-01
+ -0.380401246582E-01 -0.385189332924E-01 -0.390037637562E-01 -0.394946917404E-01
+ -0.399917938848E-01 -0.404951477893E-01 -0.410048320259E-01 -0.415209261507E-01
+ -0.420435107162E-01 -0.425726672831E-01 -0.431084784331E-01 -0.436510277812E-01
+ -0.442003999884E-01 -0.447566807744E-01 -0.453199569307E-01 -0.458903163336E-01
+ -0.464678479573E-01 -0.470526418872E-01 -0.476447893336E-01 -0.482443826454E-01
+ -0.488515153231E-01 -0.494662820337E-01 -0.500887786241E-01 -0.507191021352E-01
+ -0.513573508167E-01 -0.520036241409E-01 -0.526580228178E-01 -0.533206488093E-01
+ -0.539916053445E-01 -0.546709969341E-01 -0.553589293859E-01 -0.560555098199E-01
+ -0.567608466833E-01 -0.574750497664E-01 -0.581982302175E-01 -0.589305005592E-01
+ -0.596719747038E-01 -0.604227679690E-01 -0.611829970941E-01 -0.619527802560E-01
+ -0.627322370851E-01 -0.635214886817E-01 -0.643206576320E-01 -0.651298680246E-01
+ -0.659492454670E-01 -0.667789171017E-01 -0.676190116226E-01 -0.684696592919E-01
+ -0.693309919560E-01 -0.702031430627E-01 -0.710862476767E-01 -0.719804424971E-01
+ -0.728858658729E-01 -0.738026578197E-01 -0.747309600362E-01 -0.756709159200E-01
+ -0.766226705836E-01 -0.775863708707E-01 -0.785621653716E-01 -0.795502044388E-01
+ -0.805506402027E-01 -0.815636265861E-01 -0.825893193197E-01 -0.836278759562E-01
+ -0.846794558845E-01 -0.857442203440E-01 -0.868223324372E-01 -0.879139571435E-01
+ -0.890192613313E-01 -0.901384137696E-01 -0.912715851398E-01 -0.924189480463E-01
+ -0.935806770260E-01 -0.947569485579E-01 -0.959479410714E-01 -0.971538349533E-01
+ -0.983748125548E-01 -0.996110581965E-01 -0.100862758173     -0.102130100754
+ -0.103413276190     -0.104712476709     -0.106027896514     -0.107359731785
+ -0.108708180670     -0.110073443280     -0.111455721679     -0.112855219873
+ -0.114272143800     -0.115706701309     -0.117159102146     -0.118629557927
+ -0.120118282120     -0.121625490012     -0.123151398682     -0.124696226959
+ -0.126260195390     -0.127843526193     -0.129446443209     -0.131069171850
+ -0.132711939038     -0.134374973146     -0.136058503923     -0.137762762425
+ -0.139487980923     -0.141234392822     -0.143002232560     -0.144791735500
+ -0.146603137822     -0.148436676394     -0.150292588644     -0.152171112415
+ -0.154072485810     -0.155996947029     -0.157944734188     -0.159916085132
+ -0.161911237227     -0.163930427144     -0.165973890620     -0.168041862210
+ -0.170134575015     -0.172252260400     -0.174395147679     -0.176563463793
+ -0.178757432959     -0.180977276296     -0.183223211426     -0.185495452053
+ -0.187794207507     -0.190119682269     -0.192472075455     -0.194851580272
+ -0.197258383443     -0.199692664589     -0.202154595576     -0.204644339823
+ -0.207162051564     -0.209707875067     -0.212281943807     -0.214884379585
+ -0.217515291596     -0.220174775447     -0.222862912106     -0.225579766798
+ -0.228325387837     -0.231099805382     -0.233903030132     -0.236735051938
+ -0.239595838343     -0.242485333035     -0.245403454217     -0.248350092887
+ -0.251325111019     -0.254328339652     -0.257359576873     -0.260418585689
+ -0.263505091792     -0.266618781205     -0.269759297806     -0.272926240721
+ -0.276119161596     -0.279337561719     -0.282580889008     -0.285848534851
+ -0.289139830793     -0.292454045064     -0.295790378949     -0.299147962986
+ -0.302525852998     -0.305923025944     -0.309338375593     -0.312770708013
+ -0.316218736871     -0.319681078546     -0.323156247042     -0.326642648716
+ -0.330138576799     -0.333642205728     -0.337151585280     -0.340664634507
+ -0.344179135488     -0.347692726884     -0.351202897319     -0.354706978578
+ -0.358202138653     -0.361685374616     -0.365153505370     -0.368603164260
+ -0.372030791591     -0.375432627051     -0.378804702078     -0.382142832206
+ -0.385442609396     -0.388699394421     -0.391908309321     -0.395064229992
+ -0.398161778952     -0.401195318332     -0.404158943186     -0.407046475148
+ -0.409851456550     -0.412567145064     -0.415186508959     -0.417702223091
+ -0.420106665707     -0.422391916207     -0.424549753969     -0.426571658382
+ -0.428448810229     -0.430172094577     -0.431732105329     -0.433119151628
+ -0.434323266274     -0.435334216365     -0.436141516352     -0.436734443717
+ -0.437102057499     -0.437233219873     -0.437116621022     -0.436740807529
+ -0.436094214509     -0.435165201721     -0.433942093877     -0.432413225363
+ -0.430566989584     -0.428391893112     -0.425876614809     -0.423010070066
+ -0.419781480274     -0.416180447581     -0.412197034977     -0.407821851663
+ -0.403046143619     -0.397861889194     -0.392261899484     -0.386239923139
+ -0.379790755167     -0.372910349161     -0.365595932278     -0.357846122125
+ -0.349661044597     -0.341042451528     -0.331993836845     -0.322520549778
+ -0.312629903438     -0.302331276947     -0.291636209088     -0.280558481274
+ -0.269114187460     -0.257321788473     -0.245202148093     -0.232778548118
+ -0.220076679576     -0.207124607224     -0.193952704520     -0.180593556348
+ -0.167081826993     -0.153454091115     -0.139748625904     -0.126005163080
+ -0.112264600104     -0.985686707232E-01 -0.849595759715E-01 -0.714795778608E-01
+ -0.581705592958E-01 -0.450735552161E-01 -0.322282615914E-01 -0.196725306618E-01
+ -0.744186269966E-02  0.443109347224E-02  0.159170169859E-01  0.269903522964E-01
+  0.376296894435E-01  0.478180676608E-01  0.575431815751E-01  0.667974685302E-01
+  0.755780555425E-01  0.838865452193E-01  0.917286218591E-01  0.991134621065E-01
+  0.106052939160      0.112560615826      0.118650529866      0.124335785157
+  0.129626974355      0.134530472804      0.139046659372      0.143168137248
+  0.146878046004      0.150148574673      0.152939803029      0.155199013425
+  0.156860626668      0.157846920428      0.158069685329      0.157432959476
+  0.155836954063      0.153183238181      0.149381187527      0.144355617555
+  0.138055415609      0.130462859095      0.121603159583      0.111553609983
+  0.100451539618      0.885001084240E-01  0.759708064776E-01  0.632013784125E-01
+  0.505877723221E-01  0.385686218730E-01  0.276007013142E-01  0.181237224523E-01
+  0.105127252491E-01  0.501607772190E-02  0.167664925097E-02  0.232945889455E-03
+ -0.418295283160E-05 -0.354734653943E-05 -0.356310058740E-05 -0.358016007697E-05
+ -0.359852965305E-05 -0.361821287242E-05 -0.363921210627E-05 -0.366152849145E-05
+ -0.368516209294E-05 -0.371011193628E-05 -0.373637595073E-05 -0.376395118045E-05
+ -0.379283373572E-05 -0.382301874424E-05 -0.385450064349E-05 -0.388727306699E-05
+ -0.392132893369E-05 -0.395666051288E-05 -0.399325936736E-05 -0.403111669454E-05
+ -0.407022300968E-05 -0.411056859256E-05 -0.415214302458E-05 -0.419493571664E-05
+ -0.423893589284E-05 -0.428413221698E-05 -0.433051328790E-05 -0.437806752578E-05
+ -0.442678317216E-05 -0.447664841983E-05 -0.452765126673E-05 -0.457977992190E-05
+ -0.463302249695E-05 -0.468736722529E-05 -0.474280246213E-05 -0.479931640029E-05
+ -0.485689774418E-05 -0.491553519818E-05 -0.497521769408E-05 -0.503593465088E-05
+ -0.509767596668E-05 -0.516043227857E-05 -0.522419614819E-05 -0.528896991422E-05
+ -0.535468742718E-05 -0.542134331941E-05 -0.548892925930E-05 -0.555743598138E-05
+ -0.562685417955E-05 -0.569717445030E-05 -0.576838757687E-05 -0.584048446431E-05
+ -0.591345622070E-05 -0.598729433575E-05 -0.606199055905E-05 -0.613753692440E-05
+ -0.621392582291E-05 -0.629115005982E-05 -0.636920291137E-05 -0.644807794613E-05
+ -0.652776939855E-05 -0.660827186039E-05 -0.668958068673E-05 -0.677259881903E-05
+ -0.685632197214E-05 -0.694075055208E-05 -0.702588508667E-05 -0.711172645294E-05
+ -0.719827572279E-05 -0.728553425233E-05 -0.737350361695E-05 -0.746218586301E-05
+ -0.755158312618E-05 -0.764169811873E-05 -0.773253373966E-05 -0.782409319657E-05
+ -0.791638011931E-05 -0.800939877925E-05 -0.810315332598E-05 -0.819764876171E-05
+ -0.829289007243E-05 -0.838888289374E-05 -0.848563323481E-05 -0.858314729157E-05
+ -0.868143176344E-05 -0.878049354469E-05 -0.888034013055E-05 -0.898097908930E-05
+ -0.908241834655E-05 -0.918466598218E-05 -0.928773057142E-05 -0.939162070576E-05
+ -0.949634508223E-05 -0.960191256029E-05 -0.970833227549E-05 -0.981561294923E-05
+ -0.992376366834E-05 -0.100327934628E-04 -0.101427109972E-04 -0.102535248467E-04
+ -0.103652434567E-04 -0.104778746634E-04 -0.105914262300E-04 -0.107059051239E-04
+ -0.108213182719E-04 -0.109376714395E-04 -0.110549702543E-04 -0.111732190362E-04
+ -0.112924214315E-04 -0.114125803634E-04 -0.115336976023E-04 -0.116557736516E-04
+ -0.117788079024E-04 -0.119027986735E-04 -0.120277426358E-04 -0.121536349736E-04
+ -0.122804696291E-04 -0.124082388148E-04 -0.125369332165E-04 -0.126665416441E-04
+ -0.127970507638E-04 -0.129284456745E-04 -0.130607091527E-04 -0.131938209376E-04
+ -0.133277584626E-04 -0.134624948974E-04 -0.135980000745E-04 -0.137342386860E-04
+ -0.138711701295E-04 -0.140087465752E-04 -0.141469129338E-04 -0.142856064826E-04
+ -0.144247569632E-04 -0.145642872797E-04 -0.147041149522E-04 -0.148441524094E-04
+ -0.149843092621E-04 -0.151244917837E-04 -0.152646053867E-04 -0.154045517320E-04
+ -0.155442294515E-04 -0.156835334175E-04 -0.158223554568E-04 -0.159605829465E-04
+ -0.160980994467E-04 -0.162347851805E-04 -0.163705147429E-04 -0.165051601877E-04
+ -0.166385878271E-04 -0.167706597511E-04 -0.169012336804E-04 -0.170301617654E-04
+ -0.171572917225E-04 -0.172824660061E-04 -0.174055217761E-04 -0.175262901588E-04
+ -0.176445975870E-04 -0.177602641754E-04 -0.178731037944E-04 -0.179829251497E-04
+ -0.180895296629E-04 -0.181927130549E-04 -0.182922638520E-04 -0.183879640921E-04
+ -0.184795886753E-04 -0.185669053719E-04 -0.186496745381E-04 -0.187276487103E-04
+ -0.188005728887E-04 -0.188681834743E-04 -0.189302097056E-04 -0.189863710684E-04
+ -0.190363793097E-04 -0.190799369112E-04 -0.191167367559E-04 -0.191464634846E-04
+ -0.191687910111E-04 -0.191833841216E-04 -0.191898971512E-04 -0.191879743657E-04
+ -0.191772500995E-04 -0.191573471398E-04 -0.191278783745E-04 -0.190884455752E-04
+ -0.190386389168E-04 -0.189780382535E-04 -0.189062113723E-04 -0.188227165349E-04
+ -0.187270984741E-04 -0.186188927955E-04 -0.184976231675E-04 -0.183628029861E-04
+ -0.182139350743E-04 -0.180505125432E-04 -0.178720178090E-04 -0.176779268486E-04
+ -0.174677051551E-04 -0.172408119689E-04 -0.169967014472E-04 -0.167348216239E-04
+ -0.164546182434E-04 -0.161555359536E-04 -0.158370195485E-04 -0.154985176469E-04
+ -0.151394854697E-04 -0.147593866992E-04 -0.143576992692E-04 -0.139339179798E-04
+ -0.134875604252E-04 -0.130181725727E-04 -0.125253336429E-04 -0.120086672999E-04
+ -0.114678435677E-04 -0.109025945676E-04 -0.103127199915E-04 -0.969810371641E-05
+ -0.905872324048E-05 -0.839466517683E-05 -0.770614610701E-05 -0.699352812360E-05
+ -0.625734008963E-05 -0.549830739211E-05 -0.471737002629E-05 -0.391572366100E-05
+ -0.309484615205E-05 -0.225653899731E-05 -0.140297159338E-05 -0.536727636050E-06
+  0.339139928331E-06  0.122104872194E-05  0.210481952731E-05  0.298560143262E-05
+  0.385778714320E-05  0.471492062713E-05  0.554959279953E-05  0.635332413270E-05
+  0.711643914591E-05  0.782791956258E-05  0.847524594454E-05  0.906386390755E-05
+  0.959868045162E-05  0.100840749724E-04  0.105238970361E-04  0.109214720559E-04
+  0.112795954042E-04  0.116005365222E-04  0.118860311480E-04  0.121372821939E-04
+  0.123549448452E-04  0.125391290940E-04  0.126893849434E-04  0.128046977790E-04
+  0.128834738656E-04  0.129235337373E-04  0.129221046693E-04  0.128758050713E-04
+  0.127806429029E-04  0.126320066199E-04  0.124246575492E-04  0.121527281587E-04
+  0.118097238036E-04  0.113885165466E-04  0.108813512806E-04  0.102798414982E-04
+  0.957497302677E-05  0.875709217293E-05  0.781588674467E-05  0.674033552579E-05
+  0.551863091200E-05  0.413800683776E-05  0.258444257335E-05  0.842093990221E-06
+ -0.110783161387E-05 -0.328950139712E-05 -0.573889613114E-05 -0.852776154911E-05
+ -0.127865366965E-04 -0.166470477844E-04 -0.202163693806E-04 -0.235554062767E-04
+ -0.267087143259E-04 -0.296905384809E-04 -0.325126083486E-04 -0.351845379133E-04
+ -0.377141847788E-04 -0.401079403949E-04 -0.423709528751E-04 -0.445072881478E-04
+ -0.465200155466E-04 -0.484112167425E-04 -0.501819053836E-04 -0.518318515463E-04
+ -0.533592846393E-04 -0.547604470528E-04 -0.560289933235E-04 -0.571551413811E-04
+ -0.581245477308E-04 -0.589167622382E-04 -0.595031410739E-04 -0.598439274313E-04
+ -0.598841410644E-04 -0.595475885510E-04 -0.587278627141E-04 -0.572742365210E-04
+ -0.549679379235E-04 -0.515833070348E-04 -0.466838846478E-04 -0.394218798111E-04
+ -0.278681714576E-04
+ Core charge follows
+   0.00000000000
+ Valence charge follows
+  0.218205357080E-14  0.883834694252E-14  0.201377302231E-13  0.362540271442E-13
+  0.573661697640E-13  0.836583366893E-13  0.115320094910E-12  0.152546545337E-12
+  0.195538472141E-12  0.244502495982E-12  0.299651231245E-12  0.361203447368E-12
+  0.429384234378E-12  0.504425172738E-12  0.586564507620E-12  0.676047327711E-12
+  0.773125748680E-12  0.878059101408E-12  0.991114125119E-12  0.111256516553E-11
+  0.124269437817E-11  0.138179193692E-11  0.153015624806E-11  0.168809416980E-11
+  0.185592123753E-11  0.203396189493E-11  0.222254973107E-11  0.242202772363E-11
+  0.263274848844E-11  0.285507453552E-11  0.308937853172E-11  0.333604357013E-11
+  0.359546344655E-11  0.386804294303E-11  0.415419811882E-11  0.445435660875E-11
+  0.476895792946E-11  0.509845379343E-11  0.544330843117E-11  0.580399892177E-11
+  0.618101553191E-11  0.657486206371E-11  0.698605621149E-11  0.741512992782E-11
+  0.786262979890E-11  0.832911742976E-11  0.881516983929E-11  0.932137986552E-11
+  0.984835658130E-11  0.103967257207E-10  0.109671301166E-10  0.115602301491E-10
+  0.121767042059E-10  0.128172491543E-10  0.134825808257E-10  0.141734345121E-10
+  0.148905654755E-10  0.156347494707E-10  0.164067832813E-10  0.172074852695E-10
+  0.180376959400E-10  0.188982785188E-10  0.197901195460E-10  0.207141294849E-10
+  0.216712433460E-10  0.226624213274E-10  0.236886494711E-10  0.247509403373E-10
+  0.258503336945E-10  0.269878972288E-10  0.281647272701E-10  0.293819495380E-10
+  0.306407199061E-10  0.319422251864E-10  0.332876839333E-10  0.346783472690E-10
+  0.361154997290E-10  0.376004601303E-10  0.391345824614E-10  0.407192567948E-10
+  0.423559102236E-10  0.440460078215E-10  0.457910536275E-10  0.475925916563E-10
+  0.494522069337E-10  0.513715265594E-10  0.533522207965E-10  0.553960041888E-10
+  0.575046367072E-10  0.596799249251E-10  0.619237232236E-10  0.642379350285E-10
+  0.666245140773E-10  0.690854657207E-10  0.716228482556E-10  0.742387742928E-10
+  0.769354121602E-10  0.797149873412E-10  0.825797839500E-10  0.855321462446E-10
+  0.885744801788E-10  0.917092549936E-10  0.949390048489E-10  0.982663304978E-10
+  0.101693901002E-09  0.105224455495E-09  0.108860804982E-09  0.112605834198E-09
+  0.116462503500E-09  0.120433850821E-09  0.124522993659E-09  0.128733131131E-09
+  0.133067546072E-09  0.137529607185E-09  0.142122771253E-09  0.146850585405E-09
+  0.151716689435E-09  0.156724818187E-09  0.161878803994E-09  0.167182579189E-09
+  0.172640178669E-09  0.178255742531E-09  0.184033518773E-09  0.189977866068E-09
+  0.196093256598E-09  0.202384278974E-09  0.208855641221E-09  0.215512173843E-09
+  0.222358832963E-09  0.229400703547E-09  0.236643002707E-09  0.244091083092E-09
+  0.251750436357E-09  0.259626696733E-09  0.267725644675E-09  0.276053210612E-09
+  0.284615478791E-09  0.293418691213E-09  0.302469251676E-09  0.311773729918E-09
+  0.321338865867E-09  0.331171573996E-09  0.341278947794E-09  0.351668264344E-09
+  0.362346989024E-09  0.373322780325E-09  0.384603494789E-09  0.396197192080E-09
+  0.408112140174E-09  0.420356820689E-09  0.432939934347E-09  0.445870406579E-09
+  0.459157393264E-09  0.472810286624E-09  0.486838721262E-09  0.501252580357E-09
+  0.516062002017E-09  0.531277385787E-09  0.546909399333E-09  0.562968985290E-09
+  0.579467368280E-09  0.596416062118E-09  0.613826877196E-09  0.631711928052E-09
+  0.650083641137E-09  0.668954762775E-09  0.688338367331E-09  0.708247865578E-09
+  0.728697013285E-09  0.749699920018E-09  0.771271058167E-09  0.793425272204E-09
+  0.816177788170E-09  0.839544223410E-09  0.863540596551E-09  0.888183337738E-09
+  0.913489299123E-09  0.939475765628E-09  0.966160465977E-09  0.993561584007E-09
+  0.102169777027E-08  0.105058815394E-08  0.108025235498E-08  0.111071049669E-08
+  0.114198321849E-08  0.117409168911E-08  0.120705762005E-08  0.124090327940E-08
+  0.127565150605E-08  0.131132572420E-08  0.134794995829E-08  0.138554884825E-08
+  0.142414766522E-08  0.146377232759E-08  0.150444941747E-08  0.154620619765E-08
+  0.158907062884E-08  0.163307138752E-08  0.167823788409E-08  0.172460028160E-08
+  0.177218951489E-08  0.182103731020E-08  0.187117620537E-08  0.192263957043E-08
+  0.197546162883E-08  0.202967747909E-08  0.208532311714E-08  0.214243545906E-08
+  0.220105236458E-08  0.226121266100E-08  0.232295616786E-08  0.238632372213E-08
+  0.245135720413E-08  0.251809956402E-08  0.258659484902E-08  0.265688823134E-08
+  0.272902603671E-08  0.280305577378E-08  0.287902616416E-08  0.295698717325E-08
+  0.303699004187E-08  0.311908731868E-08  0.320333289342E-08  0.328978203099E-08
+  0.337849140640E-08  0.346951914064E-08  0.356292483737E-08  0.365876962062E-08
+  0.375711617346E-08  0.385802877755E-08  0.396157335382E-08  0.406781750405E-08
+  0.417683055364E-08  0.428868359537E-08  0.440344953427E-08  0.452120313372E-08
+  0.464202106258E-08  0.476598194365E-08  0.489316640326E-08  0.502365712218E-08
+  0.515753888779E-08  0.529489864756E-08  0.543582556395E-08  0.558041107059E-08
+  0.572874893003E-08  0.588093529283E-08  0.603706875818E-08  0.619725043612E-08
+  0.636158401124E-08  0.653017580810E-08  0.670313485818E-08  0.688057296867E-08
+  0.706260479287E-08  0.724934790249E-08  0.744092286171E-08  0.763745330313E-08
+  0.783906600567E-08  0.804589097440E-08  0.825806152247E-08  0.847571435503E-08
+  0.869898965530E-08  0.892803117290E-08  0.916298631429E-08  0.940400623563E-08
+  0.965124593786E-08  0.990486436433E-08  0.101650245008E-07  0.104318934780E-07
+  0.107056426769E-07  0.109864478363E-07  0.112744891637E-07  0.115699514486E-07
+  0.118730241784E-07  0.121839016583E-07  0.125027831327E-07  0.128298729110E-07
+  0.131653804961E-07  0.135095207158E-07  0.138625138584E-07  0.142245858106E-07
+  0.145959682000E-07  0.149768985404E-07  0.153676203812E-07  0.157683834607E-07
+  0.161794438627E-07  0.166010641775E-07  0.170335136673E-07  0.174770684349E-07
+  0.179320115975E-07  0.183986334644E-07  0.188772317197E-07  0.193681116088E-07
+  0.198715861306E-07  0.203879762339E-07  0.209176110191E-07  0.214608279448E-07
+  0.220179730397E-07  0.225894011200E-07  0.231754760123E-07  0.237765707817E-07
+  0.243930679665E-07  0.250253598181E-07  0.256738485472E-07  0.263389465766E-07
+  0.270210767996E-07  0.277206728463E-07  0.284381793547E-07  0.291740522508E-07
+  0.299287590339E-07  0.307027790707E-07  0.314966038957E-07  0.323107375196E-07
+  0.331456967461E-07  0.340020114954E-07  0.348802251376E-07  0.357808948327E-07
+  0.367045918807E-07  0.376519020802E-07  0.386234260951E-07  0.396197798322E-07
+  0.406415948273E-07  0.416895186410E-07  0.427642152653E-07  0.438663655398E-07
+  0.449966675789E-07  0.461558372095E-07  0.473446084199E-07  0.485637338200E-07
+  0.498139851137E-07  0.510961535820E-07  0.524110505799E-07  0.537595080450E-07
+  0.551423790186E-07  0.565605381813E-07  0.580148824005E-07  0.595063312935E-07
+  0.610358278037E-07  0.626043387912E-07  0.642128556399E-07  0.658623948781E-07
+  0.675539988159E-07  0.692887361989E-07  0.710677028775E-07  0.728920224941E-07
+  0.747628471873E-07  0.766813583138E-07  0.786487671890E-07  0.806663158461E-07
+  0.827352778142E-07  0.848569589166E-07  0.870326980891E-07  0.892638682189E-07
+  0.915518770050E-07  0.938981678400E-07  0.963042207148E-07  0.987715531457E-07
+  0.101301721125E-06  0.103896320098E-06  0.106556985958E-06  0.109285396075E-06
+  0.112083270346E-06  0.114952372272E-06  0.117894510063E-06  0.120911537770E-06
+  0.124005356447E-06  0.127177915341E-06  0.130431213117E-06  0.133767299103E-06
+  0.137188274582E-06  0.140696294099E-06  0.144293566818E-06  0.147982357905E-06
+  0.151764989942E-06  0.155643844384E-06  0.159621363056E-06  0.163700049672E-06
+  0.167882471413E-06  0.172171260529E-06  0.176569115989E-06  0.181078805172E-06
+  0.185703165600E-06  0.190445106715E-06  0.195307611701E-06  0.200293739351E-06
+  0.205406625985E-06  0.210649487414E-06  0.216025620951E-06  0.221538407478E-06
+  0.227191313565E-06  0.232987893637E-06  0.238931792203E-06  0.245026746136E-06
+  0.251276587016E-06  0.257685243527E-06  0.264256743916E-06  0.270995218521E-06
+  0.277904902351E-06  0.284990137742E-06  0.292255377076E-06  0.299705185566E-06
+  0.307344244119E-06  0.315177352266E-06  0.323209431163E-06  0.331445526681E-06
+  0.339890812558E-06  0.348550593643E-06  0.357430309218E-06  0.366535536401E-06
+  0.375871993643E-06  0.385445544304E-06  0.395262200329E-06  0.405328126012E-06
+  0.415649641854E-06  0.426233228522E-06  0.437085530910E-06  0.448213362297E-06
+  0.459623708615E-06  0.471323732825E-06  0.483320779402E-06  0.495622378933E-06
+  0.508236252838E-06  0.521170318200E-06  0.534432692727E-06  0.548031699836E-06
+  0.561975873866E-06  0.576273965421E-06  0.590934946853E-06  0.605968017884E-06
+  0.621382611363E-06  0.637188399178E-06  0.653395298315E-06  0.670013477068E-06
+  0.687053361410E-06  0.704525641522E-06  0.722441278496E-06  0.740811511192E-06
+  0.759647863289E-06  0.778962150498E-06  0.798766487967E-06  0.819073297875E-06
+  0.839895317208E-06  0.861245605748E-06  0.883137554250E-06  0.905584892839E-06
+  0.928601699608E-06  0.952202409447E-06  0.976401823085E-06  0.100121511637E-05
+  0.102665784977E-05  0.105274597816E-05  0.107949586076E-05  0.110692427146E-05
+  0.113504840930E-05  0.116388590925E-05  0.119345485327E-05  0.122377378167E-05
+  0.125486170470E-05  0.128673811449E-05  0.131942299729E-05  0.135293684597E-05
+  0.138730067290E-05  0.142253602313E-05  0.145866498789E-05  0.149571021846E-05
+  0.153369494037E-05  0.157264296801E-05  0.161257871952E-05  0.165352723216E-05
+  0.169551417801E-05  0.173856588005E-05  0.178270932877E-05  0.182797219902E-05
+  0.187438286745E-05  0.192197043031E-05  0.197076472171E-05  0.202079633240E-05
+  0.207209662893E-05  0.212469777341E-05  0.217863274370E-05  0.223393535412E-05
+  0.229064027673E-05  0.234878306311E-05  0.240840016672E-05  0.246952896580E-05
+  0.253220778693E-05  0.259647592908E-05  0.266237368839E-05  0.272994238346E-05
+  0.279922438144E-05  0.287026312462E-05  0.294310315784E-05  0.301779015651E-05
+  0.309437095539E-05  0.317289357811E-05  0.325340726740E-05  0.333596251619E-05
+  0.342061109938E-05  0.350740610652E-05  0.359640197531E-05  0.368765452593E-05
+  0.378122099630E-05  0.387716007818E-05  0.397553195425E-05  0.407639833617E-05
+  0.417982250351E-05  0.428586934381E-05  0.439460539359E-05  0.450609888045E-05
+  0.462041976625E-05  0.473763979138E-05  0.485783252025E-05  0.498107338785E-05
+  0.510743974762E-05  0.523701092045E-05  0.536986824507E-05  0.550609512964E-05
+  0.564577710478E-05  0.578900187786E-05  0.593585938880E-05  0.608644186730E-05
+  0.624084389153E-05  0.639916244840E-05  0.656149699535E-05  0.672794952379E-05
+  0.689862462421E-05  0.707362955297E-05  0.725307430086E-05  0.743707166347E-05
+  0.762573731336E-05  0.781918987422E-05  0.801755099694E-05  0.822094543764E-05
+  0.842950113789E-05  0.864334930694E-05  0.886262450622E-05  0.908746473603E-05
+  0.931801152456E-05  0.955441001935E-05  0.979680908111E-05  0.100453613801E-04
+  0.103002234951E-04  0.105615560150E-04  0.108295236435E-04  0.111042953058E-04
+  0.113860442592E-04  0.116749482060E-04  0.119711894097E-04  0.122749548147E-04
+  0.125864361687E-04  0.129058301490E-04  0.132333384917E-04  0.135691681254E-04
+  0.139135313079E-04  0.142666457665E-04  0.146287348433E-04  0.150000276436E-04
+  0.153807591888E-04  0.157711705739E-04  0.161715091293E-04  0.165820285869E-04
+  0.170029892517E-04  0.174346581780E-04  0.178773093503E-04  0.183312238705E-04
+  0.187966901495E-04  0.192740041053E-04  0.197634693667E-04  0.202653974828E-04
+  0.207801081396E-04  0.213079293821E-04  0.218491978441E-04  0.224042589845E-04
+  0.229734673314E-04  0.235571867330E-04  0.241557906175E-04  0.247696622601E-04
+  0.253991950593E-04  0.260447928217E-04  0.267068700561E-04  0.273858522771E-04
+  0.280821763191E-04  0.287962906602E-04  0.295286557574E-04  0.302797443928E-04
+  0.310500420320E-04  0.318400471942E-04  0.326502718364E-04  0.334812417496E-04
+  0.343334969703E-04  0.352075922063E-04  0.361040972778E-04  0.370235975750E-04
+  0.379666945327E-04  0.389340061223E-04  0.399261673627E-04  0.409438308511E-04
+  0.419876673139E-04  0.430583661794E-04  0.441566361734E-04  0.452832059386E-04
+  0.464388246793E-04  0.476242628320E-04  0.488403127655E-04  0.500877895083E-04
+  0.513675315094E-04  0.526804014298E-04  0.540272869702E-04  0.554091017345E-04
+  0.568267861325E-04  0.582813083230E-04  0.597736652003E-04  0.613048834272E-04
+  0.628760205159E-04  0.644881659600E-04  0.661424424223E-04  0.678400069790E-04
+  0.695820524266E-04  0.713698086527E-04  0.732045440769E-04  0.750875671646E-04
+  0.770202280197E-04  0.790039200592E-04  0.810400817772E-04  0.831301986022E-04
+  0.852758048550E-04  0.874784858123E-04  0.897398798850E-04  0.920616809161E-04
+  0.944456406083E-04  0.968935710887E-04  0.994073476201E-04  0.101988911469E-03
+  0.104640272937E-03  0.107363514580E-03  0.110160794602E-03  0.113034350466E-03
+  0.115986502715E-03  0.119019659026E-03  0.122136318508E-03  0.125339076274E-03
+  0.128630628284E-03  0.132013776496E-03  0.135491434347E-03  0.139066632563E-03
+  0.142742525357E-03  0.146522397012E-03  0.150409668892E-03  0.154407906901E-03
+  0.158520829436E-03  0.162752315852E-03  0.167106415487E-03  0.171587357280E-03
+  0.176199560027E-03  0.180947643325E-03  0.185836439235E-03  0.190871004744E-03
+  0.196056635054E-03  0.201398877772E-03  0.206903548067E-03  0.212576744854E-03
+  0.218424868084E-03  0.224454637218E-03  0.230673110968E-03  0.237087708397E-03
+  0.243706231475E-03  0.250536889194E-03  0.257588323353E-03  0.264869636137E-03
+  0.272390419604E-03  0.280160787240E-03  0.288191407701E-03  0.296493540927E-03
+  0.305079076770E-03  0.313960576330E-03  0.323151316199E-03  0.332665335791E-03
+  0.342517488015E-03  0.352723493491E-03  0.363299998591E-03  0.374264637556E-03
+  0.385636098979E-03  0.397434196976E-03  0.409679947353E-03  0.422395649143E-03
+  0.435604971871E-03  0.449333048961E-03  0.463606577707E-03  0.478453926268E-03
+  0.493905248182E-03  0.509992604909E-03  0.526750096968E-03  0.544214004261E-03
+  0.562422936218E-03  0.581417992430E-03  0.601242934501E-03  0.621944369876E-03
+  0.643571948464E-03  0.666178572926E-03  0.689820623547E-03  0.714558198684E-03
+  0.740455371824E-03  0.767580466369E-03  0.796006349336E-03  0.825810745204E-03
+  0.857076571265E-03  0.889892295867E-03  0.924352321065E-03  0.960557391248E-03
+  0.998615029443E-03  0.103864000305E-02  0.108075482093E-02  0.112509026375E-02
+  0.117178594986E-02  0.122099093865E-02  0.127286437407E-02  0.132757617045E-02
+  0.138530774343E-02  0.144625278876E-02  0.151061811164E-02  0.157862450983E-02
+  0.165050771367E-02  0.172651938626E-02  0.180692818730E-02  0.189202090441E-02
+  0.198210365546E-02  0.207750316613E-02  0.217856812674E-02  0.228567063267E-02
+  0.239920771284E-02  0.251960295098E-02  0.264730820436E-02  0.278280542507E-02
+  0.292660858892E-02  0.307926573717E-02  0.324136113662E-02  0.341351756346E-02
+  0.359639871649E-02  0.379071176556E-02  0.399721004088E-02  0.421669586908E-02
+  0.445002356179E-02  0.469810256273E-02  0.496190075879E-02  0.524244796104E-02
+  0.554083956099E-02  0.585824036747E-02  0.619588862916E-02  0.655510024750E-02
+  0.693727318416E-02  0.734389206703E-02  0.777653299777E-02  0.823686856350E-02
+  0.872667305431E-02  0.924782788737E-02  0.980232723722E-02  0.103922838709E-01
+  0.110199351847E-01  0.116876494387E-01  0.123979321816E-01  0.131534328596E-01
+  0.139569515970E-01  0.148114461376E-01  0.157200389298E-01  0.166860243390E-01
+  0.177128759647E-01  0.188042540372E-01  0.199640128674E-01  0.211962083136E-01
+  0.225051052318E-01  0.238951848653E-01  0.253711521281E-01  0.269379427292E-01
+  0.286007300801E-01  0.303649319220E-01  0.322362166019E-01  0.342205089194E-01
+  0.363239954632E-01  0.385531293419E-01  0.409146342138E-01  0.434155075066E-01
+  0.460630227137E-01  0.488647306447E-01  0.518284594989E-01  0.549623136242E-01
+  0.582746708159E-01  0.617741780003E-01  0.654697451446E-01  0.693705372253E-01
+  0.734859640825E-01  0.778256679832E-01  0.823995087120E-01  0.872175460070E-01
+  0.922900191547E-01  0.976273235629E-01  0.103239984130      0.109138625236
+  0.115333937193      0.121836638987      0.128657437195      0.135806980918
+  0.143295812670      0.151134315115      0.159332653623      0.167900714638
+  0.176848039883      0.186183756485      0.195916503142      0.206054352532
+  0.216604730186      0.227574330175      0.238969027959      0.250793790893
+  0.263052586920      0.275748292084      0.288882597583      0.302455917173
+  0.316467295808      0.330914320526      0.345793034631      0.361097856359
+  0.376821503229      0.392954923427      0.409487235542      0.426405678107
+  0.443695570358      0.461340285673      0.479321239144      0.497617890680
+  0.516207765020      0.535066489900      0.554167853552      0.573483882528
+  0.592984940685      0.612639849925      0.632416033085      0.652279679009
+  0.672195929622      0.692129088373      0.712042849145      0.731900544250
+  0.751665409785      0.771300866150      0.790770811144      0.810039922598
+  0.829073967122      0.847840111119      0.866307229906      0.884446210402
+  0.902230242627      0.919635095013      0.936639368400      0.953224723511
+  0.969376076738      0.985081759169       1.00033363400       1.01512716777
+   1.02946145131       1.04333916675       1.05676649762       1.06975297975
+   1.08231129149       1.09445698281       1.10620814361       1.11758501291
+   1.12860953156       1.13930484248       1.14969474355       1.15980309965
+   1.16965322181       1.17926722250       1.18866535755       1.19786536651
+   1.20688182425       1.21572551784       1.22440286351       1.23291537935
+   1.24125922958       1.24942485661       1.25739671660       1.26515313349
+   1.27266628532       1.27990233450       1.28682171128       1.29337955642
+   1.29952632471       1.30520854638       1.31036973770       1.31495144544
+   1.31889440314       1.32213976874       1.32463040542       1.32631215832
+   1.32713507119       1.32705447781       1.32603189443       1.32403563049
+   1.32104102689       1.31703024763       1.31199174437       1.30591986780
+   1.29881469126       1.29068145844       1.28153001198       1.27137411943
+   1.26023078459       1.24811963797       1.23506252071       1.22108338616
+   1.20620849173       1.19046648509       1.17388819715       1.15650658094
+   1.13835657437       1.11947496280       1.09990023968       1.07967245912
+   1.05883308410       1.03742483009       1.01549150501      0.993077846224
+  0.970229355314      0.946992131427      0.923412703942      0.899537865243
+  0.875414504379      0.851089442365      0.826609269886      0.802020188131
+  0.777367853479      0.752697226727      0.728052427509      0.703476594550
+  0.679011752325      0.654698684694      0.630576816006      0.606684100144
+  0.583056917924      0.559729983213      0.536736258091      0.514106877309
+  0.491871082275      0.470056164696      0.448687420002      0.427788110597
+  0.407379438923      0.387480530292      0.368108425355      0.349278082059
+  0.331002386877      0.313292175034      0.296156259433      0.279601467909
+  0.263632688437      0.248252921828      0.233463341461      0.219263359536
+  0.205650699309      0.192621472753      0.180170263061      0.168290211380
+  0.156973107180      0.146209481617      0.135988703278      0.126299075666
+  0.117127935822      0.108461753449      0.100286229963      0.925863968660E-01
+  0.853467129073E-01  0.785511594760E-01  0.721833337398E-01  0.662265390490E-01
+  0.606638721765E-01  0.554783069940E-01  0.506527742316E-01  0.461702370052E-01
+  0.420137618445E-01  0.381665849940E-01  0.346121738105E-01  0.313342831191E-01
+  0.283170064405E-01  0.255448220412E-01  0.230026338038E-01  0.206758069529E-01
+  0.185501987131E-01  0.166121840092E-01  0.148486763543E-01  0.132471440999E-01
+  0.117956222516E-01  0.104827200753E-01  0.929762474239E-02  0.823010127641E-02
+  0.727048907840E-02  0.640969531881E-02  0.563918548878E-02  0.495097140771E-02
+  0.433759698379E-02  0.379212202107E-02  0.330810436104E-02  0.287958063821E-02
+  0.250104591883E-02  0.216743247913E-02  0.187408796549E-02  0.161675316300E-02
+  0.139153958242E-02  0.119490705773E-02  0.102364152852E-02  0.874833162971E-03
+  0.745854958708E-03  0.634341940766E-03  0.538171057896E-03  0.455441861364E-03
+  0.384458033919E-03  0.323709821068E-03  0.271857402298E-03  0.227715226463E-03
+  0.190237323320E-03  0.158503592157E-03  0.131707058673E-03  0.109142082654E-03
+  0.901934916504E-04  0.743266096318E-04  0.610781445134E-04  0.500478944212E-04
+  0.408912295123E-04  0.333123040336E-04  0.270579519886E-04  0.219122192079E-04
+  0.176914846995E-04  0.142401247963E-04  0.114266747434E-04  0.914044389205E-05
+  0.728854251071E-05  0.579328032165E-05  0.458989915183E-05  0.362460449138E-05
+  0.285286322981E-05  0.223793734101E-05  0.174962577215E-05  0.136318922715E-05
+  0.105843489122E-05  0.818940399712E-06  0.631398493160E-06  0.485065809091E-06
+  0.371301132008E-06  0.283180151183E-06  0.215175360390E-06  0.162891175869E-06
+  0.122845652424E-06  0.922913479024E-07  0.690689303119E-07  0.514880471366E-07
+  0.382307915679E-07  0.282738140435E-07  0.208257486691E-07  0.152771615823E-07
+  0.111606907021E-07  0.811944181403E-08  0.588204232549E-08  0.424303852184E-08
+  0.304756142062E-08  0.217938643248E-08  0.155167847537E-08  0.109985185347E-08
+  0.776087459418E-09  0.545142476389E-09  0.381163188523E-09  0.265272305531E-09
+  0.183751644343E-09  0.126679728079E-09  0.869154743275E-10  0.593443633999E-10
+  0.403209900601E-10  0.272602099494E-10  0.183379129308E-10  0.122735237540E-10
+  0.817265755314E-11  0.541387153486E-11  0.356762233549E-11  0.233857577687E-11
+  0.152475720210E-11  0.988783692304E-12  0.637716378464E-12  0.409028399252E-12
+  0.260887046880E-12  0.165461848016E-12  0.104342739022E-12  0.654211037247E-13
+  0.407790000074E-13  0.252690935717E-13  0.155649581327E-13  0.952975518963E-14
+  0.579910239797E-14  0.350714924637E-14  0.210780662743E-14  0.125880466193E-14
+  0.746972082064E-15  0.440388128497E-15  0.257939669306E-15  0.150078126824E-15
+  0.867357465368E-16  0.497879591174E-16  0.283830663352E-16  0.160681415303E-16
+  0.903244125002E-17  0.504125716860E-17  0.279336086520E-17  0.153648813591E-17
+  0.838888131279E-18  0.454579092731E-18  0.244457026062E-18  0.130448631855E-18
+  0.690678497168E-19  0.362799259249E-19  0.189044795974E-19  0.977066113097E-20
+  0.500836831610E-20  0.254585128107E-20  0.128317186980E-20  0.641211669789E-21
+  0.317637483423E-21  0.155963858567E-21  0.758971471742E-22  0.366001411776E-22
+  0.174880620766E-22  0.827841589419E-23  0.388189394153E-23  0.180291161511E-23
+  0.829243870075E-24  0.377667076900E-24  0.170292773915E-24  0.760123247483E-25
+  0.335824392499E-25  0.146831715964E-25  0.635250733127E-26  0.271910298088E-26
+  0.115132543781E-26  0.482168192254E-27  0.199692770967E-27  0.817756564030E-28
+  0.331068214747E-28  0.132487769941E-28  0.524000022657E-29  0.204793251906E-29
+  0.790787238527E-30  0.301643121851E-30  0.113643941640E-30  0.422811491301E-31
+  0.155318314070E-31  0.563249623111E-32  0.201607956546E-32  0.712144763547E-33
+  0.248203144240E-33  0.853391526051E-34  0.289410479818E-34  0.967892271989E-35
+  0.319159457140E-35  0.103747235406E-35  0.332393678114E-36  0.104943308848E-36
+  0.326437437888E-37  0.100024148019E-37  0.301845686042E-38  0.896922330525E-39
+  0.262378348240E-39  0.755469568916E-40  0.214058897503E-40  0.596743064535E-41
+  0.163639695415E-41  0.441311712921E-42  0.117021318437E-42  0.305037605429E-43
+  0.781475993611E-44  0.196723217958E-44  0.486492355661E-45  0.118162146865E-45
+  0.281814295338E-46  0.659825504775E-47  0.151626297898E-47  0.341897562585E-48
+  0.756291044167E-49  0.164076947039E-49  0.349031586485E-50  0.727833533519E-51
+  0.148744138640E-51  0.297835951488E-52  0.584159571534E-53  0.112199083435E-53
+  0.210977200104E-54  0.388287792148E-55  0.699239881953E-56  0.123178153131E-56
+  0.212205082279E-57  0.357412949439E-58  0.588375179423E-59  0.946416334960E-60
+  0.148706781918E-60  0.228169537004E-61  0.341790941758E-62  0.499921918709E-63
+  0.711382638320E-64  0.958411736588E-65  0.125905552500E-65  0.161229212908E-66
+  0.201191273636E-67
Added: SwiftApps/ematter/workflow-run/N.psf
--- SwiftApps/ematter/workflow-run/N.psf	                        (rev 0)
+++ SwiftApps/ematter/workflow-run/N.psf	2015-01-27 22:12:52 UTC (rev 8376)
@@ -0,0 +1,1800 @@
+  N ca nrl nc
+ ATM3       3-OCT-14 Troullier-Martins
+ 2s 2.00  r= 1.48/2p 3.00  r= 1.48/3d 0.00  r= 1.48/4f 0.00  r= 1.48/
+   4  0 1018  0.354107453809E-03  0.125000000000E-01   5.00000000000
+ Radial grid follows
+  0.445412344792E-05  0.896427287179E-05  0.135311529916E-04  0.181554773917E-04
+  0.228379686322E-04  0.275793583619E-04  0.323803874325E-04  0.372418060146E-04
+  0.421643737147E-04  0.471488596942E-04  0.521960427889E-04  0.573067116317E-04
+  0.624816647748E-04  0.677217108153E-04  0.730276685210E-04  0.784003669585E-04
+  0.838406456230E-04  0.893493545690E-04  0.949273545435E-04  0.100575517120E-03
+  0.106294724837E-03  0.112085871330E-03  0.117949861479E-03  0.123887611544E-03
+  0.129900049310E-03  0.135988114233E-03  0.142152757586E-03  0.148394942607E-03
+  0.154715644649E-03  0.161115851336E-03  0.167596562712E-03  0.174158791402E-03
+  0.180803562768E-03  0.187531915069E-03  0.194344899623E-03  0.201243580973E-03
+  0.208229037052E-03  0.215302359352E-03  0.222464653093E-03  0.229717037400E-03
+  0.237060645471E-03  0.244496624760E-03  0.252026137154E-03  0.259650359155E-03
+  0.267370482063E-03  0.275187712163E-03  0.283103270913E-03  0.291118395135E-03
+  0.299234337209E-03  0.307452365267E-03  0.315773763392E-03  0.324199831821E-03
+  0.332731887143E-03  0.341371262509E-03  0.350119307840E-03  0.358977390035E-03
+  0.367946893187E-03  0.377029218801E-03  0.386225786007E-03  0.395538031788E-03
+  0.404967411201E-03  0.414515397606E-03  0.424183482896E-03  0.433973177728E-03
+  0.443886011762E-03  0.453923533898E-03  0.464087312520E-03  0.474378935739E-03
+  0.484800011642E-03  0.495352168544E-03  0.506037055239E-03  0.516856341264E-03
+  0.527811717154E-03  0.538904894709E-03  0.550137607260E-03  0.561511609941E-03
+  0.573028679965E-03  0.584690616895E-03  0.596499242934E-03  0.608456403203E-03
+  0.620563966033E-03  0.632823823255E-03  0.645237890498E-03  0.657808107484E-03
+  0.670536438335E-03  0.683424871878E-03  0.696475421959E-03  0.709690127751E-03
+  0.723071054080E-03  0.736620291742E-03  0.750339957833E-03  0.764232196080E-03
+  0.778299177172E-03  0.792543099104E-03  0.806966187518E-03  0.821570696051E-03
+  0.836358906686E-03  0.851333130112E-03  0.866495706082E-03  0.881849003779E-03
+  0.897395422187E-03  0.913137390466E-03  0.929077368330E-03  0.945217846433E-03
+  0.961561346757E-03  0.978110423009E-03  0.994867661014E-03  0.101183567913E-02
+  0.102901712863E-02  0.104641469417E-02  0.106403109413E-02  0.108186908114E-02
+  0.109993144240E-02  0.111822100019E-02  0.113674061230E-02  0.115549317246E-02
+  0.117448161078E-02  0.119370889425E-02  0.121317802718E-02  0.123289205165E-02
+  0.125285404803E-02  0.127306713541E-02  0.129353447213E-02  0.131425925625E-02
+  0.133524472606E-02  0.135649416059E-02  0.137801088010E-02  0.139979824663E-02
+  0.142185966449E-02  0.144419858082E-02  0.146681848614E-02  0.148972291483E-02
+  0.151291544577E-02  0.153639970284E-02  0.156017935550E-02  0.158425811936E-02
+  0.160863975679E-02  0.163332807747E-02  0.165832693899E-02  0.168364024748E-02
+  0.170927195819E-02  0.173522607613E-02  0.176150665669E-02  0.178811780626E-02
+  0.181506368288E-02  0.184234849691E-02  0.186997651165E-02  0.189795204403E-02
+  0.192627946529E-02  0.195496320164E-02  0.198400773499E-02  0.201341760358E-02
+  0.204319740279E-02  0.207335178576E-02  0.210388546417E-02  0.213480320898E-02
+  0.216610985114E-02  0.219781028238E-02  0.222990945596E-02  0.226241238744E-02
+  0.229532415547E-02  0.232864990257E-02  0.236239483598E-02  0.239656422839E-02
+  0.243116341885E-02  0.246619781355E-02  0.250167288668E-02  0.253759418131E-02
+  0.257396731019E-02  0.261079795672E-02  0.264809187575E-02  0.268585489453E-02
+  0.272409291361E-02  0.276281190777E-02  0.280201792691E-02  0.284171709707E-02
+  0.288191562132E-02  0.292261978075E-02  0.296383593548E-02  0.300557052562E-02
+  0.304783007228E-02  0.309062117859E-02  0.313395053077E-02  0.317782489910E-02
+  0.322225113904E-02  0.326723619229E-02  0.331278708786E-02  0.335891094316E-02
+  0.340561496513E-02  0.345290645138E-02  0.350079279131E-02  0.354928146723E-02
+  0.359838005562E-02  0.364809622822E-02  0.369843775329E-02  0.374941249680E-02
+  0.380102842364E-02  0.385329359892E-02  0.390621618917E-02  0.395980446366E-02
+  0.401406679567E-02  0.406901166379E-02  0.412464765327E-02  0.418098345734E-02
+  0.423802787860E-02  0.429578983035E-02  0.435427833801E-02  0.441350254052E-02
+  0.447347169180E-02  0.453419516214E-02  0.459568243971E-02  0.465794313203E-02
+  0.472098696744E-02  0.478482379668E-02  0.484946359439E-02  0.491491646065E-02
+  0.498119262263E-02  0.504830243609E-02  0.511625638710E-02  0.518506509358E-02
+  0.525473930704E-02  0.532528991422E-02  0.539672793880E-02  0.546906454310E-02
+  0.554231102988E-02  0.561647884404E-02  0.569157957445E-02  0.576762495577E-02
+  0.584462687023E-02  0.592259734953E-02  0.600154857674E-02  0.608149288813E-02
+  0.616244277516E-02  0.624441088643E-02  0.632741002961E-02  0.641145317350E-02
+  0.649655344999E-02  0.658272415619E-02  0.666997875644E-02  0.675833088446E-02
+  0.684779434543E-02  0.693838311821E-02  0.703011135748E-02  0.712299339597E-02
+  0.721704374667E-02  0.731227710515E-02  0.740870835182E-02  0.750635255425E-02
+  0.760522496955E-02  0.770534104673E-02  0.780671642914E-02  0.790936695688E-02
+  0.801330866931E-02  0.811855780754E-02  0.822513081695E-02  0.833304434979E-02
+  0.844231526778E-02  0.855296064472E-02  0.866499776916E-02  0.877844414715E-02
+  0.889331750490E-02  0.900963579162E-02  0.912741718227E-02  0.924668008044E-02
+  0.936744312119E-02  0.948972517400E-02  0.961354534568E-02  0.973892298339E-02
+  0.986587767765E-02  0.999442926537E-02  0.101245978330E-01  0.102564037197E-01
+  0.103898675203E-01  0.105250100888E-01  0.106618525417E-01  0.108004162606E-01
+  0.109407228966E-01  0.110827943729E-01  0.112266528883E-01  0.113723209210E-01
+  0.115198212321E-01  0.116691768687E-01  0.118204111679E-01  0.119735477604E-01
+  0.121286105741E-01  0.122856238379E-01  0.124446120855E-01  0.126056001590E-01
+  0.127686132132E-01  0.129336767191E-01  0.131008164684E-01  0.132700585770E-01
+  0.134414294892E-01  0.136149559821E-01  0.137906651696E-01  0.139685845066E-01
+  0.141487417933E-01  0.143311651798E-01  0.145158831700E-01  0.147029246265E-01
+  0.148923187748E-01  0.150840952083E-01  0.152782838924E-01  0.154749151694E-01
+  0.156740197634E-01  0.158756287849E-01  0.160797737357E-01  0.162864865138E-01
+  0.164957994187E-01  0.167077451557E-01  0.169223568420E-01  0.171396680109E-01
+  0.173597126178E-01  0.175825250452E-01  0.178081401079E-01  0.180365930587E-01
+  0.182679195939E-01  0.185021558587E-01  0.187393384531E-01  0.189795044371E-01
+  0.192226913374E-01  0.194689371523E-01  0.197182803583E-01  0.199707599157E-01
+  0.202264152750E-01  0.204852863828E-01  0.207474136883E-01  0.210128381494E-01
+  0.212816012393E-01  0.215537449526E-01  0.218293118125E-01  0.221083448767E-01
+  0.223908877448E-01  0.226769845647E-01  0.229666800396E-01  0.232600194350E-01
+  0.235570485857E-01  0.238578139033E-01  0.241623623828E-01  0.244707416105E-01
+  0.247829997715E-01  0.250991856566E-01  0.254193486705E-01  0.257435388394E-01
+  0.260718068187E-01  0.264042039008E-01  0.267407820234E-01  0.270815937777E-01
+  0.274266924162E-01  0.277761318611E-01  0.281299667131E-01  0.284882522597E-01
+  0.288510444837E-01  0.292184000721E-01  0.295903764249E-01  0.299670316643E-01
+  0.303484246434E-01  0.307346149555E-01  0.311256629438E-01  0.315216297103E-01
+  0.319225771255E-01  0.323285678384E-01  0.327396652857E-01  0.331559337024E-01
+  0.335774381313E-01  0.340042444331E-01  0.344364192973E-01  0.348740302521E-01
+  0.353171456751E-01  0.357658348040E-01  0.362201677474E-01  0.366802154956E-01
+  0.371460499322E-01  0.376177438446E-01  0.380953709361E-01  0.385790058368E-01
+  0.390687241156E-01  0.395646022921E-01  0.400667178482E-01  0.405751492405E-01
+  0.410899759124E-01  0.416112783067E-01  0.421391378779E-01  0.426736371051E-01
+  0.432148595049E-01  0.437628896445E-01  0.443178131546E-01  0.448797167432E-01
+  0.454486882089E-01  0.460248164545E-01  0.466081915014E-01  0.471989045031E-01
+  0.477970477596E-01  0.484027147320E-01  0.490160000572E-01  0.496369995621E-01
+  0.502658102791E-01  0.509025304613E-01  0.515472595975E-01  0.522000984278E-01
+  0.528611489598E-01  0.535305144838E-01  0.542082995896E-01  0.548946101825E-01
+  0.555895535000E-01  0.562932381283E-01  0.570057740196E-01  0.577272725091E-01
+  0.584578463324E-01  0.591976096431E-01  0.599466780308E-01  0.607051685389E-01
+  0.614731996830E-01  0.622508914698E-01  0.630383654149E-01  0.638357445629E-01
+  0.646431535059E-01  0.654607184032E-01  0.662885670009E-01  0.671268286520E-01
+  0.679756343368E-01  0.688351166827E-01  0.697054099856E-01  0.705866502307E-01
+  0.714789751135E-01  0.723825240616E-01  0.732974382563E-01  0.742238606549E-01
+  0.751619360128E-01  0.761118109060E-01  0.770736337546E-01  0.780475548453E-01
+  0.790337263553E-01  0.800323023758E-01  0.810434389363E-01  0.820672940291E-01
+  0.831040276336E-01  0.841538017414E-01  0.852167803821E-01  0.862931296480E-01
+  0.873830177210E-01  0.884866148983E-01  0.896040936193E-01  0.907356284922E-01
+  0.918813963216E-01  0.930415761362E-01  0.942163492163E-01  0.954058991227E-01
+  0.966104117250E-01  0.978300752306E-01  0.990650802146E-01  0.100315619649
+  0.101581888933      0.102864085924      0.104162410967      0.105477066929
+  0.106808259228      0.108156195864      0.109521087456      0.110903147271
+  0.112302591258      0.113719638083      0.115154509164      0.116607428700
+  0.118078623715      0.119568324085      0.121076762578      0.122604174893
+  0.124150799689      0.125716878630      0.127302656419      0.128908380837
+  0.130534302782      0.132180676307      0.133847758662      0.135535810332
+  0.137245095078      0.138975879979      0.140728435474      0.142503035403
+  0.144299957052      0.146119481193      0.147961892129      0.149827477743
+  0.151716529534      0.153629342673      0.155566216038      0.157527452271
+  0.159513357819      0.161524242984      0.163560421971      0.165622212936
+  0.167709938039      0.169823923491      0.171964499606      0.174132000855
+  0.176326765913      0.178549137716      0.180799463516      0.183078094930
+  0.185385387999      0.187721703242      0.190087405712      0.192482865057
+  0.194908455571      0.197364556258      0.199851550888      0.202369828060
+  0.204919781258      0.207501808920      0.210116314492      0.212763706495
+  0.215444398590      0.218158809641      0.220907363780      0.223690490473
+  0.226508624591      0.229362206473      0.232251681996      0.235177502646
+  0.238140125590      0.241140013743      0.244177635844      0.247253466527
+  0.250367986398      0.253521682105      0.256715046422      0.259948578316
+  0.263222783035      0.266538172179      0.269895263785      0.273294582405
+  0.276736659190      0.280222031970      0.283751245344      0.287324850756
+  0.290943406591      0.294607478256      0.298317638268      0.302074466348
+  0.305878549508      0.309730482144      0.313630866128      0.317580310902
+  0.321579433577      0.325628859022      0.329729219969      0.333881157107
+  0.338085319185      0.342342363113      0.346652954061      0.351017765569
+  0.355437479646      0.359912786883      0.364444386555      0.369032986734
+  0.373679304398      0.378384065544      0.383148005299      0.387971868040
+  0.392856407505      0.397802386913      0.402810579083      0.407881766555
+  0.413016741714      0.418216306908      0.423481274582      0.428812467396
+  0.434210718360      0.439676870963      0.445211779301      0.450816308216
+  0.456491333426      0.462237741666      0.468056430823      0.473948310080
+  0.479914300055      0.485955332945      0.492072352675      0.498266315041
+  0.504538187862      0.510888951132      0.517319597170      0.523831130778
+  0.530424569395      0.537100943260      0.543861295571      0.550706682646
+  0.557638174090      0.564656852963      0.571763815949      0.578960173524
+  0.586247050134      0.593625584368      0.601096929138      0.608662251856
+  0.616322734619      0.624079574393      0.631933983201      0.639887188309
+  0.647940432422      0.656094973876      0.664352086834      0.672713061488
+  0.681179204256      0.689751837991      0.698432302183      0.707221953174
+  0.716122164364      0.725134326429      0.734259847538      0.743500153572
+  0.752856688347      0.762330913842      0.771924310424      0.781638377079
+  0.791474631650      0.801434611074      0.811519871616      0.821731989118
+  0.832072559246      0.842543197735      0.853145540642      0.863881244605
+  0.874751987101      0.885759466704      0.896905403356      0.908191538632
+  0.919619636014      0.931191481165      0.942908882209      0.954773670015
+  0.966787698479      0.978952844818      0.991271009860       1.00374411834
+   1.01637411922       1.02916298595       1.04211271682       1.05522533525
+   1.06850289012       1.08194745607       1.09556113383       1.10934605059
+   1.12330436025       1.13743824384       1.15174990979       1.16624159434
+   1.18091556184       1.19577410514       1.21081954589       1.22605423500
+   1.24148055290       1.25710091000       1.27291774700       1.28893353532
+   1.30515077746       1.32157200739       1.33819979097       1.35503672631
+   1.37208544423       1.38934860863       1.40682891690       1.42452910038
+   1.44245192476       1.46060019052       1.47897673336       1.49758442465
+   1.51642617189       1.53550491913       1.55482364747       1.57438537549
+   1.59419315977       1.61425009530       1.63455931602       1.65512399529
+   1.67594734638       1.69703262299       1.71838311972       1.74000217265
+   1.76189315978       1.78405950163       1.80650466174       1.82923214721
+   1.85224550926       1.87554834376       1.89914429184       1.92303704040
+   1.94723032275       1.97172791913       1.99653365733       2.02165141331
+   2.04708511177       2.07283872677       2.09891628237       2.12532185324
+   2.15205956531       2.17913359638       2.20654817685       2.23430759029
+   2.26241617416       2.29087832050       2.31969847656       2.34888114556
+   2.37843088735       2.40835231913       2.43865011619       2.46932901263
+   2.50039380207       2.53184933847       2.56370053680       2.59595237390
+   2.62860988916       2.66167818539       2.69516242958       2.72906785372
+   2.76339975559       2.79816349963       2.83336451774       2.86900831014
+   2.90510044627       2.94164656557       2.97865237847       3.01612366719
+   3.05406628671       3.09248616562       3.13138930712       3.17078178989
+   3.21066976911       3.25105947734       3.29195722555       3.33336940411
+   3.37530248375       3.41776301660       3.46075763720       3.50429306356
+   3.54837609817       3.59301362909       3.63821263103       3.68398016643
+   3.73032338655       3.77724953263       3.82476593695       3.87288002407
+   3.92159931190       3.97093141293       4.02088403540       4.07146498451
+   4.12268216364       4.17454357558       4.22705732377       4.28023161360
+   4.33407475366       4.38859515705       4.44380134268       4.49970193665
+   4.55630567353       4.61362139778       4.67165806508       4.73042474379
+   4.78993061632       4.85018498058       4.91119725145       4.97297696220
+   5.03553376606       5.09887743764       5.16301787452       5.22796509879
+   5.29372925856       5.36032062963       5.42774961704       5.49602675669
+   5.56516271704       5.63516830072       5.70605444624       5.77783222970
+   5.85051286653       5.92410771324       5.99862826915       6.07408617827
+   6.15049323104       6.22786136622       6.30620267274       6.38552939159
+   6.46585391773       6.54718880202       6.62954675322       6.71294063991
+   6.79738349257       6.88288850556       6.96946903921       7.05713862191
+   7.14591095220       7.23579990095       7.32681951349       7.41898401181
+   7.51230779680       7.60680545051       7.70249173837       7.79938161157
+   7.89749020934       7.99683286135       8.09742509010       8.19928261332
+   8.30242134647       8.40685740517       8.51260710777       8.61968697788
+   8.72811374695       8.83790435688       8.94907596268       9.06164593514
+   9.17563186353       9.29105155841       9.40792305432       9.52626461268
+   9.64609472460       9.76743211377       9.89029573941       10.0147047992
+   10.1406787324       10.2682372225       10.3974002009       10.5281878496
+   10.6606206044       10.7947191582       10.9305044642       11.0679977390
+   11.2072204663       11.3481944000       11.4909415675       11.6354842733
+   11.7818451025       11.9300469243       12.0801128955       12.2320664643
+   12.3859313737       12.5417316654       12.6994916835       12.8592360783
+   13.0209898103       13.1847781538       13.3506267010       13.5185613661
+   13.6886083893       13.8607943407       14.0351461247       14.2116909843
+   14.3904565047       14.5714706186       14.7547616098       14.9403581178
+   15.1282891426       15.3185840486       15.5112725698       15.7063848143
+   15.9039512687       16.1040028031       16.3065706761       16.5116865393
+   16.7193824424       16.9296908384       17.1426445883       17.3582769667
+   17.5766216664       17.7977128044       18.0215849266       18.2482730134
+   18.4778124853       18.7102392084       18.9455894997       19.1839001333
+   19.4252083456       19.6695518415       19.9169688003       20.1674978813
+   20.4211782302       20.6780494851       20.9381517827       21.2015257643
+   21.4682125829       21.7382539086       22.0116919361       22.2885693906
+   22.5689295347       22.8528161753       23.1402736703       23.4313469354
+   23.7260814515       24.0245232714       24.3267190273       24.6327159378
+   24.9425618157       25.2563050749       25.5739947385       25.8956804461
+   26.2214124619       26.5512416820       26.8852196429       27.2233985295
+   27.5658311828       27.9125711086       28.2636724858       28.6191901747
+   28.9791797255       29.3436973875       29.7128001173       30.0865455878
+   30.4649921976       30.8481990798       31.2362261111       31.6291339217
+   32.0269839041       32.4298382233       32.8377598260       33.2508124508
+   33.6690606380       34.0925697398       34.5214059303       34.9556362160
+   35.3953284463       35.8405513241       36.2913744162       36.7478681648
+   37.2101038979       37.6781538407       38.1520911270       38.6319898106
+   39.1179248764       39.6099722530       40.1082088236       40.6127124388
+   41.1235619283       41.6408371133       42.1646188192       42.6949888878
+   43.2320301907       43.7758266416       44.3264632098       44.8840259334
+   45.4486019326       46.0202794238       46.5991477325       47.1852973082
+   47.7788197380       48.3798077608       48.9883552824       49.6045573895
+   50.2285103650       50.8603117027       51.5000601229       52.1478555876
+   52.8037993162       53.4679938012       54.1405428243       54.8215514727
+   55.5111261554       56.2093746198       56.9164059688       57.6323306772
+   58.3572606099       59.0913090387       59.8345906600       60.5872216132
+   61.3493194984       62.1210033949       62.9023938799       63.6936130472
+   64.4947845265       65.3060335024       66.1274867342       66.9592725757
+   67.8015209952       68.6543635955       69.5179336352       70.3923660487
+   71.2777974680       72.1743662435       73.0822124659       74.0014779880
+   74.9323064470       75.8748432865       76.8292357801       77.7956330534
+   78.7741861080       79.7650478447       80.7683730878       81.7843186088
+   82.8130431513       83.8547074556       84.9094742840       85.9775084457
+   87.0589768234       88.1540483987       89.2628942787       90.3856877229
+   91.5226041700       92.6738212655       93.8395188895       95.0198791846
+   96.2150865844       97.4253278426       98.6507920619       99.8916707234
+   101.148157717       102.420449371       103.708744485       105.013244356
+   106.334152815       107.671676257       109.026023674       110.397406683
+   111.786039568       113.192139303       114.615925596       116.057620916
+   117.517450531       118.995642542
+ Down Pseudopotential follows (l on next line)
+  0
+ -0.445314418875E-04 -0.896230203555E-04 -0.135281781051E-03 -0.181514858245E-03
+ -0.228329475945E-03 -0.275732949026E-03 -0.323732684373E-03 -0.372336182036E-03
+ -0.421551036406E-03 -0.471384937398E-03 -0.521845671654E-03 -0.572941123760E-03
+ -0.624679277477E-03 -0.677068216991E-03 -0.730116128170E-03 -0.783831299852E-03
+ -0.838222125131E-03 -0.893297102676E-03 -0.949064838055E-03 -0.100553404508E-02
+ -0.106271354716E-02 -0.112061227871E-02 -0.117923928651E-02 -0.123860373113E-02
+ -0.129871488837E-02 -0.135958215071E-02 -0.142121502877E-02 -0.148362315280E-02
+ -0.154681627417E-02 -0.161080426692E-02 -0.167559712928E-02 -0.174120498526E-02
+ -0.180763808619E-02 -0.187490681235E-02 -0.194302167461E-02 -0.201199331602E-02
+ -0.208183251351E-02 -0.215255017958E-02 -0.222415736398E-02 -0.229666525544E-02
+ -0.237008518344E-02 -0.244442861996E-02 -0.251970718128E-02 -0.259593262979E-02
+ -0.267311687585E-02 -0.275127197959E-02 -0.283041015288E-02 -0.291054376118E-02
+ -0.299168532547E-02 -0.307384752425E-02 -0.315704319548E-02 -0.324128533859E-02
+ -0.332658711655E-02 -0.341296185787E-02 -0.350042305871E-02 -0.358898438502E-02
+ -0.367865967460E-02 -0.376946293935E-02 -0.386140836738E-02 -0.395451032528E-02
+ -0.404878336035E-02 -0.414424220285E-02 -0.424090176834E-02 -0.433877715998E-02
+ -0.443788367092E-02 -0.453823678664E-02 -0.463985218743E-02 -0.474274575079E-02
+ -0.484693355395E-02 -0.495243187633E-02 -0.505925720216E-02 -0.516742622298E-02
+ -0.527695584029E-02 -0.538786316818E-02 -0.550016553599E-02 -0.561388049106E-02
+ -0.572902580143E-02 -0.584561945861E-02 -0.596367968044E-02 -0.608322491389E-02
+ -0.620427383797E-02 -0.632684536661E-02 -0.645095865167E-02 -0.657663308590E-02
+ -0.670388830596E-02 -0.683274419552E-02 -0.696322088832E-02 -0.709533877138E-02
+ -0.722911848812E-02 -0.736458094163E-02 -0.750174729791E-02 -0.764063898919E-02
+ -0.778127771727E-02 -0.792368545694E-02 -0.806788445934E-02 -0.821389725554E-02
+ -0.836174665996E-02 -0.851145577401E-02 -0.866304798964E-02 -0.881654699304E-02
+ -0.897197676832E-02 -0.912936160127E-02 -0.928872608311E-02 -0.945009511440E-02
+ -0.961349390888E-02 -0.977894799742E-02 -0.994648323202E-02 -0.101161257898E-01
+ -0.102879021773E-01 -0.104618392342E-01 -0.106379641379E-01 -0.108163044076E-01
+ -0.109968879087E-01 -0.111797428569E-01 -0.113648978231E-01 -0.115523817372E-01
+ -0.117422238933E-01 -0.119344539536E-01 -0.121291019536E-01 -0.123261983066E-01
+ -0.125257738084E-01 -0.127278596419E-01 -0.129324873826E-01 -0.131396890028E-01
+ -0.133494968771E-01 -0.135619437873E-01 -0.137770629273E-01 -0.139948879088E-01
+ -0.142154527661E-01 -0.144387919614E-01 -0.146649403906E-01 -0.148939333884E-01
+ -0.151258067338E-01 -0.153605966560E-01 -0.155983398396E-01 -0.158390734308E-01
+ -0.160828350430E-01 -0.163296627624E-01 -0.165795951546E-01 -0.168326712699E-01
+ -0.170889306499E-01 -0.173484133334E-01 -0.176111598629E-01 -0.178772112906E-01
+ -0.181466091853E-01 -0.184193956383E-01 -0.186956132704E-01 -0.189753052384E-01
+ -0.192585152418E-01 -0.195452875298E-01 -0.198356669081E-01 -0.201296987458E-01
+ -0.204274289825E-01 -0.207289041358E-01 -0.210341713081E-01 -0.213432781942E-01
+ -0.216562730889E-01 -0.219732048940E-01 -0.222941231266E-01 -0.226190779264E-01
+ -0.229481200637E-01 -0.232813009471E-01 -0.236186726319E-01 -0.239602878279E-01
+ -0.243061999078E-01 -0.246564629156E-01 -0.250111315747E-01 -0.253702612968E-01
+ -0.257339081903E-01 -0.261021290694E-01 -0.264749814625E-01 -0.268525236214E-01
+ -0.272348145307E-01 -0.276219139164E-01 -0.280138822557E-01 -0.284107807862E-01
+ -0.288126715156E-01 -0.292196172312E-01 -0.296316815099E-01 -0.300489287280E-01
+ -0.304714240713E-01 -0.308992335450E-01 -0.313324239846E-01 -0.317710630658E-01
+ -0.322152193151E-01 -0.326649621208E-01 -0.331203617436E-01 -0.335814893274E-01
+ -0.340484169110E-01 -0.345212174384E-01 -0.349999647712E-01 -0.354847336993E-01
+ -0.359755999530E-01 -0.364726402148E-01 -0.369759321311E-01 -0.374855543245E-01
+ -0.380015864061E-01 -0.385241089878E-01 -0.390532036949E-01 -0.395889531787E-01
+ -0.401314411298E-01 -0.406807522905E-01 -0.412369724688E-01 -0.418001885509E-01
+ -0.423704885155E-01 -0.429479614470E-01 -0.435326975498E-01 -0.441247881618E-01
+ -0.447243257693E-01 -0.453314040209E-01 -0.459461177421E-01 -0.465685629507E-01
+ -0.471988368707E-01 -0.478370379485E-01 -0.484832658675E-01 -0.491376215640E-01
+ -0.498002072428E-01 -0.504711263930E-01 -0.511504838043E-01 -0.518383855832E-01
+ -0.525349391695E-01 -0.532402533534E-01 -0.539544382915E-01 -0.546776055252E-01
+ -0.554098679968E-01 -0.561513400681E-01 -0.569021375374E-01 -0.576623776583E-01
+ -0.584321791570E-01 -0.592116622517E-01 -0.600009486705E-01 -0.608001616709E-01
+ -0.616094260585E-01 -0.624288682070E-01 -0.632586160770E-01 -0.640987992368E-01
+ -0.649495488817E-01 -0.658109978549E-01 -0.666832806681E-01 -0.675665335220E-01
+ -0.684608943280E-01 -0.693665027291E-01 -0.702835001220E-01 -0.712120296785E-01
+ -0.721522363685E-01 -0.731042669816E-01 -0.740682701505E-01 -0.750443963740E-01
+ -0.760327980399E-01 -0.770336294490E-01 -0.780470468390E-01 -0.790732084084E-01
+ -0.801122743415E-01 -0.811644068328E-01 -0.822297701122E-01 -0.833085304704E-01
+ -0.844008562849E-01 -0.855069180457E-01 -0.866268883819E-01 -0.877609420882E-01
+ -0.889092561522E-01 -0.900720097815E-01 -0.912493844315E-01 -0.924415638334E-01
+ -0.936487340227E-01 -0.948710833675E-01 -0.961088025983E-01 -0.973620848368E-01
+ -0.986311256258E-01 -0.999161229596E-01 -0.101217277314     -0.102534791679
+ -0.103868871586     -0.105219725144     -0.106587563070     -0.107972598720
+ -0.109375048123     -0.110795130014     -0.112233065869     -0.113689079936
+ -0.115163399274     -0.116656253781     -0.118167876237     -0.119698502333
+ -0.121248370713     -0.122817723006     -0.124406803865     -0.126015861003
+ -0.127645145234     -0.129294910509     -0.130965413954     -0.132656915910
+ -0.134369679975     -0.136103973041     -0.137860065337     -0.139638230468
+ -0.141438745458     -0.143261890792     -0.145107950460     -0.146977211996
+ -0.148869966528     -0.150786508815     -0.152727137296     -0.154692154137
+ -0.156681865270     -0.158696580448     -0.160736613283     -0.162802281300
+ -0.164893905981     -0.167011812817     -0.169156331353     -0.171327795240
+ -0.173526542285     -0.175752914501     -0.178007258158     -0.180289923837
+ -0.182601266479     -0.184941645443     -0.187311424553     -0.189710972159
+ -0.192140661187     -0.194600869198     -0.197091978442     -0.199614375913
+ -0.202168453412     -0.204754607599     -0.207373240057     -0.210024757346
+ -0.212709571066     -0.215428097919     -0.218180759766     -0.220967983693
+ -0.223790202071     -0.226647852621     -0.229541378476     -0.232471228249
+ -0.235437856093     -0.238441721773     -0.241483290729     -0.244563034143
+ -0.247681429009     -0.250838958203     -0.254036110547     -0.257273380887
+ -0.260551270158     -0.263870285456     -0.267230940116     -0.270633753777
+ -0.274079252462     -0.277567968650     -0.281100441354     -0.284677216191
+ -0.288298845467     -0.291965888247     -0.295678910439     -0.299438484868
+ -0.303245191363     -0.307099616827     -0.311002355329     -0.314954008180
+ -0.318955184015     -0.323006498883     -0.327108576322     -0.331262047453
+ -0.335467551058     -0.339725733674     -0.344037249674     -0.348402761358
+ -0.352822939043     -0.357298461148     -0.361830014290     -0.366418293370
+ -0.371064001669     -0.375767850935     -0.380530561483     -0.385352862284
+ -0.390235491062     -0.395179194387     -0.400184727773     -0.405252855776
+ -0.410384352088     -0.415579999639     -0.420840590692     -0.426166926946
+ -0.431559819634     -0.437020089626     -0.442548567528     -0.448146093788
+ -0.453813518793     -0.459551702980     -0.465361516934     -0.471243841496
+ -0.477199567869     -0.483229597721     -0.489334843293     -0.495516227510
+ -0.501774684082     -0.508111157619     -0.514526603736     -0.521021989164
+ -0.527598291859     -0.534256501115     -0.540997617674     -0.547822653837
+ -0.554732633577     -0.561728592652     -0.568811578719     -0.575982651446
+ -0.583242882628     -0.590593356302     -0.598035168860     -0.605569429170
+ -0.613197258684     -0.620919791566     -0.628738174797     -0.636653568305
+ -0.644667145075     -0.652780091269     -0.660993606350     -0.669308903199
+ -0.677727208235     -0.686249761535     -0.694877816963     -0.703612642282
+ -0.712455519285     -0.721407743917     -0.730470626397     -0.739645491346
+ -0.748933677911     -0.758336539896     -0.767855445885     -0.777491779374
+ -0.787246938901     -0.797122338175     -0.807119406213     -0.817239587467
+ -0.827484341967     -0.837855145452     -0.848353489511     -0.858980881722
+ -0.869738845798     -0.880628921725     -0.891652665914     -0.902811651351
+ -0.914107467742     -0.925541721676     -0.937116036777     -0.948832053869
+ -0.960691431139     -0.972695844305     -0.984846986793     -0.997146569910
+  -1.00959632303      -1.02219799378      -1.03495334823      -1.04786417111
+  -1.06093226598      -1.07415945549      -1.08754758157      -1.10109850565
+  -1.11481410894      -1.12869629264      -1.14274697819      -1.15696810759
+  -1.17136164361      -1.18592957013      -1.20067389245      -1.21559663756
+  -1.23069985452      -1.24598561476      -1.26145601253      -1.27711982001
+  -1.29296508410      -1.30900136867      -1.32523086158      -1.34165577553
+  -1.35827834854      -1.37510084450      -1.39212555372      -1.40935479346
+  -1.42679090857      -1.44443627214      -1.46229328613      -1.48036438213
+  -1.49865202208      -1.51715869906      -1.53588693815      -1.55483929730
+  -1.57401836824      -1.59342677750      -1.61306718743      -1.63294229728
+  -1.65305484441      -1.67340760543      -1.69400339758      -1.71484508001
+  -1.73593555528      -1.75727777083      -1.77887472062      -1.80072944679
+  -1.82284504145      -1.84522464857      -1.86787146592      -1.89078874723
+  -1.91397980434      -1.93744800952      -1.96119679796      -1.98522967031
+  -2.00955019539      -2.03416201310      -2.05906883736      -2.08427445934
+  -2.10978275078      -2.13559766745      -2.16172325292      -2.18816364235
+  -2.21492306665      -2.24200585670      -2.26941644785      -2.29715938470
+  -2.32523932598      -2.35366104978      -2.38242945900      -2.41154958706
+  -2.44102660390      -2.47086582219      -2.50107270395      -2.53165286739
+  -2.56261209406      -2.59395633638      -2.62569172545      -2.65782457921
+  -2.69036141098      -2.72330893831      -2.75667409226      -2.79046402701
+  -2.82468612984      -2.85934803157      -2.89445761729      -2.93002303759
+  -2.96605272010      -3.00255538151      -3.03954003991      -3.07701602758
+  -3.11499300413      -3.15348097004      -3.19249028057      -3.23203165999
+  -3.27211621616      -3.31275545540      -3.35396129765      -3.39574609186
+  -3.43812263156      -3.48110417057      -3.52470443885      -3.56893765832
+  -3.61381855864      -3.65936239283      -3.70558495274      -3.75250258405
+  -3.80013220088      -3.84849129979      -3.89759797296      -3.94747092053
+  -3.99812946169      -4.04959354453      -4.10188375424      -4.15502131954
+  -4.20902811690      -4.26392667237      -4.31974016061      -4.37649240072
+  -4.43420784854      -4.49291158483      -4.55262929899      -4.61338726765
+  -4.67521232766      -4.73813184276      -4.80217366335      -4.86736607848
+  -4.93373775951      -5.00131769431      -5.07013511142      -5.14021939293
+  -5.21159997526      -5.28430623667      -5.35836737047      -5.43381224257
+  -5.51066923234      -5.58896605529      -5.66872956645      -5.74998554278
+  -5.83275844353      -5.91707114685      -6.00294466136      -6.09039781126
+  -6.17944689342      -6.27010530535      -6.36238314256      -6.45628676420
+  -6.55181832607      -6.64897527999      -6.74774983902      -6.84812840818
+  -6.95009098070      -7.05361050012      -7.15865218939      -7.26517284812
+  -7.37312012039      -7.48243173581      -7.59303472776      -7.70484463335
+  -7.81776468101      -7.93168497286      -8.04648167013      -8.16201619161
+  -8.27813443680      -8.39466604696      -8.51142371959      -8.62820259343
+  -8.74477972376      -8.86091366965      -8.97634421740      -9.09079226677
+  -9.20395990885      -9.31553072700      -9.42517035427      -9.53252732304
+  -9.63723424396      -9.73890935314      -9.83715846698      -9.93157738434
+  -10.0217547754      -10.1072755948      -10.1877250532      -10.2626931791
+  -10.3317799949      -10.3946013246      -10.4507952407      -10.5000291455
+  -10.5419275556      -10.5763509437      -10.6030714558      -10.6219562701
+  -10.6329453965      -10.6360613632      -10.6314188657      -10.6192341327
+  -10.5998337043      -10.5736622472      -10.5412889510      -10.5034119483
+  -10.4608600865      -10.4145912339      -10.3656861297      -10.3153365817
+  -10.2648265577      -10.2155044105      -10.1687441073      -10.1258928845
+  -10.0882022248      -10.0567384252      -10.0322683016      -10.0151147387
+  -10.0049758497      -10.0006396832      -10.0000094237      -10.0000072664
+  -10.0000055384      -10.0000042076      -10.0000031862      -10.0000024047
+  -10.0000018087      -10.0000013559      -10.0000010129      -10.0000007540
+  -10.0000005594      -10.0000004134      -10.0000003045      -10.0000002234
+  -10.0000001632      -10.0000001188      -10.0000000861      -10.0000000621
+  -10.0000000446      -10.0000000319      -10.0000000226      -10.0000000160
+  -10.0000000112      -10.0000000077      -10.0000000053      -10.0000000036
+  -10.0000000023      -10.0000000015      -10.0000000009      -10.0000000005
+  -10.0000000002      -10.0000000000      -9.99999999992      -9.99999999985
+  -9.99999999980      -9.99999999978      -9.99999999978      -9.99999999978
+  -9.99999999979      -9.99999999980      -9.99999999981      -9.99999999983
+  -9.99999999984      -9.99999999986      -9.99999999987      -9.99999999989
+  -9.99999999990      -9.99999999991      -9.99999999992      -9.99999999993
+  -9.99999999994      -9.99999999995      -9.99999999995      -9.99999999996
+  -9.99999999997      -9.99999999997      -9.99999999997      -9.99999999998
+  -9.99999999998      -9.99999999998      -9.99999999999      -9.99999999999
+  -9.99999999999      -9.99999999999      -9.99999999999      -9.99999999999
+ -10.00000000000     -10.00000000000     -10.00000000000     -10.00000000000
+  -10.0000000000      -10.0000000000      -10.0000000000      -10.0000000000
+  1
+ -0.108029853616E-03 -0.217418555507E-03 -0.328183197877E-03 -0.440341087922E-03
+ -0.553909750538E-03 -0.668906931054E-03 -0.785350598009E-03 -0.903258945957E-03
+ -0.102265039831E-02 -0.114354361023E-02 -0.126595747151E-02 -0.138991110956E-02
+ -0.151542389238E-02 -0.164251543159E-02 -0.177120558550E-02 -0.190151446220E-02
+ -0.203346242271E-02 -0.216707008414E-02 -0.230235832297E-02 -0.243934827824E-02
+ -0.257806135491E-02 -0.271851922715E-02 -0.286074384179E-02 -0.300475742170E-02
+ -0.315058246928E-02 -0.329824176998E-02 -0.344775839584E-02 -0.359915570913E-02
+ -0.375245736597E-02 -0.390768732004E-02 -0.406486982631E-02 -0.422402944485E-02
+ -0.438519104466E-02 -0.454837980754E-02 -0.471362123204E-02 -0.488094113744E-02
+ -0.505036566781E-02 -0.522192129603E-02 -0.539563482801E-02 -0.557153340679E-02
+ -0.574964451686E-02 -0.592999598842E-02 -0.611261600170E-02 -0.629753309143E-02
+ -0.648477615124E-02 -0.667437443820E-02 -0.686635757738E-02 -0.706075556651E-02
+ -0.725759878061E-02 -0.745691797679E-02 -0.765874429903E-02 -0.786310928305E-02
+ -0.807004486125E-02 -0.827958336767E-02 -0.849175754307E-02 -0.870660054004E-02
+ -0.892414592817E-02 -0.914442769929E-02 -0.936748027281E-02 -0.959333850109E-02
+ -0.982203767483E-02 -0.100536135287E-01 -0.102881022468E-01 -0.105255404683E-01
+ -0.107659652934E-01 -0.110094142889E-01 -0.112559254941E-01 -0.115055374266E-01
+ -0.117582890889E-01 -0.120142199737E-01 -0.122733700706E-01 -0.125357798723E-01
+ -0.128014903806E-01 -0.130705431133E-01 -0.133429801103E-01 -0.136188439401E-01
+ -0.138981777070E-01 -0.141810250573E-01 -0.144674301863E-01 -0.147574378451E-01
+ -0.150510933479E-01 -0.153484425788E-01 -0.156495319989E-01 -0.159544086540E-01
+ -0.162631201813E-01 -0.165757148175E-01 -0.168922414059E-01 -0.172127494041E-01
+ -0.175372888919E-01 -0.178659105790E-01 -0.181986658130E-01 -0.185356065872E-01
+ -0.188767855490E-01 -0.192222560079E-01 -0.195720719442E-01 -0.199262880169E-01
+ -0.202849595727E-01 -0.206481426543E-01 -0.210158940094E-01 -0.213882710996E-01
+ -0.217653321091E-01 -0.221471359540E-01 -0.225337422914E-01 -0.229252115289E-01
+ -0.233216048340E-01 -0.237229841432E-01 -0.241294121725E-01 -0.245409524264E-01
+ -0.249576692084E-01 -0.253796276307E-01 -0.258068936246E-01 -0.262395339505E-01
+ -0.266776162087E-01 -0.271212088497E-01 -0.275703811851E-01 -0.280252033981E-01
+ -0.284857465548E-01 -0.289520826153E-01 -0.294242844445E-01 -0.299024258241E-01
+ -0.303865814636E-01 -0.308768270125E-01 -0.313732390714E-01 -0.318758952048E-01
+ -0.323848739526E-01 -0.329002548426E-01 -0.334221184029E-01 -0.339505461744E-01
+ -0.344856207238E-01 -0.350274256562E-01 -0.355760456283E-01 -0.361315663617E-01
+ -0.366940746560E-01 -0.372636584027E-01 -0.378404065988E-01 -0.384244093606E-01
+ -0.390157579379E-01 -0.396145447284E-01 -0.402208632917E-01 -0.408348083643E-01
+ -0.414564758742E-01 -0.420859629562E-01 -0.427233679665E-01 -0.433687904986E-01
+ -0.440223313987E-01 -0.446840927813E-01 -0.453541780453E-01 -0.460326918900E-01
+ -0.467197403319E-01 -0.474154307206E-01 -0.481198717560E-01 -0.488331735053E-01
+ -0.495554474200E-01 -0.502868063532E-01 -0.510273645778E-01 -0.517772378036E-01
+ -0.525365431959E-01 -0.533053993936E-01 -0.540839265279E-01 -0.548722462408E-01
+ -0.556704817042E-01 -0.564787576393E-01 -0.572972003358E-01 -0.581259376719E-01
+ -0.589650991342E-01 -0.598148158377E-01 -0.606752205466E-01 -0.615464476949E-01
+ -0.624286334073E-01 -0.633219155206E-01 -0.642264336051E-01 -0.651423289866E-01
+ -0.660697447683E-01 -0.670088258532E-01 -0.679597189668E-01 -0.689225726796E-01
+ -0.698975374311E-01 -0.708847655527E-01 -0.718844112914E-01 -0.728966308343E-01
+ -0.739215823328E-01 -0.749594259274E-01 -0.760103237724E-01 -0.770744400615E-01
+ -0.781519410534E-01 -0.792429950978E-01 -0.803477726615E-01 -0.814664463551E-01
+ -0.825991909602E-01 -0.837461834562E-01 -0.849076030484E-01 -0.860836311958E-01
+ -0.872744516392E-01 -0.884802504304E-01 -0.897012159608E-01 -0.909375389909E-01
+ -0.921894126802E-01 -0.934570326174E-01 -0.947405968508E-01 -0.960403059191E-01
+ -0.973563628830E-01 -0.986889733566E-01 -0.100038345540     -0.101404690251
+ -0.102788220959     -0.104189153816     -0.105607707696     -0.107044104221
+ -0.108498567801     -0.109971325671     -0.111462607919     -0.112972647528
+ -0.114501680411     -0.116049945448     -0.117617684521     -0.119205142554
+ -0.120812567551     -0.122440210634     -0.124088326083     -0.125757171375
+ -0.127447007224     -0.129158097623     -0.130890709882     -0.132645114674
+ -0.134421586074     -0.136220401605     -0.138041842276     -0.139886192630
+ -0.141753740789     -0.143644778495     -0.145559601160     -0.147498507907
+ -0.149461801622     -0.151449788998     -0.153462780583     -0.155501090829
+ -0.157565038141     -0.159654944927     -0.161771137647     -0.163913946865
+ -0.166083707301     -0.168280757881     -0.170505441791     -0.172758106533
+ -0.175039103974     -0.177348790405     -0.179687526596     -0.182055677848
+ -0.184453614057     -0.186881709765     -0.189340344223     -0.191829901446
+ -0.194350770277     -0.196903344445     -0.199488022626     -0.202105208505
+ -0.204755310843     -0.207438743534     -0.210155925674     -0.212907281624
+ -0.215693241078     -0.218514239128     -0.221370716332     -0.224263118784
+ -0.227191898182     -0.230157511896     -0.233160423046     -0.236201100566
+ -0.239280019282     -0.242397659983     -0.245554509499     -0.248751060772
+ -0.251987812938     -0.255265271398     -0.258583947903     -0.261944360630
+ -0.265347034262     -0.268792500072     -0.272281296001     -0.275813966747
+ -0.279391063846     -0.283013145758     -0.286680777955     -0.290394533005
+ -0.294154990666     -0.297962737971     -0.301818369324     -0.305722486586
+ -0.309675699174     -0.313678624150     -0.317731886321     -0.321836118334
+ -0.325991960774     -0.330200062261     -0.334461079553     -0.338775677649
+ -0.343144529887     -0.347568318050     -0.352047732474     -0.356583472150
+ -0.361176244837     -0.365826767166     -0.370535764755     -0.375303972317
+ -0.380132133777     -0.385021002385     -0.389971340829     -0.394983921358
+ -0.400059525899     -0.405198946174     -0.410402983826     -0.415672450539
+ -0.421008168167     -0.426410968856     -0.431881695172     -0.437421200234
+ -0.443030347842     -0.448710012610     -0.454461080098     -0.460284446954
+ -0.466181021042     -0.472151721591     -0.478197479326     -0.484319236619
+ -0.490517947625     -0.496794578434     -0.503150107215     -0.509585524366
+ -0.516101832666     -0.522700047425     -0.529381196641     -0.536146321157
+ -0.542996474816     -0.549932724623     -0.556956150907     -0.564067847486
+ -0.571268921830     -0.578560495230     -0.585943702967     -0.593419694486
+ -0.600989633568     -0.608654698502     -0.616416082270     -0.624274992721
+ -0.632232652754     -0.640290300504     -0.648449189522     -0.656710588973
+ -0.665075783814     -0.673546074998     -0.682122779660     -0.690807231316
+ -0.699600780064     -0.708504792784     -0.717520653339     -0.726649762783
+ -0.735893539569     -0.745253419757     -0.754730857228     -0.764327323900
+ -0.774044309940     -0.783883323989     -0.793845893382     -0.803933564371
+ -0.814147902350     -0.824490492090     -0.834962937964     -0.845566864181
+ -0.856303915029     -0.867175755104     -0.878184069559     -0.889330564343
+ -0.900616966447     -0.912045024156     -0.923616507296     -0.935333207489
+ -0.947196938410     -0.959209536042     -0.971372858940     -0.983688788494
+ -0.996159229194      -1.00878610890      -1.02157137910      -1.03451701521
+  -1.04762501682      -1.06089740801      -1.07433623758      -1.08794357936
+  -1.10172153252      -1.11567222182      -1.12979779790      -1.14410043760
+  -1.15858234424      -1.17324574792      -1.18809290580      -1.20312610245
+  -1.21834765010      -1.23375988896      -1.24936518756      -1.26516594302
+  -1.28116458139      -1.29736355795      -1.31376535753      -1.33037249481
+  -1.34718751468      -1.36421299252      -1.38145153455      -1.39890577814
+  -1.41657839213      -1.43447207719      -1.45258956609      -1.47093362409
+  -1.48950704923      -1.50831267268      -1.52735335904      -1.54663200674
+  -1.56615154829      -1.58591495066      -1.60592521560      -1.62618537998
+  -1.64669851610      -1.66746773206      -1.68849617203      -1.70978701664
+  -1.73134348325      -1.75316882634      -1.77526633776      -1.79763934710
+  -1.82029122199      -1.84322536844      -1.86644523108      -1.88995429355
+  -1.91375607877      -1.93785414920      -1.96225210719      -1.98695359524
+  -2.01196229626      -2.03728193388      -2.06291627268      -2.08886911846
+  -2.11514431851      -2.14174576178      -2.16867737919      -2.19594314376
+  -2.22354707087      -2.25149321844      -2.27978568706      -2.30842862021
+  -2.33742620433      -2.36678266901      -2.39650228703      -2.42658937450
+  -2.45704829086      -2.48788343896      -2.51909926505      -2.55070025876
+  -2.58269095304      -2.61507592411      -2.64785979134      -2.68104721706
+  -2.71464290645      -2.74865160722      -2.78307810942      -2.81792724508
+  -2.85320388785      -2.88891295258      -2.92505939486      -2.96164821046
+  -2.99868443476      -3.03617314206      -3.07411944486      -3.11253514788
+  -3.15141134345      -3.19076065244      -3.23058832970      -3.27089966330
+  -3.31169997326      -3.35299461019      -3.39478895377      -3.43708841112
+  -3.47989841507      -3.52322442227      -3.56707191113      -3.61144637962
+  -3.65635334296      -3.70179833101      -3.74778688560      -3.79432455759
+  -3.84141690373      -3.88906948335      -3.93728785469      -3.98607757116
+  -4.03544417719      -4.08539320384      -4.13593016418      -4.18706054825
+  -4.23878981781      -4.29112340063      -4.34406668447      -4.39762501072
+  -4.45180366749      -4.50660788244      -4.56204281499      -4.61811354820
+  -4.67482507999      -4.73218231399      -4.79019004965      -4.84885297191
+  -4.90817564018      -4.96816247661      -5.02881775380      -5.09014558162
+  -5.15214989344      -5.21483443139      -5.27820273093      -5.34225810439
+  -5.40700362374      -5.47244210224      -5.53857607518      -5.60540777951
+  -5.67293913239      -5.74117170851      -5.81010671631      -5.87974497282
+  -5.95008687724      -6.02113238319      -6.09288096941      -6.16533160909
+  -6.23848273763      -6.31233221874      -6.38687730898      -6.46211462052
+  -6.53804008214      -6.61464889843      -6.69193550709      -6.76989353431
+  -6.84851574812      -6.92779400977      -7.00771922300      -7.08828128118
+  -7.16946901227      -7.25127012169      -7.33367113280      -7.41665732535
+  -7.50021267147      -7.58431976960      -7.66895977604      -7.75411233435
+  -7.83975550256      -7.92586567821      -8.01241752135      -8.09938387552
+  -8.18673568684      -8.27444192137      -8.36246948085      -8.45078311693
+  -8.53934534425      -8.62811635248      -8.71705391762      -8.80611331292
+  -8.89524721964      -8.98440563821      -9.07353580007      -9.16258208081
+  -9.25148591499      -9.34018571340      -9.42861678329      -9.51671125241
+  -9.60439799741      -9.69160257783      -9.77824717617      -9.86425054542
+  -9.94952796487      -10.0339912055      -10.1175485063      -10.2001045622
+  -10.2815605264      -10.3618140270      -10.4407592004      -10.5182867436
+  -10.5942839855      -10.6686349816      -10.7412206309      -10.8119188201
+  -10.8806045946      -10.9471503604      -11.0114261176      -11.0732997281
+  -11.1326372206      -11.1893031333      -11.2431608986      -11.2940732695
+  -11.3419027924      -11.3865123256      -11.4277656073      -11.4655278738
+  -11.4996665291      -11.5300518677      -11.5565578510      -11.5790629377
+  -11.5974509683      -11.6116121040      -11.6214438175      -11.6268519359
+  -11.6277517326      -11.6240690652      -11.6157415565      -11.6027198135
+  -11.5849686795      -11.5624685127      -11.5352164840      -11.5032278864
+  -11.4665374449      -11.4252006189      -11.3792948826      -11.3289209723
+  -11.2742040860      -11.2152950196      -11.1523712230      -11.0856377587
+  -11.0153281426      -10.9417050476      -10.8650608464      -10.7857179721
+  -10.7040290692      -10.6203769106      -10.5351740509      -10.4488621864
+  -10.3619111892      -10.2748177810      -10.1881038086      -10.1023140817
+  -10.0180137288      -9.93578502411      -9.85622363546      -9.77993423694
+  -9.70752542946      -9.63960390657      -9.57676780208      -9.51959915490
+  -9.46857551816      -9.42433104635      -9.38731289478      -9.35794375470
+  -9.33657743921      -9.32348515907      -9.31884085371      -9.32270574564
+  -9.33501238462      -9.35554857454      -9.38394173659      -9.41964446228
+  -9.46192225601      -9.50984476462      -9.56228214802      -9.61790866642
+  -9.67521605394      -9.73253982239      -9.78810230284      -9.84007699819
+  -9.88667970402      -9.92629288189      -9.95763097208      -9.97995575989
+  -9.99335262142      -9.99916030705      -10.0000094667      -10.0000072664
+  2
+ -0.812671611284E-04 -0.163556537301E-03 -0.246880986398E-03 -0.331253528029E-03
+ -0.416687345572E-03 -0.503195788229E-03 -0.590792373117E-03 -0.679490787374E-03
+ -0.769304890304E-03 -0.860248715536E-03 -0.952336473222E-03 -0.104558255226E-02
+ -0.114000152252E-02 -0.123560813716E-02 -0.133241733490E-02 -0.143044424236E-02
+ -0.152970417645E-02 -0.163021264671E-02 -0.173198535779E-02 -0.183503821187E-02
+ -0.193938731116E-02 -0.204504896041E-02 -0.215203966945E-02 -0.226037615578E-02
+ -0.237007534719E-02 -0.248115438439E-02 -0.259363062368E-02 -0.270752163969E-02
+ -0.282284522811E-02 -0.293961940846E-02 -0.305786242693E-02 -0.317759275921E-02
+ -0.329882911339E-02 -0.342159043287E-02 -0.354589589934E-02 -0.367176493575E-02
+ -0.379921720937E-02 -0.392827263485E-02 -0.405895137734E-02 -0.419127385563E-02
+ -0.432526074534E-02 -0.446093298216E-02 -0.459831176512E-02 -0.473741855991E-02
+ -0.487827510220E-02 -0.502090340107E-02 -0.516532574246E-02 -0.531156469259E-02
+ -0.545964310156E-02 -0.560958410687E-02 -0.576141113706E-02 -0.591514791536E-02
+ -0.607081846341E-02 -0.622844710498E-02 -0.638805846981E-02 -0.654967749744E-02
+ -0.671332944111E-02 -0.687903987170E-02 -0.704683468172E-02 -0.721674008940E-02
+ -0.738878264270E-02 -0.756298922356E-02 -0.773938705202E-02 -0.791800369051E-02
+ -0.809886704816E-02 -0.828200538512E-02 -0.846744731705E-02 -0.865522181951E-02
+ -0.884535823254E-02 -0.903788626522E-02 -0.923283600035E-02 -0.943023789907E-02
+ -0.963012280571E-02 -0.983252195256E-02 -0.100374669648E-01 -0.102449898652E-01
+ -0.104551230797E-01 -0.106678994417E-01 -0.108833521978E-01 -0.111015150129E-01
+ -0.113224219750E-01 -0.115461076012E-01 -0.117726068426E-01 -0.120019550900E-01
+ -0.122341881792E-01 -0.124693423970E-01 -0.127074544863E-01 -0.129485616526E-01
+ -0.131927015689E-01 -0.134399123825E-01 -0.136902327201E-01 -0.139437016946E-01
+ -0.142003589107E-01 -0.144602444714E-01 -0.147233989838E-01 -0.149898635662E-01
+ -0.152596798537E-01 -0.155328900054E-01 -0.158095367105E-01 -0.160896631952E-01
+ -0.163733132294E-01 -0.166605311336E-01 -0.169513617857E-01 -0.172458506281E-01
+ -0.175440436748E-01 -0.178459875185E-01 -0.181517293380E-01 -0.184613169056E-01
+ -0.187747985943E-01 -0.190922233858E-01 -0.194136408775E-01 -0.197391012911E-01
+ -0.200686554796E-01 -0.204023549359E-01 -0.207402518004E-01 -0.210823988695E-01
+ -0.214288496034E-01 -0.217796581350E-01 -0.221348792780E-01 -0.224945685355E-01
+ -0.228587821086E-01 -0.232275769056E-01 -0.236010105503E-01 -0.239791413914E-01
+ -0.243620285115E-01 -0.247497317364E-01 -0.251423116443E-01 -0.255398295752E-01
+ -0.259423476410E-01 -0.263499287345E-01 -0.267626365396E-01 -0.271805355414E-01
+ -0.276036910358E-01 -0.280321691402E-01 -0.284660368034E-01 -0.289053618166E-01
+ -0.293502128232E-01 -0.298006593304E-01 -0.302567717193E-01 -0.307186212565E-01
+ -0.311862801047E-01 -0.316598213343E-01 -0.321393189351E-01 -0.326248478269E-01
+ -0.331164838723E-01 -0.336143038878E-01 -0.341183856562E-01 -0.346288079384E-01
+ -0.351456504862E-01 -0.356689940542E-01 -0.361989204128E-01 -0.367355123609E-01
+ -0.372788537387E-01 -0.378290294408E-01 -0.383861254298E-01 -0.389502287491E-01
+ -0.395214275373E-01 -0.400998110410E-01 -0.406854696298E-01 -0.412784948095E-01
+ -0.418789792369E-01 -0.424870167341E-01 -0.431027023034E-01 -0.437261321415E-01
+ -0.443574036554E-01 -0.449966154769E-01 -0.456438674784E-01 -0.462992607882E-01
+ -0.469628978067E-01 -0.476348822219E-01 -0.483153190261E-01 -0.490043145317E-01
+ -0.497019763885E-01 -0.504084135998E-01 -0.511237365401E-01 -0.518480569717E-01
+ -0.525814880627E-01 -0.533241444043E-01 -0.540761420288E-01 -0.548375984278E-01
+ -0.556086325704E-01 -0.563893649218E-01 -0.571799174624E-01 -0.579804137064E-01
+ -0.587909787213E-01 -0.596117391474E-01 -0.604428232177E-01 -0.612843607777E-01
+ -0.621364833057E-01 -0.629993239335E-01 -0.638730174671E-01 -0.647577004076E-01
+ -0.656535109727E-01 -0.665605891182E-01 -0.674790765598E-01 -0.684091167952E-01
+ -0.693508551267E-01 -0.703044386835E-01 -0.712700164452E-01 -0.722477392646E-01
+ -0.732377598912E-01 -0.742402329955E-01 -0.752553151927E-01 -0.762831650673E-01
+ -0.773239431979E-01 -0.783778121820E-01 -0.794449366619E-01 -0.805254833497E-01
+ -0.816196210538E-01 -0.827275207051E-01 -0.838493553836E-01 -0.849853003455E-01
+ -0.861355330504E-01 -0.873002331892E-01 -0.884795827119E-01 -0.896737658559E-01
+ -0.908829691753E-01 -0.921073815693E-01 -0.933471943119E-01 -0.946026010819E-01
+ -0.958737979931E-01 -0.971609836244E-01 -0.984643590514E-01 -0.997841278773E-01
+ -0.101120496265     -0.102473672969     -0.103843869367     -0.105231299495
+ -0.106636180080     -0.108058730571     -0.109499173178     -0.110957732902
+ -0.112434637573     -0.113930117885     -0.115444407430     -0.116977742739
+ -0.118530363312     -0.120102511661     -0.121694433347     -0.123306377015
+ -0.124938594435     -0.126591340543     -0.128264873476     -0.129959454616
+ -0.131675348630     -0.133412823511     -0.135172150618     -0.136953604720
+ -0.138757464040     -0.140584010295     -0.142433528742     -0.144306308222
+ -0.146202641205     -0.148122823834     -0.150067155974     -0.152035941256
+ -0.154029487125     -0.156048104888     -0.158092109763     -0.160161820927
+ -0.162257561565     -0.164379658921     -0.166528444350     -0.168704253367
+ -0.170907425702     -0.173138305349     -0.175397240623     -0.177684584213
+ -0.180000693234     -0.182345929287     -0.184720658511     -0.187125251643
+ -0.189560084073     -0.192025535903     -0.194521992008     -0.197049842090
+ -0.199609480745     -0.202201307521     -0.204825726979     -0.207483148757
+ -0.210173987632     -0.212898663588     -0.215657601876     -0.218451233081
+ -0.221279993192     -0.224144323666     -0.227044671495     -0.229981489281
+ -0.232955235298     -0.235966373570     -0.239015373937     -0.242102712131
+ -0.245228869849     -0.248394334825     -0.251599600907     -0.254845168133
+ -0.258131542809     -0.261459237582     -0.264828771527     -0.268240670219
+ -0.271695465820     -0.275193697157     -0.278735909805     -0.282322656173
+ -0.285954495586     -0.289631994373     -0.293355725955     -0.297126270928
+ -0.300944217158     -0.304810159864     -0.308724701718     -0.312688452929
+ -0.316702031342     -0.320766062528     -0.324881179882     -0.329048024722
+ -0.333267246381     -0.337539502311     -0.341865458181     -0.346245787978
+ -0.350681174113     -0.355172307518     -0.359719887760     -0.364324623138
+ -0.368987230797     -0.373708436836     -0.378488976413     -0.383329593864
+ -0.388231042808     -0.393194086267     -0.398219496778     -0.403308056511
+ -0.408460557385     -0.413677801189     -0.418960599703     -0.424309774818
+ -0.429726158663     -0.435210593726     -0.440763932981     -0.446387040019
+ -0.452080789173     -0.457846065652     -0.463683765670     -0.469594796582
+ -0.475580077018     -0.481640537021     -0.487777118182     -0.493990773784
+ -0.500282468940     -0.506653180735     -0.513103898375     -0.519635623327
+ -0.526249369472     -0.532946163250     -0.539727043814     -0.546593063177
+ -0.553545286374     -0.560584791611     -0.567712670424     -0.574930027841
+ -0.582237982537     -0.589637667002     -0.597130227702     -0.604716825243
+ -0.612398634543     -0.620176844998     -0.628052660654     -0.636027300378
+ -0.644101998035     -0.652278002660     -0.660556578642     -0.668939005896
+ -0.677426580051     -0.686020612629     -0.694722431233     -0.703533379728
+ -0.712454818438     -0.721488124327     -0.730634691199     -0.739895929884
+ -0.749273268442     -0.758768152351     -0.768382044716     -0.778116426459
+ -0.787972796531     -0.797952672111     -0.808057588813     -0.818289100895
+ -0.828648781467     -0.839138222704     -0.849759036056     -0.860512852465
+ -0.871401322583     -0.882426116985     -0.893588926393     -0.904891461895
+ -0.916335455168     -0.927922658704     -0.939654846035     -0.951533811961
+ -0.963561372777     -0.975739366507     -0.988069653133      -1.00055411483
+  -1.01319465620      -1.02599320452      -1.03895170994      -1.05207214579
+  -1.06535650873      -1.07880681909      -1.09242512104      -1.10621348285
+  -1.12017399715      -1.13430878118      -1.14861997698      -1.16310975173
+  -1.17778029791      -1.19263383359      -1.20767260270      -1.22289887522
+  -1.23831494747      -1.25392314236      -1.26972580963      -1.28572532610
+  -1.30192409593      -1.31832455084      -1.33492915040      -1.35174038227
+  -1.36876076241      -1.38599283538      -1.40343917456      -1.42110238239
+  -1.43898509064      -1.45708996062      -1.47541968346      -1.49397698030
+  -1.51276460259      -1.53178533227      -1.55104198202      -1.57053739551
+  -1.59027444761      -1.61025604460      -1.63048512441      -1.65096465685
+  -1.67169764377      -1.69268711932      -1.71393615011      -1.73544783545
+  -1.75722530751      -1.77927173148      -1.80159030581      -1.82418426234
+  -1.84705686645      -1.87021141723      -1.89365124765      -1.91737972464
+  -1.94140024924      -1.96571625672      -1.99033121666      -2.01524863308
+  -2.04047204444      -2.06600502376      -2.09185117864      -2.11801415130
+  -2.14449761857      -2.17130529189      -2.19844091727      -2.22590827525
+  -2.25371118083      -2.28185348334      -2.31033906636      -2.33917850235
+  -2.36836164881      -2.39789988992      -2.42779724285      -2.45805775784
+  -2.48868551794      -2.51968463859      -2.55105926727      -2.58281358300
+  -2.61495179587      -2.64747814649      -2.68039690536      -2.71371237224
+  -2.74742887540      -2.78155077085      -2.81608244146      -2.85102829605
+  -2.88639276833      -2.92218031587      -2.95839541886      -2.99504257886
+  -3.03212631742      -3.06965117456      -3.10762170723      -3.14604248756
+  -3.18491810099      -3.22425314437      -3.26405222375      -3.30431995219
+  -3.34506094729      -3.38627982857      -3.42798121476      -3.47016972078
+  -3.51284995459      -3.55602651381      -3.59970398214      -3.64388692549
+  -3.68857988790      -3.73378738720      -3.77951391038      -3.82576390864
+  -3.87254179218      -3.91985192462      -3.96769861709      -4.01608612194
+  -4.06501862612      -4.11450024409      -4.16453501032      -4.21512687138
+  -4.26627967751      -4.31799717372      -4.37028299039      -4.42314063328
+  -4.47657347300      -4.53058473386      -4.58517748210      -4.64035461350
+  -4.69611884020      -4.75247267692      -4.80941842634      -4.86695816374
+  -4.92509372078      -4.98382666847      -5.04315829924      -5.10308960804
+  -5.16362127253      -5.22475363224      -5.28648666671      -5.34881997256
+  -5.41175273941      -5.47528372470      -5.53941122728      -5.60413305984
+  -5.66944652000      -5.73534836022      -5.80183475623      -5.86890127430
+  -5.93654283696      -6.00475368741      -6.07352735248      -6.14285660412
+  -6.21273341946      -6.28314893937      -6.35409342556      -6.42555621624
+  -6.49752568020      -6.56998916963      -6.64293297133      -6.71634225665
+  -6.79020103006      -6.86449207646      -6.93919690722      -7.01429570520
+  -7.08976726863      -7.16558895421      -7.24173661938      -7.31818456396
+  -7.39490547147      -7.47187035012      -7.54904847391      -7.62640732392
+  -7.70391253020      -7.78152781456      -7.85921493454      -7.93693362904
+  -8.01464156598      -8.09229429249      -8.16984518809      -8.24724542152
+  -8.32444391165      -8.40138729335      -8.47801988874      -8.55428368486
+  -8.63011831835      -8.70546106813      -8.78024685686      -8.85440826242
+  -8.92787554005      -9.00057665664      -9.07243733804      -9.14338113071
+  -9.21332947893      -9.28220181892      -9.34991569114      -9.41638687224
+  -9.48152952808      -9.54525638920      -9.60747895035      -9.66810769543
+  -9.72705234945      -9.78422215892      -9.83952620206      -9.89287373034
+  -9.94417454262      -9.99333939300      -10.0402804337      -10.0849116939
+  -10.1271495950      -10.1669135031      -10.2041263195      -10.2387151082
+  -10.2706117606      -10.2997536969      -10.3260846024      -10.3495551976
+  -10.3701240389      -10.3877583473      -10.4024348621      -10.4141407128
+  -10.4228743058      -10.4286462176      -10.4314800878      -10.4314135007
+  -10.4284988469      -10.4228041510      -10.4144138515      -10.4034295170
+  -10.3899704794      -10.3741743644      -10.3561974953      -10.3362151441
+  -10.3144216010      -10.2910300304      -10.2662720788      -10.2403971953
+  -10.2136716244      -10.1863770271      -10.1588086835      -10.1312732288
+  -10.1040059646      -10.0774380860      -10.0518596615      -10.0275891749
+  -10.0049365145      -9.98419698993      -9.96564464814      -9.94952491247
+  -9.93604660512      -9.92537345656      -9.91761526497      -9.91281894277
+  -9.91095978163      -9.91193338440      -9.91554885737      -9.92152403441
+  -9.92948372131      -9.93896221154      -9.94941164195      -9.96021813819
+  -9.97072815720      -9.98028798206      -9.98829998051      -9.99430002444
+  -9.99806140951      -9.99975501362      -10.0000088511      -10.0000072664
+  3
+ -0.738035974225E-04 -0.148535529815E-03 -0.224207474191E-03 -0.300831254442E-03
+ -0.378418843185E-03 -0.456982363633E-03 -0.536534091493E-03 -0.617086456879E-03
+ -0.698652046256E-03 -0.781243604407E-03 -0.864874036425E-03 -0.949556409729E-03
+ -0.103530395611E-02 -0.112213007378E-02 -0.121004832949E-02 -0.129907246064E-02
+ -0.138921637743E-02 -0.148049416501E-02 -0.157292008572E-02 -0.166650858128E-02
+ -0.176127427507E-02 -0.185723197442E-02 -0.195439667290E-02 -0.205278355267E-02
+ -0.215240798688E-02 -0.225328554203E-02 -0.235543198042E-02 -0.245886326264E-02
+ -0.256359555000E-02 -0.266964520714E-02 -0.277702880449E-02 -0.288576312096E-02
+ -0.299586514646E-02 -0.310735208466E-02 -0.322024135559E-02 -0.333455059840E-02
+ -0.345029767411E-02 -0.356750066842E-02 -0.368617789451E-02 -0.380634789590E-02
+ -0.392802944937E-02 -0.405124156788E-02 -0.417600350353E-02 -0.430233475061E-02
+ -0.443025504858E-02 -0.455978438522E-02 -0.469094299970E-02 -0.482375138578E-02
+ -0.495823029501E-02 -0.509440073992E-02 -0.523228399739E-02 -0.537190161191E-02
+ -0.551327539894E-02 -0.565642744839E-02 -0.580138012798E-02 -0.594815608682E-02
+ -0.609677825886E-02 -0.624726986658E-02 -0.639965442451E-02 -0.655395574297E-02
+ -0.671019793179E-02 -0.686840540404E-02 -0.702860287988E-02 -0.719081539040E-02
+ -0.735506828154E-02 -0.752138721806E-02 -0.768979818752E-02 -0.786032750438E-02
+ -0.803300181408E-02 -0.820784809722E-02 -0.838489367377E-02 -0.856416620732E-02
+ -0.874569370945E-02 -0.892950454407E-02 -0.911562743184E-02 -0.930409145470E-02
+ -0.949492606038E-02 -0.968816106701E-02 -0.988382666779E-02 -0.100819534357E-01
+ -0.102825723282E-01 -0.104857146923E-01 -0.106914122692E-01 -0.108996971993E-01
+ -0.111106020274E-01 -0.113241597075E-01 -0.115404036082E-01 -0.117593675178E-01
+ -0.119810856496E-01 -0.122055926473E-01 -0.124329235903E-01 -0.126631139992E-01
+ -0.128961998413E-01 -0.131322175366E-01 -0.133712039629E-01 -0.136131964620E-01
+ -0.138582328454E-01 -0.141063514001E-01 -0.143575908947E-01 -0.146119905857E-01
+ -0.148695902229E-01 -0.151304300564E-01 -0.153945508425E-01 -0.156619938502E-01
+ -0.159328008674E-01 -0.162070142078E-01 -0.164846767173E-01 -0.167658317806E-01
+ -0.170505233281E-01 -0.173387958430E-01 -0.176306943676E-01 -0.179262645112E-01
+ -0.182255524565E-01 -0.185286049670E-01 -0.188354693946E-01 -0.191461936868E-01
+ -0.194608263939E-01 -0.197794166773E-01 -0.201020143163E-01 -0.204286697167E-01
+ -0.207594339179E-01 -0.210943586017E-01 -0.214334960996E-01 -0.217768994016E-01
+ -0.221246221638E-01 -0.224767187177E-01 -0.228332440778E-01 -0.231942539505E-01
+ -0.235598047433E-01 -0.239299535727E-01 -0.243047582738E-01 -0.246842774092E-01
+ -0.250685702779E-01 -0.254576969250E-01 -0.258517181506E-01 -0.262506955196E-01
+ -0.266546913711E-01 -0.270637688286E-01 -0.274779918093E-01 -0.278974250343E-01
+ -0.283221340388E-01 -0.287521851823E-01 -0.291876456589E-01 -0.296285835078E-01
+ -0.300750676239E-01 -0.305271677688E-01 -0.309849545814E-01 -0.314484995891E-01
+ -0.319178752187E-01 -0.323931548082E-01 -0.328744126180E-01 -0.333617238422E-01
+ -0.338551646208E-01 -0.343548120516E-01 -0.348607442018E-01 -0.353730401206E-01
+ -0.358917798512E-01 -0.364170444437E-01 -0.369489159676E-01 -0.374874775245E-01
+ -0.380328132610E-01 -0.385850083822E-01 -0.391441491648E-01 -0.397103229704E-01
+ -0.402836182596E-01 -0.408641246053E-01 -0.414519327069E-01 -0.420471344047E-01
+ -0.426498226939E-01 -0.432600917391E-01 -0.438780368895E-01 -0.445037546932E-01
+ -0.451373429124E-01 -0.457789005392E-01 -0.464285278101E-01 -0.470863262226E-01
+ -0.477523985505E-01 -0.484268488601E-01 -0.491097825263E-01 -0.498013062493E-01
+ -0.505015280712E-01 -0.512105573926E-01 -0.519285049901E-01 -0.526554830332E-01
+ -0.533916051020E-01 -0.541369862052E-01 -0.548917427973E-01 -0.556559927977E-01
+ -0.564298556083E-01 -0.572134521327E-01 -0.580069047947E-01 -0.588103375577E-01
+ -0.596238759440E-01 -0.604476470540E-01 -0.612817795865E-01 -0.621264038589E-01
+ -0.629816518267E-01 -0.638476571051E-01 -0.647245549893E-01 -0.656124824756E-01
+ -0.665115782829E-01 -0.674219828745E-01 -0.683438384797E-01 -0.692772891161E-01
+ -0.702224806124E-01 -0.711795606304E-01 -0.721486786888E-01 -0.731299861861E-01
+ -0.741236364245E-01 -0.751297846334E-01 -0.761485879939E-01 -0.771802056635E-01
+ -0.782247988004E-01 -0.792825305890E-01 -0.803535662653E-01 -0.814380731426E-01
+ -0.825362206377E-01 -0.836481802971E-01 -0.847741258240E-01 -0.859142331052E-01
+ -0.870686802386E-01 -0.882376475607E-01 -0.894213176754E-01 -0.906198754817E-01
+ -0.918335082028E-01 -0.930624054154E-01 -0.943067590792E-01 -0.955667635666E-01
+ -0.968426156932E-01 -0.981345147483E-01 -0.994426625263E-01 -0.100767263358
+ -0.102108524141     -0.103466654375     -0.104841866192     -0.106234374389
+ -0.107644396465     -0.109072152649     -0.110517865939     -0.111981762137
+ -0.113464069879     -0.114965020678     -0.116484848952     -0.118023792067
+ -0.119582090372     -0.121159987233     -0.122757729077     -0.124375565425
+ -0.126013748932     -0.127672535430     -0.129352183963     -0.131052956829
+ -0.132775119621     -0.134518941269     -0.136284694081     -0.138072653784
+ -0.139883099570     -0.141716314135     -0.143572583729     -0.145452198192
+ -0.147355451009     -0.149282639347     -0.151234064105     -0.153210029961
+ -0.155210845419     -0.157236822855     -0.159288278568     -0.161365532826
+ -0.163468909919     -0.165598738207     -0.167755350174     -0.169939082473
+ -0.172150275985     -0.174389275869     -0.176656431615     -0.178952097099
+ -0.181276630637     -0.183630395041     -0.186013757674     -0.188427090510
+ -0.190870770187     -0.193345178069     -0.195850700303     -0.198387727878
+ -0.200956656688     -0.203557887592     -0.206191826472     -0.208858884303
+ -0.211559477211     -0.214294026538     -0.217062958908     -0.219866706292
+ -0.222705706075     -0.225580401125     -0.228491239856     -0.231438676302
+ -0.234423170185     -0.237445186987     -0.240505198018     -0.243603680492
+ -0.246741117600     -0.249917998582     -0.253134818803     -0.256392079829
+ -0.259690289505     -0.263029962031     -0.266411618044     -0.269835784690
+ -0.273302995716     -0.276813791540     -0.280368719344     -0.283968333148
+ -0.287613193901     -0.291303869566     -0.295040935203     -0.298824973060
+ -0.302656572660     -0.306536330891     -0.310464852098     -0.314442748171
+ -0.318470638643     -0.322549150780     -0.326678919679     -0.330860588361
+ -0.335094807871     -0.339382237376     -0.343723544264     -0.348119404242
+ -0.352570501446     -0.357077528534     -0.361641186798     -0.366262186265
+ -0.370941245806     -0.375679093244     -0.380476465460     -0.385334108509
+ -0.390252777726     -0.395233237842     -0.400276263097     -0.405382637358
+ -0.410553154231     -0.415788617183     -0.421089839661     -0.426457645210
+ -0.431892867601     -0.437396350945     -0.442968949828     -0.448611529429
+ -0.454324965653     -0.460110145257     -0.465967965982     -0.471899336683
+ -0.477905177463     -0.483986419808     -0.490144006724     -0.496378892869
+ -0.502692044702     -0.509084440612     -0.515557071068     -0.522110938760
+ -0.528747058742     -0.535466458580     -0.542270178500     -0.549159271537
+ -0.556134803686     -0.563197854053     -0.570349515011     -0.577590892354
+ -0.584923105453     -0.592347287419     -0.599864585257     -0.607476160031
+ -0.615183187029     -0.622986855923     -0.630888370936     -0.638888951016
+ -0.646989829997     -0.655192256775     -0.663497495479     -0.671906825645
+ -0.680421542393     -0.689042956601     -0.697772395088     -0.706611200790
+ -0.715560732944     -0.724622367272     -0.733797496164     -0.743087528867
+ -0.752493891670     -0.762018028093     -0.771661399083     -0.781425483201
+ -0.791311776817     -0.801321794308     -0.811457068252     -0.821719149626
+ -0.832109608009     -0.842630031779     -0.853282028317     -0.864067224211
+ -0.874987265460     -0.886043817683     -0.897238566323     -0.908573216857
+ -0.920049495008     -0.931669146955     -0.943433939542     -0.955345660500
+ -0.967406118651     -0.979617144133     -0.991980588610      -1.00449832549
+  -1.01717225016      -1.03000428016      -1.04299635547      -1.05615043868
+  -1.06946851521      -1.08295259358      -1.09660470558      -1.11042690651
+  -1.12442127544      -1.13858991536      -1.15293495349      -1.16745854143
+  -1.18216285543      -1.19705009659      -1.21212249112      -1.22738229051
+  -1.24283177181      -1.25847323781      -1.27430901729      -1.29034146523
+  -1.30657296305      -1.32300591881      -1.33964276741      -1.35648597089
+  -1.37353801855      -1.39080142723      -1.40827874151      -1.42597253390
+  -1.44388540508      -1.46201998410      -1.48037892857      -1.49896492490
+  -1.51778068845      -1.53682896378      -1.55611252480      -1.57563417499
+  -1.59539674758      -1.61540310572      -1.63565614267      -1.65615878197
+  -1.67691397761      -1.69792471418      -1.71919400706      -1.74072490252
+  -1.76252047790      -1.78458384172      -1.80691813386      -1.82952652559
+  -1.85241221976      -1.87557845086      -1.89902848514      -1.92276562065
+  -1.94679318734      -1.97111454709      -1.99573309378      -2.02065225330
+  -2.04587548356      -2.07140627451      -2.09724814809      -2.12341131303
+  -2.14988526113      -2.17668100900      -2.20380220455      -2.23125252725
+  -2.25903568799      -2.28715542887      -2.31561552306      -2.34441977451
+  -2.37357201772      -2.40307611742      -2.43293596826      -2.46315549438
+  -2.49373864909      -2.52468941430      -2.55601180013      -2.58770984424
+  -2.61978761135      -2.65224919245      -2.68509870420      -2.71834028805
+  -2.75197810947      -2.78601635695      -2.82045924108      -2.85531099343
+  -2.89057586540      -2.92625812697      -2.96236206536      -2.99889198356
+  -3.03585219880      -3.07324704088      -3.11108085034      -3.14935797657
+  -3.18808277576      -3.22725960868      -3.26689283833      -3.30698682740
+  -3.34754593563      -3.38857451688      -3.43007691612      -3.47205746610
+  -3.51452048393      -3.55747026732      -3.60091109063      -3.64484720069
+  -3.68928281231      -3.73422210349      -3.77966921041      -3.82562822203
+  -3.87210317436      -3.91909804443      -3.96661674389      -4.01466311210
+  -4.06324090902      -4.11235380746      -4.16200538503      -4.21219911554
+  -4.26293835990      -4.31422635657      -4.36606621136      -4.41846088672
+  -4.47141319043      -4.52492576364      -4.57900106822      -4.63364137353
+  -4.68884874236      -4.74462501614      -4.80097179947      -4.85789044371
+  -4.91538202978      -4.97344735011      -5.03208688963      -5.09130080585
+  -5.15108890795      -5.21145063484      -5.27238503224      -5.33389072859
+  -5.39596590990      -5.45860829351      -5.52181510057      -5.58558302740
+  -5.64990821560      -5.71478622093      -5.78021198087      -5.84617978092
+  -5.91268321963      -5.97971517222      -6.04726775298      -6.11533227625
+  -6.18389921611      -6.25295816484      -6.32249778992      -6.39250578991
+  -6.46296884904      -6.53387259061      -6.60520152928      -6.67693902227
+  -6.74906721964      -6.82156701365      -6.89441798736      -6.96759836261
+  -7.04108494751      -7.11485308366      -7.18887659317      -7.26312772590
+  -7.33757710695      -7.41219368485      -7.48694468060      -7.56179553805
+  -7.63670987584      -7.71164944145      -7.78657406763      -7.86144163193
+  -7.93620801956      -8.01082709046      -8.08525065096      -8.15942843081
+  -8.23330806627      -8.30683509010      -8.37995292907      -8.45260291017
+  -8.52472427616      -8.59625421164      -8.66712788062      -8.73727847666
+  -8.80663728681      -8.87513377047      -8.94269565446      -9.00924904562
+  -9.07471856223      -9.13902748563      -9.20209793344      -9.26385105573
+  -9.32420725571      -9.38308643603      -9.44040827236      -9.49609251540
+  -9.55005932256      -9.60222962050      -9.65252549959      -9.70087064102
+  -9.74719077734      -9.79141418686      -9.83347222202      -9.87329987144
+  -9.91083635534      -9.94602575296      -9.97881766066      -10.0091678784
+  -10.0370391218      -10.0624017557      -10.0852345460      -10.1055254219
+  -10.1232722448      -10.1384835733      -10.1511794166      -10.1613919657
+  -10.1691662890      -10.1745609783      -10.1776487310      -10.1785168469
+  -10.1772676231      -10.1740186217      -10.1689027865      -10.1620683816
+  -10.1536787218      -10.1439116638      -10.1329588230      -10.1210244829
+  -10.1082442480      -10.0949537961      -10.0813535742      -10.0676802556
+  -10.0541718468      -10.0410640203      -10.0285859348      -10.0169555436
+  -10.0063744135      -9.99702210095      -9.98905016668      -9.98257595260
+  -9.97767629986      -9.97438145595      -9.97266950495      -9.97246176146
+  -9.97361970006      -9.97594415193      -9.97917769584      -9.98301140623
+  -9.98709740702      -9.99106902273      -9.99457073211      -9.99730062463
+  -9.99914848628      -9.99989538023      -10.0000086035      -10.0000066435
+  -10.0000050636      -10.0000038470      -10.0000029131      -10.0000021985
+  -10.0000016537      -10.0000012397      -10.0000009261      -10.0000006894
+  -10.0000005114      -10.0000003780      -10.0000002784      -10.0000002042
+  -10.0000001492      -10.0000001086      -10.0000000787      -10.0000000568
+  -10.0000000408      -10.0000000291      -10.0000000207      -10.0000000146
+  -10.0000000102      -10.0000000071      -10.0000000048      -10.0000000033
+  -10.0000000021      -10.0000000014      -10.0000000008      -10.0000000005
+  -10.0000000002      -10.0000000000      -9.99999999993      -9.99999999986
+  -9.99999999982      -9.99999999980      -9.99999999980      -9.99999999980
+  -9.99999999981      -9.99999999982      -9.99999999983      -9.99999999984
+  -9.99999999986      -9.99999999987      -9.99999999988      -9.99999999990
+  -9.99999999991      -9.99999999992      -9.99999999993      -9.99999999994
+  -9.99999999994      -9.99999999995      -9.99999999996      -9.99999999996
+  -9.99999999997      -9.99999999997      -9.99999999998      -9.99999999998
+  -9.99999999998      -9.99999999999      -9.99999999999      -9.99999999999
+  -9.99999999999      -9.99999999999      -9.99999999999     -10.00000000000
+ -10.00000000000     -10.00000000000      -10.0000000000      -10.0000000000
+ Core charge follows
+   0.00000000000       0.00000000000       0.00000000000       0.00000000000
+ Valence charge follows
+  0.491483762316E-10  0.199074123095E-09  0.453580405584E-09  0.816582414536E-09
+  0.129211040071E-08  0.188431278814E-08  0.259745936887E-08  0.343594458108E-08
+  0.440429087281E-08  0.550715215348E-08  0.674931733538E-08  0.813571396757E-08
+  0.967141196446E-08  0.113616274315E-07  0.132117265907E-07  0.152272298080E-07
+  0.174138157258E-07  0.197773255028E-07  0.223237671644E-07  0.250593200655E-07
+  0.279903394704E-07  0.311233612505E-07  0.344651067051E-07  0.380224875061E-07
+  0.418026107727E-07  0.458127842762E-07  0.500605217807E-07  0.545535485221E-07
+  0.592998068289E-07  0.643074618890E-07  0.695849076660E-07  0.751407729679E-07
+  0.809839276740E-07  0.871234891225E-07  0.935688286631E-07  0.100329578380E-06
+  0.107415637987E-06  0.114837181904E-06  0.122604666512E-06  0.130728837602E-06
+  0.139220738007E-06  0.148091715442E-06  0.157353430537E-06  0.167017865084E-06
+  0.177097330494E-06  0.187604476469E-06  0.198552299908E-06  0.209954154030E-06
+  0.221823757738E-06  0.234175205231E-06  0.247022975851E-06  0.260381944191E-06
+  0.274267390465E-06  0.288695011141E-06  0.303680929849E-06  0.319241708571E-06
+  0.335394359118E-06  0.352156354901E-06  0.369545643011E-06  0.387580656600E-06
+  0.406280327587E-06  0.425664099693E-06  0.445751941804E-06  0.466564361680E-06
+  0.488122420022E-06  0.510447744891E-06  0.533562546504E-06  0.557489632412E-06
+  0.582252423056E-06  0.607874967738E-06  0.634381960993E-06  0.661798759379E-06
+  0.690151398705E-06  0.719466611699E-06  0.749771846125E-06  0.781095283369E-06
+  0.813465857501E-06  0.846913274826E-06  0.881468033934E-06  0.917161446266E-06
+  0.954025657209E-06  0.992093667725E-06  0.103139935654E-05  0.107197750292E-05
+  0.111386380996E-05  0.115709492858E-05  0.120170848203E-05  0.124774309111E-05
+  0.129523839995E-05  0.134423510253E-05  0.139477496981E-05  0.144690087762E-05
+  0.150065683521E-05  0.155608801458E-05  0.161324078048E-05  0.167216272127E-05
+  0.173290268054E-05  0.179551078947E-05  0.186003850015E-05  0.192653861961E-05
+  0.199506534484E-05  0.206567429861E-05  0.213842256630E-05  0.221336873355E-05
+  0.229057292501E-05  0.237009684396E-05  0.245200381305E-05  0.253635881597E-05
+  0.262322854027E-05  0.271268142125E-05  0.280478768694E-05  0.289961940427E-05
+  0.299725052642E-05  0.309775694134E-05  0.320121652154E-05  0.330770917512E-05
+  0.341731689818E-05  0.353012382847E-05  0.364621630046E-05  0.376568290181E-05
+  0.388861453132E-05  0.401510445826E-05  0.414524838330E-05  0.427914450098E-05
+  0.441689356375E-05  0.455859894767E-05  0.470436671976E-05  0.485430570709E-05
+  0.500852756761E-05  0.516714686284E-05  0.533028113232E-05  0.549805097008E-05
+  0.567058010294E-05  0.584799547089E-05  0.603042730949E-05  0.621800923438E-05
+  0.641087832791E-05  0.660917522807E-05  0.681304421956E-05  0.702263332729E-05
+  0.723809441222E-05  0.745958326963E-05  0.768725972993E-05  0.792128776202E-05
+  0.816183557928E-05  0.840907574830E-05  0.866318530030E-05  0.892434584551E-05
+  0.919274369035E-05  0.946856995768E-05  0.975202071004E-05  0.100432970762E-04
+  0.103426053805E-04  0.106501572763E-04  0.109661698819E-04  0.112908659205E-04
+  0.116244738636E-04  0.119672280780E-04  0.123193689769E-04  0.126811431738E-04
+  0.130528036418E-04  0.134346098761E-04  0.138268280603E-04  0.142297312379E-04
+  0.146435994875E-04  0.150687201027E-04  0.155053877764E-04  0.159539047902E-04
+  0.164145812081E-04  0.168877350755E-04  0.173736926232E-04  0.178727884765E-04
+  0.183853658701E-04  0.189117768673E-04  0.194523825865E-04  0.200075534319E-04
+  0.205776693310E-04  0.211631199781E-04  0.217643050834E-04  0.223816346291E-04
+  0.230155291319E-04  0.236664199120E-04  0.243347493691E-04  0.250209712653E-04
+  0.257255510155E-04  0.264489659852E-04  0.271917057952E-04  0.279542726352E-04
+  0.287371815847E-04  0.295409609418E-04  0.303661525617E-04  0.312133122020E-04
+  0.320830098786E-04  0.329758302293E-04  0.338923728877E-04  0.348332528661E-04
+  0.357991009481E-04  0.367905640918E-04  0.378083058428E-04  0.388530067578E-04
+  0.399253648394E-04  0.410260959816E-04  0.421559344269E-04  0.433156332352E-04
+  0.445059647644E-04  0.457277211633E-04  0.469817148778E-04  0.482687791691E-04
+  0.495897686456E-04  0.509455598088E-04  0.523370516124E-04  0.537651660363E-04
+  0.552308486755E-04  0.567350693430E-04  0.582788226895E-04  0.598631288382E-04
+  0.614890340363E-04  0.631576113225E-04  0.648699612126E-04  0.666272124021E-04
+  0.684305224869E-04  0.702810787027E-04  0.721800986832E-04  0.741288312378E-04
+  0.761285571496E-04  0.781805899935E-04  0.802862769757E-04  0.824469997944E-04
+  0.846641755232E-04  0.869392575165E-04  0.892737363393E-04  0.916691407199E-04
+  0.941270385276E-04  0.966490377759E-04  0.992367876508E-04  0.101891979567E-03
+  0.104616348249E-03  0.107411672844E-03  0.110279778059E-03  0.113222535329E-03
+  0.116241864021E-03  0.119339732656E-03  0.122518160178E-03  0.125779217245E-03
+  0.129125027557E-03  0.132557769220E-03  0.136079676143E-03  0.139693039473E-03
+  0.143400209064E-03  0.147203594991E-03  0.151105669094E-03  0.155108966571E-03
+  0.159216087607E-03  0.163429699048E-03  0.167752536116E-03  0.172187404174E-03
+  0.176737180527E-03  0.181404816287E-03  0.186193338264E-03  0.191105850930E-03
+  0.196145538417E-03  0.201315666575E-03  0.206619585082E-03  0.212060729613E-03
+  0.217642624059E-03  0.223368882812E-03  0.229243213104E-03  0.235269417410E-03
+  0.241451395917E-03  0.247793149052E-03  0.254298780082E-03  0.260972497785E-03
+  0.267818619178E-03  0.274841572339E-03  0.282045899281E-03  0.289436258920E-03
+  0.297017430115E-03  0.304794314782E-03  0.312771941108E-03  0.320955466831E-03
+  0.329350182623E-03  0.337961515556E-03  0.346795032662E-03  0.355856444587E-03
+  0.365151609348E-03  0.374686536185E-03  0.384467389521E-03  0.394500493025E-03
+  0.404792333787E-03  0.415349566607E-03  0.426179018396E-03  0.437287692700E-03
+  0.448682774342E-03  0.460371634201E-03  0.472361834104E-03  0.484661131867E-03
+  0.497277486467E-03  0.510219063353E-03  0.523494239907E-03  0.537111611055E-03
+  0.551079995028E-03  0.565408439285E-03  0.580106226601E-03  0.595182881317E-03
+  0.610648175769E-03  0.626512136896E-03  0.642785053024E-03  0.659477480849E-03
+  0.676600252608E-03  0.694164483455E-03  0.712181579037E-03  0.730663243292E-03
+  0.749621486461E-03  0.769068633327E-03  0.789017331686E-03  0.809480561061E-03
+  0.830471641662E-03  0.852004243599E-03  0.874092396364E-03  0.896750498578E-03
+  0.919993328020E-03  0.943836051947E-03  0.968294237706E-03  0.993383863662E-03
+  0.101912133043E-02  0.104552347245E-02  0.107260756987E-02  0.110039136084E-02
+  0.112889305405E-02  0.115813134180E-02  0.118812541328E-02  0.121889496838E-02
+  0.125046023183E-02  0.128284196782E-02  0.131606149499E-02  0.135014070189E-02
+  0.138510206297E-02  0.142096865495E-02  0.145776417374E-02  0.149551295189E-02
+  0.153423997652E-02  0.157397090780E-02  0.161473209809E-02  0.165655061149E-02
+  0.169945424421E-02  0.174347154536E-02  0.178863183854E-02  0.183496524401E-02
+  0.188250270161E-02  0.193127599436E-02  0.198131777279E-02  0.203266158012E-02
+  0.208534187815E-02  0.213939407397E-02  0.219485454762E-02  0.225176068052E-02
+  0.231015088491E-02  0.237006463414E-02  0.243154249405E-02  0.249462615527E-02
+  0.255935846665E-02  0.262578346974E-02  0.269394643444E-02  0.276389389574E-02
+  0.283567369183E-02  0.290933500330E-02  0.298492839381E-02  0.306250585198E-02
+  0.314212083482E-02  0.322382831251E-02  0.330768481478E-02  0.339374847884E-02
+  0.348207909891E-02  0.357273817753E-02  0.366578897857E-02  0.376129658208E-02
+  0.385932794106E-02  0.395995194020E-02  0.406323945668E-02  0.416926342309E-02
+  0.427809889255E-02  0.438982310620E-02  0.450451556298E-02  0.462225809199E-02
+  0.474313492740E-02  0.486723278602E-02  0.499464094772E-02  0.512545133870E-02
+  0.525975861783E-02  0.539766026610E-02  0.553925667933E-02  0.568465126436E-02
+  0.583395053863E-02  0.598726423360E-02  0.614470540187E-02  0.630639052838E-02
+  0.647243964569E-02  0.664297645362E-02  0.681812844334E-02  0.699802702615E-02
+  0.718280766718E-02  0.737261002404E-02  0.756757809089E-02  0.776786034784E-02
+  0.797360991624E-02  0.818498471976E-02  0.840214765179E-02  0.862526674923E-02
+  0.885451537305E-02  0.909007239580E-02  0.933212239647E-02  0.958085586288E-02
+  0.983646940206E-02  0.100991659588E-01  0.103691550428E-01  0.106466529648E-01
+  0.109318830820E-01  0.112250760532E-01  0.115264701039E-01  0.118363113021E-01
+  0.121548538452E-01  0.124823603578E-01  0.128191022018E-01  0.131653597991E-01
+  0.135214229665E-01  0.138875912646E-01  0.142641743606E-01  0.146514924057E-01
+  0.150498764272E-01  0.154596687372E-01  0.158812233572E-01  0.163149064597E-01
+  0.167610968284E-01  0.172201863361E-01  0.176925804424E-01  0.181786987116E-01
+  0.186789753509E-01  0.191938597711E-01  0.197238171698E-01  0.202693291378E-01
+  0.208308942902E-01  0.214090289233E-01  0.220042676978E-01  0.226171643493E-01
+  0.232482924278E-01  0.238982460669E-01  0.245676407841E-01  0.252571143128E-01
+  0.259673274680E-01  0.266989650471E-01  0.274527367654E-01  0.282293782308E-01
+  0.290296519554E-01  0.298543484090E-01  0.307042871130E-01  0.315803177780E-01
+  0.324833214868E-01  0.334142119228E-01  0.343739366475E-01  0.353634784266E-01
+  0.363838566089E-01  0.374361285579E-01  0.385213911379E-01  0.396407822584E-01
+  0.407954824760E-01  0.419867166579E-01  0.432157557078E-01  0.444839183563E-01
+  0.457925730181E-01  0.471431397178E-01  0.485370920862E-01  0.499759594294E-01
+  0.514613288727E-01  0.529948475807E-01  0.545782250566E-01  0.562132355219E-01
+  0.579017203789E-01  0.596455907576E-01  0.614468301492E-01  0.633074971274E-01
+  0.652297281602E-01  0.672157405131E-01  0.692678352447E-01  0.713884002981E-01
+  0.735799136873E-01  0.758449467803E-01  0.781861676807E-01  0.806063447073E-01
+  0.831083499733E-01  0.856951630641E-01  0.883698748148E-01  0.911356911867E-01
+  0.939959372414E-01  0.969540612123E-01  0.100013638672      0.103178376790
+  0.106452118690      0.109838847881      0.113342692787      0.116967931347
+  0.120718995693      0.124600476895      0.128617129772      0.132773877753
+  0.137075817783      0.141528225271      0.146136559057      0.150906466393
+  0.155843787924      0.160954562658      0.166245032894      0.171721649111
+  0.177391074781      0.183260191092      0.189336101560      0.195626136497
+  0.202137857314      0.208879060625      0.215857782122      0.223082300189
+  0.230561139209      0.238303072530      0.246317125050      0.254612575366
+  0.263198957448      0.272086061777      0.281283935894      0.290802884308
+  0.300653467689      0.310846501290      0.321393052521      0.332304437607
+  0.343592217256      0.355268191240      0.367344391833      0.379833075993
+  0.392746716207      0.406097989914      0.419899767389      0.434165098010
+  0.448907194786      0.464139417057      0.479875251248      0.496128289582
+  0.512912206625      0.530240733575      0.548127630172      0.566586654132
+  0.585631527995      0.605275903285      0.625533321896      0.646417174597
+  0.667940656591      0.690116720032      0.712958023459      0.736476878064
+  0.760685190790      0.785594404196      0.811215433115      0.837558598096
+  0.864633555681      0.892449225556      0.921013714683      0.950334238512
+  0.980417039430       1.01126730261       1.04288906951       1.07528514922
+   1.10845702802       1.14240477743       1.17712696117       1.21262054146
+   1.24888078510       1.28590116987       1.32367329192       1.36218677454
+   1.40142917926       1.44138591981       1.48204017972       1.52337283444
+   1.56536237876       1.60798486039       1.65121382064       1.69502024308
+   1.73937251109       1.78423637528       1.82957493167       1.87534861147
+   1.92151518344       1.96802976950       2.01484487448       2.06191043057
+   2.10917385714       2.15658013634       2.20407190487       2.25158956208
+   2.29907139453       2.34645371679       2.39367102833       2.44065618581
+   2.48734059027       2.53365438825       2.57952668566       2.62488577332
+   2.66965936240       2.71377482823       2.75715946067       2.79974071888
+   2.84144648848       2.88220533880       2.92194677807       2.96060150410
+   2.99810164827       3.03438101071       3.06937528440       3.10302226657
+   3.13526205548       3.16603723136       3.19529302034       3.22297744056
+   3.24904143025       3.27343895763       3.29612711307       3.31706618439
+   3.33621971631       3.35355455564       3.36904088391       3.38265223931
+   3.39436553019       3.40416104194       3.41202243947       3.41793676689
+   3.42189444596       3.42388927423       3.42391842346       3.42198243809
+   3.41808523296       3.41223408877       3.40443964302       3.39471587358
+   3.38308007146       3.36955279907       3.35415783001       3.33692206679
+   3.31787543308       3.29705073811       3.27448351216       3.25021181346
+   3.22427600896       3.19671853376       3.16758363628       3.13691711887
+   3.10476608602       3.07117871403       3.03620405763       2.99989190924
+   2.96229272559       2.92345763392       2.88343852542       2.84228823681
+   2.80006081151       2.75681182041       2.71259870678       2.66748110281
+   2.62152104398       2.57478298082       2.52733346129       2.47924039125
+   2.43057199976       2.38139620046       2.33178069990       2.28179265952
+   2.23149859870       2.18096424805       2.13025440939       2.07943282396
+   2.02856204539       1.97770331914       1.92691646840       1.87625978687
+   1.82578993841       1.77556186398       1.72562869578       1.67604167883
+   1.62685010007       1.57810122491       1.52984024140       1.48211021185
+   1.43495203199       1.38840439747       1.34250377773       1.29728439696
+   1.25277822214       1.20901495798       1.16602204838       1.12382468449
+   1.08244581892       1.04190618587       1.00222432712      0.963416623262
+  0.925497330262      0.888478620749      0.852370629914      0.817181505625
+  0.782917462457      0.749582839330      0.717180160408      0.685710198948
+  0.655172043772      0.625563168037      0.596879499977      0.569115495313
+  0.542264211006      0.516317380061      0.491265487070      0.467097844221
+  0.443802667485      0.421367152702      0.399777551338      0.379019245624
+  0.359076822887      0.339934148815      0.321574439473      0.303980331868
+  0.287133952873      0.271016986371      0.255610738437      0.240896200451
+  0.226854109995      0.213465009455      0.200709302208      0.188567306342
+  0.177019305825      0.166045599090      0.155626544984      0.145742606073
+  0.136374389283      0.127502683872      0.119108496762      0.111173085237
+  0.103677987044      0.966050479456E-01  0.899364467637E-01  0.836547179760E-01
+  0.777427719322E-01  0.721839127566E-01  0.669618540161E-01  0.620607322325E-01
+  0.574651183260E-01  0.531600270763E-01  0.491309246942E-01  0.453637345956E-01
+  0.418448414718E-01  0.385610937534E-01  0.354998045607E-01  0.326487512383E-01
+  0.299961735666E-01  0.275307707451E-01  0.252416972388E-01  0.231185575774E-01
+  0.211514001963E-01  0.193307104043E-01  0.176474025611E-01  0.160928115441E-01
+  0.146586835832E-01  0.133371665354E-01  0.121207996724E-01  0.110025030470E-01
+  0.997556650323E-02  0.903363839205E-02  0.817071404921E-02  0.738112409070E-02
+  0.665952257673E-02  0.600087509267E-02  0.540044679195E-02  0.485379044318E-02
+  0.435673452048E-02  0.390537137360E-02  0.349604551107E-02  0.312534202764E-02
+  0.279007520392E-02  0.248727730424E-02  0.221418759593E-02  0.196824161110E-02
+  0.174706066957E-02  0.154844167960E-02  0.137034723081E-02  0.121089599179E-02
+  0.106835342281E-02  0.941122812379E-03  0.827736644444E-03  0.726848301378E-03
+  0.637224106282E-03  0.557735706574E-03  0.487352799356E-03  0.425136197659E-03
+  0.370231235388E-03  0.321861507534E-03  0.279322941089E-03  0.241978191089E-03
+  0.209251355182E-03  0.180622999312E-03  0.155625486266E-03  0.133838598197E-03
+  0.114885443564E-03  0.984286384727E-04  0.841667519219E-04  0.718310041390E-04
+  0.611822069137E-04  0.520079346518E-04  0.441199147630E-04  0.373516259558E-04
+  0.315560930419E-04  0.266038669468E-04  0.223811787695E-04  0.187882569420E-04
+  0.157377967879E-04  0.131535720754E-04  0.109691784897E-04  0.912689931290E-05
+  0.757668399057E-05  0.627523067162E-05  0.518516423774E-05  0.427430177528E-05
+  0.351499788836E-05  0.288356269998E-05  0.235974583514E-05  0.192628012256E-05
+  0.156847918666E-05  0.127388352603E-05  0.103195008674E-05  0.833780735798E-06
+  0.671885420680E-06  0.539976164138E-06  0.432788387258E-06  0.345926378726E-06
+  0.275730033033E-06  0.219160265155E-06  0.173700774124E-06  0.137274073059E-06
+  0.108169929108E-06  0.849845640133E-07  0.665691552395E-07  0.519863497756E-07
+  0.404736585535E-07  0.314127399814E-07  0.243037072824E-07  0.187437071675E-07
+  0.144091178577E-07  0.110408035741E-07  0.843194131398E-08  0.641800494873E-08
+  0.486855230837E-08  0.368051381172E-08  0.277272715247E-08  0.208150231218E-08
+  0.155703543195E-08  0.116051947575E-08  0.861824744947E-09  0.637643688623E-09
+  0.470012578550E-09  0.345137915389E-09  0.252468289502E-09  0.183963180209E-09
+  0.133519144873E-09  0.965212905808E-10  0.694940697878E-10  0.498304996213E-10
+  0.355830477954E-10  0.253028069692E-10  0.179163226447E-10  0.126316570201E-10
+  0.886705534017E-11  0.619701034916E-11  0.431165986036E-11  0.298635673561E-11
+  0.205896488228E-11  0.141299648237E-11  0.965145112429E-12  0.656111618506E-12
+  0.443884802484E-12  0.298843480737E-12  0.200203401266E-12  0.133452319579E-12
+  0.885075511449E-13  0.583991076861E-13  0.383332465304E-13  0.250299486203E-13
+  0.162566247357E-13  0.105016516454E-13  0.674702019805E-14  0.431085668645E-14
+  0.273893643287E-14  0.173035954444E-14  0.108691513680E-14  0.678778794951E-15
+  0.421407544372E-15  0.260067103446E-15  0.159530918998E-15  0.972629622192E-16
+  0.589331597327E-16  0.354852263006E-16  0.212313021985E-16  0.126215308973E-16
+  0.745449967116E-17  0.437381386044E-17  0.254918435779E-17  0.147572254139E-17
+  0.848464353185E-18  0.484451554817E-18  0.274673612052E-18  0.154630387675E-18
+  0.864261323528E-19  0.479543662330E-19  0.264121707665E-19  0.144388437913E-19
+  0.783379365950E-20  0.421775860119E-20  0.225330076092E-20  0.119437829040E-20
+  0.628068248579E-21  0.327619950764E-21  0.169507228107E-21  0.869792665669E-22
+  0.442596110960E-22  0.223315004122E-22  0.111712100530E-22  0.553997108951E-23
+  0.272327885101E-23  0.132680112514E-23  0.640618995071E-24  0.306495850787E-24
+  0.145288123538E-24  0.682284720448E-25  0.317380207954E-25  0.146224686637E-25
+  0.667168550202E-26  0.301419342451E-26  0.134825910156E-26  0.597018262054E-27
+  0.261672759566E-27  0.113508918861E-27  0.487242603975E-28  0.206941133034E-28
+  0.869513769137E-29  0.361389239242E-29  0.148553665925E-29  0.603865848388E-30
+  0.242708659321E-30  0.964396828800E-31  0.378781868533E-31  0.147035399721E-31
+  0.564013565969E-32  0.213760225168E-32  0.800327812026E-33  0.295968643620E-33
+  0.108091749715E-33  0.389798221138E-34  0.138777211760E-34  0.487704896715E-35
+  0.169155252888E-35  0.578936765550E-36  0.195488393835E-36  0.651149993624E-37
+  0.213912608715E-37  0.692964716610E-38  0.221323945624E-38  0.696803622044E-39
+  0.216211251132E-39  0.661077313340E-40  0.199136767643E-40  0.590872837093E-41
+  0.172662118367E-41  0.496794310269E-42  0.140717349465E-42  0.392305195743E-43
+  0.107626361575E-43  0.290497996142E-44  0.771272926477E-45  0.201383064271E-45
+  0.517006518290E-46  0.130477147567E-46  0.323626610705E-47  0.788733201075E-48
+  0.188840759950E-48  0.444061844890E-49  0.102535544161E-49  0.232428087417E-50
+  0.517112026603E-51  0.112891162396E-51  0.241774597776E-52  0.507845570367E-53
+  0.104596343369E-53  0.211182253891E-54  0.417874005378E-55  0.810158343091E-56
+  0.153857736651E-56  0.286141307296E-57  0.521001663809E-58  0.928494164174E-59
+  0.161913687017E-59  0.276206362422E-60  0.460796897285E-61  0.751605228911E-62
+  0.119826155117E-62  0.186668428223E-63  0.284067708858E-64  0.422160617944E-65
+  0.612505042774E-66  0.867338185497E-67  0.119834576218E-67  0.161495400115E-68
+  0.212209482853E-69  0.271908959957E-70  0.340415357065E-71  0.415183924663E-72
+  0.493145299555E-73  0.570253124647E-74
Added: SwiftApps/ematter/workflow-run/N.sic.psf
--- SwiftApps/ematter/workflow-run/N.sic.psf	                        (rev 0)
+++ SwiftApps/ematter/workflow-run/N.sic.psf	2015-01-27 22:12:52 UTC (rev 8376)
@@ -0,0 +1,1800 @@
+  N ca nrl nc
+ ATM3       3-OCT-14 Troullier-Martins
+ 2s 2.00  r= 1.48/2p 3.00  r= 1.48/3d 0.00  r= 1.48/4f 0.00  r= 1.48/
+   4  0 1018  0.354107453809E-03  0.125000000000E-01   5.00000000000
+ Radial grid follows
+  0.445412344792E-05  0.896427287179E-05  0.135311529916E-04  0.181554773917E-04
+  0.228379686322E-04  0.275793583619E-04  0.323803874325E-04  0.372418060146E-04
+  0.421643737147E-04  0.471488596942E-04  0.521960427889E-04  0.573067116317E-04
+  0.624816647748E-04  0.677217108153E-04  0.730276685210E-04  0.784003669585E-04
+  0.838406456230E-04  0.893493545690E-04  0.949273545435E-04  0.100575517120E-03
+  0.106294724837E-03  0.112085871330E-03  0.117949861479E-03  0.123887611544E-03
+  0.129900049310E-03  0.135988114233E-03  0.142152757586E-03  0.148394942607E-03
+  0.154715644649E-03  0.161115851336E-03  0.167596562712E-03  0.174158791402E-03
+  0.180803562768E-03  0.187531915069E-03  0.194344899623E-03  0.201243580973E-03
+  0.208229037052E-03  0.215302359352E-03  0.222464653093E-03  0.229717037400E-03
+  0.237060645471E-03  0.244496624760E-03  0.252026137154E-03  0.259650359155E-03
+  0.267370482063E-03  0.275187712163E-03  0.283103270913E-03  0.291118395135E-03
+  0.299234337209E-03  0.307452365267E-03  0.315773763392E-03  0.324199831821E-03
+  0.332731887143E-03  0.341371262509E-03  0.350119307840E-03  0.358977390035E-03
+  0.367946893187E-03  0.377029218801E-03  0.386225786007E-03  0.395538031788E-03
+  0.404967411201E-03  0.414515397606E-03  0.424183482896E-03  0.433973177728E-03
+  0.443886011762E-03  0.453923533898E-03  0.464087312520E-03  0.474378935739E-03
+  0.484800011642E-03  0.495352168544E-03  0.506037055239E-03  0.516856341264E-03
+  0.527811717154E-03  0.538904894709E-03  0.550137607260E-03  0.561511609941E-03
+  0.573028679965E-03  0.584690616895E-03  0.596499242934E-03  0.608456403203E-03
+  0.620563966033E-03  0.632823823255E-03  0.645237890498E-03  0.657808107484E-03
+  0.670536438335E-03  0.683424871878E-03  0.696475421959E-03  0.709690127751E-03
+  0.723071054080E-03  0.736620291742E-03  0.750339957833E-03  0.764232196080E-03
+  0.778299177172E-03  0.792543099104E-03  0.806966187518E-03  0.821570696051E-03
+  0.836358906686E-03  0.851333130112E-03  0.866495706082E-03  0.881849003779E-03
+  0.897395422187E-03  0.913137390466E-03  0.929077368330E-03  0.945217846433E-03
+  0.961561346757E-03  0.978110423009E-03  0.994867661014E-03  0.101183567913E-02
+  0.102901712863E-02  0.104641469417E-02  0.106403109413E-02  0.108186908114E-02
+  0.109993144240E-02  0.111822100019E-02  0.113674061230E-02  0.115549317246E-02
+  0.117448161078E-02  0.119370889425E-02  0.121317802718E-02  0.123289205165E-02
+  0.125285404803E-02  0.127306713541E-02  0.129353447213E-02  0.131425925625E-02
+  0.133524472606E-02  0.135649416059E-02  0.137801088010E-02  0.139979824663E-02
+  0.142185966449E-02  0.144419858082E-02  0.146681848614E-02  0.148972291483E-02
+  0.151291544577E-02  0.153639970284E-02  0.156017935550E-02  0.158425811936E-02
+  0.160863975679E-02  0.163332807747E-02  0.165832693899E-02  0.168364024748E-02
+  0.170927195819E-02  0.173522607613E-02  0.176150665669E-02  0.178811780626E-02
+  0.181506368288E-02  0.184234849691E-02  0.186997651165E-02  0.189795204403E-02
+  0.192627946529E-02  0.195496320164E-02  0.198400773499E-02  0.201341760358E-02
+  0.204319740279E-02  0.207335178576E-02  0.210388546417E-02  0.213480320898E-02
+  0.216610985114E-02  0.219781028238E-02  0.222990945596E-02  0.226241238744E-02
+  0.229532415547E-02  0.232864990257E-02  0.236239483598E-02  0.239656422839E-02
+  0.243116341885E-02  0.246619781355E-02  0.250167288668E-02  0.253759418131E-02
+  0.257396731019E-02  0.261079795672E-02  0.264809187575E-02  0.268585489453E-02
+  0.272409291361E-02  0.276281190777E-02  0.280201792691E-02  0.284171709707E-02
+  0.288191562132E-02  0.292261978075E-02  0.296383593548E-02  0.300557052562E-02
+  0.304783007228E-02  0.309062117859E-02  0.313395053077E-02  0.317782489910E-02
+  0.322225113904E-02  0.326723619229E-02  0.331278708786E-02  0.335891094316E-02
+  0.340561496513E-02  0.345290645138E-02  0.350079279131E-02  0.354928146723E-02
+  0.359838005562E-02  0.364809622822E-02  0.369843775329E-02  0.374941249680E-02
+  0.380102842364E-02  0.385329359892E-02  0.390621618917E-02  0.395980446366E-02
+  0.401406679567E-02  0.406901166379E-02  0.412464765327E-02  0.418098345734E-02
+  0.423802787860E-02  0.429578983035E-02  0.435427833801E-02  0.441350254052E-02
+  0.447347169180E-02  0.453419516214E-02  0.459568243971E-02  0.465794313203E-02
+  0.472098696744E-02  0.478482379668E-02  0.484946359439E-02  0.491491646065E-02
+  0.498119262263E-02  0.504830243609E-02  0.511625638710E-02  0.518506509358E-02
+  0.525473930704E-02  0.532528991422E-02  0.539672793880E-02  0.546906454310E-02
+  0.554231102988E-02  0.561647884404E-02  0.569157957445E-02  0.576762495577E-02
+  0.584462687023E-02  0.592259734953E-02  0.600154857674E-02  0.608149288813E-02
+  0.616244277516E-02  0.624441088643E-02  0.632741002961E-02  0.641145317350E-02
+  0.649655344999E-02  0.658272415619E-02  0.666997875644E-02  0.675833088446E-02
+  0.684779434543E-02  0.693838311821E-02  0.703011135748E-02  0.712299339597E-02
+  0.721704374667E-02  0.731227710515E-02  0.740870835182E-02  0.750635255425E-02
+  0.760522496955E-02  0.770534104673E-02  0.780671642914E-02  0.790936695688E-02
+  0.801330866931E-02  0.811855780754E-02  0.822513081695E-02  0.833304434979E-02
+  0.844231526778E-02  0.855296064472E-02  0.866499776916E-02  0.877844414715E-02
+  0.889331750490E-02  0.900963579162E-02  0.912741718227E-02  0.924668008044E-02
+  0.936744312119E-02  0.948972517400E-02  0.961354534568E-02  0.973892298339E-02
+  0.986587767765E-02  0.999442926537E-02  0.101245978330E-01  0.102564037197E-01
+  0.103898675203E-01  0.105250100888E-01  0.106618525417E-01  0.108004162606E-01
+  0.109407228966E-01  0.110827943729E-01  0.112266528883E-01  0.113723209210E-01
+  0.115198212321E-01  0.116691768687E-01  0.118204111679E-01  0.119735477604E-01
+  0.121286105741E-01  0.122856238379E-01  0.124446120855E-01  0.126056001590E-01
+  0.127686132132E-01  0.129336767191E-01  0.131008164684E-01  0.132700585770E-01
+  0.134414294892E-01  0.136149559821E-01  0.137906651696E-01  0.139685845066E-01
+  0.141487417933E-01  0.143311651798E-01  0.145158831700E-01  0.147029246265E-01
+  0.148923187748E-01  0.150840952083E-01  0.152782838924E-01  0.154749151694E-01
+  0.156740197634E-01  0.158756287849E-01  0.160797737357E-01  0.162864865138E-01
+  0.164957994187E-01  0.167077451557E-01  0.169223568420E-01  0.171396680109E-01
+  0.173597126178E-01  0.175825250452E-01  0.178081401079E-01  0.180365930587E-01
+  0.182679195939E-01  0.185021558587E-01  0.187393384531E-01  0.189795044371E-01
+  0.192226913374E-01  0.194689371523E-01  0.197182803583E-01  0.199707599157E-01
+  0.202264152750E-01  0.204852863828E-01  0.207474136883E-01  0.210128381494E-01
+  0.212816012393E-01  0.215537449526E-01  0.218293118125E-01  0.221083448767E-01
+  0.223908877448E-01  0.226769845647E-01  0.229666800396E-01  0.232600194350E-01
+  0.235570485857E-01  0.238578139033E-01  0.241623623828E-01  0.244707416105E-01
+  0.247829997715E-01  0.250991856566E-01  0.254193486705E-01  0.257435388394E-01
+  0.260718068187E-01  0.264042039008E-01  0.267407820234E-01  0.270815937777E-01
+  0.274266924162E-01  0.277761318611E-01  0.281299667131E-01  0.284882522597E-01
+  0.288510444837E-01  0.292184000721E-01  0.295903764249E-01  0.299670316643E-01
+  0.303484246434E-01  0.307346149555E-01  0.311256629438E-01  0.315216297103E-01
+  0.319225771255E-01  0.323285678384E-01  0.327396652857E-01  0.331559337024E-01
+  0.335774381313E-01  0.340042444331E-01  0.344364192973E-01  0.348740302521E-01
+  0.353171456751E-01  0.357658348040E-01  0.362201677474E-01  0.366802154956E-01
+  0.371460499322E-01  0.376177438446E-01  0.380953709361E-01  0.385790058368E-01
+  0.390687241156E-01  0.395646022921E-01  0.400667178482E-01  0.405751492405E-01
+  0.410899759124E-01  0.416112783067E-01  0.421391378779E-01  0.426736371051E-01
+  0.432148595049E-01  0.437628896445E-01  0.443178131546E-01  0.448797167432E-01
+  0.454486882089E-01  0.460248164545E-01  0.466081915014E-01  0.471989045031E-01
+  0.477970477596E-01  0.484027147320E-01  0.490160000572E-01  0.496369995621E-01
+  0.502658102791E-01  0.509025304613E-01  0.515472595975E-01  0.522000984278E-01
+  0.528611489598E-01  0.535305144838E-01  0.542082995896E-01  0.548946101825E-01
+  0.555895535000E-01  0.562932381283E-01  0.570057740196E-01  0.577272725091E-01
+  0.584578463324E-01  0.591976096431E-01  0.599466780308E-01  0.607051685389E-01
+  0.614731996830E-01  0.622508914698E-01  0.630383654149E-01  0.638357445629E-01
+  0.646431535059E-01  0.654607184032E-01  0.662885670009E-01  0.671268286520E-01
+  0.679756343368E-01  0.688351166827E-01  0.697054099856E-01  0.705866502307E-01
+  0.714789751135E-01  0.723825240616E-01  0.732974382563E-01  0.742238606549E-01
+  0.751619360128E-01  0.761118109060E-01  0.770736337546E-01  0.780475548453E-01
+  0.790337263553E-01  0.800323023758E-01  0.810434389363E-01  0.820672940291E-01
+  0.831040276336E-01  0.841538017414E-01  0.852167803821E-01  0.862931296480E-01
+  0.873830177210E-01  0.884866148983E-01  0.896040936193E-01  0.907356284922E-01
+  0.918813963216E-01  0.930415761362E-01  0.942163492163E-01  0.954058991227E-01
+  0.966104117250E-01  0.978300752306E-01  0.990650802146E-01  0.100315619649
+  0.101581888933      0.102864085924      0.104162410967      0.105477066929
+  0.106808259228      0.108156195864      0.109521087456      0.110903147271
+  0.112302591258      0.113719638083      0.115154509164      0.116607428700
+  0.118078623715      0.119568324085      0.121076762578      0.122604174893
+  0.124150799689      0.125716878630      0.127302656419      0.128908380837
+  0.130534302782      0.132180676307      0.133847758662      0.135535810332
+  0.137245095078      0.138975879979      0.140728435474      0.142503035403
+  0.144299957052      0.146119481193      0.147961892129      0.149827477743
+  0.151716529534      0.153629342673      0.155566216038      0.157527452271
+  0.159513357819      0.161524242984      0.163560421971      0.165622212936
+  0.167709938039      0.169823923491      0.171964499606      0.174132000855
+  0.176326765913      0.178549137716      0.180799463516      0.183078094930
+  0.185385387999      0.187721703242      0.190087405712      0.192482865057
+  0.194908455571      0.197364556258      0.199851550888      0.202369828060
+  0.204919781258      0.207501808920      0.210116314492      0.212763706495
+  0.215444398590      0.218158809641      0.220907363780      0.223690490473
+  0.226508624591      0.229362206473      0.232251681996      0.235177502646
+  0.238140125590      0.241140013743      0.244177635844      0.247253466527
+  0.250367986398      0.253521682105      0.256715046422      0.259948578316
+  0.263222783035      0.266538172179      0.269895263785      0.273294582405
+  0.276736659190      0.280222031970      0.283751245344      0.287324850756
+  0.290943406591      0.294607478256      0.298317638268      0.302074466348
+  0.305878549508      0.309730482144      0.313630866128      0.317580310902
+  0.321579433577      0.325628859022      0.329729219969      0.333881157107
+  0.338085319185      0.342342363113      0.346652954061      0.351017765569
+  0.355437479646      0.359912786883      0.364444386555      0.369032986734
+  0.373679304398      0.378384065544      0.383148005299      0.387971868040
+  0.392856407505      0.397802386913      0.402810579083      0.407881766555
+  0.413016741714      0.418216306908      0.423481274582      0.428812467396
+  0.434210718360      0.439676870963      0.445211779301      0.450816308216
+  0.456491333426      0.462237741666      0.468056430823      0.473948310080
+  0.479914300055      0.485955332945      0.492072352675      0.498266315041
+  0.504538187862      0.510888951132      0.517319597170      0.523831130778
+  0.530424569395      0.537100943260      0.543861295571      0.550706682646
+  0.557638174090      0.564656852963      0.571763815949      0.578960173524
