[Swift-commit] r4690 - trunk/tests
achavez at ci.uchicago.edu
Fri Jun 24 14:16:50 CDT 2011
Author: achavez
Date: 2011-06-24 14:16:50 -0500 (Fri, 24 Jun 2011)
New Revision: 4690
Modified:
trunk/tests/suite.sh
Log:
HTML enhanced, it shows the amount of time it took to run each swift script, when a helper script is not present, it fills the gap with a NP, Not Present, Flag.
Modified: trunk/tests/suite.sh
--- trunk/tests/suite.sh 2011-06-24 18:51:26 UTC (rev 4689)
+++ trunk/tests/suite.sh 2011-06-24 19:16:50 UTC (rev 4690)
@@ -31,6 +31,8 @@
SKIP_CHECKOUT=0
ALWAYS_EXITONFAILURE=0
VERBOSE=0
+TOTAL_TIME=0
+INDIVIDUAL_TEST_TIME=0
# The directory in which to start:
TOPDIR=$PWD
@@ -334,14 +336,14 @@
# Create either HTML or plain text report.
# $TEXTREPORT monitor whether the report will be plain text or HTML
output_report() {
TYPE=$1
+ LABEL="$2" # Text on link to output
+ CMD=$3 # Command issued (td title)
+ RESULT=$4 # Passed or Failed
if [ $TEXTREPORT == 1 ]; then
if [ "$TYPE" == "test" ]; then
- LABEL="$2" # Text on link to output
- CMD=$3 # Command issued (td title)
- RESULT=$4 # Passed or Failed
if [ "$RESULT" == "Passed" ]; then
printf %-10.10s "success">>$REPORT
else
@@ -357,11 +359,6 @@
fi
else
# WIDTH=$( width "$LABEL" )
html_td class "success" width 25 title "$CMD"
@@ -373,7 +370,6 @@
html_a_href $TEST_LOG $LABEL
fi
html_~td
elif [ "$TYPE" == "package" ]; then
BINPACKAGE=$2
else
@@ -397,7 +393,7 @@
printf "\n">>$REPORT
else
html_tr group
- html_th 3
+ html_th 4
html "$G"
html_~th
html_~tr
@@ -437,6 +433,9 @@
html_~tr
html_~table
html_~td
+ html_td align left
+ html "Execution Time: $INDIVIDUAL_TEST_TIME seconds"
+ html_~td
html_~tr
fi
@@ -641,12 +640,11 @@
rm killed_test > /dev/null 2>&1 && sleep 5
verbose "killing monitor: $MONITOR_PID..."
kill $MONITOR_PID
INDIVIDUAL_TEST_TIME=$(( STOP-START ))
+ TOTAL_TIME=$(( INDIVIDUAL_TEST_TIME+TOTAL_TIME ))
echo "TOOK (seconds): $INDIVIDUAL_TEST_TIME"
RESULT=$( result )
- NOPASO="Failed"
#Verifies the value of $RESULT, if the test was successful
#increases $TESTSPASSED by 1, if the test Failed
@@ -692,6 +690,10 @@
TEST_SHOULD_FAIL=0
if [ -x $GROUP/$SETUPSCRIPT ]; then
script_exec $GROUP/$SETUPSCRIPT "S"
+ else
+ html_td class "neutral" width 25
+ html "NP"
+ html_~td
fi
CDM=
@@ -715,11 +717,19 @@
TEST_SHOULD_FAIL=0
if [ -x $GROUP/$CHECKSCRIPT ]; then
script_exec $GROUP/$CHECKSCRIPT "√"
+ else
+ html "NP"
+ html_~td
fi
if [ -x $GROUP/$CLEANSCRIPT ]; then
script_exec $GROUP/$CLEANSCRIPT "C"
+ else
+ html "NP"
+ html_~td
fi
- echo
# Execute shell test case w/ setup, check, clean
@@ -733,6 +743,10 @@
TEST_SHOULD_FAIL=0
+ else
+ html "NP"
+ html_~td
fi
(( TESTCOUNT++ ))
@@ -742,17 +756,34 @@
+ else
+ html "NP"
+ html_~td
fi
if [ -x $GROUP/$SHELLSCRIPT ]; then
script_exec $SHELLSCRIPT "X"
+ else
+ html "NP"
+ html_~td
fi
+ else
+ html "NP"
+ html_~td
fi
+ else
+ html "NP"
+ html_~td
fi
@@ -881,25 +912,22 @@
# Revision:001
group_statistics(){
- printf "\n $TESTCOUNT Tests run\t$TESTSFAILED Tests failed\t$TESTSPASSED Tests succeeded. \n\n">>$REPORT
+ printf "\n $TESTCOUNT Tests run\t$TESTSFAILED Tests failed\t$TESTSPASSED Tests succeeded.\tTotal time: $TOTAL_TIME seconds \n\n">>$REPORT
else
-# html_tr group
-# html_td neutral
-# html "$TESTCOUNT Tests run"
-# html_~td
-# html_td success
-# html "$TESTSPASSED Tests succeeded"
-# html_~td
-# html_td failure
-# html "$TESTSFAILED Tests failed"
-# html_~td
-# html_~tr
- printf "<tr class=\"group\">">>$HTML
- printf "<td class=\"neutral\"> $TESTCOUNT Tests run. </td>">>$HTML
- printf "<td class=\"success\"> $TESTSPASSED Tests succeeded. </td>">>$HTML
- printf "<td class=\"failure\"> $TESTSFAILED Tests failed. </td>">>$HTML
- printf "</tr>">>$HTML
- # printf "\n $TESTCOUNT Tests run\t$TESTSFAILED Tests failed\t$TESTSPASSED Tests succeeded. \n\n">>$HTML
+ html_tr class "group"
+ html "$TESTCOUNT Tests run"
+ html_~td
+ html_td class "success"
+ html "$TESTSPASSED Tests succeeded."
+ html_~td
+ html_td class "failure"
+ html "$TESTSFAILED Tests failed."
+ html_~td
+ html_td class "neutral" align left
+ html "Total Time: $TOTAL_TIME seconds"
+ html_~td
+ html_~tr
fi
@@ -921,6 +949,7 @@
TESTNAME=$( basename $TEST )
echo -e "\nTest case: $TESTNAME"
cp -v $GROUP/$TESTNAME .
TESTLINK=$TESTNAME
start_row
@@ -929,6 +958,9 @@
(( $TESTCOUNT >= $NUMBER_OF_TESTS )) && return
(( $SHUTDOWN )) && return
done
+# html_td align right width 50
+# html $INDIVIDUAL_TEST_TIME
+# html_~td
end_row
done
group_statistics
More information about the Swift-commit
