[Swift-commit] r7660 - SwiftApps/cloud
ketan at ci.uchicago.edu
Sat Mar 8 20:37:45 CST 2014
Author: ketan
Date: 2014-03-08 20:37:45 -0600 (Sat, 08 Mar 2014)
New Revision: 7660
Modified:
SwiftApps/cloud/README
Log:
asciidocify readme
Modified: SwiftApps/cloud/README
--- SwiftApps/cloud/README 2014-03-08 23:55:42 UTC (rev 7659)
+++ SwiftApps/cloud/README 2014-03-09 02:37:45 UTC (rev 7660)
@@ -1,32 +1,45 @@
Toolkit to run Swift applications over Amazon EC2 cloud
-0. Installation and setup of EC2 commandline tools is assumed. If you do not have already, please find instructions of getting EC2 api from here:
+EC2 setup
+Installation and setup of EC2 commandline tools is assumed. If you do not have already, please find instructions of getting EC2 api from here:
http://docs.aws.amazon.com/AWSEC2/latest/UserGuide/SettingUp_CommandLine.html
-1. Install Swift
+Install Swift
-2. Configure:
- a. environment variables
+Configure
+ environment variables
Make sure GLOBUS_TCP_PORT_RANGE and GLOBUS_HOSTNAME are defined. For example:
export GLOBUS_TCP_PORT_RANGE=50000,51000
export GLOBUS_HOSTNAME=churn.mcs.anl.gov
- c. ec2
+ EC2
ami-id, security group, keypair set up.
- b. coaster-service.conf
- Configure coaster-service.conf. An example coaster-service.conf can be found in the current directory. Make sure to set the EC2XXX variables to the correct values as per your account.
- Set other environment variables e.g:
+ coaster-service.conf
+ Configure coaster-service.conf. An example coaster-service.conf can be
+ found in the current directory. Make sure to set the EC2XXX variables to
+ the correct values as per your account. Set other environment variables
+ e.g:
- export WORKER_LOCATION=/home/ubuntu/worker
- export WORKER_USERNAME=ubuntu
- export LOG_DIR=logs
- export SHARED_FILESYSTEM=no
- export SSH_TUNNELING=yes
+ export WORKER_LOCATION=/home/ubuntu/worker export WORKER_USERNAME=ubuntu
+ export LOG_DIR=logs export SHARED_FILESYSTEM=no export SSH_TUNNELING=yes
-3. Start coaster service
+Start coaster service
Start the coaster service using the following command:
start-coaster-service
@@ -35,20 +48,48 @@
Make sure coaster-service.conf is available in the current working directory or use the "-conf" option to use config file located elsewhere.
-4. Start Swift run
+Start Swift run
Start swift run. Assuming your Swift scripts, applications and data are set, run a Swift script using swift command as follows:
swift -sites.file sites.xml -tc.file apps -config cf catsnsleep.swift -s=10 -n=20
The example catsnsleep.swift and cf files are provided with the package.
-5. Manage resources:
- a. Add EC2 compute instances
+Manage resources
+ Add EC2 compute instances
Add more resources via addnodes. Use -n to add by number and -a to add by ip address.
- b. Remove EC2 compute instances
+ Remove EC2 compute instances
Remove EC2 resources via remnodes.
- c. Monitor resources
+ Monitor resources
Monitor Swift tasks and EC2 instances while jobs are running.
-6. Shut everything down: stop-coaster-service
+Shut down
+stop-coaster-service
Use the stop-coaster-service command to stop everything.
+Troubleshoot
+ Coaster service
+ Swift
+ a. Swift not found: check your PATH and make sure the bin directory of Swift is added
+ b. Swift run shows no progress in task execution: Check if the cloud instances are running
+ c. Swift runs fail: Check if ports are open between submithost and cloud instance
More information about the Swift-commit
