[Swift-commit] r8377 - in SwiftApps/subjobs: . gridpack gridpack/infiles gridpack/logs
ketan at ci.uchicago.edu
Wed Jan 28 13:16:07 CST 2015
Author: ketan
Date: 2015-01-28 13:15:58 -0600 (Wed, 28 Jan 2015)
New Revision: 8377
Added:
SwiftApps/subjobs/gridpack/
SwiftApps/subjobs/gridpack/CTG1.out
SwiftApps/subjobs/gridpack/CTG2.out
SwiftApps/subjobs/gridpack/IEEE14_ca.raw
SwiftApps/subjobs/gridpack/apps
SwiftApps/subjobs/gridpack/bgsh-cagfy8zl-ca.2.stderr
SwiftApps/subjobs/gridpack/cf
SwiftApps/subjobs/gridpack/cobalt.xml
SwiftApps/subjobs/gridpack/contan.swift
SwiftApps/subjobs/gridpack/contingencies.xml
SwiftApps/subjobs/gridpack/infiles/
SwiftApps/subjobs/gridpack/infiles/input1.xml
SwiftApps/subjobs/gridpack/infiles/input2.xml
SwiftApps/subjobs/gridpack/infiles/input3.xml
SwiftApps/subjobs/gridpack/logs/
SwiftApps/subjobs/gridpack/logs/ca.0.stderr
SwiftApps/subjobs/gridpack/logs/ca.0.stdout
SwiftApps/subjobs/gridpack/logs/ca.1.stderr
SwiftApps/subjobs/gridpack/logs/ca.1.stdout
SwiftApps/subjobs/gridpack/logs/ca.2.stderr
SwiftApps/subjobs/gridpack/logs/ca.2.stdout
SwiftApps/subjobs/gridpack/runswift.sh
SwiftApps/subjobs/gridpack/runvesta.sh
Log:
gridpack swift scripts
Added: SwiftApps/subjobs/gridpack/CTG1.out
--- SwiftApps/subjobs/gridpack/CTG1.out (rev 0)
+++ SwiftApps/subjobs/gridpack/CTG1.out 2015-01-28 19:15:58 UTC (rev 8377)
@@ -0,0 +1,20 @@
+Maximum voltage limit: 1.100000
+Minimum voltage limit: 0.900000
+Maximum number of iterations: 50
+Convergence tolerance: 0.000001
+Isolated bus found for contingency CTG1
+Iteration 1 Tol: 2.451351e-04
+Iteration 2 Tol: 1.737733e-08
+ No violations found for contingency CTG1
+Contingency evaluation converged
+Elapsed time for task: 0.038195
Added: SwiftApps/subjobs/gridpack/CTG2.out
--- SwiftApps/subjobs/gridpack/CTG2.out (rev 0)
+++ SwiftApps/subjobs/gridpack/CTG2.out 2015-01-28 19:15:58 UTC (rev 8377)
@@ -0,0 +1,22 @@
+Isolated bus found for contingency CTG2
+Iteration 1 Tol: 9.887566e-03
+Iteration 2 Tol: 6.336545e-06
+Iteration 3 Tol: 2.715800e-12
+ No violations found for contingency CTG2
+Elapsed time for task: 0.035893
Added: SwiftApps/subjobs/gridpack/IEEE14_ca.raw
--- SwiftApps/subjobs/gridpack/IEEE14_ca.raw (rev 0)
+++ SwiftApps/subjobs/gridpack/IEEE14_ca.raw 2015-01-28 19:15:58 UTC (rev 8377)
@@ -0,0 +1,61 @@
+0 100.000
+ 1, 3, 0.000, 0.000, 0.000, 0.000, 1,1.06000, 0.0000,'BUS-1 ',100.0000, 2
+ 2, 2, 21.700, 12.700, 0.000, 0.000, 1,1.04500, -4.9800,'BUS-2 ',100.0000, 2
+ 3, 2, 94.200, 19.000, 0.000, 0.000, 1,1.01000, -12.7200,'BUS-3 ',100.0000, 2
+ 4, 1, 47.800, -3.900, 0.000, 0.000, 1,1.01900, -10.3300,'BUS-4 ',100.0000, 2
+ 5, 1, 7.600, 1.600, 0.000, 0.000, 1,1.02000, -8.7800,'BUS-5 ',100.0000, 2
+ 6, 2, 11.200, 7.500, 0.000, 0.000, 1,1.07000, -14.2200,'BUS-6 ',100.0000, 2
+ 7, 1, 0.000, 0.000, 0.000, 0.000, 1,1.06200, -13.3700,'BUS-7 ',100.0000, 2
+ 8, 2, 0.000, 0.000, 0.000, 0.000, 1,1.09000, -13.3600,'BUS-8 ',100.0000, 2
+ 9, 1, 29.500, 16.600, 0.000, 19.000, 1,1.05600, -14.9400,'BUS-9 ',100.0000, 2
+ 10, 1, 9.000, 5.800, 0.000, 0.000, 1,1.05100, -15.1000,'BUS-10 ',100.0000, 2
+ 11, 1, 3.500, 1.800, 0.000, 0.000, 1,1.05700, -14.7900,'BUS-11 ',100.0000, 2
+ 12, 1, 6.100, 1.600, 0.000, 0.000, 1,1.05500, -15.0700,'BUS-12 ',100.0000, 2
+ 13, 1, 13.500, 5.800, 0.000, 0.000, 1,1.05000, -15.1600,'BUS-13 ',100.0000, 2
+ 14, 1, 14.900, 5.000, 0.000, 0.000, 1,1.03600, -16.0400,'BUS-14 ',100.0000, 2
+0
+ 1,'1 ', 232.400, -16.900, 99990.000, -9999.000,1.06000, 0, 100.000, 0.00000, 1.00000, 0.00000, 0.00000, 1.00000,1, 100.0, 0.000, 0.000
+ 2,'1 ', 40.000, 42.400, 50.000, -40.000,1.04500, 0, 100.000, 0.00000, 1.00000, 0.00000, 0.00000, 1.00000,1, 100.0, 0.000, 0.000
+ 3,'1 ', 0.000, 23.400, 40.000, 0.000,1.01000, 0, 100.000, 0.00000, 1.00000, 0.00000, 0.00000, 1.00000,1, 100.0, 0.000, 0.000
+ 6,'1 ', 0.000, 12.200, 24.000, -6.000,1.07000, 0, 100.000, 0.00000, 1.00000, 0.00000, 0.00000, 1.00000,1, 100.0, 0.000, 0.000
+ 8,'1 ', 0.000, 17.400, 24.000, -6.000,1.09000, 0, 100.000, 0.00000, 1.00000, 0.00000, 0.00000, 1.00000,1, 100.0, 0.000, 0.000
+0 / END OF GENERATOR DATA, BEGIN BRANCH DATA
+ 1, 2,'BL', 0.01938, 0.05917, 0.05280, 0.00, 0.00, 0.00,0.00000,000.000, 0.00000, 0.00000, 0.00000, 0.00000, 1
+ 1, 5,'BL', 0.05403, 0.22304, 0.04920, 0.00, 0.00, 0.00,0.00000,000.000, 0.00000, 0.00000, 0.00000, 0.00000, 1
+ 2, 3,'BL', 0.04699, 0.19797, 0.04380, 0.00, 0.00, 0.00,0.00000,000.000, 0.00000, 0.00000, 0.00000, 0.00000, 1
+ 2, 4,'BL', 0.05811, 0.17632, 0.03400, 0.00, 0.00, 0.00,0.00000,000.000, 0.00000, 0.00000, 0.00000, 0.00000, 1
+ 2, 5,'BL', 0.05695, 0.17388, 0.03460, 0.00, 0.00, 0.00,0.00000,000.000, 0.00000, 0.00000, 0.00000, 0.00000, 1
+ 3, 4,'BL', 0.06701, 0.17103, 0.01280, 0.00, 0.00, 0.00,0.00000,000.000, 0.00000, 0.00000, 0.00000, 0.00000, 1
+ 4, 5,'BL', 0.01335, 0.04211, 0.00000, 0.00, 0.00, 0.00,0.00000,000.000, 0.00000, 0.00000, 0.00000, 0.00000, 1
+ 4, 7,'BL', 0.00000, 0.20912, 0.00000, 0.00, 0.00, 0.00,0.97800, 0.000, 0.00000, 0.00000, 0.00000, 0.00000, 1
+ 4, 9,'BL', 0.00000, 0.55618, 0.00000, 0.00, 0.00, 0.00,0.96900, 0.000, 0.00000, 0.00000, 0.00000, 0.00000, 1
+ 5, 6,'BL', 0.00000, 0.25202, 0.00000, 0.00, 0.00, 0.00,0.93200, 0.000, 0.00000, 0.00000, 0.00000, 0.00000, 1
+ 6, 11,'BL', 0.09498, 0.19890, 0.00000, 0.00, 0.00, 0.00,0.00000,000.000, 0.00000, 0.00000, 0.00000, 0.00000, 1
+ 6, 12,'BL', 0.12291, 0.25581, 0.00000, 0.00, 0.00, 0.00,0.00000,000.000, 0.00000, 0.00000, 0.00000, 0.00000, 1
+ 6, 13,'BL', 0.06615, 0.13027, 0.00000, 0.00, 0.00, 0.00,0.00000,000.000, 0.00000, 0.00000, 0.00000, 0.00000, 1
+ 7, 8,'BL', 0.00000, 0.17615, 0.00000, 0.00, 0.00, 0.00,0.00000,000.000, 0.00000, 0.00000, 0.00000, 0.00000, 1
+ 7, 9,'BL', 0.00000, 0.11001, 0.00000, 0.00, 0.00, 0.00,0.00000,000.000, 0.00000, 0.00000, 0.00000, 0.00000, 1
+ 9, 10,'BL', 0.03181, 0.08450, 0.00000, 0.00, 0.00, 0.00,0.00000,000.000, 0.00000, 0.00000, 0.00000, 0.00000, 1
+ 9, 14,'BL', 0.12711, 0.27038, 0.00000, 0.00, 0.00, 0.00,0.00000,000.000, 0.00000, 0.00000, 0.00000, 0.00000, 1
+ 10, 11,'BL', 0.08205, 0.19207, 0.00000, 0.00, 0.00, 0.00,0.00000,000.000, 0.00000, 0.00000, 0.00000, 0.00000, 1
+ 12, 13,'BL', 0.22092, 0.19988, 0.00000, 0.00, 0.00, 0.00,0.00000,000.000, 0.00000, 0.00000, 0.00000, 0.00000, 1
+ 13, 14,'B1', 0.17093, 0.34802, 0.00000, 0.00, 0.00, 0.00,0.00000,000.000, 0.00000, 0.00000, 0.00000, 0.00000, 1
+ 13, 14,'B2', 0.17093, 0.34802, 0.00000, 0.00, 0.00, 0.00,0.00000,000.000, 0.00000, 0.00000, 0.00000, 0.00000, 1
+ 13, 14,'B3', 0.17093, 0.34802, 0.00000, 0.00, 0.00, 0.00,0.00000,000.000, 0.00000, 0.00000, 0.00000, 0.00000, 1
+0 / END OF BRANCH DATA, BEGIN TRANSFORMER ADJUSTMENT DATA
+0 / END OF TRANSFORMER ADJUSTMENT DATA, BEGIN AREA DATA
+ 1, 0, 0.0, 3.000,' '
+0 / END OF AREA DATA, BEGIN TWO-TERMINAL DC DATA
+0 / END OF TWO-TERMINAL DC DATA, BEGIN SWITCHED SHUNT DATA
+0 / END OF SWITCHED SHUNT DATA, BEGIN IMPEDANCE CORRECTION DATA
+0 / END OF IMPEDANCE CORRECTION DATA, BEGIN MULTI-TERMINAL DC DATA
+0 / END OF MULTI-TERMINAL DC DATA, BEGIN MULTI-SECTION LINE DATA
+0 / END OF MULTI-SECTION LINE DATA, BEGIN ZONE DATA
+ 2,'ZONE_2 '
+0 / END OF ZONE DATA, BEGIN INTER-AREA TRANSFER DATA
+ 2, 1,'1 ', 0.00
+0 / END OF INTER-AREA TRANSFER DATA, BEGIN OWNER DATA
+ 1,'OWNER_1 '
+0 / END OF OWNER DATA, BEGIN FACTS DEVICE DATA
Added: SwiftApps/subjobs/gridpack/apps
--- SwiftApps/subjobs/gridpack/apps (rev 0)
+++ SwiftApps/subjobs/gridpack/apps 2015-01-28 19:15:58 UTC (rev 8377)
@@ -0,0 +1,3 @@
+localhost cat /bin/cat null null null
+cluster bgsh /home/ketan/SwiftApps/subjobs/bg.sh null null null
Added: SwiftApps/subjobs/gridpack/bgsh-cagfy8zl-ca.2.stderr
--- SwiftApps/subjobs/gridpack/bgsh-cagfy8zl-ca.2.stderr (rev 0)
+++ SwiftApps/subjobs/gridpack/bgsh-cagfy8zl-ca.2.stderr 2015-01-28 19:15:58 UTC (rev 8377)
@@ -0,0 +1,598 @@
+2014-10-23 20:38:23.702 (INFO ) [0xfff7ec1bdd0] ibm.runjob.AbstractOptions: using properties file /bgsys/local/etc/bg.properties
+2014-10-23 20:38:23.703 (INFO ) [0xfff7ec1bdd0] ibm.runjob.AbstractOptions: max open file descriptors: 65536
+2014-10-23 20:38:23.703 (INFO ) [0xfff7ec1bdd0] ibm.runjob.AbstractOptions: core file limit: 18446744073709551615
+2014-10-23 20:38:23.704 (INFO ) [0xfff7ec1bdd0] 24459:tatu.runjob.client: scheduler job id is 222728
+2014-10-23 20:38:23.709 (INFO ) [0xfff8fba34d0] 24459:tatu.runjob.monitor: monitor started
+2014-10-23 20:38:27.397 (INFO ) [0xfff8fba34d0] 24459:tatu.runjob.monitor: task record 787265 created
+2014-10-23 20:38:27.398 (INFO ) [0xfff7ec1bdd0] VST-20020-31331-64:24459:ibm.runjob.client.options.Parser: set local socket to runjob_mux from properties file
+2014-10-23 20:38:30.678 (INFO ) [0xfff7ec1bdd0] VST-20020-31331-64:985588:ibm.runjob.client.Job: job 985588 started
+(I) sc_uname[0.0:1]: name=0x1fbfffb8d0
+(I) sc_brk[0]: brk_val=r3=0x00000000
+(I) sc_brk[0]: brk_val=0x00000000, returning 0x1f83200000.
