[Swift-commit] r5167 - trunk/bin
davidk at ci.uchicago.edu
Sat Sep 24 16:32:35 CDT 2011
Author: davidk
Date: 2011-09-24 16:32:35 -0500 (Sat, 24 Sep 2011)
New Revision: 5167
Modified:
trunk/bin/gensites
trunk/bin/start-coaster-service
trunk/bin/stop-coaster-service
Log:
Updated coaster scripts and gensites into trunk
Modified: trunk/bin/gensites
--- trunk/bin/gensites 2011-09-24 21:29:54 UTC (rev 5166)
+++ trunk/bin/gensites 2011-09-24 21:32:35 UTC (rev 5167)
@@ -45,7 +45,7 @@
Examples:
- Create a site configuration file for sites.xml using default properties.file in current directory
+ Create a site configuration file for sites.xml using swift.properties in current directory
$ gensites pads > sites.xml
Use a specific properties file for a site
@@ -88,7 +88,7 @@
fi
# List all templates
-if [ ! -z $LIST_TEMPLATES ]; then
+if [ ! -z "$LIST_TEMPLATES" ]; then
# Templates in etc/sites
for file in `ls -1 $SWIFT_HOME/* 2>/dev/null`
do
@@ -127,92 +127,89 @@
fi
# List a specific template
-if [ ! -z $LIST_SPECIFIC_TEMPLATE ]; then
+if [ ! -z "$LIST_SPECIFIC_TEMPLATE" ]; then
cat $TEMPLATE_PATH
exit 0
fi
# Ensure a properties file exists
if [ ! -f "$PROPERTIES_FILE" ]; then
- PROPERTIES_FILE="swift.properties"
+ PROPERTIES_FILE="./swift.properties"
PROPERTIES_FILE="$HOME/.swift/swift.properties"
- if [ ! -f "$PROPERTIES_FILE" ]; then
- crash "Unable to find a valid properties file! Please specify a valid file with the -p option"
- fi
fi
fi
# Setup for creating a TC file
-if [ -f "tc.data" ] && [ -n "`grep -e app $PROPERTIES_FILE`" ]; then
- mv tc.data tc.data.old
- HOSTS=`grep -i "pool handle" $TEMPLATE|grep -v "^[[:space:]]*#"|cut -d'"' -f2`
+if [ -n "`grep -e app $PROPERTIES_FILE`" ]; then
+ if [ -f "tc.data" ]; then
+ mv tc.data tc.data.old
+ fi
+ HOSTS=`grep -i "pool handle" $TEMPLATE_PATH|grep -v "^[[:space:]]*#"|cut -d'"' -f2`
fi
# Parse values into variables for later sed processing
-#WORK=`pwd`"/work"
-while read line
-do
- case "$line" in
- "#site $TEMPLATE work="*|'#site work='*)
- WORK=`get_value $line`
+if [ -f "$PROPERTIES_FILE" ]; then
+ while read line
+ do
+ case "$line" in
+ "#site $TEMPLATE work="*|'#site work='*)
+ WORK=`get_value $line`
+ "#site $TEMPLATE globus_hostname="*|'#site globus_hostname=')
+ GLOBUS_HOSTNAME=`get_value $line`
+ "#site $TEMPLATE nodes="*|'#site nodes='*)
+ NODES=`get_value $line`
+ "#site $TEMPLATE project="*|'#site project='*)
+ PROJECT=`get_value $line`
+ "#site $TEMPLATE queue="*|'#site queue='*)
+ QUEUE=`get_value $line`
+ "#site $TEMPLATE n_gran="*|'#site n_gran='*)
+ N_GRAN=`get_value $line`
+ "#site $TEMPLATE n_max="*|'#site n_max='*)
+ MAXTIME=`get_value $line`
+ "#site $TEMPLATE slots="*|'#site slots='*)
+ SLOTS=`get_value $line`
+ "#site $TEMPLATE execution_url="*|'#site execution_url='*)
+ EXECUTION_URL=`get_value $line`
+ "#site $TEMPLATE internalhostname="*|'#site internalhostname='*)
+ INTERNALHOSTNAME=`get_value $line`
+ '#app'*)
+ if [ `echo $line | wc -w` == 2 ]; then
+ for HOST in $HOSTS
+ do
+ NAME=`echo $line |cut -d'=' -f1|awk '{print $2}'`
+ COMMAND=`echo $line |cut -d'=' -f2`
+ COMMAND=`eval echo $COMMAND`
+ echo $HOST $NAME `readlink -f $COMMAND` null null null >> tc.data
+ done
+ fi
+ if [ `echo $line |wc -w` == 3 ]; then
+ do
+ if [ $HOST == `echo $line|awk '{print $2}'` ]; then
+ NAME=`echo $line|awk '{print $3}'|cut -d'=' -f1`
