[Swift-commit] r4691 - trunk/docs/cookbook
    ketan at ci.uchicago.edu
    Fri Jun 24 15:02:46 CDT 2011
Author: ketan
Date: 2011-06-24 15:02:46 -0500 (Fri, 24 Jun 2011)
New Revision: 4691
Modified:
   trunk/docs/cookbook/diverse_infrastructures
Log:
small fix
Modified: trunk/docs/cookbook/diverse_infrastructures
--- trunk/docs/cookbook/diverse_infrastructures	2011-06-24 19:16:50 UTC (rev 4690)
+++ trunk/docs/cookbook/diverse_infrastructures	2011-06-24 20:02:46 UTC (rev 4691)
@@ -21,7 +21,7 @@
 *step 4.*  In the sites file: +sites.xml+ make the following two
 changes:
- 1. change the path of the +$$<workdirectory>$$+ element to your preferred location (say to +/lustre/beagle/<yourname>/swift-lab/swift.workdir+), and
+ 1. change the path of the +$$<workdirectory>$$+ element to your preferred location (this location is *required* to be on /lustre, say to +/lustre/beagle/<yourname>/swift-lab/swift.workdir+), and
   2. Change the project name to your project (for instance, +CI-CCR000013+) . The workdirectory will contain
   execution data related to each run, e.g. wrapper scripts, system information, inputs and outputs.
More information about the Swift-commit