+  0.586247050134      0.593625584368      0.601096929138      0.608662251856
+  0.616322734619      0.624079574393      0.631933983201      0.639887188309
+  0.647940432422      0.656094973876      0.664352086834      0.672713061488
+  0.681179204256      0.689751837991      0.698432302183      0.707221953174
+  0.716122164364      0.725134326429      0.734259847538      0.743500153572
+  0.752856688347      0.762330913842      0.771924310424      0.781638377079
+  0.791474631650      0.801434611074      0.811519871616      0.821731989118
+  0.832072559246      0.842543197735      0.853145540642      0.863881244605
+  0.874751987101      0.885759466704      0.896905403356      0.908191538632
+  0.919619636014      0.931191481165      0.942908882209      0.954773670015
+  0.966787698479      0.978952844818      0.991271009860       1.00374411834
+   1.01637411922       1.02916298595       1.04211271682       1.05522533525
+   1.06850289012       1.08194745607       1.09556113383       1.10934605059
+   1.12330436025       1.13743824384       1.15174990979       1.16624159434
+   1.18091556184       1.19577410514       1.21081954589       1.22605423500
+   1.24148055290       1.25710091000       1.27291774700       1.28893353532
+   1.30515077746       1.32157200739       1.33819979097       1.35503672631
+   1.37208544423       1.38934860863       1.40682891690       1.42452910038
+   1.44245192476       1.46060019052       1.47897673336       1.49758442465
+   1.51642617189       1.53550491913       1.55482364747       1.57438537549
+   1.59419315977       1.61425009530       1.63455931602       1.65512399529
+   1.67594734638       1.69703262299       1.71838311972       1.74000217265
+   1.76189315978       1.78405950163       1.80650466174       1.82923214721
+   1.85224550926       1.87554834376       1.89914429184       1.92303704040
+   1.94723032275       1.97172791913       1.99653365733       2.02165141331
+   2.04708511177       2.07283872677       2.09891628237       2.12532185324
+   2.15205956531       2.17913359638       2.20654817685       2.23430759029
+   2.26241617416       2.29087832050       2.31969847656       2.34888114556
+   2.37843088735       2.40835231913       2.43865011619       2.46932901263
+   2.50039380207       2.53184933847       2.56370053680       2.59595237390
+   2.62860988916       2.66167818539       2.69516242958       2.72906785372
+   2.76339975559       2.79816349963       2.83336451774       2.86900831014
+   2.90510044627       2.94164656557       2.97865237847       3.01612366719
+   3.05406628671       3.09248616562       3.13138930712       3.17078178989
+   3.21066976911       3.25105947734       3.29195722555       3.33336940411
+   3.37530248375       3.41776301660       3.46075763720       3.50429306356
+   3.54837609817       3.59301362909       3.63821263103       3.68398016643
+   3.73032338655       3.77724953263       3.82476593695       3.87288002407
+   3.92159931190       3.97093141293       4.02088403540       4.07146498451
+   4.12268216364       4.17454357558       4.22705732377       4.28023161360
+   4.33407475366       4.38859515705       4.44380134268       4.49970193665
+   4.55630567353       4.61362139778       4.67165806508       4.73042474379
+   4.78993061632       4.85018498058       4.91119725145       4.97297696220
+   5.03553376606       5.09887743764       5.16301787452       5.22796509879
+   5.29372925856       5.36032062963       5.42774961704       5.49602675669
+   5.56516271704       5.63516830072       5.70605444624       5.77783222970
+   5.85051286653       5.92410771324       5.99862826915       6.07408617827
+   6.15049323104       6.22786136622       6.30620267274       6.38552939159
+   6.46585391773       6.54718880202       6.62954675322       6.71294063991
+   6.79738349257       6.88288850556       6.96946903921       7.05713862191
+   7.14591095220       7.23579990095       7.32681951349       7.41898401181
+   7.51230779680       7.60680545051       7.70249173837       7.79938161157
+   7.89749020934       7.99683286135       8.09742509010       8.19928261332
+   8.30242134647       8.40685740517       8.51260710777       8.61968697788
+   8.72811374695       8.83790435688       8.94907596268       9.06164593514
+   9.17563186353       9.29105155841       9.40792305432       9.52626461268
+   9.64609472460       9.76743211377       9.89029573941       10.0147047992
+   10.1406787324       10.2682372225       10.3974002009       10.5281878496
+   10.6606206044       10.7947191582       10.9305044642       11.0679977390
+   11.2072204663       11.3481944000       11.4909415675       11.6354842733
+   11.7818451025       11.9300469243       12.0801128955       12.2320664643
+   12.3859313737       12.5417316654       12.6994916835       12.8592360783
+   13.0209898103       13.1847781538       13.3506267010       13.5185613661
+   13.6886083893       13.8607943407       14.0351461247       14.2116909843
+   14.3904565047       14.5714706186       14.7547616098       14.9403581178
+   15.1282891426       15.3185840486       15.5112725698       15.7063848143
+   15.9039512687       16.1040028031       16.3065706761       16.5116865393
+   16.7193824424       16.9296908384       17.1426445883       17.3582769667
+   17.5766216664       17.7977128044       18.0215849266       18.2482730134
+   18.4778124853       18.7102392084       18.9455894997       19.1839001333
+   19.4252083456       19.6695518415       19.9169688003       20.1674978813
+   20.4211782302       20.6780494851       20.9381517827       21.2015257643
+   21.4682125829       21.7382539086       22.0116919361       22.2885693906
+   22.5689295347       22.8528161753       23.1402736703       23.4313469354
+   23.7260814515       24.0245232714       24.3267190273       24.6327159378
+   24.9425618157       25.2563050749       25.5739947385       25.8956804461
+   26.2214124619       26.5512416820       26.8852196429       27.2233985295
+   27.5658311828       27.9125711086       28.2636724858       28.6191901747
+   28.9791797255       29.3436973875       29.7128001173       30.0865455878
+   30.4649921976       30.8481990798       31.2362261111       31.6291339217
+   32.0269839041       32.4298382233       32.8377598260       33.2508124508
+   33.6690606380       34.0925697398       34.5214059303       34.9556362160
+   35.3953284463       35.8405513241       36.2913744162       36.7478681648
+   37.2101038979       37.6781538407       38.1520911270       38.6319898106
+   39.1179248764       39.6099722530       40.1082088236       40.6127124388
+   41.1235619283       41.6408371133       42.1646188192       42.6949888878
+   43.2320301907       43.7758266416       44.3264632098       44.8840259334
+   45.4486019326       46.0202794238       46.5991477325       47.1852973082
+   47.7788197380       48.3798077608       48.9883552824       49.6045573895
+   50.2285103650       50.8603117027       51.5000601229       52.1478555876
+   52.8037993162       53.4679938012       54.1405428243       54.8215514727
+   55.5111261554       56.2093746198       56.9164059688       57.6323306772
+   58.3572606099       59.0913090387       59.8345906600       60.5872216132
+   61.3493194984       62.1210033949       62.9023938799       63.6936130472
+   64.4947845265       65.3060335024       66.1274867342       66.9592725757
+   67.8015209952       68.6543635955       69.5179336352       70.3923660487
+   71.2777974680       72.1743662435       73.0822124659       74.0014779880
+   74.9323064470       75.8748432865       76.8292357801       77.7956330534
+   78.7741861080       79.7650478447       80.7683730878       81.7843186088
+   82.8130431513       83.8547074556       84.9094742840       85.9775084457
+   87.0589768234       88.1540483987       89.2628942787       90.3856877229
+   91.5226041700       92.6738212655       93.8395188895       95.0198791846
+   96.2150865844       97.4253278426       98.6507920619       99.8916707234
+   101.148157717       102.420449371       103.708744485       105.013244356
+   106.334152815       107.671676257       109.026023674       110.397406683
+   111.786039568       113.192139303       114.615925596       116.057620916
+   117.517450531       118.995642542
+ Down Pseudopotential follows (l on next line)
+  0
+ -0.476321741600E-04 -0.958634873108E-04 -0.144701475690E-03 -0.194153770327E-03
+ -0.244228098241E-03 -0.294932283641E-03 -0.346274249156E-03 -0.398262017066E-03
+ -0.450903710559E-03 -0.504207555003E-03 -0.558181879223E-03 -0.612835116812E-03
+ -0.668175807441E-03 -0.724212598198E-03 -0.780954244937E-03 -0.838409613648E-03
+ -0.896587681839E-03 -0.955497539941E-03 -0.101514839273E-02 -0.107554956076E-02
+ -0.113671048183E-02 -0.119864071244E-02 -0.126134992930E-02 -0.132484793085E-02
+ -0.138914463875E-02 -0.145425009949E-02 -0.152017448592E-02 -0.158692809882E-02
+ -0.165452136858E-02 -0.172296485675E-02 -0.179226925777E-02 -0.186244540054E-02
+ -0.193350425023E-02 -0.200545690990E-02 -0.207831462226E-02 -0.215208877147E-02
+ -0.222679088485E-02 -0.230243263474E-02 -0.237902584028E-02 -0.245658246929E-02
+ -0.253511464011E-02 -0.261463462352E-02 -0.269515484465E-02 -0.277668788490E-02
+ -0.285924648394E-02 -0.294284354168E-02 -0.302749212028E-02 -0.311320544621E-02
+ -0.319999691231E-02 -0.328788007987E-02 -0.337686868075E-02 -0.346697661957E-02
+ -0.355821797579E-02 -0.365060700603E-02 -0.374415814618E-02 -0.383888601373E-02
+ -0.393480541005E-02 -0.403193132265E-02 -0.413027892759E-02 -0.422986359180E-02
+ -0.433070087550E-02 -0.443280653464E-02 -0.453619652335E-02 -0.464088699643E-02
+ -0.474689431189E-02 -0.485423503346E-02 -0.496292593327E-02 -0.507298399436E-02
+ -0.518442641343E-02 -0.529727060344E-02 -0.541153419642E-02 -0.552723504614E-02
+ -0.564439123096E-02 -0.576302105663E-02 -0.588314305915E-02 -0.600477600766E-02
+ -0.612793890741E-02 -0.625265100267E-02 -0.637893177978E-02 -0.650680097018E-02
+ -0.663627855350E-02 -0.676738476067E-02 -0.690014007710E-02 -0.703456524584E-02
+ -0.717068127088E-02 -0.730850942038E-02 -0.744807123001E-02 -0.758938850634E-02
+ -0.773248333020E-02 -0.787737806016E-02 -0.802409533603E-02 -0.817265808237E-02
+ -0.832308951209E-02 -0.847541313007E-02 -0.862965273683E-02 -0.878583243227E-02
+ -0.894397661940E-02 -0.910411000817E-02 -0.926625761935E-02 -0.943044478838E-02
+ -0.959669716942E-02 -0.976504073925E-02 -0.993550180143E-02 -0.101081069903E-01
+ -0.102828832754E-01 -0.104598579651E-01 -0.106390587116E-01 -0.108205135148E-01
+ -0.110042507267E-01 -0.111902990561E-01 -0.113786875726E-01 -0.115694457117E-01
+ -0.117626032789E-01 -0.119581904549E-01 -0.121562377996E-01 -0.123567762576E-01
+ -0.125598371625E-01 -0.127654522422E-01 -0.129736536234E-01 -0.131844738372E-01
+ -0.133979458235E-01 -0.136141029368E-01 -0.138329789510E-01 -0.140546080648E-01
+ -0.142790249069E-01 -0.145062645418E-01 -0.147363624749E-01 -0.149693546579E-01
+ -0.152052774952E-01 -0.154441678486E-01 -0.156860630439E-01 -0.159310008759E-01
+ -0.161790196152E-01 -0.164301580135E-01 -0.166844553099E-01 -0.169419512371E-01
+ -0.172026860274E-01 -0.174667004192E-01 -0.177340356633E-01 -0.180047335291E-01
+ -0.182788363116E-01 -0.185563868375E-01 -0.188374284723E-01 -0.191220051268E-01
+ -0.194101612641E-01 -0.197019419064E-01 -0.199973926423E-01 -0.202965596336E-01
+ -0.205994896227E-01 -0.209062299399E-01 -0.212168285107E-01 -0.215313338633E-01
+ -0.218497951363E-01 -0.221722620862E-01 -0.224987850952E-01 -0.228294151793E-01
+ -0.231642039958E-01 -0.235032038520E-01 -0.238464677127E-01 -0.241940492089E-01
+ -0.245460026461E-01 -0.249023830127E-01 -0.252632459886E-01 -0.256286479538E-01
+ -0.259986459975E-01 -0.263732979267E-01 -0.267526622755E-01 -0.271367983138E-01
+ -0.275257660571E-01 -0.279196262756E-01 -0.283184405034E-01 -0.287222710487E-01
+ -0.291311810031E-01 -0.295452342515E-01 -0.299644954822E-01 -0.303890301970E-01
+ -0.308189047211E-01 -0.312541862141E-01 -0.316949426797E-01 -0.321412429768E-01
+ -0.325931568304E-01 -0.330507548417E-01 -0.335141085002E-01 -0.339832901938E-01
+ -0.344583732209E-01 -0.349394318013E-01 -0.354265410882E-01 -0.359197771795E-01
+ -0.364192171300E-01 -0.369249389634E-01 -0.374370216841E-01 -0.379555452900E-01
+ -0.384805907848E-01 -0.390122401905E-01 -0.395505765602E-01 -0.400956839914E-01
+ -0.406476476387E-01 -0.412065537272E-01 -0.417724895661E-01 -0.423455435620E-01
+ -0.429258052332E-01 -0.435133652229E-01 -0.441083153142E-01 -0.447107484435E-01
+ -0.453207587158E-01 -0.459384414189E-01 -0.465638930383E-01 -0.471972112724E-01
+ -0.478384950475E-01 -0.484878445334E-01 -0.491453611588E-01 -0.498111476275E-01
+ -0.504853079340E-01 -0.511679473797E-01 -0.518591725896E-01 -0.525590915286E-01
+ -0.532678135185E-01 -0.539854492550E-01 -0.547121108250E-01 -0.554479117236E-01
+ -0.561929668725E-01 -0.569473926372E-01 -0.577113068456E-01 -0.584848288060E-01
+ -0.592680793260E-01 -0.600611807308E-01 -0.608642568829E-01 -0.616774332007E-01
+ -0.625008366784E-01 -0.633345959057E-01 -0.641788410876E-01 -0.650337040650E-01
+ -0.658993183346E-01 -0.667758190705E-01 -0.676633431444E-01 -0.685620291473E-01
+ -0.694720174109E-01 -0.703934500295E-01 -0.713264708819E-01 -0.722712256540E-01
+ -0.732278618609E-01 -0.741965288706E-01 -0.751773779264E-01 -0.761705621710E-01
+ -0.771762366697E-01 -0.781945584349E-01 -0.792256864502E-01 -0.802697816952E-01
+ -0.813270071704E-01 -0.823975279224E-01 -0.834815110695E-01 -0.845791258277E-01
+ -0.856905435370E-01 -0.868159376874E-01 -0.879554839466E-01 -0.891093601865E-01
+ -0.902777465109E-01 -0.914608252837E-01 -0.926587811566E-01 -0.938718010980E-01
+ -0.951000744220E-01 -0.963437928173E-01 -0.976031503769E-01 -0.988783436286E-01
+ -0.100169571564     -0.101477035672     -0.102800939967     -0.104141491020
+ -0.105498897994     -0.106873372674     -0.108265129499     -0.109674385597
+ -0.111101360815     -0.112546277757     -0.114009361817     -0.115490841212
+ -0.116990947019     -0.118509913208     -0.120047976681     -0.121605377309
+ -0.123182357963     -0.124779164559     -0.126396046089     -0.128033254664
+ -0.129691045550     -0.131369677208     -0.133069411334     -0.134790512898
+ -0.136533250185     -0.138297894837     -0.140084721892     -0.141894009830
+ -0.143726040610     -0.145581099718     -0.147459476209     -0.149361462751
+ -0.151287355667     -0.153237454984     -0.155212064477     -0.157211491716
+ -0.159236048108     -0.161286048953     -0.163361813484     -0.165463664919
+ -0.167591930510     -0.169746941589     -0.171929033624     -0.174138546265
+ -0.176375823396     -0.178641213190     -0.180935068157     -0.183257745198
+ -0.185609605663     -0.187991015399     -0.190402344809     -0.192843968908
+ -0.195316267375     -0.197819624613     -0.200354429807     -0.202921076980
+ -0.205519965052     -0.208151497902     -0.210816084425     -0.213514138594
+ -0.216246079519     -0.219012331516     -0.221813324161     -0.224649492361
+ -0.227521276411     -0.230429122067     -0.233373480603     -0.236354808885
+ -0.239373569433     -0.242430230492     -0.245525266095     -0.248659156140
+ -0.251832386454     -0.255045448867     -0.258298841281     -0.261593067743
+ -0.264928638519     -0.268306070167     -0.271725885610     -0.275188614215
+ -0.278694791864     -0.282244961034     -0.285839670876     -0.289479477289
+ -0.293164943002     -0.296896637653     -0.300675137870     -0.304501027353
+ -0.308374896956     -0.312297344769     -0.316268976202     -0.320290404073
+ -0.324362248688     -0.328485137932     -0.332659707354     -0.336886600255
+ -0.341166467777     -0.345499968993     -0.349887770995     -0.354330548990
+ -0.358828986388     -0.363383774893     -0.367995614604     -0.372665214101
+ -0.377393290546     -0.382180569777     -0.387027786402     -0.391935683905
+ -0.396905014733     -0.401936540405     -0.407031031607     -0.412189268292
+ -0.417412039788     -0.422700144890     -0.428054391975     -0.433475599096
+ -0.438964594092     -0.444522214691     -0.450149308620     -0.455846733706
+ -0.461615357990     -0.467456059830     -0.473369728016     -0.479357261873
+ -0.485419571377     -0.491557577266     -0.497772211147     -0.504064415617
+ -0.510435144370     -0.516885362311     -0.523416045677     -0.530028182146
+ -0.536722770954     -0.543500823018     -0.550363361046     -0.557311419656
+ -0.564346045501     -0.571468297381     -0.578679246367     -0.585979975920
+ -0.593371582013     -0.600855173252     -0.608431871000     -0.616102809497
+ -0.623869135988     -0.631732010841     -0.639692607677     -0.647752113494
+ -0.655911728792     -0.664172667698     -0.672536158097     -0.681003441757
+ -0.689575774456     -0.698254426116     -0.707040680926     -0.715935837478
+ -0.724941208892     -0.734058122954     -0.743287922242     -0.752631964266
+ -0.762091621593     -0.771668281988     -0.781363348550     -0.791178239844
+ -0.801114390039     -0.811173249049     -0.821356282673     -0.831664972729
+ -0.842100817205     -0.852665330394     -0.863360043042     -0.874186502495
+ -0.885146272844     -0.896240935076     -0.907472087225     -0.918841344524
+ -0.930350339562     -0.942000722439     -0.953794160929     -0.965732340642
+ -0.977816965189     -0.990049756350      -1.00243245425      -1.01496681753
+  -1.02765462353      -1.04049766847      -1.05349776764      -1.06665675560
+  -1.07997648636      -1.09345883361      -1.10710569091      -1.12091897191
+  -1.13490061058      -1.14905256143      -1.16337679976      -1.17787532190
+  -1.19255014549      -1.20740330969      -1.22243687551      -1.23765292608
+  -1.25305356695      -1.26864092640      -1.28441715575      -1.30038442973
+  -1.31655111139      -1.33290633660      -1.34945923572      -1.36621207935
+  -1.38316716337      -1.40032680944      -1.41769336541      -1.43526920587
+  -1.45305673262      -1.47105837525      -1.48927659169      -1.50771386881
+  -1.52637272310      -1.54525570126      -1.56436538098      -1.58370437163
+  -1.60327531508      -1.62308088648      -1.64312379517      -1.66340678557
+  -1.68393263815      -1.70470417045      -1.72572423815      -1.74699573620
+  -1.76852160003      -1.79030480677      -1.81234837661      -1.83465537421
+  -1.85722891012      -1.88007214239      -1.90318827818      -1.92658057550
+  -1.95025234503      -1.97420695204      -1.99844781841      -2.02297842477
+  -2.04780231272      -2.07292308722      -2.09834441910      -2.12407004763
+  -2.15010378330      -2.17644951075      -2.20311119179      -2.23009286866
+  -2.25739866734      -2.28503280116      -2.31299957454      -2.34130338687
+  -2.36994873667      -2.39894022590      -2.42828256451      -2.45798057522
+  -2.48803919852      -2.51846349788      -2.54925866532      -2.58043002709
+  -2.61198304978      -2.64392334659      -2.67625668395      -2.70898898844
+  -2.74212635401      -2.77567504954      -2.80964152669      -2.84403242817
+  -2.87885459628      -2.91411508187      -2.94982115363      -2.98598030775
+  -3.02260027805      -3.05968904637      -3.09725485345      -3.13530621017
+  -3.17385190919      -3.21290103701      -3.25246298643      -3.29254746935
+  -3.33316453004      -3.37432455876      -3.41603830568      -3.45831689529
+  -3.50117184101      -3.54461506019      -3.58865888932      -3.63331609959
+  -3.67859991247      -3.72452401567      -3.77110257898      -3.81835027026
+  -3.86628227136      -3.91491429390      -3.96426259479      -4.01434399150
+  -4.06517587673      -4.11677623264      -4.16916364416      -4.22235731152
+  -4.27637706155      -4.33124335770      -4.38697730847      -4.44360067400
+  -4.50113587058      -4.55960597265      -4.61903471208      -4.67944647426
+  -4.74086629059      -4.80331982696      -4.86683336765      -4.93143379424
+  -4.99714855879      -5.06400565077      -5.13203355700      -5.20126121398
+  -5.27171795158      -5.34343342758      -5.41643755185      -5.49076039941
+  -5.56643211127      -5.64348278198      -5.72194233276      -5.80184036900
+  -5.88320602093      -5.96606776605      -6.05045323207      -6.13638897895
+  -6.22390025852      -6.31301075043      -6.40374227272      -6.49611446581
+  -6.59014444835      -6.68584644353      -6.78323137467      -6.88230642887
+  -6.98307458753      -7.08553412313      -7.18967806133      -7.29549360837
+  -7.40296154342      -7.51205557657      -7.62274167319      -7.73497734609
+  -7.84871091771      -7.96388075515      -8.08041448174      -8.19822816996
+  -8.31722552142      -8.43729704116      -8.55831921446      -8.68015369635
+  -8.80264652534      -8.92562737477      -9.04890885719      -9.17228589931
+  -9.29553520693      -9.41841484206      -9.54066393638      -9.66200256783
+  -9.78213182952      -9.90073412245      -10.0174737058      -10.1319975409
+  -10.2439364658      -10.3529067408      -10.4585120028      -10.5603456710
+  -10.6579938418      -10.7510387106      -10.8390625579      -10.9216523280
+  -10.9984048273      -11.0689325592      -11.1328702034      -11.1898817339
+  -11.2396681577      -11.2818964816      -11.3164746610      -11.3432378652
+  -11.3621232441      -11.3731507584      -11.3764328958      -11.3721841030
+  -11.3607296295      -11.3425134033      -11.3181044823      -11.2882015193
+  -11.2536345661      -11.2153633932      -11.1744713347      -11.1321534523
+  -11.0896975633      -11.0484563665      -11.0098085300      -10.9751061604
+  -10.9456055431      -10.9223774214      -10.9061923579      -10.8973758905
+  -10.8956272511      -10.8997943614      -10.9075966337      -10.9161303162
+  -10.9247070045      -10.9333267954      -10.9419897539      -10.9506960057
+  -10.9594457321      -10.9682391651      -10.9770765822      -10.9859583002
+  -10.9948846702      -11.0038560711      -11.0128729041      -11.0219355856
+  -11.0310445416      -11.0402002006      -11.0494029873      -11.0586533160
+  -11.0679515834      -11.0772981625      -11.0866933950      -11.0961375855
+  -11.1056309939      -11.1151738295      -11.1247662438      -11.1344083247
+  -11.1441000894      -11.1538414792      -11.1636323528      -11.1734724807
+  -11.1833615399      -11.1932991084      -11.2032846602      -11.2133175607
+  -11.2233970618      -11.2335222986      -11.2436922846      -11.2539059090
+  -11.2641619335      -11.2744589892      -11.2847955746      -11.2951700537
+  -11.3055806541      -11.3160254664      -11.3265024429      -11.3370093978
+  -11.3475440069      -11.3581038083      -11.3686862037      -11.3792884590
+  -11.3899077067      -11.4005409480      -11.4111850552      -11.4218367749
+  -11.4324927313      -11.4431494299      -11.4538032620      -11.4644505090
+  -11.4750873473      -11.4857098535      -11.4963140103      -11.5068957120
+  -11.5174507711      -11.5279749246      -11.5384638410      -11.5489131273
+  -11.5593183362      -11.5696749740      -11.5799785085      -11.5902243767
+  -11.6004079932      -11.6105247589      -11.6205700692      -11.6305393230
+  -11.6404279317      -11.6502313280      -11.6599449751      -11.6695643760
+  -11.6790850825      -11.6885027047      -11.6978129204      -11.7070114841
+  -11.7160942365      -11.7250571136      -11.7338961559      -11.7426075176
+  -11.7511874752      -11.7596324363      -11.7679389486      -11.7761037076
+  -11.7841235650      -11.7919955367      -11.7997168098      -11.8072847502
+  -11.8146969092      -11.8219510297      -11.8290450523      -11.8359771208
+  -11.8427455868      -11.8493490142      -11.8557861833      -11.8620560936
+  -11.8681579664      -11.8740912471      -11.8798556060      -11.8854509393
+  -11.8908773684      -11.8961352397      -11.9012251225      -11.9061478069
+  -11.9109043008      -11.9154958260      -11.9199238137      -11.9241898996
+  -11.9282959175      -11.9322438934      -11.9360360375      -11.9396747375
+  -11.9431625489      -11.9465021875      -11.9496965188      -11.9527485490
+  -11.9556614143      -11.9584383708      -11.9610827830      -11.9635981134
+  -11.9659879107      -11.9682557990      -11.9704054657      -11.9724406508
+  -11.9743651350      -11.9761827288      -11.9778972612      -11.9795125694
+  -11.9810324877      -11.9824608373      -11.9838014171      -11.9850579937
+  -11.9862342926      -11.9873339899      -11.9883607041      -11.9893179891
+  -11.9902093267      -11.9910381211      -11.9918076926      -11.9925212731
+  -11.9931820008      -11.9937929174      -11.9943569638      -11.9948769780
+  -11.9953556927      -11.9957957338      -11.9961996195      -11.9965697591
+  -11.9969084538      -11.9972178965      -11.9975001727      -11.9977572621
+  -11.9979910394      -11.9982032769      -11.9983956466      -11.9985697224
+  -11.9987269831      -11.9988688152      -11.9989965161      -11.9995685942
+  -11.9998165260      -11.9999228177      -11.9999678888      -11.9999867891
+  -11.9999946262      -11.9999978390      -11.9999991410      -11.9999996626
+  -11.9999998690      -11.9999999498      -11.9999999810      -11.9999999929
+  -11.9999999974      -11.9999999990      -11.9999999997      -11.9999999999
+  -12.0000000000      -12.0000000000      -12.0000000000      -12.0000000000
+  1
+ -0.111415052497E-03 -0.224231533830E-03 -0.338467071798E-03 -0.454139515934E-03
+ -0.571266940287E-03 -0.689867646251E-03 -0.809960165423E-03 -0.931563262498E-03
+ -0.105469593820E-02 -0.117937743226E-02 -0.130562722640E-02 -0.143346504740E-02
+ -0.156291087018E-02 -0.169398492091E-02 -0.182670768015E-02 -0.196109988611E-02
+ -0.209718253782E-02 -0.223497689848E-02 -0.237450449871E-02 -0.251578713999E-02
+ -0.265884689799E-02 -0.280370612608E-02 -0.295038745881E-02 -0.309891381541E-02
+ -0.324930840341E-02 -0.340159472226E-02 -0.355579656699E-02 -0.371193803193E-02
+ -0.387004351449E-02 -0.403013771896E-02 -0.419224566035E-02 -0.435639266834E-02
+ -0.452260439122E-02 -0.469090679988E-02 -0.486132619189E-02 -0.503388919560E-02
+ -0.520862277430E-02 -0.538555423045E-02 -0.556471120992E-02 -0.574612170631E-02
+ -0.592981406535E-02 -0.611581698931E-02 -0.630415954150E-02 -0.649487115078E-02
+ -0.668798161619E-02 -0.688352111158E-02 -0.708152019037E-02 -0.728200979027E-02
+ -0.748502123813E-02 -0.769058625485E-02 -0.789873696035E-02 -0.810950587852E-02
+ -0.832292594240E-02 -0.853903049923E-02 -0.875785331574E-02 -0.897942858336E-02
+ -0.920379092362E-02 -0.943097539351E-02 -0.966101749099E-02 -0.989395316054E-02
+ -0.101298187987E-01 -0.103686512600E-01 -0.106104878623E-01 -0.108553663929E-01
+ -0.111033251147E-01 -0.113544027714E-01 -0.116086385945E-01 -0.118660723085E-01
+ -0.121267441381E-01 -0.123906948136E-01 -0.126579655776E-01 -0.129285981916E-01
+ -0.132026349424E-01 -0.134801186487E-01 -0.137610926676E-01 -0.140456009019E-01
+ -0.143336878062E-01 -0.146253983947E-01 -0.149207782475E-01 -0.152198735181E-01
+ -0.155227309405E-01 -0.158293978368E-01 -0.161399221239E-01 -0.164543523217E-01
+ -0.167727375603E-01 -0.170951275879E-01 -0.174215727782E-01 -0.177521241388E-01
+ -0.180868333186E-01 -0.184257526165E-01 -0.187689349889E-01 -0.191164340585E-01
+ -0.194683041223E-01 -0.198246001605E-01 -0.201853778447E-01 -0.205506935468E-01
+ -0.209206043476E-01 -0.212951680462E-01 -0.216744431685E-01 -0.220584889765E-01
+ -0.224473654777E-01 -0.228411334345E-01 -0.232398543733E-01 -0.236435905947E-01
+ -0.240524051826E-01 -0.244663620147E-01 -0.248855257720E-01 -0.253099619491E-01
+ -0.257397368643E-01 -0.261749176703E-01 -0.266155723643E-01 -0.270617697987E-01
+ -0.275135796920E-01 -0.279710726398E-01 -0.284343201255E-01 -0.289033945315E-01
+ -0.293783691509E-01 -0.298593181985E-01 -0.303463168226E-01 -0.308394411169E-01
+ -0.313387681319E-01 -0.318443758876E-01 -0.323563433850E-01 -0.328747506189E-01
+ -0.333996785905E-01 -0.339312093195E-01 -0.344694258574E-01 -0.350144123003E-01
+ -0.355662538021E-01 -0.361250365876E-01 -0.366908479664E-01 -0.372637763460E-01
+ -0.378439112461E-01 -0.384313433122E-01 -0.390261643300E-01 -0.396284672397E-01
+ -0.402383461505E-01 -0.408558963552E-01 -0.414812143452E-01 -0.421143978256E-01
+ -0.427555457303E-01 -0.434047582378E-01 -0.440621367864E-01 -0.447277840903E-01
+ -0.454018041557E-01 -0.460843022969E-01 -0.467753851527E-01 -0.474751607034E-01
+ -0.481837382872E-01 -0.489012286178E-01 -0.496277438010E-01 -0.503633973531E-01
+ -0.511083042177E-01 -0.518625807844E-01 -0.526263449065E-01 -0.533997159199E-01
+ -0.541828146610E-01 -0.549757634865E-01 -0.557786862915E-01 -0.565917085298E-01
+ -0.574149572329E-01 -0.582485610300E-01 -0.590926501682E-01 -0.599473565325E-01
+ -0.608128136670E-01 -0.616891567952E-01 -0.625765228413E-01 -0.634750504517E-01
+ -0.643848800166E-01 -0.653061536917E-01 -0.662390154207E-01 -0.671836109578E-01
+ -0.681400878902E-01 -0.691085956612E-01 -0.700892855939E-01 -0.710823109143E-01
+ -0.720878267756E-01 -0.731059902823E-01 -0.741369605147E-01 -0.751808985540E-01
+ -0.762379675068E-01 -0.773083325316E-01 -0.783921608635E-01 -0.794896218412E-01
+ -0.806008869327E-01 -0.817261297628E-01 -0.828655261396E-01 -0.840192540823E-01
+ -0.851874938488E-01 -0.863704279641E-01 -0.875682412486E-01 -0.887811208468E-01
+ -0.900092562568E-01 -0.912528393601E-01 -0.925120644508E-01 -0.937871282666E-01
+ -0.950782300193E-01 -0.963855714258E-01 -0.977093567399E-01 -0.990497927838E-01
+ -0.100407088981     -0.101781457387     -0.103173112726     -0.104582272421
+ -0.106009156629     -0.107453988278     -0.108916993095     -0.110398399649
+ -0.111898439381     -0.113417346644     -0.114955358737     -0.116512715941
+ -0.118089661563     -0.119686441964     -0.121303306606     -0.122940508088
+ -0.124598302183     -0.126276947881     -0.127976707429     -0.129697846371
+ -0.131440633589     -0.133205341347     -0.134992245330     -0.136801624691
+ -0.138633762093     -0.140488943751     -0.142367459480     -0.144269602739
+ -0.146195670673     -0.148145964167     -0.150120787886     -0.152120450325
+ -0.154145263860     -0.156195544791     -0.158271613395     -0.160373793975
+ -0.162502414911     -0.164657808712     -0.166840312065     -0.169050265890
+ -0.171288015391     -0.173553910112     -0.175848303992     -0.178171555417
+ -0.180524027277     -0.182906087025     -0.185318106730     -0.187760463139
+ -0.190233537733     -0.192737716787     -0.195273391432     -0.197840957712
+ -0.200440816650     -0.203073374308     -0.205739041849     -0.208438235606
+ -0.211171377139     -0.213938893308     -0.216741216336     -0.219578783876
+ -0.222452039080     -0.225361430668     -0.228307412996     -0.231290446130
+ -0.234310995914     -0.237369534045     -0.240466538144     -0.243602491834
+ -0.246777884810     -0.249993212920     -0.253248978238     -0.256545689145
+ -0.259883860407     -0.263264013252     -0.266686675457     -0.270152381425
+ -0.273661672269     -0.277215095898     -0.280813207099     -0.284456567624
+ -0.288145746279     -0.291881319010     -0.295663868994     -0.299493986727
+ -0.303372270118     -0.307299324580     -0.311275763126     -0.315302206460
+ -0.319379283076     -0.323507629356     -0.327687889666     -0.331920716457
+ -0.336206770366     -0.340546720318     -0.344941243628     -0.349391026110
+ -0.353896762177     -0.358459154952     -0.363078916378     -0.367756767322
+ -0.372493437692     -0.377289666549     -0.382146202216     -0.387063802400
+ -0.392043234304     -0.397085274747     -0.402190710285     -0.407360337328
+ -0.412594962267     -0.417895401595     -0.423262482036     -0.428697040666
+ -0.434199925050     -0.439771993363     -0.445414114528     -0.451127168350
+ -0.456912045645     -0.462769648381     -0.468700889816     -0.474706694638
+ -0.480787999102     -0.486945751180     -0.493180910701     -0.499494449502
+ -0.505887351570     -0.512360613198     -0.518915243135     -0.525552262739
+ -0.532272706133     -0.539077620364     -0.545968065559     -0.552945115089
+ -0.560009855731     -0.567163387834     -0.574406825481     -0.581741296667
+ -0.589167943462     -0.596687922185     -0.604302403583     -0.612012573004
+ -0.619819630574     -0.627724791386     -0.635729285674     -0.643834359004
+ -0.652041272457     -0.660351302823     -0.668765742788     -0.677285901133
+ -0.685913102924     -0.694648689713     -0.703494019740     -0.712450468133
+ -0.721519427114     -0.730702306205     -0.740000532440     -0.749415550574
+ -0.758948823297     -0.768601831456     -0.778376074264     -0.788273069531
+ -0.798294353881     -0.808441482982     -0.818716031771     -0.829119594687
+ -0.839653785905     -0.850320239570     -0.861120610035     -0.872056572104
+ -0.883129821275     -0.894342073980     -0.905695067844     -0.917190561926
+ -0.928830336978     -0.940616195696     -0.952549962985     -0.964633486214
+ -0.976868635483     -0.989257303888      -1.00180140779      -1.01450288708
+  -1.02736370548      -1.04038585076      -1.05357133509      -1.06692219527
+  -1.08044049303      -1.09412831533      -1.10798777461      -1.12202100914
+  -1.13623018326      -1.15061748769      -1.16518513986      -1.17993538417
+  -1.19487049232      -1.20999276361      -1.22530452523      -1.24080813262
+  -1.25650596971      -1.27240044931      -1.28849401336      -1.30478913331
+  -1.32128831039      -1.33799407599      -1.35490899192      -1.37203565079
+  -1.38937667631      -1.40693472364      -1.42471247969      -1.44271266351
+  -1.46093802658      -1.47939135314      -1.49807546059      -1.51699319975
+  -1.53614745525      -1.55554114588      -1.57517722487      -1.59505868031
+  -1.61518853543      -1.63556984900      -1.65620571562      -1.67709926608
+  -1.69825366772      -1.71967212476      -1.74135787864      -1.76331420836
+  -1.78554443081      -1.80805190112      -1.83084001299      -1.85391219903
+  -1.87727193108      -1.90092272052      -1.92486811864      -1.94911171690
+  -1.97365714729      -1.99850808265      -2.02366823690      -2.04914136542
+  -2.07493126531      -2.10104177567      -2.12747677789      -2.15424019590
+  -2.18133599645      -2.20876818937      -2.23654082777      -2.26465800830
+  -2.29312387136      -2.32194260130      -2.35111842659      -2.38065562004
+  -2.41055849889      -2.44083142501      -2.47147880498      -2.50250509018
+  -2.53391477690      -2.56571240638      -2.59790256481      -2.63048988336
+  -2.66347903814      -2.69687475012      -2.73068178506      -2.76490495339
+  -2.79954910999      -2.83461915403      -2.87012002871      -2.90605672095
+  -2.94243426104      -2.97925772227      -3.01653222044      -3.05426291337
+  -3.09246116488      -3.13111912831      -3.17024896702      -3.20985599902
+  -3.24994558064      -3.29052310569      -3.33159400430      -3.37316374187
+  -3.41523781774      -3.45782176388      -3.50092114344      -3.54454154907
+  -3.58868860128      -3.63336794652      -3.67858525519      -3.72434621947
+  -3.77065655097      -3.81752197822      -3.86494824400      -3.91294110242
+  -3.96150631580      -4.01064965141      -4.06037687783      -4.11069376118
+  -4.16160606106      -4.21311952619      -4.26523988973      -4.31797286439
+  -4.37132413708      -4.42529936332      -4.47990416124      -4.53514410513
+  -4.59102471873      -4.64755146792      -4.70472975307      -4.76256490086
+  -4.82106215558      -4.88022666993      -4.94006349526      -5.00057757114
+  -5.06177371439      -5.12365660741      -5.18623078584      -5.24950062544
+  -5.31347032829      -5.37814390807      -5.44352517463      -5.50961771756
+  -5.57642488890      -5.64394978484      -5.71219522643      -5.78116373920
+  -5.85085753168      -5.92127847274      -5.99242806775      -6.06430743342
+  -6.13691727135      -6.21025784021      -6.28432892645      -6.35912981356
+  -6.43465924976      -6.51091541410      -6.58789588088      -6.66559758237
+  -6.74401676974      -6.82314897216      -6.90298895404      -6.98353067026
+  -7.06476721949      -7.14669079540      -7.22929263584      -7.31256296982
+  -7.39649096237      -7.48106465722      -7.56627091717      -7.65209536229
+  -7.73852230586      -7.82553468795      -7.91311400690      -8.00124024845
+  -8.08989181270      -8.17904543897      -8.26867612847      -8.35875706510
+  -8.44925953420      -8.54015283965      -8.63140421927      -8.72297875877
+  -8.81483930445      -8.90694637494      -8.99925807210      -9.09172999154
+  -9.18431513308      -9.27696381138      -9.36962356746      -9.46223908134
+  -9.55475208644      -9.64710128639      -9.73922227476      -9.83104745860
+  -9.92250598646      -10.0135236817      -10.1040229822      -10.1939228872
+  -10.2831389129      -10.3715830571      -10.4591637747      -10.5457859660
+  -10.6313509776      -10.7157566188      -10.7988971950      -10.8806635586
+  -10.9609431811      -11.0396202458      -11.1165757659      -11.1916877272
+  -11.2648312593      -11.3358788374      -11.4047005149      -11.4711641919
+  -11.5351359194      -11.5964802426      -11.6550605852      -11.7107396766
+  -11.7633800245      -11.8128444346      -11.8589965787      -11.9017016137
+  -11.9408268525      -11.9762424879      -12.0078223701      -12.0354448390
+  -12.0589936104      -12.0783587168      -12.0934375007      -12.1041356600
+  -12.1103683427      -12.1120612879      -12.1091520102      -12.1015910222
+  -12.0893430909      -12.0723885199      -12.0507244522      -12.0243661833
+  -11.9933484773      -11.9577268723      -11.9175789672      -11.8730056732
+  -11.8241324182      -11.7711102872      -11.7141170832      -11.6533582882
+  -11.5890679082      -11.5215091773      -11.4509751024      -11.3777888221
+  -11.3023037562      -11.2249035177      -11.1460015600      -11.0660405271
+  -10.9854912758      -10.9048515336      -10.8246441550      -10.7454149364
+  -10.6677299443      -10.5921723104      -10.5193384427      -10.4498335978
+  -10.3842667556      -10.3232447356      -10.2673654918      -10.2172105211
+  -10.1733363260      -10.1361855217      -10.1063423578      -10.0841980509
+  -10.0701032313      -10.0643252641      -10.0670335601      -10.0782841283
+  -10.0980036423      -10.1259734167      -10.1618138539      -10.2049701191
+  -10.2547000482      -10.3100655883      -10.3699294282      -10.4329588915
+  -10.4976396578      -10.5623024443      -10.6251664363      -10.6844040114
+  -10.7382321695      -10.7850370914      -10.8235394270      -10.8530093089
+  -10.8735417606      -10.8864051889      -10.8944780994      -10.9016263770
+  -10.9087827884      -10.9159475240      -10.9231208252      -10.9303029964
+  -10.9374944029      -10.9446954709      -10.9519066856      -10.9591285897
+  -10.9663617825      -10.9736069174      -10.9808647005      -10.9881358881
+  -10.9954212849      -11.0027217414      -11.0100381511      -11.0173714481
+  -11.0247226039      -11.0320926243      -11.0394825463      -11.0468934347
+  -11.0543263781      -11.0617824860      -11.0692628839      -11.0767687103
+  -11.0843011118      -11.0918612394      -11.0994502438      -11.1070692711
+  -11.1147194584      -11.1224019290      -11.1301177877      -11.1378681163
+  -11.1456539687      -11.1534763659      -11.1613362917      -11.1692346875
+  -11.1771724476      -11.1851504142      -11.1931693734      -11.2012300496
+  -11.2093331014      -11.2174791171      -11.2256686100      -11.2339020143
+  -11.2421796808      -11.2505018728      -11.2588687622      -11.2672804259
+  -11.2757368418      -11.2842378860      -11.2927833289      -11.3013728329
+  -11.3100059491      -11.3186821150      -11.3274006522      -11.3361607642
+  -11.3449615350      -11.3538019268      -11.3626807797      -11.3715968099
+  -11.3805486096      -11.3895346461      -11.3985532622      -11.4076026759
+  -11.4166809814      -11.4257861495      -11.4349160287      -11.4440683470
+  -11.4532407132      -11.4624306192      -11.4716354421      -11.4808524471
+  -11.4900787903      -11.4993115218      -11.5085475894      -11.5177838425
+  -11.5270170361      -11.5362438350      -11.5454608187      -11.5546644863
+  -11.5638512617      -11.5730174990      -11.5821594880      -11.5912734605
+  -11.6003555960      -11.6094020286      -11.6184088531      -11.6273721319
+  -11.6362879019      -11.6451521818      -11.6539609793      -11.6627102981
+  -11.6713961460      -11.6800145424      -11.6885615256      -11.6970331613
+  -11.7054255499      -11.7137348347      -11.7219572098      -11.7300889279
+  -11.7381263085      -11.7460657455      -11.7539037151      -11.7616367836
+  -11.7692616151      -11.7767749786      -11.7841737559      -11.7914549481
+  -11.7986156831      -11.8056532220      -11.8125649655      -11.8193484603
+  -11.8260014046      -11.8325216538      -11.8389072256      -11.8451563047
+  -11.8512672470      -11.8572385838      -11.8630690249      -11.8687574615
+  -11.8743029690      -11.8797048088      -11.8849624293      -11.8900754672
+  -11.8950437479      -11.8998672847      -11.9045462782      -11.9090811153
+  -11.9134723666      -11.9177207843      -11.9218272988      -11.9257930153
+  -11.9296192094      -11.9333073226      -11.9368589566      -11.9402758684
+  -11.9435599633      -11.9467132888      -11.9497380272      -11.9526364887
+  -11.9554111033      -11.9580644128      -11.9605990626      -11.9630177931
+  -11.9653234313      -11.9675188814      -11.9696071163      -11.9715911682
+  -11.9734741201      -11.9752590963      -11.9769492537      -11.9785477729
+  -11.9800578495      -11.9814826857      -11.9828254820      -11.9840894289
+  -11.9852776996      -11.9863934424      -11.9874397733      -11.9884197699
+  -11.9893364644      -11.9901928385      -11.9909918168      -11.9917362629
+  -11.9924289740      -11.9930726769      -11.9936700244      -11.9942235919
+  -11.9947358748      -11.9952092858      -11.9956461531      -11.9960487190
+  -11.9964191386      -11.9967594794      -11.9970717204      -11.9973577526
+  -11.9976193794      -11.9978583172      -11.9980761961      -11.9982745616
+  -11.9984548761      -11.9986185204      -11.9987667960      -11.9989009269
+  -11.9996178585      -11.9998689088      -11.9999556390      -11.9999851941
+  -11.9999951270      -11.9999984187      -11.9999994942      -11.9999998405
+  -11.9999999505      -11.9999999848      -11.9999999954      -11.9999999986
+  -11.9999999996      -11.9999999999      -12.0000000000      -12.0000000000
+  2
+ -0.811900329239E-04 -0.163401310739E-03 -0.246646679121E-03 -0.330939145323E-03
+ -0.416291880212E-03 -0.502718220320E-03 -0.590231669934E-03 -0.678845903203E-03
+ -0.768574766275E-03 -0.859432279463E-03 -0.951432639430E-03 -0.104459022141E-02
+ -0.113891958147E-02 -0.123443545874E-02 -0.133115277777E-02 -0.142908665082E-02
+ -0.152825238027E-02 -0.162866546093E-02 -0.173034158256E-02 -0.183329663223E-02
+ -0.193754669688E-02 -0.204310806578E-02 -0.214999723309E-02 -0.225823090045E-02
+ -0.236782597957E-02 -0.247879959489E-02 -0.259116908626E-02 -0.270495201161E-02
+ -0.282016614974E-02 -0.293682950307E-02 -0.305496030048E-02 -0.317457700011E-02
+ -0.329569829230E-02 -0.341834310248E-02 -0.354253059411E-02 -0.366828017173E-02
+ -0.379561148393E-02 -0.392454442647E-02 -0.405509914534E-02 -0.418729603995E-02
+ -0.432115576632E-02 -0.445669924025E-02 -0.459394764065E-02 -0.473292241284E-02
+ -0.487364527186E-02 -0.501613820590E-02 -0.516042347973E-02 -0.530652363817E-02
+ -0.545446150962E-02 -0.560426020963E-02 -0.575594314449E-02 -0.590953401492E-02
+ -0.606505681974E-02 -0.622253585966E-02 -0.638199574102E-02 -0.654346137970E-02
+ -0.670695800496E-02 -0.687251116341E-02 -0.704014672298E-02 -0.720989087701E-02
+ -0.738177014827E-02 -0.755581139318E-02 -0.773204180592E-02 -0.791048892279E-02
+ -0.809118062639E-02 -0.827414515007E-02 -0.845941108232E-02 -0.864700737119E-02
+ -0.883696332887E-02 -0.902930863624E-02 -0.922407334752E-02 -0.942128789496E-02
+ -0.962098309360E-02 -0.982319014608E-02 -0.100279406475E-01 -0.102352665904E-01
+ -0.104452003697E-01 -0.106577747878E-01 -0.108730230597E-01 -0.110909788183E-01
+ -0.113116761193E-01 -0.115351494469E-01 -0.117614337192E-01 -0.119905642932E-01
+ -0.122225769709E-01 -0.124575080044E-01 -0.126953941019E-01 -0.129362724335E-01
+ -0.131801806365E-01 -0.134271568218E-01 -0.136772395796E-01 -0.139304679857E-01
+ -0.141868816070E-01 -0.144465205084E-01 -0.147094252588E-01 -0.149756369370E-01
+ -0.152451971389E-01 -0.155181479834E-01 -0.157945321192E-01 -0.160743927314E-01
+ -0.163577735485E-01 -0.166447188487E-01 -0.169352734673E-01 -0.172294828037E-01
+ -0.175273928280E-01 -0.178290500888E-01 -0.181345017202E-01 -0.184437954488E-01
+ -0.187569796019E-01 -0.190741031144E-01 -0.193952155370E-01 -0.197203670434E-01
+ -0.200496084384E-01 -0.203829911659E-01 -0.207205673169E-01 -0.210623896374E-01
+ -0.214085115371E-01 -0.217589870974E-01 -0.221138710797E-01 -0.224732189346E-01
+ -0.228370868098E-01 -0.232055315593E-01 -0.235786107524E-01 -0.239563826823E-01
+ -0.243389063754E-01 -0.247262416006E-01 -0.251184488785E-01 -0.255155894911E-01
+ -0.259177254909E-01 -0.263249197111E-01 -0.267372357751E-01 -0.271547381065E-01
+ -0.275774919394E-01 -0.280055633282E-01 -0.284390191582E-01 -0.288779271559E-01
+ -0.293223558996E-01 -0.297723748304E-01 -0.302280542624E-01 -0.306894653945E-01
+ -0.311566803208E-01 -0.316297720422E-01 -0.321088144780E-01 -0.325938824770E-01
+ -0.330850518294E-01 -0.335823992787E-01 -0.340860025338E-01 -0.345959402806E-01
+ -0.351122921950E-01 -0.356351389547E-01 -0.361645622525E-01 -0.367006448084E-01
+ -0.372434703827E-01 -0.377931237894E-01 -0.383496909090E-01 -0.389132587024E-01
+ -0.394839152240E-01 -0.400617496357E-01 -0.406468522208E-01 -0.412393143981E-01
+ -0.418392287361E-01 -0.424466889677E-01 -0.430617900044E-01 -0.436846279516E-01
+ -0.443153001233E-01 -0.449539050575E-01 -0.456005425312E-01 -0.462553135766E-01
+ -0.469183204962E-01 -0.475896668795E-01 -0.482694576184E-01 -0.489577989241E-01
+ -0.496547983438E-01 -0.503605647768E-01 -0.510752084923E-01 -0.517988411461E-01
+ -0.525315757982E-01 -0.532735269305E-01 -0.540248104646E-01 -0.547855437799E-01
+ -0.555558457321E-01 -0.563358366713E-01 -0.571256384614E-01 -0.579253744986E-01
+ -0.587351697310E-01 -0.595551506780E-01 -0.603854454500E-01 -0.612261837683E-01
+ -0.620774969858E-01 -0.629395181068E-01 -0.638123818084E-01 -0.646962244614E-01
+ -0.655911841510E-01 -0.664974006991E-01 -0.674150156860E-01 -0.683441724719E-01
+ -0.692850162200E-01 -0.702376939188E-01 -0.712023544049E-01 -0.721791483867E-01
+ -0.731682284674E-01 -0.741697491691E-01 -0.751838669569E-01 -0.762107402632E-01
+ -0.772505295126E-01 -0.783033971466E-01 -0.793695076493E-01 -0.804490275730E-01
+ -0.815421255637E-01 -0.826489723883E-01 -0.837697409603E-01 -0.849046063675E-01
+ -0.860537458989E-01 -0.872173390724E-01 -0.883955676629E-01 -0.895886157307E-01
+ -0.907966696500E-01 -0.920199181380E-01 -0.932585522845E-01 -0.945127655815E-01
+ -0.957827539535E-01 -0.970687157881E-01 -0.983708519665E-01 -0.996893658954E-01
+ -0.101024463538     -0.102376353448     -0.103745246798     -0.105131357418
+ -0.106534901823     -0.107956099251     -0.109395171696     -0.110852343942
+ -0.112327843597     -0.113821901131     -0.115334749910     -0.116866626234
+ -0.118417769370     -0.119988421596     -0.121578828232     -0.123189237681
+ -0.124819901469     -0.126471074281     -0.128143014003     -0.129835981763
+ -0.131550241968     -0.133286062348     -0.135043713998     -0.136823471417
+ -0.138625612554     -0.140450418851     -0.142298175285     -0.144169170412
+ -0.146063696414     -0.147982049143     -0.149924528168     -0.151891436820
+ -0.153883082242     -0.155899775432     -0.157941831295     -0.160009568693
+ -0.162103310489     -0.164223383604     -0.166370119063     -0.168543852046
+ -0.170744921945     -0.172973672411     -0.175230451411     -0.177515611280
+ -0.179829508777     -0.182172505140     -0.184544966140     -0.186947262140
+ -0.189379768153     -0.191842863899     -0.194336933860     -0.196862367348
+ -0.199419558558     -0.202008906631     -0.204630815717     -0.207285695038
+ -0.209973958948     -0.212696027000     -0.215452324010     -0.218243280122
+ -0.221069330878     -0.223930917277     -0.226828485854     -0.229762488739
+ -0.232733383734     -0.235741634380     -0.238787710029     -0.241872085917
+ -0.244995243236     -0.248157669209     -0.251359857166     -0.254602306620
+ -0.257885523339     -0.261210019432     -0.264576313420     -0.267984930321
+ -0.271436401728     -0.274931265892     -0.278470067803     -0.282053359275
+ -0.285681699031     -0.289355652787     -0.293075793340     -0.296842700654
+ -0.300656961953     -0.304519171804     -0.308429932216     -0.312389852725
+ -0.316399550489     -0.320459650387     -0.324570785106     -0.328733595245
+ -0.332948729408     -0.337216844305     -0.341538604850     -0.345914684264
+ -0.350345764178     -0.354832534732     -0.359375694686     -0.363975951519
+ -0.368634021545     -0.373350630011     -0.378126511215     -0.382962408614
+ -0.387859074937     -0.392817272295     -0.397837772301     -0.402921356184
+ -0.408068814907     -0.413280949284     -0.418558570102     -0.423902498243
+ -0.429313564807     -0.434792611235     -0.440340489435     -0.445958061910
+ -0.451646201890     -0.457405793454     -0.463237731670     -0.469142922722
+ -0.475122284048     -0.481176744477     -0.487307244361     -0.493514735720
+ -0.499800182382     -0.506164560119     -0.512608856799     -0.519134072527
+ -0.525741219790     -0.532431323611     -0.539205421692     -0.546064564574
+ -0.553009815780     -0.560042251981     -0.567162963143     -0.574373052691
+ -0.581673637666     -0.589065848886     -0.596550831114     -0.604129743215
+ -0.611803758329     -0.619574064036     -0.627441862526     -0.635408370772
+ -0.643474820702     -0.651642459373     -0.659912549151     -0.668286367885
+ -0.676765209091     -0.685350382131     -0.694043212400     -0.702845041506
+ -0.711757227462     -0.720781144872     -0.729918185124     -0.739169756578
+ -0.748537284764     -0.758022212577     -0.767626000471     -0.777350126664
+ -0.787196087332     -0.797165396818     -0.807259587831     -0.817480211657
+ -0.827828838360     -0.838307057000     -0.848916475834     -0.859658722536
+ -0.870535444410     -0.881548308601     -0.892699002321     -0.903989233057
+ -0.915420728804     -0.926995238274     -0.938714531131     -0.950580398209
+ -0.962594651741     -0.974759125586     -0.987075675461     -0.999546179166
+  -1.01217253682      -1.02495667110      -1.03790052746      -1.05100607439
+  -1.06427530361      -1.07771023037      -1.09131289364      -1.10508535636
+  -1.11902970569      -1.13314805327      -1.14744253540      -1.16191531335
+  -1.17656857358      -1.19140452798      -1.20642541409      -1.22163349542
+  -1.23703106160      -1.25262042871      -1.26840393948      -1.28438396353
+  -1.30056289766      -1.31694316604      -1.33352722050      -1.35031754076
+  -1.36731663465      -1.38452703840      -1.40195131684      -1.41959206368
+  -1.43745190170      -1.45553348305      -1.47383948942      -1.49237263234
+  -1.51113565337      -1.53013132434      -1.54936244758      -1.56883185616
+  -1.58854241409      -1.60849701654      -1.62869859008      -1.64915009287
+  -1.66985451486      -1.69081487801      -1.71203423649      -1.73351567684
+  -1.75526231821      -1.77727731248      -1.79956384447      -1.82212513210
+  -1.84496442654      -1.86808501237      -1.89149020769      -1.91518336429
+  -1.93916786777      -1.96344713760      -1.98802462727      -2.01290382434
+  -2.03808825056      -2.06358146185      -2.08938704842      -2.11550863473
+  -2.14194987956      -2.16871447593      -2.19580615114      -2.22322866667
+  -2.25099198270      -2.27908684211      -2.30752399169      -2.33630732726
+  -2.36544077818      -2.39492830714      -2.42477390986      -2.45498161489
+  -2.48555548323      -2.51649960801      -2.54781811406      -2.57951515750
+  -2.61159492524      -2.64406163442      -2.67691953185      -2.71017289332
+  -2.74382602292      -2.77788325222      -2.81234893948      -2.84722746869
+  -2.88252324858      -2.91824071155      -2.95438431250      -2.99095852756
+  -3.02796785276      -3.06541680252      -3.10330990814      -3.14165171603
+  -3.18044678598      -3.21969968914      -3.25941500597      -3.29959732399
+  -3.34025123538      -3.38138133444      -3.42299221481      -3.46508846659
+  -3.50767467318      -3.55075540798      -3.59433523078      -3.63841868404
+  -3.68301028880      -3.72811454040      -3.77373590391      -3.81987880924
+  -3.86654764600      -3.91374675797      -3.96148043726      -4.00975291813
+  -4.05856837039      -4.10793089240      -4.15784450370      -4.20831313713
+  -4.25934063052      -4.31093071789      -4.36308702012      -4.41581303512
+  -4.46911212734      -4.52298751679      -4.57744226740      -4.63247927467
+  -4.68810125275      -4.74431072068      -4.80110998801      -4.85850113950
+  -4.91648601916      -4.97506621332      -5.03424303286      -5.09401749456
+  -5.15439030142      -5.21536182203      -5.27693206896      -5.33910067595
+  -5.40186687415      -5.46522946714      -5.52918680473      -5.59373675569
+  -5.65887667908      -5.72460339439      -5.79091315035      -5.85780159237
+  -5.92526372868      -5.99329389496      -6.06188571766      -6.13103207580
+  -6.20072506140      -6.27095593836      -6.34171509994      -6.41299202475
+  -6.48477523127      -6.55705223094      -6.62980947986      -6.70303232909
+  -6.77670497358      -6.85081039991      -6.92533033273      -7.00024518014
+  -7.07553397800      -7.15117433342      -7.22714236736      -7.30341265669
+  -7.37995817585      -7.45675023818      -7.53375843730      -7.61095058876
+  -7.68829267212      -7.76574877401      -7.84328103226      -7.92084958170
+  -7.99841250185      -8.07592576718      -8.15334320023      -8.23061642832
+  -8.30769484427      -8.38452557192      -8.46105343706      -8.53722094455
+  -8.61296826235      -8.68823321341      -8.76295127630      -8.83705559549
+  -8.91047700238      -8.98314404805      -9.05498304899      -9.12591814691
+  -9.19587138393      -9.26476279436      -9.33251051448      -9.39903091176
+  -9.46423873474      -9.52804728523      -9.59036861418      -9.65111374277
+  -9.71019291011      -9.76751584915      -9.82299209210      -9.87653130689
+  -9.92804366587      -9.97744024808      -10.0246334762      -10.0695375892
+  -10.1120691511      -10.1521475974      -10.1896958182      -10.2246407792
+  -10.2569141798      -10.2864531473      -10.3132009666      -10.3371078436
+  -10.3581316995      -10.3762389938      -10.3914055716      -10.4036175313
+  -10.4128721063      -10.4191785548      -10.4225590496      -10.4230495589
+  -10.4207007066      -10.4155786012      -10.4077656182      -10.3973611200
+  -10.3844820958      -10.3692636995      -10.3518596639      -10.3324425643
+  -10.3112039037      -10.2883539864      -10.2641215470      -10.2387530947
+  -10.2125119338      -10.1856768157      -10.1585401753      -10.1314059057
+  -10.1045866211      -10.0783210073      -10.0530360295      -10.0290193749
+  -10.0065794043      -9.98601030690      -9.96758547706      -9.95155021601
+  -9.93811381599      -9.92744112978      -9.91964378595      -9.91477128392
+  -9.91280229638      -9.91363662259      -9.91708837987      -9.92288119737
+  -9.93064639102      -9.93992535971      -9.95017775755      -9.96079737557
+  -9.97113812071      -9.98055302379      -9.98844986000      -9.99436774597
+  -9.99808001275      -9.99975321674      -10.0000049709      -10.0000042629
+  -10.0000032229      -10.0000024291      -10.0000018250      -10.0000013668
+  -10.0000010205      -10.0000007596      -10.0000005637      -10.0000004171
+  -10.0000003078      -10.0000002265      -10.0000001662      -10.0000001217
+  -10.0000000889      -10.0000000649      -10.0000000472      -10.0000000343
+  -10.0000000250      -10.0000000181      -10.0000000132      -10.0000000096
+  -10.0000000070      -10.0000000051      -10.0000000037      -10.0000000028
+  -10.0000000020      -10.0000000015      -10.0000000011      -10.0000000008
+  -10.0000000006      -10.0000000005      -10.0000000004      -10.0000000003
+  -10.0000000002      -10.0000000002      -10.0000000001      -10.0000000001
+  -10.0000000001      -10.0000000000      -10.0000000000      -10.0000000000
+  -10.0000000000      -10.0000000000     -10.00000000000     -10.00000000000
+  -9.99999999999      -9.99999999999      -9.99999999999      -9.99999999999
+  -9.99999999999      -9.99999999999     -10.00000000000     -10.00000000000
+ -10.00000000000     -10.00000000000     -10.00000000000     -10.00000000000
+ -10.00000000000      -10.0000000000      -10.0000000000      -10.0000000000
+  -10.0000000000      -10.0000000000      -10.0000000000      -10.0000000000
+  3
+ -0.738531130857E-04 -0.148635183972E-03 -0.224357897505E-03 -0.301033085510E-03
+ -0.378672728636E-03 -0.457288958231E-03 -0.536894058235E-03 -0.617500467102E-03
+ -0.699120779741E-03 -0.781767749486E-03 -0.865454290088E-03 -0.950193477732E-03
+ -0.103599855308E-02 -0.112288292335E-02 -0.121086016438E-02 -0.129994402279E-02
+ -0.139014841810E-02 -0.148148744494E-02 -0.157397537518E-02 -0.166762666026E-02
+ -0.176245593335E-02 -0.185847801173E-02 -0.195570789901E-02 -0.205416078756E-02
+ -0.215385206081E-02 -0.225479729573E-02 -0.235701226519E-02 -0.246051294048E-02
+ -0.256531549376E-02 -0.267143630063E-02 -0.277889194266E-02 -0.288769920999E-02
+ -0.299787510397E-02 -0.310943683976E-02 -0.322240184910E-02 -0.333678778298E-02
+ -0.345261251439E-02 -0.356989414117E-02 -0.368865098877E-02 -0.380890161317E-02
+ -0.393066480374E-02 -0.405395958618E-02 -0.417880522553E-02 -0.430522122913E-02
+ -0.443322734969E-02 -0.456284358840E-02 -0.469409019801E-02 -0.482698768603E-02
+ -0.496155681791E-02 -0.509781862030E-02 -0.523579438433E-02 -0.537550566895E-02
+ -0.551697430427E-02 -0.566022239498E-02 -0.580527232384E-02 -0.595214675513E-02
+ -0.610086863819E-02 -0.625146121107E-02 -0.640394800408E-02 -0.655835284351E-02
+ -0.671469985536E-02 -0.687301346907E-02 -0.703331842138E-02 -0.719563976017E-02
+ -0.736000284838E-02 -0.752643336798E-02 -0.769495732397E-02 -0.786560104845E-02
+ -0.803839120472E-02 -0.821335479149E-02 -0.839051914704E-02 -0.856991195353E-02
+ -0.875156124131E-02 -0.893549539331E-02 -0.912174314946E-02 -0.931033361120E-02
+ -0.950129624600E-02 -0.969466089200E-02 -0.989045776262E-02 -0.100887174514E-01
+ -0.102894709365E-01 -0.104927495859E-01 -0.106985851622E-01 -0.109070098273E-01
+ -0.111180561478E-01 -0.113317570998E-01 -0.115481460744E-01 -0.117672568824E-01
+ -0.119891237600E-01 -0.122137813743E-01 -0.124412648281E-01 -0.126716096657E-01
+ -0.129048518788E-01 -0.131410279116E-01 -0.133801746668E-01 -0.136223295110E-01
+ -0.138675302812E-01 -0.141158152900E-01 -0.143672233322E-01 -0.146217936902E-01
+ -0.148795661407E-01 -0.151405809608E-01 -0.154048789341E-01 -0.156725013572E-01
+ -0.159434900460E-01 -0.162178873426E-01 -0.164957361215E-01 -0.167770797966E-01
+ -0.170619623278E-01 -0.173504282279E-01 -0.176425225696E-01 -0.179382909926E-01
+ -0.182377797105E-01 -0.185410355184E-01 -0.188481057996E-01 -0.191590385339E-01
+ -0.194738823041E-01 -0.197926863045E-01 -0.201155003478E-01 -0.204423748734E-01
+ -0.207733609551E-01 -0.211085103092E-01 -0.214478753023E-01 -0.217915089597E-01
+ -0.221394649737E-01 -0.224917977120E-01 -0.228485622260E-01 -0.232098142594E-01
+ -0.235756102574E-01 -0.239460073747E-01 -0.243210634854E-01 -0.247008371909E-01
+ -0.250853878302E-01 -0.254747754884E-01 -0.258690610064E-01 -0.262683059902E-01
+ -0.266725728207E-01 -0.270819246636E-01 -0.274964254787E-01 -0.279161400307E-01
+ -0.283411338984E-01 -0.287714734858E-01 -0.292072260319E-01 -0.296484596214E-01
+ -0.300952431953E-01 -0.305476465618E-01 -0.310057404070E-01 -0.314695963061E-01
+ -0.319392867345E-01 -0.324148850790E-01 -0.328964656496E-01 -0.333841036909E-01
+ -0.338778753937E-01 -0.343778579070E-01 -0.348841293505E-01 -0.353967688260E-01
+ -0.359158564302E-01 -0.364414732674E-01 -0.369737014619E-01 -0.375126241705E-01
+ -0.380583255963E-01 -0.386108910011E-01 -0.391704067192E-01 -0.397369601705E-01
+ -0.403106398746E-01 -0.408915354640E-01 -0.414797376989E-01 -0.420753384806E-01
+ -0.426784308662E-01 -0.432891090834E-01 -0.439074685447E-01 -0.445336058625E-01
+ -0.451676188643E-01 -0.458096066080E-01 -0.464596693969E-01 -0.471179087960E-01
+ -0.477844276477E-01 -0.484593300872E-01 -0.491427215599E-01 -0.498347088368E-01
+ -0.505354000318E-01 -0.512449046183E-01 -0.519633334465E-01 -0.526907987606E-01
+ -0.534274142160E-01 -0.541732948978E-01 -0.549285573379E-01 -0.556933195339E-01
+ -0.564677009670E-01 -0.572518226210E-01 -0.580458070010E-01 -0.588497781525E-01
+ -0.596638616809E-01 -0.604881847711E-01 -0.613228762070E-01 -0.621680663921E-01
+ -0.630238873697E-01 -0.638904728431E-01 -0.647679581970E-01 -0.656564805184E-01
+ -0.665561786179E-01 -0.674671930516E-01 -0.683896661426E-01 -0.693237420039E-01
+ -0.702695665601E-01 -0.712272875706E-01 -0.721970546526E-01 -0.731790193046E-01
+ -0.741733349294E-01 -0.751801568589E-01 -0.761996423776E-01 -0.772319507476E-01
+ -0.782772432331E-01 -0.793356831257E-01 -0.804074357700E-01 -0.814926685891E-01
+ -0.825915511108E-01 -0.837042549942E-01 -0.848309540562E-01 -0.859718242988E-01
+ -0.871270439364E-01 -0.882967934237E-01 -0.894812554835E-01 -0.906806151358E-01
+ -0.918950597259E-01 -0.931247789542E-01 -0.943699649053E-01 -0.956308120783E-01
+ -0.969075174167E-01 -0.982002803397E-01 -0.995093027723E-01 -0.100834789178
+ -0.102176946589     -0.103535984640     -0.104912115601     -0.106305554408
+ -0.107716518699     -0.109145228846     -0.110591907992     -0.112056782083
+ -0.113540079902     -0.115042033111     -0.116562876279     -0.118102846924
+ -0.119662185548     -0.121241135674     -0.122839943885     -0.124458859861
+ -0.126098136421     -0.127758029556     -0.129438798476     -0.131140705646
+ -0.132864016826     -0.134609001118     -0.136375931000     -0.138165082373
+ -0.139976734605     -0.141811170571     -0.143668676698     -0.145549543010
+ -0.147454063174     -0.149382534542     -0.151335258202     -0.153312539020
+ -0.155314685690     -0.157342010784     -0.159394830794     -0.161473466187
+ -0.163578241451     -0.165709485150     -0.167867529967     -0.170052712763
+ -0.172265374627     -0.174505860927     -0.176774521364     -0.179071710028
+ -0.181397785450     -0.183753110660     -0.186138053242     -0.188552985391
+ -0.190998283970     -0.193474330567     -0.195981511558     -0.198520218164
+ -0.201090846509     -0.203693797686     -0.206329477816     -0.208998298110
+ -0.211700674934     -0.214437029874     -0.217207789799     -0.220013386924
+ -0.222854258885     -0.225730848798     -0.228643605330     -0.231592982770
+ -0.234579441096     -0.237603446046     -0.240665469192     -0.243765988009
+ -0.246905485951     -0.250084452522     -0.253303383355     -0.256562780285
+ -0.259863151427     -0.263205011251     -0.266588880668     -0.270015287100
+ -0.273484764567     -0.276997853767     -0.280555102159     -0.284157064045
+ -0.287804300653     -0.291497380229     -0.295236878117     -0.299023376847
+ -0.302857466229     -0.306739743435     -0.310670813097     -0.314651287392
+ -0.318681786140     -0.322762936896     -0.326895375043     -0.331079743891
+ -0.335316694772     -0.339606887142     -0.343950988674     -0.348349675366
+ -0.352803631636     -0.357313550429     -0.361880133322     -0.366504090626
+ -0.371186141493     -0.375927014026     -0.380727445386     -0.385588181904
+ -0.390509979190     -0.395493602247     -0.400539825585     -0.405649433336
+ -0.410823219371     -0.416061987417     -0.421366551177     -0.426737734449
+ -0.432176371249     -0.437683305934     -0.443259393326     -0.448905498838
+ -0.454622498602     -0.460411279595     -0.466272739772     -0.472207788196
+ -0.478217345169     -0.484302342370     -0.490463722986     -0.496702441854
+ -0.503019465594     -0.509415772754     -0.515892353947     -0.522450211996
+ -0.529090362079     -0.535813831872     -0.542621661699     -0.549514904679
+ -0.556494626876     -0.563561907453     -0.570717838821     -0.577963526797
+ -0.585300090760     -0.592728663807     -0.600250392913     -0.607866439093
+ -0.615577977561     -0.623386197897     -0.631292304211     -0.639297515310
+ -0.647403064865     -0.655610201584     -0.663920189379     -0.672334307543
+ -0.680853850922     -0.689480130093     -0.698214471537     -0.707058217824
+ -0.716012727788     -0.725079376714     -0.734259556517     -0.743554675928
+ -0.752966160683     -0.762495453708     -0.772144015307     -0.781913323359
+ -0.791804873502     -0.801820179333     -0.811960772598     -0.822228203393
+ -0.832624040357     -0.843149870875     -0.853807301275     -0.864597957033
+ -0.875523482972     -0.886585543467     -0.897785822655     -0.909126024633
+ -0.920607873675     -0.932233114431     -0.944003512147     -0.955920852866
+ -0.967986943648     -0.980203612777     -0.992572709980      -1.00509610664
+  -1.01777569600      -1.03061339340      -1.04361113648      -1.05677088541
+  -1.07009462309      -1.08358435538      -1.09724211131      -1.11106994333
+  -1.12506992749      -1.13924416368      -1.15359477587      -1.16812391227
+  -1.18283374563      -1.19772647340      -1.21280431798      -1.22806952694
+  -1.24352437322      -1.25917115537      -1.27501219777      -1.29104985082
+  -1.30728649120      -1.32372452205      -1.34036637322      -1.35721450146
+  -1.37427139062      -1.39153955191      -1.40902152406      -1.42671987356
+  -1.44463719487      -1.46277611057      -1.48113927164      -1.49972935762
+  -1.51854907678      -1.53760116636      -1.55688839274      -1.57641355163
+  -1.59617946823      -1.61618899746      -1.63644502406      -1.65695046283
+  -1.67770825876      -1.69872138719      -1.71999285395      -1.74152569554
+  -1.76332297923      -1.78538780323      -1.80772329679      -1.83033262031
+  -1.85321896547      -1.87638555532      -1.89983564434      -1.92357251857
+  -1.94759949563      -1.97191992478      -1.99653718700      -2.02145469497
+  -2.04668205764      -2.07220966443      -2.09804790642      -2.12420032166
+  -2.15067047978      -2.17746198188      -2.20457846047      -2.23202357930
+  -2.25980103324      -2.28791454810      -2.31636788043      -2.34516481731
+  -2.37430917603      -2.40380480387      -2.43365557769      -2.46386540364
+  -2.49443821668      -2.52537798019      -2.55668868542      -2.58837435097
+  -2.62043902219      -2.65288677053      -2.68572169282      -2.71894791049
+  -2.75256956874      -2.78659083564      -2.82101590113      -2.85584897596
+  -2.89109429054      -2.92675609370      -2.96283865137      -2.99934624512
+  -3.03628317065      -3.07365373612      -3.11146226036      -3.14971307100
+  -3.18841050237      -3.22755889342      -3.26716258525      -3.30722591873
+  -3.34775323178      -3.38874885649      -3.43021711614      -3.47216232192
+  -3.51458876948      -3.55750073523      -3.60090247243      -3.64479820700
+  -3.68919213309      -3.73408840832      -3.77949114879      -3.82540442370
+  -3.87183224972      -3.91877858493      -3.96624732244      -4.01424228364
+  -4.06276721097      -4.11182576037      -4.16142149315      -4.21155786752
+  -4.26223822951      -4.31346580345      -4.36524368188      -4.41757481485
+  -4.47046199870      -4.52390786411      -4.57791486363      -4.63248525838
+  -4.68762110414      -4.74332423666      -4.79959625621      -4.85643851127
+  -4.91385208145      -4.97183775949      -5.03039603239      -5.08952706154
+  -5.14923066196      -5.20950628047      -5.27035297284      -5.33176937987
+  -5.39375370237      -5.45630367501      -5.51941653899      -5.58308901353
+  -5.64731726611      -5.71209688154      -5.77742282967      -5.84328943190
+  -5.90969032632      -5.97661843161      -6.04406590954      -6.11202412624
+  -6.18048361208      -6.24943402026      -6.31886408419      -6.38876157349
+  -6.45911324884      -6.52990481565      -6.60112087659      -6.67274488304
+  -6.74475908566      -6.81714448395      -6.88988077519      -6.96294630267
+  -7.03631800341      -7.10997135569      -7.18388032635      -7.25801731822
+  -7.33235311795      -7.40685684436      -7.48149589778      -7.55623591061
+  -7.63104069948      -7.70587221942      -7.78069052052      -7.85545370751
+  -7.93011790273      -8.00463721321      -8.07896370237      -8.15304736694
+  -8.22683611997      -8.30027578060      -8.37331007133      -8.44588062387
+  -8.51792699428      -8.58938668853      -8.66019519936      -8.73028605577
+  -8.79959088604      -8.86803949557      -8.93555996088      -9.00207874083
+  -9.06752080668      -9.13180979201      -9.19486816425      -9.25661741883
+  -9.31697829773      -9.37587103345      -9.43321562010      -9.48893211265
+  -9.54294095572      -9.59516334303      -9.64552160858      -9.69393965030
+  -9.74034338701      -9.78466124902      -9.82682470256      -9.86676880795
+  -9.90443281080      -9.93976076538      -9.97270218848      -10.0032127418
+  -10.0312549399      -10.0567988799      -10.0798229893      -10.1003147850
+  -10.1182716387      -10.1337015390      -10.1466238429      -10.1570700042
+  -10.1650842689      -10.1707243202      -10.1740618609      -10.1751831124
+  -10.1741892112      -10.1711964808      -10.1663365535      -10.1597563156
+  -10.1516176464      -10.1420969192      -10.1313842309      -10.1196823253
+  -10.1072051736      -10.0940968238      -10.0806952965      -10.0672069155
+  -10.0538683481      -10.0409140474      -10.0285721056      -10.0170595979
+  -10.0065774381      -9.99730479453      -9.98939314310      -9.98296008315
+  -9.97808309148      -9.97479346097      -9.97307075475      -9.97283821294
+  -9.97395967895      -9.97623877123      -9.97942122018      -9.98320152398
+  -9.98723536058      -9.99115953388      -9.99462164215      -9.99732214879
+  -9.99915165904      -9.99989199010      -10.0000050528      -10.0000038975
+  -10.0000029467      -10.0000022209      -10.0000016685      -10.0000012497
+  -10.0000009330      -10.0000006945      -10.0000005154      -10.0000003814
+  -10.0000002814      -10.0000002071      -10.0000001520      -10.0000001113
+  -10.0000000813      -10.0000000593      -10.0000000432      -10.0000000314
+  -10.0000000228      -10.0000000166      -10.0000000121      -10.0000000088
+  -10.0000000064      -10.0000000047      -10.0000000034      -10.0000000025
+  -10.0000000019      -10.0000000014      -10.0000000010      -10.0000000008
+  -10.0000000006      -10.0000000004      -10.0000000003      -10.0000000002
+  -10.0000000002      -10.0000000001      -10.0000000001      -10.0000000001
+ Core charge follows
+   0.00000000000       0.00000000000       0.00000000000       0.00000000000
+ Valence charge follows
+  0.492780239702E-10  0.199599257644E-09  0.454776898355E-09  0.818736464820E-09
+  0.129551883922E-08  0.188928338877E-08  0.260431116890E-08  0.344500821000E-08
+  0.441590889006E-08  0.552167939524E-08  0.676712127079E-08  0.815717506448E-08
+  0.969692406502E-08  0.113915981379E-07  0.132465776612E-07  0.152673975636E-07
+  0.174597514681E-07  0.198294959424E-07  0.223826548613E-07  0.251254238815E-07
+  0.280641750328E-07  0.312054614290E-07  0.345560221008E-07  0.381227869541E-07
+  0.419128818577E-07  0.459336338621E-07  0.501925765539E-07  0.546974555499E-07
+  0.594562341323E-07  0.644770990308E-07  0.697684663544E-07  0.753389876766E-07
+  0.811975562783E-07  0.873533135523E-07  0.938156555734E-07  0.100594239839E-06
+  0.107698992183E-06  0.115140113869E-06  0.122928088869E-06  0.131073691325E-06
+  0.139587993208E-06  0.148482372175E-06  0.157768519624E-06  0.167458448963E-06
+  0.177564504088E-06  0.188099368081E-06  0.199076072137E-06  0.210508004711E-06
+  0.222408920910E-06  0.234792952125E-06  0.247674615907E-06  0.261068826105E-06
+  0.274990903258E-06  0.289456585258E-06  0.304482038288E-06  0.320083868041E-06
+  0.336279131225E-06  0.353085347371E-06  0.370520510937E-06  0.388603103730E-06
+  0.407352107641E-06  0.426787017711E-06  0.446927855539E-06  0.467795183019E-06
+  0.489410116447E-06  0.511794340980E-06  0.534970125470E-06  0.558960337676E-06
+  0.583788459876E-06  0.609478604864E-06  0.636055532375E-06  0.663544665919E-06
+  0.691972110051E-06  0.721364668087E-06  0.751749860272E-06  0.783155942412E-06
+  0.815611924988E-06  0.849147592757E-06  0.883793524859E-06  0.919581115434E-06
+  0.956542594775E-06  0.994711051014E-06  0.103412045237E-05  0.107480566998E-05
+  0.111680250127E-05  0.116014769398E-05  0.120487897078E-05  0.125103505449E-05
+  0.129865569401E-05  0.134778169085E-05  0.139845492637E-05  0.145071838970E-05
+  0.150461620643E-05  0.156019366793E-05  0.161749726153E-05  0.167657470139E-05
+  0.173747496022E-05  0.180024830175E-05  0.186494631412E-05  0.193162194400E-05
+  0.200032953170E-05  0.207112484711E-05  0.214406512659E-05  0.221920911076E-05
+  0.229661708332E-05  0.237635091081E-05  0.245847408342E-05  0.254305175680E-05
+  0.263015079500E-05  0.271983981443E-05  0.281218922902E-05  0.290727129650E-05
+  0.300516016584E-05  0.310593192593E-05  0.320966465550E-05  0.331643847431E-05
+  0.342633559563E-05  0.353944038012E-05  0.365583939100E-05  0.377562145069E-05
+  0.389887769888E-05  0.402570165207E-05  0.415618926463E-05  0.429043899147E-05
+  0.442855185223E-05  0.457063149713E-05  0.471678427456E-05  0.486711930032E-05
+  0.502174852867E-05  0.518078682518E-05  0.534435204142E-05  0.551256509158E-05
+  0.568555003105E-05  0.586343413699E-05  0.604634799095E-05  0.623442556360E-05
+  0.642780430165E-05  0.662662521691E-05  0.683103297775E-05  0.704117600276E-05
+  0.725720655685E-05  0.747928084988E-05  0.770755913762E-05  0.794220582550E-05
+  0.818338957483E-05  0.843128341184E-05  0.868606483943E-05  0.894791595184E-05
+  0.921702355215E-05  0.949357927289E-05  0.977777969962E-05  0.100698264977E-04
+  0.103699265424E-04  0.106782920520E-04  0.109951407249E-04  0.113206958793E-04
+  0.116551865974E-04  0.119988478728E-04  0.123519207616E-04  0.127146525374E-04
+  0.130872968505E-04  0.134701138910E-04  0.138633705558E-04  0.142673406202E-04
+  0.146823049139E-04  0.151085515013E-04  0.155463758664E-04  0.159960811023E-04
+  0.164579781062E-04  0.169323857785E-04  0.174196312274E-04  0.179200499787E-04
+  0.184339861910E-04  0.189617928764E-04  0.195038321264E-04  0.200604753444E-04
+  0.206321034831E-04  0.212191072891E-04  0.218218875527E-04  0.224408553647E-04
+  0.230764323796E-04  0.237290510853E-04  0.243991550802E-04  0.250871993569E-04
+  0.257936505930E-04  0.265189874503E-04  0.272637008803E-04  0.280282944384E-04
+  0.288132846062E-04  0.296192011212E-04  0.304465873158E-04  0.312960004645E-04
+  0.321680121400E-04  0.330632085788E-04  0.339821910553E-04  0.349255762666E-04
+  0.358939967260E-04  0.368881011674E-04  0.379085549596E-04  0.389560405314E-04
+  0.400312578076E-04  0.411349246558E-04  0.422677773451E-04  0.434305710163E-04
+  0.446240801642E-04  0.458490991322E-04  0.471064426196E-04  0.483969462019E-04
+  0.497214668642E-04  0.510808835490E-04  0.524760977171E-04  0.539080339235E-04
+  0.553776404078E-04  0.568858896998E-04  0.584337792408E-04  0.600223320206E-04
+  0.616525972312E-04  0.633256509366E-04  0.650425967605E-04  0.668045665918E-04
+  0.686127213069E-04  0.704682515127E-04  0.723723783065E-04  0.743263540571E-04
+  0.763314632051E-04  0.783890230844E-04  0.805003847639E-04  0.826669339122E-04
+  0.848900916835E-04  0.871713156268E-04  0.895121006185E-04  0.919139798190E-04
+  0.943785256541E-04  0.969073508216E-04  0.995021093239E-04  0.102164497528E-03
+  0.104896255250E-03  0.107699166874E-03  0.110575062491E-03  0.113525819076E-03
+  0.116553361690E-03  0.119659664715E-03  0.122846753122E-03  0.126116703768E-03
+  0.129471646732E-03  0.132913766684E-03  0.136445304285E-03  0.140068557630E-03
+  0.143785883725E-03  0.147599700005E-03  0.151512485885E-03  0.155526784360E-03
+  0.159645203642E-03  0.163870418839E-03  0.168205173684E-03  0.172652282298E-03
+  0.177214631009E-03  0.181895180218E-03  0.186696966306E-03  0.191623103601E-03
+  0.196676786388E-03  0.201861290978E-03  0.207179977827E-03  0.212636293716E-03
+  0.218233773982E-03  0.223976044812E-03  0.229866825596E-03  0.235909931344E-03
+  0.242109275163E-03  0.248468870805E-03  0.254992835276E-03  0.261685391520E-03
+  0.268550871171E-03  0.275593717378E-03  0.282818487707E-03  0.290229857121E-03
+  0.297832621032E-03  0.305631698446E-03  0.313632135183E-03  0.321839107187E-03
+  0.330257923924E-03  0.338894031871E-03  0.347753018097E-03  0.356840613945E-03
+  0.366162698807E-03  0.375725304005E-03  0.385534616776E-03  0.395596984365E-03
+  0.405918918224E-03  0.416507098335E-03  0.427368377639E-03  0.438509786595E-03
+  0.449938537855E-03  0.461662031074E-03  0.473687857847E-03  0.486023806780E-03
+  0.498677868707E-03  0.511658242039E-03  0.524973338275E-03  0.538631787649E-03
+  0.552642444944E-03  0.567014395465E-03  0.581756961175E-03  0.596879707002E-03
+  0.612392447323E-03  0.628305252628E-03  0.644628456371E-03  0.661372662012E-03
+  0.678548750256E-03  0.696167886499E-03  0.714241528479E-03  0.732781434148E-03
+  0.751799669763E-03  0.771308618209E-03  0.791320987560E-03  0.811849819879E-03
+  0.832908500276E-03  0.854510766222E-03  0.876670717130E-03  0.899402824216E-03
+  0.922721940639E-03  0.946643311940E-03  0.971182586781E-03  0.996355827999E-03
+  0.102217952398E-02  0.104867060037E-02  0.107584643212E-02  0.110372485589E-02
+  0.113232418286E-02  0.116166321182E-02  0.119176124276E-02  0.122263809080E-02
+  0.125431410054E-02  0.128681016088E-02  0.132014772023E-02  0.135434880223E-02
+  0.138943602192E-02  0.142543260238E-02  0.146236239192E-02  0.150024988179E-02
+  0.153912022438E-02  0.157899925205E-02  0.161991349651E-02  0.166189020877E-02
+  0.170495737977E-02  0.174914376163E-02  0.179447888952E-02  0.184099310429E-02
+  0.188871757576E-02  0.193768432677E-02  0.198792625801E-02  0.203947717357E-02
+  0.209237180743E-02  0.214664585065E-02  0.220233597957E-02  0.225947988485E-02
+  0.231811630144E-02  0.237828503961E-02  0.244002701689E-02  0.250338429113E-02
+  0.256840009462E-02  0.263511886938E-02  0.270358630352E-02  0.277384936895E-02
+  0.284595636024E-02  0.291995693485E-02  0.299590215467E-02  0.307384452903E-02
+  0.315383805911E-02  0.323593828387E-02  0.332020232761E-02  0.340668894910E-02
+  0.349545859245E-02  0.358657343971E-02  0.368009746533E-02  0.377609649251E-02
+  0.387463825150E-02  0.397579244000E-02  0.407963078565E-02  0.418622711077E-02
+  0.429565739939E-02  0.440799986665E-02  0.452333503074E-02  0.464174578739E-02
+  0.476331748707E-02  0.488813801497E-02  0.501629787393E-02  0.514789027035E-02
+  0.528301120330E-02  0.542175955685E-02  0.556423719588E-02  0.571054906536E-02
+  0.586080329343E-02  0.601511129818E-02  0.617358789857E-02  0.633635142942E-02
+  0.650352386079E-02  0.667523092184E-02  0.685160222940E-02  0.703277142144E-02
+  0.721887629562E-02  0.741005895314E-02  0.760646594817E-02  0.780824844294E-02
+  0.801556236889E-02  0.822856859406E-02  0.844743309696E-02  0.867232714719E-02
+  0.890342749321E-02  0.914091655733E-02  0.938498263842E-02  0.963582012268E-02
+  0.989362970253E-02  0.101586186043E-01  0.104310008251E-01  0.107109973784E-01
+  0.109988365505E-01  0.112947541661E-01  0.115989938655E-01  0.119118073917E-01
+  0.122334548905E-01  0.125642052211E-01  0.129043362805E-01  0.132541353401E-01
+  0.136138993962E-01  0.139839355349E-01  0.143645613112E-01  0.147561051438E-01
+  0.151589067262E-01  0.155733174536E-01  0.159997008681E-01  0.164384331214E-01
+  0.168899034562E-01  0.173545147080E-01  0.178326838263E-01  0.183248424177E-01
+  0.188314373107E-01  0.193529311438E-01  0.198898029775E-01  0.204425489310E-01
+  0.210116828448E-01  0.215977369705E-01  0.222012626884E-01  0.228228312544E-01
+  0.234630345772E-01  0.241224860265E-01  0.248018212746E-01  0.255016991718E-01
+  0.262228026567E-01  0.269658397039E-01  0.277315443091E-01  0.285206775139E-01
+  0.293340284721E-01  0.301724155580E-01  0.310366875190E-01  0.319277246742E-01
+  0.328464401598E-01  0.337937812247E-01  0.347707305756E-01  0.357783077764E-01
+  0.368175707008E-01  0.378896170419E-01  0.389955858803E-01  0.401366593122E-01
+  0.413140641396E-01  0.425290736257E-01  0.437830093154E-01  0.450772429254E-01
+  0.464131983042E-01  0.477923534647E-01  0.492162426923E-01  0.506864587291E-01
+  0.522046550378E-01  0.537725481463E-01  0.553919200761E-01  0.570646208559E-01
+  0.587925711228E-01  0.605777648126E-01  0.624222719423E-01  0.643282414855E-01
+  0.662979043432E-01  0.683335764111E-01  0.704376617463E-01  0.726126558332E-01
+  0.748611489510E-01  0.771858296442E-01  0.795894882957E-01  0.820750208047E-01
+  0.846454323693E-01  0.873038413739E-01  0.900534833812E-01  0.928977152293E-01
+  0.958400192313E-01  0.988840074788E-01  0.102033426244      0.105292160483
+  0.108664238432      0.112153836298      0.115765283036      0.119503065213
+  0.123371831946      0.127376399915      0.131521758439      0.135813074611
+  0.140255698472      0.144855168237      0.149617215525      0.154547770622
+  0.159652967727      0.164939150184      0.170412875680      0.176080921387
+  0.181950289025      0.188028209830      0.194322149393      0.200839812356
+  0.207589146913      0.214578349113      0.221815866908      0.229310403915
+  0.237070922857      0.245106648637      0.253427070998      0.262041946715
+  0.270961301285      0.280195430032      0.289754898594      0.299650542710
+  0.309893467251      0.320495044424      0.331466911062      0.342820964951
+  0.354569360076      0.366724500729      0.379299034374      0.392305843188
+  0.405758034166      0.419668927707      0.434052044561      0.448921091049
+  0.464289942432      0.480172624322      0.496583292029      0.513536207725
+  0.531045715300      0.549126212822      0.567792122452      0.587057857733
+  0.606937788121      0.627446200665      0.648597258731      0.670404957666
+  0.692883077332      0.716045131417      0.739904313462      0.764473439546
+  0.789764887594      0.815790533283      0.842561682533      0.870089000618
+  0.898382437919      0.927451152395      0.957303428867      0.987946595239
+   1.01938693582       1.05162960193       1.08467852005       1.11853629777
+   1.15320412786       1.18868169088       1.22496705658       1.26205658487
+   1.29994482644       1.33862442405       1.37808601477       1.41831813398
+   1.45930712186       1.50103703314       1.54348955079       1.58664390478
+   1.63047679654       1.67496233019       1.72007195153       1.76577439561
+   1.81203564410       1.85881889326       1.90608453351       1.95379014171
+   2.00189048690       2.05033755037       2.09908056105       2.14806604664
+   2.19723790140       2.24653747080       2.29590365365       2.34527302174
+   2.39457995708       2.44375680666       2.49273405423       2.54144050878
+   2.58980350868       2.63774914077       2.68520247290       2.73208779880
+   2.77832889329       2.82384927631       2.86857248345       2.91242234098
+   2.95532324290       2.99720042768       3.03798025211       3.07759045977
+   3.11596044160       3.15302148624       3.18870701769       3.22295281831
+   3.25569723533       3.28688136911       3.31644924211       3.34434794755
+   3.37052777736       3.39494232936       3.41754859402       3.43830702162
+   3.45718157112       3.47413974215       3.48915259210       3.50219474055
+   3.51324436308       3.52228317707       3.52929642157       3.53427283349
+   3.53720462179       3.53808744122       3.53692036634       3.53370586614
+   3.52844977885       3.52116128576       3.51185288223       3.50054034340
+   3.48724268159       3.47198209186       3.45478388237       3.43567638598
+   3.41469085004       3.39186130248       3.36722439301       3.34081921013
+   3.31268707666       3.28287132840       3.25141708326       3.21837101032
+   3.18378111077       3.14769652417       3.11016737503       3.07124467420
+   3.03098028900       2.98942699242       2.94663859753       2.90267017543
+   2.85757834615       2.81142161935       2.76426074711       2.71615903342
+   2.66718252492       2.61739998372       2.56688251629       2.51570274176
+   2.46393368328       2.41164816040       2.35891882023       2.30581782505
+   2.25241672379       2.19878629760       2.14499640429       2.09111583247
+   2.03721215988       1.98335161818       1.92959896405       1.87601735712
+   1.82266824495       1.76961125522       1.71690409542       1.66460246021
+   1.61275994650       1.56142797647       1.51065572855       1.46049007638
+   1.41097553585       1.36215422011       1.31406580257       1.26674748777
+   1.22023399011       1.17455752021       1.12974777881       1.08583195803
+   1.04283474981       1.00077836130      0.959682536933      0.919564587017
+  0.880439422502      0.842319595665      0.805215346411      0.769134653895
+  0.734083293117      0.700064896187      0.667081017907      0.635131205320
+  0.604213070887      0.574322368934      0.545453075008      0.517597467779
+  0.490746213150      0.464888450191      0.440011878568      0.416102847100
+  0.393146443113      0.371126582245      0.350026098378      0.329826833377
+  0.310509726321      0.292054901939      0.274441757953      0.257649051057
+  0.241654981287      0.226437274514      0.211973262854      0.198239962769
+  0.185214150670      0.172872435839      0.161191330513      0.150147316985
+  0.139716911592      0.129876725495      0.120603522149      0.111874271395
+  0.103666200127      0.959568394868E-01  0.887240685729E-01  0.819461546626E-01
+  0.756017899528E-01  0.696701248541E-01  0.641307978754E-01  0.589639621590E-01
+  0.541503087322E-01  0.496710865581E-01  0.455081194759E-01  0.416438201346E-01
+  0.380612010287E-01  0.347438827570E-01  0.316760996300E-01  0.288427027567E-01
+  0.262291607500E-01  0.238215581898E-01  0.216065919891E-01  0.195715658083E-01
+  0.177043826650E-01  0.159935358866E-01  0.144280985526E-01  0.129977115711E-01
+  0.116925705332E-01  0.105034114847E-01  0.942149575296E-02  0.843859395947E-02
+  0.754696934799E-02  0.673936055009E-02  0.600896390574E-02  0.534941545081E-02
+  0.475477267695E-02  0.421949616337E-02  0.373843117345E-02  0.330678930268E-02
+  0.292013025772E-02  0.257434384005E-02  0.226563220076E-02  0.199049242678E-02
+  0.174569951243E-02  0.152828976381E-02  0.133554467775E-02  0.116497533070E-02
+  0.101430730790E-02  0.881466197239E-03  0.764563667367E-03  0.661884144721E-03
+  0.571872099446E-03  0.493119946042E-03  0.424356560532E-03  0.364436412294E-03
+  0.312329305356E-03  0.267110720900E-03  0.227952749997E-03  0.194115603145E-03
+  0.164939681067E-03  0.139838189339E-03  0.118290277894E-03  0.998346851041E-04
+  0.840638651173E-04  0.706185763121E-04  0.591829081571E-04  0.494797234032E-04
+  0.412664923661E-04  0.343314960795E-04  0.284903752780E-04  0.235830025072E-04
+  0.194706551205E-04  0.160334675095E-04  0.131681415967E-04  0.107858953914E-04
+  0.881063024837E-05  0.717729836744E-05  0.583045300797E-05  0.472296486328E-05
+  0.381488902407E-05  0.307246795271E-05  0.246725687980E-05  0.197535901085E-05
+  0.157675888836E-05  0.125474318435E-05  0.995399096394E-06  0.787181380292E-06
+  0.620539872088E-06  0.487600127165E-06  0.381890533725E-06  0.298109939990E-06
+  0.231930468817E-06  0.179830780095E-06  0.138955581014E-06  0.106997678015E-06
+  0.820993138317E-07  0.627699398126E-07  0.478179408812E-07  0.362941584030E-07
+  0.274453503582E-07  0.206759876142E-07  0.155170151003E-07  0.116004086354E-07
+  0.863853457837E-08  0.640747303405E-08  0.473359830758E-08  0.348282483874E-08
+  0.255202503976E-08  0.186220921864E-08  0.135312886510E-08  0.979024624934E-09
+  0.705290751164E-09  0.505870020706E-09  0.361228209014E-09  0.256786295527E-09
+  0.181712450472E-09  0.127995663949E-09  0.897383239056E-10  0.626192205659E-10
+  0.434868716827E-10  0.300540073051E-10  0.206687018422E-10  0.141437126637E-10
+  0.962998562089E-11  0.652337146701E-11  0.439617295253E-11  0.294717010523E-11
+  0.196532617601E-11  0.130356876058E-11  0.859950837551E-12  0.564187955929E-12
+  0.368090207837E-12  0.238800022952E-12  0.154039857000E-12  0.987913907697E-13
+  0.629883969806E-13  0.399231951614E-13  0.251524745814E-13  0.157504816950E-13
+  0.980237348939E-14  0.606260267007E-14  0.372600272599E-14  0.227535281925E-14
+  0.138051372609E-14  0.832115384684E-15  0.498243006621E-15  0.296331113565E-15
+  0.175047036365E-15  0.102691941058E-15  0.598252068504E-16  0.346066833919E-16
+  0.198758116961E-16  0.113328620309E-16  0.641452321935E-17  0.360378548376E-17
+  0.200947433588E-17  0.111197155646E-17  0.610591502243E-18  0.332668248375E-18
+  0.179817762098E-18  0.964208710617E-19  0.512841044422E-19  0.270534869525E-19
+  0.141529638344E-19  0.734191877347E-20  0.377627461157E-20  0.192558448759E-20
+  0.973328000875E-21  0.487646937076E-21  0.242132362633E-21  0.119138474037E-21
+  0.580835644257E-22  0.280547285232E-22  0.134233025638E-22  0.636152819720E-23
+  0.298579453795E-23  0.138771960459E-23  0.638606237903E-24  0.290937582315E-24
+  0.131203872093E-24  0.585622644353E-25  0.258676498185E-25  0.113059430477E-25
+  0.488888030884E-26  0.209125097831E-26  0.884784809359E-27  0.370206263418E-27
+  0.153166420968E-27  0.626520645112E-28  0.253335918373E-28  0.101247535624E-28
+  0.399884351637E-29  0.156056459007E-29  0.601673368222E-30  0.229142163020E-30
+  0.861880470042E-31  0.320124313757E-31  0.117395319166E-31  0.424984835550E-32
+  0.151850337752E-32  0.535434078518E-33  0.186282262601E-33  0.639349976738E-34
+  0.216437708420E-34  0.722568202502E-35  0.237848256143E-35  0.771825090565E-36
+  0.246863687785E-36  0.778100218595E-37  0.241642579520E-37  0.739246986725E-38
+  0.222741620059E-38  0.660884224427E-39  0.193053208287E-39  0.555099250600E-40
+  0.157079497206E-40  0.437356687020E-41  0.119792739266E-41  0.322710872994E-42
+  0.854857759789E-43  0.222627547511E-43  0.569869203848E-44  0.143346796997E-44
+  0.354259414965E-45  0.859960070933E-46  0.205003042006E-46  0.479808434721E-47
+  0.110230094508E-47  0.248516440733E-48  0.549704582063E-49  0.119266434043E-49
+  0.253755707373E-50  0.529315807406E-51  0.108219818662E-51  0.216811210440E-52
+  0.425528271125E-53  0.817964134609E-54  0.153951988782E-54  0.283639175090E-55
+  0.511399475114E-56  0.902089009734E-57  0.155637430270E-57  0.262562892042E-58
+  0.432997068764E-59  0.697822770870E-60  0.109872428461E-60  0.168962031608E-61
+  0.253698739626E-62  0.371832053739E-63  0.531794420317E-64  0.741953749227E-65
+  0.100951374062E-65  0.133910546874E-66  0.173120244688E-67  0.218058694523E-68
+  0.267517359787E-69  0.319552829402E-70  0.371537987160E-71  0.420329597949E-72
+  0.462549128433E-73  0.494949053175E-74  0.514813712043E-75  0.520328484336E-76
+  0.510849038095E-77  0.487016135624E-78  0.450688985820E-79  0.404705555533E-80
+  0.352512539160E-81  0.297732734720E-82  0.243745919442E-83  0.193351775909E-84
+  0.148558887154E-85  0.110516862344E-86  0.795745402673E-88  0.554339556622E-89
+  0.373475954441E-90  0.243267521806E-91  0.153123600182E-92  0.931203792006E-94
+  0.546889201141E-95  0.309395696933E-96  0.164592103991E-97  0.843871265403E-99
+  0.416787120635-100  0.198207073332-101
Added: SwiftApps/ematter/workflow-run/O.psf
--- SwiftApps/ematter/workflow-run/O.psf	                        (rev 0)
+++ SwiftApps/ematter/workflow-run/O.psf	2015-01-27 22:12:52 UTC (rev 8376)
@@ -0,0 +1,1821 @@
+ O  ca nrl nc
+ ATM3      29-MAR-06 Troullier-Martins
+ 2s 2.00  r= 1.14/2p 4.00  r= 1.14/3d 0.00  r= 1.14/4f 0.00  r= 1.14/
+   4  0 1029  0.309844022083E-03  0.125000000000E-01   6.00000000000
+ Radial grid follows
+  0.389735801693E-05  0.784373876281E-05  0.118397588677E-04  0.158860427178E-04
+  0.199832225532E-04  0.241319385666E-04  0.283328390034E-04  0.325865802628E-04
+  0.368938270004E-04  0.412552522324E-04  0.456715374403E-04  0.501433726777E-04
+  0.546714566780E-04  0.592564969634E-04  0.638992099558E-04  0.686003210887E-04
+  0.733605649201E-04  0.781806852479E-04  0.830614352256E-04  0.880035774804E-04
+  0.930078842321E-04  0.980751374137E-04  0.103206128794E-03  0.108401660101E-03
+  0.113662543146E-03  0.118989599954E-03  0.124383662888E-03  0.129845574781E-03
+  0.135376189068E-03  0.140976369919E-03  0.146646992373E-03  0.152388942477E-03
+  0.158203117422E-03  0.164090425685E-03  0.170051787170E-03  0.176088133351E-03
+  0.182200407420E-03  0.188389564433E-03  0.194656571457E-03  0.201002407725E-03
+  0.207428064787E-03  0.213934546665E-03  0.220522870010E-03  0.227194064261E-03
+  0.233949171805E-03  0.240789248143E-03  0.247715362049E-03  0.254728595743E-03
+  0.261830045058E-03  0.269020819608E-03  0.276302042968E-03  0.283674852843E-03
+  0.291140401250E-03  0.298699854695E-03  0.306354394360E-03  0.314105216280E-03
+  0.321953531539E-03  0.329900566451E-03  0.337947562756E-03  0.346095777814E-03
+  0.354346484801E-03  0.362700972906E-03  0.371160547534E-03  0.379726530512E-03
+  0.388400260291E-03  0.397183092161E-03  0.406076398455E-03  0.415081568772E-03
+  0.424200010187E-03  0.433433147476E-03  0.442782423334E-03  0.452249298606E-03
+  0.461835252510E-03  0.471541782870E-03  0.481370406352E-03  0.491322658699E-03
+  0.501400094969E-03  0.511604289783E-03  0.521936837567E-03  0.532399352802E-03
+  0.542993470279E-03  0.553720845349E-03  0.564583154186E-03  0.575582094048E-03
+  0.586719383543E-03  0.597996762894E-03  0.609415994214E-03  0.620978861782E-03
+  0.632687172320E-03  0.644542755274E-03  0.656547463104E-03  0.668703171570E-03
+  0.681011780026E-03  0.693475211716E-03  0.706095414078E-03  0.718874359044E-03
+  0.731814043350E-03  0.744916488848E-03  0.758183742822E-03  0.771617878307E-03
+  0.785220994414E-03  0.798995216658E-03  0.812942697289E-03  0.827065615629E-03
+  0.841366178413E-03  0.855846620133E-03  0.870509203387E-03  0.885356219235E-03
+  0.900389987551E-03  0.915612857394E-03  0.931027207368E-03  0.946635445996E-03
+  0.962440012097E-03  0.978443375167E-03  0.994648035764E-03  0.101105652590E-02
+  0.102767140943E-02  0.104449528247E-02  0.106153077378E-02  0.107878054520E-02
+  0.109624729202E-02  0.111393374348E-02  0.113184266311E-02  0.114997684922E-02
+  0.116833913530E-02  0.118693239052E-02  0.120575952009E-02  0.122482346580E-02
+  0.124412720643E-02  0.126367375822E-02  0.128346617537E-02  0.130350755048E-02
+  0.132380101505E-02  0.134434973998E-02  0.136515693606E-02  0.138622585444E-02
+  0.140755978719E-02  0.142916206778E-02  0.145103607161E-02  0.147318521654E-02
+  0.149561296342E-02  0.151832281662E-02  0.154131832460E-02  0.156460308048E-02
+  0.158818072252E-02  0.161205493479E-02  0.163622944769E-02  0.166070803852E-02
+  0.168549453213E-02  0.171059280144E-02  0.173600676811E-02  0.176174040314E-02
+  0.178779772744E-02  0.181418281254E-02  0.184089978115E-02  0.186795280785E-02
+  0.189534611974E-02  0.192308399708E-02  0.195117077396E-02  0.197961083901E-02
+  0.200840863603E-02  0.203756866475E-02  0.206709548148E-02  0.209699369984E-02
+  0.212726799149E-02  0.215792308685E-02  0.218896377585E-02  0.222039490864E-02
+  0.225222139642E-02  0.228444821213E-02  0.231708039128E-02  0.235012303271E-02
+  0.238358129941E-02  0.241746041930E-02  0.245176568605E-02  0.248650245994E-02
+  0.252167616865E-02  0.255729230816E-02  0.259335644355E-02  0.262987420992E-02
+  0.266685131324E-02  0.270429353127E-02  0.274220671442E-02  0.278059678671E-02
+  0.281946974666E-02  0.285883166826E-02  0.289868870188E-02  0.293904707526E-02
+  0.297991309449E-02  0.302129314496E-02  0.306319369239E-02  0.310562128383E-02
+  0.314858254867E-02  0.319208419969E-02  0.323613303413E-02  0.328073593470E-02
+  0.332589987069E-02  0.337163189906E-02  0.341793916553E-02  0.346482890571E-02
+  0.351230844621E-02  0.356038520581E-02  0.360906669661E-02  0.365836052518E-02
+  0.370827439378E-02  0.375881610155E-02  0.380999354576E-02  0.386181472296E-02
+  0.391428773033E-02  0.396742076687E-02  0.402122213475E-02  0.407570024052E-02
+  0.413086359651E-02  0.418672082210E-02  0.424328064509E-02  0.430055190307E-02
+  0.435854354480E-02  0.441726463158E-02  0.447672433871E-02  0.453693195688E-02
+  0.459789689366E-02  0.465962867494E-02  0.472213694645E-02  0.478543147521E-02
+  0.484952215114E-02  0.491441898853E-02  0.498013212765E-02  0.504667183630E-02
+  0.511404851145E-02  0.518227268084E-02  0.525135500465E-02  0.532130627711E-02
+  0.539213742827E-02  0.546385952563E-02  0.553648377591E-02  0.561002152681E-02
+  0.568448426874E-02  0.575988363667E-02  0.583623141189E-02  0.591353952390E-02
+  0.599182005225E-02  0.607108522844E-02  0.615134743780E-02  0.623261922147E-02
+  0.631491327834E-02  0.639824246701E-02  0.648261980784E-02  0.656805848497E-02
+  0.665457184835E-02  0.674217341589E-02  0.683087687550E-02  0.692069608727E-02
+  0.701164508565E-02  0.710373808160E-02  0.719698946483E-02  0.729141380607E-02
+  0.738702585931E-02  0.748384056413E-02  0.758187304802E-02  0.768113862876E-02
+  0.778165281679E-02  0.788343131767E-02  0.798649003449E-02  0.809084507039E-02
+  0.819651273104E-02  0.830350952725E-02  0.841185217747E-02  0.852155761047E-02
+  0.863264296794E-02  0.874512560720E-02  0.885902310388E-02  0.897435325471E-02
+  0.909113408025E-02  0.920938382774E-02  0.932912097396E-02  0.945036422806E-02
+  0.957313253456E-02  0.969744507626E-02  0.982332127723E-02  0.995078080590E-02
+  0.100798435781E-01  0.102105297601E-01  0.103428597719E-01  0.104768542903E-01
+  0.106125342523E-01  0.107499208582E-01  0.108890355748E-01  0.110299001391E-01
+  0.111725365615E-01  0.113169671292E-01  0.114632144099E-01  0.116113012549E-01
+  0.117612508030E-01  0.119130864843E-01  0.120668320234E-01  0.122225114433E-01
+  0.123801490692E-01  0.125397695323E-01  0.127013977737E-01  0.128650590481E-01
+  0.130307789280E-01  0.131985833073E-01  0.133684984058E-01  0.135405507732E-01
+  0.137147672930E-01  0.138911751868E-01  0.140698020187E-01  0.142506756996E-01
+  0.144338244913E-01  0.146192770113E-01  0.148070622367E-01  0.149972095095E-01
+  0.151897485406E-01  0.153847094146E-01  0.155821225944E-01  0.157820189264E-01
+  0.159844296447E-01  0.161893863764E-01  0.163969211464E-01  0.166070663825E-01
+  0.168198549202E-01  0.170353200083E-01  0.172534953135E-01  0.174744149262E-01
+  0.176981133656E-01  0.179246255849E-01  0.181539869773E-01  0.183862333807E-01
+  0.186214010844E-01  0.188595268335E-01  0.191006478359E-01  0.193448017671E-01
+  0.195920267767E-01  0.198423614941E-01  0.200958450347E-01  0.203525170056E-01
+  0.206124175125E-01  0.208755871654E-01  0.211420670849E-01  0.214118989092E-01
+  0.216851248001E-01  0.219617874495E-01  0.222419300867E-01  0.225255964845E-01
+  0.228128309663E-01  0.231036784132E-01  0.233981842705E-01  0.236963945555E-01
+  0.239983558641E-01  0.243041153784E-01  0.246137208740E-01  0.249272207272E-01
+  0.252446639232E-01  0.255661000631E-01  0.258915793718E-01  0.262211527063E-01
+  0.265548715629E-01  0.268927880861E-01  0.272349550758E-01  0.275814259965E-01
+  0.279322549848E-01  0.282874968586E-01  0.286472071250E-01  0.290114419896E-01
+  0.293802583648E-01  0.297537138790E-01  0.301318668852E-01  0.305147764706E-01
+  0.309025024657E-01  0.312951054535E-01  0.316926467789E-01  0.320951885587E-01
+  0.325027936906E-01  0.329155258640E-01  0.333334495691E-01  0.337566301072E-01
+  0.341851336012E-01  0.346190270056E-01  0.350583781172E-01  0.355032555854E-01
+  0.359537289234E-01  0.364098685184E-01  0.368717456431E-01  0.373394324669E-01
+  0.378130020668E-01  0.382925284389E-01  0.387780865103E-01  0.392697521503E-01
+  0.397676021828E-01  0.402717143977E-01  0.407821675637E-01  0.412990414402E-01
+  0.418224167896E-01  0.423523753905E-01  0.428890000500E-01  0.434323746168E-01
+  0.439825839942E-01  0.445397141537E-01  0.451038521478E-01  0.456750861243E-01
+  0.462535053398E-01  0.468392001733E-01  0.474322621409E-01  0.480327839097E-01
+  0.486408593125E-01  0.492565833623E-01  0.498800522672E-01  0.505113634455E-01
+  0.511506155409E-01  0.517979084377E-01  0.524533432769E-01  0.531170224715E-01
+  0.537890497227E-01  0.544695300360E-01  0.551585697381E-01  0.558562764926E-01
+  0.565627593177E-01  0.572781286028E-01  0.580024961258E-01  0.587359750705E-01
+  0.594786800447E-01  0.602307270973E-01  0.609922337374E-01  0.617633189518E-01
+  0.625441032243E-01  0.633347085539E-01  0.641352584743E-01  0.649458780730E-01
+  0.657666940112E-01  0.665978345428E-01  0.674394295353E-01  0.682916104897E-01
+  0.691545105609E-01  0.700282645788E-01  0.709130090693E-01  0.718088822755E-01
+  0.727160241794E-01  0.736345765238E-01  0.745646828343E-01  0.755064884420E-01
+  0.764601405059E-01  0.774257880360E-01  0.784035819169E-01  0.793936749306E-01
+  0.803962217814E-01  0.814113791191E-01  0.824393055643E-01  0.834801617324E-01
+  0.845341102593E-01  0.856013158268E-01  0.866819451877E-01  0.877761671928E-01
+  0.888841528162E-01  0.900060751832E-01  0.911421095962E-01  0.922924335631E-01
+  0.934572268243E-01  0.946366713810E-01  0.958309515240E-01  0.970402538618E-01
+  0.982647673506E-01  0.995046833228E-01  0.100760195518      0.102031500113
+  0.103318795750      0.104622283574      0.105942167256      0.107278653031
+  0.108631949728      0.110002268801      0.111389824366      0.112794833232
+  0.114217514934      0.115658091769      0.117116788830      0.118593834041
+  0.120089458193      0.121603894981      0.123137381040      0.124690155978
+  0.126262462420      0.127854546043      0.129466655613      0.131099043025
+  0.132751963343      0.134425674838      0.136120439033      0.137836520737
+  0.139574188092      0.141333712611      0.143115369224      0.144919436319
+  0.146746195784      0.148595933054      0.150468937156      0.152365500748
+  0.154285920174      0.156230495502      0.158199530577      0.160193333064
+  0.162212214499      0.164256490336      0.166326479998      0.168422506925
+  0.170544898625      0.172693986726      0.174870107027      0.177073599552
+  0.179304808601      0.181564082805      0.183851775180      0.186168243183
+  0.188513848766      0.190888958436      0.193293943307      0.195729179164
+  0.198195046517      0.200691930664      0.203220221746      0.205780314815
+  0.208372609891      0.210997512025      0.213655431364      0.216346783211
+  0.219071988098      0.221831471842      0.224625665619      0.227455006027
+  0.230319935156      0.233220900657      0.236158355812      0.239132759605
+  0.242144576791      0.245194277974      0.248282339676      0.251409244412
+  0.254575480767      0.257781543474      0.261027933484      0.264315158055
+  0.267643730820      0.271014171876      0.274427007862      0.277882772039
+  0.281382004380      0.284925251644      0.288513067473      0.292146012469
+  0.295824654287      0.299549567724      0.303321334803      0.307140544873
+  0.311007794690      0.314923688523      0.318888838236      0.322903863392
+  0.326969391348      0.331086057351      0.335254504637      0.339475384535
+  0.343749356567      0.348077088549      0.352459256697      0.356896545736
+  0.361389648999      0.365939268545      0.370546115259      0.375210908971
+  0.379934378565      0.384717262093      0.389560306889      0.394464269689
+  0.399429916748      0.404458023958      0.409549376970      0.414704771320
+  0.419925012548      0.425210916327      0.430563308590      0.435983025661
+  0.441470914379      0.447027832241      0.452654647524      0.458352239430
+  0.464121498221      0.469963325353      0.475878633625      0.481868347315
+  0.487933402329      0.494074746343      0.500293338955      0.506590151834
+  0.512966168867      0.519422386322      0.525959812996      0.532579470374
+  0.539282392792      0.546069627594      0.552942235301      0.559901289770
+  0.566947878369      0.574083102141      0.581308075980      0.588623928802
+  0.596031803724      0.603532858242      0.611128264410      0.618819209027
+  0.626606893818      0.634492535625      0.642477366596      0.650562634375
+  0.658749602304      0.667039549612      0.675433771621      0.683933579944
+  0.692540302694      0.701255284690      0.710079887664      0.719015490479
+  0.728063489341      0.737225298018      0.746502348061      0.755896089030
+  0.765407988713      0.775039533366      0.784792227937      0.794667596303
+  0.804667181512      0.814792546019      0.825045271933      0.835426961263
+  0.845939236169      0.856583739215      0.867362133628      0.878276103552
+  0.889327354317      0.900517612705      0.911848627216      0.923322168344
+  0.934940028853      0.946704024058      0.958615992105      0.970677794266
+  0.982891315221      0.995258463357       1.00778117107       1.02046139505
+   1.03330111661       1.04630234199       1.05946710266       1.07279745563
+   1.08629548379       1.09996329625       1.11380302863       1.12781684341
+   1.14200693028       1.15637550647       1.17092481710       1.18565713552
+   1.20057476370       1.21568003255       1.23097530228       1.24646296283
+   1.26214543416       1.27802516670       1.29410464169       1.31038637157
+   1.32687290040       1.34356680424       1.36047069153       1.37758720356
+   1.39491901480       1.41246883339       1.43023940152       1.44823349588
+   1.46645392809       1.48490354512       1.50358522976       1.52250190107
+   1.54165651481       1.56105206393       1.58069157903       1.60057812881
+   1.62071482060       1.64110480079       1.66175125536       1.68265741035
+   1.70382653241       1.72526192924       1.74696695017       1.76894498665
+   1.79119947280       1.81373388593       1.83655174708       1.85965662159
+   1.88305211964       1.90674189684       1.93072965474       1.95501914150
+   1.97961415239       2.00451853043       2.02973616699       2.05527100237
+   2.08112702643       2.10730827924       2.13381885167       2.16066288605
+   2.18784457681       2.21536817116       2.24323796970       2.27145832716
+   2.30003365301       2.32896841222       2.35826712589       2.38793437201
+   2.41797478615       2.44839306218       2.47919395302       2.51038227138
+   2.54196289048       2.57394074488       2.60632083116       2.63910820880
+   2.67230800087       2.70592539492       2.73996564373       2.77443406616
+   2.80933604797       2.84467704267       2.88046257236       2.91669822860
+   2.95338967328       2.99054263952       3.02816293255       3.06625643062
+   3.10482908590       3.14388692546       3.18343605215       3.22348264563
+   3.26403296324       3.30509334105       3.34667019483       3.38877002106
+   3.43139939791       3.47456498631       3.51827353097       3.56253186145
+   3.60734689319       3.65272562863       3.69867515830       3.74520266190
+   3.79231540945       3.84002076242       3.88832617485       3.93723919457
+   3.98676746434       4.03691872305       4.08770080694       4.13912165081
+   4.19118928928       4.24391185801       4.29729759502       4.35135484193
+   4.40609204530       4.46151775793       4.51764064021       4.57446946144
+   4.63201310124       4.69028055093       4.74928091491       4.80902341211
+   4.86951737741       4.93077226313       4.99279764046       5.05560320099
+   5.11919875822       5.18359424908       5.24879973551       5.31482540599
+   5.38168157716       5.44937869544       5.51792733865       5.58733821764
+   5.65762217801       5.72879020177       5.80085340907       5.87382305993
+   5.94771055600       6.02252744237       6.09828540931       6.17499629417
+   6.25267208318       6.33132491333       6.41096707430       6.49161101033
+   6.57326932220       6.65595476919       6.73968027107       6.82445891012
+   6.91030393317       6.99722875368       7.08524695384       7.17437228666
+   7.26461867816       7.35600022952       7.44853121930       7.54222610565
+   7.63709952858       7.73316631227       7.83044146735       7.92894019324
+   8.02867788059       8.12967011361       8.23193267253       8.33548153609
+   8.44033288402       8.54650309955       8.65400877199       8.76286669931
+   8.87309389081       8.98470756969       9.09772517582       9.21216436843
+   9.32804302888       9.44537926344       9.56419140615       9.68449802164
+   9.80631790805       9.92967010001       10.0545738715       10.1810487391
+   10.3091144647       10.4387910587       10.5700987836       10.7030581563
+   10.8376899520       10.9740152072       11.1120552230       11.2518315685
+   11.3933660840       11.5366808846       11.6817983634       11.8287411953
+   11.9775323406       12.1281950481       12.2807528591       12.4352296112
+   12.5916494416       12.7500367913       12.9104164086       13.0728133531
+   13.2372529997       13.4037610425       13.5723634986       13.7430867125
+   13.9159573601       14.0910024527       14.2682493416       14.4477257219
+   14.6294596371       14.8134794836       14.9998140148       15.1884923458
+   15.3795439581       15.5729987039       15.7688868108       15.9672388867
+   16.1680859247       16.3714593073       16.5773908122       16.7859126166
+   16.9970573024       17.2108578613       17.4273477003       17.6465606462
+   17.8685309515       18.0932932995       18.3208828098       18.5513350438
+   18.7846860100       19.0209721701       19.2602304441       19.5024982168
+   19.7478133429       19.9962141534       20.2477394615       20.5024285685
+   20.7603212700       21.0214578625       21.2858791489       21.5536264456
+   21.8247415887       22.0992669405       22.3772453962       22.6587203904
+   22.9437359041       23.2323364717       23.5245671876       23.8204737133
+   24.1201022849       24.4234997200       24.7307134251       25.0417914028
+   25.3567822598       25.6757352141       25.9987001026       26.3257273893
+   26.6568681729       26.9921741948       27.3316978472       27.6754921815
+   28.0236109161       28.3761084454       28.7330398477       29.0944608944
+   29.4604280583       29.8309985223       30.2062301890       30.5861816890
+   30.9709123906       31.3604824086       31.7549526142       32.1543846442
+   32.5588409106       32.9683846106       33.3830797362       33.8029910842
+   34.2281842669       34.6587257214       35.0946827207       35.5361233840
+   35.9831166873       36.4357324741       36.8940414668       37.3581152769
+   37.8280264169       38.3038483114       38.7856553086       39.2735226917
+   39.7675266911       40.2677444958       40.7742542659       41.2871351447
+   41.8064672707       42.3323317907       42.8648108721       43.4039877158
+   43.9499465693       44.5027727398       45.0625526075       45.6293736391
+   46.2033244017       46.7844945760       47.3729749712       47.9688575386
+   48.5722353860       49.1832027924       49.8018552227       50.4282893426
+   51.0626030337       51.7048954089       52.3552668275       53.0138189116
+   53.6806545611       54.3558779705       55.0395946449       55.7319114163
+   56.4329364607       57.1427793146       57.8615508925       58.5893635038
+   59.3263308708       60.0725681461       60.8281919308       61.5933202926
+   62.3680727845       63.1525704631       63.9469359077       64.7512932395
+   65.5657681411       66.3904878757       67.2255813076       68.0711789217
+   68.9274128445       69.7944168641       70.6723264518       71.5612787827
+   72.4614127574       73.3728690237       74.2957899985       75.2303198900
+   76.1766047205       77.1347923488       78.1050324938       79.0874767575
+   80.0822786487       81.0895936073       82.1095790283       83.1423942865
+   84.1882007614       85.2471618623       86.3194430541       87.4052118830
+   88.5046380024       89.6178932000       90.7451514241       91.8865888112
+   93.0423837132       94.2127167253       95.3977707145       96.5977308479
+   97.8127846216       99.0431218904       100.288934897       101.550418302
+   102.827769215       104.121187224       105.430874429       106.757035472
+   108.099877566       109.459610535       110.836446839       112.230601612
+   113.642292693       115.071740662       116.519168873       117.984803490
+   119.468873521
+ Down Pseudopotential follows (l on next line)
+  0
+ -0.477757180914E-04 -0.961523807311E-04 -0.145137546864E-03 -0.194738870515E-03
+ -0.244964101984E-03 -0.295821089056E-03 -0.347317778231E-03 -0.399462215960E-03
+ -0.452262549909E-03 -0.505727030225E-03 -0.559864010830E-03 -0.614681950726E-03
+ -0.670189415314E-03 -0.726395077733E-03 -0.783307720218E-03 -0.840936235469E-03
+ -0.899289628041E-03 -0.958377015754E-03 -0.101820763111E-02 -0.107879082275E-02
+ -0.114013605690E-02 -0.120225291885E-02 -0.126515111446E-02 -0.132884047168E-02
+ -0.139333094208E-02 -0.145863260239E-02 -0.152475565611E-02 -0.159171043506E-02
+ -0.165950740103E-02 -0.172815714740E-02 -0.179767040080E-02 -0.186805802278E-02
+ -0.193933101151E-02 -0.201150050348E-02 -0.208457777530E-02 -0.215857424539E-02
+ -0.223350147579E-02 -0.230937117398E-02 -0.238619519472E-02 -0.246398554185E-02
+ -0.254275437021E-02 -0.262251398753E-02 -0.270327685634E-02 -0.278505559595E-02
+ -0.286786298438E-02 -0.295171196036E-02 -0.303661562541E-02 -0.312258724580E-02
+ -0.320964025469E-02 -0.329778825420E-02 -0.338704501754E-02 -0.347742449116E-02
+ -0.356894079694E-02 -0.366160823437E-02 -0.375544128281E-02 -0.385045460376E-02
+ -0.394666304312E-02 -0.404408163351E-02 -0.414272559666E-02 -0.424261034574E-02
+ -0.434375148780E-02 -0.444616482620E-02 -0.454986636306E-02 -0.465487230179E-02
+ -0.476119904960E-02 -0.486886322009E-02 -0.497788163580E-02 -0.508827133089E-02
+ -0.520004955374E-02 -0.531323376973E-02 -0.542784166387E-02 -0.554389114366E-02
+ -0.566140034180E-02 -0.578038761909E-02 -0.590087156725E-02 -0.602287101187E-02
+ -0.614640501530E-02 -0.627149287968E-02 -0.639815414991E-02 -0.652640861674E-02
+ -0.665627631983E-02 -0.678777755092E-02 -0.692093285695E-02 -0.705576304331E-02
+ -0.719228917707E-02 -0.733053259028E-02 -0.747051488331E-02 -0.761225792819E-02
+ -0.775578387208E-02 -0.790111514068E-02 -0.804827444176E-02 -0.819728476870E-02
+ -0.834816940409E-02 -0.850095192334E-02 -0.865565619841E-02 -0.881230640149E-02
+ -0.897092700882E-02 -0.913154280445E-02 -0.929417888420E-02 -0.945886065950E-02
+ -0.962561386141E-02 -0.979446454460E-02 -0.996543909147E-02 -0.101385642162E-01
+ -0.103138669690E-01 -0.104913747403E-01 -0.106711152651E-01 -0.108531166269E-01
+ -0.110374072629E-01 -0.112240159677E-01 -0.114129718979E-01 -0.116043045771E-01
+ -0.117980439001E-01 -0.119942201377E-01 -0.121928639414E-01 -0.123940063481E-01
+ -0.125976787853E-01 -0.128039130756E-01 -0.130127414418E-01 -0.132241965120E-01
+ -0.134383113247E-01 -0.136551193339E-01 -0.138746544143E-01 -0.140969508666E-01
+ -0.143220434230E-01 -0.145499672525E-01 -0.147807579662E-01 -0.150144516233E-01
+ -0.152510847365E-01 -0.154906942774E-01 -0.157333176828E-01 -0.159789928605E-01
+ -0.162277581946E-01 -0.164796525521E-01 -0.167347152890E-01 -0.169929862560E-01
+ -0.172545058050E-01 -0.175193147955E-01 -0.177874546005E-01 -0.180589671137E-01
+ -0.183338947554E-01 -0.186122804794E-01 -0.188941677797E-01 -0.191796006973E-01
+ -0.194686238268E-01 -0.197612823239E-01 -0.200576219120E-01 -0.203576888894E-01
+ -0.206615301366E-01 -0.209691931238E-01 -0.212807259180E-01 -0.215961771905E-01
+ -0.219155962250E-01 -0.222390329244E-01 -0.225665378196E-01 -0.228981620765E-01
+ -0.232339575046E-01 -0.235739765648E-01 -0.239182723777E-01 -0.242668987315E-01
+ -0.246199100913E-01 -0.249773616064E-01 -0.253393091200E-01 -0.257058091772E-01
+ -0.260769190340E-01 -0.264526966665E-01 -0.268332007795E-01 -0.272184908161E-01
+ -0.276086269666E-01 -0.280036701781E-01 -0.284036821638E-01 -0.288087254131E-01
+ -0.292188632006E-01 -0.296341595967E-01 -0.300546794772E-01 -0.304804885334E-01
+ -0.309116532823E-01 -0.313482410775E-01 -0.317903201190E-01 -0.322379594641E-01
+ -0.326912290382E-01 -0.331501996459E-01 -0.336149429815E-01 -0.340855316408E-01
+ -0.345620391319E-01 -0.350445398868E-01 -0.355331092733E-01 -0.360278236063E-01
+ -0.365287601600E-01 -0.370359971796E-01 -0.375496138939E-01 -0.380696905275E-01
+ -0.385963083130E-01 -0.391295495040E-01 -0.396694973879E-01 -0.402162362986E-01
+ -0.407698516298E-01 -0.413304298484E-01 -0.418980585076E-01 -0.424728262609E-01
+ -0.430548228759E-01 -0.436441392479E-01 -0.442408674142E-01 -0.448451005687E-01
+ -0.454569330760E-01 -0.460764604864E-01 -0.467037795504E-01 -0.473389882341E-01
+ -0.479821857342E-01 -0.486334724935E-01 -0.492929502165E-01 -0.499607218853E-01
+ -0.506368917754E-01 -0.513215654719E-01 -0.520148498862E-01 -0.527168532725E-01
+ -0.534276852441E-01 -0.541474567913E-01 -0.548762802979E-01 -0.556142695589E-01
+ -0.563615397983E-01 -0.571182076867E-01 -0.578843913598E-01 -0.586602104360E-01
+ -0.594457860359E-01 -0.602412408003E-01 -0.610466989095E-01 -0.618622861028E-01
+ -0.626881296973E-01 -0.635243586083E-01 -0.643711033691E-01 -0.652284961509E-01
+ -0.660966707836E-01 -0.669757627764E-01 -0.678659093386E-01 -0.687672494012E-01
+ -0.696799236380E-01 -0.706040744876E-01 -0.715398461752E-01 -0.724873847353E-01
+ -0.734468380336E-01 -0.744183557904E-01 -0.754020896036E-01 -0.763981929719E-01
+ -0.774068213185E-01 -0.784281320154E-01 -0.794622844073E-01 -0.805094398363E-01
+ -0.815697616667E-01 -0.826434153104E-01 -0.837305682520E-01 -0.848313900749E-01
+ -0.859460524872E-01 -0.870747293480E-01 -0.882175966946E-01 -0.893748327690E-01
+ -0.905466180456E-01 -0.917331352588E-01 -0.929345694312E-01 -0.941511079016E-01
+ -0.953829403542E-01 -0.966302588473E-01 -0.978932578429E-01 -0.991721342366E-01
+ -0.100467087387     -0.101778319148     -0.103106033897     -0.104450438568
+ -0.105811742683     -0.107190158384     -0.108585900463     -0.109999186400
+ -0.111430236391     -0.112879273384     -0.114346523111     -0.115832214125
+ -0.117336577833     -0.118859848532     -0.120402263444     -0.121964062750
+ -0.123545489632     -0.125146790303     -0.126768214048     -0.128410013262
+ -0.130072443488     -0.131755763452     -0.133460235107     -0.135186123670
+ -0.136933697659     -0.138703228941     -0.140494992765     -0.142309267808
+ -0.144146336215     -0.146006483640     -0.147889999292     -0.149797175975
+ -0.151728310136     -0.153683701901     -0.155663655130     -0.157668477453
+ -0.159698480324     -0.161753979058     -0.163835292887     -0.165942744999
+ -0.168076662593     -0.170237376920     -0.172425223340     -0.174640541362
+ -0.176883674703     -0.179154971330     -0.181454783519     -0.183783467899
+ -0.186141385510     -0.188528901851     -0.190946386937     -0.193394215349
+ -0.195872766291     -0.198382423645     -0.200923576022     -0.203496616825
+ -0.206101944300     -0.208739961595     -0.211411076816     -0.214115703091
+ -0.216854258620     -0.219627166742     -0.222434855991     -0.225277760159
+ -0.228156318355     -0.231070975068     -0.234022180229     -0.237010389275
+ -0.240036063213     -0.243099668679     -0.246201678012     -0.249342569312
+ -0.252522826507     -0.255742939424     -0.259003403852     -0.262304721611
+ -0.265647400620     -0.269031954968     -0.272458904982     -0.275928777297
+ -0.279442104929     -0.282999427344     -0.286601290530     -0.290248247072
+ -0.293940856226     -0.297679683987     -0.301465303170     -0.305298293482
+ -0.309179241599     -0.313108741239     -0.317087393243     -0.321115805652
+ -0.325194593781     -0.329324380301     -0.333505795319     -0.337739476455
+ -0.342026068922     -0.346366225609     -0.350760607164     -0.355209882071
+ -0.359714726734     -0.364275825563     -0.368893871056     -0.373569563880
+ -0.378303612960     -0.383096735563     -0.387949657380     -0.392863112617
+ -0.397837844081     -0.402874603262     -0.407974150428     -0.413137254707
+ -0.418364694179     -0.423657255964     -0.429015736311     -0.434440940689
+ -0.439933683876     -0.445494790053     -0.451125092889     -0.456825435641
+ -0.462596671241     -0.468439662387     -0.474355281642     -0.480344411524
+ -0.486407944598     -0.492546783576     -0.498761841405     -0.505054041370
+ -0.511424317183     -0.517873613083     -0.524402883932     -0.531013095311
+ -0.537705223619     -0.544480256173     -0.551339191303     -0.558283038452
+ -0.565312818279     -0.572429562757     -0.579634315275     -0.586928130738
+ -0.594312075674     -0.601787228332     -0.609354678788     -0.617015529052
+ -0.624770893173     -0.632621897342     -0.640569680005     -0.648615391969
+ -0.656760196513     -0.665005269499     -0.673351799486     -0.681800987842
+ -0.690354048860     -0.699012209880     -0.707776711400     -0.716648807206
+ -0.725629764490     -0.734720863977     -0.743923400052     -0.753238680895
+ -0.762668028610     -0.772212779363     -0.781874283523     -0.791653905805
+ -0.801553025418     -0.811573036215     -0.821715346849     -0.831981380934
+ -0.842372577213     -0.852890389725     -0.863536287982     -0.874311757157
+ -0.885218298268     -0.896257428378     -0.907430680798     -0.918739605302
+ -0.930185768344     -0.941770753294     -0.953496160675     -0.965363608415
+ -0.977374732111     -0.989531185302      -1.00183463976      -1.01428678578
+  -1.02688933251      -1.03964400828      -1.05255256095      -1.06561675825
+  -1.07883838822      -1.09221925956      -1.10576120208      -1.11946606714
+  -1.13333572813      -1.14737208098      -1.16157704463      -1.17595256166
+  -1.19050059880      -1.20522314759      -1.22012222501      -1.23519987418
+  -1.25045816507      -1.26589919524      -1.28152509071      -1.29733800675
+  -1.31334012880      -1.32953367343      -1.34592088931      -1.36250405832
+  -1.37928549664      -1.39626755591      -1.41345262453      -1.43084312895
+  -1.44844153506      -1.46625034968      -1.48427212211      -1.50250944579
+  -1.52096496001      -1.53964135176      -1.55854135769      -1.57766776612
+  -1.59702341923      -1.61661121535      -1.63643411135      -1.65649512521
+  -1.67679733869      -1.69734390020      -1.71813802777      -1.73918301224
+  -1.76048222056      -1.78203909938      -1.80385717869      -1.82594007583
+  -1.84829149955      -1.87091525442      -1.89381524543      -1.91699548281
+  -1.94046008719      -1.96421329496      -1.98825946397      -2.01260307950
+  -2.03724876058      -2.06220126659      -2.08746550432      -2.11304653525
+  -2.13894958335      -2.16518004320      -2.19174348854      -2.21864568133
+  -2.24589258118      -2.27349035528      -2.30144538892      -2.32976429640
+  -2.35845393260      -2.38752140503      -2.41697408655      -2.44681962865
+  -2.47706597536      -2.50772137791      -2.53879440994      -2.57029398354
+  -2.60222936597      -2.63461019713      -2.66744650782      -2.70074873880
+  -2.73452776072      -2.76879489477      -2.80356193437      -2.83884116755
+  -2.87464540037      -2.91098798121      -2.94788282590      -2.98534444390
+  -3.02338796530      -3.06202916880      -3.10128451062      -3.14117115424
+  -3.18170700113      -3.22291072225      -3.26480179043      -3.30740051348
+  -3.35072806809      -3.39480653433      -3.43965893074      -3.48530924992
+  -3.53178249445      -3.57910471313      -3.62730303719      -3.67640571652
+  -3.72644215559      -3.77744294883      -3.82943991536      -3.88246613255
+  -3.93655596833      -3.99174511172      -4.04807060131      -4.10557085114
+  -4.16428567352      -4.22425629831      -4.28552538796      -4.34813704769
+  -4.41213683009      -4.47757173337      -4.54449019223      -4.61294206065
+  -4.68297858528      -4.75465236854      -4.82801732004      -4.90312859508
+  -4.98004251873      -5.05881649405      -5.13950889274      -5.22217892643
+  -5.30688649680      -5.39369202248      -5.48265624070      -5.57383998134
+  -5.66730391115      -5.76310824569      -5.86131242639      -5.96197476025
+  -6.06515201932      -6.17089899740      -6.27926802116      -6.39030841295
+  -6.50406590253      -6.62058198533      -6.73989322455      -6.86203049509
+  -6.98701816709      -7.11487322769      -7.24560433970      -7.37921083664
+  -7.51568165403      -7.65499419812      -7.79711315340      -7.94198923218
+  -8.08955787024      -8.23973787416      -8.39243002780      -8.54751566713
+  -8.70485523471      -8.86428682761      -9.02562475529      -9.18865812644
+  -9.35314948742      -9.51883353807      -9.68541595405      -9.85257234936
+  -10.0199474159      -10.1871542814      -10.3537741320      -10.5193561475
+  -10.6834178055      -10.8454456089      -11.0048963010      -11.1611986293
+  -11.3137557261      -11.4619481716      -11.6051378080      -11.7426723696
+  -11.8738909916      -11.9981306552      -12.1147336171      -12.2230558628
+  -12.3224766073      -12.4124088496      -12.4923109642      -12.5616992881
+  -12.6201616241      -12.6673715480      -12.7031033570      -12.7272474441
+  -12.7398258192      -12.7410074226      -12.7311227892      -12.7106775188
+  -12.6803638820      -12.6410697488      -12.5938838468      -12.5400961475
+  -12.4811919163      -12.4188376534      -12.3548567654      -12.2911923440
+  -12.2298538615      -12.1728439116      -12.1220603046      -12.0791678588
+  -12.0454330966      -12.0215137394      -12.0071934010      -12.0010501896
+  -12.0000428749      -12.0000340386      -12.0000269757      -12.0000213201
+  -12.0000168039      -12.0000132077      -12.0000103523      -12.0000080915
+  -12.0000063067      -12.0000049017      -12.0000037991      -12.0000029363
+  -12.0000022632      -12.0000017396      -12.0000013335      -12.0000010196
+  -12.0000007776      -12.0000005916      -12.0000004491      -12.0000003402
+  -12.0000002572      -12.0000001942      -12.0000001464      -12.0000001103
+  -12.0000000831      -12.0000000626      -12.0000000472      -12.0000000357
+  -12.0000000270      -12.0000000205      -12.0000000157      -12.0000000120
+  -12.0000000093      -12.0000000073      -12.0000000057      -12.0000000045
+  -12.0000000036      -12.0000000029      -12.0000000024      -12.0000000019
+  -12.0000000016      -12.0000000013      -12.0000000011      -12.0000000009
+  -12.0000000008      -12.0000000007      -12.0000000006      -12.0000000005
+  -12.0000000004      -12.0000000003      -12.0000000003      -12.0000000003
+  -12.0000000002      -12.0000000002      -12.0000000002      -12.0000000001
+  -12.0000000001      -12.0000000001      -12.0000000001      -12.0000000001
+  -12.0000000001      -12.0000000000      -12.0000000000      -12.0000000000
+  -12.0000000000      -12.0000000000      -12.0000000000      -12.0000000000
+  -12.0000000000
+  1
+ -0.144057762305E-03 -0.289927548186E-03 -0.437632150086E-03 -0.587194647143E-03
+ -0.738638408794E-03 -0.891987098425E-03 -0.104726467707E-02 -0.120449540716E-02
+ -0.136370385631E-02 -0.152491490114E-02 -0.168815373121E-02 -0.185344585289E-02
+ -0.202081709340E-02 -0.219029360484E-02 -0.236190186822E-02 -0.253566869767E-02
+ -0.271162124461E-02 -0.288978700195E-02 -0.307019380844E-02 -0.325286985299E-02
+ -0.343784367907E-02 -0.362514418922E-02 -0.381480064947E-02 -0.400684269403E-02
+ -0.420130032982E-02 -0.439820394122E-02 -0.459758429479E-02 -0.479947254408E-02
+ -0.500390023450E-02 -0.521089930828E-02 -0.542050210939E-02 -0.563274138867E-02
+ -0.584765030889E-02 -0.606526244997E-02 -0.628561181420E-02 -0.650873283158E-02
+ -0.673466036516E-02 -0.696342971654E-02 -0.719507663133E-02 -0.742963730479E-02
+ -0.766714838743E-02 -0.790764699079E-02 -0.815117069318E-02 -0.839775754563E-02
+ -0.864744607776E-02 -0.890027530382E-02 -0.915628472883E-02 -0.941551435470E-02
+ -0.967800468649E-02 -0.994379673877E-02 -0.102129320420E-01 -0.104854526490E-01
+ -0.107614011415E-01 -0.110408206371E-01 -0.113237547954E-01 -0.116102478253E-01
+ -0.119003444919E-01 -0.121940901231E-01 -0.124915306173E-01 -0.127927124500E-01
+ -0.130976826813E-01 -0.134064889632E-01 -0.137191795472E-01 -0.140358032917E-01
+ -0.143564096696E-01 -0.146810487761E-01 -0.150097713366E-01 -0.153426287143E-01
+ -0.156796729188E-01 -0.160209566137E-01 -0.163665331249E-01 -0.167164564494E-01
+ -0.170707812630E-01 -0.174295629296E-01 -0.177928575091E-01 -0.181607217668E-01
+ -0.185332131820E-01 -0.189103899568E-01 -0.192923110257E-01 -0.196790360641E-01
+ -0.200706254984E-01 -0.204671405148E-01 -0.208686430692E-01 -0.212751958968E-01
+ -0.216868625218E-01 -0.221037072677E-01 -0.225257952667E-01 -0.229531924705E-01
+ -0.233859656603E-01 -0.238241824574E-01 -0.242679113333E-01 -0.247172216211E-01
+ -0.251721835258E-01 -0.256328681356E-01 -0.260993474328E-01 -0.265716943049E-01
+ -0.270499825566E-01 -0.275342869206E-01 -0.280246830696E-01 -0.285212476283E-01
+ -0.290240581852E-01 -0.295331933045E-01 -0.300487325387E-01 -0.305707564411E-01
+ -0.310993465779E-01 -0.316345855414E-01 -0.321765569628E-01 -0.327253455251E-01
+ -0.332810369766E-01 -0.338437181440E-01 -0.344134769461E-01 -0.349904024077E-01
+ -0.355745846732E-01 -0.361661150208E-01 -0.367650858771E-01 -0.373715908309E-01
+ -0.379857246484E-01 -0.386075832874E-01 -0.392372639131E-01 -0.398748649126E-01
+ -0.405204859105E-01 -0.411742277845E-01 -0.418361926812E-01 -0.425064840318E-01
+ -0.431852065686E-01 -0.438724663411E-01 -0.445683707329E-01 -0.452730284778E-01
+ -0.459865496778E-01 -0.467090458192E-01 -0.474406297909E-01 -0.481814159015E-01
+ -0.489315198974E-01 -0.496910589809E-01 -0.504601518283E-01 -0.512389186086E-01
+ -0.520274810022E-01 -0.528259622202E-01 -0.536344870230E-01 -0.544531817405E-01
+ -0.552821742913E-01 -0.561215942031E-01 -0.569715726324E-01 -0.578322423858E-01
+ -0.587037379398E-01 -0.595861954624E-01 -0.604797528345E-01 -0.613845496709E-01
+ -0.623007273423E-01 -0.632284289977E-01 -0.641677995863E-01 -0.651189858807E-01
+ -0.660821364990E-01 -0.670574019289E-01 -0.680449345505E-01 -0.690448886607E-01
+ -0.700574204967E-01 -0.710826882609E-01 -0.721208521453E-01 -0.731720743566E-01
+ -0.742365191416E-01 -0.753143528129E-01 -0.764057437747E-01 -0.775108625490E-01
+ -0.786298818027E-01 -0.797629763741E-01 -0.809103233004E-01 -0.820721018454E-01
+ -0.832484935273E-01 -0.844396821472E-01 -0.856458538177E-01 -0.868671969922E-01
+ -0.881039024939E-01 -0.893561635461E-01 -0.906241758018E-01 -0.919081373750E-01
+ -0.932082488707E-01 -0.945247134170E-01 -0.958577366965E-01 -0.972075269785E-01
+ -0.985742951512E-01 -0.999582547551E-01 -0.101359622016     -0.102778615879
+ -0.104215458043     -0.105670372993     -0.107143588040     -0.108635333350
+ -0.110145841987     -0.111675349943     -0.113224096179     -0.114792322661
+ -0.116380274396     -0.117988199473     -0.119616349103     -0.121264977652
+ -0.122934342686     -0.124624705011     -0.126336328711     -0.128069481190
+ -0.129824433217     -0.131601458963     -0.133400836047     -0.135222845580
+ -0.137067772206     -0.138935904149     -0.140827533257     -0.142742955046
+ -0.144682468749     -0.146646377361     -0.148634987686     -0.150648610385
+ -0.152687560026     -0.154752155132     -0.156842718229     -0.158959575898
+ -0.161103058827     -0.163273501860     -0.165471244053     -0.167696628720
+ -0.169950003494     -0.172231720379     -0.174542135800     -0.176881610667
+ -0.179250510422     -0.181649205106     -0.184078069407     -0.186537482726
+ -0.189027829229     -0.191549497914     -0.194102882667     -0.196688382326
+ -0.199306400740     -0.201957346834     -0.204641634674     -0.207359683528
+ -0.210111917933     -0.212898767764     -0.215720668295     -0.218578060271
+ -0.221471389977     -0.224401109305     -0.227367675823     -0.230371552853
+ -0.233413209535     -0.236493120905     -0.239611767968     -0.242769637772
+ -0.245967223483     -0.249205024464     -0.252483546351     -0.255803301132
+ -0.259164807227     -0.262568589568     -0.266015179680     -0.269505115765
+ -0.273038942786     -0.276617212548     -0.280240483790     -0.283909322264
+ -0.287624300830     -0.291385999540     -0.295195005733     -0.299051914118
+ -0.302957326876     -0.306911853746     -0.310916112125     -0.314970727157
+ -0.319076331838     -0.323233567107     -0.327443081952     -0.331705533504
+ -0.336021587143     -0.340391916600     -0.344817204061     -0.349298140273
+ -0.353835424650     -0.358429765384     -0.363081879550     -0.367792493221
+ -0.372562341579     -0.377392169028     -0.382282729308     -0.387234785616
+ -0.392249110718     -0.397326487073     -0.402467706949     -0.407673572553
+ -0.412944896145     -0.418282500170     -0.423687217385     -0.429159890982
+ -0.434701374723     -0.440312533070     -0.445994241316     -0.451747385724
+ -0.457572863658     -0.463471583726     -0.469444465917     -0.475492441741
+ -0.481616454377     -0.487817458811     -0.494096421990     -0.500454322962
+ -0.506892153036     -0.513410915923     -0.520011627899     -0.526695317954
+ -0.533463027954     -0.540315812799     -0.547254740580     -0.554280892749
+ -0.561395364280     -0.568599263837     -0.575893713942     -0.583279851148
+ -0.590758826209     -0.598331804260     -0.605999964988     -0.613764502817
+ -0.621626627085     -0.629587562230     -0.637648547976     -0.645810839517
+ -0.654075707713     -0.662444439277     -0.670918336971     -0.679498719804
+ -0.688186923231     -0.696984299352     -0.705892217118     -0.714912062534
+ -0.724045238872     -0.733293166878     -0.742657284985     -0.752139049531
+ -0.761739934975     -0.771461434118     -0.781305058327     -0.791272337758
+ -0.801364821586     -0.811584078235     -0.821931695612     -0.832409281339
+ -0.843018462997     -0.853760888362     -0.864638225651     -0.875652163768
+ -0.886804412553     -0.898096703031     -0.909530787672     -0.921108440641
+ -0.932831458065     -0.944701658289     -0.956720882147     -0.968890993224
+ -0.981213878135     -0.993691446792      -1.00632563268      -1.01911839315
+  -1.03207170968      -1.04518758818      -1.05846805925      -1.07191517853
+  -1.08553102693      -1.09931771096      -1.11327736301      -1.12741214169
+  -1.14172423210      -1.15621584615      -1.17088922287      -1.18574662872
+  -1.20079035794      -1.21602273280      -1.23144610402      -1.24706285100
+  -1.26287538221      -1.27888613550      -1.29509757845      -1.31151220869
+  -1.32813255423      -1.34496117386      -1.36200065742      -1.37925362620
+  -1.39672273329      -1.41441066390      -1.43232013577      -1.45045389946
+  -1.46881473878      -1.48740547112      -1.50622894783      -1.52528805458
+  -1.54458571173      -1.56412487472      -1.58390853444      -1.60393971760
+  -1.62422148713      -1.64475694254      -1.66554922033      -1.68660149436
+  -1.70791697623      -1.72949891571      -1.75135060109      -1.77347535958
+  -1.79587655774      -1.81855760181      -1.84152193819      -1.86477305376
+  -1.88831447631      -1.91214977495      -1.93628256049      -1.96071648584
+  -1.98545524640      -2.01050258050      -2.03586226972      -2.06153813934
+  -2.08753405874      -2.11385394175      -2.14050174705      -2.16748147859
+  -2.19479718592      -2.22245296463      -2.25045295667      -2.27880135074
+  -2.30750238268      -2.33656033579      -2.36597954123      -2.39576437832
+  -2.42591927492      -2.45644870772      -2.48735720262      -2.51864933499
+  -2.55032973000      -2.58240306290      -2.61487405931      -2.64774749548
+  -2.68102819852      -2.71472104667      -2.74883096948      -2.78336294804
+  -2.81832201513      -2.85371325541      -2.88954180550      -2.92581285414
+  -2.96253164225      -2.99970346298      -3.03733366173      -3.07542763615
+  -3.11399083607      -3.15302876345      -3.19254697222      -3.23255106812
+  -3.27304670848      -3.31403960199      -3.35553550832      -3.39754023778
+  -3.44005965088      -3.48309965783      -3.52666621797      -3.57076533909
+  -3.61540307676      -3.66058553350      -3.70631885788      -3.75260924351
+  -3.79946292799      -3.84688619168      -3.89488535639      -3.94346678394
+  -3.99263687461      -4.04240206539      -4.09276882820      -4.14374366781
+  -4.19533311968      -4.24754374767      -4.30038214140      -4.35385491363
+  -4.40796869719      -4.46273014192      -4.51814591120      -4.57422267829
+  -4.63096712243      -4.68838592464      -4.74648576317      -4.80527330870
+  -4.86475521920      -4.92493813438      -4.98582866983      -5.04743341070
+  -5.10975890503      -5.17281165657      -5.23659811717      -5.30112467867
+  -5.36639766423      -5.43242331920      -5.49920780128      -5.56675717016
+  -5.63507737651      -5.70417425023      -5.77405348800      -5.84472064015
+  -5.91618109660      -5.98844007210      -6.06150259047      -6.13537346802
+  -6.21005729593      -6.28555842162      -6.36188092908      -6.43902861809
+  -6.51700498220      -6.59581318555      -6.67545603837      -6.75593597117
+  -6.83725500747      -6.91941473516      -7.00241627619      -7.08626025485
+  -7.17094676424      -7.25647533108      -7.34284487876      -7.43005368846
+  -7.51809935842      -7.60697876116      -7.69668799867      -7.78722235547
+  -7.87857624943      -7.97074318043      -8.06371567656      -8.15748523808
+  -8.25204227881      -8.34737606515      -8.44347465243      -8.54032481882
+  -8.63791199645      -8.73622020005      -8.83523195280      -8.93492820957
+  -9.03528827743      -9.13628973352      -9.23790834033      -9.34011795829
+  -9.44289045592      -9.54619561747      -9.65000104829      -9.75427207792
+  -9.85897166113      -9.96406027716      -10.0694958272      -10.1752335305
+  -10.2812258196      -10.3874222341      -10.4937693150      -10.6002104983
+  -10.7066860093      -10.8131327583      -10.9194842371      -11.0256704187
+  -11.1316176596      -11.2372486054      -11.3424821021      -11.4472331123
+  -11.5514126382      -11.6549276522      -11.7576810370      -11.8595715357
+  -11.9604937132      -12.0603379319      -12.1589903407      -12.2563328820
+  -12.3522433160      -12.4465952660      -12.5392582853      -12.6300979490
+  -12.7189759721      -12.8057503571      -12.8902755716      -12.9724027616
+  -13.0519799990      -13.1288525695      -13.2028633014      -13.2738529381
+  -13.3416605577      -13.4061240418      -13.4670805962      -13.5243673245
+  -13.5778218602      -13.6272830552      -13.6725917301      -13.7135914857
+  -13.7501295783      -13.7820578588      -13.8092337767      -13.8315214493
+  -13.8487927938      -13.8609287241      -13.8678204074      -13.8693705799
+  -13.8654949174      -13.8561234564      -13.8412020603      -13.8206939244
+  -13.7945811122      -13.7628661128      -13.7255734118      -13.6827510618
+  -13.6344722405      -13.5808367829      -13.5219726699      -13.4580374572
+  -13.3892196252      -13.3157398283      -13.2378520221      -13.1558444434
+  -13.0700404164      -12.9807989581      -12.8885151516      -12.7936202538
+  -12.6965815048      -12.5979015988      -12.4981177774      -12.3978005006
+  -12.2975516496      -12.1980022086      -12.0998093716      -12.0036530147
+  -11.9102314696      -11.8202565302      -11.7344476190      -11.6535250379
+  -11.5782022255      -11.5091769409      -11.4471213003      -11.3926705974
+  -11.3464108537      -11.3088650658      -11.2804781507      -11.2616006359
+  -11.2524712079      -11.2531983166      -11.2637411520      -11.2838904519
+  -11.3132497905      -11.3512182260      -11.3969754736      -11.4494711156
+  -11.5074197752      -11.5693046734      -11.6333925701      -11.6977637624
+  -11.7603616049      -11.8190669232      -11.8718037527      -11.9166840656
+  -11.9522005986      -11.9774786127      -11.9925994747      -11.9990783357
+  -12.0000399633      -12.0000317352      -12.0000251502      -12.0000198773
+  -12.0000156668      -12.0000123140      -12.0000096517      -12.0000075439
+  -12.0000058799      -12.0000045700      -12.0000035420      -12.0000027376
+  -12.0000021100      -12.0000016218      -12.0000012433      -12.0000009506
+  -12.0000007250      -12.0000005516      -12.0000004187      -12.0000003172
+  -12.0000002398      -12.0000001810      -12.0000001365      -12.0000001029
+  -12.0000000775      -12.0000000584      -12.0000000440      -12.0000000333
+  -12.0000000252      -12.0000000192      -12.0000000146      -12.0000000112
+  -12.0000000087      -12.0000000068      -12.0000000053      -12.0000000042
+  -12.0000000034      -12.0000000027      -12.0000000022      -12.0000000018
+  -12.0000000015      -12.0000000012      -12.0000000010      -12.0000000009
+  -12.0000000007      -12.0000000006      -12.0000000005      -12.0000000004
+  -12.0000000004      -12.0000000003      -12.0000000003      -12.0000000002
+  -12.0000000002      -12.0000000002      -12.0000000001      -12.0000000001
+  -12.0000000000
+  2
+ -0.109804095643E-03 -0.220989356775E-03 -0.333573156314E-03 -0.447573085698E-03
+ -0.563006957642E-03 -0.679892808913E-03 -0.798248903156E-03 -0.918093733740E-03
+ -0.103944602665E-02 -0.116232474343E-02 -0.128674908410E-02 -0.141273849022E-02
+ -0.154031264787E-02 -0.166949149075E-02 -0.180029520332E-02 -0.193274422390E-02
+ -0.206685924789E-02 -0.220266123104E-02 -0.234017139266E-02 -0.247941121896E-02
+ -0.262040246644E-02 -0.276316716524E-02 -0.290772762261E-02 -0.305410642639E-02
+ -0.320232644855E-02 -0.335241084873E-02 -0.350438307790E-02 -0.365826688199E-02
+ -0.381408630564E-02 -0.397186569591E-02 -0.413162970611E-02 -0.429340329966E-02
+ -0.445721175397E-02 -0.462308066440E-02 -0.479103594827E-02 -0.496110384888E-02
+ -0.513331093964E-02 -0.530768412821E-02 -0.548425066069E-02 -0.566303812592E-02
+ -0.584407445973E-02 -0.602738794937E-02 -0.621300723787E-02 -0.640096132856E-02
+ -0.659127958957E-02 -0.678399175844E-02 -0.697912794677E-02 -0.717671864489E-02
+ -0.737679472668E-02 -0.757938745433E-02 -0.778452848327E-02 -0.799224986712E-02
+ -0.820258406265E-02 -0.841556393491E-02 -0.863122276231E-02 -0.884959424188E-02
+ -0.907071249447E-02 -0.929461207013E-02 -0.952132795348E-02 -0.975089556922E-02
+ -0.998335078759E-02 -0.102187299300E-01 -0.104570697749E-01 -0.106984075630E-01
+ -0.109427810038E-01 -0.111902282809E-01 -0.114407880582E-01 -0.116944994861E-01
+ -0.119514022072E-01 -0.122115363630E-01 -0.124749425995E-01 -0.127416620745E-01
+ -0.130117364631E-01 -0.132852079646E-01 -0.135621193093E-01 -0.138425137650E-01
+ -0.141264351434E-01 -0.144139278076E-01 -0.147050366785E-01 -0.149998072423E-01
+ -0.152982855569E-01 -0.156005182599E-01 -0.159065525755E-01 -0.162164363216E-01
+ -0.165302179178E-01 -0.168479463927E-01 -0.171696713916E-01 -0.174954431841E-01
+ -0.178253126724E-01 -0.181593313986E-01 -0.184975515533E-01 -0.188400259836E-01
+ -0.191868082012E-01 -0.195379523908E-01 -0.198935134190E-01 -0.202535468421E-01
+ -0.206181089154E-01 -0.209872566018E-01 -0.213610475806E-01 -0.217395402566E-01
+ -0.221227937692E-01 -0.225108680018E-01 -0.229038235909E-01 -0.233017219356E-01
+ -0.237046252075E-01 -0.241125963599E-01 -0.245256991383E-01 -0.249439980896E-01
+ -0.253675585727E-01 -0.257964467688E-01 -0.262307296913E-01 -0.266704751964E-01
+ -0.271157519939E-01 -0.275666296580E-01 -0.280231786378E-01 -0.284854702683E-01
+ -0.289535767822E-01 -0.294275713204E-01 -0.299075279438E-01 -0.303935216449E-01
+ -0.308856283593E-01 -0.313839249778E-01 -0.318884893584E-01 -0.323994003382E-01
+ -0.329167377459E-01 -0.334405824143E-01 -0.339710161929E-01 -0.345081219607E-01
+ -0.350519836391E-01 -0.356026862048E-01 -0.361603157037E-01 -0.367249592635E-01
+ -0.372967051082E-01 -0.378756425710E-01 -0.384618621091E-01 -0.390554553169E-01
+ -0.396565149414E-01 -0.402651348956E-01 -0.408814102740E-01 -0.415054373670E-01
+ -0.421373136761E-01 -0.427771379290E-01 -0.434250100952E-01 -0.440810314015E-01
+ -0.447453043479E-01 -0.454179327235E-01 -0.460990216228E-01 -0.467886774619E-01
+ -0.474870079955E-01 -0.481941223334E-01 -0.489101309577E-01 -0.496351457400E-01
+ -0.503692799590E-01 -0.511126483178E-01 -0.518653669624E-01 -0.526275534992E-01
+ -0.533993270140E-01 -0.541808080901E-01 -0.549721188273E-01 -0.557733828612E-01
+ -0.565847253820E-01 -0.574062731545E-01 -0.582381545377E-01 -0.590804995049E-01
+ -0.599334396639E-01 -0.607971082775E-01 -0.616716402848E-01 -0.625571723216E-01
+ -0.634538427419E-01 -0.643617916399E-01 -0.652811608715E-01 -0.662120940765E-01
+ -0.671547367011E-01 -0.681092360205E-01 -0.690757411621E-01 -0.700544031284E-01
+ -0.710453748210E-01 -0.720488110643E-01 -0.730648686295E-01 -0.740937062593E-01
+ -0.751354846925E-01 -0.761903666894E-01 -0.772585170567E-01 -0.783401026736E-01
+ -0.794352925178E-01 -0.805442576918E-01 -0.816671714496E-01 -0.828042092237E-01
+ -0.839555486525E-01 -0.851213696082E-01 -0.863018542247E-01 -0.874971869257E-01
+ -0.887075544543E-01 -0.899331459012E-01 -0.911741527349E-01 -0.924307688313E-01
+ -0.937031905037E-01 -0.949916165339E-01 -0.962962482029E-01 -0.976172893225E-01
+ -0.989549462668E-01 -0.100309428004     -0.101680946132     -0.103069714905
+ -0.104475951274     -0.105899874915     -0.107341708269     -0.108801676571
+ -0.110280007888     -0.111776933153     -0.113292686205     -0.114827503819
+ -0.116381625750     -0.117955294763     -0.119548756678     -0.121162260404
+ -0.122796057976     -0.124450404602     -0.126125558693     -0.127821781911
+ -0.129539339205     -0.131278498856     -0.133039532516     -0.134822715249
+ -0.136628325580     -0.138456645532     -0.140307960671     -0.142182560154
+ -0.144080736772     -0.146002786993     -0.147949011012     -0.149919712797
+ -0.151915200134     -0.153935784676     -0.155981781994     -0.158053511622
+ -0.160151297110     -0.162275466071     -0.164426350237     -0.166604285504
+ -0.168809611991     -0.171042674088     -0.173303820512     -0.175593404357
+ -0.177911783158     -0.180259318936     -0.182636378261     -0.185043332306
+ -0.187480556907     -0.189948432619     -0.192447344776     -0.194977683551
+ -0.197539844016     -0.200134226205     -0.202761235173     -0.205421281061
+ -0.208114779161     -0.210842149977     -0.213603819291     -0.216400218232
+ -0.219231783339     -0.222098956630     -0.225002185672     -0.227941923649
+ -0.230918629432     -0.233932767648     -0.236984808757     -0.240075229121
+ -0.243204511079     -0.246373143020     -0.249581619461     -0.252830441121
+ -0.256120115000     -0.259451154459     -0.262824079292     -0.266239415818
+ -0.269697696949     -0.273199462284     -0.276745258184     -0.280335637861
+ -0.283971161460     -0.287652396149     -0.291379916203     -0.295154303093
+ -0.298976145578     -0.302846039792     -0.306764589338     -0.310732405382