+(I) sc_brk[0]: brk_val=r3=0x1f83216ad0
+(I) sc_brk[0]: brk_val=0x1f83216ad0, returning 0x1f83216ad0.
+(I) sc_set_tid_address[ 0]: Entry: tid_addr=0x1f832000d0. Returning PID=1.
+(I) sc_futex[0]: op(129)=WAKE, uaddr=1fbfffb9b0, val=1 timeout=0 *uaddr=0 uaddr2=0x00000000 val3=0x00000000.
+(I) sc_futex[0]: op(393)=Other, uaddr=1fbfffb9b0, val=1 timeout=0 *uaddr=0 uaddr2=0x00000000 val3=0x00000000.
+(I) sc_rt_sigaction[0]: sig=32, act=0x1fbfffb7b0, oldact=0x00000000, sigsetsize=8.
+(I) sc_rt_sigaction[0]: act{ sa_handler:2ee6460, flags=4 }
+(I) sc_rt_sigaction[0]: sig=33, act=0x1fbfffb7b0, oldact=0x00000000, sigsetsize=8.
+(I) sc_rt_sigaction[0]: act{ sa_handler:2ee6430, flags=10000004 }
+(I) sc_rt_sigprocmask[0]: how=1 set=1fbfffb9d8 oldset=0
+(I) sc_ugetrlimit[0]: resource=3, rlp=0x0000001fbfffb9c0
+(I) sc_brk[0]: brk_val=r3=0x1f83237ad0
+(I) sc_brk[0]: brk_val=0x1f83237ad0, returning 0x1f83237ad0.
+(I) sc_brk[0]: brk_val=r3=0x1f83238000
+(I) sc_brk[0]: brk_val=0x1f83238000, returning 0x1f83238000.
+(I) sc_GET_PERSONALITY[0]: dst=0x000000000302f638, size=176.
+(I) sc_statfs[0.0:1]: pathname="/dev/shm/", buf=0x1fbfffabd8
+(I) sc_futex[0]: op(129)=WAKE, uaddr=3061f30, val=2147483647 timeout=0 *uaddr=2 uaddr2=0x00000000 val3=0x00000000.
+(I) sc_open[0.0:1]: pathname="/dev/shm/job0-pami-global-shmem", flags=0x000880c2 mode=(I) sc_fcntl[0.0:1]: fd=3, cmd=1, parm3=0x0
+(I) sc_ftruncate[0.0:1]: fd=3, len=389256
+(I) sc_mmap[0]: Entry: addr=0x0000000000000000, len=0x0005f088, prot=0x00000003(RW--), flags=0x00000001=(Shared ), filedes=0x00000003, off=0x00000000, MMap_Start=0x0000000000000000, MMap_End=0x0000000000000000.
+(I) sc_mmap[0]: Returning 0x31c1000000 for len=0x0005f088 fd=0x3.
+(I) sc_close[0.0:1]: fd=3
+(I) sc_open[0.0:1]: pathname="/dev/shm/job0-pami-global-shmem-a", flags=0x000880c2 mode=(I) sc_ftruncate[0.0:1]: fd=3, len=217984
+(I) sc_mmap[0]: Entry: addr=0x0000000000000000, len=0x00035380, prot=0x00000003(RW--), flags=0x00000001=(Shared ), filedes=0x00000003, off=0x00000000, MMap_Start=0x0000000000000000, MMap_End=0x0000000000000000.
+(I) sc_mmap[0]: Returning 0x31c3010000 for len=0x00035380 fd=0x3.
+(I) sc_open[0.0:1]: pathname="/dev/shm/unique-comm-agent-shmem-file", flags=0x00088042 mode=(I) sc_ioctl[0.0:1]: fd=3, cmd=3221529856
+(I) sc_ftruncate[0.0:1]: fd=3, len=65536
+(I) sc_mmap[0]: Entry: addr=0x0000000000000000, len=0x00010000, prot=0x00000003(RW--), flags=0x00000001=(Shared ), filedes=0x00000003, off=0x00000000, MMap_Start=0x0000000000000000, MMap_End=0x0000000000000000.
+(I) sc_mmap[0]: Returning 0x31c3000000 for len=0x00010000 fd=0x3.
+(I) sc_open[0.0:1]: pathname="/dev/shm/job0-L2AtomicFactory-shared", flags=0x000880c2 mode=(I) sc_ioctl[0.0:1]: fd=4, cmd=3221529856
+(I) sc_ftruncate[0.0:1]: fd=4, len=98440
+(I) sc_mmap[0]: Entry: addr=0x0000000000000000, len=0x00018088, prot=0x00000003(RW--), flags=0x00000001=(Shared ), filedes=0x00000004, off=0x00000000, MMap_Start=0x0000000000000000, MMap_End=0x0000000000000000.
+(I) sc_mmap[0]: Returning 0x31c3045380 for len=0x00018088 fd=0x4.
+(I) sc_close[0.0:1]: fd=4
+(I) sc_open[0.0:1]: pathname="/dev/shm/job0-unique-pami-globalRM-shmem-file", flags=0x000880c2 mode=(I) sc_ftruncate[0.0:1]: fd=4, len=657988
+(I) sc_mmap[0]: Entry: addr=0x0000000000000000, len=0x000a0a44, prot=0x00000003(RW--), flags=0x00000001=(Shared ), filedes=0x00000004, off=0x00000000, MMap_Start=0x0000000000000000, MMap_End=0x0000000000000000.
+(I) sc_mmap[0]: Returning 0x31c1060000 for len=0x000a0a44 fd=0x4.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=64, nfifos=1fbfffb1b0, fifoids=1fbfffb1e0.
+(I) sc_ALLOCATE_INJ_FIFOS[0]: subgrpid=64, sg_ptr=1f832207c0, nfifos=1, fifoids=1fbfffb1e0, fifoAttrs=1f83220720.
+(I) sc_brk[0]: brk_val=r3=0x1f83271000
+(I) sc_brk[0]: brk_val=0x1f83271000, returning 0x1f83271000.
+(I) sc_ALLOCATE_INJ_FIFOS[0]: subgrpid=64, sg_ptr=31c1060080, nfifos=6, fifoids=1fbfffb1e0, fifoAttrs=1f83220300.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=65, nfifos=1fbfffb1b0, fifoids=1fbfffb1e0.
+(I) sc_ALLOCATE_INJ_FIFOS[0]: subgrpid=65, sg_ptr=31c1060350, nfifos=4, fifoids=1fbfffb1e0, fifoAttrs=1f83220300.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=64, nbatids=1fbfffb330, batids=1fbfffb358.
+(I) sc_ALLOCATE_BASE_ADDRESS_TABLE[0]: subgrpid=64, sg_ptr=31c1100680, nbatids=7, batids=1fbfffb358, system=0.
+(I) sc_CFG_REC_FIFO_THRESH[0]: threshold=21845.
+(I) sc_futex[0]: op(129)=WAKE, uaddr=3066fe4, val=2147483647 timeout=0 *uaddr=2 uaddr2=0x029d93e8 val3=0x029d93d8.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=0, nfifos=1fbfffb440, fifoids=1fbfffb460.
+(I) sc_QUERY_REC_FIFOS[0]: subgrpid=0, nfifos=1fbfffb440, fifoids=1fbfffb450.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=0, nbatids=1fbfffb440, batids=1fbfffb480.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=1, nfifos=1fbfffb440, fifoids=1fbfffb460.
+(I) sc_QUERY_REC_FIFOS[0]: subgrpid=1, nfifos=1fbfffb440, fifoids=1fbfffb450.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=1, nbatids=1fbfffb440, batids=1fbfffb480.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=2, nfifos=1fbfffb440, fifoids=1fbfffb460.
+(I) sc_QUERY_REC_FIFOS[0]: subgrpid=2, nfifos=1fbfffb440, fifoids=1fbfffb450.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=2, nbatids=1fbfffb440, batids=1fbfffb480.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=3, nfifos=1fbfffb440, fifoids=1fbfffb460.
+(I) sc_QUERY_REC_FIFOS[0]: subgrpid=3, nfifos=1fbfffb440, fifoids=1fbfffb450.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=3, nbatids=1fbfffb440, batids=1fbfffb480.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=4, nfifos=1fbfffb440, fifoids=1fbfffb460.
+(I) sc_QUERY_REC_FIFOS[0]: subgrpid=4, nfifos=1fbfffb440, fifoids=1fbfffb450.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=4, nbatids=1fbfffb440, batids=1fbfffb480.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=5, nfifos=1fbfffb440, fifoids=1fbfffb460.
+(I) sc_QUERY_REC_FIFOS[0]: subgrpid=5, nfifos=1fbfffb440, fifoids=1fbfffb450.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=5, nbatids=1fbfffb440, batids=1fbfffb480.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=6, nfifos=1fbfffb440, fifoids=1fbfffb460.
+(I) sc_QUERY_REC_FIFOS[0]: subgrpid=6, nfifos=1fbfffb440, fifoids=1fbfffb450.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=6, nbatids=1fbfffb440, batids=1fbfffb480.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=7, nfifos=1fbfffb440, fifoids=1fbfffb460.
+(I) sc_QUERY_REC_FIFOS[0]: subgrpid=7, nfifos=1fbfffb440, fifoids=1fbfffb450.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=7, nbatids=1fbfffb440, batids=1fbfffb480.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=8, nfifos=1fbfffb440, fifoids=1fbfffb460.
+(I) sc_QUERY_REC_FIFOS[0]: subgrpid=8, nfifos=1fbfffb440, fifoids=1fbfffb450.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=8, nbatids=1fbfffb440, batids=1fbfffb480.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=9, nfifos=1fbfffb440, fifoids=1fbfffb460.
