[Swift-commit] r4473 - in trunk/src/org/griphyn/vdl: karajan/lib karajan/lib/swiftscript mapping
hategan at ci.uchicago.edu
Fri May 13 18:12:32 CDT 2011
Author: hategan
Date: 2011-05-13 18:12:32 -0500 (Fri, 13 May 2011)
New Revision: 4473
Modified:
trunk/src/org/griphyn/vdl/karajan/lib/SwiftArg.java
trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java
trunk/src/org/griphyn/vdl/mapping/AbstractDataNode.java
trunk/src/org/griphyn/vdl/mapping/MappingParam.java
Log:
nicer representation of data in toString()
Modified: trunk/src/org/griphyn/vdl/karajan/lib/SwiftArg.java
--- trunk/src/org/griphyn/vdl/karajan/lib/SwiftArg.java 2011-05-13 23:11:48 UTC (rev 4472)
+++ trunk/src/org/griphyn/vdl/karajan/lib/SwiftArg.java 2011-05-13 23:12:32 UTC (rev 4473)
@@ -22,7 +22,7 @@
public abstract class SwiftArg extends Arg {
public static final Logger logger = Logger.getLogger(SwiftArg.class);
public SwiftArg(String name, int index) {
super(name, index);
Modified: trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java
--- trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java 2011-05-13 23:11:48 UTC (rev 4472)
+++ trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java 2011-05-13 23:12:32 UTC (rev 4473)
@@ -65,22 +65,27 @@
for (int i = 0; i < args.length; i++) {
DSHandle handle = args[i];
VDLFunction.waitFor(stack, handle);
- if(i!=0) buf.append(", ");
+ if (i != 0) {
+ buf.append(", ");
buf.append(args[i]);
traceLogger.warn(buf);
return null;
- public DSHandle swiftscript_strcat(VariableStack stack)
- throws ExecutionException {
- logger.debug(stack);
+ public DSHandle swiftscript_strcat(VariableStack stack) throws ExecutionException {
+ if (logger.isDebugEnabled()) {
+ logger.debug(stack);
Object[] args = SwiftArg.VARGS.asArray(stack);
int provid = VDLFunction.nextProvenanceID();
StringBuffer buf = new StringBuffer();
buf.append(TypeUtil.toString(args[i]));
DSHandle handle = new RootDataNode(Types.STRING);
handle.setValue(buf.toString());
handle.closeShallow();
Modified: trunk/src/org/griphyn/vdl/mapping/AbstractDataNode.java
--- trunk/src/org/griphyn/vdl/mapping/AbstractDataNode.java 2011-05-13 23:11:48 UTC (rev 4472)
+++ trunk/src/org/griphyn/vdl/mapping/AbstractDataNode.java 2011-05-13 23:12:32 UTC (rev 4473)
@@ -85,24 +85,36 @@
* text description.
public String toString() {
- if (this.value != null && !(this.value instanceof Exception)) {
- // special handling for ints...
- if (this.getType().equals(Types.INT)) {
- try {
- Number n = (Number) this.getValue();
- return String.valueOf(n.intValue());
- catch (ClassCastException e) {
- throw new RuntimeException(
- "Internal type error. Value is not a Number for "
- + getDisplayableName() + getPathFromRoot());
- else {
- return this.value.toString();
+ return toDisplayableString();
+ private String toDisplayableString() {
+ StringBuilder sb = new StringBuilder();
+ sb.append(getDisplayableName());
+ Path p = getPathFromRoot();
+ if (!p.isEmpty()) {
+ sb.append(".");
+ sb.append(p.toString());
- return getIdentifyingString();
+ sb.append(":");
+ sb.append(getType());
+ sb.append(" = ");
+ if (value == null) {
+ sb.append("?");
+ else if (value instanceof Throwable) {
+ sb.append(value.getClass().getName());
+ else {
+ sb.append(value);
+ if (closed) {
+ sb.append(" - Closed");
+ else {
+ sb.append(" - Open");
+ return sb.toString();
public String getIdentifyingString() {
@@ -152,7 +164,7 @@
prefix = getRoot().getParam("prefix");
if (prefix == null) {
- prefix = "unnamed SwiftScript value";
+ prefix = "?";
return prefix;
Modified: trunk/src/org/griphyn/vdl/mapping/MappingParam.java
--- trunk/src/org/griphyn/vdl/mapping/MappingParam.java 2011-05-13 23:11:48 UTC (rev 4472)
+++ trunk/src/org/griphyn/vdl/mapping/MappingParam.java 2011-05-13 23:12:32 UTC (rev 4473)
@@ -44,7 +44,7 @@
if (value instanceof DSHandle) {
DSHandle handle = (DSHandle) value;
checkHandle(handle);
- return handle.toString();
+ return handle.getValue().toString();
else if (value == null) {
if (!defSet) {
@@ -65,7 +65,7 @@
if (!defSet) {
@@ -102,15 +102,17 @@
converted to a String as appropriate. */
public String getStringValue(Mapper mapper) {
Object value = getValue(mapper);
- if (value == null)
return null;
return String.valueOf(value);
public String getStringValue(Map params) {
Object value = getValue(params);
return null;
More information about the Swift-commit