+ -0.314750106742     -0.318818319990     -0.322937679540     -0.327108827755
+ -0.331332415036     -0.335609099929     -0.339939549220     -0.344324438045
+ -0.348764449983     -0.353260277171     -0.357812620402     -0.362422189237
+ -0.367089702110     -0.371815886441     -0.376601478744     -0.381447224742
+ -0.386353879479     -0.391322207434     -0.396352982641     -0.401446988804
+ -0.406605019415     -0.411827877879     -0.417116377631     -0.422471342264
+ -0.427893605649     -0.433384012066     -0.438943416328     -0.444572683915
+ -0.450272691099     -0.456044325079     -0.461888484119     -0.467806077674
+ -0.473798026536     -0.479865262970     -0.486008730849     -0.492229385805
+ -0.498528195363     -0.504906139093     -0.511364208754     -0.517903408441
+ -0.524524754738     -0.531229276868     -0.538018016846     -0.544892029635
+ -0.551852383303     -0.558900159183     -0.566036452029     -0.573262370182
+ -0.580579035736     -0.587987584697     -0.595489167157     -0.603084947461
+ -0.610776104377     -0.618563831272     -0.626449336286     -0.634433842509
+ -0.642518588159     -0.650704826762     -0.658993827340     -0.667386874589
+ -0.675885269070     -0.684490327395     -0.693203382420     -0.702025783436
+ -0.710958896364     -0.720004103952     -0.729162805971     -0.738436419422
+ -0.747826378730     -0.757334135956     -0.766961161000     -0.776708941812
+ -0.786578984600     -0.796572814047     -0.806691973521     -0.816938025300
+ -0.827312550781     -0.837817150711     -0.848453445403     -0.859223074969
+ -0.870127699541     -0.881168999504     -0.892348675728     -0.903668449802
+ -0.915130064271     -0.926735282871     -0.938485890775     -0.950383694829
+ -0.962430523803     -0.974628228635     -0.986978682680     -0.999483781959
+  -1.01214544542      -1.02496561517      -1.03794625679      -1.05108935950
+  -1.06439693652      -1.07787102526      -1.09151368764      -1.10532701030
+  -1.11931310493      -1.13347410848      -1.14781218351      -1.16232951838
+  -1.17702832759      -1.19191085202      -1.20697935927      -1.22223614384
+  -1.23768352753      -1.25332385965      -1.26915951732      -1.28519290579
+  -1.30142645871      -1.31786263841      -1.33450393623      -1.35135287277
+  -1.36841199823      -1.38568389271      -1.40317116644      -1.42087646019
+  -1.43880244547      -1.45695182491      -1.47532733253      -1.49393173404
+  -1.51276782715      -1.53183844190      -1.55114644096      -1.57069471989
+  -1.59048620753      -1.61052386625      -1.63081069227      -1.65134971599
+  -1.67214400228      -1.69319665080      -1.71451079629      -1.73608960890
+  -1.75793629450      -1.78005409494      -1.80244628842      -1.82511618975
+  -1.84806715067      -1.87130256014      -1.89482584463      -1.91864046846
+  -1.94274993402      -1.96715778212      -1.99186759226      -2.01688298287
+  -2.04220761167      -2.06784517585      -2.09379941243      -2.12007409843
+  -2.14667305119      -2.17360012861      -2.20085922935      -2.22845429314
+  -2.25638930090      -2.28466827507      -2.31329527971      -2.34227442079
+  -2.37160984629      -2.40130574642      -2.43136635376      -2.46179594340
+  -2.49259883306      -2.52377938321      -2.55534199715      -2.58729112108
+  -2.61963124415      -2.65236689847      -2.68550265914      -2.71904314420
+  -2.75299301456      -2.78735697396      -2.82213976880      -2.85734618803
+  -2.89298106294      -2.92904926690      -2.96555571517      -3.00250536447
+  -3.03990321272      -3.07775429852      -3.11606370076      -3.15483653804
+  -3.19407796806      -3.23379318700      -3.27398742874      -3.31466596405
+  -3.35583409973      -3.39749717757      -3.43966057331      -3.48232969545
+  -3.52550998398      -3.56920690898      -3.61342596909      -3.65817268990
+  -3.70345262216      -3.74927133985      -3.79563443816      -3.84254753119
+  -3.89001624962      -3.93804623807      -3.98664315236      -4.03581265653
+  -4.08556041962      -4.13589211228      -4.18681340308      -4.23832995460
+  -4.29044741923      -4.34317143470      -4.39650761926      -4.45046156664
+  -4.50503884053      -4.56024496884      -4.61608543746      -4.67256568374
+  -4.72969108945      -4.78746697334      -4.84589858326      -4.90499108771
+  -4.96474956694      -5.02517900350      -5.08628427217      -5.14807012935
+  -5.21054120174      -5.27370197446      -5.33755677836      -5.40210977666
+  -5.46736495086      -5.53332608573      -5.59999675362      -5.66738029770
+  -5.73547981449      -5.80429813525      -5.87383780649      -5.94410106937
+  -6.01508983805      -6.08680567690      -6.15924977650      -6.23242292850
+  -6.30632549913      -6.38095740141      -6.45631806608      -6.53240641103
+  -6.60922080929      -6.68675905563      -6.76501833146      -6.84399516829
+  -6.92368540949      -7.00408417041      -7.08518579683      -7.16698382164
+  -7.24947091977      -7.33263886141      -7.41647846331      -7.50097953837
+  -7.58613084335      -7.67192002477      -7.75833356304      -7.84535671471
+  -7.93297345307      -8.02116640689      -8.10991679762      -8.19920437491
+  -8.28900735061      -8.37930233140      -8.47006425006      -8.56126629564
+  -8.65287984262      -8.74487437920      -8.83721743514      -8.92987450911
+  -9.02280899605      -9.11598211476      -9.20935283604      -9.30287781185
+  -9.39651130580      -9.49020512555      -9.58390855756      -9.67756830477
+  -9.77112842783      -9.86453029058      -9.95771251047      -10.0506109147
+  -10.1431585028      -10.2352854172      -10.3269189215      -10.4179833889
+  -10.5084003014      -10.5980882595      -10.6869630071      -10.7749374688
+  -10.8619218045      -10.9478234800      -11.0325473578      -11.1159958070
+  -11.1980688362      -11.2786642496      -11.3576778290      -11.4350035431
+  -11.5105337857      -11.5841596453      -11.6557712072      -11.7252578904
+  -11.7925088213      -11.8574132449      -11.9198609770      -11.9797428963
+  -12.0369514810      -12.0913813883      -12.1429300796      -12.1914984913
+  -12.2369917520      -12.2793199463      -12.3183989246      -12.3541511575
+  -12.3865066351      -12.4154038073      -12.4407905632      -12.4626252459
+  -12.4808776976      -12.4955303306      -12.5065792153      -12.5140351787
+  -12.5179249029      -12.5182920123      -12.5151981361      -12.5087239313
+  -12.4989700471      -12.4860580136      -12.4701310283      -12.4513546176
+  -12.4299171435      -12.4060301229      -12.3799283242      -12.3518696020
+  -12.3221344258      -12.2910250566      -12.2588643205      -12.2259939243
+  -12.1927722581      -12.1595716242      -12.1267748344      -12.0947711156
+  -12.0639512706      -12.0347020430      -12.0073996514      -11.9824024693
+  -11.9600428522      -11.9406181470      -11.9243809566      -11.9115287931
+  -11.9021933215      -11.8964294896      -11.8942049538      -11.8953903548
+  -11.8997511767      -11.9069421387      -11.9165053353      -11.9278736670
+  -11.9403814869      -11.9532848616      -11.9657944055      -11.9771243203
+  -11.9865620795      -11.9935641627      -11.9978844060      -11.9997603153
+  -12.0000392409      -12.0000317352      -12.0000251502      -12.0000198773
+  -12.0000000000
+  3
+ -0.997906871302E-04 -0.200836586576E-03 -0.303153486958E-03 -0.406757375493E-03
+ -0.511664440491E-03 -0.617891073886E-03 -0.725453873797E-03 -0.834369647119E-03
+ -0.944655412154E-03 -0.105632840127E-02 -0.116940606357E-02 -0.128390606768E-02
+ -0.139984630443E-02 -0.151724488971E-02 -0.163612016727E-02 -0.175649071160E-02
+ -0.187837533082E-02 -0.200179306964E-02 -0.212676321231E-02 -0.225330528564E-02
+ -0.238143906208E-02 -0.251118456277E-02 -0.264256206067E-02 -0.277559208377E-02
+ -0.291029541825E-02 -0.304669311176E-02 -0.318480647667E-02 -0.332465709346E-02
+ -0.346626681404E-02 -0.360965776517E-02 -0.375485235196E-02 -0.390187326130E-02
+ -0.405074346549E-02 -0.420148622574E-02 -0.435412509588E-02 -0.450868392599E-02
+ -0.466518686616E-02 -0.482365837024E-02 -0.498412319967E-02 -0.514660642736E-02
+ -0.531113344157E-02 -0.547772994992E-02 -0.564642198340E-02 -0.581723590040E-02
+ -0.599019839089E-02 -0.616533648052E-02 -0.634267753490E-02 -0.652224926385E-02
+ -0.670407972573E-02 -0.688819733182E-02 -0.707463085080E-02 -0.726340941316E-02
+ -0.745456251585E-02 -0.764812002681E-02 -0.784411218970E-02 -0.804256962856E-02
+ -0.824352335264E-02 -0.844700476125E-02 -0.865304564864E-02 -0.886167820896E-02
+ -0.907293504134E-02 -0.928684915493E-02 -0.950345397409E-02 -0.972278334357E-02
+ -0.994487153388E-02 -0.101697532466E-01 -0.103974636196E-01 -0.106280382331E-01
+ -0.108615131145E-01 -0.110979247446E-01 -0.113373100629E-01 -0.115797064736E-01
+ -0.118251518514E-01 -0.120736845474E-01 -0.123253433951E-01 -0.125801677163E-01
+ -0.128381973276E-01 -0.130994725463E-01 -0.133640341969E-01 -0.136319236174E-01
+ -0.139031826657E-01 -0.141778537261E-01 -0.144559797162E-01 -0.147376040934E-01
+ -0.150227708615E-01 -0.153115245782E-01 -0.156039103612E-01 -0.158999738960E-01
+ -0.161997614427E-01 -0.165033198430E-01 -0.168106965281E-01 -0.171219395256E-01
+ -0.174370974674E-01 -0.177562195969E-01 -0.180793557770E-01 -0.184065564976E-01
+ -0.187378728838E-01 -0.190733567039E-01 -0.194130603770E-01 -0.197570369819E-01
+ -0.201053402647E-01 -0.204580246476E-01 -0.208151452375E-01 -0.211767578343E-01
+ -0.215429189397E-01 -0.219136857661E-01 -0.222891162455E-01 -0.226692690388E-01
+ -0.230542035443E-01 -0.234439799078E-01 -0.238386590313E-01 -0.242383025830E-01
+ -0.246429730067E-01 -0.250527335316E-01 -0.254676481822E-01 -0.258877817883E-01
+ -0.263131999950E-01 -0.267439692732E-01 -0.271801569298E-01 -0.276218311182E-01
+ -0.280690608492E-01 -0.285219160013E-01 -0.289804673321E-01 -0.294447864893E-01
+ -0.299149460213E-01 -0.303910193895E-01 -0.308730809789E-01 -0.313612061102E-01
+ -0.318554710515E-01 -0.323559530301E-01 -0.328627302445E-01 -0.333758818770E-01
+ -0.338954881055E-01 -0.344216301166E-01 -0.349543901178E-01 -0.354938513507E-01
+ -0.360400981038E-01 -0.365932157256E-01 -0.371532906382E-01 -0.377204103505E-01
+ -0.382946634721E-01 -0.388761397271E-01 -0.394649299680E-01 -0.400611261899E-01
+ -0.406648215449E-01 -0.412761103568E-01 -0.418950881356E-01 -0.425218515926E-01
+ -0.431564986553E-01 -0.437991284828E-01 -0.444498414815E-01 -0.451087393203E-01
+ -0.457759249470E-01 -0.464515026039E-01 -0.471355778445E-01 -0.478282575496E-01
+ -0.485296499444E-01 -0.492398646150E-01 -0.499590125257E-01 -0.506872060364E-01
+ -0.514245589201E-01 -0.521711863803E-01 -0.529272050698E-01 -0.536927331080E-01
+ -0.544678901000E-01 -0.552527971549E-01 -0.560475769050E-01 -0.568523535246E-01
+ -0.576672527498E-01 -0.584924018976E-01 -0.593279298863E-01 -0.601739672555E-01
+ -0.610306461861E-01 -0.618981005213E-01 -0.627764657876E-01 -0.636658792156E-01
+ -0.645664797614E-01 -0.654784081288E-01 -0.664018067908E-01 -0.673368200118E-01
+ -0.682835938705E-01 -0.692422762824E-01 -0.702130170230E-01 -0.711959677509E-01
+ -0.721912820320E-01 -0.731991153629E-01 -0.742196251957E-01 -0.752529709620E-01
+ -0.762993140981E-01 -0.773588180704E-01 -0.784316484004E-01 -0.795179726909E-01
+ -0.806179606519E-01 -0.817317841272E-01 -0.828596171213E-01 -0.840016358264E-01
+ -0.851580186499E-01 -0.863289462423E-01 -0.875146015251E-01 -0.887151697198E-01
+ -0.899308383763E-01 -0.911617974027E-01 -0.924082390942E-01 -0.936703581636E-01
+ -0.949483517717E-01 -0.962424195576E-01 -0.975527636701E-01 -0.988795887995E-01
+ -0.100223102209     -0.101583513767     -0.102961035980     -0.104355884026
+ -0.105768275787     -0.107198431886     -0.108646575716     -0.110112933481
+ -0.111597734224     -0.113101209871     -0.114623595260     -0.116165128183
+ -0.117726049418     -0.119306602771     -0.120907035111     -0.122527596409
+ -0.124168539779     -0.125830121514     -0.127512601129     -0.129216241399
+ -0.130941308402     -0.132688071557     -0.134456803671     -0.136247780978
+ -0.138061283181     -0.139897593500     -0.141756998710     -0.143639789190
+ -0.145546258969     -0.147476705767     -0.149431431045     -0.151410740051
+ -0.153414941866     -0.155444349455     -0.157499279713     -0.159580053514
+ -0.161686995764     -0.163820435447     -0.165980705682     -0.168168143767
+ -0.170383091238     -0.172625893919     -0.174896901976     -0.177196469973
+ -0.179524956922     -0.181882726345     -0.184270146327     -0.186687589573
+ -0.189135433467     -0.191614060129     -0.194123856476     -0.196665214281
+ -0.199238530231     -0.201844205994     -0.204482648278     -0.207154268891
+ -0.209859484813     -0.212598718249     -0.215372396707     -0.218180953052
+ -0.221024825582     -0.223904458092     -0.226820299941     -0.229772806125
+ -0.232762437344     -0.235789660076     -0.238854946647     -0.241958775302
+ -0.245101630285     -0.248284001906     -0.251506386623     -0.254769287113
+ -0.258073212355     -0.261418677703     -0.264806204968     -0.268236322498
+ -0.271709565259     -0.275226474918     -0.278787599924     -0.282393495596
+ -0.286044724202     -0.289741855053     -0.293485464582     -0.297276136442
+ -0.301114461585     -0.305001038361     -0.308936472603     -0.312921377724
+ -0.316956374811     -0.321042092715     -0.325179168154     -0.329368245801
+ -0.333609978394     -0.337905026824     -0.342254060243     -0.346657756163
+ -0.351116800560     -0.355631887978     -0.360203721633     -0.364833013523
+ -0.369520484533     -0.374266864544     -0.379072892546     -0.383939316750
+ -0.388866894697     -0.393856393376     -0.398908589341     -0.404024268823
+ -0.409204227852     -0.414449272378     -0.419760218389     -0.425137892035
+ -0.430583129754     -0.436096778392     -0.441679695336     -0.447332748640
+ -0.453056817151     -0.458852790649     -0.464721569969     -0.470664067143
+ -0.476681205534     -0.482773919971     -0.488943156891     -0.495189874474
+ -0.501515042792     -0.507919643947     -0.514404672219     -0.520971134211
+ -0.527620048997     -0.534352448273     -0.541169376508     -0.548071891097
+ -0.555061062516     -0.562137974479     -0.569303724094     -0.576559422024
+ -0.583906192650     -0.591345174231     -0.598877519074     -0.606504393693
+ -0.614226978985     -0.622046470395     -0.629964078091     -0.637981027134
+ -0.646098557660     -0.654317925048     -0.662640400107     -0.671067269254
+ -0.679599834694     -0.688239414609     -0.696987343340     -0.705844971578
+ -0.714813666554     -0.723894812227     -0.733089809483     -0.742400076326
+ -0.751827048077     -0.761372177574     -0.771036935370     -0.780822809941
+ -0.790731307885     -0.800763954133     -0.810922292154     -0.821207884168
+ -0.831622311358     -0.842167174081     -0.852844092089     -0.863654704743
+ -0.874600671232     -0.885683670799     -0.896905402959     -0.908267587730
+ -0.919771965853     -0.931420299027     -0.943214370138     -0.955155983490
+ -0.967246965040     -0.979489162636     -0.991884446252      -1.00443470823
+  -1.01714186352      -1.03000784992      -1.04303462834      -1.05622418302
+  -1.06957852178      -1.08309967632      -1.09678970239      -1.11065068011
+  -1.12468471421      -1.13889393425      -1.15328049494      -1.16784657634
+  -1.18259438416      -1.19752615000      -1.21264413164      -1.22795061327
+  -1.24344790579      -1.25913834705      -1.27502430215      -1.29110816368
+  -1.30739235202      -1.32387931558      -1.34057153110      -1.35747150393
+  -1.37458176828      -1.39190488750      -1.40944345440      -1.42720009146
+  -1.44517745118      -1.46337821630      -1.48180510011      -1.50046084675
+  -1.51934823144      -1.53847006080      -1.55782917312      -1.57742843865
+  -1.59727075987      -1.61735907177      -1.63769634215      -1.65828557187
+  -1.67912979516      -1.70023207989      -1.72159552785      -1.74322327499
+  -1.76511849178      -1.78728438338      -1.80972419001      -1.83244118714
+  -1.85543868583      -1.87872003293      -1.90228861139      -1.92614784049
+  -1.95030117615      -1.97475211108      -1.99950417515      -2.02456093554
+  -2.04992599703      -2.07560300222      -2.10159563175      -2.12790760454
+  -2.15454267797      -2.18150464814      -2.20879735001      -2.23642465763
+  -2.26439048431      -2.29269878277      -2.32135354534      -2.35035880406
+  -2.37971863082      -2.40943713752      -2.43951847613      -2.46996683877
+  -2.50078645782      -2.53198160594      -2.56355659609      -2.59551578158
+  -2.62786355598      -2.66060435317      -2.69374264717      -2.72728295212
+  -2.76122982212      -2.79558785104      -2.83036167236      -2.86555595890
+  -2.90117542255      -2.93722481396      -2.97370892212      -3.01063257399
+  -3.04800063399      -3.08581800347      -3.12408962010      -3.16282045723
+  -3.20201552315      -3.24167986027      -3.28181854422      -3.32243668289
+  -3.36353941539      -3.40513191084      -3.44721936711      -3.48980700949
+  -3.53290008915      -3.57650388155      -3.62062368467      -3.66526481715
+  -3.71043261625      -3.75613243561      -3.80236964296      -3.84914961753
+  -3.89647774735      -3.94435942630      -3.99280005099      -4.04180501738
+  -4.09137971720      -4.14152953408      -4.19225983944      -4.24357598809
+  -4.29548331356      -4.34798712304      -4.40109269208      -4.45480525888
+  -4.50913001827      -4.56407211520      -4.61963663792      -4.67582861069
+  -4.73265298602      -4.79011463646      -4.84821834584      -4.90696880005
+  -4.96637057720      -5.02642813721      -5.08714581083      -5.14852778791
+  -5.21057810515      -5.27330063297      -5.33669906180      -5.40077688744
+  -5.46553739575      -5.53098364640      -5.59711845577      -5.66394437890
+  -5.73146369054      -5.79967836512      -5.86859005574      -5.93820007203
+  -6.00850935693      -6.07951846228      -6.15122752319      -6.22363623119
+  -6.29674380608      -6.37054896645      -6.44504989879      -6.52024422528
+  -6.59612897004      -6.67270052393      -6.74995460787      -6.82788623457
+  -6.90648966866      -6.98575838531      -7.06568502712      -7.14626135948
+  -7.22747822420      -7.30932549152      -7.39179201053      -7.47486555788
+  -7.55853278489      -7.64277916315      -7.72758892851      -7.81294502361
+  -7.89882903900      -7.98522115295      -8.07210007002      -8.15944295847
+  -8.24722538678      -8.33542125933      -8.42400275143      -8.51294024394
+  -8.60220225777      -8.69175538836      -8.78156424067      -8.87159136479
+  -8.96179719269      -9.05213997649      -9.14257572864      -9.23305816455
+  -9.32353864832      -9.41396614188      -9.50428715853      -9.59444572133
+  -9.68438332723      -9.77403891767      -9.86334885664      -9.95224691704
+  -10.0406642764      -10.1285295231      -10.2157686739      -10.3023052051
+  -10.3880600963      -10.4729518914      -10.5568967747      -10.6398086669
+  -10.7215993400      -10.8021785539      -10.8814542165      -10.9593325680
+  -11.0357183925      -11.1105152572      -11.1836257819      -11.2549519404
+  -11.3243953954      -11.3918578677      -11.4572415433      -11.5204495174
+  -11.5813862785      -11.6399582325      -11.6960742686      -11.7496463664
+  -11.8005902456      -11.8488260572      -11.8942791164      -11.9368806746
+  -11.9765687303      -12.0132888747      -12.0469951691      -12.0776510501
+  -12.1052302561      -12.1297177684      -12.1511107589      -12.1694195354
+  -12.1846684703      -12.1968969033      -12.2061599985      -12.2125295414
+  -12.2160946542      -12.2169624071      -12.2152582995      -12.2111265852
+  -12.2047304067      -12.1962517088      -12.1858908917      -12.1738661644
+  -12.1604125580      -12.1457805534      -12.1302342794      -12.1140492357
+  -12.0975094973      -12.0809043600      -12.0645243920      -12.0486568663
+  -12.0335805605      -12.0195599304      -12.0068386875      -11.9956328433
+  -11.9861233263      -11.9784483328      -11.9726956408      -11.9688952048
+  -11.9670124588      -11.9669428853      -11.9685085801      -11.9714577369
+  -11.9754682273      -11.9801567454      -11.9850953470      -11.9898376444
+  -11.9939574386      -11.9971031932      -11.9991345136      -11.9999230921
+  -12.0000373010      -12.0000296134      -12.0000234687      -12.0000185484
+  -12.0000146193      -12.0000114907      -12.0000090064      -12.0000070395
+  -12.0000054868      -12.0000042645      -12.0000033052      -12.0000025546
+  -12.0000019689      -12.0000015134      -12.0000011601      -12.0000008870
+  -12.0000006765      -12.0000005147      -12.0000003907      -12.0000002960
+  -12.0000002238      -12.0000001689      -12.0000001274      -12.0000000960
+  -12.0000000723      -12.0000000545      -12.0000000411      -12.0000000310
+  -12.0000000235      -12.0000000179      -12.0000000137      -12.0000000105
+  -12.0000000081      -12.0000000063      -12.0000000050      -12.0000000039
+  -12.0000000031      -12.0000000025      -12.0000000021      -12.0000000017
+  -12.0000000014      -12.0000000012      -12.0000000010      -12.0000000008
+  -12.0000000000
+ Core charge follows
+   0.00000000000       0.00000000000       0.00000000000       0.00000000000
+   0.00000000000
+ Valence charge follows
+  0.492067138082E-10  0.199310418009E-09  0.454118792434E-09  0.817551676193E-09
+  0.129364410540E-08  0.188654943031E-08  0.260054251385E-08  0.344002301379E-08
+  0.440951875045E-08  0.551368916247E-08  0.675732885253E-08  0.814537122571E-08
+  0.968289222256E-08  0.113751141495E-07  0.132274096089E-07  0.152453055317E-07
+  0.174344873149E-07  0.198008030662E-07  0.223502679600E-07  0.250890687061E-07
+  0.280235681343E-07  0.311603098984E-07  0.345060233031E-07  0.380676282544E-07
+  0.418522403407E-07  0.458671760441E-07  0.501199580876E-07  0.546183209208E-07
+  0.593702163479E-07  0.643838193018E-07  0.696675337669E-07  0.752299988566E-07
+  0.810800950472E-07  0.872269505734E-07  0.936799479897E-07  0.100448730901E-06
+  0.107543210869E-06  0.114973574491E-06  0.122750290675E-06  0.130884118085E-06
+  0.139386112795E-06  0.148267636130E-06  0.157540362713E-06  0.167216288724E-06
+  0.177307740364E-06  0.187827382542E-06  0.198788227788E-06  0.210203645393E-06
+  0.222087370783E-06  0.234453515142E-06  0.247316575271E-06  0.260691443715E-06
+  0.274593419142E-06  0.289038216989E-06  0.304041980389E-06  0.319621291371E-06
+  0.335793182355E-06  0.352575147941E-06  0.369985156997E-06  0.388041665068E-06
+  0.406763627091E-06  0.426170510450E-06  0.446282308355E-06  0.467119553576E-06
+  0.488703332524E-06  0.511055299691E-06  0.534197692467E-06  0.558153346340E-06
+  0.582945710472E-06  0.608598863693E-06  0.635137530898E-06  0.662587099859E-06
+  0.690973638477E-06  0.720323912479E-06  0.750665403555E-06  0.782026327979E-06
+  0.814435655691E-06  0.847923129883E-06  0.882519287074E-06  0.918255477711E-06
+  0.955163887290E-06  0.993277558026E-06  0.103263041107E-05  0.107325726930E-05
+  0.111519388071E-05  0.115847694236E-05  0.120314412497E-05  0.124923409818E-05
+  0.129678655633E-05  0.134584224508E-05  0.139644298856E-05  0.144863171727E-05
+  0.150245249674E-05  0.155795055682E-05  0.161517232186E-05  0.167416544149E-05
+  0.173497882236E-05  0.179766266058E-05  0.186226847501E-05  0.192884914143E-05
+  0.199745892760E-05  0.206815352911E-05  0.214099010632E-05  0.221602732205E-05
+  0.229332538042E-05  0.237294606653E-05  0.245495278726E-05  0.253941061305E-05
+  0.262638632079E-05  0.271594843779E-05  0.280816728683E-05  0.290311503248E-05
+  0.300086572846E-05  0.310149536631E-05  0.320508192528E-05  0.331170542345E-05
+  0.342144797026E-05  0.353439382025E-05  0.365062942827E-05  0.377024350609E-05
+  0.389332708039E-05  0.401997355235E-05  0.415027875860E-05  0.428434103391E-05
+  0.442226127534E-05  0.456414300807E-05  0.471009245297E-05  0.486021859581E-05
+  0.501463325830E-05  0.517345117089E-05  0.533679004749E-05  0.550477066206E-05
+  0.567751692718E-05  0.585515597457E-05  0.603781823776E-05  0.622563753681E-05
+  0.641875116518E-05  0.661729997888E-05  0.682142848784E-05  0.703128494965E-05
+  0.724702146568E-05  0.746879407965E-05  0.769676287874E-05  0.793109209725E-05
+  0.817195022295E-05  0.841951010611E-05  0.867394907134E-05  0.893544903226E-05
+  0.920419660914E-05  0.948038324954E-05  0.976420535195E-05  0.100558643928E-04
+  0.103555670563E-04  0.106635253682E-04  0.109799568324E-04  0.113050845716E-04
+  0.116391374708E-04  0.119823503252E-04  0.123349639915E-04  0.126972255432E-04
+  0.130693884300E-04  0.134517126406E-04  0.138444648708E-04  0.142479186948E-04
+  0.146623547415E-04  0.150880608754E-04  0.155253323816E-04  0.159744721557E-04
+  0.164357908993E-04  0.169096073193E-04  0.173962483330E-04  0.178960492786E-04
+  0.184093541309E-04  0.189365157218E-04  0.194778959680E-04  0.200338661031E-04
+  0.206048069163E-04  0.211911089971E-04  0.217931729865E-04  0.224114098343E-04
+  0.230462410629E-04  0.236980990384E-04  0.243674272484E-04  0.250546805865E-04
+  0.257603256450E-04  0.264848410142E-04  0.272287175897E-04  0.279924588884E-04
+  0.287765813709E-04  0.295816147739E-04  0.304081024504E-04  0.312566017181E-04
+  0.321276842180E-04  0.330219362812E-04  0.339399593058E-04  0.348823701426E-04
+  0.358498014923E-04  0.368429023109E-04  0.378623382275E-04  0.389087919715E-04
+  0.399829638115E-04  0.410855720054E-04  0.422173532617E-04  0.433790632134E-04
+  0.445714769038E-04  0.457953892845E-04  0.470516157271E-04  0.483409925473E-04
+  0.496643775429E-04  0.510226505460E-04  0.524167139892E-04  0.538474934862E-04
+  0.553159384280E-04  0.568230225944E-04  0.583697447810E-04  0.599571294430E-04
+  0.615862273553E-04  0.632581162902E-04  0.649739017122E-04  0.667347174912E-04
+  0.685417266343E-04  0.703961220364E-04  0.722991272508E-04  0.742519972794E-04
+  0.762560193837E-04  0.783125139174E-04  0.804228351799E-04  0.825883722933E-04
+  0.848105501008E-04  0.870908300904E-04  0.894307113414E-04  0.918317314961E-04
+  0.942954677579E-04  0.968235379142E-04  0.994176013871E-04  0.102079360312E-03
+  0.104810560643E-03  0.107612993290E-03  0.110488495283E-03  0.113438950971E-03
+  0.116466293248E-03  0.119572504813E-03  0.122759619466E-03  0.126029723436E-03
+  0.129384956744E-03  0.132827514603E-03  0.136359648857E-03  0.139983669451E-03
+  0.143701945954E-03  0.147516909107E-03  0.151431052423E-03  0.155446933826E-03
+  0.159567177336E-03  0.163794474794E-03  0.168131587640E-03  0.172581348737E-03
+  0.177146664240E-03  0.181830515518E-03  0.186635961131E-03  0.191566138860E-03
+  0.196624267781E-03  0.201813650414E-03  0.207137674916E-03  0.212599817338E-03
+  0.218203643943E-03  0.223952813593E-03  0.229851080191E-03  0.235902295196E-03
+  0.242110410211E-03  0.248479479633E-03  0.255013663380E-03  0.261717229699E-03
+  0.268594558041E-03  0.275650142024E-03  0.282888592474E-03  0.290314640554E-03
+  0.297933140975E-03  0.305749075304E-03  0.313767555357E-03  0.321993826691E-03
+  0.330433272196E-03  0.339091415783E-03  0.347973926182E-03  0.357086620841E-03
+  0.366435469944E-03  0.376026600532E-03  0.385866300755E-03  0.395961024231E-03
+  0.406317394545E-03  0.416942209860E-03  0.427842447679E-03  0.439025269729E-03
+  0.450498026997E-03  0.462268264905E-03  0.474343728639E-03  0.486732368634E-03
+  0.499442346218E-03  0.512482039422E-03  0.525860048959E-03  0.539585204385E-03
+  0.553666570433E-03  0.568113453547E-03  0.582935408601E-03  0.598142245822E-03
+  0.613744037919E-03  0.629751127431E-03  0.646174134289E-03  0.663023963614E-03
+  0.680311813747E-03  0.698049184526E-03  0.716247885813E-03  0.734920046285E-03
+  0.754078122493E-03  0.773734908208E-03  0.793903544042E-03  0.814597527383E-03
+  0.835830722629E-03  0.857617371751E-03  0.879972105181E-03  0.902909953045E-03
+  0.926446356756E-03  0.950597180967E-03  0.975378725913E-03  0.100080774014E-02
+  0.102690143366E-02  0.105367749151E-02  0.108115408773E-02  0.110934989988E-02
+  0.113828412393E-02  0.116797648970E-02  0.119844727677E-02  0.122971733095E-02
+  0.126180808129E-02  0.129474155762E-02  0.132854040870E-02  0.136322792101E-02
+  0.139882803814E-02  0.143536538078E-02  0.147286526753E-02  0.151135373629E-02
+  0.155085756642E-02  0.159140430172E-02  0.163302227408E-02  0.167574062809E-02
+  0.171958934640E-02  0.176459927601E-02  0.181080215550E-02  0.185823064315E-02
+  0.190691834614E-02  0.195689985074E-02  0.200821075356E-02  0.206088769395E-02
+  0.211496838758E-02  0.217049166118E-02  0.222749748857E-02  0.228602702799E-02
+  0.234612266084E-02  0.240782803174E-02  0.247118809016E-02  0.253624913355E-02
+  0.260305885208E-02  0.267166637502E-02  0.274212231887E-02  0.281447883733E-02
+  0.288878967312E-02  0.296511021172E-02  0.304349753723E-02  0.312401049032E-02
+  0.320670972840E-02  0.329165778805E-02  0.337891914998E-02  0.346856030636E-02
+  0.356064983085E-02  0.365525845133E-02  0.375245912547E-02  0.385232711927E-02
+  0.395494008868E-02  0.406037816446E-02  0.416872404034E-02  0.428006306480E-02
+  0.439448333638E-02  0.451207580285E-02  0.463293436441E-02  0.475715598095E-02
+  0.488484078369E-02  0.501609219132E-02  0.515101703085E-02  0.528972566340E-02
+  0.543233211511E-02  0.557895421334E-02  0.572971372860E-02  0.588473652216E-02
+  0.604415269985E-02  0.620809677216E-02  0.637670782102E-02  0.655012967344E-02
+  0.672851108243E-02  0.691200591544E-02  0.710077335066E-02  0.729497808160E-02
+  0.749479053015E-02  0.770038706870E-02  0.791195025155E-02  0.812966905610E-02
+  0.835373913423E-02  0.858436307433E-02  0.882175067440E-02  0.906611922679E-02
+  0.931769381501E-02  0.957670762319E-02  0.984340225871E-02  0.101180280886E-01
+  0.104008445903E-01  0.106921207175E-01  0.109921352814E-01  0.113011773486E-01
+  0.116195466556E-01  0.119475540419E-01  0.122855219006E-01  0.126337846489E-01
+  0.129926892193E-01  0.133625955705E-01  0.137438772220E-01  0.141369218101E-01
+  0.145421316685E-01  0.149599244340E-01  0.153907336779E-01  0.158350095643E-01
+  0.162932195372E-01  0.167658490362E-01  0.172534022441E-01  0.177564028652E-01
+  0.182753949375E-01  0.188109436796E-01  0.193636363739E-01  0.199340832866E-01
+  0.205229186279E-01  0.211308015522E-01  0.217584172011E-01  0.224064777903E-01
+  0.230757237425E-01  0.237669248682E-01  0.244808815957E-01  0.252184262532E-01
+  0.259804244041E-01  0.267677762382E-01  0.275814180207E-01  0.284223236008E-01
+  0.292915059839E-01  0.301900189664E-01  0.311189588398E-01  0.320794661626E-01
+  0.330727276048E-01  0.340999778676E-01  0.351625016793E-01  0.362616358722E-01
+  0.373987715415E-01  0.385753562902E-01  0.397928965620E-01  0.410529600660E-01
+  0.423571782954E-01  0.437072491434E-01  0.451049396194E-01  0.465520886685E-01
+  0.480506100978E-01  0.496024956112E-01  0.512098179574E-01  0.528747341930E-01
+  0.545994890649E-01  0.563864185130E-01  0.582379532984E-01  0.601566227584E-01
+  0.621450586919E-01  0.642059993774E-01  0.663422937265E-01  0.685569055749E-01
+  0.708529181140E-01  0.732335384636E-01  0.757021023898E-01  0.782620791668E-01
+  0.809170765870E-01  0.836708461174E-01  0.865272882051E-01  0.894904577308E-01
+  0.925645696109E-01  0.957540045462E-01  0.990633149169E-01  0.102497230822
+  0.106060666260      0.109758725445      0.113596709263      0.117580121849
+  0.121714677291      0.126006306451      0.130461163890      0.135085634890
+  0.139886342569      0.144870155065      0.150044192782      0.155415835687
+  0.160992730627      0.166782798660      0.172794242379      0.179035553190
+  0.185515518542      0.192243229057      0.199228085549      0.206479805888
+  0.214008431673      0.221824334681      0.229938223042      0.238361147097
+  0.247104504893      0.256180047255      0.265599882383      0.275376479910
+  0.285522674357      0.296051667916      0.306977032482      0.318312710863
+  0.330073017079      0.342272635658      0.354926619848      0.368050388635
+  0.381659722469      0.395770757591      0.410399978842      0.425564210848
+  0.441280607445      0.457566639229      0.474440079091      0.491918985611
+  0.510021684163      0.528766745600      0.548172962370      0.568259321916
+  0.589044977219      0.610549214330      0.632791416759      0.655791026560
+  0.679567501983      0.704140271557      0.729528684466      0.755751957110
+  0.782829115719      0.810778934941      0.839619872303      0.869369998471
+  0.900046923277      0.931667717455      0.964248830099      0.997806001852
+   1.03235417388       1.06790739272       1.10447871109       1.14208008487
+   1.18072226639       1.22041469435       1.26116538063       1.30298079424
+   1.34586574303       1.38982325343       1.43485444883       1.48095842711
+   1.52813213812       1.57637026161       1.62566508655       1.67600639262
+   1.72738133475       1.77977433171       1.83316695973       1.88753785230
+   1.94286260710       1.99911370140       2.05626041706       2.11426877616
+   2.17310148880       2.23271791391       2.29307403456       2.35412244869
+   2.41581237648       2.47808968531       2.54089693326       2.60417343186
+   2.66785532896       2.73187571190       2.79616473160       2.86064974751
+   2.92525549331       2.98990426307       3.05451611718       3.11900910724
+   3.18329951858       3.24730212917       3.31093048295       3.37409717567
+   3.43671415091       3.49869300374       3.55994528916       3.62038283249
+   3.67991803844       3.73846419577       3.79593577419       3.85224871027
+   3.90732067927       3.96107134979       4.01342261853       4.06429882274
+   4.11362692821       4.16133669127       4.20736079363       4.25163494961
+   4.29409798580       4.33469189396       4.37336185843       4.41005626012
+   4.44472665979       4.47732776356       4.50781737440       4.53615633346
+   4.56230845529       4.58624046122       4.60792191475       4.62732516275
+   4.64442528556       4.65920005847       4.67162992619       4.68169799093
+   4.68939001375       4.69469442739       4.69760235819       4.69810765343
+   4.69620690965       4.69189949733       4.68518757689       4.67607610157
+   4.66457280356       4.65068816116       4.63443534695       4.61583015916
+   4.59489094172       4.57163850139       4.54609603353       4.51828907108
+   4.48824547317       4.45599547098       4.42157178748       4.38500984471
+   4.34634806684       4.30562827773       4.26289617956       4.21820188173
+   4.17160042837       4.12315224651       4.07292340562       4.02098553498
+   3.96741520785       3.91229270410       3.85570039022       3.79772183704
+   3.73844220461       3.67794751735       3.61632467743       3.55366118319
+   3.49004493484       3.42556402346       3.36030652592       3.29436030323
+   3.22781280335       3.16075086907       3.09326055139       3.02542692910
+   2.95733393492       2.88906418864       2.82069883781       2.75231740615
+   2.68399765019       2.61581542427       2.54784455424       2.48015672003
+   2.41282134725       2.34590550793       2.27947383050       2.21358841904
+   2.14830878184       2.08369176910       2.01979151997       1.95665941851
+   1.89434405873       1.83289121832       1.77234384105       1.71274202751
+   1.65412303402       1.59652127942       1.53996835945       1.48449306846
+   1.43012142805       1.37687672242       1.32477954001       1.27384782105
+   1.22409691075       1.17553961764       1.12818627686       1.08204481776
+   1.03712083564      0.993417667225      0.950936469352      0.909676300637
+  0.869634205674      0.830805301416      0.793182865369      0.756758425238
+  0.721521849691      0.687461439890      0.654564021475      0.622815036670
+  0.592198636236      0.562697770947      0.534294282351      0.506968992525
+  0.480701792603      0.455471729826      0.431257092922      0.408035495597
+  0.385783957966      0.364478985760      0.344096647145      0.324612647041
+  0.306002398794      0.288241093127      0.271303764262      0.255165353147
+  0.239800767736      0.225184940264      0.211292881502      0.198099731964
+  0.185580810065      0.173711657235      0.162468080012      0.151826189135
+  0.141762435681      0.132253644289      0.123277043532      0.114810293494
+  0.106831510624      0.993192899499E-01  0.922527247176E-01  0.856114235606E-01
+  0.793755252759E-01  0.735257113068E-01  0.680432160256E-01  0.629098349172E-01
+  0.581079307604E-01  0.536204379104E-01  0.494308647819E-01  0.455232946350E-01
+  0.418823847648E-01  0.384933641941E-01  0.353420299687E-01  0.324147421527E-01
+  0.296984176190E-01  0.271805227286E-01  0.248490649910E-01  0.226925837928E-01
+  0.207001402830E-01  0.188613064967E-01  0.171661537993E-01  0.156052407289E-01
+  0.141696003109E-01  0.128507269183E-01  0.116405627456E-01  0.105314839628E-01
+  0.951628661145E-02  0.858817230414E-02  0.774073378304E-02  0.696794039176E-02
+  0.626412351155E-02  0.562396200967E-02  0.504246774498E-02  0.451497117308E-02
+  0.403710709027E-02  0.360480055288E-02  0.321425300590E-02  0.286192865197E-02
+  0.254454108916E-02  0.225904024338E-02  0.200259961863E-02  0.177260388584E-02
+  0.156663682850E-02  0.138246966090E-02  0.121804973242E-02  0.107148962906E-02
+  0.941056680999E-03  0.825162883251E-03  0.722355233772E-03  0.631306492009E-03
+  0.550806358615E-03  0.479753075379E-03  0.417145442735E-03  0.362075250607E-03
+  0.313720116855E-03  0.271336726279E-03  0.234254461811E-03  0.201869418488E-03
+  0.173638789701E-03  0.149075614399E-03  0.127743873121E-03  0.109253920075E-03
+  0.932582379718E-04  0.794475018828E-04  0.675469380754E-04  0.573129635842E-04
+  0.485300921564E-04  0.410080921990E-04  0.345793824258E-04  0.290966510552E-04
+  0.244306846351E-04  0.204683928657E-04  0.171110161383E-04  0.142725029168E-04
+  0.118780445310E-04  0.986275543853E-05  0.817048752448E-05  0.675276754701E-05
+  0.556784739077E-05  0.457985735541E-05  0.375805327709E-05  0.307614885108E-05
+  0.251172508931E-05  0.204570940361E-05  0.166191734962E-05  0.134665059473E-05
+  0.108834518340E-05  0.877264662498E-06  0.705233096067E-06  0.565403441574E-06
+  0.452057178061E-06  0.360431469062E-06  0.286570510258E-06  0.227198053263E-06
+  0.179608413059E-06  0.141573558050E-06  0.111264149080E-06  0.871826381401E-07
+  0.681067597077E-07  0.530419490085E-07  0.411814030886E-07  0.318726636740E-07
+  0.245897466955E-07  0.189099733068E-07  0.144947725022E-07  0.110738272880E-07
+  0.843202596278E-08  0.639875858380E-08  0.483916721040E-08  0.364701806971E-08
+  0.273891533024E-08  0.204962060172E-08  0.152828042193E-08  0.113539660121E-08
+  0.840402060306E-09  0.619728337900E-09  0.455270821749E-09  0.333174470035E-09
+  0.242876783297E-09  0.176356454175E-09  0.127545807960E-09  0.918731534479E-10
+  0.659077533627E-10  0.470855238046E-10  0.334979781015E-10  0.237305092574E-10
+  0.167389992590E-10  0.117560732930E-10  0.822018397684E-11  0.572220007784E-11
+  0.396535681356E-11  0.273535948917E-11  0.187816745983E-11  0.128356100872E-11
+  0.873042207832E-12  0.590968561573E-12  0.398086537088E-12  0.266838079981E-12
+  0.177970581347E-12  0.118100374875E-12  0.779702958636E-13  0.512098838858E-13
+  0.334577400568E-13  0.217434652220E-13  0.140546823862E-13  0.903532640703E-14
+  0.577653260681E-14  0.367249190038E-14  0.232163520229E-14  0.145926956738E-14
+  0.911914218637E-15  0.566522907140E-15  0.349859521426E-15  0.214758300607E-15
+  0.131024693049E-15  0.794455821452E-16  0.478702634244E-16  0.286620320988E-16
+  0.170513367862E-16  0.100782457014E-16  0.591767113104E-17  0.345159598746E-17
+  0.199965810434E-17  0.115059149725E-17  0.657474155632E-18  0.373070016172E-18
+  0.210192726828E-18  0.117576834047E-18  0.652924778229E-19  0.359916639437E-19
+  0.196923551975E-19  0.106932426660E-19  0.576229862933E-20  0.308116323952E-20
+  0.163464617449E-20  0.860359369593E-21  0.449199768652E-21  0.232626150035E-21
+  0.119479182375E-21  0.608548798450E-22  0.307342220241E-22  0.153895634018E-22
+  0.763942482450E-23  0.375904692605E-23  0.183328249804E-23  0.886067537415E-24
+  0.424366078291E-24  0.201372837587E-24  0.946666200138E-25  0.440836277435E-25
+  0.203324788198E-25  0.928716786553E-26  0.420051926338E-26  0.188102888673E-26
+  0.833884973108E-27  0.365914599941E-27  0.158913299884E-27  0.682953245445E-28
+  0.290411964045E-28  0.122172284825E-28  0.508401321601E-29  0.209245826429E-29
+  0.851653071921E-30  0.342738794474E-30  0.136362993830E-30  0.536290125592E-31
+  0.208453688437E-31  0.800684778135E-32  0.303871971308E-32  0.113928098484E-32
+  0.421905710049E-33  0.154303817980E-33  0.557244976821E-34  0.198680164185E-34
+  0.699248382639E-35  0.242887913961E-35  0.832541269227E-36  0.281551670888E-36
+  0.939266932373E-37  0.309046419098E-37  0.100273547372E-37  0.320774827980E-38
+  0.101155080901E-38  0.314390876900E-39  0.962869150211E-40  0.290535357025E-40
+  0.863541762031E-41  0.252776994573E-41  0.728580853642E-42  0.206737407810E-42
+  0.577398300454E-43  0.158693809563E-43  0.429125521307E-44  0.114145628156E-44
+  0.298603144915E-45  0.768065153932E-46  0.194212694339E-46  0.482657587451E-47
+  0.117865732555E-47  0.282765622001E-48  0.666283105993E-49  0.154164876476E-49
+  0.350192293451E-50  0.780766289613E-51  0.170815157143E-51  0.366622337931E-52
+  0.771780157695E-53  0.159310415172E-53  0.322376223486E-54  0.639353712212E-55
+  0.124242014289E-55  0.236501169681E-56  0.440882316897E-57  0.804678407908E-58
+  0.143752904980E-58  0.251297681758E-59  0.429753553999E-60  0.718769753010E-61
+  0.117537976706E-61  0.187872019797E-62  0.293438733658E-63  0.447732651294E-64
+  0.667174161333E-65  0.970622839050E-66  0.137823387980E-66  0.190952492053E-67
+  0.258062668806E-68  0.340085800652E-69  0.436897851068E-70  0.546968808213E-71
+  0.667111386681E-72  0.792405437706E-73  0.916366802301E-74  0.103138442653E-74
+  0.112943105188E-75  0.120292104148E-76  0.124570818704E-77  0.125376680381E-78
+  0.122655219193E-79  0.116821097578E-80  0.108021194521E-81  0.969365470997E-83
+  0.843904678485E-84
Added: SwiftApps/ematter/workflow-run/O.sic.psf
--- SwiftApps/ematter/workflow-run/O.sic.psf	                        (rev 0)
+++ SwiftApps/ematter/workflow-run/O.sic.psf	2015-01-27 22:12:52 UTC (rev 8376)
@@ -0,0 +1,1821 @@
+ O  ca nrl nc
+ ATM3      29-MAR-06 Troullier-Martins
+ 2s 2.00  r= 1.14/2p 4.00  r= 1.14/3d 0.00  r= 1.14/4f 0.00  r= 1.14/
+   4  0 1029  0.309844022083E-03  0.125000000000E-01   6.00000000000
+ Radial grid follows
+  0.389735801693E-05  0.784373876281E-05  0.118397588677E-04  0.158860427178E-04
+  0.199832225532E-04  0.241319385666E-04  0.283328390034E-04  0.325865802628E-04
+  0.368938270004E-04  0.412552522324E-04  0.456715374403E-04  0.501433726777E-04
+  0.546714566780E-04  0.592564969634E-04  0.638992099558E-04  0.686003210887E-04
+  0.733605649201E-04  0.781806852479E-04  0.830614352256E-04  0.880035774804E-04
+  0.930078842321E-04  0.980751374137E-04  0.103206128794E-03  0.108401660101E-03
+  0.113662543146E-03  0.118989599954E-03  0.124383662888E-03  0.129845574781E-03
+  0.135376189068E-03  0.140976369919E-03  0.146646992373E-03  0.152388942477E-03
+  0.158203117422E-03  0.164090425685E-03  0.170051787170E-03  0.176088133351E-03
+  0.182200407420E-03  0.188389564433E-03  0.194656571457E-03  0.201002407725E-03
+  0.207428064787E-03  0.213934546665E-03  0.220522870010E-03  0.227194064261E-03
+  0.233949171805E-03  0.240789248143E-03  0.247715362049E-03  0.254728595743E-03
+  0.261830045058E-03  0.269020819608E-03  0.276302042968E-03  0.283674852843E-03
+  0.291140401250E-03  0.298699854695E-03  0.306354394360E-03  0.314105216280E-03
+  0.321953531539E-03  0.329900566451E-03  0.337947562756E-03  0.346095777814E-03
+  0.354346484801E-03  0.362700972906E-03  0.371160547534E-03  0.379726530512E-03
+  0.388400260291E-03  0.397183092161E-03  0.406076398455E-03  0.415081568772E-03
+  0.424200010187E-03  0.433433147476E-03  0.442782423334E-03  0.452249298606E-03
+  0.461835252510E-03  0.471541782870E-03  0.481370406352E-03  0.491322658699E-03
+  0.501400094969E-03  0.511604289783E-03  0.521936837567E-03  0.532399352802E-03
+  0.542993470279E-03  0.553720845349E-03  0.564583154186E-03  0.575582094048E-03
+  0.586719383543E-03  0.597996762894E-03  0.609415994214E-03  0.620978861782E-03
+  0.632687172320E-03  0.644542755274E-03  0.656547463104E-03  0.668703171570E-03
+  0.681011780026E-03  0.693475211716E-03  0.706095414078E-03  0.718874359044E-03
+  0.731814043350E-03  0.744916488848E-03  0.758183742822E-03  0.771617878307E-03
+  0.785220994414E-03  0.798995216658E-03  0.812942697289E-03  0.827065615629E-03
+  0.841366178413E-03  0.855846620133E-03  0.870509203387E-03  0.885356219235E-03
+  0.900389987551E-03  0.915612857394E-03  0.931027207368E-03  0.946635445996E-03
+  0.962440012097E-03  0.978443375167E-03  0.994648035764E-03  0.101105652590E-02
+  0.102767140943E-02  0.104449528247E-02  0.106153077378E-02  0.107878054520E-02
+  0.109624729202E-02  0.111393374348E-02  0.113184266311E-02  0.114997684922E-02
+  0.116833913530E-02  0.118693239052E-02  0.120575952009E-02  0.122482346580E-02
+  0.124412720643E-02  0.126367375822E-02  0.128346617537E-02  0.130350755048E-02
+  0.132380101505E-02  0.134434973998E-02  0.136515693606E-02  0.138622585444E-02
+  0.140755978719E-02  0.142916206778E-02  0.145103607161E-02  0.147318521654E-02
+  0.149561296342E-02  0.151832281662E-02  0.154131832460E-02  0.156460308048E-02
+  0.158818072252E-02  0.161205493479E-02  0.163622944769E-02  0.166070803852E-02
+  0.168549453213E-02  0.171059280144E-02  0.173600676811E-02  0.176174040314E-02
+  0.178779772744E-02  0.181418281254E-02  0.184089978115E-02  0.186795280785E-02
+  0.189534611974E-02  0.192308399708E-02  0.195117077396E-02  0.197961083901E-02
+  0.200840863603E-02  0.203756866475E-02  0.206709548148E-02  0.209699369984E-02
+  0.212726799149E-02  0.215792308685E-02  0.218896377585E-02  0.222039490864E-02
+  0.225222139642E-02  0.228444821213E-02  0.231708039128E-02  0.235012303271E-02
+  0.238358129941E-02  0.241746041930E-02  0.245176568605E-02  0.248650245994E-02
+  0.252167616865E-02  0.255729230816E-02  0.259335644355E-02  0.262987420992E-02
+  0.266685131324E-02  0.270429353127E-02  0.274220671442E-02  0.278059678671E-02
+  0.281946974666E-02  0.285883166826E-02  0.289868870188E-02  0.293904707526E-02
+  0.297991309449E-02  0.302129314496E-02  0.306319369239E-02  0.310562128383E-02
+  0.314858254867E-02  0.319208419969E-02  0.323613303413E-02  0.328073593470E-02
+  0.332589987069E-02  0.337163189906E-02  0.341793916553E-02  0.346482890571E-02
+  0.351230844621E-02  0.356038520581E-02  0.360906669661E-02  0.365836052518E-02
+  0.370827439378E-02  0.375881610155E-02  0.380999354576E-02  0.386181472296E-02
+  0.391428773033E-02  0.396742076687E-02  0.402122213475E-02  0.407570024052E-02
+  0.413086359651E-02  0.418672082210E-02  0.424328064509E-02  0.430055190307E-02
+  0.435854354480E-02  0.441726463158E-02  0.447672433871E-02  0.453693195688E-02
+  0.459789689366E-02  0.465962867494E-02  0.472213694645E-02  0.478543147521E-02
+  0.484952215114E-02  0.491441898853E-02  0.498013212765E-02  0.504667183630E-02
+  0.511404851145E-02  0.518227268084E-02  0.525135500465E-02  0.532130627711E-02
+  0.539213742827E-02  0.546385952563E-02  0.553648377591E-02  0.561002152681E-02
+  0.568448426874E-02  0.575988363667E-02  0.583623141189E-02  0.591353952390E-02
+  0.599182005225E-02  0.607108522844E-02  0.615134743780E-02  0.623261922147E-02
+  0.631491327834E-02  0.639824246701E-02  0.648261980784E-02  0.656805848497E-02
+  0.665457184835E-02  0.674217341589E-02  0.683087687550E-02  0.692069608727E-02
+  0.701164508565E-02  0.710373808160E-02  0.719698946483E-02  0.729141380607E-02
+  0.738702585931E-02  0.748384056413E-02  0.758187304802E-02  0.768113862876E-02
+  0.778165281679E-02  0.788343131767E-02  0.798649003449E-02  0.809084507039E-02
+  0.819651273104E-02  0.830350952725E-02  0.841185217747E-02  0.852155761047E-02
+  0.863264296794E-02  0.874512560720E-02  0.885902310388E-02  0.897435325471E-02
+  0.909113408025E-02  0.920938382774E-02  0.932912097396E-02  0.945036422806E-02
+  0.957313253456E-02  0.969744507626E-02  0.982332127723E-02  0.995078080590E-02
+  0.100798435781E-01  0.102105297601E-01  0.103428597719E-01  0.104768542903E-01
+  0.106125342523E-01  0.107499208582E-01  0.108890355748E-01  0.110299001391E-01
+  0.111725365615E-01  0.113169671292E-01  0.114632144099E-01  0.116113012549E-01
+  0.117612508030E-01  0.119130864843E-01  0.120668320234E-01  0.122225114433E-01
+  0.123801490692E-01  0.125397695323E-01  0.127013977737E-01  0.128650590481E-01
+  0.130307789280E-01  0.131985833073E-01  0.133684984058E-01  0.135405507732E-01
+  0.137147672930E-01  0.138911751868E-01  0.140698020187E-01  0.142506756996E-01
+  0.144338244913E-01  0.146192770113E-01  0.148070622367E-01  0.149972095095E-01
+  0.151897485406E-01  0.153847094146E-01  0.155821225944E-01  0.157820189264E-01
+  0.159844296447E-01  0.161893863764E-01  0.163969211464E-01  0.166070663825E-01
+  0.168198549202E-01  0.170353200083E-01  0.172534953135E-01  0.174744149262E-01
+  0.176981133656E-01  0.179246255849E-01  0.181539869773E-01  0.183862333807E-01
+  0.186214010844E-01  0.188595268335E-01  0.191006478359E-01  0.193448017671E-01
+  0.195920267767E-01  0.198423614941E-01  0.200958450347E-01  0.203525170056E-01
+  0.206124175125E-01  0.208755871654E-01  0.211420670849E-01  0.214118989092E-01
+  0.216851248001E-01  0.219617874495E-01  0.222419300867E-01  0.225255964845E-01
+  0.228128309663E-01  0.231036784132E-01  0.233981842705E-01  0.236963945555E-01
+  0.239983558641E-01  0.243041153784E-01  0.246137208740E-01  0.249272207272E-01
+  0.252446639232E-01  0.255661000631E-01  0.258915793718E-01  0.262211527063E-01
+  0.265548715629E-01  0.268927880861E-01  0.272349550758E-01  0.275814259965E-01
+  0.279322549848E-01  0.282874968586E-01  0.286472071250E-01  0.290114419896E-01
+  0.293802583648E-01  0.297537138790E-01  0.301318668852E-01  0.305147764706E-01
+  0.309025024657E-01  0.312951054535E-01  0.316926467789E-01  0.320951885587E-01
+  0.325027936906E-01  0.329155258640E-01  0.333334495691E-01  0.337566301072E-01
+  0.341851336012E-01  0.346190270056E-01  0.350583781172E-01  0.355032555854E-01
+  0.359537289234E-01  0.364098685184E-01  0.368717456431E-01  0.373394324669E-01
+  0.378130020668E-01  0.382925284389E-01  0.387780865103E-01  0.392697521503E-01
+  0.397676021828E-01  0.402717143977E-01  0.407821675637E-01  0.412990414402E-01
+  0.418224167896E-01  0.423523753905E-01  0.428890000500E-01  0.434323746168E-01
+  0.439825839942E-01  0.445397141537E-01  0.451038521478E-01  0.456750861243E-01
+  0.462535053398E-01  0.468392001733E-01  0.474322621409E-01  0.480327839097E-01
+  0.486408593125E-01  0.492565833623E-01  0.498800522672E-01  0.505113634455E-01
+  0.511506155409E-01  0.517979084377E-01  0.524533432769E-01  0.531170224715E-01
+  0.537890497227E-01  0.544695300360E-01  0.551585697381E-01  0.558562764926E-01
+  0.565627593177E-01  0.572781286028E-01  0.580024961258E-01  0.587359750705E-01
+  0.594786800447E-01  0.602307270973E-01  0.609922337374E-01  0.617633189518E-01
+  0.625441032243E-01  0.633347085539E-01  0.641352584743E-01  0.649458780730E-01
+  0.657666940112E-01  0.665978345428E-01  0.674394295353E-01  0.682916104897E-01
+  0.691545105609E-01  0.700282645788E-01  0.709130090693E-01  0.718088822755E-01
+  0.727160241794E-01  0.736345765238E-01  0.745646828343E-01  0.755064884420E-01
+  0.764601405059E-01  0.774257880360E-01  0.784035819169E-01  0.793936749306E-01
+  0.803962217814E-01  0.814113791191E-01  0.824393055643E-01  0.834801617324E-01
+  0.845341102593E-01  0.856013158268E-01  0.866819451877E-01  0.877761671928E-01
+  0.888841528162E-01  0.900060751832E-01  0.911421095962E-01  0.922924335631E-01
+  0.934572268243E-01  0.946366713810E-01  0.958309515240E-01  0.970402538618E-01
+  0.982647673506E-01  0.995046833228E-01  0.100760195518      0.102031500113
+  0.103318795750      0.104622283574      0.105942167256      0.107278653031
+  0.108631949728      0.110002268801      0.111389824366      0.112794833232
+  0.114217514934      0.115658091769      0.117116788830      0.118593834041
+  0.120089458193      0.121603894981      0.123137381040      0.124690155978
+  0.126262462420      0.127854546043      0.129466655613      0.131099043025
+  0.132751963343      0.134425674838      0.136120439033      0.137836520737
+  0.139574188092      0.141333712611      0.143115369224      0.144919436319
+  0.146746195784      0.148595933054      0.150468937156      0.152365500748
+  0.154285920174      0.156230495502      0.158199530577      0.160193333064
+  0.162212214499      0.164256490336      0.166326479998      0.168422506925
+  0.170544898625      0.172693986726      0.174870107027      0.177073599552
+  0.179304808601      0.181564082805      0.183851775180      0.186168243183
+  0.188513848766      0.190888958436      0.193293943307      0.195729179164
+  0.198195046517      0.200691930664      0.203220221746      0.205780314815
+  0.208372609891      0.210997512025      0.213655431364      0.216346783211
+  0.219071988098      0.221831471842      0.224625665619      0.227455006027
+  0.230319935156      0.233220900657      0.236158355812      0.239132759605
+  0.242144576791      0.245194277974      0.248282339676      0.251409244412
+  0.254575480767      0.257781543474      0.261027933484      0.264315158055
+  0.267643730820      0.271014171876      0.274427007862      0.277882772039
+  0.281382004380      0.284925251644      0.288513067473      0.292146012469
+  0.295824654287      0.299549567724      0.303321334803      0.307140544873
+  0.311007794690      0.314923688523      0.318888838236      0.322903863392
+  0.326969391348      0.331086057351      0.335254504637      0.339475384535
+  0.343749356567      0.348077088549      0.352459256697      0.356896545736
+  0.361389648999      0.365939268545      0.370546115259      0.375210908971
+  0.379934378565      0.384717262093      0.389560306889      0.394464269689
+  0.399429916748      0.404458023958      0.409549376970      0.414704771320
+  0.419925012548      0.425210916327      0.430563308590      0.435983025661
+  0.441470914379      0.447027832241      0.452654647524      0.458352239430
+  0.464121498221      0.469963325353      0.475878633625      0.481868347315
+  0.487933402329      0.494074746343      0.500293338955      0.506590151834
+  0.512966168867      0.519422386322      0.525959812996      0.532579470374
+  0.539282392792      0.546069627594      0.552942235301      0.559901289770
+  0.566947878369      0.574083102141      0.581308075980      0.588623928802
+  0.596031803724      0.603532858242      0.611128264410      0.618819209027
+  0.626606893818      0.634492535625      0.642477366596      0.650562634375
+  0.658749602304      0.667039549612      0.675433771621      0.683933579944
+  0.692540302694      0.701255284690      0.710079887664      0.719015490479
+  0.728063489341      0.737225298018      0.746502348061      0.755896089030
+  0.765407988713      0.775039533366      0.784792227937      0.794667596303
+  0.804667181512      0.814792546019      0.825045271933      0.835426961263
+  0.845939236169      0.856583739215      0.867362133628      0.878276103552
+  0.889327354317      0.900517612705      0.911848627216      0.923322168344
+  0.934940028853      0.946704024058      0.958615992105      0.970677794266
+  0.982891315221      0.995258463357       1.00778117107       1.02046139505
+   1.03330111661       1.04630234199       1.05946710266       1.07279745563
+   1.08629548379       1.09996329625       1.11380302863       1.12781684341
+   1.14200693028       1.15637550647       1.17092481710       1.18565713552
+   1.20057476370       1.21568003255       1.23097530228       1.24646296283
+   1.26214543416       1.27802516670       1.29410464169       1.31038637157
+   1.32687290040       1.34356680424       1.36047069153       1.37758720356
+   1.39491901480       1.41246883339       1.43023940152       1.44823349588
+   1.46645392809       1.48490354512       1.50358522976       1.52250190107
+   1.54165651481       1.56105206393       1.58069157903       1.60057812881
+   1.62071482060       1.64110480079       1.66175125536       1.68265741035
+   1.70382653241       1.72526192924       1.74696695017       1.76894498665
+   1.79119947280       1.81373388593       1.83655174708       1.85965662159
+   1.88305211964       1.90674189684       1.93072965474       1.95501914150
+   1.97961415239       2.00451853043       2.02973616699       2.05527100237
+   2.08112702643       2.10730827924       2.13381885167       2.16066288605
+   2.18784457681       2.21536817116       2.24323796970       2.27145832716
+   2.30003365301       2.32896841222       2.35826712589       2.38793437201
+   2.41797478615       2.44839306218       2.47919395302       2.51038227138
+   2.54196289048       2.57394074488       2.60632083116       2.63910820880
+   2.67230800087       2.70592539492       2.73996564373       2.77443406616
+   2.80933604797       2.84467704267       2.88046257236       2.91669822860
+   2.95338967328       2.99054263952       3.02816293255       3.06625643062
+   3.10482908590       3.14388692546       3.18343605215       3.22348264563
+   3.26403296324       3.30509334105       3.34667019483       3.38877002106
+   3.43139939791       3.47456498631       3.51827353097       3.56253186145
+   3.60734689319       3.65272562863       3.69867515830       3.74520266190
+   3.79231540945       3.84002076242       3.88832617485       3.93723919457
+   3.98676746434       4.03691872305       4.08770080694       4.13912165081
+   4.19118928928       4.24391185801       4.29729759502       4.35135484193
+   4.40609204530       4.46151775793       4.51764064021       4.57446946144
+   4.63201310124       4.69028055093       4.74928091491       4.80902341211
+   4.86951737741       4.93077226313       4.99279764046       5.05560320099
+   5.11919875822       5.18359424908       5.24879973551       5.31482540599
+   5.38168157716       5.44937869544       5.51792733865       5.58733821764
+   5.65762217801       5.72879020177       5.80085340907       5.87382305993
+   5.94771055600       6.02252744237       6.09828540931       6.17499629417
+   6.25267208318       6.33132491333       6.41096707430       6.49161101033
+   6.57326932220       6.65595476919       6.73968027107       6.82445891012
+   6.91030393317       6.99722875368       7.08524695384       7.17437228666
+   7.26461867816       7.35600022952       7.44853121930       7.54222610565
+   7.63709952858       7.73316631227       7.83044146735       7.92894019324
+   8.02867788059       8.12967011361       8.23193267253       8.33548153609
+   8.44033288402       8.54650309955       8.65400877199       8.76286669931
+   8.87309389081       8.98470756969       9.09772517582       9.21216436843
+   9.32804302888       9.44537926344       9.56419140615       9.68449802164
+   9.80631790805       9.92967010001       10.0545738715       10.1810487391
+   10.3091144647       10.4387910587       10.5700987836       10.7030581563
+   10.8376899520       10.9740152072       11.1120552230       11.2518315685
+   11.3933660840       11.5366808846       11.6817983634       11.8287411953
+   11.9775323406       12.1281950481       12.2807528591       12.4352296112
+   12.5916494416       12.7500367913       12.9104164086       13.0728133531
+   13.2372529997       13.4037610425       13.5723634986       13.7430867125
+   13.9159573601       14.0910024527       14.2682493416       14.4477257219
+   14.6294596371       14.8134794836       14.9998140148       15.1884923458
+   15.3795439581       15.5729987039       15.7688868108       15.9672388867
+   16.1680859247       16.3714593073       16.5773908122       16.7859126166
+   16.9970573024       17.2108578613       17.4273477003       17.6465606462
+   17.8685309515       18.0932932995       18.3208828098       18.5513350438
+   18.7846860100       19.0209721701       19.2602304441       19.5024982168
+   19.7478133429       19.9962141534       20.2477394615       20.5024285685
+   20.7603212700       21.0214578625       21.2858791489       21.5536264456
+   21.8247415887       22.0992669405       22.3772453962       22.6587203904
+   22.9437359041       23.2323364717       23.5245671876       23.8204737133
+   24.1201022849       24.4234997200       24.7307134251       25.0417914028
+   25.3567822598       25.6757352141       25.9987001026       26.3257273893
+   26.6568681729       26.9921741948       27.3316978472       27.6754921815
+   28.0236109161       28.3761084454       28.7330398477       29.0944608944
+   29.4604280583       29.8309985223       30.2062301890       30.5861816890
+   30.9709123906       31.3604824086       31.7549526142       32.1543846442
+   32.5588409106       32.9683846106       33.3830797362       33.8029910842
+   34.2281842669       34.6587257214       35.0946827207       35.5361233840
+   35.9831166873       36.4357324741       36.8940414668       37.3581152769
+   37.8280264169       38.3038483114       38.7856553086       39.2735226917
+   39.7675266911       40.2677444958       40.7742542659       41.2871351447
+   41.8064672707       42.3323317907       42.8648108721       43.4039877158
+   43.9499465693       44.5027727398       45.0625526075       45.6293736391
+   46.2033244017       46.7844945760       47.3729749712       47.9688575386
+   48.5722353860       49.1832027924       49.8018552227       50.4282893426
+   51.0626030337       51.7048954089       52.3552668275       53.0138189116
+   53.6806545611       54.3558779705       55.0395946449       55.7319114163
+   56.4329364607       57.1427793146       57.8615508925       58.5893635038
+   59.3263308708       60.0725681461       60.8281919308       61.5933202926
+   62.3680727845       63.1525704631       63.9469359077       64.7512932395
+   65.5657681411       66.3904878757       67.2255813076       68.0711789217
+   68.9274128445       69.7944168641       70.6723264518       71.5612787827
+   72.4614127574       73.3728690237       74.2957899985       75.2303198900
+   76.1766047205       77.1347923488       78.1050324938       79.0874767575
+   80.0822786487       81.0895936073       82.1095790283       83.1423942865
+   84.1882007614       85.2471618623       86.3194430541       87.4052118830
+   88.5046380024       89.6178932000       90.7451514241       91.8865888112
+   93.0423837132       94.2127167253       95.3977707145       96.5977308479
+   97.8127846216       99.0431218904       100.288934897       101.550418302
+   102.827769215       104.121187224       105.430874429       106.757035472
+   108.099877566       109.459610535       110.836446839       112.230601612
+   113.642292693       115.071740662       116.519168873       117.984803490
+   119.468873521
+ Down Pseudopotential follows (l on next line)
+  0
+ -0.509963456940E-04 -0.102634146444E-03 -0.154921470755E-03 -0.207866488619E-03
+ -0.261477472795E-03 -0.315762800099E-03 -0.370730952715E-03 -0.426390519517E-03
+ -0.482750197416E-03 -0.539818792714E-03 -0.597605222483E-03 -0.656118515957E-03
+ -0.715367815943E-03 -0.775362380249E-03 -0.836111583133E-03 -0.897624916764E-03
+ -0.959911992709E-03 -0.102298254343E-02 -0.108684642381E-02 -0.115151361269E-02
+ -0.121699421442E-02 -0.128329846047E-02 -0.135043671097E-02 -0.141841945639E-02
+ -0.148725731915E-02 -0.155696105527E-02 -0.162754155607E-02 -0.169900984987E-02
+ -0.177137710369E-02 -0.184465462504E-02 -0.191885386363E-02 -0.199398641322E-02
+ -0.207006401336E-02 -0.214709855130E-02 -0.222510206379E-02 -0.230408673900E-02
+ -0.238406491838E-02 -0.246504909864E-02 -0.254705193366E-02 -0.263008623649E-02
+ -0.271416498136E-02 -0.279930130567E-02 -0.288550851207E-02 -0.297280007055E-02
+ -0.306118962051E-02 -0.315069097292E-02 -0.324131811248E-02 -0.333308519975E-02
+ -0.342600657346E-02 -0.352009675266E-02 -0.361537043903E-02 -0.371184251918E-02
+ -0.380952806695E-02 -0.390844234579E-02 -0.400860081115E-02 -0.411001911287E-02
+ -0.421271309762E-02 -0.431669881143E-02 -0.442199250211E-02 -0.452861062189E-02
+ -0.463656982989E-02 -0.474588699481E-02 -0.485657919750E-02 -0.496866373366E-02
+ -0.508215811655E-02 -0.519708007970E-02 -0.531344757970E-02 -0.543127879899E-02
+ -0.555059214872E-02 -0.567140627161E-02 -0.579374004488E-02 -0.591761258316E-02
+ -0.604304324154E-02 -0.617005161854E-02 -0.629865755918E-02 -0.642888115810E-02
+ -0.656074276270E-02 -0.669426297629E-02 -0.682946266133E-02 -0.696636294270E-02
+ -0.710498521097E-02 -0.724535112577E-02 -0.738748261916E-02 -0.753140189904E-02
+ -0.767713145267E-02 -0.782469405011E-02 -0.797411274786E-02 -0.812541089238E-02
+ -0.827861212381E-02 -0.843374037960E-02 -0.859081989830E-02 -0.874987522332E-02
+ -0.891093120675E-02 -0.907401301329E-02 -0.923914612414E-02 -0.940635634098E-02
+ -0.957566979004E-02 -0.974711292612E-02 -0.992071253679E-02 -0.100964957465E-01
+ -0.102744900209E-01 -0.104547231711E-01 -0.106372233579E-01 -0.108220190965E-01
+ -0.110091392604E-01 -0.111986130866E-01 -0.113904701797E-01 -0.115847405166E-01
+ -0.117814544512E-01 -0.119806427193E-01 -0.121823364431E-01 -0.123865671364E-01
+ -0.125933667093E-01 -0.128027674732E-01 -0.130148021458E-01 -0.132295038564E-01
+ -0.134469061511E-01 -0.136670429976E-01 -0.138899487910E-01 -0.141156583589E-01
+ -0.143442069671E-01 -0.145756303247E-01 -0.148099645901E-01 -0.150472463762E-01
+ -0.152875127566E-01 -0.155308012710E-01 -0.157771499314E-01 -0.160265972278E-01
+ -0.162791821340E-01 -0.165349441143E-01 -0.167939231292E-01 -0.170561596418E-01
+ -0.173216946238E-01 -0.175905695625E-01 -0.178628264668E-01 -0.181385078740E-01
+ -0.184176568561E-01 -0.187003170271E-01 -0.189865325492E-01 -0.192763481401E-01
+ -0.195698090800E-01 -0.198669612181E-01 -0.201678509807E-01 -0.204725253776E-01
+ -0.207810320098E-01 -0.210934190770E-01 -0.214097353849E-01 -0.217300303531E-01
+ -0.220543540224E-01 -0.223827570631E-01 -0.227152907825E-01 -0.230520071333E-01
+ -0.233929587212E-01 -0.237381988137E-01 -0.240877813478E-01 -0.244417609389E-01
+ -0.248001928891E-01 -0.251631331960E-01 -0.255306385611E-01 -0.259027663989E-01
+ -0.262795748460E-01 -0.266611227699E-01 -0.270474697781E-01 -0.274386762278E-01
+ -0.278348032350E-01 -0.282359126841E-01 -0.286420672375E-01 -0.290533303457E-01
+ -0.294697662566E-01 -0.298914400262E-01 -0.303184175281E-01 -0.307507654644E-01
+ -0.311885513754E-01 -0.316318436508E-01 -0.320807115401E-01 -0.325352251632E-01
+ -0.329954555215E-01 -0.334614745091E-01 -0.339333549239E-01 -0.344111704788E-01
+ -0.348949958134E-01 -0.353849065056E-01 -0.358809790831E-01 -0.363832910358E-01
+ -0.368919208276E-01 -0.374069479085E-01 -0.379284527273E-01 -0.384565167439E-01
+ -0.389912224421E-01 -0.395326533423E-01 -0.400808940147E-01 -0.406360300924E-01
+ -0.411981482847E-01 -0.417673363906E-01 -0.423436833124E-01 -0.429272790700E-01
+ -0.435182148140E-01 -0.441165828409E-01 -0.447224766068E-01 -0.453359907422E-01
+ -0.459572210666E-01 -0.465862646036E-01 -0.472232195957E-01 -0.478681855199E-01
+ -0.485212631031E-01 -0.491825543375E-01 -0.498521624967E-01 -0.505301921518E-01
+ -0.512167491876E-01 -0.519119408189E-01 -0.526158756074E-01 -0.533286634785E-01
+ -0.540504157381E-01 -0.547812450905E-01 -0.555212656553E-01 -0.562705929854E-01
+ -0.570293440851E-01 -0.577976374278E-01 -0.585755929749E-01 -0.593633321941E-01
+ -0.601609780783E-01 -0.609686551650E-01 -0.617864895549E-01 -0.626146089324E-01
+ -0.634531425845E-01 -0.643022214215E-01 -0.651619779970E-01 -0.660325465285E-01
+ -0.669140629181E-01 -0.678066647739E-01 -0.687104914307E-01 -0.696256839722E-01
+ -0.705523852525E-01 -0.714907399183E-01 -0.724408944313E-01 -0.734029970908E-01
+ -0.743771980567E-01 -0.753636493726E-01 -0.763625049896E-01 -0.773739207896E-01
+ -0.783980546099E-01 -0.794350662673E-01 -0.804851175828E-01 -0.815483724066E-01
+ -0.826249966433E-01 -0.837151582778E-01 -0.848190274009E-01 -0.859367762354E-01
+ -0.870685791632E-01 -0.882146127517E-01 -0.893750557809E-01 -0.905500892714E-01
+ -0.917398965120E-01 -0.929446630876E-01 -0.941645769084E-01 -0.953998282380E-01
+ -0.966506097235E-01 -0.979171164243E-01 -0.991995458425E-01 -0.100498097953
+ -0.101812975234     -0.103144382699     -0.104492527927     -0.105857621095
+ -0.107239875010     -0.108639505140     -0.110056729651     -0.111491769437
+ -0.112944848153     -0.114416192253     -0.115906031019     -0.117414596604
+ -0.118942124059     -0.120488851372     -0.122055019506     -0.123640872436
+ -0.125246657180     -0.126872623845     -0.128519025657     -0.130186119007
+ -0.131874163482     -0.133583421913     -0.135314160405     -0.137066648387
+ -0.138841158644     -0.140637967366     -0.142457354182     -0.144299602210
+ -0.146164998091     -0.148053832042     -0.149966397889     -0.151902993120
+ -0.153863918924     -0.155849480240     -0.157859985798     -0.159895748171
+ -0.161957083817     -0.164044313127     -0.166157760473     -0.168297754260
+ -0.170464626968     -0.172658715207     -0.174880359762     -0.177129905650
+ -0.179407702163     -0.181714102927     -0.184049465950     -0.186414153674
+ -0.188808533031     -0.191232975496     -0.193687857140     -0.196173558687
+ -0.198690465568     -0.201238967977     -0.203819460931     -0.206432344324
+ -0.209078022984     -0.211756906736     -0.214469410458     -0.217215954143
+ -0.219996962955     -0.222812867296     -0.225664102864     -0.228551110716
+ -0.231474337331     -0.234434234673     -0.237431260258     -0.240465877216
+ -0.243538554355     -0.246649766233     -0.249799993218     -0.252989721561
+ -0.256219443460     -0.259489657132     -0.262800866878     -0.266153583159
+ -0.269548322662     -0.272985608372     -0.276465969646     -0.279989942284
+ -0.283558068603     -0.287170897510     -0.290828984578     -0.294532892120
+ -0.298283189266     -0.302080452038     -0.305925263429     -0.309818213481
+ -0.313759899360     -0.317750925442     -0.321791903384     -0.325883452212
+ -0.330026198398     -0.334220775945     -0.338467826465     -0.342767999266
+ -0.347121951432     -0.351530347913     -0.355993861602     -0.360513173428
+ -0.365088972438     -0.369721955885     -0.374412829313     -0.379162306650
+ -0.383971110293     -0.388839971197     -0.393769628965     -0.398760831941
+ -0.403814337298     -0.408930911130     -0.414111328545     -0.419356373756
+ -0.424666840178     -0.430043530515     -0.435487256863     -0.440998840797
+ -0.446579113471     -0.452228915711     -0.457949098116     -0.463740521150
+ -0.469604055241     -0.475540580880     -0.481550988721     -0.487636179676
+ -0.493797065017     -0.500034566477     -0.506349616348     -0.512743157585
+ -0.519216143905     -0.525769539891     -0.532404321093     -0.539121474135
+ -0.545921996812     -0.552806898203     -0.559777198767     -0.566833930455
+ -0.573978136814     -0.581210873091     -0.588533206345     -0.595946215551
+ -0.603450991711     -0.611048637962     -0.618740269686     -0.626527014622
+ -0.634410012976     -0.642390417535     -0.650469393779     -0.658648119997
+ -0.666927787401     -0.675309600241     -0.683794775928     -0.692384545146
+ -0.701080151976     -0.709882854020     -0.718793922516     -0.727814642473
+ -0.736946312788     -0.746190246381     -0.755547770321     -0.765020225962
+ -0.774608969074     -0.784315369983     -0.794140813711     -0.804086700114
+ -0.814154444034     -0.824345475445     -0.834661239604     -0.845103197211
+ -0.855672824563     -0.866371613728     -0.877201072704     -0.888162725599
+ -0.899258112812     -0.910488791213     -0.921856334335     -0.933362332577
+ -0.945008393402     -0.956796141553     -0.968727219272     -0.980803286528
+ -0.993026021255      -1.00539711960      -1.01791829617      -1.03059128433
+  -1.04341783644      -1.05639972418      -1.06953873885      -1.08283669168
+  -1.09629541416      -1.10991675841      -1.12370259754      -1.13765482604
+  -1.15177536015      -1.16606613833      -1.18052912170      -1.19516629447
+  -1.20997966449      -1.22497126371      -1.24014314878      -1.25549740159
+  -1.27103612988      -1.28676146791      -1.30267557708      -1.31878064668
+  -1.33507889462      -1.35157256821      -1.36826394504      -1.38515533377
+  -1.40224907513      -1.41954754288      -1.43705314480      -1.45476832382
+  -1.47269555917      -1.49083736755      -1.50919630444      -1.52777496543
+  -1.54657598767      -1.56560205135      -1.58485588129      -1.60434024861
+  -1.62405797252      -1.64401192217      -1.66420501861      -1.68464023689
+  -1.70532060823      -1.72624922236      -1.74742922997      -1.76886384524
+  -1.79055634862      -1.81251008966      -1.83472849008      -1.85721504692
+  -1.87997333594      -1.90300701517      -1.92631982867      -1.94991561046
+  -1.97379828872      -1.99797189017      -2.02244054469      -2.04720849023
+  -2.07228007795      -2.09765977763      -2.12335218338      -2.14936201968
+  -2.17569414770      -2.20235357195      -2.22934544733      -2.25667508652
+  -2.28434796772      -2.31236974284      -2.34074624612      -2.36948350314
+  -2.39858774033      -2.42806539495      -2.45792312556      -2.48816782306
+  -2.51880662219      -2.54984691371      -2.58129635706      -2.61316289371
+  -2.64545476115      -2.67818050745      -2.71134900665      -2.74496947473
+  -2.77905148638      -2.81360499253      -2.84864033862      -2.88416828371
+  -2.92020002042      -2.95674719565      -2.99382193223      -3.03143685146
+  -3.06960509647      -3.10834035656      -3.14765689244      -3.18756956235
+  -3.22809384921      -3.26924588860      -3.31104249771      -3.35350120515
+  -3.39664028177      -3.44047877216      -3.48503652714      -3.53033423697
+  -3.57639346526      -3.62323668358      -3.67088730667      -3.71936972808
+  -3.76870935623      -3.81893265072      -3.87006715870      -3.92214155122
+  -3.97518565925      -4.02923050928      -4.08430835808      -4.14045272658
+  -4.19769843225      -4.25608161987      -4.31563979020      -4.37641182606
+  -4.43843801542      -4.50176007086      -4.56642114493      -4.63246584053
+  -4.69994021589      -4.76889178298      -4.83936949881      -4.91142374842
+  -4.98510631871      -5.06047036180      -5.13757034680      -5.21646199863
+  -5.29720222254      -5.37984901255      -5.46446134253      -5.55109903772
+  -5.63982262528      -5.73069316138      -5.82377203314      -5.91912073290
+  -6.01680060266      -6.11687254605      -6.21939670555      -6.32443210208
+  -6.43203623445      -6.54226463581      -6.65517038444      -6.77080356605
+  -6.88921068497      -7.01043402158      -7.13451093340      -7.26147309781
+  -7.39134569422      -7.52414652409      -7.65988506761      -7.79856147645
+  -7.94016550254      -8.08467536367      -8.23205654783      -8.38226055895
+  -8.53522360846      -8.69086525803      -8.84908702107      -9.00977093205
+  -9.17277809511      -9.33794722563      -9.50509320130      -9.67400564173
+  -9.84444753941      -10.0161539674      -10.1888308937      -10.3621541351
+  -10.5357684882      -10.7092870792      -10.8822909771      -11.0543291217
+  -11.2249186187      -11.3935454614      -11.5596657377      -11.7227073896
+  -11.8820725888      -12.0371407975      -12.1872725811      -12.3318142397
+  -12.4701033204      -12.6014750682      -12.7252698647      -12.8408416934
+  -12.9475676562      -13.0448585471      -13.1321704666      -13.2090174345
+  -13.2749849240      -13.3297442018      -13.3730673130      -13.4048424934
+  -13.4250897301      -13.4339761149      -13.4318305467      -13.4191572353
+  -13.3966473367      -13.3651879005      -13.3258671354      -13.2799747857
+  -13.2289961501      -13.1745979652      -13.1186039852      -13.0629576305
+  -13.0096685053      -12.9607389058      -12.9180656198      -12.8833113546
+  -12.8577389917      -12.8420005615      -12.8358713349      -12.8379177470
+  -12.8450859718      -12.8532803656      -12.8615173540      -12.8697960582
+  -12.8781156803      -12.8864755169      -12.8948749529      -12.9033134605
+  -12.9117905957      -12.9203059960      -12.9288593766      -12.9374505273
+  -12.9460793084      -12.9547456469      -12.9634495320      -12.9721910112
+  -12.9809701846      -12.9897872010      -12.9986422521      -13.0075355674
+  -13.0164674085      -13.0254380638      -13.0344478423      -13.0434970680
+  -13.0525860735      -13.0617151941      -13.0708847616      -13.0800950979
+  -13.0893465087      -13.0986392776      -13.1079736593      -13.1173498735
+  -13.1267680989      -13.1362284672      -13.1457310565      -13.1552758862
+  -13.1648629106      -13.1744920137      -13.1841630038      -13.1938756080
+  -13.2036294677      -13.2134241334      -13.2232590607      -13.2331336055
+  -13.2430470206      -13.2529984519      -13.2629869350      -13.2730113923
+  -13.2830706303      -13.2931633374      -13.3032880817      -13.3134433096
+  -13.3236273445      -13.3338383858      -13.3440745088      -13.3543336640
+  -13.3646136776      -13.3749122524      -13.3852269682      -13.3955552837
+  -13.4058945380      -13.4162419524      -13.4265946335      -13.4369495754
+  -13.4473036631      -13.4576536758      -13.4679962909      -13.4783280882
+  -13.4886455539      -13.4989450857      -13.5092229977      -13.5194755257
+  -13.5296988327      -13.5398890148      -13.5500421072      -13.5601540907
+  -13.5702208977      -13.5802384196      -13.5902025131      -13.6001090078
+  -13.6099537130      -13.6197324257      -13.6294409376      -13.6390750431
+  -13.6486305471      -13.6581032730      -13.6674890706      -13.6767838240
+  -13.6859834604      -13.6950839573      -13.7040813519      -13.7129717482
+  -13.7217513259      -13.7304163486      -13.7389631714      -13.7473882496
+  -13.7556881462      -13.7638595400      -13.7718992333      -13.7798041594
+  -13.7875713899      -13.7951981419      -13.8026817849      -13.8100198476
+  -13.8172100237      -13.8242501784      -13.8311383539      -13.8378727742
+  -13.8444518505      -13.8508741853      -13.8571385761      -13.8632440189
+  -13.8691897111      -13.8749750536      -13.8805996526      -13.8860633207
+  -13.8913660770      -13.8965081476      -13.9014899642      -13.9063121627
+  -13.9109755812      -13.9154812575      -13.9198304247      -13.9240245082
+  -13.9280651201      -13.9319540542      -13.9356932798      -13.9392849355
+  -13.9427313215      -13.9460348924      -13.9491982486      -13.9522241283
+  -13.9551153977      -13.9578750423      -13.9605061569      -13.9630119354
+  -13.9653956611      -13.9676606959      -13.9698104701      -13.9718484717
+  -13.9737782362      -13.9756033356      -13.9773273687      -13.9789539502
+  -13.9804867014      -13.9819292398      -13.9832851702      -13.9845580754
+  -13.9857515074      -13.9868689792      -13.9879139569      -13.9888898526
+  -13.9898000169      -13.9906477334      -13.9914362119      -13.9921685840
+  -13.9928478980      -13.9934771144      -13.9940591030      -13.9945966390
+  -13.9950924013      -13.9955489697      -13.9959688240      -13.9963543426
+  -13.9967078021      -13.9970313772      -13.9973271412      -13.9975970663
+  -13.9978430254      -13.9980667928      -13.9982700464      -13.9984543698
+  -13.9986212543      -13.9987721017      -13.9989082269      -13.9994850685
+  -13.9997594598      -13.9998887256      -13.9999490294      -13.9999768842
+  -13.9999896221      -13.9999953883      -13.9999979718      -13.9999991173
+  -13.9999996199      -13.9999998381      -13.9999999318      -13.9999999716
+  -13.9999999883      -13.9999999952      -13.9999999981      -13.9999999992
+  -13.9999999997      -13.9999999999      -14.0000000000      -14.0000000000
+  -14.0000000000      -14.0000000000      -14.0000000000      -14.0000000000
+  -14.0000000000
+  1
+ -0.147553840932E-03 -0.296963680695E-03 -0.448252864873E-03 -0.601445032701E-03
+ -0.756564120759E-03 -0.913634366711E-03 -0.107268031309E-02 -0.123372681115E-02
+ -0.139679902470E-02 -0.156192243412E-02 -0.172912284025E-02 -0.189842636848E-02
+ -0.206985947283E-02 -0.224344894004E-02 -0.241922189381E-02 -0.259720579901E-02
+ -0.277742846596E-02 -0.295991805480E-02 -0.314470307988E-02 -0.333181241423E-02
+ -0.352127529402E-02 -0.371312132320E-02 -0.390738047807E-02 -0.410408311199E-02
+ -0.430325996014E-02 -0.450494214425E-02 -0.470916117756E-02 -0.491594896967E-02
+ -0.512533783156E-02 -0.533736048063E-02 -0.555205004581E-02 -0.576944007275E-02
+ -0.598956452903E-02 -0.621245780951E-02 -0.643815474166E-02 -0.666669059105E-02
+ -0.689810106682E-02 -0.713242232726E-02 -0.736969098550E-02 -0.760994411518E-02
+ -0.785321925629E-02 -0.809955442100E-02 -0.834898809960E-02 -0.860155926655E-02
+ -0.885730738653E-02 -0.911627242063E-02 -0.937849483257E-02 -0.964401559506E-02
+ -0.991287619616E-02 -0.101851186458E-01 -0.104607854823E-01 -0.107399197791E-01
+ -0.110225651513E-01 -0.113087657628E-01 -0.115985663329E-01 -0.118920121434E-01
+ -0.121891490456E-01 -0.124900234677E-01 -0.127946824217E-01 -0.131031735112E-01
+ -0.134155449382E-01 -0.137318455113E-01 -0.140521246530E-01 -0.143764324073E-01
+ -0.147048194478E-01 -0.150373370854E-01 -0.153740372765E-01 -0.157149726310E-01
+ -0.160601964205E-01 -0.164097625867E-01 -0.167637257497E-01 -0.171221412169E-01
+ -0.174850649909E-01 -0.178525537793E-01 -0.182246650024E-01 -0.186014568033E-01
+ -0.189829880560E-01 -0.193693183753E-01 -0.197605081257E-01 -0.201566184310E-01
+ -0.205577111840E-01 -0.209638490558E-01 -0.213750955058E-01 -0.217915147918E-01
+ -0.222131719797E-01 -0.226401329537E-01 -0.230724644270E-01 -0.235102339517E-01
+ -0.239535099297E-01 -0.244023616231E-01 -0.248568591656E-01 -0.253170735725E-01
+ -0.257830767528E-01 -0.262549415197E-01 -0.267327416024E-01 -0.272165516575E-01
+ -0.277064472805E-01 -0.282025050178E-01 -0.287048023788E-01 -0.292134178476E-01
+ -0.297284308955E-01 -0.302499219935E-01 -0.307779726247E-01 -0.313126652971E-01
+ -0.318540835565E-01 -0.324023119997E-01 -0.329574362872E-01 -0.335195431574E-01
+ -0.340887204393E-01 -0.346650570668E-01 -0.352486430925E-01 -0.358395697014E-01
+ -0.364379292258E-01 -0.370438151590E-01 -0.376573221704E-01 -0.382785461203E-01
+ -0.389075840744E-01 -0.395445343195E-01 -0.401894963787E-01 -0.408425710268E-01
+ -0.415038603060E-01 -0.421734675422E-01 -0.428514973608E-01 -0.435380557032E-01
+ -0.442332498432E-01 -0.449371884041E-01 -0.456499813753E-01 -0.463717401295E-01
+ -0.471025774404E-01 -0.478426075001E-01 -0.485919459369E-01 -0.493507098336E-01
+ -0.501190177454E-01 -0.508969897188E-01 -0.516847473102E-01 -0.524824136048E-01
+ -0.532901132360E-01 -0.541079724048E-01 -0.549361188994E-01 -0.557746821152E-01
+ -0.566237930754E-01 -0.574835844508E-01 -0.583541905809E-01 -0.592357474950E-01
+ -0.601283929332E-01 -0.610322663681E-01 -0.619475090263E-01 -0.628742639107E-01
+ -0.638126758230E-01 -0.647628913858E-01 -0.657250590661E-01 -0.666993291980E-01
+ -0.676858540063E-01 -0.686847876306E-01 -0.696962861489E-01 -0.707205076023E-01
+ -0.717576120196E-01 -0.728077614423E-01 -0.738711199496E-01 -0.749478536848E-01
+ -0.760381308803E-01 -0.771421218846E-01 -0.782599991885E-01 -0.793919374522E-01
+ -0.805381135326E-01 -0.816987065107E-01 -0.828738977199E-01 -0.840638707741E-01
+ -0.852688115963E-01 -0.864889084478E-01 -0.877243519578E-01 -0.889753351524E-01
+ -0.902420534856E-01 -0.915247048695E-01 -0.928234897050E-01 -0.941386109133E-01
+ -0.954702739676E-01 -0.968186869249E-01 -0.981840604591E-01 -0.995666078932E-01
+ -0.100966545233     -0.102384091200     -0.103819467269     -0.105272897695
+ -0.106744609558     -0.108234832791     -0.109743800220     -0.111271747596
+ -0.112818913639     -0.114385540066     -0.115971871638     -0.117578156190
+ -0.119204644677     -0.120851591208     -0.122519253086     -0.124207890852
+ -0.125917768321     -0.127649152627     -0.129402314261     -0.131177527118
+ -0.132975068535     -0.134795219336     -0.136638263876     -0.138504490086
+ -0.140394189518     -0.142307657388     -0.144245192626     -0.146207097918
+ -0.148193679757     -0.150205248490     -0.152242118364     -0.154304607579
+ -0.156393038334     -0.158507736881     -0.160649033569     -0.162817262906
+ -0.165012763600     -0.167235878621     -0.169486955249     -0.171766345128
+ -0.174074404327     -0.176411493386     -0.178777977381     -0.181174225974
+ -0.183600613477     -0.186057518905     -0.188545326037     -0.191064423477
+ -0.193615204712     -0.196198068177     -0.198813417313     -0.201461660632
+ -0.204143211780     -0.206858489603     -0.209607918210     -0.212391927040
+ -0.215210950929     -0.218065430178     -0.220955810620     -0.223882543692
+ -0.226846086501     -0.229846901902     -0.232885458563     -0.235962231041
+ -0.239077699856     -0.242232351566     -0.245426678843     -0.248661180545
+ -0.251936361802     -0.255252734087     -0.258610815298     -0.262011129840
+ -0.265454208706     -0.268940589558     -0.272470816811     -0.276045441719
+ -0.279665022460     -0.283330124219     -0.287041319284     -0.290799187127
+ -0.294604314497     -0.298457295512     -0.302358731750     -0.306309232342
+ -0.310309414068     -0.314359901450     -0.318461326854     -0.322614330579
+ -0.326819560968     -0.331077674499     -0.335389335890     -0.339755218203
+ -0.344176002947     -0.348652380185     -0.353185048637     -0.357774715794
+ -0.362422098023     -0.367127920678     -0.371892918214     -0.376717834302
+ -0.381603421939     -0.386550443569     -0.391559671198     -0.396631886516
+ -0.401767881013     -0.406968456108     -0.412234423266     -0.417566604127
+ -0.422965830632     -0.428432945150     -0.433968800611     -0.439574260632
+ -0.445250199657     -0.450997503085     -0.456817067410     -0.462709800359
+ -0.468676621030     -0.474718460032     -0.480836259634     -0.487030973901
+ -0.493303568849     -0.499655022587     -0.506086325470     -0.512598480249
+ -0.519192502229     -0.525869419417     -0.532630272686     -0.539476115933
+ -0.546408016236     -0.553427054022     -0.560534323231     -0.567730931479
+ -0.575018000233     -0.582396664979     -0.589868075392     -0.597433395518
+ -0.605093803945     -0.612850493985     -0.620704673854     -0.628657566859
+ -0.636710411578     -0.644864462052     -0.653120987973     -0.661481274880
+ -0.669946624345     -0.678518354181     -0.687197798632     -0.695986308577
+ -0.704885251737     -0.713896012875     -0.723019994010     -0.732258614625
+ -0.741613311879     -0.751085540825     -0.760676774628     -0.770388504785
+ -0.780222241346     -0.790179513142     -0.800261868015     -0.810470873042
+ -0.820808114777     -0.831275199478     -0.841873753354     -0.852605422799
+ -0.863471874640     -0.874474796382     -0.885615896458     -0.896896904481
+ -0.908319571495     -0.919885670239     -0.931596995403     -0.943455363891
+ -0.955462615086     -0.967620611124     -0.979931237158     -0.992396401638
+  -1.00501803659      -1.01779809788      -1.03073856552      -1.04384144394
+  -1.05710876228      -1.07054257469      -1.08414496061      -1.09791802506
+  -1.11186389898      -1.12598473949      -1.14028273024      -1.15476008166
+  -1.16941903134      -1.18426184429      -1.19929081330      -1.21450825923
+  -1.22991653136      -1.24551800770      -1.26131509532      -1.27731023071
+  -1.29350588007      -1.30990453970      -1.32650873632      -1.34332102739
+  -1.36034400151      -1.37758027873      -1.39503251092      -1.41270338214
+  -1.43059560896      -1.44871194086      -1.46705516061      -1.48562808456
+  -1.50443356312      -1.52347448103      -1.54275375782      -1.56227434811
+  -1.58203924208      -1.60205146578      -1.62231408154      -1.64283018838
+  -1.66360292236      -1.68463545700      -1.70593100369      -1.72749281203
+  -1.74932417029      -1.77142840578      -1.79380888525      -1.81646901529
+  -1.83941224276      -1.86264205517      -1.88616198111      -1.90997559061
+  -1.93408649560      -1.95849835032      -1.98321485167      -2.00823973967
+  -2.03357679788      -2.05922985373      -2.08520277904      -2.11149949031
+  -2.13812394923      -2.16508016300      -2.19237218477      -2.22000411405
+  -2.24798009708      -2.27630432721      -2.30498104533      -2.33401454025
+  -2.36340914902      -2.39316925737      -2.42329930007      -2.45380376126
+  -2.48468717481      -2.51595412470      -2.54760924533      -2.57965722183
+  -2.61210279044      -2.64495073875      -2.67820590603      -2.71187318349
+  -2.74595751458      -2.78046389520      -2.81539737397      -2.85076305240
+  -2.88656608514      -2.92281168011      -2.95950509867      -2.99665165575
+  -3.03425671992      -3.07232571353      -3.11086411266      -3.14987744720
+  -3.18937130078      -3.22935131074      -3.26982316798      -3.31079261686
+  -3.35226545498      -3.39424753293      -3.43674475400      -3.47976307384
+  -3.52330850003      -3.56738709159      -3.61200495846      -3.65716826088
+  -3.70288320866      -3.74915606043      -3.79599312275      -3.84340074915
+  -3.89138533907      -3.93995333666      -3.98911122953      -4.03886554732
+  -4.08922286015      -4.14018977695      -4.19177294364      -4.24397904116
+  -4.29681478327      -4.35028691432      -4.40440220666      -4.45916745796
+  -4.51458948830      -4.57067513705      -4.62743125942      -4.68486472290
+  -4.74298240336      -4.80179118083      -4.86129793505      -4.92150954067
+  -4.98243286213      -5.04407474817      -5.10644202596      -5.16954149487
+  -5.23337991974      -5.29796402383      -5.36330048115      -5.42939590845
+  -5.49625685654      -5.56388980118      -5.63230113331      -5.70149714869
+  -5.77148403690      -5.84226786964      -5.91385458833      -5.98624999094
+  -6.05945971801      -6.13348923788      -6.20834383101      -6.28402857331
+  -6.36054831867      -6.43790768025      -6.51611101091      -6.59516238235
+  -6.67506556319      -6.75582399578      -6.83744077170      -6.91991860594
+  -7.00325980972      -7.08746626174      -7.17253937799      -7.25848007995
+  -7.34528876108      -7.43296525167      -7.52150878182      -7.61091794259
+  -7.70119064527      -7.79232407854      -7.88431466369      -7.97715800760
+  -8.07084885362      -8.16538103011      -8.26074739666      -8.35693978800
+  -8.45394895534      -8.55176450533      -8.65037483640      -8.74976707251
+  -8.84992699435      -8.95083896777      -9.05248586963      -9.15484901090
+  -9.25790805714      -9.36164094622      -9.46602380345      -9.57103085415
+  -9.67663433358      -9.78280439452      -9.88950901239      -9.99671388825
+  -10.1043823497      -10.2124752498      -10.3209508645      -10.4297647885
+  -10.5388698301      -10.6482159051      -10.7577499306      -10.8674157182
+  -10.9771538686      -11.0869016661      -11.1965929758      -11.3061581422
+  -11.4155238916      -11.5246132370      -11.6333453895      -11.7416356734
+  -11.8493954494      -11.9565320445      -12.0629486919      -12.1685444799
+  -12.2732143139      -12.3768488906      -12.4793346872      -12.5805539673
+  -12.6803848052      -12.7787011299      -12.8753727922      -12.9702656556
+  -13.0632417135      -13.1541592365      -13.2428729496      -13.3292342442
+  -13.4130914257      -13.4942900006      -13.5726730043      -13.6480813735
+  -13.7203543654      -13.7893300255      -13.8548457076      -13.9167386482
+  -13.9748465968      -14.0290085051      -14.0790652765      -14.1248605779
+  -14.1662417143      -14.2030605687      -14.2351746060      -14.2624479422
+  -14.2847524776      -14.3019690939      -14.3139889114      -14.3207146062
+  -14.3220617816      -14.3179603910      -14.3083562054      -14.2932123204
+  -14.2725106944      -14.2462537090      -14.2144657414      -14.1771947383
+  -14.1345137768      -14.0865225995      -14.0333491061      -13.9751507860
+  -13.9121160709      -13.8444655876      -13.7724532875      -13.6963674298
+  -13.6165313896      -13.5333042654      -13.4470812523      -13.3582937510
+  -13.2674091751      -13.1749304202      -13.0813949531      -12.9873734777
+  -12.8934681295      -12.8003101485      -12.7085569738      -12.6188887015
+  -12.5320038415      -12.4486143041      -12.3694395450      -12.2951997912
+  -12.2266082722      -12.1643623752      -12.1091336530      -12.0615566145
+  -12.0222162463      -11.9916342338      -11.9702538828      -11.9584237918
+  -11.9563803894      -11.9642295374      -11.9819275162      -12.0092618564
+  -12.0458326643      -12.0910353252      -12.1440457477      -12.2038096624
+  -12.2690378978      -12.3382100492      -12.4095895304      -12.4812536711
+  -12.5511433005      -12.6171371622      -12.6771575499      -12.7293147703
+  -12.7720994702      -12.8046335548      -12.8269924512      -12.8406139161
+  -12.8488115365      -12.8559613184      -12.8631170236      -12.8702781429
+  -12.8774442317      -12.8846149115      -12.8917898663      -12.8989688438
+  -12.9061516551      -12.9133381739      -12.9205283366      -12.9277221421
+  -12.9349196505      -12.9421209833      -12.9493263222      -12.9565359083
+  -12.9637500415      -12.9709690787      -12.9781934332      -12.9854235732
+  -12.9926600198      -12.9999033461      -13.0071541745      -13.0144131757
+  -13.0216810655      -13.0289586036      -13.0362465903      -13.0435458644
+  -13.0508573003      -13.0581818052      -13.0655203160      -13.0728737964
+  -13.0802432332      -13.0876296333      -13.0950340199      -13.1024574292
+  -13.1099009061      -13.1173655009      -13.1248522653      -13.1323622480
+  -13.1398964911      -13.1474560256      -13.1550418674      -13.1626550131
+  -13.1702964355      -13.1779670796      -13.1856678579      -13.1933996468
+  -13.2011632816      -13.2089595524      -13.2167892003      -13.2246529127
+  -13.2325513196      -13.2404849892      -13.2484544243      -13.2564600580
+  -13.2645022504      -13.2725812847      -13.2806973637      -13.2888506065
+  -13.2970410451      -13.3052686218      -13.3135331856      -13.3218344901
+  -13.3301721908      -13.3385458426      -13.3469548977      -13.3553987040
+  -13.3638765031      -13.3723874289      -13.3809305065      -13.3895046510
+  -13.3981086670      -13.4067412478      -13.4154009755      -13.4240863208
+  -13.4327956432      -13.4415271917      -13.4502791056      -13.4590494154
+  -13.4678360443      -13.4766368094      -13.4854494242      -13.4942715002
+  -13.5031005493      -13.5119339867      -13.5207691336      -13.5296032203
+  -13.5384333896      -13.5472567007      -13.5560701327      -13.5648705889
+  -13.5736549010      -13.5824198340      -13.5911620906      -13.5998783164
+  -13.6085651051      -13.6172190036      -13.6258365181      -13.6344141196
+  -13.6429482497      -13.6514353268      -13.6598717524      -13.6682539177
+  -13.6765782094      -13.6848410172      -13.6930387401      -13.7011677930
+  -13.7092246142      -13.7172056717      -13.7251074709      -13.7329265610
+  -13.7406595425      -13.7483030739      -13.7558538791      -13.7633087541
+  -13.7706645741      -13.7779183001      -13.7850669859      -13.7921077846
+  -13.7990379550      -13.8058548680      -13.8125560126      -13.8191390019
+  -13.8256015786      -13.8319416206      -13.8381571458      -13.8442463172
+  -13.8502074469      -13.8560390008      -13.8617396017      -13.8673080333
+  -13.8727432424      -13.8780443419      -13.8832106124      -13.8882415042
+  -13.8931366382      -13.8978958063      -13.9025189716      -13.9070062682
+  -13.9113580000      -13.9155746393      -13.9196568249      -13.9236053596
+  -13.9274212073      -13.9311054895      -13.9346594812      -13.9380846066
+  -13.9413824343      -13.9445546718      -13.9476031601      -13.9505298672
+  -13.9533368818      -13.9560264065      -13.9586007509      -13.9610623237
+  -13.9634136259      -13.9656572422      -13.9677958335      -13.9698321287
+  -13.9717689166      -13.9736090378      -13.9753553759      -13.9770108504
+  -13.9785784073      -13.9800610121      -13.9814616415      -13.9827832756
+  -13.9840288908      -13.9852014522      -13.9863039066      -13.9873391760
+  -13.9883101511      -13.9892196852      -13.9900705888      -13.9908656236
+  -13.9916074985      -13.9922988642      -13.9929423098      -13.9935403591
+  -13.9940954653      -13.9946100102      -13.9950863010      -13.9955265686
+  -13.9959329657      -13.9963075653      -13.9966523597      -13.9969692602
+  -13.9972600965      -13.9975266177      -13.9977704899      -13.9979932982
+  -13.9981965529      -13.9983816828      -13.9985500403      -13.9987029031
+  -13.9988414756      -13.9989668907      -13.9996041124      -13.9998501405
+  -13.9999439704      -13.9999793127      -13.9999924582      -13.9999972857
+  -13.9999990357      -13.9999996619      -13.9999998830      -13.9999999601
+  -13.9999999866      -13.9999999955      -13.9999999985      -13.9999999995
+  -13.9999999998      -14.0000000000      -14.0000000000      -14.0000000000
+  -14.0000000000
+  2
+ -0.109653958533E-03 -0.220687194063E-03 -0.333117055751E-03 -0.446961110985E-03
+ -0.562237148121E-03 -0.678963179266E-03 -0.797157443089E-03 -0.916838407676E-03
+ -0.103802477341E-02 -0.116073547589E-02 -0.128498968891E-02 -0.141080682742E-02
+ -0.153820655060E-02 -0.166720876490E-02 -0.179783362715E-02 -0.193010154775E-02
+ -0.206403319380E-02 -0.219964949238E-02 -0.233697163380E-02 -0.247602107489E-02
+ -0.261681954239E-02 -0.275938903633E-02 -0.290375183345E-02 -0.304993049070E-02
+ -0.319794784878E-02 -0.334782703567E-02 -0.349959147026E-02 -0.365326486602E-02
+ -0.380887123471E-02 -0.396643489008E-02 -0.412598045176E-02 -0.428753284902E-02
+ -0.445111732470E-02 -0.461675943917E-02 -0.478448507430E-02 -0.495432043752E-02
+ -0.512629206589E-02 -0.530042683027E-02 -0.547675193953E-02 -0.565529494476E-02
+ -0.583608374360E-02 -0.601914658461E-02 -0.620451207166E-02 -0.639220916841E-02
+ -0.658226720285E-02 -0.677471587184E-02 -0.696958524581E-02 -0.716690577339E-02
+ -0.736670828624E-02 -0.756902400381E-02 -0.777388453824E-02 -0.798132189930E-02
+ -0.819136849940E-02 -0.840405715862E-02 -0.861942110989E-02 -0.883749400413E-02
+ -0.905830991556E-02 -0.928190334696E-02 -0.950830923512E-02 -0.973756295628E-02
+ -0.996970033164E-02 -0.102047576330E-01 -0.104427715883E-01 -0.106837793876E-01
+ -0.109278186886E-01 -0.111749276228E-01 -0.114251448013E-01 -0.116785093208E-01
+ -0.119350607697E-01 -0.121948392346E-01 -0.124578853061E-01 -0.127242400855E-01
+ -0.129939451909E-01 -0.132670427640E-01 -0.135435754767E-01 -0.138235865374E-01
+ -0.141071196981E-01 -0.143942192612E-01 -0.146849300860E-01 -0.149792975966E-01
+ -0.152773677879E-01 -0.155791872338E-01 -0.158848030936E-01 -0.161942631202E-01
+ -0.165076156667E-01 -0.168249096948E-01 -0.171461947817E-01 -0.174715211284E-01
+ -0.178009395674E-01 -0.181345015703E-01 -0.184722592564E-01 -0.188142654004E-01
+ -0.191605734408E-01 -0.195112374883E-01 -0.198663123343E-01 -0.202258534591E-01
+ -0.205899170412E-01 -0.209585599654E-01 -0.213318398322E-01 -0.217098149665E-01
+ -0.220925444268E-01 -0.224800880145E-01 -0.228725062831E-01 -0.232698605478E-01
+ -0.236722128950E-01 -0.240796261922E-01 -0.244921640972E-01 -0.249098910690E-01
+ -0.253328723769E-01 -0.257611741115E-01 -0.261948631945E-01 -0.266340073894E-01
+ -0.270786753119E-01 -0.275289364408E-01 -0.279848611290E-01 -0.284465206140E-01
+ -0.289139870293E-01 -0.293873334160E-01 -0.298666337334E-01 -0.303519628715E-01
+ -0.308433966621E-01 -0.313410118905E-01 -0.318448863083E-01 -0.323550986445E-01
+ -0.328717286188E-01 -0.333948569531E-01 -0.339245653851E-01 -0.344609366801E-01
+ -0.350040546446E-01 -0.355540041392E-01 -0.361108710918E-01 -0.366747425110E-01
+ -0.372457064997E-01 -0.378238522691E-01 -0.384092701523E-01 -0.390020516184E-01
+ -0.396022892873E-01 -0.402100769435E-01 -0.408255095511E-01 -0.414486832688E-01
+ -0.420796954643E-01 -0.427186447304E-01 -0.433656308994E-01 -0.440207550596E-01
+ -0.446841195705E-01 -0.453558280789E-01 -0.460359855354E-01 -0.467246982104E-01
+ -0.474220737109E-01 -0.481282209971E-01 -0.488432503997E-01 -0.495672736370E-01
+ -0.503004038325E-01 -0.510427555320E-01 -0.517944447222E-01 -0.525555888486E-01
+ -0.533263068334E-01 -0.541067190947E-01 -0.548969475650E-01 -0.556971157102E-01
+ -0.565073485488E-01 -0.573277726719E-01 -0.581585162623E-01 -0.589997091151E-01
+ -0.598514826575E-01 -0.607139699695E-01 -0.615873058051E-01 -0.624716266124E-01
+ -0.633670705558E-01 -0.642737775371E-01 -0.651918892175E-01 -0.661215490397E-01
+ -0.670629022500E-01 -0.680160959216E-01 -0.689812789769E-01 -0.699586022113E-01
+ -0.709482183162E-01 -0.719502819034E-01 -0.729649495286E-01 -0.739923797166E-01
+ -0.750327329851E-01 -0.760861718708E-01 -0.771528609538E-01 -0.782329668840E-01
+ -0.793266584067E-01 -0.804341063890E-01 -0.815554838468E-01 -0.826909659711E-01
+ -0.838407301561E-01 -0.850049560263E-01 -0.861838254650E-01 -0.873775226421E-01
+ -0.885862340435E-01 -0.898101484997E-01 -0.910494572153E-01 -0.923043537991E-01
+ -0.935750342942E-01 -0.948616972083E-01 -0.961645435451E-01 -0.974837768351E-01
+ -0.988196031681E-01 -0.100172231225     -0.101541872309     -0.102928740381
+ -0.104333052092     -0.105755026816     -0.107194886685     -0.108652856623
+ -0.110129164382     -0.111624040578     -0.113137718723     -0.114670435269
+ -0.116222429635     -0.117793944253     -0.119385224602     -0.120996519245
+ -0.122628079871     -0.124280161332     -0.125953021682     -0.127646922220
+ -0.129362127528     -0.131098905514     -0.132857527452     -0.134638268028
+ -0.136441405376     -0.138267221129     -0.140116000456     -0.141988032112
+ -0.143883608480     -0.145803025617     -0.147746583298     -0.149714585069
+ -0.151707338285     -0.153725154168     -0.155768347845     -0.157837238406
+ -0.159932148948     -0.162053406629     -0.164201342713     -0.166376292630
+ -0.168578596021     -0.170808596793     -0.173066643175     -0.175353087767
+ -0.177668287601     -0.180012604190     -0.182386403589     -0.184790056449
+ -0.187223938078     -0.189688428493     -0.192183912488     -0.194710779683
+ -0.197269424595     -0.199860246691     -0.202483650454     -0.205140045446
+ -0.207829846370     -0.210553473132     -0.213311350914     -0.216103910230
+ -0.218931587000     -0.221794822613     -0.224694063999     -0.227629763695
+ -0.230602379917     -0.233612376630     -0.236660223621     -0.239746396570
+ -0.242871377123     -0.246035652970     -0.249239717917     -0.252484071964
+ -0.255769221380     -0.259095678785     -0.262463963225     -0.265874600254
+ -0.269328122016     -0.272825067326     -0.276365981753     -0.279951417703
+ -0.283581934507     -0.287258098504     -0.290980483131     -0.294749669009
+ -0.298566244033     -0.302430803462     -0.306343950013     -0.310306293948
+ -0.314318453176     -0.318381053338     -0.322494727913     -0.326660118307
+ -0.330877873955     -0.335148652420     -0.339473119496     -0.343851949305
+ -0.348285824403     -0.352775435884     -0.357321483489     -0.361924675704
+ -0.366585729878     -0.371305372326     -0.376084338443     -0.380923372814
+ -0.385823229329     -0.390784671296     -0.395808471558     -0.400895412612
+ -0.406046286724     -0.411261896053     -0.416543052770     -0.421890579184
+ -0.427305307862     -0.432788081760     -0.438339754346     -0.443961189733
+ -0.449653262804     -0.455416859351     -0.461252876201     -0.467162221358
+ -0.473145814133     -0.479204585287     -0.485339477168     -0.491551443854
+ -0.497841451294     -0.504210477454     -0.510659512463     -0.517189558759
+ -0.523801631241     -0.530496757419     -0.537275977566     -0.544140344876
+ -0.551090925614     -0.558128799281     -0.565255058768     -0.572470810522
+ -0.579777174705     -0.587175285365     -0.594666290597     -0.602251352713
+ -0.609931648417     -0.617708368971     -0.625582720374     -0.633555923536
+ -0.641629214457     -0.649803844406     -0.658081080104     -0.666462203905
+ -0.674948513986     -0.683541324532     -0.692241965924     -0.701051784935
+ -0.709972144918     -0.719004426008     -0.728150025312     -0.737410357116
+ -0.746786853080     -0.756280962445     -0.765894152240     -0.775627907485
+ -0.785483731404     -0.795463145635     -0.805567690446     -0.815798924949
+ -0.826158427316     -0.836647795003     -0.847268644970     -0.858022613903
+ -0.868911358446     -0.879936555422     -0.891099902067     -0.902403116264
+ -0.913847936775     -0.925436123476     -0.937169457601     -0.949049741978
+ -0.961078801272     -0.973258482233     -0.985590653940     -0.998077208053
+  -1.01072005906      -1.02352114453      -1.03648242538      -1.04960588611
+  -1.06289353507      -1.07634740476      -1.08996955201      -1.10376205834
+  -1.11772703014      -1.13186659901      -1.14618292198      -1.16067818182
+  -1.17535458729      -1.19021437343      -1.20525980182      -1.22049316088
+  -1.23591676615      -1.25153296056      -1.26734411472      -1.28335262723
+  -1.29956092492      -1.31597146319      -1.33258672627      -1.34940922752
+  -1.36644150974      -1.38368614543      -1.40114573713      -1.41882291769
+  -1.43672035057      -1.45484073015      -1.47318678204      -1.49176126336
+  -1.51056696305      -1.52960670218      -1.54888333426      -1.56839974553
+  -1.58815885526      -1.60816361609      -1.62841701431      -1.64892207015
+  -1.66968183813      -1.69069940733      -1.71197790170      -1.73352048038
+  -1.75533033800      -1.77741070497      -1.79976484779      -1.82239606935
+  -1.84530770923      -1.86850314399      -1.89198578749      -1.91575909114
+  -1.93982654423      -1.96419167420      -1.98885804689      -2.01382926690
+  -2.03910897779      -2.06470086238      -2.09060864303      -2.11683608186
+  -2.14338698104      -2.17026518304      -2.19747457083      -2.22501906817
+  -2.25290263978      -2.28112929158      -2.30970307092      -2.33862806672
+  -2.36790840970      -2.39754827251      -2.42755186993      -2.45792345900
+  -2.48866733910      -2.51978785213      -2.55128938256      -2.58317635750
+  -2.61545324678      -2.64812456294      -2.68119486126      -2.71466873975
+  -2.74855083905      -2.78284584240      -2.81755847550      -2.85269350637
+  -2.88825574520      -2.92425004405      -2.96068129666      -2.99755443811
+  -3.03487444447      -3.07264633236      -3.11087515853      -3.14956601932
+  -3.18872405006      -3.22835442445      -3.26846235379      -3.30905308624
+  -3.35013190587      -3.39170413175      -3.43377511687      -3.47635024699
+  -3.51943493937      -3.56303464138      -3.60715482907      -3.65180100550
+  -3.69697869902      -3.74269346136      -3.78895086561      -3.83575650403
+  -3.88311598563      -3.93103493371      -3.97951898302      -4.02857377691
+  -4.07820496411      -4.12841819540      -4.17921911995      -4.23061338147
+  -4.28260661404      -4.33520443771      -4.38841245377      -4.44223623967
+  -4.49668134366      -4.55175327907      -4.60745751815      -4.66379948561
+  -4.72078455167      -4.77841802469      -4.83670514336      -4.89565106838
+  -4.95526087363      -5.01553953679      -5.07649192943      -5.13812280645
+  -5.20043679494      -5.26343838233      -5.32713190392      -5.39152152962
+  -5.45661124993      -5.52240486120      -5.58890594998      -5.65611787650
+  -5.72404375732      -5.79268644693      -5.86204851840      -5.93213224302
+  -6.00293956884      -6.07447209807      -6.14673106333      -6.21971730270
+  -6.29343123351      -6.36787282481      -6.44304156850      -6.51893644908
+  -6.59555591195      -6.67289783019      -6.75095946991      -6.82973745391
+  -6.90922772384      -6.98942550061      -7.07032524320      -7.15192060573
+  -7.23420439273      -7.31716851271      -7.40080392994      -7.48510061435
+  -7.57004748967      -7.65563237981      -7.74184195328      -7.82866166603
+  -7.91607570234      -8.00406691408      -8.09261675833      -8.18170523332
+  -8.27131081287      -8.36141037948      -8.45197915597      -8.54299063613
+  -8.63441651420      -8.72622661363      -8.81838881520      -8.91086898476
+  -9.00363090087      -9.09663618268      -9.18984421829      -9.28321209407
+  -9.37669452535      -9.47024378878      -9.56380965717      -9.65733933705
+  -9.75077740977      -9.84406577668      -9.93714360919      -10.0299473044
+  -10.1224104473      -10.2144637801      -10.3060351803      -10.3970496473
+  -10.4874293007      -10.5770933890      -10.6659583120      -10.7539376570
+  -10.8409422507      -10.9268802279      -11.0116571196      -11.0951759597
+  -11.1773374151      -11.2580399382      -11.3371799449      -11.4146520200
+  -11.4903491509      -11.5641629922      -11.6359841627      -11.7057025769
+  -11.7732078127      -11.8383895165      -11.9011378483      -11.9613439678
+  -12.0189005630      -12.0737024225      -12.1256470528      -12.1746353416
+  -12.2205722661      -12.2633676492      -12.3029369603      -12.3392021621
+  -12.3720926014      -12.4015459409      -12.4275091319      -12.4499394209
+  -12.4688053889      -12.4840880152      -12.4957817614      -12.5038956653
+  -12.5084544367      -12.5094995431      -12.5070902725      -12.5013047583
+  -12.4922409490      -12.4800175022      -12.4647745815      -12.4466745300
+  -12.4259023927      -12.4026662550      -12.3771973624      -12.3497499824
+  -12.3206009648      -12.2900489554      -12.2584132101      -12.2260319583
+  -12.1932602572      -12.1604672786      -12.1280329697      -12.0963440273
+  -12.0657891324      -12.0367533941      -12.0096119656      -11.9847228093
+  -11.9624186096      -11.9429978668      -11.9267152422      -11.9137712829
+  -11.9043017246      -11.8983666610      -11.8959399818      -11.8968996235
+  -11.9010193547      -11.9079630299      -11.9172825117      -11.9284207794
+  -11.9407221261      -11.9534518116      -11.9658280937      -11.9770702264
+  -11.9864668147      -11.9934698695      -11.9978210558      -11.9997370837
+  -12.0000262050      -12.0000212634      -12.0000167353      -12.0000131344
+  -12.0000102792      -12.0000080217      -12.0000062421      -12.0000048433
+  -12.0000037473      -12.0000028909      -12.0000022239      -12.0000017060
+  -12.0000013050      -12.0000009955      -12.0000007575      -12.0000005748
+  -12.0000004352      -12.0000003287      -12.0000002477      -12.0000001864
+  -12.0000001400      -12.0000001050      -12.0000000788      -12.0000000590
+  -12.0000000443      -12.0000000332      -12.0000000250      -12.0000000188
+  -12.0000000143      -12.0000000109      -12.0000000083      -12.0000000064
+  -12.0000000050      -12.0000000039      -12.0000000031      -12.0000000024
+  -12.0000000020      -12.0000000016      -12.0000000013      -12.0000000011
+  -12.0000000009      -12.0000000007      -12.0000000006      -12.0000000005
+  -12.0000000004      -12.0000000004      -12.0000000003      -12.0000000003
+  -12.0000000002      -12.0000000002      -12.0000000002      -12.0000000001
+  -12.0000000001      -12.0000000001      -12.0000000001      -12.0000000001
+  -12.0000000001      -12.0000000000      -12.0000000000      -12.0000000000
+  -12.0000000000      -12.0000000000      -12.0000000000      -12.0000000000
+  -12.0000000000
+  3
+ -0.997504329208E-04 -0.200755571821E-03 -0.303031198953E-03 -0.406593295083E-03
+ -0.511458041990E-03 -0.617641824997E-03 -0.725161235525E-03 -0.834033073691E-03
+ -0.944274350930E-03 -0.105590229265E-02 -0.116893434095E-02 -0.128338815728E-02
+ -0.139928162527E-02 -0.151663285352E-02 -0.163546017835E-02 -0.175578216678E-02
+ -0.187761761934E-02 -0.200098557304E-02 -0.212590530436E-02 -0.225239633224E-02
+ -0.238047842114E-02 -0.251017158412E-02 -0.264149608599E-02 -0.277447244642E-02
+ -0.290912144323E-02 -0.304546411555E-02 -0.318352176719E-02 -0.332331596990E-02
+ -0.346486856677E-02 -0.360820167565E-02 -0.375333769258E-02 -0.390029929534E-02
+ -0.404910944692E-02 -0.419979139917E-02 -0.435236869640E-02 -0.450686517908E-02
+ -0.466330498756E-02 -0.482171256580E-02 -0.498211266527E-02 -0.514453034874E-02
+ -0.530899099425E-02 -0.547552029905E-02 -0.564414428360E-02 -0.581488929567E-02
+ -0.598778201445E-02 -0.616284945470E-02 -0.634011897097E-02 -0.651961826191E-02
+ -0.670137537455E-02 -0.688541870872E-02 -0.707177702146E-02 -0.726047943153E-02
+ -0.745155542397E-02 -0.764503485466E-02 -0.784094795505E-02 -0.803932533683E-02
+ -0.824019799673E-02 -0.844359732140E-02 -0.864955509223E-02 -0.885810349041E-02
+ -0.906927510188E-02 -0.928310292248E-02 -0.949962036307E-02 -0.971886125476E-02
+ -0.994085985421E-02 -0.101656508489E-01 -0.103932693628E-01 -0.106237509615E-01
+ -0.108571316579E-01 -0.110934479181E-01 -0.113327366667E-01 -0.115750352928E-01
+ -0.118203816558E-01 -0.120688140913E-01 -0.123203714171E-01 -0.125750929392E-01
+ -0.128330184580E-01 -0.130941882747E-01 -0.133586431972E-01 -0.136264245468E-01
+ -0.138975741644E-01 -0.141721344175E-01 -0.144501482060E-01 -0.147316589700E-01
+ -0.150167106955E-01 -0.153053479220E-01 -0.155976157492E-01 -0.158935598440E-01
+ -0.161932264478E-01 -0.164966623835E-01 -0.168039150632E-01 -0.171150324949E-01
+ -0.174300632910E-01 -0.177490566748E-01 -0.180720624892E-01 -0.183991312037E-01
+ -0.187303139228E-01 -0.190656623937E-01 -0.194052290145E-01 -0.197490668424E-01
+ -0.200972296018E-01 -0.204497716930E-01 -0.208067482006E-01 -0.211682149017E-01
+ -0.215342282755E-01 -0.219048455111E-01 -0.222801245171E-01 -0.226601239306E-01
+ -0.230449031260E-01 -0.234345222246E-01 -0.238290421040E-01 -0.242285244073E-01
+ -0.246330315530E-01 -0.250426267449E-01 -0.254573739815E-01 -0.258773380662E-01
+ -0.263025846178E-01 -0.267331800801E-01 -0.271691917328E-01 -0.276106877018E-01
+ -0.280577369699E-01 -0.285104093873E-01 -0.289687756830E-01 -0.294329074755E-01
+ -0.299028772842E-01 -0.303787585403E-01 -0.308606255989E-01 -0.313485537501E-01
+ -0.318426192312E-01 -0.323428992381E-01 -0.328494719377E-01 -0.333624164800E-01
+ -0.338818130107E-01 -0.344077426832E-01 -0.349402876719E-01 -0.354795311844E-01
+ -0.360255574751E-01 -0.365784518579E-01 -0.371383007198E-01 -0.377051915343E-01
+ -0.382792128748E-01 -0.388604544292E-01 -0.394490070129E-01 -0.400449625837E-01
+ -0.406484142560E-01 -0.412594563151E-01 -0.418781842324E-01 -0.425046946796E-01
+ -0.431390855445E-01 -0.437814559460E-01 -0.444319062495E-01 -0.450905380826E-01
+ -0.457574543512E-01 -0.464327592553E-01 -0.471165583052E-01 -0.478089583383E-01
+ -0.485100675358E-01 -0.492199954389E-01 -0.499388529669E-01 -0.506667524339E-01
+ -0.514038075663E-01 -0.521501335209E-01 -0.529058469026E-01 -0.536710657828E-01
+ -0.544459097177E-01 -0.552304997670E-01 -0.560249585128E-01 -0.568294100787E-01
+ -0.576439801494E-01 -0.584687959898E-01 -0.593039864657E-01 -0.601496820628E-01
+ -0.610060149083E-01 -0.618731187905E-01 -0.627511291802E-01 -0.636401832518E-01
+ -0.645404199046E-01 -0.654519797845E-01 -0.663750053061E-01 -0.673096406745E-01
+ -0.682560319085E-01 -0.692143268627E-01 -0.701846752509E-01 -0.711672286696E-01
+ -0.721621406212E-01 -0.731695665385E-01 -0.741896638085E-01 -0.752225917971E-01
+ -0.762685118742E-01 -0.773275874386E-01 -0.783999839433E-01 -0.794858689219E-01
+ -0.805854120143E-01 -0.816987849932E-01 -0.828261617910E-01 -0.839677185268E-01
+ -0.851236335342E-01 -0.862940873884E-01 -0.874792629353E-01 -0.886793453193E-01
+ -0.898945220124E-01 -0.911249828433E-01 -0.923709200274E-01 -0.936325281963E-01
+ -0.949100044285E-01 -0.962035482796E-01 -0.975133618141E-01 -0.988396496365E-01
+ -0.100182618923     -0.101542479454     -0.102919443648     -0.104313726591
+ -0.105725546076     -0.107155122629     -0.108602679552     -0.110068442952
+ -0.111552641777     -0.113055507853     -0.114577275920     -0.116118183669
+ -0.117678471775     -0.119258383941     -0.120858166931     -0.122478070610
+ -0.124118347982     -0.125779255233     -0.127461051766     -0.129164000243
+ -0.130888366627     -0.132634420224     -0.134402433721     -0.136192683233
+ -0.138005448344     -0.139841012150     -0.141699661302     -0.143581686054
+ -0.145487380305     -0.147417041647     -0.149370971408     -0.151349474704
+ -0.153352860479     -0.155381441562     -0.157435534707     -0.159515460647
+ -0.161621544145     -0.163754114039     -0.165913503299     -0.168100049074
+ -0.170314092748     -0.172555979989     -0.174826060806     -0.177124689604
+ -0.179452225233     -0.181809031051     -0.184195474977     -0.186611929545
+ -0.189058771967     -0.191536384189     -0.194045152951     -0.196585469844
+ -0.199157731373     -0.201762339021     -0.204399699306     -0.207070223844
+ -0.209774329420     -0.212512438042     -0.215284977014     -0.218092378999
+ -0.220935082087     -0.223813529860     -0.226728171463     -0.229679461674
+ -0.232667860970     -0.235693835604     -0.238757857672     -0.241860405186
+ -0.245001962151     -0.248183018639     -0.251404070858     -0.254665621239
+ -0.257968178505     -0.261312257750     -0.264698380524     -0.268127074907
+ -0.271598875592     -0.275114323968     -0.278673968203     -0.282278363326
+ -0.285928071314     -0.289623661179     -0.293365709053     -0.297154798276
+ -0.300991519488     -0.304876470716     -0.308810257468     -0.312793492823
+ -0.316826797528     -0.320910800090     -0.325046136871     -0.329233452189
+ -0.333473398412     -0.337766636059     -0.342113833900     -0.346515669060
+ -0.350972827118     -0.355486002213     -0.360055897149     -0.364683223503
+ -0.369368701730     -0.374113061273     -0.378917040676     -0.383781387691
+ -0.388706859393     -0.393694222296     -0.398744252466     -0.403857735638
+ -0.409035467335     -0.414278252988     -0.419586908055     -0.424962258145
+ -0.430405139142     -0.435916397327     -0.441496889510     -0.447147483151
+ -0.452869056496     -0.458662498704     -0.464528709979     -0.470468601707
+ -0.476483096587     -0.482573128773     -0.488739644006     -0.494983599761
+ -0.501305965381     -0.507707722227     -0.514189863817     -0.520753395974
+ -0.527399336975     -0.534128717700     -0.540942581779     -0.547841985751
+ -0.554827999213     -0.561901704977     -0.569064199229     -0.576316591687
+ -0.583660005763     -0.591095578722     -0.598624461850     -0.606247820618
+ -0.613966834850     -0.621782698895     -0.629696621790     -0.637709827443
+ -0.645823554801     -0.654039058029     -0.662357606684     -0.670780485903
+ -0.679308996575     -0.687944455532     -0.696688195729     -0.705541566436
+ -0.714505933422     -0.723582679147     -0.732773202957     -0.742078921274
+ -0.751501267798     -0.761041693696     -0.770701667812     -0.780482676860
+ -0.790386225632     -0.800413837202     -0.810567053134     -0.820847433687
+ -0.831256558032     -0.841796024459     -0.852467450594     -0.863272473614
+ -0.874212750467     -0.885289958088     -0.896505793625     -0.907861974660
+ -0.919360239434     -0.931002347075     -0.942790077826     -0.954725233276
+ -0.966809636593     -0.979045132756     -0.991433588793      -1.00397689402
+  -1.01667696027      -1.02953572215      -1.04255513728      -1.05573718651
+  -1.06908387422      -1.08259722852      -1.09627930150      -1.11013216954
+  -1.12415793346      -1.13835871890      -1.15273667644      -1.16729398198
+  -1.18203283691      -1.19695546842      -1.21206412974      -1.22736110040
+  -1.24284868651      -1.25852922100      -1.27440506393      -1.29047860271
+  -1.30675225239      -1.32322845593      -1.33990968447      -1.35679843761
+  -1.37389724365      -1.39120865992      -1.40873527301      -1.42647969903
+  -1.44444458397      -1.46263260387      -1.48104646517      -1.49968890496
+  -1.51856269129      -1.53767062338      -1.55701553196      -1.57660027954
+  -1.59642776067      -1.61650090222      -1.63682266367      -1.65739603739
+  -1.67822404890      -1.69930975715      -1.72065625482      -1.74226666857
+  -1.76414415932      -1.78629192251      -1.80871318841      -1.83141122232
+  -1.85438932492      -1.87765083245      -1.90119911706      -1.92503758697
+  -1.94916968682      -1.97359889784      -1.99832873816      -2.02336276301
+  -2.04870456499      -2.07435777428      -2.10032605888      -2.12661312482
+  -2.15322271640      -2.18015861635      -2.20742464608      -2.23502466583
+  -2.26296257488      -2.29124231170      -2.31986785411      -2.34884321946
+  -2.37817246470      -2.40785968657      -2.43790902166      -2.46832464650
+  -2.49911077768      -2.53027167182      -2.56181162569      -2.59373497615
+  -2.62604610017      -2.65874941482      -2.69184937712      -2.72535048405
+  -2.75925727234      -2.79357431835      -2.82830623789      -2.86345768595
+  -2.89903335644      -2.93503798189      -2.97147633308      -3.00835321860
+  -3.04567348440      -3.08344201328      -3.12166372426      -3.16034357199
+  -3.19948654596      -3.23909766975      -3.27918200015      -3.31974462617
+  -3.36079066803      -3.40232527596      -3.44435362903      -3.48688093371
+  -3.52991242244      -3.57345335204      -3.61750900196      -3.66208467244
+  -3.70718568245      -3.75281736758      -3.79898507768      -3.84569417431
+  -3.89295002810      -3.94075801581      -3.98912351725      -4.03805191194
+  -4.08754857551      -4.13761887596      -4.18826816948      -4.23950179620
+  -4.29132507545      -4.34374330084      -4.39676173496      -4.45038560372
+  -4.50462009037      -4.55947032907      -4.61494139814      -4.67103831277
+  -4.72776601739      -4.78512937747      -4.84313317087      -4.90178207867
+  -4.96108067543      -5.02103341883      -5.08164463877      -5.14291852582
+  -5.20485911892      -5.26747029246      -5.33075574263      -5.39471897291
+  -5.45936327884      -5.52469173191      -5.59070716261      -5.65741214247
+  -5.72480896527      -5.79289962716      -5.86168580576      -5.93116883827
+  -6.00134969830      -6.07222897173      -6.14380683118      -6.21608300943
+  -6.28905677140      -6.36272688488      -6.43709158992      -6.51214856674
+  -6.58789490228      -6.66432705522      -6.74144081953      -6.81923128645
+  -6.89769280494      -6.97681894047      -7.05660243228      -7.13703514896
+  -7.21810804243      -7.29981110020      -7.38213329611      -7.46506253934
+  -7.54858562190      -7.63268816445      -7.71735456066      -7.80256792010
+  -7.88831000962      -7.97456119351      -8.06130037238      -8.14850492090
+  -8.23615062464      -8.32421161598      -8.41266030947      -8.50146733676
+  -8.59060148123      -8.68002961282      -8.76971662312      -8.85962536121
+  -8.94971657051      -9.03994882711      -9.13027848004      -9.22065959387
+  -9.31104389429      -9.40138071721      -9.49161696200      -9.58169704962
+  -9.67156288627      -9.76115383359      -9.85040668599      -9.93925565635
+  -10.0276323708      -10.1154658740      -10.2026826455      -10.2892066292
+  -10.3749592761      -10.4598596032      -10.5438242680      -10.6267676620
+  -10.7086020233      -10.7892375706      -10.8685826607      -10.9465439692
+  -11.0230266988      -11.0979348152      -11.1711713121      -11.2426385086
+  -11.3122383796      -11.3798729198      -11.4454445462      -11.5088565363
+  -11.5700135068      -11.6288219316      -11.6851907016      -11.7390317260
+  -11.7902605749      -11.8387971646      -11.8845664835      -11.9274993582
+  -11.9675332571      -12.0046131309      -12.0386922835      -12.0697332717
+  -12.0977088272      -12.1226027931      -12.1444110687      -12.1631425519
+  -12.1788200675      -12.1914812695      -12.2011795008      -12.2079845940
+  -12.2119835927      -12.2132813711      -12.2120011275      -12.2082847225
+  -12.2022928326      -12.1942048843      -12.1842187328      -12.1725500460
+  -12.1594313517      -12.1451107049      -12.1298499299      -12.1139223935
+  -12.0976102634      -12.0812012133      -12.0649845381      -12.0492466538
+  -12.0342659673      -12.0203071209      -12.0076146391      -11.9964060389
+  -11.9868645038      -11.9791312793      -11.9732980119      -11.9693993420
+  -11.9674061673      -11.9672201234      -11.9686699942      -11.9715109601
+  -11.9754278340      -11.9800437294      -11.9849359552      -11.9896613591
+  -11.9937938530      -11.9969774658      -11.9989990059      -11.9998930606
+  -12.0000269340      -12.0000212634      -12.0000167353      -12.0000131344
+  -12.0000000000
+ Core charge follows
+   0.00000000000       0.00000000000       0.00000000000       0.00000000000
+   0.00000000000
+ Valence charge follows
+  0.491975821641E-10  0.199273430558E-09  0.454034518454E-09  0.817399957631E-09
+  0.129340403555E-08  0.188619933192E-08  0.260005991663E-08  0.343938463132E-08
+  0.440870045651E-08  0.551266596663E-08  0.675607487525E-08  0.814385967262E-08
+  0.968109535815E-08  0.113730032701E-07  0.132249550149E-07  0.152424764991E-07
+  0.174312520659E-07  0.197971287395E-07  0.223461205798E-07  0.250844131503E-07
+  0.280183681024E-07  0.311545278782E-07  0.344996205359E-07  0.380605647008E-07
+  0.418444746439E-07  0.458586654932E-07  0.501106585799E-07  0.546081869226E-07
+  0.593592008548E-07  0.643718737974E-07  0.696546081814E-07  0.752160415231E-07
+  0.810650526577E-07  0.872107681335E-07  0.936625687721E-07  0.100430096398E-06
+  0.107523260741E-06  0.114952246522E-06  0.122727520715E-06  0.130859840000E-06
+  0.139360258413E-06  0.148240135185E-06  0.157511142787E-06  0.167185275190E-06
+  0.177274856325E-06  0.187792548771E-06  0.198751362663E-06  0.210164664833E-06
+  0.222046188183E-06  0.234410041302E-06  0.247270718331E-06  0.260643109080E-06
+  0.274542509410E-06  0.288984631875E-06  0.303985616649E-06  0.319562042723E-06
+  0.335730939399E-06  0.352509798074E-06  0.369916584332E-06  0.387969750342E-06
+  0.406688247579E-06  0.426091539873E-06  0.446199616788E-06  0.467033007350E-06
+  0.488612794127E-06  0.510960627671E-06  0.534098741327E-06  0.558049966430E-06
+  0.582837747885E-06  0.608486160154E-06  0.635019923646E-06  0.662464421535E-06
+  0.690845717007E-06  0.720190570946E-06  0.750526460080E-06  0.781881595589E-06
+  0.814284942195E-06  0.847766237730E-06  0.882356013222E-06  0.918085613486E-06
+  0.954987218242E-06  0.993093863781E-06  0.103243946518E-05  0.107305883910E-05
+  0.111498772714E-05  0.115826281983E-05  0.120292178117E-05  0.124900327393E-05
+  0.129654698542E-05  0.134559365405E-05  0.139618509656E-05  0.144836423587E-05
+  0.150217512972E-05  0.155766300003E-05  0.161487426296E-05  0.167385655980E-05
+  0.173465878863E-05  0.179733113678E-05  0.186192511414E-05  0.192849358729E-05
+  0.199709081455E-05  0.206777248188E-05  0.214059573974E-05  0.221561924086E-05
+  0.229290317897E-05  0.237250932860E-05  0.245450108575E-05  0.253894350978E-05
+  0.262590336620E-05  0.271544917067E-05  0.280765123411E-05  0.290258170889E-05
+  0.300031463628E-05  0.310092599507E-05  0.320449375149E-05  0.331109791030E-05
+  0.342082056730E-05  0.353374596311E-05  0.364996053834E-05  0.376955299020E-05
+  0.389261433052E-05  0.401923794524E-05  0.414951965549E-05  0.428355778016E-05
+  0.442145320011E-05  0.456330942398E-05  0.470923265575E-05  0.485933186392E-05
+  0.501371885260E-05  0.517250833427E-05  0.533581800451E-05  0.550376861859E-05
+  0.567648406997E-05  0.585409147096E-05  0.603672123525E-05  0.622450716265E-05
+  0.641758652606E-05  0.661610016047E-05  0.682019255444E-05  0.703001194379E-05
+  0.724571040773E-05  0.746744396741E-05  0.769537268707E-05  0.792966077765E-05
+  0.817047670320E-05  0.841799328985E-05  0.867238783768E-05  0.893384223542E-05
+  0.920254307805E-05  0.947868178744E-05  0.976245473607E-05  0.100540633739E-04
+  0.103537143584E-04  0.106616196882E-04  0.109779968399E-04  0.113030689080E-04
+  0.116370647496E-04  0.119802191315E-04  0.123327728816E-04  0.126949730444E-04
+  0.130670730403E-04  0.134493328285E-04  0.138420190750E-04  0.142454053241E-04
+  0.146597721747E-04  0.150854074609E-04  0.155226064373E-04  0.159716719694E-04
+  0.164329147279E-04  0.169066533893E-04  0.173932148405E-04  0.178929343893E-04
+  0.184061559799E-04  0.189332324145E-04  0.194745255795E-04  0.200304066791E-04
+  0.206012564731E-04  0.211874655222E-04  0.217894344391E-04  0.224075741455E-04
+  0.230423061370E-04  0.236940627531E-04  0.243632874558E-04  0.250504351141E-04
+  0.257559722965E-04  0.264803775709E-04  0.272241418119E-04  0.279877685164E-04
+  0.287717741268E-04  0.295766883633E-04  0.304030545641E-04  0.312514300343E-04
+  0.321223864043E-04  0.330165099973E-04  0.339344022056E-04  0.348766798774E-04
+  0.358439757137E-04  0.368369386740E-04  0.378562343945E-04  0.389025456154E-04
+  0.399765726202E-04  0.410790336861E-04  0.422106655456E-04  0.433722238607E-04
+  0.445644837090E-04  0.457882400823E-04  0.470443083986E-04  0.483335250264E-04
+  0.496567478237E-04  0.510148566900E-04  0.524087541334E-04  0.538393658517E-04
+  0.553076413294E-04  0.568145544491E-04  0.583611041198E-04  0.599483149211E-04
+  0.615772377642E-04  0.632489505698E-04  0.649645589645E-04  0.667251969941E-04
+  0.685320278566E-04  0.703862446541E-04  0.722890711635E-04  0.742417626285E-04
+  0.762456065714E-04  0.783019236268E-04  0.804120683965E-04  0.825774303276E-04
+  0.847994346125E-04  0.870795431136E-04  0.894192553117E-04  0.918201092795E-04
+  0.942836826804E-04  0.968115937944E-04  0.994055025699E-04  0.102067111704E-03
+  0.104798167752E-03  0.107600462263E-03  0.110475832951E-03  0.113426164891E-03
+  0.116453391753E-03  0.119559497060E-03  0.122746515493E-03  0.126016534213E-03
+  0.129371694236E-03  0.132814191830E-03  0.136346279960E-03  0.139970269767E-03
+  0.143688532081E-03  0.147503498989E-03  0.151417665430E-03  0.155433590839E-03
+  0.159553900839E-03  0.163781288974E-03  0.168118518487E-03  0.172568424148E-03
+  0.177133914136E-03  0.181817971966E-03  0.186623658467E-03  0.191554113820E-03
+  0.196612559649E-03  0.201802301164E-03  0.207126729369E-03  0.212589323329E-03
+  0.218193652496E-03  0.223943379099E-03  0.229842260605E-03  0.235894152242E-03
+  0.242103009594E-03  0.248472891264E-03  0.255007961620E-03  0.261712493605E-03
+  0.268590871633E-03  0.275647594563E-03  0.282887278759E-03  0.290314661228E-03
+  0.297934602855E-03  0.305752091721E-03  0.313772246523E-03  0.322000320077E-03
+  0.330441702934E-03  0.339101927093E-03  0.347986669814E-03  0.357101757548E-03
+  0.366453169973E-03  0.376047044149E-03  0.385889678790E-03  0.395987538659E-03
+  0.406347259090E-03  0.416975650640E-03  0.427879703878E-03  0.439066594306E-03
+  0.450543687436E-03  0.462318544000E-03  0.474398925323E-03  0.486792798851E-03
+  0.499508343841E-03  0.512553957218E-03  0.525938259607E-03  0.539670101547E-03
+  0.553758569881E-03  0.568212994348E-03  0.583042954363E-03  0.598258286009E-03
+  0.613869089236E-03  0.629885735275E-03  0.646318874280E-03  0.663179443207E-03
+  0.680478673928E-03  0.698228101591E-03  0.716439573248E-03  0.735125256741E-03
+  0.754297649863E-03  0.773969589811E-03  0.794154262924E-03  0.814865214737E-03
+  0.836116360341E-03  0.857921995075E-03  0.880296805559E-03  0.903255881071E-03
+  0.926814725290E-03  0.950989268418E-03  0.975795879688E-03  0.100125138028E-02
+  0.102737305663E-02  0.105417867425E-02  0.108168649186E-02  0.110991527614E-02
+  0.113888431687E-02  0.116861344255E-02  0.119912303667E-02  0.123043405434E-02
+  0.126256803963E-02  0.129554714342E-02  0.132939414184E-02  0.136413245539E-02
+  0.139978616863E-02  0.143638005065E-02  0.147393957612E-02  0.151249094717E-02
+  0.155206111593E-02  0.159267780796E-02  0.163436954637E-02  0.167716567692E-02
+  0.172109639385E-02  0.176619276678E-02  0.181248676844E-02  0.186001130341E-02
+  0.190880023797E-02  0.195888843088E-02  0.201031176539E-02  0.206310718233E-02
+  0.211731271445E-02  0.217296752197E-02  0.223011192944E-02  0.228878746399E-02
+  0.234903689494E-02  0.241090427489E-02  0.247443498234E-02  0.253967576592E-02
+  0.260667479025E-02  0.267548168352E-02  0.274614758688E-02  0.281872520569E-02
+  0.289326886272E-02  0.296983455341E-02  0.304848000318E-02  0.312926472701E-02
+  0.321225009127E-02  0.329749937798E-02  0.338507785153E-02  0.347505282804E-02
+  0.356749374740E-02  0.366247224818E-02  0.376006224541E-02  0.386034001156E-02
+  0.396338426060E-02  0.406927623547E-02  0.417809979909E-02  0.428994152888E-02
+  0.440489081522E-02  0.452303996378E-02  0.464448430201E-02  0.476932228998E-02
+  0.489765563567E-02  0.502958941500E-02  0.516523219675E-02  0.530469617262E-02
+  0.544809729257E-02  0.559555540584E-02  0.574719440768E-02  0.590314239227E-02
+  0.606353181188E-02  0.622849964276E-02  0.639818755781E-02  0.657274210665E-02
+  0.675231490302E-02  0.693706282025E-02  0.712714819478E-02  0.732273903839E-02
+  0.752400925930E-02  0.773113889264E-02  0.794431434074E-02  0.816372862352E-02
+  0.838958163963E-02  0.862208043862E-02  0.886143950473E-02  0.910788105286E-02
+  0.936163533710E-02  0.962294097253E-02  0.989204527074E-02  0.101692045898E-01
+  0.104546846994E-01  0.107487611611E-01  0.110517197257E-01  0.113638567473E-01
+  0.116854796151E-01  0.120169072041E-01  0.123584703450E-01  0.127105123143E-01
+  0.130733893457E-01  0.134474711638E-01  0.138331415402E-01  0.142307988739E-01
+  0.146408567971E-01  0.150637448061E-01  0.154999089209E-01  0.159498123717E-01
+  0.164139363159E-01  0.168927805856E-01  0.173868644674E-01  0.178967275153E-01
+  0.184229303993E-01  0.189660557891E-01  0.195267092772E-01  0.201055203401E-01
+  0.207031433409E-01  0.213202585755E-01  0.219575733615E-01  0.226158231754E-01
+  0.232957728362E-01  0.239982177401E-01  0.247239851468E-01  0.254739355201E-01
+  0.262489639244E-01  0.270500014798E-01  0.278780168781E-01  0.287340179613E-01
+  0.296190533656E-01  0.305342142335E-01  0.314806359956E-01  0.324595002260E-01
+  0.334720365730E-01  0.345195247678E-01  0.356032967146E-01  0.367247386642E-01
+  0.378852934754E-01  0.390864629644E-01  0.403298103487E-01  0.416169627856E-01
+  0.429496140104E-01  0.443295270755E-01  0.457585371960E-01  0.472385547028E-01
+  0.487715681073E-01  0.503596472812E-01  0.520049467539E-01  0.537097091312E-01
+  0.554762686385E-01  0.573070547909E-01  0.592045961943E-01  0.611715244797E-01
+  0.632105783743E-01  0.653246079112E-01  0.675165787814E-01  0.697895768299E-01
+  0.721468126992E-01  0.745916266203E-01  0.771274933559E-01  0.797580272951E-01
+  0.824869877016E-01  0.853182841173E-01  0.882559819199E-01  0.913043080369E-01
+  0.944676568140E-01  0.977505960374E-01  0.101157873109      0.104694421371
+  0.108365366581      0.112176033528      0.116131952787      0.120238867612
+  0.124502740954      0.128929762597      0.133526356410      0.138299187697
+  0.143255170637      0.148401475800      0.153745537732      0.159295062573
+  0.165058035717      0.171042729472      0.177257710702      0.183711848440
+  0.190414321423      0.197374625541      0.204602581150      0.212108340225
+  0.219902393310      0.227995576226      0.236399076485      0.245124439375
+  0.254183573645      0.263588756753      0.273352639604      0.283488250716
+  0.294008999748      0.304928680309      0.316261471986      0.328021941482
+  0.340225042804      0.352886116385      0.366020887055      0.379645460752
+  0.393776319867      0.408430317107      0.423624667759      0.439376940226
+  0.455705044716      0.472627219939      0.490162017687      0.508328285138
+  0.527145144757      0.546631971634      0.566808368111      0.587694135545
+  0.609309243053      0.631673793089      0.654807983689      0.678732067250
+  0.703466305679      0.729030921780      0.755446046743      0.782731663599
+  0.810907546531      0.839993195942      0.870007769169      0.900970006795
+  0.932898154487      0.965809880341      0.999722187716       1.03465132359
+   1.07061268252       1.10762070617       1.14568877877       1.18482911845
+   1.22505266473       1.26636896251       1.30878604282       1.35231030061
+   1.39694637025       1.44269699888       1.48956291860       1.53754271765
+   1.58663271168       1.63682681559       1.68811641690       1.74049025151
+   1.79393428276       1.84843158490       1.90396223196       1.96050319327
+   2.01802823666       2.07650784068       2.13590911713       2.19619574499
+   2.25732791729       2.31926230194       2.38195201799       2.44534662839
+   2.50939215047       2.57403108522       2.63920246628       2.70484192957
+   2.77088180418       2.83725122509       2.90387626810       2.97068010697
+   3.03758319272       3.10450345471       3.17135652281       3.23805596968
+   3.30451357200       3.37063958897       3.43634305628       3.50153209335
+   3.56611422140       3.62999668952       3.69308680595       3.75529227112
+   3.81652150938       3.87668399565       3.93569057381       3.99345376293
+   4.04988804828       4.10491015355       4.15843929148       4.21039739001
+   4.26070929170       4.30930292466       4.35610944351       4.40106333985
+   4.44410252210       4.48516836535       4.52420573250       4.56116296880
+   4.59599187230       4.62864764349       4.65908881785       4.68727718535
+   4.71317770132       4.73675839302       4.75799026635       4.77684721663
+   4.79330594707       4.80734589792       4.81894918828       4.82810057179
+   4.83478740623       4.83899963615       4.84072978624       4.83997296273
+   4.83672685877       4.83099175982       4.82277054458       4.81206867757
+   4.79889419035       4.78325764969       4.76517211313       4.74465307470
+   4.72171840653       4.69638830510       4.66868525388       4.63863401678
+   4.60626167869       4.57159774980       4.53467434974       4.49552648337
+   4.45419241467       4.41071413479       4.36513790757       4.31751485815
+   4.26790154845       4.21636045701       4.16296024894       4.10777568503
+   4.05088697484       3.99237839978       3.93233655146       3.87084949823
+   3.80800695438       3.74389974902       3.67861970691       3.61225941100
+   3.54491198139       3.47667085660       3.40762957615       3.33788156644
+   3.26751993047       3.19663724206       3.12532534501       3.05367515804
+   2.98177648576       2.90971783640       2.83758624656       2.76546711361
+   2.69344403596       2.62159866160       2.55001054529       2.47875701452
+   2.40791304462       2.33755114309       2.26774124339       2.19855060824
+   2.13004374251       2.06228231581       1.99532509467       1.92922788435
+   1.86404348024       1.79982162868       1.73660899708       1.67444915327
+   1.61338255384       1.55344654119       1.49467534922       1.43710011724
+   1.38074891195       1.32564675711       1.27181567062       1.21927470874
+   1.16804001693       1.11812488720       1.06953982139       1.02229260013
+  0.976388357057      0.931829657869      0.888616583882      0.846746819651
+  0.806215744254      0.767016525865      0.729140219186      0.692575865360
+  0.657310593968      0.623329726706      0.590616882382      0.559154082833
+  0.528921859410      0.499899359663      0.472064453882      0.445393841145
+  0.419863154573      0.395447065440      0.372119385881      0.349853169881
+  0.328620812292      0.308394145625      0.289144534371      0.270842966638
+  0.253460142901      0.236966561677      0.221332601959      0.206528602261
+  0.192524936140      0.179292084089      0.166800701695      0.155021683993
+  0.143926225963      0.133485879112      0.123672604128      0.114458819603
+  0.105817446813      0.977219506067E-01  0.901463764160E-01  0.830653834578E-01
+  0.764542741863E-01  0.702890200759E-01  0.645462838271E-01  0.592034380940E-01
+  0.542385808479E-01  0.496305474957E-01  0.453589198824E-01  0.414040323130E-01
+  0.377469747370E-01  0.343695932402E-01  0.312544879984E-01  0.283850088439E-01
+  0.257452486053E-01  0.233200343769E-01  0.210949168770E-01  0.190561580553E-01
+  0.171907171062E-01  0.154862350440E-01  0.139310179954E-01  0.125140193575E-01
+  0.112248209704E-01  0.100536134467E-01  0.899117579425E-02  0.802885446745E-02
+  0.715854197221E-02  0.637265514683E-02  0.566411323349E-02  0.502631584889E-02
+  0.445312095578E-02  0.393882293054E-02  0.347813081480E-02  0.306614683220E-02
+  0.269834524465E-02  0.237055161504E-02  0.207892253697E-02  0.181992588492E-02
+  0.159032163202E-02  0.138714327580E-02  0.120767990619E-02  0.104945894415E-02
+  0.910229573411E-03  0.787946882218E-03  0.680756727009E-03  0.586981324900E-03
+  0.505105577294E-03  0.433764122705E-03  0.371729112961E-03  0.317898703352E-03
+  0.271286244080E-03  0.231010157442E-03  0.196284482636E-03  0.166410067817E-03
+  0.140766387155E-03  0.118803959028E-03  0.100037340187E-03  0.840386697475E-04
+  0.704317360837E-04  0.588865392821E-04  0.491143215218E-04  0.408630377678E-04
+  0.339132393368E-04  0.280743432691E-04  0.231812609754E-04  0.190913603056E-04
+  0.156817359895E-04  0.128467643124E-04  0.104959188811E-04  0.855182540662E-05
+  0.694853454807E-05  0.562999301897E-05  0.454869433813E-05  0.366449179480E-05
+  0.294355738375E-05  0.235747163700E-05  0.188243042640E-05  0.149855592681E-05
+  0.118930000555E-05  0.940929335119E-06  0.742082508052E-06  0.583390360946E-06
+  0.457151588222E-06  0.357056542058E-06  0.277952873596E-06  0.215647371612E-06
+  0.166738999532E-06  0.128478720813E-06  0.986522394979E-07  0.754822670342E-07
+  0.575473645456E-07  0.437148002541E-07  0.330852109812E-07  0.249471662565E-07
+  0.187400066387E-07  0.140235677625E-07  0.104536113314E-07  0.776196665745E-08
+  0.574054420034E-08  0.422851851329E-08  0.310209452834E-08  0.226637049901E-08
+  0.164889527058E-08  0.119458879012E-08  0.861754641379E-09  0.618963461651E-09
+  0.442627758594E-09  0.315123159185E-09  0.223339487377E-09  0.157568552277E-09
+  0.110654004765E-09  0.773451931252E-10  0.538074306206E-10  0.372535157279E-10
+  0.256673835379E-10  0.175978003291E-10  0.120052302656E-10  0.814874056255E-11
+  0.550288716668E-11  0.369694281566E-11  0.247069082370E-11  0.164243728309E-11
+  0.108598725417E-11  0.714161859626E-12  0.467062121943E-12  0.303758485213E-12
+  0.196438806701E-12  0.126310714948E-12  0.807487271910E-13  0.513194410696E-13
+  0.324225108918E-13  0.203609115239E-13  0.127086837889E-13  0.788357569905E-14
+  0.485994469465E-14  0.297708002927E-14  0.181203273532E-14  0.109577838757E-14
+  0.658301668586E-15  0.392858940616E-15  0.232874137473E-15  0.137101379622E-15
+  0.801605869848E-16  0.465415165748E-16  0.268313395896E-16  0.153577462063E-16
+  0.872683081661E-17  0.492254512939E-17  0.275604671915E-17  0.153146224788E-17
+  0.844515229878E-18  0.462113063447E-18  0.250891614974E-18  0.135138230786E-18
+  0.722072807377E-19  0.382692880355E-19  0.201160082093E-19  0.104860057476E-19
+  0.542012762490E-20  0.277775386793E-20  0.141128896583E-20  0.710769178870E-21
+  0.354799995778E-21  0.175522306852E-21  0.860449577742E-22  0.417939106530E-22
+  0.201115027215E-22  0.958669203528E-23  0.452620208963E-23  0.211635018308E-23
+  0.979887902591E-24  0.449207211234E-24  0.203865624381E-24  0.915826182187E-25
+  0.407190836124E-25  0.179160485898E-25  0.779988961696E-26  0.335953089410E-26
+  0.143137693075E-26  0.603191301429E-27  0.251374688657E-27  0.103583937206E-27
+  0.421993612054E-28  0.169941462100E-28  0.676409127223E-29  0.266055366647E-29
+  0.103400359775E-29  0.397002936940E-30  0.150563734725E-30  0.563942113385E-31
+  0.208577668265E-31  0.761642192744E-32  0.274545280072E-32  0.976755291925E-33
+  0.342921305677E-33  0.118786546374E-33  0.405910601869E-34  0.136807279902E-34
+  0.454703260473E-35  0.149008274613E-35  0.481369530289E-36  0.153268938619E-36
+  0.480903009429E-37  0.148664771985E-37  0.452714375647E-38  0.135776159117E-38
+  0.400979430273E-39  0.116583012341E-39  0.333639328271E-40  0.939639111162E-41
+  0.260374714029E-41  0.709743257073E-42  0.190273470157E-42  0.501577792377E-43
+  0.129983702785E-43  0.331082579444E-44  0.828677736689E-45  0.203770272375E-45
+  0.492157925692E-46  0.116728823959E-46  0.271807813656E-47  0.621233615737E-48
+  0.139333281021E-48  0.306590104744E-49  0.661698148830E-50  0.140040639649E-50
+  0.290558233421E-51  0.590865256846E-52  0.117736138695E-52  0.229818902177E-53
+  0.439342814156E-54  0.822335371645E-55  0.150662975578E-55  0.270121601381E-56
+  0.473793377701E-57  0.812785302745E-58  0.136332301405E-58  0.223529696904E-59
+  0.358146971611E-60  0.560598015791E-61  0.856996895971E-62  0.127913426001E-62
+  0.186351348585E-63  0.264909405951E-64  0.367348369705E-65  0.496753334205E-66
+  0.654862327240E-67  0.841334979848E-68  0.105307515065E-68  0.128375340194E-69
+  0.152368295526E-70  0.176017524206E-71  0.197843439846E-72  0.216295071746E-73
+  0.229923961315E-74  0.237567240189E-75  0.238508755502E-76  0.232587832467E-77
+  0.220233153983E-78  0.202412968835E-79  0.180509286762E-80  0.156138780451E-81
+  0.130952950943E-82  0.106452330607E-83  0.838438909196E-85  0.639593350740E-86
+  0.472380087041E-87  0.337654223220E-88  0.233497724420E-89  0.156156077493E-90
+  0.100956913084E-91  0.630736877359E-93  0.380652941906E-94  0.221825223673E-95
+  0.124774827381E-96  0.677182395570E-98  0.354473677059E-99  0.178887413723-100
+  0.870057222731-102  0.407629158582-103  0.183939936590-104  0.798913420733-106
+  0.333116646816-107  0.129356541937-108  0.482206846924-110  0.172467809932-111
+  0.591543113016-113
Added: SwiftApps/ematter/workflow-run/Ta.lammps.eam
--- SwiftApps/ematter/workflow-run/Ta.lammps.eam	                        (rev 0)
+++ SwiftApps/ematter/workflow-run/Ta.lammps.eam	2015-01-27 22:12:52 UTC (rev 8376)
@@ -0,0 +1,609 @@
+# EAM potentials generated by H.W.Sheng (hsheng at gmu.edu) on Sat Feb  8 19:14:35 2014
+   1  Ta
+ 1001   1.0000000000000000e-03 1001   5.8999999999999999e-03   5.8999999999999995e+00 # nrho drho nr dr cutoff
+   73 180.95  0 dummy #Atomic_number  atomic_mass (g/cm^3) lattice_constant lattice_type
+ -2.0823156143930086e-02 -1.1376792222961352e-01 -2.0607906318359553e-01 -2.9775665503751375e-01 -3.8880082405683269e-01
+ -4.7921174635175962e-01 -5.6898964748815994e-01 -6.5813480209847386e-01 -7.4664753349263113e-01 -8.3452821326896776e-01
+ -9.2177726092514101e-01 -1.0083951434690459e+00 -1.0943823750297308e+00 -1.1797395164683127e+00 -1.2644671749888938e+00
+ -1.3485660037494769e+00 -1.4320367014728812e+00 -1.5148800120576578e+00 -1.5970967241890066e+00 -1.6786876709496912e+00
+ -1.7596537294309538e+00 -1.8399958203434335e+00 -1.9197149076280799e+00 -1.9988119980670696e+00 -2.0772881408947224e+00
+ -2.1551444274084157e+00 -2.2323819905795035e+00 -2.3090020046642272e+00 -2.3850056848146370e+00 -2.4603942866895032e+00
