[Swift-commit] r5168 - in branches/release-0.93: bin etc/sites tests
davidk at ci.uchicago.edu davidk at ci.uchicago.edu
Sat Sep 24 20:53:15 CDT 2011
Author: davidk
Date: 2011-09-24 20:53:14 -0500 (Sat, 24 Sep 2011)
New Revision: 5168
Added:
   branches/release-0.93/etc/sites/local
   branches/release-0.93/etc/sites/local-coasters
Modified:
   branches/release-0.93/bin/gensites
   branches/release-0.93/tests/suite.sh
Log:
Suite and gensites fixes
Added site templates from suite
Modified: branches/release-0.93/bin/gensites
--- branches/release-0.93/bin/gensites	2011-09-24 21:32:35 UTC (rev 5167)
+++ branches/release-0.93/bin/gensites	2011-09-25 01:53:14 UTC (rev 5168)
@@ -133,19 +133,22 @@
 fi
 # Ensure a properties file exists
-if [ ! -f "$PROPERTIES_FILE" ]; then
-   PROPERTIES_FILE="./swift.properties"
-   if [ ! -f "$PROPERTIES_FILE" ]; then
+if [ -z "$PROPERTIES_FILE" ]; then
+   if [ -f "./swift.properties" ]; then
+      PROPERTIES_FILE="./swift.properties"
+   elif [ -f "$HOME/.swift/swift.properties" ]; then
       PROPERTIES_FILE="$HOME/.swift/swift.properties"
    fi
 fi
 # Setup for creating a TC file
-if [ -n "`grep -e app $PROPERTIES_FILE`" ]; then
-   if [ -f "tc.data" ]; then
-      mv tc.data tc.data.old
+if [ -f "$PROPERTIES_FILE" ]; then
+   if [ -n "`grep -e app $PROPERTIES_FILE`" ]; then
+      if [ -f "tc.data" ]; then
+         mv tc.data tc.data.old
+      fi
+      HOSTS=`grep -i "pool handle" $TEMPLATE_PATH|grep -v "^[[:space:]]*#"|cut -d'"' -f2`
    fi
-   HOSTS=`grep -i "pool handle" $TEMPLATE_PATH|grep -v "^[[:space:]]*#"|cut -d'"' -f2`
 fi
 # Parse values into variables for later sed processing
Added: branches/release-0.93/etc/sites/local
--- branches/release-0.93/etc/sites/local	                        (rev 0)
+++ branches/release-0.93/etc/sites/local	2011-09-25 01:53:14 UTC (rev 5168)
@@ -0,0 +1,9 @@
+<config>
+<pool handle="local">
+  <execution provider="local" />
+  <gridftp url="local://localhost" />
+  <profile key="initialScore" namespace="karajan">10000</profile>
+  <profile key="jobThrottle" namespace="karajan">.31</profile>
+  <workdirectory>_WORK_</workdirectory>
+</pool>
+</config>
Added: branches/release-0.93/etc/sites/local-coasters
--- branches/release-0.93/etc/sites/local-coasters	                        (rev 0)
+++ branches/release-0.93/etc/sites/local-coasters	2011-09-25 01:53:14 UTC (rev 5168)
@@ -0,0 +1,24 @@
+<config>
+  <pool handle="localhost" sysinfo="INTEL32::LINUX">
+    <execution provider="local" url="none" />
+    <profile namespace="swift" key="stagingMethod">file</profile>
+  </pool>
+  <pool handle="coasterslocal">
+    <filesystem provider="local" />
+    <execution provider="coaster" jobmanager="local:local"/>
+    <profile namespace="globus"   key="internalHostname">_HOST_</profile>
+    <profile namespace="karajan"  key="jobthrottle">2.55</profile>
+    <profile namespace="karajan"  key="initialScore">10000</profile>
+    <profile namespace="globus"   key="jobsPerNode">4</profile>
+    <profile namespace="globus"   key="slots">8</profile>
+    <profile namespace="globus"   key="maxTime">1000</profile>
+    <profile namespace="globus"   key="nodeGranularity">1</profile>
+    <profile namespace="globus"   key="maxNodes">4</profile>
+  </pool>
+</config>
Modified: branches/release-0.93/tests/suite.sh
--- branches/release-0.93/tests/suite.sh	2011-09-24 21:32:35 UTC (rev 5167)
+++ branches/release-0.93/tests/suite.sh	2011-09-25 01:53:14 UTC (rev 5168)
@@ -940,18 +940,6 @@
   output_report package "swift-$DATE.tar.gz"
-# Generate the sites.sed file
-make_sites_sed() {
-    echo "s at _WORK_@$WORK@"
-    echo "s at _HOST_@$GLOBUS_HOSTNAME@"
-    echo "s at _PROJECT_@$PROJECT@"
-    echo "s at _QUEUE_@$QUEUE@"
-    echo "s at _EXECUTION_URL_@$EXECUTION_URL@"
-  } > $RUNDIR/sites.sed
-  return 0
 # Setup coasters variables
 if which ifconfig > /dev/null 2>&1; then
   IFCONFIG=ifconfig
@@ -965,20 +953,34 @@
 # Generate sites.xml
 group_sites_xml() {
-  TEMPLATE=$GROUP/sites.template.xml
-  if [ -f $TEMPLATE ]; then
-    sed -f $RUNDIR/sites.sed < $TEMPLATE > sites.xml
-    [ $? != 0 ] && crash "Could not create sites.xml!"
-    echo "Using: $GROUP/sites.template.xml"
+  # Determine template
+  if [ -f "$GROUP/sites.template.xml" ]; then
+     TEMPLATE="$GROUP/sites.template.xml"
+  elif [ -f "$GROUP/gensites.template" ]; then
+     TEMPLATE=`cat $GROUP/gensites.template`
   else
-    sed "s at _WORK_@$PWD/work@" < $TESTDIR/sites/localhost.xml > sites.xml
-    echo "Using: $TESTDIR/sites/localhost.xml"
+     TEMPLATE="$TESTDIR/sites/localhost.xml"
   fi
+  # Call gensites
+  TEMPLATE_DIRNAME=`dirname $TEMPLATE`
+  TEMPLATE=`basename $TEMPLATE`
+  if [ "$TEMPLATE_DIRNAME" != "." ]; then
+     gensites -L $TEMPLATE_DIRNAME $TEMPLATE > sites.xml
+  else
+     gensites $TEMPLATE > sites.xml
+  fi
 # Generate tc.data
 group_tc_data() {
+  # Gensites will create a tc.data file if it is being used
+  if [ -f "$GROUP/gensites.template" ]; then
+     return
+  fi
   if [ -f $GROUP/tc.template.data ]; then
     sed "s at _DIR_@$GROUP@" < $GROUP/tc.template.data > tc.data
     [ $? != 0 ] && crash "Could not create tc.data!"
@@ -994,6 +996,7 @@
   fi
 # Generate the CDM file, fs.data
 group_fs_data() {
   if [ -f $GROUP/fs.template.data ]; then
@@ -1062,10 +1065,10 @@
 # Execute all tests in current GROUP
 test_group() {
+  group_swift_properties
   group_sites_xml
   group_tc_data
   group_fs_data
-  group_swift_properties
   SWIFTS=$( echo $GROUP/*.swift )
   checkfail "Could not list: $GROUP"
@@ -1159,7 +1162,6 @@
 date > $LOG
-make_sites_sed
 # Here the report starts.
 # Call to function header()
@@ -1244,6 +1246,7 @@
   (( $SHUTDOWN )) && break
 done
+footer
 exit 0
 # Local Variables:
