[Swift-commit] r4575 - in trunk: bin docs/newuser-guide examples
davidk at ci.uchicago.edu
Tue Jun 7 14:02:17 CDT 2011
Author: davidk
Date: 2011-06-07 14:02:17 -0500 (Tue, 07 Jun 2011)
New Revision: 4575
Added:
trunk/docs/newuser-guide/futuregrid-quickstart.txt
trunk/examples/hostsn.swift
Modified:
trunk/bin/start-coaster-service
trunk/docs/newuser-guide/pads-quickstart.txt
Log:
More content for the new user guide
More apps for start-coaster-service tc generation
Include hostsn script in examples
Modified: trunk/bin/start-coaster-service
--- trunk/bin/start-coaster-service 2011-06-07 18:33:55 UTC (rev 4574)
+++ trunk/bin/start-coaster-service 2011-06-07 19:02:17 UTC (rev 4575)
@@ -244,13 +244,14 @@
# Generate TC file
echo Generating tc.data
cat > $RUN_DIR/tc.data << EOF
-persistent-coasters echo /bin/echo null null null
-persistent-coasters cat /bin/cat null null null
-persistent-coasters ls /bin/ls null null null
-persistent-coasters grep /bin/grep null null null
-persistent-coasters sort /bin/sort null null null
-persistent-coasters paste /bin/paste null null null
-persistent-coasters cp /bin/cp null null null
-persistent-coasters wc /usr/bin/wc null null null
+persistent-coasters echo /bin/echo null null null
+persistent-coasters cat /bin/cat null null null
+persistent-coasters ls /bin/ls null null null
+persistent-coasters grep /bin/grep null null null
+persistent-coasters sort /bin/sort null null null
+persistent-coasters paste /bin/paste null null null
+persistent-coasters cp /bin/cp null null null
+persistent-coasters wc /usr/bin/wc null null null
+persistent-coasters hostname /bin/hostname null null null
EOF
Added: trunk/docs/newuser-guide/futuregrid-quickstart.txt
--- trunk/docs/newuser-guide/futuregrid-quickstart.txt (rev 0)
+++ trunk/docs/newuser-guide/futuregrid-quickstart.txt 2011-06-07 19:02:17 UTC (rev 4575)
@@ -0,0 +1,134 @@
+Futuregrid Quickstart Guide
+Downloading and Building Swift
+The most recent versions of Swift can be found at
+http://www.ci.uchicago.edu/swift/downloads/index.php. To run on futuregrid,
+you will need to download the development/trunk version from SVN.
+Adding Swift to your PATH
+Once you have installed Swift, add the Swift binary to your PATH so you can
+easily run it from any directory.
+In your home directory, edit the file ".bashrc".
+If you have installed Swift via a source repository, add the following line
+at the bottom of .bashrc.
+export PATH=$PATH:$HOME/cog/modules/swift/dist/swift-svn/bin
+Requesting Futuregrid Access
+If you do not already have a futuregrid account, you can follow the
+instructions at https://portal.futuregrid.org/gettingstarted to get started.
+This page provides information on how to create an account, how to join
+a project, how to set up your SSH keys, and how to create a new project.
+Downloading Swift VM Tools
+A set of scripts based around cloudinitd are used to easily start virtual
+machines. To download, change to your home directory and run the
+following command:
+$ svn co https://svn.ci.uchicago.edu/svn/vdl2/usertools/swift-vm-boot
+Download your Credentials
+Run the following commands to retrieve your credentials:
+$ scp yourusername at hotel.futuregrid.org:nimbus_creds.tar.gz .
+$ tar xvfz nimbus_creds.tar.gz
+When you extract your credential file, look at the file called
+hotel.conf. Near the bottom of this file will be two settings
+called vws.repository.s3id and vws.repository.s3key. Copy these
+values for the next step.
+Configuring Swift VM Tools
+Change directories into the swift-vm-boot directory. Edit the file
+called env.sh. There are two settings here that you will need to
+modify: FUTUREGRID_IAAS_ACCESS_KEY and FUTUREGRID_IAAS_SECRET_KEY.
+Paste your access key (s3id) and secret key (s3key) here and save
+the file. By default, env.sh requests 2 nodes on hotel and 2 nodes
+on sierra. Change these values as needed. Run install.sh from the
+swift-vm-boot directory to complete the installation of Swift VM
+Tools. The Swift VM Tools may require a fairly recent version of
+Python. If you run into problems while running the install.sh
+script, please try a more recent version of Python and associated
+libraries.
+Configuring coaster-service.conf
+Within your swift distribution's etc directory is a file called
+coaster-service.conf. There are many options here you can modify
+as needed, but these are the settings that will be required
+to run on futuregrid:
+export WORKER_WORK=/tmp
+export WORKER_MODE=futuregrid
+export SHARED_FILESYSTEM=no
+export WORKER_USERNAME=root
+export SSH_TUNNELING=yes
+export SWIFTVMBOOT_DIR=$HOME/swift-vm-boot
+export WORK=/tmp
+These is a brief description of these settings in the coaster-service.conf file.
+Tunneling should be used when you are restricted by a firewall. If your local
+machine has multiple network interfaces, you should also manually set the IP
+address of your machine with export IPADDR=your.ip.address.here.
+Starting the Coaster Service Script
+Now that everything is configured, change to a temporary directory
+and run this command to start the coaster service:
+$ start-coaster-service
+This command will start the VMs, start the required processes on the worker nodes,
+and generate Swift configuration files for you to use. The configuration files
+will be generated in your current directory. These files are sites.xml, tc.data,
+and cf.
+Running Swift
+Now that you have all of your configuration files generated, run the following command:
+$ swift -sites.file sites.xml -tc.file tc.data -config cf <yourscript.swift>
+If you would like to create a custom tc file for repeated use, rename it to something other
+than tc.data to prevent it from being overwritten. The sites.xml however will need to be
+regenerated every time you start the coaster service. If you need to repeatedly modify some
+sites.xml options, you may edit the template in Swift's etc/sites/persistent-coasters. You
+may also create your own custom tc files with the hostname of persistent-coasters. More
+information about this can be found in the Swift userguide at
+http://www.ci.uchicago.edu/swift/guides/trunk/userguide/userguide.html.
+Stopping the Coaster Service Script
+To stop the coaster service, run the following command:
+$ stop-coaster-service
+This will kill the coaster service, kill the worker scripts on remote systems and terminate
+the virtual machines that were created during start-coaster-service.
+More Help
+The best place for additional help is the Swift user mailing list. You can subscribe to this list at
+http://mail.ci.uchicago.edu/mailman/listinfo/swift-user. When submitting information, please send
+your sites.xml file, your tc.data, and any error messages you run into.
Modified: trunk/docs/newuser-guide/pads-quickstart.txt
--- trunk/docs/newuser-guide/pads-quickstart.txt 2011-06-07 18:33:55 UTC (rev 4574)
+++ trunk/docs/newuser-guide/pads-quickstart.txt 2011-06-07 19:02:17 UTC (rev 4575)
@@ -39,7 +39,7 @@
@default
-Downloading and building swift
+Downloading and building Swift
http://www.ci.uchicago.edu/swift/downloads/index.php. Follow the instructions
Added: trunk/examples/hostsn.swift
--- trunk/examples/hostsn.swift (rev 0)
+++ trunk/examples/hostsn.swift 2011-06-07 19:02:17 UTC (rev 4575)
@@ -0,0 +1,11 @@
+type file;
+app (file o) hostname ()
+ hostname stdout=@o;
+file out[]<simple_mapper; location="outdir", prefix="f.",suffix=".out">;
+foreach j in [1:@toint(@arg("n","1"))] {
+ out[j] = hostname();
More information about the Swift-commit