+ -2.5351691060652337e+00 -2.6093314784467916e+00 -2.6828827786786063e+00 -2.7558244205554954e+00 -2.8281578564335752e+00
+ -2.8998845768411798e+00 -2.9710061100897738e+00 -3.0415240218848729e+00 -3.1114399149369545e+00 -3.1807554285723776e+00
+ -3.2494722383442944e+00 -3.3175920556435714e+00 -3.3851166273097002e+00 -3.4520477352417167e+00 -3.5183871960091153e+00
+ -3.5841368604627633e+00 -3.6492986133458212e+00 -3.7138743729046548e+00 -3.7778660904997503e+00 -3.8412757502166346e+00
+ -3.9041053684767850e+00 -3.9663569936485499e+00 -4.0280327056580632e+00 -4.0891346156001607e+00 -4.1496648653492931e+00
+ -4.2096256271704426e+00 -4.2690191033300433e+00 -4.3278475257068916e+00 -4.3861131554030628e+00 -4.4438182823548313e+00
+ -4.5009652249435801e+00 -4.5575563296067187e+00 -4.6135939704486049e+00 -4.6690805488514497e+00 -4.7240184930862430e+00
+ -4.7784102579236629e+00 -4.8322583242449957e+00 -4.8855651986530493e+00 -4.9383334130830674e+00 -4.9905655244136495e+00
+ -5.0422641140776676e+00 -5.0934317876731718e+00 -5.1440711745743206e+00 -5.1941849275422847e+00 -5.2437757223361698e+00
+ -5.2928462573239310e+00 -5.3413992530932850e+00 -5.3894374520626309e+00 -5.4369636180919638e+00 -5.4839805360937888e+00
+ -5.5304910116440400e+00 -5.5764978705929948e+00 -5.6220039586761885e+00 -5.6670121411253351e+00 -5.7115253022792318e+00
+ -5.7555463451946940e+00 -5.7990781912574469e+00 -5.8421237797930630e+00 -5.8846860676778636e+00 -5.9267680289498434e+00
+ -5.9683726544195794e+00 -6.0095029512811520e+00 -6.0501619427230588e+00 -6.0903526675391282e+00 -6.1300781797394404e+00
+ -6.1693415481612393e+00 -6.2081458560798470e+00 -6.2464942008195843e+00 -6.2843896933646839e+00 -6.3218354579702041e+00
+ -6.3588346317729476e+00 -6.3953903644023775e+00 -6.4315058175915327e+00 -6.4671841647879402e+00 -6.5024285907645361e+00
+ -6.5372422912305774e+00 -6.5716284724425620e+00 -6.6055903508151399e+00 -6.6391311525320296e+00 -6.6722541131569395e+00
+ -6.7049624772444760e+00 -6.7372594979510652e+00 -6.7691484366458656e+00 -6.8006325625216819e+00 -6.8317151522058870e+00
+ -6.8623994893713336e+00 -6.8926888643472726e+00 -6.9225865737302605e+00 -6.9520959199950889e+00 -6.9812202111056898e+00
+ -7.0099627601260561e+00 -7.0383268848311538e+00 -7.0663159073178416e+00 -7.0939331536157857e+00 -7.1211819532983753e+00
+ -7.1480656390936348e+00 -7.1745875464951467e+00 -7.2007510133729609e+00 -7.2265593795845167e+00 -7.2520159865855511e+00
+ -7.2771241770410215e+00 -7.3018872944360167e+00 -7.3263086826866761e+00 -7.3503916857511031e+00 -7.3741396472402831e+00
+ -7.3975559100289967e+00 -7.4206438158667369e+00 -7.4434067049886234e+00 -7.4658479157263251e+00 -7.4879707841189642e+00
+ -7.5097786435240437e+00 -7.5312748242283538e+00 -7.5524626530588925e+00 -7.5733454529937836e+00 -7.5939265427731870e+00
+ -7.6142092365102174e+00 -7.6341968433018614e+00 -7.6538926668398899e+00 -7.6733000050217752e+00 -7.6924221495616099e+00
+ -7.7112623856010174e+00 -7.7298239913200737e+00 -7.7481102375482171e+00 -7.7661243873751644e+00 -7.7838696957618376e+00
+ -7.8013494091512623e+00 -7.8185667650794972e+00 -7.8355249917865422e+00 -7.8522273078272598e+00 -7.8686769216822858e+00
+ -7.8848770313689531e+00 -7.9008308240521927e+00 -7.9165414756554657e+00 -7.9320121504716701e+00 -7.9472460007740580e+00
+ -7.9622461664271524e+00 -7.9770157744976631e+00 -7.9915579388654017e+00 -8.0058757598341970e+00 -8.0199723237428113e+00
+ -8.0338507025758563e+00 -8.0475139535747129e+00 -8.0609651188484381e+00 -8.0742072249846881e+00 -8.0872432826606282e+00
+ -8.1000762862538593e+00 -8.1127092134533214e+00 -8.1251450248702142e+00 -8.1373866636489165e+00 -8.1494370550778950e+00
+ -8.1612991062006301e+00 -8.1729757054265164e+00 -8.1844697221417970e+00 -8.1957840063204586e+00 -8.2069213881351715e+00
+ -8.2178846775681844e+00 -8.2286766640222488e+00 -8.2393001159315364e+00 -8.2497577803725513e+00 -8.2600523826750525e+00
+ -8.2701866260329524e+00 -8.2801631911152569e+00 -8.2899847356769598e+00 -8.2996538941699818e+00 -8.3091732773540485e+00
+ -8.3185454719076528e+00 -8.3277730400389398e+00 -8.3368585190966282e+00 -8.3458044211809295e+00 -8.3546132327544615e+00
+ -8.3632874142531701e+00 -8.3718293997016406e+00 -8.3802415964429180e+00 -8.3885263851589524e+00 -8.3966861200055511e+00
+ -8.4047231287517299e+00 -8.4126397129190575e+00 -8.4204381479210166e+00 -8.4281206832023408e+00 -8.4356895423783769e+00
+ -8.4431469233744298e+00 -8.4504949985651123e+00 -8.4577359149136981e+00 -8.4648717941114704e+00 -8.4719047327170767e+00
+ -8.4788368022958718e+00 -8.4856700495592747e+00 -8.4924064965041168e+00 -8.4990481405519898e+00 -8.5055969546886026e+00
+ -8.5120548876031261e+00 -8.5184238638275449e+00 -8.5247057838760103e+00 -8.5309025243841852e+00 -8.5370159382486026e+00
+ -8.5430478547660123e+00 -8.5490000797727248e+00 -8.5548743957839744e+00 -8.5606725621332593e+00 -8.5663963151116995e+00
+ -8.5720473681073805e+00 -8.5776274117447073e+00 -8.5831381140237557e+00 -8.5885811204596223e+00 -8.5939580542217744e+00
+ -8.5992705162733980e+00 -8.6045200855107549e+00 -8.6097083189025252e+00 -8.6148367516291646e+00 -8.6199068972222506e+00
+ -8.6249202477038320e+00 -8.6298782737257884e+00 -8.6347824247091669e+00 -8.6396341289835448e+00 -8.6444347939263722e+00
+ -8.6491858061023272e+00 -8.6538885314026608e+00 -8.6585443151845567e+00 -8.6631544824104729e+00 -8.6677203377874950e+00
+ -8.6722431659066874e+00 -8.6767242313824475e+00 -8.6811647789918442e+00 -8.6855660338139860e+00 -8.6899292013693561e+00
+ -8.6942554677591684e+00 -8.6985459998047201e+00 -8.7028019451867404e+00 -8.7070244325847419e+00 -8.7112145718163685e+00
+ -8.7153734539767473e+00 -8.7195021515778404e+00 -8.7236017186877941e+00 -8.7276731910702914e+00 -8.7317175863238958e+00
+ -8.7357359040214142e+00 -8.7397291258492320e+00 -8.7436982157466776e+00 -8.7476441200453632e+00 -8.7515677676085399e+00
+ -8.7554700699704497e+00 -8.7593519214756679e+00 -8.7632141994184654e+00 -8.7670577641821499e+00 -8.7708834593784175e+00
+ -8.7746921119867096e+00 -8.7784845324935556e+00 -8.7822615150319265e+00 -8.7860238375205881e+00 -8.7897722618034493e+00
+ -8.7935075337889081e+00 -8.7972303835892092e+00 -8.8009415256597929e+00 -8.8046416589386425e+00 -8.8083314669856350e+00
+ -8.8120116181218968e+00 -8.8156827655691483e+00 -8.8193455475890552e+00 -8.8230005876225839e+00 -8.8266484944293442e+00
+ -8.8302898622269517e+00 -8.8339252708303615e+00 -8.8375552857912325e+00 -8.8411804585372735e+00 -8.8448013265115932e+00
+ -8.8484184133120500e+00 -8.8520322288306037e+00 -8.8556432693926652e+00 -8.8592520178964520e+00 -8.8628589439523253e+00
+ -8.8664645040221579e+00 -8.8700691415586732e+00 -8.8736732871447952e+00 -8.8772773586330107e+00 -8.8808817612847015e+00
+ -8.8844868879095120e+00 -8.8880931190046919e+00 -8.8917008228944443e+00 -8.8953103558692828e+00 -8.8989220623253740e+00
+ -8.9025362749038983e+00 -8.9061533146303908e+00 -8.9097734910540982e+00 -8.9133971023873215e+00 -8.9170244356447768e+00
+ -8.9206557667829394e+00 -8.9242913608393941e+00 -8.9279314720721903e+00 -8.9315763440991844e+00 -8.9352262100374009e+00
+ -8.9388812926423711e+00 -8.9425418044474956e+00 -8.9462079479033854e+00 -8.9498799155172151e+00 -8.9535578899920800e+00
+ -8.9572420443663319e+00 -8.9609325421529444e+00 -8.9646295374788583e+00 -8.9683331752243269e+00 -8.9720435911622740e+00
+ -8.9757609120976394e+00 -8.9794852560067326e+00 -8.9832167321765812e+00 -8.9869554413442820e+00 -8.9907014758363513e+00
+ -8.9944549197080779e+00 -8.9982158488828681e+00 -9.0019843312916006e+00 -9.0057604270119764e+00 -9.0095441884078689e+00
+ -9.0133356602686749e+00 -9.0171348799486619e+00 -9.0209418775063224e+00 -9.0247566758437223e+00 -9.0285792908458564e+00
+ -9.0324097315199889e+00 -9.0362480001350125e+00 -9.0400940923607962e+00 -9.0439479974075336e+00 -9.0478096981650982e+00
+ -9.0516791713423892e+00 -9.0555563876066856e+00 -9.0594413117229937e+00 -9.0633339026933974e+00 -9.0672341138964150e+00
+ -9.0711418932263399e+00 -9.0750571832325981e+00 -9.0789799212590960e+00 -9.0829100395835738e+00 -9.0868474655569500e+00
+ -9.0907921217426786e+00 -9.0947439260560952e+00 -9.0987027919037722e+00 -9.1026686283228582e+00 -9.1066413401204453e+00
+ -9.1106208280129053e+00 -9.1146069887652459e+00 -9.1185997153304612e+00 -9.1225988969888832e+00 -9.1266044194875313e+00
+ -9.1306161651794575e+00 -9.1346340131631063e+00 -9.1386578394216595e+00 -9.1426875169623880e+00 -9.1467229159560013e+00
+ -9.1507639038759994e+00 -9.1548103456380208e+00 -9.1588621037391977e+00 -9.1629190383975043e+00 -9.1669810076911027e+00
+ -9.1710478676976983e+00 -9.1751194726338934e+00 -9.1791956749945278e+00 -9.1832763256920398e+00 -9.1873612741958102e+00
+ -9.1914503686715143e+00 -9.1955434561204719e+00 -9.1996403825190001e+00 -9.2037409929577620e+00 -9.2078451317811165e+00
+ -9.2119526427264713e+00 -9.2160633690636313e+00 -9.2201771537341486e+00 -9.2242938394906755e+00 -9.2284132690363112e+00
+ -9.2325352851639551e+00 -9.2366597308956617e+00 -9.2407864496219787e+00 -9.2449152852413103e+00 -9.2490460822992588e+00
+ -9.2531786861279830e+00 -9.2573129429843917e+00 -9.2614487001585140e+00 -9.2655858060061131e+00 -9.2697241099514631e+00
+ -9.2738634624889755e+00 -9.2780037151848269e+00 -9.2821447206785930e+00 -9.2862863326848686e+00 -9.2904284059949056e+00
+ -9.2945707964782347e+00 -9.2987133610842925e+00 -9.3028559578440575e+00 -9.3069984458716739e+00 -9.3111406853660768e+00
+ -9.3152825376126280e+00 -9.3194238649847385e+00 -9.3235645309454984e+00 -9.3277044000493099e+00 -9.3318433379435071e+00
+ -9.3359812113699938e+00 -9.3401178881668603e+00 -9.3442532372700278e+00 -9.3483871287148599e+00 -9.3525194336378057e+00
+ -9.3566500242780162e+00 -9.3607787739789821e+00 -9.3649055571901556e+00 -9.3690302494685831e+00 -9.3731527274805320e+00
+ -9.3772728690031180e+00 -9.3813905529259340e+00 -9.3855056592526847e+00 -9.3896180691028022e+00 -9.3937276647130865e+00
+ -9.3978343294393287e+00 -9.4019379477579399e+00 -9.4060384052675783e+00 -9.4101355886907818e+00 -9.4142293858755917e+00
+ -9.4183196857971829e+00 -9.4224063785594954e+00 -9.4264893553968587e+00 -9.4305685086756181e+00 -9.4346437318957737e+00
+ -9.4387149196925950e+00 -9.4427819678382594e+00 -9.4468447732434768e+00 -9.4509032339591190e+00 -9.4549572491778466e+00
+ -9.4590067192357399e+00 -9.4630515456139257e+00 -9.4670916309402049e+00 -9.4711268789906828e+00 -9.4751571946913966e+00
+ -9.4791824841199457e+00 -9.4832026545071155e+00 -9.4872176142385118e+00 -9.4912272728561842e+00 -9.4952315410602601e+00
+ -9.4992303307105637e+00 -9.5032235548282546e+00 -9.5072111275974525e+00 -9.5111929643668631e+00 -9.5151689816514100e+00
+ -9.5191390971338627e+00 -9.5231032296664591e+00 -9.5270612992725461e+00 -9.5310132271481969e+00 -9.5349589356638429e+00
+ -9.5388983483659064e+00 -9.5428313899784190e+00 -9.5467579864046641e+00 -9.5506780647287908e+00 -9.5545915532174543e+00
+ -9.5584983813214350e+00 -9.5623984796772756e+00 -9.5662917801089034e+00 -9.5701782156292570e+00 -9.5740577204419228e+00
+ -9.5779302299427549e+00 -9.5817956807215143e+00 -9.5856540105634807e+00 -9.5895051584511002e+00 -9.5933490645655972e+00
+ -9.5971856702886136e+00 -9.6010149182038340e+00 -9.6048367520986115e+00 -9.6086511169655999e+00 -9.6124579590043790e+00
+ -9.6162572256230874e+00 -9.6200488654400456e+00 -9.6238328282853889e+00 -9.6276090652026927e+00 -9.6313775284506011e+00
+ -9.6351381715044617e+00 -9.6388909490579415e+00 -9.6426358170246687e+00 -9.6463727325398523e+00 -9.6501016539619151e+00
+ -9.6538225408741152e+00 -9.6575353540861872e+00 -9.6612400556359574e+00 -9.6649366087909829e+00 -9.6686249780501683e+00
+ -9.6723051291454070e+00 -9.6759770290431995e+00 -9.6796406459462894e+00 -9.6832959492952853e+00 -9.6869429097702948e+00
+ -9.6905814992925485e+00 -9.6942116910260303e+00 -9.6978334593791082e+00 -9.7014467800061581e+00 -9.7050516298091942e+00
+ -9.7086479869394999e+00 -9.7122358307992531e+00 -9.7158151420431569e+00 -9.7193859025800649e+00 -9.7229480955746119e+00
+ -9.7265017054488432e+00 -9.7300467178838410e+00 -9.7335831198213558e+00 -9.7371108994654278e+00 -9.7406300462840267e+00
+ -9.7441405510106680e+00 -9.7476424056460527e+00 -9.7511356034596837e+00 -9.7546201389915073e+00 -9.7580960080535313e+00
+ -9.7615632077314576e+00 -9.7650217363863110e+00 -9.7684715936560664e+00 -9.7719127804572814e+00 -9.7753452989867142e+00
+ -9.7787691527229637e+00 -9.7821843464280942e+00 -9.7855908861492580e+00 -9.7889887792203325e+00 -9.7923780342635460e+00
+ -9.7957586611911012e+00 -9.7991306712068109e+00 -9.8024940768077169e+00 -9.8058488917857343e+00 -9.8091951312292611e+00
+ -9.8125328115248216e+00 -9.8158619503586859e+00 -9.8191825667185011e+00 -9.8224946808949234e+00 -9.8257983144832384e+00
+ -9.8290934903849987e+00 -9.8323802328096459e+00 -9.8356585672761394e+00 -9.8389285206145907e+00 -9.8421901209678850e+00
+ -9.8454433977933125e+00 -9.8486883818641964e+00 -9.8519251052715227e+00 -9.8551536014255667e+00 -9.8583739050575225e+00
+ -9.8615860522211314e+00 -9.8647900802943109e+00 -9.8679860279807805e+00 -9.8711739353116936e+00 -9.8743538436472633e+00
+ -9.8775257956783946e+00 -9.8806898354283064e+00 -9.8838460082541673e+00 -9.8869943608487176e+00 -9.8901349412419020e+00
+ -9.8932677988024977e+00 -9.8963929842397391e+00 -9.8995105496049494e+00 -9.9026205482931715e+00 -9.9057230350447920e+00
+ -9.9088180659471714e+00 -9.9119056984362679e+00 -9.9149859912982787e+00 -9.9180590046712531e+00 -9.9211248000467300e+00
+ -9.9241834402713653e+00 -9.9272349895485590e+00 -9.9302795134400821e+00 -9.9333170788677077e+00 -9.9363477541148395e+00
+ -9.9393716088281376e+00 -9.9423887140191507e+00 -9.9453991420659413e+00 -9.9484029667147169e+00 -9.9514002630814531e+00
+ -9.9543911076535281e+00 -9.9573755782913498e+00 -9.9603537542299829e+00 -9.9633257160807762e+00 -9.9662915458329948e+00
+ -9.9692513268554439e+00 -9.9722051438981030e+00 -9.9751530830937476e+00 -9.9780952319595819e+00 -9.9810316793988676e+00
+ -9.9839625157025509e+00 -9.9868878325500656e+00 -9.9898077229887150e+00 -9.9927222813586543e+00 -9.9956316031964576e+00
+ -9.9985357851378520e+00 -1.0001434924820456e+01 -1.0004329120786517e+01 -1.0007218472385645e+01 -1.0010103079677556e+01
+ -1.0012983043334808e+01 -1.0015858464545536e+01 -1.0018729444916186e+01 -1.0021596086374265e+01 -1.0024458491071062e+01
+ -1.0027316761284400e+01 -1.0030170999321363e+01 -1.0033021307421038e+01 -1.0035867787657251e+01 -1.0038710541841306e+01
+ -1.0041549671424724e+01 -1.0044385277401974e+01 -1.0047217460213211e+01 -1.0050046319647027e+01 -1.0052871954743168e+01
+ -1.0055694463695286e+01 -1.0058513943753669e+01 -1.0061330491127984e+01 -1.0064144200890009e+01 -1.0066955166876376e+01
+ -1.0069763481591298e+01 -1.0072569236109324e+01 -1.0075372519978055e+01 -1.0078173421120900e+01 -1.0080972025739802e+01
+ -1.0083768418217982e+01 -1.0086562681022670e+01 -1.0089354894607848e+01 -1.0092145137316983e+01 -1.0094933485285768e+01
+ -1.0097720012344858e+01 -1.0100504789922608e+01 -1.0103287886947809e+01 -1.0106069369752422e+01 -1.0108849301974328e+01
+ -1.0111627744460048e+01 -1.0114404755167495e+01 -1.0117180389068704e+01 -1.0119954698052567e+01 -1.0122727730827581e+01
+ -1.0125499532824573e+01 -1.0128270146099446e+01 -1.0131039609235913e+01 -1.0133807957248235e+01 -1.0136575221483955e+01
+ -1.0139341429526645e+01 -1.0142106605098629e+01 -1.0144870767963736e+01 -1.0147633933830022e+01 -1.0150396114252521e+01
+ -1.0153157316535975e+01 -1.0155917543637569e+01 -1.0158676794069677e+01 -1.0161435061802594e+01 -1.0164192336167272e+01
+ -1.0166948601758056e+01 -1.0169703838335435e+01 -1.0172458020728756e+01 -1.0175211118738986e+01 -1.0177963097041431e+01
+ -1.0180713915088480e+01 -1.0183463527012346e+01 -1.0186211881527797e+01 -1.0188958921834899e+01 -1.0191704585521748e+01
+ -1.0194448804467212e+01 -1.0197191504743666e+01 -1.0199932606519727e+01 -1.0202672023962998e+01 -1.0205409665142799e+01
+ -1.0208145431932909e+01 -1.0210879219914300e+01 -1.0213610918277876e+01 -1.0216340409727207e+01 -1.0219067570381277e+01
+ -1.0221792269677204e+01 -1.0224514370272995e+01 -1.0227233727950273e+01 -1.0229950191517014e+01 -1.0232663602710291e+01
+ -1.0235373796099008e+01 -1.0238080598986633e+01 -1.0240783831313943e+01 -1.0243483305561757e+01 -1.0246178826653672e+01
+ -1.0248870191858806e+01 -1.0251557190694530e+01 -1.0254239604829207e+01 -1.0256917207984930e+01 -1.0259589765840261e+01
+ -1.0262257035932960e+01 -1.0264918767562737e+01 -1.0267574701693977e+01 -1.0270224570858481e+01 -1.0272868099058206e+01
+ -1.0275505001667998e+01 -1.0278134985338333e+01 -1.0280757747898054e+01 -1.0283372978257104e+01 -1.0285980356309270e+01
+ -1.0288579552834918e+01 -1.0291170229403724e+01 -1.0293752038277423e+01 -1.0296324622312538e+01 -1.0298887614863119e+01
+ -1.0301440639683481e+01 -1.0303983310830942e+01 -1.0306515232568561e+01 -1.0309035999267870e+01 -1.0311545195311620e+01
+ -1.0314042394996514e+01 -1.0316527162435939e+01 -1.0318999051462715e+01 -1.0321457605531823e+01 -1.0323902357623144e+01
+ -1.0326332830144201e+01 -1.0328748534832890e+01 -1.0331148972660223e+01 -1.0333533633733062e+01 -1.0335901997196858e+01
+ -1.0338253531138385e+01 -1.0340587692488484e+01 -1.0342903926924793e+01 -1.0345201668774489e+01 -1.0347480340917025e+01
+ -1.0349739354686866e+01 -1.0351978109776224e+01 -1.0354195994137806e+01 -1.0356392383887536e+01 -1.0358566643207302e+01
+ -1.0360718124247692e+01 -1.0362846167030732e+01 -1.0364950099352621e+01 -1.0367029236686468e+01 -1.0369082882085035e+01
+ -1.0371110326083466e+01 -1.0373110846602032e+01 -1.0375083708848861e+01 -1.0377028165222683e+01 -1.0378943455215563e+01
+ -1.0380828805315637e+01 -1.0382683428909857e+01 -1.0384506526186716e+01 -1.0386297284038996e+01 -1.0388054875966501e+01
+ -1.0389778461978798e+01 -1.0391467188497947e+01 -1.0393120188261241e+01 -1.0394736580223954e+01 -1.0396315469462060e+01
+ -1.0397855947074987e+01 -1.0399357090088342e+01 -1.0400817961356656e+01 -1.0402237609466122e+01 -1.0403615068637322e+01
+ -1.0404949358627979e+01 -1.0406239484635684e+01 -1.0407484437200637e+01 -1.0408683192108382e+01 -1.0409834710292550e+01
+ -1.0410937937737589e+01 -1.0411991805381509e+01 -1.0412995229018613e+01 -1.0413947109202235e+01 -1.0414846331147483e+01
+ -1.0415691764633969e+01 -1.0416482263908552e+01 -1.0417216667588075e+01 -1.0417893798562096e+01 -1.0418512463895633e+01
+ -1.0419071454731899e+01 -1.0419569546195037e+01 -1.0420005497292859e+01 -1.0420378050819586e+01 -1.0420685933258582e+01
+ -1.0420927854685091e+01 -1.0421102508668977e+01 -1.0421208572177456e+01 -1.0421244705477843e+01 -1.0421209552040283e+01
+ -1.0421101738440488e+01 -1.0420919874262472e+01 -1.0420662552001298e+01 -1.0420328346965805e+01 -1.0419915817181352e+01
+ -1.0419423503292553e+01 -1.0418849928466011e+01 -1.0418193598293065e+01 -1.0417453000692515e+01 -1.0416626605813368e+01
+ -1.0415712865937575e+01 -1.0414710215385734e+01 -1.0413617070500074e+01 -1.0412431829823557e+01 -1.0411152874356269e+01
+ -1.0409778567814756e+01 -1.0408307256891389e+01 -1.0406737271513702e+01 -1.0405066925103750e+01 -1.0403294514837453e+01
+ -1.0401418321903957e+01 -1.0399436611764969e+01 -1.0397347634414121e+01 -1.0395149624636312e+01 -1.0392840802267063e+01
+ -1.0390419372451863e+01 -1.0387883525905520e+01 -1.0385231439171520e+01 -1.0382461274881363e+01 -1.0379571182013922e+01
+ -1.0376559296154795e+01 -1.0373423739755646e+01 -1.0370162622393568e+01 -1.0366774041030421e+01 -1.0363256080272189e+01
+ -1.0359606812628332e+01 -1.0355824298771129e+01 -1.0351906587795035e+01 -1.0347851717476029e+01 -1.0343657714530963e+01
+ -1.0339322594876915e+01 -1.0334844363890534e+01 -1.0330221016667398e+01 -1.0325450538281361e+01 -1.0320530904043896e+01
+ -1.0315460079763458e+01 -1.0310236022004828e+01 -1.0304856678348457e+01 -1.0299319987649831e+01 -1.0293623880298805e+01
+ -1.0287766278478967e+01 -1.0281745096426983e+01 -1.0275558240691939e+01 -1.0269203610394706e+01 -1.0262679097487283e+01
+ -1.0255982587012145e+01 -1.0249111957361594e+01 -1.0242065080537117e+01 -1.0234839822408725e+01 -1.0227434042974313e+01
+ -1.0219845596618999e+01 -1.0212072332374492e+01 -1.0204112094178418e+01 -1.0195962721133698e+01 -1.0187622047767873e+01
+ -1.0179087904292468e+01 -1.0170358116862344e+01 -1.0161430507835039e+01 -1.0152302896030124e+01 -1.0142973096988554e+01
+ -1.0133438923232017e+01 -1.0123698184522279e+01 -1.0113748688120547e+01 -1.0103588239046804e+01 -1.0093214640339173e+01
+ -1.0082625693313256e+01 -1.0071819197821492e+01 -1.0060792952512505e+01 -1.0049544755090452e+01 -1.0038072402574377e+01
+ -1.0026373691557557e+01 -1.0014446418466857e+01 -1.0002288379822076e+01 -9.9898973724953031e+00 -9.9772711939702585e+00
+ -9.9644076426016532e+00 -9.9513045178745347e+00 -9.9379596206636354e+00 -9.9243707534927275e+00 -9.9105357207939715e+00
+ -9.8964523291672641e+00 -9.8821183876395917e+00 -9.8675317079243801e+00 -9.8526901046808426e+00 -9.8375913957733339e+00
+ -9.8222334025306939e+00 -9.8066139500056071e+00 -9.7907308672339468e+00 -9.7745819874941251e+00 -9.7581651485664445e+00
+ -9.7414781929924530e+00 -9.7245189683342836e+00 -9.7072853274340165e+00 -9.6897751286730180e+00 -9.6719862362312998e+00
+ -9.6539165203468666e+00 -9.6355638575750628e+00 -9.6169261310479293e+00 -9.5980012307335478e+00 -9.5787870536953914e+00
+ -9.5592815043516826e+00 -9.5394824947347328e+00 -9.5193879447502976e+00 -9.4989957824369338e+00 -9.4783039442253330e+00
+ -9.4573103751976895e+00 -9.4360130293470394e+00 -9.4144098698366161e+00 -9.3924988692591977e+00 -9.3702780098964595e+00
+ -9.3477452839783233e+00 -9.3248986939423038e+00 -9.3017362526928693e+00 -9.2782559838607810e+00 -9.2544559220624478e+00
+ -9.2303341131592802e+00 -9.2058886145170291e+00 -9.1811174952651520e+00 -9.1560188365561501e+00 -9.1305907318249240e+00
+ -9.1048312870481283e+00 -9.0787386210035095e+00 -9.0523108655292681e+00 -9.0255461657834068e+00 -8.9984426805030733e+00
+ -8.9709985822639204e+00 -8.9432120577394478e+00 -8.9150813079603601e+00 -8.8866045485739118e+00 -8.8577800101032569e+00
+ -8.8286059382068043e+00 -8.7990805939375658e+00 -8.7692022540025025e+00 -8.7389692110218800e+00 -8.7083797737886162e+00
+ -8.6774322675276352e+00 -8.6461250341552098e+00 -8.6144564325383222e+00 -8.5824248387540027e+00 -8.5500286463486930e+00
+ -8.5172662665975825e+00 -8.4841361287639714e+00 -8.4506366803586115e+00 -8.4167663873990612e+00 -8.3825237346690340e+00
+ -8.3479072259777531e+00 -8.3129153844192913e+00 -8.2775467526319364e+00 -8.2417998930575251e+00 -8.2056733882008075e+00
+ -8.1691658408887857e+00 -8.1322758745300767e+00 -8.0950021333742477e+00 -8.0573432827711784e+00 -8.0192980094304076e+00
+ -7.9808650216804811e+00 -7.9420430497283050e+00 -7.9028308459184942e+00 -7.8632271849927236e+00 -7.8232308643490764e+00
+ -7.7828407043013996e+00 -7.7420555483386462e+00 -7.7008742633842360e+00 -7.6592957400553932e+00 -7.6173188929225066e+00
+ -7.5749426607684773e+00 -7.5321660068480671e+00 -7.4889879191472506e+00 -7.4454074106425647e+00 -7.4014235195604572e+00
+ -7.3570353096366414e+00 -7.3122418703754430e+00 -7.2670423173091514e+00 -7.2214357922573686e+00 -7.1754214635863622e+00
+ -7.1289985264684148e+00 -7.0821662031411714e+00 -7.0349237431669920e+00 -6.9872704236923040e+00 -6.9392055497069496e+00
+ -6.8907284543035328e+00 -6.8418384989367818e+00 -6.7925350736828838e+00 -6.7428175974988447e+00 -6.6926855184818388e+00
+ -6.6421383141285553e+00 -6.5911754915945524e+00 -6.5397965879536049e+00 -6.4880011704570570e+00 -6.4357888367931686e+00
+ -6.3831592153464722e+00 -6.3301119654571139e+00 -6.2766467776802113e+00 -6.2227633740452042e+00 -6.1684615083151986e+00
+ -6.1137409662463194e+00 -6.0586015658470647e+00 -6.0030431576376513e+00 -5.9470656249093672e+00 -5.8906688839839214e+00
+ -5.8338528844727993e+00 -5.7766176095365989e+00
+  0.0000000000000000e+00  9.2997097907380056e-05  3.7076508662388277e-04  8.3146900864105200e-04  1.4732739064504314e-03
+  2.2943448225435648e-03  3.2928467994119965e-03  4.4669448795472706e-03  5.8148041054409301e-03  7.3345895195845185e-03
+  9.0244661644695804e-03  1.0882599082587659e-02  1.2907153316430301e-02  1.5096293908489043e-02  1.7448185901255436e-02
+  1.9960994337221025e-02  2.2632884258877346e-02  2.5462020708715949e-02  2.8446568729228374e-02  3.1584693362906167e-02
+  3.4874559652240865e-02  3.8314332639724030e-02  4.1902177367847168e-02  4.5636258879101867e-02  4.9514742215979644e-02
+  5.3535792420972061e-02  5.7697574536570637e-02  6.1998253605266937e-02  6.6435994669552495e-02  7.1008962771918857e-02
+  7.5715322954857570e-02  8.0553240260860179e-02  8.5520879732418217e-02  9.0616406412023245e-02  9.5837985342166782e-02
+  1.0118378156534040e-01  1.0665196012403562e-01  1.1224068606074401e-01  1.1794812441795709e-01  1.2377244023816641e-01
+  1.2971179856386353e-01  1.3576436443753997e-01  1.4192830290168726e-01  1.4820177899879705e-01  1.5458295777136077e-01
+  1.6107000426187001e-01  1.6766108351281631e-01  1.7435436056669118e-01  1.8114800046598620e-01  1.8804016825319289e-01
+  1.9502902897080282e-01  2.0211274766130749e-01  2.0928948936719854e-01  2.1655741913096738e-01  2.2391470199510566e-01
+  2.3135950300210487e-01  2.3888998719445659e-01  2.4650431961465230e-01  2.5420066530518365e-01  2.6197718930854208e-01
+  2.6983205666721916e-01  2.7776343242370649e-01  2.8576948162049554e-01  2.9384836930007785e-01  3.0199826050494505e-01
+  3.1021732027758864e-01  3.1850371366050012e-01  3.2685560569617111e-01  3.3527116142709307e-01  3.4374854589575760e-01
+  3.5228592414465620e-01  3.6088146121628051e-01  3.6953332215312212e-01  3.7823967199767228e-01  3.8699867579242275e-01
+  3.9580849857986500e-01  4.0466730540249063e-01  4.1357326130279137e-01  4.2252453132325829e-01  4.3151928050638344e-01
+  4.4055567389465788e-01  4.4963187653057352e-01  4.5874605345662195e-01  4.6789636971529436e-01  4.7708099034908247e-01
+  4.8629808040047795e-01  4.9554580491197214e-01  5.0482232892605672e-01  5.1412581748522324e-01  5.2345443563196314e-01
+  5.3280634840876795e-01  5.4217972085812938e-01  5.5157271802253882e-01  5.6098350494448790e-01  5.7041024666646822e-01
+  5.7985110823097108e-01  5.8930425468048819e-01  5.9876785105751118e-01  6.0824006240453143e-01  6.1771905376404057e-01
+  6.2720299017853010e-01  6.3669003669049162e-01  6.4617835834241677e-01  6.5566612017679682e-01  6.6515148723612350e-01
+  6.7463262456288819e-01  6.8410769719958253e-01  6.9357487018869857e-01  7.0303230857272681e-01  7.1247817739415964e-01
+  7.2191064169548835e-01  7.3132786651920434e-01  7.4072801690779921e-01  7.5010925790376470e-01  7.5946975454959231e-01
+  7.6880767188777321e-01  7.7812117496079947e-01  7.8740842881116235e-01  7.9666759848135327e-01  8.0589684901386405e-01
+  8.1509434545118620e-01  8.2425825283581111e-01  8.3338673621023029e-01  8.4247796061693569e-01  8.5153009109841826e-01
+  8.6054129269717006e-01  8.6950973045568214e-01  8.7843356941644646e-01  8.8731097462195430e-01  8.9614011111469760e-01
+  9.0491914393716755e-01  9.1364623813185575e-01  9.2231955874125371e-01  9.3093727080785293e-01  9.3949753937414537e-01
+  9.4799852948262231e-01  9.5643840617577458e-01  9.6481533449609502e-01  9.7312747948607403e-01  9.8137300618820422e-01
+  9.8955007964497632e-01  9.9765686489888195e-01  1.0056915269924132e+00  1.0136522309680611e+00  1.0215371418683172e+00
+  1.0293444247356733e+00  1.0370722446126206e+00  1.0447187665416515e+00  1.0522821555652564e+00  1.0597605767259273e+00
+  1.0671521950661562e+00  1.0744551756284337e+00  1.0816676834552523e+00  1.0887878835891034e+00  1.0958139410724776e+00
+  1.1027440209478674e+00  1.1095762882577644e+00  1.1163089080446598e+00  1.1229400453510443e+00  1.1294678652194112e+00
+  1.1358905326922510e+00  1.1422062128120551e+00  1.1484130706213154e+00  1.1545092711625233e+00  1.1604929794781706e+00
+  1.1663623606107487e+00  1.1721155796027489e+00  1.1777508014966631e+00  1.1832661913349825e+00  1.1886599141601994e+00
+  1.1939301350148044e+00  1.1990750189412893e+00  1.2040927309821459e+00  1.2089814361798654e+00  1.2137392995769400e+00
+  1.2183644862158605e+00  1.2228551611391187e+00  1.2272094893892065e+00  1.2314256360086149e+00  1.2355017660398355e+00
+  1.2394360445253607e+00  1.2432266365076805e+00  1.2468717070292876e+00  1.2503694211326730e+00  1.2537179438603294e+00
+  1.2569154402547467e+00  1.2599600753584173e+00  1.2628500142138330e+00  1.2655834218634840e+00  1.2681584633498639e+00
+  1.2705733037154627e+00  1.2728261080027718e+00  1.2749150412542845e+00  1.2768382685124902e+00  1.2785939548198821e+00
+  1.2801802652189509e+00  1.2815953647521883e+00  1.2828374184620861e+00  1.2839045913911349e+00  1.2847950485818274e+00
+  1.2855069550766554e+00  1.2860384759181085e+00  1.2863877761486799e+00  1.2865530208108606e+00  1.2793826305176494e+00
+  1.2673250906883835e+00  1.2549172906908883e+00  1.2421613699695182e+00  1.2290604327446919e+00  1.2156185151905938e+00
+  1.2018405526128755e+00  1.1877323466263556e+00  1.1733005323327226e+00  1.1585525454982344e+00  1.1434965897314202e+00
+  1.1281416036607821e+00  1.1124972281124943e+00  1.0965737732881067e+00  1.0803821859422440e+00  1.0639340165603077e+00
+  1.0472413865361772e+00  1.0303169553499103e+00  1.0131738877454455e+00  9.9582582090830152e-01  9.7828683164327979e-01
+  9.6057140355216486e-01  9.4269439421142498e-01  9.2467100234991495e-01  9.0651673502657526e-01  8.8824737480813409e-01
+  8.6987894694680845e-01  8.5142768655800549e-01  8.3291000579802255e-01  8.1434246104174979e-01  7.9574172006036969e-01
+  7.7712452919905950e-01  7.5850768055469164e-01  7.3990797915353457e-01  7.2134221012895472e-01  7.0282710589911701e-01
+  6.8437931334468549e-01  6.6601536098652603e-01  6.4775162616340531e-01  6.2960430220969354e-01  6.1158936563306521e-01
+  5.9372254329219953e-01  5.7601927957448196e-01  5.5849470357370568e-01  5.4116359626777222e-01  5.2404035769639246e-01
+  5.0713897413878806e-01  4.9047298529139249e-01  4.7405545144555217e-01  4.5789892066522708e-01  4.4201539596469275e-01
+  4.2641630248624041e-01  4.1111245467787871e-01  3.9611402347103464e-01  3.8143050345825491e-01  3.6707068007090604e-01
+  3.5304259675687688e-01  3.3935352223830245e-01  3.2600992378901666e-01  3.1301746773084194e-01  3.0038103845517961e-01
+  2.8810475903317340e-01  2.7619201182679526e-01  2.6464545909993120e-01  2.5346706362946692e-01  2.4265810931637360e-01
+  2.3221922179679383e-01  2.2215038905312723e-01  2.1245098202511603e-01  2.0311977522093125e-01  1.9415496732825815e-01
+  1.8555420182538210e-01  1.7731458759227425e-01  1.6943271952167757e-01  1.6190469913019218e-01  1.5472615516936150e-01
+  1.4789226423675783e-01  1.4139777138706805e-01  1.3523701074317956e-01  1.2940392610726600e-01  1.2389209157187289e-01
+  1.1869473213100348e-01  1.1380474429120455e-01  1.0921471668265201e-01  1.0491695067023699e-01  1.0090348096465124e-01
+  9.7166096233472998e-02  9.3696359712253097e-02  9.0485629815599933e-02  8.7525080748266371e-02  8.4805723116234133e-02
+  8.2318424537800916e-02  8.0053930254665229e-02  7.8002883743012508e-02  7.6155847324600845e-02  7.4503322777846714e-02
+  7.3035771948910810e-02  7.1743637362783552e-02  7.0617362834371422e-02  6.9647414079582026e-02  6.8824299326410376e-02
+  6.8138589926024340e-02  6.7580940963850533e-02  6.7142111870660215e-02  6.6812987033654792e-02  6.6584596407551655e-02
+  6.6448136125670298e-02  6.6394989111017322e-02  6.6416745687372880e-02  6.6505224190376244e-02  6.6652491578611417e-02
+  6.6850884044693137e-02  6.7093027626352553e-02  6.7371858817522667e-02  6.7680645098163045e-02  6.8013001404330531e-02
+  6.8362891601016412e-02  6.8724621467243091e-02  6.9092831117912229e-02  6.9462487425592620e-02  6.9828876442308188e-02
+  7.0187595821325915e-02  7.0534547238943840e-02  7.0865928816278928e-02  7.1178227541055059e-02  7.1468211689391020e-02
+  7.1732923247588370e-02  7.1969670333919447e-02  7.2176019620415324e-02  7.2349788754653713e-02  7.2489038781546930e-02
+  7.2592066565129898e-02  7.2657397210348001e-02  7.2683776484845114e-02  7.2670163240751526e-02  7.2615721836471858e-02
+  7.2519814558473075e-02  7.2381994043072370e-02  7.2201995698225177e-02  7.1979730125313043e-02  7.1715275540931683e-02
+  7.1408870198678823e-02  7.1060904810942183e-02  7.0671914970687491e-02  7.0242573573246356e-02  6.9773683238104206e-02
+  6.9266168730688332e-02  6.8721069384155745e-02  6.8139531521181143e-02  6.7522800875744943e-02  6.6872215014921063e-02
+  6.6189195760665065e-02  6.5475241611601953e-02  6.4731920164814216e-02  6.3960860537629713e-02  6.3163745789409670e-02
+  6.2342305343336617e-02  6.1498307408202307e-02  6.0633551400195704e-02  5.9749860364690932e-02  5.8849073398035190e-02
+  5.7933038069336716e-02  5.7003602842252768e-02  5.6062609496777542e-02  5.5111885551030103e-02  5.4153236683042394e-02
+  5.3188439152547111e-02  5.2219232222765755e-02  5.1247310582196441e-02  5.0274316766401983e-02  4.9301833579797720e-02
+  4.8331376564057796e-02  4.7364388096796516e-02  4.6402236437358524e-02  4.5446217095529505e-02  4.4497554317539621e-02
+  4.3557402572067347e-02  4.2626848036243378e-02  4.1706910081654475e-02  4.0798542760347362e-02  3.9902636290832599e-02
+  3.9020018544088431e-02  3.8151456529564691e-02  3.7297657881186663e-02  3.6459272343358953e-02  3.5636893256969372e-02
+  3.4831059045392791e-02  3.4042254700495038e-02  3.3270913268636765e-02  3.2517417336677325e-02  3.1782100517978626e-02
+  3.1065248938409028e-02  3.0367102722347213e-02  2.9687857478686061e-02  2.9027665786836500e-02  2.8386638682731422e-02
+  2.7764847144829515e-02  2.7162323580119177e-02  2.6579063310122348e-02  2.6015026056898427e-02  2.5470137429048106e-02
+  2.4944290407717288e-02  2.4437346832600914e-02  2.3949138887946864e-02  2.3479470588559842e-02  2.3028119265805221e-02
+  2.2594837053612940e-02  2.2179352374481362e-02  2.1781371425481165e-02  2.1400579664259203e-02  2.1036643295042384e-02
+  2.0689210754641543e-02  2.0357914198455326e-02  2.0042370986474038e-02  1.9742185169283572e-02  1.9456948974069199e-02
+  1.9186244290619530e-02  1.8929644157330332e-02  1.8686714247208407e-02  1.8457014353875516e-02  1.8240099877572184e-02
+  1.8035523311161619e-02  1.7842835726133571e-02  1.7661588258608224e-02  1.7491333595340032e-02  1.7331627459721631e-02
+  1.7182030097787696e-02  1.7042107764218814e-02  1.6911434194946919e-02  1.6789591739075200e-02  1.6676171637970097e-02
+  1.6570773973054235e-02  1.6473007601139632e-02  1.6382490089760945e-02  1.6298847652508702e-02  1.6221715084362522e-02
+  1.6150735697024354e-02  1.6085561254251708e-02  1.6025851907190875e-02  1.5971276129710176e-02  1.5921510653733175e-02
+  1.5876240404571917e-02  1.5835158436260165e-02  1.5797965866886612e-02  1.5764371813928132e-02  1.5734093329583004e-02
+  1.5706855336104133e-02  1.5682390561132298e-02  1.5660439473029367e-02  1.5640750216211533e-02  1.5623078546482547e-02
+  1.5607187766366951e-02  1.5592848660443300e-02  1.5579839430677396e-02  1.5567945631755526e-02  1.5556960106417680e-02
+  1.5546682920790793e-02  1.5536921299721970e-02  1.5527489562111713e-02  1.5518209056247163e-02  1.5508908095135320e-02
+  1.5499421891836274e-02  1.5489592494796447e-02  1.5479268723181810e-02  1.5468306102211119e-02  1.5456566798489150e-02
+  1.5443919555339920e-02  1.5430239628139927e-02  1.5415408719651377e-02  1.5399314915355412e-02  1.5381852618785347e-02
+  1.5362922486859889e-02  1.5342431365216385e-02  1.5320292223544035e-02  1.5296424090917131e-02  1.5270751991128297e-02
+  1.5243206878021697e-02  1.5213725570826288e-02  1.5182250689489035e-02  1.5148730590008151e-02  1.5113119299766317e-02
+  1.5075376452863939e-02  1.5035467225452334e-02  1.4993362271067007e-02  1.4949037655960845e-02  1.4902474793367241e-02
+  1.4853660357425622e-02  1.4802586154968548e-02  1.4749248983812574e-02  1.4693650490681847e-02  1.4635797029131677e-02
+  1.4575699517472132e-02  1.4513373296691627e-02  1.4448837988380503e-02  1.4382117352654615e-02  1.4313239146078920e-02
+  1.4242234979591060e-02  1.4169140176424953e-02  1.4093993630034373e-02  1.4016837662016540e-02  1.3937717880035701e-02
+  1.3856683035746727e-02  1.3773784882718685e-02  1.3689078034358435e-02  1.3602619821834206e-02  1.3514470151999195e-02
+  1.3424691365315142e-02  1.3333348093775919e-02  1.3240507118831117e-02  1.3146237229309632e-02  1.3050609079343252e-02
+  1.2953695046290240e-02  1.2855569088658921e-02  1.2756306604031270e-02  1.2655984286986496e-02  1.2554679987024631e-02
+  1.2452472566490109e-02  1.2349441758495359e-02  1.2245668024844392e-02  1.2141232413956376e-02  1.2036216418789237e-02
+  1.1930701834763233e-02  1.1824770617684544e-02  1.1718504741668865e-02  1.1611986057064979e-02  1.1505296148378351e-02
+  1.1398516192194716e-02  1.1291726815103655e-02  1.1185007951622193e-02  1.1078438702118380e-02  1.0972097190734872e-02
+  1.0866060423312524e-02  1.0760404145313974e-02  1.0655202699747231e-02  1.0550528885089250e-02  1.0446453813209536e-02
+  1.0343046767293716e-02  1.0240375059767128e-02  1.0138503890218416e-02  1.0037496203323098e-02  9.9374125467671659e-03
+  9.8383109291712428e-03  9.7402466819188661e-03  9.6432723775958431e-03  9.5474378457806510e-03  9.4527902144292287e-03
+  9.3593739517440610e-03  9.2672309080432894e-03  9.1764003576298003e-03  9.0869190406603212e-03  8.9988212050145251e-03
+  8.9121386481641179e-03  8.8269007590419390e-03  8.7431345599110599e-03  8.6608647482338784e-03  8.5801137385412181e-03
+  8.5009017043014192e-03  8.4232466197894425e-03  8.3471643019559626e-03  8.2726684522964611e-03  8.1997706987203302e-03
+  8.1284806374199645e-03  8.0588058747398626e-03  7.9907520690457156e-03  7.9243229725935102e-03  7.8595204733986276e-03
+  7.7963446371049341e-03  7.7347937488538767e-03  7.6748643551535880e-03  7.6165513057479765e-03  7.5598477954858254e-03
+  7.5047454061898874e-03  7.4512341485259868e-03  7.3993025038721072e-03  7.3489374661874982e-03  7.3001245838817622e-03
+  7.2528480016839604e-03  7.2070905025117035e-03  7.1628335493402499e-03  7.1200573270716041e-03  7.0787407844036098e-03
+  7.0388616756990501e-03  7.0003966028547426e-03  6.9633210571706378e-03  6.9276094612189098e-03  6.8932352107130626e-03
+  6.8601707163770207e-03  6.8283874458142232e-03  6.7978559653767293e-03  6.7685459820343062e-03  6.7404263852435314e-03
+  6.7134652888168871e-03  6.6876300727918558e-03  6.6628874253000202e-03  6.6392033844361572e-03  6.6165433801273366e-03
+  6.5948722760020171e-03  6.5741544112591400e-03  6.5543536425369826e-03  6.5354333854283032e-03  6.5173566520176822e-03
+  6.5000860827291651e-03  6.4835839769528895e-03  6.4678123236565242e-03  6.4527328319966947e-03  6.4383069619304185e-03
+  6.4244959548265352e-03  6.4112608640771356e-03  6.3985625857089978e-03  6.3863618889950149e-03  6.3746194470656273e-03
+  6.3632958675202541e-03  6.3523517230387270e-03  6.3417475819927170e-03  6.3314440390571693e-03  6.3214017458217350e-03
+  6.3115814414021979e-03  6.3019439830519141e-03  6.2924503767732339e-03  6.2830618079289403e-03  6.2737396718536781e-03
+  6.2644456044653853e-03  6.2551415128767225e-03  6.2457896060065096e-03  6.2363524251911519e-03  6.2267928747960716e-03
+  6.2170742528271459e-03  6.2071602815421288e-03  6.1970151380620914e-03  6.1866034849828453e-03  6.1758905009863816e-03
+  6.1648419114522972e-03  6.1534240190692265e-03  6.1416037344462762e-03  6.1293486067244525e-03  6.1166268541880961e-03
+  6.1034073948763121e-03  6.0896598771944003e-03  6.0753547105252877e-03  6.0604630958409613e-03  6.0449570563138972e-03
+  6.0288094679284924e-03  6.0119940900924974e-03  5.9944855962484481e-03  5.9762596044850933e-03  5.9572927081488316e-03
+  5.9375625064551386e-03  5.9170476351000012e-03  5.8957277968713457e-03  5.8735837922604724e-03  5.8505975500734858e-03
+  5.8267521580427249e-03  5.8020318934381976e-03  5.7764222536790099e-03  5.7499099869447951e-03  5.7224831227823863e-03
+  5.6941310003337390e-03  5.6648442755251110e-03  5.6346149031875192e-03  5.6034361148169631e-03  5.5713023963015907e-03
+  5.5382094656488724e-03  5.5041542507127767e-03  5.4691348669209409e-03  5.4331505950018441e-03  5.3962018587119789e-03
+  5.3582902025630279e-03  5.3194182695490318e-03  5.2795897788735649e-03  5.2388095036769071e-03  5.1970832487632183e-03
+  5.1544178283277091e-03  5.1108210436838133e-03  5.0663016609903619e-03  5.0208693889787588e-03  4.9745348566801496e-03
+  4.9273095911525917e-03  4.8792059952082328e-03  4.8302373251404808e-03  4.7804176684511793e-03  4.7297619215777766e-03
+  4.6782857676205027e-03  4.6260056540695371e-03  4.5729387705321853e-03  4.5191030264600529e-03  4.4645170288762116e-03
+  4.4092000601023799e-03  4.3531720554860903e-03  4.2964535811278676e-03  4.2390658116083944e-03  4.1810305077156903e-03
+  4.1223699941722808e-03  4.0631071373623722e-03  4.0032653230590238e-03  3.9428684341513203e-03  3.8819408283715454e-03
+  3.8205073160223531e-03  3.7585931377039430e-03  3.6962239420412300e-03  3.6334257634110198e-03  3.5702249996691802e-03
+  3.5066483898778139e-03  3.4427229920324324e-03  3.3784761607891273e-03  3.3139355251917435e-03  3.2491289663990545e-03
+  3.1840845954119305e-03  3.1188307308005151e-03  3.0533958764313958e-03  2.9878086991947791e-03  2.9220980067316605e-03
+  2.8562927251609997e-03  2.7904218768075202e-03  2.7245145580748606e-03  2.6585999183418815e-03  2.5927071398753527e-03
+  2.5268654178846818e-03  2.4611039405772312e-03  2.3954518692136319e-03  2.3299383181630993e-03  2.2645923349587475e-03
+  2.1994428803529058e-03  2.1345188083724330e-03  2.0698488463740329e-03  2.0054615750995687e-03  1.9413854087313789e-03
+  1.8776485749475926e-03  1.8142790949774437e-03  1.7513047636565872e-03  1.6887531294824129e-03  1.6266514746693629e-03
+  1.5650267952042433e-03  1.5039057809015429e-03  1.4433147954587464e-03  1.3832798565116492e-03  1.3238266156896737e-03
+  1.2649803386711844e-03  1.2067658852388022e-03  1.1492076893347199e-03  1.0923297391160173e-03  1.0361555570099772e-03
+  9.8070817976939929e-04  9.2601013852791516e-04  8.7208343885530589e-04  8.1894954081281404e-04  7.6662933900845977e-04
+  7.1514314265235836e-04  6.6451065561203091e-04  6.1475095646772388e-04  5.6588247856772167e-04  5.1792299008366228e-04
+  4.7088957406585209e-04  4.2479860849858322e-04  3.7966574635544441e-04  3.3550589565464143e-04  2.9233319951430707e-04
+  2.5016101620782116e-04  2.0900189921912136e-04  1.6886757729801978e-04  1.2976893451552198e-04  9.1715990319134449e-05
+  5.4717879588186708e-05  1.8782832689143072e-05 -1.6081844469081723e-05 -4.9869790379807304e-05 -8.2575607883271594e-05
+ -1.1419488411131690e-04 -1.4472421043207513e-04 -1.7416120239465045e-04 -2.0250451964407896e-04 -2.2975388206608296e-04
+ -2.5591006459201222e-04 -2.8097487433166438e-04 -3.0495112574198445e-04 -3.2784261579208042e-04 -3.4965409912823895e-04
+ -3.7039126323894082e-04 -3.9006070361987663e-04 -4.0866989893896240e-04 -4.2622718620135506e-04 -4.4274173591446811e-04
+ -4.5822352725298737e-04 -4.7268332322388603e-04 -4.8613264583144118e-04 -4.9858375124224835e-04 -5.1004960495023774e-04
+ -5.2054385694168996e-04 -5.3008081686025093e-04 -5.3867542917194816e-04 -5.4634324833020592e-04 -5.5310041394086113e-04
+ -5.5896362592717857e-04 -5.6395011969486710e-04 -5.6807764129709437e-04 -5.7136442259950323e-04 -5.7382915644522687e-04
+ -5.7549097181990461e-04 -5.7636940901669754e-04 -5.7648439480130357e-04 -5.7585621757697404e-04 -5.7450550254952814e-04
+ -5.7245318689236942e-04 -5.6972049491150123e-04 -5.6632891321054153e-04 -5.6230016585573979e-04 -5.5765618954099132e-04
+ -5.5241910875285390e-04 -5.4661121093556222e-04 -5.4025492165604499e-04 -5.3337277976893904e-04 -5.2598741258160593e-04
+ -5.1812151101914700e-04 -5.0979780478941912e-04 -5.0103903754805071e-04 -4.9186794206345611e-04 -4.8230721538185294e-04
+ -4.7237949399227600e-04 -4.6210732899159407e-04 -4.5151316124952465e-04 -4.4061929657365057e-04 -4.2944788087443444e-04
+ -4.1802087533023452e-04 -4.0636003155232123e-04 -3.9448686674989190e-04 -3.8242263889508624e-04 -3.7018832188800250e-04
+ -3.5780458075041161e-04 -3.4529174904977063e-04 -3.3266981656057215e-04 -3.1995842398746885e-04 -3.0717685830505966e-04
+ -2.9434404809807000e-04 -2.8147855890153187e-04 -2.6859858854096444e-04 -2.5572196247255417e-04 -2.4286612912333505e-04
+ -2.3004815523136905e-04 -2.1728472118592626e-04 -2.0459211636766536e-04 -1.9198623448881365e-04 -1.7948256893334755e-04
+ -1.6709620809717286e-04 -1.5484183072830490e-04 -1.4273370126704902e-04 -1.3078566518618070e-04 -1.1901114433112597e-04
+ -1.0742313226014169e-04 -9.6034189584495559e-05 -8.4856439308646984e-05 -7.3901562170426715e-05 -6.3180791981217669e-05
+ -5.2704910966134872e-05 -4.2484245104205942e-05 -3.2528659468551257e-05 -2.2847553566564271e-05 -1.3449856680091841e-05
+ -4.3440232056146059e-06  4.4619720055730184e-06  1.2960638307182187e-05  2.1144973917749683e-05  2.9008470580457269e-05
+  3.6545118222951634e-05  4.3749409617164234e-05  5.0616345039130586e-05  5.7141436928810434e-05  6.3320714549906993e-05
+  6.9150728649687164e-05  7.4628556118800835e-05  7.9751804651100771e-05  8.4518617403462454e-05  8.8927677655603328e-05
+  9.2978213469903229e-05  9.6670002351223309e-05  1.0000337590672636e-04  1.0297922450569621e-04  1.0559900193935759e-04
+  1.0786473008069576e-04  1.0977900354427605e-04  1.1134499434606407e-04  1.1256645656324487e-04  1.1344773099404305e-04
+  1.1399374981754210e-04  1.1421004125350442e-04  1.1410273413618241e-04  1.1367855806940978e-04  1.1294482701850641e-04
+  1.1190941340013680e-04  1.1058072152932831e-04  1.0896766106640909e-04  1.0707962046394609e-04  1.0492644041368290e-04
+  1.0251838729347787e-04  9.9866126614241900e-05  9.6980696466876490e-05  9.3873480969211684e-05  9.0556183712943992e-05
+  8.7040801210574374e-05  8.3339596342346173e-05  7.9465071803183068e-05  7.5429943549627047e-05  7.1247114246776350e-05
+  6.6929646715223416e-05  6.2490737377992873e-05  5.7943689707479426e-05  5.3301887672385849e-05  4.8578769184660960e-05
+  4.3787799546437554e-05  3.8942444896970305e-05  3.4056145659573840e-05  2.9142289988560576e-05  2.4214187216178740e-05
+  1.9285041299550276e-05  1.4367924267608880e-05  9.4757496680378115e-06  4.6212460142080374e-06 -1.8306976788399674e-07
+ -4.9249188926782925e-06 -9.5922872681133758e-06 -1.4173452048688414e-05 -1.8657008188525129e-05 -2.3031894994429957e-05
+ -2.7287422678955989e-05 -3.1413298913465234e-05 -3.5399655381190294e-05 -3.9237074330296872e-05 -4.2916615126945305e-05
+ -4.6429840808353130e-05 -4.9768844635856674e-05 -5.2926276647973533e-05 -5.5895370213464112e-05 -5.8669968584394239e-05
+ -6.1244551449196675e-05 -6.3614261485733542e-05 -6.5774930914358265e-05 -6.7723108050977510e-05 -6.9456083860113292e-05
+ -7.0971918507965130e-05 -7.2269467915471881e-05 -7.3348410311374060e-05 -7.4209272785275509e-05 -7.4853457490995916e-05
+ -7.5283255314904842e-05 -7.5501820961103332e-05 -7.5513129668962383e-05 -7.5321932983864082e-05 -7.4933714527937166e-05
+ -7.4354645770792539e-05 -7.3591541800258718e-05 -7.2651817093117457e-05 -7.1543441285839158e-05 -7.0274894945318467e-05
+ -6.8855125339609762e-05 -6.7293502208662630e-05 -6.5599773535057480e-05 -6.3784021314740959e-05 -6.1856617327761513e-05
+ -5.9828178909004924e-05 -5.7709524718929791e-05 -5.5511630514303065e-05 -5.3245584918935548e-05 -5.0922545194417428e-05
+ -4.8553693010853809e-05 -4.6150190217600186e-05 -4.3723134613997989e-05 -4.1283515720110101e-05 -3.8842170547456357e-05
+ -3.6409739369749104e-05 -3.3996621493628647e-05 -3.1612931029398814e-05 -2.9268452661762482e-05 -2.6972597420557061e-05
+ -2.4734358451490038e-05 -2.2562266786874458e-05 -2.0464347116364473e-05 -1.8448073557690873e-05 -1.6520325427396535e-05
+ -1.4687343011572024e-05 -1.2954683336591005e-05 -1.1327175939845912e-05 -9.8088786404833397e-06 -8.4030333101395527e-06
+ -7.1120216436761048e-06 -5.9373209299152868e-06 -4.8794598223756021e-06 -3.9379741100074189e-06 -3.1113624879283637e-06
+ -2.3970423281587843e-06 -1.7913054503575497e-06 -1.2892738925572285e-06 -8.8485568189978049e-07 -5.7070060537212769e-07
+ -3.3815598054145351e-07 -1.7722242629096302e-07 -7.6509633555209484e-08 -2.3192136055827416e-08 -2.9650810367507245e-09
+  1.3552527156068805e-20  3.0994205589638529e-09
+  0.0000000000000000e+00  8.8342990367529892e+03  8.2070013250846314e+03  7.6519140576016853e+03  7.1576253217107906e+03
+  6.7147917685333996e+03  6.3157452926445339e+03  5.9541756652979266e+03  5.6248743815462867e+03  5.3235278465011925e+03
+  5.0465503337192386e+03  4.7909490076981820e+03  4.5542147999943263e+03  4.3342341348305781e+03  4.1292174718803708e+03
+  3.9376414167994471e+03  3.7582017807769503e+03  3.5897754784849544e+03  3.4313895631611263e+03  3.2821960273655063e+03
+  3.1414512636776221e+03  3.0084992937042016e+03  2.8827580462872088e+03  2.7637081048214536e+03  2.6508834556231250e+03
+  2.5438638595811158e+03  2.4422685420978023e+03  2.3457509549889924e+03  2.2539944113062188e+03  2.1667084321773791e+03
+  2.0836256755132158e+03  2.0044993412310068e+03  1.9291009676576111e+03  1.8572185499222339e+03  1.7886549241842552e+03
+  1.7232263720671444e+03  1.6607614081722411e+03  1.6010997204180164e+03  1.5440912385071952e+03  1.4895953103201718e+03
+  1.4374799696736695e+03  1.3876212818337547e+03  1.3399027555653224e+03  1.2942148124433500e+03  1.2504543057311312e+03
+  1.2085240824170669e+03  1.1683325830506733e+03  1.1297934748756393e+03  1.0928253144595619e+03  1.0573512365959859e+03
+  1.0232986667283495e+03  9.9059905453660645e+02  9.5918762665123450e+02  9.2900315672853026e+02  8.9998775134568893e+02
+  8.7208665036240245e+02  8.4524804055413153e+02  8.1942288145628095e+02  7.9456474247249866e+02  7.7062965039780931e+02
+  7.4757594659113249e+02  7.2536415310423763e+02  7.0395684713727451e+02  6.8331854324621315e+02  6.6341558277611887e+02
+  6.4421603003716893e+02  6.2568957477859749e+02  6.0780744054996512e+02  5.9054229856991731e+02  5.7386818675037807e+02
+  5.5776043354930778e+02  5.4219558634808789e+02  5.2715134407055677e+02  5.1260649377990535e+02  4.9854085100731487e+02
+  4.8493520358247264e+02  4.7177125875114280e+02  4.5903159337887354e+02  4.4669960705283268e+02  4.3475947790574247e+02
+  4.2319612099703301e+02  4.1199514909672041e+02  4.0114283572718841e+02  3.9062608032708948e+02  3.8043237541001702e+02
+  3.7054977559848021e+02  3.6096686842109415e+02  3.5167274676778874e+02  3.4265698290430367e+02  3.3390960395328472e+02
+  3.2542106875495853e+02  3.1718224602567994e+02  3.0918439373761760e+02  3.0141913964751132e+02  2.9387846290681603e+02
+  2.8655467668964332e+02  2.7944041177877153e+02  2.7252860105360065e+02  2.6581246482732371e+02  2.5928549698376520e+02
+  2.5294145186732197e+02  2.4677433188225027e+02  2.4077837576016418e+02  2.3494804745709024e+02  2.2927802564373516e+02
+  2.2376319375480338e+02  2.1839863056524442e+02  2.1317960126322964e+02  2.0810154899146181e+02  2.0316008683011131e+02
+  1.9835099019626298e+02  1.9367018963625438e+02  1.8911376398868239e+02  1.8467793389717792e+02  1.8035905565328247e+02
+  1.7615361535092444e+02  1.7205822333508456e+02  1.6806960892826515e+02  1.6418461541934215e+02  1.6040019530028604e+02
+  1.5671340573708554e+02  1.5312140426201097e+02  1.4962144467510271e+02  1.4621087314347929e+02  1.4288712448772071e+02
+  1.3964771864520870e+02  1.3649025730088945e+02  1.3341242067647886e+02  1.3041196446964571e+02  1.2748671693519691e+02
+  1.2463457610074575e+02  1.2185350710977711e+02  1.1914153968542540e+02  1.1649676570866561e+02  1.1391733690497109e+02
+  1.1140146263383544e+02  1.0894740777586567e+02  1.0655349071245737e+02  1.0421808139334001e+02  1.0193959948754595e+02
+  9.9716512613604962e+01  9.7547334644998983e+01  9.5430624087132699e+01  9.3364982522282276e+01  9.1349053119179544e+01
+  8.9381519204072674e+01  8.7461102890276990e+01  8.5586563763391609e+01  8.3756697619513204e+01  8.1970335253919700e+01
+  8.0226341297834395e+01  7.8523613101009190e+01  7.6861079657985258e+01  7.5237700576005253e+01  7.3652465082655709e+01
+  7.2104391071422313e+01  7.0592524183434080e+01  6.9115936923762746e+01  6.7673727810730199e+01  6.6265020556753072e+01
+  6.4888963279334178e+01  6.3544727740876631e+01  6.2231508616067572e+01  6.0948522785639618e+01  5.9695008655379048e+01
+  5.8470225499306551e+01  5.7273452826008466e+01  5.6103989767148910e+01  5.4961154487238851e+01  5.3844283613785379e+01
+  5.2752731686985058e+01  5.1685870628166668e+01  5.0643089226227275e+01  4.9623792641339534e+01  4.8627401925245294e+01
+  4.7653353557479761e+01  4.6701098996903198e+01  4.5770104247945497e+01  4.4859849440995703e+01  4.3969828426395587e+01
+  4.3099548381520137e+01  4.2248529430451676e+01  4.1416304275776220e+01  4.0602417842051644e+01  3.9806426930516906e+01
+  3.9027899884631488e+01  3.8266416266050300e+01  3.7521566540658370e+01  3.6792951774303944e+01  3.6080183337885302e+01
+  3.5382882621460709e+01  3.4700680757064504e+01  3.4033218349925853e+01  3.3380145217799353e+01  3.2741120138128188e+01
+  3.2115810602772221e+01  3.1503892580044035e+01  3.0905050283806386e+01  3.0318975949394279e+01  2.9745369616134131e+01
+  2.9183938916241342e+01  2.8634398869886738e+01  2.8096471686229247e+01  2.7569886570221179e+01  2.7278462183622882e+01
+  2.7130133422810708e+01  2.6979073245903173e+01  2.6825294128961758e+01  2.6668814279229863e+01  2.6509657562619978e+01
+  2.6347853425326516e+01  2.6183436809564263e+01  2.6016448063432513e+01  2.5846932844904774e+01  2.5674942019944211e+01
+  2.5500531554744672e+01  2.5323762402097351e+01  2.5144700381883162e+01  2.4963416055690665e+01  2.4779984595559714e+01
+  2.4594485646850718e+01  2.4407003185239528e+01  2.4217625367838004e+01  2.4026444378440196e+01  2.3833556266894210e+01
+  2.3639060782599650e+01  2.3443061202130771e+01  2.3245664150985245e+01  2.3046979419458584e+01  2.2847119772644181e+01
+  2.2646200754559022e+01  2.2444340486395031e+01  2.2241659458896073e+01  2.2038280318860583e+01  2.1834327649769833e+01
+  2.1629927746541870e+01  2.1425208384411089e+01  2.1220298581933424e+01  2.1015328358117234e+01  2.0810428483679775e+01
+  2.0605730226429358e+01  2.0401365090773144e+01  2.0197464551350560e+01  1.9994159780792394e+01  1.9791581371605510e+01
+  1.9589859052183197e+01  1.9389121396941210e+01  1.9189495530579396e+01  1.8991106826469011e+01  1.8794078599165648e+01
+  1.8598531791047833e+01  1.8404584653081244e+01  1.8212352419708605e+01  1.8021946977865174e+01  1.7833476530119942e+01
+  1.7647045251942412e+01  1.7462752943095069e+01  1.7280694673151451e+01  1.7100960421139916e+01  1.6923634709313010e+01
+  1.6748796231042490e+01  1.6576517473520898e+01  1.6406864386019357e+01  1.6239896276829739e+01  1.6075665870283370e+01
+  1.5914219381759430e+01  1.5755596597278196e+01  1.5599830957671385e+01  1.5446949647329552e+01  1.5296973687526551e+01
+  1.5149918034321063e+01  1.5005791681035209e+01  1.4864597765310195e+01  1.4726333680739076e+01  1.4590991193076528e+01
+  1.4458556561025732e+01  1.4329010661602315e+01  1.4202329120075332e+01  1.4078482444485358e+01  1.3957436164739612e+01
+  1.3839150976284166e+01  1.3723582888353222e+01  1.3610683376795446e+01  1.3500399541477368e+01  1.3392674268263864e+01
+  1.3287446395575703e+01  1.3184650885524141e+01  1.3084218999622600e+01  1.2986078479075426e+01  1.2890153729643673e+01
+  1.2796366011087997e+01  1.2704633631188605e+01  1.2614872144342247e+01  1.2526994554736318e+01  1.2440911524099979e+01
+  1.2356531584032396e+01  1.2273761352908005e+01  1.2192505757358861e+01  1.2112668258334056e+01  1.2034151081736201e+01
+  1.1956855453634979e+01  1.1880681840057754e+01  1.1805530191357258e+01  1.1731300191156347e+01  1.1657891509869815e+01
+  1.1585204062803282e+01  1.1513138272829140e+01  1.1441595337639587e+01  1.1370477501576701e+01  1.1299688332039603e+01
+  1.1229133000468678e+01  1.1158718567906853e+01  1.1088354275137975e+01  1.1017951837402222e+01  1.0947425743688582e+01
+  1.0876693560604437e+01  1.0805676240822169e+01  1.0734298436102865e+01  1.0662488813842502e+01  1.0590180325324747e+01
+  1.0517310281688191e+01  1.0443820318596897e+01  1.0369656351322176e+01  1.0294768527498361e+01  1.0219111177553316e+01
+  1.0142642762813686e+01  1.0065325821284921e+01  9.9871269111060172e+00  9.9080165516790419e+00  9.8279691624733783e+00
+  9.7469629995047313e+00  9.6649800894888909e+00  9.5820061616702272e+00  9.4980305773249505e+00  9.4130462569391149e+00
+  9.3270496050613545e+00  9.2400404328304102e+00  9.1520218781773579e+00  9.0630003237026173e+00  8.9729853122277010e+00
+  8.8819894600217104e+00  8.7900283677025790e+00  8.6971205288130768e+00  8.6032872360715515e+00  8.5085524852974181e+00
+  8.4129428770114139e+00  8.3164875157105769e+00  8.2192179068180042e+00  8.1211678513073320e+00  8.0223733380019766e+00
+  7.9228724335491307e+00  7.8227051700684971e+00  7.7219134304757784e+00  7.6205408314809153e+00  7.5186326042610698e+00
+  7.4162354728083679e+00  7.3133975299523755e+00  7.2101681110573379e+00  7.1065976653941645e+00  7.0027376251871578e+00
+  6.8986402723354967e+00  6.7943586028094662e+00  6.6899461887214411e+00  6.5854570380716106e+00  6.4809454521684611e+00
+  6.3764658807239991e+00  6.2720727746237346e+00  6.1678204363714011e+00  6.0637628682084346e+00  5.9599536179081953e+00
+  5.8564456222449470e+00  5.7532910481375703e+00  5.6505411314680476e+00  5.5482460135746692e+00  5.4464545754200211e+00
+  5.3452142703577827e+00  5.2445709869916470e+00  5.1445690088286282e+00  5.0452510201228318e+00  4.9466581145814432e+00
+  4.8488298046203120e+00  4.7518040311691072e+00  4.6556171740260552e+00  4.5603040627622518e+00  4.4658979881755521e+00
+  4.3724307142940440e+00  4.2799324909290863e+00  4.1884320667779420e+00  4.0979567030759734e+00  4.0085321877984246e+00
+  3.9201828504117784e+00  3.8329315771746888e+00  3.7467998269884961e+00  3.6618076477973163e+00  3.5779736935377078e+00
+  3.4953152416379174e+00  3.4138482110667057e+00  3.3335871809317434e+00  3.2545454096275939e+00  3.1767348545332670e+00
+  3.1001661922593531e+00  3.0248488394447373e+00  2.9507909741028837e+00  2.8779995575177062e+00  2.8064803566890135e+00
+  2.7362379673275257e+00  2.6672758373994809e+00  2.5995962912208110e+00  2.5332005541008926e+00  2.4680887775358853e+00
+  2.4042600649516404e+00  2.3417124979961872e+00  2.2804431633818005e+00  2.2204481802766485e+00  2.1617227282460036e+00
+  2.1042610757430538e+00  2.0480566091492669e+00  1.9931018623643559e+00  1.9393885469458054e+00  1.8869075827979802e+00
+  1.8356491294108148e+00  1.7856026176480790e+00  1.7367567820852183e+00  1.6890996938967773e+00  1.6426187942933943e+00
+  1.5973009285083786e+00  1.5531323803338661e+00  1.5100989072065427e+00  1.4681857758429653e+00  1.4273777984244371e+00
+  1.3876593693314769e+00  1.3490145024278581e+00  1.3114268686580710e+00  1.2748798281722105e+00  1.2393564478121359e+00
+  1.2048395129716807e+00  1.1713115394082239e+00  1.1387547852242237e+00  1.1071512630187155e+00  1.0764827522087721e+00
+  1.0467308115209235e+00  1.0178767916525440e+00  9.8990184810319737e-01  9.6278695417594817e-01  9.3651291414863236e-01
+  9.1106037661509254e-01  8.8640984799637590e-01  8.6254170622189252e-01  8.3943621458053852e-01  8.1707353574178043e-01
+  7.9543374594670280e-01  7.7449684936901708e-01  7.5424279264603467e-01  7.3465147957960164e-01  7.1570278600699588e-01
+  6.9737657484178617e-01  6.7965271128465610e-01  6.6251107820418742e-01  6.4593159168760816e-01  6.2989421676150215e-01
+  6.1437898328248175e-01  5.9936600199782242e-01  5.8483548077606018e-01  5.7076774100755190e-01  5.5714323417499678e-01
+  5.4394255859392304e-01  5.3114647632313317e-01  5.1873593024511588e-01  5.0669206131641742e-01  4.9499622598797677e-01
+  4.8363001379542403e-01  4.7257526511933901e-01  4.6181408911547528e-01  4.5132888181494402e-01  4.4110234439436219e-01
+  4.3111750161596285e-01  4.2135772043766728e-01  4.1180672879312069e-01  4.0244863454168878e-01  3.9326794458841946e-01
+  3.8424958417396410e-01  3.7537891633446374e-01  3.6664176153139616e-01  3.5802441745138719e-01  3.4951367897598101e-01
+  3.4109685832137804e-01  3.3276180534813171e-01  3.2449692804080865e-01  3.1629121315760772e-01  3.0813424665516481e-01
+  3.0001622676019513e-01  2.9192796150495809e-01  2.8386086113546549e-01  2.7580693020430763e-01  2.6775875948303829e-01
+  2.5970951769411815e-01  2.5165294306241781e-01  2.4358333468627938e-01  2.3549554372813711e-01  2.2738496442469677e-01
+  2.1924752491667440e-01  2.1107967789809329e-01  2.0287839108514072e-01  1.9464113750458306e-01  1.8636588560174003e-01
+  1.7805108916801762e-01  1.6969567708800051e-01  1.6129904290610275e-01  1.5286103421277800e-01  1.4438194185028813e-01
+  1.3586248893803118e-01  1.2730381971742813e-01  1.1870748821636851e-01  1.1007544673321502e-01  1.0141003414036709e-01
+  9.2713964007383326e-02  8.3990312543663015e-02  7.5242506360686398e-02  6.6474310053814031e-02  5.7689813603644897e-02
+  4.8893419596933579e-02  4.0089830267066549e-02  3.1284034354096817e-02  2.2481293784338292e-02  1.3687130169518384e-02
+  4.9073111254899259e-03 -3.8521635894979869e-03 -1.2585076116970385e-02 -2.1285004720837920e-02 -2.9945338190449044e-02
+ -3.8559290424083549e-02 -4.7119915192887392e-02 -5.5620121085247991e-02 -6.4052686631611233e-02 -7.2410275609738992e-02
+ -8.0685452530408028e-02 -8.8870698303550003e-02 -9.6958426084832169e-02 -1.0494099730267983e-01 -1.1281073786573897e-01
+ -1.2055995455078064e-01 -1.2818095157104611e-01 -1.3566604732503332e-01 -1.4300759132572405e-01 -1.5019798131025228e-01
+ -1.5722968052997327e-01 -1.6409523493857331e-01 -1.7078728645517963e-01 -1.7729857929232962e-01 -1.8362196447741203e-01
+ -1.8975040437343330e-01 -1.9567697723401276e-01 -2.0139488179260684e-01 -2.0689744188596199e-01 -2.1217811111179632e-01
+ -2.1723047752071062e-01 -2.2204826834232777e-01 -2.2662535474566126e-01 -2.3095575663371226e-01 -2.3503364747229616e-01
+ -2.3885335915309744e-01 -2.4240938689095354e-01 -2.4569639415536773e-01 -2.4870921763625073e-01 -2.5144287224389122e-01
+ -2.5389255614315531e-01 -2.5605365582191481e-01 -2.5792175119370414e-01 -2.5949262073460666e-01 -2.6076224665436920e-01
+ -2.6172682010174619e-01 -2.6238274640407183e-01 -2.6272665034106191e-01 -2.6275538145284394e-01 -2.6246601938221659e-01
+ -2.6185587925113751e-01 -2.6092251707144037e-01 -2.5966373518978081e-01 -2.5807758776681100e-01 -2.5616238629058313e-01
+ -2.5391670512418207e-01 -2.5133938708758635e-01 -2.4842954907375867e-01 -2.4518658769896470e-01 -2.4161018498732090e-01
+ -2.3770031408957162e-01 -2.3345724503609439e-01 -2.2888155052413470e-01 -2.2397411173926915e-01 -2.1873612421109775e-01
+ -2.1316910370316533e-01 -2.0727489213711095e-01 -2.0105566355104734e-01 -1.9451393009216808e-01 -1.8765254804358483e-01
+ -1.8047472388539196e-01 -1.7298402038996186e-01 -1.6518436275146683e-01 -1.5708004474963277e-01 -1.4867573494771869e-01
+ -1.3997648292472739e-01 -1.3098772554184357e-01 -1.2171529324270816e-01 -1.1216541582556626e-01 -1.0234472190925052e-01
+ -9.2260229288804438e-02 -8.1919333215865031e-02 -7.1329794511088632e-02 -6.0499727532710351e-02 -4.9437588001237445e-02
+ -3.8152160680276395e-02 -2.6652546913493932e-02 -1.4948152017711843e-02 -3.0486725321354209e-03  9.0359166762838394e-03
+  2.1295375451352423e-02  3.3719211530004255e-02  4.6296693868537256e-02  5.9016866112715421e-02  7.1868560211737278e-02
+  8.4840410176070885e-02  9.7920865979154156e-02  1.1109820760296261e-01  1.2436055922744192e-01  1.3769590356380762e-01
+  1.5109209633171089e-01  1.6453688088026996e-01  1.7801790295296821e-01  1.9152272559641853e-01  2.0503884421299323e-01
+  2.1855370175732097e-01  2.3205470407664913e-01  2.4552923539507274e-01  2.5896467394162975e-01  2.7234840772226199e-01
+  2.8566785043564269e-01  2.9891045753287021e-01  3.1206374242102769e-01  3.2511529281060886e-01  3.3805278720681059e-01
+  3.5086401154469110e-01  3.6353687596819373e-01  3.7605943175303919e-01  3.8841988837348079e-01  4.0060663071292868e-01
+  4.1260823641843841e-01  4.2441349339906681e-01  4.3601141746809313e-01  4.4739127012910757e-01  4.5854257650596414e-01
+  4.6945514341660194e-01  4.8011907759073097e-01  4.9052480403138443e-01  5.0066308452033814e-01  5.1052503626739443e-01
+  5.2010215070353438e-01  5.2938631241793399e-01  5.3836981823884844e-01  5.4704539645836114e-01  5.5540622619862279e-01
+  5.6344595573331646e-01  5.7115871041350930e-01  5.7853908806658183e-01  5.8558215213010079e-01  5.9228342467286632e-01
+  5.9863887931959447e-01  6.0464493407923459e-01  6.1029844407692224e-01  6.1559669418956708e-01  6.2053739158507648e-01
+  6.2511865816521317e-01  6.2933902291208887e-01  6.3319741413829345e-01  6.3669315164065821e-01  6.3982593875765492e-01
+  6.4259585433043032e-01  6.4500334456747532e-01  6.4704921481292965e-01  6.4873462121852099e-01  6.5006106231914085e-01
+  6.5103037051205370e-01  6.5164470343974290e-01  6.5190653527639031e-01  6.5181864791799282e-01  6.5138412207611218e-01
+  6.5060632827526188e-01  6.4948891775392703e-01  6.4803581326922199e-01  6.4625119980518075e-01  6.4413951518468393e-01
+  6.4170544058502099e-01  6.3895389095708643e-01  6.3589000534821249e-01  6.3251913712863628e-01  6.2884684412160230e-01
+  6.2487887863710012e-01  6.2062117740923728e-01  6.1607985143724708e-01  6.1126117573013183e-01  6.0617157895494167e-01
+  6.0081763298868740e-01  5.9520604237388985e-01  5.8934363367776299e-01  5.8323734475503419e-01  5.7689421391439677e-01
+  5.7032136898860120e-01  5.6352601630817856e-01  5.5651542957880051e-01  5.4929693866227447e-01  5.4187791826117349e-01
+  5.3426577650710128e-01  5.2646794345259373e-01  5.1849185946665322e-01  5.1034496353392000e-01  5.0203468145747854e-01
+  4.9356841396529821e-01  4.8495352472325376e-01  4.7619732893354827e-01  4.6730708664821574e-01  4.5829000081265969e-01
+  4.4915321596764446e-01  4.3990381694903630e-01  4.3054882758255941e-01  4.2109520937356787e-01  4.1154986019183187e-01
+  4.0191961295133999e-01  3.9221123428511628e-01  3.8243142321505269e-01  3.7258680981675668e-01  3.6268395387941410e-01
+  3.5272934356066771e-01  3.4272939403650976e-01  3.3269044614619120e-01  3.2261876503214543e-01  3.1252053877492703e-01
+  3.0240187702316645e-01  2.9226880961853935e-01  2.8212728521575114e-01  2.7198316989753757e-01  2.6184224578467924e-01
+  2.5171020964103258e-01  2.4159267147357527e-01  2.3149515312746743e-01  2.2142308687612733e-01  2.1138181400632339e-01
+  2.0137658339828018e-01  1.9141255010080074e-01  1.8149477390140353e-01  1.7162821789147467e-01  1.6181774702643567e-01
+  1.5206812668092601e-01  1.4238402119900131e-01  1.3276999243934667e-01  1.2323049831550495e-01  1.1376989133112067e-01
+  1.0439241711019895e-01  9.5102212922379609e-02  8.5903306203226615e-02  7.6799613069532952e-02  6.7794936829640232e-02
+  5.8892966488774019e-02  5.0097275249394072e-02  4.1411319006559928e-02  3.2838434838311940e-02  2.4381839491067266e-02
+  1.6044627860030844e-02  7.8297714646224231e-03 -2.5988308108209447e-04 -8.2216156028933011e-03 -1.6052833906036418e-02
+ -2.3751075319663275e-02 -3.1314008246350417e-02 -3.8739433716580306e-02 -4.6025286946142677e-02 -5.3169638636067842e-02
+ -6.0170694788170609e-02 -6.7026795278722046e-02 -7.3736412276759297e-02 -8.0298148642961378e-02 -8.6710736309347017e-02
+ -9.2973034639794477e-02 -9.9084028771383281e-02 -1.0504282793655832e-01 -1.1084866376611545e-01 -1.1650088857300951e-01
+ -1.2199897361698415e-01 -1.2734250735002381e-01 -1.3253119364262755e-01 -1.3756484999090501e-01 -1.4244340570449443e-01
+ -1.4716690007530242e-01 -1.5173548052706609e-01 -1.5614940074573705e-01 -1.6040901879068709e-01 -1.6451479518673676e-01
+ -1.6846729099700472e-01 -1.7226716587658031e-01 -1.7591517610701726e-01 -1.7941217261164996e-01 -1.8275909895173134e-01
+ -1.8595698930339311e-01 -1.8900696641542775e-01 -1.9191023954789269e-01 -1.9466810239153629e-01 -1.9728193096804625e-01
+ -1.9975318151111940e-01 -2.0208338832835415e-01 -2.0427416164396450e-01 -2.0632718542231629e-01 -2.0824421517228534e-01
+ -2.1002707573243765e-01 -2.1167765903703187e-01 -2.1319792186284306e-01 -2.1458988355680936e-01 -2.1585562374450007e-01
+ -2.1699728001940594e-01 -2.1801704561305141e-01 -2.1891716704592903e-01 -2.1969994175925570e-01 -2.2036771572755087e-01
+ -2.2092288105203722e-01 -2.2136787353486251e-01 -2.2170517023414441e-01 -2.2193728699983664e-01 -2.2206677599041749e-01
+ -2.2209622317039979e-01 -2.2202824578866409e-01 -2.2186548983761237e-01 -2.2161062749314489e-01 -2.2126635453545848e-01
+ -2.2083538775139458e-01 -2.2032046237423233e-01 -2.1972432976490952e-01 -2.1904975525605508e-01 -2.1829951599613889e-01
+ -2.1747639877815117e-01 -2.1658319785280239e-01 -2.1562271272624234e-01 -2.1459774594229974e-01 -2.1351110084924138e-01
+ -2.1236557935105121e-01 -2.1116397964322933e-01 -2.0990909393311105e-01 -2.0860370614470575e-01 -2.0725058960805529e-01
+ -2.0585250473311290e-01 -2.0441219666814164e-01 -2.0293239294263279e-01 -2.0141580109474408e-01 -1.9986510628325799e-01
+ -1.9828296888405977e-01 -1.9667202207113554e-01 -1.9503486938209003e-01 -1.9337408226818448e-01 -1.9169219762889425e-01
+ -1.8999171533098655e-01 -1.8827509571211762e-01 -1.8654475706895043e-01 -1.8480307312979169e-01 -1.8305237051174927e-01
+ -1.8129492616240900e-01 -1.7953296478603167e-01 -1.7776865625427024e-01 -1.7600411300140606e-01 -1.7424138740410586e-01
+ -1.7248246914569818e-01 -1.7072928256496986e-01 -1.6898368398948235e-01 -1.6724745905340796e-01 -1.6552231999988598e-01
+ -1.6380990296789866e-01 -1.6211176526366725e-01 -1.6042938261656772e-01 -1.5876414641956652e-01 -1.5711736095417617e-01
+ -1.5549024059993077e-01 -1.5388390702838151e-01 -1.5229938638161178e-01 -1.5073760643527248e-01 -1.4919939374613722e-01
+ -1.4768547078417713e-01 -1.4619645304915579e-01 -1.4473284617174415e-01 -1.4329504299915502e-01 -1.4188332066529785e-01
+ -1.4049783764545301e-01 -1.3913863079546629e-01 -1.3780561239706929e-01 -1.3649856829914062e-01 -1.3521716022134897e-01
+ -1.3396093047319188e-01 -1.3272930687171622e-01 -1.3152160769681837e-01 -1.3033704668410326e-01 -1.2917473805530275e-01
+ -1.2803370158625274e-01 -1.2691286771242988e-01 -1.2581108267204713e-01 -1.2472711368670826e-01 -1.2365965417962192e-01
+ -1.2260732903137447e-01 -1.2156869987326202e-01 -1.2054227041818155e-01 -1.1952649182908136e-01 -1.1851976812497027e-01
+ -1.1752046162448627e-01 -1.1652689842702410e-01 -1.1553737393142198e-01 -1.1455015839220747e-01 -1.1356350251340254e-01
+ -1.1257564307988745e-01 -1.1158480862632418e-01 -1.1058922514363864e-01 -1.0958712182306207e-01 -1.0857673683773177e-01
+ -1.0755632316185046e-01 -1.0652415442740540e-01 -1.0547853081844606e-01 -1.0441778500292122e-01 -1.0334028810207509e-01
+ -1.0224445569740252e-01 -1.0112875387516343e-01 -9.9991705308456247e-02 -9.8831895376850470e-02 -9.7647978323578369e-02
+ -9.6438683450285945e-02 -9.5202821349342617e-02 -9.3939290173710527e-02 -9.2647081944372572e-02 -9.1325288895319712e-02
+ -8.9973109856097327e-02 -8.8589856671910855e-02 -8.7174960661290310e-02 -8.5727979111313968e-02 -8.4248601810391496e-02
+ -8.2736657618605616e-02 -8.1192121075613397e-02 -7.9615119046106353e-02 -7.8005937402829836e-02 -7.6365027747161446e-02
+ -7.4693014167248592e-02 -7.2990700033705141e-02 -7.1259074832867211e-02 -6.9499321037608100e-02 -6.7712820923354969e-02
+ -6.5901160107111112e-02 -6.4066120891129577e-02 -6.2209670691498693e-02 -6.0333950135956584e-02 -5.8441261080449204e-02
+ -5.6534054544433610e-02 -5.4614918564926430e-02 -5.2686565969297369e-02 -5.0751822066808075e-02 -4.8813612258896008e-02
+ -4.6874949568203574e-02 -4.4938922086352362e-02 -4.3008680340462659e-02 -4.1087424578417943e-02 -3.9178391972874774e-02
+ -3.7284843744017693e-02 -3.5410052201059326e-02 -3.3557287702485700e-02 -3.1729805535046687e-02 -2.9930832711491596e-02
+ -2.8163554687050011e-02 -2.6431101994657751e-02 -2.4736536798927952e-02 -2.3082839368867399e-02 -2.1472894469338023e-02
+ -1.9909477671263467e-02 -1.8395241580580961e-02 -1.6932701985938253e-02 -1.5524223925135741e-02 -1.4172007670313871e-02
+ -1.2878074631885497e-02 -1.1644253181213633e-02 -1.0472164392034196e-02 -9.3632077006240572e-03 -8.3185464847141538e-03
+ -7.3390935611478345e-03 -6.4254966022843510e-03 -5.5781234711475324e-03 -4.7970474753196010e-03 -4.0820325395801672e-03
+ -3.4325182972903961e-03 -2.8476051005224315e-03 -2.3260389489337587e-03 -1.8661963373870153e-03 -1.4660690223147327e-03
+ -1.1232487068294067e-03 -8.3491164457871465e-04 -5.9780316234579387e-04 -4.0822210139476701e-04 -2.6200517756151887e-04
+ -1.5451126008946922e-04 -8.0605569210626379e-05 -3.4643792471779022e-05 -1.0456119805897798e-05 -1.3311973486344696e-06
+  1.0234868508262941e-17  1.3803772686861652e-06
Added: SwiftApps/ematter/workflow-run/Ta.psf
--- SwiftApps/ematter/workflow-run/Ta.psf	                        (rev 0)
+++ SwiftApps/ematter/workflow-run/Ta.psf	2015-01-27 22:12:52 UTC (rev 8376)
@@ -0,0 +1,3041 @@
+ Ta ca rel nc
+ ATM3      14-OCT-14 Troullier-Martins
+ 6s 2.00r r= 2.78/6p 0.00r r= 2.89/5d 3.00r r= 2.48/5f 0.00r r= 2.48/
+   4  3 1206  0.339555092694E-04  0.125000000000E-01   5.00000000000
+ Radial grid follows
+  0.427107727883E-06  0.859587809623E-06  0.129750782111E-05  0.174093618825E-05
+  0.218994219761E-05  0.264459600730E-05  0.310496865791E-05  0.357113208359E-05
+  0.404315912333E-05  0.452112353232E-05  0.500509999346E-05  0.549516412907E-05
+  0.599139251265E-05  0.649386268092E-05  0.700265314585E-05  0.751784340698E-05
+  0.803951396385E-05  0.856774632853E-05  0.910262303842E-05  0.964422766909E-05
+  0.101926448474E-04  0.107479602645E-04  0.113102606897E-04  0.118796339836E-04
+  0.124561691119E-04  0.130399561593E-04  0.136310863439E-04  0.142296520308E-04
+  0.148357467472E-04  0.154494651966E-04  0.160709032738E-04  0.167001580797E-04
+  0.173373279367E-04  0.179825124039E-04  0.186358122926E-04  0.192973296823E-04
+  0.199671679365E-04  0.206454317187E-04  0.213322270089E-04  0.220276611205E-04
+  0.227318427164E-04  0.234448818263E-04  0.241668898641E-04  0.248979796450E-04
+  0.256382654033E-04  0.263878628102E-04  0.271468889917E-04  0.279154625472E-04
+  0.286937035680E-04  0.294817336557E-04  0.302796759417E-04  0.310876551061E-04
+  0.319057973972E-04  0.327342306516E-04  0.335730843134E-04  0.344224894554E-04
+  0.352825787988E-04  0.361534867343E-04  0.370353493431E-04  0.379283044180E-04
+  0.388324914850E-04  0.397480518253E-04  0.406751284969E-04  0.416138663575E-04
+  0.425644120867E-04  0.435269142094E-04  0.445015231184E-04  0.454883910983E-04
+  0.464876723493E-04  0.474995230110E-04  0.485241011873E-04  0.495615669705E-04
+  0.506120824668E-04  0.516758118214E-04  0.527529212441E-04  0.538435790355E-04
+  0.549479556130E-04  0.560662235379E-04  0.571985575416E-04  0.583451345537E-04
+  0.595061337292E-04  0.606817364766E-04  0.618721264861E-04  0.630774897587E-04
+  0.642980146348E-04  0.655338918240E-04  0.667853144344E-04  0.680524780035E-04
+  0.693355805282E-04  0.706348224958E-04  0.719504069155E-04  0.732825393501E-04
+  0.746314279480E-04  0.759972834757E-04  0.773803193510E-04  0.787807516761E-04
+  0.801987992713E-04  0.816346837094E-04  0.830886293503E-04  0.845608633761E-04
+  0.860516158262E-04  0.875611196337E-04  0.890896106618E-04  0.906373277401E-04
+  0.922045127028E-04  0.937914104255E-04  0.953982688644E-04  0.970253390942E-04
+  0.986728753481E-04  0.100341135057E-03  0.102030378890E-03  0.103740870794E-03
+  0.105472878038E-03  0.107226671251E-03  0.109002524467E-03  0.110800715167E-03
+  0.112621524321E-03  0.114465236435E-03  0.116332139593E-03  0.118222525501E-03
+  0.120136689537E-03  0.122074930792E-03  0.124037552122E-03  0.126024860188E-03
+  0.128037165513E-03  0.130074782522E-03  0.132138029599E-03  0.134227229129E-03
+  0.136342707554E-03  0.138484795421E-03  0.140653827438E-03  0.142850142518E-03
+  0.145074083841E-03  0.147325998902E-03  0.149606239568E-03  0.151915162131E-03
+  0.154253127364E-03  0.156620500579E-03  0.159017651684E-03  0.161444955237E-03
+  0.163902790511E-03  0.166391541547E-03  0.168911597217E-03  0.171463351285E-03
+  0.174047202468E-03  0.176663554498E-03  0.179312816185E-03  0.181995401482E-03
+  0.184711729548E-03  0.187462224815E-03  0.190247317053E-03  0.193067441440E-03
+  0.195923038624E-03  0.198814554799E-03  0.201742441770E-03  0.204707157025E-03
+  0.207709163808E-03  0.210748931187E-03  0.213826934133E-03  0.216943653590E-03
+  0.220099576552E-03  0.223295196137E-03  0.226531011669E-03  0.229807528750E-03
+  0.233125259342E-03  0.236484721847E-03  0.239886441189E-03  0.243330948892E-03
+  0.246818783169E-03  0.250350489000E-03  0.253926618222E-03  0.257547729612E-03
+  0.261214388977E-03  0.264927169238E-03  0.268686650526E-03  0.272493420267E-03
+  0.276348073277E-03  0.280251211853E-03  0.284203445868E-03  0.288205392868E-03
+  0.292257678164E-03  0.296360934934E-03  0.300515804320E-03  0.304722935530E-03
+  0.308982985936E-03  0.313296621179E-03  0.317664515274E-03  0.322087350714E-03
+  0.326565818574E-03  0.331100618626E-03  0.335692459440E-03  0.340342058502E-03
+  0.345050142320E-03  0.349817446542E-03  0.354644716069E-03  0.359532705172E-03
+  0.364482177609E-03  0.369493906746E-03  0.374568675674E-03  0.379707277338E-03
+  0.384910514653E-03  0.390179200637E-03  0.395514158532E-03  0.400916221937E-03
+  0.406386234934E-03  0.411925052225E-03  0.417533539261E-03  0.423212572379E-03
+  0.428963038940E-03  0.434785837466E-03  0.440681877781E-03  0.446652081153E-03
+  0.452697380439E-03  0.458818720230E-03  0.465017056996E-03  0.471293359241E-03
+  0.477648607649E-03  0.484083795242E-03  0.490599927530E-03  0.497198022672E-03
+  0.503879111634E-03  0.510644238350E-03  0.517494459885E-03  0.524430846599E-03
+  0.531454482317E-03  0.538566464497E-03  0.545767904400E-03  0.553059927265E-03
+  0.560443672487E-03  0.567920293791E-03  0.575490959413E-03  0.583156852286E-03
+  0.590919170221E-03  0.598779126096E-03  0.606737948045E-03  0.614796879650E-03
+  0.622957180136E-03  0.631220124566E-03  0.639587004043E-03  0.648059125907E-03
+  0.656637813945E-03  0.665324408596E-03  0.674120267156E-03  0.683026763997E-03
+  0.692045290777E-03  0.701177256658E-03  0.710424088531E-03  0.719787231229E-03
+  0.729268147765E-03  0.738868319549E-03  0.748589246630E-03  0.758432447920E-03
+  0.768399461441E-03  0.778491844559E-03  0.788711174228E-03  0.799059047240E-03
+  0.809537080472E-03  0.820146911137E-03  0.830890197043E-03  0.841768616850E-03
+  0.852783870333E-03  0.863937678649E-03  0.875231784602E-03  0.886667952919E-03
+  0.898247970525E-03  0.909973646822E-03  0.921846813970E-03  0.933869327175E-03
+  0.946043064980E-03  0.958369929556E-03  0.970851847001E-03  0.983490767639E-03
+  0.996288666329E-03  0.100924754277E-02  0.102236942180E-02  0.103565635376E-02
+  0.104911041475E-02  0.106273370699E-02  0.107652835915E-02  0.109049652667E-02
+  0.110464039212E-02  0.111896216549E-02  0.113346408459E-02  0.114814841538E-02
+  0.116301745231E-02  0.117807351870E-02  0.119331896710E-02  0.120875617963E-02
+  0.122438756838E-02  0.124021557581E-02  0.125624267506E-02  0.127247137040E-02
+  0.128890419759E-02  0.130554372431E-02  0.132239255051E-02  0.133945330885E-02
+  0.135672866512E-02  0.137422131861E-02  0.139193400260E-02  0.140986948473E-02
+  0.142803056745E-02  0.144642008847E-02  0.146504092119E-02  0.148389597515E-02
+  0.150298819649E-02  0.152232056841E-02  0.154189611164E-02  0.156171788489E-02
+  0.158178898535E-02  0.160211254918E-02  0.162269175197E-02  0.164352980926E-02
+  0.166462997705E-02  0.168599555228E-02  0.170762987336E-02  0.172953632070E-02
+  0.175171831723E-02  0.177417932892E-02  0.179692286536E-02  0.181995248027E-02
+  0.184327177208E-02  0.186688438447E-02  0.189079400696E-02  0.191500437548E-02
+  0.193951927294E-02  0.196434252986E-02  0.198947802491E-02  0.201492968556E-02
+  0.204070148870E-02  0.206679746121E-02  0.209322168065E-02  0.211997827585E-02
+  0.214707142759E-02  0.217450536922E-02  0.220228438736E-02  0.223041282253E-02
+  0.225889506986E-02  0.228773557976E-02  0.231693885862E-02  0.234650946950E-02
+  0.237645203288E-02  0.240677122735E-02  0.243747179033E-02  0.246855851885E-02
+  0.250003627028E-02  0.253190996309E-02  0.256418457759E-02  0.259686515677E-02
+  0.262995680703E-02  0.266346469901E-02  0.269739406838E-02  0.273175021668E-02
+  0.276653851213E-02  0.280176439047E-02  0.283743335581E-02  0.287355098151E-02
+  0.291012291101E-02  0.294715485875E-02  0.298465261105E-02  0.302262202701E-02
+  0.306106903943E-02  0.309999965573E-02  0.313941995891E-02  0.317933610845E-02
+  0.321975434135E-02  0.326068097304E-02  0.330212239837E-02  0.334408509267E-02
+  0.338657561268E-02  0.342960059764E-02  0.347316677029E-02  0.351728093793E-02
+  0.356194999350E-02  0.360718091661E-02  0.365298077469E-02  0.369935672407E-02
+  0.374631601109E-02  0.379386597322E-02  0.384201404024E-02  0.389076773539E-02
+  0.394013467653E-02  0.399012257735E-02  0.404073924856E-02  0.409199259912E-02
+  0.414389063746E-02  0.419644147276E-02  0.424965331619E-02  0.430353448222E-02
+  0.435809338989E-02  0.441333856413E-02  0.446927863712E-02  0.452592234961E-02
+  0.458327855229E-02  0.464135620718E-02  0.470016438905E-02  0.475971228677E-02
+  0.482000920485E-02  0.488106456478E-02  0.494288790661E-02  0.500548889034E-02
+  0.506887729751E-02  0.513306303269E-02  0.519805612503E-02  0.526386672983E-02
+  0.533050513014E-02  0.539798173833E-02  0.546630709777E-02  0.553549188444E-02
+  0.560554690859E-02  0.567648311646E-02  0.574831159199E-02  0.582104355852E-02
+  0.589469038057E-02  0.596926356559E-02  0.604477476581E-02  0.612123578001E-02
+  0.619865855536E-02  0.627705518935E-02  0.635643793159E-02  0.643681918581E-02
+  0.651821151175E-02  0.660062762711E-02  0.668408040958E-02  0.676858289883E-02
+  0.685414829855E-02  0.694078997851E-02  0.702852147663E-02  0.711735650116E-02
+  0.720730893273E-02  0.729839282661E-02  0.739062241483E-02  0.748401210846E-02
+  0.757857649982E-02  0.767433036480E-02  0.777128866513E-02  0.786946655074E-02
+  0.796887936212E-02  0.806954263274E-02  0.817147209143E-02  0.827468366488E-02
+  0.837919348010E-02  0.848501786696E-02  0.859217336075E-02  0.870067670473E-02
+  0.881054485276E-02  0.892179497196E-02  0.903444444540E-02  0.914851087478E-02
+  0.926401208322E-02  0.938096611800E-02  0.949939125345E-02  0.961930599373E-02
+  0.974072907575E-02  0.986367947213E-02  0.998817639411E-02  0.101142392946E-01
+  0.102418878712E-01  0.103711420692E-01  0.105020220848E-01  0.106345483684E-01
+  0.107687416275E-01  0.109046228299E-01  0.110422132075E-01  0.111815342589E-01
+  0.113226077535E-01  0.114654557341E-01  0.116101005212E-01  0.117565647157E-01
+  0.119048712030E-01  0.120550431563E-01  0.122071040402E-01  0.123610776145E-01
+  0.125169879380E-01  0.126748593719E-01  0.128347165841E-01  0.129965845524E-01
+  0.131604885691E-01  0.133264542445E-01  0.134945075112E-01  0.136646746277E-01
+  0.138369821831E-01  0.140114571007E-01  0.141881266425E-01  0.143670184137E-01
+  0.145481603663E-01  0.147315808042E-01  0.149173083872E-01  0.151053721356E-01
+  0.152958014347E-01  0.154886260396E-01  0.156838760794E-01  0.158815820624E-01
+  0.160817748804E-01  0.162844858142E-01  0.164897465376E-01  0.166975891231E-01
+  0.169080460464E-01  0.171211501920E-01  0.173369348577E-01  0.175554337604E-01
+  0.177766810410E-01  0.180007112697E-01  0.182275594519E-01  0.184572610329E-01
+  0.186898519041E-01  0.189253684083E-01  0.191638473454E-01  0.194053259783E-01
+  0.196498420385E-01  0.198974337321E-01  0.201481397458E-01  0.204019992529E-01
+  0.206590519196E-01  0.209193379108E-01  0.211828978967E-01  0.214497730591E-01
+  0.217200050978E-01  0.219936362371E-01  0.222707092324E-01  0.225512673770E-01
+  0.228353545086E-01  0.231230150165E-01  0.234142938481E-01  0.237092365163E-01
+  0.240078891066E-01  0.243102982841E-01  0.246165113007E-01  0.249265760029E-01
+  0.252405408390E-01  0.255584548665E-01  0.258803677602E-01  0.262063298197E-01
+  0.265363919771E-01  0.268706058054E-01  0.272090235261E-01  0.275516980177E-01
+  0.278986828238E-01  0.282500321615E-01  0.286058009298E-01  0.289660447183E-01
+  0.293308198158E-01  0.297001832193E-01  0.300741926424E-01  0.304529065249E-01
+  0.308363840416E-01  0.312246851117E-01  0.316178704080E-01  0.320160013664E-01
+  0.324191401959E-01  0.328273498875E-01  0.332406942250E-01  0.336592377943E-01
+  0.340830459935E-01  0.345121850436E-01  0.349467219984E-01  0.353867247553E-01
+  0.358322620656E-01  0.362834035453E-01  0.367402196862E-01  0.372027818669E-01
+  0.376711623635E-01  0.381454343615E-01  0.386256719668E-01  0.391119502176E-01
+  0.396043450958E-01  0.401029335391E-01  0.406077934530E-01  0.411190037229E-01
+  0.416366442263E-01  0.421607958458E-01  0.426915404810E-01  0.432289610618E-01
+  0.437731415614E-01  0.443241670091E-01  0.448821235036E-01  0.454470982268E-01
+  0.460191794573E-01  0.465984565838E-01  0.471850201195E-01  0.477789617162E-01
+  0.483803741786E-01  0.489893514784E-01  0.496059887697E-01  0.502303824033E-01
+  0.508626299420E-01  0.515028301757E-01  0.521510831370E-01  0.528074901167E-01
+  0.534721536799E-01  0.541451776814E-01  0.548266672828E-01  0.555167289681E-01
+  0.562154705608E-01  0.569230012408E-01  0.576394315612E-01  0.583648734656E-01
+  0.590994403059E-01  0.598432468596E-01  0.605964093480E-01  0.613590454543E-01
+  0.621312743418E-01  0.629132166730E-01  0.637049946279E-01  0.645067319235E-01
+  0.653185538328E-01  0.661405872046E-01  0.669729604833E-01  0.678158037290E-01
+  0.686692486376E-01  0.695334285617E-01  0.704084785310E-01  0.712945352740E-01
+  0.721917372388E-01  0.731002246150E-01  0.740201393557E-01  0.749516251993E-01
+  0.758948276925E-01  0.768498942126E-01  0.778169739905E-01  0.787962181346E-01
+  0.797877796538E-01  0.807918134814E-01  0.818084764999E-01  0.828379275649E-01
+  0.838803275302E-01  0.849358392730E-01  0.860046277191E-01  0.870868598688E-01
+  0.881827048233E-01  0.892923338103E-01  0.904159202118E-01  0.915536395904E-01
+  0.927056697171E-01  0.938721905989E-01  0.950533845071E-01  0.962494360057E-01
+  0.974605319800E-01  0.986868616664E-01  0.999286166812E-01  0.101185991051
+  0.102459181244      0.103748386198      0.105053807354      0.106375648687
+  0.107714116737      0.109069420642      0.110441772172      0.111831385759
+  0.113238478533      0.114663270355      0.116105983853      0.117566844452
+  0.119046080416      0.120543922877      0.122060605877      0.123596366401
+  0.125151444414      0.126726082900      0.128320527901      0.129935028550
+  0.131569837118      0.133225209046      0.134901402990      0.136598680858
+  0.138317307853      0.140057552515      0.141819686760      0.143603985925
+  0.145410728811      0.147240197725      0.149092678524      0.150968460664
+  0.152867837238      0.154791105029      0.156738564550      0.158710520097
+  0.160707279790      0.162729155629      0.164776463535      0.166849523404
+  0.168948659157      0.171074198787      0.173226474414      0.175405822335
+  0.177612583079      0.179847101456      0.182109726614      0.184400812093
+  0.186720715880      0.189069800464      0.191448432895      0.193856984838
+  0.196295832636      0.198765357362      0.201265944885      0.203797985927
+  0.206361876125      0.208958016092      0.211586811479      0.214248673041
+  0.216944016700      0.219673263609      0.222436840218      0.225235178341
+  0.228068715225      0.230937893615      0.233843161827      0.236784973814
+  0.239763789240      0.242780073552      0.245834298050      0.248926939963
+  0.252058482522      0.255229415037      0.258440232974      0.261691438028
+  0.264983538208      0.268317047910      0.271692488002      0.275110385904
+  0.278571275669      0.282075698069      0.285624200675      0.289217337950
+  0.292855671328      0.296539769306      0.300270207532      0.304047568894
+  0.307872443613      0.311745429334      0.315667131217      0.319638162038
+  0.323659142277      0.327730700222      0.331853472061      0.336028101985
+  0.340255242290      0.344535553475      0.348869704346      0.353258372124
+  0.357702242546      0.362202009978      0.366758377516      0.371372057102
+  0.376043769634      0.380774245075      0.385564222573      0.390414450570
+  0.395325686925      0.400298699028      0.405334263923      0.410433168428
+  0.415596209255      0.420824193141      0.426117936970      0.431478267898
+  0.436906023490      0.442402051842      0.447967211720      0.453602372692
+  0.459308415263      0.465086231015      0.470936722741      0.476860804595
+  0.482859402225      0.488933452924      0.495083905776      0.501311721801
+  0.507617874109      0.514003348047      0.520469141360      0.527016264340
+  0.533645739990      0.540358604178      0.547155905803      0.554038706957
+  0.561008083092      0.568065123187      0.575210929919      0.582446619834
+  0.589773323524      0.597192185802      0.604704365879      0.612311037550
+  0.620013389371      0.627812624851      0.635709962637      0.643706636704
+  0.651803896548      0.660003007382      0.668305250335      0.676711922649
+  0.685224337882      0.693843826119      0.702571734170      0.711409425790
+  0.720358281885      0.729419700734      0.738595098200      0.747885907958
+  0.757293581717      0.766819589445      0.776465419599      0.786232579360
+  0.796122594867      0.806137011454      0.816277393896      0.826545326646
+  0.836942414091      0.847470280797      0.858130571764      0.868924952684
+  0.879855110202      0.890922752176      0.902129607948      0.913477428613
+  0.924967987290      0.936603079402      0.948384522957      0.960314158829
+  0.972393851047      0.984625487089      0.997010978172       1.00955225955
+   1.02225129084       1.03511005627       1.04813056506       1.06131485169
+   1.07466497623       1.08818302466       1.10187110921       1.11573136867
+   1.12976596873       1.14397710233       1.15836698998       1.17293788014
+   1.18769204953       1.20263180353       1.21775947650       1.23307743217
+   1.24858806400       1.26429379557       1.28019708092       1.29630040497
+   1.31260628390       1.32911726554       1.34583592977       1.36276488890
+   1.37990678812       1.39726430590       1.41484015437       1.43263707979
+   1.45065786298       1.46890531972       1.48738230121       1.50609169452
+   1.52503642302       1.54421944688       1.56364376346       1.58331240788
+   1.60322845338       1.62339501190       1.64381523449       1.66449231187
+   1.68542947486       1.70662999495       1.72809718474       1.74983439855
+   1.77184503284       1.79413252683       1.81670036298       1.83955206757
+   1.86269121122       1.88612140946       1.90984632332       1.93386965985
+   1.95819517276       1.98282666296       2.00776797916       2.03302301850
+   2.05859572713       2.08449010083       2.11071018566       2.13726007855
+   2.16414392799       2.19136593462       2.21893035194       2.24684148696
+   2.27510370083       2.30372140958       2.33269908481       2.36204125431
+   2.39175250287       2.42183747294       2.45230086534       2.48314744004
+   2.51438201689       2.54600947635       2.57803476028       2.61046287269
+   2.64329888054       2.67654791453       2.71021516987       2.74430590716
+   2.77882545313       2.81377920154       2.84917261398       2.88501122075
+   2.92130062169       2.95804648710       2.99525455860       3.03293065003
+   3.07108064834       3.10971051456       3.14882628468       3.18843407062
+   3.22854006118       3.26915052299       3.31027180153       3.35191032208
+   3.39407259075       3.43676519546       3.47999480704       3.52376818019
+   3.56809215459       3.61297365596       3.65841969711       3.70443737910
+   3.75103389226       3.79821651741       3.84599262692       3.89436968591
+   3.94335525340       3.99295698347       4.04318262650       4.09404003034
+   4.14553714158       4.19768200673       4.25048277354       4.30394769224
+   4.35808511683       4.41290350639       4.46841142640       4.52461755010
+   4.58153065980       4.63915964830       4.69751352023       4.75660139351
+   4.81643250075       4.87701619067       4.93836192959       5.00047930292
+   5.06337801662       5.12706789874       5.19155890096       5.25686110012
+   5.32298469983       5.38994003204       5.45773755865       5.52638787316
+   5.59590170232       5.66628990782       5.73756348795       5.80973357935
+   5.88281145875       5.95680854471       6.03173639944       6.10760673055
+   6.18443139295       6.26222239064       6.34099187863       6.42075216480
+   6.50151571186       6.58329513929       6.66610322529       6.74995290878
+   6.83485729145       6.92082963979       7.00788338714       7.09603213584
+   7.18528965930       7.27566990419       7.36718699261       7.45985522430
+   7.55368907884       7.64870321798       7.74491248787       7.84233192139
+   7.94097674054       8.04086235876       8.14200438339       8.24441861808
+   8.34812106526       8.45312792864       8.55945561576       8.66712074055
+   8.77614012589       8.88653080628       8.99831003050       9.11149526428
+   9.22610419303       9.34215472464       9.45966499223       9.57865335704
+   9.69913841122       9.82113898082       9.94467412867       10.0697631574
+   10.1964256124       10.3246812850       10.4545502153       10.5860526957
+   10.7192092736       10.8540407551       10.9905682079       11.1288129646
+   11.2687966263       11.4105410657       11.5540684306       11.6994011476
+   11.8465619251       11.9955737573       12.1464599276       12.2992440123
+   12.4539498842       12.6106017164       12.7692239861       12.9298414783
+   13.0924792899       13.2571628333       13.4239178407       13.5927703678
+   13.7637467983       13.9368738476       14.1121785670       14.2896883483
+   14.4694309279       14.6514343907       14.8357271753       15.0223380778
+   15.2112962564       15.4026312363       15.5963729141       15.7925515621
+   15.9911978337       16.1923427678       16.3960177938       16.6022547362
+   16.8110858199       17.0225436754       17.2366613432       17.4534722797
+   17.6730103621       17.8953098937       18.1204056091       18.3483326800
+   18.5791267206       18.8128237928       19.0494604124       19.2890735541
+   19.5317006582       19.7773796356       20.0261488740       20.2780472443
+   20.5331141060       20.7913893139       21.0529132239       21.3177266998
+   21.5858711192       21.8573883801       22.1323209077       22.4107116609
+   22.6926041386       22.9780423872       23.2670710070       23.5597351592
+   23.8560805733       24.1561535539       24.4600009879       24.7676703521
+   25.0792097205       25.3946677718       25.7140937968       26.0375377067
+   26.3650500401       26.6966819715       27.0324853191       27.3725125528
+   27.7168168026       28.0654518667       28.4184722201       28.7759330228
+   29.1378901290       29.5044000951       29.8755201891       30.2513083991
+   30.6318234430       31.0171247768       31.4072726049       31.8023278885
+   32.2023523558       32.6074085115       33.0175596465       33.4328698476
+   33.8534040079       34.2792278368       34.7104078701       35.1470114806
+   35.5891068884       36.0367631719       36.4900502782       36.9490390345
+   37.4138011585       37.8844092705       38.3609369037       38.8434585167
+   39.3320495045       39.8267862103       40.3277459377       40.8350069629
+   41.3486485462       41.8687509453       42.3953954273       42.9286642813
+   43.4686408318       44.0154094511       44.5690555731       45.1296657059
+   45.6973274461       46.2721294921       46.8541616577       47.4435148867
+   48.0402812667       48.6445540437       49.2564276366       49.8759976518
+   50.5033608984       51.1386154032       51.7818604260       52.4331964752
+   53.0927253233       53.7605500230       54.4367749234       55.1215056859
+   55.8148493011       56.5169141054       57.2278097978       57.9476474572
+   58.6765395598       59.4145999963       60.1619440903       60.9186886157
+   61.6849518155       62.4608534198       63.2465146648       64.0420583118
+   64.8476086659       65.6632915962       66.4892345546       67.3255665965
+   68.1724184005       69.0299222889       69.8982122484       70.7774239510
+   71.6676947755       72.5691638283       73.4819719660       74.4062618166
+   75.3421778023       76.2898661618       77.2494749735       78.2211541781
+   79.2050556025       80.2013329833       81.2101419908       82.2316402535
+   83.2659873827       84.3133449971       85.3738767485       86.4477483471
+   87.5351275876       88.6361843751       89.7510907522       90.8800209250
+   92.0231512913       93.1806604676       94.3527293169       95.5395409774
+   96.7412808910       97.9581368317       99.1902989360       100.437959732
+   101.701314168       102.980559647       104.275896053       105.587525786
+   106.915653789       108.260487586       109.622237310       111.001115737
+   112.397338320       113.811123220       115.242691345       116.692266381
+   118.160074826       119.646346028
+ Down Pseudopotential follows (l on next line)
+  0
+ -0.658445829754E-06 -0.132517388847E-05 -0.200028835376E-05 -0.268389471364E-05
+ -0.337609978299E-05 -0.407701172026E-05 -0.478674004437E-05 -0.550539565181E-05
+ -0.623309083398E-05 -0.696993929474E-05 -0.771605616815E-05 -0.847155803649E-05
+ -0.923656294848E-05 -0.100111904377E-04 -0.107955615412E-04 -0.115897988187E-04
+ -0.123940263712E-04 -0.132083698611E-04 -0.140329565310E-04 -0.148679152245E-04
+ -0.157133764054E-04 -0.165694721788E-04 -0.174363363114E-04 -0.183141042524E-04
+ -0.192029131550E-04 -0.201029018973E-04 -0.210142111044E-04 -0.219369831701E-04
+ -0.228713622796E-04 -0.238174944315E-04 -0.247755274607E-04 -0.257456110620E-04
+ -0.267278968128E-04 -0.277225381974E-04 -0.287296906304E-04 -0.297495114814E-04
+ -0.307821600997E-04 -0.318277978385E-04 -0.328865880809E-04 -0.339586962651E-04
+ -0.350442899101E-04 -0.361435386422E-04 -0.372566142212E-04 -0.383836905674E-04
+ -0.395249437888E-04 -0.406805522085E-04 -0.418506963928E-04 -0.430355591789E-04
+ -0.442353257042E-04 -0.454501834345E-04 -0.466803221940E-04 -0.479259341942E-04
+ -0.491872140646E-04 -0.504643588827E-04 -0.517575682050E-04 -0.530670440980E-04
+ -0.543929911701E-04 -0.557356166032E-04 -0.570951301853E-04 -0.584717443430E-04
+ -0.598656741752E-04 -0.612771374862E-04 -0.627063548200E-04 -0.641535494948E-04
+ -0.656189476377E-04 -0.671027782201E-04 -0.686052730935E-04 -0.701266670259E-04
+ -0.716671977381E-04 -0.732271059412E-04 -0.748066353740E-04 -0.764060328412E-04
+ -0.780255482519E-04 -0.796654346587E-04 -0.813259482972E-04 -0.830073486259E-04
+ -0.847098983672E-04 -0.864338635479E-04 -0.881795135410E-04 -0.899471211079E-04
+ -0.917369624409E-04 -0.935493172063E-04 -0.953844685883E-04 -0.972427033330E-04
+ -0.991243117932E-04 -0.101029587974E-03 -0.102958829579E-03 -0.104912338057E-03
+ -0.106890418645E-03 -0.108893380425E-03 -0.110921536362E-03 -0.112975203360E-03
+ -0.115054702309E-03 -0.117160358135E-03 -0.119292499851E-03 -0.121451460607E-03
+ -0.123637577747E-03 -0.125851192855E-03 -0.128092651813E-03 -0.130362304855E-03
+ -0.132660506617E-03 -0.134987616198E-03 -0.137343997214E-03 -0.139730017855E-03
+ -0.142146050940E-03 -0.144592473981E-03 -0.147069669235E-03 -0.149578023769E-03
+ -0.152117929519E-03 -0.154689783351E-03 -0.157293987121E-03 -0.159930947742E-03
+ -0.162601077244E-03 -0.165304792840E-03 -0.168042516992E-03 -0.170814677475E-03
+ -0.173621707443E-03 -0.176464045502E-03 -0.179342135771E-03 -0.182256427960E-03
+ -0.185207377432E-03 -0.188195445278E-03 -0.191221098391E-03 -0.194284809534E-03
+ -0.197387057419E-03 -0.200528326779E-03 -0.203709108443E-03 -0.206929899414E-03
+ -0.210191202949E-03 -0.213493528631E-03 -0.216837392457E-03 -0.220223316912E-03
+ -0.223651831053E-03 -0.227123470592E-03 -0.230638777981E-03 -0.234198302493E-03
+ -0.237802600311E-03 -0.241452234614E-03 -0.245147775665E-03 -0.248889800899E-03
+ -0.252678895016E-03 -0.256515650070E-03 -0.260400665560E-03 -0.264334548529E-03
+ -0.268317913653E-03 -0.272351383342E-03 -0.276435587833E-03 -0.280571165292E-03
+ -0.284758761911E-03 -0.288999032011E-03 -0.293292638141E-03 -0.297640251188E-03
+ -0.302042550473E-03 -0.306500223866E-03 -0.311013967887E-03 -0.315584487818E-03
+ -0.320212497810E-03 -0.324898721002E-03 -0.329643889623E-03 -0.334448745118E-03
+ -0.339314038253E-03 -0.344240529240E-03 -0.349228987855E-03 -0.354280193554E-03
+ -0.359394935597E-03 -0.364574013174E-03 -0.369818235525E-03 -0.375128422072E-03
+ -0.380505402542E-03 -0.385950017098E-03 -0.391463116473E-03 -0.397045562100E-03
+ -0.402698226246E-03 -0.408421992153E-03 -0.414217754170E-03 -0.420086417896E-03
+ -0.426028900323E-03 -0.432046129975E-03 -0.438139047056E-03 -0.444308603597E-03
+ -0.450555763604E-03 -0.456881503207E-03 -0.463286810817E-03 -0.469772687276E-03
+ -0.476340146014E-03 -0.482990213211E-03 -0.489723927953E-03 -0.496542342396E-03
+ -0.503446521932E-03 -0.510437545351E-03 -0.517516505017E-03 -0.524684507030E-03
+ -0.531942671404E-03 -0.539292132244E-03 -0.546734037917E-03 -0.554269551234E-03
+ -0.561899849637E-03 -0.569626125374E-03 -0.577449585690E-03 -0.585371453018E-03
+ -0.593392965165E-03 -0.601515375508E-03 -0.609739953190E-03 -0.618067983319E-03
+ -0.626500767164E-03 -0.635039622366E-03 -0.643685883138E-03 -0.652440900474E-03
+ -0.661306042365E-03 -0.670282694006E-03 -0.679372258017E-03 -0.688576154660E-03
+ -0.697895822063E-03 -0.707332716442E-03 -0.716888312330E-03 -0.726564102809E-03
+ -0.736361599739E-03 -0.746282334000E-03 -0.756327855725E-03 -0.766499734547E-03
+ -0.776799559843E-03 -0.787228940980E-03 -0.797789507570E-03 -0.808482909722E-03
+ -0.819310818302E-03 -0.830274925191E-03 -0.841376943553E-03 -0.852618608100E-03
+ -0.864001675364E-03 -0.875527923972E-03 -0.887199154923E-03 -0.899017191869E-03
+ -0.910983881402E-03 -0.923101093340E-03 -0.935370721022E-03 -0.947794681601E-03
+ -0.960374916345E-03 -0.973113390940E-03 -0.986012095798E-03 -0.999073046366E-03
+ -0.101229828344E-02 -0.102568987350E-02 -0.103924990899E-02 -0.105298050871E-02
+ -0.106688381808E-02 -0.108096200953E-02 -0.109521728279E-02 -0.110965186528E-02
+ -0.112426801244E-02 -0.113906800806E-02 -0.115405416468E-02 -0.116922882390E-02
+ -0.118459435679E-02 -0.120015316426E-02 -0.121590767739E-02 -0.123186035786E-02
+ -0.124801369830E-02 -0.126437022270E-02 -0.128093248681E-02 -0.129770307850E-02
+ -0.131468461821E-02 -0.133187975934E-02 -0.134929118867E-02 -0.136692162675E-02
+ -0.138477382838E-02 -0.140285058301E-02 -0.142115471515E-02 -0.143968908486E-02
+ -0.145845658817E-02 -0.147746015753E-02 -0.149670276230E-02 -0.151618740916E-02
+ -0.153591714262E-02 -0.155589504549E-02 -0.157612423935E-02 -0.159660788506E-02
+ -0.161734918321E-02 -0.163835137467E-02 -0.165961774108E-02 -0.168115160534E-02
+ -0.170295633216E-02 -0.172503532856E-02 -0.174739204442E-02 -0.177002997302E-02
+ -0.179295265158E-02 -0.181616366181E-02 -0.183966663046E-02 -0.186346522991E-02
+ -0.188756317875E-02 -0.191196424230E-02 -0.193667223329E-02 -0.196169101237E-02
+ -0.198702448878E-02 -0.201267662091E-02 -0.203865141694E-02 -0.206495293549E-02
+ -0.209158528622E-02 -0.211855263045E-02 -0.214585918190E-02 -0.217350920725E-02
+ -0.220150702687E-02 -0.222985701545E-02 -0.225856360273E-02 -0.228763127416E-02
+ -0.231706457161E-02 -0.234686809407E-02 -0.237704649839E-02 -0.240760449999E-02
+ -0.243854687362E-02 -0.246987845405E-02 -0.250160413689E-02 -0.253372887934E-02
+ -0.256625770092E-02 -0.259919568432E-02 -0.263254797613E-02 -0.266631978771E-02
+ -0.270051639595E-02 -0.273514314410E-02 -0.277020544266E-02 -0.280570877014E-02
+ -0.284165867400E-02 -0.287806077145E-02 -0.291492075036E-02 -0.295224437016E-02
+ -0.299003746271E-02 -0.302830593322E-02 -0.306705576119E-02 -0.310629300133E-02
+ -0.314602378450E-02 -0.318625431867E-02 -0.322699088993E-02 -0.326823986340E-02
+ -0.331000768427E-02 -0.335230087882E-02 -0.339512605540E-02 -0.343848990548E-02
+ -0.348239920472E-02 -0.352686081397E-02 -0.357188168040E-02 -0.361746883858E-02
+ -0.366362941152E-02 -0.371037061186E-02 -0.375769974295E-02 -0.380562420000E-02
+ -0.385415147124E-02 -0.390328913910E-02 -0.395304488136E-02 -0.400342647239E-02
+ -0.405444178435E-02 -0.410609878840E-02 -0.415840555599E-02 -0.421137026006E-02
+ -0.426500117639E-02 -0.431930668481E-02 -0.437429527059E-02 -0.442997552570E-02
+ -0.448635615021E-02 -0.454344595361E-02 -0.460125385617E-02 -0.465978889040E-02
+ -0.471906020240E-02 -0.477907705331E-02 -0.483984882077E-02 -0.490138500036E-02
+ -0.496369520710E-02 -0.502678917695E-02 -0.509067676834E-02 -0.515536796366E-02
+ -0.522087287091E-02 -0.528720172520E-02 -0.535436489038E-02 -0.542237286066E-02
+ -0.549123626224E-02 -0.556096585498E-02 -0.563157253408E-02 -0.570306733178E-02
+ -0.577546141907E-02 -0.584876610746E-02 -0.592299285074E-02 -0.599815324674E-02
+ -0.607425903919E-02 -0.615132211953E-02 -0.622935452875E-02 -0.630836845930E-02
+ -0.638837625698E-02 -0.646939042289E-02 -0.655142361535E-02 -0.663448865189E-02
+ -0.671859851126E-02 -0.680376633546E-02 -0.689000543178E-02 -0.697732927488E-02
+ -0.706575150891E-02 -0.715528594962E-02 -0.724594658654E-02 -0.733774758514E-02
+ -0.743070328907E-02 -0.752482822239E-02 -0.762013709182E-02 -0.771664478907E-02
+ -0.781436639313E-02 -0.791331717267E-02 -0.801351258839E-02 -0.811496829544E-02
+ -0.821770014587E-02 -0.832172419112E-02 -0.842705668448E-02 -0.853371408371E-02
+ -0.864171305353E-02 -0.875107046826E-02 -0.886180341446E-02 -0.897392919357E-02
+ -0.908746532466E-02 -0.920242954712E-02 -0.931883982345E-02 -0.943671434208E-02
+ -0.955607152016E-02 -0.967693000649E-02 -0.979930868444E-02 -0.992322667482E-02
+ -0.100487033390E-01 -0.101757582817E-01 -0.103044113543E-01 -0.104346826580E-01
+ -0.105665925465E-01 -0.107001616297E-01 -0.108354107765E-01 -0.109723611186E-01
+ -0.111110340530E-01 -0.112514512462E-01 -0.113936346369E-01 -0.115376064400E-01
+ -0.116833891494E-01 -0.118310055421E-01 -0.119804786817E-01 -0.121318319216E-01
+ -0.122850889088E-01 -0.124402735881E-01 -0.125974102049E-01 -0.127565233100E-01
+ -0.129176377625E-01 -0.130807787344E-01 -0.132459717142E-01 -0.134132425109E-01
+ -0.135826172579E-01 -0.137541224175E-01 -0.139277847847E-01 -0.141036314911E-01
+ -0.142816900100E-01 -0.144619881598E-01 -0.146445541089E-01 -0.148294163797E-01
+ -0.150166038535E-01 -0.152061457746E-01 -0.153980717550E-01 -0.155924117792E-01
+ -0.157891962085E-01 -0.159884557860E-01 -0.161902216417E-01 -0.163945252964E-01
+ -0.166013986678E-01 -0.168108740744E-01 -0.170229842415E-01 -0.172377623056E-01
+ -0.174552418198E-01 -0.176754567590E-01 -0.178984415255E-01 -0.181242309538E-01
+ -0.183528603165E-01 -0.185843653296E-01 -0.188187821582E-01 -0.190561474218E-01
+ -0.192964982005E-01 -0.195398720403E-01 -0.197863069593E-01 -0.200358414535E-01
+ -0.202885145028E-01 -0.205443655770E-01 -0.208034346421E-01 -0.210657621663E-01
+ -0.213313891265E-01 -0.216003570148E-01 -0.218727078445E-01 -0.221484841570E-01
+ -0.224277290285E-01 -0.227104860764E-01 -0.229967994662E-01 -0.232867139185E-01
+ -0.235802747158E-01 -0.238775277097E-01 -0.241785193277E-01 -0.244832965810E-01
+ -0.247919070710E-01 -0.251043989977E-01 -0.254208211662E-01 -0.257412229949E-01
+ -0.260656545230E-01 -0.263941664183E-01 -0.267268099849E-01 -0.270636371716E-01
+ -0.274047005793E-01 -0.277500534699E-01 -0.280997497738E-01 -0.284538440989E-01
+ -0.288123917387E-01 -0.291754486812E-01 -0.295430716170E-01 -0.299153179487E-01
+ -0.302922457994E-01 -0.306739140219E-01 -0.310603822077E-01 -0.314517106961E-01
+ -0.318479605838E-01 -0.322491937341E-01 -0.326554727867E-01 -0.330668611671E-01
+ -0.334834230965E-01 -0.339052236017E-01 -0.343323285252E-01 -0.347648045353E-01
+ -0.352027191361E-01 -0.356461406784E-01 -0.360951383697E-01 -0.365497822853E-01
+ -0.370101433786E-01 -0.374762934923E-01 -0.379483053693E-01 -0.384262526639E-01
+ -0.389102099529E-01 -0.394002527473E-01 -0.398964575036E-01 -0.403989016356E-01
+ -0.409076635261E-01 -0.414228225388E-01 -0.419444590306E-01 -0.424726543636E-01
+ -0.430074909176E-01 -0.435490521024E-01 -0.440974223707E-01 -0.446526872304E-01
+ -0.452149332583E-01 -0.457842481123E-01 -0.463607205450E-01 -0.469444404170E-01
+ -0.475354987106E-01 -0.481339875429E-01 -0.487400001801E-01 -0.493536310508E-01
+ -0.499749757609E-01 -0.506041311069E-01 -0.512411950909E-01 -0.518862669347E-01
+ -0.525394470946E-01 -0.532008372760E-01 -0.538705404485E-01 -0.545486608610E-01
+ -0.552353040565E-01 -0.559305768877E-01 -0.566345875327E-01 -0.573474455099E-01
+ -0.580692616944E-01 -0.588001483335E-01 -0.595402190630E-01 -0.602895889227E-01
+ -0.610483743734E-01 -0.618166933126E-01 -0.625946650913E-01 -0.633824105306E-01
+ -0.641800519383E-01 -0.649877131255E-01 -0.658055194239E-01 -0.666335977024E-01
+ -0.674720763843E-01 -0.683210854644E-01 -0.691807565264E-01 -0.700512227598E-01
+ -0.709326189777E-01 -0.718250816336E-01 -0.727287488394E-01 -0.736437603822E-01
+ -0.745702577425E-01 -0.755083841110E-01 -0.764582844061E-01 -0.774201052919E-01
+ -0.783939951948E-01 -0.793801043212E-01 -0.803785846747E-01 -0.813895900733E-01
+ -0.824132761662E-01 -0.834498004509E-01 -0.844993222898E-01 -0.855620029268E-01
+ -0.866380055038E-01 -0.877274950765E-01 -0.888306386303E-01 -0.899476050962E-01
+ -0.910785653656E-01 -0.922236923052E-01 -0.933831607719E-01 -0.945571476260E-01
+ -0.957458317456E-01 -0.969493940389E-01 -0.981680174571E-01 -0.994018870059E-01
+ -0.100651189757     -0.101916114857     -0.103196853540     -0.104493599132
+ -0.105806547065     -0.107135894875     -0.108481842216     -0.109844590860
+ -0.111224344702     -0.112621309761     -0.114035694180     -0.115467708228
+ -0.116917564293     -0.118385476881     -0.119871662610     -0.121376340198
+ -0.122899730457     -0.124442056280     -0.126003542621     -0.127584416485
+ -0.129184906904     -0.130805244912     -0.132445663523     -0.134106397702
+ -0.135787684327     -0.137489762161     -0.139212871804     -0.140957255656
+ -0.142723157865     -0.144510824277     -0.146320502376     -0.148152441226
+ -0.150006891401     -0.151884104915     -0.153784335142     -0.155707836733
+ -0.157654865527     -0.159625678454     -0.161620533432     -0.163639689257
+ -0.165683405487     -0.167751942313     -0.169845560434     -0.171964520908
+ -0.174109085012     -0.176279514075     -0.178476069319     -0.180699011680
+ -0.182948601626     -0.185225098958     -0.187528762610     -0.189859850435
+ -0.192218618977     -0.194605323243     -0.197020216451     -0.199463549783
+ -0.201935572114     -0.204436529741     -0.206966666096     -0.209526221451
+ -0.212115432611     -0.214734532606     -0.217383750360     -0.220063310368
+ -0.222773432347     -0.225514330896     -0.228286215142     -0.231089288376
+ -0.233923747696     -0.236789783632     -0.239687579781     -0.242617312434
+ -0.245579150204     -0.248573253657     -0.251599774943     -0.254658857438
+ -0.257750635385     -0.260875233551     -0.264032766890     -0.267223340218
+ -0.270447047908     -0.273703973596     -0.276994189912     -0.280317758225
+ -0.283674728425     -0.287065138711     -0.290489015429     -0.293946372926
+ -0.297437213441     -0.300961527030     -0.304519291533     -0.308110472567
+ -0.311735023573     -0.315392885895     -0.319083988904     -0.322808250169
+ -0.326565575668     -0.330355860050     -0.334178986937     -0.338034829276
+ -0.341923249739     -0.345844101166     -0.349797227057     -0.353782462113
+ -0.357799632814     -0.361848558054     -0.365929049812     -0.370040913877
+ -0.374183950607     -0.378357955743     -0.382562721261     -0.386798036270
+ -0.391063687957     -0.395359462577     -0.399685146489     -0.404040527239
+ -0.408425394701     -0.412839542260     -0.417282768060     -0.421754876303
+ -0.426255678617     -0.430784995489     -0.435342657772     -0.439928508265
+ -0.444542403385     -0.449184214926     -0.453853831918     -0.458551162596
+ -0.463276136480     -0.468028706588     -0.472808851780     -0.477616579251
+ -0.482451927186     -0.487314967581     -0.492205809253     -0.497124601045
+ -0.502071535244     -0.507046851228     -0.512050839355     -0.517083845110
+ -0.522146273536     -0.527238593949     -0.532361344977     -0.537515139930
+ -0.542700672519     -0.547918722960     -0.553170164467     -0.558455970174
+ -0.563777220493     -0.569135110956     -0.574530960537     -0.579966220514
+ -0.585442483872     -0.590961495295     -0.596525161769     -0.602135563822
+ -0.607794967457     -0.613505836781     -0.619270847389     -0.625092900536
+ -0.630975138120     -0.636920958540     -0.642934033444     -0.649018325432
+ -0.655178106743     -0.661417978968     -0.667742893857     -0.674158175232
+ -0.680669542090     -0.687283132920     -0.694005531292     -0.700843792774
+ -0.707805473225     -0.714898658507     -0.722131995686     -0.729514725766
+ -0.737056718000     -0.744768505846     -0.752661324610     -0.760747150832
+ -0.769038743453     -0.777549686828     -0.786294435611     -0.795288361567
+ -0.804547802342     -0.814090112227     -0.823933714942     -0.834098158464
+ -0.844604171907     -0.855473724475     -0.866730086458     -0.878397892290
+ -0.890503205604     -0.903073586274     -0.916138159364     -0.929727685915
+ -0.943874635469     -0.958613260215     -0.973979670597     -0.990011912221
+  -1.00675004384      -1.02423621617      -1.04251475130      -1.06163222225
+  -1.08163753245      -1.10258199461      -1.12451940849      -1.14750613708
+  -1.17160118055      -1.19686624716      -1.22336582054      -1.25116722236
+  -1.28034066934      -1.31095932371      -1.34309933583      -1.37683987763
+  -1.41226316554      -1.44945447123      -1.48850211853      -1.52949746466
+  -1.57253486366      -1.61771160992      -1.66512785943      -1.71488652614
+  -1.76709315083      -1.82185573949      -1.87928456815      -1.93949195096
+  -2.00259196798      -2.06870014919      -2.13793311095      -2.21040814099
+  -2.28624272804      -2.36555403206      -2.44845829088      -2.53507015943
+  -2.62550197733      -2.71986296127      -2.81825831831      -2.92078827710
+  -3.02754703393      -3.13862161148      -3.25409062844      -3.37402297945
+  -3.49847642539      -3.62749609549      -3.76111290405      -3.89934188626
+  -4.04218045921      -4.18960661671      -4.34157706837      -4.49802533652
+  -4.65885982702      -4.82396189353      -4.99318391785      -5.16634743303
+  -5.34324131938      -5.52362010793      -5.70720242978      -5.89366965436
+  -6.08266476334      -6.27379151167      -6.46661393065      -6.66065623169
+  -6.85540317245      -7.05030094935      -7.24475868207      -7.43815055578
+  -7.62981868625      -7.81907677015      -8.00521457866      -8.18750334584
+  -8.36520209416      -8.53756492792      -8.70384931014      -8.86332532041
+  -9.01528586907      -9.15905781680      -9.29401391888      -9.41958547766
+  -9.53527554762      -9.64067249181      -9.73546363774      -9.81944872379
+  -9.89255276256      -9.95483787524      -10.0065135678      -10.0479448250
+  -10.0796572850      -10.1023386286      -10.1168351545      -10.1241423249
+  -10.1253879103      -10.1218053525      -10.1146962735      -10.1053778819
+  -10.0951135324      -10.0850221612      -10.0759621805      -10.0683844589
+  -10.0621480342      -10.0565743921      -10.0514424045      -10.0467234672
+  -10.0423899217      -10.0384153698      -10.0347746805      -10.0314439896
+  -10.0284006898      -10.0256234153      -10.0230920182      -10.0207875410
+  -10.0186921834      -10.0167892655      -10.0150631885      -10.0134993920
+  -10.0120843100      -10.0108053261      -10.0096507269      -10.0086096566
+  -10.0076720700      -10.0068286878      -10.0060709515      -10.0053909796
+  -10.0047815249      -10.0042359341      -10.0037481075      -10.0033124613
+  -10.0029238912      -10.0025777380      -10.0022697549      -10.0019960760
+  -10.0017531872      -10.0015378989      -10.0013473195      -10.0011788316
+  -10.0010300690      -10.0006833964      -10.0004512375      -10.0002965106
+  -10.0001938893      -10.0001261602      -10.0000816811      -10.0000526172
+  -10.0000337223      -10.0000215014      -10.0000136380      -10.0000086049
+  -10.0000054005      -10.0000033712      -10.0000020931      -10.0000012924
+  -10.0000007937      -10.0000004847      -10.0000002943      -10.0000001777
+  -10.0000001067      -10.0000000637      -10.0000000378      -10.0000000223
+  -10.0000000131      -10.0000000076      -10.0000000044      -10.0000000026
+  -10.0000000015      -10.0000000008      -10.0000000005      -10.0000000003
+  -10.0000000002      -10.0000000001      -10.0000000000      -10.0000000000
+  -10.0000000000      -10.0000000000      -10.0000000000      -10.0000000000
+  1
+ -0.279833373546E-05 -0.563186617620E-05 -0.850104006744E-05 -0.114063037234E-04
+ -0.143481110975E-04 -0.173269218531E-04 -0.203432014355E-04 -0.233974211444E-04
+ -0.264900582079E-04 -0.296215958568E-04 -0.327925234003E-04 -0.360033363022E-04
+ -0.392545362587E-04 -0.425466312762E-04 -0.458801357514E-04 -0.492555705511E-04
+ -0.526734630938E-04 -0.561343474322E-04 -0.596387643366E-04 -0.631872613792E-04
+ -0.667803930199E-04 -0.704187206928E-04 -0.741028128941E-04 -0.778332452705E-04
+ -0.816106007098E-04 -0.854354694315E-04 -0.893084490790E-04 -0.932301448134E-04
+ -0.972011694075E-04 -0.101222143342E-03 -0.105293694902E-03 -0.109416460277E-03
+ -0.113591083655E-03 -0.117818217332E-03 -0.122098521805E-03 -0.126432665880E-03
+ -0.130821326776E-03 -0.135265190231E-03 -0.139764950607E-03 -0.144321311000E-03
+ -0.148934983352E-03 -0.153606688559E-03 -0.158337156582E-03 -0.163127126569E-03
+ -0.167977346961E-03 -0.172888575615E-03 -0.177861579920E-03 -0.182897136920E-03
+ -0.187996033429E-03 -0.193159066160E-03 -0.198387041849E-03 -0.203680777376E-03
+ -0.209041099900E-03 -0.214468846980E-03 -0.219964866714E-03 -0.225530017866E-03
+ -0.231165170002E-03 -0.236871203626E-03 -0.242649010317E-03 -0.248499492870E-03
+ -0.254423565434E-03 -0.260422153658E-03 -0.266496194833E-03 -0.272646638040E-03
+ -0.278874444300E-03 -0.285180586718E-03 -0.291566050644E-03 -0.298031833818E-03
+ -0.304578946532E-03 -0.311208411786E-03 -0.317921265448E-03 -0.324718556414E-03
+ -0.331601346775E-03 -0.338570711981E-03 -0.345627741010E-03 -0.352773536536E-03
+ -0.360009215105E-03 -0.367335907306E-03 -0.374754757950E-03 -0.382266926247E-03
+ -0.389873585989E-03 -0.397575925732E-03 -0.405375148982E-03 -0.413272474384E-03
+ -0.421269135910E-03 -0.429366383056E-03 -0.437565481033E-03 -0.445867710967E-03
+ -0.454274370097E-03 -0.462786771981E-03 -0.471406246700E-03 -0.480134141065E-03
+ -0.488971818825E-03 -0.497920660887E-03 -0.506982065524E-03 -0.516157448601E-03
+ -0.525448243790E-03 -0.534855902795E-03 -0.544381895583E-03 -0.554027710609E-03
+ -0.563794855053E-03 -0.573684855049E-03 -0.583699255931E-03 -0.593839622469E-03
+ -0.604107539116E-03 -0.614504610255E-03 -0.625032460449E-03 -0.635692734697E-03
+ -0.646487098687E-03 -0.657417239062E-03 -0.668484863677E-03 -0.679691701873E-03
+ -0.691039504739E-03 -0.702530045394E-03 -0.714165119257E-03 -0.725946544333E-03
+ -0.737876161493E-03 -0.749955834764E-03 -0.762187451620E-03 -0.774572923275E-03
+ -0.787114184986E-03 -0.799813196348E-03 -0.812671941610E-03 -0.825692429975E-03
+ -0.838876695922E-03 -0.852226799520E-03 -0.865744826748E-03 -0.879432889826E-03
+ -0.893293127542E-03 -0.907327705586E-03 -0.921538816889E-03 -0.935928681967E-03
+ -0.950499549266E-03 -0.965253695512E-03 -0.980193426071E-03 -0.995321075307E-03
+ -0.101063900695E-02 -0.102614961444E-02 -0.104185532137E-02 -0.105775858176E-02
+ -0.107386188055E-02 -0.109016773390E-02 -0.110667868963E-02 -0.112339732762E-02
+ -0.114032626019E-02 -0.115746813251E-02 -0.117482562305E-02 -0.119240144393E-02
+ -0.121019834143E-02 -0.122821909634E-02 -0.124646652444E-02 -0.126494347693E-02
+ -0.128365284088E-02 -0.130259753964E-02 -0.132178053339E-02 -0.134120481949E-02
+ -0.136087343302E-02 -0.138078944727E-02 -0.140095597413E-02 -0.142137616467E-02
+ -0.144205320958E-02 -0.146299033970E-02 -0.148419082650E-02 -0.150565798259E-02
+ -0.152739516227E-02 -0.154940576200E-02 -0.157169322099E-02 -0.159426102171E-02
+ -0.161711269041E-02 -0.164025179772E-02 -0.166368195916E-02 -0.168740683576E-02
+ -0.171143013456E-02 -0.173575560926E-02 -0.176038706076E-02 -0.178532833778E-02
+ -0.181058333745E-02 -0.183615600590E-02 -0.186205033892E-02 -0.188827038255E-02
+ -0.191482023372E-02 -0.194170404091E-02 -0.196892600476E-02 -0.199649037877E-02
+ -0.202440146991E-02 -0.205266363936E-02 -0.208128130313E-02 -0.211025893280E-02
+ -0.213960105617E-02 -0.216931225802E-02 -0.219939718077E-02 -0.222986052527E-02
+ -0.226070705146E-02 -0.229194157919E-02 -0.232356898890E-02 -0.235559422245E-02
+ -0.238802228385E-02 -0.242085824004E-02 -0.245410722170E-02 -0.248777442407E-02
+ -0.252186510770E-02 -0.255638459934E-02 -0.259133829273E-02 -0.262673164945E-02
+ -0.266257019979E-02 -0.269885954359E-02 -0.273560535114E-02 -0.277281336403E-02
+ -0.281048939611E-02 -0.284863933432E-02 -0.288726913968E-02 -0.292638484816E-02
+ -0.296599257168E-02 -0.300609849902E-02 -0.304670889681E-02 -0.308783011051E-02
+ -0.312946856540E-02 -0.317163076757E-02 -0.321432330494E-02 -0.325755284831E-02
+ -0.330132615239E-02 -0.334565005684E-02 -0.339053148736E-02 -0.343597745677E-02
+ -0.348199506609E-02 -0.352859150566E-02 -0.357577405628E-02 -0.362355009031E-02
+ -0.367192707285E-02 -0.372091256291E-02 -0.377051421456E-02 -0.382073977816E-02
+ -0.387159710157E-02 -0.392309413133E-02 -0.397523891397E-02 -0.402803959721E-02
+ -0.408150443127E-02 -0.413564177012E-02 -0.419046007285E-02 -0.424596790492E-02
+ -0.430217393953E-02 -0.435908695901E-02 -0.441671585612E-02 -0.447506963548E-02
+ -0.453415741501E-02 -0.459398842728E-02 -0.465457202100E-02 -0.471591766249E-02
+ -0.477803493713E-02 -0.484093355086E-02 -0.490462333172E-02 -0.496911423136E-02
+ -0.503441632662E-02 -0.510053982108E-02 -0.516749504667E-02 -0.523529246528E-02
+ -0.530394267039E-02 -0.537345638872E-02 -0.544384448195E-02 -0.551511794834E-02
+ -0.558728792453E-02 -0.566036568721E-02 -0.573436265492E-02 -0.580929038985E-02
+ -0.588516059961E-02 -0.596198513905E-02 -0.603977601218E-02 -0.611854537396E-02
+ -0.619830553228E-02 -0.627906894980E-02 -0.636084824598E-02 -0.644365619900E-02
+ -0.652750574776E-02 -0.661240999391E-02 -0.669838220392E-02 -0.678543581112E-02
+ -0.687358441780E-02 -0.696284179736E-02 -0.705322189643E-02 -0.714473883709E-02
+ -0.723740691905E-02 -0.733124062186E-02 -0.742625460724E-02 -0.752246372130E-02
+ -0.761988299691E-02 -0.771852765602E-02 -0.781841311205E-02 -0.791955497230E-02
+ -0.802196904039E-02 -0.812567131872E-02 -0.823067801096E-02 -0.833700552462E-02
+ -0.844467047358E-02 -0.855368968070E-02 -0.866408018044E-02 -0.877585922153E-02
+ -0.888904426967E-02 -0.900365301024E-02 -0.911970335107E-02 -0.923721342526E-02
+ -0.935620159398E-02 -0.947668644937E-02 -0.959868681742E-02 -0.972222176091E-02
+ -0.984731058242E-02 -0.997397282732E-02 -0.101022282868E-01 -0.102320970011E-01
+ -0.103635992624E-01 -0.104967556182E-01 -0.106315868743E-01 -0.107681140986E-01
+ -0.109063586235E-01 -0.110463420501E-01 -0.111880862511E-01 -0.113316133741E-01
+ -0.114769458457E-01 -0.116241063743E-01 -0.117731179540E-01 -0.119240038682E-01
+ -0.120767876929E-01 -0.122314933011E-01 -0.123881448658E-01 -0.125467668639E-01
+ -0.127073840806E-01 -0.128700216126E-01 -0.130347048722E-01 -0.132014595916E-01
+ -0.133703118264E-01 -0.135412879601E-01 -0.137144147082E-01 -0.138897191218E-01
+ -0.140672285927E-01 -0.142469708571E-01 -0.144289739999E-01 -0.146132664596E-01
+ -0.147998770321E-01 -0.149888348757E-01 -0.151801695153E-01 -0.153739108474E-01
+ -0.155700891443E-01 -0.157687350593E-01 -0.159698796312E-01 -0.161735542890E-01
+ -0.163797908575E-01 -0.165886215612E-01 -0.168000790306E-01 -0.170141963060E-01
+ -0.172310068437E-01 -0.174505445207E-01 -0.176728436402E-01 -0.178979389367E-01
+ -0.181258655817E-01 -0.183566591893E-01 -0.185903558212E-01 -0.188269919929E-01
+ -0.190666046793E-01 -0.193092313201E-01 -0.195549098263E-01 -0.198036785854E-01
+ -0.200555764679E-01 -0.203106428334E-01 -0.205689175362E-01 -0.208304409323E-01
+ -0.210952538850E-01 -0.213633977719E-01 -0.216349144907E-01 -0.219098464663E-01
+ -0.221882366574E-01 -0.224701285627E-01 -0.227555662283E-01 -0.230445942542E-01
+ -0.233372578015E-01 -0.236336025992E-01 -0.239336749516E-01 -0.242375217455E-01
+ -0.245451904573E-01 -0.248567291607E-01 -0.251721865340E-01 -0.254916118677E-01
+ -0.258150550726E-01 -0.261425666871E-01 -0.264741978851E-01 -0.268100004846E-01
+ -0.271500269550E-01 -0.274943304259E-01 -0.278429646951E-01 -0.281959842372E-01
+ -0.285534442117E-01 -0.289154004722E-01 -0.292819095747E-01 -0.296530287867E-01
+ -0.300288160959E-01 -0.304093302195E-01 -0.307946306131E-01 -0.311847774802E-01
+ -0.315798317818E-01 -0.319798552453E-01 -0.323849103747E-01 -0.327950604602E-01
+ -0.332103695881E-01 -0.336309026508E-01 -0.340567253567E-01 -0.344879042411E-01
+ -0.349245066758E-01 -0.353666008803E-01 -0.358142559320E-01 -0.362675417773E-01
+ -0.367265292422E-01 -0.371912900438E-01 -0.376618968011E-01 -0.381384230465E-01
+ -0.386209432375E-01 -0.391095327680E-01 -0.396042679801E-01 -0.401052261763E-01
+ -0.406124856315E-01 -0.411261256048E-01 -0.416462263525E-01 -0.421728691405E-01
+ -0.427061362565E-01 -0.432461110234E-01 -0.437928778122E-01 -0.443465220550E-01
+ -0.449071302586E-01 -0.454747900178E-01 -0.460495900290E-01 -0.466316201047E-01
+ -0.472209711864E-01 -0.478177353601E-01 -0.484220058695E-01 -0.490338771316E-01
+ -0.496534447506E-01 -0.502808055333E-01 -0.509160575043E-01 -0.515592999208E-01
+ -0.522106332888E-01 -0.528701593781E-01 -0.535379812389E-01 -0.542142032173E-01
+ -0.548989309718E-01 -0.555922714901E-01 -0.562943331052E-01 -0.570052255131E-01
+ -0.577250597892E-01 -0.584539484060E-01 -0.591920052508E-01 -0.599393456433E-01
+ -0.606960863534E-01 -0.614623456200E-01 -0.622382431689E-01 -0.630239002320E-01
+ -0.638194395657E-01 -0.646249854706E-01 -0.654406638105E-01 -0.662666020325E-01
+ -0.671029291863E-01 -0.679497759450E-01 -0.688072746249E-01 -0.696755592069E-01
+ -0.705547653566E-01 -0.714450304461E-01 -0.723464935751E-01 -0.732592955931E-01
+ -0.741835791206E-01 -0.751194885722E-01 -0.760671701786E-01 -0.770267720098E-01
+ -0.779984439978E-01 -0.789823379606E-01 -0.799786076254E-01 -0.809874086526E-01
+ -0.820088986606E-01 -0.830432372500E-01 -0.840905860285E-01 -0.851511086364E-01
+ -0.862249707720E-01 -0.873123402174E-01 -0.884133868649E-01 -0.895282827431E-01
+ -0.906572020445E-01 -0.918003211519E-01 -0.929578186664E-01 -0.941298754352E-01
+ -0.953166745799E-01 -0.965184015246E-01 -0.977352440257E-01 -0.989673922005E-01
+ -0.100215038557     -0.101478378025     -0.102757607983     -0.104052928295
+ -0.105364541336     -0.106692652026     -0.108037467863     -0.109399198954
+ -0.110778058046     -0.112174260563     -0.113588024639     -0.115019571147
+ -0.116469123742     -0.117936908886     -0.119423155893     -0.120928096958
+ -0.122451967195     -0.123995004676     -0.125557450465     -0.127139548657
+ -0.128741546415     -0.130363694010     -0.132006244862     -0.133669455572
+ -0.135353585970     -0.137058899152     -0.138785661522     -0.140534142831
+ -0.142304616222     -0.144097358271     -0.145912649032     -0.147750772076
+ -0.149612014542     -0.151496667174     -0.153405024374     -0.155337384242
+ -0.157294048624     -0.159275323159     -0.161281517329     -0.163312944504
+ -0.165369921991     -0.167452771083     -0.169561817113     -0.171697389499
+ -0.173859821799     -0.176049451761     -0.178266621374     -0.180511676926
+ -0.182784969053     -0.185086852795     -0.187417687651     -0.189777837636
+ -0.192167671334     -0.194587561959     -0.197037887411     -0.199519030333
+ -0.202031378174     -0.204575323245     -0.207151262780     -0.209759599002
+ -0.212400739179     -0.215075095690     -0.217783086088     -0.220525133166
+ -0.223301665019     -0.226113115112     -0.228959922345     -0.231842531124
+ -0.234761391424     -0.237716958863     -0.240709694769     -0.243740066251
+ -0.246808546272     -0.249915613719     -0.253061753478     -0.256247456508
+ -0.259473219914     -0.262739547024     -0.266046947466     -0.269395937245
+ -0.272787038821     -0.276220781188     -0.279697699953     -0.283218337420
+ -0.286783242668     -0.290392971638     -0.294048087212     -0.297749159299
+ -0.301496764921     -0.305291488300     -0.309133920942     -0.313024661729
+ -0.316964317003     -0.320953500660     -0.324992834237     -0.329082947008
+ -0.333224476072     -0.337418066446     -0.341664371163     -0.345964051365
+ -0.350317776396     -0.354726223902     -0.359190079926     -0.363710039010
+ -0.368286804289     -0.372921087591     -0.377613609542     -0.382365099662
+ -0.387176296472     -0.392047947591     -0.396980809841     -0.401975649354
+ -0.407033241670     -0.412154371850     -0.417339834574     -0.422590434249
+ -0.427906985117     -0.433290311362     -0.438741247213     -0.444260637055
+ -0.449849335535     -0.455508207668     -0.461238128948     -0.467039985452
+ -0.472914673951     -0.478863102015     -0.484886188119     -0.490984861753
+ -0.497160063527     -0.503412745274     -0.509743870159     -0.516154412781
+ -0.522645359279     -0.529217707428     -0.535872466749     -0.542610658601
+ -0.549433316283     -0.556341485131     -0.563336222610     -0.570418598411
+ -0.577589694537     -0.584850605394     -0.592202437876     -0.599646311446
+ -0.607183358220     -0.614814723038     -0.622541563540     -0.630365050234
+ -0.638286366562     -0.646306708960     -0.654427286911     -0.662649323003
+ -0.670974052966     -0.679402725721     -0.687936603407     -0.696576961414
+ -0.705325088403     -0.714182286322     -0.723149870410     -0.732229169203
+ -0.741421524523     -0.750728291461     -0.760150838356     -0.769690546758
+ -0.779348811389     -0.789127040090     -0.799026653758     -0.809049086275
+ -0.819195784427     -0.829468207808     -0.839867828722     -0.850396132061
+ -0.861054615186     -0.871844787784     -0.882768171725     -0.893826300898
+ -0.905020721040     -0.916352989557     -0.927824675323     -0.939437358484
+ -0.951192630234     -0.963092092593     -0.975137358171     -0.987330049922
+ -0.999671800886      -1.01216425393      -1.02480906148      -1.03760788523
+  -1.05056239587      -1.06367427281      -1.07694520386      -1.09037688495
+  -1.10397101983      -1.11772931979      -1.13165350332      -1.14574529588
+  -1.16000642955      -1.17443864277      -1.18904368009      -1.20382329182
+  -1.21877923385      -1.23391326736      -1.24922715858      -1.26472267853
+  -1.28040160286      -1.29626571162      -1.31231678904      -1.32855662340
+  -1.34498700682      -1.36160973515      -1.37842660780      -1.39543942764
+  -1.41265000086      -1.43006013688      -1.44767164824      -1.46548635051
+  -1.48350606220      -1.50173260465      -1.52016780196      -1.53881348085
+  -1.55767147059      -1.57674360282      -1.59603171142      -1.61553763236
+  -1.63526320343      -1.65521026408      -1.67538065511      -1.69577621831
+  -1.71639879618      -1.73725023141      -1.75833236649      -1.77964704309
+  -1.80119610150      -1.82298137989      -1.84500471360      -1.86726793425
+  -1.88977286879      -1.91252133851      -1.93551515788      -1.95875613330
+  -1.98224606180      -2.00598672955      -2.02997991033      -2.05422736378
+  -2.07873083367      -2.10349204590      -2.12851270642      -2.15379449906
+  -2.17933908313      -2.20514809096      -2.23122312517      -2.25756575593
+  -2.28417751792      -2.31105990721      -2.33821437791      -2.36564233864
+  -2.39334514885      -2.42132411490      -2.44958048594      -2.47811544958
+  -2.50693012731      -2.53602556975      -2.56540275160      -2.59506256629
+  -2.62500582051      -2.65523322829      -2.68574540493      -2.71654286053
+  -2.74762599324      -2.77899508221      -2.81065028012      -2.84259160544
+  -2.87481893425      -2.90733199170      -2.94013034303      -2.97321338424
+  -3.00658033225      -3.04023021463      -3.07416185889      -3.10837388122
+  -3.14286467476      -3.17763239740      -3.21267495891      -3.24799000769
+  -3.28357491677      -3.31942676937      -3.35554234382      -3.39191809780
+  -3.42855015210      -3.46543427361      -3.50256585776      -3.53993991029
+  -3.57755102840      -3.61539338119      -3.65346068951      -3.69174620521
+  -3.73024268966      -3.76894239178      -3.80783702538      -3.84691774606
+  -3.88617512744      -3.92559913703      -3.96517911163      -4.00490373229
+  -4.04476099907      -4.08473820545      -4.12482191271      -4.16499792416
+  -4.20525125951      -4.24556612941      -4.28592591035      -4.32631312001
+  -4.36670939336      -4.40709545955      -4.44745111998      -4.48775522758
+  -4.52798566780      -4.56811934132      -4.60813214904      -4.64799897952
+  -4.68769369925      -4.72718914619      -4.76645712691      -4.80546841789
+  -4.84419277130      -4.88259892585      -4.92065462325      -4.95832663077
+  -4.99558077053      -5.03238195621      -5.06869423760      -5.10448085400
+  -5.13970429688      -5.17432638270      -5.20830833655      -5.24161088755
+  -5.27419437657      -5.30601887736      -5.33704433181      -5.36723070012
+  -5.39653812703      -5.42492712476      -5.45235877370      -5.47879494182
+  -5.50419852370      -5.52853370016      -5.55176621958      -5.57386370180
+  -5.59479596582      -5.61453538225      -5.63305725183      -5.65034021098
+  -5.66636666596      -5.68112325663      -5.69460135158      -5.70679757588
+  -5.71771437330      -5.72736060460      -5.73575218387      -5.74291275484
+  -5.74887440931      -5.75367844993      -5.75737619933      -5.76002985818
+  -5.76171341384      -5.76251360179      -5.76253092113      -5.76188070489
+  -5.76069424528      -5.75911997221      -5.75732468229      -5.75549481275
+  -5.75383775216      -5.75258317601      -5.75198439065      -5.75231966354
+  -5.75389351090      -5.75703790570      -5.76211335954      -5.76950982075
+  -5.77964731820      -5.79297626636      -5.80997733070      -5.83116073562
+  -5.85706487840      -5.88825409352      -5.92531539258      -5.96885398669
+  -6.01948738196      -6.07783782604      -6.14452287666      -6.22014386383
+  -6.30527202902      -6.40043215047      -6.50608350738      -6.62259810192
+  -6.75023615118      -6.88911898649      -7.03919965984      -7.20023176185
+  -7.37173720680      -7.55297404111      -7.74290568496      -7.94017342180
+  -8.14307440610      -8.34954796046      -8.55717347246      -8.76318377022
+  -8.96449852692      -9.15778211980      -9.33953264285      -9.50620666078
+  -9.65438800134      -9.78100777957      -9.88362445810      -9.96077404444
+  -10.0124024899      -10.0403952781      -10.0492221957      -10.0467232191
+  2
+ -0.625224581455E-05 -0.125831352001E-04 -0.189936573710E-04 -0.254848139844E-04
+ -0.320576192966E-04 -0.387131003220E-04 -0.454522969929E-04 -0.522762623226E-04
+ -0.591860625695E-04 -0.661827774040E-04 -0.732675000769E-04 -0.804413375907E-04
+ -0.877054108720E-04 -0.950608549470E-04 -0.102508819119E-03 -0.110050467147E-03
+ -0.117686977430E-03 -0.125419543187E-03 -0.133249372648E-03 -0.141177689239E-03
+ -0.149205731776E-03 -0.157334754657E-03 -0.165566028059E-03 -0.173900838134E-03
+ -0.182340487214E-03 -0.190886294011E-03 -0.199539593825E-03 -0.208301738750E-03
+ -0.217174097892E-03 -0.226158057572E-03 -0.235255021555E-03 -0.244466411257E-03
+ -0.253793665979E-03 -0.263238243123E-03 -0.272801618422E-03 -0.282485286174E-03
+ -0.292290759471E-03 -0.302219570440E-03 -0.312273270476E-03 -0.322453430490E-03
+ -0.332761641154E-03 -0.343199513146E-03 -0.353768677406E-03 -0.364470785386E-03
+ -0.375307509312E-03 -0.386280542445E-03 -0.397391599344E-03 -0.408642416133E-03
+ -0.420034750776E-03 -0.431570383349E-03 -0.443251116317E-03 -0.455078774818E-03
+ -0.467055206948E-03 -0.479182284050E-03 -0.491461901004E-03 -0.503895976524E-03
+ -0.516486453460E-03 -0.529235299101E-03 -0.542144505479E-03 -0.555216089683E-03
+ -0.568452094176E-03 -0.581854587110E-03 -0.595425662652E-03 -0.609167441310E-03
+ -0.623082070265E-03 -0.637171723705E-03 -0.651438603169E-03 -0.665884937885E-03
+ -0.680512985122E-03 -0.695325030542E-03 -0.710323388558E-03 -0.725510402693E-03
+ -0.740888445950E-03 -0.756459921178E-03 -0.772227261453E-03 -0.788192930453E-03
+ -0.804359422848E-03 -0.820729264683E-03 -0.837305013781E-03 -0.854089260135E-03
+ -0.871084626319E-03 -0.888293767892E-03 -0.905719373819E-03 -0.923364166886E-03
+ -0.941230904127E-03 -0.959322377256E-03 -0.977641413104E-03 -0.996190874056E-03
+ -0.101497365850E-02 -0.103399270130E-02 -0.105325097420E-02 -0.107275148635E-02
+ -0.109249728475E-02 -0.111249145471E-02 -0.113273712038E-02 -0.115323744517E-02
+ -0.117399563230E-02 -0.119501492528E-02 -0.121629860842E-02 -0.123785000734E-02
+ -0.125967248949E-02 -0.128176946466E-02 -0.130414438557E-02 -0.132680074834E-02
+ -0.134974209307E-02 -0.137297200439E-02 -0.139649411203E-02 -0.142031209136E-02
+ -0.144442966398E-02 -0.146885059832E-02 -0.149357871021E-02 -0.151861786345E-02
+ -0.154397197046E-02 -0.156964499288E-02 -0.159564094217E-02 -0.162196388025E-02
+ -0.164861792013E-02 -0.167560722656E-02 -0.170293601667E-02 -0.173060856064E-02
+ -0.175862918236E-02 -0.178700226012E-02 -0.181573222726E-02 -0.184482357290E-02
+ -0.187428084262E-02 -0.190410863918E-02 -0.193431162324E-02 -0.196489451406E-02
+ -0.199586209030E-02 -0.202721919069E-02 -0.205897071485E-02 -0.209112162401E-02
+ -0.212367694183E-02 -0.215664175514E-02 -0.219002121475E-02 -0.222382053628E-02
+ -0.225804500093E-02 -0.229269995636E-02 -0.232779081746E-02 -0.236332306725E-02
+ -0.239930225773E-02 -0.243573401071E-02 -0.247262401874E-02 -0.250997804593E-02
+ -0.254780192895E-02 -0.258610157785E-02 -0.262488297703E-02 -0.266415218615E-02
+ -0.270391534112E-02 -0.274417865500E-02 -0.278494841903E-02 -0.282623100356E-02
+ -0.286803285907E-02 -0.291036051720E-02 -0.295322059172E-02 -0.299661977962E-02
+ -0.304056486209E-02 -0.308506270566E-02 -0.313012026319E-02 -0.317574457502E-02
+ -0.322194277005E-02 -0.326872206684E-02 -0.331608977474E-02 -0.336405329506E-02
+ -0.341262012219E-02 -0.346179784480E-02 -0.351159414702E-02 -0.356201680960E-02
+ -0.361307371120E-02 -0.366477282957E-02 -0.371712224278E-02 -0.377013013056E-02
+ -0.382380477548E-02 -0.387815456431E-02 -0.393318798933E-02 -0.398891364962E-02
+ -0.404534025242E-02 -0.410247661451E-02 -0.416033166356E-02 -0.421891443954E-02
+ -0.427823409612E-02 -0.433829990213E-02 -0.439912124296E-02 -0.446070762208E-02
+ -0.452306866248E-02 -0.458621410821E-02 -0.465015382586E-02 -0.471489780615E-02
+ -0.478045616545E-02 -0.484683914739E-02 -0.491405712445E-02 -0.498212059958E-02
+ -0.505104020783E-02 -0.512082671802E-02 -0.519149103445E-02 -0.526304419855E-02
+ -0.533549739065E-02 -0.540886193172E-02 -0.548314928510E-02 -0.555837105836E-02
+ -0.563453900504E-02 -0.571166502654E-02 -0.578976117395E-02 -0.586883964997E-02
+ -0.594891281076E-02 -0.602999316792E-02 -0.611209339041E-02 -0.619522630657E-02
+ -0.627940490607E-02 -0.636464234201E-02 -0.645095193289E-02 -0.653834716477E-02
+ -0.662684169333E-02 -0.671644934603E-02 -0.680718412423E-02 -0.689906020543E-02
+ -0.699209194545E-02 -0.708629388070E-02 -0.718168073042E-02 -0.727826739899E-02
+ -0.737606897829E-02 -0.747510074999E-02 -0.757537818803E-02 -0.767691696094E-02
+ -0.777973293438E-02 -0.788384217354E-02 -0.798926094571E-02 -0.809600572278E-02
+ -0.820409318384E-02 -0.831354021778E-02 -0.842436392591E-02 -0.853658162467E-02
+ -0.865021084829E-02 -0.876526935158E-02 -0.888177511266E-02 -0.899974633578E-02
+ -0.911920145420E-02 -0.924015913302E-02 -0.936263827211E-02 -0.948665800910E-02
+ -0.961223772231E-02 -0.973939703383E-02 -0.986815581257E-02 -0.999853417733E-02
+ -0.101305525000E-01 -0.102642314087E-01 -0.103995917911E-01 -0.105366547975E-01
+ -0.106754418442E-01 -0.108159746170E-01 -0.109582750744E-01 -0.111023654512E-01
+ -0.112482682618E-01 -0.113960063038E-01 -0.115456026615E-01 -0.116970807098E-01
+ -0.118504641173E-01 -0.120057768505E-01 -0.121630431773E-01 -0.123222876710E-01
+ -0.124835352137E-01 -0.126468110008E-01 -0.128121405444E-01 -0.129795496776E-01
+ -0.131490645584E-01 -0.133207116739E-01 -0.134945178442E-01 -0.136705102270E-01
+ -0.138487163213E-01 -0.140291639723E-01 -0.142118813752E-01 -0.143968970801E-01
+ -0.145842399959E-01 -0.147739393955E-01 -0.149660249196E-01 -0.151605265822E-01
+ -0.153574747743E-01 -0.155569002697E-01 -0.157588342289E-01 -0.159633082045E-01
+ -0.161703541460E-01 -0.163800044047E-01 -0.165922917389E-01 -0.168072493189E-01
+ -0.170249107323E-01 -0.172453099891E-01 -0.174684815271E-01 -0.176944602174E-01
+ -0.179232813695E-01 -0.181549807372E-01 -0.183895945240E-01 -0.186271593888E-01
+ -0.188677124516E-01 -0.191112912992E-01 -0.193579339914E-01 -0.196076790665E-01
+ -0.198605655477E-01 -0.201166329491E-01 -0.203759212816E-01 -0.206384710597E-01
+ -0.209043233071E-01 -0.211735195640E-01 -0.214461018926E-01 -0.217221128846E-01
+ -0.220015956671E-01 -0.222845939101E-01 -0.225711518324E-01 -0.228613142093E-01
+ -0.231551263793E-01 -0.234526342511E-01 -0.237538843110E-01 -0.240589236297E-01
+ -0.243677998703E-01 -0.246805612954E-01 -0.249972567745E-01 -0.253179357919E-01
+ -0.256426484543E-01 -0.259714454988E-01 -0.263043783005E-01 -0.266414988808E-01
+ -0.269828599155E-01 -0.273285147428E-01 -0.276785173722E-01 -0.280329224920E-01
+ -0.283917854789E-01 -0.287551624059E-01 -0.291231100512E-01 -0.294956859076E-01
+ -0.298729481906E-01 -0.302549558482E-01 -0.306417685699E-01 -0.310334467959E-01
+ -0.314300517267E-01 -0.318316453325E-01 -0.322382903632E-01 -0.326500503577E-01
+ -0.330669896545E-01 -0.334891734011E-01 -0.339166675644E-01 -0.343495389413E-01
+ -0.347878551687E-01 -0.352316847345E-01 -0.356810969877E-01 -0.361361621500E-01
+ -0.365969513261E-01 -0.370635365152E-01 -0.375359906221E-01 -0.380143874687E-01
+ -0.384988018054E-01 -0.389893093227E-01 -0.394859866636E-01 -0.399889114346E-01
+ -0.404981622188E-01 -0.410138185875E-01 -0.415359611130E-01 -0.420646713810E-01
+ -0.426000320035E-01 -0.431421266316E-01 -0.436910399686E-01 -0.442468577831E-01
+ -0.448096669227E-01 -0.453795553274E-01 -0.459566120433E-01 -0.465409272365E-01
+ -0.471325922074E-01 -0.477316994046E-01 -0.483383424397E-01 -0.489526161018E-01
+ -0.495746163723E-01 -0.502044404398E-01 -0.508421867153E-01 -0.514879548480E-01
+ -0.521418457402E-01 -0.528039615634E-01 -0.534744057745E-01 -0.541532831316E-01
+ -0.548406997103E-01 -0.555367629207E-01 -0.562415815238E-01 -0.569552656489E-01
+ -0.576779268101E-01 -0.584096779246E-01 -0.591506333297E-01 -0.599009088008E-01
+ -0.606606215699E-01 -0.614298903432E-01 -0.622088353203E-01 -0.629975782125E-01
+ -0.637962422623E-01 -0.646049522621E-01 -0.654238345742E-01 -0.662530171503E-01
+ -0.670926295514E-01 -0.679428029682E-01 -0.688036702418E-01 -0.696753658838E-01
+ -0.705580260982E-01 -0.714517888018E-01 -0.723567936464E-01 -0.732731820404E-01
+ -0.742010971707E-01 -0.751406840256E-01 -0.760920894167E-01 -0.770554620025E-01
+ -0.780309523114E-01 -0.790187127650E-01 -0.800188977022E-01 -0.810316634033E-01
+ -0.820571681143E-01 -0.830955720717E-01 -0.841470375274E-01 -0.852117287742E-01
+ -0.862898121714E-01 -0.873814561710E-01 -0.884868313436E-01 -0.896061104054E-01
+ -0.907394682451E-01 -0.918870819511E-01 -0.930491308394E-01 -0.942257964813E-01
+ -0.954172627322E-01 -0.966237157598E-01 -0.978453440738E-01 -0.990823385547E-01
+ -0.100334892484     -0.101603201575     -0.102887464001     -0.104187880430
+ -0.105504654053     -0.106837990617     -0.108188098457     -0.109555188528
+ -0.110939474439     -0.112341172485     -0.113760501683     -0.115197683804
+ -0.116652943409     -0.118126507881     -0.119618607468     -0.121129475309
+ -0.122659347478     -0.124208463019     -0.125777063981     -0.127365395459
+ -0.128973705629     -0.130602245791     -0.132251270404     -0.133921037128
+ -0.135611806863     -0.137323843794     -0.139057415425     -0.140812792627
+ -0.142590249677     -0.144390064301     -0.146212517721     -0.148057894694
+ -0.149926483558     -0.151818576281     -0.153734468500     -0.155674459572
+ -0.157638852618     -0.159627954575     -0.161642076236     -0.163681532306
+ -0.165746641448     -0.167837726332     -0.169955113688     -0.172099134355
+ -0.174270123331     -0.176468419831     -0.178694367335     -0.180948313643
+ -0.183230610929     -0.185541615797     -0.187881689337     -0.190251197180
+ -0.192650509555     -0.195080001348     -0.197540052162     -0.200031046372
+ -0.202553373187     -0.205107426714     -0.207693606014     -0.210312315169
+ -0.212963963343     -0.215648964844     -0.218367739194     -0.221120711190
+ -0.223908310970     -0.226730974085     -0.229589141562     -0.232483259974
+ -0.235413781513     -0.238381164056     -0.241385871239     -0.244428372529
+ -0.247509143299     -0.250628664898     -0.253787424729     -0.256985916328
+ -0.260224639433     -0.263504100071     -0.266824810631     -0.270187289945
+ -0.273592063371     -0.277039662874     -0.280530627109     -0.284065501505
+ -0.287644838348     -0.291269196872     -0.294939143343     -0.298655251147
+ -0.302418100881     -0.306228280443     -0.310086385123     -0.313993017699
+ -0.317948788526     -0.321954315635     -0.326010224828     -0.330117149778
+ -0.334275732122     -0.338486621567     -0.342750475991     -0.347067961540
+ -0.351439752738     -0.355866532590     -0.360348992686     -0.364887833314
+ -0.369483763565     -0.374137501444     -0.378849773983     -0.383621317356
+ -0.388452876988     -0.393345207678     -0.398299073711     -0.403315248981
+ -0.408394517110     -0.413537671567     -0.418745515798     -0.424018863346
+ -0.429358537977     -0.434765373815     -0.440240215461     -0.445783918136
+ -0.451397347803     -0.457081381312     -0.462836906526     -0.468664822469
+ -0.474566039458     -0.480541479247     -0.486592075171     -0.492718772291
+ -0.498922527537     -0.505204309864     -0.511565100392     -0.518005892567
+ -0.524527692310     -0.531131518176     -0.537818401508     -0.544589386599
+ -0.551445530855     -0.558387904954     -0.565417593016     -0.572535692768
+ -0.579743315713     -0.587041587305     -0.594431647118     -0.601914649023
+ -0.609491761370     -0.617164167161     -0.624933064237     -0.632799665458
+ -0.640765198894     -0.648830908009     -0.656998051856     -0.665267905264
+ -0.673641759040     -0.682120920159     -0.690706711971     -0.699400474396