+(I) sc_QUERY_REC_FIFOS[0]: subgrpid=9, nfifos=1fbfffb440, fifoids=1fbfffb450.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=9, nbatids=1fbfffb440, batids=1fbfffb480.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=10, nfifos=1fbfffb440, fifoids=1fbfffb460.
+(I) sc_QUERY_REC_FIFOS[0]: subgrpid=10, nfifos=1fbfffb440, fifoids=1fbfffb450.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=10, nbatids=1fbfffb440, batids=1fbfffb480.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=11, nfifos=1fbfffb440, fifoids=1fbfffb460.
+(I) sc_QUERY_REC_FIFOS[0]: subgrpid=11, nfifos=1fbfffb440, fifoids=1fbfffb450.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=11, nbatids=1fbfffb440, batids=1fbfffb480.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=12, nfifos=1fbfffb440, fifoids=1fbfffb460.
+(I) sc_QUERY_REC_FIFOS[0]: subgrpid=12, nfifos=1fbfffb440, fifoids=1fbfffb450.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=12, nbatids=1fbfffb440, batids=1fbfffb480.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=13, nfifos=1fbfffb440, fifoids=1fbfffb460.
+(I) sc_QUERY_REC_FIFOS[0]: subgrpid=13, nfifos=1fbfffb440, fifoids=1fbfffb450.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=13, nbatids=1fbfffb440, batids=1fbfffb480.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=14, nfifos=1fbfffb440, fifoids=1fbfffb460.
+(I) sc_QUERY_REC_FIFOS[0]: subgrpid=14, nfifos=1fbfffb440, fifoids=1fbfffb450.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=14, nbatids=1fbfffb440, batids=1fbfffb480.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=15, nfifos=1fbfffb440, fifoids=1fbfffb460.
+(I) sc_QUERY_REC_FIFOS[0]: subgrpid=15, nfifos=1fbfffb440, fifoids=1fbfffb450.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=15, nbatids=1fbfffb440, batids=1fbfffb480.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=16, nfifos=1fbfffb440, fifoids=1fbfffb460.
+(I) sc_QUERY_REC_FIFOS[0]: subgrpid=16, nfifos=1fbfffb440, fifoids=1fbfffb450.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=16, nbatids=1fbfffb440, batids=1fbfffb480.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=17, nfifos=1fbfffb440, fifoids=1fbfffb460.
+(I) sc_QUERY_REC_FIFOS[0]: subgrpid=17, nfifos=1fbfffb440, fifoids=1fbfffb450.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=17, nbatids=1fbfffb440, batids=1fbfffb480.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=18, nfifos=1fbfffb440, fifoids=1fbfffb460.
+(I) sc_QUERY_REC_FIFOS[0]: subgrpid=18, nfifos=1fbfffb440, fifoids=1fbfffb450.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=18, nbatids=1fbfffb440, batids=1fbfffb480.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=19, nfifos=1fbfffb440, fifoids=1fbfffb460.
+(I) sc_QUERY_REC_FIFOS[0]: subgrpid=19, nfifos=1fbfffb440, fifoids=1fbfffb450.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=19, nbatids=1fbfffb440, batids=1fbfffb480.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=20, nfifos=1fbfffb440, fifoids=1fbfffb460.
+(I) sc_QUERY_REC_FIFOS[0]: subgrpid=20, nfifos=1fbfffb440, fifoids=1fbfffb450.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=20, nbatids=1fbfffb440, batids=1fbfffb480.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=21, nfifos=1fbfffb440, fifoids=1fbfffb460.
+(I) sc_QUERY_REC_FIFOS[0]: subgrpid=21, nfifos=1fbfffb440, fifoids=1fbfffb450.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=21, nbatids=1fbfffb440, batids=1fbfffb480.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=22, nfifos=1fbfffb440, fifoids=1fbfffb460.
+(I) sc_QUERY_REC_FIFOS[0]: subgrpid=22, nfifos=1fbfffb440, fifoids=1fbfffb450.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=22, nbatids=1fbfffb440, batids=1fbfffb480.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=23, nfifos=1fbfffb440, fifoids=1fbfffb460.
+(I) sc_QUERY_REC_FIFOS[0]: subgrpid=23, nfifos=1fbfffb440, fifoids=1fbfffb450.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=23, nbatids=1fbfffb440, batids=1fbfffb480.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=24, nfifos=1fbfffb440, fifoids=1fbfffb460.
+(I) sc_QUERY_REC_FIFOS[0]: subgrpid=24, nfifos=1fbfffb440, fifoids=1fbfffb450.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=24, nbatids=1fbfffb440, batids=1fbfffb480.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=25, nfifos=1fbfffb440, fifoids=1fbfffb460.
+(I) sc_QUERY_REC_FIFOS[0]: subgrpid=25, nfifos=1fbfffb440, fifoids=1fbfffb450.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=25, nbatids=1fbfffb440, batids=1fbfffb480.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=26, nfifos=1fbfffb440, fifoids=1fbfffb460.
+(I) sc_QUERY_REC_FIFOS[0]: subgrpid=26, nfifos=1fbfffb440, fifoids=1fbfffb450.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=26, nbatids=1fbfffb440, batids=1fbfffb480.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=27, nfifos=1fbfffb440, fifoids=1fbfffb460.
+(I) sc_QUERY_REC_FIFOS[0]: subgrpid=27, nfifos=1fbfffb440, fifoids=1fbfffb450.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=27, nbatids=1fbfffb440, batids=1fbfffb480.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=28, nfifos=1fbfffb440, fifoids=1fbfffb460.
+(I) sc_QUERY_REC_FIFOS[0]: subgrpid=28, nfifos=1fbfffb440, fifoids=1fbfffb450.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=28, nbatids=1fbfffb440, batids=1fbfffb480.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=29, nfifos=1fbfffb440, fifoids=1fbfffb460.
+(I) sc_QUERY_REC_FIFOS[0]: subgrpid=29, nfifos=1fbfffb440, fifoids=1fbfffb450.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=29, nbatids=1fbfffb440, batids=1fbfffb480.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=30, nfifos=1fbfffb440, fifoids=1fbfffb460.
+(I) sc_QUERY_REC_FIFOS[0]: subgrpid=30, nfifos=1fbfffb440, fifoids=1fbfffb450.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=30, nbatids=1fbfffb440, batids=1fbfffb480.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=31, nfifos=1fbfffb440, fifoids=1fbfffb460.
+(I) sc_QUERY_REC_FIFOS[0]: subgrpid=31, nfifos=1fbfffb440, fifoids=1fbfffb450.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=31, nbatids=1fbfffb440, batids=1fbfffb480.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=32, nfifos=1fbfffb440, fifoids=1fbfffb460.
+(I) sc_QUERY_REC_FIFOS[0]: subgrpid=32, nfifos=1fbfffb440, fifoids=1fbfffb450.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=32, nbatids=1fbfffb440, batids=1fbfffb480.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=33, nfifos=1fbfffb440, fifoids=1fbfffb460.
+(I) sc_QUERY_REC_FIFOS[0]: subgrpid=33, nfifos=1fbfffb440, fifoids=1fbfffb450.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=33, nbatids=1fbfffb440, batids=1fbfffb480.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=34, nfifos=1fbfffb440, fifoids=1fbfffb460.
+(I) sc_QUERY_REC_FIFOS[0]: subgrpid=34, nfifos=1fbfffb440, fifoids=1fbfffb450.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=34, nbatids=1fbfffb440, batids=1fbfffb480.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=35, nfifos=1fbfffb440, fifoids=1fbfffb460.
+(I) sc_QUERY_REC_FIFOS[0]: subgrpid=35, nfifos=1fbfffb440, fifoids=1fbfffb450.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=35, nbatids=1fbfffb440, batids=1fbfffb480.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=36, nfifos=1fbfffb440, fifoids=1fbfffb460.
+(I) sc_QUERY_REC_FIFOS[0]: subgrpid=36, nfifos=1fbfffb440, fifoids=1fbfffb450.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=36, nbatids=1fbfffb440, batids=1fbfffb480.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=37, nfifos=1fbfffb440, fifoids=1fbfffb460.
+(I) sc_QUERY_REC_FIFOS[0]: subgrpid=37, nfifos=1fbfffb440, fifoids=1fbfffb450.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=37, nbatids=1fbfffb440, batids=1fbfffb480.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=38, nfifos=1fbfffb440, fifoids=1fbfffb460.
+(I) sc_QUERY_REC_FIFOS[0]: subgrpid=38, nfifos=1fbfffb440, fifoids=1fbfffb450.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=38, nbatids=1fbfffb440, batids=1fbfffb480.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=39, nfifos=1fbfffb440, fifoids=1fbfffb460.
+(I) sc_QUERY_REC_FIFOS[0]: subgrpid=39, nfifos=1fbfffb440, fifoids=1fbfffb450.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=39, nbatids=1fbfffb440, batids=1fbfffb480.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=40, nfifos=1fbfffb440, fifoids=1fbfffb460.
+(I) sc_QUERY_REC_FIFOS[0]: subgrpid=40, nfifos=1fbfffb440, fifoids=1fbfffb450.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=40, nbatids=1fbfffb440, batids=1fbfffb480.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=41, nfifos=1fbfffb440, fifoids=1fbfffb460.
+(I) sc_QUERY_REC_FIFOS[0]: subgrpid=41, nfifos=1fbfffb440, fifoids=1fbfffb450.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=41, nbatids=1fbfffb440, batids=1fbfffb480.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=42, nfifos=1fbfffb440, fifoids=1fbfffb460.
+(I) sc_QUERY_REC_FIFOS[0]: subgrpid=42, nfifos=1fbfffb440, fifoids=1fbfffb450.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=42, nbatids=1fbfffb440, batids=1fbfffb480.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=43, nfifos=1fbfffb440, fifoids=1fbfffb460.
+(I) sc_QUERY_REC_FIFOS[0]: subgrpid=43, nfifos=1fbfffb440, fifoids=1fbfffb450.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=43, nbatids=1fbfffb440, batids=1fbfffb480.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=44, nfifos=1fbfffb440, fifoids=1fbfffb460.
+(I) sc_QUERY_REC_FIFOS[0]: subgrpid=44, nfifos=1fbfffb440, fifoids=1fbfffb450.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=44, nbatids=1fbfffb440, batids=1fbfffb480.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=45, nfifos=1fbfffb440, fifoids=1fbfffb460.
+(I) sc_QUERY_REC_FIFOS[0]: subgrpid=45, nfifos=1fbfffb440, fifoids=1fbfffb450.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=45, nbatids=1fbfffb440, batids=1fbfffb480.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=46, nfifos=1fbfffb440, fifoids=1fbfffb460.
+(I) sc_QUERY_REC_FIFOS[0]: subgrpid=46, nfifos=1fbfffb440, fifoids=1fbfffb450.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=46, nbatids=1fbfffb440, batids=1fbfffb480.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=47, nfifos=1fbfffb440, fifoids=1fbfffb460.
+(I) sc_QUERY_REC_FIFOS[0]: subgrpid=47, nfifos=1fbfffb440, fifoids=1fbfffb450.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=47, nbatids=1fbfffb440, batids=1fbfffb480.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=48, nfifos=1fbfffb440, fifoids=1fbfffb460.
+(I) sc_QUERY_REC_FIFOS[0]: subgrpid=48, nfifos=1fbfffb440, fifoids=1fbfffb450.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=48, nbatids=1fbfffb440, batids=1fbfffb480.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=49, nfifos=1fbfffb440, fifoids=1fbfffb460.
+(I) sc_QUERY_REC_FIFOS[0]: subgrpid=49, nfifos=1fbfffb440, fifoids=1fbfffb450.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=49, nbatids=1fbfffb440, batids=1fbfffb480.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=50, nfifos=1fbfffb440, fifoids=1fbfffb460.
+(I) sc_QUERY_REC_FIFOS[0]: subgrpid=50, nfifos=1fbfffb440, fifoids=1fbfffb450.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=50, nbatids=1fbfffb440, batids=1fbfffb480.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=51, nfifos=1fbfffb440, fifoids=1fbfffb460.
