[Swift-commit] r7659 - SwiftApps/cloud
ketan at ci.uchicago.edu
Sat Mar 8 17:55:42 CST 2014
Author: ketan
Date: 2014-03-08 17:55:42 -0600 (Sat, 08 Mar 2014)
New Revision: 7659
Modified:
SwiftApps/cloud/README
Log:
add to readme
Modified: SwiftApps/cloud/README
--- SwiftApps/cloud/README 2014-03-08 23:31:39 UTC (rev 7658)
+++ SwiftApps/cloud/README 2014-03-08 23:55:42 UTC (rev 7659)
@@ -8,20 +8,40 @@
2. Configure:
a. environment variables
- Make sure GLOBUS_TCP_PORT_RANGE and GLOBUS_HOSTNAME are defined.
+ Make sure GLOBUS_TCP_PORT_RANGE and GLOBUS_HOSTNAME are defined. For example:
- b. coaster-service.conf
- Configure coaster-service.conf
+ export GLOBUS_TCP_PORT_RANGE=50000,51000
+ export GLOBUS_HOSTNAME=churn.mcs.anl.gov
c. ec2
ami-id, security group, keypair set up.
+ b. coaster-service.conf
+ Configure coaster-service.conf. An example coaster-service.conf can be found in the current directory. Make sure to set the EC2XXX variables to the correct values as per your account.
+ Set other environment variables e.g:
+ export WORKER_LOCATION=/home/ubuntu/worker
+ export WORKER_USERNAME=ubuntu
+ export LOG_DIR=logs
+ export SHARED_FILESYSTEM=no
+ export SSH_TUNNELING=yes
3. Start coaster service
-Start coaster service: start-coaster-service
+Start the coaster service using the following command:
+start-coaster-service
+Above command will generate an apps and sites configuration file. Use these configuration files to run Swift command as shown in the next section.
+Make sure coaster-service.conf is available in the current working directory or use the "-conf" option to use config file located elsewhere.
4. Start Swift run
-Start swift run.
+Start swift run. Assuming your Swift scripts, applications and data are set, run a Swift script using swift command as follows:
+ swift -sites.file sites.xml -tc.file apps -config cf catsnsleep.swift -s=10 -n=20
+The example catsnsleep.swift and cf files are provided with the package.
5. Manage resources:
a. Add EC2 compute instances
Add more resources via addnodes. Use -n to add by number and -a to add by ip address.
@@ -31,3 +51,4 @@
Monitor Swift tasks and EC2 instances while jobs are running.
6. Shut everything down: stop-coaster-service
+Use the stop-coaster-service command to stop everything.
More information about the Swift-commit