+ -0.708203564134     -0.717117354866     -0.726143237468     -0.735282620217
+ -0.744536929010     -0.753907607575     -0.763396117689     -0.773003939405
+ -0.782732571266     -0.792583530537     -0.802558353429     -0.812658595331
+ -0.822885831041     -0.833241655002     -0.843727681537     -0.854345545093
+ -0.865096900478     -0.875983423107     -0.887006809252     -0.898168776285
+ -0.909471062934     -0.920915429535     -0.932503658287     -0.944237553514
+ -0.956118941918     -0.968149672851     -0.980331618571     -0.992666674516
+  -1.00515675957      -1.01780381632      -1.03060981138      -1.04357673558
+  -1.05670660432      -1.07000145782      -1.08346336140      -1.09709440574
+  -1.11089670721      -1.12487240813      -1.13902367704      -1.15335270901
+  -1.16786172592      -1.18255297676      -1.19742873791      -1.21249131342
+  -1.22774303533      -1.24318626393      -1.25882338809      -1.27465682550
+  -1.29068902302      -1.30692245693      -1.32335963324      -1.34000308796
+  -1.35685538744      -1.37391912858      -1.39119693919      -1.40869147823
+  -1.42640543610      -1.44434153493      -1.46250252886      -1.48089120430
+  -1.49951038020      -1.51836290835      -1.53745167359      -1.55677959411
+  -1.57634962168      -1.59616474192      -1.61622797453      -1.63654237351
+  -1.65711102742      -1.67793705961      -1.69902362838      -1.72037392724
+  -1.74199118511      -1.76387866648      -1.78603967161      -1.80847753671
+  -1.83119563409      -1.85419737230      -1.87748619633      -1.90106558766
+  -1.92493906444      -1.94911018158      -1.97358253082      -1.99835974087
+  -2.02344547742      -2.04884344325      -2.07455737821      -2.10059105934
+  -2.12694830080      -2.15363295394      -2.18064890726      -2.20800008640
+  -2.23569045409      -2.26372401014      -2.29210479132      -2.32083687136
+  -2.34992436080      -2.37937140694      -2.40918219372      -2.43936094158
+  -2.46991190735      -2.50083938413      -2.53214770109      -2.56384122337
+  -2.59592435185      -2.62840152305      -2.66127720887      -2.69455591644
+  -2.72824218791      -2.76234060024      -2.79685576498      -2.83179232804
+  -2.86715496945      -2.90294840312      -2.93917737657      -2.97584667062
+  -3.01296109918      -3.05052550883      -3.08854477856      -3.12702381940
+  -3.16596757399      -3.20538101618      -3.24526915058      -3.28563701206
+  -3.32648966513      -3.36783220341      -3.40966974892      -3.45200745132
+  -3.49485048715      -3.53820405883      -3.58207339373      -3.62646374306
+  -3.67138038062      -3.71682860145      -3.76281372040      -3.80934107045
+  -3.85641600098      -3.90404387575      -3.95223007085      -4.00097997230
+  -4.05029897357      -4.10019247279      -4.15066586978      -4.20172456283
+  -4.25337394517      -4.30561940121      -4.35846630249      -4.41192000328
+  -4.46598583592      -4.52066910572      -4.57597508563      -4.63190901041
+  -4.68847607047      -4.74568140534      -4.80353009654      -4.86202716020
+  -4.92117753905      -4.98098609397      -5.04145759499      -5.10259671178
+  -5.16440800346      -5.22689590797      -5.29006473062      -5.35391863208
+  -5.41846161568      -5.48369751394      -5.54962997428      -5.61626244409
+  -5.68359815479      -5.75164010510      -5.82039104336      -5.88985344895
+  -5.96002951257      -6.03092111566      -6.10252980852      -6.17485678746
+  -6.24790287065      -6.32166847279      -6.39615357841      -6.47135771393
+  -6.54727991822      -6.62391871176      -6.70127206431      -6.77933736095
+  -6.85811136659      -6.93759018870      -7.01776923845      -7.09864318994
+  -7.18020593770      -7.26245055226      -7.34536923378      -7.42895326377
+  -7.51319295473      -7.59807759778      -7.68359540819      -7.76973346879
+  -7.85647767129      -7.94381265541      -8.03172174590      -8.12018688737
+  -8.20918857706      -8.29870579549      -8.38871593501      -8.47919472644
+  -8.57011616375      -8.66145242689      -8.75317380302      -8.84524860601
+  -8.93764309473      -9.03032138997      -9.12324539051      -9.21637468832
+  -9.30966648350      -9.40307549894      -9.49655389538      -9.59005118706
+  -9.68351415858      -9.77688678341      -9.87011014457      -9.96312235828
+  -10.0558585010      -10.1482505410      -10.2402272747      -10.3317142694
+  -10.4226338124      -10.5129048691      -10.6024430489      -10.6911605826
+  -10.7789663105      -10.8657656839      -10.9514607808      -11.0359503373
+  -11.1191297965      -11.2008913770      -11.2811241612      -11.3597142073
+  -11.4365446848      -11.5114960371      -11.5844461720      -11.6552706825
+  -11.7238430997      -11.7900351801      -11.8537172287      -11.9147584602
+  -11.9730273993      -12.0283923235      -12.0807217475      -12.1298849527
+  -12.1757525614      -12.2181971577      -12.2570939548      -12.2923215093
+  -12.3237624823      -12.3513044465      -12.3748407380      -12.3942713518
+  -12.4095038773      -12.4204544722      -12.4270488697      -12.4292234157
+  -12.4269261291      -12.4201177807      -12.4087729814      -12.3928812731
+  -12.3724482124      -12.3474964365      -12.3180667015      -12.2842188781
+  -12.2460328947      -12.2036096106      -12.1570716056      -12.1065638699
+  -12.0522543754      -11.9943345131      -11.9330193750      -11.8685478637
+  -11.8011826073      -11.7312096604      -11.6589379694      -11.5846985809
+  -11.5088435697      -11.4317446651      -11.3537915522      -11.2753898240
+  -11.1969585613      -11.1189275156      -11.0417338724      -10.9658185696
+  -10.8916221483      -10.8195801166      -10.7501178052      -10.6836447047
+  -10.6205482747      -10.5611872317      -10.5058843335      -10.4549187006
+  -10.4085177430      -10.3668487977      -10.3300106337      -10.2980250419
+  -10.2708288100      -10.2482664836      -10.2300844364      -10.2159269277
+  -10.2053350069      -10.1977493417      -10.1925183086      -10.1889129830
+  -10.1861510239      -10.1834318559      -10.1799860299      -10.1751422016
+  -10.1684158173      -10.1596243651      -10.1490349667      -10.1375511718
+  -10.1265120464      -10.1162220903      -10.1066450228      -10.0977445119
+  -10.0894844178      -10.0818290845      -10.0747436312      -10.0681942117
+  -10.0621482020      -10.0565743921      -10.0514424045      -10.0467234672
+  3
+ -0.764261441628E-05 -0.153813610876E-04 -0.232174492090E-04 -0.311521031850E-04
+ -0.391865628216E-04 -0.473220835194E-04 -0.555599364700E-04 -0.639014088548E-04
+ -0.723478040457E-04 -0.809004418092E-04 -0.895606585124E-04 -0.983298073317E-04
+ -0.107209258465E-03 -0.116200399343E-03 -0.125304634852E-03 -0.134523387545E-03
+ -0.143858097873E-03 -0.153310224402E-03 -0.162881244046E-03 -0.172572652298E-03
+ -0.182385963458E-03 -0.192322710877E-03 -0.202384447193E-03 -0.212572744571E-03
+ -0.222889194953E-03 -0.233335410307E-03 -0.243913022875E-03 -0.254623685429E-03
+ -0.265469071534E-03 -0.276450875802E-03 -0.287570814163E-03 -0.298830624129E-03
+ -0.310232065070E-03 -0.321776918483E-03 -0.333466988275E-03 -0.345304101044E-03
+ -0.357290106362E-03 -0.369426877067E-03 -0.381716309554E-03 -0.394160324072E-03
+ -0.406760865024E-03 -0.419519901270E-03 -0.432439426434E-03 -0.445521459220E-03
+ -0.458768043722E-03 -0.472181249744E-03 -0.485763173129E-03 -0.499515936078E-03
+ -0.513441687490E-03 -0.527542603291E-03 -0.541820886778E-03 -0.556278768963E-03
+ -0.570918508917E-03 -0.585742394131E-03 -0.600752740867E-03 -0.615951894522E-03
+ -0.631342229995E-03 -0.646926152056E-03 -0.662706095726E-03 -0.678684526653E-03
+ -0.694863941499E-03 -0.711246868331E-03 -0.727835867013E-03 -0.744633529612E-03
+ -0.761642480796E-03 -0.778865378247E-03 -0.796304913080E-03 -0.813963810257E-03
+ -0.831844829016E-03 -0.849950763303E-03 -0.868284442207E-03 -0.886848730402E-03
+ -0.905646528597E-03 -0.924680773986E-03 -0.943954440708E-03 -0.963470540312E-03
+ -0.983232122230E-03 -0.100324227425E-02 -0.102350412299E-02 -0.104402083442E-02
+ -0.106479561431E-02 -0.108583170876E-02 -0.110713240471E-02 -0.112870103042E-02
+ -0.115054095605E-02 -0.117265559413E-02 -0.119504840011E-02 -0.121772287291E-02
+ -0.124068255548E-02 -0.126393103529E-02 -0.128747194499E-02 -0.131130896287E-02
+ -0.133544581353E-02 -0.135988626840E-02 -0.138463414634E-02 -0.140969331426E-02
+ -0.143506768772E-02 -0.146076123150E-02 -0.148677796028E-02 -0.151312193922E-02
+ -0.153979728462E-02 -0.156680816456E-02 -0.159415879954E-02 -0.162185346317E-02
+ -0.164989648277E-02 -0.167829224014E-02 -0.170704517217E-02 -0.173615977156E-02
+ -0.176564058752E-02 -0.179549222651E-02 -0.182571935288E-02 -0.185632668970E-02
+ -0.188731901942E-02 -0.191870118466E-02 -0.195047808895E-02 -0.198265469748E-02
+ -0.201523603793E-02 -0.204822720119E-02 -0.208163334219E-02 -0.211545968072E-02
+ -0.214971150222E-02 -0.218439415858E-02 -0.221951306906E-02 -0.225507372106E-02
+ -0.229108167099E-02 -0.232754254517E-02 -0.236446204069E-02 -0.240184592630E-02
+ -0.243970004330E-02 -0.247803030648E-02 -0.251684270501E-02 -0.255614330342E-02
+ -0.259593824250E-02 -0.263623374030E-02 -0.267703609305E-02 -0.271835167623E-02
+ -0.276018694547E-02 -0.280254843761E-02 -0.284544277173E-02 -0.288887665015E-02
+ -0.293285685950E-02 -0.297739027179E-02 -0.302248384544E-02 -0.306814462643E-02
+ -0.311437974933E-02 -0.316119643849E-02 -0.320860200910E-02 -0.325660386838E-02
+ -0.330520951673E-02 -0.335442654887E-02 -0.340426265505E-02 -0.345472562229E-02
+ -0.350582333551E-02 -0.355756377884E-02 -0.360995503683E-02 -0.366300529572E-02
+ -0.371672284472E-02 -0.377111607730E-02 -0.382619349252E-02 -0.388196369634E-02
+ -0.393843540297E-02 -0.399561743622E-02 -0.405351873090E-02 -0.411214833421E-02
+ -0.417151540714E-02 -0.423162922593E-02 -0.429249918346E-02 -0.435413479081E-02
+ -0.441654567865E-02 -0.447974159883E-02 -0.454373242582E-02 -0.460852815832E-02
+ -0.467413892080E-02 -0.474057496508E-02 -0.480784667192E-02 -0.487596455267E-02
+ -0.494493925087E-02 -0.501478154397E-02 -0.508550234496E-02 -0.515711270413E-02
+ -0.522962381072E-02 -0.530304699475E-02 -0.537739372874E-02 -0.545267562951E-02
+ -0.552890446003E-02 -0.560609213119E-02 -0.568425070373E-02 -0.576339239009E-02
+ -0.584352955631E-02 -0.592467472399E-02 -0.600684057222E-02 -0.609003993959E-02
+ -0.617428582616E-02 -0.625959139554E-02 -0.634596997688E-02 -0.643343506701E-02
+ -0.652200033254E-02 -0.661167961197E-02 -0.670248691786E-02 -0.679443643904E-02
+ -0.688754254281E-02 -0.698181977719E-02 -0.707728287319E-02 -0.717394674711E-02
+ -0.727182650288E-02 -0.737093743441E-02 -0.747129502798E-02 -0.757291496467E-02
+ -0.767581312280E-02 -0.778000558042E-02 -0.788550861781E-02 -0.799233872004E-02
+ -0.810051257952E-02 -0.821004709865E-02 -0.832095939240E-02 -0.843326679106E-02
+ -0.854698684288E-02 -0.866213731685E-02 -0.877873620546E-02 -0.889680172754E-02
+ -0.901635233105E-02 -0.913740669602E-02 -0.925998373745E-02 -0.938410260823E-02
+ -0.950978270221E-02 -0.963704365714E-02 -0.976590535781E-02 -0.989638793913E-02
+ -0.100285117893E-01 -0.101622975528E-01 -0.102977661341E-01 -0.104349387003E-01
+ -0.105738366851E-01 -0.107144817913E-01 -0.108568959952E-01 -0.110011015492E-01
+ -0.111471209858E-01 -0.112949771208E-01 -0.114446930570E-01 -0.115962921878E-01
+ -0.117497982009E-01 -0.119052350819E-01 -0.120626271182E-01 -0.122219989025E-01
+ -0.123833753371E-01 -0.125467816373E-01 -0.127122433357E-01 -0.128797862861E-01
+ -0.130494366672E-01 -0.132212209875E-01 -0.133951660884E-01 -0.135712991494E-01
+ -0.137496476915E-01 -0.139302395820E-01 -0.141131030388E-01 -0.142982666347E-01
+ -0.144857593019E-01 -0.146756103365E-01 -0.148678494031E-01 -0.150625065394E-01
+ -0.152596121610E-01 -0.154591970660E-01 -0.156612924401E-01 -0.158659298609E-01
+ -0.160731413036E-01 -0.162829591453E-01 -0.164954161705E-01 -0.167105455760E-01
+ -0.169283809763E-01 -0.171489564085E-01 -0.173723063380E-01 -0.175984656637E-01
+ -0.178274697234E-01 -0.180593542996E-01 -0.182941556245E-01 -0.185319103864E-01
+ -0.187726557350E-01 -0.190164292872E-01 -0.192632691331E-01 -0.195132138419E-01
+ -0.197663024680E-01 -0.200225745570E-01 -0.202820701519E-01 -0.205448297995E-01
+ -0.208108945565E-01 -0.210803059959E-01 -0.213531062140E-01 -0.216293378362E-01
+ -0.219090440244E-01 -0.221922684831E-01 -0.224790554668E-01 -0.227694497865E-01
+ -0.230634968169E-01 -0.233612425035E-01 -0.236627333695E-01 -0.239680165236E-01
+ -0.242771396668E-01 -0.245901511003E-01 -0.249070997328E-01 -0.252280350880E-01
+ -0.255530073127E-01 -0.258820671847E-01 -0.262152661200E-01 -0.265526561817E-01
+ -0.268942900876E-01 -0.272402212188E-01 -0.275905036277E-01 -0.279451920466E-01
+ -0.283043418962E-01 -0.286680092944E-01 -0.290362510651E-01 -0.294091247467E-01
+ -0.297866886014E-01 -0.301690016244E-01 -0.305561235528E-01 -0.309481148751E-01
+ -0.313450368410E-01 -0.317469514700E-01 -0.321539215623E-01 -0.325660107076E-01
+ -0.329832832958E-01 -0.334058045265E-01 -0.338336404195E-01 -0.342668578249E-01
+ -0.347055244339E-01 -0.351497087889E-01 -0.355994802947E-01 -0.360549092289E-01
+ -0.365160667532E-01 -0.369830249244E-01 -0.374558567055E-01 -0.379346359775E-01
+ -0.384194375505E-01 -0.389103371758E-01 -0.394074115574E-01 -0.399107383641E-01
+ -0.404203962417E-01 -0.409364648253E-01 -0.414590247515E-01 -0.419881576714E-01
+ -0.425239462630E-01 -0.430664742442E-01 -0.436158263862E-01 -0.441720885263E-01
+ -0.447353475815E-01 -0.453056915621E-01 -0.458832095855E-01 -0.464679918899E-01
+ -0.470601298487E-01 -0.476597159846E-01 -0.482668439840E-01 -0.488816087119E-01
+ -0.495041062264E-01 -0.501344337940E-01 -0.507726899045E-01 -0.514189742866E-01
+ -0.520733879235E-01 -0.527360330685E-01 -0.534070132612E-01 -0.540864333435E-01
+ -0.547743994761E-01 -0.554710191549E-01 -0.561764012280E-01 -0.568906559128E-01
+ -0.576138948128E-01 -0.583462309355E-01 -0.590877787097E-01 -0.598386540036E-01
+ -0.605989741428E-01 -0.613688579288E-01 -0.621484256572E-01 -0.629377991371E-01
+ -0.637371017093E-01 -0.645464582664E-01 -0.653659952717E-01 -0.661958407795E-01
+ -0.670361244545E-01 -0.678869775926E-01 -0.687485331410E-01 -0.696209257193E-01
+ -0.705042916405E-01 -0.713987689319E-01 -0.723044973572E-01 -0.732216184381E-01
+ -0.741502754762E-01 -0.750906135759E-01 -0.760427796666E-01 -0.770069225258E-01
+ -0.779831928025E-01 -0.789717430406E-01 -0.799727277026E-01 -0.809863031942E-01
+ -0.820126278882E-01 -0.830518621494E-01 -0.841041683600E-01 -0.851697109444E-01
+ -0.862486563955E-01 -0.873411733001E-01 -0.884474323659E-01 -0.895676064474E-01
+ -0.907018705737E-01 -0.918504019753E-01 -0.930133801120E-01 -0.941909867009E-01
+ -0.953834057448E-01 -0.965908235610E-01 -0.978134288102E-01 -0.990514125265E-01
+ -0.100304968146     -0.101574291540     -0.102859581041     -0.104161037477
+ -0.105478864203     -0.106813267131     -0.108164454764     -0.109532638226
+ -0.110918031298     -0.112320850448     -0.113741314871     -0.115179646514
+ -0.116636070119     -0.118110813254     -0.119604106349     -0.121116182733
+ -0.122647278671     -0.124197633396     -0.125767489154     -0.127357091237
+ -0.128966688022     -0.130596531009     -0.132246874863     -0.133917977452
+ -0.135610099888     -0.137323506567     -0.139058465208     -0.140815246902
+ -0.142594126146     -0.144395380893     -0.146219292589     -0.148066146222
+ -0.149936230364     -0.151829837217     -0.153747262658     -0.155688806286
+ -0.157654771469     -0.159645465388     -0.161661199091     -0.163702287538
+ -0.165769049648     -0.167861808355     -0.169980890651     -0.172126627645
+ -0.174299354607     -0.176499411027     -0.178727140664     -0.180982891600
+ -0.183267016296     -0.185579871646     -0.187921819034     -0.190293224387
+ -0.192694458238     -0.195125895779     -0.197587916919     -0.200080906349
+ -0.202605253597     -0.205161353089     -0.207749604215     -0.210370411387
+ -0.213024184103     -0.215711337013     -0.218432289980     -0.221187468151
+ -0.223977302019     -0.226802227490     -0.229662685956     -0.232559124358
+ -0.235491995259     -0.238461756916     -0.241468873347     -0.244513814409
+ -0.247597055865     -0.250719079467     -0.253880373021     -0.257081430471
+ -0.260322751975     -0.263604843978     -0.266928219297     -0.270293397200
+ -0.273700903483     -0.277151270556     -0.280645037528     -0.284182750284
+ -0.287764961578     -0.291392231114     -0.295065125637     -0.298784219019
+ -0.302550092349     -0.306363334026     -0.310224539847     -0.314134313104
+ -0.318093264675     -0.322102013122     -0.326161184785     -0.330271413881
+ -0.334433342606     -0.338647621229     -0.342914908198     -0.347235870243
+ -0.351611182477     -0.356041528504     -0.360527600524     -0.365070099444
+ -0.369669734984     -0.374327225788     -0.379043299539     -0.383818693069
+ -0.388654152479     -0.393550433248     -0.398508300358     -0.403528528409
+ -0.408611901743     -0.413759214562     -0.418971271057     -0.424248885529
+ -0.429592882520     -0.435004096937     -0.440483374186     -0.446031570304
+ -0.451649552089     -0.457338197237     -0.463098394481     -0.468931043726
+ -0.474837056190     -0.480817354549     -0.486872873077     -0.493004557793
+ -0.499213366608     -0.505500269477     -0.511866248545     -0.518312298303
+ -0.524839425745     -0.531448650518     -0.538141005088     -0.544917534897
+ -0.551779298525     -0.558727367857     -0.565762828247     -0.572886778689
+ -0.580100331989     -0.587404614932     -0.594800768465     -0.602289947867
+ -0.609873322934     -0.617552078156     -0.625327412906     -0.633200541620
+ -0.641172693990     -0.649245115153     -0.657419065885     -0.665695822792
+ -0.674076678515     -0.682562941924     -0.691155938322     -0.699857009653
+ -0.708667514704     -0.717588829319     -0.726622346612     -0.735769477178
+ -0.745031649314     -0.754410309238     -0.763906921310     -0.773522968262
+ -0.783259951420     -0.793119390941     -0.803102826041     -0.813211815235
+ -0.823447936574     -0.833812787887     -0.844307987026     -0.854935172112
+ -0.865696001788     -0.876592155469     -0.887625333599     -0.898797257910
+ -0.910109671684     -0.921564340016     -0.933163050083     -0.944907611415
+ -0.956799856166     -0.968841639392     -0.981034839331     -0.993381357684
+  -1.00588311990      -1.01854207547      -1.03136019820      -1.04433948653
+  -1.05748196382      -1.07078967866      -1.08426470513      -1.09790914317
+  -1.11172511885      -1.12571478469      -1.13988031997      -1.15422393106
+  -1.16874785174      -1.18345434350      -1.19834569590      -1.21342422688
+  -1.22869228308      -1.24415224020      -1.25980650333      -1.27565750728
+  -1.29170771692      -1.30795962755      -1.32441576520      -1.34107868704
+  -1.35795098166      -1.37503526949      -1.39233420310      -1.40985046761
+  -1.42758678099      -1.44554589447      -1.46373059287      -1.48214369497
+  -1.50078805387      -1.51966655737      -1.53878212833      -1.55813772500
+  -1.57773634144      -1.59758100783      -1.61767479090      -1.63802079421
+  -1.65862215861      -1.67948206251      -1.70060372230      -1.72199039270
+  -1.74364536709      -1.76557197789      -1.78777359691      -1.81025363568
+  -1.83301554581      -1.85606281934      -1.87939898905      -1.90302762879
+  -1.92695235386      -1.95117682124      -1.97570472999      -2.00053982149
+  -2.02568587979      -2.05114673185      -2.07692624787      -2.10302834152
+  -2.12945697024      -2.15621613547      -2.18330988288      -2.21074230263
+  -2.23851752957      -2.26663974344      -2.29511316905      -2.32394207650
+  -2.35313078130      -2.38268364450      -2.41260507288      -2.44289951902
+  -2.47357148139      -2.50462550444      -2.53606617868      -2.56789814067
+  -2.60012607308      -2.63275470468      -2.66578881031      -2.69923321083
+  -2.73309277309      -2.76737240980      -2.80207707947      -2.83721178622
+  -2.87278157967      -2.90879155475      -2.94524685149      -2.98215265478
+  -3.01951419414      -3.05733674343      -3.09562562054      -3.13438618707
+  -3.17362384794      -3.21334405102      -3.25355228672      -3.29425408751
+  -3.33545502743      -3.37716072160      -3.41937682566      -3.46210903514
+  -3.50536308483      -3.54914474812      -3.59345983625      -3.63831419753
+  -3.68371371647      -3.72966431292      -3.77617194108      -3.82324258842
+  -3.87088227460      -3.91909705025      -3.96789299561      -4.01727621919
+  -4.06725285619      -4.11782906683      -4.16901103463      -4.22080496442
+  -4.27321708024      -4.32625362311      -4.37992084856      -4.43422502397
+  -4.48917242568      -4.54476933594      -4.60102203952      -4.65793682010
+  -4.71551995635      -4.77377771778      -4.83271636013      -4.89234212057
+  -4.95266121242      -5.01367981954      -5.07540409030      -5.13784013111
+  -5.20099399949      -5.26487169668      -5.32947915971      -5.39482225298
+  -5.46090675923      -5.52773836993      -5.59532267508      -5.66366515231
+  -5.73277115532      -5.80264590162      -5.87329445947      -5.94472173405
+  -6.01693245282      -6.08993114996      -6.16372214997      -6.23830955028
+  -6.31369720283      -6.38988869467      -6.46688732745      -6.54469609575
+  -6.62331766423      -6.70275434358      -6.78300806507      -6.86408035388
+  -6.94597230092      -7.02868453322      -7.11221718279      -7.19656985390
+  -7.28174158865      -7.36773083092      -7.45453538844      -7.54215239309
+  -7.63057825922      -7.71980864007      -7.80983838206      -7.90066147707
+  -7.99227101244      -8.08465911882      -8.17781691571      -8.27173445459
+  -8.36640065978      -8.46180326666      -8.55792875756      -8.65476229501
+  -8.75228765244      -8.85048714229      -8.94934154150      -9.04883001437
+  -9.14893003280      -9.24961729393      -9.35086563520      -9.45264694687
+  -9.55493108213      -9.65768576473      -9.76087649443      -9.86446645023
+  -9.96841639165      -10.0726845581      -10.1772265670      -10.2819953096
+  -10.3869408473      -10.4920103055      -10.5971477681      -10.7022941721
+  -10.8073872016      -10.9123611843      -11.0171469881      -11.1216719207
+  -11.2258596318      -11.3296300189      -11.4328991375      -11.5355791163
+  -11.6375780792      -11.7388000738      -11.8391450089      -11.9385086014
+  -12.0367823338      -12.1338534237      -12.2296048077      -12.3239151394
+  -12.4166588048      -12.5077059560      -12.5969225642      -12.6841704959
+  -12.7693076119      -12.8521878922      -12.9326615887      -13.0105754076
+  -13.0857727234      -13.1580938264      -13.2273762062      -13.2934548730
+  -13.3561627179      -13.4153309155      -13.4707893691      -13.5223672013
+  -13.5698932905      -13.6131968552      -13.6521080876      -13.6864588355
+  -13.7160833361      -13.7408189983      -13.7605072371      -13.7749943568
+  -13.7841324837      -13.7877805466      -13.7858053038      -13.7780824137
+  -13.7644975484      -13.7449475446      -13.7193415915      -13.6876024499
+  -13.6496676998      -13.6054910120      -13.5550434385      -13.4983147193
+  -13.4353145986      -13.3660741473      -13.2906470882      -13.2091111179
+  -13.1215692232      -13.0281509881      -12.9290138884      -12.8243445710
+  -12.7143601160      -12.5993092779      -12.4794737046      -12.3551691294
+  -12.2267465307      -12.0945932535      -11.9591340802      -11.8208322361
+  -11.6801903077      -11.5377510427      -11.3940979929      -11.2498559439
+  -11.1056910639      -10.9623106825      -10.8204625885      -10.6809337139
+  -10.5445480383      -10.4121635254      -10.2846678653      -10.1629727724
+  -10.0480065551      -9.94070465445      -9.84199783070      -9.75279767589
+  -9.67397914557      -9.60635984124      -9.55067584657      -9.50755402972
+  -9.47748088362      -9.46076819327      -9.45751610648      -9.46757455119
+  -9.49050440069      -9.52554034579      -9.57155810223      -9.62704936833
+  -9.69010886237      -9.75843881962      -9.82937752775      -9.89995984571
+  -9.96701921665      -10.0273425008      -10.0778911014      -10.1161044580
+  -10.1403052011      -10.1502293343      -10.1477099712      -10.1375496623
+ Up Pseudopotential follows (l on next line)
+  1
+ -0.763256798856E-06 -0.153611418637E-05 -0.231869292308E-05 -0.311111528851E-05
+ -0.391350510025E-05 -0.472598773337E-05 -0.554869013991E-05 -0.638174086880E-05
+ -0.722527008592E-05 -0.807940959442E-05 -0.894429285534E-05 -0.982005500844E-05
+ -0.107068328933E-04 -0.116047650709E-04 -0.125139918448E-04 -0.134346552837E-04
+ -0.143668992430E-04 -0.153108693878E-04 -0.162667132153E-04 -0.172345800780E-04
+ -0.182146212072E-04 -0.192069897363E-04 -0.202118407248E-04 -0.212293311827E-04
+ -0.222596200951E-04 -0.233028684466E-04 -0.243592392470E-04 -0.254288975563E-04
+ -0.265120105108E-04 -0.276087473491E-04 -0.287192794386E-04 -0.298437803021E-04
+ -0.309824256453E-04 -0.321353933838E-04 -0.333028636710E-04 -0.344850189267E-04
+ -0.356820438651E-04 -0.368941255235E-04 -0.381214532924E-04 -0.393642189442E-04
+ -0.406226166635E-04 -0.418968430775E-04 -0.431870972867E-04 -0.444935808959E-04
+ -0.458164980460E-04 -0.471560554452E-04 -0.485124624024E-04 -0.498859308587E-04
+ -0.512766754214E-04 -0.526849133972E-04 -0.541108648261E-04 -0.555547525160E-04
+ -0.570168020773E-04 -0.584972419581E-04 -0.599963034801E-04 -0.615142208749E-04
+ -0.630512313201E-04 -0.646075749767E-04 -0.661834950266E-04 -0.677792377104E-04
+ -0.693950523663E-04 -0.710311914685E-04 -0.726879106671E-04 -0.743654688279E-04
+ -0.760641280727E-04 -0.777841538205E-04 -0.795258148288E-04 -0.812893832357E-04
+ -0.830751346023E-04 -0.848833479560E-04 -0.867143058338E-04 -0.885682943264E-04
+ -0.904456031235E-04 -0.923465255583E-04 -0.942713586538E-04 -0.962204031692E-04
+ -0.981939636465E-04 -0.100192348459E-03 -0.102215869857E-03 -0.104264844022E-03
+ -0.106339591109E-03 -0.108440435301E-03 -0.110567704861E-03 -0.112721732177E-03
+ -0.114902853822E-03 -0.117111410599E-03 -0.119347747601E-03 -0.121612214260E-03
+ -0.123905164402E-03 -0.126226956307E-03 -0.128577952759E-03 -0.130958521106E-03
+ -0.133369033316E-03 -0.135809866038E-03 -0.138281400655E-03 -0.140784023351E-03
+ -0.143318125166E-03 -0.145884102057E-03 -0.148482354964E-03 -0.151113289869E-03
+ -0.153777317862E-03 -0.156474855201E-03 -0.159206323384E-03 -0.161972149206E-03
+ -0.164772764835E-03 -0.167608607871E-03 -0.170480121422E-03 -0.173387754167E-03
+ -0.176331960429E-03 -0.179313200248E-03 -0.182331939446E-03 -0.185388649710E-03
+ -0.188483808655E-03 -0.191617899907E-03 -0.194791413175E-03 -0.198004844325E-03
+ -0.201258695463E-03 -0.204553475009E-03 -0.207889697781E-03 -0.211267885069E-03
+ -0.214688564723E-03 -0.218152271229E-03 -0.221659545800E-03 -0.225210936454E-03
+ -0.228806998104E-03 -0.232448292641E-03 -0.236135389024E-03 -0.239868863371E-03
+ -0.243649299044E-03 -0.247477286743E-03 -0.251353424601E-03 -0.255278318271E-03
+ -0.259252581025E-03 -0.263276833851E-03 -0.267351705547E-03 -0.271477832818E-03
+ -0.275655860381E-03 -0.279886441062E-03 -0.284170235897E-03 -0.288507914237E-03
+ -0.292900153854E-03 -0.297347641044E-03 -0.301851070737E-03 -0.306411146602E-03
+ -0.311028581159E-03 -0.315704095894E-03 -0.320438421364E-03 -0.325232297318E-03
+ -0.330086472808E-03 -0.335001706310E-03 -0.339978765837E-03 -0.345018429067E-03
+ -0.350121483457E-03 -0.355288726368E-03 -0.360520965195E-03 -0.365819017484E-03
+ -0.371183711067E-03 -0.376615884188E-03 -0.382116385635E-03 -0.387686074874E-03
+ -0.393325822178E-03 -0.399036508771E-03 -0.404819026959E-03 -0.410674280271E-03
+ -0.416603183603E-03 -0.422606663359E-03 -0.428685657593E-03 -0.434841116162E-03
+ -0.441074000869E-03 -0.447385285613E-03 -0.453775956547E-03 -0.460247012226E-03
+ -0.466799463765E-03 -0.473434334998E-03 -0.480152662637E-03 -0.486955496435E-03
+ -0.493843899348E-03 -0.500818947704E-03 -0.507881731367E-03 -0.515033353912E-03
+ -0.522274932795E-03 -0.529607599527E-03 -0.537032499852E-03 -0.544550793926E-03
+ -0.552163656497E-03 -0.559872277092E-03 -0.567677860197E-03 -0.575581625451E-03
+ -0.583584807834E-03 -0.591688657858E-03 -0.599894441766E-03 -0.608203441731E-03
+ -0.616616956048E-03 -0.625136299348E-03 -0.633762802794E-03 -0.642497814296E-03
+ -0.651342698717E-03 -0.660298838088E-03 -0.669367631824E-03 -0.678550496943E-03
+ -0.687848868285E-03 -0.697264198741E-03 -0.706797959475E-03 -0.716451640156E-03
+ -0.726226749192E-03 -0.736124813963E-03 -0.746147381062E-03 -0.756296016536E-03
+ -0.766572306129E-03 -0.776977855533E-03 -0.787514290636E-03 -0.798183257777E-03
+ -0.808986424004E-03 -0.819925477335E-03 -0.831002127017E-03 -0.842218103801E-03
+ -0.853575160205E-03 -0.865075070793E-03 -0.876719632448E-03 -0.888510664659E-03
+ -0.900450009796E-03 -0.912539533408E-03 -0.924781124507E-03 -0.937176695866E-03
+ -0.949728184319E-03 -0.962437551061E-03 -0.975306781957E-03 -0.988337887850E-03
+ -0.100153290488E-02 -0.101489389479E-02 -0.102842294526E-02 -0.104212217024E-02
+ -0.105599371025E-02 -0.107003973277E-02 -0.108426243249E-02 -0.109866403175E-02
+ -0.111324678083E-02 -0.112801295832E-02 -0.114296487145E-02 -0.115810485650E-02
+ -0.117343527911E-02 -0.118895853471E-02 -0.120467704882E-02 -0.122059327750E-02
+ -0.123670970769E-02 -0.125302885762E-02 -0.126955327718E-02 -0.128628554835E-02
+ -0.130322828559E-02 -0.132038413622E-02 -0.133775578090E-02 -0.135534593396E-02
+ -0.137315734391E-02 -0.139119279381E-02 -0.140945510175E-02 -0.142794712125E-02
+ -0.144667174171E-02 -0.146563188891E-02 -0.148483052540E-02 -0.150427065101E-02
+ -0.152395530330E-02 -0.154388755803E-02 -0.156407052966E-02 -0.158450737182E-02
+ -0.160520127781E-02 -0.162615548110E-02 -0.164737325581E-02 -0.166885791728E-02
+ -0.169061282252E-02 -0.171264137078E-02 -0.173494700407E-02 -0.175753320768E-02
+ -0.178040351077E-02 -0.180356148685E-02 -0.182701075441E-02 -0.185075497745E-02
+ -0.187479786604E-02 -0.189914317695E-02 -0.192379471417E-02 -0.194875632955E-02
+ -0.197403192341E-02 -0.199962544509E-02 -0.202554089365E-02 -0.205178231843E-02
+ -0.207835381969E-02 -0.210525954929E-02 -0.213250371131E-02 -0.216009056271E-02
+ -0.218802441397E-02 -0.221630962983E-02 -0.224495062991E-02 -0.227395188941E-02
+ -0.230331793986E-02 -0.233305336975E-02 -0.236316282530E-02 -0.239365101118E-02
+ -0.242452269123E-02 -0.245578268921E-02 -0.248743588956E-02 -0.251948723815E-02
+ -0.255194174308E-02 -0.258480447543E-02 -0.261808057007E-02 -0.265177522644E-02
+ -0.268589370943E-02 -0.272044135009E-02 -0.275542354658E-02 -0.279084576493E-02
+ -0.282671353994E-02 -0.286303247602E-02 -0.289980824808E-02 -0.293704660241E-02
+ -0.297475335756E-02 -0.301293440532E-02 -0.305159571153E-02 -0.309074331710E-02
+ -0.313038333894E-02 -0.317052197087E-02 -0.321116548464E-02 -0.325232023087E-02
+ -0.329399264009E-02 -0.333618922369E-02 -0.337891657497E-02 -0.342218137016E-02
+ -0.346599036949E-02 -0.351035041819E-02 -0.355526844761E-02 -0.360075147629E-02
+ -0.364680661104E-02 -0.369344104807E-02 -0.374066207411E-02 -0.378847706754E-02
+ -0.383689349954E-02 -0.388591893529E-02 -0.393556103511E-02 -0.398582755567E-02
+ -0.403672635122E-02 -0.408826537481E-02 -0.414045267951E-02 -0.419329641969E-02
+ -0.424680485230E-02 -0.430098633813E-02 -0.435584934316E-02 -0.441140243983E-02
+ -0.446765430844E-02 -0.452461373846E-02 -0.458228962990E-02 -0.464069099475E-02
+ -0.469982695833E-02 -0.475970676077E-02 -0.482033975840E-02 -0.488173542526E-02
+ -0.494390335453E-02 -0.500685326009E-02 -0.507059497798E-02 -0.513513846799E-02
+ -0.520049381515E-02 -0.526667123138E-02 -0.533368105704E-02 -0.540153376253E-02
+ -0.547023995000E-02 -0.553981035491E-02 -0.561025584779E-02 -0.568158743589E-02
+ -0.575381626491E-02 -0.582695362076E-02 -0.590101093129E-02 -0.597599976811E-02
+ -0.605193184838E-02 -0.612881903664E-02 -0.620667334667E-02 -0.628550694337E-02
+ -0.636533214464E-02 -0.644616142333E-02 -0.652800740919E-02 -0.661088289082E-02
+ -0.669480081767E-02 -0.677977430210E-02 -0.686581662138E-02 -0.695294121980E-02
+ -0.704116171075E-02 -0.713049187888E-02 -0.722094568220E-02 -0.731253725429E-02
+ -0.740528090653E-02 -0.749919113030E-02 -0.759428259927E-02 -0.769057017167E-02
+ -0.778806889263E-02 -0.788679399652E-02 -0.798676090934E-02 -0.808798525113E-02
+ -0.819048283839E-02 -0.829426968658E-02 -0.839936201260E-02 -0.850577623735E-02
+ -0.861352898826E-02 -0.872263710192E-02 -0.883311762669E-02 -0.894498782538E-02
+ -0.905826517793E-02 -0.917296738417E-02 -0.928911236654E-02 -0.940671827293E-02
+ -0.952580347951E-02 -0.964638659357E-02 -0.976848645648E-02 -0.989212214659E-02
+ -0.100173129822E-01 -0.101440785247E-01 -0.102724385814E-01 -0.104024132088E-01
+ -0.105340227158E-01 -0.106672876665E-01 -0.108022288840E-01 -0.109388674530E-01
+ -0.110772247236E-01 -0.112173223144E-01 -0.113591821159E-01 -0.115028262940E-01
+ -0.116482772935E-01 -0.117955578412E-01 -0.119446909502E-01 -0.120956999227E-01
+ -0.122486083542E-01 -0.124034401370E-01 -0.125602194638E-01 -0.127189708317E-01
+ -0.128797190459E-01 -0.130424892238E-01 -0.132073067984E-01 -0.133741975228E-01
+ -0.135431874740E-01 -0.137143030570E-01 -0.138875710091E-01 -0.140630184036E-01
+ -0.142406726546E-01 -0.144205615209E-01 -0.146027131105E-01 -0.147871558850E-01
+ -0.149739186638E-01 -0.151630306291E-01 -0.153545213300E-01 -0.155484206873E-01
+ -0.157447589981E-01 -0.159435669406E-01 -0.161448755792E-01 -0.163487163685E-01
+ -0.165551211591E-01 -0.167641222022E-01 -0.169757521546E-01 -0.171900440839E-01
+ -0.174070314736E-01 -0.176267482285E-01 -0.178492286797E-01 -0.180745075902E-01
+ -0.183026201603E-01 -0.185336020329E-01 -0.187674892996E-01 -0.190043185056E-01
+ -0.192441266559E-01 -0.194869512211E-01 -0.197328301428E-01 -0.199818018403E-01
+ -0.202339052157E-01 -0.204891796607E-01 -0.207476650624E-01 -0.210094018097E-01
+ -0.212744307993E-01 -0.215427934427E-01 -0.218145316719E-01 -0.220896879465E-01
+ -0.223683052603E-01 -0.226504271476E-01 -0.229360976906E-01 -0.232253615257E-01
+ -0.235182638510E-01 -0.238148504329E-01 -0.241151676137E-01 -0.244192623185E-01
+ -0.247271820625E-01 -0.250389749587E-01 -0.253546897254E-01 -0.256743756935E-01
+ -0.259980828144E-01 -0.263258616680E-01 -0.266577634702E-01 -0.269938400812E-01
+ -0.273341440135E-01 -0.276787284401E-01 -0.280276472029E-01 -0.283809548210E-01
+ -0.287387064992E-01 -0.291009581367E-01 -0.294677663359E-01 -0.298391884111E-01
+ -0.302152823974E-01 -0.305961070602E-01 -0.309817219036E-01 -0.313721871806E-01
+ -0.317675639018E-01 -0.321679138453E-01 -0.325732995663E-01 -0.329837844066E-01
+ -0.333994325050E-01 -0.338203088069E-01 -0.342464790746E-01 -0.346780098977E-01
+ -0.351149687031E-01 -0.355574237661E-01 -0.360054442204E-01 -0.364591000697E-01
+ -0.369184621979E-01 -0.373836023805E-01 -0.378545932959E-01 -0.383315085366E-01
+ -0.388144226207E-01 -0.393034110035E-01 -0.397985500897E-01 -0.402999172445E-01
+ -0.408075908066E-01 -0.413216500998E-01 -0.418421754457E-01 -0.423692481760E-01
+ -0.429029506457E-01 -0.434433662451E-01 -0.439905794139E-01 -0.445446756534E-01
+ -0.451057415405E-01 -0.456738647410E-01 -0.462491340232E-01 -0.468316392719E-01
+ -0.474214715024E-01 -0.480187228748E-01 -0.486234867081E-01 -0.492358574951E-01
+ -0.498559309170E-01 -0.504838038583E-01 -0.511195744221E-01 -0.517633419452E-01
+ -0.524152070138E-01 -0.530752714790E-01 -0.537436384729E-01 -0.544204124245E-01
+ -0.551056990762E-01 -0.557996055002E-01 -0.565022401153E-01 -0.572137127035E-01
+ -0.579341344275E-01 -0.586636178480E-01 -0.594022769411E-01 -0.601502271161E-01
+ -0.609075852336E-01 -0.616744696237E-01 -0.624510001044E-01 -0.632372980005E-01
+ -0.640334861621E-01 -0.648396889840E-01 -0.656560324254E-01 -0.664826440289E-01
+ -0.673196529409E-01 -0.681671899315E-01 -0.690253874148E-01 -0.698943794698E-01
+ -0.707743018610E-01 -0.716652920599E-01 -0.725674892658E-01 -0.734810344282E-01
+ -0.744060702684E-01 -0.753427413014E-01 -0.762911938591E-01 -0.772515761124E-01
+ -0.782240380946E-01 -0.792087317246E-01 -0.802058108308E-01 -0.812154311745E-01
+ -0.822377504746E-01 -0.832729284316E-01 -0.843211267532E-01 -0.853825091783E-01
+ -0.864572415034E-01 -0.875454916079E-01 -0.886474294800E-01 -0.897632272435E-01
+ -0.908930591838E-01 -0.920371017757E-01 -0.931955337101E-01 -0.943685359220E-01
+ -0.955562916183E-01 -0.967589863061E-01 -0.979768078218E-01 -0.992099463593E-01
+ -0.100458594500     -0.101722947243     -0.103003202033     -0.104299558794
+ -0.105612219957     -0.106941390493     -0.108287277943     -0.109650092452
+ -0.111030046800     -0.112427356433     -0.113842239500     -0.115274916882
+ -0.116725612229     -0.118194551993     -0.119681965460     -0.121188084791
+ -0.122713145050     -0.124257384246     -0.125821043366     -0.127404366409
+ -0.129007600430     -0.130630995570     -0.132274805096     -0.133939285443
+ -0.135624696247     -0.137331300385     -0.139059364017     -0.140809156624
+ -0.142580951046     -0.144375023526     -0.146191653749     -0.148031124882
+ -0.149893723619     -0.151779740219     -0.153689468551     -0.155623206137
+ -0.157581254193     -0.159563917674     -0.161571505316     -0.163604329683
+ -0.165662707209     -0.167746958245     -0.169857407101     -0.171994382095
+ -0.174158215597     -0.176349244072     -0.178567808133     -0.180814252582
+ -0.183088926459     -0.185392183087     -0.187724380121     -0.190085879597
+ -0.192477047973     -0.194898256184     -0.197349879685     -0.199832298498
+ -0.202345897266     -0.204891065291     -0.207468196589     -0.210077689936
+ -0.212719948912     -0.215395381952     -0.218104402389     -0.220847428506
+ -0.223624883576     -0.226437195911     -0.229284798907     -0.232168131088
+ -0.235087636149     -0.238043763003     -0.241036965816     -0.244067704057
+ -0.247136442531     -0.250243651423     -0.253389806334     -0.256575388317
+ -0.259800883912     -0.263066785180     -0.266373589735     -0.269721800771
+ -0.273111927091     -0.276544483131     -0.280019988985     -0.283538970418
+ -0.287101958890     -0.290709491565     -0.294362111320     -0.298060366754
+ -0.301804812188     -0.305596007662     -0.309434518931     -0.313320917447
+ -0.317255780348     -0.321239690429     -0.325273236117     -0.329357011430
+ -0.333491615938     -0.337677654709     -0.341915738251     -0.346206482442
+ -0.350550508458     -0.354948442679     -0.359400916595     -0.363908566697
+ -0.368472034354     -0.373091965680     -0.377769011386     -0.382503826616
+ -0.387297070770     -0.392149407311     -0.397061503549     -0.402034030412
+ -0.407067662193     -0.412163076280     -0.417320952858     -0.422541974592
+ -0.427826826281     -0.433176194485     -0.438590767128     -0.444071233060
+ -0.449618281600     -0.455232602034     -0.460914883080     -0.466665812313
+ -0.472486075556     -0.478376356212     -0.484337334567     -0.490369687034
+ -0.496474085345     -0.502651195692     -0.508901677809     -0.515226183990
+ -0.521625358045     -0.528099834185     -0.534650235833     -0.541277174362
+ -0.547981247749     -0.554763039142     -0.561623115337     -0.568562025162
+ -0.575580297754     -0.582678440735     -0.589856938269     -0.597116249010
+ -0.604456803909     -0.611879003908     -0.619383217478     -0.626969778021
+ -0.634638981116     -0.642391081597     -0.650226290470     -0.658144771640
+ -0.666146638461     -0.674231950081     -0.682400707576     -0.690652849878
+ -0.698988249464     -0.707406707811     -0.715907950597     -0.724491622641
+ -0.733157282572     -0.741904397206     -0.750732335623     -0.759640362939
+ -0.768627633740     -0.777693185185     -0.786835929751     -0.796054647609
+ -0.805347978620     -0.814714413928     -0.824152287143     -0.833659765099
+ -0.843234838161     -0.852875310083     -0.862578787389     -0.872342668263
+ -0.882164130943     -0.892040121595     -0.901967341659     -0.911942234652
+ -0.921960972414     -0.932019440788     -0.942113224731     -0.952237592826
+ -0.962387481214     -0.972557476921     -0.982741800582     -0.992934288563
+  -1.00312837448      -1.01331707013      -1.02349294579      -1.03364810997
+  -1.04377418863      -1.05386230372      -1.06390305135      -1.07388647936
+  -1.08380206444      -1.09363868881      -1.10338461661      -1.11302746981
+  -1.12255420397      -1.13195108375      -1.14120365830      -1.15029673664
+  -1.15921436304      -1.16793979262      -1.17645546723      -1.18474299173
+  -1.19278311078      -1.20055568645      -1.20803967661      -1.21521311441
+  -1.22205308905      -1.22853572797      -1.23463618079      -1.24032860511
+  -1.24558615460      -1.25038096950      -1.25468416988      -1.25846585202
+  -1.26169508808      -1.26433992958      -1.26636741492      -1.26774358131
+  -1.26843348155      -1.26840120599      -1.26760991006      -1.26602184787
+  -1.26359841220      -1.26030018130      -1.25608697305      -1.25091790672
+  -1.24475147300      -1.23754561245      -1.22925780312      -1.21984515751
+  -1.20926452942      -1.19747263118      -1.18442616155      -1.17008194487
+  -1.15439708179      -1.13732911217      -1.11883619050      -1.09887727443
+  -1.07741232700      -1.05440253303      -1.02981053057      -1.00360065795
+ -0.975739217598     -0.946194757350     -0.914938370779     -0.881944017731
+ -0.847188866863     -0.810653662072     -0.772323115103     -0.732186326939
+ -0.690237240994     -0.646475131527     -0.600905131141     -0.553538801678
+ -0.504394753257     -0.453499316578     -0.400887273978     -0.346602654929
+ -0.290699601732     -0.233243311029     -0.174311056289     -0.113993295644
+ -0.523948681226E-01  0.103637205346E-01  0.741449238756E-01  0.138792697445
+  0.204130967522      0.269962040870      0.336064977426      0.402193956314
+  0.468076675619      0.533412838169      0.597872789114      0.661096386477
+  0.722692202838      0.782237174803      0.839276836407      0.893326292548
+  0.943872108168      0.990375306944       1.03227568834       1.06899768214
+   1.09995796282       1.12457503932       1.14228101645       1.15253568782
+   1.15484306395       1.14877035793       1.13396934113       1.11019983903
+   1.07735495786       1.03548741509      0.984836088392      0.925851600088
+  0.859219419381      0.785878599023      0.707033874253      0.624158450744
+  0.538984406687      0.453477243071      0.369790742670      0.290197939507
+  0.216993637925      0.152363509568      0.982142587551E-01  0.559585594325E-01
+  0.262472616592E-01  0.863953882960E-02  0.119899986701E-02  0.223213078243E-06
+   0.00000000000       0.00000000000       0.00000000000       0.00000000000
+  2
+  0.715068399059E-07  0.143913125132E-06  0.217230169309E-06  0.291469428372E-06
+  0.366642502359E-06  0.442761137213E-06  0.519837226628E-06  0.597882813898E-06
+  0.676910093805E-06  0.756931414524E-06  0.837959279546E-06  0.920006349643E-06
+  0.100308544484E-05  0.108720954640E-05  0.117239179890E-05  0.125864551223E-05
+  0.134598416372E-05  0.143442140021E-05  0.152397104018E-05  0.161464707597E-05
+  0.170646367587E-05  0.179943518643E-05  0.189357613463E-05  0.198890123019E-05
+  0.208542536783E-05  0.218316362967E-05  0.228213128750E-05  0.238234380521E-05
+  0.248381684123E-05  0.258656625091E-05  0.269060808906E-05  0.279595861243E-05
+  0.290263428225E-05  0.301065176681E-05  0.312002794407E-05  0.323077990428E-05
+  0.334292495265E-05  0.345648061208E-05  0.357146462586E-05  0.368789496049E-05
+  0.380578980845E-05  0.392516759103E-05  0.404604696127E-05  0.416844680681E-05
+  0.429238625287E-05  0.441788466525E-05  0.454496165334E-05  0.467363707315E-05
+  0.480393103050E-05  0.493586388408E-05  0.506945624866E-05  0.520472899833E-05
+  0.534170326972E-05  0.548040046535E-05  0.562084225693E-05  0.576305058879E-05
+  0.590704768125E-05  0.605285603416E-05  0.620049843038E-05  0.634999793932E-05
+  0.650137792058E-05  0.665466202761E-05  0.680987421135E-05  0.696703872402E-05
+  0.712618012290E-05  0.728732327415E-05  0.745049335672E-05  0.761571586627E-05
+  0.778301661915E-05  0.795242175644E-05  0.812395774804E-05  0.829765139679E-05
+  0.847352984270E-05  0.865162056710E-05  0.883195139706E-05  0.901455050963E-05
+  0.919944643628E-05  0.938666806738E-05  0.957624465670E-05  0.976820582597E-05
+  0.996258156949E-05  0.101594022589E-04  0.103586986478E-04  0.105605018767E-04
+  0.107648434777E-04  0.109717553796E-04  0.111812699129E-04  0.113934198145E-04
+  0.116082382335E-04  0.118257587355E-04  0.120460153085E-04  0.122690423683E-04
+  0.124948747630E-04  0.127235477797E-04  0.129550971487E-04  0.131895590503E-04
+  0.134269701196E-04  0.136673674525E-04  0.139107886116E-04  0.141572716319E-04
+  0.144068550270E-04  0.146595777947E-04  0.149154794235E-04  0.151745998986E-04
+  0.154369797080E-04  0.157026598491E-04  0.159716818349E-04  0.162440877008E-04
+  0.165199200107E-04  0.167992218639E-04  0.170820369019E-04  0.173684093152E-04
+  0.176583838501E-04  0.179520058155E-04  0.182493210906E-04  0.185503761315E-04
+  0.188552179787E-04  0.191638942642E-04  0.194764532194E-04  0.197929436823E-04
+  0.201134151052E-04  0.204379175623E-04  0.207665017579E-04  0.210992190338E-04
+  0.214361213779E-04  0.217772614318E-04  0.221226924993E-04  0.224724685547E-04
+  0.228266442514E-04  0.231852749298E-04  0.235484166269E-04  0.239161260842E-04
+  0.242884607571E-04  0.246654788236E-04  0.250472391936E-04  0.254338015179E-04
+  0.258252261977E-04  0.262215743939E-04  0.266229080366E-04  0.270292898352E-04
+  0.274407832874E-04  0.278574526902E-04  0.282793631488E-04  0.287065805876E-04
+  0.291391717604E-04  0.295772042602E-04  0.300207465306E-04  0.304698678759E-04
+  0.309246384724E-04  0.313851293787E-04  0.318514125476E-04  0.323235608368E-04
+  0.328016480203E-04  0.332857488003E-04  0.337759388184E-04  0.342722946680E-04
+  0.347748939056E-04  0.352838150633E-04  0.357991376612E-04  0.363209422193E-04
+  0.368493102709E-04  0.373843243743E-04  0.379260681268E-04  0.384746261767E-04
+  0.390300842375E-04  0.395925291006E-04  0.401620486492E-04  0.407387318718E-04
+  0.413226688764E-04  0.419139509043E-04  0.425126703445E-04  0.431189207482E-04
+  0.437327968433E-04  0.443543945490E-04  0.449838109913E-04  0.456211445179E-04
+  0.462664947134E-04  0.469199624150E-04  0.475816497284E-04  0.482516600437E-04
+  0.489300980512E-04  0.496170697583E-04  0.503126825057E-04  0.510170449844E-04
+  0.517302672524E-04  0.524524607522E-04  0.531837383278E-04  0.539242142430E-04
+  0.546740041987E-04  0.554332253509E-04  0.562019963296E-04  0.569804372569E-04
+  0.577686697655E-04  0.585668170187E-04  0.593750037283E-04  0.601933561754E-04
+  0.610220022290E-04  0.618610713669E-04  0.627106946952E-04  0.635710049694E-04
+  0.644421366147E-04  0.653242257472E-04  0.662174101951E-04  0.671218295203E-04
+  0.680376250401E-04  0.689649398495E-04  0.699039188433E-04  0.708547087389E-04
+  0.718174580991E-04  0.727923173555E-04  0.737794388318E-04  0.747789767677E-04
+  0.757910873431E-04  0.768159287024E-04  0.778536609791E-04  0.789044463209E-04
+  0.799684489152E-04  0.810458350146E-04  0.821367729627E-04  0.832414332211E-04
+  0.843599883949E-04  0.854926132608E-04  0.866394847937E-04  0.878007821946E-04
+  0.889766869185E-04  0.901673827031E-04  0.913730555969E-04  0.925938939887E-04
+  0.938300886371E-04  0.950818327000E-04  0.963493217649E-04  0.976327538797E-04
+  0.989323295830E-04  0.100248251936E-03  0.101580726555E-03  0.102929961642E-03
+  0.104296168016E-03  0.105679559151E-03  0.107080351205E-03  0.108498763053E-03
+  0.109935016327E-03  0.111389335442E-03  0.112861947640E-03  0.114353083019E-03
+  0.115862974572E-03  0.117391858223E-03  0.118939972863E-03  0.120507560388E-03
+  0.122094865736E-03  0.123702136928E-03  0.125329625103E-03  0.126977584559E-03
+  0.128646272793E-03  0.130335950541E-03  0.132046881818E-03  0.133779333963E-03
+  0.135533577672E-03  0.137309887051E-03  0.139108539651E-03  0.140929816516E-03
+  0.142774002223E-03  0.144641384931E-03  0.146532256422E-03  0.148446912149E-03
+  0.150385651279E-03  0.152348776746E-03  0.154336595292E-03  0.156349417517E-03
+  0.158387557928E-03  0.160451334990E-03  0.162541071172E-03  0.164657092999E-03
+  0.166799731104E-03  0.168969320278E-03  0.171166199525E-03  0.173390712111E-03
+  0.175643205621E-03  0.177924032011E-03  0.180233547666E-03  0.182572113451E-03
+  0.184940094773E-03  0.187337861632E-03  0.189765788687E-03  0.192224255304E-03
+  0.194713645624E-03  0.197234348619E-03  0.199786758156E-03  0.202371273051E-03
+  0.204988297143E-03  0.207638239344E-03  0.210321513716E-03  0.213038539524E-03
+  0.215789741310E-03  0.218575548954E-03  0.221396397744E-03  0.224252728444E-03
+  0.227144987362E-03  0.230073626418E-03  0.233039103218E-03  0.236041881125E-03
+  0.239082429328E-03  0.242161222920E-03  0.245278742967E-03  0.248435476589E-03
+  0.251631917032E-03  0.254868563747E-03  0.258145922465E-03  0.261464505281E-03
+  0.264824830730E-03  0.268227423870E-03  0.271672816363E-03  0.275161546558E-03
+  0.278694159577E-03  0.282271207398E-03  0.285893248941E-03  0.289560850159E-03
+  0.293274584120E-03  0.297035031104E-03  0.300842778689E-03  0.304698421842E-03
+  0.308602563015E-03  0.312555812239E-03  0.316558787217E-03  0.320612113422E-03
+  0.324716424193E-03  0.328872360839E-03  0.333080572733E-03  0.337341717416E-03
+  0.341656460701E-03  0.346025476775E-03  0.350449448306E-03  0.354929066549E-03
+  0.359465031452E-03  0.364058051771E-03  0.368708845173E-03  0.373418138354E-03
+  0.378186667151E-03  0.383015176657E-03  0.387904421335E-03  0.392855165141E-03
+  0.397868181637E-03  0.402944254119E-03  0.408084175733E-03  0.413288749601E-03
+  0.418558788950E-03  0.423895117233E-03  0.429298568262E-03  0.434769986339E-03
+  0.440310226383E-03  0.445920154067E-03  0.451600645956E-03  0.457352589635E-03
+  0.463176883860E-03  0.469074438688E-03  0.475046175623E-03  0.481093027761E-03
+  0.487215939936E-03  0.493415868865E-03  0.499693783300E-03  0.506050664177E-03
+  0.512487504772E-03  0.519005310854E-03  0.525605100844E-03  0.532287905973E-03
+  0.539054770442E-03  0.545906751588E-03  0.552844920046E-03  0.559870359920E-03
+  0.566984168949E-03  0.574187458680E-03  0.581481354642E-03  0.588866996520E-03
+  0.596345538337E-03  0.603918148629E-03  0.611586010632E-03  0.619350322466E-03
+  0.627212297320E-03  0.635173163643E-03  0.643234165338E-03  0.651396561951E-03
+  0.659661628874E-03  0.668030657541E-03  0.676504955629E-03  0.685085847264E-03
+  0.693774673228E-03  0.702572791169E-03  0.711481575809E-03  0.720502419165E-03
+  0.729636730761E-03  0.738885937852E-03  0.748251485646E-03  0.757734837529E-03
+  0.767337475293E-03  0.777060899370E-03  0.786906629065E-03  0.796876202793E-03
+  0.806971178320E-03  0.817193133006E-03  0.827543664054E-03  0.838024388754E-03
+  0.848636944740E-03  0.859382990247E-03  0.870264204365E-03  0.881282287306E-03
+  0.892438960669E-03  0.903735967704E-03  0.915175073595E-03  0.926758065722E-03
+  0.938486753953E-03  0.950362970919E-03  0.962388572302E-03  0.974565437127E-03
+  0.986895468055E-03  0.999380591676E-03  0.101202275882E-02  0.102482394484E-02
+  0.103778614996E-02  0.105091139955E-02  0.106420174445E-02  0.107765926130E-02
+  0.109128605288E-02  0.110508424839E-02  0.111905600383E-02  0.113320350231E-02
+  0.114752895441E-02  0.116203459851E-02  0.117672270115E-02  0.119159555737E-02
+  0.120665549108E-02  0.122190485544E-02  0.123734603318E-02  0.125298143701E-02
+  0.126881351001E-02  0.128484472596E-02  0.130107758978E-02  0.131751463788E-02
+  0.133415843858E-02  0.135101159251E-02  0.136807673301E-02  0.138535652654E-02
+  0.140285367310E-02  0.142057090667E-02  0.143851099557E-02  0.145667674301E-02
+  0.147507098740E-02  0.149369660288E-02  0.151255649975E-02  0.153165362489E-02
+  0.155099096228E-02  0.157057153341E-02  0.159039839777E-02  0.161047465337E-02
+  0.163080343714E-02  0.165138792551E-02  0.167223133484E-02  0.169333692194E-02
+  0.171470798462E-02  0.173634786213E-02  0.175825993576E-02  0.178044762930E-02
+  0.180291440962E-02  0.182566378721E-02  0.184869931668E-02  0.187202459740E-02
+  0.189564327396E-02  0.191955903685E-02  0.194377562293E-02  0.196829681610E-02
+  0.199312644783E-02  0.201826839781E-02  0.204372659450E-02  0.206950501579E-02
+  0.209560768961E-02  0.212203869454E-02  0.214880216049E-02  0.217590226927E-02
+  0.220334325534E-02  0.223112940640E-02  0.225926506406E-02  0.228775462459E-02
+  0.231660253951E-02  0.234581331637E-02  0.237539151939E-02  0.240534177021E-02
+  0.243566874861E-02  0.246637719323E-02  0.249747190229E-02  0.252895773440E-02
+  0.256083960927E-02  0.259312250847E-02  0.262581147627E-02  0.265891162035E-02
+  0.269242811265E-02  0.272636619017E-02  0.276073115578E-02  0.279552837904E-02
+  0.283076329705E-02  0.286644141532E-02  0.290256830859E-02  0.293914962171E-02
+  0.297619107056E-02  0.301369844288E-02  0.305167759925E-02  0.309013447394E-02
+  0.312907507585E-02  0.316850548948E-02  0.320843187586E-02  0.324886047350E-02
+  0.328979759938E-02  0.333124964996E-02  0.337322310211E-02  0.341572451420E-02
+  0.345876052708E-02  0.350233786512E-02  0.354646333727E-02  0.359114383812E-02
+  0.363638634899E-02  0.368219793900E-02  0.372858576617E-02  0.377555707857E-02
+  0.382311921542E-02  0.387127960826E-02  0.392004578208E-02  0.396942535654E-02
+  0.401942604711E-02  0.407005566631E-02  0.412132212492E-02  0.417323343322E-02
+  0.422579770222E-02  0.427902314494E-02  0.433291807773E-02  0.438749092148E-02
+  0.444275020303E-02  0.449870455644E-02  0.455536272434E-02  0.461273355935E-02
+  0.467082602540E-02  0.472964919914E-02  0.478921227139E-02  0.484952454854E-02
+  0.491059545402E-02  0.497243452978E-02  0.503505143773E-02  0.509845596132E-02
+  0.516265800701E-02  0.522766760582E-02  0.529349491495E-02  0.536015021927E-02
+  0.542764393303E-02  0.549598660140E-02  0.556518890215E-02  0.563526164732E-02
+  0.570621578488E-02  0.577806240047E-02  0.585081271910E-02  0.592447810693E-02
+  0.599907007299E-02  0.607460027102E-02  0.615108050129E-02  0.622852271237E-02
+  0.630693900309E-02  0.638634162434E-02  0.646674298102E-02  0.654815563397E-02
+  0.663059230189E-02  0.671406586337E-02  0.679858935886E-02  0.688417599269E-02
+  0.697083913516E-02  0.705859232458E-02  0.714744926941E-02  0.723742385034E-02
+  0.732853012250E-02  0.742078231763E-02  0.751419484622E-02  0.760878229987E-02
+  0.770455945344E-02  0.780154126740E-02  0.789974289015E-02  0.799917966033E-02
+  0.809986710921E-02  0.820182096313E-02  0.830505714588E-02  0.840959178120E-02
+  0.851544119523E-02  0.862262191908E-02  0.873115069137E-02  0.884104446076E-02
+  0.895232038864E-02  0.906499585174E-02  0.917908844476E-02  0.929461598317E-02
+  0.941159650586E-02  0.953004827795E-02  0.964998979363E-02  0.977143977888E-02
+  0.989441719447E-02  0.100189412388E-01  0.101450313507E-01  0.102727072128E-01
+  0.104019887540E-01  0.105328961530E-01  0.106654498408E-01  0.107996705044E-01
+  0.109355790897E-01  0.110731968044E-01  0.112125451217E-01  0.113536457830E-01
+  0.114965208018E-01  0.116411924664E-01  0.117876833435E-01  0.119360162818E-01
+  0.120862144150E-01  0.122383011655E-01  0.123923002478E-01  0.125482356720E-01
+  0.127061317476E-01  0.128660130864E-01  0.130279046071E-01  0.131918315381E-01
+  0.133578194216E-01  0.135258941171E-01  0.136960818055E-01  0.138684089925E-01
+  0.140429025124E-01  0.142195895324E-01  0.143984975558E-01  0.145796544265E-01
+  0.147630883326E-01  0.149488278103E-01  0.151369017481E-01  0.153273393906E-01
+  0.155201703426E-01  0.157154245732E-01  0.159131324198E-01  0.161133245921E-01
+  0.163160321762E-01  0.165212866390E-01  0.167291198319E-01  0.169395639952E-01
+  0.171526517621E-01  0.173684161629E-01  0.175868906291E-01  0.178081089978E-01
+  0.180321055153E-01  0.182589148416E-01  0.184885720545E-01  0.187211126535E-01
+  0.189565725641E-01  0.191949881417E-01  0.194363961755E-01  0.196808338927E-01
+  0.199283389623E-01  0.201789494989E-01  0.204327040666E-01  0.206896416830E-01
+  0.209498018222E-01  0.212132244192E-01  0.214799498725E-01  0.217500190486E-01
+  0.220234732842E-01  0.223003543900E-01  0.225807046536E-01  0.228645668425E-01
+  0.231519842063E-01  0.234430004799E-01  0.237376598855E-01  0.240360071349E-01
+  0.243380874311E-01  0.246439464705E-01  0.249536304438E-01  0.252671860377E-01
+  0.255846604351E-01  0.259061013160E-01  0.262315568577E-01  0.265610757342E-01
+  0.268947071161E-01  0.272325006688E-01  0.275745065518E-01  0.279207754158E-01
+  0.282713584008E-01  0.286263071323E-01  0.289856737182E-01  0.293495107435E-01
+  0.297178712658E-01  0.300908088092E-01  0.304683773572E-01  0.308506313454E-01
+  0.312376256530E-01  0.316294155930E-01  0.320260569018E-01  0.324276057273E-01
+  0.328341186163E-01  0.332456524999E-01  0.336622646782E-01  0.340840128033E-01
+  0.345109548606E-01  0.349431491488E-01  0.353806542575E-01  0.358235290442E-01
+  0.362718326078E-01  0.367256242611E-01  0.371849635005E-01  0.376499099737E-01
+  0.381205234447E-01  0.385968637560E-01  0.390789907882E-01  0.395669644163E-01
+  0.400608444636E-01  0.405606906506E-01  0.410665625424E-01  0.415785194905E-01
+  0.420966205714E-01  0.426209245210E-01  0.431514896641E-01  0.436883738395E-01
+  0.442316343193E-01  0.447813277240E-01  0.453375099306E-01  0.459002359759E-01
+  0.464695599525E-01  0.470455348985E-01  0.476282126802E-01  0.482176438668E-01
+  0.488138775982E-01  0.494169614429E-01  0.500269412485E-01  0.506438609822E-01
+  0.512677625615E-01  0.518986856745E-01  0.525366675897E-01  0.531817429537E-01
+  0.538339435774E-01  0.544932982088E-01  0.551598322929E-01  0.558335677174E-01
+  0.565145225434E-01  0.572027107205E-01  0.578981417859E-01  0.586008205458E-01
+  0.593107467394E-01  0.600279146831E-01  0.607523128964E-01  0.614839237051E-01
+  0.622227228247E-01  0.629686789199E-01  0.637217531409E-01  0.644818986350E-01
+  0.652490600320E-01  0.660231729030E-01  0.668041631911E-01  0.675919466131E-01
+  0.683864280305E-01  0.691875007891E-01  0.699950460262E-01  0.708089319439E-01
+  0.716290130468E-01  0.724551293444E-01  0.732871055154E-01  0.741247500338E-01
+  0.749678542555E-01  0.758161914640E-01  0.766695158748E-01  0.775275615964E-01
+  0.783900415489E-01  0.792566463375E-01  0.801270430813E-01  0.810008741968E-01
+  0.818777561354E-01  0.827572780749E-01  0.836390005647E-01  0.845224541252E-01
+  0.854071378023E-01  0.862925176757E-01  0.871780253253E-01  0.880630562538E-01
+  0.889469682700E-01  0.898290798324E-01  0.907086683585E-01  0.915849685008E-01
+  0.924571703944E-01  0.933244178804E-01  0.941858067104E-01  0.950403827369E-01
+  0.958871400984E-01  0.967250194042E-01  0.975529059296E-01  0.983696278298E-01
+  0.991739543830E-01  0.999645942761E-01  0.100740193944      0.101499335980
+  0.102240537628      0.102962249377      0.103662853686      0.104340663837
+  0.104993922964      0.105620803267      0.106219405438      0.106787758339
+  0.107323818950      0.107825472615      0.108290533647      0.108716746292
+  0.109101786122      0.109443261880      0.109738717825      0.109985636623
+  0.110181442826      0.110323507000      0.110409150529      0.110435651172
+  0.110400249402      0.110300155597      0.110132558122      0.109894632362
+  0.109583550756      0.109196493874      0.108730662597      0.108183291424
+  0.107551662966      0.106833123643      0.106025100622      0.105125120011
+  0.104130826314      0.103040003156      0.101850595256      0.100560731626
+  0.991687499557E-01  0.976732221067E-01  0.960729806626E-01  0.943671464125E-01
+  0.925551566546E-01  0.906367941705E-01  0.886122166942E-01  0.864819866756E-01
+  0.842471011044E-01  0.819090211356E-01  0.794697012205E-01  0.769316174211E-01
+  0.742977945493E-01  0.715718317459E-01  0.687579260799E-01  0.658608937228E-01
+  0.628861882259E-01  0.598399154053E-01  0.567288443207E-01  0.535604138169E-01
+  0.503427340922E-01  0.470845827494E-01  0.437953947907E-01  0.404852460294E-01
+  0.371648294041E-01  0.338454237118E-01  0.305388543049E-01  0.272574453367E-01
+  0.240139631889E-01  0.208215507592E-01  0.176936523480E-01  0.146439289340E-01
+  0.116861636875E-01  0.883415762374E-02  0.610161534685E-02  0.350202088155E-02
+  0.104850362535E-02 -0.124630551397E-02 -0.337042770346E-02 -0.531269937304E-02
+ -0.706294484936E-02 -0.861215822024E-02 -0.995269411642E-02 -0.110784669338E-01
+ -0.119851577601E-01 -0.126704278700E-01 -0.131341370634E-01 -0.133785642798E-01
+ -0.134086267544E-01 -0.132320924112E-01 -0.128597781168E-01 -0.123057237624E-01
+ -0.115873287949E-01 -0.107254336900E-01 -0.974432387549E-02 -0.867162769382E-02
+ -0.753807309929E-02 -0.637705989494E-02 -0.522399542388E-02 -0.411533174985E-02
+ -0.308723149063E-02 -0.217377755596E-02 -0.140462892581E-02 -0.802009959386E-03
+ -0.376903953020E-03 -0.124301878407E-03 -0.173332527766E-04 -0.766932430452E-07
+  3
+ -0.126334425889E-06 -0.254257943232E-06 -0.383790540339E-06 -0.514952456942E-06
+ -0.647764187356E-06 -0.782246483686E-06 -0.918420359063E-06 -0.105630709093E-05
+ -0.119592822438E-05 -0.133730557548E-05 -0.148046123475E-05 -0.162541757054E-05
+ -0.177219723257E-05 -0.192082315547E-05 -0.207131856234E-05 -0.222370696839E-05
+ -0.237801218462E-05 -0.253425832154E-05 -0.269246979291E-05 -0.285267131962E-05
+ -0.301488793346E-05 -0.317914498112E-05 -0.334546812810E-05 -0.351388336272E-05
+ -0.368441700020E-05 -0.385709568679E-05 -0.403194640386E-05 -0.420899647220E-05
+ -0.438827355625E-05 -0.456980566842E-05 -0.475362117346E-05 -0.493974879292E-05
+ -0.512821760962E-05 -0.531905707220E-05 -0.551229699972E-05 -0.570796758629E-05
+ -0.590609940586E-05 -0.610672341692E-05 -0.630987096738E-05 -0.651557379946E-05
+ -0.672386405465E-05 -0.693477427872E-05 -0.714833742682E-05 -0.736458686862E-05
+ -0.758355639356E-05 -0.780528021605E-05 -0.802979298089E-05 -0.825712976868E-05
+ -0.848732610122E-05 -0.872041794719E-05 -0.895644172764E-05 -0.919543432178E-05
+ -0.943743307268E-05 -0.968247579314E-05 -0.993060077159E-05 -0.101818467781E-04
+ -0.104362530702E-04 -0.106938593996E-04 -0.109547060178E-04 -0.112188336824E-04
+ -0.114862836641E-04 -0.117570977525E-04 -0.120313182627E-04 -0.123089880423E-04
+ -0.125901504778E-04 -0.128748495014E-04 -0.131631295978E-04 -0.134550358115E-04
+ -0.137506137533E-04 -0.140499096079E-04 -0.143529701410E-04 -0.146598427063E-04
+ -0.149705752532E-04 -0.152852163345E-04 -0.156038151133E-04 -0.159264213715E-04
+ -0.162530855168E-04 -0.165838585912E-04 -0.169187922788E-04 -0.172579389135E-04
+ -0.176013514877E-04 -0.179490836603E-04 -0.183011897652E-04 -0.186577248197E-04
+ -0.190187445331E-04 -0.193843053154E-04 -0.197544642864E-04 -0.201292792840E-04
+ -0.205088088739E-04 -0.208931123584E-04 -0.212822497856E-04 -0.216762819591E-04
+ -0.220752704472E-04 -0.224792775927E-04 -0.228883665224E-04 -0.233026011574E-04
+ -0.237220462228E-04 -0.241467672575E-04 -0.245768306252E-04 -0.250123035241E-04
+ -0.254532539978E-04 -0.258997509457E-04 -0.263518641338E-04 -0.268096642057E-04
+ -0.272732226936E-04 -0.277426120295E-04 -0.282179055564E-04 -0.286991775399E-04
+ -0.291865031797E-04 -0.296799586215E-04 -0.301796209686E-04 -0.306855682944E-04
+ -0.311978796541E-04 -0.317166350974E-04 -0.322419156809E-04 -0.327738034807E-04
+ -0.333123816055E-04 -0.338577342091E-04 -0.344099465040E-04 -0.349691047745E-04
+ -0.355352963902E-04 -0.361086098198E-04 -0.366891346445E-04 -0.372769615726E-04
+ -0.378721824532E-04 -0.384748902908E-04 -0.390851792597E-04 -0.397031447189E-04
+ -0.403288832266E-04 -0.409624925559E-04 -0.416040717094E-04 -0.422537209351E-04
+ -0.429115417422E-04 -0.435776369164E-04 -0.442521105365E-04 -0.449350679904E-04
+ -0.456266159915E-04 -0.463268625956E-04 -0.470359172176E-04 -0.477538906489E-04
+ -0.484808950742E-04 -0.492170440895E-04 -0.499624527194E-04 -0.507172374357E-04
+ -0.514815161749E-04 -0.522554083572E-04 -0.530390349049E-04 -0.538325182611E-04
+ -0.546359824092E-04 -0.554495528922E-04 -0.562733568321E-04 -0.571075229500E-04
+ -0.579521815859E-04 -0.588074647195E-04 -0.596735059906E-04 -0.605504407199E-04
+ -0.614384059301E-04 -0.623375403677E-04 -0.632479845243E-04 -0.641698806586E-04
+ -0.651033728187E-04 -0.660486068647E-04 -0.670057304914E-04 -0.679748932512E-04
+ -0.689562465778E-04 -0.699499438097E-04 -0.709561402141E-04 -0.719749930112E-04
+ -0.730066613988E-04 -0.740513065772E-04 -0.751090917744E-04 -0.761801822714E-04
+ -0.772647454284E-04 -0.783629507104E-04 -0.794749697144E-04 -0.806009761956E-04
+ -0.817411460947E-04 -0.828956575656E-04 -0.840646910031E-04 -0.852484290710E-04
+ -0.864470567309E-04 -0.876607612707E-04 -0.888897323343E-04 -0.901341619508E-04
+ -0.913942445649E-04 -0.926701770672E-04 -0.939621588246E-04 -0.952703917119E-04
+ -0.965950801432E-04 -0.979364311037E-04 -0.992946541823E-04 -0.100669961604E-03
+ -0.102062568264E-03 -0.103472691758E-03 -0.104900552423E-03 -0.106346373365E-03
+ -0.107810380494E-03 -0.109292802567E-03 -0.110793871214E-03 -0.112313820980E-03
+ -0.113852889360E-03 -0.115411316837E-03 -0.116989346919E-03 -0.118587226176E-03
+ -0.120205204280E-03 -0.121843534043E-03 -0.123502471457E-03 -0.125182275735E-03
+ -0.126883209350E-03 -0.128605538076E-03 -0.130349531031E-03 -0.132115460716E-03
+ -0.133903603062E-03 -0.135714237471E-03 -0.137547646856E-03 -0.139404117692E-03
+ -0.141283940057E-03 -0.143187407677E-03 -0.145114817971E-03 -0.147066472103E-03
+ -0.149042675021E-03 -0.151043735512E-03 -0.153069966246E-03 -0.155121683824E-03
+ -0.157199208833E-03 -0.159302865890E-03 -0.161432983694E-03 -0.163589895083E-03
+ -0.165773937076E-03 -0.167985450937E-03 -0.170224782217E-03 -0.172492280817E-03
+ -0.174788301038E-03 -0.177113201638E-03 -0.179467345888E-03 -0.181851101627E-03
+ -0.184264841323E-03 -0.186708942126E-03 -0.189183785933E-03 -0.191689759442E-03
+ -0.194227254218E-03 -0.196796666749E-03 -0.199398398511E-03 -0.202032856030E-03
+ -0.204700450945E-03 -0.207401600073E-03 -0.210136725475E-03 -0.212906254519E-03
+ -0.215710619950E-03 -0.218550259956E-03 -0.221425618236E-03 -0.224337144071E-03
+ -0.227285292392E-03 -0.230270523854E-03 -0.233293304905E-03 -0.236354107862E-03
+ -0.239453410980E-03 -0.242591698532E-03 -0.245769460882E-03 -0.248987194562E-03
+ -0.252245402349E-03 -0.255544593344E-03 -0.258885283054E-03 -0.262267993468E-03
+ -0.265693253140E-03 -0.269161597275E-03 -0.272673567809E-03 -0.276229713494E-03
+ -0.279830589985E-03 -0.283476759927E-03 -0.287168793040E-03 -0.290907266213E-03
+ -0.294692763590E-03 -0.298525876662E-03 -0.302407204361E-03 -0.306337353153E-03
+ -0.310316937130E-03 -0.314346578112E-03 -0.318426905738E-03 -0.322558557567E-03
+ -0.326742179178E-03 -0.330978424271E-03 -0.335267954767E-03 -0.339611440915E-03
+ -0.344009561393E-03 -0.348463003417E-03 -0.352972462845E-03 -0.357538644290E-03
+ -0.362162261227E-03 -0.366844036105E-03 -0.371584700462E-03 -0.376384995036E-03
+ -0.381245669883E-03 -0.386167484492E-03 -0.391151207908E-03 -0.396197618848E-03
+ -0.401307505823E-03 -0.406481667264E-03 -0.411720911643E-03 -0.417026057604E-03
+ -0.422397934087E-03 -0.427837380458E-03 -0.433345246641E-03 -0.438922393252E-03
+ -0.444569691731E-03 -0.450288024481E-03 -0.456078285002E-03 -0.461941378034E-03
+ -0.467878219698E-03 -0.473889737638E-03 -0.479976871164E-03 -0.486140571404E-03
+ -0.492381801449E-03 -0.498701536504E-03 -0.505100764040E-03 -0.511580483949E-03
+ -0.518141708701E-03 -0.524785463501E-03 -0.531512786449E-03 -0.538324728702E-03
+ -0.545222354641E-03 -0.552206742033E-03 -0.559278982204E-03 -0.566440180204E-03
+ -0.573691454987E-03 -0.581033939579E-03 -0.588468781257E-03 -0.595997141731E-03
+ -0.603620197321E-03 -0.611339139148E-03 -0.619155173310E-03 -0.627069521079E-03
+ -0.635083419088E-03 -0.643198119524E-03 -0.651414890327E-03 -0.659735015383E-03
+ -0.668159794729E-03 -0.676690544754E-03 -0.685328598404E-03 -0.694075305393E-03
+ -0.702932032413E-03 -0.711900163344E-03 -0.720981099475E-03 -0.730176259721E-03
+ -0.739487080845E-03 -0.748915017681E-03 -0.758461543363E-03 -0.768128149556E-03
+ -0.777916346687E-03 -0.787827664181E-03 -0.797863650701E-03 -0.808025874392E-03
+ -0.818315923120E-03 -0.828735404728E-03 -0.839285947280E-03 -0.849969199320E-03
+ -0.860786830128E-03 -0.871740529981E-03 -0.882832010417E-03 -0.894063004501E-03
+ -0.905435267100E-03 -0.916950575153E-03 -0.928610727950E-03 -0.940417547414E-03
+ -0.952372878383E-03 -0.964478588904E-03 -0.976736570518E-03 -0.989148738559E-03
+ -0.100171703245E-02 -0.101444341602E-02 -0.102732987779E-02 -0.104037843130E-02
+ -0.105359111540E-02 -0.106696999461E-02 -0.108051715940E-02 -0.109423472654E-02
+ -0.110812483944E-02 -0.112218966845E-02 -0.113643141123E-02 -0.115085229308E-02
+ -0.116545456729E-02 -0.118024051551E-02 -0.119521244805E-02 -0.121037270432E-02
+ -0.122572365314E-02 -0.124126769312E-02 -0.125700725306E-02 -0.127294479229E-02
+ -0.128908280108E-02 -0.130542380103E-02 -0.132197034545E-02 -0.133872501978E-02
+ -0.135569044197E-02 -0.137286926290E-02 -0.139026416680E-02 -0.140787787164E-02
+ -0.142571312962E-02 -0.144377272753E-02 -0.146205948721E-02 -0.148057626600E-02
+ -0.149932595720E-02 -0.151831149048E-02 -0.153753583237E-02 -0.155700198671E-02
+ -0.157671299512E-02 -0.159667193749E-02 -0.161688193245E-02 -0.163734613785E-02
+ -0.165806775126E-02 -0.167905001048E-02 -0.170029619402E-02 -0.172180962164E-02
+ -0.174359365487E-02 -0.176565169750E-02 -0.178798719615E-02 -0.181060364077E-02
+ -0.183350456524E-02 -0.185669354788E-02 -0.188017421199E-02 -0.190395022650E-02
+ -0.192802530645E-02 -0.195240321361E-02 -0.197708775709E-02 -0.200208279388E-02
+ -0.202739222953E-02 -0.205302001868E-02 -0.207897016572E-02 -0.210524672541E-02
+ -0.213185380352E-02 -0.215879555745E-02 -0.218607619692E-02 -0.221369998457E-02
+ -0.224167123668E-02 -0.226999432381E-02 -0.229867367150E-02 -0.232771376095E-02
+ -0.235711912973E-02 -0.238689437250E-02 -0.241704414168E-02 -0.244757314825E-02
+ -0.247848616242E-02 -0.250978801441E-02 -0.254148359519E-02 -0.257357785726E-02
+ -0.260607581542E-02 -0.263898254752E-02 -0.267230319532E-02 -0.270604296522E-02
+ -0.274020712914E-02 -0.277480102528E-02 -0.280983005901E-02 -0.284529970369E-02
+ -0.288121550151E-02 -0.291758306438E-02 -0.295440807481E-02 -0.299169628677E-02
+ -0.302945352661E-02 -0.306768569398E-02 -0.310639876272E-02 -0.314559878183E-02
+ -0.318529187636E-02 -0.322548424846E-02 -0.326618217823E-02 -0.330739202482E-02
+ -0.334912022733E-02 -0.339137330587E-02 -0.343415786256E-02 -0.347748058256E-02
+ -0.352134823512E-02 -0.356576767463E-02 -0.361074584172E-02 -0.365628976429E-02
+ -0.370240655866E-02 -0.374910343066E-02 -0.379638767675E-02 -0.384426668516E-02
+ -0.389274793708E-02 -0.394183900777E-02 -0.399154756779E-02 -0.404188138417E-02
+ -0.409284832166E-02 -0.414445634391E-02 -0.419671351475E-02 -0.424962799944E-02
+ -0.430320806593E-02 -0.435746208619E-02 -0.441239853749E-02 -0.446802600370E-02
+ -0.452435317669E-02 -0.458138885765E-02 -0.463914195848E-02 -0.469762150315E-02
+ -0.475683662916E-02 -0.481679658893E-02 -0.487751075127E-02 -0.493898860281E-02
+ -0.500123974953E-02 -0.506427391822E-02 -0.512810095801E-02 -0.519273084192E-02
+ -0.525817366840E-02 -0.532443966293E-02 -0.539153917961E-02 -0.545948270276E-02
+ -0.552828084857E-02 -0.559794436676E-02 -0.566848414226E-02 -0.573991119692E-02
+ -0.581223669121E-02 -0.588547192596E-02 -0.595962834416E-02 -0.603471753271E-02
+ -0.611075122426E-02 -0.618774129900E-02 -0.626569978659E-02 -0.634463886794E-02
+ -0.642457087721E-02 -0.650550830365E-02 -0.658746379363E-02 -0.667045015254E-02
+ -0.675448034685E-02 -0.683956750610E-02 -0.692572492497E-02 -0.701296606534E-02
+ -0.710130455839E-02 -0.719075420675E-02 -0.728132898663E-02 -0.737304305003E-02
+ -0.746591072692E-02 -0.755994652749E-02 -0.765516514442E-02 -0.775158145517E-02
+ -0.784921052429E-02 -0.794806760580E-02 -0.804816814552E-02 -0.814952778355E-02
+ -0.825216235665E-02 -0.835608790074E-02 -0.846132065340E-02 -0.856787705639E-02
+ -0.867577375823E-02 -0.878502761680E-02 -0.889565570195E-02 -0.900767529816E-02
+ -0.912110390728E-02 -0.923595925121E-02 -0.935225927467E-02 -0.947002214802E-02
+ -0.958926627009E-02 -0.971001027101E-02 -0.983227301517E-02 -0.995607360410E-02
+ -0.100814313795E-01 -0.102083659262E-01 -0.103368970753E-01 -0.104670449072E-01
+ -0.105988297545E-01 -0.107322722058E-01 -0.108673931081E-01 -0.110042135706E-01
+ -0.111427549679E-01 -0.112830389431E-01 -0.114250874114E-01 -0.115689225634E-01
+ -0.117145668685E-01 -0.118620430786E-01 -0.120113742313E-01 -0.121625836537E-01
+ -0.123156949663E-01 -0.124707320859E-01 -0.126277192300E-01 -0.127866809204E-01
+ -0.129476419867E-01 -0.131106275704E-01 -0.132756631291E-01 -0.134427744396E-01
+ -0.136119876027E-01 -0.137833290469E-01 -0.139568255325E-01 -0.141325041555E-01
+ -0.143103923524E-01 -0.144905179039E-01 -0.146729089393E-01 -0.148575939410E-01
+ -0.150446017485E-01 -0.152339615634E-01 -0.154257029536E-01 -0.156198558575E-01
+ -0.158164505892E-01 -0.160155178429E-01 -0.162170886974E-01 -0.164211946211E-01
+ -0.166278674769E-01 -0.168371395267E-01 -0.170490434365E-01 -0.172636122817E-01
+ -0.174808795515E-01 -0.177008791546E-01 -0.179236454238E-01 -0.181492131217E-01
+ -0.183776174455E-01 -0.186088940328E-01 -0.188430789664E-01 -0.190802087803E-01
+ -0.193203204647E-01 -0.195634514719E-01 -0.198096397218E-01 -0.200589236072E-01
+ -0.203113420002E-01 -0.205669342573E-01 -0.208257402256E-01 -0.210878002486E-01
+ -0.213531551722E-01 -0.216218463502E-01 -0.218939156513E-01 -0.221694054644E-01
+ -0.224483587047E-01 -0.227308188207E-01 -0.230168297997E-01 -0.233064361741E-01
+ -0.235996830285E-01 -0.238966160052E-01 -0.241972813111E-01 -0.245017257242E-01
+ -0.248099966000E-01 -0.251221418782E-01 -0.254382100890E-01 -0.257582503603E-01
+ -0.260823124238E-01 -0.264104466220E-01 -0.267427039148E-01 -0.270791358867E-01
+ -0.274197947527E-01 -0.277647333661E-01 -0.281140052246E-01 -0.284676644774E-01
+ -0.288257659319E-01 -0.291883650608E-01 -0.295555180084E-01 -0.299272815981E-01
+ -0.303037133383E-01 -0.306848714302E-01 -0.310708147736E-01 -0.314616029739E-01
+ -0.318572963490E-01 -0.322579559356E-01 -0.326636434957E-01 -0.330744215229E-01
+ -0.334903532491E-01 -0.339115026506E-01 -0.343379344538E-01 -0.347697141419E-01
+ -0.352069079600E-01 -0.356495829214E-01 -0.360978068127E-01 -0.365516481994E-01
+ -0.370111764306E-01 -0.374764616443E-01 -0.379475747720E-01 -0.384245875424E-01
+ -0.389075724864E-01 -0.393966029399E-01 -0.398917530480E-01 -0.403930977671E-01
+ -0.409007128682E-01 -0.414146749386E-01 -0.419350613837E-01 -0.424619504278E-01
+ -0.429954211151E-01 -0.435355533094E-01 -0.440824276931E-01 -0.446361257664E-01
+ -0.451967298446E-01 -0.457643230554E-01 -0.463389893350E-01 -0.469208134233E-01
+ -0.475098808582E-01 -0.481062779689E-01 -0.487100918677E-01 -0.493214104412E-01
+ -0.499403223395E-01 -0.505669169647E-01 -0.512012844576E-01 -0.518435156824E-01
+ -0.524937022108E-01 -0.531519363030E-01 -0.538183108883E-01 -0.544929195419E-01
+ -0.551758564612E-01 -0.558672164386E-01 -0.565670948327E-01 -0.572755875362E-01
+ -0.579927909415E-01 -0.587188019031E-01 -0.594537176969E-01 -0.601976359765E-01
+ -0.609506547252E-01 -0.617128722051E-01 -0.624843869017E-01 -0.632652974643E-01
+ -0.640557026418E-01 -0.648557012144E-01 -0.656653919194E-01 -0.664848733717E-01
+ -0.673142439795E-01 -0.681536018526E-01 -0.690030447057E-01 -0.698626697538E-01
+ -0.707325736012E-01 -0.716128521222E-01 -0.725036003347E-01 -0.734049122643E-01
+ -0.743168808000E-01 -0.752395975406E-01 -0.761731526300E-01 -0.771176345833E-01
+ -0.780731301008E-01 -0.790397238699E-01 -0.800174983556E-01 -0.810065335765E-01
+ -0.820069068680E-01 -0.830186926301E-01 -0.840419620598E-01 -0.850767828676E-01
+ -0.861232189764E-01 -0.871813302026E-01 -0.882511719179E-01 -0.893327946910E-01
+ -0.904262439089E-01 -0.915315593751E-01 -0.926487748855E-01 -0.937779177790E-01
+ -0.949190084630E-01 -0.960720599122E-01 -0.972370771383E-01 -0.984140566315E-01
+ -0.996029857699E-01 -0.100803842197     -0.102016593167     -0.103241194849
+ -0.104477591605     -0.105725715216     -0.106985484080     -0.108256802361
+ -0.109539559098     -0.110833627263     -0.112138862784     -0.113455103506
+ -0.114782168108     -0.116119854971     -0.117467940982     -0.118826180295
+ -0.120194303026     -0.121572013886     -0.122958990768     -0.124354883255
+ -0.125759311073     -0.127171862481     -0.128592092590     -0.130019521613
+ -0.131453633058     -0.132893871838     -0.134339642322     -0.135790306316
+ -0.137245180965     -0.138703536604     -0.140164594522     -0.141627524676
+ -0.143091443331     -0.144555410639     -0.146018428164     -0.147479436345
+ -0.148937311911     -0.150390865253     -0.151838837750     -0.153279899063
+ -0.154712644412     -0.156135591824     -0.157547179387     -0.158945762501
+ -0.160329611157     -0.161696907240     -0.163045741884     -0.164374112903
+ -0.165679922292     -0.166960973851     -0.168214970933     -0.169439514346
+ -0.170632100447     -0.171790119445     -0.172910853950     -0.173991477804
+ -0.175029055231     -0.176020540339     -0.176962777028     -0.177852499337
+ -0.178686332282     -0.179460793230     -0.180172293872     -0.180817142832
+ -0.181391548980     -0.181891625498     -0.182313394764     -0.182652794109
+ -0.182905682509     -0.183067848264     -0.183135017742     -0.183102865225
+ -0.182967023920     -0.182723098198     -0.182366677093     -0.181893349118
+ -0.181298718427     -0.180578422361     -0.179728150393     -0.178743664485
+ -0.177620820857     -0.176355593153     -0.174944096971     -0.173382615724
+ -0.171667627747     -0.169795834579     -0.167764190319     -0.165569931909
+ -0.163210610210     -0.160684121687     -0.157988740499     -0.155123150772
+ -0.152086478804     -0.148878324931     -0.145498794757     -0.141948529436
+ -0.138228734699     -0.134341208264     -0.130288365335     -0.126073261823
+ -0.121699615020     -0.117171821401     -0.112494971350     -0.107674860581
+ -0.102717998150     -0.976316110003E-01 -0.924236451011E-01 -0.871027633339E-01
+ -0.816783404264E-01 -0.761604553618E-01 -0.705598818478E-01 -0.648880775849E-01
+ -0.591571732327E-01 -0.533799621228E-01 -0.475698919035E-01 -0.417410594052E-01
+ -0.359082100861E-01 -0.300867434189E-01 -0.242927255128E-01 -0.185429100930E-01
+ -0.128547686712E-01 -0.724653029756E-02 -0.173723068031E-02  0.365323035531E-02
+  0.890402511785E-02  0.139933313253E-01  0.188982672272E-01  0.235948351494E-01
+  0.280578820194E-01  0.322610876010E-01  0.361769934767E-01  0.397770881481E-01
+  0.430319658805E-01  0.459115788858E-01  0.483856039324E-01  0.504239451764E-01
+  0.519973946266E-01  0.530784697678E-01  0.536424440500E-01  0.536685797169E-01
+  0.531415632875E-01  0.520531314144E-01  0.504038583347E-01  0.482050553078E-01
+  0.454807069730E-01  0.422693393319E-01  0.386256790909E-01  0.346219246182E-01
+  0.303484052031E-01  0.259133581456E-01  0.214415028551E-01  0.170710376396E-01
+  0.129486273795E-01  0.922188652424E-02  0.602878729196E-02  0.348332999966E-02
+  0.165668983265E-02  0.552887168884E-03  0.777999563054E-04  0.327157262551E-07
+ Core charge follows
+ Valence charge follows
+  0.226292419238E-14  0.916591113279E-14  0.208840688017E-13  0.375976631344E-13
+  0.594922577157E-13  0.867588571254E-13  0.119594054029E-12  0.158200180110E-12
+  0.202785460940E-12  0.253564174895E-12  0.310756816211E-12  0.374590262293E-12
+  0.445297945389E-12  0.523120028727E-12  0.608303587252E-12  0.701102793055E-12
+  0.801779105641E-12  0.910601467134E-12  0.102784650257E-11  0.115379872539E-11
+  0.128875074827E-11  0.143300349945E-11  0.158686644464E-11  0.175065781475E-11
+  0.192470483944E-11  0.210934398683E-11  0.230492120937E-11  0.251179219607E-11
+  0.273032263131E-11  0.296088846035E-11  0.320387616170E-11  0.345968302654E-11
+  0.372871744542E-11  0.401139920229E-11  0.430815977625E-11  0.461944265104E-11
+  0.494570363252E-11  0.528741117440E-11  0.564504671237E-11  0.601910500688E-11
+  0.641009449472E-11  0.681853764979E-11  0.724497135305E-11  0.768994727211E-11
+  0.815403225060E-11  0.863780870760E-11  0.914187504730E-11  0.966684607930E-11
+  0.102133534497E-10  0.107820460835E-10  0.113735906379E-10  0.119886719678E-10
+  0.126279936031E-10  0.132922782384E-10  0.139822682348E-10  0.146987261356E-10
+  0.154424351940E-10  0.162141999157E-10  0.170148466144E-10  0.178452239821E-10
+  0.187062036743E-10  0.195986809093E-10  0.205235750842E-10  0.214818304054E-10
+  0.224744165367E-10  0.235023292624E-10  0.245665911694E-10  0.256682523446E-10
+  0.268083910925E-10  0.279881146693E-10  0.292085600367E-10  0.304708946355E-10
+  0.317763171779E-10  0.331260584612E-10  0.345213822015E-10  0.359635858895E-10
+  0.374540016682E-10  0.389939972319E-10  0.405849767503E-10  0.422283818145E-10
+  0.439256924079E-10  0.456784279024E-10  0.474881480793E-10  0.493564541770E-10
+  0.512849899653E-10  0.532754428467E-10  0.553295449873E-10  0.574490744747E-10
+  0.596358565075E-10  0.618917646136E-10  0.642187219008E-10  0.666187023389E-10
+  0.690937320745E-10  0.716458907799E-10  0.742773130359E-10  0.769901897504E-10
+  0.797867696133E-10  0.826693605881E-10  0.856403314421E-10  0.887021133157E-10
+  0.918572013314E-10  0.951081562444E-10  0.984576061350E-10  0.101908248145E-09
+  0.105462850255E-09  0.109124253116E-09  0.112895371915E-09  0.116779198299E-09
+  0.120778802341E-09  0.124897334565E-09  0.129138028009E-09  0.133504200356E-09
+  0.137999256105E-09  0.142626688813E-09  0.147390083375E-09  0.152293118383E-09
+  0.157339568528E-09  0.162533307073E-09  0.167878308386E-09  0.173378650537E-09
+  0.179038517964E-09  0.184862204203E-09  0.190854114692E-09  0.197018769639E-09
+  0.203360806977E-09  0.209884985378E-09  0.216596187354E-09  0.223499422435E-09
+  0.230599830427E-09  0.237902684755E-09  0.245413395885E-09  0.253137514844E-09
+  0.261080736818E-09  0.269248904851E-09  0.277648013633E-09  0.286284213385E-09
+  0.295163813846E-09  0.304293288355E-09  0.313679278048E-09  0.323328596148E-09
+  0.333248232377E-09  0.343445357470E-09  0.353927327811E-09  0.364701690187E-09
+  0.375776186655E-09  0.387158759542E-09  0.398857556569E-09  0.410880936103E-09
+  0.423237472546E-09  0.435935961860E-09  0.448985427231E-09  0.462395124881E-09
+  0.476174550023E-09  0.490333442970E-09  0.504881795401E-09  0.519829856783E-09
+  0.535188140958E-09  0.550967432898E-09  0.567178795631E-09  0.583833577344E-09
+  0.600943418665E-09  0.618520260130E-09  0.636576349845E-09  0.655124251333E-09
+  0.674176851591E-09  0.693747369346E-09  0.713849363521E-09  0.734496741914E-09
+  0.755703770110E-09  0.777485080597E-09  0.799855682141E-09  0.822830969373E-09
+  0.846426732638E-09  0.870659168089E-09  0.895544888031E-09  0.921100931539E-09
+  0.947344775335E-09  0.974294344952E-09  0.100196802617E-08  0.103038467675E-08
+  0.105956363848E-08  0.108952474947E-08  0.112028835686E-08  0.115187532973E-08
+  0.118430707246E-08  0.121760553831E-08  0.125179324345E-08  0.128689328127E-08
+  0.132292933712E-08  0.135992570334E-08  0.139790729473E-08  0.143689966446E-08
+  0.147692902023E-08  0.151802224103E-08  0.156020689416E-08  0.160351125280E-08
+  0.164796431395E-08  0.169359581687E-08  0.174043626199E-08  0.178851693024E-08
+  0.183786990296E-08  0.188852808224E-08  0.194052521181E-08  0.199389589848E-08
+  0.204867563405E-08  0.210490081789E-08  0.216260877998E-08  0.222183780460E-08
+  0.228262715461E-08  0.234501709634E-08  0.240904892510E-08  0.247476499136E-08
+  0.254220872761E-08  0.261142467582E-08  0.268245851568E-08  0.275535709356E-08
+  0.283016845213E-08  0.290694186079E-08  0.298572784686E-08  0.306657822755E-08
+  0.314954614277E-08  0.323468608874E-08  0.332205395244E-08  0.341170704700E-08
+  0.350370414794E-08  0.359810553028E-08  0.369497300674E-08  0.379436996673E-08
+  0.389636141645E-08  0.400101401998E-08  0.410839614141E-08  0.421857788798E-08
+  0.433163115442E-08  0.444762966834E-08  0.456664903681E-08  0.468876679404E-08
+  0.481406245044E-08  0.494261754270E-08  0.507451568534E-08  0.520984262345E-08
+  0.534868628678E-08  0.549113684529E-08  0.563728676594E-08  0.578723087113E-08
+  0.594106639841E-08  0.609889306188E-08  0.626081311504E-08  0.642693141528E-08
+  0.659735548997E-08  0.677219560426E-08  0.695156483059E-08  0.713557911995E-08
+  0.732435737496E-08  0.751802152479E-08  0.771669660199E-08  0.792051082125E-08
+  0.812959566021E-08  0.834408594222E-08  0.856411992130E-08  0.878983936921E-08
+  0.902138966469E-08  0.925891988504E-08  0.950258289996E-08  0.975253546778E-08
+  0.100089383342E-07  0.102719563333E-07  0.105417584915E-07  0.108185181338E-07
+  0.111024129930E-07  0.113936253212E-07  0.116923420049E-07  0.119987546822E-07
+  0.123130598635E-07  0.126354590553E-07  0.129661588866E-07  0.133053712390E-07
+  0.136533133802E-07  0.140102081000E-07  0.143762838512E-07  0.147517748924E-07
+  0.151369214359E-07  0.155319697985E-07  0.159371725563E-07  0.163527887033E-07
+  0.167790838146E-07  0.172163302131E-07  0.176648071402E-07  0.181248009321E-07
+  0.185966051991E-07  0.190805210103E-07  0.195768570826E-07  0.200859299749E-07
+  0.206080642868E-07  0.211435928624E-07  0.216928569995E-07  0.222562066641E-07
+  0.228340007097E-07  0.234266071032E-07  0.240344031557E-07  0.246577757595E-07
+  0.252971216309E-07  0.259528475594E-07  0.266253706631E-07  0.273151186506E-07
+  0.280225300892E-07  0.287480546806E-07  0.294921535430E-07  0.302552995004E-07
+  0.310379773796E-07  0.318406843141E-07  0.326639300568E-07  0.335082372989E-07
+  0.343741419988E-07  0.352621937179E-07  0.361729559654E-07  0.371070065521E-07
+  0.380649379528E-07  0.390473576782E-07  0.400548886553E-07  0.410881696193E-07
+  0.421478555132E-07  0.432346178993E-07  0.443491453801E-07  0.454921440303E-07
+  0.466643378397E-07  0.478664691670E-07  0.490992992059E-07  0.503636084616E-07
+  0.516601972412E-07  0.529898861547E-07  0.543535166302E-07  0.557519514412E-07
+  0.571860752473E-07  0.586567951495E-07  0.601650412582E-07  0.617117672771E-07
+  0.632979511001E-07  0.649245954252E-07  0.665927283829E-07  0.683034041800E-07
+  0.700577037615E-07  0.718567354871E-07  0.737016358267E-07  0.755935700722E-07
+  0.775337330683E-07  0.795233499609E-07  0.815636769651E-07  0.836560021528E-07
+  0.858016462592E-07  0.880019635113E-07  0.902583424759E-07  0.925722069299E-07
+  0.949450167528E-07  0.973782688410E-07  0.998734980459E-07  0.102432278136E-06
+  0.105056222782E-06  0.107746986569E-06  0.110506266032E-06  0.113335800720E-06
+  0.116237374286E-06  0.119212815603E-06  0.122263999909E-06  0.125392849986E-06
+  0.128601337359E-06  0.131891483537E-06  0.135265361274E-06  0.138725095871E-06
+  0.142272866504E-06  0.145910907594E-06  0.149641510201E-06  0.153467023463E-06
+  0.157389856066E-06  0.161412477754E-06  0.165537420873E-06  0.169767281960E-06
+  0.174104723369E-06  0.178552474936E-06  0.183113335693E-06  0.187790175617E-06
+  0.192585937431E-06  0.197503638443E-06  0.202546372439E-06  0.207717311621E-06
+  0.213019708590E-06  0.218456898388E-06  0.224032300583E-06  0.229749421411E-06
+  0.235611855973E-06  0.241623290486E-06  0.247787504593E-06  0.254108373727E-06
+  0.260589871541E-06  0.267236072394E-06  0.274051153903E-06  0.281039399564E-06
+  0.288205201426E-06  0.295553062849E-06  0.303087601321E-06  0.310813551350E-06
+  0.318735767428E-06  0.326859227073E-06  0.335189033946E-06  0.343730421046E-06
+  0.352488753989E-06  0.361469534365E-06  0.370678403188E-06  0.380121144425E-06
+  0.389803688620E-06  0.399732116609E-06  0.409912663325E-06  0.420351721707E-06
+  0.431055846702E-06  0.442031759370E-06  0.453286351093E-06  0.464826687893E-06
+  0.476660014857E-06  0.488793760674E-06  0.501235542289E-06  0.513993169673E-06
+  0.527074650714E-06  0.540488196237E-06  0.554242225143E-06  0.568345369683E-06
+  0.582806480868E-06  0.597634634012E-06  0.612839134417E-06  0.628429523201E-06
+  0.644415583279E-06  0.660807345489E-06  0.677615094877E-06  0.694849377143E-06
+  0.712521005244E-06  0.730641066174E-06  0.749220927907E-06  0.768272246525E-06
+  0.787806973516E-06  0.807837363269E-06  0.828375980752E-06  0.849435709386E-06
+  0.871029759119E-06  0.893171674708E-06  0.915875344208E-06  0.939155007676E-06
+  0.963025266100E-06  0.987501090550E-06  0.101259783157E-05  0.103833122878E-05
+  0.106471742080E-05  0.109177295528E-05  0.111951479938E-05  0.114796035033E-05
+  0.117712744638E-05  0.120703437798E-05  0.123769989924E-05  0.126914323973E-05
+  0.130138411651E-05  0.133444274652E-05  0.136833985924E-05  0.140309670973E-05
+  0.143873509196E-05  0.147527735249E-05  0.151274640447E-05  0.155116574208E-05
+  0.159055945522E-05  0.163095224469E-05  0.167236943765E-05  0.171483700359E-05
+  0.175838157057E-05  0.180303044202E-05  0.184881161385E-05  0.189575379204E-05
+  0.194388641073E-05  0.199323965066E-05  0.204384445819E-05  0.209573256474E-05
+  0.214893650675E-05  0.220348964614E-05  0.225942619130E-05  0.231678121865E-05
+  0.237559069465E-05  0.243589149851E-05  0.249772144534E-05  0.256111931003E-05
+  0.262612485166E-05  0.269277883850E-05  0.276112307377E-05  0.283120042197E-05
+  0.290305483587E-05  0.297673138429E-05  0.305227628050E-05  0.312973691140E-05
+  0.320916186742E-05  0.329060097320E-05  0.337410531909E-05  0.345972729342E-05
+  0.354752061562E-05  0.363754037015E-05  0.372984304144E-05  0.382448654954E-05
+  0.392153028686E-05  0.402103515573E-05  0.412306360706E-05  0.422767967989E-05
+  0.433494904201E-05  0.444493903165E-05  0.455771870026E-05  0.467335885631E-05
+  0.479193211037E-05  0.491351292128E-05  0.503817764350E-05  0.516600457579E-05
+  0.529707401107E-05  0.543146828767E-05  0.556927184183E-05  0.571057126164E-05
+  0.585545534244E-05  0.600401514353E-05  0.615634404657E-05  0.631253781535E-05
+  0.647269465726E-05  0.663691528632E-05  0.680530298793E-05  0.697796368530E-05
+  0.715500600769E-05  0.733654136046E-05  0.752268399698E-05  0.771355109250E-05
+  0.790926281994E-05  0.810994242786E-05  0.831571632037E-05  0.852671413933E-05
+  0.874306884871E-05  0.896491682131E-05  0.919239792780E-05  0.942565562825E-05
+  0.966483706611E-05  0.991009316482E-05  0.101615787272E-04  0.104194525372E-04
+  0.106838774654E-04  0.109550205760E-04  0.112330532386E-04  0.115181512413E-04
+  0.118104949087E-04  0.121102692219E-04  0.124176639430E-04  0.127328737421E-04
+  0.130560983292E-04  0.133875425889E-04  0.137274167194E-04  0.140759363759E-04
+  0.144333228177E-04  0.147998030598E-04  0.151756100297E-04  0.155609827276E-04
+  0.159561663929E-04  0.163614126746E-04  0.167769798077E-04  0.172031327946E-04
+  0.176401435925E-04  0.180882913062E-04  0.185478623876E-04  0.190191508413E-04
+  0.195024584362E-04  0.199980949253E-04  0.205063782713E-04  0.210276348806E-04
+  0.215621998445E-04  0.221104171889E-04  0.226726401323E-04  0.232492313525E-04
+  0.238405632628E-04  0.244470182978E-04  0.250689892089E-04  0.257068793710E-04
+  0.263611030998E-04  0.270320859808E-04  0.277202652101E-04  0.284260899488E-04
+  0.291500216899E-04  0.298925346392E-04  0.306541161118E-04  0.314352669430E-04
+  0.322365019160E-04  0.330583502066E-04  0.339013558463E-04  0.347660782036E-04
+  0.356530924856E-04  0.365629902612E-04  0.374963800061E-04  0.384538876706E-04
+  0.394361572738E-04  0.404438515227E-04  0.414776524591E-04  0.425382621366E-04
+  0.436264033279E-04  0.447428202653E-04  0.458882794155E-04  0.470635702921E-04
+  0.482695063067E-04  0.495069256612E-04  0.507766922850E-04  0.520796968182E-04
+  0.534168576449E-04  0.547891219790E-04  0.561974670068E-04  0.576429010884E-04
+  0.591264650235E-04  0.606492333844E-04  0.622123159213E-04  0.638168590441E-04
+  0.654640473863E-04  0.671551054559E-04  0.688912993798E-04  0.706739387464E-04
+  0.725043785552E-04  0.743840212788E-04  0.763143190457E-04  0.782967759521E-04
+  0.803329505108E-04  0.824244582485E-04  0.845729744586E-04  0.867802371238E-04
+  0.890480500172E-04  0.913782859962E-04  0.937728905024E-04  0.962338852808E-04
+  0.987633723352E-04  0.101363538135E-03  0.104036658094E-03  0.106785101333E-03
+  0.109611335760E-03  0.112517933473E-03  0.115507576527E-03  0.118583063069E-03
+  0.121747313899E-03  0.125003379446E-03  0.128354447232E-03  0.131803849823E-03
+  0.135355073326E-03  0.139011766462E-03  0.142777750254E-03  0.146657028377E-03
+  0.150653798228E-03  0.154772462743E-03  0.159017643046E-03  0.163394191963E-03
+  0.167907208485E-03  0.172562053233E-03  0.177364365007E-03  0.182320078493E-03
+  0.187435443219E-03  0.192717043836E-03  0.198171821838E-03  0.203807098818E-03
+  0.209630601363E-03  0.215650487720E-03  0.221875376361E-03  0.228314376568E-03
+  0.234977121209E-03  0.241873801847E-03  0.249015206351E-03  0.256412759204E-03
+  0.264078564692E-03  0.272025453177E-03  0.280267030696E-03  0.288817732106E-03
+  0.297692878048E-03  0.306908735992E-03  0.316482585660E-03  0.326432789152E-03
+  0.336778866099E-03  0.347541574211E-03  0.358742995603E-03  0.370406629324E-03
+  0.382557490506E-03  0.395222216642E-03  0.408429181463E-03  0.422208616979E-03
+  0.436592744259E-03  0.451615913557E-03  0.467314754457E-03  0.483728336743E-03
+  0.500898342729E-03  0.518869251887E-03  0.537688538601E-03  0.557406883982E-03
+  0.578078402717E-03  0.599760885994E-03  0.622516061628E-03  0.646409872551E-03
+  0.671512774953E-03  0.697900057412E-03  0.725652182442E-03  0.754855151996E-03
+  0.785600898539E-03  0.817987703422E-03  0.852120644403E-03  0.888112074246E-03
+  0.926082132501E-03  0.966159292637E-03  0.100848094689E-02  0.105319403131E-02
+  0.110045569357E-02  0.115043400644E-02  0.120330872978E-02  0.125927212419E-02
+  0.131852981967E-02  0.138130174271E-02  0.144782310556E-02  0.151834546155E-02
+  0.159313783054E-02  0.167248789888E-02  0.175670329837E-02  0.184611296913E-02
+  0.194106861123E-02  0.204194623061E-02  0.214914778466E-02  0.226310293334E-02
+  0.238427090198E-02  0.251314246203E-02  0.265024203652E-02  0.279612993706E-02
+  0.295140473971E-02  0.311670580712E-02  0.329271596476E-02  0.348016433939E-02
+  0.367982936794E-02  0.389254198556E-02  0.411918900166E-02  0.436071667290E-02
+  0.461813448260E-02  0.489251913601E-02  0.518501878104E-02  0.549685746428E-02
+  0.582933983221E-02  0.618385608749E-02  0.656188721017E-02  0.696501045379E-02
+  0.739490512592E-02  0.785335866267E-02  0.834227300626E-02  0.886367129448E-02
+  0.941970487009E-02  0.100126606178E-01  0.106449686357E-01  0.113192102463E-01
+  0.120381263528E-01  0.128046261435E-01  0.136217961453E-01  0.144929096281E-01
+  0.154214363566E-01  0.164110526861E-01  0.174656519954E-01  0.185893554467E-01
+  0.197865230604E-01  0.210617650877E-01  0.224199536607E-01  0.238662346953E-01
+  0.254060400177E-01  0.270450996781E-01  0.287894544124E-01  0.306454682042E-01
+  0.326198408930E-01  0.347196207680E-01  0.369522170765E-01  0.393254123719E-01
+  0.418473746114E-01  0.445266689081E-01  0.473722688299E-01  0.503935671274E-01
+  0.536003857597E-01  0.570029850786E-01  0.606120720132E-01  0.644388070913E-01
+  0.684948101124E-01  0.727921642796E-01  0.773434185812E-01  0.821615881961E-01
+  0.872601526888E-01  0.926530517393E-01  0.983546781432E-01  0.104379867804
+  0.110743886427      0.117462412608      0.124551517013      0.132027637319
+  0.139907548593      0.148208328787      0.156947318995      0.166142078172
+  0.175810331973      0.185969915398      0.196638708965      0.207834568117
+  0.219575245621      0.231878306749      0.244761037061      0.258240342659
+  0.272332642861      0.287053755269      0.302418773321      0.318441936468
+  0.335136493233      0.352514557502      0.370586958506      0.389363085101
+  0.408850725037      0.429055900105      0.449982698156      0.471633103158
+  0.494006824617      0.517101127846      0.540910666735      0.565427320827
+  0.590640038681      0.616534689641      0.643093926256      0.670297059768
+  0.698119951124      0.726534920109      0.755510675211      0.785012266879
+  0.815001066780      0.845434775650      0.876267462183      0.907449635269
+  0.938928351677      0.970647361001       1.00254728937       1.03456586302
+   1.06663817241       1.09869697696       1.13067305012       1.16249556360
+   1.19409250914       1.22539115546       1.25631853719       1.28680197203
+   1.31676960134       1.34615094915       1.37487749320       1.40288324154
+   1.43010530731       1.45648447382       1.48196574180       1.50649885013
+   1.53003876134       1.55254610312       1.57398755707       1.59433618632
+   1.61357169401       1.63168060529       1.64865636625       1.66449935404
+   1.67921679392       1.69282257968       1.70533699582       1.71678634115
+   1.72720245506       1.73662214959       1.74508655218       1.75264036575
+   1.75933105465       1.76520796690       1.77032140481       1.77472165803
+   1.77845801451       1.78157776640       1.78412522948       1.78614079544
+   1.78766003763       1.78871289121       1.78932292888       1.78950675331
+   1.78927352640       1.78862465459       1.78755364718       1.78604616247
+   1.78408025262       1.78162681461       1.77865024920       1.77510932409
+   1.77095823081       1.76614781723       1.76062696909       1.75434410513
+   1.74724874064       1.73929306405       1.73043346119       1.72063191122
+   1.70985716805       1.69808564021       1.68530179831       1.67149819545
+   1.65667468220       1.64083732368       1.62399773460       1.60617255547
+   1.58738277423       1.56765297990       1.54701061290       1.52548531249
+   1.50310848849       1.47991325058       1.45593465376       1.43120980420
+   1.40577762504       1.37967879345       1.35295558866       1.32565174209
+   1.29781228640       1.26948339693       1.24071222932       1.21154675376
+   1.18203558645       1.15222781935       1.12217284903       1.09192020549
+   1.06151938182       1.03101966554       1.00046997249      0.969918683980
+  0.939413488081      0.909001225741      0.878727742433      0.848637746015
+  0.818774671421      0.789180552746      0.759895903264      0.730959603847
+  0.702408800213      0.674278809362      0.646603035525      0.619412896013
+  0.592737755368      0.566604879856      0.541039358633      0.516064166401
+  0.491699964618      0.467965302132      0.444876564035      0.422447871660
+  0.400691098356      0.379615914477      0.359229834036      0.339538265122
+  0.320544565334      0.302250102903      0.284654323707      0.267754824168
+  0.251547429747      0.236026278678      0.221183910439      0.207011358428
+  0.193498246241      0.180632886942      0.168402384684      0.156792738046
+  0.145788944435      0.135375104942      0.125534528999      0.116249838277
+  0.107503069211      0.992757736291E-01  0.915491169452E-01  0.843039734507E-01
+  0.775210182435E-01  0.711808153956E-01  0.652639019926E-01  0.597508677264E-01
+  0.546224297666E-01  0.498595026822E-01  0.454432632336E-01  0.413552098987E-01
+  0.375772170454E-01  0.340915837060E-01  0.308810769528E-01  0.279289699164E-01
+  0.252190745259E-01  0.227357690877E-01  0.204640208550E-01  0.183894037664E-01
+  0.164981115644E-01  0.147769665250E-01  0.132134240506E-01  0.117955733978E-01
+  0.105121348191E-01  0.935245341458E-02  0.830648998906E-02  0.736480921750E-02
+  0.651856541922E-02  0.575948623881E-02  0.507985452574E-02  0.447248869632E-02
+  0.393072185095E-02  0.344837990753E-02  0.301975899753E-02  0.263960235595E-02
+  0.230307692006E-02  0.200574983452E-02  0.174356504279E-02  0.151282012691E-02
+  0.131014353966E-02  0.113247235535E-02  0.977030648344E-03  0.841308591327E-03
+  0.723042349541E-03  0.620194831808E-03  0.530937344966E-03  0.453632185051E-03
+  0.386816186382E-03  0.329185238637E-03  0.279579772069E-03  0.236971202187E-03
+  0.200449317540E-03  0.169210587616E-03  0.142547362278E-03  0.119837929570E-03
+  0.100537395050E-03  0.841693429945E-04  0.703182377939E-04  0.586225225376E-04
+  0.487683711375E-04  0.404840502136E-04  0.335348473655E-04  0.277185232618E-04
+  0.228612461455E-04  0.188139688128E-04  0.154492098138E-04  0.126582024918E-04
+  0.103483774764E-04  0.844114633199E-05  0.686995618622E-05  0.557858730942E-05
+  0.451966773489E-05  0.365338109221E-05  0.294634584313E-05  0.237064604892E-05
+  0.190299564572E-05  0.152401995149E-05  0.121763976847E-05  0.970544974360E-06
+  0.771745912763E-06  0.612192199302E-06  0.484449755452E-06  0.382427971892E-06
+  0.301149890527E-06  0.236559184820E-06  0.185358517154E-06  0.144874565650E-06
+  0.112945647460E-06  0.878284271853E-07  0.681206940569E-07  0.526976258145E-07
+  0.406593367555E-07  0.312878376604E-07  0.240118215253E-07  0.183779360988E-07
+  0.140274166473E-07  0.106771343093E-07  0.810427062393E-08  0.613396074531E-08
+  0.462935956269E-08  0.348367917971E-08  0.261382540732E-08  0.195532724660E-08
+  0.145830867356E-08  0.108429804232E-08  0.803708531291E-09  0.593854513723E-09
+  0.437394607858E-09  0.321113369087E-09  0.234970908399E-09  0.171363820260E-09
+  0.124552239101E-09  0.902170875591E-10  0.651190261173E-10  0.468365915892E-10
+  0.335657942777E-10  0.239672564805E-10  0.170500044319E-10  0.120834244454E-10
+  0.853078670824E-11  0.599922843870E-11  0.420225427871E-11  0.293172236909E-11
+  0.203699303627E-11  0.140946630048E-11  0.971158732733E-12  0.666296777882E-12
+  0.455154106286E-12  0.309551893171E-12  0.209586550051E-12  0.141259841599E-12
+  0.947697040634E-13  0.632828036264E-13  0.420568641123E-13  0.278158543673E-13
+  0.183071760433E-13  0.119892658680E-13  0.781222408890E-14  0.506449324859E-14
+  0.326621360705E-14  0.209540645205E-14  0.133713309641E-14  0.848654595931E-15
+  0.535678596469E-15  0.336249288953E-15  0.209878854822E-15  0.130254404668E-15
+  0.803708329327E-16  0.493006261783E-16  0.300621200636E-16  0.182206954617E-16
+  0.109762278803E-16  0.657125640887E-17  0.390944235924E-17  0.231108507886E-17
+  0.135742244654E-17  0.792090813545E-18  0.459153909554E-18  0.264379069149E-18
+  0.151196952157E-18  0.858751466940E-19  0.484352246291E-19  0.271259508109E-19
+  0.150833727152E-19  0.832647848983E-20  0.456281420708E-20  0.248182621640E-20
+  0.133978551902E-20  0.717764874144E-21  0.381565692462E-21  0.201258076009E-21
+  0.105315031696E-21  0.546683675653E-22  0.281478781705E-22  0.143738666370E-22
+  0.727903789549E-23  0.365510824308E-23  0.181972308599E-23  0.898134747044E-24
+  0.439400527192E-24  0.213065771665E-24  0.102388551046E-24  0.487555041790E-25
+  0.230027512366E-25  0.107514860399E-25  0.497780477884E-26  0.228262886623E-26
+  0.103659140866E-26  0.466123366955E-27  0.207520286984E-27  0.914600479838E-28
+  0.398985901957E-28  0.172259157065E-28  0.735950159020E-29  0.311098393858E-29
+  0.130098308792E-29  0.538158931925E-30  0.220168018471E-30  0.890721018432E-31
+  0.356296204998E-31  0.140896495989E-31  0.550738422456E-32  0.212756404381E-32
+  0.812170257453E-33  0.306318319331E-33  0.114128408936E-33  0.419993022387E-34
+  0.152633435282E-34  0.547705986153E-35  0.194028509176E-35  0.678473707342E-36
+  0.234141388057E-36  0.797312215396E-37  0.267861420304E-37  0.887664738052E-38
+  0.290114485080E-38  0.934964550498E-39  0.297063191516E-39  0.930362530636E-40
+  0.287161337830E-40  0.873353026145E-41  0.261675160771E-41  0.772256650504E-42
+  0.224441902436E-42  0.642251223558E-43  0.180916916821E-43  0.501579870464E-44
+  0.136835902161E-44  0.367257189120E-45  0.969529397533E-46  0.251698753806E-46
+  0.642448703356E-47  0.161190530725E-47  0.397458150177E-48  0.962934879296E-49
+  0.229156123145E-49  0.535724567581E-50  0.123367377551E-50  0.278884207996E-51
+  0.618744561394E-52  0.134697812218E-52
Added: SwiftApps/ematter/workflow-run/Ta.sic.psf
--- SwiftApps/ematter/workflow-run/Ta.sic.psf	                        (rev 0)
+++ SwiftApps/ematter/workflow-run/Ta.sic.psf	2015-01-27 22:12:52 UTC (rev 8376)
@@ -0,0 +1,3041 @@
+ Ta ca rel nc
+ ATM3      14-OCT-14 Troullier-Martins
+ 6s 2.00r r= 2.78/6p 0.00r r= 2.89/5d 3.00r r= 2.48/5f 0.00r r= 2.48/
+   4  3 1206  0.339555092694E-04  0.125000000000E-01   5.00000000000
+ Radial grid follows
+  0.427107727883E-06  0.859587809623E-06  0.129750782111E-05  0.174093618825E-05
+  0.218994219761E-05  0.264459600730E-05  0.310496865791E-05  0.357113208359E-05
+  0.404315912333E-05  0.452112353232E-05  0.500509999346E-05  0.549516412907E-05
+  0.599139251265E-05  0.649386268092E-05  0.700265314585E-05  0.751784340698E-05
+  0.803951396385E-05  0.856774632853E-05  0.910262303842E-05  0.964422766909E-05
+  0.101926448474E-04  0.107479602645E-04  0.113102606897E-04  0.118796339836E-04
+  0.124561691119E-04  0.130399561593E-04  0.136310863439E-04  0.142296520308E-04
+  0.148357467472E-04  0.154494651966E-04  0.160709032738E-04  0.167001580797E-04
+  0.173373279367E-04  0.179825124039E-04  0.186358122926E-04  0.192973296823E-04
+  0.199671679365E-04  0.206454317187E-04  0.213322270089E-04  0.220276611205E-04
+  0.227318427164E-04  0.234448818263E-04  0.241668898641E-04  0.248979796450E-04
+  0.256382654033E-04  0.263878628102E-04  0.271468889917E-04  0.279154625472E-04
+  0.286937035680E-04  0.294817336557E-04  0.302796759417E-04  0.310876551061E-04
+  0.319057973972E-04  0.327342306516E-04  0.335730843134E-04  0.344224894554E-04
+  0.352825787988E-04  0.361534867343E-04  0.370353493431E-04  0.379283044180E-04
+  0.388324914850E-04  0.397480518253E-04  0.406751284969E-04  0.416138663575E-04
+  0.425644120867E-04  0.435269142094E-04  0.445015231184E-04  0.454883910983E-04
+  0.464876723493E-04  0.474995230110E-04  0.485241011873E-04  0.495615669705E-04
+  0.506120824668E-04  0.516758118214E-04  0.527529212441E-04  0.538435790355E-04
+  0.549479556130E-04  0.560662235379E-04  0.571985575416E-04  0.583451345537E-04
+  0.595061337292E-04  0.606817364766E-04  0.618721264861E-04  0.630774897587E-04
+  0.642980146348E-04  0.655338918240E-04  0.667853144344E-04  0.680524780035E-04
+  0.693355805282E-04  0.706348224958E-04  0.719504069155E-04  0.732825393501E-04
+  0.746314279480E-04  0.759972834757E-04  0.773803193510E-04  0.787807516761E-04
+  0.801987992713E-04  0.816346837094E-04  0.830886293503E-04  0.845608633761E-04
+  0.860516158262E-04  0.875611196337E-04  0.890896106618E-04  0.906373277401E-04
+  0.922045127028E-04  0.937914104255E-04  0.953982688644E-04  0.970253390942E-04
+  0.986728753481E-04  0.100341135057E-03  0.102030378890E-03  0.103740870794E-03
+  0.105472878038E-03  0.107226671251E-03  0.109002524467E-03  0.110800715167E-03
+  0.112621524321E-03  0.114465236435E-03  0.116332139593E-03  0.118222525501E-03
+  0.120136689537E-03  0.122074930792E-03  0.124037552122E-03  0.126024860188E-03
+  0.128037165513E-03  0.130074782522E-03  0.132138029599E-03  0.134227229129E-03
+  0.136342707554E-03  0.138484795421E-03  0.140653827438E-03  0.142850142518E-03
+  0.145074083841E-03  0.147325998902E-03  0.149606239568E-03  0.151915162131E-03
+  0.154253127364E-03  0.156620500579E-03  0.159017651684E-03  0.161444955237E-03
+  0.163902790511E-03  0.166391541547E-03  0.168911597217E-03  0.171463351285E-03
+  0.174047202468E-03  0.176663554498E-03  0.179312816185E-03  0.181995401482E-03
+  0.184711729548E-03  0.187462224815E-03  0.190247317053E-03  0.193067441440E-03
+  0.195923038624E-03  0.198814554799E-03  0.201742441770E-03  0.204707157025E-03
+  0.207709163808E-03  0.210748931187E-03  0.213826934133E-03  0.216943653590E-03
+  0.220099576552E-03  0.223295196137E-03  0.226531011669E-03  0.229807528750E-03
+  0.233125259342E-03  0.236484721847E-03  0.239886441189E-03  0.243330948892E-03
+  0.246818783169E-03  0.250350489000E-03  0.253926618222E-03  0.257547729612E-03
+  0.261214388977E-03  0.264927169238E-03  0.268686650526E-03  0.272493420267E-03
+  0.276348073277E-03  0.280251211853E-03  0.284203445868E-03  0.288205392868E-03
+  0.292257678164E-03  0.296360934934E-03  0.300515804320E-03  0.304722935530E-03
+  0.308982985936E-03  0.313296621179E-03  0.317664515274E-03  0.322087350714E-03
+  0.326565818574E-03  0.331100618626E-03  0.335692459440E-03  0.340342058502E-03
+  0.345050142320E-03  0.349817446542E-03  0.354644716069E-03  0.359532705172E-03
+  0.364482177609E-03  0.369493906746E-03  0.374568675674E-03  0.379707277338E-03
+  0.384910514653E-03  0.390179200637E-03  0.395514158532E-03  0.400916221937E-03
+  0.406386234934E-03  0.411925052225E-03  0.417533539261E-03  0.423212572379E-03
+  0.428963038940E-03  0.434785837466E-03  0.440681877781E-03  0.446652081153E-03
+  0.452697380439E-03  0.458818720230E-03  0.465017056996E-03  0.471293359241E-03
+  0.477648607649E-03  0.484083795242E-03  0.490599927530E-03  0.497198022672E-03
+  0.503879111634E-03  0.510644238350E-03  0.517494459885E-03  0.524430846599E-03
+  0.531454482317E-03  0.538566464497E-03  0.545767904400E-03  0.553059927265E-03
+  0.560443672487E-03  0.567920293791E-03  0.575490959413E-03  0.583156852286E-03
+  0.590919170221E-03  0.598779126096E-03  0.606737948045E-03  0.614796879650E-03
+  0.622957180136E-03  0.631220124566E-03  0.639587004043E-03  0.648059125907E-03
+  0.656637813945E-03  0.665324408596E-03  0.674120267156E-03  0.683026763997E-03
+  0.692045290777E-03  0.701177256658E-03  0.710424088531E-03  0.719787231229E-03
+  0.729268147765E-03  0.738868319549E-03  0.748589246630E-03  0.758432447920E-03
+  0.768399461441E-03  0.778491844559E-03  0.788711174228E-03  0.799059047240E-03
+  0.809537080472E-03  0.820146911137E-03  0.830890197043E-03  0.841768616850E-03
+  0.852783870333E-03  0.863937678649E-03  0.875231784602E-03  0.886667952919E-03
+  0.898247970525E-03  0.909973646822E-03  0.921846813970E-03  0.933869327175E-03
+  0.946043064980E-03  0.958369929556E-03  0.970851847001E-03  0.983490767639E-03
+  0.996288666329E-03  0.100924754277E-02  0.102236942180E-02  0.103565635376E-02
+  0.104911041475E-02  0.106273370699E-02  0.107652835915E-02  0.109049652667E-02
+  0.110464039212E-02  0.111896216549E-02  0.113346408459E-02  0.114814841538E-02
+  0.116301745231E-02  0.117807351870E-02  0.119331896710E-02  0.120875617963E-02
+  0.122438756838E-02  0.124021557581E-02  0.125624267506E-02  0.127247137040E-02
+  0.128890419759E-02  0.130554372431E-02  0.132239255051E-02  0.133945330885E-02
+  0.135672866512E-02  0.137422131861E-02  0.139193400260E-02  0.140986948473E-02
+  0.142803056745E-02  0.144642008847E-02  0.146504092119E-02  0.148389597515E-02
+  0.150298819649E-02  0.152232056841E-02  0.154189611164E-02  0.156171788489E-02
+  0.158178898535E-02  0.160211254918E-02  0.162269175197E-02  0.164352980926E-02
+  0.166462997705E-02  0.168599555228E-02  0.170762987336E-02  0.172953632070E-02
+  0.175171831723E-02  0.177417932892E-02  0.179692286536E-02  0.181995248027E-02
+  0.184327177208E-02  0.186688438447E-02  0.189079400696E-02  0.191500437548E-02
+  0.193951927294E-02  0.196434252986E-02  0.198947802491E-02  0.201492968556E-02
+  0.204070148870E-02  0.206679746121E-02  0.209322168065E-02  0.211997827585E-02
+  0.214707142759E-02  0.217450536922E-02  0.220228438736E-02  0.223041282253E-02
+  0.225889506986E-02  0.228773557976E-02  0.231693885862E-02  0.234650946950E-02
+  0.237645203288E-02  0.240677122735E-02  0.243747179033E-02  0.246855851885E-02
+  0.250003627028E-02  0.253190996309E-02  0.256418457759E-02  0.259686515677E-02
+  0.262995680703E-02  0.266346469901E-02  0.269739406838E-02  0.273175021668E-02
+  0.276653851213E-02  0.280176439047E-02  0.283743335581E-02  0.287355098151E-02
+  0.291012291101E-02  0.294715485875E-02  0.298465261105E-02  0.302262202701E-02
+  0.306106903943E-02  0.309999965573E-02  0.313941995891E-02  0.317933610845E-02
+  0.321975434135E-02  0.326068097304E-02  0.330212239837E-02  0.334408509267E-02
+  0.338657561268E-02  0.342960059764E-02  0.347316677029E-02  0.351728093793E-02
+  0.356194999350E-02  0.360718091661E-02  0.365298077469E-02  0.369935672407E-02
+  0.374631601109E-02  0.379386597322E-02  0.384201404024E-02  0.389076773539E-02
+  0.394013467653E-02  0.399012257735E-02  0.404073924856E-02  0.409199259912E-02
+  0.414389063746E-02  0.419644147276E-02  0.424965331619E-02  0.430353448222E-02
+  0.435809338989E-02  0.441333856413E-02  0.446927863712E-02  0.452592234961E-02
+  0.458327855229E-02  0.464135620718E-02  0.470016438905E-02  0.475971228677E-02
+  0.482000920485E-02  0.488106456478E-02  0.494288790661E-02  0.500548889034E-02
+  0.506887729751E-02  0.513306303269E-02  0.519805612503E-02  0.526386672983E-02
+  0.533050513014E-02  0.539798173833E-02  0.546630709777E-02  0.553549188444E-02
+  0.560554690859E-02  0.567648311646E-02  0.574831159199E-02  0.582104355852E-02
+  0.589469038057E-02  0.596926356559E-02  0.604477476581E-02  0.612123578001E-02
+  0.619865855536E-02  0.627705518935E-02  0.635643793159E-02  0.643681918581E-02
+  0.651821151175E-02  0.660062762711E-02  0.668408040958E-02  0.676858289883E-02
+  0.685414829855E-02  0.694078997851E-02  0.702852147663E-02  0.711735650116E-02
+  0.720730893273E-02  0.729839282661E-02  0.739062241483E-02  0.748401210846E-02
+  0.757857649982E-02  0.767433036480E-02  0.777128866513E-02  0.786946655074E-02
+  0.796887936212E-02  0.806954263274E-02  0.817147209143E-02  0.827468366488E-02
+  0.837919348010E-02  0.848501786696E-02  0.859217336075E-02  0.870067670473E-02
+  0.881054485276E-02  0.892179497196E-02  0.903444444540E-02  0.914851087478E-02
+  0.926401208322E-02  0.938096611800E-02  0.949939125345E-02  0.961930599373E-02
+  0.974072907575E-02  0.986367947213E-02  0.998817639411E-02  0.101142392946E-01
+  0.102418878712E-01  0.103711420692E-01  0.105020220848E-01  0.106345483684E-01
+  0.107687416275E-01  0.109046228299E-01  0.110422132075E-01  0.111815342589E-01
+  0.113226077535E-01  0.114654557341E-01  0.116101005212E-01  0.117565647157E-01
+  0.119048712030E-01  0.120550431563E-01  0.122071040402E-01  0.123610776145E-01
+  0.125169879380E-01  0.126748593719E-01  0.128347165841E-01  0.129965845524E-01
+  0.131604885691E-01  0.133264542445E-01  0.134945075112E-01  0.136646746277E-01
+  0.138369821831E-01  0.140114571007E-01  0.141881266425E-01  0.143670184137E-01
+  0.145481603663E-01  0.147315808042E-01  0.149173083872E-01  0.151053721356E-01
+  0.152958014347E-01  0.154886260396E-01  0.156838760794E-01  0.158815820624E-01
+  0.160817748804E-01  0.162844858142E-01  0.164897465376E-01  0.166975891231E-01
+  0.169080460464E-01  0.171211501920E-01  0.173369348577E-01  0.175554337604E-01
+  0.177766810410E-01  0.180007112697E-01  0.182275594519E-01  0.184572610329E-01
+  0.186898519041E-01  0.189253684083E-01  0.191638473454E-01  0.194053259783E-01
+  0.196498420385E-01  0.198974337321E-01  0.201481397458E-01  0.204019992529E-01
+  0.206590519196E-01  0.209193379108E-01  0.211828978967E-01  0.214497730591E-01
+  0.217200050978E-01  0.219936362371E-01  0.222707092324E-01  0.225512673770E-01
+  0.228353545086E-01  0.231230150165E-01  0.234142938481E-01  0.237092365163E-01
+  0.240078891066E-01  0.243102982841E-01  0.246165113007E-01  0.249265760029E-01
+  0.252405408390E-01  0.255584548665E-01  0.258803677602E-01  0.262063298197E-01
+  0.265363919771E-01  0.268706058054E-01  0.272090235261E-01  0.275516980177E-01
+  0.278986828238E-01  0.282500321615E-01  0.286058009298E-01  0.289660447183E-01
+  0.293308198158E-01  0.297001832193E-01  0.300741926424E-01  0.304529065249E-01
+  0.308363840416E-01  0.312246851117E-01  0.316178704080E-01  0.320160013664E-01
+  0.324191401959E-01  0.328273498875E-01  0.332406942250E-01  0.336592377943E-01
+  0.340830459935E-01  0.345121850436E-01  0.349467219984E-01  0.353867247553E-01
+  0.358322620656E-01  0.362834035453E-01  0.367402196862E-01  0.372027818669E-01
+  0.376711623635E-01  0.381454343615E-01  0.386256719668E-01  0.391119502176E-01
+  0.396043450958E-01  0.401029335391E-01  0.406077934530E-01  0.411190037229E-01
+  0.416366442263E-01  0.421607958458E-01  0.426915404810E-01  0.432289610618E-01
+  0.437731415614E-01  0.443241670091E-01  0.448821235036E-01  0.454470982268E-01
+  0.460191794573E-01  0.465984565838E-01  0.471850201195E-01  0.477789617162E-01
+  0.483803741786E-01  0.489893514784E-01  0.496059887697E-01  0.502303824033E-01
+  0.508626299420E-01  0.515028301757E-01  0.521510831370E-01  0.528074901167E-01
+  0.534721536799E-01  0.541451776814E-01  0.548266672828E-01  0.555167289681E-01
+  0.562154705608E-01  0.569230012408E-01  0.576394315612E-01  0.583648734656E-01
+  0.590994403059E-01  0.598432468596E-01  0.605964093480E-01  0.613590454543E-01
+  0.621312743418E-01  0.629132166730E-01  0.637049946279E-01  0.645067319235E-01
+  0.653185538328E-01  0.661405872046E-01  0.669729604833E-01  0.678158037290E-01
+  0.686692486376E-01  0.695334285617E-01  0.704084785310E-01  0.712945352740E-01
+  0.721917372388E-01  0.731002246150E-01  0.740201393557E-01  0.749516251993E-01
+  0.758948276925E-01  0.768498942126E-01  0.778169739905E-01  0.787962181346E-01
+  0.797877796538E-01  0.807918134814E-01  0.818084764999E-01  0.828379275649E-01
+  0.838803275302E-01  0.849358392730E-01  0.860046277191E-01  0.870868598688E-01
+  0.881827048233E-01  0.892923338103E-01  0.904159202118E-01  0.915536395904E-01
+  0.927056697171E-01  0.938721905989E-01  0.950533845071E-01  0.962494360057E-01
+  0.974605319800E-01  0.986868616664E-01  0.999286166812E-01  0.101185991051
+  0.102459181244      0.103748386198      0.105053807354      0.106375648687
+  0.107714116737      0.109069420642      0.110441772172      0.111831385759
+  0.113238478533      0.114663270355      0.116105983853      0.117566844452
+  0.119046080416      0.120543922877      0.122060605877      0.123596366401
+  0.125151444414      0.126726082900      0.128320527901      0.129935028550
+  0.131569837118      0.133225209046      0.134901402990      0.136598680858
+  0.138317307853      0.140057552515      0.141819686760      0.143603985925
+  0.145410728811      0.147240197725      0.149092678524      0.150968460664
+  0.152867837238      0.154791105029      0.156738564550      0.158710520097
+  0.160707279790      0.162729155629      0.164776463535      0.166849523404
+  0.168948659157      0.171074198787      0.173226474414      0.175405822335
+  0.177612583079      0.179847101456      0.182109726614      0.184400812093
+  0.186720715880      0.189069800464      0.191448432895      0.193856984838
+  0.196295832636      0.198765357362      0.201265944885      0.203797985927
+  0.206361876125      0.208958016092      0.211586811479      0.214248673041
+  0.216944016700      0.219673263609      0.222436840218      0.225235178341
+  0.228068715225      0.230937893615      0.233843161827      0.236784973814
+  0.239763789240      0.242780073552      0.245834298050      0.248926939963
+  0.252058482522      0.255229415037      0.258440232974      0.261691438028
+  0.264983538208      0.268317047910      0.271692488002      0.275110385904
+  0.278571275669      0.282075698069      0.285624200675      0.289217337950
+  0.292855671328      0.296539769306      0.300270207532      0.304047568894
+  0.307872443613      0.311745429334      0.315667131217      0.319638162038
+  0.323659142277      0.327730700222      0.331853472061      0.336028101985
+  0.340255242290      0.344535553475      0.348869704346      0.353258372124
+  0.357702242546      0.362202009978      0.366758377516      0.371372057102
+  0.376043769634      0.380774245075      0.385564222573      0.390414450570
+  0.395325686925      0.400298699028      0.405334263923      0.410433168428
+  0.415596209255      0.420824193141      0.426117936970      0.431478267898
+  0.436906023490      0.442402051842      0.447967211720      0.453602372692
+  0.459308415263      0.465086231015      0.470936722741      0.476860804595
+  0.482859402225      0.488933452924      0.495083905776      0.501311721801
+  0.507617874109      0.514003348047      0.520469141360      0.527016264340
+  0.533645739990      0.540358604178      0.547155905803      0.554038706957
+  0.561008083092      0.568065123187      0.575210929919      0.582446619834
+  0.589773323524      0.597192185802      0.604704365879      0.612311037550
+  0.620013389371      0.627812624851      0.635709962637      0.643706636704
+  0.651803896548      0.660003007382      0.668305250335      0.676711922649
+  0.685224337882      0.693843826119      0.702571734170      0.711409425790
+  0.720358281885      0.729419700734      0.738595098200      0.747885907958
+  0.757293581717      0.766819589445      0.776465419599      0.786232579360
+  0.796122594867      0.806137011454      0.816277393896      0.826545326646
+  0.836942414091      0.847470280797      0.858130571764      0.868924952684
+  0.879855110202      0.890922752176      0.902129607948      0.913477428613
+  0.924967987290      0.936603079402      0.948384522957      0.960314158829
+  0.972393851047      0.984625487089      0.997010978172       1.00955225955
+   1.02225129084       1.03511005627       1.04813056506       1.06131485169
+   1.07466497623       1.08818302466       1.10187110921       1.11573136867
+   1.12976596873       1.14397710233       1.15836698998       1.17293788014
+   1.18769204953       1.20263180353       1.21775947650       1.23307743217
+   1.24858806400       1.26429379557       1.28019708092       1.29630040497
+   1.31260628390       1.32911726554       1.34583592977       1.36276488890
+   1.37990678812       1.39726430590       1.41484015437       1.43263707979
+   1.45065786298       1.46890531972       1.48738230121       1.50609169452
+   1.52503642302       1.54421944688       1.56364376346       1.58331240788
+   1.60322845338       1.62339501190       1.64381523449       1.66449231187
+   1.68542947486       1.70662999495       1.72809718474       1.74983439855
+   1.77184503284       1.79413252683       1.81670036298       1.83955206757
+   1.86269121122       1.88612140946       1.90984632332       1.93386965985
+   1.95819517276       1.98282666296       2.00776797916       2.03302301850
+   2.05859572713       2.08449010083       2.11071018566       2.13726007855
+   2.16414392799       2.19136593462       2.21893035194       2.24684148696
+   2.27510370083       2.30372140958       2.33269908481       2.36204125431
+   2.39175250287       2.42183747294       2.45230086534       2.48314744004
+   2.51438201689       2.54600947635       2.57803476028       2.61046287269
+   2.64329888054       2.67654791453       2.71021516987       2.74430590716
+   2.77882545313       2.81377920154       2.84917261398       2.88501122075
+   2.92130062169       2.95804648710       2.99525455860       3.03293065003
+   3.07108064834       3.10971051456       3.14882628468       3.18843407062
+   3.22854006118       3.26915052299       3.31027180153       3.35191032208
+   3.39407259075       3.43676519546       3.47999480704       3.52376818019
+   3.56809215459       3.61297365596       3.65841969711       3.70443737910
+   3.75103389226       3.79821651741       3.84599262692       3.89436968591
+   3.94335525340       3.99295698347       4.04318262650       4.09404003034
+   4.14553714158       4.19768200673       4.25048277354       4.30394769224
+   4.35808511683       4.41290350639       4.46841142640       4.52461755010
+   4.58153065980       4.63915964830       4.69751352023       4.75660139351
+   4.81643250075       4.87701619067       4.93836192959       5.00047930292
+   5.06337801662       5.12706789874       5.19155890096       5.25686110012
+   5.32298469983       5.38994003204       5.45773755865       5.52638787316
+   5.59590170232       5.66628990782       5.73756348795       5.80973357935
+   5.88281145875       5.95680854471       6.03173639944       6.10760673055
+   6.18443139295       6.26222239064       6.34099187863       6.42075216480
+   6.50151571186       6.58329513929       6.66610322529       6.74995290878
+   6.83485729145       6.92082963979       7.00788338714       7.09603213584
+   7.18528965930       7.27566990419       7.36718699261       7.45985522430
+   7.55368907884       7.64870321798       7.74491248787       7.84233192139
+   7.94097674054       8.04086235876       8.14200438339       8.24441861808
+   8.34812106526       8.45312792864       8.55945561576       8.66712074055
+   8.77614012589       8.88653080628       8.99831003050       9.11149526428
+   9.22610419303       9.34215472464       9.45966499223       9.57865335704
+   9.69913841122       9.82113898082       9.94467412867       10.0697631574
+   10.1964256124       10.3246812850       10.4545502153       10.5860526957
+   10.7192092736       10.8540407551       10.9905682079       11.1288129646
+   11.2687966263       11.4105410657       11.5540684306       11.6994011476
+   11.8465619251       11.9955737573       12.1464599276       12.2992440123
+   12.4539498842       12.6106017164       12.7692239861       12.9298414783
+   13.0924792899       13.2571628333       13.4239178407       13.5927703678
+   13.7637467983       13.9368738476       14.1121785670       14.2896883483
+   14.4694309279       14.6514343907       14.8357271753       15.0223380778
+   15.2112962564       15.4026312363       15.5963729141       15.7925515621
+   15.9911978337       16.1923427678       16.3960177938       16.6022547362
+   16.8110858199       17.0225436754       17.2366613432       17.4534722797
+   17.6730103621       17.8953098937       18.1204056091       18.3483326800
+   18.5791267206       18.8128237928       19.0494604124       19.2890735541
+   19.5317006582       19.7773796356       20.0261488740       20.2780472443
+   20.5331141060       20.7913893139       21.0529132239       21.3177266998
+   21.5858711192       21.8573883801       22.1323209077       22.4107116609
+   22.6926041386       22.9780423872       23.2670710070       23.5597351592
+   23.8560805733       24.1561535539       24.4600009879       24.7676703521
+   25.0792097205       25.3946677718       25.7140937968       26.0375377067
+   26.3650500401       26.6966819715       27.0324853191       27.3725125528
+   27.7168168026       28.0654518667       28.4184722201       28.7759330228
+   29.1378901290       29.5044000951       29.8755201891       30.2513083991
+   30.6318234430       31.0171247768       31.4072726049       31.8023278885
+   32.2023523558       32.6074085115       33.0175596465       33.4328698476
+   33.8534040079       34.2792278368       34.7104078701       35.1470114806
+   35.5891068884       36.0367631719       36.4900502782       36.9490390345
+   37.4138011585       37.8844092705       38.3609369037       38.8434585167
+   39.3320495045       39.8267862103       40.3277459377       40.8350069629
+   41.3486485462       41.8687509453       42.3953954273       42.9286642813
+   43.4686408318       44.0154094511       44.5690555731       45.1296657059
+   45.6973274461       46.2721294921       46.8541616577       47.4435148867
+   48.0402812667       48.6445540437       49.2564276366       49.8759976518
+   50.5033608984       51.1386154032       51.7818604260       52.4331964752
+   53.0927253233       53.7605500230       54.4367749234       55.1215056859
+   55.8148493011       56.5169141054       57.2278097978       57.9476474572
+   58.6765395598       59.4145999963       60.1619440903       60.9186886157
+   61.6849518155       62.4608534198       63.2465146648       64.0420583118
+   64.8476086659       65.6632915962       66.4892345546       67.3255665965
+   68.1724184005       69.0299222889       69.8982122484       70.7774239510
+   71.6676947755       72.5691638283       73.4819719660       74.4062618166
+   75.3421778023       76.2898661618       77.2494749735       78.2211541781
+   79.2050556025       80.2013329833       81.2101419908       82.2316402535
+   83.2659873827       84.3133449971       85.3738767485       86.4477483471
+   87.5351275876       88.6361843751       89.7510907522       90.8800209250
+   92.0231512913       93.1806604676       94.3527293169       95.5395409774
+   96.7412808910       97.9581368317       99.1902989360       100.437959732
+   101.701314168       102.980559647       104.275896053       105.587525786
+   106.915653789       108.260487586       109.622237310       111.001115737
+   112.397338320       113.811123220       115.242691345       116.692266381
+   118.160074826       119.646346028
+ Down Pseudopotential follows (l on next line)
+  0
+ -0.791543882160E-06 -0.159304416068E-05 -0.240462607162E-05 -0.322641642630E-05
+ -0.405854363112E-05 -0.490113770767E-05 -0.575433031298E-05 -0.661825476013E-05
+ -0.749304603908E-05 -0.837884083773E-05 -0.927577756333E-05 -0.101839963641E-04
+ -0.111036391510E-04 -0.120348496201E-04 -0.129777732750E-04 -0.139325574494E-04
+ -0.148993513303E-04 -0.158783059811E-04 -0.168695743656E-04 -0.178733113714E-04
+ -0.188896738345E-04 -0.199188205636E-04 -0.209609123650E-04 -0.220161120675E-04
+ -0.230845845484E-04 -0.241664967587E-04 -0.252620177492E-04 -0.263713186974E-04
+ -0.274945729338E-04 -0.286319559692E-04 -0.297836455220E-04 -0.309498215460E-04
+ -0.321306662587E-04 -0.333263641693E-04 -0.345371021081E-04 -0.357630692555E-04
+ -0.370044571711E-04 -0.382614598245E-04 -0.395342736249E-04 -0.408230974520E-04
+ -0.421281326871E-04 -0.434495832447E-04 -0.447876556041E-04 -0.461425588417E-04
+ -0.475145046642E-04 -0.489037074406E-04 -0.503103842368E-04 -0.517347548490E-04
+ -0.531770418378E-04 -0.546374705637E-04 -0.561162692215E-04 -0.576136688765E-04
+ -0.591299035005E-04 -0.606652100083E-04 -0.622198282945E-04 -0.637940012716E-04
+ -0.653879749071E-04 -0.670019982627E-04 -0.686363235329E-04 -0.702912060843E-04
+ -0.719669044956E-04 -0.736636805982E-04 -0.753817995168E-04 -0.771215297109E-04
+ -0.788831430169E-04 -0.806669146904E-04 -0.824731234496E-04 -0.843020515180E-04
+ -0.861539846696E-04 -0.880292122725E-04 -0.899280273348E-04 -0.918507265505E-04
+ -0.937976103450E-04 -0.957689829229E-04 -0.977651523153E-04 -0.997864304275E-04
+ -0.101833133089E-03 -0.103905580100E-03 -0.106004095285E-03 -0.108129006542E-03
+ -0.110280645893E-03 -0.112459349534E-03 -0.114665457894E-03 -0.116899315680E-03
+ -0.119161271939E-03 -0.121451680105E-03 -0.123770898059E-03 -0.126119288183E-03
+ -0.128497217419E-03 -0.130905057322E-03 -0.133343184123E-03 -0.135811978783E-03
+ -0.138311827058E-03 -0.140843119552E-03 -0.143406251787E-03 -0.146001624256E-03
+ -0.148629642492E-03 -0.151290717128E-03 -0.153985263962E-03 -0.156713704023E-03
+ -0.159476463635E-03 -0.162273974485E-03 -0.165106673689E-03 -0.167975003863E-03
+ -0.170879413188E-03 -0.173820355486E-03 -0.176798290283E-03 -0.179813682889E-03
+ -0.182867004465E-03 -0.185958732098E-03 -0.189089348877E-03 -0.192259343967E-03
+ -0.195469212687E-03 -0.198719456585E-03 -0.202010583518E-03 -0.205343107732E-03
+ -0.208717549939E-03 -0.212134437404E-03 -0.215594304023E-03 -0.219097690405E-03
+ -0.222645143964E-03 -0.226237218995E-03 -0.229874476767E-03 -0.233557485610E-03
+ -0.237286821000E-03 -0.241063065655E-03 -0.244886809620E-03 -0.248758650363E-03
+ -0.252679192867E-03 -0.256649049724E-03 -0.260668841233E-03 -0.264739195495E-03
+ -0.268860748509E-03 -0.273034144279E-03 -0.277260034904E-03 -0.281539080690E-03
+ -0.285871950245E-03 -0.290259320589E-03 -0.294701877258E-03 -0.299200314411E-03
+ -0.303755334937E-03 -0.308367650567E-03 -0.313037981985E-03 -0.317767058940E-03
+ -0.322555620360E-03 -0.327404414467E-03 -0.332314198895E-03 -0.337285740808E-03
+ -0.342319817020E-03 -0.347417214114E-03 -0.352578728570E-03 -0.357805166884E-03
+ -0.363097345699E-03 -0.368456091928E-03 -0.373882242885E-03 -0.379376646419E-03
+ -0.384940161040E-03 -0.390573656059E-03 -0.396278011722E-03 -0.402054119344E-03
+ -0.407902881456E-03 -0.413825211937E-03 -0.419822036164E-03 -0.425894291152E-03
+ -0.432042925704E-03 -0.438268900557E-03 -0.444573188531E-03 -0.450956774685E-03
+ -0.457420656466E-03 -0.463965843869E-03 -0.470593359593E-03 -0.477304239201E-03
+ -0.484099531281E-03 -0.490980297612E-03 -0.497947613326E-03 -0.505002567082E-03
+ -0.512146261229E-03 -0.519379811985E-03 -0.526704349606E-03 -0.534121018566E-03
+ -0.541630977735E-03 -0.549235400559E-03 -0.556935475245E-03 -0.564732404944E-03
+ -0.572627407943E-03 -0.580621717851E-03 -0.588716583796E-03 -0.596913270617E-03
+ -0.605213059062E-03 -0.613617245991E-03 -0.622127144574E-03 -0.630744084501E-03
+ -0.639469412185E-03 -0.648304490976E-03 -0.657250701374E-03 -0.666309441241E-03
+ -0.675482126025E-03 -0.684770188974E-03 -0.694175081369E-03 -0.703698272742E-03
+ -0.713341251110E-03 -0.723105523209E-03 -0.732992614727E-03 -0.743004070539E-03
+ -0.753141454958E-03 -0.763406351968E-03 -0.773800365482E-03 -0.784325119584E-03
+ -0.794982258788E-03 -0.805773448294E-03 -0.816700374247E-03 -0.827764744000E-03
+ -0.838968286383E-03 -0.850312751973E-03 -0.861799913364E-03 -0.873431565449E-03
+ -0.885209525697E-03 -0.897135634436E-03 -0.909211755146E-03 -0.921439774744E-03
+ -0.933821603883E-03 -0.946359177248E-03 -0.959054453859E-03 -0.971909417379E-03
+ -0.984926076422E-03 -0.998106464866E-03 -0.101145264217E-02 -0.102496669371E-02
+ -0.103865073107E-02 -0.105250689242E-02 -0.106653734281E-02 -0.108074427452E-02
+ -0.109512990741E-02 -0.110969648927E-02 -0.112444629616E-02 -0.113938163275E-02
+ -0.115450483274E-02 -0.116981825914E-02 -0.118532430471E-02 -0.120102539229E-02
+ -0.121692397523E-02 -0.123302253769E-02 -0.124932359512E-02 -0.126582969457E-02
+ -0.128254341518E-02 -0.129946736847E-02 -0.131660419886E-02 -0.133395658402E-02
+ -0.135152723527E-02 -0.136931889808E-02 -0.138733435241E-02 -0.140557641323E-02
+ -0.142404793089E-02 -0.144275179160E-02 -0.146169091788E-02 -0.148086826899E-02
+ -0.150028684144E-02 -0.151994966941E-02 -0.153985982527E-02 -0.156002042001E-02
+ -0.158043460375E-02 -0.160110556627E-02 -0.162203653743E-02 -0.164323078773E-02
+ -0.166469162883E-02 -0.168642241401E-02 -0.170842653876E-02 -0.173070744125E-02
+ -0.175326860293E-02 -0.177611354901E-02 -0.179924584906E-02 -0.182266911755E-02
+ -0.184638701441E-02 -0.187040324559E-02 -0.189472156369E-02 -0.191934576848E-02
+ -0.194427970754E-02 -0.196952727684E-02 -0.199509242137E-02 -0.202097913572E-02
+ -0.204719146474E-02 -0.207373350416E-02 -0.210060940122E-02 -0.212782335531E-02
+ -0.215537961868E-02 -0.218328249704E-02 -0.221153635027E-02 -0.224014559307E-02
+ -0.226911469569E-02 -0.229844818461E-02 -0.232815064324E-02 -0.235822671263E-02
+ -0.238868109223E-02 -0.241951854059E-02 -0.245074387610E-02 -0.248236197779E-02
+ -0.251437778604E-02 -0.254679630336E-02 -0.257962259521E-02 -0.261286179076E-02
+ -0.264651908368E-02 -0.268059973297E-02 -0.271510906381E-02 -0.275005246833E-02
+ -0.278543540649E-02 -0.282126340694E-02 -0.285754206785E-02 -0.289427705784E-02
+ -0.293147411679E-02 -0.296913905681E-02 -0.300727776311E-02 -0.304589619492E-02
+ -0.308500038642E-02 -0.312459644772E-02 -0.316469056574E-02 -0.320528900527E-02
+ -0.324639810987E-02 -0.328802430290E-02 -0.333017408851E-02 -0.337285405266E-02
+ -0.341607086417E-02 -0.345983127573E-02 -0.350414212495E-02 -0.354901033548E-02
+ -0.359444291803E-02 -0.364044697150E-02 -0.368702968409E-02 -0.373419833442E-02
+ -0.378196029265E-02 -0.383032302164E-02 -0.387929407813E-02 -0.392888111392E-02
+ -0.397909187704E-02 -0.402993421298E-02 -0.408141606592E-02 -0.413354547996E-02
+ -0.418633060038E-02 -0.423977967491E-02 -0.429390105504E-02 -0.434870319729E-02
+ -0.440419466455E-02 -0.446038412742E-02 -0.451728036556E-02 -0.457489226907E-02
+ -0.463322883986E-02 -0.469229919308E-02 -0.475211255852E-02 -0.481267828207E-02
+ -0.487400582718E-02 -0.493610477633E-02 -0.499898483253E-02 -0.506265582084E-02
+ -0.512712768989E-02 -0.519241051345E-02 -0.525851449202E-02 -0.532544995438E-02
+ -0.539322735923E-02 -0.546185729684E-02 -0.553135049066E-02 -0.560171779904E-02
+ -0.567297021690E-02 -0.574511887746E-02 -0.581817505397E-02 -0.589215016149E-02
+ -0.596705575864E-02 -0.604290354944E-02 -0.611970538512E-02 -0.619747326597E-02
+ -0.627621934324E-02 -0.635595592100E-02 -0.643669545808E-02 -0.651845057003E-02
+ -0.660123403109E-02 -0.668505877614E-02 -0.676993790278E-02 -0.685588467336E-02
+ -0.694291251701E-02 -0.703103503181E-02 -0.712026598686E-02 -0.721061932443E-02
+ -0.730210916219E-02 -0.739474979536E-02 -0.748855569895E-02 -0.758354153008E-02
+ -0.767972213019E-02 -0.777711252739E-02 -0.787572793884E-02 -0.797558377309E-02
+ -0.807669563248E-02 -0.817907931560E-02 -0.828275081977E-02 -0.838772634350E-02
+ -0.849402228906E-02 -0.860165526500E-02 -0.871064208878E-02 -0.882099978941E-02
+ -0.893274561004E-02 -0.904589701073E-02 -0.916047167114E-02 -0.927648749330E-02
+ -0.939396260440E-02 -0.951291535963E-02 -0.963336434505E-02 -0.975532838047E-02
+ -0.987882652242E-02 -0.100038780671E-01 -0.101305025535E-01 -0.102587197662E-01
+ -0.103885497386E-01 -0.105200127564E-01 -0.106531293601E-01 -0.107879203486E-01
+ -0.109244067825E-01 -0.110626099873E-01 -0.112025515566E-01 -0.113442533555E-01
+ -0.114877375245E-01 -0.116330264821E-01 -0.117801429291E-01 -0.119291098515E-01
+ -0.120799505248E-01 -0.122326885169E-01 -0.123873476921E-01 -0.125439522152E-01
+ -0.127025265545E-01 -0.128630954864E-01 -0.130256840985E-01 -0.131903177942E-01
+ -0.133570222965E-01 -0.135258236516E-01 -0.136967482334E-01 -0.138698227476E-01
+ -0.140450742356E-01 -0.142225300790E-01 -0.144022180038E-01 -0.145841660845E-01
+ -0.147684027488E-01 -0.149549567820E-01 -0.151438573312E-01 -0.153351339103E-01
+ -0.155288164041E-01 -0.157249350734E-01 -0.159235205596E-01 -0.161246038893E-01
+ -0.163282164793E-01 -0.165343901417E-01 -0.167431570884E-01 -0.169545499364E-01
+ -0.171686017131E-01 -0.173853458610E-01 -0.176048162432E-01 -0.178270471487E-01
+ -0.180520732977E-01 -0.182799298469E-01 -0.185106523951E-01 -0.187442769888E-01
+ -0.189808401278E-01 -0.192203787709E-01 -0.194629303414E-01 -0.197085327335E-01
+ -0.199572243176E-01 -0.202090439468E-01 -0.204640309626E-01 -0.207222252012E-01
+ -0.209836669997E-01 -0.212483972023E-01 -0.215164571669E-01 -0.217878887713E-01
+ -0.220627344199E-01 -0.223410370501E-01 -0.226228401392E-01 -0.229081877113E-01
+ -0.231971243438E-01 -0.234896951745E-01 -0.237859459087E-01 -0.240859228264E-01
+ -0.243896727894E-01 -0.246972432485E-01 -0.250086822510E-01 -0.253240384484E-01
+ -0.256433611035E-01 -0.259667000985E-01 -0.262941059426E-01 -0.266256297800E-01
+ -0.269613233976E-01 -0.273012392332E-01 -0.276454303838E-01 -0.279939506138E-01
+ -0.283468543631E-01 -0.287041967561E-01 -0.290660336097E-01 -0.294324214423E-01
+ -0.298034174829E-01 -0.301790796791E-01 -0.305594667072E-01 -0.309446379805E-01
+ -0.313346536589E-01 -0.317295746583E-01 -0.321294626597E-01 -0.325343801193E-01
+ -0.329443902779E-01 -0.333595571707E-01 -0.337799456374E-01 -0.342056213321E-01
+ -0.346366507337E-01 -0.350731011559E-01 -0.355150407580E-01 -0.359625385554E-01
+ -0.364156644299E-01 -0.368744891412E-01 -0.373390843373E-01 -0.378095225659E-01
+ -0.382858772855E-01 -0.387682228769E-01 -0.392566346545E-01 -0.397511888783E-01
+ -0.402519627652E-01 -0.407590345015E-01 -0.412724832545E-01 -0.417923891850E-01
+ -0.423188334596E-01 -0.428518982633E-01 -0.433916668119E-01 -0.439382233652E-01
+ -0.444916532397E-01 -0.450520428219E-01 -0.456194795815E-01 -0.461940520848E-01
+ -0.467758500086E-01 -0.473649641535E-01 -0.479614864583E-01 -0.485655100137E-01
+ -0.491771290769E-01 -0.497964390857E-01 -0.504235366735E-01 -0.510585196835E-01
+ -0.517014871842E-01 -0.523525394843E-01 -0.530117781477E-01 -0.536793060094E-01
+ -0.543552271910E-01 -0.550396471160E-01 -0.557326725268E-01 -0.564344114997E-01
+ -0.571449734622E-01 -0.578644692089E-01 -0.585930109186E-01 -0.593307121708E-01
+ -0.600776879630E-01 -0.608340547280E-01 -0.615999303511E-01 -0.623754341879E-01
+ -0.631606870819E-01 -0.639558113829E-01 -0.647609309645E-01 -0.655761712428E-01
+ -0.664016591952E-01 -0.672375233784E-01 -0.680838939481E-01 -0.689409026773E-01
+ -0.698086829761E-01 -0.706873699107E-01 -0.715771002233E-01 -0.724780123518E-01
+ -0.733902464495E-01 -0.743139444056E-01 -0.752492498649E-01 -0.761963082490E-01
+ -0.771552667762E-01 -0.781262744824E-01 -0.791094822422E-01 -0.801050427898E-01
+ -0.811131107402E-01 -0.821338426105E-01 -0.831673968411E-01 -0.842139338179E-01
+ -0.852736158931E-01 -0.863466074076E-01 -0.874330747126E-01 -0.885331861919E-01
+ -0.896471122832E-01 -0.907750255009E-01 -0.919171004581E-01 -0.930735138884E-01
+ -0.942444446685E-01 -0.954300738404E-01 -0.966305846333E-01 -0.978461624862E-01
+ -0.990769950699E-01 -0.100323272309     -0.101585186403     -0.102862931851
+ -0.104156705471     -0.105466706420     -0.106793136221     -0.108136198779
+ -0.109496100403     -0.110873049828     -0.112267258237     -0.113678939277
+ -0.115108309079     -0.116555586281     -0.118020992044     -0.119504750070
+ -0.121007086622     -0.122528230537     -0.124068413246     -0.125627868788
+ -0.127206833823     -0.128805547651     -0.130424252218     -0.132063192135
+ -0.133722614681     -0.135402769820     -0.137103910204     -0.138826291182
+ -0.140570170804     -0.142335809829     -0.144123471719     -0.145933422647
+ -0.147765931491     -0.149621269832     -0.151499711947     -0.153401534799
+ -0.155327018030     -0.157276443944     -0.159250097493     -0.161248266255
+ -0.163271240412     -0.165319312727     -0.167392778510     -0.169491935587
+ -0.171617084263     -0.173768527278     -0.175946569765     -0.178151519196
+ -0.180383685328     -0.182643380141     -0.184930917773     -0.187246614450
+ -0.189590788403     -0.191963759791     -0.194365850605     -0.196797384574
+ -0.199258687059     -0.201750084943     -0.204271906512     -0.206824481327
+ -0.209408140089     -0.212023214496     -0.214670037090     -0.217348941097
+ -0.220060260256     -0.222804328639     -0.225581480460     -0.228392049880
+ -0.231236370792     -0.234114776607     -0.237027600018     -0.239975172768
+ -0.242957825393     -0.245975886963     -0.249029684812     -0.252119544258
+ -0.255245788310     -0.258408737368     -0.261608708911     -0.264846017185
+ -0.268120972866     -0.271433882733     -0.274785049321     -0.278174770575
+ -0.281603339492     -0.285071043768     -0.288578165431     -0.292124980477
+ -0.295711758508     -0.299338762365     -0.303006247763     -0.306714462939
+ -0.310463648289     -0.314254036031     -0.318085849863     -0.321959304639
+ -0.325874606059     -0.329831950372     -0.333831524095     -0.337873503763
+ -0.341958055686     -0.346085335744     -0.350255489204     -0.354468650564
+ -0.358724943435     -0.363024480453     -0.367367363226     -0.371753682322
+ -0.376183517293     -0.380656936747     -0.385173998454     -0.389734749504
+ -0.394339226504     -0.398987455827     -0.403679453904     -0.408415227564
+ -0.413194774424     -0.418018083323     -0.422885134813     -0.427795901682
+ -0.432750349544     -0.437748437461     -0.442790118619     -0.447875341051
+ -0.453004048402     -0.458176180748     -0.463391675450     -0.468650468063
+ -0.473952493290     -0.479297685975     -0.484685982155     -0.490117320153
+ -0.495591641722     -0.501108893243     -0.506669026978     -0.512272002381
+ -0.517917787467     -0.523606360248     -0.529337710245     -0.535111840062
+ -0.540928767058     -0.546788525090     -0.552691166368     -0.558636763398
+ -0.564625411046     -0.570657228719     -0.576732362678     -0.582850988494
+ -0.589013313651     -0.595219580319     -0.601470068303     -0.607765098180
+ -0.614105034644     -0.620490290066     -0.626921328294     -0.633398668697
+ -0.639922890485     -0.646494637307     -0.653114622157     -0.659783632602
+ -0.666502536353     -0.673272287200     -0.680093931337     -0.686968614087
+ -0.693897587069     -0.700882215815     -0.707923987874     -0.715024521424
+ -0.722185574420     -0.729409054309     -0.736697028340     -0.744051734502
+ -0.751475593123     -0.758971219157     -0.766541435199     -0.774189285272
+ -0.781918049403     -0.789731259043     -0.797632713371     -0.805626496510
+ -0.813716995709     -0.821908920532     -0.830207323096     -0.838617619406
+ -0.847145611836     -0.855797512795     -0.864579969645     -0.873500090897
+ -0.882565473759     -0.891784233073     -0.901165031691     -0.910717112356
+ -0.920450331124     -0.930375192392     -0.940502885566     -0.950845323439
+ -0.961415182315     -0.972225943926     -0.983291939190     -0.994628393854
+  -1.00625147605      -1.01817834582      -1.03042720660      -1.04301735871
+  -1.05596925491      -1.06930455793      -1.08304620003      -1.09721844465
+  -1.11184694993      -1.12695883427      -1.14258274379      -1.15874892157
+  -1.17548927861      -1.19283746655      -1.21082895165      -1.22950109028
+  -1.24889320546      -1.26904666422      -1.29000495566      -1.31181376930
+  -1.33452107331      -1.35817719232      -1.38283488427      -1.40854941579
+  -1.43537863552      -1.46338304464      -1.49262586399      -1.52317309679
+  -1.55509358609      -1.58845906593      -1.62334420511      -1.65982664212
+  -1.69798701007      -1.73790894997      -1.77967911072      -1.82338713399
+  -1.86912562208      -1.91699008650      -1.96707887513      -2.01949307538
+  -2.07433639066      -2.13171498748      -2.19173730996      -2.25451385876
+  -2.32015693087      -2.38878031687      -2.46049895196      -2.53542851681
+  -2.61368498452      -2.69538410956      -2.78064085461      -2.86956875141
+  -2.96227919152      -3.05888064324      -3.15947779094      -3.26417059353
+  -3.37305325918      -3.48621313365      -3.60372950068      -3.72567229326
+  -3.85210071586      -3.98306177869      -4.11858874644      -4.25869950558
+  -4.40339485588      -4.55265673420      -4.70644638048      -4.86470245880
+  -5.02733914887      -5.19424422671      -5.36527715638      -5.54026721840
+  -5.71901170422      -5.90127421013      -6.08678306832      -6.27522995662
+  -6.46626873320      -6.65951454639      -6.85454327359      -7.05089134732
+  -7.24805602922      -7.44549619552      -7.64263369908      -7.83885537400
+  -8.03351574764      -8.22594052328      -8.41543089215      -8.60126872771
+  -8.78272270634      -8.95905538753      -9.12953127192      -9.29342583838
+  -9.45003553942      -9.59868870924      -9.73875730882      -9.86966939855
+  -9.99092218946      -10.1020954803      -10.2028652371      -10.2930170170
+  -10.3724588723      -10.4412333034      -10.4995277428      -10.5476829632
+  -10.5861986912      -10.6157355787      -10.6371125318      -10.6512982077
+  -10.6593954053      -10.6626156549      -10.6622438715      -10.6595877062
+  -10.6559108106      -10.6523454701      -10.6497803474      -10.6487180782
+  -10.6490964913      -10.6503250286      -10.6521985912      -10.6546836389
+  -10.6577477579      -10.6613599736      -10.6654907628      -10.6701120578
