[Swift-commit] r4472 - trunk/src/org/griphyn/vdl/mapping
hategan at ci.uchicago.edu
Fri May 13 18:11:48 CDT 2011
Author: hategan
Date: 2011-05-13 18:11:48 -0500 (Fri, 13 May 2011)
New Revision: 4472
Modified:
trunk/src/org/griphyn/vdl/mapping/RootDataNode.java
Log:
fixed issue where odd exception would be thrown when using dependent mapper params
Modified: trunk/src/org/griphyn/vdl/mapping/RootDataNode.java
--- trunk/src/org/griphyn/vdl/mapping/RootDataNode.java 2011-05-13 20:21:23 UTC (rev 4471)
+++ trunk/src/org/griphyn/vdl/mapping/RootDataNode.java 2011-05-13 23:11:48 UTC (rev 4472)
@@ -58,9 +58,13 @@
try {
mapper = MapperFactory.getMapper(desc, params);
+ getField().setName(PARAM_PREFIX.getStringValue(mapper));
+ // initialized means that this data has its mapper initialized
+ // this should be called before checkInputs because the latter
+ // may trigger calls to things that try to access this data node's
+ // mapper
+ initialized();
checkInputs();
- getField().setName(PARAM_PREFIX.getStringValue(mapper));
- initialized();
catch (InvalidMapperException e) {
throw new RuntimeException("InvalidMapperException caught in mapper initialization", e);
@@ -202,10 +206,11 @@
public Mapper getMapper() {
- if(initialized) {
+ if (initialized) {
return mapper;
- } else {
- assert(waitingMapperParam != null);
+ else {
+ assert (waitingMapperParam != null);
throw new VDL2FutureException(waitingMapperParam);
@@ -220,6 +225,7 @@
private void initialized() {
- initialized=true;
+ initialized = true;
+ waitingMapperParam = null;
More information about the Swift-commit