+(I) sc_QUERY_REC_FIFOS[0]: subgrpid=51, nfifos=1fbfffb440, fifoids=1fbfffb450.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=51, nbatids=1fbfffb440, batids=1fbfffb480.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=52, nfifos=1fbfffb440, fifoids=1fbfffb460.
+(I) sc_QUERY_REC_FIFOS[0]: subgrpid=52, nfifos=1fbfffb440, fifoids=1fbfffb450.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=52, nbatids=1fbfffb440, batids=1fbfffb480.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=53, nfifos=1fbfffb440, fifoids=1fbfffb460.
+(I) sc_QUERY_REC_FIFOS[0]: subgrpid=53, nfifos=1fbfffb440, fifoids=1fbfffb450.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=53, nbatids=1fbfffb440, batids=1fbfffb480.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=54, nfifos=1fbfffb440, fifoids=1fbfffb460.
+(I) sc_QUERY_REC_FIFOS[0]: subgrpid=54, nfifos=1fbfffb440, fifoids=1fbfffb450.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=54, nbatids=1fbfffb440, batids=1fbfffb480.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=55, nfifos=1fbfffb440, fifoids=1fbfffb460.
+(I) sc_QUERY_REC_FIFOS[0]: subgrpid=55, nfifos=1fbfffb440, fifoids=1fbfffb450.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=55, nbatids=1fbfffb440, batids=1fbfffb480.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=56, nfifos=1fbfffb440, fifoids=1fbfffb460.
+(I) sc_QUERY_REC_FIFOS[0]: subgrpid=56, nfifos=1fbfffb440, fifoids=1fbfffb450.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=56, nbatids=1fbfffb440, batids=1fbfffb480.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=57, nfifos=1fbfffb440, fifoids=1fbfffb460.
+(I) sc_QUERY_REC_FIFOS[0]: subgrpid=57, nfifos=1fbfffb440, fifoids=1fbfffb450.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=57, nbatids=1fbfffb440, batids=1fbfffb480.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=58, nfifos=1fbfffb440, fifoids=1fbfffb460.
+(I) sc_QUERY_REC_FIFOS[0]: subgrpid=58, nfifos=1fbfffb440, fifoids=1fbfffb450.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=58, nbatids=1fbfffb440, batids=1fbfffb480.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=59, nfifos=1fbfffb440, fifoids=1fbfffb460.
+(I) sc_QUERY_REC_FIFOS[0]: subgrpid=59, nfifos=1fbfffb440, fifoids=1fbfffb450.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=59, nbatids=1fbfffb440, batids=1fbfffb480.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=60, nfifos=1fbfffb440, fifoids=1fbfffb460.
+(I) sc_QUERY_REC_FIFOS[0]: subgrpid=60, nfifos=1fbfffb440, fifoids=1fbfffb450.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=60, nbatids=1fbfffb440, batids=1fbfffb480.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=61, nfifos=1fbfffb440, fifoids=1fbfffb460.
+(I) sc_QUERY_REC_FIFOS[0]: subgrpid=61, nfifos=1fbfffb440, fifoids=1fbfffb450.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=61, nbatids=1fbfffb440, batids=1fbfffb480.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=62, nfifos=1fbfffb440, fifoids=1fbfffb460.
+(I) sc_QUERY_REC_FIFOS[0]: subgrpid=62, nfifos=1fbfffb440, fifoids=1fbfffb450.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=62, nbatids=1fbfffb440, batids=1fbfffb480.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=63, nfifos=1fbfffb440, fifoids=1fbfffb460.
+(I) sc_QUERY_REC_FIFOS[0]: subgrpid=63, nfifos=1fbfffb440, fifoids=1fbfffb450.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=63, nbatids=1fbfffb440, batids=1fbfffb480.
+(I) sc_open[0.0:1]: pathname="/dev/shm/job0-pami-client-MPI", flags=0x000880c2 mode=(I) sc_ftruncate[0.0:1]: fd=4, len=4194440
+(I) sc_mmap[0]: Entry: addr=0x0000000000000000, len=0x00400088, prot=0x00000003(RW--), flags=0x00000001=(Shared ), filedes=0x00000004, off=0x00000000, MMap_Start=0x0000000000000000, MMap_End=0x0000000000000000.
+(I) sc_mmap[0]: Returning 0x31c305e000 for len=0x00400088 fd=0x4.
+(I) sc_brk[0]: brk_val=r3=0x1f832a4000
+(I) sc_brk[0]: brk_val=0x1f832a4000, returning 0x1f832a4000.
+(I) sc_brk[0]: brk_val=r3=0x1f832c5000
+(I) sc_brk[0]: brk_val=0x1f832c5000, returning 0x1f832c5000.
+(I) sc_brk[0]: brk_val=r3=0x1f832f5000
+(I) sc_brk[0]: brk_val=0x1f832f5000, returning 0x1f832f5000.
+(I) sc_brk[0]: brk_val=r3=0x1f83325000
+(I) sc_brk[0]: brk_val=0x1f83325000, returning 0x1f83325000.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=0, nfifos=1fbfffa8f0, fifoids=1fbfffa920.
+(I) sc_ALLOCATE_INJ_FIFOS[0]: subgrpid=0, sg_ptr=1f83283f20, nfifos=8, fifoids=1fbfffa920, fifoAttrs=1f83324e00.
+(I) sc_CFG_INJ_FIFO_INTS[0]: sg_ptr=1f83283f20, nfifos=8, fifoids=1fbfffa920, fifoInterrupts=1f83324e00.
+(I) sc_QUERY_INJ_FIFOS[0]: subgrpid=1, nfifos=1fbfffa8f0, fifoids=1fbfffa920.
+(I) sc_ALLOCATE_INJ_FIFOS[0]: subgrpid=1, sg_ptr=1f832841f0, nfifos=2, fifoids=1fbfffa920, fifoAttrs=1f83314d20.
+(I) sc_CFG_INJ_FIFO_INTS[0]: sg_ptr=1f832841f0, nfifos=2, fifoids=1fbfffa920, fifoInterrupts=1f83314d20.
+(I) sc_brk[0]: brk_val=r3=0x1f83348000
+(I) sc_brk[0]: brk_val=0x1f83348000, returning 0x1f83348000.
+(I) sc_mmap[0]: Entry: addr=0x0000000000000000, len=0x00101000, prot=0x00000003(RW--), flags=0x00000022=(Private Anonymous ), filedes=0xffffffffffffffff, off=0x00000000, MMap_Start=0x0000000000000000, MMap_End=0x0000000000000000.
+(I) sc_mmap[0]: Brk: 0x1f83200000 - 0x1f833fffff. MMap: 0x1f83400000 - 0x1fbfb00000.
+(I) sc_mmap[0]: Returning 0x1f83400000 for len=0x00101000.
+(I) sc_QUERY_REC_FIFOS[0]: subgrpid=0, nfifos=1fbfffa910, fifoids=1fbfffa928.
+(I) sc_ALLOCATE_REC_FIFOS[0]: subgrpid=0, sg_ptr=1f83324e00, nfifos=1, fifoids=1fbfffa928, fifoAttrs=1f832b4ba0.
+(I) sc_CFG_REC_FIFO_INTS[0]: sg_ptr=1f83324e00, nfifos=1, fifoids=1fbfffa928, fifoInterrupts=1f832b4ba0.
+(I) sc_REC_FIFO_ENABLE[0]: groupid=0, enableBitsr=0000000000008000.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=0, nbatids=1fbfffab40, batids=1fbfffab68.
+(I) sc_ALLOCATE_BASE_ADDRESS_TABLE[0]: subgrpid=0, sg_ptr=1f833274a0, nbatids=8, batids=1fbfffab68, system=0.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=1, nbatids=1fbfffab40, batids=1fbfffab68.
+(I) sc_ALLOCATE_BASE_ADDRESS_TABLE[0]: subgrpid=1, sg_ptr=1f833274f0, nbatids=8, batids=1fbfffab68, system=0.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=2, nbatids=1fbfffab40, batids=1fbfffab68.
+(I) sc_ALLOCATE_BASE_ADDRESS_TABLE[0]: subgrpid=2, sg_ptr=1f83327540, nbatids=8, batids=1fbfffab68, system=0.
+(I) sc_QUERY_BASE_ADDRESS_TABLE[0]: subgrpid=3, nbatids=1fbfffab40, batids=1fbfffab68.
+(I) sc_ALLOCATE_BASE_ADDRESS_TABLE[0]: subgrpid=3, sg_ptr=1f83327590, nbatids=8, batids=1fbfffab68, system=0.
+(I) sc_brk[0]: brk_val=r3=0x1f83388000
+(I) sc_brk[0]: brk_val=0x1f83388000, returning 0x1f83388000.
+(I) sc_brk[0]: brk_val=r3=0x1f833c8000
+(I) sc_brk[0]: brk_val=0x1f833c8000, returning 0x1f833c8000.
+(I) sc_brk[0]: brk_val=r3=0x1f83408000
+(I) sc_brk[0]: brk_val=0x1f83408000, returning 0x1f833c8000.
+(I) sc_mmap[0]: Entry: addr=0x0000000000000000, len=0x00800000, prot=0x00000003(RW--), flags=0x00000022=(Private Anonymous ), filedes=0xffffffffffffffff, off=0x00000000, MMap_Start=0x0000001f83400000, MMap_End=0x0000001fbfb00000.
+(I) sc_mmap[0]: Returning 0x1f83501000 for len=0x00800000.
+(I) sc_open[0.0:1]: pathname="/dev/shm/job0-pami-clt0-ctx-mm", flags=0x000880c2 mode=(I) sc_ftruncate[0.0:1]: fd=4, len=138376
+(I) sc_mmap[0]: Entry: addr=0x0000000000000000, len=0x00021c88, prot=0x00000003(RW--), flags=0x00000001=(Shared ), filedes=0x00000004, off=0x00000000, MMap_Start=0x0000001f83400000, MMap_End=0x0000001fbfb00000.
+(I) sc_mmap[0]: Returning 0x31c1101000 for len=0x00021c88 fd=0x4.
+(I) sc_getuid[0]: returning 5222.
+(I) sc_time[0]: buf=0x0000000000000000
+(I) sc_open[0.0:1]: pathname="/etc/mtab", flags=0x00000000 mode=(I) sc_futex[0]: op(129)=WAKE, uaddr=307c318, val=2147483647 timeout=0 *uaddr=2 uaddr2=0x00000000 val3=0x00000000.
+(I) sc_fstat[0.0:1]: fd=4, buf=0x1fbfffacf0
+(I) sc_mmap[0]: Entry: addr=0x0000000000000000, len=0x00010000, prot=0x00000003(RW--), flags=0x00000022=(Private Anonymous ), filedes=0xffffffffffffffff, off=0x00000000, MMap_Start=0x0000001f83400000, MMap_End=0x0000001fbfb00000.
+(I) sc_mmap[0]: Returning 0x1f83d01000 for len=0x00010000.
+(I) sc_read[0.0:1]: fd=4, buf=0x1f83d01000, cnt=65536
+(I) sc_statfs[0.0:1]: pathname="/gpfs/vesta-fs0", buf=0x1fbfffb4b0
+(I) sc_statfs[0.0:1]: pathname="/gpfs/vesta-home", buf=0x1fbfffb4b0
+(I) sc_munmap[0]: start=0x1f83d01000, len=0x00010000.
+(I) sc_open[0.0:1]: pathname="/etc/mtab", flags=0x00000000 mode=(I) sc_fstat[0.0:1]: fd=4, buf=0x1fbfffacf0
+(I) sc_statfs[0.0:1]: pathname="/", buf=0x1fbfffb4b0
+(I) sc_statfs[0.0:1]: pathname="/bgsys", buf=0x1fbfffb4b0
+(I) sc_uname[0.0:1]: name=0x1fbfffb370
+(I) sc_open[0.0:1]: pathname="/etc/localtime", flags=0x00000000 mode=(I) sc_fstat[0.0:1]: fd=4, buf=0x1fbfffb128
+(I) sc_fstat[0.0:1]: fd=4, buf=0x1fbfffad50
+(I) sc_lseek[0.0:1]: fd=4, offset=18446744073709551554, whence=1
+(I) sc_open[0.0:1]: pathname="", flags=0x00000000 mode=(I) sc_open[0.0:1]: pathname=".petscrc", flags=0x00000000 mode=(I) sc_open[0.0:1]: pathname="petscrc", flags=0x00000000 mode=(I) sc_uname[0.0:1]: name=0x1fbfff6cf0
+(I) sc_rt_sigaction[0]: sig=7, act=0x1fbfff6ef0, oldact=0x1fbfff6f88, sigsetsize=8.