+  -10.6751972400      -10.6807211270      -10.6866599512      -10.6929913328
+  -10.6996942470      -10.7067489856      -10.7141371153      -10.7218414321
+  -10.7298459128      -10.7381356640      -10.7466968700      -10.7555167381
+  -10.7645834447      -10.7738860791      -10.7834145887      -10.7931597233
+  -10.8031129798      -10.8132665486      -10.8236132589      -10.8341465271
+  -10.8448603045      -10.8557490274      -10.8668075679      -10.8780311866
+  -10.8894154862      -10.9009563676      -10.9126499865      -10.9244927126
+  -10.9364810899      -10.9486117991      -10.9608816217      -10.9732874057
+  -10.9858260335      -10.9984943910      -11.0112893392      -11.0242076873
+  -11.0372461677      -11.0504014127      -11.0636699334      -11.0770481005
+  -11.0905321260      -11.1041180482      -11.1178017175      -11.1315787842
+  -11.1454446884      -11.1593946511      -11.1734236681      -11.1875265044
+  -11.2016976911      -11.2159315236      -11.2302220616      -11.2445631308
+  -11.2589483258      -11.2733710146      -11.2878243449      -11.3023012513
+  -11.3167944642      -11.3312965196      -11.3457997707      -11.3602963999
+  -11.3747784327      -11.3892377517      -11.4036661126      -11.4180551603
+  -11.4323964457      -11.4466814442      -11.4609015738      -11.4750482141
+  -11.4891127263      -11.5030864727      -11.5169608376      -11.5307272475
+  -11.5443771920      -11.5579022448      -11.5712940842      -11.5845445149
+  -11.5976454874      -11.6105891198      -11.6233677169      -11.6359737908
+  -11.6484000799      -11.6606395679      -11.6726855017      -11.6845314093
+  -11.6961711165      -11.7075987628      -11.7188088163      -11.7297960880
+  -11.7405557449      -11.7510833217      -11.7613747317      -11.7714262766
+  -11.7812346545      -11.7907969673      -11.8001107262      -11.8091738560
+  -11.8179846982      -11.8265420121      -11.8348449756      -11.8428931831
+  -11.8506866429      -11.8582257730      -11.8655113954      -11.8725447291
+  -11.8793273810      -11.8858613371      -11.8921489505      -11.8981929295
+  -11.9039963242      -11.9095625113      -11.9148951795      -11.9199983117
+  -11.9248761687      -11.9295332703      -11.9339743768      -11.9382044693
+  -11.9422287304      -11.9460525234      -11.9496813721      -11.9531209405
+  -11.9563770118      -11.9594554680      -11.9623622698      -11.9651034365
+  -11.9676850261      -11.9701131166      -11.9723937870      -11.9745330998
+  -11.9765370833      -11.9784117158      -11.9801629097      -11.9817964967
+  -11.9833182148      -11.9847336950      -11.9860484498      -11.9872678631
+  -11.9883971799      -11.9894414985      -11.9904057628      -11.9912947560
+  -11.9921130954      -11.9928652280      -11.9935554273      -11.9941877908
+  -11.9947662391      -11.9952945145      -11.9957761822      -11.9962146304
+  -11.9966130729      -11.9969745512      -11.9973019372      -11.9975979373
+  -11.9978650962      -11.9981058015      -11.9983222884      -11.9985166452
+  -11.9986908185      -11.9988466189      -11.9989857269      -11.9997786809
+  -11.9999526337      -11.9999900596      -11.9999979549      -11.9999995876
+  -11.9999999185      -11.9999999842      -11.9999999970      -11.9999999994
+  -11.9999999999      -12.0000000000      -12.0000000000      -12.0000000000
+  -12.0000000000      -12.0000000000      -12.0000000000      -12.0000000000
+  1
+ -0.300012113321E-05 -0.603797914470E-05 -0.911404870598E-05 -0.122288104592E-04
+ -0.153827510921E-04 -0.185763634145E-04 -0.218101464347E-04 -0.250846054380E-04
+ -0.284002520651E-04 -0.317576043926E-04 -0.351571870137E-04 -0.385995311201E-04
+ -0.420851745850E-04 -0.456146620473E-04 -0.491885449966E-04 -0.528073818594E-04
+ -0.564717380863E-04 -0.601821862404E-04 -0.639393060868E-04 -0.677436846832E-04
+ -0.715959164713E-04 -0.754966033704E-04 -0.794463548705E-04 -0.834457881286E-04
+ -0.874955280640E-04 -0.915962074569E-04 -0.957484670469E-04 -0.999529556329E-04
+ -0.104210330175E-03 -0.108521255896E-03 -0.112886406388E-03 -0.117306463713E-03
+ -0.121782118516E-03 -0.126314070125E-03 -0.130903026668E-03 -0.135549705179E-03
+ -0.140254831710E-03 -0.145019141447E-03 -0.149843378823E-03 -0.154728297636E-03
+ -0.159674661163E-03 -0.164683242283E-03 -0.169754823599E-03 -0.174890197555E-03
+ -0.180090166563E-03 -0.185355543129E-03 -0.190687149979E-03 -0.196085820187E-03
+ -0.201552397308E-03 -0.207087735503E-03 -0.212692699682E-03 -0.218368165631E-03
+ -0.224115020153E-03 -0.229934161207E-03 -0.235826498044E-03 -0.241792951355E-03
+ -0.247834453409E-03 -0.253951948204E-03 -0.260146391612E-03 -0.266418751525E-03
+ -0.272770008013E-03 -0.279201153474E-03 -0.285713192786E-03 -0.292307143469E-03
+ -0.298984035841E-03 -0.305744913180E-03 -0.312590831887E-03 -0.319522861650E-03
+ -0.326542085615E-03 -0.333649600547E-03 -0.340846517012E-03 -0.348133959542E-03
+ -0.355513066814E-03 -0.362984991830E-03 -0.370550902092E-03 -0.378211979790E-03
+ -0.385969421982E-03 -0.393824440785E-03 -0.401778263562E-03 -0.409832133112E-03
+ -0.417987307871E-03 -0.426245062100E-03 -0.434606686090E-03 -0.443073486363E-03
+ -0.451646785872E-03 -0.460327924214E-03 -0.469118257833E-03 -0.478019160238E-03
+ -0.487032022213E-03 -0.496158252035E-03 -0.505399275697E-03 -0.514756537127E-03
+ -0.524231498416E-03 -0.533825640046E-03 -0.543540461122E-03 -0.553377479604E-03
+ -0.563338232547E-03 -0.573424276337E-03 -0.583637186941E-03 -0.593978560145E-03
+ -0.604450011811E-03 -0.615053178124E-03 -0.625789715851E-03 -0.636661302597E-03
+ -0.647669637070E-03 -0.658816439345E-03 -0.670103451132E-03 -0.681532436050E-03
+ -0.693105179900E-03 -0.704823490948E-03 -0.716689200203E-03 -0.728704161708E-03
+ -0.740870252823E-03 -0.753189374525E-03 -0.765663451703E-03 -0.778294433455E-03
+ -0.791084293400E-03 -0.804035029977E-03 -0.817148666767E-03 -0.830427252802E-03
+ -0.843872862887E-03 -0.857487597927E-03 -0.871273585252E-03 -0.885232978950E-03
+ -0.899367960205E-03 -0.913680737636E-03 -0.928173547645E-03 -0.942848654761E-03
+ -0.957708352001E-03 -0.972754961223E-03 -0.987990833488E-03 -0.100341834943E-02
+ -0.101903991964E-02 -0.103485798501E-02 -0.105087501715E-02 -0.106709351876E-02
+ -0.108351602399E-02 -0.110014509892E-02 -0.111698334185E-02 -0.113403338381E-02
+ -0.115129788890E-02 -0.116877955472E-02 -0.118648111283E-02 -0.120440532913E-02
+ -0.122255500432E-02 -0.124093297432E-02 -0.125954211072E-02 -0.127838532124E-02
+ -0.129746555017E-02 -0.131678577883E-02 -0.133634902605E-02 -0.135615834863E-02
+ -0.137621684182E-02 -0.139652763978E-02 -0.141709391614E-02 -0.143791888440E-02
+ -0.145900579852E-02 -0.148035795336E-02 -0.150197868525E-02 -0.152387137246E-02
+ -0.154603943578E-02 -0.156848633900E-02 -0.159121558951E-02 -0.161423073880E-02
+ -0.163753538302E-02 -0.166113316358E-02 -0.168502776768E-02 -0.170922292890E-02
+ -0.173372242778E-02 -0.175853009241E-02 -0.178364979906E-02 -0.180908547271E-02
+ -0.183484108775E-02 -0.186092066854E-02 -0.188732829008E-02 -0.191406807860E-02
+ -0.194114421225E-02 -0.196856092174E-02 -0.199632249097E-02 -0.202443325776E-02
+ -0.205289761446E-02 -0.208172000869E-02 -0.211090494400E-02 -0.214045698061E-02
+ -0.217038073608E-02 -0.220068088605E-02 -0.223136216499E-02 -0.226242936690E-02
+ -0.229388734610E-02 -0.232574101797E-02 -0.235799535970E-02 -0.239065541110E-02
+ -0.242372627538E-02 -0.245721311991E-02 -0.249112117709E-02 -0.252545574512E-02
+ -0.256022218884E-02 -0.259542594059E-02 -0.263107250102E-02 -0.266716743997E-02
+ -0.270371639737E-02 -0.274072508404E-02 -0.277819928268E-02 -0.281614484871E-02
+ -0.285456771119E-02 -0.289347387379E-02 -0.293286941565E-02 -0.297276049242E-02
+ -0.301315333717E-02 -0.305405426134E-02 -0.309546965580E-02 -0.313740599179E-02
+ -0.317986982193E-02 -0.322286778130E-02 -0.326640658841E-02 -0.331049304628E-02
+ -0.335513404352E-02 -0.340033655536E-02 -0.344610764480E-02 -0.349245446366E-02
+ -0.353938425373E-02 -0.358690434787E-02 -0.363502217120E-02 -0.368374524223E-02
+ -0.373308117404E-02 -0.378303767545E-02 -0.383362255229E-02 -0.388484370853E-02
+ -0.393670914759E-02 -0.398922697354E-02 -0.404240539241E-02 -0.409625271342E-02
+ -0.415077735033E-02 -0.420598782273E-02 -0.426189275736E-02 -0.431850088948E-02
+ -0.437582106423E-02 -0.443386223799E-02 -0.449263347983E-02 -0.455214397286E-02
+ -0.461240301571E-02 -0.467342002400E-02 -0.473520453173E-02 -0.479776619288E-02
+ -0.486111478282E-02 -0.492526019990E-02 -0.499021246697E-02 -0.505598173296E-02
+ -0.512257827443E-02 -0.519001249724E-02 -0.525829493812E-02 -0.532743626633E-02
+ -0.539744728535E-02 -0.546833893455E-02 -0.554012229087E-02 -0.561280857062E-02
+ -0.568640913117E-02 -0.576093547277E-02 -0.583639924028E-02 -0.591281222510E-02
+ -0.599018636688E-02 -0.606853375551E-02 -0.614786663291E-02 -0.622819739500E-02
+ -0.630953859363E-02 -0.639190293853E-02 -0.647530329928E-02 -0.655975270735E-02
+ -0.664526435815E-02 -0.673185161302E-02 -0.681952800141E-02 -0.690830722293E-02
+ -0.699820314949E-02 -0.708922982753E-02 -0.718140148014E-02 -0.727473250932E-02
+ -0.736923749823E-02 -0.746493121346E-02 -0.756182860736E-02 -0.765994482031E-02
+ -0.775929518319E-02 -0.785989521968E-02 -0.796176064873E-02 -0.806490738702E-02
+ -0.816935155142E-02 -0.827510946155E-02 -0.838219764230E-02 -0.849063282638E-02
+ -0.860043195703E-02 -0.871161219056E-02 -0.882419089911E-02 -0.893818567332E-02
+ -0.905361432509E-02 -0.917049489039E-02 -0.928884563203E-02 -0.940868504253E-02
+ -0.953003184705E-02 -0.965290500626E-02 -0.977732371932E-02 -0.990330742691E-02
+ -0.100308758142E-01 -0.101600488141E-01 -0.102908466100E-01 -0.104232896393E-01
+ -0.105573985967E-01 -0.106931944367E-01 -0.108306983779E-01 -0.109699319054E-01
+ -0.111109167748E-01 -0.112536750151E-01 -0.113982289328E-01 -0.115446011145E-01
+ -0.116928144312E-01 -0.118428920416E-01 -0.119948573955E-01 -0.121487342379E-01
+ -0.123045466122E-01 -0.124623188645E-01 -0.126220756469E-01 -0.127838419218E-01
+ -0.129476429654E-01 -0.131135043720E-01 -0.132814520577E-01 -0.134515122646E-01
+ -0.136237115651E-01 -0.137980768655E-01 -0.139746354107E-01 -0.141534147884E-01
+ -0.143344429331E-01 -0.145177481309E-01 -0.147033590234E-01 -0.148913046129E-01
+ -0.150816142660E-01 -0.152743177190E-01 -0.154694450822E-01 -0.156670268446E-01
+ -0.158670938787E-01 -0.160696774454E-01 -0.162748091986E-01 -0.164825211906E-01
+ -0.166928458767E-01 -0.169058161206E-01 -0.171214651992E-01 -0.173398268081E-01
+ -0.175609350666E-01 -0.177848245234E-01 -0.180115301615E-01 -0.182410874041E-01
+ -0.184735321198E-01 -0.187089006287E-01 -0.189472297073E-01 -0.191885565951E-01
+ -0.194329189997E-01 -0.196803551033E-01 -0.199309035680E-01 -0.201846035426E-01
+ -0.204414946680E-01 -0.207016170840E-01 -0.209650114350E-01 -0.212317188769E-01
+ -0.215017810831E-01 -0.217752402513E-01 -0.220521391099E-01 -0.223325209249E-01
+ -0.226164295062E-01 -0.229039092151E-01 -0.231950049707E-01 -0.234897622571E-01
+ -0.237882271307E-01 -0.240904462270E-01 -0.243964667682E-01 -0.247063365704E-01
+ -0.250201040514E-01 -0.253378182376E-01 -0.256595287724E-01 -0.259852859236E-01
+ -0.263151405910E-01 -0.266491443151E-01 -0.269873492842E-01 -0.273298083435E-01
+ -0.276765750025E-01 -0.280277034441E-01 -0.283832485324E-01 -0.287432658220E-01
+ -0.291078115658E-01 -0.294769427247E-01 -0.298507169759E-01 -0.302291927219E-01
+ -0.306124291002E-01 -0.310004859918E-01 -0.313934240310E-01 -0.317913046149E-01
+ -0.321941899126E-01 -0.326021428756E-01 -0.330152272468E-01 -0.334335075710E-01
+ -0.338570492051E-01 -0.342859183278E-01 -0.347201819502E-01 -0.351599079264E-01
+ -0.356051649641E-01 -0.360560226349E-01 -0.365125513858E-01 -0.369748225498E-01
+ -0.374429083570E-01 -0.379168819461E-01 -0.383968173759E-01 -0.388827896366E-01
+ -0.393748746615E-01 -0.398731493394E-01 -0.403776915258E-01 -0.408885800557E-01
+ -0.414058947557E-01 -0.419297164564E-01 -0.424601270051E-01 -0.429972092785E-01
+ -0.435410471961E-01 -0.440917257325E-01 -0.446493309313E-01 -0.452139499185E-01
+ -0.457856709157E-01 -0.463645832544E-01 -0.469507773897E-01 -0.475443449142E-01
+ -0.481453785728E-01 -0.487539722770E-01 -0.493702211192E-01 -0.499942213882E-01
+ -0.506260705838E-01 -0.512658674320E-01 -0.519137119009E-01 -0.525697052157E-01
+ -0.532339498749E-01 -0.539065496662E-01 -0.545876096829E-01 -0.552772363399E-01
+ -0.559755373908E-01 -0.566826219442E-01 -0.573986004815E-01 -0.581235848732E-01
+ -0.588576883974E-01 -0.596010257565E-01 -0.603537130960E-01 -0.611158680221E-01
+ -0.618876096201E-01 -0.626690584734E-01 -0.634603366816E-01 -0.642615678806E-01
+ -0.650728772610E-01 -0.658943915879E-01 -0.667262392211E-01 -0.675685501348E-01
+ -0.684214559377E-01 -0.692850898941E-01 -0.701595869443E-01 -0.710450837258E-01
+ -0.719417185947E-01 -0.728496316472E-01 -0.737689647416E-01 -0.746998615203E-01
+ -0.756424674326E-01 -0.765969297567E-01 -0.775633976236E-01 -0.785420220398E-01
+ -0.795329559108E-01 -0.805363540656E-01 -0.815523732802E-01 -0.825811723026E-01
+ -0.836229118771E-01 -0.846777547698E-01 -0.857458657941E-01 -0.868274118360E-01
+ -0.879225618803E-01 -0.890314870373E-01 -0.901543605693E-01 -0.912913579175E-01
+ -0.924426567296E-01 -0.936084368876E-01 -0.947888805356E-01 -0.959841721086E-01
+ -0.971944983610E-01 -0.984200483958E-01 -0.996610136943E-01 -0.100917588146
+ -0.102189968078     -0.103478352288     -0.104782942073     -0.106103941260
+ -0.107441556241     -0.108795996003     -0.110167472161     -0.111556198992
+ -0.112962393466     -0.114386275283     -0.115828066905     -0.117287993590
+ -0.118766283432     -0.120263167390     -0.121778879330     -0.123313656055
+ -0.124867737349     -0.126441366011     -0.128034787890     -0.129648251929
+ -0.131282010200     -0.132936317945     -0.134611433614     -0.136307618909
+ -0.138025138820     -0.139764261669     -0.141525259152     -0.143308406381
+ -0.145113981926     -0.146942267861     -0.148793549803     -0.150668116962
+ -0.152566262183     -0.154488281991     -0.156434476642     -0.158405150162
+ -0.160400610401     -0.162421169078     -0.164467141830     -0.166538848261
+ -0.168636611992     -0.170760760712     -0.172911626227     -0.175089544514
+ -0.177294855770     -0.179527904470     -0.181789039416     -0.184078613793
+ -0.186396985222     -0.188744515821     -0.191121572253     -0.193528525791
+ -0.195965752370     -0.198433632648     -0.200932552065     -0.203462900901
+ -0.206025074337     -0.208619472520     -0.211246500620     -0.213906568893
+ -0.216600092750     -0.219327492814     -0.222089194991     -0.224885630531
+ -0.227717236101     -0.230584453843     -0.233487731452     -0.236427522240
+ -0.239404285205     -0.242418485105     -0.245470592528     -0.248561083963
+ -0.251690441878     -0.254859154787     -0.258067717331     -0.261316630351
+ -0.264606400968     -0.267937542655     -0.271310575320     -0.274726025386
+ -0.278184425867     -0.281686316455     -0.285232243598     -0.288822760584
+ -0.292458427627     -0.296139811949     -0.299867487870     -0.303642036892
+ -0.307464047786     -0.311334116685     -0.315252847170     -0.319220850364
+ -0.323238745019     -0.327307157614     -0.331426722447     -0.335598081727
+ -0.339821885674     -0.344098792613     -0.348429469072     -0.352814589880
+ -0.357254838268     -0.361750905969     -0.366303493318     -0.370913309357
+ -0.375581071937     -0.380307507820     -0.385093352788     -0.389939351748
+ -0.394846258835     -0.399814837528     -0.404845860749     -0.409940110980
+ -0.415098380370     -0.420321470845     -0.425610194225     -0.430965372331
+ -0.436387837098     -0.441878430697     -0.447438005638     -0.453067424896
+ -0.458767562019     -0.464539301248     -0.470383537634     -0.476301177151
+ -0.482293136821     -0.488360344822     -0.494503740615     -0.500724275056
+ -0.507022910518     -0.513400621007     -0.519858392280     -0.526397221963
+ -0.533018119672     -0.539722107123     -0.546510218257     -0.553383499349
+ -0.560343009129     -0.567389818891     -0.574525012613     -0.581749687062
+ -0.589064951911     -0.596471929847     -0.603971756676     -0.611565581434
+ -0.619254566486     -0.627039887631     -0.634922734203     -0.642904309163
+ -0.650985829198     -0.659168524807     -0.667453640394     -0.675842434349
+ -0.684336179126     -0.692936161325     -0.701643681758     -0.710460055517
+ -0.719386612040     -0.728424695161     -0.737575663166     -0.746840888836
+ -0.756221759486     -0.765719676995     -0.775336057834     -0.785072333082
+ -0.794929948435     -0.804910364210     -0.815015055334     -0.825245511335
+ -0.835603236313     -0.846089748905     -0.856706582247     -0.867455283911
+ -0.878337415851     -0.889354554320     -0.900508289787     -0.911800226842
+ -0.923231984081     -0.934805193995     -0.946521502828     -0.958382570443
+ -0.970390070160     -0.982545688588     -0.994851125453      -1.00730809340
+  -1.01991831779      -1.03268353650      -1.04560549967      -1.05868596951
+  -1.07192672000      -1.08532953670      -1.09889621643      -1.11262856702
+  -1.12652840705      -1.14059756553      -1.15483788162      -1.16925120437
+  -1.18383939235      -1.19860431342      -1.21354784439      -1.22867187072
+  -1.24397828622      -1.25946899278      -1.27514590002      -1.29101092506
+  -1.30706599220      -1.32331303265      -1.33975398430      -1.35639079140
+  -1.37322540437      -1.39025977953      -1.40749587892      -1.42493567001
+  -1.44258112559      -1.46043422353      -1.47849694659      -1.49677128230
+  -1.51525922276      -1.53396276450      -1.55288390836      -1.57202465929
+  -1.59138702625      -1.61097302208      -1.63078466330      -1.65082396997
+  -1.67109296554      -1.69159367665      -1.71232813288      -1.73329836658
+  -1.75450641253      -1.77595430769      -1.79764409082      -1.81957780210
+  -1.84175748264      -1.86418517405      -1.88686291779      -1.90979275456
+  -1.93297672359      -1.95641686180      -1.98011520296      -2.00407377667
+  -2.02829460729      -2.05277971276      -2.07753110330      -2.10255077997
+  -2.12784073321      -2.15340294109      -2.17923936759      -2.20535196063
+  -2.23174265004      -2.25841334529      -2.28536593317      -2.31260227520
+  -2.34012420500      -2.36793352536      -2.39603200522      -2.42442137644
+  -2.45310333036      -2.48207951417      -2.51135152710      -2.54092091635
+  -2.57078917281      -2.60095772658      -2.63142794217      -2.66220111357
+  -2.69327845890      -2.72466111492      -2.75635013116      -2.78834646382
+  -2.82065096931      -2.85326439749      -2.88618738454      -2.91942044552
+  -2.95296396651      -2.98681819643      -3.02098323837      -3.05545904060
+  -3.09024538706      -3.12534188746      -3.16074796687      -3.19646285484
+  -3.23248557402      -3.26881492824      -3.30544949005      -3.34238758768
+  -3.37962729151      -3.41716639978      -3.45500242387      -3.49313257280
+  -3.53155373715      -3.57026247232      -3.60925498109      -3.64852709552
+  -3.68807425808      -3.72789150221      -3.76797343200      -3.80831420125
+  -3.84890749184      -3.88974649127      -3.93082386961      -3.97213175568
+  -4.01366171259      -4.05540471259      -4.09735111133      -4.13949062150
+  -4.18181228592      -4.22430445014      -4.26695473462      -4.30975000650
+  -4.35267635116      -4.39571904348      -4.43886251911      -4.48209034575
+  -4.52538519459      -4.56872881207      -4.61210199217      -4.65548454930
+  -4.69885529219      -4.74219199878      -4.78547139256      -4.82866912047
+  -4.87175973279      -4.91471666527      -4.95751222381      -5.00011757216
+  -5.04250272301      -5.08463653284      -5.12648670104      -5.16801977383
+  -5.20920115343      -5.24999511303      -5.29036481823      -5.33027235544
+  -5.36967876795      -5.40854410038      -5.44682745204      -5.48448704015
+  -5.52148027345      -5.55776383712      -5.59329378974      -5.62802567302
+  -5.66191463532      -5.69491556961      -5.72698326675      -5.75807258505
+  -5.78813863687      -5.81713699315      -5.84502390682      -5.87175655580
+  -5.89729330670      -5.92159399993      -5.94462025718      -5.96633581230
+  -5.98670686628      -6.00570246761      -6.02329491878      -6.03946021017
+  -6.05417848241      -6.06743451846      -6.07921826683      -6.08952539730
+  -6.09835789097      -6.10572466626      -6.11164224301      -6.11613544684
+  -6.11923815613      -6.12099409438      -6.12145767047      -6.12069487003
+  -6.11878420061      -6.11581769358      -6.11190196553      -6.10715934112
+  -6.10172903898      -6.09576842084      -6.08945430279      -6.08298432489
+  -6.07657837310      -6.07048004325      -6.06495813214      -6.06030813517
+  -6.05685372216      -6.05494815471      -6.05497559750      -6.05735226399
+  -6.06252732242      -6.07098347199      -6.08323708082      -6.09983775729
+  -6.12136720487      -6.14843718812      -6.18168641424      -6.22177611289
+  -6.26938407610      -6.32519690409      -6.38990019164      -6.46416638799
+  -6.54864007280      -6.64392041651      -6.75054063880      -6.86894435007
+  -6.99945876227      -7.14226489322      -7.29736506907      -7.46454825749
+  -7.64335404543      -7.83303641316      -8.03252885347      -8.24041284053
+  -8.45489216509      -8.67377621432      -8.89447587758      -9.11401639078
+  -9.32907222335      -9.53602862618      -9.73107801801      -9.91035525108
+  -10.0701215976      -10.2070049907      -10.3183061245      -10.4023813388
+  -10.4591153398      -10.4904999900      -10.5013388501      -10.5001055818
+  -10.4970850062      -10.4946546132      -10.4927861997      -10.4914524830
+  -10.4906273743      -10.4902859670      -10.4904045186      -10.4909604278
+  -10.4919322091      -10.4932994627      -10.4950428434      -10.4971440259
+  -10.4995856704      -10.5023513860      -10.5054256941      -10.5087939913
+  -10.5124425136      -10.5163582993      -10.5205291040      -10.5249434112
+  -10.5295903986      -10.5344599045      -10.5395423969      -10.5448289423
+  -10.5503111767      -10.5559812773      -10.5618319357      -10.5678563321
+  -10.5740481108      -10.5804013564      -10.5869105713      -10.5935706540
+  -10.6003768782      -10.6073248728      -10.6144106019      -10.6216303495
+  -10.6289806853      -10.6364585106      -10.6440607913      -10.6526474949
+  -10.6613653754      -10.6702133262      -10.6791903278      -10.6882956320
+  -10.6975286636      -10.7068890270      -10.7163764833      -10.7259909353
+  -10.7357324109      -10.7456010470      -10.7555970730      -10.8845274167
+  -10.9781917693      -11.2873857182      -11.5053025981      -11.6581790681
+  -11.7649257010      -11.8391088008      -11.8904145594      -11.9257255820
+  -11.9499085558      -11.9663877753      -11.9775605824      -11.9850968753
+  -11.9901538843      -11.9935294026      -11.9957705366      -11.9972504806
+  -11.9982224260      -11.9988572103      -11.9992694658      -11.9995356795
+  -11.9997065964      -11.9998156897      -11.9998849103      -11.9999285681
+  -11.9999559362      -11.9999729872      -11.9999835442      -11.9999900391
+  -11.9999940095      -11.9999964208      -11.9999978757      -11.9999987476
+  -11.9999992667      -11.9999995736      -11.9999997538      -11.9999998588
+  -11.9999999196      -11.9999999546      -11.9999999745      -11.9999999858
+  -11.9999999922      -11.9999999957      -11.9999999977      -11.9999999987
+  -11.9999999993      -11.9999999996      -11.9999999998      -11.9999999999
+  2
+ -0.637769594389E-05 -0.128356134271E-04 -0.193747615125E-04 -0.259961619552E-04
+ -0.327008493625E-04 -0.394898713554E-04 -0.463642887325E-04 -0.533251756354E-04
+ -0.603736197169E-04 -0.675107223107E-04 -0.747375986037E-04 -0.820553778099E-04
+ -0.894652033472E-04 -0.969682330159E-04 -0.104565639180E-03 -0.112258608949E-03
+ -0.120048344365E-03 -0.127936062591E-03 -0.135922996099E-03 -0.144010392863E-03
+ -0.152199516554E-03 -0.160491646742E-03 -0.168888079087E-03 -0.177390125549E-03
+ -0.185999114591E-03 -0.194716391384E-03 -0.203543318022E-03 -0.212481273728E-03
+ -0.221531655076E-03 -0.230695876208E-03 -0.239975369052E-03 -0.249371583546E-03
+ -0.258885987869E-03 -0.268520068666E-03 -0.278275331281E-03 -0.288153299994E-03
+ -0.298155518258E-03 -0.308283548940E-03 -0.318538974565E-03 -0.328923397564E-03
+ -0.339438440525E-03 -0.350085746444E-03 -0.360866978985E-03 -0.371783822736E-03
+ -0.382837983478E-03 -0.394031188445E-03 -0.405365186598E-03 -0.416841748897E-03
+ -0.428462668580E-03 -0.440229761437E-03 -0.452144866102E-03 -0.464209844333E-03
+ -0.476426581309E-03 -0.488796985918E-03 -0.501322991062E-03 -0.514006553955E-03
+ -0.526849656429E-03 -0.539854305246E-03 -0.553022532407E-03 -0.566356395475E-03
+ -0.579857977894E-03 -0.593529389313E-03 -0.607372765918E-03 -0.621390270765E-03
+ -0.635584094117E-03 -0.649956453788E-03 -0.664509595489E-03 -0.679245793178E-03
+ -0.694167349415E-03 -0.709276595724E-03 -0.724575892956E-03 -0.740067631656E-03
+ -0.755754232441E-03 -0.771638146374E-03 -0.787721855348E-03 -0.804007872476E-03
+ -0.820498742482E-03 -0.837197042096E-03 -0.854105380463E-03 -0.871226399545E-03
+ -0.888562774536E-03 -0.906117214279E-03 -0.923892461692E-03 -0.941891294193E-03
+ -0.960116524137E-03 -0.978570999252E-03 -0.997257603088E-03 -0.101617925546E-02
+ -0.103533891293E-02 -0.105473956922E-02 -0.107438425572E-02 -0.109427604196E-02
+ -0.111441803606E-02 -0.113481338527E-02 -0.115546527639E-02 -0.117637693631E-02
+ -0.119755163254E-02 -0.121899267366E-02 -0.124070340988E-02 -0.126268723354E-02
+ -0.128494757966E-02 -0.130748792646E-02 -0.133031179593E-02 -0.135342275433E-02
+ -0.137682441280E-02 -0.140052042790E-02 -0.142451450217E-02 -0.144881038475E-02
+ -0.147341187190E-02 -0.149832280767E-02 -0.152354708444E-02 -0.154908864355E-02
+ -0.157495147593E-02 -0.160113962269E-02 -0.162765717578E-02 -0.165450827863E-02
+ -0.168169712678E-02 -0.170922796853E-02 -0.173710510565E-02 -0.176533289398E-02
+ -0.179391574418E-02 -0.182285812237E-02 -0.185216455087E-02 -0.188183960885E-02
+ -0.191188793312E-02 -0.194231421877E-02 -0.197312321999E-02 -0.200431975073E-02
+ -0.203590868552E-02 -0.206789496020E-02 -0.210028357269E-02 -0.213307958376E-02
+ -0.216628811787E-02 -0.219991436392E-02 -0.223396357608E-02 -0.226844107460E-02
+ -0.230335224666E-02 -0.233870254721E-02 -0.237449749980E-02 -0.241074269747E-02
+ -0.244744380359E-02 -0.248460655281E-02 -0.252223675186E-02 -0.256034028055E-02
+ -0.259892309262E-02 -0.263799121673E-02 -0.267755075734E-02 -0.271760789572E-02
+ -0.275816889087E-02 -0.279924008053E-02 -0.284082788216E-02 -0.288293879394E-02
+ -0.292557939577E-02 -0.296875635035E-02 -0.301247640417E-02 -0.305674638855E-02
+ -0.310157322079E-02 -0.314696390517E-02 -0.319292553407E-02 -0.323946528909E-02
+ -0.328659044216E-02 -0.333430835669E-02 -0.338262648869E-02 -0.343155238797E-02
+ -0.348109369930E-02 -0.353125816362E-02 -0.358205361921E-02 -0.363348800299E-02
+ -0.368556935166E-02 -0.373830580306E-02 -0.379170559735E-02 -0.384577707836E-02
+ -0.390052869487E-02 -0.395596900194E-02 -0.401210666222E-02 -0.406895044734E-02
+ -0.412650923926E-02 -0.418479203165E-02 -0.424380793131E-02 -0.430356615961E-02
+ -0.436407605388E-02 -0.442534706892E-02 -0.448738877846E-02 -0.455021087662E-02
+ -0.461382317951E-02 -0.467823562665E-02 -0.474345828265E-02 -0.480950133865E-02
+ -0.487637511403E-02 -0.494409005795E-02 -0.501265675101E-02 -0.508208590689E-02
+ -0.515238837404E-02 -0.522357513736E-02 -0.529565731993E-02 -0.536864618474E-02
+ -0.544255313644E-02 -0.551738972315E-02 -0.559316763823E-02 -0.566989872214E-02
+ -0.574759496426E-02 -0.582626850480E-02 -0.590593163664E-02 -0.598659680733E-02
+ -0.606827662095E-02 -0.615098384014E-02 -0.623473138807E-02 -0.631953235047E-02
+ -0.640539997765E-02 -0.649234768662E-02 -0.658038906312E-02 -0.666953786381E-02
+ -0.675980801835E-02 -0.685121363165E-02 -0.694376898602E-02 -0.703748854342E-02
+ -0.713238694772E-02 -0.722847902699E-02 -0.732577979581E-02 -0.742430445763E-02
+ -0.752406840712E-02 -0.762508723260E-02 -0.772737671847E-02 -0.783095284767E-02
+ -0.793583180417E-02 -0.804202997554E-02 -0.814956395544E-02 -0.825845054629E-02
+ -0.836870676182E-02 -0.848034982981E-02 -0.859339719469E-02 -0.870786652037E-02
+ -0.882377569288E-02 -0.894114282329E-02 -0.905998625045E-02 -0.918032454387E-02
+ -0.930217650666E-02 -0.942556117844E-02 -0.955049783832E-02 -0.967700600789E-02
+ -0.980510545431E-02 -0.993481619340E-02 -0.100661584927E-01 -0.101991528747E-01
+ -0.103338201201E-01 -0.104701812709E-01 -0.106082576337E-01 -0.107480707834E-01
+ -0.108896425660E-01 -0.110329951023E-01 -0.111781507916E-01 -0.113251323146E-01
+ -0.114739626375E-01 -0.116246650154E-01 -0.117772629958E-01 -0.119317804225E-01
+ -0.120882414391E-01 -0.122466704929E-01 -0.124070923389E-01 -0.125695320433E-01
+ -0.127340149875E-01 -0.129005668725E-01 -0.130692137222E-01 -0.132399818880E-01
+ -0.134128980529E-01 -0.135879892354E-01 -0.137652827937E-01 -0.139448064304E-01
+ -0.141265881964E-01 -0.143106564954E-01 -0.144970400886E-01 -0.146857680986E-01
+ -0.148768700147E-01 -0.150703756969E-01 -0.152663153809E-01 -0.154647196826E-01
+ -0.156656196031E-01 -0.158690465334E-01 -0.160750322594E-01 -0.162836089668E-01
+ -0.164948092461E-01 -0.167086660977E-01 -0.169252129372E-01 -0.171444836006E-01
+ -0.173665123492E-01 -0.175913338755E-01 -0.178189833084E-01 -0.180494962185E-01
+ -0.182829086239E-01 -0.185192569958E-01 -0.187585782641E-01 -0.190009098232E-01
+ -0.192462895378E-01 -0.194947557492E-01 -0.197463472805E-01 -0.200011034436E-01
+ -0.202590640445E-01 -0.205202693901E-01 -0.207847602942E-01 -0.210525780841E-01
+ -0.213237646069E-01 -0.215983622360E-01 -0.218764138778E-01 -0.221579629785E-01
+ -0.224430535305E-01 -0.227317300800E-01 -0.230240377332E-01 -0.233200221637E-01
+ -0.236197296197E-01 -0.239232069311E-01 -0.242305015168E-01 -0.245416613922E-01
+ -0.248567351766E-01 -0.251757721010E-01 -0.254988220154E-01 -0.258259353972E-01
+ -0.261571633583E-01 -0.264925576538E-01 -0.268321706898E-01 -0.271760555313E-01
+ -0.275242659112E-01 -0.278768562379E-01 -0.282338816045E-01 -0.285953977967E-01
+ -0.289614613023E-01 -0.293321293193E-01 -0.297074597653E-01 -0.300875112866E-01
+ -0.304723432667E-01 -0.308620158366E-01 -0.312565898833E-01 -0.316561270598E-01
+ -0.320606897944E-01 -0.324703413010E-01 -0.328851455883E-01 -0.333051674704E-01
+ -0.337304725764E-01 -0.341611273612E-01 -0.345971991153E-01 -0.350387559757E-01
+ -0.354858669367E-01 -0.359386018601E-01 -0.363970314866E-01 -0.368612274468E-01
+ -0.373312622721E-01 -0.378072094063E-01 -0.382891432172E-01 -0.387771390077E-01
+ -0.392712730282E-01 -0.397716224880E-01 -0.402782655677E-01 -0.407912814312E-01
+ -0.413107502381E-01 -0.418367531565E-01 -0.423693723752E-01 -0.429086911171E-01
+ -0.434547936517E-01 -0.440077653085E-01 -0.445676924903E-01 -0.451346626869E-01
+ -0.457087644883E-01 -0.462900875990E-01 -0.468787228518E-01 -0.474747622220E-01
+ -0.480782988419E-01 -0.486894270151E-01 -0.493082422316E-01 -0.499348411823E-01
+ -0.505693217744E-01 -0.512117831466E-01 -0.518623256847E-01 -0.525210510371E-01
+ -0.531880621308E-01 -0.538634631875E-01 -0.545473597398E-01 -0.552398586476E-01
+ -0.559410681151E-01 -0.566510977076E-01 -0.573700583684E-01 -0.580980624362E-01
+ -0.588352236631E-01 -0.595816572316E-01 -0.603374797733E-01 -0.611028093867E-01
+ -0.618777656558E-01 -0.626624696689E-01 -0.634570440373E-01 -0.642616129144E-01
+ -0.650763020155E-01 -0.659012386371E-01 -0.667365516768E-01 -0.675823716537E-01
+ -0.684388307284E-01 -0.693060627241E-01 -0.701842031470E-01 -0.710733892080E-01
+ -0.719737598438E-01 -0.728854557386E-01 -0.738086193463E-01 -0.747433949127E-01
+ -0.756899284977E-01 -0.766483679986E-01 -0.776188631730E-01 -0.786015656622E-01
+ -0.795966290148E-01 -0.806042087108E-01 -0.816244621860E-01 -0.826575488565E-01
+ -0.837036301432E-01 -0.847628694980E-01 -0.858354324283E-01 -0.869214865234E-01
+ -0.880212014808E-01 -0.891347491322E-01 -0.902623034708E-01 -0.914040406785E-01
+ -0.925601391529E-01 -0.937307795359E-01 -0.949161447412E-01 -0.961164199837E-01
+ -0.973317928076E-01 -0.985624531162E-01 -0.998085932015E-01 -0.101070407774
+ -0.102348093994     -0.103641851501     -0.104951882445     -0.106278391520
+ -0.107621585995     -0.108981675745     -0.110358873284     -0.111753393802
+ -0.113165455192     -0.114595278091     -0.116043085909     -0.117509104868
+ -0.118993564033     -0.120496695352     -0.122018733690     -0.123559916867
+ -0.125120485693     -0.126700684007     -0.128300758716     -0.129920959833
+ -0.131561540513     -0.133222757099     -0.134904869155     -0.136608139512
+ -0.138332834306     -0.140079223020     -0.141847578527     -0.143638177134
+ -0.145451298619     -0.147287226285     -0.149146246992     -0.151028651214
+ -0.152934733074     -0.154864790397     -0.156819124753     -0.158798041506
+ -0.160801849860     -0.162830862909     -0.164885397683     -0.166965775203
+ -0.169072320524     -0.171205362793     -0.173365235294     -0.175552275504
+ -0.177766825145     -0.180009230238     -0.182279841155     -0.184579012673
+ -0.186907104036     -0.189264479002     -0.191651505906     -0.194068557715
+ -0.196516012090     -0.198994251438     -0.201503662977     -0.204044638796
+ -0.206617575916     -0.209222876350     -0.211860947168     -0.214532200559
+ -0.217237053897     -0.219975929806     -0.222749256225     -0.225557466474
+ -0.228400999324     -0.231280299065     -0.234195815573     -0.237148004385
+ -0.240137326764     -0.243164249776     -0.246229246362     -0.249332795409
+ -0.252475381828     -0.255657496628     -0.258879636994     -0.262142306363
+ -0.265446014505     -0.268791277598     -0.272178618315     -0.275608565900
+ -0.279081656253     -0.282598432015     -0.286159442650     -0.289765244531
+ -0.293416401030     -0.297113482603     -0.300857066879     -0.304647738750
+ -0.308486090467     -0.312372721725     -0.316308239762     -0.320293259451
+ -0.324328403397     -0.328414302034     -0.332551593725     -0.336740924858
+ -0.340982949950     -0.345278331746     -0.349627741327     -0.354031858210
+ -0.358491370457     -0.363006974780     -0.367579376652     -0.372209290414
+ -0.376897439391     -0.381644555998     -0.386451381863     -0.391318667932
+ -0.396247174597     -0.401237671805     -0.406290939183     -0.411407766161
+ -0.416588952089     -0.421835306366     -0.427147648566     -0.432526808563
+ -0.437973626663     -0.443488953731     -0.449073651329     -0.454728591845
+ -0.460454658630     -0.466252746137     -0.472123760058     -0.478068617465
+ -0.484088246955     -0.490183588792     -0.496355595052     -0.502605229773
+ -0.508933469104     -0.515341301455     -0.521829727655     -0.528399761100
+ -0.535052427916     -0.541788767115     -0.548609830758     -0.555516684115
+ -0.562510405833     -0.569592088101     -0.576762836819     -0.584023771769
+ -0.591376026790     -0.598820749949     -0.606359103721     -0.613992265169
+ -0.621721426122     -0.629547793362     -0.637472588808     -0.645497049703
+ -0.653622428808     -0.661849994589     -0.670181031416     -0.678616839758
+ -0.687158736380     -0.695808054552     -0.704566144242     -0.713434372331
+ -0.722414122818     -0.731506797031     -0.740713813838     -0.750036609869
+ -0.759476639726     -0.769035376211     -0.778714310542     -0.788514952583
+ -0.798438831070     -0.808487493843     -0.818662508075     -0.828965460509
+ -0.839397957698     -0.849961626242     -0.860658113031     -0.871489085489
+ -0.882456231826     -0.893561261283     -0.904805904384     -0.916191913197
+ -0.927721061584     -0.939395145463     -0.951215983073     -0.963185415234
+ -0.975305305615     -0.987577541006      -1.00000403158      -1.01258671119
+  -1.02532753760      -1.03822849281      -1.05129158331      -1.06451884038
+  -1.07791232035      -1.09147410489      -1.10520630132      -1.11911104288
+  -1.13319048903      -1.14744682572      -1.16188226573      -1.17649904892
+  -1.19129944255      -1.20628574157      -1.22146026892      -1.23682537583
+  -1.25238344214      -1.26813687655      -1.28408811698      -1.30023963084
+  -1.31659391533      -1.33315349776      -1.34992093582      -1.36689881792
+  -1.38408976346      -1.40149642315      -1.41912147929      -1.43696764605
+  -1.45503766982      -1.47333432946      -1.49186043656      -1.51061883581
+  -1.52961240521      -1.54884405638      -1.56831673483      -1.58803342022
+  -1.60799712667      -1.62821090296      -1.64867783282      -1.66940103520
+  -1.69038366448      -1.71162891071      -1.73313999985      -1.75492019402
+  -1.77697279167      -1.79930112779      -1.82190857415      -1.84479853945
+  -1.86797446951      -1.89143984744      -1.91519819379      -1.93925306671
+  -1.96360806209      -1.98826681365      -2.01323299309      -2.03851031016
+  -2.06410251277      -2.09001338706      -2.11624675743      -2.14280648665
+  -2.16969647581      -2.19692066442      -2.22448303035      -2.25238758989
+  -2.28063839766      -2.30923954663      -2.33819516804      -2.36750943135
+  -2.39718654417      -2.42723075219      -2.45764633903      -2.48843762619
+  -2.51960897289      -2.55116477595      -2.58310946967      -2.61544752562
+  -2.64818345255      -2.68132179616      -2.71486713894      -2.74882409998
+  -2.78319733480      -2.81799153507      -2.85321142846      -2.88886177840
+  -2.92494738380      -2.96147307888      -2.99844373281      -3.03586424953
+  -3.07373956739      -3.11207465890      -3.15087453033      -3.19014422143
+  -3.22988880499      -3.27011338647      -3.31082310354      -3.35202312556
+  -3.39371865310      -3.43591491731      -3.47861717929      -3.52183072938
+  -3.56556088637      -3.60981299663      -3.65459243315      -3.69990459448
+  -3.74575490357      -3.79214880648      -3.83909177096      -3.88658928489
+  -3.93464685456      -3.98327000281      -4.03246426696      -4.08223519660
+  -4.13258835109      -4.18352929695      -4.23506360495      -4.28719684698
+  -4.33993459265      -4.39328240564      -4.44724583974      -4.50183043459
+  -4.55704171111      -4.61288516658      -4.66936626937      -4.72649045330
+  -4.78426311161      -4.84268959049      -4.90177518225      -4.96152511792
+  -5.02194455952      -5.08303859170      -5.14481221293      -5.20727032614
+  -5.27041772874      -5.33425910213      -5.39879900044      -5.46404183878
+  -5.52999188062      -5.59665322461      -5.66402979055      -5.73212530454
+  -5.80094328342      -5.87048701818      -5.94075955662      -6.01176368494
+  -6.08350190840      -6.15597643090      -6.22918913356      -6.30314155201
+  -6.37783485272      -6.45326980786      -6.52944676912      -6.60636563999
+  -6.68402584679      -6.76242630822      -6.84156540343      -6.92144093850
+  -7.00205011140      -7.08338947521      -7.16545489974      -7.24824153125
+  -7.33174375052      -7.41595512889      -7.50086838257      -7.58647532482
+  -7.67276681630      -7.75973271325      -7.84736181371      -7.93564180156
+  -8.02455918855      -8.11409925410      -8.20424598302      -8.29498200115
+  -8.38628850878      -8.47814521208      -8.57053025247      -8.66342013396
+  -8.75678964868      -8.85061180045      -8.94485772681      -9.03949661932
+  -9.13449564261      -9.22981985210      -9.32543211076      -9.42129300512
+  -9.51736076084      -9.61359115812      -9.70993744733      -9.80635026526
+  -9.90277755255      -9.99916447258      -10.0954533327      -10.1915835078
+  -10.2874913683      -10.3831102108      -10.4783701953      -10.5731982873
+  -10.6675182068      -10.7612503858      -10.8543119334      -10.9466166128
+  -11.0380748279      -11.1285936236      -11.2180767000      -11.3064244417
+  -11.3935339654      -11.4792991845      -11.5636108961      -11.6463568888
+  -11.7274220752      -11.8066886504      -11.8840362783      -11.9593423075
+  -12.0324820192      -12.1033289086      -12.1717550020      -12.2376312112
+  -12.3008277274      -12.3612144554      -12.4186614906      -12.4730396400
+  -12.5242209872      -12.5720795040      -12.6164917077      -12.6573373655
+  -12.6945002452      -12.7278689109      -12.7573375647      -12.7828069303
+  -12.8041851781      -12.8213888874      -12.8343440430      -12.8429870618
+  -12.8472658429      -12.8471408361      -12.8425861223      -12.8335904952
+  -12.8201585384      -12.8023116853      -12.7800892521      -12.7535494314
+  -12.7227702328      -12.6878503571      -12.6489099877      -12.6060914848
+  -12.5595599640      -12.5095037411      -12.4561346261      -12.3996880457
+  -12.3404229736      -12.2786216496      -12.2145890648      -12.1486521913
+  -12.0811589342      -12.0124767824      -11.9429911364      -11.8731032872
+  -11.8032280234      -11.7337908428      -11.6652247424      -11.5979665640
+  -11.5324528724      -11.4691153439      -11.4083756479      -11.3506398070
+  -11.2962920305      -11.2456880247      -11.1991478009      -11.1569480201
+  -11.1193139456      -11.0864111084      -11.0583368419      -11.0351119068
+  -11.0166725037      -11.0028630753      -10.9934304211      -10.9880197984
+  -10.9861738655      -10.9873355392      -10.9908560910      -10.9960101104
+  -11.0020193041      -11.0080875125      -11.0134497841      -11.0174389002
+  -11.0195733736      -11.0196716966      -11.0179985013      -11.0154493519
+  -11.0133511378      -11.0120057937      -11.0113775971      -11.0114309402
+  -11.0121305032      -11.0134415255      -11.0153300803      -11.0177633220
+  -11.0207096688      -11.0241389939      -11.0280220687      -11.0323313077
+  -11.0370402850      -11.0421238675      -11.0475582150      -11.0533207712
+  -11.0593902476      -11.0657465994      -11.0723709970      -11.0792457903
+  -11.0863544698      -11.0936816239      -11.1012128922      -11.1089349180
+  -11.1168352976      -11.1249025293      -11.1331259620      -11.1414957424
+  -11.1500027636      -11.1586386139      -11.1673955261      -11.1762663279
+  -11.1852443945      -11.1943236012      -11.2034982791      -11.2127631716
+  -11.2221133925      -11.2315443874      -11.2410518953      -11.2506319131
+  -11.2602806619      -11.2699945554      -11.2797701694      -11.2896042147
+  -11.2994935101      -11.3094349589      -11.3194255258      -11.3294622166
+  -11.3395420590      -11.3496620852      -11.3598193161      -11.3700107470
+  -11.3802333351      -11.3904839879      -11.4007595534      -11.4110568116
+  -11.4213724669      -11.4317031425      -11.4420453751      -11.4523956115
+  -11.4627502059      -11.4731054182      -11.4834574137      -11.4938022632
+  -11.5041359447      -11.5144543454      -11.5247532648      -11.5350284187
+  -11.5452754436      -11.5554899020      -11.5656672889      -11.5758030379
+  -11.5858925287      -11.5959310947      -11.6059140317      -11.6158366062
+  -11.6256940650      -11.6354816443      -11.6451945802      -11.6548281185
+  -11.6643775253      -11.6738380977      -11.6832051744      -11.6924741472
+  -11.7016404715      -11.7106996774      -11.7196473811      -11.7284792956
+  -11.7371912413      -11.7457791573      -11.7542391113      -11.7625673100
+  -11.7707601094      -11.7788140238      -11.7867257352      -11.7944921023
+  -11.8021101685      -11.8095771699      -11.8168905423      -11.8240479280
+  -11.8310471819      -11.8378863768      -11.8445638081      -11.8510779979
+  -11.8574276981      -11.8636118930      -11.8696298014      -11.8754808770
+  -11.8811648094      -11.8866815229      -11.8920311752      -11.8972141560
+  -11.9022310832      -11.9070828000      -11.9117703701      -11.9162950728
+  -11.9206583970      -11.9248620351      -11.9289078756      -11.9327979958
+  -11.9365346529      -11.9401202761      -11.9435574565      -11.9468489384
+  -11.9499976083      -11.9530064853      -11.9558787101      -11.9586175342
+  -11.9612263090      -11.9637084746      -11.9660675488      -11.9683071154
+  -11.9704308138      -11.9724423276      -11.9743453736      -11.9761436911
+  -11.9778410321      -11.9794411501      -11.9809477912      -11.9823646842
+  -11.9836955316      -11.9849440008      -11.9861137163      -11.9872082516
+  -11.9882311224      -11.9891857795      -11.9900756028      -11.9909038960
+  -11.9916738809      -11.9923886933      -11.9930513792      -11.9936648906
+  -11.9942320834      -11.9947557145      -11.9952384402      -11.9956828147
+  -11.9960912889      -11.9964662105      -11.9968098236      -11.9971242690
+  -11.9974115853      -11.9976737098      -11.9979124797      -11.9981296345
+  -11.9983268175      -11.9985055781      -11.9989423440      -11.9991278660
+  -11.9992413002      -11.9993298869      -11.9998391236      -11.9999620719
+  -11.9999912208      -11.9999980053      -11.9999995552      -11.9999999027
+  -11.9999999791      -11.9999999956      -11.9999999991      -11.9999999998
+  3
+ -0.885696401124E-05 -0.178253349151E-04 -0.269065140377E-04 -0.361019203319E-04
+ -0.454129905986E-04 -0.548411797114E-04 -0.643879608441E-04 -0.740548257006E-04
+ -0.838432847482E-04 -0.937548674537E-04 -0.103791122522E-03 -0.113953618138E-03
+ -0.124243942213E-03 -0.134663702631E-03 -0.145214527500E-03 -0.155898065408E-03
+ -0.166715985680E-03 -0.177669978638E-03 -0.188761755866E-03 -0.199993050476E-03
+ -0.211365617381E-03 -0.222881233568E-03 -0.234541698375E-03 -0.246348833774E-03
+ -0.258304484653E-03 -0.270410519107E-03 -0.282668828729E-03 -0.295081328904E-03
+ -0.307649959111E-03 -0.320376683225E-03 -0.333263489821E-03 -0.346312392489E-03
+ -0.359525430147E-03 -0.372904667359E-03 -0.386452194658E-03 -0.400170128872E-03
+ -0.414060613457E-03 -0.428125818830E-03 -0.442367942706E-03 -0.456789210448E-03
+ -0.471391875407E-03 -0.486178219280E-03 -0.501150552462E-03 -0.516311214412E-03
+ -0.531662574013E-03 -0.547207029948E-03 -0.562947011068E-03 -0.578884976777E-03
+ -0.595023417417E-03 -0.611364854649E-03 -0.627911841858E-03 -0.644666964544E-03
+ -0.661632840728E-03 -0.678812121364E-03 -0.696207490749E-03 -0.713821666945E-03
+ -0.731657402202E-03 -0.749717483391E-03 -0.768004732436E-03 -0.786522006757E-03
+ -0.805272199715E-03 -0.824258241067E-03 -0.843483097420E-03 -0.862949772698E-03
+ -0.882661308606E-03 -0.902620785114E-03 -0.922831320930E-03 -0.943296073992E-03
+ -0.964018241958E-03 -0.985001062709E-03 -0.100624781485E-02 -0.102776181824E-02
+ -0.104954643448E-02 -0.107160506746E-02 -0.109394116388E-02 -0.111655821381E-02
+ -0.113945975120E-02 -0.116264935448E-02 -0.118613064705E-02 -0.120990729793E-02
+ -0.123398302225E-02 -0.125836158191E-02 -0.128304678610E-02 -0.130804249193E-02
+ -0.133335260504E-02 -0.135898108018E-02 -0.138493192185E-02 -0.141120918493E-02
+ -0.143781697528E-02 -0.146475945044E-02 -0.149204082022E-02 -0.151966534738E-02
+ -0.154763734832E-02 -0.157596119372E-02 -0.160464130923E-02 -0.163368217619E-02
+ -0.166308833229E-02 -0.169286437229E-02 -0.172301494877E-02 -0.175354477282E-02
+ -0.178445861478E-02 -0.181576130500E-02 -0.184745773459E-02 -0.187955285619E-02
+ -0.191205168472E-02 -0.194495929818E-02 -0.197828083847E-02 -0.201202151214E-02
+ -0.204618659124E-02 -0.208078141413E-02 -0.211581138632E-02 -0.215128198132E-02
+ -0.218719874148E-02 -0.222356727887E-02 -0.226039327614E-02 -0.229768248743E-02
+ -0.233544073926E-02 -0.237367393143E-02 -0.241238803796E-02 -0.245158910800E-02
+ -0.249128326680E-02 -0.253147671665E-02 -0.257217573786E-02 -0.261338668974E-02
+ -0.265511601158E-02 -0.269737022367E-02 -0.274015592832E-02 -0.278347981088E-02
+ -0.282734864080E-02 -0.287176927267E-02 -0.291674864731E-02 -0.296229379283E-02
+ -0.300841182575E-02 -0.305510995212E-02 -0.310239546860E-02 -0.315027576367E-02
+ -0.319875831870E-02 -0.324785070920E-02 -0.329756060596E-02 -0.334789577624E-02
+ -0.339886408503E-02 -0.345047349621E-02 -0.350273207388E-02 -0.355564798352E-02
+ -0.360922949338E-02 -0.366348497565E-02 -0.371842290789E-02 -0.377405187424E-02
+ -0.383038056684E-02 -0.388741778718E-02 -0.394517244742E-02 -0.400365357187E-02
+ -0.406287029830E-02 -0.412283187945E-02 -0.418354768445E-02 -0.424502720025E-02
+ -0.430728003317E-02 -0.437031591032E-02 -0.443414468120E-02 -0.449877631918E-02
+ -0.456422092309E-02 -0.463048871877E-02 -0.469759006071E-02 -0.476553543363E-02
+ -0.483433545413E-02 -0.490400087234E-02 -0.497454257365E-02 -0.504597158032E-02
+ -0.511829905329E-02 -0.519153629388E-02 -0.526569474554E-02 -0.534078599569E-02
+ -0.541682177750E-02 -0.549381397169E-02 -0.557177460847E-02 -0.565071586934E-02
+ -0.573065008903E-02 -0.581158975743E-02 -0.589354752152E-02 -0.597653618737E-02
+ -0.606056872214E-02 -0.614565825606E-02 -0.623181808457E-02 -0.631906167030E-02
+ -0.640740264524E-02 -0.649685481285E-02 -0.658743215021E-02 -0.667914881022E-02
+ -0.677201912378E-02 -0.686605760209E-02 -0.696127893883E-02 -0.705769801254E-02
+ -0.715532988889E-02 -0.725418982306E-02 -0.735429326212E-02 -0.745565584743E-02
+ -0.755829341711E-02 -0.766222200848E-02 -0.776745786059E-02 -0.787401741676E-02
+ -0.798191732714E-02 -0.809117445131E-02 -0.820180586092E-02 -0.831382884234E-02
+ -0.842726089941E-02 -0.854211975610E-02 -0.865842335934E-02 -0.877618988182E-02
+ -0.889543772478E-02 -0.901618552095E-02 -0.913845213742E-02 -0.926225667859E-02
+ -0.938761848917E-02 -0.951455715720E-02 -0.964309251711E-02 -0.977324465280E-02
+ -0.990503390082E-02 -0.100384808535E-01 -0.101736063622E-01 -0.103104315405E-01
+ -0.104489777677E-01 -0.105892666919E-01 -0.107313202336E-01 -0.108751605888E-01
+ -0.110208102329E-01 -0.111682919240E-01 -0.113176287064E-01 -0.114688439143E-01
+ -0.116219611753E-01 -0.117770044143E-01 -0.119339978572E-01 -0.120929660345E-01
+ -0.122539337853E-01 -0.124169262611E-01 -0.125819689298E-01 -0.127490875798E-01
+ -0.129183083236E-01 -0.130896576022E-01 -0.132631621895E-01 -0.134388491957E-01
+ -0.136167460725E-01 -0.137968806164E-01 -0.139792809740E-01 -0.141639756456E-01
+ -0.143509934901E-01 -0.145403637295E-01 -0.147321159533E-01 -0.149262801231E-01
+ -0.151228865774E-01 -0.153219660365E-01 -0.155235496068E-01 -0.157276687863E-01
+ -0.159343554690E-01 -0.161436419500E-01 -0.163555609309E-01 -0.165701455244E-01
+ -0.167874292597E-01 -0.170074460879E-01 -0.172302303871E-01 -0.174558169677E-01
+ -0.176842410781E-01 -0.179155384101E-01 -0.181497451044E-01 -0.183868977561E-01
+ -0.186270334209E-01 -0.188701896204E-01 -0.191164043484E-01 -0.193657160763E-01
+ -0.196181637597E-01 -0.198737868439E-01 -0.201326252706E-01 -0.203947194839E-01
+ -0.206601104364E-01 -0.209288395961E-01 -0.212009489524E-01 -0.214764810229E-01
+ -0.217554788602E-01 -0.220379860581E-01 -0.223240467590E-01 -0.226137056605E-01
+ -0.229070080224E-01 -0.232039996736E-01 -0.235047270199E-01 -0.238092370503E-01
+ -0.241175773453E-01 -0.244297960836E-01 -0.247459420501E-01 -0.250660646431E-01
+ -0.253902138825E-01 -0.257184404172E-01 -0.260507955334E-01 -0.263873311621E-01
+ -0.267280998877E-01 -0.270731549560E-01 -0.274225502826E-01 -0.277763404612E-01
+ -0.281345807722E-01 -0.284973271913E-01 -0.288646363985E-01 -0.292365657866E-01
+ -0.296131734702E-01 -0.299945182950E-01 -0.303806598470E-01 -0.307716584615E-01
+ -0.311675752329E-01 -0.315684720239E-01 -0.319744114754E-01 -0.323854570164E-01
+ -0.328016728735E-01 -0.332231240812E-01 -0.336498764921E-01 -0.340819967873E-01
+ -0.345195524862E-01 -0.349626119579E-01 -0.354112444313E-01 -0.358655200061E-01
+ -0.363255096638E-01 -0.367912852786E-01 -0.372629196290E-01 -0.377404864087E-01
+ -0.382240602384E-01 -0.387137166777E-01 -0.392095322362E-01 -0.397115843861E-01
+ -0.402199515740E-01 -0.407347132334E-01 -0.412559497967E-01 -0.417837427082E-01
+ -0.423181744366E-01 -0.428593284879E-01 -0.434072894184E-01 -0.439621428482E-01
+ -0.445239754742E-01 -0.450928750838E-01 -0.456689305687E-01 -0.462522319387E-01
+ -0.468428703358E-01 -0.474409380484E-01 -0.480465285257E-01 -0.486597363924E-01
+ -0.492806574636E-01 -0.499093887592E-01 -0.505460285197E-01 -0.511906762214E-01
+ -0.518434325918E-01 -0.525043996252E-01 -0.531736805991E-01 -0.538513800898E-01
+ -0.545376039893E-01 -0.552324595213E-01 -0.559360552584E-01 -0.566485011388E-01
+ -0.573699084834E-01 -0.581003900136E-01 -0.588400598684E-01 -0.595890336228E-01
+ -0.603474283053E-01 -0.611153624165E-01 -0.618929559475E-01 -0.626803303989E-01
+ -0.634776087994E-01 -0.642849157252E-01 -0.651023773195E-01 -0.659301213123E-01
+ -0.667682770402E-01 -0.676169754664E-01 -0.684763492018E-01 -0.693465325251E-01
+ -0.702276614040E-01 -0.711198735166E-01 -0.720233082726E-01 -0.729381068355E-01
+ -0.738644121441E-01 -0.748023689353E-01 -0.757521237667E-01 -0.767138250392E-01
+ -0.776876230202E-01 -0.786736698676E-01 -0.796721196529E-01 -0.806831283858E-01
+ -0.817068540380E-01 -0.827434565686E-01 -0.837930979487E-01 -0.848559421864E-01
+ -0.859321553532E-01 -0.870219056092E-01 -0.881253632297E-01 -0.892427006321E-01
+ -0.903740924021E-01 -0.915197153218E-01 -0.926797483967E-01 -0.938543728838E-01
+ -0.950437723205E-01 -0.962481325522E-01 -0.974676417623E-01 -0.987024905012E-01
+ -0.999528717161E-01 -0.101218980781     -0.102501015528     -0.103799176276
+ -0.105113665866     -0.106444689689     -0.107792455719     -0.109157174547
+ -0.110539059412     -0.111938326236     -0.113355193657     -0.114789883062
+ -0.116242618625     -0.117713627336     -0.119203139043     -0.120711386485
+ -0.122238605328     -0.123785034202     -0.125350914738     -0.126936491608
+ -0.128542012560     -0.130167728459     -0.131813893326     -0.133480764377
+ -0.135168602061     -0.136877670106     -0.138608235556     -0.140360568814
+ -0.142134943684     -0.143931637416     -0.145750930743     -0.147593107934
+ -0.149458456830     -0.151347268895     -0.153259839257     -0.155196466758
+ -0.157157453998     -0.159143107383     -0.161153737174     -0.163189657533
+ -0.165251186576     -0.167338646418     -0.169452363226     -0.171592667271
+ -0.173759892978     -0.175954378976     -0.178176468156     -0.180426507722
+ -0.182704849244     -0.185011848713     -0.187347866601     -0.189713267911
+ -0.192108422239     -0.194533703829     -0.196989491633     -0.199476169367
+ -0.201994125578     -0.204543753695     -0.207125452100     -0.209739624184
+ -0.212386678411     -0.215067028384     -0.217781092908     -0.220529296056
+ -0.223312067235     -0.226129841251     -0.228983058382     -0.231872164443
+ -0.234797610856     -0.237759854720     -0.240759358885     -0.243796592023
+ -0.246872028698     -0.249986149447     -0.253139440847     -0.256332395600
+ -0.259565512600     -0.262839297020     -0.266154260384     -0.269510920652
+ -0.272909802298     -0.276351436392     -0.279836360685     -0.283365119690
+ -0.286938264771     -0.290556354224     -0.294219953370     -0.297929634638
+ -0.301685977658     -0.305489569349     -0.309341004014     -0.313240883429
+ -0.317189816940     -0.321188421556     -0.325237322047     -0.329337151040
+ -0.333488549120     -0.337692164929     -0.341948655265     -0.346258685187
+ -0.350622928121     -0.355042065961     -0.359516789176     -0.364047796921
+ -0.368635797142     -0.373281506691     -0.377985651434     -0.382748966368
+ -0.387572195730     -0.392456093120     -0.397401421616     -0.402408953889
+ -0.407479472332     -0.412613769175     -0.417812646611     -0.423076916922
+ -0.428407402604     -0.433804936500     -0.439270361922     -0.444804532790
+ -0.450408313763     -0.456082580370     -0.461828219154     -0.467646127804
+ -0.473537215297     -0.479502402043     -0.485542620022     -0.491658812937
+ -0.497851936355     -0.504122957859     -0.510472857198     -0.516902626443
+ -0.523413270134     -0.530005805446     -0.536681262341     -0.543440683732
+ -0.550285125641     -0.557215657372     -0.564233361668     -0.571339334886
+ -0.578534687168     -0.585820542610     -0.593198039438     -0.600668330189
+ -0.608232581886     -0.615891976224     -0.623647709750     -0.631500994050
+ -0.639453055940     -0.647505137655     -0.655658497042     -0.663914407757
+ -0.672274159463     -0.680739058027     -0.689310425728     -0.697989601461
+ -0.706777940942     -0.715676816923     -0.724687619401     -0.733811755838
+ -0.743050651374     -0.752405749055     -0.761878510051     -0.771470413884
+ -0.781182958660     -0.791017661296     -0.800976057761     -0.811059703308
+ -0.821270172718     -0.831609060543     -0.842077981352     -0.852678569979
+ -0.863412481780     -0.874281392882     -0.885287000446     -0.896431022928
+ -0.907715200342     -0.919141294530     -0.930711089430     -0.942426391353
+ -0.954289029260     -0.966300855039     -0.978463743794     -0.990779594128
+  -1.00325032844      -1.01587789320      -1.02866425929      -1.04161142223
+  -1.05472140257      -1.06799624614      -1.08143802435      -1.09504883456
+  -1.10883080036      -1.12278607189      -1.13691682618      -1.15122526746
+  -1.16571362753      -1.18038416602      -1.19523917083      -1.21028095838
+  -1.22551187401      -1.24093429232      -1.25655061751      -1.27236328374
+  -1.28837475550      -1.30458752796      -1.32100412735      -1.33762711132
+  -1.35445906933      -1.37150262299      -1.38876042650      -1.40623516696
+  -1.42392956482      -1.44184637425      -1.45998838352      -1.47835841541
+  -1.49695932759      -1.51579401307      -1.53486540054      -1.55417645484
+  -1.57373017732      -1.59352960628      -1.61357781739      -1.63387792409
+  -1.65443307802      -1.67524646944      -1.69632132766      -1.71766092145
+  -1.73926855948      -1.76114759074      -1.78330140499      -1.80573343315
+  -1.82844714776      -1.85144606342      -1.87473373719      -1.89831376903
+  -1.92218980226      -1.94636552393      -1.97084466532      -1.99563100229
+  -2.02072835577      -2.04614059213      -2.07187162365      -2.09792540888
+  -2.12430595309      -2.15101730866      -2.17806357550      -2.20544890142
+  -2.23317748254      -2.26125356367      -2.28968143869      -2.31846545090
+  -2.34760999343      -2.37711950951      -2.40699849291      -2.43725148819
+  -2.46788309105      -2.49889794866      -2.53030075992      -2.56209627575
+  -2.59428929936      -2.62688468651      -2.65988734573      -2.69330223853
+  -2.72713437962      -2.76138883708      -2.79607073252      -2.83118524121
+  -2.86673759219      -2.90273306841      -2.93917700672      -2.97607479799
+  -3.01343188709      -3.05125377286      -3.08954600815      -3.12831419964
+  -3.16756400786      -3.20730114698      -3.24753138467      -3.28826054193
+  -3.32949449284      -3.37123916429      -3.41350053570      -3.45628463867
+  -3.49959755657      -3.54344542418      -3.58783442717      -3.63277080163
+  -3.67826083348      -3.72431085789      -3.77092725862      -3.81811646730
+  -3.86588496268      -3.91423926979      -3.96318595906      -4.01273164537
+  -4.06288298702      -4.11364668461      -4.16502947989      -4.21703815447
+  -4.26967952847      -4.32296045902      -4.37688783875      -4.43146859406
+  -4.48670968331      -4.54261809487      -4.59920084506      -4.65646497585
+  -4.71441755246      -4.77306566076      -4.83241640446      -4.89247690207
+  -4.95325428369      -5.01475568747      -5.07698825590      -5.13995913172
+  -5.20367545359      -5.26814435142      -5.33337294134      -5.39936832028
+  -5.46613756022      -5.53368770194      -5.60202574838      -5.67115865751
+  -5.74109333464      -5.81183662430      -5.88339530150      -5.95577606234
+  -6.02898551409      -6.10303016455      -6.17791641073      -6.25365052675
+  -6.33023865103      -6.40768677261      -6.48600071665      -6.56518612900
+  -6.64524845986      -6.72619294640      -6.80802459437      -6.89074815867
+  -6.97436812266      -7.05888867639      -7.14431369351      -7.23064670694
+  -7.31789088305      -7.40604899461      -7.49512339201      -7.58511597313
+  -7.67602815149      -7.76786082269      -7.86061432913      -7.95428842290
+  -8.04888222672      -8.14439419294      -8.24082206043      -8.33816280939
+  -8.43641261389      -8.53556679213      -8.63561975440      -8.73656494843
+  -8.83839480238      -8.94110066514      -9.04467274394      -9.14910003924
+  -9.25437027685      -9.36046983704      -9.46738368083      -9.57509527323
+  -9.68358650344      -9.79283760196      -9.90282705462      -10.0135315135
+  -10.1249257044      -10.2369823320      -10.3496719808      -10.4629630136
+  -10.5768214673      -10.6912109451      -10.8060925058      -10.9214245513
+  -11.0371627106      -11.1532597219      -11.2696653124      -11.3863260762
+  -11.5031853509      -11.6201830924      -11.7372557497      -11.8543361381
+  -11.9713533139      -12.0882324483      -12.2048947039      -12.3212571120
+  -12.4372324535      -12.5527291427      -12.6676511160      -12.7818977256
+  -12.8953636399      -13.0079387516      -13.1195080947      -13.2299517717
+  -13.3391448926      -13.4469575266      -13.5532546697      -13.6578962279
+  -13.7607370195      -13.8616267971      -13.9604102927      -14.0569272869
+  -14.1510127043      -14.2424967381      -14.3312050064      -14.4169587406
+  -14.4995750110      -14.5788669892      -14.6546442522      -14.7267131288
+  -14.7948770903      -14.8589371901      -14.9186925504      -14.9739409016
+  -15.0244791736      -15.0701041410      -15.1106131242      -15.1458047455
+  -15.1754797427      -15.1994418378      -15.2174986622      -15.2294627371
+  -15.2351525060      -15.2343934194      -15.2270190674      -15.2128723571
+  -15.1918067307      -15.1636874208      -15.1283927347      -15.0858153655
+  -15.0358637204      -14.9784632613      -14.9135578493      -14.8411110862
+  -14.7611076462      -14.6735545891      -14.5784826488      -14.4759474919
+  -14.3660309388      -14.2488421455      -14.1245187419      -13.9932279265
+  -13.8551675190      -13.7105669732      -13.5596883581      -13.4028273132
+  -13.2403139924      -13.0725140057      -12.8998293773      -12.7226995330
+  -12.5416023350      -12.3570551751      -12.1696161404      -11.9798852517
+  -11.7885057722      -11.5961655681      -11.4035984844      -11.2115856817
+  -11.0209568463      -10.8325911589      -10.6474178629      -10.4664162312
+  -10.2906146788      -10.1210887133      -9.95895735609      -9.80537761138
+  -9.66153650124      -9.52864013844      -9.40789927384      -9.30051074079
+  -9.20763423504      -9.13036392466      -9.06969449298      -9.02648139225
+  -9.00139534103      -8.99487144970      -9.00705382164      -9.03773706622
+  -9.08630688835      -9.15168279641      -9.23226700485      -9.32590480234
+  -9.42986301203      -9.54083468824      -9.65497987684      -9.76801413029
+  -9.87535854876      -9.97236749021      -10.0546528830      -10.1185274892
+  -10.1615938040      -10.1835109187      -10.1869790795      -10.1789912134
+  -10.1693594933      -10.1604520195      -10.1522350666      -10.1446730023
+  -10.1377304001      -10.1313723167      -10.1255645714      -10.1202740002
+  -10.1154686426      -10.1111179397      -10.1071921822      -10.1036632609
+  -10.1005041891      -10.0976892408      -10.0951939564      -10.0929951389
+  -10.0910708429      -10.0894003562      -10.0879641755      -10.0867439766
+  -10.0857225801      -10.0848839132      -10.0842129683      -10.0836957597
+  -10.0833192777      -10.0830714421      -10.0829410545      -10.0829177503
+  -10.0829919505      -10.0831548145      -10.0833981902      -10.0837145697
+  -10.0840970445      -10.0845392609      -10.0850353766      -10.0855800190
+  -10.0861682445      -10.0867954987      -10.0874443667      -10.0881364049
+  -10.0888683262      -10.0896371669      -10.0904402610      -10.0912752159
+  -10.0921398893      -10.0930323683      -10.0939509489      -10.0948941180
+  -10.0958605358      -10.0968490200      -10.0978585311      -10.0988881585
+  -10.0999371078      -10.1010046891      -10.1020903062      -10.1031934469
+  -10.1043136734      -10.1054506143      -10.1066039566      -10.1077734388
+  -10.1089588446      -10.1101599964      -10.1113767507      -10.1126089923
+  -10.1138566304      -10.1151195941      -10.1163978287      -10.1176912922
+  -10.1189999525      -10.1203237837      -10.1216627644      -10.1230168743
+  -10.1243860930      -10.1257703969      -10.1271697582      -10.1285841426
+  -10.1300135080      -10.1314578029      -10.1329169650      -10.1343909201
+  -10.1358795806      -10.1373828450      -10.1389005960      -10.1404327006
+  -10.1419790082      -10.1435393505      -10.1451135404      -10.1467013712
+  -10.1483026163      -10.1499170279      -10.1515443371      -10.1531842528
+  -10.1548364614      -10.1565006262      -10.1581763870      -10.1598633597
+  -10.1615611355      -10.1632692811      -10.1649873378      -10.1667148214
+  -10.1684512219      -10.1701960032      -10.1719486024      -10.1737084305
+  -10.1754748711      -10.1772472809      -10.1790249892      -10.1808072978
+  -10.1825934810      -10.1843827852      -10.1861744286      -10.1879676017
+  -10.1897614665      -10.1915551565      -10.1933477767      -10.1951384018
+  -10.1969260787      -10.1987098267      -10.2004886396      -10.2022614869
+  -10.2040273166      -10.2057850594      -10.2075336336      -10.2092719524
+  -10.2109989343      -10.2127135136      -10.2144146579      -10.2161013844
+  -10.2177727734      -10.2194279741      -10.2210662015      -10.2226867231
+  -10.2242888418      -10.2258718775      -10.2274351509      -10.2289779714
+  -10.2304996284      -10.2319993869      -10.2334765107      -10.2349302616
+  -10.2363599014      -10.2377646933      -10.2391439046      -10.2404968078
+  -10.2418226833      -10.2431208206      -10.2443905211      -10.2456311000
+  -10.2468418880      -10.2480222342      -10.2491715078      -10.2502891006
+  -10.2513744290      -10.2524269368      -10.2534460972      -10.2544314153
+  -10.2553824306      -10.2562987193      -10.2571798968      -10.2580256202
+  -10.2588355909      -10.2596095568      -10.2603473151      -10.2610487146
+  -10.2617136581      -10.2623421050      -10.2629340737      -10.2634896439
+  -10.2640089589      -10.2644922278      -10.2649397280      -10.2653518068
+  -10.2657288840      -10.2660714533      -10.2663800842      -10.2666554240
+  -10.2668981989      -10.2671092154      -10.2672893616      -10.2674396082
+  -10.2675610091      -10.2676547019      -10.2677219086      -10.2677639350
+  -10.2677821710      -10.2677780899      -10.2677532476      -10.2677092811
+  -10.2676479077      -10.2675709227      -10.2674801970      -10.2673776753
+  -10.2672653722      -10.2671453696      -10.2670198125      -10.2668909049
+  -10.2667609053      -10.2666321214      -10.2665069050      -10.2663876458
+  -10.2662767652      -10.2661767096      -10.2660899431      -10.2660189398
+  -10.2659661762      -10.2659341228      -10.2659252348      -10.2659419438
+  -10.2659866482      -10.2660617033      -10.2661694117      -10.2663120133
+  -10.2664916747      -10.2667104793      -10.2669704165      -10.2672733716
+  -10.2676211154      -10.2680152938      -10.2684574180      -10.2689488551
+  -10.2694908181      -10.2700843578      -10.2707303541      -10.2714295086
+  -10.2721823382      -10.2729891686      -10.2738501303      -10.2747651545
+  -10.2757339715      -10.2767561095      -10.2778308961      -10.2789574607
+  -10.2801347401      -10.2813614849      -10.2826362695      -10.2839575041
+  -10.2853234501      -10.2867322374      -10.2881818866      -10.2896703332
+  -10.2911954564      -10.2927551115      -10.2943471666      -10.2959695435
+  -10.2976202636      -10.2992974981      -10.3009996253      -10.3027252855
+  -10.3044908469      -10.3063130396      -10.3082090061      -10.3101963410
+  -10.3122931310      -10.3145179890      -10.3168900843      -10.3194291651
+  -10.3221555747      -10.3250902573      -10.3282547550      -10.3316711928
+  -10.3353622509      -10.3393511235      -10.3436614627      -10.3483173071
+  -10.3533429938      -10.3587630547      -10.3646020960      -10.3708846625
+  -10.3776350880      -10.3848773328      -10.3926348128      -10.4009302225
+  -10.4097853580      -10.4192209458      -10.4292564854      -10.4399101149
+  -10.4511985111      -10.4631368372      -10.4757387545      -10.4890165160
+  -10.5029811649      -10.5176428633      -10.5330113828      -10.5490967983
+  -10.5659104348      -10.5834661393      -10.6017819884      -10.6208826154
+  -10.6408025372      -10.6615914546      -10.6833251791      -10.7061488374
+  -10.7298217022      -10.7542449826      -10.7794028753      -10.8053850406
+  -10.8323371723      -10.8604717659      -10.8900821243      -10.9215610952
+  -10.9554268335      -10.9923592162      -11.0332529075      -11.0792974177
+  -11.1321035069      -11.1939140843      -11.2686073221      -11.3617809275
+  -11.4827713741      -11.6516802418
+ Up Pseudopotential follows (l on next line)
+  1
+ -0.776594917730E-06 -0.156295819700E-05 -0.235921270867E-05 -0.316548286913E-05
+ -0.398189465973E-05 -0.480857564648E-05 -0.564565499996E-05 -0.649326351552E-05
+ -0.735153363372E-05 -0.822059946101E-05 -0.910059679070E-05 -0.999166312415E-05
+ -0.108939376923E-04 -0.118075614774E-04 -0.127326772350E-04 -0.136694295163E-04
+ -0.146179646908E-04 -0.155784309690E-04 -0.165509784257E-04 -0.175357590235E-04
+ -0.185329266364E-04 -0.195426370737E-04 -0.205650481048E-04 -0.216003194836E-04
+ -0.226486129732E-04 -0.237100923717E-04 -0.247849235373E-04 -0.258732744147E-04
+ -0.269753150609E-04 -0.280912176719E-04 -0.292211566098E-04 -0.303653084299E-04
+ -0.315238519083E-04 -0.326969680696E-04 -0.338848402157E-04 -0.350876539541E-04
+ -0.363055972267E-04 -0.375388603398E-04 -0.387876359932E-04 -0.400521193107E-04
+ -0.413325078703E-04 -0.426290017353E-04 -0.439418034856E-04 -0.452711182490E-04
+ -0.466171537339E-04 -0.479801202608E-04 -0.493602307961E-04 -0.507577009850E-04
+ -0.521727491849E-04 -0.536055965000E-04 -0.550564668156E-04 -0.565255868331E-04
+ -0.580131861056E-04 -0.595194970735E-04 -0.610447551009E-04 -0.625891985125E-04
+ -0.641530686307E-04 -0.657366098134E-04 -0.673400694921E-04 -0.689636982107E-04
+ -0.706077496644E-04 -0.722724807397E-04 -0.739581515541E-04 -0.756650254972E-04
+ -0.773933692715E-04 -0.791434529341E-04 -0.809155499394E-04 -0.827099371809E-04
+ -0.845268950354E-04 -0.863667074062E-04 -0.882296617678E-04 -0.901160492105E-04
+ -0.920261644862E-04 -0.939603060544E-04 -0.959187761286E-04 -0.979018807237E-04
+ -0.999099297039E-04 -0.101943236831E-03 -0.104002119813E-03 -0.106086900355E-03
+ -0.108197904208E-03 -0.110335461220E-03 -0.112499905390E-03 -0.114691574916E-03
+ -0.116910812251E-03 -0.119157964155E-03 -0.121433381751E-03 -0.123737420576E-03
+ -0.126070440643E-03 -0.128432806489E-03 -0.130824887239E-03 -0.133247056661E-03
+ -0.135699693224E-03 -0.138183180157E-03 -0.140697905510E-03 -0.143244262214E-03
+ -0.145822648143E-03 -0.148433466174E-03 -0.151077124253E-03 -0.153754035457E-03
+ -0.156464618059E-03 -0.159209295592E-03 -0.161988496920E-03 -0.164802656296E-03
+ -0.167652213440E-03 -0.170537613600E-03 -0.173459307626E-03 -0.176417752039E-03
+ -0.179413409102E-03 -0.182446746892E-03 -0.185518239374E-03 -0.188628366475E-03
+ -0.191777614160E-03 -0.194966474504E-03 -0.198195445773E-03 -0.201465032501E-03
+ -0.204775745568E-03 -0.208128102278E-03 -0.211522626444E-03 -0.214959848468E-03
+ -0.218440305423E-03 -0.221964541137E-03 -0.225533106279E-03 -0.229146558445E-03
+ -0.232805462244E-03 -0.236510389387E-03 -0.240261918777E-03 -0.244060636597E-03
+ -0.247907136405E-03 -0.251802019224E-03 -0.255745893639E-03 -0.259739375886E-03
+ -0.263783089957E-03 -0.267877667689E-03 -0.272023748868E-03 -0.276221981329E-03
+ -0.280473021053E-03 -0.284777532275E-03 -0.289136187582E-03 -0.293549668024E-03
+ -0.298018663216E-03 -0.302543871447E-03 -0.307125999791E-03 -0.311765764214E-03
+ -0.316463889689E-03 -0.321221110307E-03 -0.326038169395E-03 -0.330915819627E-03
+ -0.335854823146E-03 -0.340855951681E-03 -0.345919986669E-03 -0.351047719376E-03
+ -0.356239951020E-03 -0.361497492899E-03 -0.366821166513E-03 -0.372211803698E-03
+ -0.377670246751E-03 -0.383197348566E-03 -0.388793972763E-03 -0.394460993827E-03
+ -0.400199297240E-03 -0.406009779625E-03 -0.411893348880E-03 -0.417850924327E-03
+ -0.423883436848E-03 -0.429991829035E-03 -0.436177055337E-03 -0.442440082208E-03
+ -0.448781888260E-03 -0.455203464411E-03 -0.461705814047E-03 -0.468289953173E-03
+ -0.474956910573E-03 -0.481707727975E-03 -0.488543460206E-03 -0.495465175363E-03
+ -0.502473954979E-03 -0.509570894190E-03 -0.516757101907E-03 -0.524033700989E-03
+ -0.531401828420E-03 -0.538862635485E-03 -0.546417287951E-03 -0.554066966246E-03
+ -0.561812865649E-03 -0.569656196472E-03 -0.577598184252E-03 -0.585640069940E-03
+ -0.593783110098E-03 -0.602028577092E-03 -0.610377759292E-03 -0.618831961277E-03
+ -0.627392504031E-03 -0.636060725158E-03 -0.644837979084E-03 -0.653725637273E-03
+ -0.662725088440E-03 -0.671837738768E-03 -0.681065012126E-03 -0.690408350295E-03
+ -0.699869213190E-03 -0.709449079090E-03 -0.719149444870E-03 -0.728971826230E-03
+ -0.738917757939E-03 -0.748988794067E-03 -0.759186508236E-03 -0.769512493858E-03
+ -0.779968364389E-03 -0.790555753582E-03 -0.801276315736E-03 -0.812131725962E-03
+ -0.823123680439E-03 -0.834253896683E-03 -0.845524113813E-03 -0.856936092823E-03
+ -0.868491616858E-03 -0.880192491491E-03 -0.892040545010E-03 -0.904037628695E-03
+ -0.916185617116E-03 -0.928486408421E-03 -0.940941924633E-03 -0.953554111953E-03
+ -0.966324941059E-03 -0.979256407420E-03 -0.992350531605E-03 -0.100560935960E-02
+ -0.101903496311E-02 -0.103262943993E-02 -0.104639491422E-02 -0.106033353686E-02
+ -0.107444748578E-02 -0.108873896634E-02 -0.110321021158E-02 -0.111786348269E-02
+ -0.113270106925E-02 -0.114772528968E-02 -0.116293849153E-02 -0.117834305191E-02
+ -0.119394137780E-02 -0.120973590649E-02 -0.122572910588E-02 -0.124192347496E-02
+ -0.125832154412E-02 -0.127492587561E-02 -0.129173906387E-02 -0.130876373600E-02
+ -0.132600255215E-02 -0.134345820591E-02 -0.136113342477E-02 -0.137903097051E-02
+ -0.139715363967E-02 -0.141550426394E-02 -0.143408571064E-02 -0.145290088318E-02
+ -0.147195272145E-02 -0.149124420234E-02 -0.151077834019E-02 -0.153055818725E-02
+ -0.155058683416E-02 -0.157086741043E-02 -0.159140308495E-02 -0.161219706645E-02
+ -0.163325260404E-02 -0.165457298769E-02 -0.167616154876E-02 -0.169802166049E-02
+ -0.172015673858E-02 -0.174257024168E-02 -0.176526567193E-02 -0.178824657556E-02
+ -0.181151654337E-02 -0.183507921135E-02 -0.185893826120E-02 -0.188309742095E-02
+ -0.190756046552E-02 -0.193233121732E-02 -0.195741354681E-02 -0.198281137318E-02
+ -0.200852866486E-02 -0.203456944026E-02 -0.206093776829E-02 -0.208763776905E-02
+ -0.211467361448E-02 -0.214204952899E-02 -0.216976979010E-02 -0.219783872918E-02
+ -0.222626073204E-02 -0.225504023970E-02 -0.228418174899E-02 -0.231368981335E-02
+ -0.234356904346E-02 -0.237382410803E-02 -0.240445973445E-02 -0.243548070962E-02
+ -0.246689188062E-02 -0.249869815552E-02 -0.253090450410E-02 -0.256351595867E-02
+ -0.259653761485E-02 -0.262997463233E-02 -0.266383223571E-02 -0.269811571532E-02
+ -0.273283042801E-02 -0.276798179804E-02 -0.280357531787E-02 -0.283961654906E-02
+ -0.287611112314E-02 -0.291306474244E-02 -0.295048318106E-02 -0.298837228569E-02
+ -0.302673797659E-02 -0.306558624847E-02 -0.310492317145E-02 -0.314475489202E-02
+ -0.318508763395E-02 -0.322592769933E-02 -0.326728146948E-02 -0.330915540604E-02
+ -0.335155605187E-02 -0.339449003217E-02 -0.343796405546E-02 -0.348198491465E-02
+ -0.352655948808E-02 -0.357169474062E-02 -0.361739772475E-02 -0.366367558165E-02
+ -0.371053554233E-02 -0.375798492875E-02 -0.380603115499E-02 -0.385468172835E-02
+ -0.390394425059E-02 -0.395382641908E-02 -0.400433602800E-02 -0.405548096960E-02
+ -0.410726923536E-02 -0.415970891732E-02 -0.421280820928E-02 -0.426657540810E-02
+ -0.432101891503E-02 -0.437614723697E-02 -0.443196898784E-02 -0.448849288990E-02
+ -0.454572777512E-02 -0.460368258657E-02 -0.466236637980E-02 -0.472178832429E-02
+ -0.478195770482E-02 -0.484288392299E-02 -0.490457649865E-02 -0.496704507138E-02
+ -0.503029940202E-02 -0.509434937419E-02 -0.515920499583E-02 -0.522487640077E-02
+ -0.529137385029E-02 -0.535870773476E-02 -0.542688857523E-02 -0.549592702510E-02
+ -0.556583387176E-02 -0.563662003830E-02 -0.570829658521E-02 -0.578087471209E-02
+ -0.585436575942E-02 -0.592878121033E-02 -0.600413269238E-02 -0.608043197939E-02
+ -0.615769099329E-02 -0.623592180595E-02 -0.631513664109E-02 -0.639534787619E-02
+ -0.647656804443E-02 -0.655880983662E-02 -0.664208610320E-02 -0.672640985627E-02
+ -0.681179427157E-02 -0.689825269061E-02 -0.698579862267E-02 -0.707444574700E-02
+ -0.716420791488E-02 -0.725509915184E-02 -0.734713365981E-02 -0.744032581938E-02
+ -0.753469019201E-02 -0.763024152232E-02 -0.772699474041E-02 -0.782496496416E-02
+ -0.792416750162E-02 -0.802461785338E-02 -0.812633171502E-02 -0.822932497954E-02
+ -0.833361373983E-02 -0.843921429124E-02 -0.854614313406E-02 -0.865441697614E-02
+ -0.876405273549E-02 -0.887506754292E-02 -0.898747874472E-02 -0.910130390536E-02
+ -0.921656081026E-02 -0.933326746855E-02 -0.945144211587E-02 -0.957110321725E-02
+ -0.969226946999E-02 -0.981495980655E-02 -0.993919339755E-02 -0.100649896547E-01
+ -0.101923682341E-01 -0.103213490386E-01 -0.104519522220E-01 -0.105841981911E-01
+ -0.107181076098E-01 -0.108537014016E-01 -0.109910007532E-01 -0.111300271181E-01
+ -0.112708022194E-01 -0.114133480534E-01 -0.115576868933E-01 -0.117038412922E-01
+ -0.118518340872E-01 -0.120016884023E-01 -0.121534276526E-01 -0.123070755477E-01
+ -0.124626560953E-01 -0.126201936053E-01 -0.127797126931E-01 -0.129412382841E-01
+ -0.131047956168E-01 -0.132704102474E-01 -0.134381080536E-01 -0.136079152384E-01
+ -0.137798583346E-01 -0.139539642087E-01 -0.141302600650E-01 -0.143087734500E-01
+ -0.144895322570E-01 -0.146725647298E-01 -0.148578994675E-01 -0.150455654292E-01
+ -0.152355919380E-01 -0.154280086858E-01 -0.156228457383E-01 -0.158201335391E-01
+ -0.160199029148E-01 -0.162221850798E-01 -0.164270116409E-01 -0.166344146029E-01
+ -0.168444263729E-01 -0.170570797655E-01 -0.172724080083E-01 -0.174904447467E-01
+ -0.177112240495E-01 -0.179347804138E-01 -0.181611487707E-01 -0.183903644907E-01
+ -0.186224633892E-01 -0.188574817322E-01 -0.190954562417E-01 -0.193364241017E-01
+ -0.195804229638E-01 -0.198274909534E-01 -0.200776666753E-01 -0.203309892199E-01
+ -0.205874981694E-01 -0.208472336037E-01 -0.211102361071E-01 -0.213765467741E-01
+ -0.216462072163E-01 -0.219192595686E-01 -0.221957464960E-01 -0.224757112000E-01
+ -0.227591974257E-01 -0.230462494683E-01 -0.233369121801E-01 -0.236312309778E-01
+ -0.239292518492E-01 -0.242310213606E-01 -0.245365866640E-01 -0.248459955045E-01
+ -0.251592962277E-01 -0.254765377875E-01 -0.257977697533E-01 -0.261230423182E-01
+ -0.264524063066E-01 -0.267859131822E-01 -0.271236150558E-01 -0.274655646941E-01
+ -0.278118155271E-01 -0.281624216570E-01 -0.285174378666E-01 -0.288769196278E-01
+ -0.292409231100E-01 -0.296095051894E-01 -0.299827234574E-01 -0.303606362298E-01
+ -0.307433025561E-01 -0.311307822283E-01 -0.315231357907E-01 -0.319204245489E-01
+ -0.323227105799E-01 -0.327300567412E-01 -0.331425266811E-01 -0.335601848485E-01
+ -0.339830965029E-01 -0.344113277247E-01 -0.348449454253E-01 -0.352840173578E-01
+ -0.357286121277E-01 -0.361787992031E-01 -0.366346489260E-01 -0.370962325232E-01
+ -0.375636221175E-01 -0.380368907385E-01 -0.385161123346E-01 -0.390013617844E-01
+ -0.394927149081E-01 -0.399902484797E-01 -0.404940402388E-01 -0.410041689026E-01
+ -0.415207141788E-01 -0.420437567773E-01 -0.425733784231E-01 -0.431096618694E-01
+ -0.436526909100E-01 -0.442025503926E-01 -0.447593262323E-01 -0.453231054245E-01
+ -0.458939760589E-01 -0.464720273331E-01 -0.470573495667E-01 -0.476500342150E-01
+ -0.482501738837E-01 -0.488578623432E-01 -0.494731945432E-01 -0.500962666276E-01
+ -0.507271759495E-01 -0.513660210862E-01 -0.520129018550E-01 -0.526679193284E-01
+ -0.533311758502E-01 -0.540027750510E-01 -0.546828218650E-01 -0.553714225458E-01
+ -0.560686846834E-01 -0.567747172208E-01 -0.574896304709E-01 -0.582135361340E-01
+ -0.589465473151E-01 -0.596887785413E-01 -0.604403457800E-01 -0.612013664570E-01
+ -0.619719594745E-01 -0.627522452299E-01 -0.635423456345E-01 -0.643423841325E-01
+ -0.651524857204E-01 -0.659727769662E-01 -0.668033860293E-01 -0.676444426806E-01
+ -0.684960783223E-01 -0.693584260089E-01 -0.702316204677E-01 -0.711157981196E-01
+ -0.720110971007E-01 -0.729176572835E-01 -0.738356202988E-01 -0.747651295579E-01
+ -0.757063302747E-01 -0.766593694884E-01 -0.776243960863E-01 -0.786015608271E-01
+ -0.795910163642E-01 -0.805929172696E-01 -0.816074200576E-01 -0.826346832094E-01
+ -0.836748671979E-01 -0.847281345121E-01 -0.857946496828E-01 -0.868745793077E-01
+ -0.879680920777E-01 -0.890753588028E-01 -0.901965524385E-01 -0.913318481130E-01
+ -0.924814231537E-01 -0.936454571154E-01 -0.948241318074E-01 -0.960176313220E-01
+ -0.972261420630E-01 -0.984498527743E-01 -0.996889545690E-01 -0.100943640959
+ -0.102214107886     -0.103500553748     -0.104803179436     -0.106122188358
+ -0.107457786475     -0.108810182332     -0.110179587088     -0.111566214551
+ -0.112970281209     -0.114392006262     -0.115831611660     -0.117289322131
+ -0.118765365222     -0.120259971326     -0.121773373724     -0.123305808616
+ -0.124857515158     -0.126428735502     -0.128019714824     -0.129630701371
+ -0.131261946490     -0.132913704673     -0.134586233589     -0.136279794127
+ -0.137994650433     -0.139731069949     -0.141489323456     -0.143269685109
+ -0.145072432483     -0.146897846609     -0.148746212021     -0.150617816792
+ -0.152512952580     -0.154431914669     -0.156375002013     -0.158342517277
+ -0.160334766884     -0.162352061056     -0.164394713860     -0.166463043252
+ -0.168557371120     -0.170678023336     -0.172825329792     -0.174999624455
+ -0.177201245406     -0.179430534892     -0.181687839368     -0.183973509548
+ -0.186287900447     -0.188631371436     -0.191004286280     -0.193407013194
+ -0.195839924886     -0.198303398605     -0.200797816190     -0.203323564117
+ -0.205881033548     -0.208470620377     -0.211092725279     -0.213747753755
+ -0.216436116182     -0.219158227859     -0.221914509053     -0.224705385046
+ -0.227531286179     -0.230392647899     -0.233289910804     -0.236223520685
+ -0.239193928571     -0.242201590769     -0.245246968908     -0.248330529978
+ -0.251452746368     -0.254614095906     -0.257815061895     -0.261056133144
+ -0.264337804008     -0.267660574413     -0.271024949887     -0.274431441589
+ -0.277880566331     -0.281372846600     -0.284908810581     -0.288488992168
+ -0.292113930977     -0.295784172360     -0.299500267408     -0.303262772948
+ -0.307072251547     -0.310929271500     -0.314834406816     -0.318788237204
+ -0.322791348044     -0.326844330358     -0.330947780775     -0.335102301482
+ -0.339308500174     -0.343566989994     -0.347878389463     -0.352243322400
+ -0.356662417835     -0.361136309906     -0.365665637753     -0.370251045389
+ -0.374893181567     -0.379592699629     -0.384350257339     -0.389166516706
+ -0.394042143781     -0.398977808445     -0.403974184173     -0.409031947780
+ -0.414151779141     -0.419334360898     -0.424580378129     -0.429890518003
+ -0.435265469404     -0.440705922519     -0.446212568406     -0.451786098522
+ -0.457427204218     -0.463136576199     -0.468914903939     -0.474762875060
+ -0.480681174668     -0.486670484635     -0.492731482837     -0.498864842340
+ -0.505071230528     -0.511351308173     -0.517705728441     -0.524135135838
+ -0.530640165079     -0.537221439887     -0.543879571716     -0.550615158389
+ -0.557428782648     -0.564321010614     -0.571292390155     -0.578343449140
+ -0.585474693595     -0.592686605744     -0.599979641924     -0.607354230380
+ -0.614810768927     -0.622349622461     -0.629971120338     -0.637675553586
+ -0.645463171959     -0.653334180813     -0.661288737809     -0.669326949423
+ -0.677448867253     -0.685654484121     -0.693943729953     -0.702316467435
+ -0.710772487415     -0.719311504069     -0.727933149789     -0.736636969801
+ -0.745422416496     -0.754288843456     -0.763235499166     -0.772261520396
+ -0.781365925250     -0.790547605847     -0.799805320640     -0.809137686349
+ -0.818543169491     -0.828020077504     -0.837566549433     -0.847180546177
+ -0.856859840281     -0.866602005250     -0.876404404375     -0.886264179066
+ -0.896178236657     -0.906143237697     -0.916155582691     -0.926211398294
+ -0.936306522940     -0.946436491903     -0.956596521773     -0.966781494356
+ -0.976985939971     -0.987204020164     -0.997429509826      -1.00765577872
+  -1.01787577243      -1.02808199272      -1.03826647732      -1.04842077923
+  -1.05853594541      -1.06860249500      -1.07861039710      -1.08854904811
+  -1.09840724861      -1.10817317998      -1.11783438074      -1.12737772255
+  -1.13678938625      -1.14605483768      -1.15515880357      -1.16408524765
+  -1.17281734682      -1.18133746789      -1.18962714468      -1.19766705581
+  -1.20543700334      -1.21291589235      -1.22008171175      -1.22691151638
+  -1.23338141083      -1.23946653502      -1.24514105185      -1.25037813725
+  -1.25514997280      -1.25942774131      -1.26318162559      -1.26638081080
+  -1.26899349060      -1.27098687765      -1.27232721855      -1.27297981381
+  -1.27290904315      -1.27207839640      -1.27045051058      -1.26798721336
+  -1.26464957342      -1.26039795800      -1.25519209801      -1.24899116116
+  -1.24175383336      -1.23343840869      -1.22400288845      -1.21340508939
+  -1.20160276145      -1.18855371540      -1.17421596041      -1.15854785198
+  -1.14150825029      -1.12305668926      -1.10315355653      -1.08176028451
+  -1.05883955282      -1.03435550235      -1.00827396141     -0.980562684192
+ -0.951191602375     -0.920133090378     -0.887362245312     -0.852857182715
+ -0.816599349544     -0.778573856201     -0.738769829763     -0.697180791058
+ -0.653805058709     -0.608646183843     -0.561713419750     -0.513022231411
+ -0.462594850466     -0.410460881795     -0.356657968519     -0.301232522684
+ -0.244240529278     -0.185748431360     -0.125834103977     -0.645879239716E-01
+ -0.211394180760E-02  0.614688401321E-01  0.126025080753      0.191401606296
+  0.257425815051      0.323903992365      0.390619554858      0.457331251758
+  0.523771362092      0.589643939350      0.654623170151      0.718351930539
+  0.780440642594      0.840466554967      0.897973593235      0.952472949043
+   1.00344459996       1.05033997354       1.09258598770       1.12959071313
+   1.16075090943       1.18546168228       1.20312849010       1.21318169232
+   1.21509377168       1.20839927712       1.19271741506       1.16777706249
+   1.13344378005       1.08974816513       1.03691460217      0.975389141303
+  0.905864870136      0.829302744449      0.746945421100      0.660321204334
+  0.571234788901      0.481741074539      0.394097945743      0.310693557619
+  0.233943323708      0.166151417155      0.109331084751      0.649772969920E-01
+  0.337840255889E-01  0.152965218821E-01  0.748613893487E-02  0.623138297283E-02
+  0.623353461852E-02  0.623323733136E-02  0.623015144070E-02  0.622416810349E-02
+  0.621517621073E-02  0.620306226349E-02  0.618771025718E-02  0.616900155251E-02
+  0.614681467725E-02  0.612102534069E-02  0.609150621881E-02  0.605812683144E-02
+  0.602075340621E-02  0.597924874393E-02  0.593347208566E-02  0.588327897390E-02
+  0.582852112048E-02  0.576904626187E-02  0.570469770707E-02  0.563531447610E-02
+  0.556073114353E-02  0.548077768730E-02  0.539527932117E-02  0.530405632295E-02
+  0.520692385186E-02  0.510369175155E-02  0.499416434252E-02  0.487814019785E-02
+  0.475541189475E-02  0.462576574989E-02  0.448898152761E-02  0.434483212712E-02
+  0.419308318980E-02  0.403349289301E-02  0.386581081081E-02  0.368978023873E-02
+  0.350512679609E-02  0.331160027243E-02  0.310880864951E-02  0.345205103253E-02
+  0.379332155372E-02  0.413302690381E-02  0.447152152733E-02  0.480920934801E-02
+  0.514648913897E-02  0.548376864056E-02  0.582145941121E-02  0.615997706651E-02
+  0.649973999964E-02  0.684116851513E-02  0.718468385732E-02  0.245143951399
+  0.412318041503      0.287729677631      0.199868509324      0.138192972142
+  0.951006592962E-01  0.651344634479E-01  0.443957387299E-01  0.301125751878E-01
+  0.203237326173E-01  0.136483469555E-01  0.911905023623E-02  0.606154986615E-02
+  0.400823754018E-02  0.263651176634E-02  0.172497534138E-02  0.112249140463E-02
+  0.726440036155E-03  0.467522382189E-03  0.299198780336E-03  0.190388408927E-03
+  0.120451599196E-03  0.757606562895E-04  0.473697717815E-04  0.294409742535E-04
+  0.181870765500E-04  0.111660495238E-04  0.681283449092E-05  0.413059908766E-05
+  0.248839910929E-05  0.148940656786E-05  0.885639044175E-06  0.523135396927E-06
+  0.306936469722E-06  0.178863884296E-06  0.103513952373E-06  0.594893284263E-07
+  0.339472509362E-07  0.192334172292E-07  0.108182049985E-07  0.604033327060E-08
+  0.334759538608E-08  0.184132649868E-08  0.100510888501E-08  0.544424949567E-09
+  0.292592024683E-09  0.156007947301E-09  0.825176963796E-10  0.432933688899E-10
+  0.225277574373E-10  0.116244791570E-10  0.594842693620E-11  0.301743815119E-11
+  0.151819297874E-11  0.756728013585E-12  0.374219174167E-12  0.183556873405E-12
+  0.888178419700E-13  0.426325641456E-13  0.201320441799E-13  0.947390314347E-14
+  0.473695157173E-14  0.236847578587E-14   0.00000000000      0.118423789293E-14
+   0.00000000000       0.00000000000       0.00000000000       0.00000000000
+  2
+  0.740140326664E-07  0.148959047256E-06  0.224846754080E-06  0.301689010746E-06
+  0.379497824015E-06  0.458285351671E-06  0.538063904425E-06  0.618845947839E-06
+  0.700644104271E-06  0.783471154851E-06  0.867340041472E-06  0.952263868819E-06
+  0.103825590641E-05  0.112532959069E-05  0.121349852708E-05  0.130277649216E-05
+  0.139317743580E-05  0.148471548333E-05  0.157740493776E-05  0.167126028199E-05
+  0.176629618113E-05  0.186252748471E-05  0.195996922909E-05  0.205863663973E-05
+  0.215854513360E-05  0.225971032163E-05  0.236214801108E-05  0.246587420803E-05
+  0.257090511993E-05  0.267725715806E-05  0.278494694015E-05  0.289399129295E-05
+  0.300440725485E-05  0.311621207858E-05  0.322942323387E-05  0.334405841019E-05
+  0.346013551951E-05  0.357767269914E-05  0.369668831448E-05  0.381720096197E-05
+  0.393922947196E-05  0.406279291164E-05  0.418791058807E-05  0.431460205112E-05
+  0.444288709661E-05  0.457278576932E-05  0.470431836619E-05  0.483750543946E-05
+  0.497236779987E-05  0.510892651995E-05  0.524720293728E-05  0.538721865781E-05
+  0.552899555931E-05  0.567255579468E-05  0.581792179553E-05  0.596511627556E-05
+  0.611416223423E-05  0.626508296028E-05  0.641790203536E-05  0.657264333777E-05
+  0.672933104615E-05  0.688798964328E-05  0.704864391989E-05  0.721131897853E-05
+  0.737604023751E-05  0.754283343486E-05  0.771172463237E-05  0.788274021962E-05
+  0.805590691815E-05  0.823125178560E-05  0.840880221997E-05  0.858858596388E-05
+  0.877063110889E-05  0.895496609994E-05  0.914161973975E-05  0.933062119331E-05
+  0.952199999250E-05  0.971578604064E-05  0.991200961720E-05  0.101107013825E-04
+  0.103118923826E-04  0.105156140538E-04  0.107218982283E-04  0.109307771383E-04
+  0.111422834215E-04  0.113564501262E-04  0.115733107165E-04  0.117928990771E-04
+  0.120152495194E-04  0.122403967859E-04  0.124683760563E-04  0.126992229530E-04
+  0.129329735462E-04  0.131696643599E-04  0.134093323775E-04  0.136520150477E-04
+  0.138977502901E-04  0.141465765013E-04  0.143985325609E-04  0.146536578377E-04
+  0.149119921953E-04  0.151735759992E-04  0.154384501223E-04  0.157066559517E-04
+  0.159782353951E-04  0.162532308874E-04  0.165316853971E-04  0.168136424335E-04
+  0.170991460527E-04  0.173882408654E-04  0.176809720431E-04  0.179773853258E-04
+  0.182775270287E-04  0.185814440493E-04  0.188891838755E-04  0.192007945922E-04
+  0.195163248892E-04  0.198358240687E-04  0.201593420532E-04  0.204869293930E-04
+  0.208186372743E-04  0.211545175270E-04  0.214946226333E-04  0.218390057351E-04
+  0.221877206431E-04  0.225408218447E-04  0.228983645126E-04  0.232604045137E-04
+  0.236269984173E-04  0.239982035046E-04  0.243740777771E-04  0.247546799660E-04
+  0.251400695410E-04  0.255303067201E-04  0.259254524787E-04  0.263255685590E-04
+  0.267307174801E-04  0.271409625472E-04  0.275563678620E-04  0.279769983325E-04
+  0.284029196829E-04  0.288341984645E-04  0.292709020652E-04  0.297130987211E-04
+  0.301608575261E-04  0.306142484436E-04  0.310733423167E-04  0.315382108800E-04
+  0.320089267699E-04  0.324855635368E-04  0.329681956562E-04  0.334568985403E-04
+  0.339517485499E-04  0.344528230064E-04  0.349602002037E-04  0.354739594205E-04
+  0.359941809327E-04  0.365209460260E-04  0.370543370085E-04  0.375944372236E-04
+  0.381413310630E-04  0.386951039802E-04  0.392558425031E-04  0.398236342484E-04
+  0.403985679346E-04  0.409807333964E-04  0.415702215982E-04  0.421671246487E-04
+  0.427715358154E-04  0.433835495387E-04  0.440032614469E-04  0.446307683713E-04
+  0.452661683611E-04  0.459095606989E-04  0.465610459161E-04  0.472207258085E-04
+  0.478887034524E-04  0.485650832208E-04  0.492499707994E-04  0.499434732031E-04
+  0.506456987932E-04  0.513567572939E-04  0.520767598095E-04  0.528058188418E-04
+  0.535440483078E-04  0.542915635574E-04  0.550484813914E-04  0.558149200796E-04
+  0.565909993797E-04  0.573768405557E-04  0.581725663969E-04  0.589783012370E-04
+  0.597941709737E-04  0.606203030884E-04  0.614568266658E-04  0.623038724145E-04
+  0.631615726872E-04  0.640300615011E-04  0.649094745595E-04  0.657999492724E-04
+  0.667016247784E-04  0.676146419660E-04  0.685391434961E-04  0.694752738239E-04
+  0.704231792216E-04  0.713830078014E-04  0.723549095386E-04  0.733390362946E-04
+  0.743355418413E-04  0.753445818848E-04  0.763663140896E-04  0.774008981033E-04
+  0.784484955820E-04  0.795092702148E-04  0.805833877498E-04  0.816710160204E-04
+  0.827723249704E-04  0.838874866815E-04  0.850166754003E-04  0.861600675646E-04
+  0.873178418318E-04  0.884901791066E-04  0.896772625690E-04  0.908792777031E-04
+  0.920964123265E-04  0.933288566186E-04  0.945768031516E-04  0.958404469196E-04
+  0.971199853696E-04  0.984156184318E-04  0.997275485518E-04  0.101055980721E-03
+  0.102401122510E-03  0.103763184100E-03  0.105142378316E-03  0.106538920659E-03
+  0.107953029342E-03  0.109384925323E-03  0.110834832338E-03  0.112302976938E-03
+  0.113789588524E-03  0.115294899382E-03  0.116819144720E-03  0.118362562703E-03
+  0.119925394495E-03  0.121507884291E-03  0.123110279358E-03  0.124732830073E-03
+  0.126375789965E-03  0.128039415748E-03  0.129723967366E-03  0.131429708036E-03
+  0.133156904282E-03  0.134905825983E-03  0.136676746410E-03  0.138469942274E-03
+  0.140285693766E-03  0.142124284599E-03  0.143986002059E-03  0.145871137041E-03
+  0.147779984102E-03  0.149712841503E-03  0.151670011258E-03  0.153651799177E-03
+  0.155658514920E-03  0.157690472039E-03  0.159747988033E-03  0.161831384392E-03
+  0.163940986651E-03  0.166077124440E-03  0.168240131534E-03  0.170430345908E-03
+  0.172648109788E-03  0.174893769703E-03  0.177167676543E-03  0.179470185609E-03
+  0.181801656675E-03  0.184162454036E-03  0.186552946572E-03  0.188973507803E-03
+  0.191424515946E-03  0.193906353976E-03  0.196419409686E-03  0.198964075745E-03
+  0.201540749763E-03  0.204149834350E-03  0.206791737181E-03  0.209466871059E-03
+  0.212175653978E-03  0.214918509193E-03  0.217695865278E-03  0.220508156203E-03
+  0.223355821393E-03  0.226239305801E-03  0.229159059978E-03  0.232115540142E-03
+  0.235109208248E-03  0.238140532064E-03  0.241209985239E-03  0.244318047382E-03
+  0.247465204134E-03  0.250651947244E-03  0.253878774649E-03  0.257146190546E-03
+  0.260454705475E-03  0.263804836399E-03  0.267197106783E-03  0.270632046675E-03
+  0.274110192792E-03  0.277632088601E-03  0.281198284407E-03  0.284809337433E-03
+  0.288465811915E-03  0.292168279184E-03  0.295917317758E-03  0.299713513432E-03
+  0.303557459369E-03  0.307449756194E-03  0.311391012086E-03  0.315381842875E-03
+  0.319422872134E-03  0.323514731285E-03  0.327658059688E-03  0.331853504746E-03
+  0.336101722007E-03  0.340403375262E-03  0.344759136655E-03  0.349169686781E-03
+  0.353635714798E-03  0.358157918532E-03  0.362737004587E-03  0.367373688453E-03
+  0.372068694623E-03  0.376822756701E-03  0.381636617518E-03  0.386511029250E-03
+  0.391446753534E-03  0.396444561586E-03  0.401505234325E-03  0.406629562490E-03
+  0.411818346770E-03  0.417072397920E-03  0.422392536899E-03  0.427779594987E-03
+  0.433234413925E-03  0.438757846038E-03  0.444350754375E-03  0.450014012838E-03
+  0.455748506323E-03  0.461555130857E-03  0.467434793736E-03  0.473388413669E-03
+  0.479416920922E-03  0.485521257461E-03  0.491702377102E-03  0.497961245657E-03
+  0.504298841086E-03  0.510716153652E-03  0.517214186073E-03  0.523793953680E-03
+  0.530456484575E-03  0.537202819792E-03  0.544034013460E-03  0.550951132966E-03
+  0.557955259124E-03  0.565047486343E-03  0.572228922799E-03  0.579500690606E-03
+  0.586863925990E-03  0.594319779475E-03  0.601869416051E-03  0.609514015365E-03
+  0.617254771900E-03  0.625092895166E-03  0.633029609886E-03  0.641066156187E-03
+  0.649203789795E-03  0.657443782234E-03  0.665787421018E-03  0.674236009858E-03
+  0.682790868863E-03  0.691453334747E-03  0.700224761038E-03  0.709106518289E-03
+  0.718099994293E-03  0.727206594299E-03  0.736427741231E-03  0.745764875913E-03
+  0.755219457290E-03  0.764792962660E-03  0.774486887904E-03  0.784302747715E-03
+  0.794242075843E-03  0.804306425328E-03  0.814497368743E-03  0.824816498446E-03
+  0.835265426822E-03  0.845845786535E-03  0.856559230790E-03  0.867407433583E-03
+  0.878392089968E-03  0.889514916321E-03  0.900777650604E-03  0.912182052643E-03
+  0.923729904400E-03  0.935423010248E-03  0.947263197261E-03  0.959252315490E-03
+  0.971392238261E-03  0.983684862460E-03  0.996132108834E-03  0.100873592229E-02
+  0.102149827221E-02  0.103442115272E-02  0.104750658305E-02  0.106075660783E-02
+  0.107417329741E-02  0.108775874816E-02  0.110151508284E-02  0.111544445091E-02
+  0.112954902885E-02  0.114383102055E-02  0.115829265757E-02  0.117293619960E-02
+  0.118776393470E-02  0.120277817975E-02  0.121798128074E-02  0.123337561320E-02
+  0.124896358252E-02  0.126474762434E-02  0.128073020497E-02  0.129691382170E-02
+  0.131330100327E-02  0.132989431019E-02  0.134669633522E-02  0.136370970369E-02
+  0.138093707398E-02  0.139838113791E-02  0.141604462114E-02  0.143393028362E-02
+  0.145204092003E-02  0.147037936019E-02  0.148894846951E-02  0.150775114946E-02
+  0.152679033800E-02  0.154606901002E-02  0.156559017787E-02  0.158535689177E-02
+  0.160537224029E-02  0.162563935089E-02  0.164616139033E-02  0.166694156522E-02
+  0.168798312251E-02  0.170928934998E-02  0.173086357677E-02  0.175270917389E-02
+  0.177482955476E-02  0.179722817573E-02  0.181990853664E-02  0.184287418132E-02
+  0.186612869820E-02  0.188967572086E-02  0.191351892854E-02  0.193766204681E-02
+  0.196210884806E-02  0.198686315215E-02  0.201192882699E-02  0.203730978914E-02
+  0.206301000442E-02  0.208903348854E-02  0.211538430770E-02  0.214206657928E-02
+  0.216908447242E-02  0.219644220873E-02  0.222414406288E-02  0.225219436335E-02
+  0.228059749305E-02  0.230935789001E-02  0.233848004809E-02  0.236796851767E-02
+  0.239782790639E-02  0.242806287982E-02  0.245867816221E-02  0.248967853727E-02
+  0.252106884884E-02  0.255285400171E-02  0.258503896236E-02  0.261762875973E-02
+  0.265062848604E-02  0.268404329753E-02  0.271787841531E-02  0.275213912618E-02
+  0.278683078340E-02  0.282195880761E-02  0.285752868758E-02  0.289354598118E-02
+  0.293001631613E-02  0.296694539097E-02  0.300433897590E-02  0.304220291372E-02
+  0.308054312071E-02  0.311936558755E-02  0.315867638029E-02  0.319848164127E-02
+  0.323878759010E-02  0.327960052461E-02  0.332092682184E-02  0.336277293906E-02
+  0.340514541474E-02  0.344805086959E-02  0.349149600761E-02  0.353548761710E-02
+  0.358003257177E-02  0.362513783177E-02  0.367081044478E-02  0.371705754715E-02
+  0.376388636497E-02  0.381130421524E-02  0.385931850695E-02  0.390793674231E-02
+  0.395716651789E-02  0.400701552579E-02  0.405749155486E-02  0.410860249192E-02
+  0.416035632297E-02  0.421276113449E-02  0.426582511460E-02  0.431955655448E-02
+  0.437396384952E-02  0.442905550074E-02  0.448484011608E-02  0.454132641170E-02
+  0.459852321342E-02  0.465643945805E-02  0.471508419477E-02  0.477446658662E-02
+  0.483459591182E-02  0.489548156531E-02  0.495713306017E-02  0.501956002913E-02
+  0.508277222603E-02  0.514677952741E-02  0.521159193399E-02  0.527721957226E-02
+  0.534367269606E-02  0.541096168816E-02  0.547909706190E-02  0.554808946284E-02
+  0.561794967038E-02  0.568868859947E-02  0.576031730233E-02  0.583284697012E-02
+  0.590628893474E-02  0.598065467056E-02  0.605595579621E-02  0.613220407644E-02
+  0.620941142387E-02  0.628758990092E-02  0.636675172167E-02  0.644690925372E-02
+  0.652807502018E-02  0.661026170157E-02  0.669348213783E-02  0.677774933030E-02
+  0.686307644375E-02  0.694947680840E-02  0.703696392207E-02  0.712555145218E-02
+  0.721525323795E-02  0.730608329252E-02  0.739805580514E-02  0.749118514336E-02
+  0.758548585529E-02  0.768097267181E-02  0.777766050891E-02  0.787556446998E-02
+  0.797469984816E-02  0.807508212868E-02  0.817672699132E-02  0.827965031280E-02
+  0.838386816924E-02  0.848939683867E-02  0.859625280351E-02  0.870445275317E-02
+  0.881401358659E-02  0.892495241488E-02  0.903728656394E-02  0.915103357715E-02
+  0.926621121806E-02  0.938283747314E-02  0.950093055455E-02  0.962050890294E-02
+  0.974159119029E-02  0.986419632277E-02  0.998834344364E-02  0.101140519362E-01
+  0.102413414268E-01  0.103702317877E-01  0.105007431404E-01  0.106328958582E-01
+  0.107667105700E-01  0.109022081628E-01  0.110394097854E-01  0.111783368510E-01
+  0.113190110412E-01  0.114614543088E-01  0.116056888811E-01  0.117517372634E-01
+  0.118996222426E-01  0.120493668902E-01  0.122009945661E-01  0.123545289217E-01
+  0.125099939042E-01  0.126674137592E-01  0.128268130352E-01  0.129882165865E-01
+  0.131516495775E-01  0.133171374860E-01  0.134847061071E-01  0.136543815571E-01
+  0.138261902770E-01  0.140001590369E-01  0.141763149391E-01  0.143546854228E-01
+  0.145352982678E-01  0.147181815980E-01  0.149033638863E-01  0.150908739579E-01
+  0.152807409948E-01  0.154729945397E-01  0.156676645003E-01  0.158647811532E-01
+  0.160643751484E-01  0.162664775133E-01  0.164711196571E-01  0.166783333748E-01
+  0.168881508516E-01  0.171006046675E-01  0.173157278008E-01  0.175335536334E-01
+  0.177541159543E-01  0.179774489645E-01  0.182035872810E-01  0.184325659412E-01
+  0.186644204072E-01  0.188991865703E-01  0.191369007552E-01  0.193775997242E-01
+  0.196213206817E-01  0.198681012781E-01  0.201179796145E-01  0.203709942464E-01
+  0.206271841884E-01  0.208865889176E-01  0.211492483783E-01  0.214152029856E-01
+  0.216844936296E-01  0.219571616787E-01  0.222332489842E-01  0.225127978831E-01
+  0.227958512021E-01  0.230824522610E-01  0.233726448760E-01  0.236664733627E-01
+  0.239639825392E-01  0.242652177289E-01  0.245702247633E-01  0.248790499843E-01
+  0.251917402464E-01  0.255083429187E-01  0.258289058869E-01  0.261534775542E-01
+  0.264821068432E-01  0.268148431961E-01  0.271517365755E-01  0.274928374646E-01
+  0.278381968666E-01  0.281878663044E-01  0.285418978190E-01  0.289003439682E-01
+  0.292632578243E-01  0.296306929710E-01  0.300027035007E-01  0.303793440098E-01
+  0.307606695942E-01  0.311467358440E-01  0.315375988371E-01  0.319333151317E-01
+  0.323339417589E-01  0.327395362132E-01  0.331501564427E-01  0.335658608375E-01
+  0.339867082181E-01  0.344127578209E-01  0.348440692839E-01  0.352807026301E-01
+  0.357227182495E-01  0.361701768797E-01  0.366231395845E-01  0.370816677310E-01
+  0.375458229645E-01  0.380156671812E-01  0.384912624992E-01  0.389726712267E-01
+  0.394599558278E-01  0.399531788857E-01  0.404524030632E-01  0.409576910604E-01
+  0.414691055683E-01  0.419867092206E-01  0.425105645401E-01  0.430407338835E-01
+  0.435772793798E-01  0.441202628668E-01  0.446697458212E-01  0.452257892853E-01
+  0.457884537878E-01  0.463577992601E-01  0.469338849459E-01  0.475167693061E-01
+  0.481065099166E-01  0.487031633591E-01  0.493067851064E-01  0.499174293985E-01
+  0.505351491117E-01  0.511599956199E-01  0.517920186459E-01  0.524312661049E-01
+  0.530777839369E-01  0.537316159301E-01  0.543928035323E-01  0.550613856522E-01
+  0.557373984474E-01  0.564208751007E-01  0.571118455830E-01  0.578103364015E-01
+  0.585163703341E-01  0.592299661483E-01  0.599511383029E-01  0.606798966340E-01
+  0.614162460224E-01  0.621601860422E-01  0.629117105906E-01  0.636708074957E-01
+  0.644374581045E-01  0.652116368476E-01  0.659933107796E-01  0.667824390970E-01
+  0.675789726282E-01  0.683828532989E-01  0.691940135679E-01  0.700123758354E-01
+  0.708378518202E-01  0.716703419063E-01  0.725097344570E-01  0.733559050948E-01
+  0.742087159474E-01  0.750680148572E-01  0.759336345542E-01  0.768053917897E-01
+  0.776830864321E-01  0.785665005210E-01  0.794553972808E-01  0.803495200913E-01
+  0.812485914156E-01  0.821523116839E-01  0.830603581319E-01  0.839723835951E-01
+  0.848880152570E-01  0.858068533504E-01  0.867284698149E-01  0.876524069064E-01
+  0.885781757628E-01  0.895052549246E-01  0.904330888110E-01  0.913610861551E-01
+  0.922886183976E-01  0.932150180421E-01  0.941395769744E-01  0.950615447500E-01
+  0.959801268513E-01  0.968944829210E-01  0.978037249755E-01  0.987069156045E-01
+  0.996030661628E-01  0.100491134962      0.101370025473      0.102238584542
+  0.103095600636      0.103939802132      0.104769855657      0.105584364489
+  0.106381867051      0.107160835495      0.107919674415      0.108656719688
+  0.109370237484      0.110058423460      0.110719402162      0.111351226667
+  0.111951878497      0.112519267834      0.113051234062      0.113545546691
+  0.113999906684      0.114411948233      0.114779241034      0.115099293091
+  0.115369554102      0.115587419488      0.115750235084      0.115855302571
+  0.115899885689      0.115881217278      0.115796507210      0.115642951254
+  0.115417740928      0.115118074389      0.114741168407      0.114284271463
+  0.113744678006      0.113119743924      0.112406903223      0.111603685963
+  0.110707737451      0.109716838680      0.108628928027      0.107442124156
+  0.106154750115      0.104765358539      0.103272757911      0.101676039755
+  0.999746066710E-01  0.981682010419E-01  0.962569342559E-01  0.942413162442E-01
+  0.921222851057E-01  0.899012365633E-01  0.875800529636E-01  0.851611315020E-01
+  0.826474113217E-01  0.800423991064E-01  0.773501927548E-01  0.745755026966E-01
+  0.717236703836E-01  0.688006834673E-01  0.658131871511E-01  0.627684911941E-01
+  0.596745720293E-01  0.565400694576E-01  0.533742773765E-01  0.501871280163E-01
+  0.469891691675E-01  0.437915339075E-01  0.406059023678E-01  0.374444551131E-01
+  0.343198177548E-01  0.312449964615E-01  0.282333040878E-01  0.252982766906E-01
+  0.224535802598E-01  0.197129075410E-01  0.170898648781E-01  0.145978490436E-01
+  0.122499140694E-01  0.100586281165E-01  0.803592045796E-02  0.619291868113E-02
+  0.453977625569E-02  0.308549068453E-02  0.183771256010E-02  0.802546023431E-03
+ -0.156586040816E-04 -0.614518833959E-03 -0.993838884449E-03 -0.115583077596E-02
+ -0.110533383402E-02 -0.850027207468E-03 -0.400627942531E-03  0.228935496989E-03
+  0.102138769774E-02  0.195602627782E-02  0.300871984018E-02  0.415201219945E-02
+  0.535536797311E-02  0.658560238468E-02  0.780754684326E-02  0.898501152325E-02
+  0.100821167624E-01  0.110650766636E-01  0.119045309631E-01  0.125785353249E-01
+  0.130763362868E-01  0.134030759728E-01  0.135855944962E-01  0.136795258848E-01
+  0.137568142683E-01  0.138347155283E-01  0.139132942528E-01  0.139926313049E-01
+  0.140728004639E-01  0.141538680754E-01  0.142358927213E-01  0.143189249133E-01
+  0.144030068047E-01  0.144881719262E-01  0.145744449456E-01  0.146618414501E-01
+  0.147503677528E-01  0.148400207251E-01  0.149307876533E-01  0.150226461222E-01
+  0.151155639231E-01  0.152094989904E-01  0.153043993634E-01  0.154002031740E-01
+  0.154968386655E-01  0.155942242349E-01  0.156922685041E-01  0.157908704192E-01
+  0.158899193744E-01  0.159892953691E-01  0.160888691835E-01  0.161885025916E-01
+  0.162880485936E-01  0.163873516750E-01  0.164862480979E-01  0.165845662152E-01
+  0.166821268038E-01  0.167787434349E-01  0.168742228599E-01  0.169683654221E-01
+  0.170609654927E-01  0.171518119275E-01  0.172406885442E-01  0.173273746276E-01
+  0.174116454409E-01  0.174932727665E-01  0.175720254646E-01  0.176476700354E-01
+  0.177199712153E-01  0.177886925710E-01  0.178535971110E-01  0.179144479165E-01
+  0.179710087680E-01  0.180230447901E-01  0.180703230964E-01  0.181126134547E-01
+  0.181496889371E-01  0.181813265770E-01  0.182073080366E-01  0.182274202620E-01
+  0.182414561430E-01  0.182492151644E-01  0.182505040515E-01  0.182451374074E-01
+  0.182329383493E-01  0.182137391147E-01  0.181873816760E-01  0.181537183252E-01
+  0.181126122500E-01  0.180639380852E-01  0.180075824525E-01  0.179434444708E-01
+  0.178714362476E-01  0.177914833442E-01  0.177035252118E-01  0.176075156027E-01
+  0.175034229442E-01  0.173912306939E-01  0.172709376417E-01  0.171425581948E-01
+  0.170061226130E-01  0.168616772078E-01  0.167092845077E-01  0.165490233690E-01
+  0.163809890527E-01  0.162052932521E-01  0.160220640736E-01  0.158314459672E-01
+  0.156335996107E-01  0.154287017434E-01  0.152169449455E-01  0.149985373573E-01
+  0.147737023673E-01  0.145426782153E-01  0.143057175706E-01  0.140630870299E-01
+  0.138150665798E-01  0.135619489904E-01  0.133040391653E-01  0.130416534310E-01
+  0.127751187814E-01  0.125047720663E-01  0.122309591314E-01  0.119540339110E-01
+  0.116743574974E-01  0.113922971286E-01  0.111082251785E-01  0.108225180915E-01
+  0.105355552995E-01  0.102477180961E-01  0.995938851872E-02  0.967094818905E-02
+  0.938277715200E-02  0.909525271722E-02  0.880874832676E-02  0.852363231977E-02
+  0.824026685126E-02  0.795900677282E-02  0.768019851624E-02  0.740417903872E-02
+  0.713127479320E-02  0.686180073919E-02  0.659605941421E-02  0.633434005364E-02
+  0.607691776416E-02  0.582405278282E-02  0.557598980268E-02  0.533295730295E-02
+  0.509516706741E-02  0.486281370976E-02  0.463607430120E-02  0.441510807736E-02
+  0.420005622419E-02  0.399104176504E-02  0.378816951986E-02  0.359152614203E-02
+  0.340118027736E-02  0.321718275006E-02  0.303956686112E-02  0.286834875822E-02
+  0.270352786736E-02  0.254508740996E-02  0.239299496973E-02  0.224720312534E-02
+  0.210765012866E-02  0.197426065082E-02  0.184694654391E-02  0.172560766447E-02
+  0.161013270148E-02  0.150040006989E-02  0.139627877140E-02  0.129762930985E-02
+  0.120430459019E-02  0.111615082628E-02  0.103300844456E-02  0.954712971986E-03
+  0.881095914417E-03  0.811985607504E-03  0.747208053644E-03  0.686587721282E-03
+  0.629948308631E-03  0.577113483087E-03  0.527907576031E-03  0.482156227577E-03
+  0.439687007645E-03  0.400329968113E-03  0.363918168625E-03  0.330288148700E-03
+  0.299280347349E-03  0.270739486962E-03  0.519484248261E-03  0.534750176710E-03
+  0.494268559721E-03  0.443943224597E-03  0.106583704609E-03  0.251292242986E-04
+  0.581692661612E-05  0.132170463090E-05  0.294713743898E-06  0.644746577905E-07
+  0.138355567003E-07  0.291150854537E-08  0.600685012841E-09  0.121472254477E-09
+  0.240710562593E-10  0.467252903036E-11  0.888888962436E-12  0.165556457432E-12
+  0.305533376377E-13  0.568434188608E-14  0.710542735760E-15   0.00000000000
+  3
+ -0.202270991009E-06 -0.407086237877E-06 -0.614477743402E-06 -0.824477912930E-06
+ -0.103711955941E-05 -0.125243590854E-05 -0.147046060394E-05 -0.169122771239E-05
+ -0.191477172923E-05 -0.214112758364E-05 -0.237033064421E-05 -0.260241672436E-05
+ -0.283742208802E-05 -0.307538345527E-05 -0.331633800804E-05 -0.356032339597E-05
+ -0.380737774229E-05 -0.405753964973E-05 -0.431084820660E-05 -0.456734299287E-05
+ -0.482706408638E-05 -0.509005206909E-05 -0.535634803339E-05 -0.562599358857E-05
+ -0.589903086730E-05 -0.617550253221E-05 -0.645545178256E-05 -0.673892236099E-05
+ -0.702595856035E-05 -0.731660523064E-05 -0.761090778598E-05 -0.790891221176E-05
+ -0.821066507177E-05 -0.851621351550E-05 -0.882560528552E-05 -0.913888872493E-05
+ -0.945611278490E-05 -0.977732703234E-05 -0.101025816576E-04 -0.104319274824E-04
+ -0.107654159678E-04 -0.111030992218E-04 -0.114450300084E-04 -0.117912617547E-04
+ -0.121418485603E-04 -0.124968452050E-04 -0.128563071579E-04 -0.132202905855E-04
+ -0.135888523610E-04 -0.139620500729E-04 -0.143399420341E-04 -0.147225872911E-04
+ -0.151100456329E-04 -0.155023776007E-04 -0.158996444971E-04 -0.163019083960E-04
+ -0.167092321517E-04 -0.171216794097E-04 -0.175393146154E-04 -0.179622030254E-04
+ -0.183904107167E-04 -0.188240045977E-04 -0.192630524184E-04 -0.197076227807E-04
+ -0.201577851499E-04 -0.206136098646E-04 -0.210751681483E-04 -0.215425321206E-04
+ -0.220157748080E-04 -0.224949701555E-04 -0.229801930385E-04 -0.234715192741E-04
+ -0.239690256329E-04 -0.244727898513E-04 -0.249828906435E-04 -0.254994077138E-04
+ -0.260224217690E-04 -0.265520145313E-04 -0.270882687504E-04 -0.276312682172E-04
+ -0.281810977764E-04 -0.287378433402E-04 -0.293015919010E-04 -0.298724315458E-04
+ -0.304504514694E-04 -0.310357419887E-04 -0.316283945563E-04 -0.322285017755E-04
+ -0.328361574144E-04 -0.334514564202E-04 -0.340744949347E-04 -0.347053703091E-04
+ -0.353441811187E-04 -0.359910271792E-04 -0.366460095614E-04 -0.373092306079E-04
+ -0.379807939481E-04 -0.386608045153E-04 -0.393493685624E-04 -0.400465936790E-04
+ -0.407525888080E-04 -0.414674642625E-04 -0.421913317432E-04 -0.429243043560E-04
+ -0.436664966293E-04 -0.444180245321E-04 -0.451790054922E-04 -0.459495584144E-04
+ -0.467298036993E-04 -0.475198632616E-04 -0.483198605499E-04 -0.491299205653E-04
+ -0.499501698813E-04 -0.507807366636E-04 -0.516217506899E-04 -0.524733433704E-04
+ -0.533356477682E-04 -0.542087986201E-04 -0.550929323576E-04 -0.559881871285E-04
+ -0.568947028181E-04 -0.578126210715E-04 -0.587420853150E-04 -0.596832407796E-04
+ -0.606362345225E-04 -0.616012154511E-04 -0.625783343455E-04 -0.635677438826E-04
+ -0.645695986596E-04 -0.655840552183E-04 -0.666112720697E-04 -0.676514097185E-04
+ -0.687046306883E-04 -0.697710995471E-04 -0.708509829327E-04 -0.719444495791E-04
+ -0.730516703428E-04 -0.741728182291E-04 -0.753080684199E-04 -0.764575983001E-04
+ -0.776215874863E-04 -0.788002178540E-04 -0.799936735666E-04 -0.812021411042E-04
+ -0.824258092921E-04 -0.836648693309E-04 -0.849195148265E-04 -0.861899418196E-04
+ -0.874763488171E-04 -0.887789368226E-04 -0.900979093683E-04 -0.914334725462E-04
+ -0.927858350408E-04 -0.941552081616E-04 -0.955418058757E-04 -0.969458448420E-04
+ -0.983675444445E-04 -0.998071268264E-04 -0.101264816926E-03 -0.102740842509E-03
+ -0.104235434209E-03 -0.105748825558E-03 -0.107281253027E-03 -0.108832956060E-03
+ -0.110404177115E-03 -0.111995161698E-03 -0.113606158403E-03 -0.115237418952E-03
+ -0.116889198233E-03 -0.118561754340E-03 -0.120255348612E-03 -0.121970245678E-03
+ -0.123706713494E-03 -0.125465023386E-03 -0.127245450094E-03 -0.129048271812E-03
+ -0.130873770237E-03 -0.132722230605E-03 -0.134593941742E-03 -0.136489196106E-03
+ -0.138408289837E-03 -0.140351522794E-03 -0.142319198613E-03 -0.144311624747E-03
+ -0.146329112517E-03 -0.148371977159E-03 -0.150440537874E-03 -0.152535117881E-03
+ -0.154656044460E-03 -0.156803649012E-03 -0.158978267104E-03 -0.161180238523E-03
+ -0.163409907334E-03 -0.165667621926E-03 -0.167953735071E-03 -0.170268603980E-03
+ -0.172612590355E-03 -0.174986060449E-03 -0.177389385121E-03 -0.179822939897E-03
+ -0.182287105023E-03 -0.184782265531E-03 -0.187308811295E-03 -0.189867137092E-03
+ -0.192457642666E-03 -0.195080732789E-03 -0.197736817324E-03 -0.200426311289E-03
+ -0.203149634924E-03 -0.205907213754E-03 -0.208699478655E-03 -0.211526865925E-03
+ -0.214389817348E-03 -0.217288780268E-03 -0.220224207651E-03 -0.223196558167E-03
+ -0.226206296248E-03 -0.229253892175E-03 -0.232339822139E-03 -0.235464568324E-03
+ -0.238628618977E-03 -0.241832468488E-03 -0.245076617465E-03 -0.248361572813E-03
+ -0.251687847812E-03 -0.255055962200E-03 -0.258466442252E-03 -0.261919820861E-03
+ -0.265416637627E-03 -0.268957438932E-03 -0.272542778035E-03 -0.276173215152E-03
+ -0.279849317547E-03 -0.283571659617E-03 -0.287340822987E-03 -0.291157396596E-03
+ -0.295021976791E-03 -0.298935167420E-03 -0.302897579928E-03 -0.306909833450E-03
+ -0.310972554909E-03 -0.315086379112E-03 -0.319251948854E-03 -0.323469915013E-03
+ -0.327740936655E-03 -0.332065681135E-03 -0.336444824205E-03 -0.340879050113E-03
+ -0.345369051717E-03 -0.349915530589E-03 -0.354519197125E-03 -0.359180770657E-03
+ -0.363900979566E-03 -0.368680561394E-03 -0.373520262960E-03 -0.378420840478E-03
+ -0.383383059673E-03 -0.388407695902E-03 -0.393495534274E-03 -0.398647369774E-03
+ -0.403864007388E-03 -0.409146262225E-03 -0.414494959648E-03 -0.419910935403E-03
+ -0.425395035746E-03 -0.430948117580E-03 -0.436571048584E-03 -0.442264707354E-03
+ -0.448029983535E-03 -0.453867777962E-03 -0.459779002804E-03 -0.465764581701E-03
+ -0.471825449913E-03 -0.477962554461E-03 -0.484176854281E-03 -0.490469320371E-03
+ -0.496840935941E-03 -0.503292696568E-03 -0.509825610353E-03 -0.516440698078E-03
+ -0.523138993364E-03 -0.529921542832E-03 -0.536789406269E-03 -0.543743656795E-03
+ -0.550785381023E-03 -0.557915679239E-03 -0.565135665565E-03 -0.572446468139E-03
+ -0.579849229289E-03 -0.587345105711E-03 -0.594935268652E-03 -0.602620904089E-03
+ -0.610403212920E-03 -0.618283411145E-03 -0.626262730061E-03 -0.634342416454E-03
+ -0.642523732790E-03 -0.650807957418E-03 -0.659196384763E-03 -0.667690325536E-03
+ -0.676291106930E-03 -0.685000072837E-03 -0.693818584050E-03 -0.702748018478E-03
+ -0.711789771364E-03 -0.720945255502E-03 -0.730215901452E-03 -0.739603157774E-03
+ -0.749108491244E-03 -0.758733387090E-03 -0.768479349223E-03 -0.778347900468E-03
+ -0.788340582806E-03 -0.798458957615E-03 -0.808704605912E-03 -0.819079128598E-03
+ -0.829584146716E-03 -0.840221301695E-03 -0.850992255612E-03 -0.861898691452E-03
+ -0.872942313365E-03 -0.884124846942E-03 -0.895448039476E-03 -0.906913660238E-03
+ -0.918523500755E-03 -0.930279375089E-03 -0.942183120118E-03 -0.954236595827E-03
+ -0.966441685596E-03 -0.978800296496E-03 -0.991314359583E-03 -0.100398583021E-02
+ -0.101681668831E-02 -0.102980893874E-02 -0.104296461156E-02 -0.105628576238E-02
+ -0.106977447264E-02 -0.108343284999E-02 -0.109726302858E-02 -0.111126716941E-02
+ -0.112544746064E-02 -0.113980611797E-02 -0.115434538498E-02 -0.116906753345E-02
+ -0.118397486376E-02 -0.119906970520E-02 -0.121435441637E-02 -0.122983138554E-02
+ -0.124550303101E-02 -0.126137180152E-02 -0.127744017658E-02 -0.129371066693E-02
+ -0.131018581485E-02 -0.132686819462E-02 -0.134376041289E-02 -0.136086510911E-02
+ -0.137818495593E-02 -0.139572265960E-02 -0.141348096042E-02 -0.143146263317E-02
+ -0.144967048752E-02 -0.146810736848E-02 -0.148677615686E-02 -0.150567976968E-02
+ -0.152482116068E-02 -0.154420332074E-02 -0.156382927836E-02 -0.158370210014E-02
+ -0.160382489125E-02 -0.162420079590E-02 -0.164483299788E-02 -0.166572472102E-02
+ -0.168687922968E-02 -0.170829982930E-02 -0.172998986690E-02 -0.175195273158E-02
+ -0.177419185509E-02 -0.179671071234E-02 -0.181951282194E-02 -0.184260174677E-02
+ -0.186598109452E-02 -0.188965451826E-02 -0.191362571702E-02 -0.193789843633E-02
+ -0.196247646887E-02 -0.198736365499E-02 -0.201256388338E-02 -0.203808109162E-02
+ -0.206391926683E-02 -0.209008244626E-02 -0.211657471798E-02 -0.214340022145E-02
+ -0.217056314822E-02 -0.219806774254E-02 -0.222591830206E-02 -0.225411917849E-02
+ -0.228267477828E-02 -0.231158956329E-02 -0.234086805153E-02 -0.237051481780E-02
+ -0.240053449448E-02 -0.243093177220E-02 -0.246171140061E-02 -0.249287818907E-02
+ -0.252443700746E-02 -0.255639278692E-02 -0.258875052060E-02 -0.262151526445E-02
+ -0.265469213804E-02 -0.268828632531E-02 -0.272230307544E-02 -0.275674770360E-02
+ -0.279162559183E-02 -0.282694218989E-02 -0.286270301605E-02 -0.289891365801E-02
+ -0.293557977377E-02 -0.297270709248E-02 -0.301030141535E-02 -0.304836861658E-02
+ -0.308691464424E-02 -0.312594552122E-02 -0.316546734618E-02 -0.320548629448E-02
+ -0.324600861916E-02 -0.328704065192E-02 -0.332858880409E-02 -0.337065956766E-02
+ -0.341325951626E-02 -0.345639530622E-02 -0.350007367760E-02 -0.354430145523E-02
+ -0.358908554978E-02 -0.363443295885E-02 -0.368035076808E-02 -0.372684615221E-02
+ -0.377392637623E-02 -0.382159879652E-02 -0.386987086199E-02 -0.391875011525E-02
+ -0.396824419377E-02 -0.401836083110E-02 -0.406910785807E-02 -0.412049320398E-02
+ -0.417252489792E-02 -0.422521106991E-02 -0.427855995229E-02 -0.433257988092E-02
+ -0.438727929652E-02 -0.444266674596E-02 -0.449875088365E-02 -0.455554047285E-02
+ -0.461304438702E-02 -0.467127161127E-02 -0.473023124371E-02 -0.478993249688E-02
+ -0.485038469923E-02 -0.491159729652E-02 -0.497357985333E-02 -0.503634205455E-02
+ -0.509989370689E-02 -0.516424474040E-02 -0.522940521005E-02 -0.529538529728E-02
+ -0.536219531160E-02 -0.542984569219E-02 -0.549834700954E-02 -0.556770996709E-02
+ -0.563794540292E-02 -0.570906429145E-02 -0.578107774512E-02 -0.585399701614E-02
+ -0.592783349828E-02 -0.600259872860E-02 -0.607830438930E-02 -0.615496230949E-02
+ -0.623258446709E-02 -0.631118299070E-02 -0.639077016143E-02 -0.647135841492E-02
+ -0.655296034318E-02 -0.663558869663E-02 -0.671925638607E-02 -0.680397648468E-02
+ -0.688976223009E-02 -0.697662702644E-02 -0.706458444645E-02 -0.715364823357E-02
+ -0.724383230413E-02 -0.733515074948E-02 -0.742761783823E-02 -0.752124801845E-02
+ -0.761605591994E-02 -0.771205635654E-02 -0.780926432837E-02 -0.790769502426E-02
+ -0.800736382409E-02 -0.810828630116E-02 -0.821047822466E-02 -0.831395556214E-02
+ -0.841873448196E-02 -0.852483135588E-02 -0.863226276156E-02 -0.874104548516E-02
+ -0.885119652399E-02 -0.896273308915E-02 -0.907567260820E-02 -0.919003272792E-02
+ -0.930583131704E-02 -0.942308646901E-02 -0.954181650488E-02 -0.966203997613E-02
+ -0.978377566757E-02 -0.990704260026E-02 -0.100318600345E-01 -0.101582474729E-01
+ -0.102862246632E-01 -0.104158116016E-01 -0.105470285359E-01 -0.106798959685E-01
+ -0.108144346595E-01 -0.109506656302E-01 -0.110886101664E-01 -0.112282898215E-01
+ -0.113697264199E-01 -0.115129420606E-01 -0.116579591205E-01 -0.118048002579E-01
+ -0.119534884160E-01 -0.121040468266E-01 -0.122564990138E-01 -0.124108687972E-01
+ -0.125671802963E-01 -0.127254579337E-01 -0.128857264392E-01 -0.130480108535E-01
+ -0.132123365325E-01 -0.133787291505E-01 -0.135472147050E-01 -0.137178195202E-01
+ -0.138905702514E-01 -0.140654938892E-01 -0.142426177633E-01 -0.144219695473E-01
+ -0.146035772626E-01 -0.147874692830E-01 -0.149736743389E-01 -0.151622215223E-01
+ -0.153531402904E-01 -0.155464604713E-01 -0.157422122677E-01 -0.159404262622E-01
+ -0.161411334217E-01 -0.163443651027E-01 -0.165501530554E-01 -0.167585294295E-01
+ -0.169695267786E-01 -0.171831780656E-01 -0.173995166676E-01 -0.176185763812E-01
+ -0.178403914278E-01 -0.180649964589E-01 -0.182924265613E-01 -0.185227172628E-01
+ -0.187559045376E-01 -0.189920248120E-01 -0.192311149697E-01 -0.194732123582E-01
+ -0.197183547937E-01 -0.199665805677E-01 -0.202179284527E-01 -0.204724377081E-01
+ -0.207301480863E-01 -0.209910998389E-01 -0.212553337232E-01 -0.215228910078E-01
+ -0.217938134798E-01 -0.220681434506E-01 -0.223459237629E-01 -0.226271977970E-01
+ -0.229120094776E-01 -0.232004032805E-01 -0.234924242395E-01 -0.237881179536E-01
+ -0.240875305934E-01 -0.243907089087E-01 -0.246977002354E-01 -0.250085525030E-01
+ -0.253233142417E-01 -0.256420345898E-01 -0.259647633016E-01 -0.262915507546E-01
+ -0.266224479571E-01 -0.269575065564E-01 -0.272967788464E-01 -0.276403177755E-01
+ -0.279881769546E-01 -0.283404106654E-01 -0.286970738684E-01 -0.290582222114E-01
+ -0.294239120376E-01 -0.297942003945E-01 -0.301691450419E-01 -0.305488044610E-01
+ -0.309332378628E-01 -0.313225051972E-01 -0.317166671618E-01 -0.321157852107E-01
+ -0.325199215639E-01 -0.329291392164E-01 -0.333435019472E-01 -0.337630743289E-01
+ -0.341879217369E-01 -0.346181103594E-01 -0.350537072061E-01 -0.354947801189E-01
+ -0.359413977807E-01 -0.363936297260E-01 -0.368515463502E-01 -0.373152189198E-01
+ -0.377847195827E-01 -0.382601213779E-01 -0.387414982456E-01 -0.392289250381E-01
+ -0.397224775293E-01 -0.402222324255E-01 -0.407282673756E-01 -0.412406609817E-01
+ -0.417594928094E-01 -0.422848433986E-01 -0.428167942736E-01 -0.433554279540E-01
+ -0.439008279653E-01 -0.444530788492E-01 -0.450122661745E-01 -0.455784765476E-01
+ -0.461517976230E-01 -0.467323181139E-01 -0.473201278028E-01 -0.479153175518E-01
+ -0.485179793130E-01 -0.491282061392E-01 -0.497460921937E-01 -0.503717327608E-01
+ -0.510052242555E-01 -0.516466642337E-01 -0.522961514020E-01 -0.529537856271E-01
+ -0.536196679452E-01 -0.542939005713E-01 -0.549765869083E-01 -0.556678315555E-01
+ -0.563677403169E-01 -0.570764202096E-01 -0.577939794716E-01 -0.585205275689E-01
+ -0.592561752025E-01 -0.600010343154E-01 -0.607552180979E-01 -0.615188409940E-01
+ -0.622920187054E-01 -0.630748681966E-01 -0.638675076984E-01 -0.646700567104E-01
+ -0.654826360037E-01 -0.663053676221E-01 -0.671383748822E-01 -0.679817823735E-01
+ -0.688357159559E-01 -0.697003027580E-01 -0.705756711724E-01 -0.714619508509E-01
+ -0.723592726979E-01 -0.732677688622E-01 -0.741875727273E-01 -0.751188189003E-01
+ -0.760616431986E-01 -0.770161826348E-01 -0.779825753995E-01 -0.789609608422E-01
+ -0.799514794491E-01 -0.809542728192E-01 -0.819694836374E-01 -0.829972556443E-01
+ -0.840377336040E-01 -0.850910632673E-01 -0.861573913326E-01 -0.872368654025E-01
+ -0.883296339367E-01 -0.894358462006E-01 -0.905556522094E-01 -0.916892026679E-01
+ -0.928366489047E-01 -0.939981428016E-01 -0.951738367166E-01 -0.963638834020E-01
+ -0.975684359151E-01 -0.987876475224E-01 -0.100021671597     -0.101270661508
+ -0.102534770501     -0.103814151573     -0.105108957333     -0.106419339858
+ -0.107745450538     -0.109087439907     -0.110445457462     -0.111819651478
+ -0.113210168802     -0.114617154633     -0.116040752295     -0.117481102989
+ -0.118938345528     -0.120412616060     -0.121904047768     -0.123412770557
+ -0.124938910711     -0.126482590544     -0.128043928013     -0.129623036316
+ -0.131220023466     -0.132834991835     -0.134468037672     -0.136119250595
+ -0.137788713046     -0.139476499719     -0.141182676956     -0.142907302101
+ -0.144650422824     -0.146412076399     -0.148192288949     -0.149991074640
+ -0.151808434834     -0.153644357197     -0.155498814755     -0.157371764894
+ -0.159263148318     -0.161172887934     -0.163100887698     -0.165047031378
+ -0.167011181271     -0.168993176846     -0.170992833313     -0.173009940129
+ -0.175044259426     -0.177095524355     -0.179163437362     -0.181247668372
+ -0.183347852885     -0.185463589995     -0.187594440308     -0.189739923769
+ -0.191899517392     -0.194072652897     -0.196258714238     -0.198457035037
+ -0.200666895906     -0.202887521669     -0.205118078475     -0.207357670801
+ -0.209605338356     -0.211860052863     -0.214120714744     -0.216386149699
+ -0.218655105174     -0.220926246734     -0.223198154335     -0.225469318502
+ -0.227738136419     -0.230002907941     -0.232261831525     -0.234513000102
+ -0.236754396894     -0.238983891186     -0.241199234075     -0.243398054201
+ -0.245577853489     -0.247736002915     -0.249869738321     -0.251976156302
+ -0.254052210195     -0.256094706201     -0.258100299672     -0.260065491600
+ -0.261986625345     -0.263859883657     -0.265681286024     -0.267446686410
+ -0.269151771429     -0.270792059022     -0.272362897695     -0.273859466387
+ -0.275276775039     -0.276609665944     -0.277852815951     -0.279000739612
+ -0.280047793357     -0.280988180792     -0.281815959205     -0.282525047383
+ -0.283109234843     -0.283562192561     -0.283877485316     -0.284048585735
+ -0.284068890145     -0.283931736318     -0.283630423212     -0.283158232769
+ -0.282508453869     -0.281674408489     -0.280649480119     -0.279427144479
+ -0.278001002549     -0.276364815912     -0.274512544376     -0.272438385832
+ -0.270136818254     -0.267602643718     -0.264831034297     -0.261817579607
+ -0.258558335793     -0.255049875626     -0.251289339403     -0.247274486224
+ -0.243003745221     -0.238476266210     -0.233691969224     -0.228651592305
+ -0.223356736885     -0.217809910057     -0.212014562981     -0.205975124645
+ -0.199697030197     -0.193186743036     -0.186451769902     -0.179500668197
+ -0.172343044883     -0.164989546349     -0.157451838797     -0.149742578831
+ -0.141875374155     -0.133864734501     -0.125726013222     -0.117475340275
+ -0.109129547712     -0.100706089202     -0.922229555265E-01 -0.836985884770E-01
+ -0.751517960411E-01 -0.666016722425E-01 -0.580675254357E-01 -0.495688192516E-01
+ -0.411251306918E-01 -0.327561300501E-01 -0.244815873565E-01 -0.163214098328E-01
+ -0.829571437527E-02 -0.424938274015E-03  0.727000981933E-02  0.147675583089E-01
+  0.220452422445E-01  0.290794385742E-01  0.358450748329E-01  0.423153229110E-01
+  0.484612939773E-01  0.542517555526E-01  0.596528970237E-01  0.646281753530E-01
+  0.691382781194E-01  0.731412459435E-01  0.765928003495E-01  0.794469256085E-01
+  0.816567534051E-01  0.831757964653E-01  0.839595706772E-01  0.839676337560E-01
+  0.831660511646E-01  0.815302758244E-01  0.790483963119E-01  0.757246680700E-01
+  0.715831933744E-01  0.666715584614E-01  0.610641709732E-01  0.548649688780E-01
+  0.482090949519E-01  0.412630507919E-01  0.342227630895E-01  0.273089137359E-01
+  0.207588036537E-01  0.148139342587E-01  0.970239139349E-02  0.561498884996E-02
+  0.267394842267E-02  0.892629015198E-03  0.124432912263E-03 -0.151519396598E-05
+ -0.158311596416E-05 -0.159845775930E-05 -0.161440388118E-05 -0.163094681024E-05
+ -0.164807993640E-05 -0.166579682822E-05 -0.168408935711E-05 -0.170294994665E-05
+ -0.172237184058E-05 -0.174234556230E-05 -0.176286549244E-05 -0.178392294207E-05
+ -0.180551083823E-05 -0.182762255463E-05 -0.185025082341E-05 -0.187338951361E-05
+ -0.189703262419E-05 -0.192117451953E-05 -0.194581066840E-05 -0.197093532149E-05
+ -0.199654445916E-05 -0.202263381815E-05 -0.204920033704E-05 -0.207624162028E-05
+ -0.210375394870E-05 -0.213173504855E-05 -0.216018353935E-05 -0.218909877146E-05
+ -0.221847869040E-05 -0.224832282519E-05 -0.227862990901E-05 -0.230940253232E-05
+ -0.234064031344E-05 -0.237234217236E-05 -0.240451186885E-05 -0.243715049919E-05
+ -0.247025954942E-05 -0.250384307979E-05 -0.253806627727E-05 -0.257269941325E-05
+ -0.260774359211E-05 -0.264319947161E-05 -0.267906996701E-05 -0.271535537877E-05
+ -0.275205846784E-05 -0.278917973771E-05 -0.282672155955E-05 -0.286468451804E-05
+ -0.290307065143E-05 -0.294188159192E-05 -0.298111857384E-05 -0.302078198696E-05
+ -0.306087360968E-05 -0.310139567513E-05 -0.314234940138E-05 -0.318373492649E-05
+ -0.322555487336E-05 -0.326781123152E-05 -0.331050495106E-05 -0.335363735563E-05
+ -0.339721122243E-05 -0.344122742035E-05 -0.348568915699E-05 -0.353059660288E-05
+ -0.357595412684E-05 -0.362176426246E-05 -0.366802761066E-05 -0.371474769573E-05
+ -0.376192947929E-05 -0.380957396016E-05 -0.385768547468E-05 -0.390626658892E-05
+ -0.395532330393E-05 -0.400485695958E-05 -0.405487462071E-05 -0.410537855292E-05
+ -0.415637523637E-05 -0.420786973012E-05 -0.425986660600E-05 -0.431237133723E-05
+ -0.436539112668E-05 -0.441893216216E-05 -0.447299888557E-05 -0.452760110647E-05
+ -0.458274472846E-05 -0.463843446141E-05 -0.469468247794E-05 -0.475149346357E-05
+ -0.480887540074E-05 -0.486683800156E-05 -0.492539080759E-05 -0.498454018530E-05
+ -0.504429497791E-05 -0.510466617243E-05 -0.516566122347E-05 -0.522729101249E-05
+ -0.528956342448E-05 -0.535248947894E-05 -0.541607839263E-05 -0.548033913057E-05
+ -0.554528122620E-05 -0.561091529302E-05 -0.567724911856E-05 -0.574429329195E-05
+ -0.581205751717E-05 -0.588054981725E-05 -0.594977967694E-05 -0.601975407173E-05
+ -0.609048491437E-05 -0.616197697972E-05 -0.623423828269E-05 -0.630727554705E-05
+ -0.638109875289E-05 -0.645571010084E-05 -0.653111759773E-05 -0.660732644876E-05
+ -0.668433939057E-05 -0.676216131978E-05 -0.684079577695E-05 -0.692024437805E-05
+ -0.700050692006E-05 -0.708158511640E-05 -0.716347557272E-05 -0.724617620205E-05
+ -0.732968012634E-05 -0.741398085730E-05 -0.749906707499E-05 -0.758492251407E-05
+ -0.767153065746E-05 -0.775886898704E-05 -0.784690943842E-05 -0.793562313512E-05
+ -0.802497527275E-05 -0.811493210254E-05 -0.820545474361E-05 -0.829650338931E-05
+ -0.838803891514E-05 -0.848001903770E-05 -0.857239962215E-05 -0.866513417057E-05
+ -0.875817487765E-05 -0.885147201351E-05 -0.894497309543E-05 -0.903862085774E-05
+ -0.913235965072E-05 -0.922612782363E-05 -0.931986480574E-05 -0.941350187337E-05
+ -0.950697199999E-05 -0.960020416382E-05 -0.969312197542E-05 -0.978564826580E-05
+ -0.987770092057E-05 -0.996919585207E-05 -0.100600453753E-04 -0.101501571521E-04
+ -0.102394347031E-04 -0.103277791205E-04 -0.104150864380E-04 -0.105012493431E-04
+ -0.105861543277E-04 -0.106696874046E-04 -0.107517251990E-04 -0.108321430373E-04
+ -0.109108092862E-04 -0.109875886177E-04 -0.110623416195E-04 -0.111349203605E-04
+ -0.112051726546E-04 -0.112729437417E-04 -0.113380676875E-04 -0.114003767554E-04
+ -0.114596942759E-04 -0.115158393815E-04 -0.115686220040E-04 -0.116178477388E-04
+ -0.116633154416E-04 -0.117048129888E-04 -0.117421247572E-04 -0.117750261909E-04
+ -0.118032846623E-04 -0.118266605438E-04 -0.118449049182E-04 -0.118577600168E-04
+ -0.118649621998E-04 -0.118662351026E-04 -0.118612979918E-04 -0.118498579371E-04
+ -0.118316141879E-04 -0.118062571184E-04 -0.117734678773E-04 -0.117329173496E-04
+ -0.116842670406E-04 -0.116271714319E-04 -0.115612737984E-04 -0.114862091648E-04
+ -0.114016055233E-04 -0.113070788968E-04 -0.112022412395E-04 -0.110866931046E-04
+ -0.109600329340E-04 -0.108218474517E-04 -0.106717230405E-04 -0.105092367448E-04
+ -0.103339662912E-04 -0.101454848099E-04 -0.994336730693E-05 -0.972718753798E-05
+ -0.949652357057E-05 -0.925095853128E-05 -0.899008434122E-05 -0.871350492356E-05
+ -0.842083374307E-05 -0.811170798443E-05 -0.778578219394E-05 -0.744274117486E-05
+ -0.708229827394E-05 -0.670420758654E-05 -0.630826473623E-05 -0.589431846265E-05
+ -0.546227706926E-05 -0.501211646256E-05 -0.454389162639E-05 -0.405774647204E-05
+ -0.355392776490E-05 -0.303279757320E-05 -0.249484773868E-05 -0.194071781477E-05
+ -0.137121472627E-05 -0.787329530080E-06 -0.190263108379E-06  0.418550281925E-06
+  0.103741315830E-05  0.166433813677E-05  0.229701388272E-05  0.293276610007E-05
+  0.356851731047E-05  0.420074457809E-05  0.482543071355E-05  0.543800844558E-05
+  0.603330453584E-05  0.660547078724E-05  0.714791665197E-05  0.765323480729E-05
+  0.811310829769E-05  0.851822254942E-05  0.885816803020E-05  0.912131238400E-05
+  0.931123317319E-05  0.943129569058E-05  0.948466578978E-05  0.947429645391E-05
+  0.940292835594E-05  0.927308982617E-05  0.908708722948E-05  0.884700793741E-05
+  0.855471911824E-05  0.821186210130E-05  0.781985592572E-05  0.737989522090E-05
+  0.689295350347E-05  0.635978311233E-05  0.578092219225E-05  0.515670121461E-05
+  0.448724639617E-05  0.377249652469E-05  0.301220694610E-05  0.220597801867E-05
+  0.135325641233E-05  0.453375175117E-06 -0.494438121937E-06 -0.149102604447E-05
+ -0.253727124086E-05 -0.363406733024E-05 -0.478228114227E-05 -0.598271468074E-05
+ -0.723607373792E-05 -0.854293252165E-05 -0.990368769343E-05 -0.113185474057E-04
+ -0.127874985034E-04 -0.143103047857E-04 -0.158865113024E-04 -0.175154818537E-04
+ -0.191964840123E-04 -0.209288198302E-04 -0.227121060529E-04 -0.245467646615E-04
+ -0.264350936001E-04 -0.283839849301E-04 -0.304159494898E-04 -0.318300861051E-04
+ -0.330283635971E-04 -0.340612851184E-04 -0.349595475200E-04 -0.357216479025E-04
+ -0.363437658361E-04 -0.368194965940E-04 -0.371393630465E-04 -0.372900019800E-04
+ -0.372529370095E-04 -0.370027609051E-04 -0.365044358789E-04 -0.357092518876E-04
+ -0.345484973617E-04 -0.329230027449E-04 -0.306312507275E-04 -0.273918375829E-04
+ -0.227447227660E-04 -0.157123159121E-04
+ Core charge follows
+ Valence charge follows
+  0.235834565595E-14  0.955241310144E-14  0.217646941523E-13  0.391830560765E-13
+  0.620008871791E-13  0.904172461924E-13  0.124637015569E-12  0.164871058778E-12
+  0.211336381708E-12  0.264256298281E-12  0.323860600384E-12  0.390385732238E-12
+  0.464074969302E-12  0.545178601848E-12  0.633954123309E-12  0.730666423534E-12
+  0.835587987077E-12  0.948999096631E-12  0.107118804177E-11  0.120245133311E-11
+  0.134309392202E-11  0.149342942607E-11  0.165378036033E-11  0.182447837464E-11
+  0.200586449707E-11  0.219828938370E-11  0.240211357486E-11  0.261770775802E-11
+  0.284545303750E-11  0.308574121117E-11  0.333897505429E-11  0.360556861075E-11
+  0.388594749184E-11  0.418054918268E-11  0.448982335670E-11  0.481423219814E-11
+  0.515425073298E-11  0.551036716838E-11  0.588308324089E-11  0.627291457367E-11
+  0.668039104295E-11  0.710605715394E-11  0.755047242644E-11  0.801421179040E-11
+  0.849786599176E-11  0.900204200862E-11  0.952736347829E-11  0.100744711352E-10
+  0.106440232605E-10  0.112366961422E-10  0.118531845490E-10  0.124942022142E-10
+  0.131604823337E-10  0.138527780762E-10  0.145718631062E-10  0.153185321212E-10
+  0.160936014023E-10  0.168979093791E-10  0.177323172085E-10  0.185977093699E-10
+  0.194949942739E-10  0.204251048880E-10  0.213889993775E-10  0.223876617638E-10
+  0.234221025986E-10  0.244933596559E-10  0.256024986421E-10  0.267506139239E-10
+  0.279388292747E-10  0.291682986406E-10  0.304402069264E-10  0.317557708003E-10
+  0.331162395213E-10  0.345228957859E-10  0.359770565979E-10  0.374800741597E-10
+  0.390333367871E-10  0.406382698465E-10  0.422963367177E-10  0.440090397796E-10
+  0.457779214229E-10  0.476045650871E-10  0.494905963255E-10  0.514376838963E-10
+  0.534475408826E-10  0.555219258403E-10  0.576626439763E-10  0.598715483554E-10
+  0.621505411398E-10  0.645015748592E-10  0.669266537138E-10  0.694278349102E-10
+  0.720072300323E-10  0.746670064466E-10  0.774093887435E-10  0.802366602156E-10
+  0.831511643740E-10  0.861553065029E-10  0.892515552542E-10  0.924424442829E-10
+  0.957305739242E-10  0.991186129135E-10  0.102609300150E-09  0.106205446507E-09
+  0.109909936684E-09  0.113725731114E-09  0.117655867909E-09  0.121703464866E-09
+  0.125871721516E-09  0.130163921231E-09  0.134583433379E-09  0.139133715538E-09
+  0.143818315769E-09  0.148640874940E-09  0.153605129113E-09  0.158714911997E-09
+  0.163974157450E-09  0.169386902060E-09  0.174957287785E-09  0.180689564656E-09
+  0.186588093557E-09  0.192657349072E-09  0.198901922401E-09  0.205326524362E-09
+  0.211935988454E-09  0.218735274010E-09  0.225729469425E-09  0.232923795468E-09
+  0.240323608676E-09  0.247934404839E-09  0.255761822571E-09  0.263811646967E-09
+  0.272089813367E-09  0.280602411200E-09  0.289355687935E-09  0.298356053132E-09
+  0.307610082593E-09  0.317124522624E-09  0.326906294397E-09  0.336962498431E-09
+  0.347300419185E-09  0.357927529766E-09  0.368851496758E-09  0.380080185174E-09
+  0.391621663533E-09  0.403484209069E-09  0.415676313070E-09  0.428206686353E-09
+  0.441084264880E-09  0.454318215516E-09  0.467917941929E-09  0.481893090652E-09
+  0.496253557284E-09  0.511009492863E-09  0.526171310390E-09  0.541749691523E-09
+  0.557755593446E-09  0.574200255903E-09  0.591095208422E-09  0.608452277711E-09
+  0.626283595253E-09  0.644601605084E-09  0.663419071778E-09  0.682749088631E-09
+  0.702605086050E-09  0.723000840157E-09  0.743950481620E-09  0.765468504694E-09
+  0.787569776501E-09  0.810269546545E-09  0.833583456469E-09  0.857527550056E-09
+  0.882118283487E-09  0.907372535862E-09  0.933307619984E-09  0.959941293418E-09
+  0.987291769834E-09  0.101537773064E-08  0.104421833688E-08  0.107383324152E-08
+  0.110424260191E-08  0.113546709271E-08  0.116752791902E-08  0.120044682993E-08
+  0.123424613237E-08  0.126894870532E-08  0.130457801439E-08  0.134115812677E-08
+  0.137871372654E-08  0.141727013038E-08  0.145685330371E-08  0.149748987717E-08
+  0.153920716359E-08  0.158203317537E-08  0.162599664225E-08  0.167112702960E-08
+  0.171745455717E-08  0.176501021823E-08  0.181382579932E-08  0.186393390042E-08
+  0.191536795565E-08  0.196816225448E-08  0.202235196354E-08  0.207797314889E-08
+  0.213506279896E-08  0.219365884795E-08  0.225380019995E-08  0.231552675360E-08
+  0.237887942735E-08  0.244390018546E-08  0.251063206456E-08  0.257911920091E-08
+  0.264940685843E-08  0.272154145731E-08  0.279557060343E-08  0.287154311854E-08
+  0.294950907113E-08  0.302951980817E-08  0.311162798757E-08  0.319588761154E-08
+  0.328235406074E-08  0.337108412936E-08  0.346213606098E-08  0.355556958547E-08
+  0.365144595673E-08  0.374982799145E-08  0.385078010879E-08  0.395436837113E-08
+  0.406066052581E-08  0.416972604795E-08  0.428163618435E-08  0.439646399848E-08
+  0.451428441670E-08  0.463517427549E-08  0.475921237005E-08  0.488647950403E-08
+  0.501705854053E-08  0.515103445445E-08  0.528849438610E-08  0.542952769618E-08
+  0.557422602222E-08  0.572268333638E-08  0.587499600471E-08  0.603126284798E-08
+  0.619158520401E-08  0.635606699155E-08  0.652481477584E-08  0.669793783583E-08
+  0.687554823299E-08  0.705776088207E-08  0.724469362346E-08  0.743646729746E-08
+  0.763320582048E-08  0.783503626311E-08  0.804208893017E-08  0.825449744280E-08
+  0.847239882268E-08  0.869593357828E-08  0.892524579341E-08  0.916048321793E-08
+  0.940179736079E-08  0.964934358547E-08  0.990328120773E-08  0.101637735960E-07
+  0.104309882740E-07  0.107050970266E-07  0.109862760076E-07  0.112747058505E-07
+  0.115705717825E-07  0.118740637409E-07  0.121853764925E-07  0.125047097564E-07
+  0.128322683293E-07  0.131682622144E-07  0.135129067539E-07  0.138664227637E-07
+  0.142290366731E-07  0.146009806663E-07  0.149824928291E-07  0.153738172983E-07
+  0.157752044153E-07  0.161869108831E-07  0.166091999284E-07  0.170423414661E-07
+  0.174866122699E-07  0.179422961456E-07  0.184096841095E-07  0.188890745717E-07
+  0.193807735232E-07  0.198850947282E-07  0.204023599213E-07  0.209328990097E-07
+  0.214770502804E-07  0.220351606125E-07  0.226075856954E-07  0.231946902518E-07
+  0.237968482672E-07  0.244144432245E-07  0.250478683448E-07  0.256975268344E-07
+  0.263638321379E-07  0.270472081979E-07  0.277480897210E-07  0.284669224508E-07
+  0.292041634478E-07  0.299602813761E-07  0.307357567978E-07  0.315310824742E-07
+  0.323467636759E-07  0.331833184988E-07  0.340412781904E-07  0.349211874822E-07
+  0.358236049320E-07  0.367491032745E-07  0.376982697801E-07  0.386717066242E-07
+  0.396700312641E-07  0.406938768271E-07  0.417438925071E-07  0.428207439723E-07
+  0.439251137827E-07  0.450577018179E-07  0.462192257164E-07  0.474104213257E-07
+  0.486320431635E-07  0.498848648914E-07  0.511696797995E-07  0.524873013046E-07
+  0.538385634596E-07  0.552243214767E-07  0.566454522639E-07  0.581028549747E-07
+  0.595974515716E-07  0.611301874045E-07  0.627020318032E-07  0.643139786853E-07
+  0.659670471790E-07  0.676622822621E-07  0.694007554172E-07  0.711835653031E-07
+  0.730118384439E-07  0.748867299344E-07  0.768094241650E-07  0.787811355632E-07
+  0.808031093554E-07  0.828766223467E-07  0.850029837219E-07  0.871835358652E-07
+  0.894196552018E-07  0.917127530606E-07  0.940642765583E-07  0.964757095063E-07
+  0.989485733407E-07  0.101484428075E-06  0.104084873280E-06  0.106751549081E-06
+  0.109486137190E-06  0.112290361959E-06  0.115165991459E-06  0.118114838586E-06
+  0.121138762200E-06  0.124239668291E-06  0.127419511165E-06  0.130680294680E-06
+  0.134024073489E-06  0.137452954338E-06  0.140969097378E-06  0.144574717524E-06
+  0.148272085835E-06  0.152063530947E-06  0.155951440520E-06  0.159938262744E-06
+  0.164026507866E-06  0.168218749763E-06  0.172517627557E-06  0.176925847267E-06
+  0.181446183501E-06  0.186081481198E-06  0.190834657406E-06  0.195708703114E-06
+  0.200706685118E-06  0.205831747950E-06  0.211087115840E-06  0.216476094742E-06
+  0.222002074397E-06  0.227668530463E-06  0.233479026689E-06  0.239437217144E-06
+  0.245546848510E-06  0.251811762425E-06  0.258235897893E-06  0.264823293744E-06
+  0.271578091172E-06  0.278504536319E-06  0.285606982942E-06  0.292889895137E-06
+  0.300357850131E-06  0.308015541154E-06  0.315867780374E-06  0.323919501915E-06
+  0.332175764941E-06  0.340641756829E-06  0.349322796415E-06  0.358224337327E-06
+  0.367351971399E-06  0.376711432172E-06  0.386308598487E-06  0.396149498165E-06
+  0.406240311782E-06  0.416587376540E-06  0.427197190237E-06  0.438076415335E-06
+  0.449231883130E-06  0.460670598038E-06  0.472399741972E-06  0.484426678850E-06
+  0.496758959198E-06  0.509404324886E-06  0.522370713972E-06  0.535666265678E-06
+  0.549299325484E-06  0.563278450358E-06  0.577612414116E-06  0.592310212917E-06
+  0.607381070896E-06  0.622834445945E-06  0.638680035638E-06  0.654927783302E-06
+  0.671587884253E-06  0.688670792174E-06  0.706187225672E-06  0.724148174988E-06
+  0.742564908888E-06  0.761448981716E-06  0.780812240642E-06  0.800666833079E-06
+  0.821025214296E-06  0.841900155226E-06  0.863304750465E-06  0.885252426481E-06
+  0.907756950026E-06  0.930832436768E-06  0.954493360135E-06  0.978754560387E-06
+  0.100363125392E-05  0.102913904280E-05  0.105529392456E-05  0.108211230221E-05
+  0.110961099451E-05  0.113780724657E-05  0.116671874059E-05  0.119636360703E-05
+  0.122676043588E-05  0.125792828843E-05  0.128988670912E-05  0.132265573790E-05
+  0.135625592271E-05  0.139070833245E-05  0.142603457012E-05  0.146225678645E-05
+  0.149939769375E-05  0.153748058020E-05  0.157652932443E-05  0.161656841054E-05
+  0.165762294345E-05  0.169971866468E-05  0.174288196849E-05  0.178713991849E-05
+  0.183252026461E-05  0.187905146052E-05  0.192676268157E-05  0.197568384303E-05
+  0.202584561896E-05  0.207727946147E-05  0.213001762046E-05  0.218409316396E-05
+  0.223953999883E-05  0.229639289220E-05  0.235468749324E-05  0.241446035562E-05
+  0.247574896055E-05  0.253859174031E-05  0.260302810248E-05  0.266909845475E-05
+  0.273684423035E-05  0.280630791416E-05  0.287753306949E-05  0.295056436551E-05
+  0.302544760545E-05  0.310222975542E-05  0.318095897409E-05  0.326168464304E-05
+  0.334445739795E-05  0.342932916052E-05  0.351635317132E-05  0.360558402339E-05
+  0.369707769672E-05  0.379089159367E-05  0.388708457527E-05  0.398571699842E-05
+  0.408685075413E-05  0.419054930670E-05  0.429687773389E-05  0.440590276820E-05
+  0.451769283916E-05  0.463231811673E-05  0.474985055586E-05  0.487036394214E-05
