[Swift-commit] r4689 - trunk/docs/cookbook
ketan at ci.uchicago.edu ketan at ci.uchicago.edu
Fri Jun 24 13:51:26 CDT 2011
Author: ketan
Date: 2011-06-24 13:51:26 -0500 (Fri, 24 Jun 2011)
New Revision: 4689
Modified:
   trunk/docs/cookbook/overview
Log:
Added under-construction warning to cookbook
Modified: trunk/docs/cookbook/overview
--- trunk/docs/cookbook/overview	2011-06-24 01:50:53 UTC (rev 4688)
+++ trunk/docs/cookbook/overview	2011-06-24 18:51:26 UTC (rev 4689)
@@ -6,3 +6,6 @@
 Swift runtime system. For
 introductory material, consult the Swift tutorial found
 link:http://www.ci.uchicago.edu/swift/guides/tutorial.php[here].
+WARNING: Please be warned that the cookbook is under construction and most recipes are not tested rigorously. You are advised to use them at your own risk.