+(I) sc_rt_sigaction[0]: act{ sa_handler:2e71978, flags=10000000 }
+(I) sc_rt_sigaction[0]: sig=8, act=0x1fbfff6ef0, oldact=0x1fbfff6f88, sigsetsize=8.
+(I) sc_rt_sigaction[0]: sig=1, act=0x1fbfff6ef0, oldact=0x1fbfff6f88, sigsetsize=8.
+(I) sc_rt_sigaction[0]: sig=4, act=0x1fbfff6ef0, oldact=0x1fbfff6f88, sigsetsize=8.
+(I) sc_rt_sigaction[0]: sig=13, act=0x1fbfff6ef0, oldact=0x1fbfff6f88, sigsetsize=8.
+(I) sc_rt_sigaction[0]: sig=3, act=0x1fbfff6ef0, oldact=0x1fbfff6f88, sigsetsize=8.
+(I) sc_rt_sigaction[0]: sig=11, act=0x1fbfff6ef0, oldact=0x1fbfff6f88, sigsetsize=8.
+(I) sc_rt_sigaction[0]: sig=31, act=0x1fbfff6ef0, oldact=0x1fbfff6f88, sigsetsize=8.
+(I) sc_rt_sigaction[0]: sig=15, act=0x1fbfff6ef0, oldact=0x1fbfff6f88, sigsetsize=8.
+(I) sc_rt_sigaction[0]: sig=5, act=0x1fbfff6ef0, oldact=0x1fbfff6f88, sigsetsize=8.
+(I) sc_rt_sigaction[0]: sig=23, act=0x1fbfff6ef0, oldact=0x1fbfff6f88, sigsetsize=8.
+(I) sc_gettimeofday[0]: tv=0x0000000002f71d88, tz=0x0000000000000000
+(I) sc_gettimeofday[0]: tv=0x0000000002f6ff08, tz=0x0000000000000000
+(I) sc_uname[0.0:1]: name=0x1fbfffb430
+(I) sc_open[0.0:1]: pathname="gridpack.petscrc", flags=0x00000000 mode=(I) sc_fstat[0.0:1]: fd=1, buf=0x1fbfffae70
+(I) sc_write[0.0:1]: fd=1, buf=0x1f83d01000, cnt=1
+(I) sc_write[0.0:1]: fd=1, buf=0x1f83d01000, cnt=48
+(I) sc_uname[0.0:1]: name=0x1fbfffb410
+(I) sc_rt_sigaction[0]: sig=17, act=0x1fbfffb310, oldact=0x1fbfffb3a8, sigsetsize=8.
+(I) sc_rt_sigaction[0]: act{ sa_handler:2e68438, flags=10000000 }
+(I) sc_rt_sigaction[0]: sig=1, act=0x1fbfffb310, oldact=0x1fbfffb3a8, sigsetsize=8.
+(I) sc_rt_sigaction[0]: act{ sa_handler:2e685d0, flags=10000000 }
+(I) sc_rt_sigaction[0]: sig=7, act=0x1fbfffb310, oldact=0x1fbfffb3a8, sigsetsize=8.
+(I) sc_rt_sigaction[0]: act{ sa_handler:2e68498, flags=10000000 }
+(I) sc_rt_sigaction[0]: sig=8, act=0x1fbfffb310, oldact=0x1fbfffb3a8, sigsetsize=8.
+(I) sc_rt_sigaction[0]: act{ sa_handler:2e684c8, flags=10000000 }
+(I) sc_rt_sigaction[0]: sig=4, act=0x1fbfffb310, oldact=0x1fbfffb3a8, sigsetsize=8.
+(I) sc_rt_sigaction[0]: act{ sa_handler:2e684f8, flags=10000000 }
+(I) sc_rt_sigaction[0]: sig=11, act=0x1fbfffb310, oldact=0x1fbfffb3a8, sigsetsize=8.
+(I) sc_rt_sigaction[0]: act{ sa_handler:2e68528, flags=10000000 }
+(I) sc_rt_sigaction[0]: sig=5, act=0x1fbfffb310, oldact=0x1fbfffb3a8, sigsetsize=8.
+(I) sc_rt_sigaction[0]: act{ sa_handler:2e685a0, flags=10000000 }
+(I) sc_rt_sigaction[0]: sig=2, act=0x1fbfffb310, oldact=0x1fbfffb3a8, sigsetsize=8.
+(I) sc_rt_sigaction[0]: act{ sa_handler:2e68408, flags=10000000 }
+(I) sc_rt_sigaction[0]: sig=15, act=0x1fbfffb310, oldact=0x1fbfffb3a8, sigsetsize=8.
+(I) sc_rt_sigaction[0]: act{ sa_handler:2e68618, flags=10000000 }
+(I) sc_rt_sigaction[0]: act{ sa_handler:2e683c0, flags=10000000 }
+(I) sc_mmap[0]: Entry: addr=0x0000000000000000, len=0x02001000, prot=0x00000003(RW--), flags=0x00000022=(Private Anonymous ), filedes=0xffffffffffffffff, off=0x00000000, MMap_Start=0x0000001f83400000, MMap_End=0x0000001fbfb00000.
+(I) sc_mmap[0]: Returning 0x1f83d11000 for len=0x02001000.
+(I) sc_mmap[0]: Entry: addr=0x0000000000000000, len=0x01681000, prot=0x00000003(RW--), flags=0x00000022=(Private Anonymous ), filedes=0xffffffffffffffff, off=0x00000000, MMap_Start=0x0000001f83400000, MMap_End=0x0000001fbfb00000.
+(I) sc_mmap[0]: Returning 0x1f85d12000 for len=0x01681000.
+(I) sc_mmap[0]: Entry: addr=0x0000000000000000, len=0x0030e000, prot=0x00000003(RW--), flags=0x00000022=(Private Anonymous ), filedes=0xffffffffffffffff, off=0x00000000, MMap_Start=0x0000001f83400000, MMap_End=0x0000001fbfb00000.
+(I) sc_mmap[0]: Returning 0x1f87393000 for len=0x0030e000.
+(I) sc_open[0.0:1]: pathname="infiles/input3.xml", flags=0x00000000 mode=(I) sc_getcwd[0.0:1]: buf=0x1f83a3dc80, len=4096
+(I) sc_lseek[0.0:1]: fd=4, offset=0, whence=2
+(I) sc_lseek[0.0:1]: fd=4, offset=0, whence=1
+(I) sc_lseek[0.0:1]: fd=4, offset=0, whence=0
+(I) sc_read[0.0:1]: fd=4, buf=0x1f83a3dc80, cnt=8191
+(I) sc_open[0.0:1]: pathname="contingencies.xml", flags=0x00000000 mode=(I) sc_getcwd[0.0:1]: buf=0x1f83a3df20, len=4096
+(I) sc_read[0.0:1]: fd=4, buf=0x1f83a3df20, cnt=8191
+(I) sc_write[0.0:1]: fd=1, buf=0x1f83d01000, cnt=11
+(I) sc_write[0.0:1]: fd=1, buf=0x1f83d01000, cnt=37
+(I) sc_write[0.0:1]: fd=1, buf=0x1f83d01000, cnt=38
+(I) sc_open[0.0:1]: pathname="infiles/input3.xml", flags=0x00000000 mode=(I) sc_getcwd[0.0:1]: buf=0x1f83a3e2c0, len=4096
+(I) sc_read[0.0:1]: fd=4, buf=0x1f83a45ce0, cnt=8191
+(I) sc_open[0.0:1]: pathname="IEEE14_ca.raw", flags=0x00000000 mode=(I) sc_getcwd[0.0:1]: buf=0x1f83a45ce0, len=4096
+(I) sc_write[0.0:1]: fd=1, buf=0x1f83d01000, cnt=30
+(I) sc_open[0.0:1]: pathname="CTG1.out", flags=0x00000241 mode=(I) sc_getcwd[0.0:1]: buf=0x1f83a7b8e0, len=4096
+(I) sc_open[0.0:1]: pathname="/dev/urandom", flags=0x00000000 mode=(I) sc_read[0.0:1]: fd=5, buf=0x1fbfff9a28, cnt=4
+(I) sc_read[0.0:1]: fd=5, buf=0x1fbfff9a28, cnt=4
+(I) sc_close[0.0:1]: fd=5
+(I) sc_rt_sigaction[0]: sig=6, act=0x1fbfff7cf0, oldact=0x1fbfff7d88, sigsetsize=8.
+(I) sc_rt_sigaction[0]: act{ sa_handler:2e8f450, flags=10000000 }
+(I) sc_rt_sigaction[0]: sig=15, act=0x1fbfff7cf0, oldact=0x1fbfff7d88, sigsetsize=8.
+(I) sc_rt_sigaction[0]: act{ sa_handler:0, flags=10000000 }
+(I) sc_futex[0]: op(129)=WAKE, uaddr=2dd4a8c, val=2147483647 timeout=0 *uaddr=2 uaddr2=0x7f7f7f7f7f7f7f7f val3=0x00008080.
+(I) sc_write[0.0:1]: fd=2, buf=0x1f83a5ccd8, cnt=52
+0: PETSc KSP converged after 1 iterations, reason: 3(I) sc_write[0.0:1]: fd=2, buf=0x2e1b32b, cnt=1
+(I) sc_write[0.0:1]: fd=2, buf=0x1f83a56a78, cnt=52
+0: PETSc KSP converged after 0 iterations, reason: 3(I) sc_write[0.0:1]: fd=2, buf=0x2e1b32b, cnt=1
+(I) sc_write[0.0:1]: fd=4, buf=0x1f83a7b8e0, cnt=352
+(I) sc_open[0.0:1]: pathname="CTG2.out", flags=0x00000241 mode=(I) sc_getcwd[0.0:1]: buf=0x1f838eb540, len=4096
+(I) sc_write[0.0:1]: fd=2, buf=0x1f83a54598, cnt=52
+(I) sc_write[0.0:1]: fd=2, buf=0x1f838ec638, cnt=52
+(I) sc_write[0.0:1]: fd=4, buf=0x1f83a7b8e0, cnt=383
+(I) sc_write[0.0:1]: fd=1, buf=0x1f83d01000, cnt=32
+(I) sc_write[0.0:1]: fd=1, buf=0x1f83d01000, cnt=44
+(I) sc_write[0.0:1]: fd=1, buf=0x1f83d01000, cnt=41
+(I) sc_write[0.0:1]: fd=1, buf=0x1f83d01000, cnt=40
+(I) sc_write[0.0:1]: fd=1, buf=0x1f83d01000, cnt=35
+(I) sc_write[0.0:1]: fd=1, buf=0x1f83d01000, cnt=42
+(I) sc_write[0.0:1]: fd=1, buf=0x1f83d01000, cnt=51
+(I) sc_write[0.0:1]: fd=1, buf=0x1f83d01000, cnt=49
+(I) sc_munmap[0]: start=0x1f85d12000, len=0x01681000.
+(I) sc_rt_sigaction[0]: sig=17, act=0x1fbfffb190, oldact=0x1fbfffb228, sigsetsize=8.
+(I) sc_rt_sigaction[0]: sig=15, act=0x1fbfffb190, oldact=0x1fbfffb228, sigsetsize=8.
+(I) sc_rt_sigaction[0]: sig=2, act=0x1fbfffb190, oldact=0x1fbfffb228, sigsetsize=8.
+(I) sc_rt_sigaction[0]: sig=11, act=0x1fbfffb190, oldact=0x1fbfffb228, sigsetsize=8.
+(I) sc_rt_sigaction[0]: sig=1, act=0x1fbfffb190, oldact=0x1fbfffb228, sigsetsize=8.