+  0.499393393872E-05  0.512063813439E-05  0.525055609293E-05  0.538376940377E-05
+  0.552036173393E-05  0.566041888135E-05  0.580402882964E-05  0.595128180419E-05
+  0.610227032982E-05  0.625708928994E-05  0.641583598722E-05  0.657861020594E-05
+  0.674551427590E-05  0.691665313808E-05  0.709213441203E-05  0.727206846503E-05
+  0.745656848312E-05  0.764575054401E-05  0.783973369192E-05  0.803864001446E-05
+  0.824259472156E-05  0.845172622650E-05  0.866616622914E-05  0.888604980146E-05
+  0.911151547531E-05  0.934270533260E-05  0.957976509798E-05  0.982284423403E-05
+  0.100720960390E-04  0.103276777474E-04  0.105897506330E-04  0.108584801154E-04
+  0.111340358688E-04  0.114165919339E-04  0.117063268337E-04  0.120034236916E-04
+  0.123080703534E-04  0.126204595125E-04  0.129407888389E-04  0.132692611117E-04
+  0.136060843556E-04  0.139514719808E-04  0.143056429281E-04  0.146688218168E-04
+  0.150412390983E-04  0.154231312133E-04  0.158147407537E-04  0.162163166306E-04
+  0.166281142451E-04  0.170503956668E-04  0.174834298156E-04  0.179274926506E-04
+  0.183828673639E-04  0.188498445807E-04  0.193287225664E-04  0.198198074389E-04
+  0.203234133887E-04  0.208398629059E-04  0.213694870142E-04  0.219126255132E-04
+  0.224696272278E-04  0.230408502666E-04  0.236266622893E-04  0.242274407819E-04
+  0.248435733426E-04  0.254754579772E-04  0.261235034045E-04  0.267881293729E-04
+  0.274697669883E-04  0.281688590536E-04  0.288858604207E-04  0.296212383555E-04
+  0.303754729168E-04  0.311490573488E-04  0.319424984898E-04  0.327563171951E-04
+  0.335910487780E-04  0.344472434670E-04  0.353254668824E-04  0.362263005315E-04
+  0.371503423243E-04  0.380982071106E-04  0.390705272403E-04  0.400679531463E-04
+  0.410911539540E-04  0.421408181165E-04  0.432176540782E-04  0.443223909679E-04
+  0.454557793238E-04  0.466185918516E-04  0.478116242172E-04  0.490356958782E-04
+  0.502916509533E-04  0.515803591350E-04  0.529027166462E-04  0.542596472442E-04
+  0.556521032751E-04  0.570810667811E-04  0.585475506653E-04  0.600525999157E-04
+  0.615972928945E-04  0.631827426951E-04  0.648100985713E-04  0.664805474449E-04
+  0.681953154952E-04  0.699556698360E-04  0.717629202872E-04  0.736184212455E-04
+  0.755235736623E-04  0.774798271347E-04  0.794886821182E-04  0.815516922697E-04
+  0.836704669274E-04  0.858466737402E-04  0.880820414543E-04  0.903783628688E-04
+  0.927374979721E-04  0.951613772715E-04  0.976520053290E-04  0.100211464518E-03
+  0.102841919019E-03  0.105545619062E-03  0.108324905447E-03  0.111182214353E-03
+  0.114120082449E-03  0.117141152354E-03  0.120248178435E-03  0.123444033001E-03
+  0.126731712897E-03  0.130114346539E-03  0.133595201420E-03  0.137177692112E-03
+  0.140865388822E-03  0.144662026504E-03  0.148571514612E-03  0.152597947503E-03
+  0.156745615559E-03  0.161019017066E-03  0.165422870923E-03  0.169962130215E-03
+  0.174641996738E-03  0.179467936528E-03  0.184445696477E-03  0.189581322107E-03
+  0.194881176591E-03  0.200351961109E-03  0.206000736639E-03  0.211834947285E-03
+  0.217862445250E-03  0.224091517580E-03  0.230530914804E-03  0.237189881611E-03
+  0.244078189699E-03  0.251206172976E-03  0.258584765262E-03  0.266225540682E-03
+  0.274140756951E-03  0.282343401748E-03  0.290847242406E-03  0.299666879167E-03
+  0.308817802245E-03  0.318316452984E-03  0.328180289391E-03  0.338427856379E-03
+  0.349078861038E-03  0.360154253310E-03  0.371676312443E-03  0.383668739650E-03
+  0.396156757405E-03  0.409167215857E-03  0.422728706862E-03  0.436871686187E-03
+  0.451628604444E-03  0.467034047398E-03  0.483124886293E-03  0.499940438906E-03
+  0.517522642091E-03  0.535916236610E-03  0.555168965118E-03  0.575331784216E-03
+  0.596459091556E-03  0.618608969041E-03  0.641843443232E-03  0.666228764161E-03
+  0.691835703799E-03  0.718739875542E-03  0.747022076156E-03  0.776768651682E-03
+  0.808071888973E-03  0.841030434551E-03  0.875749742656E-03  0.912342554424E-03
+  0.950929410294E-03  0.991639197823E-03  0.103460973728E-02  0.107998840751E-02
+  0.112793281463E-02  0.117861150650E-02  0.123220473574E-02  0.128890527461E-02
+  0.134891928493E-02  0.141246724661E-02  0.147978494844E-02  0.155112454518E-02
+  0.162675568485E-02  0.170696671078E-02  0.179206594291E-02  0.188238304310E-02
+  0.197827046962E-02  0.208010502609E-02  0.218828951044E-02  0.230325446979E-02
+  0.242546006729E-02  0.255539806746E-02  0.269359394664E-02  0.284060913542E-02
+  0.299704340065E-02  0.316353737418E-02  0.334077523653E-02  0.352948756337E-02
+  0.373045434339E-02  0.394450817614E-02  0.417253765884E-02  0.441549097130E-02
+  0.467437966841E-02  0.495028268972E-02  0.524435059599E-02  0.555781004258E-02
+  0.589196849965E-02  0.624821922937E-02  0.662804653010E-02  0.703303125755E-02
+  0.746485663293E-02  0.792531434765E-02  0.841631097389E-02  0.893987469026E-02
+  0.949816233074E-02  0.100934667649E-01  0.107282246164E-01  0.114050243259E-01
+  0.121266145633E-01  0.128959129935E-01  0.137160153967E-01  0.145902051457E-01
+  0.155219630368E-01  0.165149774714E-01  0.175731549824E-01  0.187006310960E-01
+  0.199017815160E-01  0.211812336158E-01  0.225438782175E-01  0.239948816350E-01
+  0.255396979503E-01  0.271840814910E-01  0.289340994671E-01  0.307961447227E-01
+  0.327769485474E-01  0.348835934885E-01  0.371235260956E-01  0.395045695189E-01
+  0.420349358772E-01  0.447232382982E-01  0.475785025249E-01  0.506101779709E-01
+  0.538281480959E-01  0.572427399596E-01  0.608647327998E-01  0.647053654690E-01
+  0.687763425465E-01  0.730898389329E-01  0.776585027173E-01  0.824954560930E-01
+  0.876142940848E-01  0.930290808346E-01  0.987543431787E-01  0.104805061238
+  0.111196655728      0.117944971682      0.125066258276      0.132577144433
+  0.140494609865      0.148835951237      0.157618743093      0.166860793236
+  0.176580092208      0.186794756563      0.197522965628      0.208782891465
+  0.220592621768      0.232970075485      0.245932910959      0.259498426461
+  0.273683453023      0.288504239562      0.303976330330      0.320114434842
+  0.336932290511      0.354442518307      0.372656471899      0.391584080837
+  0.411233688483      0.431611885512      0.452723339987      0.474570625139
+  0.497154046161      0.520471467480      0.544518142134      0.569286545065
+  0.594766212273      0.620943587948      0.647801881842      0.675320939261
+  0.703477126169      0.732243232008      0.761588392855      0.791478037610
+  0.821873859868      0.852733818094      0.884012166621      0.915659519823
+  0.947622951662      0.979846132482       1.01226950466       1.04483049832
+   1.07746378786       1.11010158961       1.14267400022       1.17510937503
+   1.20733474475       1.23927626816       1.27085971803       1.30201099629
+   1.33265667417       1.36272455197       1.39214423251       1.42084770177
+   1.44876990932       1.47584934085       1.50202857451       1.52725481260
+   1.55148037960       1.57466317799       1.59676709270       1.61776233604
+   1.63762572466       1.65634088116       1.67389835353       1.69029564661
+   1.70553716067       1.71963403383       1.73260388598       1.74447046388
+   1.75526318827       1.76501660592       1.77376975121       1.78156542361
+   1.78844938941       1.79446951791       1.79967486384       1.80411471012
+   1.80783758598       1.81089027773       1.81331685027       1.81515769902
+   1.81644865257       1.81722014717       1.81749649435       1.81729526272
+   1.81662679453       1.81549387625       1.81389158059       1.81180729485
+   1.80922094736       1.80610543938       1.80242728515       1.79814745675
+   1.79322242371       1.78760536979       1.78124756088       1.77409982858
+   1.76611412481       1.75724509183       1.74745158227       1.73669805275
+   1.72495574439       1.71220355368       1.69842847714       1.68362557377
+   1.66779721925       1.65095202487       1.63310413563       1.61427279708
+   1.59448162818       1.57375789353       1.55213174699       1.52963555894
+   1.50630344961       1.48217115883       1.45727622432       1.43165805492
+   1.40535770075       1.37841777677       1.35088230966       1.32279658626
+   1.29420700227       1.26516090484       1.23570643283       1.20589235460
+   1.17576790445       1.14538261814       1.11478616855       1.08402820196
+   1.05315817597       1.02222519958      0.991277876237      0.960364150584
+  0.929531159479      0.898825088023      0.868291031158      0.837972861431
+  0.807913103458      0.778152815597      0.748731479288      0.719686896469
+  0.691055095457      0.662870245599      0.635164580989      0.607968333454
+  0.581309675030      0.555214669998      0.529707236608      0.504809118482
+  0.480539865699      0.456916825466      0.433955142263      0.411667767284
+  0.390065476958      0.369156900281      0.348948554647      0.329444889835
+  0.310648339741      0.292559381445      0.275176601133      0.258496766383
+  0.242514904289      0.227224384866      0.212617009176      0.198683101566
+  0.185411605433      0.172790181888      0.160805310709      0.149442392952
+  0.138685854622      0.128519250772      0.118925369450      0.109886334909
+  0.101383709511      0.933985938032E-01  0.859117242409E-01  0.789035680948E-01
+  0.723544150874E-01  0.662444653578E-01  0.605539133864E-01  0.552630275522E-01
+  0.503522250422E-01  0.458021418706E-01  0.415936978170E-01  0.377081561313E-01
+  0.341271779028E-01  0.308328710325E-01  0.278078337909E-01  0.250351929871E-01
+  0.224986368119E-01  0.201824424571E-01  0.180714986487E-01  0.161513232613E-01
+  0.144080762134E-01  0.128285678668E-01  0.114002631776E-01  0.101112818637E-01
+  0.895039487091E-02  0.790701743028E-02  0.697119900964E-02  0.613361046519E-02
+  0.538552870265E-02  0.471881915520E-02  0.412591638150E-02  0.359980308007E-02
+  0.313398780679E-02  0.272248167077E-02  0.235977427020E-02  0.204080911453E-02
+  0.176095876298E-02  0.151599989150E-02  0.130208848230E-02  0.111573531091E-02
+  0.953781886782E-03  0.813376984562E-03  0.691953884171E-03  0.587208419629E-03
+  0.497077918919E-03  0.419721100338E-03  0.353498974871E-03  0.296956789327E-03
+  0.248807031286E-03  0.207913504423E-03  0.173276471579E-03  0.144018852939E-03
+  0.119373458013E-03  0.986712226328E-04  0.813304158978E-04  0.668467768930E-04
+  0.547845369692E-04  0.447682803339E-04  0.364755936214E-04  0.296304538553E-04
+  0.239973037321E-04  0.193757633344E-04  0.155959281461E-04  0.125142044999E-04
+  0.100096352566E-04  0.798067051710E-05  0.634234042812E-05  0.502378959395E-05
+  0.396613518410E-05  0.312061347983E-05  0.244698227897E-05  0.191214923758E-05
+  0.148899883354E-05  0.115539316072E-05  0.893324180733E-06  0.688197352907E-06
+  0.528228719817E-06  0.403939536212E-06  0.307734388555E-06  0.233550459208E-06
+  0.176567144757E-06  0.132966645700E-06  0.997374103152E-07  0.745134459105E-07
+  0.554435139370E-07  0.410851104251E-07  0.303189090749E-07  0.222800205328E-07
+  0.163030072278E-07  0.118780977734E-07  0.861647710191E-08  0.622289650341E-08
+  0.447415931725E-08  0.320230036074E-08  0.228149676342E-08  0.161793079298E-08
+  0.114197634687E-08  0.802205940794E-09  0.560816002000E-09  0.390152639546E-09
+  0.270085830587E-09  0.186035368122E-09  0.127493650294E-09  0.869267155168E-10
+  0.589606173952E-10  0.397819780141E-10  0.266992272722E-10  0.178225504047E-10
+  0.118323140299E-10  0.781210731985E-11  0.512903154097E-11  0.334842729105E-11
+  0.217347188443E-11  0.140263208039E-11  0.899867666016E-12  0.573887579316E-12
+  0.363794449684E-12  0.229210097151E-12  0.143524756824E-12  0.893103622217E-13
+  0.552236344891E-13  0.339282888877E-13  0.207099036091E-13  0.125585134444E-13
+  0.756496440427E-14  0.452634930271E-14  0.268983322693E-14  0.158745673943E-14
+  0.930337225186E-15  0.541381110166E-15  0.312789226750E-15  0.179410471985E-15
+  0.102153197151E-15  0.577330759573E-16  0.323836574464E-16  0.180266484356E-16
+  0.995751364935E-17  0.545747939676E-17  0.296753955967E-17  0.160074291389E-17
+  0.856493848462E-18  0.454528283707E-18  0.239214487013E-18  0.124841595102E-18
+  0.645998104793E-19  0.331403873086E-19  0.168535762532E-19  0.849547996617E-20
+  0.424421892509E-20  0.210123066303E-20  0.103078311560E-20  0.500990420979E-21
+  0.241218422833E-21  0.115043008329E-21  0.543410314920E-22  0.254192074666E-22
+  0.117736357674E-22  0.539909563159E-23  0.245098147764E-23  0.110132057003E-23
+  0.489764925154E-24  0.215529475025E-24  0.938458203042E-25  0.404255583510E-25
+  0.172255399160E-25  0.725951507095E-26  0.302553291975E-26  0.124679923301E-26
+  0.507962579379E-27  0.204572353234E-27  0.814293485576E-28  0.320310984819E-28
+  0.124496427064E-28  0.478049338751E-29  0.181323957178E-29  0.679265237009E-30
+  0.251281006794E-30  0.917803224807E-31  0.330934406744E-31  0.117779223280E-31
+  0.413676698998E-32  0.143367072358E-32  0.490188712051E-33  0.165322299120E-33
+  0.549897397812E-34  0.180360314406E-34  0.583224163247E-35  0.185904739745E-35
+  0.584023283340E-36  0.180791496990E-36  0.551386892966E-37  0.165648298245E-37
+  0.490106155056E-38  0.142785964735E-38  0.409535554594E-39  0.115618132630E-39
+  0.321221801628E-40  0.878100480726E-41  0.236133653617E-41  0.624538561267E-42
+  0.162427826999E-42  0.415309984873E-43  0.104377012681E-43  0.257790259615E-44
+  0.625553817749E-45  0.149109575472E-45  0.349055071174E-46  0.802293975773E-47
+  0.181019999320E-47  0.400842708487E-48  0.870914281829E-49  0.185621827196E-49
+  0.387999963652E-50  0.795204282869E-51  0.159758524058E-51  0.314543065787E-52
+  0.606761312913E-53  0.114648074461E-53  0.212136132989E-54  0.384280065310E-55
+  0.681319997634E-56  0.118197323454E-56  0.200585214017E-57  0.332893165218E-58
+  0.540136853070E-59  0.856588722325E-60  0.132735006036E-60  0.200916925329E-61
+  0.296986758804E-62  0.428565588502E-63  0.603566502320E-64  0.829331113010E-65
+  0.111144841026E-65  0.145236631597E-66  0.184984698398E-67  0.229593341149E-68
+  0.277681678125E-69  0.326191050173E-70  0.363140684456E-71  0.393408805618E-72
+  0.414597717311E-73  0.424882383793E-74
Added: SwiftApps/ematter/workflow-run/Ti.psf
--- SwiftApps/ematter/workflow-run/Ti.psf	                        (rev 0)
+++ SwiftApps/ematter/workflow-run/Ti.psf	2015-01-27 22:12:52 UTC (rev 8376)
@@ -0,0 +1,2801 @@
+ Ti ca rel pcec
+ ATM3      14-MAR-14 Troullier-Martins
+ 4s 2.00r r= 2.48/4p 0.00r r= 2.78/3d 2.00r r= 1.40/4f 0.00r r= 2.48/
+   4  3 1110  0.112670553485E-03  0.125000000000E-01   4.00000000000
+ Radial grid follows
+  0.141722109707E-05  0.285226864102E-05  0.430536686097E-05  0.577674280646E-05
+  0.726662638298E-05  0.877525038787E-05  0.103028505467E-04  0.118496655501E-04
+  0.134159370911E-04  0.150019099027E-04  0.166078317965E-04  0.182339537010E-04
+  0.198805297011E-04  0.215478170776E-04  0.232360763476E-04  0.249455713050E-04
+  0.266765690619E-04  0.284293400901E-04  0.302041582639E-04  0.320013009020E-04
+  0.338210488117E-04  0.356636863323E-04  0.375295013796E-04  0.394187854911E-04
+  0.413318338713E-04  0.432689454378E-04  0.452304228683E-04  0.472165726475E-04
+  0.492277051156E-04  0.512641345159E-04  0.533261790447E-04  0.554141609008E-04
+  0.575284063354E-04  0.596692457037E-04  0.618370135164E-04  0.640320484914E-04
+  0.662546936074E-04  0.685052961574E-04  0.707842078024E-04  0.730917846272E-04
+  0.754283871952E-04  0.777943806054E-04  0.801901345490E-04  0.826160233675E-04
+  0.850724261110E-04  0.875597265974E-04  0.900783134723E-04  0.926285802703E-04
+  0.952109254756E-04  0.978257525849E-04  0.100473470170E-03  0.103154491943E-03
+  0.105869236818E-03  0.108618128980E-03  0.111401597949E-03  0.114220078647E-03
+  0.117074011469E-03  0.119963842346E-03  0.122890022820E-03  0.125853010114E-03
+  0.128853267200E-03  0.131891262875E-03  0.134967471831E-03  0.138082374732E-03
+  0.141236458288E-03  0.144430215331E-03  0.147664144893E-03  0.150938752281E-03
+  0.154254549159E-03  0.157612053628E-03  0.161011790303E-03  0.164454290402E-03
+  0.167940091822E-03  0.171469739226E-03  0.175043784128E-03  0.178662784981E-03
+  0.182327307261E-03  0.186037923557E-03  0.189795213661E-03  0.193599764655E-03
+  0.197452171010E-03  0.201353034672E-03  0.205302965158E-03  0.209302579654E-03
+  0.213352503106E-03  0.217453368325E-03  0.221605816078E-03  0.225810495194E-03
+  0.230068062662E-03  0.234379183736E-03  0.238744532038E-03  0.243164789662E-03
+  0.247640647282E-03  0.252172804260E-03  0.256761968756E-03  0.261408857834E-03
+  0.266114197582E-03  0.270878723218E-03  0.275703179208E-03  0.280588319384E-03
+  0.285534907060E-03  0.290543715148E-03  0.295615526287E-03  0.300751132956E-03
+  0.305951337605E-03  0.311216952776E-03  0.316548801232E-03  0.321947716085E-03
+  0.327414540928E-03  0.332950129962E-03  0.338555348134E-03  0.344231071271E-03
+  0.349978186217E-03  0.355797590970E-03  0.361690194823E-03  0.367656918508E-03
+  0.373698694339E-03  0.379816466353E-03  0.386011190467E-03  0.392283834617E-03
+  0.398635378918E-03  0.405066815811E-03  0.411579150222E-03  0.418173399715E-03
+  0.424850594656E-03  0.431611778370E-03  0.438458007306E-03  0.445390351200E-03
+  0.452409893246E-03  0.459517730262E-03  0.466714972861E-03  0.474002745628E-03
+  0.481382187291E-03  0.488854450903E-03  0.496420704022E-03  0.504082128888E-03
+  0.511839922616E-03  0.519695297376E-03  0.527649480587E-03  0.535703715106E-03
+  0.543859259424E-03  0.552117387860E-03  0.560479390765E-03  0.568946574719E-03
+  0.577520262735E-03  0.586201794471E-03  0.594992526433E-03  0.603893832190E-03
+  0.612907102591E-03  0.622033745977E-03  0.631275188405E-03  0.640632873868E-03
+  0.650108264524E-03  0.659702840923E-03  0.669418102236E-03  0.679255566492E-03
+  0.689216770816E-03  0.699303271666E-03  0.709516645078E-03  0.719858486912E-03
+  0.730330413103E-03  0.740934059910E-03  0.751671084174E-03  0.762543163578E-03
+  0.773551996906E-03  0.784699304310E-03  0.795986827581E-03  0.807416330415E-03
+  0.818989598698E-03  0.830708440774E-03  0.842574687738E-03  0.854590193714E-03
+  0.866756836150E-03  0.879076516108E-03  0.891551158563E-03  0.904182712705E-03
+  0.916973152237E-03  0.929924475694E-03  0.943038706745E-03  0.956317894516E-03
+  0.969764113906E-03  0.983379465916E-03  0.997166077971E-03  0.101112610426E-02
+  0.102526172606E-02  0.103957515209E-02  0.105406861886E-02  0.106874439100E-02
+  0.108360476163E-02  0.109865205271E-02  0.111388861542E-02  0.112931683048E-02
+  0.114493910861E-02  0.116075789080E-02  0.117677564877E-02  0.119299488534E-02
+  0.120941813479E-02  0.122604796329E-02  0.124288696928E-02  0.125993778389E-02
+  0.127720307135E-02  0.129468552939E-02  0.131238788968E-02  0.133031291825E-02
+  0.134846341592E-02  0.136684221875E-02  0.138545219846E-02  0.140429626289E-02
+  0.142337735648E-02  0.144269846068E-02  0.146226259445E-02  0.148207281474E-02
+  0.150213221691E-02  0.152244393531E-02  0.154301114367E-02  0.156383705566E-02
+  0.158492492538E-02  0.160627804785E-02  0.162789975953E-02  0.164979343887E-02
+  0.167196250679E-02  0.169441042725E-02  0.171714070780E-02  0.174015690008E-02
+  0.176346260042E-02  0.178706145038E-02  0.181095713733E-02  0.183515339502E-02
+  0.185965400416E-02  0.188446279303E-02  0.190958363805E-02  0.193502046440E-02
+  0.196077724664E-02  0.198685800932E-02  0.201326682760E-02  0.204000782793E-02
+  0.206708518863E-02  0.209450314061E-02  0.212226596796E-02  0.215037800869E-02
+  0.217884365536E-02  0.220766735579E-02  0.223685361374E-02  0.226640698963E-02
+  0.229633210121E-02  0.232663362437E-02  0.235731629376E-02  0.238838490362E-02
+  0.241984430849E-02  0.245169942396E-02  0.248395522745E-02  0.251661675901E-02
+  0.254968912205E-02  0.258317748422E-02  0.261708707812E-02  0.265142320221E-02
+  0.268619122157E-02  0.272139656877E-02  0.275704474473E-02  0.279314131955E-02
+  0.282969193338E-02  0.286670229733E-02  0.290417819436E-02  0.294212548014E-02
+  0.298055008402E-02  0.301945800991E-02  0.305885533726E-02  0.309874822199E-02
+  0.313914289743E-02  0.318004567534E-02  0.322146294687E-02  0.326340118353E-02
+  0.330586693827E-02  0.334886684645E-02  0.339240762689E-02  0.343649608293E-02
+  0.348113910348E-02  0.352634366409E-02  0.357211682808E-02  0.361846574760E-02
+  0.366539766476E-02  0.371291991276E-02  0.376103991705E-02  0.380976519649E-02
+  0.385910336449E-02  0.390906213025E-02  0.395964929992E-02  0.401087277785E-02
+  0.406274056782E-02  0.411526077427E-02  0.416844160360E-02  0.422229136540E-02
+  0.427681847383E-02  0.433203144885E-02  0.438793891760E-02  0.444454961573E-02
+  0.450187238879E-02  0.455991619357E-02  0.461869009954E-02  0.467820329024E-02
+  0.473846506472E-02  0.479948483901E-02  0.486127214757E-02  0.492383664480E-02
+  0.498718810653E-02  0.505133643155E-02  0.511629164317E-02  0.518206389077E-02
+  0.524866345139E-02  0.531610073137E-02  0.538438626790E-02  0.545353073074E-02
+  0.552354492386E-02  0.559443978712E-02  0.566622639797E-02  0.573891597323E-02
+  0.581251987080E-02  0.588704959142E-02  0.596251678052E-02  0.603893323000E-02
+  0.611631088009E-02  0.619466182119E-02  0.627399829582E-02  0.635433270045E-02
+  0.643567758749E-02  0.651804566725E-02  0.660144980992E-02  0.668590304754E-02
+  0.677141857613E-02  0.685800975765E-02  0.694569012215E-02  0.703447336986E-02
+  0.712437337336E-02  0.721540417969E-02  0.730758001260E-02  0.740091527477E-02
+  0.749542455001E-02  0.759112260558E-02  0.768802439451E-02  0.778614505790E-02
+  0.788549992730E-02  0.798610452710E-02  0.808797457699E-02  0.819112599437E-02
+  0.829557489685E-02  0.840133760479E-02  0.850843064382E-02  0.861687074746E-02
+  0.872667485968E-02  0.883786013761E-02  0.895044395418E-02  0.906444390082E-02
+  0.917987779026E-02  0.929676365929E-02  0.941511977157E-02  0.953496462046E-02
+  0.965631693198E-02  0.977919566766E-02  0.990362002757E-02  0.100296094533E-01
+  0.101571836308E-01  0.102863624940E-01  0.104171662273E-01  0.105496152690E-01
+  0.106837303145E-01  0.108195323196E-01  0.109570425037E-01  0.110962823530E-01
+  0.112372736239E-01  0.113800383467E-01  0.115245988287E-01  0.116709776577E-01
+  0.118191977057E-01  0.119692821324E-01  0.121212543888E-01  0.122751382208E-01
+  0.124309576732E-01  0.125887370929E-01  0.127485011335E-01  0.129102747583E-01
+  0.130740832449E-01  0.132399521885E-01  0.134079075066E-01  0.135779754425E-01
+  0.137501825697E-01  0.139245557960E-01  0.141011223674E-01  0.142799098728E-01
+  0.144609462483E-01  0.146442597810E-01  0.148298791141E-01  0.150178332510E-01
+  0.152081515599E-01  0.154008637784E-01  0.155960000182E-01  0.157935907697E-01
+  0.159936669070E-01  0.161962596922E-01  0.164014007810E-01  0.166091222270E-01
+  0.168194564872E-01  0.170324364267E-01  0.172480953240E-01  0.174664668763E-01
+  0.176875852046E-01  0.179114848590E-01  0.181382008244E-01  0.183677685256E-01
+  0.186002238330E-01  0.188356030683E-01  0.190739430098E-01  0.193152808987E-01
+  0.195596544446E-01  0.198071018313E-01  0.200576617229E-01  0.203113732700E-01
+  0.205682761155E-01  0.208284104010E-01  0.210918167730E-01  0.213585363893E-01
+  0.216286109253E-01  0.219020825808E-01  0.221789940863E-01  0.224593887098E-01
+  0.227433102634E-01  0.230308031105E-01  0.233219121725E-01  0.236166829357E-01
+  0.239151614586E-01  0.242173943792E-01  0.245234289219E-01  0.248333129053E-01
+  0.251470947494E-01  0.254648234832E-01  0.257865487525E-01  0.261123208274E-01
+  0.264421906107E-01  0.267762096450E-01  0.271144301216E-01  0.274569048880E-01
+  0.278036874567E-01  0.281548320131E-01  0.285103934243E-01  0.288704272475E-01
+  0.292349897387E-01  0.296041378615E-01  0.299779292961E-01  0.303564224481E-01
+  0.307396764579E-01  0.311277512097E-01  0.315207073410E-01  0.319186062519E-01
+  0.323215101150E-01  0.327294818848E-01  0.331425853077E-01  0.335608849320E-01
+  0.339844461179E-01  0.344133350477E-01  0.348476187360E-01  0.352873650407E-01
+  0.357326426729E-01  0.361835212083E-01  0.366400710975E-01  0.371023636773E-01
+  0.375704711820E-01  0.380444667542E-01  0.385244244568E-01  0.390104192840E-01
+  0.395025271737E-01  0.400008250185E-01  0.405053906787E-01  0.410163029936E-01
+  0.415336417943E-01  0.420574879160E-01  0.425879232108E-01  0.431250305602E-01
+  0.436688938884E-01  0.442195981751E-01  0.447772294690E-01  0.453418749011E-01
+  0.459136226984E-01  0.464925621976E-01  0.470787838593E-01  0.476723792818E-01
+  0.482734412155E-01  0.488820635776E-01  0.494983414666E-01  0.501223711772E-01
+  0.507542502153E-01  0.513940773132E-01  0.520419524452E-01  0.526979768433E-01
+  0.533622530124E-01  0.540348847471E-01  0.547159771475E-01  0.554056366356E-01
+  0.561039709722E-01  0.568110892734E-01  0.575271020279E-01  0.582521211141E-01
+  0.589862598178E-01  0.597296328496E-01  0.604823563630E-01  0.612445479727E-01
+  0.620163267726E-01  0.627978133547E-01  0.635891298280E-01  0.643903998371E-01
+  0.652017485822E-01  0.660233028383E-01  0.668551909747E-01  0.676975429757E-01
+  0.685504904605E-01  0.694141667039E-01  0.702887066572E-01  0.711742469688E-01
+  0.720709260063E-01  0.729788838777E-01  0.738982624531E-01  0.748292053874E-01
+  0.757718581423E-01  0.767263680092E-01  0.776928841322E-01  0.786715575314E-01
+  0.796625411265E-01  0.806659897608E-01  0.816820602251E-01  0.827109112824E-01
+  0.837527036930E-01  0.848076002389E-01  0.858757657499E-01  0.869573671290E-01
+  0.880525733786E-01  0.891615556270E-01  0.902844871548E-01  0.914215434224E-01
+  0.925729020973E-01  0.937387430814E-01  0.949192485398E-01  0.961146029289E-01
+  0.973249930253E-01  0.985506079549E-01  0.997916392224E-01  0.101048280742
+  0.102320728865      0.103609182416      0.104913842717      0.106234913625
+  0.107572601559      0.108927115536      0.110298667201      0.111687470863
+  0.113093743524      0.114517704917      0.115959577540      0.117419586688
+  0.118897960490      0.120394929946      0.121910728959      0.123445594376
+  0.124999766024      0.126573486745      0.128167002435      0.129780562086
+  0.131414417818      0.133068824925      0.134744041912      0.136440330535
+  0.138157955842      0.139897186216      0.141658293414      0.143441552614
+  0.145247242454      0.147075645076      0.148927046171      0.150801735025
+  0.152700004563      0.154622151392      0.156568475851      0.158539282058
+  0.160534877956      0.162555575360      0.164601690009      0.166673541611
+  0.168771453898      0.170895754674      0.173046775864      0.175224853569
+  0.177430328120      0.179663544125      0.181924850529      0.184214600667
+  0.186533152315      0.188880867754      0.191258113817      0.193665261954
+  0.196102688288      0.198570773671      0.201069903746      0.203600469007
+  0.206162864861      0.208757491688      0.211384754902      0.214045065019
+  0.216738837718      0.219466493906      0.222228459786      0.225025166919
+  0.227857052298      0.230724558409      0.233628133308      0.236568230682
+  0.239545309929      0.242559836223      0.245612280589      0.248703119980
+  0.251832837343      0.255001921705      0.258210868241      0.261460178356
+  0.264750359760      0.268081926552      0.271455399295      0.274871305102
+  0.278330177714      0.281832557588      0.285378991977      0.288970035019
+  0.292606247823      0.296288198552      0.300016462521      0.303791622277
+  0.307614267698      0.311484996078      0.315404412228      0.319373128564
+  0.323391765206      0.327460950075      0.331581318988      0.335753515762
+  0.339978192310      0.344256008748      0.348587633493      0.352973743370
+  0.357415023717      0.361912168494      0.366465880388      0.371076870927
+  0.375745860587      0.380473578907      0.385260764603      0.390108165682
+  0.395016539561      0.399986653182      0.405019283137      0.410115215784
+  0.415275247373      0.420500184170      0.425790842580      0.431148049281
+  0.436572641347      0.442065466381      0.447627382649      0.453259259211
+  0.458961976059      0.464736424255      0.470583506068      0.476504135116
+  0.482499236510      0.488569746995      0.494716615103      0.500940801294
+  0.507243278109      0.513625030323      0.520087055098      0.526630362138
+  0.533255973850      0.539964925496      0.546758265367      0.553637054933
+  0.560602369021      0.567655295974      0.574796937827      0.582028410477
+  0.589350843854      0.596765382105      0.604273183766      0.611875421947
+  0.619573284512      0.627367974268      0.635260709151      0.643252722418
+  0.651345262837      0.659539594882      0.667836998937      0.676238771486
+  0.684746225324      0.693360689758      0.702083510816      0.710916051455
+  0.719859691779      0.728915829249      0.738085878906      0.747371273587
+  0.756773464156      0.766293919723      0.775934127880      0.785695594927
+  0.795579846114      0.805588425877      0.815722898074      0.825984846239
+  0.836375873822      0.846897604442      0.857551682140      0.868339771639
+  0.879263558598      0.890324749883      0.901525073826      0.912866280501
+  0.924350141994      0.935978452683      0.947753029514      0.959675712289
+  0.971748363952      0.983972870879      0.996351143174       1.00888511497
+   1.02157674472       1.03442801552       1.04744093540       1.06061753767
+   1.07395988119       1.08747005074       1.10115015729       1.11500233841
+   1.12902875851       1.14323160926       1.15761310987       1.17217550750
+   1.18692107754       1.20185212402       1.21697097994       1.23228000766
+   1.24778159924       1.26347817684       1.27937219308       1.29546613144
+   1.31176250661       1.32826386496       1.34497278484       1.36189187706
+   1.37902378526       1.39637118633       1.41393679085       1.43172334348
+   1.44973362340       1.46797044475       1.48643665707       1.50513514575
+   1.52406883246       1.54324067564       1.56265367091       1.58231085161
+   1.60221528920       1.62237009379       1.64277841462       1.66344344052
+   1.68436840045       1.70555656397       1.72701124178       1.74873578622
+   1.77073359179       1.79300809568       1.81556277835       1.83840116400
+   1.86152682117       1.88494336330       1.90865444928       1.93266378399
+   1.95697511897       1.98159225289       2.00651903224       2.03175935187
+   2.05731715564       2.08319643701       2.10940123966       2.13593565815
+   2.16280383855       2.19000997904       2.21755833066       2.24545319788
+   2.27369893934       2.30229996848       2.33126075429       2.36058582194
+   2.39027975353       2.42034718880       2.45079282585       2.48162142186
+   2.51283779388       2.54444681952       2.57645343776       2.60886264969
+   2.64167951933       2.67490917437       2.70855680702       2.74262767478
+   2.77712710130       2.81206047719       2.84743326085       2.88325097936
+   2.91951922931       2.95624367767       2.99343006274       3.03108419494
+   3.06921195783       3.10781930893       3.14691228072       3.18649698157
+   3.22657959666       3.26716638898       3.30826370030       3.34987795216
+   3.39201564686       3.43468336853       3.47788778405       3.52163564423
+   3.56593378475       3.61078912728       3.65620868056       3.70219954149
+   3.74876889624       3.79592402136       3.84367228493       3.89202114773
+   3.94097816435       3.99055098444       4.04074735383       4.09157511583
+   4.14304221237       4.19515668529       4.24792667759       4.30136043467
+   4.35546630568       4.41025274476       4.46572831241       4.52190167681
+   4.57878161514       4.63637701502       4.69469687585       4.75375031022
+   4.81354654536       4.87409492454       4.93540490857       4.99748607727
+   5.06034813094       5.12400089190       5.18845430604       5.25371844432
+   5.31980350440       5.38671981221       5.45447782355       5.52308812575
+   5.59256143932       5.66290861959       5.73414065846       5.80626868608
+   5.87930397261       5.95325792994       6.02814211354       6.10396822422
+   6.18074810995       6.25849376776       6.33721734555       6.41693114406
+   6.49764761872       6.57937938164       6.66213920358       6.74594001593
+   6.83079491273       6.91671715275       7.00372016150       7.09181753337
+   7.18102303377       7.27135060124       7.36281434963       7.45542857035
+   7.54920773456       7.64416649544       7.74031969049       7.83768234385
+   7.93626966862       8.03609706928       8.13718014407       8.23953468741
+   8.34317669241       8.44812235335       8.55438806821       8.66199044120
+   8.77094628543       8.88127262547       8.99298670003       9.10610596466
+   9.22064809449       9.33663098694       9.45407276458       9.57299177793
+   9.69340660833       9.81533607084       9.93879921718       10.0638153387
+   10.1904039695       10.3185848892       10.4483781265       10.5798039616
+   10.7128829303       10.8476358263       10.9840837051       11.1222478869
+   11.2621499602       11.4038117849       11.5472554961       11.6925035070
+   11.8395785130       11.9885034948       12.1393017222       12.2919967579
+   12.4466124607       12.6031729896       12.7617028075       12.9222266851
+   13.0847697045       13.2493572633       13.4160150788       13.5847691916
+   13.7556459698       13.9286721132       14.1038746577       14.2812809788
+   14.4609187967       14.6428161803       14.8270015512       15.0135036890
+   15.2023517348       15.3935751966       15.5872039535       15.7832682603
+   15.9817987525       16.1828264508       16.3863827664       16.5924995051
+   16.8012088733       17.0125434822       17.2265363532       17.4432209231
+   17.6626310494       17.8848010154       18.1097655355       18.3375597609
+   18.5682192850       18.8017801487       19.0382788464       19.2777523315
+   19.5202380222       19.7657738075       20.0143980527       20.2661496059
+   20.5210678039       20.7791924780       21.0405639609       21.3052230923
+   21.5732112257       21.8445702349       22.1193425203       22.3975710155
+   22.6792991944       22.9645710775       23.2534312392       23.5459248144
+   23.8420975058       24.1419955912       24.4456659300       24.7531559715
+   25.0645137616       25.3797879506       25.6990278007       26.0222831937
+   26.3496046391       26.6810432813       27.0166509085       27.3564799600
+   27.7005835347       28.0490153996       28.4018299978       28.7590824573
+   29.1208285995       29.4871249481       29.8580287376       30.2335979224
+   30.6138911860       30.9989679499       31.3888883833       31.7837134120
+   32.1835047281       32.5883248000       32.9982368815       33.4133050223
+   33.8335940775       34.2591697183       34.6900984416       35.1264475810
+   35.5682853170       36.0156806874       36.4687035989       36.9274248371
+   37.3919160781       37.8622498997       38.3384997925       38.8207401715
+   39.3090463878       39.8034947401       40.3041624871       40.8111278590
+   41.3244700703       41.8442693318       42.3706068630       42.9035649054
+   43.4432267347       43.9896766742       44.5430001078       45.1032834933
+   45.6706143763       46.2450814033       46.8267743359       47.4157840649
+   48.0122026243       48.6161232055       49.2276401726       49.8468490762
+   50.4738466690       51.1087309206       51.7516010330       52.4025574560
+   53.0617019028       53.7291373660       54.4049681339       55.0892998064
+   55.7822393116       56.4838949229       57.1943762752       57.9137943828
+   58.6422616562       59.3798919199       60.1268004301       60.8831038928
+   61.6489204820       62.4243698580       63.2095731865       64.0046531569
+   64.8097340023       65.6249415180       66.4504030820       67.2862476742
+   68.1326058971       68.9896099960       69.8573938793       70.7360931402
+   71.6258450772       72.5267887158       73.4390648302       74.3628159656
+   75.2981864599       76.2453224666       77.2043719777       78.1754848465
+   79.1588128116       80.1545095197       81.1627305507       82.1836334411
+   83.2173777090       84.2641248791       85.3240385077       86.3972842085
+   87.4840296784       88.5844447235       89.6987012859       90.8269734705
+   91.9694375721       93.1262721031       94.2976578211       95.4837777576
+   96.6848172463       97.9009639520       99.1324079000       100.379341506
+   101.641959606       102.920459487       104.215040916       105.525906175
+   106.853260090       108.197310061       109.558266100       110.936340858
+   112.331749663       113.744710549       115.175444296       116.624174458
+   118.091127402       119.576532343
+ Down Pseudopotential follows (l on next line)
+  0
+ -0.329654675809E-06 -0.663455896997E-06 -0.100145582070E-05 -0.134370726011E-05
+ -0.169026369272E-05 -0.204117926871E-05 -0.239650881936E-05 -0.275630786566E-05
+ -0.312063262698E-05 -0.348954002980E-05 -0.386308771671E-05 -0.424133405530E-05
+ -0.462433814737E-05 -0.501215983811E-05 -0.540485972550E-05 -0.580249916971E-05
+ -0.620514030276E-05 -0.661284603818E-05 -0.702568008087E-05 -0.744370693702E-05
+ -0.786699192423E-05 -0.829560118170E-05 -0.872960168053E-05 -0.916906123425E-05
+ -0.961404850936E-05 -0.100646330361E-04 -0.105208852192E-04 -0.109828763492E-04
+ -0.114506786132E-04 -0.119243651062E-04 -0.124040098429E-04 -0.128896877687E-04
+ -0.133814747720E-04 -0.138794476956E-04 -0.143836843488E-04 -0.148942635197E-04
+ -0.154112649875E-04 -0.159347695348E-04 -0.164648589604E-04 -0.170016160919E-04
+ -0.175451247989E-04 -0.180954700059E-04 -0.186527377056E-04 -0.192170149722E-04
+ -0.197883899755E-04 -0.203669519941E-04 -0.209527914297E-04 -0.215459998210E-04
+ -0.221466698583E-04 -0.227548953976E-04 -0.233707714758E-04 -0.239943943247E-04
+ -0.246258613871E-04 -0.252652713312E-04 -0.259127240663E-04 -0.265683207585E-04
+ -0.272321638464E-04 -0.279043570570E-04 -0.285850054223E-04 -0.292742152953E-04
+ -0.299720943666E-04 -0.306787516818E-04 -0.313942976577E-04 -0.321188441002E-04
+ -0.328525042217E-04 -0.335953926583E-04 -0.343476254884E-04 -0.351093202502E-04
+ -0.358805959606E-04 -0.366615731336E-04 -0.374523737987E-04 -0.382531215208E-04
+ -0.390639414190E-04 -0.398849601859E-04 -0.407163061081E-04 -0.415581090857E-04
+ -0.424105006527E-04 -0.432736139977E-04 -0.441475839847E-04 -0.450325471740E-04
+ -0.459286418436E-04 -0.468360080110E-04 -0.477547874548E-04 -0.486851237371E-04
+ -0.496271622256E-04 -0.505810501167E-04 -0.515469364585E-04 -0.525249721735E-04
+ -0.535153100829E-04 -0.545181049303E-04 -0.555335134054E-04 -0.565616941691E-04
+ -0.576028078781E-04 -0.586570172098E-04 -0.597244868879E-04 -0.608053837081E-04
+ -0.618998765643E-04 -0.630081364748E-04 -0.641303366091E-04 -0.652666523149E-04
+ -0.664172611455E-04 -0.675823428879E-04 -0.687620795903E-04 -0.699566555910E-04
+ -0.711662575469E-04 -0.723910744630E-04 -0.736312977218E-04 -0.748871211128E-04
+ -0.761587408636E-04 -0.774463556698E-04 -0.787501667265E-04 -0.800703777597E-04
+ -0.814071950578E-04 -0.827608275042E-04 -0.841314866099E-04 -0.855193865463E-04
+ -0.869247441792E-04 -0.883477791018E-04 -0.897887136701E-04 -0.912477730367E-04
+ -0.927251851866E-04 -0.942211809725E-04 -0.957359941512E-04 -0.972698614198E-04
+ -0.988230224527E-04 -0.100395719939E-03 -0.101988199622E-03 -0.103600710334E-03
+ -0.105233504039E-03 -0.106886835870E-03 -0.108560964169E-03 -0.110256150528E-03
+ -0.111972659831E-03 -0.113710760291E-03 -0.115470723498E-03 -0.117252824456E-03
+ -0.119057341630E-03 -0.120884556986E-03 -0.122734756040E-03 -0.124608227898E-03
+ -0.126505265300E-03 -0.128426164673E-03 -0.130371226171E-03 -0.132340753723E-03
+ -0.134335055082E-03 -0.136354441872E-03 -0.138399229638E-03 -0.140469737894E-03
+ -0.142566290172E-03 -0.144689214076E-03 -0.146838841329E-03 -0.149015507830E-03
+ -0.151219553700E-03 -0.153451323340E-03 -0.155711165485E-03 -0.157999433255E-03
+ -0.160316484213E-03 -0.162662680419E-03 -0.165038388491E-03 -0.167443979654E-03
+ -0.169879829807E-03 -0.172346319576E-03 -0.174843834377E-03 -0.177372764471E-03
+ -0.179933505033E-03 -0.182526456205E-03 -0.185152023167E-03 -0.187810616194E-03
+ -0.190502650722E-03 -0.193228547414E-03 -0.195988732226E-03 -0.198783636470E-03
+ -0.201613696888E-03 -0.204479355714E-03 -0.207381060745E-03 -0.210319265413E-03
+ -0.213294428855E-03 -0.216307015981E-03 -0.219357497555E-03 -0.222446350259E-03
+ -0.225574056776E-03 -0.228741105857E-03 -0.231947992407E-03 -0.235195217554E-03
+ -0.238483288732E-03 -0.241812719760E-03 -0.245184030920E-03 -0.248597749041E-03
+ -0.252054407580E-03 -0.255554546705E-03 -0.259098713382E-03 -0.262687461456E-03
+ -0.266321351744E-03 -0.270000952116E-03 -0.273726837589E-03 -0.277499590414E-03
+ -0.281319800167E-03 -0.285188063845E-03 -0.289104985955E-03 -0.293071178609E-03
+ -0.297087261623E-03 -0.301153862611E-03 -0.305271617085E-03 -0.309441168553E-03
+ -0.313663168620E-03 -0.317938277090E-03 -0.322267162071E-03 -0.326650500078E-03
+ -0.331088976136E-03 -0.335583283895E-03 -0.340134125729E-03 -0.344742212853E-03
+ -0.349408265433E-03 -0.354133012696E-03 -0.358917193046E-03 -0.363761554181E-03
+ -0.368666853206E-03 -0.373633856757E-03 -0.378663341116E-03 -0.383756092336E-03
+ -0.388912906361E-03 -0.394134589155E-03 -0.399421956823E-03 -0.404775835745E-03
+ -0.410197062697E-03 -0.415686484991E-03 -0.421244960602E-03 -0.426873358304E-03
+ -0.432572557807E-03 -0.438343449894E-03 -0.444186936561E-03 -0.450103931156E-03
+ -0.456095358525E-03 -0.462162155158E-03 -0.468305269331E-03 -0.474525661260E-03
+ -0.480824303247E-03 -0.487202179836E-03 -0.493660287964E-03 -0.500199637121E-03
+ -0.506821249505E-03 -0.513526160184E-03 -0.520315417260E-03 -0.527190082029E-03
+ -0.534151229150E-03 -0.541199946817E-03 -0.548337336921E-03 -0.555564515233E-03
+ -0.562882611573E-03 -0.570292769986E-03 -0.577796148928E-03 -0.585393921443E-03
+ -0.593087275348E-03 -0.600877413418E-03 -0.608765553581E-03 -0.616752929103E-03
+ -0.624840788781E-03 -0.633030397148E-03 -0.641323034659E-03 -0.649719997906E-03
+ -0.658222599809E-03 -0.666832169831E-03 -0.675550054184E-03 -0.684377616040E-03
+ -0.693316235748E-03 -0.702367311048E-03 -0.711532257293E-03 -0.720812507671E-03
+ -0.730209513431E-03 -0.739724744111E-03 -0.749359687770E-03 -0.759115851220E-03
+ -0.768994760268E-03 -0.778997959952E-03 -0.789127014786E-03 -0.799383509007E-03
+ -0.809769046826E-03 -0.820285252677E-03 -0.830933771477E-03 -0.841716268883E-03
+ -0.852634431558E-03 -0.863689967432E-03 -0.874884605978E-03 -0.886220098480E-03
+ -0.897698218312E-03 -0.909320761218E-03 -0.921089545595E-03 -0.933006412781E-03
+ -0.945073227347E-03 -0.957291877391E-03 -0.969664274836E-03 -0.982192355734E-03
+ -0.994878080573E-03 -0.100772343458E-02 -0.102073042806E-02 -0.103390109668E-02
+ -0.104723750180E-02 -0.106074173084E-02 -0.107441589756E-02 -0.108826214240E-02
+ -0.110228263287E-02 -0.111647956384E-02 -0.113085515790E-02 -0.114541166573E-02
+ -0.116015136646E-02 -0.117507656801E-02 -0.119018960748E-02 -0.120549285150E-02
+ -0.122098869662E-02 -0.123667956971E-02 -0.125256792830E-02 -0.126865626102E-02
+ -0.128494708798E-02 -0.130144296117E-02 -0.131814646484E-02 -0.133506021599E-02
+ -0.135218686471E-02 -0.136952909463E-02 -0.138708962338E-02 -0.140487120299E-02
+ -0.142287662034E-02 -0.144110869761E-02 -0.145957029274E-02 -0.147826429987E-02
+ -0.149719364983E-02 -0.151636131061E-02 -0.153577028780E-02 -0.155542362514E-02
+ -0.157532440494E-02 -0.159547574863E-02 -0.161588081726E-02 -0.163654281197E-02
+ -0.165746497456E-02 -0.167865058797E-02 -0.170010297686E-02 -0.172182550810E-02
+ -0.174382159137E-02 -0.176609467965E-02 -0.178864826986E-02 -0.181148590334E-02
+ -0.183461116653E-02 -0.185802769146E-02 -0.188173915640E-02 -0.190574928644E-02
+ -0.193006185414E-02 -0.195468068007E-02 -0.197960963353E-02 -0.200485263310E-02
+ -0.203041364736E-02 -0.205629669549E-02 -0.208250584797E-02 -0.210904522722E-02
+ -0.213591900832E-02 -0.216313141966E-02 -0.219068674369E-02 -0.221858931758E-02
+ -0.224684353398E-02 -0.227545384175E-02 -0.230442474668E-02 -0.233376081226E-02
+ -0.236346666046E-02 -0.239354697246E-02 -0.242400648948E-02 -0.245485001357E-02
+ -0.248608240842E-02 -0.251770860015E-02 -0.254973357819E-02 -0.258216239611E-02
+ -0.261500017249E-02 -0.264825209174E-02 -0.268192340506E-02 -0.271601943129E-02
+ -0.275054555785E-02 -0.278550724163E-02 -0.282091000996E-02 -0.285675946157E-02
+ -0.289306126752E-02 -0.292982117223E-02 -0.296704499444E-02 -0.300473862826E-02
+ -0.304290804417E-02 -0.308155929007E-02 -0.312069849236E-02 -0.316033185702E-02
+ -0.320046567068E-02 -0.324110630176E-02 -0.328226020159E-02 -0.332393390555E-02
+ -0.336613403426E-02 -0.340886729477E-02 -0.345214048173E-02 -0.349596047865E-02
+ -0.354033425913E-02 -0.358526888814E-02 -0.363077152331E-02 -0.367684941620E-02
+ -0.372350991369E-02 -0.377076045929E-02 -0.381860859453E-02 -0.386706196037E-02
+ -0.391612829861E-02 -0.396581545333E-02 -0.401613137240E-02 -0.406708410894E-02
+ -0.411868182285E-02 -0.417093278240E-02 -0.422384536575E-02 -0.427742806260E-02
+ -0.433168947582E-02 -0.438663832309E-02 -0.444228343864E-02 -0.449863377493E-02
+ -0.455569840443E-02 -0.461348652141E-02 -0.467200744375E-02 -0.473127061481E-02
+ -0.479128560533E-02 -0.485206211534E-02 -0.491360997610E-02 -0.497593915216E-02
+ -0.503905974336E-02 -0.510298198690E-02 -0.516771625949E-02 -0.523327307948E-02
+ -0.529966310908E-02 -0.536689715661E-02 -0.543498617876E-02 -0.550394128295E-02
+ -0.557377372972E-02 -0.564449493513E-02 -0.571611647328E-02 -0.578865007879E-02
+ -0.586210764944E-02 -0.593650124875E-02 -0.601184310872E-02 -0.608814563255E-02
+ -0.616542139744E-02 -0.624368315748E-02 -0.632294384654E-02 -0.640321658129E-02
+ -0.648451466426E-02 -0.656685158692E-02 -0.665024103288E-02 -0.673469688117E-02
+ -0.682023320957E-02 -0.690686429797E-02 -0.699460463188E-02 -0.708346890601E-02
+ -0.717347202785E-02 -0.726462912146E-02 -0.735695553120E-02 -0.745046682567E-02
+ -0.754517880172E-02 -0.764110748844E-02 -0.773826915141E-02 -0.783668029693E-02
+ -0.793635767641E-02 -0.803731829081E-02 -0.813957939526E-02 -0.824315850373E-02
+ -0.834807339382E-02 -0.845434211170E-02 -0.856198297715E-02 -0.867101458869E-02
+ -0.878145582890E-02 -0.889332586985E-02 -0.900664417860E-02 -0.912143052294E-02
+ -0.923770497721E-02 -0.935548792827E-02 -0.947480008163E-02 -0.959566246777E-02
+ -0.971809644853E-02 -0.984212372378E-02 -0.996776633813E-02 -0.100950466879E-01
+ -0.102239875285E-01 -0.103546119811E-01 -0.104869435410E-01 -0.106210060845E-01
+ -0.107568238776E-01 -0.108944215833E-01 -0.110338242707E-01 -0.111750574229E-01
+ -0.113181469463E-01 -0.114631191790E-01 -0.116100009008E-01 -0.117588193419E-01
+ -0.119096021933E-01 -0.120623776163E-01 -0.122171742532E-01 -0.123740212374E-01
+ -0.125329482046E-01 -0.126939853038E-01 -0.128571632086E-01 -0.130225131289E-01
+ -0.131900668232E-01 -0.133598566108E-01 -0.135319153845E-01 -0.137062766236E-01
+ -0.138829744074E-01 -0.140620434288E-01 -0.142435190086E-01 -0.144274371100E-01
+ -0.146138343532E-01 -0.148027480313E-01 -0.149942161252E-01 -0.151882773205E-01
+ -0.153849710237E-01 -0.155843373792E-01 -0.157864172868E-01 -0.159912524198E-01
+ -0.161988852433E-01 -0.164093590329E-01 -0.166227178944E-01 -0.168390067838E-01
+ -0.170582715274E-01 -0.172805588428E-01 -0.175059163611E-01 -0.177343926478E-01
+ -0.179660372268E-01 -0.182009006026E-01 -0.184390342846E-01 -0.186804908118E-01
+ -0.189253237772E-01 -0.191735878542E-01 -0.194253388226E-01 -0.196806335956E-01
+ -0.199395302479E-01 -0.202020880434E-01 -0.204683674648E-01 -0.207384302432E-01
+ -0.210123393885E-01 -0.212901592207E-01 -0.215719554016E-01 -0.218577949680E-01
+ -0.221477463646E-01 -0.224418794782E-01 -0.227402656730E-01 -0.230429778260E-01
+ -0.233500903637E-01 -0.236616792992E-01 -0.239778222705E-01 -0.242985985789E-01
+ -0.246240892293E-01 -0.249543769701E-01 -0.252895463346E-01 -0.256296836832E-01
+ -0.259748772460E-01 -0.263252171666E-01 -0.266807955461E-01 -0.270417064889E-01
+ -0.274080461482E-01 -0.277799127726E-01 -0.281574067539E-01 -0.285406306749E-01
+ -0.289296893585E-01 -0.293246899175E-01 -0.297257418040E-01 -0.301329568614E-01
+ -0.305464493751E-01 -0.309663361251E-01 -0.313927364385E-01 -0.318257722430E-01
+ -0.322655681203E-01 -0.327122513609E-01 -0.331659520182E-01 -0.336268029641E-01
+ -0.340949399445E-01 -0.345705016347E-01 -0.350536296959E-01 -0.355444688312E-01
+ -0.360431668426E-01 -0.365498746874E-01 -0.370647465348E-01 -0.375879398231E-01
+ -0.381196153166E-01 -0.386599371620E-01 -0.392090729458E-01 -0.397671937506E-01
+ -0.403344742114E-01 -0.409110925728E-01 -0.414972307443E-01 -0.420930743567E-01
+ -0.426988128181E-01 -0.433146393690E-01 -0.439407511379E-01 -0.445773491965E-01
+ -0.452246386150E-01 -0.458828285166E-01 -0.465521321332E-01 -0.472327668600E-01
+ -0.479249543115E-01 -0.486289203769E-01 -0.493448952770E-01 -0.500731136211E-01
+ -0.508138144660E-01 -0.515672413753E-01 -0.523336424816E-01 -0.531132705502E-01
+ -0.539063830457E-01 -0.547132422020E-01 -0.555341150958E-01 -0.563692737250E-01
+ -0.572189950927E-01 -0.580835612963E-01 -0.589632596254E-01 -0.598583826664E-01
+ -0.607692284178E-01 -0.616961004155E-01 -0.626393078709E-01 -0.635991658224E-01
+ -0.645759953030E-01 -0.655701235247E-01 -0.665818840837E-01 -0.676116171860E-01
+ -0.686596698988E-01 -0.697263964281E-01 -0.708121584263E-01 -0.719173253330E-01
+ -0.730422747525E-01 -0.741873928702E-01 -0.753530749142E-01 -0.765397256639E-01
+ -0.777477600109E-01 -0.789776035769E-01 -0.802296933938E-01 -0.815044786505E-01
+ -0.828024215117E-01 -0.841239980158E-01 -0.854696990569E-01 -0.868400314572E-01
+ -0.882355191364E-01 -0.896567043867E-01 -0.911041492571E-01 -0.925784370581E-01
+ -0.940801739922E-01 -0.956099909185E-01 -0.971685452598E-01 -0.987565230608E-01
+ -0.100374641204     -0.102023649796     -0.103704334727     -0.105417520414
+ -0.107164072748     -0.108944902228     -0.110760967321     -0.112613278035
+ -0.114502899721     -0.116430957119     -0.118398638643     -0.120407200925
+ -0.122457973626     -0.124552364513     -0.126691864820     -0.128878054899
+ -0.131112610164     -0.133397307347     -0.135734031064     -0.138124780708
+ -0.140571677674     -0.143076972925     -0.145643054919     -0.148272457900
+ -0.150967870562     -0.153732145124     -0.156568306802     -0.159479563719
+ -0.162469317274     -0.165541172979     -0.168698951814     -0.171946702116
+ -0.175288712057     -0.178729522733     -0.182273941937     -0.185927058651
+ -0.189694258339     -0.193581239094     -0.197594028739     -0.201739002957
+ -0.206022904556     -0.210452863974     -0.215036421166     -0.219781548973
+ -0.224696678161     -0.229790724254     -0.235073116365     -0.240553828194
+ -0.246243411407     -0.252153031613     -0.258294507173     -0.264680351085
+ -0.271323816224     -0.278238944204     -0.285440618161     -0.292944619785
+ -0.300767690905     -0.308927599998     -0.317353783588     -0.325997803138
+ -0.334910550948     -0.344141751791     -0.353739962017     -0.363752594729
+ -0.374225967212     -0.385205367140     -0.396735134475     -0.408858756347
+ -0.421618972569     -0.435057889781     -0.449217102527     -0.464137819857
+ -0.479860996261     -0.496427465980     -0.513878079901     -0.532253844385
+ -0.551596061507     -0.571946470272     -0.593347388439     -0.615841854649
+ -0.639473770565     -0.664288042751     -0.690330724024     -0.717649153969
+ -0.746292098293     -0.776309886612     -0.807754548205     -0.840679945173
+ -0.875141902294     -0.911198332734     -0.948909358584     -0.988337424956
+  -1.02954740612      -1.07260670186      -1.11758532175      -1.16455595490
+  -1.21359402185      -1.26477770508      -1.31818795384      -1.37390845843
+  -1.43202558837      -1.49262828820      -1.55580792427      -1.62165807502
+  -1.69027425734      -1.76175358136      -1.83619432651      -1.91369543266
+  -1.99435590064      -2.07827411558      -2.16554703082      -2.25626938253
+  -2.35038782759      -2.44815786607      -2.54964113405      -2.65491419284
+  -2.76404643913      -2.87709831919      -2.99411974544      -3.11514827656
+  -3.24020714349      -3.36930311241      -3.50242418644      -3.63953714879
+  -3.78058495391      -3.92548397736      -4.07412114016      -4.22635092893
+  -4.38199234022      -4.54082578502      -4.70258999835      -4.86697900908
+  -5.03363923608      -5.20216678991      -5.37210507284      -5.54294278568
+  -5.71411246665      -5.88498970604      -6.05489320037      -6.22308583135
+  -6.38877697850      -6.55112629961      -6.70924924054      -6.86222456600
+  -7.00910423552      -7.14892598538      -7.28072901780      -7.40357324539
+  -7.51656259274      -7.61887292133      -7.70978522109      -7.78872480772
+  -7.85530738356      -7.90939296958      -7.95114890523      -7.98112335011
+  -8.00033101707      -8.01035322673      -8.01345480067      -8.01272079501
+  -8.01139867497      -8.01019981544      -8.00911425217      -8.00813267396
+  -8.00724639390      -8.00644732064      -8.00572792986      -8.00508123595
+  -8.00450076414      -8.00398052306      -8.00351497784      -8.00309902394
+  -8.00272796160      -8.00239747106      -8.00210358866      -8.00184268372
+  -8.00161143635      -8.00140681613      -8.00122606179      -8.00106666173
+  -8.00075810621      -8.00053647952      -8.00037797997      -8.00026512380
+  -8.00018512435      -8.00012867154      -8.00008901709      -8.00006129177
+  -8.00004199840      -8.00002863695      -8.00001942866      -8.00001311404
+  -8.00000880560      -8.00000588109      -8.00000390636      -8.00000258011
+  -8.00000169426      -8.00000110589      -8.00000071736      -8.00000046232
+  -8.00000029594      -8.00000018808      -8.00000011862      -8.00000007421
+  -8.00000004601      -8.00000002826      -8.00000001717      -8.00000001030
+  -8.00000000610      -8.00000000355      -8.00000000202      -8.00000000112
+  -8.00000000060      -8.00000000031      -8.00000000014      -8.00000000006
+  -8.00000000001      -7.99999999999      -7.99999999999      -7.99999999998
+  -7.99999999999      -7.99999999999      -7.99999999999      -7.99999999999
+  -8.00000000000      -8.00000000000      -8.00000000000      -8.00000000000
+  1
+ -0.494078167236E-05 -0.994371072756E-05 -0.150095688835E-04 -0.201391476908E-04
+ -0.253332486566E-04 -0.305926833698E-04 -0.359182736277E-04 -0.413108515647E-04
+ -0.467712597822E-04 -0.523003514800E-04 -0.578989905899E-04 -0.635680519108E-04
+ -0.693084212450E-04 -0.751209955370E-04 -0.810066830133E-04 -0.869664033247E-04
+ -0.930010876896E-04 -0.991116790397E-04 -0.105299132167E-03 -0.111564413875E-03
+ -0.117908503125E-03 -0.124332391195E-03 -0.130837081831E-03 -0.137423591403E-03
+ -0.144092949067E-03 -0.150846196924E-03 -0.157684390183E-03 -0.164608597325E-03
+ -0.171619900273E-03 -0.178719394555E-03 -0.185908189484E-03 -0.193187408322E-03
+ -0.200558188462E-03 -0.208021681605E-03 -0.215579053936E-03 -0.223231486310E-03
+ -0.230980174435E-03 -0.238826329060E-03 -0.246771176163E-03 -0.254815957141E-03
+ -0.262961929010E-03 -0.271210364592E-03 -0.279562552724E-03 -0.288019798452E-03
+ -0.296583423238E-03 -0.305254765165E-03 -0.314035179150E-03 -0.322926037149E-03
+ -0.331928728378E-03 -0.341044659525E-03 -0.350275254974E-03 -0.359621957023E-03
+ -0.369086226115E-03 -0.378669541061E-03 -0.388373399274E-03 -0.398199317001E-03
+ -0.408148829563E-03 -0.418223491591E-03 -0.428424877272E-03 -0.438754580594E-03
+ -0.449214215593E-03 -0.459805416611E-03 -0.470529838543E-03 -0.481389157102E-03
+ -0.492385069081E-03 -0.503519292613E-03 -0.514793567443E-03 -0.526209655200E-03
+ -0.537769339672E-03 -0.549474427083E-03 -0.561326746377E-03 -0.573328149505E-03
+ -0.585480511710E-03 -0.597785731823E-03 -0.610245732563E-03 -0.622862460828E-03
+ -0.635637888011E-03 -0.648574010297E-03 -0.661672848983E-03 -0.674936450789E-03
+ -0.688366888182E-03 -0.701966259696E-03 -0.715736690260E-03 -0.729680331533E-03
+ -0.743799362239E-03 -0.758095988505E-03 -0.772572444210E-03 -0.787230991331E-03
+ -0.802073920295E-03 -0.817103550343E-03 -0.832322229885E-03 -0.847732336873E-03
+ -0.863336279168E-03 -0.879136494920E-03 -0.895135452945E-03 -0.911335653115E-03
+ -0.927739626745E-03 -0.944349936992E-03 -0.961169179251E-03 -0.978199981566E-03
+ -0.995445005035E-03 -0.101290694423E-02 -0.103058852762E-02 -0.104849251798E-02
+ -0.106662171286E-02 -0.108497894498E-02 -0.110356708269E-02 -0.112238903044E-02
+ -0.114144772919E-02 -0.116074615691E-02 -0.118028732902E-02 -0.120007429887E-02
+ -0.122011015821E-02 -0.124039803769E-02 -0.126094110734E-02 -0.128174257706E-02
+ -0.130280569713E-02 -0.132413375869E-02 -0.134573009432E-02 -0.136759807847E-02
+ -0.138974112809E-02 -0.141216270305E-02 -0.143486630680E-02 -0.145785548681E-02
+ -0.148113383519E-02 -0.150470498925E-02 -0.152857263202E-02 -0.155274049288E-02
+ -0.157721234811E-02 -0.160199202150E-02 -0.162708338492E-02 -0.165249035896E-02
+ -0.167821691351E-02 -0.170426706841E-02 -0.173064489406E-02 -0.175735451205E-02
+ -0.178440009582E-02 -0.181178587131E-02 -0.183951611760E-02 -0.186759516761E-02
+ -0.189602740877E-02 -0.192481728367E-02 -0.195396929080E-02 -0.198348798524E-02
+ -0.201337797934E-02 -0.204364394349E-02 -0.207429060683E-02 -0.210532275795E-02
+ -0.213674524573E-02 -0.216856297998E-02 -0.220078093232E-02 -0.223340413688E-02
+ -0.226643769110E-02 -0.229988675658E-02 -0.233375655980E-02 -0.236805239302E-02
+ -0.240277961503E-02 -0.243794365205E-02 -0.247354999856E-02 -0.250960421814E-02
+ -0.254611194435E-02 -0.258307888162E-02 -0.262051080613E-02 -0.265841356671E-02
+ -0.269679308577E-02 -0.273565536021E-02 -0.277500646236E-02 -0.281485254094E-02
+ -0.285519982201E-02 -0.289605460994E-02 -0.293742328840E-02 -0.297931232136E-02
+ -0.302172825409E-02 -0.306467771421E-02 -0.310816741269E-02 -0.315220414491E-02
+ -0.319679479174E-02 -0.324194632060E-02 -0.328766578655E-02 -0.333396033337E-02
+ -0.338083719474E-02 -0.342830369530E-02 -0.347636725182E-02 -0.352503537440E-02
+ -0.357431566756E-02 -0.362421583151E-02 -0.367474366330E-02 -0.372590705806E-02
+ -0.377771401023E-02 -0.383017261481E-02 -0.388329106863E-02 -0.393707767162E-02
+ -0.399154082810E-02 -0.404668904813E-02 -0.410253094880E-02 -0.415907525559E-02
+ -0.421633080375E-02 -0.427430653964E-02 -0.433301152219E-02 -0.439245492424E-02
+ -0.445264603404E-02 -0.451359425667E-02 -0.457530911550E-02 -0.463780025372E-02
+ -0.470107743578E-02 -0.476515054900E-02 -0.483002960503E-02 -0.489572474148E-02
+ -0.496224622346E-02 -0.502960444523E-02 -0.509780993177E-02 -0.516687334046E-02
+ -0.523680546275E-02 -0.530761722582E-02 -0.537931969429E-02 -0.545192407200E-02
+ -0.552544170368E-02 -0.559988407679E-02 -0.567526282328E-02 -0.575158972141E-02
+ -0.582887669762E-02 -0.590713582834E-02 -0.598637934193E-02 -0.606661962058E-02
+ -0.614786920220E-02 -0.623014078245E-02 -0.631344721668E-02 -0.639780152192E-02
+ -0.648321687898E-02 -0.656970663444E-02 -0.665728430280E-02 -0.674596356853E-02
+ -0.683575828825E-02 -0.692668249288E-02 -0.701875038985E-02 -0.711197636530E-02
+ -0.720637498631E-02 -0.730196100325E-02 -0.739874935199E-02 -0.749675515632E-02
+ -0.759599373024E-02 -0.769648058043E-02 -0.779823140859E-02 -0.790126211397E-02
+ -0.800558879579E-02 -0.811122775582E-02 -0.821819550088E-02 -0.832650874542E-02
+ -0.843618441418E-02 -0.854723964477E-02 -0.865969179042E-02 -0.877355842260E-02
+ -0.888885733388E-02 -0.900560654062E-02 -0.912382428581E-02 -0.924352904195E-02
+ -0.936473951391E-02 -0.948747464185E-02 -0.961175360420E-02 -0.973759582065E-02
+ -0.986502095519E-02 -0.999404891915E-02 -0.101246998744E-01 -0.102569942363E-01
+ -0.103909526773E-01 -0.105265961296E-01 -0.106639457890E-01 -0.108030231177E-01
+ -0.109438498480E-01 -0.110864479856E-01 -0.112308398132E-01 -0.113770478934E-01
+ -0.115250950731E-01 -0.116750044863E-01 -0.118267995582E-01 -0.119805040086E-01
+ -0.121361418558E-01 -0.122937374201E-01 -0.124533153280E-01 -0.126149005156E-01
+ -0.127785182327E-01 -0.129441940470E-01 -0.131119538477E-01 -0.132818238496E-01
+ -0.134538305975E-01 -0.136280009700E-01 -0.138043621840E-01 -0.139829417987E-01
+ -0.141637677201E-01 -0.143468682052E-01 -0.145322718666E-01 -0.147200076767E-01
+ -0.149101049728E-01 -0.151025934609E-01 -0.152975032209E-01 -0.154948647111E-01
+ -0.156947087732E-01 -0.158970666368E-01 -0.161019699242E-01 -0.163094506561E-01
+ -0.165195412555E-01 -0.167322745538E-01 -0.169476837953E-01 -0.171658026426E-01
+ -0.173866651817E-01 -0.176103059278E-01 -0.178367598302E-01 -0.180660622779E-01
+ -0.182982491053E-01 -0.185333565977E-01 -0.187714214969E-01 -0.190124810070E-01
+ -0.192565728004E-01 -0.195037350235E-01 -0.197540063025E-01 -0.200074257500E-01
+ -0.202640329704E-01 -0.205238680668E-01 -0.207869716467E-01 -0.210533848289E-01
+ -0.213231492493E-01 -0.215963070680E-01 -0.218729009757E-01 -0.221529742001E-01
+ -0.224365705132E-01 -0.227237342376E-01 -0.230145102539E-01 -0.233089440074E-01
+ -0.236070815155E-01 -0.239089693746E-01 -0.242146547678E-01 -0.245241854717E-01
+ -0.248376098645E-01 -0.251549769332E-01 -0.254763362814E-01 -0.258017381371E-01
+ -0.261312333604E-01 -0.264648734516E-01 -0.268027105595E-01 -0.271447974890E-01
+ -0.274911877099E-01 -0.278419353651E-01 -0.281970952789E-01 -0.285567229660E-01
+ -0.289208746398E-01 -0.292896072215E-01 -0.296629783487E-01 -0.300410463850E-01
+ -0.304238704284E-01 -0.308115103212E-01 -0.312040266592E-01 -0.316014808009E-01
+ -0.320039348777E-01 -0.324114518030E-01 -0.328240952828E-01 -0.332419298249E-01
+ -0.336650207496E-01 -0.340934341998E-01 -0.345272371514E-01 -0.349664974237E-01
+ -0.354112836900E-01 -0.358616654887E-01 -0.363177132340E-01 -0.367794982269E-01
+ -0.372470926665E-01 -0.377205696614E-01 -0.382000032412E-01 -0.386854683677E-01
+ -0.391770409474E-01 -0.396747978430E-01 -0.401788168854E-01 -0.406891768863E-01
+ -0.412059576501E-01 -0.417292399871E-01 -0.422591057255E-01 -0.427956377250E-01
+ -0.433389198891E-01 -0.438890371790E-01 -0.444460756264E-01 -0.450101223475E-01
+ -0.455812655564E-01 -0.461595945792E-01 -0.467451998679E-01 -0.473381730149E-01
+ -0.479386067672E-01 -0.485465950410E-01 -0.491622329369E-01 -0.497856167543E-01
+ -0.504168440072E-01 -0.510560134392E-01 -0.517032250391E-01 -0.523585800568E-01
+ -0.530221810195E-01 -0.536941317474E-01 -0.543745373705E-01 -0.550635043450E-01
+ -0.557611404704E-01 -0.564675549061E-01 -0.571828581893E-01 -0.579071622517E-01
+ -0.586405804380E-01 -0.593832275234E-01 -0.601352197317E-01 -0.608966747542E-01
+ -0.616677117678E-01 -0.624484514543E-01 -0.632390160193E-01 -0.640395292116E-01
+ -0.648501163432E-01 -0.656709043086E-01 -0.665020216054E-01 -0.673435983548E-01
+ -0.681957663218E-01 -0.690586589366E-01 -0.699324113156E-01 -0.708171602831E-01
+ -0.717130443929E-01 -0.726202039505E-01 -0.735387810354E-01 -0.744689195238E-01
+ -0.754107651115E-01 -0.763644653373E-01 -0.773301696065E-01 -0.783080292147E-01
+ -0.792981973720E-01 -0.803008292275E-01 -0.813160818946E-01 -0.823441144752E-01
+ -0.833850880863E-01 -0.844391658850E-01 -0.855065130950E-01 -0.865872970332E-01
+ -0.876816871366E-01 -0.887898549893E-01 -0.899119743504E-01 -0.910482211817E-01
+ -0.921987736762E-01 -0.933638122871E-01 -0.945435197563E-01 -0.957380811443E-01
+ -0.969476838603E-01 -0.981725176920E-01 -0.994127748368E-01 -0.100668649933
+ -0.101940340089     -0.103228044922     -0.104531966580     -0.105852309785
+ -0.107189281860     -0.108543092764     -0.109913955128     -0.111302084287
+ -0.112707698319     -0.114131018074     -0.115572267220     -0.117031672269
+ -0.118509462622     -0.120005870604     -0.121521131501     -0.123055483600
+ -0.124609168228     -0.126182429792     -0.127775515819     -0.129388676997
+ -0.131022167218     -0.132676243616     -0.134351166616     -0.136047199970
+ -0.137764610807     -0.139503669673     -0.141264650581     -0.143047831051
+ -0.144853492162     -0.146681918594     -0.148533398680     -0.150408224452
+ -0.152306691691     -0.154229099976     -0.156175752738     -0.158146957304
+ -0.160143024958     -0.162164270987     -0.164211014738     -0.166283579671
+ -0.168382293413     -0.170507487818     -0.172659499020     -0.174838667492
+ -0.177045338103     -0.179279860180     -0.181542587567     -0.183833878683
+ -0.186154096589     -0.188503609050     -0.190882788593     -0.193292012580
+ -0.195731663268     -0.198202127878     -0.200703798662     -0.203237072973
+ -0.205802353332     -0.208400047502     -0.211030568557     -0.213694334957
+ -0.216391770620     -0.219123305001     -0.221889373161     -0.224690415854
+ -0.227526879596     -0.230399216752     -0.233307885613     -0.236253350479
+ -0.239236081742     -0.242256555973     -0.245315256003     -0.248412671015
+ -0.251549296632     -0.254725635002     -0.257942194893     -0.261199491788
+ -0.264498047971     -0.267838392631     -0.271221061951     -0.274646599212
+ -0.278115554887     -0.281628486748     -0.285185959963     -0.288788547202
+ -0.292436828742     -0.296131392574     -0.299872834512     -0.303661758301
+ -0.307498775729     -0.311384506742     -0.315319579554     -0.319304630768
+ -0.323340305488     -0.327427257444     -0.331566149108     -0.335757651819
+ -0.340002445902     -0.344301220802     -0.348654675201     -0.353063517152
+ -0.357528464209     -0.362050243555     -0.366629592137     -0.371267256799
+ -0.375963994421     -0.380720572051     -0.385537767046     -0.390416367212
+ -0.395357170945     -0.400360987372     -0.405428636495     -0.410560949338
+ -0.415758768088     -0.421022946244     -0.426354348767     -0.431753852223
+ -0.437222344938     -0.442760727142     -0.448369911126     -0.454050821387
+ -0.459804394780     -0.465631580674     -0.471533341099     -0.477510650897
+ -0.483564497877     -0.489695882963     -0.495905820344     -0.502195337625
+ -0.508565475976     -0.515017290275     -0.521551849262     -0.528170235674
+ -0.534873546396     -0.541662892595     -0.548539399866     -0.555504208357
+ -0.562558472912     -0.569703363194     -0.576940063814     -0.584269774452
+ -0.591693709975     -0.599213100551     -0.606829191757     -0.614543244683
+ -0.622356536030     -0.630270358198     -0.638286019377     -0.646404843621
+ -0.654628170922     -0.662957357271     -0.671393774713     -0.679938811397
+ -0.688593871613     -0.697360375816     -0.706239760652     -0.715233478959
+ -0.724342999772     -0.733569808301     -0.742915405917     -0.752381310104
+ -0.761969054420     -0.771680188428     -0.781516277628     -0.791478903363
+ -0.801569662726     -0.811790168439     -0.822142048727     -0.832626947177
+ -0.843246522582     -0.854002448767     -0.864896414410     -0.875930122840
+ -0.887105291824     -0.898423653347     -0.909886953366     -0.921496951562
+ -0.933255421073     -0.945164148219     -0.957224932210     -0.969439584850
+ -0.981809930221     -0.994337804371      -1.00702505498      -1.01987354102
+  -1.03288513241      -1.04606170968      -1.05940516359      -1.07291739480
+  -1.08660031347      -1.10045583892      -1.11448589922      -1.12869243087
+  -1.14307737839      -1.15764269396      -1.17239033701      -1.18732227388
+  -1.20244047743      -1.21774692662      -1.23324360619      -1.24893250618
+  -1.26481562159      -1.28089495196      -1.29717250088      -1.31365027563
+  -1.33033028663      -1.34721454698      -1.36430507194      -1.38160387828
+  -1.39911298371      -1.41683440620      -1.43477016314      -1.45292227060
+  -1.47129274231      -1.48988358868      -1.50869681562      -1.52773442326
+  -1.54699840451      -1.56649074348      -1.58621341369      -1.60616837611
+  -1.62635757703      -1.64678294561      -1.66744639130      -1.68834980096
+  -1.70949503572      -1.73088392757      -1.75251827574      -1.77439984269
+  -1.79653034992      -1.81891147343      -1.84154483902      -1.86443201719
+  -1.88757451796      -1.91097378538      -1.93463119196      -1.95854803288
+  -1.98272552024      -2.00716477722      -2.03186683237      -2.05683261404
+  -2.08206294503      -2.10755853771      -2.13331998953      -2.15934777925
+  -2.18564226395      -2.21220367700      -2.23903212723      -2.26612759948
+  -2.29348995672      -2.32111894405      -2.34901419486      -2.37717523937
+  -2.40560151586      -2.43429238505      -2.46315771743      -2.49212829430
+  -2.52123295594      -2.55049804372      -2.57994733790      -2.60960201980
+  -2.63948065455      -2.66959919112      -2.69997097651      -2.73060678167
+  -2.76151483686      -2.79270087468      -2.82416817926      -2.85591764046
+  -2.88794781223      -2.92025497440      -2.95283319754      -2.98567441075
+  -3.01876847215      -3.05210324235      -3.08566466108      -3.11943682738
+  -3.15340208373      -3.18754110486      -3.22183299183      -3.25625537206
+  -3.29078450625      -3.32539540311      -3.36006194265      -3.39475700924
+  -3.42945263531      -3.46412015683      -3.49873038148      -3.53325377060
+  -3.56766063580      -3.60192135102      -3.63600658087      -3.66988752560
+  -3.70353618307      -3.73692562776      -3.77003030644      -3.80282635001
+  -3.83529190028      -3.86740745059      -3.89915619853      -3.93052440887
+  -3.96150178507      -3.99208184764      -4.02226231868      -4.05204551270
+  -4.08143873500      -4.11045470747      -4.13911196667      -4.16743541084
+  -4.19531189488      -4.22294874073      -4.25037275427      -4.27764087930
+  -4.30482011676      -4.33198789392      -4.35923278180      -4.38665511981
+  -4.41436762398      -4.44249596107      -4.47117927661      -4.50057066060
+  -4.53083753272      -4.56216192517      -4.59474063829      -4.62878523986
+  -4.66452187480      -4.70219084750      -4.74204593343      -4.78435337158
+  -4.82939048348      -4.87744385856      -4.92880703999      -4.98377763972
+  -5.04265380672      -5.10572996909      -5.17329176921      -5.24561011220
+  -5.32293425308      -5.40548385767      -5.49343998832      -5.58693498972
+  -5.68604128333      -5.79075912450      -5.90100343499      -6.01658989839
+  -6.13722059873      -6.26246959507      -6.39176896030      -6.52439597055
+  -6.65946231627      -6.79590641677      -6.93249015875      -7.06780164693
+  -7.20026585241      -7.32816537426      -7.44967389544      -7.56290532218
+  -7.66598205164      -7.75712613673      -7.83477748213      -7.89774448625
+  -7.94539349719      -7.97788451997      -7.99646214937      -8.00381266215
+  -8.00450062255      -8.00398052306      -8.00351497784      -8.00309902394
+  2
+ -0.538733810068E-04 -0.108424405726E-03 -0.163661597866E-03 -0.219593588351E-03
+ -0.276229116668E-03 -0.333577032233E-03 -0.391646295775E-03 -0.450445980735E-03
+ -0.509985274683E-03 -0.570273480754E-03 -0.631320019105E-03 -0.693134428379E-03
+ -0.755726367206E-03 -0.819105615703E-03 -0.883282077005E-03 -0.948265778817E-03
+ -0.101406687497E-02 -0.108069564703E-02 -0.114816250586E-02 -0.121647799332E-02
+ -0.128565278382E-02 -0.135569768607E-02 -0.142662364473E-02 -0.149844174212E-02
+ -0.157116319998E-02 -0.164479938116E-02 -0.171936179149E-02 -0.179486208148E-02
+ -0.187131204821E-02 -0.194872363715E-02 -0.202710894400E-02 -0.210648021664E-02
+ -0.218684985699E-02 -0.226823042296E-02 -0.235063463045E-02 -0.243407535526E-02
+ -0.251856563519E-02 -0.260411867201E-02 -0.269074783356E-02 -0.277846665583E-02
+ -0.286728884505E-02 -0.295722827988E-02 -0.304829901353E-02 -0.314051527599E-02
+ -0.323389147625E-02 -0.332844220451E-02 -0.342418223454E-02 -0.352112652589E-02
+ -0.361929022632E-02 -0.371868867410E-02 -0.381933740044E-02 -0.392125213191E-02
+ -0.402444879290E-02 -0.412894350809E-02 -0.423475260500E-02 -0.434189261650E-02
+ -0.445038028346E-02 -0.456023255728E-02 -0.467146660261E-02 -0.478409979999E-02
+ -0.489814974860E-02 -0.501363426896E-02 -0.513057140577E-02 -0.524897943069E-02
+ -0.536887684523E-02 -0.549028238359E-02 -0.561321501564E-02 -0.573769394985E-02
+ -0.586373863631E-02 -0.599136876976E-02 -0.612060429267E-02 -0.625146539835E-02
+ -0.638397253411E-02 -0.651814640447E-02 -0.665400797437E-02 -0.679157847245E-02
+ -0.693087939439E-02 -0.707193250623E-02 -0.721475984782E-02 -0.735938373622E-02
+ -0.750582676920E-02 -0.765411182880E-02 -0.780426208484E-02 -0.795630099862E-02
+ -0.811025232652E-02 -0.826614012376E-02 -0.842398874812E-02 -0.858382286377E-02
+ -0.874566744512E-02 -0.890954778071E-02 -0.907548947718E-02 -0.924351846327E-02
+ -0.941366099383E-02 -0.958594365400E-02 -0.976039336328E-02 -0.993703737981E-02
+ -0.101159033046E-01 -0.102970190857E-01 -0.104804130230E-01 -0.106661137720E-01
+ -0.108541503490E-01 -0.110445521349E-01 -0.112373488805E-01 -0.114325707107E-01
+ -0.116302481293E-01 -0.118304120237E-01 -0.120330936700E-01 -0.122383247376E-01
+ -0.124461372943E-01 -0.126565638113E-01 -0.128696371680E-01 -0.130853906577E-01
+ -0.133038579922E-01 -0.135250733076E-01 -0.137490711692E-01 -0.139758865770E-01
+ -0.142055549716E-01 -0.144381122390E-01 -0.146735947167E-01 -0.149120391995E-01
+ -0.151534829448E-01 -0.153979636785E-01 -0.156455196014E-01 -0.158961893946E-01
+ -0.161500122257E-01 -0.164070277551E-01 -0.166672761419E-01 -0.169307980506E-01
+ -0.171976346570E-01 -0.174678276547E-01 -0.177414192622E-01 -0.180184522285E-01
+ -0.182989698407E-01 -0.185830159302E-01 -0.188706348798E-01 -0.191618716305E-01
+ -0.194567716888E-01 -0.197553811333E-01 -0.200577466224E-01 -0.203639154013E-01
+ -0.206739353095E-01 -0.209878547883E-01 -0.213057228883E-01 -0.216275892769E-01
+ -0.219535042465E-01 -0.222835187219E-01 -0.226176842687E-01 -0.229560531008E-01
+ -0.232986780891E-01 -0.236456127695E-01 -0.239969113512E-01 -0.243526287253E-01
+ -0.247128204735E-01 -0.250775428764E-01 -0.254468529226E-01 -0.258208083177E-01
+ -0.261994674930E-01 -0.265828896146E-01 -0.269711345932E-01 -0.273642630928E-01
+ -0.277623365406E-01 -0.281654171363E-01 -0.285735678622E-01 -0.289868524926E-01
+ -0.294053356042E-01 -0.298290825857E-01 -0.302581596486E-01 -0.306926338371E-01
+ -0.311325730386E-01 -0.315780459945E-01 -0.320291223110E-01 -0.324858724697E-01
+ -0.329483678387E-01 -0.334166806840E-01 -0.338908841803E-01 -0.343710524230E-01
+ -0.348572604394E-01 -0.353495842005E-01 -0.358481006329E-01 -0.363528876309E-01
+ -0.368640240685E-01 -0.373815898119E-01 -0.379056657319E-01 -0.384363337163E-01
+ -0.389736766832E-01 -0.395177785936E-01 -0.400687244645E-01 -0.406266003825E-01
+ -0.411914935167E-01 -0.417634921331E-01 -0.423426856076E-01 -0.429291644404E-01
+ -0.435230202701E-01 -0.441243458879E-01 -0.447332352523E-01 -0.453497835036E-01
+ -0.459740869787E-01 -0.466062432264E-01 -0.472463510225E-01 -0.478945103852E-01
+ -0.485508225908E-01 -0.492153901896E-01 -0.498883170216E-01 -0.505697082333E-01
+ -0.512596702933E-01 -0.519583110099E-01 -0.526657395471E-01 -0.533820664423E-01
+ -0.541074036230E-01 -0.548418644249E-01 -0.555855636090E-01 -0.563386173800E-01
+ -0.571011434042E-01 -0.578732608280E-01 -0.586550902965E-01 -0.594467539723E-01
+ -0.602483755545E-01 -0.610600802985E-01 -0.618819950348E-01 -0.627142481896E-01
+ -0.635569698042E-01 -0.644102915558E-01 -0.652743467779E-01 -0.661492704811E-01
+ -0.670351993742E-01 -0.679322718857E-01 -0.688406281851E-01 -0.697604102053E-01
+ -0.706917616643E-01 -0.716348280880E-01 -0.725897568327E-01 -0.735566971082E-01
+ -0.745358000012E-01 -0.755272184990E-01 -0.765311075128E-01 -0.775476239029E-01
+ -0.785769265022E-01 -0.796191761418E-01 -0.806745356757E-01 -0.817431700064E-01
+ -0.828252461105E-01 -0.839209330651E-01 -0.850304020740E-01 -0.861538264943E-01
+ -0.872913818640E-01 -0.884432459288E-01 -0.896095986703E-01 -0.907906223342E-01
+ -0.919865014583E-01 -0.931974229016E-01 -0.944235758739E-01 -0.956651519645E-01
+ -0.969223451729E-01 -0.981953519388E-01 -0.994843711728E-01 -0.100789604287
+ -0.102111255229     -0.103449530508     -0.104804639235     -0.106176793149
+ -0.107566206651     -0.108973096843     -0.110397683554     -0.111840189379
+ -0.113300839715     -0.114779862792     -0.116277489711     -0.117793954482
+ -0.119329494054     -0.120884348362     -0.122458760356     -0.124052976041
+ -0.125667244519     -0.127301818024     -0.128956951962     -0.130632904954
+ -0.132329938872     -0.134048318883     -0.135788313489     -0.137550194568
+ -0.139334237422     -0.141140720811     -0.142969927005     -0.144822141822
+ -0.146697654678     -0.148596758628     -0.150519750411     -0.152466930503
+ -0.154438603156     -0.156435076452     -0.158456662345     -0.160503676715
+ -0.162576439416     -0.164675274324     -0.166800509389     -0.168952476687
+ -0.171131512470     -0.173337957221     -0.175572155704     -0.177834457023
+ -0.180125214668     -0.182444786582     -0.184793535204     -0.187171827537
+ -0.189580035198     -0.192018534479     -0.194487706405     -0.196987936795
+ -0.199519616320     -0.202083140565     -0.204678910092     -0.207307330502
+ -0.209968812495     -0.212663771942     -0.215392629940     -0.218155812887
+ -0.220953752542     -0.223786886097     -0.226655656241     -0.229560511235
+ -0.232501904976     -0.235480297071     -0.238496152908     -0.241549943731
+ -0.244642146710     -0.247773245017     -0.250943727904     -0.254154090776
+ -0.257404835268     -0.260696469329     -0.264029507294     -0.267404469969
+ -0.270821884712     -0.274282285514     -0.277786213084     -0.281334214931
+ -0.284926845453     -0.288564666020     -0.292248245066     -0.295978158173
+ -0.299754988165     -0.303579325197     -0.307451766847     -0.311372918211
+ -0.315343391997     -0.319363808620     -0.323434796299     -0.327556991155
+ -0.331731037313     -0.335957587000     -0.340237300647     -0.344570846992
+ -0.348958903188     -0.353402154903     -0.357901296434     -0.362457030809
+ -0.367070069901     -0.371741134538     -0.376470954614     -0.381260269209
+ -0.386109826696     -0.391020384864     -0.395992711035     -0.401027582184
+ -0.406125785059     -0.411288116305     -0.416515382590     -0.421808400730
+ -0.427167997814     -0.432595011337     -0.438090289330     -0.443654690493
+ -0.449289084325     -0.454994351267     -0.460771382835     -0.466621081758
+ -0.472544362123     -0.478542149518     -0.484615381172     -0.490765006106
+ -0.496991985280     -0.503297291742     -0.509681910782     -0.516146840085
+ -0.522693089887     -0.529321683132     -0.536033655635     -0.542830056241
+ -0.549711946988     -0.556680403278     -0.563736514040     -0.570881381901
+ -0.578116123363     -0.585441868971     -0.592859763494     -0.600370966103
+ -0.607976650550     -0.615678005355     -0.623476233991     -0.631372555069
+ -0.639368202532     -0.647464425846     -0.655662490197     -0.663963676687
+ -0.672369282535     -0.680880621279     -0.689499022982     -0.698225834440
+ -0.707062419394     -0.716010158738     -0.725070450741     -0.734244711261
+ -0.743534373969     -0.752940890571     -0.762465731037     -0.772110383828
+ -0.781876356132     -0.791765174094     -0.801778383061     -0.811917547820
+ -0.822184252841     -0.832580102527     -0.843106721464     -0.853765754674
+ -0.864558867872     -0.875487747727     -0.886554102124     -0.897759660432
+ -0.909106173772     -0.920595415292     -0.932229180443     -0.944009287261
+ -0.955937576645     -0.968015912652     -0.980246182782     -0.992630298273
+  -1.00517019440      -1.01786783078      -1.03072519168      -1.04374428629
+  -1.05692714910      -1.07027584018      -1.08379244548      -1.09747907720
+  -1.11133787408      -1.12537100177      -1.13958065313      -1.15396904859
+  -1.16853843651      -1.18329109347      -1.19822932471      -1.21335546441
+  -1.22867187611      -1.24418095304      -1.25988511848      -1.27578682620
+  -1.29188856077      -1.30819283796      -1.32470220518      -1.34141924180
+  -1.35834655958      -1.37548680310      -1.39284265013      -1.41041681205
+  -1.42821203427      -1.44623109666      -1.46447681398      -1.48295203628
+  -1.50165964938      -1.52060257527      -1.53978377260      -1.55920623710
+  -1.57887300203      -1.59878713867      -1.61895175679      -1.63937000507
+  -1.66004507164      -1.68098018453      -1.70217861216      -1.72364366381
+  -1.74537869018      -1.76738708383      -1.78967227972      -1.81223775569
+  -1.83508703303      -1.85822367695      -1.88165129715      -1.90537354830
+  -1.92939413065      -1.95371679049      -1.97834532077      -2.00328356159
+  -2.02853540080      -2.05410477454      -2.07999566781      -2.10621211502
+  -2.13275820061      -2.15963805956      -2.18685587803      -2.21441589391
+  -2.24232239741      -2.27057973168      -2.29919229336      -2.32816453318
+  -2.35750095662      -2.38720612441      -2.41728465323      -2.44774121624
+  -2.47858054372      -2.50980742369      -2.54142670246      -2.57344328528
+  -2.60586213693      -2.63868828234      -2.67192680716      -2.70558285835
+  -2.73966164484      -2.77416843804      -2.80910857247      -2.84448744634
+  -2.88031052211      -2.91658332705      -2.95331145380      -2.99050056095
+  -3.02815637352      -3.06628468351      -3.10489135045      -3.14398230180
+  -3.18356353353      -3.22364111051      -3.26422116699      -3.30530990699
+  -3.34691360473      -3.38903860494      -3.43169132328      -3.47487824658
+  -3.51860593316      -3.56288101303      -3.60771018814      -3.65310023250
+  -3.69905799233      -3.74559038609      -3.79270440450      -3.84040711053
+  -3.88870563927      -3.93760719774      -3.98711906470      -4.03724859030
+  -4.08800319570      -4.13939037259      -4.19141768262      -4.24409275672
+  -4.29742329434      -4.35141706256      -4.40608189506      -4.46142569102
+  -4.51745641383      -4.57418208967      -4.63161080596      -4.68975070959
+  -4.74861000502      -4.80819695222      -4.86851986428      -4.92958710500
+  -4.99140708606      -5.05398826412      -5.11733913753      -5.18146824285
+  -5.24638415107      -5.31209546347      -5.37861080727      -5.44593883077
+  -5.51408819830      -5.58306758468      -5.65288566926      -5.72355112960
+  -5.79507263462      -5.86745883731      -5.94071836688      -6.01485982040
+  -6.08989175387      -6.16582267260      -6.24266102107      -6.32041517199
+  -6.39909341471      -6.47870394284      -6.55925484107      -6.64075407116
+  -6.72320945697      -6.80662866867      -6.89101920578      -6.97638837937
+  -7.06274329294      -7.15009082233      -7.23843759425      -7.32778996365
+  -7.41815398964      -7.50953541007      -7.60193961453      -7.69537161587
+  -7.78983602006      -7.88533699423      -7.98187823306      -8.07946292320
+  -8.17809370566      -8.27777263627      -8.37850114383      -8.48027998615
+  -8.58310920360      -8.68698807033      -8.79191504284      -8.89788770596
+  -9.00490271604      -9.11295574125      -9.22204139896      -9.33215319001
+  -9.44328342976      -9.55542317588      -9.66856215277      -9.78268867237
+  -9.89778955149      -10.0138500253      -10.1308536573      -10.2487822449
+  -10.3676157215      -10.4873320544      -10.6079071387      -10.7293146865
+  -10.8515261127      -10.9745104162      -11.0982340566      -11.2226608273
+  -11.3477517239      -11.4734648082      -11.5997550696      -11.7265742803
+  -11.8538708488      -11.9815896685      -12.1096719632      -12.2380551298
+  -12.3666725775      -12.4954535650      -12.6243230360      -12.7532014517
+  -12.8820046241      -13.0106435475      -13.1390242308      -13.2670475310
+  -13.3946089883      -13.5215986646      -13.6479009852      -13.7733945863
+  -13.8979521689      -14.0214403603      -14.1437195850      -14.2646439472
+  -14.3840611256      -14.5018122833      -14.6177319948      -14.7316481923
+  -14.8433821334      -14.9527483936      -15.0595548851      -15.1636029061
+  -15.2646872231      -15.3625961893      -15.4571119024      -15.5480104060
+  -15.6350619374      -15.7180312262      -15.7966778471      -15.8707566312
+  -15.9400181394      -16.0042092026      -16.0630735314      -16.1163524012
+  -16.1637854142      -16.2051113440      -16.2400690651      -16.2683985710
+  -16.2898420834      -16.3041452553      -16.3110584695      -16.3103382347
+  -16.3017486782      -16.2850631372      -16.2600658458      -16.2265537170
+  -16.1843382154      -16.1332473179      -16.0731275545      -16.0038461251
+  -15.9252930803      -15.8373835592      -15.7400600700      -15.6332948015
+  -15.5170919486      -15.3914900361      -15.2564747895      -15.1120917744
+  -14.9585257131      -14.7960020011      -14.6247885992      -14.4451978018
+  -14.2575878473      -14.0623643395      -13.8599814423      -13.6509428163
+  -13.4358022594      -13.2151640192      -12.9896827403      -12.7600630127
+  -12.5270584867      -12.2914705190      -12.0541463167      -11.8159765410
+  -11.5778923363      -11.3408617447      -11.1058854649      -10.8739919090
+  -10.6462315075      -10.4236702057      -10.2073820849      -9.99844103781
+  -9.79791141252      -9.60683753526      -9.42623201042      -9.25706269216
+  -9.10023822032      -8.95659201958      -8.82686467722      -8.71168464671
+  -8.61154727588      -8.52679223646      -8.45757954322      -8.40386450393
+  -8.36537214494      -8.34157192099      -8.33165385190      -8.33450764353
+  -8.34870685575      -8.37250078541      -8.40381744758      -8.44028187068
+  -8.47925488155      -8.51789865468      -8.55327655237      -8.58249621432
+  -8.60290650346      -8.61236085994      -8.60956183276      -8.59450457196
+  -8.56889520877      -8.53731723924      -8.50576181008      -8.47562313653
+  -8.44686821654      -8.41946321079      -8.39337356722      -8.36856409351
+  -8.34499902427      -8.32264208274      -8.30145653718      -8.28140525243
+  -8.26245073716      -8.24455518786      -8.22768053068      -8.21178846273
+  -8.19684049458      -8.18279799604      -8.16962224753      -8.15727449941
+  -8.14571604185      -8.13490828738      -8.12481286847      -8.11539175145
+  -8.10660736786      -8.09842276311      -8.09080176113      -8.08370914253
+  -8.07711083212      -8.07097409008      -8.06526769951      -8.05996214202
+  -8.05502975162      -8.05044483700      -8.04618376225      -8.04222497701
+  -8.03854898870      -8.03513827197      -8.03197711407      -8.02905139873
+  -8.02634833607      -8.02385615150      -8.02156375245      -8.01946039776
+  -8.01753540199      -8.01577791348      -8.01417681382      -8.01272079501
+  3
+ -0.129736678237E-04 -0.261105242995E-04 -0.394126220878E-04 -0.528820396686E-04
+ -0.665208816658E-04 -0.803312791762E-04 -0.943153901026E-04 -0.108475399491E-03
+ -0.122813519871E-03 -0.137331991604E-03 -0.152033083230E-03 -0.166919091824E-03
+ -0.181992343357E-03 -0.197255193054E-03 -0.212710025767E-03 -0.228359256344E-03
+ -0.244205330010E-03 -0.260250722746E-03 -0.276497941678E-03 -0.292949525466E-03
+ -0.309608044704E-03 -0.326476102320E-03 -0.343556333981E-03 -0.360851408510E-03
+ -0.378364028296E-03 -0.396096929722E-03 -0.414052883590E-03 -0.432234695554E-03
+ -0.450645206560E-03 -0.469287293288E-03 -0.488163868601E-03 -0.507277882003E-03
+ -0.526632320098E-03 -0.546230207055E-03 -0.566074605086E-03 -0.586168614916E-03
+ -0.606515376277E-03 -0.627118068392E-03 -0.647979910473E-03 -0.669104162225E-03
+ -0.690494124356E-03 -0.712153139091E-03 -0.734084590695E-03 -0.756291906003E-03
+ -0.778778554953E-03 -0.801548051130E-03 -0.824603952313E-03 -0.847949861035E-03
+ -0.871589425142E-03 -0.895526338363E-03 -0.919764340890E-03 -0.944307219961E-03
+ -0.969158810451E-03 -0.994322995471E-03 -0.101980370698E-02 -0.104560492638E-02
+ -0.107173068518E-02 -0.109818506557E-02 -0.112497220111E-02 -0.115209627735E-02
+ -0.117956153246E-02 -0.120737225796E-02 -0.123553279933E-02 -0.126404755672E-02
+ -0.129292098560E-02 -0.132215759751E-02 -0.135176196074E-02 -0.138173870103E-02
+ -0.141209250229E-02 -0.144282810739E-02 -0.147395031881E-02 -0.150546399947E-02
+ -0.153737407345E-02 -0.156968552675E-02 -0.160240340811E-02 -0.163553282977E-02
+ -0.166907896827E-02 -0.170304706525E-02 -0.173744242831E-02 -0.177227043179E-02
+ -0.180753651764E-02 -0.184324619626E-02 -0.187940504735E-02 -0.191601872081E-02
+ -0.195309293761E-02 -0.199063349066E-02 -0.202864624576E-02 -0.206713714248E-02
+ -0.210611219509E-02 -0.214557749354E-02 -0.218553920435E-02 -0.222600357163E-02
+ -0.226697691801E-02 -0.230846564567E-02 -0.235047623730E-02 -0.239301525716E-02
+ -0.243608935204E-02 -0.247970525236E-02 -0.252386977320E-02 -0.256858981536E-02
+ -0.261387236644E-02 -0.265972450192E-02 -0.270615338631E-02 -0.275316627420E-02
+ -0.280077051146E-02 -0.284897353636E-02 -0.289778288071E-02 -0.294720617108E-02
+ -0.299725112996E-02 -0.304792557698E-02 -0.309923743012E-02 -0.315119470697E-02
+ -0.320380552597E-02 -0.325707810766E-02 -0.331102077599E-02 -0.336564195963E-02
+ -0.342095019325E-02 -0.347695411886E-02 -0.353366248721E-02 -0.359108415910E-02
+ -0.364922810678E-02 -0.370810341537E-02 -0.376771928425E-02 -0.382808502854E-02
+ -0.388921008051E-02 -0.395110399107E-02 -0.401377643129E-02 -0.407723719386E-02
+ -0.414149619466E-02 -0.420656347430E-02 -0.427244919967E-02 -0.433916366557E-02
+ -0.440671729627E-02 -0.447512064717E-02 -0.454438440643E-02 -0.461451939668E-02
+ -0.468553657664E-02 -0.475744704292E-02 -0.483026203166E-02 -0.490399292038E-02
+ -0.497865122968E-02 -0.505424862508E-02 -0.513079691884E-02 -0.520830807180E-02
+ -0.528679419524E-02 -0.536626755279E-02 -0.544674056233E-02 -0.552822579795E-02
+ -0.561073599189E-02 -0.569428403655E-02 -0.577888298649E-02 -0.586454606050E-02
+ -0.595128664360E-02 -0.603911828921E-02 -0.612805472122E-02 -0.621810983614E-02
+ -0.630929770528E-02 -0.640163257694E-02 -0.649512887867E-02 -0.658980121946E-02
+ -0.668566439208E-02 -0.678273337536E-02 -0.688102333656E-02 -0.698054963369E-02
+ -0.708132781797E-02 -0.718337363622E-02 -0.728670303333E-02 -0.739133215475E-02
+ -0.749727734902E-02 -0.760455517032E-02 -0.771318238105E-02 -0.782317595448E-02
+ -0.793455307734E-02 -0.804733115258E-02 -0.816152780203E-02 -0.827716086918E-02
+ -0.839424842196E-02 -0.851280875560E-02 -0.863286039541E-02 -0.875442209975E-02
+ -0.887751286292E-02 -0.900215191816E-02 -0.912835874060E-02 -0.925615305038E-02
+ -0.938555481566E-02 -0.951658425577E-02 -0.964926184440E-02 -0.978360831273E-02
+ -0.991964465273E-02 -0.100573921204E-01 -0.101968722392E-01 -0.103381068031E-01
+ -0.104811178805E-01 -0.106259278171E-01 -0.107725592400E-01 -0.109210350606E-01
+ -0.110713784786E-01 -0.112236129856E-01 -0.113777623687E-01 -0.115338507140E-01
+ -0.116919024109E-01 -0.118519421552E-01 -0.120139949536E-01 -0.121780861273E-01
+ -0.123442413160E-01 -0.125124864818E-01 -0.126828479136E-01 -0.128553522308E-01
+ -0.130300263875E-01 -0.132068976773E-01 -0.133859937366E-01 -0.135673425498E-01
+ -0.137509724531E-01 -0.139369121393E-01 -0.141251906618E-01 -0.143158374398E-01
+ -0.145088822624E-01 -0.147043552934E-01 -0.149022870760E-01 -0.151027085377E-01
+ -0.153056509950E-01 -0.155111461581E-01 -0.157192261364E-01 -0.159299234429E-01
+ -0.161432709998E-01 -0.163593021434E-01 -0.165780506291E-01 -0.167995506371E-01
+ -0.170238367775E-01 -0.172509440957E-01 -0.174809080780E-01 -0.177137646570E-01
+ -0.179495502174E-01 -0.181883016014E-01 -0.184300561147E-01 -0.186748515324E-01
+ -0.189227261045E-01 -0.191737185624E-01 -0.194278681244E-01 -0.196852145025E-01
+ -0.199457979078E-01 -0.202096590575E-01 -0.204768391809E-01 -0.207473800259E-01
+ -0.210213238655E-01 -0.212987135045E-01 -0.215795922862E-01 -0.218640040988E-01
+ -0.221519933830E-01 -0.224436051382E-01 -0.227388849299E-01 -0.230378788969E-01
+ -0.233406337582E-01 -0.236471968205E-01 -0.239576159856E-01 -0.242719397580E-01
+ -0.245902172520E-01 -0.249124982000E-01 -0.252388329598E-01 -0.255692725228E-01
+ -0.259038685217E-01 -0.262426732387E-01 -0.265857396137E-01 -0.269331212524E-01
+ -0.272848724351E-01 -0.276410481245E-01 -0.280017039751E-01 -0.283668963411E-01
+ -0.287366822857E-01 -0.291111195901E-01 -0.294902667621E-01 -0.298741830455E-01
+ -0.302629284295E-01 -0.306565636576E-01 -0.310551502378E-01 -0.314587504516E-01
+ -0.318674273639E-01 -0.322812448329E-01 -0.327002675203E-01 -0.331245609010E-01
+ -0.335541912735E-01 -0.339892257705E-01 -0.344297323689E-01 -0.348757799010E-01
+ -0.353274380648E-01 -0.357847774349E-01 -0.362478694741E-01 -0.367167865437E-01
+ -0.371916019156E-01 -0.376723897833E-01 -0.381592252736E-01 -0.386521844583E-01
+ -0.391513443663E-01 -0.396567829954E-01 -0.401685793246E-01 -0.406868133265E-01
+ -0.412115659795E-01 -0.417429192808E-01 -0.422809562593E-01 -0.428257609882E-01
+ -0.433774185982E-01 -0.439360152911E-01 -0.445016383531E-01 -0.450743761685E-01
+ -0.456543182332E-01 -0.462415551693E-01 -0.468361787387E-01 -0.474382818578E-01
+ -0.480479586117E-01 -0.486653042693E-01 -0.492904152980E-01 -0.499233893785E-01
+ -0.505643254208E-01 -0.512133235788E-01 -0.518704852666E-01 -0.525359131741E-01
+ -0.532097112829E-01 -0.538919848831E-01 -0.545828405891E-01 -0.552823863566E-01
+ -0.559907314996E-01 -0.567079867073E-01 -0.574342640613E-01 -0.581696770534E-01
+ -0.589143406034E-01 -0.596683710765E-01 -0.604318863022E-01 -0.612050055924E-01
+ -0.619878497599E-01 -0.627805411377E-01 -0.635832035976E-01 -0.643959625702E-01
+ -0.652189450640E-01 -0.660522796855E-01 -0.668960966592E-01 -0.677505278482E-01
+ -0.686157067746E-01 -0.694917686404E-01 -0.703788503487E-01 -0.712770905251E-01
+ -0.721866295394E-01 -0.731076095277E-01 -0.740401744142E-01 -0.749844699343E-01
+ -0.759406436570E-01 -0.769088450081E-01 -0.778892252934E-01 -0.788819377227E-01
+ -0.798871374338E-01 -0.809049815162E-01 -0.819356290363E-01 -0.829792410622E-01
+ -0.840359806884E-01 -0.851060130620E-01 -0.861895054082E-01 -0.872866270563E-01
+ -0.883975494667E-01 -0.895224462572E-01 -0.906614932306E-01 -0.918148684020E-01
+ -0.929827520267E-01 -0.941653266284E-01 -0.953627770279E-01 -0.965752903718E-01
+ -0.978030561620E-01 -0.990462662855E-01 -0.100305115044     -0.101579799185
+ -0.102870517931     -0.104177473013     -0.105500868702     -0.106840911838
+ -0.108197811865     -0.109571780863     -0.110963033583     -0.112371787477
+ -0.113798262735     -0.115242682320     -0.116705271998     -0.118186260382
+ -0.119685878957     -0.121204362127     -0.122741947245     -0.124298874651
+ -0.125875387713     -0.127471732860     -0.129088159626     -0.130724920686
+ -0.132382271895     -0.134060472330     -0.135759784332     -0.137480473542
+ -0.139222808949     -0.140987062926     -0.142773511278     -0.144582433283
+ -0.146414111734     -0.148268832987     -0.150146887005     -0.152048567400
+ -0.153974171485     -0.155924000316     -0.157898358740     -0.159897555447
+ -0.161921903011     -0.163971717946     -0.166047320754     -0.168149035972
+ -0.170277192226     -0.172432122284     -0.174614163105     -0.176823655894
+ -0.179060946154     -0.181326383743     -0.183620322927     -0.185943122437
+ -0.188295145523     -0.190676760014     -0.193088338376     -0.195530257767
+ -0.198002900101     -0.200506652106     -0.203041905383     -0.205609056472
+ -0.208208506912     -0.210840663302     -0.213505937372     -0.216204746039
+ -0.218937511482     -0.221704661199     -0.224506628084     -0.227343850489
+ -0.230216772294     -0.233125842980     -0.236071517697     -0.239054257337
+ -0.242074528609     -0.245132804109     -0.248229562395     -0.251365288068
+ -0.254540471843     -0.257755610628     -0.261011207604     -0.264307772304
+ -0.267645820694     -0.271025875254     -0.274448465063     -0.277914125878
+ -0.281423400225     -0.284976837482     -0.288574993966     -0.292218433023
+ -0.295907725115     -0.299643447914     -0.303426186390     -0.307256532908
+ -0.311135087319     -0.315062457058     -0.319039257239     -0.323066110753
+ -0.327143648368     -0.331272508832     -0.335453338968     -0.339686793786
+ -0.343973536580     -0.348314239039     -0.352709581352     -0.357160252316
+ -0.361666949451     -0.366230379104     -0.370851256569     -0.375530306198
+ -0.380268261519     -0.385065865349     -0.389923869923     -0.394843037002
+ -0.399824138008     -0.404867954137     -0.409975276493     -0.415146906210
+ -0.420383654584     -0.425686343203     -0.431055804076     -0.436492879775
+ -0.441998423562     -0.447573299533     -0.453218382755     -0.458934559409
+ -0.464722726930     -0.470583794158     -0.476518681478     -0.482528320977
+ -0.488613656587     -0.494775644246     -0.501015252047     -0.507333460398
+ -0.513731262182     -0.520209662917     -0.526769680919     -0.533412347472
+ -0.540138706989     -0.546949817189     -0.553846749267     -0.560830588066
+ -0.567902432259     -0.575063394526     -0.582314601735     -0.589657195128
+ -0.597092330508     -0.604621178425     -0.612244924372     -0.619964768976
+ -0.627781928198     -0.635697633529     -0.643713132193     -0.651829687353
+ -0.660048578316     -0.668371100747     -0.676798566877     -0.685332305721
+ -0.693973663296     -0.702724002842     -0.711584705047     -0.720557168271
+ -0.729642808777     -0.738843060967     -0.748159377611     -0.757593230089
+ -0.767146108635     -0.776819522575     -0.786615000580     -0.796534090912
+ -0.806578361681     -0.816749401100     -0.827048817743     -0.837478240809
+ -0.848039320386     -0.858733727722     -0.869563155494     -0.880529318083
+ -0.891633951853     -0.902878815430     -0.914265689984     -0.925796379520
+ -0.937472711163     -0.949296535452     -0.961269726634     -0.973394182962
+ -0.985671826999     -0.998104605914      -1.01069449179      -1.02344348195
+  -1.03635359923      -1.04942689232      -1.06266543608      -1.07607133186
+  -1.08964670778      -1.10339371910      -1.11731454854      -1.13141140655
+  -1.14568653172      -1.16014219102      -1.17478068020      -1.18960432408
+  -1.20461547689      -1.21981652259      -1.23520987522      -1.25079797921
+  -1.26658330974      -1.28256837300      -1.29875570662      -1.31514787989
+  -1.33174749415      -1.34855718311      -1.36557961311      -1.38281748351
+  -1.40027352695      -1.41795050968      -1.43585123184      -1.45397852779
+  -1.47233526636      -1.49092435116      -1.50974872084      -1.52881134938
+  -1.54811524630      -1.56766345697      -1.58745906279      -1.60750518146
+  -1.62780496715      -1.64836161074      -1.66917833997      -1.69025841962
+  -1.71160515167      -1.73322187541      -1.75511196759      -1.77727884245
+  -1.79972595185      -1.82245678528      -1.84547486991      -1.86878377055
+  -1.89238708961      -1.91628846708      -1.94049158040      -1.96500014433
+  -1.98981791078      -2.01494866861      -2.04039624341      -2.06616449717
+  -2.09225732796      -2.11867866957      -2.14543249109      -2.17252279641
+  -2.19995362368      -2.22772904475      -2.25585316452      -2.28433012021
+  -2.31316408061      -2.34235924522      -2.37191984333      -2.40185013307
+  -2.43215440030      -2.46283695748      -2.49390214245      -2.52535431708
+  -2.55719786587      -2.58943719444      -2.62207672790      -2.65512090912
+  -2.68857419692      -2.72244106409      -2.75672599534      -2.79143348504
+  -2.82656803493      -2.86213415161      -2.89813634391      -2.93457912007
+  -2.97146698480      -3.00880443616      -3.04659596217      -3.08484603735
+  -3.12355911897      -3.16273964311      -3.20239202043      -3.24252063182
+  -3.28312982363      -3.32422390276      -3.36580713134      -3.40788372119
+  -3.45045782786      -3.49353354439      -3.53711489464      -3.58120582620
+  -3.62581020295      -3.67093179704      -3.71657428052      -3.76274121632
+  -3.80943604876      -3.85666209348      -3.90442252664      -3.95272037363
+  -4.00155849695      -4.05093958339      -4.10086613046      -4.15134043199
+  -4.20236456285      -4.25394036281      -4.30606941942      -4.35875304993
+  -4.41199228224      -4.46578783466      -4.52014009476      -4.57504909693
+  -4.63051449890      -4.68653555707      -4.74311110060      -4.80023950434
+  -4.85791866057      -4.91614594947      -4.97491820847      -5.03423170040
+  -5.09408208049      -5.15446436233      -5.21537288277      -5.27680126586
+  -5.33874238599      -5.40118833018      -5.46413035990      -5.52755887225
+  -5.59146336093      -5.65583237712      -5.72065349039      -5.78591325000
+  -5.85159714681      -5.91768957609      -5.98417380156      -6.05103192104
+  -6.11824483408      -6.18579221199      -6.25356304034      -6.32146597478
+  -6.38950644363      -6.45768604429      -6.52600243545      -6.59444925383
+  -6.66301605193      -6.73168825374      -6.80044712556      -6.86926975970
+  -6.93812906912      -7.00699379154      -7.07582850189      -7.14459363235
+  -7.21324549932      -7.28173633741      -7.35001434012      -7.41802370785
+  -7.48570470338      -7.55299371568      -7.61982333275      -7.68612242446
+  -7.75181623651      -7.81682649662      -7.88107153439      -7.94446641606
+  -8.00692309579      -8.06835058500      -8.12865514126      -8.18774047844
+  -8.24550799985      -8.30185705585      -8.35668522764      -8.40988863877
+  -8.46136229568      -8.51100045867      -8.55869704427      -8.60434605977
+  -8.64784207049      -8.68908069973      -8.72795916121      -8.76437682305
+  -8.79823580197      -8.82944158599      -8.85790368316      -8.88353629375
+  -8.90625900294      -8.92599749133      -8.94268426068      -8.95625937372
+  -8.96667120686      -8.97387723376      -8.97784478192      -8.97855193636
+  -8.97584348610      -8.96988977791      -8.96068606463      -8.94826347473
+  -8.93266922720      -8.91396727184      -8.89223924865      -8.86758531985
+  -8.84012494560      -8.80999757989      -8.77736326806      -8.74240312357
+  -8.70531965808      -8.66633693622      -8.62570052150      -8.58367717668
+  -8.54055427633      -8.49663888545      -8.45225645225      -8.40774905897
+  -8.36347316964      -8.31979681018      -8.27709611316      -8.23575115942
+  -8.19614105004      -8.15863814863      -8.12360144467      -8.09136900669
+  -8.06224952119      -8.03651295169      -8.01438040468      -7.99601336005
+  -7.98150251485      -7.97085660691      -7.96399173255      -7.96072185658
+  -7.96075143845      -7.96367137302      -7.96895977582      -7.97598953968
+  -7.98404506375      -7.99235112070      -8.00011749999      -8.00660386626
+  -8.01121023017      -8.01359957726      -8.01386058150      -8.01271999165
+ Up Pseudopotential follows (l on next line)
+  1
+ -0.151139468401E-06 -0.304180037280E-06 -0.459145619540E-06 -0.616060428866E-06
+ -0.774948983517E-06 -0.935836110153E-06 -0.109874694772E-05 -0.126370695135E-05
+ -0.143074189640E-05 -0.159987788242E-05 -0.177114133723E-05 -0.194455902111E-05
+ -0.212015803093E-05 -0.229796580438E-05 -0.247801012429E-05 -0.266031912296E-05
+ -0.284492128653E-05 -0.303184545947E-05 -0.322112084906E-05 -0.341277702997E-05
+ -0.360684394886E-05 -0.380335192909E-05 -0.400233167542E-05 -0.420381427885E-05
+ -0.440783122144E-05 -0.461441438126E-05 -0.482359603734E-05 -0.503540887475E-05
+ -0.524988598967E-05 -0.546706089459E-05 -0.568696752352E-05 -0.590964023733E-05
+ -0.613511382908E-05 -0.636342352947E-05 -0.659460501237E-05 -0.682869440035E-05
+ -0.706572827035E-05 -0.730574365940E-05 -0.754877807039E-05 -0.779486947794E-05
+ -0.804405633433E-05 -0.829637757553E-05 -0.855187262722E-05 -0.881058141105E-05
+ -0.907254435077E-05 -0.933780237864E-05 -0.960639694175E-05 -0.987837000857E-05
+ -0.101537640754E-04 -0.104326221732E-04 -0.107149878740E-04 -0.110009052982E-04
+ -0.112904191208E-04 -0.115835745790E-04 -0.118804174789E-04 -0.121809942028E-04
+ -0.124853517165E-04 -0.127935375764E-04 -0.131055999373E-04 -0.134215875594E-04
+ -0.137415498165E-04 -0.140655367034E-04 -0.143935988436E-04 -0.147257874975E-04
+ -0.150621545704E-04 -0.154027526201E-04 -0.157476348660E-04 -0.160968551964E-04
+ -0.164504681779E-04 -0.168085290631E-04 -0.171710937997E-04 -0.175382190394E-04
+ -0.179099621461E-04 -0.182863812055E-04 -0.186675350337E-04 -0.190534831869E-04
+ -0.194442859703E-04 -0.198400044475E-04 -0.202407004504E-04 -0.206464365885E-04
+ -0.210572762591E-04 -0.214732836565E-04 -0.218945237828E-04 -0.223210624576E-04
+ -0.227529663284E-04 -0.231903028812E-04 -0.236331404506E-04 -0.240815482309E-04
+ -0.245355962868E-04 -0.249953555641E-04 -0.254608979012E-04 -0.259322960400E-04
+ -0.264096236375E-04 -0.268929552770E-04 -0.273823664802E-04 -0.278779337184E-04
+ -0.283797344251E-04 -0.288878470077E-04 -0.294023508598E-04 -0.299233263737E-04
+ -0.304508549528E-04 -0.309850190246E-04 -0.315259020533E-04 -0.320735885530E-04
+ -0.326281641007E-04 -0.331897153501E-04 -0.337583300447E-04 -0.343340970316E-04
+ -0.349171062757E-04 -0.355074488734E-04 -0.361052170668E-04 -0.367105042584E-04
+ -0.373234050257E-04 -0.379440151355E-04 -0.385724315595E-04 -0.392087524891E-04
+ -0.398530773507E-04 -0.405055068213E-04 -0.411661428444E-04 -0.418350886456E-04
+ -0.425124487493E-04 -0.431983289941E-04 -0.438928365504E-04 -0.445960799364E-04
+ -0.453081690351E-04 -0.460292151121E-04 -0.467593308323E-04 -0.474986302776E-04
+ -0.482472289652E-04 -0.490052438651E-04 -0.497727934187E-04 -0.505499975572E-04
+ -0.513369777202E-04 -0.521338568751E-04 -0.529407595359E-04 -0.537578117826E-04
+ -0.545851412815E-04 -0.554228773043E-04 -0.562711507491E-04 -0.571300941603E-04
+ -0.579998417497E-04 -0.588805294169E-04 -0.597722947712E-04 -0.606752771529E-04
+ -0.615896176547E-04 -0.625154591441E-04 -0.634529462859E-04 -0.644022255643E-04
+ -0.653634453061E-04 -0.663367557038E-04 -0.673223088391E-04 -0.683202587069E-04
+ -0.693307612387E-04 -0.703539743276E-04 -0.713900578528E-04 -0.724391737044E-04
+ -0.735014858088E-04 -0.745771601547E-04 -0.756663648181E-04 -0.767692699896E-04
+ -0.778860480004E-04 -0.790168733492E-04 -0.801619227300E-04 -0.813213750588E-04
+ -0.824954115026E-04 -0.836842155069E-04 -0.848879728248E-04 -0.861068715458E-04
+ -0.873411021252E-04 -0.885908574142E-04 -0.898563326895E-04 -0.911377256843E-04
+ -0.924352366187E-04 -0.937490682316E-04 -0.950794258117E-04 -0.964265172302E-04
+ -0.977905529728E-04 -0.991717461729E-04 -0.100570312645E-03 -0.101986470917E-03
+ -0.103420442268E-03 -0.104872450758E-03 -0.106342723266E-03 -0.107831489525E-03
+ -0.109338982159E-03 -0.110865436716E-03 -0.112411091708E-03 -0.113976188646E-03
+ -0.115560972080E-03 -0.117165689636E-03 -0.118790592054E-03 -0.120435933228E-03
+ -0.122101970246E-03 -0.123788963430E-03 -0.125497176376E-03 -0.127226875996E-03
+ -0.128978332559E-03 -0.130751819733E-03 -0.132547614630E-03 -0.134365997846E-03
+ -0.136207253507E-03 -0.138071669313E-03 -0.139959536583E-03 -0.141871150300E-03
+ -0.143806809157E-03 -0.145766815606E-03 -0.147751475901E-03 -0.149761100149E-03
+ -0.151796002358E-03 -0.153856500486E-03 -0.155942916490E-03 -0.158055576376E-03
+ -0.160194810253E-03 -0.162360952379E-03 -0.164554341219E-03 -0.166775319494E-03
+ -0.169024234237E-03 -0.171301436845E-03 -0.173607283136E-03 -0.175942133402E-03
+ -0.178306352469E-03 -0.180700309752E-03 -0.183124379310E-03 -0.185578939909E-03
+ -0.188064375080E-03 -0.190581073177E-03 -0.193129427439E-03 -0.195709836051E-03
+ -0.198322702208E-03 -0.200968434176E-03 -0.203647445355E-03 -0.206360154346E-03
+ -0.209106985015E-03 -0.211888366561E-03 -0.214704733581E-03 -0.217556526136E-03
+ -0.220444189825E-03 -0.223368175853E-03 -0.226328941097E-03 -0.229326948183E-03
+ -0.232362665556E-03 -0.235436567553E-03 -0.238549134477E-03 -0.241700852673E-03
+ -0.244892214604E-03 -0.248123718926E-03 -0.251395870569E-03 -0.254709180812E-03
+ -0.258064167368E-03 -0.261461354460E-03 -0.264901272905E-03 -0.268384460198E-03
+ -0.271911460593E-03 -0.275482825191E-03 -0.279099112026E-03 -0.282760886150E-03
+ -0.286468719722E-03 -0.290223192099E-03 -0.294024889924E-03 -0.297874407222E-03
+ -0.301772345486E-03 -0.305719313778E-03 -0.309715928819E-03 -0.313762815089E-03
+ -0.317860604922E-03 -0.322009938605E-03 -0.326211464481E-03 -0.330465839047E-03
+ -0.334773727056E-03 -0.339135801627E-03 -0.343552744340E-03 -0.348025245354E-03
+ -0.352554003505E-03 -0.357139726421E-03 -0.361783130630E-03 -0.366484941674E-03
+ -0.371245894220E-03 -0.376066732177E-03 -0.380948208810E-03 -0.385891086861E-03
+ -0.390896138664E-03 -0.395964146268E-03 -0.401095901560E-03 -0.406292206387E-03
+ -0.411553872682E-03 -0.416881722592E-03 -0.422276588603E-03 -0.427739313675E-03
+ -0.433270751370E-03 -0.438871765985E-03 -0.444543232691E-03 -0.450286037665E-03
+ -0.456101078234E-03 -0.461989263008E-03 -0.467951512029E-03 -0.473988756910E-03
+ -0.480101940983E-03 -0.486292019445E-03 -0.492559959509E-03 -0.498906740552E-03
+ -0.505333354273E-03 -0.511840804843E-03 -0.518430109064E-03 -0.525102296529E-03
+ -0.531858409779E-03 -0.538699504472E-03 -0.545626649543E-03 -0.552640927372E-03
+ -0.559743433953E-03 -0.566935279069E-03 -0.574217586459E-03 -0.581591493999E-03
+ -0.589058153877E-03 -0.596618732773E-03 -0.604274412044E-03 -0.612026387904E-03
+ -0.619875871616E-03 -0.627824089677E-03 -0.635872284012E-03 -0.644021712169E-03
+ -0.652273647511E-03 -0.660629379421E-03 -0.669090213498E-03 -0.677657471764E-03
+ -0.686332492872E-03 -0.695116632309E-03 -0.704011262618E-03 -0.713017773600E-03
+ -0.722137572542E-03 -0.731372084430E-03 -0.740722752176E-03 -0.750191036840E-03
+ -0.759778417861E-03 -0.769486393286E-03 -0.779316480006E-03 -0.789270213991E-03
+ -0.799349150534E-03 -0.809554864486E-03 -0.819888950513E-03 -0.830353023335E-03
+ -0.840948717985E-03 -0.851677690061E-03 -0.862541615987E-03 -0.873542193272E-03
+ -0.884681140779E-03 -0.895960198990E-03 -0.907381130281E-03 -0.918945719194E-03
+ -0.930655772721E-03 -0.942513120579E-03 -0.954519615502E-03 -0.966677133531E-03
+ -0.978987574299E-03 -0.991452861338E-03 -0.100407494237E-02 -0.101685578963E-02
+ -0.102979740014E-02 -0.104290179606E-02 -0.105617102497E-02 -0.106960716022E-02
+ -0.108321230122E-02 -0.109698857381E-02 -0.111093813056E-02 -0.112506315111E-02
+ -0.113936584252E-02 -0.115384843962E-02 -0.116851320534E-02 -0.118336243107E-02
+ -0.119839843704E-02 -0.121362357265E-02 -0.122904021686E-02 -0.124465077854E-02
+ -0.126045769688E-02 -0.127646344174E-02 -0.129267051403E-02 -0.130908144616E-02
+ -0.132569880234E-02 -0.134252517909E-02 -0.135956320554E-02 -0.137681554392E-02
+ -0.139428488994E-02 -0.141197397322E-02 -0.142988555770E-02 -0.144802244210E-02
+ -0.146638746034E-02 -0.148498348199E-02 -0.150381341270E-02 -0.152288019468E-02
+ -0.154218680715E-02 -0.156173626679E-02 -0.158153162825E-02 -0.160157598457E-02
+ -0.162187246773E-02 -0.164242424907E-02 -0.166323453984E-02 -0.168430659168E-02
+ -0.170564369713E-02 -0.172724919014E-02 -0.174912644660E-02 -0.177127888487E-02
+ -0.179370996627E-02 -0.181642319571E-02 -0.183942212216E-02 -0.186271033921E-02
+ -0.188629148569E-02 -0.191016924616E-02 -0.193434735157E-02 -0.195882957975E-02
+ -0.198361975609E-02 -0.200872175406E-02 -0.203413949588E-02 -0.205987695309E-02
+ -0.208593814718E-02 -0.211232715023E-02 -0.213904808554E-02 -0.216610512826E-02
+ -0.219350250607E-02 -0.222124449983E-02 -0.224933544421E-02 -0.227777972844E-02
+ -0.230658179694E-02 -0.233574615002E-02 -0.236527734461E-02 -0.239517999496E-02
+ -0.242545877334E-02 -0.245611841079E-02 -0.248716369786E-02 -0.251859948535E-02
+ -0.255043068508E-02 -0.258266227063E-02 -0.261529927815E-02 -0.264834680712E-02
+ -0.268181002117E-02 -0.271569414887E-02 -0.275000448453E-02 -0.278474638908E-02
+ -0.281992529085E-02 -0.285554668646E-02 -0.289161614164E-02 -0.292813929213E-02
+ -0.296512184456E-02 -0.300256957730E-02 -0.304048834141E-02 -0.307888406155E-02
+ -0.311776273687E-02 -0.315713044195E-02 -0.319699332781E-02 -0.323735762278E-02
+ -0.327822963355E-02 -0.331961574610E-02 -0.336152242671E-02 -0.340395622300E-02
+ -0.344692376492E-02 -0.349043176578E-02 -0.353448702331E-02 -0.357909642074E-02
+ -0.362426692783E-02 -0.367000560198E-02 -0.371631958934E-02 -0.376321612593E-02
+ -0.381070253871E-02 -0.385878624679E-02 -0.390747476258E-02 -0.395677569290E-02
+ -0.400669674023E-02 -0.405724570389E-02 -0.410843048125E-02 -0.416025906895E-02
+ -0.421273956416E-02 -0.426588016586E-02 -0.431968917606E-02 -0.437417500116E-02
+ -0.442934615319E-02 -0.448521125120E-02 -0.454177902255E-02 -0.459905830429E-02
+ -0.465705804454E-02 -0.471578730386E-02 -0.477525525667E-02 -0.483547119267E-02
+ -0.489644451831E-02 -0.495818475819E-02 -0.502070155661E-02 -0.508400467902E-02
+ -0.514810401352E-02 -0.521300957246E-02 -0.527873149393E-02 -0.534528004334E-02
+ -0.541266561504E-02 -0.548089873389E-02 -0.554999005692E-02 -0.561995037495E-02
+ -0.569079061430E-02 -0.576252183840E-02 -0.583515524959E-02 -0.590870219077E-02
+ -0.598317414722E-02 -0.605858274827E-02 -0.613493976922E-02 -0.621225713302E-02
+ -0.629054691220E-02 -0.636982133066E-02 -0.645009276560E-02 -0.653137374936E-02
+ -0.661367697138E-02 -0.669701528011E-02 -0.678140168501E-02 -0.686684935849E-02
+ -0.695337163796E-02 -0.704098202783E-02 -0.712969420156E-02 -0.721952200376E-02
+ -0.731047945229E-02 -0.740258074032E-02 -0.749584023856E-02 -0.759027249736E-02
+ -0.768589224894E-02 -0.778271440957E-02 -0.788075408183E-02 -0.798002655686E-02
+ -0.808054731664E-02 -0.818233203628E-02 -0.828539658640E-02 -0.838975703540E-02
+ -0.849542965191E-02 -0.860243090711E-02 -0.871077747722E-02 -0.882048624589E-02
+ -0.893157430667E-02 -0.904405896552E-02 -0.915795774326E-02 -0.927328837815E-02
+ -0.939006882838E-02 -0.950831727469E-02 -0.962805212291E-02 -0.974929200658E-02
+ -0.987205578957E-02 -0.999636256870E-02 -0.101222316764E-01 -0.102496826835E-01
+ -0.103787354016E-01 -0.105094098860E-01 -0.106417264387E-01 -0.107757056103E-01
+ -0.109113682036E-01 -0.110487352759E-01 -0.111878281417E-01 -0.113286683756E-01
+ -0.114712778152E-01 -0.116156785636E-01 -0.117618929921E-01 -0.119099437433E-01
+ -0.120598537336E-01 -0.122116461560E-01 -0.123653444828E-01 -0.125209724684E-01
+ -0.126785541520E-01 -0.128381138602E-01 -0.129996762097E-01 -0.131632661099E-01
+ -0.133289087658E-01 -0.134966296801E-01 -0.136664546559E-01 -0.138384097994E-01
+ -0.140125215220E-01 -0.141888165431E-01 -0.143673218918E-01 -0.145480649098E-01
+ -0.147310732531E-01 -0.149163748942E-01 -0.151039981242E-01 -0.152939715546E-01
+ -0.154863241191E-01 -0.156810850752E-01 -0.158782840058E-01 -0.160779508205E-01
+ -0.162801157570E-01 -0.164848093819E-01 -0.166920625918E-01 -0.169019066140E-01
+ -0.171143730068E-01 -0.173294936600E-01 -0.175473007945E-01 -0.177678269628E-01
+ -0.179911050476E-01 -0.182171682615E-01 -0.184460501460E-01 -0.186777845693E-01
+ -0.189124057253E-01 -0.191499481306E-01 -0.193904466225E-01 -0.196339363551E-01
+ -0.198804527964E-01 -0.201300317236E-01 -0.203827092188E-01 -0.206385216635E-01
+ -0.208975057325E-01 -0.211596983877E-01 -0.214251368706E-01 -0.216938586940E-01
+ -0.219659016334E-01 -0.222413037170E-01 -0.225201032151E-01 -0.228023386284E-01
+ -0.230880486752E-01 -0.233772722773E-01 -0.236700485454E-01 -0.239664167624E-01
+ -0.242664163656E-01 -0.245700869280E-01 -0.248774681373E-01 -0.251885997737E-01
+ -0.255035216858E-01 -0.258222737650E-01 -0.261448959176E-01 -0.264714280348E-01
+ -0.268019099611E-01 -0.271363814593E-01 -0.274748821743E-01 -0.278174515935E-01
+ -0.281641290043E-01 -0.285149534496E-01 -0.288699636790E-01 -0.292291980974E-01
+ -0.295926947103E-01 -0.299604910646E-01 -0.303326241866E-01 -0.307091305147E-01
+ -0.310900458286E-01 -0.314754051733E-01 -0.318652427789E-01 -0.322595919742E-01
+ -0.326584850959E-01 -0.330619533912E-01 -0.334700269150E-01 -0.338827344198E-01
+ -0.343001032400E-01 -0.347221591675E-01 -0.351489263212E-01 -0.355804270077E-01
+ -0.360166815736E-01 -0.364577082493E-01 -0.369035229833E-01 -0.373541392664E-01
+ -0.378095679461E-01 -0.382698170295E-01 -0.387348914755E-01 -0.392047929741E-01
+ -0.396795197137E-01 -0.401590661348E-01 -0.406434226701E-01 -0.411325754695E-01
+ -0.416265061102E-01 -0.421251912906E-01 -0.426286025071E-01 -0.431367057134E-01
+ -0.436494609622E-01 -0.441668220260E-01 -0.446887359991E-01 -0.452151428780E-01
+ -0.457459751204E-01 -0.462811571804E-01 -0.468206050205E-01 -0.473642255994E-01
+ -0.479119163323E-01 -0.484635645266E-01 -0.490190467880E-01 -0.495782283989E-01
+ -0.501409626666E-01 -0.507070902404E-01 -0.512764383979E-01 -0.518488202967E-01
+ -0.524240341944E-01 -0.530018626318E-01 -0.535820715819E-01 -0.541644095615E-01
+ -0.547486067054E-01 -0.553343738029E-01 -0.559214012948E-01 -0.565093582316E-01
+ -0.570978911904E-01 -0.576866231530E-01 -0.582751523421E-01 -0.588630510169E-01
+ -0.594498642285E-01 -0.600351085337E-01 -0.606182706699E-01 -0.611988061897E-01
+ -0.617761380573E-01 -0.623496552080E-01 -0.629187110714E-01 -0.634826220612E-01
+ -0.640406660339E-01 -0.645920807179E-01 -0.651360621180E-01 -0.656717628971E-01
+ -0.661982907410E-01 -0.667147067103E-01 -0.672200235842E-01 -0.677132042040E-01
+ -0.681931598218E-01 -0.686587484621E-01 -0.691087733062E-01 -0.695419811067E-01
+ -0.699570606443E-01 -0.703526412367E-01 -0.707272913137E-01 -0.710795170704E-01
+ -0.714077612143E-01 -0.717104018214E-01 -0.719857513204E-01 -0.722320556207E-01
+ -0.724474934068E-01 -0.726301756199E-01 -0.727781451486E-01 -0.728893767550E-01
+ -0.729617772613E-01 -0.729931860251E-01 -0.729813757324E-01 -0.729240535409E-01
+ -0.728188626047E-01 -0.726633840168E-01 -0.724551392046E-01 -0.721915928180E-01
+ -0.718701561491E-01 -0.714881911257E-01 -0.710430149231E-01 -0.705319052385E-01
+ -0.699521062764E-01 -0.693008354937E-01 -0.685752911560E-01 -0.677726607570E-01
+ -0.668901303575E-01 -0.659248948993E-01 -0.648741695539E-01 -0.637352021665E-01
+ -0.625052868587E-01 -0.611817788555E-01 -0.597621106056E-01 -0.582438092643E-01
+ -0.566245156157E-01 -0.549020045091E-01 -0.530742068917E-01 -0.511392335228E-01
+ -0.490954004568E-01 -0.469412563887E-01 -0.446756119592E-01 -0.422975711195E-01
+ -0.398065646618E-01 -0.372023860217E-01 -0.344852294625E-01 -0.316557307516E-01
+ -0.287150104336E-01 -0.256647198034E-01 -0.225070896672E-01 -0.192449819661E-01
+ -0.158819443090E-01 -0.124222674286E-01 -0.887104552515E-02 -0.523423939935E-02
+ -0.151874219349E-02  0.226755254695E-02  0.611568091127E-02  0.100155373471E-01
+  0.139558028582E-01  0.179238737115E-01  0.219057919802E-01  0.258861796010E-01
+  0.298481780237E-01  0.337733960053E-01  0.376418686266E-01  0.414320312105E-01
+  0.451207124768E-01  0.486831519777E-01  0.520930476142E-01  0.553226398043E-01
+  0.583428396403E-01  0.611234090943E-01  0.636332019531E-01  0.658404746239E-01
+  0.677132761728E-01  0.692199268278E-01  0.703295935951E-01  0.710129704472E-01
+  0.712430686007E-01  0.709961195253E-01  0.702525893320E-01  0.689982978753E-01
+  0.672256290789E-01  0.649348104660E-01  0.621352294779E-01  0.588467417791E-01
+  0.551009122909E-01  0.509421131712E-01  0.464283844348E-01  0.416319425364E-01
+  0.366392002256E-01  0.315501375536E-01  0.264768392241E-01  0.215409874906E-01
+  0.168700720811E-01  0.125920480802E-01  0.882813723850E-02  0.568342437464E-02
+  0.323484327653E-02  0.151606888668E-02  0.498726282316E-03  0.691837624345E-04
+  0.124122199926E-07   0.00000000000       0.00000000000       0.00000000000
+   0.00000000000       0.00000000000       0.00000000000       0.00000000000
+  2
+  0.325314401054E-07  0.654720753538E-07  0.988270527863E-07  0.132601584186E-06
+  0.166800946892E-06  0.201430484625E-06  0.236495608320E-06  0.272001796975E-06
+  0.307954598502E-06  0.344359630602E-06  0.381222581633E-06  0.418549211508E-06
+  0.456345352587E-06  0.494616910596E-06  0.533369865543E-06  0.572610272655E-06
+  0.612344263327E-06  0.652578046074E-06  0.693317907510E-06  0.734570213317E-06
+  0.776341409253E-06  0.818638022155E-06  0.861466660950E-06  0.904834017705E-06
+  0.948746868654E-06  0.993212075271E-06  0.103823658533E-05  0.108382743402E-05
+  0.112999174498E-05  0.117673673149E-05  0.122406969755E-05  0.127199803903E-05
+  0.132052924483E-05  0.136967089805E-05  0.141943067717E-05  0.146981635726E-05
+  0.152083581119E-05  0.157249701085E-05  0.162480802840E-05  0.167777703756E-05
+  0.173141231483E-05  0.178572224083E-05  0.184071530160E-05  0.189640008993E-05
+  0.195278530667E-05  0.200987976213E-05  0.206769237742E-05  0.212623218590E-05
+  0.218550833452E-05  0.224553008530E-05  0.230630681677E-05  0.236784802540E-05
+  0.243016332715E-05  0.249326245891E-05  0.255715528003E-05  0.262185177390E-05
+  0.268736204949E-05  0.275369634291E-05  0.282086501903E-05  0.288887857307E-05
+  0.295774763232E-05  0.302748295768E-05  0.309809544547E-05  0.316959612900E-05
+  0.324199618042E-05  0.331530691237E-05  0.338953977982E-05  0.346470638179E-05
+  0.354081846322E-05  0.361788791678E-05  0.369592678472E-05  0.377494726079E-05
+  0.385496169208E-05  0.393598258102E-05  0.401802258729E-05  0.410109452980E-05
+  0.418521138871E-05  0.427038630746E-05  0.435663259479E-05  0.444396372687E-05
+  0.453239334936E-05  0.462193527958E-05  0.471260350862E-05  0.480441220359E-05
+  0.489737570978E-05  0.499150855292E-05  0.508682544148E-05  0.518334126889E-05
+  0.528107111597E-05  0.538003025319E-05  0.548023414312E-05  0.558169844283E-05
+  0.568443900631E-05  0.578847188699E-05  0.589381334022E-05  0.600047982582E-05
+  0.610848801063E-05  0.621785477117E-05  0.632859719620E-05  0.644073258945E-05
+  0.655427847232E-05  0.666925258657E-05  0.678567289715E-05  0.690355759496E-05
+  0.702292509974E-05  0.714379406288E-05  0.726618337042E-05  0.739011214594E-05
+  0.751559975355E-05  0.764266580096E-05  0.777133014249E-05  0.790161288219E-05
+  0.803353437703E-05  0.816711523999E-05  0.830237634337E-05  0.843933882199E-05
+  0.857802407649E-05  0.871845377677E-05  0.886064986521E-05  0.900463456027E-05
+  0.915043035983E-05  0.929806004479E-05  0.944754668259E-05  0.959891363081E-05
+  0.975218454087E-05  0.990738336164E-05  0.100645343433E-04  0.102236620409E-04
+  0.103847913185E-04  0.105479473530E-04  0.107131556377E-04  0.108804419869E-04
+  0.110498325393E-04  0.112213537625E-04  0.113950324571E-04  0.115708957608E-04
+  0.117489711525E-04  0.119292864569E-04  0.121118698486E-04  0.122967498567E-04
+  0.124839553690E-04  0.126735156367E-04  0.128654602791E-04  0.130598192879E-04
+  0.132566230320E-04  0.134559022625E-04  0.136576881172E-04  0.138620121254E-04
+  0.140689062133E-04  0.142784027084E-04  0.144905343451E-04  0.147053342692E-04
+  0.149228360438E-04  0.151430736540E-04  0.153660815122E-04  0.155918944640E-04
+  0.158205477930E-04  0.160520772269E-04  0.162865189425E-04  0.165239095719E-04
+  0.167642862078E-04  0.170076864096E-04  0.172541482090E-04  0.175037101162E-04
+  0.177564111258E-04  0.180122907228E-04  0.182713888889E-04  0.185337461087E-04
+  0.187994033761E-04  0.190684022006E-04  0.193407846137E-04  0.196165931759E-04
+  0.198958709826E-04  0.201786616717E-04  0.204650094298E-04  0.207549589993E-04
+  0.210485556854E-04  0.213458453632E-04  0.216468744848E-04  0.219516900866E-04
+  0.222603397967E-04  0.225728718422E-04  0.228893350569E-04  0.232097788888E-04
+  0.235342534079E-04  0.238628093140E-04  0.241954979447E-04  0.245323712832E-04
+  0.248734819667E-04  0.252188832943E-04  0.255686292358E-04  0.259227744397E-04
+  0.262813742419E-04  0.266444846743E-04  0.270121624737E-04  0.273844650905E-04
+  0.277614506976E-04  0.281431782000E-04  0.285297072433E-04  0.289210982234E-04
+  0.293174122959E-04  0.297187113859E-04  0.301250581970E-04  0.305365162217E-04
+  0.309531497513E-04  0.313750238855E-04  0.318022045431E-04  0.322347584719E-04
+  0.326727532594E-04  0.331162573429E-04  0.335653400212E-04  0.340200714641E-04
+  0.344805227245E-04  0.349467657487E-04  0.354188733882E-04  0.358969194107E-04
+  0.363809785120E-04  0.368711263272E-04  0.373674394430E-04  0.378699954092E-04
+  0.383788727513E-04  0.388941509823E-04  0.394159106157E-04  0.399442331773E-04
+  0.404792012185E-04  0.410208983294E-04  0.415694091511E-04  0.421248193896E-04
+  0.426872158289E-04  0.432566863445E-04  0.438333199174E-04  0.444172066477E-04
+  0.450084377689E-04  0.456071056621E-04  0.462133038704E-04  0.468271271135E-04
+  0.474486713024E-04  0.480780335548E-04  0.487153122097E-04  0.493606068433E-04
+  0.500140182842E-04  0.506756486291E-04  0.513456012593E-04  0.520239808562E-04
+  0.527108934178E-04  0.534064462758E-04  0.541107481117E-04  0.548239089740E-04
+  0.555460402957E-04  0.562772549112E-04  0.570176670742E-04  0.577673924756E-04
+  0.585265482616E-04  0.592952530518E-04  0.600736269579E-04  0.608617916025E-04
+  0.616598701376E-04  0.624679872649E-04  0.632862692543E-04  0.641148439638E-04
+  0.649538408601E-04  0.658033910382E-04  0.666636272418E-04  0.675346838848E-04
+  0.684166970713E-04  0.693098046178E-04  0.702141460743E-04  0.711298627457E-04
+  0.720570977147E-04  0.729959958637E-04  0.739467038974E-04  0.749093703657E-04
+  0.758841456874E-04  0.768711821730E-04  0.778706340490E-04  0.788826574816E-04
+  0.799074106017E-04  0.809450535290E-04  0.819957483973E-04  0.830596593796E-04
+  0.841369527144E-04  0.852277967307E-04  0.863323618753E-04  0.874508207386E-04
+  0.885833480820E-04  0.897301208652E-04  0.908913182737E-04  0.920671217470E-04
+  0.932577150069E-04  0.944632840856E-04  0.956840173558E-04  0.969201055597E-04
+  0.981717418383E-04  0.994391217623E-04  0.100722443363E-03  0.102021907160E-03
+  0.103337716200E-03  0.104670076078E-03  0.106019194979E-03  0.107385283706E-03
+  0.108768555713E-03  0.110169227138E-03  0.111587516839E-03  0.113023646427E-03
+  0.114477840299E-03  0.115950325677E-03  0.117441332639E-03  0.118951094158E-03
+  0.120479846137E-03  0.122027827446E-03  0.123595279961E-03  0.125182448599E-03
+  0.126789581358E-03  0.128416929355E-03  0.130064746867E-03  0.131733291369E-03
+  0.133422823573E-03  0.135133607472E-03  0.136865910380E-03  0.138620002971E-03
+  0.140396159327E-03  0.142194656974E-03  0.144015776932E-03  0.145859803753E-03
+  0.147727025570E-03  0.149617734141E-03  0.151532224890E-03  0.153470796962E-03
+  0.155433753261E-03  0.157421400503E-03  0.159434049260E-03  0.161472014014E-03
+  0.163535613198E-03  0.165625169254E-03  0.167741008679E-03  0.169883462076E-03
+  0.172052864206E-03  0.174249554043E-03  0.176473874822E-03  0.178726174097E-03
+  0.181006803793E-03  0.183316120263E-03  0.185654484339E-03  0.188022261394E-03
+  0.190419821398E-03  0.192847538973E-03  0.195305793451E-03  0.197794968939E-03
+  0.200315454374E-03  0.202867643584E-03  0.205451935352E-03  0.208068733477E-03
+  0.210718446835E-03  0.213401489448E-03  0.216118280543E-03  0.218869244623E-03
+  0.221654811526E-03  0.224475416500E-03  0.227331500267E-03  0.230223509093E-03
+  0.233151894853E-03  0.236117115112E-03  0.239119633186E-03  0.242159918219E-03
+  0.245238445256E-03  0.248355695319E-03  0.251512155478E-03  0.254708318930E-03
+  0.257944685074E-03  0.261221759593E-03  0.264540054529E-03  0.267900088363E-03
+  0.271302386098E-03  0.274747479342E-03  0.278235906387E-03  0.281768212296E-03
+  0.285344948989E-03  0.288966675325E-03  0.292633957194E-03  0.296347367602E-03
+  0.300107486763E-03  0.303914902188E-03  0.307770208776E-03  0.311674008910E-03
+  0.315626912547E-03  0.319629537318E-03  0.323682508619E-03  0.327786459712E-03
+  0.331942031824E-03  0.336149874247E-03  0.340410644438E-03  0.344725008120E-03
+  0.349093639392E-03  0.353517220829E-03  0.357996443588E-03  0.362532007521E-03
+  0.367124621278E-03  0.371775002424E-03  0.376483877544E-03  0.381251982363E-03
+  0.386080061855E-03  0.390968870363E-03  0.395919171717E-03  0.400931739348E-03
+  0.406007356417E-03  0.411146815929E-03  0.416350920860E-03  0.421620484284E-03
+  0.426956329496E-03  0.432359290145E-03  0.437830210358E-03  0.443369944876E-03
+  0.448979359187E-03  0.454659329658E-03  0.460410743673E-03  0.466234499772E-03
+  0.472131507791E-03  0.478102689002E-03  0.484148976255E-03  0.490271314130E-03
+  0.496470659075E-03  0.502747979562E-03  0.509104256232E-03  0.515540482051E-03
+  0.522057662464E-03  0.528656815552E-03  0.535338972184E-03  0.542105176186E-03
+  0.548956484497E-03  0.555893967335E-03  0.562918708362E-03  0.570031804856E-03
+  0.577234367872E-03  0.584527522425E-03  0.591912407658E-03  0.599390177018E-03
+  0.606961998437E-03  0.614629054511E-03  0.622392542685E-03  0.630253675434E-03
+  0.638213680453E-03  0.646273800847E-03  0.654435295320E-03  0.662699438372E-03
+  0.671067520491E-03  0.679540848357E-03  0.688120745038E-03  0.696808550195E-03
+  0.705605620290E-03  0.714513328789E-03  0.723533066377E-03  0.732666241166E-03
+  0.741914278917E-03  0.751278623249E-03  0.760760735867E-03  0.770362096780E-03
+  0.780084204527E-03  0.789928576405E-03  0.799896748700E-03  0.809990276916E-03
+  0.820210736014E-03  0.830559720649E-03  0.841038845408E-03  0.851649745053E-03
+  0.862394074770E-03  0.873273510411E-03  0.884289748750E-03  0.895444507730E-03
+  0.906739526724E-03  0.918176566790E-03  0.929757410929E-03  0.941483864353E-03
+  0.953357754747E-03  0.965380932535E-03  0.977555271158E-03  0.989882667335E-03
+  0.100236504135E-02  0.101500433731E-02  0.102780252345E-02  0.104076159241E-02
+  0.105388356148E-02  0.106717047294E-02  0.108062439433E-02  0.109424741871E-02
+  0.110804166500E-02  0.112200927822E-02  0.113615242985E-02  0.115047331806E-02
+  0.116497416806E-02  0.117965723236E-02  0.119452479111E-02  0.120957915235E-02
+  0.122482265238E-02  0.124025765599E-02  0.125588655683E-02  0.127171177766E-02
+  0.128773577070E-02  0.130396101789E-02  0.132039003123E-02  0.133702535305E-02
+  0.135386955637E-02  0.137092524510E-02  0.138819505446E-02  0.140568165117E-02
+  0.142338773381E-02  0.144131603310E-02  0.145946931217E-02  0.147785036686E-02
+  0.149646202598E-02  0.151530715163E-02  0.153438863941E-02  0.155370941876E-02
+  0.157327245313E-02  0.159308074030E-02  0.161313731259E-02  0.163344523710E-02
+  0.165400761594E-02  0.167482758641E-02  0.169590832127E-02  0.171725302885E-02
+  0.173886495328E-02  0.176074737463E-02  0.178290360902E-02  0.180533700882E-02
+  0.182805096270E-02  0.185104889571E-02  0.187433426938E-02  0.189791058175E-02
+  0.192178136734E-02  0.194595019722E-02  0.197042067887E-02  0.199519645618E-02
+  0.202028120927E-02  0.204567865443E-02  0.207139254384E-02  0.209742666540E-02
+  0.212378484244E-02  0.215047093337E-02  0.217748883134E-02  0.220484246380E-02
+  0.223253579197E-02  0.226057281034E-02  0.228895754602E-02  0.231769405803E-02
+  0.234678643655E-02  0.237623880207E-02  0.240605530439E-02  0.243624012169E-02
+  0.246679745926E-02  0.249773154839E-02  0.252904664490E-02  0.256074702773E-02
+  0.259283699734E-02  0.262532087390E-02  0.265820299550E-02  0.269148771603E-02
+  0.272517940300E-02  0.275928243521E-02  0.279380120009E-02  0.282874009104E-02
+  0.286410350441E-02  0.289989583630E-02  0.293612147918E-02  0.297278481818E-02
+  0.300989022718E-02  0.304744206457E-02  0.308544466876E-02  0.312390235331E-02
+  0.316281940183E-02  0.320220006242E-02  0.324204854178E-02  0.328236899898E-02
+  0.332316553867E-02  0.336444220400E-02  0.340620296900E-02  0.344845173042E-02
+  0.349119229917E-02  0.353442839105E-02  0.357816361705E-02  0.362240147291E-02
+  0.366714532809E-02  0.371239841405E-02  0.375816381177E-02  0.380444443854E-02
+  0.385124303393E-02  0.389856214490E-02  0.394640411001E-02  0.399477104272E-02
+  0.404366481365E-02  0.409308703183E-02  0.414303902482E-02  0.419352181770E-02
+  0.424453611085E-02  0.429608225643E-02  0.434816023349E-02  0.440076962180E-02
+  0.445390957405E-02  0.450757878662E-02  0.456177546870E-02  0.461649730969E-02
+  0.467174144487E-02  0.472750441924E-02  0.478378214937E-02  0.484056988328E-02
+  0.489786215823E-02  0.495565275631E-02  0.501393465776E-02  0.507269999190E-02
+  0.513193998568E-02  0.519164490962E-02  0.525180402115E-02  0.531240550520E-02
+  0.537343641199E-02  0.543488259194E-02  0.549672862750E-02  0.555895776204E-02
+  0.562155182545E-02  0.568449115657E-02  0.574775452235E-02  0.581131903352E-02
+  0.587516005698E-02  0.593925112460E-02  0.600356383854E-02  0.606806777307E-02
+  0.613273037276E-02  0.619751684718E-02  0.626239006206E-02  0.632731042691E-02
+  0.639223577935E-02  0.645712126590E-02  0.652191921976E-02  0.658657903541E-02
+  0.665104704033E-02  0.671526636409E-02  0.677917680506E-02  0.684271469497E-02
+  0.690581276178E-02  0.696839999129E-02  0.703040148785E-02  0.709173833480E-02
+  0.715232745529E-02  0.721208147403E-02  0.727090858094E-02  0.732871239738E-02
+  0.738539184603E-02  0.744084102539E-02  0.749494909026E-02  0.754760013916E-02
+  0.759867311043E-02  0.764804168837E-02  0.769557422100E-02  0.774113365156E-02
+  0.778457746531E-02  0.782575765405E-02  0.786452070054E-02  0.790070758507E-02
+  0.793415381708E-02  0.796468949431E-02  0.799213939255E-02  0.801632308900E-02
+  0.803705512256E-02  0.805414519432E-02  0.806739841197E-02  0.807661558158E-02
+  0.808159355074E-02  0.808212560692E-02  0.807800193487E-02  0.806901013725E-02
+  0.805493582247E-02  0.803556326374E-02  0.801067613324E-02  0.798005831529E-02
+  0.794349480222E-02  0.790077267608E-02  0.785168217967E-02  0.779601787924E-02
+  0.773357992118E-02  0.766417538435E-02  0.758761972884E-02  0.750373834138E-02
+  0.741236817652E-02  0.731335949155E-02  0.720657767238E-02  0.709190514559E-02
+  0.696924337097E-02  0.683851490701E-02  0.669966553986E-02  0.655266646476E-02
+  0.639751650671E-02  0.623424436475E-02  0.606291086261E-02  0.588361118546E-02
+  0.569647708070E-02  0.550167899787E-02  0.529942814086E-02  0.508997840288E-02
+  0.487362815286E-02  0.465072183959E-02  0.442165137873E-02  0.418685728574E-02
+  0.394682951745E-02  0.370210798409E-02  0.345328269372E-02  0.320099349178E-02
+  0.294592935989E-02  0.268882724015E-02  0.243047035414E-02  0.217168598992E-02
+  0.191334273466E-02  0.165634713648E-02  0.140163978481E-02  0.115019080596E-02
+  0.902994777476E-03  0.661065072694E-03  0.425427653929E-03  0.197114340051E-03
+ -0.228444199536E-04 -0.233427231146E-03 -0.433629855340E-03 -0.622473692800E-03
+ -0.799014605698E-03 -0.962352052173E-03 -0.111163850889E-02 -0.124608917330E-02
+ -0.136499195332E-02 -0.146771777148E-02 -0.155373123174E-02 -0.162260171804E-02
+ -0.167401501156E-02 -0.170778552539E-02 -0.172386925559E-02 -0.172237753097E-02
+ -0.170359160332E-02 -0.166797804681E-02 -0.161620482087E-02 -0.154915768544E-02
+ -0.146795643016E-02 -0.137397008154E-02 -0.126882987464E-02 -0.115443831321E-02
+ -0.103297209115E-02 -0.906876011140E-03 -0.778844317679E-03 -0.651785076820E-03
+ -0.528762394973E-03 -0.412910395966E-03 -0.307311978685E-03 -0.214834462190E-03
+ -0.137913269819E-03 -0.782737555426E-04 -0.365800275404E-04 -0.119980277844E-04
+ -0.165797361831E-05  0.162074513810E-08   0.00000000000       0.00000000000
+  3
+  0.683150590422E-08  0.137489415744E-07  0.207533878740E-07  0.278459392619E-07
+  0.350277039637E-07  0.422998041448E-07  0.496633760857E-07  0.571195703593E-07
+  0.646695520113E-07  0.723145007417E-07  0.800556110892E-07  0.878940926181E-07
+  0.958311701070E-07  0.103868083740E-06  0.112006089303E-06  0.120246458373E-06
+  0.128590478527E-06  0.137039453534E-06  0.145594703564E-06  0.154257565391E-06
+  0.163029392607E-06  0.171911555825E-06  0.180905442904E-06  0.190012459155E-06
+  0.199234027569E-06  0.208571589034E-06  0.218026602564E-06  0.227600545523E-06
+  0.237294913860E-06  0.247111222339E-06  0.257051004778E-06  0.267115814289E-06
+  0.277307223520E-06  0.287626824897E-06  0.298076230880E-06  0.308657074209E-06
+  0.319371008164E-06  0.330219706818E-06  0.341204865303E-06  0.352328200070E-06
+  0.363591449166E-06  0.374996372494E-06  0.386544752097E-06  0.398238392433E-06
+  0.410079120659E-06  0.422068786910E-06  0.434209264597E-06  0.446502450694E-06
+  0.458950266037E-06  0.471554655622E-06  0.484317588911E-06  0.497241060138E-06
+  0.510327088620E-06  0.523577719079E-06  0.536995021950E-06  0.550581093716E-06
+  0.564338057227E-06  0.578268062037E-06  0.592373284736E-06  0.606655929297E-06
+  0.621118227409E-06  0.635762438838E-06  0.650590851770E-06  0.665605783176E-06
+  0.680809579170E-06  0.696204615373E-06  0.711793297294E-06  0.727578060697E-06
+  0.743561371978E-06  0.759745728567E-06  0.776133659303E-06  0.792727724828E-06
+  0.809530518005E-06  0.826544664300E-06  0.843772822210E-06  0.861217683671E-06
+  0.878881974474E-06  0.896768454705E-06  0.914879919159E-06  0.933219197792E-06
+  0.951789156152E-06  0.970592695834E-06  0.989632754931E-06  0.100891230848E-05
+  0.102843436897E-05  0.104820198675E-05  0.106821825055E-05  0.108848628795E-05
+  0.110900926588E-05  0.112979039109E-05  0.115083291068E-05  0.117214011258E-05
+  0.119371532609E-05  0.121556192238E-05  0.123768331502E-05  0.126008296052E-05
+  0.128276435888E-05  0.130573105412E-05  0.132898663481E-05  0.135253473470E-05
+  0.137637903322E-05  0.140052325609E-05  0.142497117591E-05  0.144972661270E-05
+  0.147479343455E-05  0.150017555819E-05  0.152587694966E-05  0.155190162483E-05
+  0.157825365012E-05  0.160493714308E-05  0.163195627307E-05  0.165931526187E-05
+  0.168701838439E-05  0.171506996929E-05  0.174347439969E-05  0.177223611384E-05
+  0.180135960582E-05  0.183084942623E-05  0.186071018292E-05  0.189094654170E-05
+  0.192156322704E-05  0.195256502288E-05  0.198395677330E-05  0.201574338334E-05
+  0.204792981971E-05  0.208052111161E-05  0.211352235149E-05  0.214693869588E-05
+  0.218077536613E-05  0.221503764930E-05  0.224973089893E-05  0.228486053594E-05
+  0.232043204936E-05  0.235645099735E-05  0.239292300794E-05  0.242985377993E-05
+  0.246724908386E-05  0.250511476280E-05  0.254345673336E-05  0.258228098653E-05
+  0.262159358868E-05  0.266140068251E-05  0.270170848792E-05  0.274252330312E-05
+  0.278385150549E-05  0.282569955265E-05  0.286807398345E-05  0.291098141897E-05
+  0.295442856359E-05  0.299842220601E-05  0.304296922034E-05  0.308807656711E-05
+  0.313375129447E-05  0.318000053917E-05  0.322683152775E-05  0.327425157766E-05
+  0.332226809837E-05  0.337088859256E-05  0.342012065727E-05  0.346997198512E-05
+  0.352045036549E-05  0.357156368572E-05  0.362331993236E-05  0.367572719245E-05
+  0.372879365472E-05  0.378252761092E-05  0.383693745708E-05  0.389203169485E-05
+  0.394781893282E-05  0.400430788786E-05  0.406150738649E-05  0.411942636624E-05
+  0.417807387707E-05  0.423745908277E-05  0.429759126240E-05  0.435847981174E-05
+  0.442013424475E-05  0.448256419505E-05  0.454577941746E-05  0.460978978948E-05
+  0.467460531286E-05  0.474023611516E-05  0.480669245133E-05  0.487398470531E-05
+  0.494212339164E-05  0.501111915714E-05  0.508098278252E-05  0.515172518413E-05
+  0.522335741562E-05  0.529589066965E-05  0.536933627971E-05  0.544370572182E-05
+  0.551901061634E-05  0.559526272983E-05  0.567247397684E-05  0.575065642178E-05
+  0.582982228081E-05  0.590998392377E-05  0.599115387607E-05  0.607334482067E-05
+  0.615656960008E-05  0.624084121836E-05  0.632617284311E-05  0.641257780756E-05
+  0.650006961265E-05  0.658866192919E-05  0.667836859989E-05  0.676920364160E-05
+  0.686118124748E-05  0.695431578922E-05  0.704862181927E-05  0.714411407315E-05
+  0.724080747174E-05  0.733871712353E-05  0.743785832714E-05  0.753824657358E-05
+  0.763989754871E-05  0.774282713569E-05  0.784705141751E-05  0.795258667942E-05
+  0.805944941150E-05  0.816765631125E-05  0.827722428628E-05  0.838817045674E-05
+  0.850051215825E-05  0.861426694443E-05  0.872945258963E-05  0.884608709190E-05
+  0.896418867561E-05  0.908377579439E-05  0.920486713390E-05  0.932748161499E-05
+  0.945163839638E-05  0.957735687785E-05  0.970465670312E-05  0.983355776306E-05
+  0.996408019877E-05  0.100962444046E-04  0.102300710315E-04  0.103655809901E-04
+  0.105027954542E-04  0.106417358637E-04  0.107824239285E-04  0.109248816313E-04
+  0.110691312313E-04  0.112151952680E-04  0.113630965641E-04  0.115128582295E-04
+  0.116645036647E-04  0.118180565647E-04  0.119735409224E-04  0.121309810326E-04
+  0.122904014955E-04  0.124518272210E-04  0.126152834322E-04  0.127807956694E-04
+  0.129483897943E-04  0.131180919937E-04  0.132899287841E-04  0.134639270151E-04
+  0.136401138745E-04  0.138185168918E-04  0.139991639427E-04  0.141820832539E-04
+  0.143673034067E-04  0.145548533422E-04  0.147447623655E-04  0.149370601503E-04
+  0.151317767435E-04  0.153289425698E-04  0.155285884370E-04  0.157307455400E-04
+  0.159354454663E-04  0.161427202007E-04  0.163526021303E-04  0.165651240496E-04
+  0.167803191656E-04  0.169982211029E-04  0.172188639091E-04  0.174422820602E-04
+  0.176685104657E-04  0.178975844742E-04  0.181295398790E-04  0.183644129236E-04
+  0.186022403075E-04  0.188430591915E-04  0.190869072042E-04  0.193338224473E-04
+  0.195838435018E-04  0.198370094340E-04  0.200933598016E-04  0.203529346599E-04
+  0.206157745679E-04  0.208819205951E-04  0.211514143270E-04  0.214242978729E-04
+  0.217006138711E-04  0.219804054967E-04  0.222637164677E-04  0.225505910521E-04
+  0.228410740744E-04  0.231352109234E-04  0.234330475584E-04  0.237346305171E-04
+  0.240400069224E-04  0.243492244900E-04  0.246623315357E-04  0.249793769832E-04
+  0.253004103715E-04  0.256254818627E-04  0.259546422499E-04  0.262879429649E-04
+  0.266254360868E-04  0.269671743496E-04  0.273132111505E-04  0.276636005585E-04
+  0.280183973226E-04  0.283776568805E-04  0.287414353674E-04  0.291097896243E-04
+  0.294827772072E-04  0.298604563963E-04  0.302428862047E-04  0.306301263879E-04
+  0.310222374528E-04  0.314192806677E-04  0.318213180714E-04  0.322284124829E-04
+  0.326406275115E-04  0.330580275669E-04  0.334806778685E-04  0.339086444563E-04
+  0.343419942010E-04  0.347807948142E-04  0.352251148596E-04  0.356750237629E-04
+  0.361305918233E-04  0.365918902244E-04  0.370589910448E-04  0.375319672701E-04
+  0.380108928037E-04  0.384958424785E-04  0.389868920691E-04  0.394841183028E-04
+  0.399875988725E-04  0.404974124476E-04  0.410136386878E-04  0.415363582543E-04
+  0.420656528233E-04  0.426016050978E-04  0.431442988216E-04  0.436938187917E-04
+  0.442502508716E-04  0.448136820048E-04  0.453842002287E-04  0.459618946878E-04
+  0.465468556480E-04  0.471391745107E-04  0.477389438265E-04  0.483462573111E-04
+  0.489612098579E-04  0.495838975546E-04  0.502144176974E-04  0.508528688063E-04
+  0.514993506404E-04  0.521539642137E-04  0.528168118110E-04  0.534879970033E-04
+  0.541676246647E-04  0.548558009880E-04  0.555526335025E-04  0.562582310892E-04
+  0.569727039992E-04  0.576961638701E-04  0.584287237439E-04  0.591704980844E-04
+  0.599216027953E-04  0.606821552378E-04  0.614522742498E-04  0.622320801636E-04
+  0.630216948254E-04  0.638212416139E-04  0.646308454594E-04  0.654506328639E-04
+  0.662807319210E-04  0.671212723349E-04  0.679723854410E-04  0.688342042276E-04
+  0.697068633552E-04  0.705904991780E-04  0.714852497656E-04  0.723912549242E-04
+  0.733086562186E-04  0.742375969938E-04  0.751782223983E-04  0.761306794066E-04
+  0.770951168410E-04  0.780716853961E-04  0.790605376623E-04  0.800618281492E-04
+  0.810757133093E-04  0.821023515637E-04  0.831419033258E-04  0.841945310269E-04
+  0.852603991409E-04  0.863396742113E-04  0.874325248755E-04  0.885391218928E-04
+  0.896596381695E-04  0.907942487879E-04  0.919431310311E-04  0.931064644133E-04
+  0.942844307060E-04  0.954772139670E-04  0.966850005694E-04  0.979079792302E-04
+  0.991463410401E-04  0.100400279494E-03  0.101669990520E-03  0.102955672510E-03
+  0.104257526352E-03  0.105575755460E-03  0.106910565808E-03  0.108262165959E-03
+  0.109630767100E-03  0.111016583075E-03  0.112419830414E-03  0.113840728376E-03
+  0.115279498974E-03  0.116736367014E-03  0.118211560129E-03  0.119705308816E-03
+  0.121217846472E-03  0.122749409426E-03  0.124300236983E-03  0.125870571455E-03
+  0.127460658204E-03  0.129070745675E-03  0.130701085442E-03  0.132351932237E-03
+  0.134023544001E-03  0.135716181916E-03  0.137430110449E-03  0.139165597395E-03
+  0.140922913915E-03  0.142702334581E-03  0.144504137416E-03  0.146328603943E-03
+  0.148176019222E-03  0.150046671900E-03  0.151940854252E-03  0.153858862230E-03
+  0.155800995506E-03  0.157767557524E-03  0.159758855538E-03  0.161775200670E-03
+  0.163816907952E-03  0.165884296380E-03  0.167977688957E-03  0.170097412751E-03
+  0.172243798939E-03  0.174417182865E-03  0.176617904088E-03  0.178846306435E-03
+  0.181102738058E-03  0.183387551483E-03  0.185701103672E-03  0.188043756070E-03
+  0.190415874668E-03  0.192817830058E-03  0.195249997490E-03  0.197712756931E-03
+  0.200206493122E-03  0.202731595643E-03  0.205288458966E-03  0.207877482526E-03
+  0.210499070774E-03  0.213153633244E-03  0.215841584618E-03  0.218563344787E-03
+  0.221319338919E-03  0.224109997522E-03  0.226935756514E-03  0.229797057289E-03
+  0.232694346787E-03  0.235628077559E-03  0.238598707843E-03  0.241606701629E-03
+  0.244652528737E-03  0.247736664885E-03  0.250859591764E-03  0.254021797110E-03
+  0.257223774788E-03  0.260466024856E-03  0.263749053652E-03  0.267073373867E-03
+  0.270439504623E-03  0.273847971560E-03  0.277299306907E-03  0.280794049573E-03
+  0.284332745222E-03  0.287915946362E-03  0.291544212430E-03  0.295218109872E-03
+  0.298938212235E-03  0.302705100252E-03  0.306519361934E-03  0.310381592655E-03
+  0.314292395245E-03  0.318252380083E-03  0.322262165187E-03  0.326322376308E-03
+  0.330433647030E-03  0.334596618854E-03  0.338811941309E-03  0.343080272040E-03
+  0.347402276909E-03  0.351778630099E-03  0.356210014207E-03  0.360697120355E-03
+  0.365240648284E-03  0.369841306467E-03  0.374499812207E-03  0.379216891746E-03
+  0.383993280370E-03  0.388829722522E-03  0.393726971905E-03  0.398685791595E-03
+  0.403706954153E-03  0.408791241733E-03  0.413939446200E-03  0.419152369240E-03
+  0.424430822477E-03  0.429775627584E-03  0.435187616406E-03  0.440667631076E-03
+  0.446216524126E-03  0.451835158612E-03  0.457524408236E-03  0.463285157459E-03
+  0.469118301629E-03  0.475024747094E-03  0.481005411332E-03  0.487061223070E-03
+  0.493193122406E-03  0.499402060934E-03  0.505689001867E-03  0.512054920159E-03
+  0.518500802633E-03  0.525027648100E-03  0.531636467485E-03  0.538328283953E-03
+  0.545104133028E-03  0.551965062719E-03  0.558912133640E-03  0.565946419136E-03
+  0.573069005402E-03  0.580280991597E-03  0.587583489976E-03  0.594977625993E-03
+  0.602464538431E-03  0.610045379506E-03  0.617721314982E-03  0.625493524285E-03
+  0.633363200608E-03  0.641331551017E-03  0.649399796553E-03  0.657569172329E-03
+  0.665840927632E-03  0.674216326005E-03  0.682696645343E-03  0.691283177967E-03
+  0.699977230712E-03  0.708780124987E-03  0.717693196848E-03  0.726717797058E-03
+  0.735855291129E-03  0.745107059381E-03  0.754474496965E-03  0.763959013899E-03
+  0.773562035078E-03  0.783285000285E-03  0.793129364187E-03  0.803096596319E-03
+  0.813188181053E-03  0.823405617549E-03  0.833750419713E-03  0.844224116107E-03
+  0.854828249869E-03  0.865564378595E-03  0.876434074217E-03  0.887438922851E-03