+ COMMAND=`echo $line|awk '{print $3}'|cut -d'=' -f2`
+ eval echo $HOST $NAME `readlink -f $COMMAND` null null null >> tc.data
+ fi
+ done
+ fi
- "#site $TEMPLATE globus_hostname="*|'#site globus_hostname=')
- GLOBUS_HOSTNAME=`get_value $line`
- "#site $TEMPLATE nodes="*|'#site nodes='*)
- NODES=`get_value $line`
- "#site $TEMPLATE project="*|'#site project='*)
- PROJECT=`get_value $line`
- "#site $TEMPLATE queue="*|'#site queue='*)
- QUEUE=`get_value $line`
- "#site $TEMPLATE n_gran="*|'#site n_gran='*)
- N_GRAN=`get_value $line`
- "#site $TEMPLATE n_max="*|'#site n_max='*)
- MAXTIME=`get_value $line`
- "#site $TEMPLATE slots="*|'#site slots='*)
- SLOTS=`get_value $line`
- "#site $TEMPLATE execution_url="*|'#site execution_url='*)
- EXECUTION_URL=`get_value $line`
- "#site $TEMPLATE internalhostname="*|'#site internalhostname='*)
- INTERNALHOSTNAME=`get_value $line`
- '#app'*)
- if [ `echo $line | wc -w` == 2 ]; then
- for HOST in $HOSTS
- do
- NAME=`echo $line |cut -d'=' -f1|awk '{print $2}'`
- COMMAND=`echo $line |cut -d'=' -f2`
- COMMAND=`eval echo $COMMAND`
- echo $HOST $NAME `readlink -f $COMMAND` null null null >> tc.data
- done
- fi
- if [ `echo $line |wc -w` == 3 ]; then
- do
- if [ $HOST == `echo $line|awk '{print $2}'` ]; then
- NAME=`echo $line|awk '{print $3}'|cut -d'=' -f1`
- COMMAND=`echo $line|awk '{print $3}'|cut -d'=' -f2`
- eval echo $HOST $NAME `readlink -f $COMMAND` null null null >> tc.data
- fi
- done
- fi
- esac
-done < $PROPERTIES_FILE
+ esac
+ done < $PROPERTIES_FILE
+fi
-# Test for mandatory variables
-[[ ${WORK} == "" ]] && crash "Not specified: WORK"
# Verify that the variables by the template are defined
for TOKEN in NODES HOST WORK PROJECT QUEUE N_GRAN N_MAX SLOTS INTERNALHOSTNAME MAXTIME EXECUTION_URL
do
Modified: trunk/bin/start-coaster-service
--- trunk/bin/start-coaster-service 2011-09-24 21:29:54 UTC (rev 5166)
+++ trunk/bin/start-coaster-service 2011-09-24 21:32:35 UTC (rev 5167)
@@ -119,18 +119,18 @@
RUN_DIR=`pwd`
# Import settings
-if [ -f "$HOME/.swift/coaster-service.conf" ]; then
+if [ -f "$RUN_DIR/coaster-service.conf" ]; then
+ CONFIG_FILE="$RUN_DIR/coaster-service.conf"
+elif [ -f "$HOME/.swift/coaster-service.conf" ]; then
CONFIG_FILE="$HOME/.swift/coaster-service.conf"
elif [ -f "$(dirname $(readlink -f $0))/../etc/coaster-service.conf" ]; then
CONFIG_FILE="$(dirname $(readlink -f $0))/../etc/coaster-service.conf"
-fi
-if [ -n "$CONFIG_FILE" ]; then
- source "$CONFIG_FILE"
else
crash "Cannot find coaster-service.conf!"
fi
+source $CONFIG_FILE
# Determine information needed about this machine
if [ -z "$IPADDR" ]; then
if [ -x "/sbin/ifconfig" ]; then
Modified: trunk/bin/stop-coaster-service
--- trunk/bin/stop-coaster-service 2011-09-24 21:29:54 UTC (rev 5166)
+++ trunk/bin/stop-coaster-service 2011-09-24 21:32:35 UTC (rev 5167)
@@ -12,24 +12,19 @@
PID_FILE="$HOME/.swift/.coaster-service-pids"
SWIFTVM_INSTANCES="$HOME/.swift/.swiftvm_instances"
+# Import settings
+if [ -f "./coaster-service.conf" ]; then
+ CONFIG_FILE="./coaster-service.conf"
-fi
-if [ -z "$CONFIG_FILE" ]; then
- crash "Unable to find coaster-service.conf!"
-fi
-# Read config file to determine worker mode
-if [ -f "$CONFIG_FILE" ]; then
else
fi
+source "$CONFIG_FILE"
echo Ending coaster processes..
if [ -f "$PID_FILE" ]; then
for pid in `cat $PID_FILE`
More information about the Swift-commit