+(I) sc_rt_sigaction[0]: sig=7, act=0x1fbfff7330, oldact=0x1fbfff73c8, sigsetsize=8.
+(I) sc_rt_sigaction[0]: sig=8, act=0x1fbfff7330, oldact=0x1fbfff73c8, sigsetsize=8.
+(I) sc_rt_sigaction[0]: sig=1, act=0x1fbfff7330, oldact=0x1fbfff73c8, sigsetsize=8.
+(I) sc_rt_sigaction[0]: sig=4, act=0x1fbfff7330, oldact=0x1fbfff73c8, sigsetsize=8.
+(I) sc_rt_sigaction[0]: sig=13, act=0x1fbfff7330, oldact=0x1fbfff73c8, sigsetsize=8.
+(I) sc_rt_sigaction[0]: sig=3, act=0x1fbfff7330, oldact=0x1fbfff73c8, sigsetsize=8.
+(I) sc_rt_sigaction[0]: sig=11, act=0x1fbfff7330, oldact=0x1fbfff73c8, sigsetsize=8.
+(I) sc_rt_sigaction[0]: sig=31, act=0x1fbfff7330, oldact=0x1fbfff73c8, sigsetsize=8.
+(I) sc_rt_sigaction[0]: sig=15, act=0x1fbfff7330, oldact=0x1fbfff73c8, sigsetsize=8.
+(I) sc_rt_sigaction[0]: sig=5, act=0x1fbfff7330, oldact=0x1fbfff73c8, sigsetsize=8.
+(I) sc_rt_sigaction[0]: sig=23, act=0x1fbfff7330, oldact=0x1fbfff73c8, sigsetsize=8.
+(I) sc_stat[0.0:1]: path="/etc/localtime", buf=0x1fbfffaee8
+(I) sc_geteuid[0]: returning 5222.
+(I) sc_socketcall[0.0:1]: operation=1 sockfd=1
+(I) sc_socketcall[0.0:1]: operation=3 sockfd=4
+(I) sc_socketcall[0.0:1]: operation=9 sockfd=4
+(I) sc_poll[0.0:1]: nfds=1, timeout=5000
+(I) sc_socketcall[0.0:1]: operation=17 sockfd=4
+(I) sc_close[0.0:1]: fd=-1
+(I) sc_read[0.0:1]: fd=4, buf=0x1fbfffaa94, cnt=36
+(I) sc_read[0.0:1]: fd=4, buf=0x1fbfffade8, cnt=64
+(I) sc_uname[0.0:1]: name=0x1fbfffb050
+(I) sc_open[0.0:1]: pathname="/proc/meminfo", flags=0x00000000 mode=(I) sc_fstat[0.0:1]: fd=4, buf=0x1fbfff49b0
+(I) sc_mmap[0]: Entry: addr=0x0000000000000000, len=0x00001000, prot=0x00000003(RW--), flags=0x00000022=(Private Anonymous ), filedes=0xffffffffffffffff, off=0x00000000, MMap_Start=0x0000001f83400000, MMap_End=0x0000001fbfb00000.
+(I) sc_mmap[0]: Returning 0x1f85d12000 for len=0x00001000.
+(I) sc_read[0.0:1]: fd=4, buf=0x1f85d12000, cnt=1024
+(I) sc_munmap[0]: start=0x1f85d12000, len=0x00001000.
+(I) sc_open[0.0:1]: pathname="/etc/romio-hints", flags=0x00000000 mode=(I) sc_statfs[0.0:1]: pathname="/gpfs/vesta-fs0/logs/darshan/vesta/2014/10/23/ketan_ca.x_id222728_10-23-74310-11943461529772078178.darshan_partial", buf=0x1fbfffaea0
+(I) sc_lstat[0.0:1]: path="/gpfs/vesta-fs0/logs/darshan/vesta/2014/10/23/ketan_ca.x_id222728_10-23-74310-11943461529772078178.darshan_partial", buf=0x1fbfffaf20
+(I) sc_statfs[0.0:1]: pathname="/gpfs/vesta-fs0/logs/darshan/vesta/2014/10/23", buf=0x1fbfffaea0
+(I) sc_GET_PERSONALITY[0]: dst=0x0000001fbfffac80, size=176.
+(I) sc_umask[0.0:1]: newmask=0x00000012
+(I) sc_open[0.0:1]: pathname="/gpfs/vesta-fs0/logs/darshan/vesta/2014/10/23/ketan_ca.x_id222728_10-23-74310-11943461529772078178.darshan_partial", flags=0x000000c1 mode=(I) sc_stat[0.0:1]: path="/gpfs/vesta-fs0/logs/darshan/vesta/2014/10/23/ketan_ca.x_id222728_10-23-74310-11943461529772078178.darshan_partial", buf=0x1fbfffad20
+(I) sc_statfs[0.0:1]: pathname="/gpfs/vesta-fs0/logs/darshan/vesta/2014/10/23/ketan_ca.x_id222728_10-23-74310-11943461529772078178.darshan_partial", buf=0x1fbfffaca0
+(I) sc_open[0.0:1]: pathname="/gpfs/vesta-fs0/logs/darshan/vesta/2014/10/23/ketan_ca.x_id222728_10-23-74310-11943461529772078178.darshan_partial", flags=0x00000002 mode=(I) sc_stat[0.0:1]: path="/gpfs/vesta-fs0/logs/darshan/vesta/2014/10/23/ketan_ca.x_id222728_10-23-74310-11943461529772078178.darshan_partial", buf=0x1fbfffad20
+(I) sc_mmap[0]: Entry: addr=0x0000000000000000, len=0x01001000, prot=0x00000003(RW--), flags=0x00000022=(Private Anonymous ), filedes=0xffffffffffffffff, off=0x00000000, MMap_Start=0x0000001f83400000, MMap_End=0x0000001fbfb00000.
+(I) sc_mmap[0]: Returning 0x1f85d12000 for len=0x01001000.
+(I) sc_fcntl[0.0:1]: fd=4, cmd=7, parm3=0x1fbfffa9c0
+(I) sc_write[0.0:1]: fd=4, buf=0x1f85d120b8, cnt=978
+(I) sc_fcntl[0.0:1]: fd=4, cmd=6, parm3=0x1fbfffa9c0
+(I) sc_munmap[0]: start=0x1f85d12000, len=0x01001000.
+(I) sc_rename[0.0:1]: old="/gpfs/vesta-fs0/logs/darshan/vesta/2014/10/23/ketan_ca.x_id222728_10-23-74310-11943461529772078178.darshan_partial", new="/gpfs/vesta-fs0/logs/darshan/vesta/2014/10/23/ketan_ca.x_id222728_10-23-74310-11943461529772078178_1.darshan.gz"
+(I) sc_chmod[0.0:1]: path="/gpfs/vesta-fs0/logs/darshan/vesta/2014/10/23/ketan_ca.x_id222728_10-23-74310-11943461529772078178_1.darshan.gz", mode=0x00000120
+(I) sc_exit_group[ 0:0]: status = 0.
+2014-10-23 20:38:32.533 (INFO ) [0xfff7ec1bdd0] VST-20020-31331-64:985588:ibm.runjob.client.Job: exited with status 0
+2014-10-23 20:38:32.533 (INFO ) [0xfff7ec1bdd0] tatu.runjob.client: task exited with status 0
Added: SwiftApps/subjobs/gridpack/cf
--- SwiftApps/subjobs/gridpack/cf (rev 0)
+++ SwiftApps/subjobs/gridpack/cf 2015-01-28 19:15:58 UTC (rev 8377)
@@ -0,0 +1,6 @@
+use.provider.staging=false
+wrapperlog.always.transfer=false
+execution.retries=0
+provider.staging.pin.swiftfiles=false
+sitedir.keep=false
+use.wrapper.staging=false
Added: SwiftApps/subjobs/gridpack/cobalt.xml
--- SwiftApps/subjobs/gridpack/cobalt.xml (rev 0)
+++ SwiftApps/subjobs/gridpack/cobalt.xml 2015-01-28 19:15:58 UTC (rev 8377)
@@ -0,0 +1,30 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<config xmlns="http://www.ci.uchicago.edu/swift/SwiftSites">
+<pool handle="cluster">
+<execution provider="coaster" jobmanager="local:cobalt" />
+<profile namespace="globus" key="slots">2</profile>
+<profile namespace="globus" key="mode">script</profile>
+<profile namespace="karajan" key="jobThrottle">2.99</profile>
+<profile namespace="karajan" key="initialScore">10000</profile>
+<profile namespace="globus" key="maxwalltime">00:40:00</profile>
+<profile namespace="globus" key="walltime">2050</profile>
+<profile namespace="globus" key="maxnodes">64</profile>
+<profile namespace="globus" key="nodegranularity">64</profile>
+<profile key="SUBBLOCK_SIZE" namespace="env">1</profile>
+<profile key="WORKER_LOGGING_LEVEL" namespace="env">DEBUG</profile>
+<profile key="ENABLE_WORKER_LOGGING" namespace="env">TRUE</profile>
+<profile key="ENABLE_WORKER_LOGGING" namespace="env">ON</profile>
+<profile key="WORKER_LOG_DIR" namespace="env">/home/ketan/workerlogs</profile>
+<profile namespace="globus" key="workerLoggingLevel">DEBUG</profile>
+<profile namespace="globus" key="workerLoggingDirectory">/home/ketan/workerlogs</profile>
+<profile namespace="globus" key="jobsPerNode">32</profile>
+<workdirectory>/home/ketan/swiftwork</workdirectory>
+<filesystem provider="local"/>
+</pool>
+</config>
Added: SwiftApps/subjobs/gridpack/contan.swift
--- SwiftApps/subjobs/gridpack/contan.swift (rev 0)
+++ SwiftApps/subjobs/gridpack/contan.swift 2015-01-28 19:15:58 UTC (rev 8377)
@@ -0,0 +1,26 @@
+type file;
+// Contingency Analysis App
+app (file _ctg1, file _ctg2, file _out, file _err) ca (file _infile, file _contfile, file _ieeraw)
+ bgsh "/home/ketan/gridpack-examples/contingency_analysis/ca.x" @_infile stdout=@_out stderr=@_err;
+// Files
+file infiles[] <filesys_mapper; location="infiles", suffix=".xml">;
+file logs[];
+file contfile<"contingencies.xml">;
+file ieeeraw<"IEEE14_ca.raw">;
+// Run scaling tests
+foreach infile,i in infiles {
+ file out <single_file_mapper; file=strcat("logs/ca.", i, ".stdout")>;
+ file err <single_file_mapper; file=strcat("logs/ca.", i, ".stderr")>;
+ string[] fname=strsplit(filename(infile),"\\/");
+ file ctg1 <single_file_mapper; file=strcat("CTG1", fname[1],".out")>;
+ file ctg2 <single_file_mapper; file=strcat("CTG2", fname[1],".out")>;
+ (ctg1, ctg2, out, err) = ca(infile, contfile, ieeeraw);
+ logs[i] = out;
Added: SwiftApps/subjobs/gridpack/contingencies.xml
--- SwiftApps/subjobs/gridpack/contingencies.xml (rev 0)
