[Swift-commit] r7661 - SwiftApps/cloud
ketan at ci.uchicago.edu
Sun Mar 9 11:54:35 CDT 2014
Author: ketan
Date: 2014-03-09 11:54:34 -0500 (Sun, 09 Mar 2014)
New Revision: 7661
Added:
SwiftApps/cloud/docbuild
Modified:
SwiftApps/cloud/README
Log:
doc build script
Modified: SwiftApps/cloud/README
--- SwiftApps/cloud/README 2014-03-09 02:37:45 UTC (rev 7660)
+++ SwiftApps/cloud/README 2014-03-09 16:54:34 UTC (rev 7661)
@@ -9,34 +9,35 @@
Install Swift
+To install Swift, follow instructions on swift-lang.org. Note that Swift installation is required only on the submit host and not on cloud nodes.
Configure
- environment variables
+environment variables
- Make sure GLOBUS_TCP_PORT_RANGE and GLOBUS_HOSTNAME are defined. For example:
- export GLOBUS_TCP_PORT_RANGE=50000,51000
- export GLOBUS_HOSTNAME=churn.mcs.anl.gov
- EC2
+Make sure GLOBUS_TCP_PORT_RANGE and GLOBUS_HOSTNAME are defined. For example:
- ami-id, security group, keypair set up.
+export GLOBUS_TCP_PORT_RANGE=50000,51000
+export GLOBUS_HOSTNAME=churn.mcs.anl.gov
- coaster-service.conf
+EC2
- Configure coaster-service.conf. An example coaster-service.conf can be
- found in the current directory. Make sure to set the EC2XXX variables to
- the correct values as per your account. Set other environment variables
- e.g:
- export WORKER_LOCATION=/home/ubuntu/worker export WORKER_USERNAME=ubuntu
- export LOG_DIR=logs export SHARED_FILESYSTEM=no export SSH_TUNNELING=yes
+ami-id, security group, keypair set up.
+coaster-service.conf
+Configure coaster-service.conf. An example coaster-service.conf can be
+found in the current directory. Make sure to set the EC2XXX variables to
+the correct values as per your account. Set other environment variables
+e.g:
+export WORKER_LOCATION=/home/ubuntu/worker export WORKER_USERNAME=ubuntu
+export LOG_DIR=logs export SHARED_FILESYSTEM=no export SSH_TUNNELING=yes
Start coaster service
@@ -60,21 +61,21 @@
Manage resources
- Add EC2 compute instances
+Add EC2 compute instances
- Add more resources via addnodes. Use -n to add by number and -a to add by ip address.
+Add more resources via addnodes. Use -n to add by number and -a to add by ip address.
- Remove EC2 compute instances
- Remove EC2 resources via remnodes.
- Monitor resources
+Remove EC2 compute instances
- Monitor Swift tasks and EC2 instances while jobs are running.
+Remove EC2 resources via remnodes.
+Monitor resources
+Monitor Swift tasks and EC2 instances while jobs are running.
Shut down
@@ -84,12 +85,12 @@
Troubleshoot
- Coaster service
+Coaster service
- Swift
- a. Swift not found: check your PATH and make sure the bin directory of Swift is added
- b. Swift run shows no progress in task execution: Check if the cloud instances are running
- c. Swift runs fail: Check if ports are open between submithost and cloud instance
+Swift
+a. Swift not found: check your PATH and make sure the bin directory of Swift is added
+b. Swift run shows no progress in task execution: Check if the cloud instances are running
+c. Swift runs fail: Check if ports are open between submithost and cloud instance
Added: SwiftApps/cloud/docbuild
--- SwiftApps/cloud/docbuild (rev 0)
+++ SwiftApps/cloud/docbuild 2014-03-09 16:54:34 UTC (rev 7661)
@@ -0,0 +1,3 @@
+#!/bin/bash
+asciidoc -a toc -a toclevels=2 -a max-width=750px -a textwidth=80 -o /home/ketan/public_html/cloudreadme.html README
Property changes on: SwiftApps/cloud/docbuild
___________________________________________________________________
Added: svn:executable
More information about the Swift-commit