+  0.898580524628E-03  0.909860493488E-03  0.921280456973E-03  0.932842055971E-03
+  0.944546944435E-03  0.956396789087E-03  0.968393269060E-03  0.980538075540E-03
+  0.992832911336E-03  0.100527949044E-02  0.101787953751E-02  0.103063478737E-02
+  0.104354698438E-02  0.105661788179E-02  0.106984924111E-02  0.108324283128E-02
+  0.109680042791E-02  0.111052381237E-02  0.112441477087E-02  0.113847509340E-02
+  0.115270657270E-02  0.116711100300E-02  0.118169017879E-02  0.119644589346E-02
+  0.121137993785E-02  0.122649409865E-02  0.124179015676E-02  0.125726988546E-02
+  0.127293504855E-02  0.128878739825E-02  0.130482867303E-02  0.132106059528E-02
+  0.133748486884E-02  0.135410317631E-02  0.137091717624E-02  0.138792850012E-02
+  0.140513874918E-02  0.142254949098E-02  0.144016225575E-02  0.145797853260E-02
+  0.147599976538E-02  0.149422734832E-02  0.151266262146E-02  0.153130686572E-02
+  0.155016129769E-02  0.156922706419E-02  0.158850523633E-02  0.160799680341E-02
+  0.162770266633E-02  0.164762363070E-02  0.166776039943E-02  0.168811356505E-02
+  0.170868360149E-02  0.172947085538E-02  0.175047553694E-02  0.177169771031E-02
+  0.179313728334E-02  0.181479399682E-02  0.183666741316E-02  0.185875690445E-02
+  0.188106163980E-02  0.190358057216E-02  0.192631242429E-02  0.194925567412E-02
+  0.197240853932E-02  0.199576896103E-02  0.201933458687E-02  0.204310275303E-02
+  0.206707046552E-02  0.209123438051E-02  0.211559078369E-02  0.214013556871E-02
+  0.216486421459E-02  0.218977176211E-02  0.221485278912E-02  0.224010138479E-02
+  0.226551112272E-02  0.229107503290E-02  0.231678557254E-02  0.234263459568E-02
+  0.236861332159E-02  0.239471230200E-02  0.242092138703E-02  0.244722968992E-02
+  0.247362555055E-02  0.250009649759E-02  0.252662920959E-02  0.255320947475E-02
+  0.257982214949E-02  0.260645111593E-02  0.263307923818E-02  0.265968831759E-02
+  0.268625904700E-02  0.271277096405E-02  0.273920240365E-02  0.276553044970E-02
+  0.279173088619E-02  0.281777814786E-02  0.284364527047E-02  0.286930384098E-02
+  0.289472394774E-02  0.291987413096E-02  0.294472133377E-02  0.296923085394E-02
+  0.299336629689E-02  0.301708952996E-02  0.304036063862E-02  0.306313788478E-02
+  0.308537766792E-02  0.310703448913E-02  0.312806091896E-02  0.314840756943E-02
+  0.316802307079E-02  0.318685405378E-02  0.320484513800E-02  0.322193892718E-02
+  0.323807601204E-02  0.325319498168E-02  0.326723244428E-02  0.328012305810E-02
+  0.329179957369E-02  0.330219288837E-02  0.331123211389E-02  0.331884465867E-02
+  0.332495632528E-02  0.332949142475E-02  0.333237290861E-02  0.333352251994E-02
+  0.333286096466E-02  0.333030810418E-02  0.332578317072E-02  0.331920500632E-02
+  0.331049232697E-02  0.329956401255E-02  0.328633942409E-02  0.327073874896E-02
+  0.325268337516E-02  0.323209629527E-02  0.320890254095E-02  0.318302964831E-02
+  0.315440815477E-02  0.312297212735E-02  0.308865972254E-02  0.305141377760E-02
+  0.301118243262E-02  0.296791978292E-02  0.292158656062E-02  0.287215084419E-02
+  0.281958879456E-02  0.276388541578E-02  0.270503533810E-02  0.264304362108E-02
+  0.257792657373E-02  0.250971258860E-02  0.243844298616E-02  0.236417286559E-02
+  0.228697195761E-02  0.220692547450E-02  0.212413495204E-02  0.203871907763E-02
+  0.195081449794E-02  0.186057659917E-02  0.176818025152E-02  0.167382050901E-02
+  0.157771325396E-02  0.148009577427E-02  0.138122725925E-02  0.128138919773E-02
+  0.118088565898E-02  0.108004343347E-02  0.979212006482E-03  0.878763332243E-03
+  0.779091370664E-03  0.680611341951E-03  0.583758646749E-03  0.488987390984E-03
+  0.396768445449E-03  0.307586960417E-03  0.221939245713E-03  0.140328917256E-03
+  0.632622024028E-04 -0.875770976044E-05 -0.752373904049E-04 -0.135701080714E-03
+ -0.189699896302E-03 -0.236822415470E-03 -0.276706710196E-03 -0.309053833178E-03
+ -0.333642708457E-03 -0.350346283467E-03 -0.359148680748E-03 -0.360162933006E-03
+ -0.353648689166E-03 -0.340029034595E-03 -0.319905269525E-03 -0.294068127068E-03
+ -0.263503478980E-03 -0.229390063877E-03 -0.193086168293E-03 -0.156101483567E-03
+ -0.120049533523E-03 -0.865750976605E-04 -0.572499103413E-04 -0.334285565974E-04
+ -0.160548518774E-04 -0.540701250884E-05 -0.767507034181E-06 -0.529439603270E-09
+ Core charge follows
+  0.546695950979E-10  0.221437665485E-09  0.504534614641E-09  0.908315456186E-09
+  0.143726318873E-08  0.209599225895E-08  0.288925211510E-08  0.382193085338E-08
+  0.489905895944E-08  0.612581314753E-08  0.750752029980E-08  0.904966150831E-08
+  0.107578762224E-07  0.126379665039E-07  0.146959013938E-07  0.169378213916E-07
+  0.193700430524E-07  0.219990637023E-07  0.248315662778E-07  0.278744242898E-07
+  0.311347069173E-07  0.346196842336E-07  0.383368325673E-07  0.422938400034E-07
+  0.464986120271E-07  0.509592773131E-07  0.556841936664E-07  0.606819541164E-07
+  0.659613931686E-07  0.715315932193E-07  0.774018911356E-07  0.835818850063E-07
+  0.900814410672E-07  0.969107008063E-07  0.104080088252E-06  0.111600317451E-06
+  0.119482400137E-06  0.127737653602E-06  0.136377708767E-06  0.145414518464E-06
+  0.154860365928E-06  0.164727873515E-06  0.175030011638E-06  0.185780107939E-06
+  0.196991856693E-06  0.208679328462E-06  0.220856979988E-06  0.233539664348E-06
+  0.246742641369E-06  0.260481588316E-06  0.274772610844E-06  0.289632254242E-06
+  0.305077514966E-06  0.321125852466E-06  0.337795201316E-06  0.355103983660E-06
+  0.373071121978E-06  0.391716052180E-06  0.411058737032E-06  0.431119679936E-06
+  0.451919939059E-06  0.473481141826E-06  0.495825499783E-06  0.518975823850E-06
+  0.542955539956E-06  0.567788705084E-06  0.593500023721E-06  0.620114864736E-06
+  0.647659278689E-06  0.676160015585E-06  0.705644543081E-06  0.736141065167E-06
+  0.767678541317E-06  0.800286706139E-06  0.833996089524E-06  0.868838037319E-06
+  0.904844732517E-06  0.942049217005E-06  0.980485413859E-06  0.102018815022E-05
+  0.106119318073E-05  0.110353721162E-05  0.114725792537E-05  0.119239400600E-05
+  0.123898516503E-05  0.128707216813E-05  0.133669686236E-05  0.138790220422E-05
+  0.144073228834E-05  0.149523237694E-05  0.155144893002E-05  0.160942963635E-05
+  0.166922344521E-05  0.173088059904E-05  0.179445266675E-05  0.185999257809E-05
+  0.192755465873E-05  0.199719466631E-05  0.206896982744E-05  0.214293887558E-05
+  0.221916208990E-05  0.229770133522E-05  0.237862010280E-05  0.246198355237E-05
+  0.254785855507E-05  0.263631373758E-05  0.272741952737E-05  0.282124819903E-05
+  0.291787392190E-05  0.301737280880E-05  0.311982296610E-05  0.322530454500E-05
+  0.333389979417E-05  0.344569311368E-05  0.356077111036E-05  0.367922265451E-05
+  0.380113893815E-05  0.392661353463E-05  0.405574245990E-05  0.418862423522E-05
+  0.432535995155E-05  0.446605333552E-05  0.461081081717E-05  0.475974159931E-05
+  0.491295772873E-05  0.507057416917E-05  0.523270887621E-05  0.539948287401E-05
+  0.557102033402E-05  0.574744865573E-05  0.592889854945E-05  0.611550412117E-05
+  0.630740295965E-05  0.650473622567E-05  0.670764874360E-05  0.691628909523E-05
+  0.713080971608E-05  0.735136699409E-05  0.757812137089E-05  0.781123744557E-05
+  0.805088408114E-05  0.829723451371E-05  0.855046646441E-05  0.881076225421E-05
+  0.907830892161E-05  0.935329834333E-05  0.963592735814E-05  0.992639789375E-05
+  0.102249170970E-04  0.105316974672E-04  0.108469569933E-04  0.111709192940E-04
+  0.115038137615E-04  0.118458757096E-04  0.121973465246E-04  0.125584738205E-04
+  0.129295115984E-04  0.133107204096E-04  0.137023675226E-04  0.141047270951E-04
+  0.145180803497E-04  0.149427157544E-04  0.153789292076E-04  0.158270242279E-04
+  0.162873121483E-04  0.167601123161E-04  0.172457522973E-04  0.177445680859E-04
+  0.182569043200E-04  0.187831145010E-04  0.193235612211E-04  0.198786163941E-04
+  0.204486614939E-04  0.210340877978E-04  0.216352966371E-04  0.222526996529E-04
+  0.228867190593E-04  0.235377879129E-04  0.242063503895E-04  0.248928620668E-04
+  0.255977902158E-04  0.263216140985E-04  0.270648252734E-04  0.278279279089E-04
+  0.286114391050E-04  0.294158892220E-04  0.302418222191E-04  0.310897960002E-04
+  0.319603827696E-04  0.328541693960E-04  0.337717577857E-04  0.347137652663E-04
+  0.356808249786E-04  0.366735862798E-04  0.376927151559E-04  0.387388946456E-04
+  0.398128252739E-04  0.409152254977E-04  0.420468321616E-04  0.432084009665E-04
+  0.444007069494E-04  0.456245449749E-04  0.468807302405E-04  0.481700987934E-04
+  0.494935080616E-04  0.508518373969E-04  0.522459886338E-04  0.536768866602E-04
+  0.551454800051E-04  0.566527414387E-04  0.581996685898E-04  0.597872845775E-04
+  0.614166386598E-04  0.630888068981E-04  0.648048928386E-04  0.665660282114E-04
+  0.683733736470E-04  0.702281194110E-04  0.721314861575E-04  0.740847257015E-04
+  0.760891218111E-04  0.781459910198E-04  0.802566834590E-04  0.824225837120E-04
+  0.846451116897E-04  0.869257235282E-04  0.892659125094E-04  0.916672100050E-04
+  0.941311864439E-04  0.966594523052E-04  0.992536591351E-04  0.101915500591E-03
+  0.104646713509E-03  0.107449079006E-03  0.110324423597E-03  0.113274620356E-03
+  0.116301590092E-03  0.119407302567E-03  0.122593777733E-03  0.125863087014E-03
+  0.129217354606E-03  0.132658758823E-03  0.136189533467E-03  0.139811969239E-03
+  0.143528415183E-03  0.147341280170E-03  0.151253034410E-03  0.155266211017E-03
+  0.159383407603E-03  0.163607287913E-03  0.167940583507E-03  0.172386095481E-03
+  0.176946696230E-03  0.181625331259E-03  0.186425021039E-03  0.191348862910E-03
+  0.196400033030E-03  0.201581788377E-03  0.206897468799E-03  0.212350499117E-03
+  0.217944391284E-03  0.223682746591E-03  0.229569257936E-03  0.235607712151E-03
+  0.241801992382E-03  0.248156080534E-03  0.254674059775E-03  0.261360117108E-03
+  0.268218546003E-03  0.275253749098E-03  0.282470240969E-03  0.289872650968E-03
+  0.297465726137E-03  0.305254334191E-03  0.313243466579E-03  0.321438241624E-03
+  0.329843907738E-03  0.338465846725E-03  0.347309577159E-03  0.356380757858E-03
+  0.365685191436E-03  0.375228827952E-03  0.385017768651E-03  0.395058269789E-03
+  0.405356746576E-03  0.415919777195E-03  0.426754106943E-03  0.437866652461E-03
+  0.449264506083E-03  0.460954940288E-03  0.472945412270E-03  0.485243568616E-03
+  0.497857250111E-03  0.510794496661E-03  0.524063552337E-03  0.537672870554E-03
+  0.551631119377E-03  0.565947186961E-03  0.580630187128E-03  0.595689465090E-03
+  0.611134603311E-03  0.626975427522E-03  0.643222012884E-03  0.659884690312E-03
+  0.676974052955E-03  0.694500962840E-03  0.712476557689E-03  0.730912257902E-03
+  0.749819773725E-03  0.769211112585E-03  0.789098586632E-03  0.809494820449E-03
+  0.830412758977E-03  0.851865675624E-03  0.873867180593E-03  0.896431229411E-03
+  0.919572131680E-03  0.943304560043E-03  0.967643559386E-03  0.992604556264E-03
+  0.101820336857E-02  0.104445621545E-02  0.107137972745E-02  0.109899095698E-02
+  0.112730738895E-02  0.115634695174E-02  0.118612802845E-02  0.121666946839E-02
+  0.124799059890E-02  0.128011123748E-02  0.131305170414E-02  0.134683283418E-02
+  0.138147599122E-02  0.141700308059E-02  0.145343656302E-02  0.149079946871E-02
+  0.152911541178E-02  0.156840860502E-02  0.160870387504E-02  0.165002667785E-02
+  0.169240311476E-02  0.173585994872E-02  0.178042462108E-02  0.182612526876E-02
+  0.187299074185E-02  0.192105062165E-02  0.197033523920E-02  0.202087569426E-02
+  0.207270387473E-02  0.212585247663E-02  0.218035502453E-02  0.223624589252E-02
+  0.229356032571E-02  0.235233446229E-02  0.241260535607E-02  0.247441099972E-02
+  0.253779034847E-02  0.260278334446E-02  0.266943094175E-02  0.273777513187E-02
+  0.280785897012E-02  0.287972660240E-02  0.295342329286E-02  0.302899545216E-02
+  0.310649066646E-02  0.318595772716E-02  0.326744666135E-02  0.335100876310E-02
+  0.343669662547E-02  0.352456417335E-02  0.361466669715E-02  0.370706088728E-02
+  0.380180486962E-02  0.389895824171E-02  0.399858211003E-02  0.410073912808E-02
+  0.420549353554E-02  0.431291119827E-02  0.442305964950E-02  0.453600813187E-02
+  0.465182764070E-02  0.477059096822E-02  0.489237274899E-02  0.501724950642E-02
+  0.514529970051E-02  0.527660377674E-02  0.541124421621E-02  0.554930558707E-02
+  0.569087459721E-02  0.583604014828E-02  0.598489339107E-02  0.613752778232E-02
+  0.629403914291E-02  0.645452571751E-02  0.661908823579E-02  0.678782997511E-02
+  0.696085682482E-02  0.713827735213E-02  0.732020286971E-02  0.750674750491E-02
+  0.769802827078E-02  0.789416513883E-02  0.809528111364E-02  0.830150230935E-02
+  0.851295802802E-02  0.872978084002E-02  0.895210666642E-02  0.918007486339E-02
+  0.941382830881E-02  0.965351349097E-02  0.989928059951E-02  0.101512836187E-01
+  0.104096804230E-01  0.106746328749E-01  0.109463069255E-01  0.112248727173E-01
+  0.115105046899E-01  0.118033816879E-01  0.121036870718E-01  0.124116088316E-01
+  0.127273397034E-01  0.130510772886E-01  0.133830241762E-01  0.137233880683E-01
+  0.140723819086E-01  0.144302240140E-01  0.147971382098E-01  0.151733539678E-01
+  0.155591065484E-01  0.159546371457E-01  0.163601930365E-01  0.167760277330E-01
+  0.172024011395E-01  0.176395797123E-01  0.180878366241E-01  0.185474519328E-01
+  0.190187127535E-01  0.195019134360E-01  0.199973557455E-01  0.205053490485E-01
+  0.210262105032E-01  0.215602652545E-01  0.221078466340E-01  0.226692963644E-01
+  0.232449647697E-01  0.238352109903E-01  0.244404032029E-01  0.250609188466E-01
+  0.256971448544E-01  0.263494778896E-01  0.270183245894E-01  0.277041018130E-01
+  0.284072368970E-01  0.291281679165E-01  0.298673439524E-01  0.306252253659E-01
+  0.314022840790E-01  0.321990038624E-01  0.330158806303E-01  0.338534227420E-01
+  0.347121513115E-01  0.355926005240E-01  0.364953179609E-01  0.374208649314E-01
+  0.383698168140E-01  0.393427634041E-01  0.403403092722E-01  0.413630741288E-01
+  0.424116931999E-01  0.434868176098E-01  0.445891147747E-01  0.457192688049E-01
+  0.468779809165E-01  0.480659698540E-01  0.492839723217E-01  0.505327434263E-01
+  0.518130571300E-01  0.531257067142E-01  0.544715052540E-01  0.558512861048E-01
+  0.572659033994E-01  0.587162325577E-01  0.602031708080E-01  0.617276377209E-01
+  0.632905757556E-01  0.648929508188E-01  0.665357528372E-01  0.682199963433E-01
+  0.699467210746E-01  0.717169925866E-01  0.735319028811E-01  0.753925710476E-01
+  0.773001439208E-01  0.792557967524E-01  0.812607338989E-01  0.833161895250E-01
+  0.854234283229E-01  0.875837462483E-01  0.897984712733E-01  0.920689641557E-01
+  0.943966192262E-01  0.967828651935E-01  0.992291659670E-01  0.101737021498
+  0.104307968641      0.106943582030      0.109645474980      0.112415300405
+  0.115254751755      0.118165563977      0.121149514492      0.124208424200
+  0.127344158501      0.130558628338      0.133853791266      0.137231652540
+  0.140694266230      0.144243736354      0.147882218037      0.151611918698
+  0.155435099255      0.159354075357      0.163371218644      0.167488958028
+  0.171709781000      0.176036234969      0.180470928616      0.185016533287
+  0.189675784403      0.194451482902      0.199346496708      0.204363762225
+  0.209506285861      0.214777145578      0.220179492475      0.225716552390
+  0.231391627539      0.237208098179      0.243169424304      0.249279147358
+  0.255540891995      0.261958367849      0.268535371343      0.275275787527
+  0.282183591934      0.289262852479      0.296517731371      0.303952487063
+  0.311571476222      0.319379155729      0.327380084707      0.335578926570
+  0.343980451096      0.352589536533      0.361411171719      0.370450458225
+  0.379712612527      0.389202968191      0.398926978079      0.408890216576
+  0.419098381828      0.429557297999      0.440272917539      0.451251323465
+  0.462498731651      0.474021493120      0.485826096353      0.497919169585
+  0.510307483113      0.522997951593      0.535997636334      0.549313747585
+  0.562953646801      0.576924848898      0.591235024485      0.605892002072
+  0.620903770244      0.636278479802      0.652024445868      0.668150149934
+  0.684664241868      0.701575541858      0.718893042291      0.736625909559
+  0.754783485787      0.773375290472      0.792411022025      0.811900559209
+  0.831853962460      0.852281475085      0.873193524321      0.894600722250
+  0.916513866553      0.938943941092      0.961902116306      0.985399749411
+   1.00944838438       1.03405975170       1.05924576788       1.08501853469
+   1.11139033811       1.13837364702       1.16598111152       1.19422556090
+   1.22312000131       1.25267761298       1.28291174705       1.31383592193
+   1.34546381924       1.37780927924       1.41088629568       1.44470901019
+   1.47929170597       1.51464880094       1.55079484019       1.58774448771
+   1.62551251743       1.66411380342       1.70356330931       1.74387607683
+   1.78506721338       1.82715187870       1.87014527049       1.91406260890
+   1.95891912002       2.00473001800       2.05151048609       2.09927565621
+   2.14804058725       2.19782024184       2.24862946164       2.30048294099
+   2.35339519890       2.40738054926       2.46245306923       2.51862656565
+   2.57591453948       2.63433014808       2.69388616529       2.75459493914
+   2.81646834727       2.87951774964       2.94375393879       3.00918708717
+   3.07582669172       3.14368151544       3.21275952576       3.28306782981
+   3.35461260617       3.42739903320       3.50143121374       3.57671209595
+   3.65324339027       3.73102548234       3.81005734167       3.89033642590
+   3.97185858066       4.05461793466       4.13860679000       4.22381550756
+   4.31023238712       4.39784354241       4.48663277055       4.57658141601
+   4.66766822886       4.75986921706       4.85315749290       4.94750311315
+   5.04287291306       5.13923033391       5.23653524416       5.33474375393
+   5.43380802285       5.53367606114       5.63429152398       5.73559349891
+   5.83751628651       5.93998917411       6.04293620280       6.14627592758
+   6.24992117090       6.35377876963       6.45774931563       6.56172689014
+   6.66559879223       6.76924526159       6.87253919603       6.97534586409
+   7.07752261320       7.17891857395       7.27937436117       7.37872177229
+   7.47678348405       7.57337274815       7.66829308703       7.76133799078
+   7.85229061633       7.94092349031       8.02852313948       8.11602626857
+   8.20268672712       8.28777931073       8.37060259283       8.45048159645
+   8.52677029330       8.59885391874       8.66615109230       8.72811573496
+   8.78423877567       8.83404964087       8.87711752261       8.91305242196
+   8.94150596613       8.96217199927       8.97478694802       8.97912996482
+   8.97502285290       8.96232977856       8.94095677742       8.91085106242
+   8.87200014272       8.82443076340       8.76820767675       8.70343225692
+   8.63024097019       8.54880371374       8.45932203626       8.36202725402
+   8.25717847635       8.14506055450       8.02598196779       7.90027266111
+   7.76828184733       7.63037578816       7.48693556639       7.33835486238
+   7.18503774654       7.02739649974       6.86584947223       6.70081899153
+   6.53272932874       6.36200473210       6.18906753571       6.01433635092
+   5.83822434653       5.66113762379       5.48347369074       5.30562004118
+   5.12795285474       4.95083566541       4.77461867672       4.59963704522
+   4.42621078125       4.25464326246       4.08522098225       3.91821323651
+   3.75387136188       3.59242863672       3.43409996982       3.27908181304
+   3.12755213470       2.97967049144       2.83557818614       2.69539850795
+   2.55923704997       2.42718209811       2.29930508689       2.17566111603
+   2.05628952233       1.94121450088       1.83044577015       1.72397927481
+   1.62179792087       1.52387233713       1.43016165758       1.34061431915
+   1.25516886952       1.17375477984       1.09629325742       1.02269805370
+  0.952876263031      0.886729108098      0.824152708114      0.765038826180
+  0.709275592608      0.656748201258      0.607339576356      0.560931007547
+  0.517402751341      0.476634597422      0.438506398651      0.402898563937
+  0.369692513457      0.338771096026      0.310018968721      0.283322939111
+  0.258572270722      0.235658952579      0.214477933880      0.194927325024
+  0.176908566376      0.160326566293      0.145089810009      0.131110441087
+  0.118304317192      0.106591041981      0.958939749173E-01  0.861402208412E-01
+  0.772606010824E-01  0.691896079070E-01  0.618653440295E-01  0.552294488811E-01
+  0.492270132662E-01  0.438064839713E-01  0.389195598215E-01  0.345210806020E-01
+  0.305689101808E-01  0.270238150896E-01  0.238493397301E-01  0.210116792918E-01
+  0.184795513802E-01  0.162240672671E-01  0.142186035948E-01  0.124386752792E-01
+  0.108618102802E-01  0.946742682641E-02  0.823671361053E-02  0.715251339601E-02
+  0.619921041017E-02  0.536262183329E-02  0.462989363293E-02  0.398940093599E-02
+  0.343065307846E-02  0.294420342440E-02  0.252156400138E-02  0.215512495953E-02
+  0.183807882495E-02  0.156434948639E-02  0.132852582568E-02  0.112579987786E-02
+  0.951909385903E-03  0.803084597567E-03  0.675999137296E-03  0.567724774918E-03
+  0.475689904234E-03  0.397641538637E-03  0.331610627292E-03  0.275880493881E-03
+  0.228958200355E-03  0.189548640241E-03  0.156531169619E-03  0.128938588751E-03
+  0.105938293272E-03  0.868154206545E-04  0.709578252001E-04  0.578427228704E-04
+  0.470248557478E-04  0.381260346458E-04  0.308259272554E-04  0.248539681094E-04
+  0.199822754665E-04  0.160194688897E-04  0.128052897332E-04  0.102059349115E-04
+  0.811002214368E-05  0.642511232217E-05  0.507472170092E-05  0.399576323297E-05
+  0.313636258453E-05  0.245400011716E-05  0.191393545798E-05  0.148787617834E-05
+  0.115285658513E-05  0.890296709974E-06  0.685215278526E-06  0.525573773873E-06
+  0.401731697141E-06  0.305995796457E-06  0.232248406297E-06  0.175642135836E-06
+  0.132349990445E-06  0.993616274172E-07  0.743178571616E-07  0.553767252035E-07
+  0.411055680402E-07  0.303943456092E-07  0.223863319348E-07  0.164229091665E-07
+  0.119997731155E-07  0.873233361032E-08  0.632849230189E-08  0.456731450601E-08
+  0.328238965245E-08  0.234890519890E-08  0.167364873640E-08  0.118730880476E-08
+  0.838572148036E-09  0.589618511077E-09  0.412697663118E-09  0.287540588395E-09
+  0.199410627734E-09  0.137643247250E-09  0.945571057183E-10  0.646458990535E-10
+  0.439814902993E-10  0.297752461327E-10  0.200572431031E-10  0.134428474016E-10
+  0.896373131164E-11  0.594616535093E-11  0.392381441882E-11  0.257558368063E-11
+  0.168155341554E-11  0.109190585116E-11  0.705132318370E-12  0.452832900596E-12
+  0.289173117421E-12  0.183611869068E-12  0.115914136639E-12  0.727502394551E-13
+  0.453903973745E-13  0.281510017775E-13  0.173537131773E-13  0.106323103501E-13
+  0.647391676927E-14  0.391722004690E-14  0.235519540978E-14  0.140695545676E-14
+  0.835033776565E-15  0.492338113745E-15  0.288352401212E-15  0.167744741023E-15
+  0.969177998962E-16  0.556097664665E-16  0.316850657470E-16  0.179257286035E-16
+  0.100688493702E-16  0.561468454273E-17  0.310795366597E-17  0.170760741170E-17
+  0.931163615758E-18  0.503904305053E-18  0.270591002071E-18  0.144171833457E-18
+  0.762091854328E-19  0.399623980363E-19  0.207859573465E-19  0.107230709835E-19
+  0.548598752397E-20  0.278312167913E-20  0.139992896837E-20  0.698120412234E-21
+  0.345110933124E-21  0.169100178951E-21  0.821180649939E-22  0.395179453261E-22
+  0.188435237977E-22  0.890210044852E-23  0.416615412993E-23  0.193125618037E-23
+  0.886655179883E-24  0.403114021310E-24  0.181470757265E-24  0.808793524153E-25
+  0.356834598923E-25  0.155825983768E-25  0.673443412394E-26  0.288001442883E-26
+  0.121860758150E-26  0.510095390029E-27  0.211202570297E-27  0.864865461095E-28
+  0.350219273938E-28  0.140221158346E-28  0.555019515779E-29  0.217151396792E-29
+  0.839681204688E-30  0.320849020757E-30  0.121131701770E-30  0.451774119562E-31
+  0.166427925822E-31  0.605489403399E-32  0.217518316919E-32  0.771483751630E-33
+  0.270104233628E-33  0.933342252462E-34  0.318262840057E-34  0.107077009112E-34
+  0.355386491999E-35  0.116339813243E-35  0.375583258170E-36  0.119553266239E-36
+  0.375163219134E-37  0.116040120908E-37  0.353712188578E-38  0.106235567234E-38
+  0.314334002195E-39  0.916087701720E-40  0.262923320764E-40  0.743000262606E-41
+  0.206698544438E-41  0.565971572559E-42  0.152503602216E-42  0.404308433302E-43
+  0.105441373225E-43  0.270453515412E-44  0.682141936066E-45  0.169150814706E-45
+  0.412293832736E-46  0.987617259319E-47  0.232452818826E-47  0.537477226204E-48
+  0.122061528767E-48  0.272210602426E-49  0.596008458111E-50  0.128095629526E-50
+  0.270186581401E-51  0.559182596221E-52  0.113531545957E-52  0.226081466723E-53
+  0.441480197301E-54  0.845215837452E-55  0.158615785194E-55  0.291715721150E-56
+  0.525678546226E-57  0.927983215778E-58  0.160447175159E-58  0.271649544842E-59
+  0.450281386604E-60  0.730584771286E-61  0.116006614004E-61  0.180233193499E-62
+  0.273931266696E-63  0.407210287468E-64  0.591946361284E-65  0.841297021329E-66
+  0.116879254700E-66  0.158695706914E-67  0.210548476964E-68  0.272909557894E-69
+  0.345530768596E-70  0.427246812065E-71  0.515844831074E-72  0.608040936172E-73
+  0.699595106809E-74  0.785577625299E-75  0.860774864629E-76  0.920194273460E-77
+  0.959603885974E-78  0.976026945771E-79  0.968112035292E-80  0.936315086972E-81
+  0.882859518582E-82  0.811478528933E-83  0.726981114568E-84  0.634712333826E-85
+  0.539992600062E-86  0.447617921705E-87  0.361484838941E-88  0.284375625389E-89
+  0.217908216407E-90  0.162628164175E-91  0.118201647655E-92  0.836612654777E-94
+  0.576592313778E-95  0.386927975540E-96  0.252804407111E-97  0.160809548604E-98
+  0.995850907991-100  0.600368585693-101  0.352348062500-102  0.201302248033-103
+  0.111955163544-104  0.606118957733-106  0.319442643982-107  0.163891300169-108
+  0.818572797919-110  0.398025870852-111  0.188423852760-112  0.868466133982-114
+  0.389751707035-115  0.170322045424-116  0.724827853992-118  0.300412172919-119
+  0.121271984371-120  0.476880905353-122  0.182690960486-123  0.681928158552-125
+  0.248049053886-126  0.879394113357-128  0.303915734177-129  0.102407090529-130
+  0.336514803241-132  0.107862758475-133  0.337312857600-135  0.102942136927-136
+  0.306662534735-138  0.891963639338-140  0.253377312857-141  0.703140363662-143
+  0.190674850600-144  0.505416063002-146  0.131016902430-147  0.332674069830-149
+  0.822118747447-151  0.173466043095-152  0.140278769909-154  0.106777286059-156
+  0.764441407190-159  0.514342832813-161
+ Valence charge follows
+  0.405627165146E-13  0.164298148444E-12  0.374345090893E-12  0.673934794852E-12
+  0.106639347121E-11  0.155514486022E-11  0.214371286808E-11  0.283572427236E-11
+  0.363491149811E-11  0.454511546630E-11  0.557028851668E-11  0.671449740676E-11
+  0.798192638900E-11  0.937688036812E-11  0.109037881407E-10  0.125672057192E-10
+  0.143718197421E-10  0.163224509733E-10  0.184240578923E-10  0.206817403774E-10
+  0.231007434852E-10  0.256864613279E-10  0.284444410511E-10  0.313803869157E-10
+  0.345001644849E-10  0.378098049201E-10  0.413155093884E-10  0.450236535841E-10
+  0.489407923678E-10  0.530736645252E-10  0.574291976495E-10  0.620145131505E-10
+  0.668369313927E-10  0.719039769669E-10  0.772233840981E-10  0.828031021933E-10
+  0.886513015327E-10  0.947763791081E-10  0.101186964612E-09  0.107891926582E-09
+  0.114900378704E-09  0.122221686276E-09  0.129865472843E-09  0.137841626999E-09
+  0.146160309365E-09  0.154831959754E-09  0.163867304507E-09  0.173277364035E-09
+  0.183073460539E-09  0.193267225940E-09  0.203870610013E-09  0.214895888722E-09
+  0.226355672781E-09  0.238262916426E-09  0.250630926417E-09  0.263473371273E-09
+  0.276804290743E-09  0.290638105522E-09  0.304989627210E-09  0.319874068540E-09
+  0.335307053859E-09  0.351304629881E-09  0.367883276716E-09  0.385059919187E-09
+  0.402851938429E-09  0.421277183795E-09  0.440353985063E-09  0.460101164956E-09
+  0.480538051985E-09  0.501684493624E-09  0.523560869817E-09  0.546188106837E-09
+  0.569587691501E-09  0.593781685743E-09  0.618792741569E-09  0.644644116392E-09
+  0.671359688757E-09  0.698963974473E-09  0.727482143161E-09  0.756940035219E-09
+  0.787364179229E-09  0.818781809801E-09  0.851220885886E-09  0.884710109548E-09
+  0.919278945220E-09  0.954957639457E-09  0.991777241186E-09  0.102976962249E-08
+  0.106896749988E-08  0.110940445622E-08  0.115111496304E-08  0.119413440358E-08
+  0.123849909637E-08  0.128424631935E-08  0.133141433471E-08  0.138004241430E-08
+  0.143017086571E-08  0.148184105898E-08  0.153509545409E-08  0.158997762903E-08
+  0.164653230866E-08  0.170480539433E-08  0.176484399416E-08  0.182669645419E-08
+  0.189041239029E-08  0.195604272087E-08  0.202363970044E-08  0.209325695403E-08
+  0.216494951248E-08  0.223877384867E-08  0.231478791456E-08  0.239305117935E-08
+  0.247362466847E-08  0.255657100359E-08  0.264195444375E-08  0.272984092739E-08
+  0.282029811558E-08  0.291339543626E-08  0.300920412969E-08  0.310779729498E-08
+  0.320924993786E-08  0.331363901965E-08  0.342104350750E-08  0.353154442585E-08
+  0.364522490927E-08  0.376217025664E-08  0.388246798664E-08  0.400620789476E-08
+  0.413348211165E-08  0.426438516308E-08  0.439901403130E-08  0.453746821808E-08
+  0.467984980926E-08  0.482626354102E-08  0.497681686776E-08  0.513162003182E-08
+  0.529078613483E-08  0.545443121103E-08  0.562267430231E-08  0.579563753530E-08
+  0.597344620031E-08  0.615622883235E-08  0.634411729418E-08  0.653724686148E-08
+  0.673575631017E-08  0.693978800603E-08  0.714948799648E-08  0.736500610479E-08
+  0.758649602665E-08  0.781411542920E-08  0.804802605258E-08  0.828839381410E-08
+  0.853538891495E-08  0.878918594978E-08  0.904996401895E-08  0.931790684366E-08
+  0.959320288406E-08  0.987604546028E-08  0.101666328766E-07  0.104651685489E-07
+  0.107718611348E-07  0.110869246680E-07  0.114105786953E-07  0.117430484175E-07
+  0.120845648335E-07  0.124353648886E-07  0.127956916258E-07  0.131657943423E-07
+  0.135459287481E-07  0.139363571302E-07  0.143373485203E-07  0.147491788669E-07
+  0.151721312115E-07  0.156064958698E-07  0.160525706171E-07  0.165106608786E-07
+  0.169810799243E-07  0.174641490690E-07  0.179601978778E-07  0.184695643759E-07
+  0.189925952646E-07  0.195296461422E-07  0.200810817310E-07  0.206472761094E-07
+  0.212286129508E-07  0.218254857679E-07  0.224382981630E-07  0.230674640856E-07
+  0.237134080957E-07  0.243765656340E-07  0.250573832991E-07  0.257563191319E-07
+  0.264738429064E-07  0.272104364291E-07  0.279665938449E-07  0.287428219516E-07
+  0.295396405217E-07  0.303575826328E-07  0.311971950063E-07  0.320590383550E-07
+  0.329436877383E-07  0.338517329284E-07  0.347837787838E-07  0.357404456339E-07
+  0.367223696721E-07  0.377302033597E-07  0.387646158398E-07  0.398262933616E-07
+  0.409159397153E-07  0.420342766790E-07  0.431820444753E-07  0.443600022413E-07
+  0.455689285089E-07  0.468096216985E-07  0.480829006246E-07  0.493896050143E-07
+  0.507305960391E-07  0.521067568603E-07  0.535189931877E-07  0.549682338534E-07
+  0.564554313988E-07  0.579815626780E-07  0.595476294757E-07  0.611546591404E-07
+  0.628037052347E-07  0.644958482011E-07  0.662321960454E-07  0.680138850371E-07
+  0.698420804277E-07  0.717179771867E-07  0.736428007573E-07  0.756178078304E-07
+  0.776442871386E-07  0.797235602700E-07  0.818569825032E-07  0.840459436630E-07
+  0.862918689981E-07  0.885962200807E-07  0.909604957293E-07  0.933862329550E-07
+  0.958750079308E-07  0.984284369871E-07  0.101048177631E-06  0.103735929592E-06
+  0.106493435896E-06  0.109322483960E-06  0.112224906725E-06  0.115202583810E-06
+  0.118257442694E-06  0.121391459937E-06  0.124606662421E-06  0.127905128631E-06
+  0.131288989962E-06  0.134760432066E-06  0.138321696227E-06  0.141975080773E-06
+  0.145722942526E-06  0.149567698284E-06  0.153511826348E-06  0.157557868076E-06
+  0.161708429491E-06  0.165966182919E-06  0.170333868670E-06  0.174814296767E-06
+  0.179410348712E-06  0.184124979304E-06  0.188961218496E-06  0.193922173303E-06
+  0.199011029757E-06  0.204231054915E-06  0.209585598911E-06  0.215078097069E-06
+  0.220712072060E-06  0.226491136122E-06  0.232418993329E-06  0.238499441927E-06
+  0.244736376717E-06  0.251133791510E-06  0.257695781635E-06  0.264426546520E-06
+  0.271330392328E-06  0.278411734666E-06  0.285675101368E-06  0.293125135331E-06
+  0.300766597446E-06  0.308604369584E-06  0.316643457668E-06  0.324888994819E-06
+  0.333346244586E-06  0.342020604252E-06  0.350917608227E-06  0.360042931530E-06
+  0.369402393353E-06  0.379001960719E-06  0.388847752234E-06  0.398946041933E-06
+  0.409303263221E-06  0.419926012917E-06  0.430821055403E-06  0.441995326869E-06
+  0.453455939679E-06  0.465210186836E-06  0.477265546565E-06  0.489629687015E-06
+  0.502310471078E-06  0.515315961326E-06  0.528654425081E-06  0.542334339612E-06
+  0.556364397455E-06  0.570753511885E-06  0.585510822510E-06  0.600645701015E-06
+  0.616167757057E-06  0.632086844299E-06  0.648413066603E-06  0.665156784382E-06
+  0.682328621112E-06  0.699939470005E-06  0.718000500861E-06  0.736523167086E-06
+  0.755519212889E-06  0.775000680672E-06  0.794979918595E-06  0.815469588341E-06
+  0.836482673077E-06  0.858032485618E-06  0.880132676799E-06  0.902797244059E-06
+  0.926040540248E-06  0.949877282652E-06  0.974322562252E-06  0.999391853222E-06
+  0.102510102266E-05  0.105146634059E-05  0.107850449017E-05  0.110623257823E-05
+  0.113466814603E-05  0.116382918030E-05  0.119373412456E-05  0.122440189077E-05
+  0.125585187122E-05  0.128810395077E-05  0.132117851936E-05  0.135509648488E-05
+  0.138987928637E-05  0.142554890753E-05  0.146212789059E-05  0.149963935054E-05
+  0.153810698974E-05  0.157755511287E-05  0.161800864230E-05  0.165949313385E-05
+  0.170203479293E-05  0.174566049113E-05  0.179039778322E-05  0.183627492461E-05
+  0.188332088925E-05  0.193156538795E-05  0.198103888729E-05  0.203177262888E-05
+  0.208379864927E-05  0.213714980022E-05  0.219185976964E-05  0.224796310300E-05
+  0.230549522533E-05  0.236449246376E-05  0.242499207070E-05  0.248703224763E-05
+  0.255065216947E-05  0.261589200960E-05  0.268279296564E-05  0.275139728575E-05
+  0.282174829578E-05  0.289389042706E-05  0.296786924496E-05  0.304373147819E-05
+  0.312152504894E-05  0.320129910377E-05  0.328310404539E-05  0.336699156525E-05
+  0.345301467705E-05  0.354122775116E-05  0.363168654998E-05  0.372444826424E-05
+  0.381957155038E-05  0.391711656884E-05  0.401714502358E-05  0.411972020252E-05
+  0.422490701927E-05  0.433277205593E-05  0.444338360716E-05  0.455681172546E-05
+  0.467312826781E-05  0.479240694357E-05  0.491472336380E-05  0.504015509205E-05
+  0.516878169657E-05  0.530068480408E-05  0.543594815517E-05  0.557465766129E-05
+  0.571690146348E-05  0.586276999290E-05  0.601235603314E-05  0.616575478453E-05
+  0.632306393031E-05  0.648438370503E-05  0.664981696494E-05  0.681946926070E-05
+  0.699344891242E-05  0.717186708706E-05  0.735483787844E-05  0.754247838977E-05
+  0.773490881903E-05  0.793225254714E-05  0.813463622917E-05  0.834218988862E-05
+  0.855504701503E-05  0.877334466492E-05  0.899722356642E-05  0.922682822752E-05
+  0.946230704835E-05  0.970381243751E-05  0.995150093271E-05  0.102055333260E-04
+  0.104660747938E-04  0.107332950316E-04  0.110073683946E-04  0.112884740431E-04
+  0.115767960942E-04  0.118725237796E-04  0.121758516099E-04  0.124869795454E-04
+  0.128061131746E-04  0.131334638999E-04  0.134692491317E-04  0.138136924908E-04
+  0.141670240196E-04  0.145294804036E-04  0.149013052019E-04  0.152827490895E-04
+  0.156740701100E-04  0.160755339410E-04  0.164874141721E-04  0.169099925960E-04
+  0.173435595148E-04  0.177884140610E-04  0.182448645350E-04  0.187132287600E-04
+  0.191938344552E-04  0.196870196286E-04  0.201931329910E-04  0.207125343919E-04
+  0.212455952792E-04  0.217926991847E-04  0.223542422362E-04  0.229306336985E-04
+  0.235222965450E-04  0.241296680629E-04  0.247532004929E-04  0.253933617064E-04
+  0.260506359234E-04  0.267255244728E-04  0.274185465989E-04  0.281302403168E-04
+  0.288611633205E-04  0.296118939473E-04  0.303830322022E-04  0.311752008470E-04
+  0.319890465585E-04  0.328252411603E-04  0.336844829346E-04  0.345674980182E-04
+  0.354750418901E-04  0.364079009567E-04  0.373668942414E-04  0.383528751865E-04
+  0.393667335760E-04  0.404093975872E-04  0.414818359806E-04  0.425850604389E-04
+  0.437201280655E-04  0.448881440539E-04  0.460902645411E-04  0.473276996581E-04
+  0.486017167924E-04  0.499136440768E-04  0.512648741237E-04  0.526568680199E-04
+  0.540911596037E-04  0.555693600432E-04  0.570931627397E-04  0.586643485786E-04
+  0.602847915550E-04  0.619564648005E-04  0.636814470414E-04  0.654619295204E-04
+  0.673002234157E-04  0.691987677945E-04  0.711601381407E-04  0.731870554985E-04
+  0.752823962789E-04  0.774492027761E-04  0.796906944490E-04  0.820102800219E-04
+  0.844115704664E-04  0.868983929293E-04  0.894748056765E-04  0.921451141280E-04
+  0.949138880642E-04  0.977859800903E-04  0.100766545452E-03  0.103861063299E-03
+  0.107075359513E-03  0.110415631197E-03  0.113888472966E-03  0.117500905164E-03
+  0.121260404149E-03  0.125174934792E-03  0.129252985367E-03  0.133503604990E-03
+  0.137936443805E-03  0.142561796111E-03  0.147390646648E-03  0.152434720271E-03
+  0.157706535255E-03  0.163219460500E-03  0.168987776913E-03  0.175026743273E-03
+  0.181352666902E-03  0.187982979485E-03  0.194936318411E-03  0.202232614037E-03
+  0.209893183290E-03  0.217940830064E-03  0.226399952897E-03  0.235296660450E-03
+  0.244658895329E-03  0.254516566861E-03  0.264901693431E-03  0.275848555080E-03
+  0.287393857065E-03  0.299576905155E-03  0.312439793488E-03  0.326027605856E-03
+  0.340388631352E-03  0.355574595375E-03  0.371640907052E-03  0.388646924192E-03
+  0.406656236998E-03  0.425736971782E-03  0.445962116074E-03  0.467409866542E-03
+  0.490164001282E-03  0.514314278096E-03  0.539956860497E-03  0.567194773280E-03
+  0.596138389612E-03  0.626905951709E-03  0.659624127298E-03  0.694428604180E-03
+  0.731464725366E-03  0.770888167373E-03  0.812865664444E-03  0.857575781594E-03
+  0.905209739543E-03  0.955972294788E-03  0.101008267821E-02  0.106777559582E-02
+  0.112930229541E-02  0.119493170313E-02  0.126495163408E-02  0.133967008138E-02
+  0.141941658826E-02  0.150454370803E-02  0.159542855685E-02  0.169247446467E-02
+  0.179611272969E-02  0.190680448219E-02  0.202504266345E-02  0.215135412605E-02
+  0.228630186193E-02  0.243048736462E-02  0.258455313262E-02  0.274918532080E-02
+  0.292511654699E-02  0.311312886118E-02  0.331405688469E-02  0.352879112705E-02
+  0.375828148820E-02  0.400354095388E-02  0.426564949197E-02  0.454575815753E-02
+  0.484509341447E-02  0.516496168121E-02  0.550675410798E-02  0.587195159281E-02
+  0.626213004318E-02  0.667896588963E-02  0.712424185732E-02  0.759985300078E-02
+  0.810781300630E-02  0.865026076563E-02  0.922946722348E-02  0.984784250015E-02
+  0.105079432893E-01  0.112124805288E-01  0.119643273423E-01  0.127665272439E-01
+  0.136223026007E-01  0.145350633407E-01  0.155084158936E-01  0.165461723487E-01
+  0.176523598084E-01  0.188312299156E-01  0.200872685244E-01  0.214252054846E-01
+  0.228500244989E-01  0.243669730126E-01  0.259815720850E-01  0.276996261875E-01
+  0.295272328668E-01  0.314707922020E-01  0.335370159800E-01  0.357329365027E-01
+  0.380659149303E-01  0.405436490598E-01  0.431741804217E-01  0.459659005747E-01
+  0.489275564612E-01  0.520682546811E-01  0.553974645268E-01  0.589250196111E-01
+  0.626611179116E-01  0.666163200381E-01  0.708015455249E-01  0.752280669320E-01
+  0.799075015350E-01  0.848518003678E-01  0.900732343784E-01  0.955843774444E-01
+  0.101398085993      0.107527474965      0.113985889847      0.120786874525
+  0.127944134670      0.135471496419      0.143382860078      0.151692148625
+  0.160413250778      0.169559958431      0.179145898279      0.189184457484
+  0.199688703290      0.210671296506      0.222144398860      0.234119574273
+  0.246607684153      0.259618776923      0.273161972024      0.287245338781
+  0.301875770564      0.317058854828      0.332798739681      0.349097997795
+  0.365957488545      0.383376219434      0.401351207965      0.419877345250
+  0.438947262785      0.458551203949      0.478676901881      0.499309465529
+  0.520431275745      0.542021893388      0.564057981467      0.586513243401
+  0.609358379483      0.632561063630      0.656085942455      0.679894658633
+  0.703945900374      0.728195478712      0.752596434062      0.777099173288
+  0.801651638203      0.826199506099      0.850686422517      0.875054266040
+  0.899243444436      0.923193220986      0.946842069307      0.970128054451
+  0.992989237528       1.01536410054       1.03719198762       1.05841355829
+   1.07897124805       1.09880973104       1.11787637917       1.13612171209
+   1.15349983179       1.16996883595       1.18549120381       1.20003414888
+   1.21356993247       1.22607613315       1.23753586696       1.24793795433
+   1.25727703002       1.26555359339       1.27277399692       1.27895037193
+   1.28410049136       1.28824757038       1.29142000638       1.29365106113
+   1.29497848836       1.29544411098       1.29509335287       1.29397473069
+   1.29213931161       1.28964014338       1.28653166343       1.28286909368
+   1.27870782811       1.27410282020       1.26910797707       1.26377556759
+   1.25815565148       1.25229553667       1.24623927239       1.24002718566
+   1.23369546958       1.22727583189       1.22079521366       1.21427558803
+   1.20773385035       1.20118181116       1.19462630451       1.18806942341
+   1.18150889420       1.17493859906       1.16834925343       1.16172923957
+   1.15506559039       1.14834510767       1.14155558533       1.13468709161
+   1.12773324308       1.12069237768       1.11356850426       1.10637187052
+   1.09911895045       1.09183160496       1.08453520993       1.07725625604
+   1.07002124544       1.06285708304       1.05579061819       1.04884862429
+   1.04205768069       1.03544403150       1.02903343921       1.02285102026
+   1.01692106555       1.01126684515       1.00591039726       1.00087230146
+  0.996171437250      0.991824728822      0.987846878249      0.984250089358
+  0.981043785810      0.978234327588      0.975824731079      0.973814398985
+  0.972198867270      0.970969577424      0.970113683237      0.969613902110
+  0.969448421580      0.969590872044      0.970010376644      0.970671688786
+  0.971535426612      0.972558412027      0.973694119229      0.974893234340
+  0.976104323278      0.977274599731      0.978350778738      0.979279994125
+  0.980010749878      0.980493866508      0.980683373769      0.980537290612
+  0.980018222222      0.979093692176      0.977736115124      0.975922301645
+  0.973632422154      0.970848743062      0.967555126285      0.963737351471
+  0.959382963719      0.954481372703      0.949023893467      0.943003774170
+  0.936416221187      0.929258414282      0.921529513893      0.913230660219
+  0.904364964074      0.894937489507      0.884955228268      0.874427065895
+  0.863363741713      0.851777793206      0.839683516598      0.827096871297
+  0.814035460805      0.800518499085      0.786566670107      0.772201901403
+  0.757447413406      0.742327551221      0.726867717141      0.711094260446
+  0.695034371165      0.678715968736      0.662167587912      0.645418262640
+  0.628497408677      0.611434705631      0.594259979123      0.577003083704
+  0.559693787136      0.542361656643      0.525035947680      0.507745495772
+  0.490518611927      0.473382982114      0.456365571269      0.439492532239
+  0.422789120078      0.406279612048      0.389987233616      0.373934090833
+  0.358141109225      0.342627979480      0.327413110085      0.312513587027
+  0.297945140663      0.283722119785      0.269857472894      0.256362736627
+  0.243248031265      0.230522063186      0.218192134102      0.206264156867
+  0.194742677620      0.183630903980      0.172930738973      0.162642820360
+  0.152766564972      0.143300217676      0.134240904533      0.125584689708
+  0.117326635691      0.109460866338      0.101980632273      0.948783781607E-01
+  0.881458113753E-01  0.817739715815E-01  0.757533007619E-01  0.700737132309E-01
+  0.647246651914E-01  0.596952234076E-01  0.549741325905E-01  0.505498811162E-01
+  0.464107647234E-01  0.425449478672E-01  0.389405224365E-01  0.355855635756E-01
+  0.324681823861E-01  0.295765753160E-01  0.268990700847E-01  0.244241680210E-01
+  0.221405827323E-01  0.200372750528E-01  0.181034842548E-01  0.163287555377E-01
+  0.147029638396E-01  0.132163340438E-01  0.118594576798E-01  0.106233062412E-01
+  0.949924126250E-02  0.847902131835E-02  0.755480611993E-02  0.671915790013E-02
+  0.596504028640E-02  0.528581486855E-02  0.467523567336E-02  0.412744175991E-02
+  0.363694814937E-02  0.319863530055E-02  0.280773733829E-02  0.245982923507E-02
+  0.215081313887E-02  0.187690403070E-02  0.163461488491E-02  0.142074149410E-02
+  0.123234710822E-02  0.106674702495E-02  0.921493255497E-03  0.794359376898E-03
+  0.683325668956E-03  0.586564621110E-03  0.502426882153E-03  0.429427713722E-03
+  0.366233997110E-03  0.311651832230E-03  0.264614757569E-03  0.224172610750E-03
+  0.189481040936E-03  0.159791676732E-03  0.134442946530E-03  0.112851542319E-03
+  0.945045129122E-04  0.789519682191E-04  0.658003726244E-04  0.547064026674E-04
+  0.453713419854E-04  0.375359848671E-04  0.309760186733E-04  0.254978547867E-04
+  0.209348775835E-04  0.171440811260E-04  0.140030638038E-04  0.114073519452E-04
+  0.926802444390E-05  0.750961163663E-05  0.606824300079E-05  0.489001966856E-05
+  0.392958924672E-05  0.314890195849E-05  0.251612865968E-05  0.200472280415E-05
+  0.159260992440E-05  0.126148963689E-05  0.996236566743E-06  0.784387902486E-06
+  0.615706533354E-06  0.481809882905E-06  0.375855632630E-06  0.292276525673E-06
+  0.226557355056E-06  0.175048074372E-06  0.134807724598E-06  0.103474551863E-06
+  0.791583018285E-07  0.603512210442E-07  0.458547789993E-07  0.347195512804E-07
+  0.261960790975E-07  0.196948481136E-07  0.147538145875E-07  0.110121536699E-07
+  0.818911740633E-08  0.606707245515E-08  0.447794330150E-08  0.329241913013E-08
+  0.241139450276E-08  0.175920827832E-08  0.127832424744E-08  0.925162891524E-09
+  0.666848437992E-09  0.478680652991E-09  0.342178063068E-09  0.243569807358E-09
+  0.172638194836E-09  0.121834224292E-09  0.856046253259E-10  0.598820815897E-10
+  0.417007800887E-10  0.289077765212E-10  0.199472799188E-10  0.137001745981E-10
+  0.936518937205E-11  0.637131904321E-11  0.431358561673E-11  0.290614572895E-11
+  0.194822685911E-11  0.129950444489E-11  0.862391965991E-12  0.569367348959E-12
+  0.373949724466E-12  0.244308287576E-12  0.158759112278E-12  0.102608985649E-12
+  0.659551657757E-13  0.421598416456E-13  0.267981937141E-13  0.169370491989E-13
+  0.106430117642E-13  0.664897038353E-14  0.412929030683E-14  0.254914942035E-14
+  0.156416050039E-14  0.953894527478E-15  0.578121177227E-15  0.348179271566E-15
+  0.208361783213E-15  0.123888076766E-15  0.731816139056E-16  0.429437307677E-16
+  0.250314908633E-16  0.144919292156E-16  0.833261195736E-17  0.475788602756E-17
+  0.269765756156E-17  0.151866162806E-17  0.848784922255E-18  0.470930978916E-18
+  0.259358130154E-18  0.141770217681E-18  0.769080325620E-19  0.414017271229E-19
+  0.221148124929E-19  0.117198907928E-19  0.616163954225E-20  0.321334835009E-20
+  0.166212604066E-20  0.852648425660E-21  0.433741162679E-21  0.218776175293E-21
+  0.109403625266E-21  0.542348791934E-22  0.266497598221E-22  0.129785854911E-22
+  0.626371573732E-23  0.299542115250E-23  0.141923676963E-23  0.666150304702E-24
+  0.309712466669E-24  0.142614026192E-24  0.650324707059E-25  0.293636084705E-25
+  0.131264043433E-25  0.580877638826E-26  0.254431407219E-26  0.110292991961E-26
+  0.473107138392E-27  0.200792736801E-27  0.843053660258E-28  0.350124279543E-28
+  0.143810088723E-28  0.584112052684E-29  0.234574865468E-29  0.931286511748E-30
+  0.365459225111E-30  0.141737504231E-30  0.543195949598E-31  0.205678545991E-31
+  0.769336271113E-32  0.284230937442E-32  0.103701907864E-32  0.373588831205E-33
+  0.132868910066E-33  0.466449836926E-34  0.161609709065E-34  0.552508324466E-35
+  0.186357171761E-35  0.620033869498E-36  0.203456659574E-36  0.658324213422E-37
+  0.210011193183E-37  0.660392377853E-38  0.204663302653E-38  0.624995005636E-39
+  0.188031702947E-39  0.557213818840E-40  0.162617101827E-40  0.467283369879E-41
+  0.132184149082E-41  0.368025142204E-42  0.100829516252E-42  0.271782757757E-43
+  0.720594554583E-44  0.187890415164E-44  0.481694226412E-45  0.121394460411E-45
+  0.300672152134E-46  0.731744695370E-47  0.174945168364E-47  0.410793043128E-48
+  0.947162576742E-49  0.214391050986E-49  0.476286841668E-50  0.103826497715E-50
+  0.222035381045E-51  0.465699529658E-52  0.957753724987E-53  0.193089414014E-53
+  0.381504482368E-54  0.738645572024E-55  0.140289284430E-55  0.260948742124E-56
+  0.475242271468E-57  0.847206974733E-58
Added: SwiftApps/ematter/workflow-run/Ti.sic.psf
--- SwiftApps/ematter/workflow-run/Ti.sic.psf	                        (rev 0)
+++ SwiftApps/ematter/workflow-run/Ti.sic.psf	2015-01-27 22:12:52 UTC (rev 8376)
@@ -0,0 +1,2801 @@
+ Ti ca rel pcec
+ ATM3      14-MAR-14 Troullier-Martins
+ 4s 2.00r r= 2.48/4p 0.00r r= 2.78/3d 2.00r r= 1.40/4f 0.00r r= 2.48/
+   4  3 1110  0.112670553485E-03  0.125000000000E-01   4.00000000000
+ Radial grid follows
+  0.141722109707E-05  0.285226864102E-05  0.430536686097E-05  0.577674280646E-05
+  0.726662638298E-05  0.877525038787E-05  0.103028505467E-04  0.118496655501E-04
+  0.134159370911E-04  0.150019099027E-04  0.166078317965E-04  0.182339537010E-04
+  0.198805297011E-04  0.215478170776E-04  0.232360763476E-04  0.249455713050E-04
+  0.266765690619E-04  0.284293400901E-04  0.302041582639E-04  0.320013009020E-04
+  0.338210488117E-04  0.356636863323E-04  0.375295013796E-04  0.394187854911E-04
+  0.413318338713E-04  0.432689454378E-04  0.452304228683E-04  0.472165726475E-04
+  0.492277051156E-04  0.512641345159E-04  0.533261790447E-04  0.554141609008E-04
+  0.575284063354E-04  0.596692457037E-04  0.618370135164E-04  0.640320484914E-04
+  0.662546936074E-04  0.685052961574E-04  0.707842078024E-04  0.730917846272E-04
+  0.754283871952E-04  0.777943806054E-04  0.801901345490E-04  0.826160233675E-04
+  0.850724261110E-04  0.875597265974E-04  0.900783134723E-04  0.926285802703E-04
+  0.952109254756E-04  0.978257525849E-04  0.100473470170E-03  0.103154491943E-03
+  0.105869236818E-03  0.108618128980E-03  0.111401597949E-03  0.114220078647E-03
+  0.117074011469E-03  0.119963842346E-03  0.122890022820E-03  0.125853010114E-03
+  0.128853267200E-03  0.131891262875E-03  0.134967471831E-03  0.138082374732E-03
+  0.141236458288E-03  0.144430215331E-03  0.147664144893E-03  0.150938752281E-03
+  0.154254549159E-03  0.157612053628E-03  0.161011790303E-03  0.164454290402E-03
+  0.167940091822E-03  0.171469739226E-03  0.175043784128E-03  0.178662784981E-03
+  0.182327307261E-03  0.186037923557E-03  0.189795213661E-03  0.193599764655E-03
+  0.197452171010E-03  0.201353034672E-03  0.205302965158E-03  0.209302579654E-03
+  0.213352503106E-03  0.217453368325E-03  0.221605816078E-03  0.225810495194E-03
+  0.230068062662E-03  0.234379183736E-03  0.238744532038E-03  0.243164789662E-03
+  0.247640647282E-03  0.252172804260E-03  0.256761968756E-03  0.261408857834E-03
+  0.266114197582E-03  0.270878723218E-03  0.275703179208E-03  0.280588319384E-03
+  0.285534907060E-03  0.290543715148E-03  0.295615526287E-03  0.300751132956E-03
+  0.305951337605E-03  0.311216952776E-03  0.316548801232E-03  0.321947716085E-03
+  0.327414540928E-03  0.332950129962E-03  0.338555348134E-03  0.344231071271E-03
+  0.349978186217E-03  0.355797590970E-03  0.361690194823E-03  0.367656918508E-03
+  0.373698694339E-03  0.379816466353E-03  0.386011190467E-03  0.392283834617E-03
+  0.398635378918E-03  0.405066815811E-03  0.411579150222E-03  0.418173399715E-03
+  0.424850594656E-03  0.431611778370E-03  0.438458007306E-03  0.445390351200E-03
+  0.452409893246E-03  0.459517730262E-03  0.466714972861E-03  0.474002745628E-03
+  0.481382187291E-03  0.488854450903E-03  0.496420704022E-03  0.504082128888E-03
+  0.511839922616E-03  0.519695297376E-03  0.527649480587E-03  0.535703715106E-03
+  0.543859259424E-03  0.552117387860E-03  0.560479390765E-03  0.568946574719E-03
+  0.577520262735E-03  0.586201794471E-03  0.594992526433E-03  0.603893832190E-03
+  0.612907102591E-03  0.622033745977E-03  0.631275188405E-03  0.640632873868E-03
+  0.650108264524E-03  0.659702840923E-03  0.669418102236E-03  0.679255566492E-03
+  0.689216770816E-03  0.699303271666E-03  0.709516645078E-03  0.719858486912E-03
+  0.730330413103E-03  0.740934059910E-03  0.751671084174E-03  0.762543163578E-03
+  0.773551996906E-03  0.784699304310E-03  0.795986827581E-03  0.807416330415E-03
+  0.818989598698E-03  0.830708440774E-03  0.842574687738E-03  0.854590193714E-03
+  0.866756836150E-03  0.879076516108E-03  0.891551158563E-03  0.904182712705E-03
+  0.916973152237E-03  0.929924475694E-03  0.943038706745E-03  0.956317894516E-03
+  0.969764113906E-03  0.983379465916E-03  0.997166077971E-03  0.101112610426E-02
+  0.102526172606E-02  0.103957515209E-02  0.105406861886E-02  0.106874439100E-02
+  0.108360476163E-02  0.109865205271E-02  0.111388861542E-02  0.112931683048E-02
+  0.114493910861E-02  0.116075789080E-02  0.117677564877E-02  0.119299488534E-02
+  0.120941813479E-02  0.122604796329E-02  0.124288696928E-02  0.125993778389E-02
+  0.127720307135E-02  0.129468552939E-02  0.131238788968E-02  0.133031291825E-02
+  0.134846341592E-02  0.136684221875E-02  0.138545219846E-02  0.140429626289E-02
+  0.142337735648E-02  0.144269846068E-02  0.146226259445E-02  0.148207281474E-02
+  0.150213221691E-02  0.152244393531E-02  0.154301114367E-02  0.156383705566E-02
+  0.158492492538E-02  0.160627804785E-02  0.162789975953E-02  0.164979343887E-02
+  0.167196250679E-02  0.169441042725E-02  0.171714070780E-02  0.174015690008E-02
+  0.176346260042E-02  0.178706145038E-02  0.181095713733E-02  0.183515339502E-02
+  0.185965400416E-02  0.188446279303E-02  0.190958363805E-02  0.193502046440E-02
+  0.196077724664E-02  0.198685800932E-02  0.201326682760E-02  0.204000782793E-02
+  0.206708518863E-02  0.209450314061E-02  0.212226596796E-02  0.215037800869E-02
+  0.217884365536E-02  0.220766735579E-02  0.223685361374E-02  0.226640698963E-02
+  0.229633210121E-02  0.232663362437E-02  0.235731629376E-02  0.238838490362E-02
+  0.241984430849E-02  0.245169942396E-02  0.248395522745E-02  0.251661675901E-02
+  0.254968912205E-02  0.258317748422E-02  0.261708707812E-02  0.265142320221E-02
+  0.268619122157E-02  0.272139656877E-02  0.275704474473E-02  0.279314131955E-02
+  0.282969193338E-02  0.286670229733E-02  0.290417819436E-02  0.294212548014E-02
+  0.298055008402E-02  0.301945800991E-02  0.305885533726E-02  0.309874822199E-02
+  0.313914289743E-02  0.318004567534E-02  0.322146294687E-02  0.326340118353E-02
+  0.330586693827E-02  0.334886684645E-02  0.339240762689E-02  0.343649608293E-02
+  0.348113910348E-02  0.352634366409E-02  0.357211682808E-02  0.361846574760E-02
+  0.366539766476E-02  0.371291991276E-02  0.376103991705E-02  0.380976519649E-02
+  0.385910336449E-02  0.390906213025E-02  0.395964929992E-02  0.401087277785E-02
+  0.406274056782E-02  0.411526077427E-02  0.416844160360E-02  0.422229136540E-02
+  0.427681847383E-02  0.433203144885E-02  0.438793891760E-02  0.444454961573E-02
+  0.450187238879E-02  0.455991619357E-02  0.461869009954E-02  0.467820329024E-02
+  0.473846506472E-02  0.479948483901E-02  0.486127214757E-02  0.492383664480E-02
+  0.498718810653E-02  0.505133643155E-02  0.511629164317E-02  0.518206389077E-02
+  0.524866345139E-02  0.531610073137E-02  0.538438626790E-02  0.545353073074E-02
+  0.552354492386E-02  0.559443978712E-02  0.566622639797E-02  0.573891597323E-02
+  0.581251987080E-02  0.588704959142E-02  0.596251678052E-02  0.603893323000E-02
+  0.611631088009E-02  0.619466182119E-02  0.627399829582E-02  0.635433270045E-02
+  0.643567758749E-02  0.651804566725E-02  0.660144980992E-02  0.668590304754E-02
+  0.677141857613E-02  0.685800975765E-02  0.694569012215E-02  0.703447336986E-02
+  0.712437337336E-02  0.721540417969E-02  0.730758001260E-02  0.740091527477E-02
+  0.749542455001E-02  0.759112260558E-02  0.768802439451E-02  0.778614505790E-02
+  0.788549992730E-02  0.798610452710E-02  0.808797457699E-02  0.819112599437E-02
+  0.829557489685E-02  0.840133760479E-02  0.850843064382E-02  0.861687074746E-02
+  0.872667485968E-02  0.883786013761E-02  0.895044395418E-02  0.906444390082E-02
+  0.917987779026E-02  0.929676365929E-02  0.941511977157E-02  0.953496462046E-02
+  0.965631693198E-02  0.977919566766E-02  0.990362002757E-02  0.100296094533E-01
+  0.101571836308E-01  0.102863624940E-01  0.104171662273E-01  0.105496152690E-01
+  0.106837303145E-01  0.108195323196E-01  0.109570425037E-01  0.110962823530E-01
+  0.112372736239E-01  0.113800383467E-01  0.115245988287E-01  0.116709776577E-01
+  0.118191977057E-01  0.119692821324E-01  0.121212543888E-01  0.122751382208E-01
+  0.124309576732E-01  0.125887370929E-01  0.127485011335E-01  0.129102747583E-01
+  0.130740832449E-01  0.132399521885E-01  0.134079075066E-01  0.135779754425E-01
+  0.137501825697E-01  0.139245557960E-01  0.141011223674E-01  0.142799098728E-01
+  0.144609462483E-01  0.146442597810E-01  0.148298791141E-01  0.150178332510E-01
+  0.152081515599E-01  0.154008637784E-01  0.155960000182E-01  0.157935907697E-01
+  0.159936669070E-01  0.161962596922E-01  0.164014007810E-01  0.166091222270E-01
+  0.168194564872E-01  0.170324364267E-01  0.172480953240E-01  0.174664668763E-01
+  0.176875852046E-01  0.179114848590E-01  0.181382008244E-01  0.183677685256E-01
+  0.186002238330E-01  0.188356030683E-01  0.190739430098E-01  0.193152808987E-01
+  0.195596544446E-01  0.198071018313E-01  0.200576617229E-01  0.203113732700E-01
+  0.205682761155E-01  0.208284104010E-01  0.210918167730E-01  0.213585363893E-01
+  0.216286109253E-01  0.219020825808E-01  0.221789940863E-01  0.224593887098E-01
+  0.227433102634E-01  0.230308031105E-01  0.233219121725E-01  0.236166829357E-01
+  0.239151614586E-01  0.242173943792E-01  0.245234289219E-01  0.248333129053E-01
+  0.251470947494E-01  0.254648234832E-01  0.257865487525E-01  0.261123208274E-01
+  0.264421906107E-01  0.267762096450E-01  0.271144301216E-01  0.274569048880E-01
+  0.278036874567E-01  0.281548320131E-01  0.285103934243E-01  0.288704272475E-01
+  0.292349897387E-01  0.296041378615E-01  0.299779292961E-01  0.303564224481E-01
+  0.307396764579E-01  0.311277512097E-01  0.315207073410E-01  0.319186062519E-01
+  0.323215101150E-01  0.327294818848E-01  0.331425853077E-01  0.335608849320E-01
+  0.339844461179E-01  0.344133350477E-01  0.348476187360E-01  0.352873650407E-01
+  0.357326426729E-01  0.361835212083E-01  0.366400710975E-01  0.371023636773E-01
+  0.375704711820E-01  0.380444667542E-01  0.385244244568E-01  0.390104192840E-01
+  0.395025271737E-01  0.400008250185E-01  0.405053906787E-01  0.410163029936E-01
+  0.415336417943E-01  0.420574879160E-01  0.425879232108E-01  0.431250305602E-01
+  0.436688938884E-01  0.442195981751E-01  0.447772294690E-01  0.453418749011E-01
+  0.459136226984E-01  0.464925621976E-01  0.470787838593E-01  0.476723792818E-01
+  0.482734412155E-01  0.488820635776E-01  0.494983414666E-01  0.501223711772E-01
+  0.507542502153E-01  0.513940773132E-01  0.520419524452E-01  0.526979768433E-01
+  0.533622530124E-01  0.540348847471E-01  0.547159771475E-01  0.554056366356E-01
+  0.561039709722E-01  0.568110892734E-01  0.575271020279E-01  0.582521211141E-01
+  0.589862598178E-01  0.597296328496E-01  0.604823563630E-01  0.612445479727E-01
+  0.620163267726E-01  0.627978133547E-01  0.635891298280E-01  0.643903998371E-01
+  0.652017485822E-01  0.660233028383E-01  0.668551909747E-01  0.676975429757E-01
+  0.685504904605E-01  0.694141667039E-01  0.702887066572E-01  0.711742469688E-01
+  0.720709260063E-01  0.729788838777E-01  0.738982624531E-01  0.748292053874E-01
+  0.757718581423E-01  0.767263680092E-01  0.776928841322E-01  0.786715575314E-01
+  0.796625411265E-01  0.806659897608E-01  0.816820602251E-01  0.827109112824E-01
+  0.837527036930E-01  0.848076002389E-01  0.858757657499E-01  0.869573671290E-01
+  0.880525733786E-01  0.891615556270E-01  0.902844871548E-01  0.914215434224E-01
+  0.925729020973E-01  0.937387430814E-01  0.949192485398E-01  0.961146029289E-01
+  0.973249930253E-01  0.985506079549E-01  0.997916392224E-01  0.101048280742
+  0.102320728865      0.103609182416      0.104913842717      0.106234913625
+  0.107572601559      0.108927115536      0.110298667201      0.111687470863
+  0.113093743524      0.114517704917      0.115959577540      0.117419586688
+  0.118897960490      0.120394929946      0.121910728959      0.123445594376
+  0.124999766024      0.126573486745      0.128167002435      0.129780562086
+  0.131414417818      0.133068824925      0.134744041912      0.136440330535
+  0.138157955842      0.139897186216      0.141658293414      0.143441552614
+  0.145247242454      0.147075645076      0.148927046171      0.150801735025
+  0.152700004563      0.154622151392      0.156568475851      0.158539282058
+  0.160534877956      0.162555575360      0.164601690009      0.166673541611
+  0.168771453898      0.170895754674      0.173046775864      0.175224853569
+  0.177430328120      0.179663544125      0.181924850529      0.184214600667
+  0.186533152315      0.188880867754      0.191258113817      0.193665261954
+  0.196102688288      0.198570773671      0.201069903746      0.203600469007
+  0.206162864861      0.208757491688      0.211384754902      0.214045065019
+  0.216738837718      0.219466493906      0.222228459786      0.225025166919
+  0.227857052298      0.230724558409      0.233628133308      0.236568230682
+  0.239545309929      0.242559836223      0.245612280589      0.248703119980
+  0.251832837343      0.255001921705      0.258210868241      0.261460178356
+  0.264750359760      0.268081926552      0.271455399295      0.274871305102
+  0.278330177714      0.281832557588      0.285378991977      0.288970035019
+  0.292606247823      0.296288198552      0.300016462521      0.303791622277
+  0.307614267698      0.311484996078      0.315404412228      0.319373128564
+  0.323391765206      0.327460950075      0.331581318988      0.335753515762
+  0.339978192310      0.344256008748      0.348587633493      0.352973743370
+  0.357415023717      0.361912168494      0.366465880388      0.371076870927
+  0.375745860587      0.380473578907      0.385260764603      0.390108165682
+  0.395016539561      0.399986653182      0.405019283137      0.410115215784
+  0.415275247373      0.420500184170      0.425790842580      0.431148049281
+  0.436572641347      0.442065466381      0.447627382649      0.453259259211
+  0.458961976059      0.464736424255      0.470583506068      0.476504135116
+  0.482499236510      0.488569746995      0.494716615103      0.500940801294
+  0.507243278109      0.513625030323      0.520087055098      0.526630362138
+  0.533255973850      0.539964925496      0.546758265367      0.553637054933
+  0.560602369021      0.567655295974      0.574796937827      0.582028410477
+  0.589350843854      0.596765382105      0.604273183766      0.611875421947
+  0.619573284512      0.627367974268      0.635260709151      0.643252722418
+  0.651345262837      0.659539594882      0.667836998937      0.676238771486
+  0.684746225324      0.693360689758      0.702083510816      0.710916051455
+  0.719859691779      0.728915829249      0.738085878906      0.747371273587
+  0.756773464156      0.766293919723      0.775934127880      0.785695594927
+  0.795579846114      0.805588425877      0.815722898074      0.825984846239
+  0.836375873822      0.846897604442      0.857551682140      0.868339771639
+  0.879263558598      0.890324749883      0.901525073826      0.912866280501
+  0.924350141994      0.935978452683      0.947753029514      0.959675712289
+  0.971748363952      0.983972870879      0.996351143174       1.00888511497
+   1.02157674472       1.03442801552       1.04744093540       1.06061753767
+   1.07395988119       1.08747005074       1.10115015729       1.11500233841
+   1.12902875851       1.14323160926       1.15761310987       1.17217550750
+   1.18692107754       1.20185212402       1.21697097994       1.23228000766
+   1.24778159924       1.26347817684       1.27937219308       1.29546613144
+   1.31176250661       1.32826386496       1.34497278484       1.36189187706
+   1.37902378526       1.39637118633       1.41393679085       1.43172334348
+   1.44973362340       1.46797044475       1.48643665707       1.50513514575
+   1.52406883246       1.54324067564       1.56265367091       1.58231085161
+   1.60221528920       1.62237009379       1.64277841462       1.66344344052
+   1.68436840045       1.70555656397       1.72701124178       1.74873578622
+   1.77073359179       1.79300809568       1.81556277835       1.83840116400
+   1.86152682117       1.88494336330       1.90865444928       1.93266378399
+   1.95697511897       1.98159225289       2.00651903224       2.03175935187
+   2.05731715564       2.08319643701       2.10940123966       2.13593565815
+   2.16280383855       2.19000997904       2.21755833066       2.24545319788
+   2.27369893934       2.30229996848       2.33126075429       2.36058582194
+   2.39027975353       2.42034718880       2.45079282585       2.48162142186
+   2.51283779388       2.54444681952       2.57645343776       2.60886264969
+   2.64167951933       2.67490917437       2.70855680702       2.74262767478
+   2.77712710130       2.81206047719       2.84743326085       2.88325097936
+   2.91951922931       2.95624367767       2.99343006274       3.03108419494
+   3.06921195783       3.10781930893       3.14691228072       3.18649698157
+   3.22657959666       3.26716638898       3.30826370030       3.34987795216
+   3.39201564686       3.43468336853       3.47788778405       3.52163564423
+   3.56593378475       3.61078912728       3.65620868056       3.70219954149
+   3.74876889624       3.79592402136       3.84367228493       3.89202114773
+   3.94097816435       3.99055098444       4.04074735383       4.09157511583
+   4.14304221237       4.19515668529       4.24792667759       4.30136043467
+   4.35546630568       4.41025274476       4.46572831241       4.52190167681
+   4.57878161514       4.63637701502       4.69469687585       4.75375031022
+   4.81354654536       4.87409492454       4.93540490857       4.99748607727
+   5.06034813094       5.12400089190       5.18845430604       5.25371844432
+   5.31980350440       5.38671981221       5.45447782355       5.52308812575
+   5.59256143932       5.66290861959       5.73414065846       5.80626868608
+   5.87930397261       5.95325792994       6.02814211354       6.10396822422
+   6.18074810995       6.25849376776       6.33721734555       6.41693114406
+   6.49764761872       6.57937938164       6.66213920358       6.74594001593
+   6.83079491273       6.91671715275       7.00372016150       7.09181753337
+   7.18102303377       7.27135060124       7.36281434963       7.45542857035
+   7.54920773456       7.64416649544       7.74031969049       7.83768234385
+   7.93626966862       8.03609706928       8.13718014407       8.23953468741
+   8.34317669241       8.44812235335       8.55438806821       8.66199044120
+   8.77094628543       8.88127262547       8.99298670003       9.10610596466
+   9.22064809449       9.33663098694       9.45407276458       9.57299177793
+   9.69340660833       9.81533607084       9.93879921718       10.0638153387
+   10.1904039695       10.3185848892       10.4483781265       10.5798039616
+   10.7128829303       10.8476358263       10.9840837051       11.1222478869
+   11.2621499602       11.4038117849       11.5472554961       11.6925035070
+   11.8395785130       11.9885034948       12.1393017222       12.2919967579
+   12.4466124607       12.6031729896       12.7617028075       12.9222266851
+   13.0847697045       13.2493572633       13.4160150788       13.5847691916
+   13.7556459698       13.9286721132       14.1038746577       14.2812809788
+   14.4609187967       14.6428161803       14.8270015512       15.0135036890
+   15.2023517348       15.3935751966       15.5872039535       15.7832682603
+   15.9817987525       16.1828264508       16.3863827664       16.5924995051
+   16.8012088733       17.0125434822       17.2265363532       17.4432209231
+   17.6626310494       17.8848010154       18.1097655355       18.3375597609
+   18.5682192850       18.8017801487       19.0382788464       19.2777523315
+   19.5202380222       19.7657738075       20.0143980527       20.2661496059
+   20.5210678039       20.7791924780       21.0405639609       21.3052230923
+   21.5732112257       21.8445702349       22.1193425203       22.3975710155
+   22.6792991944       22.9645710775       23.2534312392       23.5459248144
+   23.8420975058       24.1419955912       24.4456659300       24.7531559715
+   25.0645137616       25.3797879506       25.6990278007       26.0222831937
+   26.3496046391       26.6810432813       27.0166509085       27.3564799600
+   27.7005835347       28.0490153996       28.4018299978       28.7590824573
+   29.1208285995       29.4871249481       29.8580287376       30.2335979224
+   30.6138911860       30.9989679499       31.3888883833       31.7837134120
+   32.1835047281       32.5883248000       32.9982368815       33.4133050223
+   33.8335940775       34.2591697183       34.6900984416       35.1264475810
+   35.5682853170       36.0156806874       36.4687035989       36.9274248371
+   37.3919160781       37.8622498997       38.3384997925       38.8207401715
+   39.3090463878       39.8034947401       40.3041624871       40.8111278590
+   41.3244700703       41.8442693318       42.3706068630       42.9035649054
+   43.4432267347       43.9896766742       44.5430001078       45.1032834933
+   45.6706143763       46.2450814033       46.8267743359       47.4157840649
+   48.0122026243       48.6161232055       49.2276401726       49.8468490762
+   50.4738466690       51.1087309206       51.7516010330       52.4025574560
+   53.0617019028       53.7291373660       54.4049681339       55.0892998064
+   55.7822393116       56.4838949229       57.1943762752       57.9137943828
+   58.6422616562       59.3798919199       60.1268004301       60.8831038928
+   61.6489204820       62.4243698580       63.2095731865       64.0046531569
+   64.8097340023       65.6249415180       66.4504030820       67.2862476742
+   68.1326058971       68.9896099960       69.8573938793       70.7360931402
+   71.6258450772       72.5267887158       73.4390648302       74.3628159656
+   75.2981864599       76.2453224666       77.2043719777       78.1754848465
+   79.1588128116       80.1545095197       81.1627305507       82.1836334411
+   83.2173777090       84.2641248791       85.3240385077       86.3972842085
+   87.4840296784       88.5844447235       89.6987012859       90.8269734705
+   91.9694375721       93.1262721031       94.2976578211       95.4837777576
+   96.6848172463       97.9009639520       99.1324079000       100.379341506
+   101.641959606       102.920459487       104.215040916       105.525906175
+   106.853260090       108.197310061       109.558266100       110.936340858
+   112.331749663       113.744710549       115.175444296       116.624174458
+   118.091127402       119.576532343
+ Down Pseudopotential follows (l on next line)
+  0
+ -0.106615606638E-05 -0.214572272519E-05 -0.323886866092E-05 -0.434576467988E-05
+ -0.546658373684E-05 -0.660150096206E-05 -0.775069368870E-05 -0.891434148047E-05
+ -0.100926261597E-04 -0.112857318359E-04 -0.124938449342E-04 -0.137171542247E-04
+ -0.149558508521E-04 -0.162101283653E-04 -0.174801827476E-04 -0.187662124478E-04
+ -0.200684184105E-04 -0.213870041083E-04 -0.227221755727E-04 -0.240741414272E-04
+ -0.254431129192E-04 -0.268293039532E-04 -0.282329311246E-04 -0.296542137529E-04
+ -0.310933739166E-04 -0.325506364873E-04 -0.340262291655E-04 -0.355203825155E-04
+ -0.370333300018E-04 -0.385653080258E-04 -0.401165559620E-04 -0.416873161964E-04
+ -0.432778341633E-04 -0.448883583847E-04 -0.465191405082E-04 -0.481704353470E-04
+ -0.498425009194E-04 -0.515355984891E-04 -0.532499926061E-04 -0.549859511482E-04
+ -0.567437453626E-04 -0.585236499082E-04 -0.603259428990E-04 -0.621509059470E-04
+ -0.639988242065E-04 -0.658699864187E-04 -0.677646849567E-04 -0.696832158712E-04
+ -0.716258789366E-04 -0.735929776982E-04 -0.755848195195E-04 -0.776017156299E-04
+ -0.796439811738E-04 -0.817119352595E-04 -0.838059010094E-04 -0.859262056100E-04
+ -0.880731803637E-04 -0.902471607397E-04 -0.924484864272E-04 -0.946775013882E-04
+ -0.969345539111E-04 -0.992199966652E-04 -0.101534186756E-03 -0.103877485781E-03
+ -0.106250259885E-03 -0.108652879820E-03 -0.111085721000E-03 -0.113549163563E-03
+ -0.116043592426E-03 -0.118569397350E-03 -0.121126972997E-03 -0.123716718994E-03
+ -0.126339039994E-03 -0.128994345742E-03 -0.131683051135E-03 -0.134405576289E-03
+ -0.137162346604E-03 -0.139953792833E-03 -0.142780351145E-03 -0.145642463197E-03
+ -0.148540576199E-03 -0.151475142989E-03 -0.154446622100E-03 -0.157455477832E-03
+ -0.160502180326E-03 -0.163587205636E-03 -0.166711035805E-03 -0.169874158938E-03
+ -0.173077069280E-03 -0.176320267295E-03 -0.179604259740E-03 -0.182929559746E-03
+ -0.186296686900E-03 -0.189706167322E-03 -0.193158533753E-03 -0.196654325634E-03
+ -0.200194089190E-03 -0.203778377518E-03 -0.207407750672E-03 -0.211082775751E-03
+ -0.214804026986E-03 -0.218572085833E-03 -0.222387541059E-03 -0.226250988841E-03
+ -0.230163032850E-03 -0.234124284354E-03 -0.238135362309E-03 -0.242196893456E-03
+ -0.246309512420E-03 -0.250473861809E-03 -0.254690592313E-03 -0.258960362807E-03
+ -0.263283840455E-03 -0.267661700811E-03 -0.272094627929E-03 -0.276583314465E-03
+ -0.281128461788E-03 -0.285730780091E-03 -0.290390988500E-03 -0.295109815183E-03
+ -0.299887997472E-03 -0.304726281972E-03 -0.309625424678E-03 -0.314586191095E-03
+ -0.319609356357E-03 -0.324695705350E-03 -0.329846032831E-03 -0.335061143553E-03
+ -0.340341852393E-03 -0.345688984479E-03 -0.351103375317E-03 -0.356585870921E-03
+ -0.362137327949E-03 -0.367758613834E-03 -0.373450606919E-03 -0.379214196599E-03
+ -0.385050283451E-03 -0.390959779384E-03 -0.396943607776E-03 -0.403002703622E-03
+ -0.409138013675E-03 -0.415350496599E-03 -0.421641123116E-03 -0.428010876158E-03
+ -0.434460751023E-03 -0.440991755527E-03 -0.447604910162E-03 -0.454301248260E-03
+ -0.461081816148E-03 -0.467947673315E-03 -0.474899892578E-03 -0.481939560249E-03
+ -0.489067776303E-03 -0.496285654552E-03 -0.503594322820E-03 -0.510994923116E-03
+ -0.518488611814E-03 -0.526076559834E-03 -0.533759952827E-03 -0.541539991355E-03
+ -0.549417891084E-03 -0.557394882971E-03 -0.565472213456E-03 -0.573651144661E-03
+ -0.581932954581E-03 -0.590318937287E-03 -0.598810403131E-03 -0.607408678945E-03
+ -0.616115108251E-03 -0.624931051475E-03 -0.633857886151E-03 -0.642897007145E-03
+ -0.652049826865E-03 -0.661317775491E-03 -0.670702301188E-03 -0.680204870342E-03
+ -0.689826967782E-03 -0.699570097015E-03 -0.709435780464E-03 -0.719425559699E-03
+ -0.729540995683E-03 -0.739783669016E-03 -0.750155180179E-03 -0.760657149786E-03
+ -0.771291218839E-03 -0.782059048981E-03 -0.792962322757E-03 -0.804002743878E-03
+ -0.815182037487E-03 -0.826501950428E-03 -0.837964251518E-03 -0.849570731828E-03
+ -0.861323204955E-03 -0.873223507315E-03 -0.885273498421E-03 -0.897475061181E-03
+ -0.909830102187E-03 -0.922340552016E-03 -0.935008365532E-03 -0.947835522188E-03
+ -0.960824026341E-03 -0.973975907560E-03 -0.987293220947E-03 -0.100077804745E-02
+ -0.101443249421E-02 -0.102825869487E-02 -0.104225880989E-02 -0.105643502695E-02
+ -0.107078956122E-02 -0.108532465575E-02 -0.110004258180E-02 -0.111494563921E-02
+ -0.113003615675E-02 -0.114531649248E-02 -0.116078903414E-02 -0.117645619950E-02
+ -0.119232043673E-02 -0.120838422483E-02 -0.122465007396E-02 -0.124112052588E-02
+ -0.125779815431E-02 -0.127468556535E-02 -0.129178539791E-02 -0.130910032406E-02
+ -0.132663304953E-02 -0.134438631405E-02 -0.136236289184E-02 -0.138056559202E-02
+ -0.139899725906E-02 -0.141766077318E-02 -0.143655905089E-02 -0.145569504535E-02
+ -0.147507174690E-02 -0.149469218349E-02 -0.151455942116E-02 -0.153467656454E-02
+ -0.155504675731E-02 -0.157567318272E-02 -0.159655906405E-02 -0.161770766514E-02
+ -0.163912229089E-02 -0.166080628781E-02 -0.168276304449E-02 -0.170499599215E-02
+ -0.172750860520E-02 -0.175030440177E-02 -0.177338694424E-02 -0.179675983981E-02
+ -0.182042674110E-02 -0.184439134665E-02 -0.186865740157E-02 -0.189322869807E-02
+ -0.191810907610E-02 -0.194330242391E-02 -0.196881267869E-02 -0.199464382717E-02
+ -0.202079990625E-02 -0.204728500361E-02 -0.207410325840E-02 -0.210125886183E-02
+ -0.212875605787E-02 -0.215659914388E-02 -0.218479247133E-02 -0.221334044642E-02
+ -0.224224753081E-02 -0.227151824232E-02 -0.230115715561E-02 -0.233116890294E-02
+ -0.236155817483E-02 -0.239232972087E-02 -0.242348835040E-02 -0.245503893330E-02
+ -0.248698640076E-02 -0.251933574601E-02 -0.255209202513E-02 -0.258526035785E-02
+ -0.261884592835E-02 -0.265285398604E-02 -0.268728984642E-02 -0.272215889190E-02
+ -0.275746657264E-02 -0.279321840741E-02 -0.282941998445E-02 -0.286607696234E-02
+ -0.290319507092E-02 -0.294078011212E-02 -0.297883796096E-02 -0.301737456640E-02
+ -0.305639595229E-02 -0.309590821834E-02 -0.313591754105E-02 -0.317643017468E-02
+ -0.321745245226E-02 -0.325899078653E-02 -0.330105167100E-02 -0.334364168096E-02
+ -0.338676747446E-02 -0.343043579342E-02 -0.347465346466E-02 -0.351942740098E-02
+ -0.356476460222E-02 -0.361067215640E-02 -0.365715724079E-02 -0.370422712308E-02
+ -0.375188916248E-02 -0.380015081092E-02 -0.384901961419E-02 -0.389850321311E-02
+ -0.394860934479E-02 -0.399934584380E-02 -0.405072064339E-02 -0.410274177680E-02
+ -0.415541737844E-02 -0.420875568526E-02 -0.426276503796E-02 -0.431745388236E-02
+ -0.437283077071E-02 -0.442890436302E-02 -0.448568342848E-02 -0.454317684676E-02
+ -0.460139360948E-02 -0.466034282156E-02 -0.472003370274E-02 -0.478047558894E-02
+ -0.484167793380E-02 -0.490365031015E-02 -0.496640241149E-02 -0.502994405357E-02
+ -0.509428517591E-02 -0.515943584336E-02 -0.522540624771E-02 -0.529220670930E-02
+ -0.535984767861E-02 -0.542833973798E-02 -0.549769360321E-02 -0.556792012531E-02
+ -0.563903029219E-02 -0.571103523039E-02 -0.578394620686E-02 -0.585777463074E-02
+ -0.593253205514E-02 -0.600823017901E-02 -0.608488084898E-02 -0.616249606120E-02
+ -0.624108796329E-02 -0.632066885627E-02 -0.640125119646E-02 -0.648284759750E-02
+ -0.656547083234E-02 -0.664913383526E-02 -0.673384970394E-02 -0.681963170156E-02
+ -0.690649325884E-02 -0.699444797625E-02 -0.708350962614E-02 -0.717369215494E-02
+ -0.726500968539E-02 -0.735747651877E-02 -0.745110713721E-02 -0.754591620595E-02
+ -0.764191857577E-02 -0.773912928524E-02 -0.783756356326E-02 -0.793723683137E-02
+ -0.803816470631E-02 -0.814036300247E-02 -0.824384773442E-02 -0.834863511951E-02
+ -0.845474158047E-02 -0.856218374800E-02 -0.867097846348E-02 -0.878114278167E-02
+ -0.889269397345E-02 -0.900564952860E-02 -0.912002715860E-02 -0.923584479953E-02
+ -0.935312061489E-02 -0.947187299862E-02 -0.959212057799E-02 -0.971388221666E-02
+ -0.983717701772E-02 -0.996202432679E-02 -0.100884437351E-01 -0.102164550828E-01
+ -0.103460784621E-01 -0.104773342204E-01 -0.106102429638E-01 -0.107448255605E-01
+ -0.108811031440E-01 -0.110190971166E-01 -0.111588291530E-01 -0.113003212038E-01
+ -0.114435954989E-01 -0.115886745516E-01 -0.117355811618E-01 -0.118843384200E-01
+ -0.120349697111E-01 -0.121874987182E-01 -0.123419494265E-01 -0.124983461273E-01
+ -0.126567134218E-01 -0.128170762257E-01 -0.129794597727E-01 -0.131438896191E-01
+ -0.133103916479E-01 -0.134789920732E-01 -0.136497174443E-01 -0.138225946507E-01
+ -0.139976509259E-01 -0.141749138525E-01 -0.143544113665E-01 -0.145361717623E-01
+ -0.147202236971E-01 -0.149065961961E-01 -0.150953186570E-01 -0.152864208555E-01
+ -0.154799329498E-01 -0.156758854862E-01 -0.158743094039E-01 -0.160752360406E-01
+ -0.162786971375E-01 -0.164847248453E-01 -0.166933517292E-01 -0.169046107745E-01
+ -0.171185353928E-01 -0.173351594273E-01 -0.175545171587E-01 -0.177766433114E-01
+ -0.180015730593E-01 -0.182293420322E-01 -0.184599863217E-01 -0.186935424878E-01
+ -0.189300475652E-01 -0.191695390699E-01 -0.194120550057E-01 -0.196576338710E-01
+ -0.199063146658E-01 -0.201581368985E-01 -0.204131405930E-01 -0.206713662957E-01
+ -0.209328550831E-01 -0.211976485690E-01 -0.214657889121E-01 -0.217373188238E-01
+ -0.220122815757E-01 -0.222907210074E-01 -0.225726815353E-01 -0.228582081598E-01
+ -0.231473464743E-01 -0.234401426733E-01 -0.237366435611E-01 -0.240368965605E-01
+ -0.243409497219E-01 -0.246488517320E-01 -0.249606519231E-01 -0.252764002826E-01
+ -0.255961474623E-01 -0.259199447884E-01 -0.262478442708E-01 -0.265798986138E-01
+ -0.269161612256E-01 -0.272566862292E-01 -0.276015284728E-01 -0.279507435405E-01
+ -0.283043877633E-01 -0.286625182300E-01 -0.290251927990E-01 -0.293924701095E-01
+ -0.297644095933E-01 -0.301410714870E-01 -0.305225168438E-01 -0.309088075462E-01
+ -0.313000063189E-01 -0.316961767409E-01 -0.320973832595E-01 -0.325036912032E-01
+ -0.329151667952E-01 -0.333318771678E-01 -0.337538903763E-01 -0.341812754131E-01
+ -0.346141022229E-01 -0.350524417175E-01 -0.354963657911E-01 -0.359459473356E-01
+ -0.364012602571E-01 -0.368623794914E-01 -0.373293810209E-01 -0.378023418914E-01
+ -0.382813402292E-01 -0.387664552587E-01 -0.392577673199E-01 -0.397553578873E-01
+ -0.402593095877E-01 -0.407697062197E-01 -0.412866327729E-01 -0.418101754474E-01
+ -0.423404216741E-01 -0.428774601354E-01 -0.434213807857E-01 -0.439722748732E-01
+ -0.445302349615E-01 -0.450953549517E-01 -0.456677301054E-01 -0.462474570678E-01
+ -0.468346338911E-01 -0.474293600589E-01 -0.480317365106E-01 -0.486418656667E-01
+ -0.492598514543E-01 -0.498857993333E-01 -0.505198163232E-01 -0.511620110300E-01
+ -0.518124936744E-01 -0.524713761198E-01 -0.531387719016E-01 -0.538147962563E-01
+ -0.544995661519E-01 -0.551932003185E-01 -0.558958192798E-01 -0.566075453847E-01
+ -0.573285028404E-01 -0.580588177451E-01 -0.587986181223E-01 -0.595480339554E-01
+ -0.603071972224E-01 -0.610762419327E-01 -0.618553041628E-01 -0.626445220943E-01
+ -0.634440360514E-01 -0.642539885403E-01 -0.650745242878E-01 -0.659057902823E-01
+ -0.667479358142E-01 -0.676011125176E-01 -0.684654744130E-01 -0.693411779500E-01
+ -0.702283820516E-01 -0.711272481583E-01 -0.720379402741E-01 -0.729606250120E-01
+ -0.738954716413E-01 -0.748426521348E-01 -0.758023412174E-01 -0.767747164149E-01
+ -0.777599581040E-01 -0.787582495624E-01 -0.797697770203E-01 -0.807947297119E-01
+ -0.818332999280E-01 -0.828856830692E-01 -0.839520776994E-01 -0.850326856003E-01
+ -0.861277118261E-01 -0.872373647593E-01 -0.883618561662E-01 -0.895014012535E-01
+ -0.906562187251E-01 -0.918265308395E-01 -0.930125634672E-01 -0.942145461487E-01
+ -0.954327121526E-01 -0.966672985339E-01 -0.979185461927E-01 -0.991866999325E-01
+ -0.100472008519     -0.101774724739     -0.103095105457     -0.104433411677
+ -0.105789908595     -0.107164865664     -0.108558556644     -0.109971259663
+ -0.111403257269     -0.112854836491     -0.114326288889     -0.115817910608
+ -0.117330002431     -0.118862869833     -0.120416823027     -0.121992177013
+ -0.123589251630     -0.125208371597     -0.126849866561     -0.128514071136
+ -0.130201324946     -0.131911972664     -0.133646364050     -0.135404853982
+ -0.137187802495     -0.138995574806     -0.140828541347     -0.142687077792
+ -0.144571565077     -0.146482389430     -0.148419942388     -0.150384620815
+ -0.152376826924     -0.154396968290     -0.156445457865     -0.158522713997
+ -0.160629160438     -0.162765226362     -0.164931346378     -0.167127960545
+ -0.169355514390     -0.171614458929     -0.173905250685     -0.176228351721
+ -0.178584229667     -0.180973357762     -0.183396214900     -0.185853285685
+ -0.188345060496     -0.190872035568     -0.193434713088     -0.196033601297
+ -0.198669214628     -0.201342073851     -0.204052706247     -0.206801645814
+ -0.209589433491     -0.212416617430     -0.215283753295     -0.218191404602
+ -0.221140143111     -0.224130549261     -0.227163212661     -0.230238732640
+ -0.233357718858     -0.236520791995     -0.239728584500     -0.242981741438
+ -0.246280921406     -0.249626797560     -0.253020058726     -0.256461410626
+ -0.259951577215     -0.263491302139     -0.267081350319     -0.270722509667
+ -0.274415592951     -0.278161439801     -0.281960918877     -0.285814930201
+ -0.289724407651     -0.293690321647     -0.297713682011     -0.301795541022
+ -0.305936996674     -0.310139196131     -0.314403339395     -0.318730683200
+ -0.323122545114     -0.327580307877     -0.332105423974     -0.336699420440
+ -0.341363903912     -0.346100565927     -0.350911188474     -0.355797649800
+ -0.360761930488     -0.365806119790     -0.370932422249     -0.376143164598
+ -0.381440802948     -0.386827930285     -0.392307284278     -0.397881755417
+ -0.403554395496     -0.409328426463     -0.415207249672     -0.421194455536
+ -0.427293833653     -0.433509383414     -0.439845325153     -0.446306111889
+ -0.452896441716     -0.459621270916     -0.466485827862     -0.473495627807
+ -0.480656488656     -0.487974547822     -0.495456280296     -0.503108518050
+ -0.510938470943     -0.518953749262     -0.527162388087     -0.535572873674
+ -0.544194172040     -0.553035759985     -0.562107658779     -0.571420470764
+ -0.580985419124     -0.590814391126     -0.600919985106     -0.611315561515
+ -0.622015298358     -0.633034251362     -0.644310373617     -0.655804228147
+ -0.667564437559     -0.679638243158     -0.692071513668     -0.704908779325
+ -0.718193287436     -0.731967075894     -0.746271061581     -0.761145141005
+ -0.776628300891     -0.792758736833     -0.809573978418     -0.827111019536
+ -0.845406452827     -0.864496607451     -0.884417689528     -0.905205924762
+ -0.926897702874     -0.949529723581     -0.973139143929     -0.997763726834
+  -1.02344199074      -1.05021336033      -1.07811831816      -1.10719855723
+  -1.13749713427      -1.16905862363      -1.20192927160      -1.23615715071
+  -1.27179231368      -1.30888694643      -1.34749551932      -1.38767493571
+  -1.42948467655      -1.47298693941      -1.51824677007      -1.56533218419
+  -1.61431427619      -1.66526731194      -1.71826880107      -1.77339954421
+  -1.83074364962      -1.89038851304      -1.95242475398      -2.01694610100
+  -2.08404921820      -2.15383346521      -2.22640058313      -2.30185429983
+  -2.38029984870      -2.46184341204      -2.54659143416      -2.63464995234
+  -2.72599753294      -2.82086659112      -2.91935597963      -3.02156210511
+  -3.12757664170      -3.23748482478      -3.35136393230      -3.46928150634
+  -3.59129338927      -3.71744156145      -3.84775177541      -3.98223098231
+  -4.12086455007      -4.26361327618      -4.41041020321      -4.56115725041
+  -4.71572168245      -4.87393244397      -5.03557639889      -5.20039452445
+  -5.36807812336      -5.53826513218      -5.71053662134      -5.88441360143
+  -6.05935427186      -6.23475187221      -6.40993332316      -6.58415887348
+  -6.75662300177      -6.92645685738      -7.09273256392      -7.25446975159
+  -7.41064473173      -7.56020277953      -7.70207404884      -7.83519370986
+  -7.95852697586      -8.07109977472      -8.17203592676      -8.26060181996
+  -8.33625973302      -8.39873115682      -8.44807171675      -8.48475961599
+  -8.50979991727      -8.52484747076      -8.53235188378      -8.53572860671
+  -8.53862794992      -8.54185295456      -8.54538940753      -8.54922405414
+  -8.55334432056      -8.55773829351      -8.56239469974      -8.56730288561
+  -8.57245279678      -8.57783495802      -8.58344045334      -8.58926090633
+  -8.59528846083      -8.60151576195      -8.60793593747      -8.61454257955
+  -8.62132972693      -8.62829184732      -8.63542382037      -8.64272092079
+  -8.65017880187      -8.65779347933      -8.66556131534      -8.67347900279
+  -8.68154354984      -8.68975226445      -8.69810273922      -8.70659283612
+  -8.71522067140      -8.72398460042      -8.73288320251      -8.74191526574
+  -8.75107977160      -8.76037587959      -8.76980291168      -8.77936033666
+  -8.78904775425      -8.79886487919      -8.80881152506      -8.81888758802
+  -8.82909303041      -8.83942786418      -8.84989213431      -8.86048590204
+  -8.87120922823      -8.88206215651      -8.89304469662      -8.90415680781
+  -8.91539838228      -8.92676922888      -8.93826905699      -8.94989746076
+  -8.96165390358      -8.97353770304      -8.98554801637      -8.99768382627
+  -9.00994392749      -9.02232691394      -9.03483116655      -9.04745484185
+  -9.06019586142      -9.07305190217      -9.08602038753      -9.09909847964
+  -9.11228307252      -9.12557078630      -9.13895796254      -9.15244066067
+  -9.16601465554      -9.17967543622      -9.19341820587      -9.20723788292
+  -9.22112910335      -9.23508622431      -9.24910332878      -9.26317423157
+  -9.27729248644      -9.29145139440      -9.30564401312      -9.31986316753
+  -9.33410146145      -9.34835129026      -9.36260485463      -9.37685417518
+  -9.39109110806      -9.40530736136      -9.41949451243      -9.43364402584
+  -9.44774727205      -9.46179554679      -9.47578009089      -9.48969211064
+  -9.50352279860      -9.51726335470      -9.53090500764      -9.54443903651
+  -9.55785679246      -9.57114972045      -9.58430938098      -9.59732747166
+  -9.61019584858      -9.62290654744      -9.63545180423      -9.64782407560
+  -9.66001605855      -9.67202070962      -9.68383126338      -9.69544125013
+  -9.70684451277      -9.71803522279      -9.72900789523      -9.73975740264
+  -9.75027898787      -9.76056827573      -9.77062128337      -9.78043442941
+  -9.79000454171      -9.79932886376      -9.80840505966      -9.81723121761
+  -9.82580585205      -9.83412790410      -9.84219674075      -9.85001215231
+  -9.85757434859      -9.86488395338      -9.87194199766      -9.87874991129
+  -9.88530951328      -9.89162300086      -9.89769293710      -9.90352223741
+  -9.90911415492      -9.91447226465      -9.91960044690      -9.92450286953
+  -9.92918396962      -9.93364843431      -9.93790118113      -9.94194733781
+  -9.94579222170      -9.94944131898      -9.95290026365      -9.95617481653
+  -9.95927084434      -9.96219429890      -9.96495119667      -9.96754759868
+  -9.96998959086      -9.97228326506      -9.97443470062      -9.97644994675
+  -9.97833500569      -9.98009581675      -9.98173824125      -9.98326804844
+  -9.98469090252      -9.98601235056      -9.98723781141      -9.98837256632
+  -9.98942174991      -9.99039034241      -9.99128316306      -9.99210486473
+  -9.99285992939      -9.99355266458      -9.99418720097      -9.99476749077
+  -9.99529730707      -9.99578024399      -9.99621971770      -9.99661896807
+  -9.99698106108      -9.99730889183      -9.99760518810      -9.99787251444
+  -9.99811327660      -9.99832972671      -9.99852396822      -9.99869796154
+  -9.99885352976      -9.99899236456      -9.99980634680      -9.99996355530
+  -9.99999328542      -9.99999878923      -9.99999978638      -9.99999996313
+  -9.99999999378      -9.99999999897      -9.99999999983      -9.99999999997
+ -10.00000000000     -10.00000000000      -10.0000000000      -10.0000000000
+  -10.0000000000      -10.0000000000      -10.0000000000      -10.0000000000
+  1
+ -0.586534967213E-05 -0.118044763609E-04 -0.178183080669E-04 -0.239077844637E-04
+ -0.300738570443E-04 -0.363174892701E-04 -0.426396567214E-04 -0.490413472498E-04
+ -0.555235611323E-04 -0.620873112283E-04 -0.687336231369E-04 -0.754635353579E-04
+ -0.822780994540E-04 -0.891783802145E-04 -0.961654558225E-04 -0.103240418023E-03
+ -0.110404372293E-03 -0.117658438014E-03 -0.125003748651E-03 -0.132441451921E-03
+ -0.139972709983E-03 -0.147598699609E-03 -0.155320612377E-03 -0.163139654851E-03
+ -0.171057048773E-03 -0.179074031251E-03 -0.187191854956E-03 -0.195411788313E-03
+ -0.203735115705E-03 -0.212163137668E-03 -0.220697171097E-03 -0.229338549454E-03
+ -0.238088622971E-03 -0.246948758865E-03 -0.255920341550E-03 -0.265004772854E-03
+ -0.274203472239E-03 -0.283517877020E-03 -0.292949442591E-03 -0.302499642655E-03
+ -0.312169969449E-03 -0.321961933983E-03 -0.331877066269E-03 -0.341916915569E-03
+ -0.352083050629E-03 -0.362377059929E-03 -0.372800551928E-03 -0.383355155319E-03
+ -0.394042519281E-03 -0.404864313734E-03 -0.415822229609E-03 -0.426917979100E-03
+ -0.438153295942E-03 -0.449529935676E-03 -0.461049675926E-03 -0.472714316674E-03
+ -0.484525680545E-03 -0.496485613088E-03 -0.508595983068E-03 -0.520858682755E-03
+ -0.533275628221E-03 -0.545848759640E-03 -0.558580041588E-03 -0.571471463355E-03
+ -0.584525039253E-03 -0.597742808929E-03 -0.611126837687E-03 -0.624679216810E-03
+ -0.638402063885E-03 -0.652297523134E-03 -0.666367765753E-03 -0.680614990245E-03
+ -0.695041422770E-03 -0.709649317486E-03 -0.724440956909E-03 -0.739418652261E-03
+ -0.754584743840E-03 -0.769941601379E-03 -0.785491624417E-03 -0.801237242680E-03
+ -0.817180916452E-03 -0.833325136966E-03 -0.849672426790E-03 -0.866225340222E-03
+ -0.882986463689E-03 -0.899958416152E-03 -0.917143849514E-03 -0.934545449034E-03
+ -0.952165933750E-03 -0.970008056898E-03 -0.988074606349E-03 -0.100636840504E-02
+ -0.102489231141E-02 -0.104364921986E-02 -0.106264206120E-02 -0.108187380311E-02
+ -0.110134745057E-02 -0.112106604639E-02 -0.114103267164E-02 -0.116125044615E-02
+ -0.118172252899E-02 -0.120245211896E-02 -0.122344245511E-02 -0.124469681723E-02
+ -0.126621852634E-02 -0.128801094527E-02 -0.131007747912E-02 -0.133242157585E-02
+ -0.135504672675E-02 -0.137795646707E-02 -0.140115437649E-02 -0.142464407974E-02
+ -0.144842924714E-02 -0.147251359517E-02 -0.149690088706E-02 -0.152159493338E-02
+ -0.154659959262E-02 -0.157191877183E-02 -0.159755642717E-02 -0.162351656458E-02
+ -0.164980324040E-02 -0.167642056198E-02 -0.170337268832E-02 -0.173066383075E-02
+ -0.175829825359E-02 -0.178628027477E-02 -0.181461426653E-02 -0.184330465614E-02
+ -0.187235592652E-02 -0.190177261700E-02 -0.193155932401E-02 -0.196172070178E-02
+ -0.199226146310E-02 -0.202318638003E-02 -0.205450028466E-02 -0.208620806985E-02
+ -0.211831469002E-02 -0.215082516191E-02 -0.218374456534E-02 -0.221707804405E-02
+ -0.225083080647E-02 -0.228500812654E-02 -0.231961534456E-02 -0.235465786798E-02
+ -0.239014117227E-02 -0.242607080179E-02 -0.246245237062E-02 -0.249929156346E-02
+ -0.253659413654E-02 -0.257436591846E-02 -0.261261281115E-02 -0.265134079078E-02
+ -0.269055590869E-02 -0.273026429233E-02 -0.277047214624E-02 -0.281118575300E-02
+ -0.285241147419E-02 -0.289415575144E-02 -0.293642510739E-02 -0.297922614674E-02
+ -0.302256555725E-02 -0.306645011082E-02 -0.311088666450E-02 -0.315588216164E-02
+ -0.320144363288E-02 -0.324757819732E-02 -0.329429306360E-02 -0.334159553104E-02
+ -0.338949299078E-02 -0.343799292690E-02 -0.348710291767E-02 -0.353683063663E-02
+ -0.358718385388E-02 -0.363817043723E-02 -0.368979835348E-02 -0.374207566963E-02
+ -0.379501055415E-02 -0.384861127826E-02 -0.390288621721E-02 -0.395784385162E-02
+ -0.401349276876E-02 -0.406984166394E-02 -0.412689934182E-02 -0.418467471784E-02
+ -0.424317681955E-02 -0.430241478808E-02 -0.436239787953E-02 -0.442313546644E-02
+ -0.448463703922E-02 -0.454691220769E-02 -0.460997070252E-02 -0.467382237679E-02
+ -0.473847720751E-02 -0.480394529722E-02 -0.487023687548E-02 -0.493736230058E-02
+ -0.500533206106E-02 -0.507415677742E-02 -0.514384720374E-02 -0.521441422937E-02
+ -0.528586888064E-02 -0.535822232257E-02 -0.543148586064E-02 -0.550567094251E-02
+ -0.558078915985E-02 -0.565685225014E-02 -0.573387209851E-02 -0.581186073957E-02
+ -0.589083035933E-02 -0.597079329707E-02 -0.605176204728E-02 -0.613374926163E-02
+ -0.621676775094E-02 -0.630083048713E-02 -0.638595060535E-02 -0.647214140592E-02
+ -0.655941635650E-02 -0.664778909415E-02 -0.673727342744E-02 -0.682788333868E-02
+ -0.691963298602E-02 -0.701253670574E-02 -0.710660901441E-02 -0.720186461125E-02
+ -0.729831838035E-02 -0.739598539302E-02 -0.749488091018E-02 -0.759502038468E-02
+ -0.769641946378E-02 -0.779909399154E-02 -0.790306001135E-02 -0.800833376839E-02
+ -0.811493171218E-02 -0.822287049918E-02 -0.833216699536E-02 -0.844283827884E-02
+ -0.855490164257E-02 -0.866837459705E-02 -0.878327487301E-02 -0.889962042424E-02
+ -0.901742943037E-02 -0.913672029969E-02 -0.925751167209E-02 -0.937982242190E-02
+ -0.950367166089E-02 -0.962907874122E-02 -0.975606325852E-02 -0.988464505488E-02
+ -0.100148442220E-01 -0.101466811044E-01 -0.102801763023E-01 -0.104153506752E-01
+ -0.105522253452E-01 -0.106908216997E-01 -0.108311613954E-01 -0.109732663613E-01
+ -0.111171588024E-01 -0.112628612030E-01 -0.114103963300E-01 -0.115597872370E-01
+ -0.117110572674E-01 -0.118642300585E-01 -0.120193295445E-01 -0.121763799612E-01
+ -0.123354058490E-01 -0.124964320568E-01 -0.126594837467E-01 -0.128245863966E-01
+ -0.129917658056E-01 -0.131610480967E-01 -0.133324597221E-01 -0.135060274664E-01
+ -0.136817784511E-01 -0.138597401393E-01 -0.140399403391E-01 -0.142224072087E-01
+ -0.144071692605E-01 -0.145942553656E-01 -0.147836947581E-01 -0.149755170402E-01
+ -0.151697521862E-01 -0.153664305476E-01 -0.155655828578E-01 -0.157672402368E-01
+ -0.159714341960E-01 -0.161781966433E-01 -0.163875598881E-01 -0.165995566460E-01
+ -0.168142200446E-01 -0.170315836278E-01 -0.172516813619E-01 -0.174745476402E-01
+ -0.177002172890E-01 -0.179287255725E-01 -0.181601081986E-01 -0.183944013245E-01
+ -0.186316415624E-01 -0.188718659848E-01 -0.191151121309E-01 -0.193614180121E-01
+ -0.196108221181E-01 -0.198633634226E-01 -0.201190813900E-01 -0.203780159809E-01
+ -0.206402076589E-01 -0.209056973966E-01 -0.211745266821E-01 -0.214467375255E-01
+ -0.217223724655E-01 -0.220014745760E-01 -0.222840874728E-01 -0.225702553207E-01
+ -0.228600228399E-01 -0.231534353134E-01 -0.234505385941E-01 -0.237513791116E-01
+ -0.240560038799E-01 -0.243644605046E-01 -0.246767971902E-01 -0.249930627476E-01
+ -0.253133066023E-01 -0.256375788015E-01 -0.259659300220E-01 -0.262984115786E-01
+ -0.266350754316E-01 -0.269759741952E-01 -0.273211611459E-01 -0.276706902304E-01
+ -0.280246160742E-01 -0.283829939905E-01 -0.287458799884E-01 -0.291133307819E-01
+ -0.294854037987E-01 -0.298621571892E-01 -0.302436498358E-01 -0.306299413616E-01
+ -0.310210921406E-01 -0.314171633061E-01 -0.318182167611E-01 -0.322243151877E-01
+ -0.326355220568E-01 -0.330519016384E-01 -0.334735190111E-01 -0.339004400730E-01
+ -0.343327315513E-01 -0.347704610133E-01 -0.352136968768E-01 -0.356625084209E-01
+ -0.361169657964E-01 -0.365771400375E-01 -0.370431030727E-01 -0.375149277355E-01
+ -0.379926877768E-01 -0.384764578756E-01 -0.389663136513E-01 -0.394623316752E-01
+ -0.399645894825E-01 -0.404731655849E-01 -0.409881394823E-01 -0.415095916757E-01
+ -0.420376036797E-01 -0.425722580353E-01 -0.431136383227E-01 -0.436618291748E-01
+ -0.442169162899E-01 -0.447789864458E-01 -0.453481275129E-01 -0.459244284683E-01
+ -0.465079794096E-01 -0.470988715691E-01 -0.476971973283E-01 -0.483030502320E-01
+ -0.489165250035E-01 -0.495377175590E-01 -0.501667250230E-01 -0.508036457435E-01
+ -0.514485793074E-01 -0.521016265561E-01 -0.527628896015E-01 -0.534324718419E-01
+ -0.541104779785E-01 -0.547970140314E-01 -0.554921873570E-01 -0.561961066640E-01
+ -0.569088820315E-01 -0.576306249255E-01 -0.583614482167E-01 -0.591014661985E-01
+ -0.598507946049E-01 -0.606095506283E-01 -0.613778529388E-01 -0.621558217020E-01
+ -0.629435785986E-01 -0.637412468432E-01 -0.645489512041E-01 -0.653668180225E-01
+ -0.661949752328E-01 -0.670335523827E-01 -0.678826806534E-01 -0.687424928808E-01
+ -0.696131235760E-01 -0.704947089468E-01 -0.713873869192E-01 -0.722912971591E-01
+ -0.732065810944E-01 -0.741333819375E-01 -0.750718447078E-01 -0.760221162545E-01
+ -0.769843452804E-01 -0.779586823648E-01 -0.789452799875E-01 -0.799442925535E-01
+ -0.809558764166E-01 -0.819801899049E-01 -0.830173933454E-01 -0.840676490898E-01
+ -0.851311215401E-01 -0.862079771748E-01 -0.872983845750E-01 -0.884025144517E-01
+ -0.895205396725E-01 -0.906526352894E-01 -0.917989785664E-01 -0.929597490077E-01
+ -0.941351283866E-01 -0.953253007741E-01 -0.965304525684E-01 -0.977507725246E-01
+ -0.989864517847E-01 -0.100237683908     -0.101504664903     -0.102787593257
+ -0.104086669969     -0.105402098581     -0.106734085213     -0.108082838592
+ -0.109448570089     -0.110831493750     -0.112231826332     -0.113649787340
+ -0.115085599056     -0.116539486581     -0.118011677869     -0.119502403760
+ -0.121011898025     -0.122540397395     -0.124088141607     -0.125655373436
+ -0.127242338739     -0.128849286492     -0.130476468831     -0.132124141094
+ -0.133792561860     -0.135481992992     -0.137192699682     -0.138924950490
+ -0.140679017388     -0.142455175807     -0.144253704681     -0.146074886491
+ -0.147919007312     -0.149786356858     -0.151677228533     -0.153591919476
+ -0.155530730611     -0.157493966694     -0.159481936366     -0.161494952203
+ -0.163533330764     -0.165597392650     -0.167687462549     -0.169803869294
+ -0.171946945916     -0.174117029702     -0.176314462245     -0.178539589505
+ -0.180792761865     -0.183074334188     -0.185384665881     -0.187724120946
+ -0.190093068049     -0.192491880577     -0.194920936702     -0.197380619442
+ -0.199871316730     -0.202393421472     -0.204947331621     -0.207533450236
+ -0.210152185556     -0.212803951065     -0.215489165563     -0.218208253239
+ -0.220961643738     -0.223749772238     -0.226573079522     -0.229432012053
+ -0.232327022050     -0.235258567567     -0.238227112567     -0.241233127004
+ -0.244277086905     -0.247359474449     -0.250480778047     -0.253641492435
+ -0.256842118748     -0.260083164616     -0.263365144244     -0.266688578505
+ -0.270053995031     -0.273461928300     -0.276912919731     -0.280407517782
+ -0.283946278036     -0.287529763307     -0.291158543733     -0.294833196877
+ -0.298554307825     -0.302322469293     -0.306138281729     -0.310002353414
+ -0.313915300574     -0.317877747486     -0.321890326587     -0.325953678584
+ -0.330068452570     -0.334235306135     -0.338454905482     -0.342727925545
+ -0.347055050106     -0.351436971918     -0.355874392824     -0.360368023881
+ -0.364918585486     -0.369526807502     -0.374193429383     -0.378919200310
+ -0.383704879315     -0.388551235419     -0.393459047763     -0.398429105746
+ -0.403462209161     -0.408559168332     -0.413720804258     -0.418947948754
+ -0.424241444591     -0.429602145643     -0.435030917034     -0.440528635281
+ -0.446096188448     -0.451734476293     -0.457444410416     -0.463226914419
+ -0.469082924049     -0.475013387363     -0.481019264872     -0.487101529708
+ -0.493261167771     -0.499499177893     -0.505816571992     -0.512214375234
+ -0.518693626186     -0.525255376981     -0.531900693474     -0.538630655401
+ -0.545446356537     -0.552348904854     -0.559339422680     -0.566419046858
+ -0.573588928893     -0.580850235117     -0.588204146835     -0.595651860481
+ -0.603194587763     -0.610833555813     -0.618570007332     -0.626405200732
+ -0.634340410273     -0.642376926201     -0.650516054877     -0.658759118907
+ -0.667107457264     -0.675562425406     -0.684125395390     -0.692797755976
+ -0.701580912734     -0.710476288131     -0.719485321623     -0.728609469735
+ -0.737850206129     -0.747209021669     -0.756687424475     -0.766286939968
+ -0.776009110901     -0.785855497384     -0.795827676895     -0.805927244281
+ -0.816155811742     -0.826515008808     -0.837006482297     -0.847631896263
+ -0.858392931922     -0.869291287573     -0.880328678491     -0.891506836815
+ -0.902827511407     -0.914292467701     -0.925903487532     -0.937662368944
+ -0.949570925981     -0.961630988453     -0.973844401690     -0.986213026264
+ -0.998738737703      -1.01142342617      -1.02426899613      -1.03727736599
+  -1.05045046772      -1.06379024645      -1.07729866002      -1.09097767858
+  -1.10482928407      -1.11885546975      -1.13305823968      -1.14743960818
+  -1.16200159924      -1.17674624599      -1.19167559004      -1.20679168090
+  -1.22209657527      -1.23759233643      -1.25328103349      -1.26916474073
+  -1.28524553680      -1.30152550402      -1.31800672756      -1.33469129465
+  -1.35158129376      -1.36867881373      -1.38598594289      -1.40350476817
+  -1.42123737416      -1.43918584213      -1.45735224902      -1.47573866643
+  -1.49434715949      -1.51317978574      -1.53223859393      -1.55152562277
+  -1.57104289963      -1.59079243907      -1.61077624143      -1.63099629118
+  -1.65145455527      -1.67215298128      -1.69309349545      -1.71427800064
+  -1.73570837397      -1.75738646443      -1.77931409020      -1.80149303577
+  -1.82392504883      -1.84661183687      -1.86955506358      -1.89275634485
+  -1.91621724451      -1.93993926974      -1.96392386607      -1.98817241205
+  -2.01268621353      -2.03746649750      -2.06251440553      -2.08783098681
+  -2.11341719070      -2.13927385894      -2.16540171733      -2.19180136711
+  -2.21847327584      -2.24541776797      -2.27263501509      -2.30012502583
+  -2.32788763555      -2.35592249589      -2.38422906412      -2.41280659262
+  -2.44165411828      -2.47077045225      -2.50015416993      -2.52980360149
+  -2.55971682301      -2.58989164838      -2.62032562238      -2.65101601476
+  -2.68195981599      -2.71315373459      -2.74459419652      -2.77627734676
+  -2.80819905359      -2.84035491573      -2.87266222712      -2.90505963295
+  -2.93757252090      -2.97022352011      -3.00303244818      -3.03601628174
+  -3.06918914705      -3.10256232709      -3.13614428207      -3.16994068109
+  -3.20395444263      -3.23818578215      -3.27263226564      -3.30728886780
+  -3.34214803427      -3.37719974733      -3.41243159481      -3.44782884212
+  -3.48337450747      -3.51904944053      -3.55483240493      -3.59070016513
+  -3.62662757814      -3.66258769097      -3.69855184454      -3.73448978488
+  -3.77036978272      -3.80615876235      -3.84182244094      -3.87732547935
+  -3.91263164573      -3.94770399281      -3.98250505041      -4.01699703385
+  -4.05114206969      -4.08490243948      -4.11824084246      -4.15112067773
+  -4.18350634630      -4.21536357313      -4.24665974888      -4.27736429081
+  -4.30744902184      -4.33688856661      -4.36566076281      -4.39374708616
+  -4.42113308729      -4.44780883924      -4.47376939493      -4.49901525518
+  -4.52355284920      -4.54739504638      -4.57056165279      -4.59308004911
+  -4.61485956534      -4.63607437950      -4.65677783373      -4.67703543403
+  -4.69692461014      -4.71653522449      -4.73597044164      -4.75534751329
+  -4.77479855264      -4.79447128141      -4.81452973627      -4.83515491744
+  -4.85654535928      -4.87891759887      -4.90250651445      -4.92756550056
+  -4.95436644174      -4.98319944031      -5.01437224738      -5.04820933907
+  -5.08505057248      -5.12524934790      -5.16917019591      -5.21718570049
+  -5.26967266191      -5.32700739788      -5.38956007753      -5.45768798233
+  -5.53172759188      -5.61198540168      -5.69872739735      -5.79216713585
+  -5.89245242263      -5.99965062644      -6.11373274258      -6.23455640529
+  -6.36184816157      -6.49518545637      -6.63397894428      -6.77745593843
+  -6.92464603443      -7.07437020784      -7.22523497787      -7.37563355889
+  -7.52375628474      -7.66761299049      -7.80507047500      -7.93390865201
+  -8.05189947275      -8.15691349074      -8.24705814304      -8.32085529785
+  -8.37746475038      -8.41696279766      -8.44068647028      -8.45165642749
+  -8.45509448118      -8.45729104330      -8.45970535512      -8.46233056610
+  -8.46516002312      -8.46818742792      -8.47140681585      -8.47481253592
+  -8.47839923214      -8.48216182610      -8.48609550085      -8.49019568607
+  -8.49445804440      -8.49887845903      -8.50345302243      -8.50817802621
+  -8.51304995028      -8.51806545641      -8.52322138110      -8.52851472938
+  -8.53394266935      -8.53950252750      -8.54519178476      -8.55100807301
+  -8.55694917223      -8.56301300808      -8.56919764975      -8.57550130821
+  -8.58192233463      -8.58845921893      -8.59511058845      -8.60187520656
+  -8.60875197127      -8.61573991363      -8.62283819613      -8.63004611052
+  -8.63736307610      -8.64478863534      -8.65232245769      -8.65996431003
+  -8.66780979674      -8.67576429368      -8.68382801974      -8.69200127195
+  -8.70028445002      -8.70867804138      -8.71718261660      -8.72579882132
+  -8.73452736841      -8.74336902944      -8.75232462579      -8.76139501918
+  -8.77058110186      -8.77988378642      -8.78930399511      -8.79884264901
+  -8.80850065680      -9.16869952666      -9.42266725429      -9.60090877140
+  -9.72541960170      -9.81198547551      -9.87188186886      -9.91312405341
+  -9.94138208974      -9.96064729075      -9.97371525388      -9.98253419024
+  -9.98845483832      -9.99240884516      -9.99503542570      -9.99677082245
+  -9.99791115318      -9.99865632373      -9.99914054270      -9.99945340784
+  -9.99965439555      -9.99978276034      -9.99986425953      -9.99991569445
+  -9.99994795903      -9.99996807416      -9.99998053691      -9.99998820988
+  -9.99999290380      -9.99999575675      -9.99999747943      -9.99999851273
+  -9.99999912837      -9.99999949267      -9.99999970676      -9.99999983170
+  -9.99999990409      -9.99999994574      -9.99999996953      -9.99999998301
+  -9.99999999060      -9.99999999484      -9.99999999719      -9.99999999848
+  -9.99999999918      -9.99999999957      -9.99999999977      -9.99999999988
+  -9.99999999994      -9.99999999997      -9.99999999998      -9.99999999999
+ -10.00000000000     -10.00000000000     -10.00000000000      -10.0000000000
+  2
+ -0.548425357222E-04 -0.110374905622E-03 -0.166605786746E-03 -0.223543965284E-03
+ -0.281198337940E-03 -0.339577913330E-03 -0.398691813380E-03 -0.458549274756E-03
+ -0.519159650311E-03 -0.580532410537E-03 -0.642677145054E-03 -0.705603564102E-03
+ -0.769321500064E-03 -0.833840908995E-03 -0.899171872186E-03 -0.965324597731E-03
+ -0.103230942213E-02 -0.110013681190E-02 -0.116881736520E-02 -0.123836181351E-02
+ -0.130878102330E-02 -0.138008599771E-02 -0.145228787828E-02 -0.152539794670E-02
+ -0.159942762659E-02 -0.167438848521E-02 -0.175029223536E-02 -0.182715073716E-02
+ -0.190497599989E-02 -0.198378018393E-02 -0.206357560257E-02 -0.214437472402E-02
+ -0.222619017331E-02 -0.230903473426E-02 -0.239292135151E-02 -0.247786313251E-02
+ -0.256387334959E-02 -0.265096544202E-02 -0.273915301811E-02 -0.282844985736E-02
+ -0.291886991257E-02 -0.301042731207E-02 -0.310313636189E-02 -0.319701154799E-02
+ -0.329206753858E-02 -0.338831918634E-02 -0.348578153079E-02 -0.358446980062E-02
+ -0.368439941608E-02 -0.378558599136E-02 -0.388804533708E-02 -0.399179346272E-02
+ -0.409684657913E-02 -0.420322110108E-02 -0.431093364980E-02 -0.442000105560E-02
+ -0.453044036048E-02 -0.464226882081E-02 -0.475550391002E-02 -0.487016332131E-02
+ -0.498626497046E-02 -0.510382699858E-02 -0.522286777498E-02 -0.534340590003E-02
+ -0.546546020804E-02 -0.558904977026E-02 -0.571419389781E-02 -0.584091214470E-02
+ -0.596922431094E-02 -0.609915044554E-02 -0.623071084975E-02 -0.636392608013E-02
+ -0.649881695183E-02 -0.663540454185E-02 -0.677371019225E-02 -0.691375551359E-02
+ -0.705556238822E-02 -0.719915297377E-02 -0.734454970655E-02 -0.749177530510E-02
+ -0.764085277372E-02 -0.779180540607E-02 -0.794465678881E-02 -0.809943080527E-02
+ -0.825615163921E-02 -0.841484377858E-02 -0.857553201936E-02 -0.873824146940E-02
+ -0.890299755240E-02 -0.906982601182E-02 -0.923875291496E-02 -0.940980465698E-02
+ -0.958300796507E-02 -0.975838990260E-02 -0.993597787336E-02 -0.101157996258E-01
+ -0.102978832575E-01 -0.104822572194E-01 -0.106689503202E-01 -0.108579917312E-01
+ -0.110494109904E-01 -0.112432380076E-01 -0.114395030685E-01 -0.116382368401E-01
+ -0.118394703747E-01 -0.120432351157E-01 -0.122495629017E-01 -0.124584859717E-01
+ -0.126700369705E-01 -0.128842489533E-01 -0.131011553912E-01 -0.133207901763E-01
+ -0.135431876270E-01 -0.137683824932E-01 -0.139964099623E-01 -0.142273056638E-01
+ -0.144611056758E-01 -0.146978465300E-01 -0.149375652176E-01 -0.151802991952E-01
+ -0.154260863905E-01 -0.156749652081E-01 -0.159269745360E-01 -0.161821537510E-01
+ -0.164405427256E-01 -0.167021818334E-01 -0.169671119561E-01 -0.172353744897E-01
+ -0.175070113506E-01 -0.177820649828E-01 -0.180605783638E-01 -0.183425950120E-01
+ -0.186281589931E-01 -0.189173149270E-01 -0.192101079949E-01 -0.195065839464E-01
+ -0.198067891064E-01 -0.201107703826E-01 -0.204185752727E-01 -0.207302518719E-01
+ -0.210458488802E-01 -0.213654156104E-01 -0.216890019954E-01 -0.220166585962E-01
+ -0.223484366099E-01 -0.226843878774E-01 -0.230245648920E-01 -0.233690208068E-01
+ -0.237178094439E-01 -0.240709853021E-01 -0.244286035661E-01 -0.247907201143E-01
+ -0.251573915282E-01 -0.255286751010E-01 -0.259046288465E-01 -0.262853115083E-01
+ -0.266707825688E-01 -0.270611022587E-01 -0.274563315662E-01 -0.278565322468E-01
+ -0.282617668326E-01 -0.286720986424E-01 -0.290875917913E-01 -0.295083112012E-01
+ -0.299343226101E-01 -0.303656925833E-01 -0.308024885233E-01 -0.312447786804E-01
+ -0.316926321632E-01 -0.321461189500E-01 -0.326053098988E-01 -0.330702767592E-01
+ -0.335410921834E-01 -0.340178297372E-01 -0.345005639118E-01 -0.349893701355E-01
+ -0.354843247853E-01 -0.359855051988E-01 -0.364929896867E-01 -0.370068575443E-01
+ -0.375271890647E-01 -0.380540655507E-01 -0.385875693280E-01 -0.391277837575E-01
+ -0.396747932490E-01 -0.402286832738E-01 -0.407895403785E-01 -0.413574521981E-01
+ -0.419325074702E-01 -0.425147960482E-01 -0.431044089160E-01 -0.437014382020E-01
+ -0.443059771932E-01 -0.449181203500E-01 -0.455379633213E-01 -0.461656029588E-01
+ -0.468011373326E-01 -0.474446657462E-01 -0.480962887523E-01 -0.487561081685E-01
+ -0.494242270930E-01 -0.501007499209E-01 -0.507857823601E-01 -0.514794314487E-01
+ -0.521818055707E-01 -0.528930144737E-01 -0.536131692856E-01 -0.543423825321E-01
+ -0.550807681545E-01 -0.558284415270E-01 -0.565855194754E-01 -0.573521202948E-01
+ -0.581283637681E-01 -0.589143711852E-01 -0.597102653614E-01 -0.605161706571E-01
+ -0.613322129966E-01 -0.621585198885E-01 -0.629952204450E-01 -0.638424454026E-01
+ -0.647003271419E-01 -0.655689997090E-01 -0.664485988358E-01 -0.673392619619E-01
+ -0.682411282553E-01 -0.691543386346E-01 -0.700790357911E-01 -0.710153642109E-01
+ -0.719634701974E-01 -0.729235018943E-01 -0.738956093089E-01 -0.748799443351E-01
+ -0.758766607777E-01 -0.768859143759E-01 -0.779078628279E-01 -0.789426658156E-01
+ -0.799904850293E-01 -0.810514841935E-01 -0.821258290915E-01 -0.832136875926E-01
+ -0.843152296770E-01 -0.854306274635E-01 -0.865600552356E-01 -0.877036894692E-01
+ -0.888617088599E-01 -0.900342943510E-01 -0.912216291619E-01 -0.924238988167E-01
+ -0.936412911728E-01 -0.948739964510E-01 -0.961222072645E-01 -0.973861186494E-01
+ -0.986659280949E-01 -0.999618355747E-01 -0.101274043577     -0.102602757139
+ -0.103948183875     -0.105310534010     -0.106690020417     -0.108086858643
+ -0.109501266948     -0.110933466338     -0.112383680596     -0.113852136323
+ -0.115339062969     -0.116844692871     -0.118369261287     -0.119913006435
+ -0.121476169529     -0.123058994819     -0.124661729625     -0.126284624379
+ -0.127927932663     -0.129591911248     -0.131276820137     -0.132982922600
+ -0.134710485222     -0.136459777939     -0.138231074083     -0.140024650425
+ -0.141840787217     -0.143679768234     -0.145541880825     -0.147427415949
+ -0.149336668228     -0.151269935988     -0.153227521308     -0.155209730068
+ -0.157216871994     -0.159249260708     -0.161307213778     -0.163391052765
+ -0.165501103278     -0.167637695018     -0.169801161835     -0.171991841779
+ -0.174210077150     -0.176456214557     -0.178730604965     -0.181033603757
+ -0.183365570785     -0.185726870427     -0.188117871645     -0.190538948042
+ -0.192990477921     -0.195472844342     -0.197986435186     -0.200531643210
+ -0.203108866113     -0.205718506598     -0.208360972432     -0.211036676510
+ -0.213746036922     -0.216489477018     -0.219267425473     -0.222080316352
+ -0.224928589182     -0.227812689020     -0.230733066518     -0.233690178000
+ -0.236684485527     -0.239716456975     -0.242786566103     -0.245895292632
+ -0.249043122315     -0.252230547016     -0.255458064787     -0.258726179945
+ -0.262035403148     -0.265386251482     -0.268779248534     -0.272214924479
+ -0.275693816160     -0.279216467174     -0.282783427955     -0.286395255862
+ -0.290052515264     -0.293755777630     -0.297505621618     -0.301302633163
+ -0.305147405574     -0.309040539620     -0.312982643628     -0.316974333580
+ -0.321016233202     -0.325108974071     -0.329253195704     -0.333449545667
+ -0.337698679668     -0.342001261666     -0.346357963972     -0.350769467353
+ -0.355236461140     -0.359759643337     -0.364339720726     -0.368977408982
+ -0.373673432781     -0.378428525917     -0.383243431414     -0.388118901641
+ -0.393055698435     -0.398054593214     -0.403116367101     -0.408241811045
+ -0.413431725944     -0.418686922774     -0.424008222710     -0.429396457258
+ -0.434852468384     -0.440377108646     -0.445971241327     -0.451635740569
+ -0.457371491512     -0.463179390431     -0.469060344874     -0.475015273808
+ -0.481045107760     -0.487150788962     -0.493333271500     -0.499593521462
+ -0.505932517091     -0.512351248934     -0.518850720000     -0.525431945918
+ -0.532095955090     -0.538843788857     -0.545676501663     -0.552595161211
+ -0.559600848643     -0.566694658696     -0.573877699882     -0.581151094658
+ -0.588515979602     -0.595973505589     -0.603524837974     -0.611171156772
+ -0.618913656842     -0.626753548075     -0.634692055584     -0.642730419893
+ -0.650869897133     -0.659111759237     -0.667457294138     -0.675907805975
+ -0.684464615290     -0.693129059239     -0.701902491801     -0.710786283986
+ -0.719781824052     -0.728890517725     -0.738113788410     -0.747453077422
+ -0.756909844207     -0.766485566570     -0.776181740909     -0.785999882443
+ -0.795941525455     -0.806008223528     -0.816201549790     -0.826523097155
+ -0.836974478577     -0.847557327302     -0.858273297116     -0.869124062614
+ -0.880111319451     -0.891236784615     -0.902502196688     -0.913909316124
+ -0.925459925519     -0.937155829890     -0.948998856960     -0.960990857437
+ -0.973133705310     -0.985429298134     -0.997879557332      -1.01048642849
+  -1.02325188167      -1.03617791169      -1.04926653847      -1.06251980733
+  -1.07593978931      -1.08952858149      -1.10328830731      -1.11722111691
+  -1.13132918748      -1.14561472357      -1.16007995744      -1.17472714941
+  -1.18955858823      -1.20457659141      -1.21978350557      -1.23518170686
+  -1.25077360125      -1.26656162496      -1.28254824484      -1.29873595870
+  -1.31512729575      -1.33172481697      -1.34853111549      -1.36554881705
+  -1.38278058030      -1.40022909732      -1.41789709398      -1.43578733036
+  -1.45390260117      -1.47224573621      -1.49081960078      -1.50962709613
+  -1.52867115990      -1.54795476655      -1.56748092786      -1.58725269336
+  -1.60727315078      -1.62754542656      -1.64807268629      -1.66885813522
+  -1.68990501870      -1.71121662273      -1.73279627443      -1.75464734250
+  -1.77677323779      -1.79917741380      -1.82186336715      -1.84483463814
+  -1.86809481128      -1.89164751582      -1.91549642626      -1.93964526291
+  -1.96409779245      -1.98885782847      -2.01392923201      -2.03931591216
+  -2.06502182658      -2.09105098211      -2.11740743533      -2.14409529312
+  -2.17111871328      -2.19848190508      -2.22618912990      -2.25424470176
+  -2.28265298798      -2.31141840974      -2.34054544271      -2.37003861763
+  -2.39990252096      -2.43014179546      -2.46076114081      -2.49176531422
+  -2.52315913107      -2.55494746551      -2.58713525108      -2.61972748132
+  -2.65272921040      -2.68614555373      -2.71998168857      -2.75424285463
+  -2.78893435472      -2.82406155530      -2.85962988710      -2.89564484574
+  -2.93211199227      -2.96903695377      -3.00642542395      -3.04428316365
+  -3.08261600145      -3.12142983415      -3.16073062736      -3.20052441595
+  -3.24081730457      -3.28161546815      -3.32292515229      -3.36475267376
+  -3.40710442087      -3.44998685386      -3.49340650527      -3.53736998025
+  -3.58188395687      -3.62695518633      -3.67259049326      -3.71879677579
+  -3.76558100579      -3.81295022886      -3.86091156440      -3.90947220561
+  -3.95863941932      -4.00842054594      -4.05882299915      -4.10985426564
+  -4.16152190475      -4.21383354796      -4.26679689838      -4.32041973006
+  -4.37470988725      -4.42967528354      -4.48532390081      -4.54166378821
+  -4.59870306081      -4.65644989823      -4.71491254312      -4.77409929938
+  -4.83401853028      -4.89467865641      -4.95608815334      -5.01825554914
+  -5.08118942169      -5.14489839564      -5.20939113928      -5.27467636098
+  -5.34076280542      -5.40765924954      -5.47537449809      -5.54391737890
+  -5.61329673775      -5.68352143286      -5.75460032895      -5.82654229095
+  -5.89935617711      -5.97305083173      -6.04763507736      -6.12311770640
+  -6.19950747214      -6.27681307926      -6.35504317356      -6.43420633112
+  -6.51431104666      -6.59536572117      -6.67737864872      -6.76035800246
+  -6.84431181966      -6.92924798587      -7.01517421801      -7.10209804648
+  -7.19002679613      -7.27896756608      -7.36892720828      -7.45991230484
+  -7.55192914394      -7.64498369439      -7.73908157863      -7.83422804421
+  -7.93042793360      -8.02768565226      -8.12600513498      -8.22538981021
+  -8.32584256253      -8.42736569296      -8.52996087716      -8.63362912139
+  -8.73837071601      -8.84418518668      -8.95107124288      -9.05902672380
+  -9.16804854153      -9.27813262131      -9.38927383878      -9.50146595425
+  -9.61470154368      -9.72897192642      -9.84426708949      -9.96057560841
+  -10.0778845644      -10.1961794578      -10.3154441179      -10.4356606087
+  -10.5568091305      -10.6788679181      -10.8018131342      -10.9256187590
+  -11.0502564755      -11.1756955509      -11.3019027128      -11.4288420226
+  -11.5564747434      -11.6847592047      -11.8136506623      -11.9431011548
+  -12.0730593558      -12.2034704234      -12.3342758447      -12.4654132789
+  -12.5968163962      -12.7284147147      -12.8601334359      -12.9918932770
+  -13.1236103039      -13.2551957627      -13.3865559119      -13.5175918552
+  -13.6481993769      -13.7782687798      -13.9076847268      -14.0363260883
+  -14.1640657956      -14.2907707020      -14.4163014540      -14.5405123724
+  -14.6632513479      -14.7843597497      -14.9036723528      -15.0210172834
+  -15.1362159864      -15.2490832171      -15.3594270600      -15.4670489774
+  -15.5717438908      -15.6733002991      -15.7715004357      -15.8661204694
+  -15.9569307512      -16.0436961127      -16.1261762179      -16.2041259737
+  -16.2772960033      -16.3454331845      -16.4082812603      -16.4655815216
+  -16.5170735699      -16.5624961607      -16.6015881324      -16.6340894239
+  -16.6597421834      -16.6782919712      -16.6894890578      -16.6930898195
+  -16.6888582317      -16.6765674597      -16.6560015462      -16.6269571935
+  -16.5892456374      -16.5426946076      -16.4871503710      -16.4224798482
+  -16.3485727969      -16.2653440512      -16.1727358040      -16.0707199209
+  -15.9593002680      -15.8385150385      -15.7083610114      -15.5688954558
+  -15.4203037012      -15.2628117222      -15.0966880501      -14.9222455600
+  -14.7398431005      -14.5498869311      -14.3528319336      -14.1491825628
+  -13.9394934999      -13.7243699759      -13.5044677278      -13.2804925534
+  -13.0531994302      -12.8233911630      -12.5919165245      -12.3596678541
+  -12.1275780757      -11.8966170982      -11.6677875531      -11.4421198263
+  -11.2206663310      -11.0044949649      -10.7946816864      -10.5923021360
+  -10.3984222210      -10.2140875694      -10.0403117556      -9.87806319007
+  -9.72825056873      -9.59170678129      -9.46917119642      -9.36127027369
+  -9.26849650454      -9.19118576330      -9.12949326182      -9.08336845497
+  -9.05252944882      -9.03643772798      -9.03427435321      -9.04491919540
+  -9.06693527711      -9.09856089742      -9.13771292866      -9.18200550283
+  -9.22878926006      -9.27521742176      -9.31834619167      -9.35527840355
+  -9.38336096052      -9.40044852458      -9.40524810248      -9.39776210737
+  -9.37972426967      -9.35568809649      -9.33167108107      -9.30907628017
+  -9.28786975711      -9.26801682409      -9.24948214026      -9.23222978331
+  -9.21622331752      -9.20142585540      -9.18780011370      -9.17530846383
+  -9.16391297751      -9.15357546821      -9.14425752996      -9.13592057456
+  -9.12852586944      -9.12203457786      -9.11640780417      -9.11160664651
+  -9.10759225972      -9.10432593112      -9.10176917162      -9.09988382426
+  -9.09863219162      -9.09797718265      -9.09788247827      -9.09831271373
+  -9.09923367407      -9.10061249719      -9.10241787740      -9.10462026052
+  -9.10719202025      -9.11010760462      -9.11334364111      -9.11687898932
+  -9.12069473187      -9.12477409628      -9.12910230445      -9.13366635063
+  -9.13845471428      -9.14345702063      -9.14866366874      -9.15406545480
+  -9.15965322675      -9.16541761616      -9.17134890348      -9.17743708516
+  -9.18367215876      -9.19004482411      -9.19654628880      -9.20316846683
+  -9.20990388856      -9.21674566603      -9.22368745842      -9.23072343779
+  -9.23784825520      -9.24505700742      -9.25234520432      -9.25970873693
+  -9.26714384645      -9.27464709413      -9.28221533219      -9.28984567572
+  -9.29753547576      -9.30528229345      -9.31308387537      -9.32093813000
+  -9.32884310547      -9.33679696838      -9.34479798387      -9.35284449684
+  -9.36093491434      -9.36906768912      -9.37724130420      -9.38545425869
+  -9.39370505451      -9.40199218427      -9.41031412004      -9.41866930318
+  -9.42705613503      -9.43547296853      -9.44391810067      -9.45238976584
+  -9.46088612985      -9.46940528481      -9.47794524470      -9.48650394164
+  -9.49507922280      -9.50366884797      -9.51227048778      -9.52088172241
+  -9.52950004092      -9.53812284117      -9.54674743013      -9.55537102479
+  -9.56399075354      -9.57260365798      -9.58120669517      -9.58979674040
+  -9.59837059028      -9.60692496626      -9.61545651864      -9.62396183079
+  -9.63243742392      -9.64087976208      -9.64928525758      -9.65765027670
+  -9.66597114577      -9.67424415750      -9.68246557766      -9.69063165200
+  -9.69873861349      -9.70678268968      -9.71476011047      -9.72266711593
+  -9.73049996438      -9.73825494064      -9.74592836437      -9.75351659856
+  -9.76101605810      -9.76842321842      -9.77573462412      -9.78294689759
+  -9.79005674766      -9.79706097812      -9.80395649611      -9.81074032040
+  -9.81740958952      -9.82396156960      -9.83039366197      -9.83670341052
+  -9.84288850861      -9.84894680577      -9.85487631383      -9.86067521270
+  -9.86634185565      -9.87187477410      -9.87727268178      -9.88253447848
+  -9.88765925303      -9.89264628580      -9.89749505045      -9.90220521513
+  -9.90677664292      -9.91120939167      -9.91550371306      -9.91966005109
+  -9.92367903980      -9.92756150035      -9.93130843743      -9.93492103502
+  -9.93840065152      -9.94174881428      -9.94496721353      -9.94805769582
+  -9.95102225685      -9.95386303393      -9.95658229791      -9.95918244487
+  -9.96166598715      -9.96403554524      -9.96629383621      -9.96844366657
+  -9.97048792169      -9.97242955614      -9.97427158395      -9.97601706873
+  -9.97766911474      -9.97923085546      -9.98070544585      -9.98209605265
+  -9.98340584534      -9.98463798747      -9.98579562817      -9.98688189421
+  -9.98789988234      -9.98885265204      -9.98974321870      -9.99057454734
+  -9.99134954671      -9.99207106385      -9.99274187926      -9.99336470246
+  -9.99394216807      -9.99447683241      -9.99497117061      -9.99542757411
+  -9.99584834871      -9.99623571310      -9.99659179770      -9.99691864410
+  -9.99721820476      -9.99749234313      -9.99774283419      -9.99797136523
+  -9.99817953704      -9.99836886523      -9.99854078202      -9.99869663807
+  -9.99883770463      -9.99896517579      -9.99968447958      -9.99990523988
+  -9.99997197284      -9.99999183785      -9.99999765998      -9.99999933971
+  -9.99999981665      -9.99999994991      -9.99999998654      -9.99999999644
+  -9.99999999908      -9.99999999976      -9.99999999994      -9.99999999999
+  3
+ -0.129917817764E-04 -0.261469800503E-04 -0.394676503482E-04 -0.529558740520E-04
+ -0.666137587240E-04 -0.804434384367E-04 -0.944470741055E-04 -0.108626853827E-03
+ -0.122984993221E-03 -0.137523735775E-03 -0.152245353199E-03 -0.167152145774E-03
+ -0.182246442717E-03 -0.197530602543E-03 -0.213007013433E-03 -0.228678093608E-03
+ -0.244546291706E-03 -0.260614087165E-03 -0.276883990611E-03 -0.293358544249E-03
+ -0.310040322263E-03 -0.326931931213E-03 -0.344036010449E-03 -0.361355232517E-03
+ -0.378892303581E-03 -0.396649963844E-03 -0.414630987977E-03 -0.432838185552E-03
+ -0.451274401480E-03 -0.469942516458E-03 -0.488845447416E-03 -0.507986147977E-03
+ -0.527367608913E-03 -0.546992858617E-03 -0.566864963575E-03 -0.586987028844E-03
+ -0.607362198537E-03 -0.627993656316E-03 -0.648884625888E-03 -0.670038371511E-03
+ -0.691458198500E-03 -0.713147453746E-03 -0.735109526241E-03 -0.757347847603E-03
+ -0.779865892614E-03 -0.802667179766E-03 -0.825755271805E-03 -0.849133776295E-03
+ -0.872806346173E-03 -0.896776680327E-03 -0.921048524171E-03 -0.945625670229E-03
+ -0.970511958732E-03 -0.995711278213E-03 -0.102122756612E-02 -0.104706480941E-02
+ -0.107322704523E-02 -0.109971836147E-02 -0.112654289744E-02 -0.115370484455E-02
+ -0.118120844690E-02 -0.120905800198E-02 -0.123725786135E-02 -0.126581243129E-02
+ -0.129472617351E-02 -0.132400360584E-02 -0.135364930295E-02 -0.138366789702E-02
+ -0.141406407853E-02 -0.144484259695E-02 -0.147600826148E-02 -0.150756594182E-02
+ -0.153952056891E-02 -0.157187713575E-02 -0.160464069811E-02 -0.163781637536E-02
+ -0.167140935126E-02 -0.170542487480E-02 -0.173986826097E-02 -0.177474489161E-02
+ -0.181006021627E-02 -0.184581975305E-02 -0.188202908944E-02 -0.191869388323E-02
+ -0.195581986337E-02 -0.199341283086E-02 -0.203147865970E-02 -0.207002329773E-02
+ -0.210905276765E-02 -0.214857316788E-02 -0.218859067357E-02 -0.222911153753E-02
+ -0.227014209125E-02 -0.231168874582E-02 -0.235375799299E-02 -0.239635640618E-02
+ -0.243949064147E-02 -0.248316743868E-02 -0.252739362239E-02 -0.257217610304E-02
+ -0.261752187799E-02 -0.266343803260E-02 -0.270993174137E-02 -0.275701026904E-02
+ -0.280468097172E-02 -0.285295129807E-02 -0.290182879042E-02 -0.295132108598E-02
+ -0.300143591803E-02 -0.305218111711E-02 -0.310356461227E-02 -0.315559443228E-02
+ -0.320827870691E-02 -0.326162566819E-02 -0.331564365170E-02 -0.337034109785E-02
+ -0.342572655324E-02 -0.348180867196E-02 -0.353859621696E-02 -0.359609806142E-02
+ -0.365432319011E-02 -0.371328070083E-02 -0.377297980583E-02 -0.383342983321E-02
+ -0.389464022841E-02 -0.395662055570E-02 -0.401938049962E-02 -0.408292986655E-02
+ -0.414727858621E-02 -0.421243671323E-02 -0.427841442870E-02 -0.434522204179E-02
+ -0.441286999131E-02 -0.448136884742E-02 -0.455072931319E-02 -0.462096222636E-02
+ -0.469207856096E-02 -0.476408942908E-02 -0.483700608256E-02 -0.491083991479E-02
+ -0.498560246247E-02 -0.506130540740E-02 -0.513796057833E-02 -0.521557995280E-02
+ -0.529417565901E-02 -0.537375997769E-02 -0.545434534408E-02 -0.553594434981E-02
+ -0.561856974491E-02 -0.570223443977E-02 -0.578695150719E-02 -0.587273418438E-02
+ -0.595959587509E-02 -0.604755015164E-02 -0.613661075709E-02 -0.622679160734E-02
+ -0.631810679335E-02 -0.641057058334E-02 -0.650419742495E-02 -0.659900194761E-02
+ -0.669499896473E-02 -0.679220347605E-02 -0.689063067000E-02 -0.699029592604E-02
+ -0.709121481711E-02 -0.719340311200E-02 -0.729687677786E-02 -0.740165198270E-02
+ -0.750774509786E-02 -0.761517270066E-02 -0.772395157689E-02 -0.783409872350E-02
+ -0.794563135124E-02 -0.805856688733E-02 -0.817292297823E-02 -0.828871749232E-02
+ -0.840596852279E-02 -0.852469439036E-02 -0.864491364624E-02 -0.876664507497E-02
+ -0.888990769738E-02 -0.901472077353E-02 -0.914110380577E-02 -0.926907654176E-02
+ -0.939865897753E-02 -0.952987136066E-02 -0.966273419339E-02 -0.979726823587E-02
+ -0.993349450938E-02 -0.100714342996E-01 -0.102111091599E-01 -0.103525409150E-01
+ -0.104957516637E-01 -0.106407637833E-01 -0.107875999322E-01 -0.109362830538E-01
+ -0.110868363804E-01 -0.112392834362E-01 -0.113936480416E-01 -0.115499543163E-01
+ -0.117082266836E-01 -0.118684898741E-01 -0.120307689291E-01 -0.121950892054E-01
+ -0.123614763783E-01 -0.125299564463E-01 -0.127005557348E-01 -0.128733009005E-01
+ -0.130482189352E-01 -0.132253371704E-01 -0.134046832813E-01 -0.135862852912E-01
+ -0.137701715759E-01 -0.139563708682E-01 -0.141449122622E-01 -0.143358252181E-01
+ -0.145291395665E-01 -0.147248855135E-01 -0.149230936448E-01 -0.151237949310E-01
+ -0.153270207324E-01 -0.155328028036E-01 -0.157411732986E-01 -0.159521647760E-01
+ -0.161658102038E-01 -0.163821429647E-01 -0.166011968615E-01 -0.168230061221E-01
+ -0.170476054047E-01 -0.172750298037E-01 -0.175053148551E-01 -0.177384965414E-01
+ -0.179746112983E-01 -0.182136960192E-01 -0.184557880622E-01 -0.187009252548E-01
+ -0.189491459005E-01 -0.192004887848E-01 -0.194549931808E-01 -0.197126988557E-01
+ -0.199736460770E-01 -0.202378756186E-01 -0.205054287673E-01 -0.207763473293E-01
+ -0.210506736367E-01 -0.213284505539E-01 -0.216097214847E-01 -0.218945303788E-01
+ -0.221829217386E-01 -0.224749406264E-01 -0.227706326714E-01 -0.230700440766E-01
+ -0.233732216263E-01 -0.236802126934E-01 -0.239910652463E-01 -0.243058278572E-01
+ -0.246245497091E-01 -0.249472806037E-01 -0.252740709691E-01 -0.256049718679E-01
+ -0.259400350047E-01 -0.262793127347E-01 -0.266228580718E-01 -0.269707246964E-01
+ -0.273229669646E-01 -0.276796399158E-01 -0.280407992820E-01 -0.284065014961E-01
+ -0.287768037011E-01 -0.291517637586E-01 -0.295314402581E-01 -0.299158925261E-01
+ -0.303051806354E-01 -0.306993654145E-01 -0.310985084569E-01 -0.315026721310E-01
+ -0.319119195898E-01 -0.323263147807E-01 -0.327459224553E-01 -0.331708081801E-01
+ -0.336010383460E-01 -0.340366801793E-01 -0.344778017519E-01 -0.349244719918E-01
+ -0.353767606943E-01 -0.358347385327E-01 -0.362984770691E-01 -0.367680487660E-01
+ -0.372435269974E-01 -0.377249860601E-01 -0.382125011860E-01 -0.387061485527E-01
+ -0.392060052967E-01 -0.397121495245E-01 -0.402246603252E-01 -0.407436177829E-01
+ -0.412691029889E-01 -0.418011980549E-01 -0.423399861253E-01 -0.428855513905E-01
+ -0.434379791002E-01 -0.439973555761E-01 -0.445637682262E-01 -0.451373055578E-01
+ -0.457180571919E-01 -0.463061138766E-01 -0.469015675018E-01 -0.475045111133E-01
+ -0.481150389275E-01 -0.487332463460E-01 -0.493592299705E-01 -0.499930876181E-01
+ -0.506349183362E-01 -0.512848224186E-01 -0.519429014205E-01 -0.526092581748E-01
+ -0.532839968083E-01 -0.539672227573E-01 -0.546590427850E-01 -0.553595649974E-01
+ -0.560688988608E-01 -0.567871552183E-01 -0.575144463078E-01 -0.582508857792E-01
+ -0.589965887120E-01 -0.597516716337E-01 -0.605162525377E-01 -0.612904509020E-01
+ -0.620743877075E-01 -0.628681854575E-01 -0.636719681963E-01 -0.644858615289E-01
+ -0.653099926406E-01 -0.661444903169E-01 -0.669894849634E-01 -0.678451086265E-01
+ -0.687114950142E-01 -0.695887795165E-01 -0.704770992268E-01 -0.713765929636E-01
+ -0.722874012918E-01 -0.732096665451E-01 -0.741435328478E-01 -0.750891461379E-01
+ -0.760466541893E-01 -0.770162066355E-01 -0.779979549927E-01 -0.789920526836E-01
+ -0.799986550611E-01 -0.810179194332E-01 -0.820500050872E-01 -0.830950733147E-01
+ -0.841532874368E-01 -0.852248128297E-01 -0.863098169507E-01 -0.874084693642E-01
+ -0.885209417683E-01 -0.896474080219E-01 -0.907880441716E-01 -0.919430284792E-01
+ -0.931125414500E-01 -0.942967658608E-01 -0.954958867886E-01 -0.967100916392E-01
+ -0.979395701773E-01 -0.991845145555E-01 -0.100445119345     -0.101721581564
+ -0.103014100714     -0.104322878803     -0.105648120385     -0.106990032586
+ -0.108348825140     -0.109724710421     -0.111117903475     -0.112528622057
+ -0.113957086659     -0.115403520553     -0.116868149817     -0.118351203379
+ -0.119852913045     -0.121373513540     -0.122913242546     -0.124472340735
+ -0.126051051808     -0.127649622537     -0.129268302797     -0.130907345612
+ -0.132567007189     -0.134247546963     -0.135949227633     -0.137672315208
+ -0.139417079045     -0.141183791892     -0.142972729933     -0.144784172829
+ -0.146618403761     -0.148475709479     -0.150356380341     -0.152260710364
+ -0.154188997267     -0.156141542518     -0.158118651382     -0.160120632969
+ -0.162147800284     -0.164200470270     -0.166278963868     -0.168383606058
+ -0.170514725914     -0.172672656657     -0.174857735706     -0.177070304729
+ -0.179310709700     -0.181579300953     -0.183876433235     -0.186202465763
+ -0.188557762280     -0.190942691115     -0.193357625236     -0.195802942314
+ -0.198279024778     -0.200786259878     -0.203325039745     -0.205895761453
+ -0.208498827081     -0.211134643778     -0.213803623826     -0.216506184703
+ -0.219242749152     -0.222013745248     -0.224819606463     -0.227660771735
+ -0.230537685538     -0.233450797952     -0.236400564735     -0.239387447393
+ -0.242411913255     -0.245474435543     -0.248575493453     -0.251715572226
+ -0.254895163226     -0.258114764017     -0.261374878445     -0.264676016714
+ -0.268018695467     -0.271403437870     -0.274830773695     -0.278301239402
+ -0.281815378224     -0.285373740255     -0.288976882537     -0.292625369145
+ -0.296319771283     -0.300060667368     -0.303848643127     -0.307684291686
+ -0.311568213668     -0.315501017286     -0.319483318441     -0.323515740819
+ -0.327598915991     -0.331733483515     -0.335920091035     -0.340159394385
+ -0.344452057697     -0.348798753501     -0.353200162838     -0.357656975366
+ -0.362169889470     -0.366739612376     -0.371366860259     -0.376052358364
+ -0.380796841117     -0.385601052247     -0.390465744901     -0.395391681767
+ -0.400379635196     -0.405430387325     -0.410544730205     -0.415723465925
+ -0.420967406744     -0.426277375219     -0.431654204339     -0.437098737659
+ -0.442611829433     -0.448194344758     -0.453847159705     -0.459571161469
+ -0.465367248505     -0.471236330677     -0.477179329406     -0.483197177813
+ -0.489290820877     -0.495461215584     -0.501709331082     -0.508036148841
+ -0.514442662807     -0.520929879567     -0.527498818513     -0.534150512003
+ -0.540886005532     -0.547706357904     -0.554612641397     -0.561605941944
+ -0.568687359308     -0.575858007259     -0.583119013758     -0.590471521137
+ -0.597916686290     -0.605455680858     -0.613089691421     -0.620819919692
+ -0.628647582712     -0.636573913050     -0.644600159002     -0.652727584799
+ -0.660957470807     -0.669291113741     -0.677729826875     -0.686274940258
+ -0.694927800926     -0.703689773129     -0.712562238549     -0.721546596525
+ -0.730644264284     -0.739856677171     -0.749185288880     -0.758631571696
+ -0.768197016731     -0.777883134165     -0.787691453495     -0.797623523782
+ -0.807680913901     -0.817865212796     -0.828178029737     -0.838620994577
+ -0.849195758021     -0.859903991885     -0.870747389368     -0.881727665322
+ -0.892846556527     -0.904105821968     -0.915507243113     -0.927052624199
+ -0.938743792513     -0.950582598682     -0.962570916965     -0.974710645542
+ -0.987003706815     -0.999452047699      -1.01205763993      -1.02482248036
+  -1.03774859126      -1.05083802065      -1.06409284257      -1.07751515742
+  -1.09110709226      -1.10487080112      -1.11880846533      -1.13292229381
+  -1.14721452343      -1.16168741928      -1.17634327500      -1.19118441314
+  -1.20621318543      -1.22143197310      -1.23684318723      -1.25244926905
+  -1.26825269027      -1.28425595334      -1.30046159183      -1.31687217073
+  -1.33349028671      -1.35031856847      -1.36735967702      -1.38461630600
+  -1.40209118193      -1.41978706454      -1.43770674703      -1.45585305635
+  -1.47422885344      -1.49283703355      -1.51168052643      -1.53076229660
+  -1.55008534358      -1.56965270210      -1.58946744233      -1.60953267004
+  -1.62985152681      -1.65042719019      -1.67126287383      -1.69236182766
+  -1.71372733795      -1.73536272743      -1.75727135537      -1.77945661762
+  -1.80192194664      -1.82467081152      -1.84770671791      -1.87103320803
+  -1.89465386053      -1.91857229043      -1.94279214891      -1.96731712320
+  -1.99215093629      -2.01729734673      -2.04276014829      -2.06854316963
+  -2.09465027394      -2.12108535846      -2.14785235400      -2.17495522445
+  -2.20239796612      -2.23018460716      -2.25831920680      -2.28680585458
+  -2.31564866955      -2.34485179932      -2.37441941912      -2.40435573074
+  -2.43466496136      -2.46535136241      -2.49641920822      -2.52787279464
+  -2.55971643761      -2.59195447152      -2.62459124759      -2.65763113206
+  -2.69107850432      -2.72493775488      -2.75921328325      -2.79390949573
+  -2.82903080294      -2.86458161736      -2.90056635064      -2.93698941075
+  -2.97385519901      -3.01116810691      -3.04893251276      -3.08715277819
+  -3.12583324435      -3.16497822797      -3.20459201720      -3.24467886713
+  -3.28524299513      -3.32628857587      -3.36781973605      -3.40984054885
+  -3.45235502798      -3.49536712145      -3.53888070491      -3.58289957459
+  -3.62742743983      -3.67246791512      -3.71802451169      -3.76410062849
+  -3.81069954274      -3.85782439977      -3.90547820231      -3.95366379904
+  -4.00238387252      -4.05164092628      -4.10143727119      -4.15177501094
+  -4.20265602674      -4.25408196094      -4.30605419987      -4.35857385557
+  -4.41164174646      -4.46525837706      -4.51942391641      -4.57413817552
+  -4.62940058349      -4.68521016255      -4.74156550181      -4.79846472979
+  -4.85590548572      -4.91388488957      -4.97239951097      -5.03144533675
+  -5.09101773747      -5.15111143279      -5.21172045569      -5.27283811587
+  -5.33445696212      -5.39656874398      -5.45916437271      -5.52223388177
+  -5.58576638694      -5.64975004635      -5.71417202043      -5.77901843230
+  -5.84427432866      -5.90992364147      -5.97594915087      -6.04233244959
+  -6.10905390914      -6.17609264845      -6.24334845947      -6.31074142356
+  -6.37827726278      -6.44595779867      -6.51378085888      -6.58174020759
+  -6.64982549603      -6.71802222992      -6.78631175108      -6.85467123081
+  -6.92307367331      -6.99148792758      -7.05987870671      -7.12820661392
+  -7.19642817478      -7.26449587552      -7.33235820758      -7.39995971849
+  -7.46724106990      -7.53413910310      -7.60058691319      -7.66651393253
+  -7.73184602498      -7.79650559169      -7.86041169023      -7.92348016806
+  -7.98562381212      -8.04675251596      -8.10677346609      -8.16559134909
+  -8.22310858130      -8.27922556253      -8.33384095563      -8.38685199319
+  -8.43815481299      -8.48764482337      -8.53521709944      -8.58076681113
+  -8.62418968327      -8.66538248788      -8.70424356827      -8.74067339395
+  -8.77457514512      -8.80585532469      -8.83442439556      -8.86019744043
+  -8.88309484122      -8.90304297536      -8.91997492673      -8.93383120995
+  -8.94456050763      -8.95212043711      -8.95647829751      -8.95761195053
+  -8.95538442737      -8.94992704541      -8.94125392403      -8.92939516188
+  -8.91439674788      -8.89632118986      -8.87524846794      -8.85127686218
+  -8.82452372358      -8.79512616607      -8.76324166100      -8.72904851170
+  -8.69274618244      -8.65455545308      -8.61471836670      -8.57349793317
+  -8.53117754765      -8.48806007793      -8.44446657002      -8.40073451667
+  -8.35721562906      -8.31427304853      -8.27227793241      -8.23160534783
+  -8.19262940929      -8.15571760147      -8.12122424007      -8.08948304084
+  -8.06079879354      -8.03543817487      -8.01361978627      -7.99550357056
+  -7.98117985148      -7.97065835466      -7.96385771332      -7.96059614238
+  -7.96058418589      -7.96342071260      -7.96859366058      -7.97548742218
+  -7.98339922844      -7.99156744809      -7.99921537953      -8.00561490420
+  -8.01017531459      -8.01256376261      -8.01286513521      -8.01179080103
+  -8.01053777272      -8.00940346646      -8.00837876356      -8.00745446442
+  -8.00662199849      -8.00587339484      -8.00520125283      -8.00459871312
+  -8.00405942905      -8.00357753854      -8.00314763656      -8.00276474830
+  -8.00242430304      -8.00212210892      -8.00185432842      -8.00161745483
+  -8.00140828967      -8.00122392094      -8.00106170251      -8.00075416982
+  -8.00053335099      -8.00037549577      -8.00026315641      -8.00018357236
+  -8.00012745318      -8.00008806588      -8.00006055352      -8.00004142896
+  -8.00002820047      -8.00001909619      -8.00001286237      -8.00000861626
+  -8.00000573947      -8.00000380105      -8.00000250222      -8.00000163695
+  -8.00000106393      -8.00000068678      -8.00000044013      -8.00000027989
+  -8.00000017651      -8.00000011032      -8.00000006826      -8.00000004176
+  -8.00000002523      -8.00000001501      -8.00000000877      -8.00000000500
+  -8.00000000277      -8.00000000147      -8.00000000073      -8.00000000032
+  -8.00000000011      -8.00000000000      -7.99999999996      -7.99999999994
+  -7.99999999994      -7.99999999995      -7.99999999996      -7.99999999997
+  -7.99999999998      -7.99999999998      -7.99999999999      -7.99999999999
+  -7.99999999999      -8.00000000000      -8.00000000000      -8.00000000000
+  -8.00000000000      -8.00000000000      -8.00000000000      -8.00000000000
+  -8.0000000000
