[Swift-commit] r4471 - in trunk/src/org/griphyn/vdl/karajan: . lib lib/cache
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Fri May 13 15:21:23 CDT 2011
Author: hategan
Date: 2011-05-13 15:21:23 -0500 (Fri, 13 May 2011)
New Revision: 4471
Modified:
   trunk/src/org/griphyn/vdl/karajan/ArrayIndexFutureList.java
   trunk/src/org/griphyn/vdl/karajan/DSHandleFutureWrapper.java
   trunk/src/org/griphyn/vdl/karajan/FuturePairIterator.java
   trunk/src/org/griphyn/vdl/karajan/lib/FileCopier.java
   trunk/src/org/griphyn/vdl/karajan/lib/ThrottledParallelFor.java
   trunk/src/org/griphyn/vdl/karajan/lib/cache/File.java
Log:
updated to reflect removal of checked exception in Future.getValue()
Modified: trunk/src/org/griphyn/vdl/karajan/ArrayIndexFutureList.java
--- trunk/src/org/griphyn/vdl/karajan/ArrayIndexFutureList.java	2011-05-13 20:19:45 UTC (rev 4470)
+++ trunk/src/org/griphyn/vdl/karajan/ArrayIndexFutureList.java	2011-05-13 20:21:23 UTC (rev 4471)
@@ -84,7 +84,7 @@
         return closed;
-    public Object getValue() throws VariableNotFoundException {
+    public Object getValue() {
         return this;
Modified: trunk/src/org/griphyn/vdl/karajan/DSHandleFutureWrapper.java
--- trunk/src/org/griphyn/vdl/karajan/DSHandleFutureWrapper.java	2011-05-13 20:19:45 UTC (rev 4470)
+++ trunk/src/org/griphyn/vdl/karajan/DSHandleFutureWrapper.java	2011-05-13 20:21:23 UTC (rev 4471)
@@ -33,7 +33,7 @@
 		return handle.isClosed();
-	public synchronized Object getValue() throws VariableNotFoundException {
+	public synchronized Object getValue() {
 		Object value = handle.getValue();
 		if (value instanceof RuntimeException) {
 			throw (RuntimeException) value;
Modified: trunk/src/org/griphyn/vdl/karajan/FuturePairIterator.java
--- trunk/src/org/griphyn/vdl/karajan/FuturePairIterator.java	2011-05-13 20:19:45 UTC (rev 4470)
+++ trunk/src/org/griphyn/vdl/karajan/FuturePairIterator.java	2011-05-13 20:21:23 UTC (rev 4471)
@@ -89,7 +89,7 @@
 		return array.isClosed();
 		return this;
Modified: trunk/src/org/griphyn/vdl/karajan/lib/FileCopier.java
--- trunk/src/org/griphyn/vdl/karajan/lib/FileCopier.java	2011-05-13 20:19:45 UTC (rev 4470)
+++ trunk/src/org/griphyn/vdl/karajan/lib/FileCopier.java	2011-05-13 20:21:23 UTC (rev 4471)
@@ -106,7 +106,7 @@
         actions();
-    public Object getValue() throws ExecutionException {
         return null;
Modified: trunk/src/org/griphyn/vdl/karajan/lib/ThrottledParallelFor.java
--- trunk/src/org/griphyn/vdl/karajan/lib/ThrottledParallelFor.java	2011-05-13 20:19:45 UTC (rev 4470)
+++ trunk/src/org/griphyn/vdl/karajan/lib/ThrottledParallelFor.java	2011-05-13 20:21:23 UTC (rev 4471)
@@ -285,7 +285,7 @@
 		public void fail(FutureEvaluationException e) {
 			return null;
Modified: trunk/src/org/griphyn/vdl/karajan/lib/cache/File.java
--- trunk/src/org/griphyn/vdl/karajan/lib/cache/File.java	2011-05-13 20:19:45 UTC (rev 4470)
+++ trunk/src/org/griphyn/vdl/karajan/lib/cache/File.java	2011-05-13 20:21:23 UTC (rev 4471)
@@ -175,7 +175,7 @@
 		return null;