+++ SwiftApps/subjobs/gridpack/contingencies.xml 2015-01-28 19:15:58 UTC (rev 8377)
@@ -0,0 +1,19 @@
+<?xml version="1.0" encoding="utf-8"?>
+<ContingencyList>
+ <Contingency_analysis>
+ <Contingencies>
+ <Contingency>
+ <contingencyType>Line</contingencyType>
+ <contingencyName>CTG1</contingencyName>
+ <contingencyLineBuses> 13 14</contingencyLineBuses>
+ <contingencyLineNames> B1 </contingencyLineNames>
+ </Contingency>
+ <Contingency>
+ <contingencyType>Generator</contingencyType>
+ <contingencyName>CTG2</contingencyName>
+ <contingencyBuses> 2 </contingencyBuses>
+ <contingencyGenerators>1 </contingencyGenerators>
+ </Contingency>
+ </Contingencies>
+ </Contingency_analysis>
+</ContingencyList>
Added: SwiftApps/subjobs/gridpack/infiles/input1.xml
--- SwiftApps/subjobs/gridpack/infiles/input1.xml (rev 0)
+++ SwiftApps/subjobs/gridpack/infiles/input1.xml 2015-01-28 19:15:58 UTC (rev 8377)
@@ -0,0 +1,29 @@
+<Configuration>
+ <networkConfiguration> IEEE14_ca.raw </networkConfiguration>
+ <groupSize>1</groupSize>
+ <Contingencies>
+ <Contingency>
+ </Contingency>
+ <Contingency>
+ <contingencyBuses> 3 </contingencyBuses>
+ <contingencyGenerators> 1 </contingencyGenerators>
+ </Contingency>
+ </Contingencies>
+ <LinearSolver>
+ <PETScOptions>
+ -ksp_type richardson
+ -pc_type lu
+ -pc_factor_mat_solver_package superlu_dist
+ -ksp_max_it 1
+ </PETScOptions>
+ </LinearSolver>
+</Configuration>
Added: SwiftApps/subjobs/gridpack/infiles/input2.xml
--- SwiftApps/subjobs/gridpack/infiles/input2.xml (rev 0)
+++ SwiftApps/subjobs/gridpack/infiles/input2.xml 2015-01-28 19:15:58 UTC (rev 8377)
@@ -0,0 +1,29 @@
+<Configuration>
+ <Contingencies>
+ <Contingency>
+ </Contingency>
+ <Contingency>
+ </Contingency>
+ </Contingencies>
+ <LinearSolver>
+ <PETScOptions>
+ -pc_type lu
+ -ksp_max_it 1
+ </PETScOptions>
+ </LinearSolver>
+</Configuration>
Added: SwiftApps/subjobs/gridpack/infiles/input3.xml
--- SwiftApps/subjobs/gridpack/infiles/input3.xml (rev 0)
+++ SwiftApps/subjobs/gridpack/infiles/input3.xml 2015-01-28 19:15:58 UTC (rev 8377)
@@ -0,0 +1,29 @@
+<Configuration>
+ <Contingencies>
+ <Contingency>
+ </Contingency>
+ <Contingency>
+ </Contingency>
+ </Contingencies>
+ <LinearSolver>
+ <PETScOptions>
+ -pc_type lu
+ -ksp_max_it 1
+ </PETScOptions>
+ </LinearSolver>
+</Configuration>
Added: SwiftApps/subjobs/gridpack/logs/ca.0.stderr
--- SwiftApps/subjobs/gridpack/logs/ca.0.stderr (rev 0)
+++ SwiftApps/subjobs/gridpack/logs/ca.0.stderr 2015-01-28 19:15:58 UTC (rev 8377)
@@ -0,0 +1,601 @@
+2014-10-23 20:38:09.687 (INFO ) [0xfffb669bdd0] ibm.runjob.AbstractOptions: using properties file /bgsys/local/etc/bg.properties
+2014-10-23 20:38:09.688 (INFO ) [0xfffb669bdd0] ibm.runjob.AbstractOptions: max open file descriptors: 65536
+2014-10-23 20:38:09.688 (INFO ) [0xfffb669bdd0] ibm.runjob.AbstractOptions: core file limit: 18446744073709551615
+2014-10-23 20:38:09.689 (INFO ) [0xfffb669bdd0] 24194:tatu.runjob.client: scheduler job id is 222728
+2014-10-23 20:38:09.696 (INFO ) [0xfff9b1634d0] 24194:tatu.runjob.monitor: monitor started
+2014-10-23 20:38:13.188 (INFO ) [0xfff9b1634d0] 24194:tatu.runjob.monitor: task record 787263 created
+2014-10-23 20:38:13.189 (INFO ) [0xfffb669bdd0] VST-20020-31331-64:24194:ibm.runjob.client.options.Parser: set local socket to runjob_mux from properties file
+2014-10-23 20:38:16.833 (INFO ) [0xfffb669bdd0] VST-20020-31331-64:985586:ibm.runjob.client.Job: job 985586 started
+(I) sc_open[0.0:1]: pathname="infiles/input1.xml", flags=0x00000000 mode=(I) sc_getcwd[0.0:1]: buf=0x1f83a3dc80, len=4096
+(I) sc_open[0.0:1]: pathname="infiles/input1.xml", flags=0x00000000 mode=(I) sc_getcwd[0.0:1]: buf=0x1f83a3e2c0, len=4096
+(I) sc_open[0.0:1]: pathname="/etc/romio-hints", flags=0x00000000 mode=(I) sc_statfs[0.0:1]: pathname="/gpfs/vesta-fs0/logs/darshan/vesta/2014/10/23/ketan_ca.x_id222728_10-23-74296-12842200408161474066.darshan_partial", buf=0x1fbfffaea0
+(I) sc_lstat[0.0:1]: path="/gpfs/vesta-fs0/logs/darshan/vesta/2014/10/23/ketan_ca.x_id222728_10-23-74296-12842200408161474066.darshan_partial", buf=0x1fbfffaf20
+(I) sc_open[0.0:1]: pathname="/gpfs/vesta-fs0/logs/darshan/vesta/2014/10/23/ketan_ca.x_id222728_10-23-74296-12842200408161474066.darshan_partial", flags=0x000000c1 mode=(I) sc_stat[0.0:1]: path="/gpfs/vesta-fs0/logs/darshan/vesta/2014/10/23/ketan_ca.x_id222728_10-23-74296-12842200408161474066.darshan_partial", buf=0x1fbfffad20
+(I) sc_statfs[0.0:1]: pathname="/gpfs/vesta-fs0/logs/darshan/vesta/2014/10/23/ketan_ca.x_id222728_10-23-74296-12842200408161474066.darshan_partial", buf=0x1fbfffaca0
+(I) sc_open[0.0:1]: pathname="/gpfs/vesta-fs0/logs/darshan/vesta/2014/10/23/ketan_ca.x_id222728_10-23-74296-12842200408161474066.darshan_partial", flags=0x00000002 mode=(I) sc_stat[0.0:1]: path="/gpfs/vesta-fs0/logs/darshan/vesta/2014/10/23/ketan_ca.x_id222728_10-23-74296-12842200408161474066.darshan_partial", buf=0x1fbfffad20
+(I) sc_write[0.0:1]: fd=4, buf=0x1f85d120b8, cnt=985
+(I) sc_rename[0.0:1]: old="/gpfs/vesta-fs0/logs/darshan/vesta/2014/10/23/ketan_ca.x_id222728_10-23-74296-12842200408161474066.darshan_partial", new="/gpfs/vesta-fs0/logs/darshan/vesta/2014/10/23/ketan_ca.x_id222728_10-23-74296-12842200408161474066_1.darshan.gz"
+(I) sc_chmod[0.0:1]: path="/gpfs/vesta-fs0/logs/darshan/vesta/2014/10/23/ketan_ca.x_id222728_10-23-74296-12842200408161474066_1.darshan.gz", mode=0x00000120
+2014-10-23 20:38:18.701 (INFO ) [0xfffb669bdd0] VST-20020-31331-64:985586:ibm.runjob.client.Job: exited with status 0
+2014-10-23 20:38:18.702 (INFO ) [0xfffb669bdd0] tatu.runjob.client: task exited with status 0
+2014-10-23 20:38:34.261 (INFO ) [0xfff9b1634d0] 24194:tatu.runjob.monitor: tracklib completed
+2014-10-23 20:38:34.261 (INFO ) [0xfff9b1634d0] 24194:tatu.runjob.monitor: monitor terminating
+2014-10-23 20:38:34.266 (INFO ) [0xfffb669bdd0] tatu.runjob.client: monitor completed
Added: SwiftApps/subjobs/gridpack/logs/ca.0.stdout
--- SwiftApps/subjobs/gridpack/logs/ca.0.stdout (rev 0)
+++ SwiftApps/subjobs/gridpack/logs/ca.0.stdout 2015-01-28 19:15:58 UTC (rev 8377)
@@ -0,0 +1,47 @@
+/home/ketan/SwiftApps/subjobs/bg.sh: running BLOCK=VST-20020-31331-64 SLOT=0
+/home/ketan/SwiftApps/subjobs/bg.sh: running cmd: /home/ketan/SwiftApps/subjobs/bg.sh args: /home/ketan/gridpack-examples/contingency_analysis/ca.x infiles/input1.xml
+/home/ketan/SwiftApps/subjobs/bg.sh: running runjob --block VST-20020-31331-64 --corner R00-M0-N06-J17 --shape 1x1x1x1x1 --ranks-per-node 1 :
+GridPACK math module configured on 1 processors
+Name: CTG1
+ Line: (to) 13 (from) 14 (line) 'B1'
+Name: CTG2
+ Generator: (bus) 2 (generator ID) 1
+Executing task 0 on process 0
+Executing task 1 on process 0
+Number of tasks per processors
+ Number of tasks on process 0: 2
+Timing statistics for: Total Application
+ Average time: 0.1925
+ Maximum time: 0.1925
+ Minimum time: 0.1925
+Timing statistics for: Parse Input
+ Average time: 0.0395
+ Maximum time: 0.0395
+ Minimum time: 0.0395
+Timing statistics for: Partition Network
+ Average time: 0.0029
+ Maximum time: 0.0029
+ Minimum time: 0.0029
+Timing statistics for: Initialize Network
+ Average time: 0.0109
+ Maximum time: 0.0109
+ Minimum time: 0.0109
+Timing statistics for: Evaluate Contingency
+ Average time: 0.0812
+ Maximum time: 0.0812
+ Minimum time: 0.0812
+Timing statistics for: Check for Lone Bus
+ Average time: 0.0016
+ Maximum time: 0.0016
+ Minimum time: 0.0016
+Timing statistics for: Create Matrices and Vectors
+ Average time: 0.0168
+ Maximum time: 0.0168
+ Minimum time: 0.0168
+Timing statistics for: Solve Powerflow Equations
+ Average time: 0.0425
+ Maximum time: 0.0425
+ Minimum time: 0.0425
+Runjob finished.
Added: SwiftApps/subjobs/gridpack/logs/ca.1.stderr
--- SwiftApps/subjobs/gridpack/logs/ca.1.stderr (rev 0)
+++ SwiftApps/subjobs/gridpack/logs/ca.1.stderr 2015-01-28 19:15:58 UTC (rev 8377)
@@ -0,0 +1,601 @@
+2014-10-23 20:38:16.690 (INFO ) [0xfff8413bdd0] ibm.runjob.AbstractOptions: using properties file /bgsys/local/etc/bg.properties
+2014-10-23 20:38:16.691 (INFO ) [0xfff8413bdd0] ibm.runjob.AbstractOptions: max open file descriptors: 65536
+2014-10-23 20:38:16.691 (INFO ) [0xfff8413bdd0] ibm.runjob.AbstractOptions: core file limit: 18446744073709551615
+2014-10-23 20:38:16.693 (INFO ) [0xfff8413bdd0] 24278:tatu.runjob.client: scheduler job id is 222728
+2014-10-23 20:38:16.698 (INFO ) [0xfff9c9a34d0] 24278:tatu.runjob.monitor: monitor started
+2014-10-23 20:38:20.207 (INFO ) [0xfff9c9a34d0] 24278:tatu.runjob.monitor: task record 787264 created
+2014-10-23 20:38:20.208 (INFO ) [0xfff8413bdd0] VST-20020-31331-64:24278:ibm.runjob.client.options.Parser: set local socket to runjob_mux from properties file
+2014-10-23 20:38:23.515 (INFO ) [0xfff8413bdd0] VST-20020-31331-64:985587:ibm.runjob.client.Job: job 985587 started
+(I) sc_open[0.0:1]: pathname="infiles/input2.xml", flags=0x00000000 mode=(I) sc_getcwd[0.0:1]: buf=0x1f83a3dc80, len=4096
+(I) sc_open[0.0:1]: pathname="infiles/input2.xml", flags=0x00000000 mode=(I) sc_getcwd[0.0:1]: buf=0x1f83a3e2c0, len=4096
+(I) sc_open[0.0:1]: pathname="/etc/romio-hints", flags=0x00000000 mode=(I) sc_statfs[0.0:1]: pathname="/gpfs/vesta-fs0/logs/darshan/vesta/2014/10/23/ketan_ca.x_id222728_10-23-74303-14160679182986862505.darshan_partial", buf=0x1fbfffaea0
+(I) sc_lstat[0.0:1]: path="/gpfs/vesta-fs0/logs/darshan/vesta/2014/10/23/ketan_ca.x_id222728_10-23-74303-14160679182986862505.darshan_partial", buf=0x1fbfffaf20
+(I) sc_open[0.0:1]: pathname="/gpfs/vesta-fs0/logs/darshan/vesta/2014/10/23/ketan_ca.x_id222728_10-23-74303-14160679182986862505.darshan_partial", flags=0x000000c1 mode=(I) sc_stat[0.0:1]: path="/gpfs/vesta-fs0/logs/darshan/vesta/2014/10/23/ketan_ca.x_id222728_10-23-74303-14160679182986862505.darshan_partial", buf=0x1fbfffad20
+(I) sc_statfs[0.0:1]: pathname="/gpfs/vesta-fs0/logs/darshan/vesta/2014/10/23/ketan_ca.x_id222728_10-23-74303-14160679182986862505.darshan_partial", buf=0x1fbfffaca0
+(I) sc_open[0.0:1]: pathname="/gpfs/vesta-fs0/logs/darshan/vesta/2014/10/23/ketan_ca.x_id222728_10-23-74303-14160679182986862505.darshan_partial", flags=0x00000002 mode=(I) sc_stat[0.0:1]: path="/gpfs/vesta-fs0/logs/darshan/vesta/2014/10/23/ketan_ca.x_id222728_10-23-74303-14160679182986862505.darshan_partial", buf=0x1fbfffad20
+(I) sc_write[0.0:1]: fd=4, buf=0x1f85d120b8, cnt=983
+(I) sc_rename[0.0:1]: old="/gpfs/vesta-fs0/logs/darshan/vesta/2014/10/23/ketan_ca.x_id222728_10-23-74303-14160679182986862505.darshan_partial", new="/gpfs/vesta-fs0/logs/darshan/vesta/2014/10/23/ketan_ca.x_id222728_10-23-74303-14160679182986862505_1.darshan.gz"
+(I) sc_chmod[0.0:1]: path="/gpfs/vesta-fs0/logs/darshan/vesta/2014/10/23/ketan_ca.x_id222728_10-23-74303-14160679182986862505_1.darshan.gz", mode=0x00000120
+2014-10-23 20:38:25.359 (INFO ) [0xfff8413bdd0] VST-20020-31331-64:985587:ibm.runjob.client.Job: exited with status 0
+2014-10-23 20:38:25.360 (INFO ) [0xfff8413bdd0] tatu.runjob.client: task exited with status 0
+2014-10-23 20:38:34.298 (INFO ) [0xfff9c9a34d0] 24278:tatu.runjob.monitor: tracklib completed
+2014-10-23 20:38:34.298 (INFO ) [0xfff9c9a34d0] 24278:tatu.runjob.monitor: monitor terminating
+2014-10-23 20:38:34.302 (INFO ) [0xfff8413bdd0] tatu.runjob.client: monitor completed
Added: SwiftApps/subjobs/gridpack/logs/ca.1.stdout
--- SwiftApps/subjobs/gridpack/logs/ca.1.stdout (rev 0)
+++ SwiftApps/subjobs/gridpack/logs/ca.1.stdout 2015-01-28 19:15:58 UTC (rev 8377)
@@ -0,0 +1,47 @@
+/home/ketan/SwiftApps/subjobs/bg.sh: running BLOCK=VST-20020-31331-64 SLOT=1
+/home/ketan/SwiftApps/subjobs/bg.sh: running cmd: /home/ketan/SwiftApps/subjobs/bg.sh args: /home/ketan/gridpack-examples/contingency_analysis/ca.x infiles/input2.xml
+/home/ketan/SwiftApps/subjobs/bg.sh: running runjob --block VST-20020-31331-64 --corner R00-M0-N06-J22 --shape 1x1x1x1x1 --ranks-per-node 1 :
+Name: CTG1
+Name: CTG2
+ Average time: 0.1763
+ Maximum time: 0.1763
+ Minimum time: 0.1763
+ Average time: 0.0342
+ Maximum time: 0.0342
+ Minimum time: 0.0342
+ Average time: 0.0782
+ Maximum time: 0.0782
+ Minimum time: 0.0782
+ Average time: 0.0424
+ Maximum time: 0.0424
+ Minimum time: 0.0424
+Runjob finished.
Added: SwiftApps/subjobs/gridpack/logs/ca.2.stderr
--- SwiftApps/subjobs/gridpack/logs/ca.2.stderr (rev 0)
+++ SwiftApps/subjobs/gridpack/logs/ca.2.stderr 2015-01-28 19:15:58 UTC (rev 8377)
@@ -0,0 +1,601 @@
+2014-10-23 19:54:21.119 (INFO ) [0xfff7fcfbdd0] ibm.runjob.AbstractOptions: using properties file /bgsys/local/etc/bg.properties
+2014-10-23 19:54:21.121 (INFO ) [0xfff7fcfbdd0] ibm.runjob.AbstractOptions: max open file descriptors: 65536
+2014-10-23 19:54:21.121 (INFO ) [0xfff7fcfbdd0] ibm.runjob.AbstractOptions: core file limit: 18446744073709551615
+2014-10-23 19:54:21.122 (INFO ) [0xfff7fcfbdd0] 39910:tatu.runjob.client: scheduler job id is 222720
+2014-10-23 19:54:21.127 (INFO ) [0xfff9e2e34d0] 39910:tatu.runjob.monitor: monitor started
+2014-10-23 19:54:24.941 (INFO ) [0xfff9e2e34d0] 39910:tatu.runjob.monitor: task record 787256 created
+2014-10-23 19:54:24.942 (INFO ) [0xfff7fcfbdd0] VST-20000-31311-64:39910:ibm.runjob.client.options.Parser: set local socket to runjob_mux from properties file
+2014-10-23 19:54:28.222 (INFO ) [0xfff7fcfbdd0] VST-20000-31311-64:985579:ibm.runjob.client.Job: job 985579 started
+(I) sc_open[0.0:1]: pathname="/etc/romio-hints", flags=0x00000000 mode=(I) sc_statfs[0.0:1]: pathname="/gpfs/vesta-fs0/logs/darshan/vesta/2014/10/23/ketan_ca.x_id222720_10-23-71668-3888828592325710046.darshan_partial", buf=0x1fbfffaea0
+(I) sc_lstat[0.0:1]: path="/gpfs/vesta-fs0/logs/darshan/vesta/2014/10/23/ketan_ca.x_id222720_10-23-71668-3888828592325710046.darshan_partial", buf=0x1fbfffaf20
+(I) sc_open[0.0:1]: pathname="/gpfs/vesta-fs0/logs/darshan/vesta/2014/10/23/ketan_ca.x_id222720_10-23-71668-3888828592325710046.darshan_partial", flags=0x000000c1 mode=(I) sc_stat[0.0:1]: path="/gpfs/vesta-fs0/logs/darshan/vesta/2014/10/23/ketan_ca.x_id222720_10-23-71668-3888828592325710046.darshan_partial", buf=0x1fbfffad20
+(I) sc_statfs[0.0:1]: pathname="/gpfs/vesta-fs0/logs/darshan/vesta/2014/10/23/ketan_ca.x_id222720_10-23-71668-3888828592325710046.darshan_partial", buf=0x1fbfffaca0
+(I) sc_open[0.0:1]: pathname="/gpfs/vesta-fs0/logs/darshan/vesta/2014/10/23/ketan_ca.x_id222720_10-23-71668-3888828592325710046.darshan_partial", flags=0x00000002 mode=(I) sc_stat[0.0:1]: path="/gpfs/vesta-fs0/logs/darshan/vesta/2014/10/23/ketan_ca.x_id222720_10-23-71668-3888828592325710046.darshan_partial", buf=0x1fbfffad20
+(I) sc_write[0.0:1]: fd=4, buf=0x1f85d120b8, cnt=980
+(I) sc_rename[0.0:1]: old="/gpfs/vesta-fs0/logs/darshan/vesta/2014/10/23/ketan_ca.x_id222720_10-23-71668-3888828592325710046.darshan_partial", new="/gpfs/vesta-fs0/logs/darshan/vesta/2014/10/23/ketan_ca.x_id222720_10-23-71668-3888828592325710046_1.darshan.gz"
+(I) sc_chmod[0.0:1]: path="/gpfs/vesta-fs0/logs/darshan/vesta/2014/10/23/ketan_ca.x_id222720_10-23-71668-3888828592325710046_1.darshan.gz", mode=0x00000120
+2014-10-23 19:54:30.067 (INFO ) [0xfff7fcfbdd0] VST-20000-31311-64:985579:ibm.runjob.client.Job: exited with status 0
+2014-10-23 19:54:30.067 (INFO ) [0xfff7fcfbdd0] tatu.runjob.client: task exited with status 0
+2014-10-23 19:54:38.048 (INFO ) [0xfff9e2e34d0] 39910:tatu.runjob.monitor: tracklib completed
+2014-10-23 19:54:38.048 (INFO ) [0xfff9e2e34d0] 39910:tatu.runjob.monitor: monitor terminating
+2014-10-23 19:54:38.052 (INFO ) [0xfff7fcfbdd0] tatu.runjob.client: monitor completed
Added: SwiftApps/subjobs/gridpack/logs/ca.2.stdout
--- SwiftApps/subjobs/gridpack/logs/ca.2.stdout (rev 0)
+++ SwiftApps/subjobs/gridpack/logs/ca.2.stdout 2015-01-28 19:15:58 UTC (rev 8377)
@@ -0,0 +1,47 @@
+/home/ketan/SwiftApps/subjobs/bg.sh: running BLOCK=VST-20000-31311-64 SLOT=2
+/home/ketan/SwiftApps/subjobs/bg.sh: running cmd: /home/ketan/SwiftApps/subjobs/bg.sh args: /home/ketan/gridpack-examples/contingency_analysis/ca.x infiles/input3.xml
+/home/ketan/SwiftApps/subjobs/bg.sh: running runjob --block VST-20000-31311-64 --corner R00-M0-N04-J17 --shape 1x1x1x1x1 --ranks-per-node 1 :
+Name: CTG1
+Name: CTG2
+ Average time: 0.1757
+ Maximum time: 0.1757
+ Minimum time: 0.1757
+ Average time: 0.0340
+ Maximum time: 0.0340
+ Minimum time: 0.0340
+ Average time: 0.0779
+ Maximum time: 0.0779
+ Minimum time: 0.0779
+ Average time: 0.0422
+ Maximum time: 0.0422
+ Minimum time: 0.0422
+Runjob finished.
Added: SwiftApps/subjobs/gridpack/runswift.sh
--- SwiftApps/subjobs/gridpack/runswift.sh (rev 0)
+++ SwiftApps/subjobs/gridpack/runswift.sh 2015-01-28 19:15:58 UTC (rev 8377)
@@ -0,0 +1,10 @@
+#! /bin/sh
+#Old method
+#qsub -A ATPESC2014 -n 512 -t 15 --mode script runswift_script.sh -config cf -tc.file apps -sites.file localcoast.xml "$@"
+export COBALT_PROJ=ExM
+#New method
+/home/ketan/swift-0.95/cog/modules/swift/dist/swift-svn/bin/swift -sites.file cobalt.xml -config cf -tc.file apps contan.swift
+#A testblock run
+#qsub -A ATPESC2013 -n 32 -t 5 -q low --mode c16 --mode script testblock.sh # --disable_preboot
Property changes on: SwiftApps/subjobs/gridpack/runswift.sh
___________________________________________________________________
Added: svn:executable
Added: SwiftApps/subjobs/gridpack/runvesta.sh
--- SwiftApps/subjobs/gridpack/runvesta.sh (rev 0)
+++ SwiftApps/subjobs/gridpack/runvesta.sh 2015-01-28 19:15:58 UTC (rev 8377)
@@ -0,0 +1,10 @@
+#! /bin/sh
+#Old method
+#New method
+#A testblock run
Property changes on: SwiftApps/subjobs/gridpack/runvesta.sh
More information about the Swift-commit
