[Swift-commit] r5166 - branches/release-0.93/bin
davidk at ci.uchicago.edu
Sat Sep 24 16:29:54 CDT 2011
Author: davidk
Date: 2011-09-24 16:29:54 -0500 (Sat, 24 Sep 2011)
New Revision: 5166
Modified:
branches/release-0.93/bin/gensites
Log:
Gensites fixes
Modified: branches/release-0.93/bin/gensites
--- branches/release-0.93/bin/gensites 2011-09-24 20:59:40 UTC (rev 5165)
+++ branches/release-0.93/bin/gensites 2011-09-24 21:29:54 UTC (rev 5166)
@@ -88,7 +88,7 @@
fi
# List all templates
-if [ ! -z $LIST_TEMPLATES ]; then
+if [ ! -z "$LIST_TEMPLATES" ]; then
# Templates in etc/sites
for file in `ls -1 $SWIFT_HOME/* 2>/dev/null`
do
@@ -115,7 +115,7 @@
# Locate template
if [ ! -f "$TEMPLATE_PATH" ]; then
if [ -f "$TEMPLATE" ]; then
- $TEMPLATE_PATH = $TEMPLATE
+ TEMPLATE_PATH=$TEMPLATE
elif [ -f "$SWIFT_HOME/$TEMPLATE" ]; then
TEMPLATE_PATH=$SWIFT_HOME/$TEMPLATE
elif [ -f "$HOME/.swift/sites/$TEMPLATE" ]; then
@@ -127,7 +127,7 @@
fi
# List a specific template
-if [ ! -z $LIST_SPECIFIC_TEMPLATE ]; then
+if [ ! -z "$LIST_SPECIFIC_TEMPLATE" ]; then
cat $TEMPLATE_PATH
exit 0
fi
@@ -140,6 +140,14 @@
fi
fi
+# Setup for creating a TC file
+if [ -n "`grep -e app $PROPERTIES_FILE`" ]; then
+ if [ -f "tc.data" ]; then
+ mv tc.data tc.data.old
+ fi
+ HOSTS=`grep -i "pool handle" $TEMPLATE_PATH|grep -v "^[[:space:]]*#"|cut -d'"' -f2`
+fi
# Parse values into variables for later sed processing
if [ -f "$PROPERTIES_FILE" ]; then
while read line
@@ -175,6 +183,29 @@
"#site $TEMPLATE internalhostname="*|'#site internalhostname='*)
INTERNALHOSTNAME=`get_value $line`
+ '#app'*)
+ if [ `echo $line | wc -w` == 2 ]; then
+ for HOST in $HOSTS
+ do
+ NAME=`echo $line |cut -d'=' -f1|awk '{print $2}'`
+ COMMAND=`echo $line |cut -d'=' -f2`
+ COMMAND=`eval echo $COMMAND`
+ echo $HOST $NAME `readlink -f $COMMAND` null null null >> tc.data
+ done
+ fi
+ if [ `echo $line |wc -w` == 3 ]; then
+ do
+ if [ $HOST == `echo $line|awk '{print $2}'` ]; then
+ NAME=`echo $line|awk '{print $3}'|cut -d'=' -f1`
+ COMMAND=`echo $line|awk '{print $3}'|cut -d'=' -f2`
+ eval echo $HOST $NAME `readlink -f $COMMAND` null null null >> tc.data
+ fi
+ done
+ fi
esac
done < $PROPERTIES_FILE
fi
More information about the Swift-commit
