[Swift-commit] r4576 - trunk/docs/newuser-guide
    ketan at ci.uchicago.edu
    Tue Jun  7 14:02:51 CDT 2011
Author: ketan
Date: 2011-06-07 14:02:50 -0500 (Tue, 07 Jun 2011)
New Revision: 4576
Added:
   trunk/docs/newuser-guide/beagle-quickstart.txt
Log:
Added beagle quickstart guide to swift newuser guide
Added: trunk/docs/newuser-guide/beagle-quickstart.txt
--- trunk/docs/newuser-guide/beagle-quickstart.txt	                        (rev 0)
+++ trunk/docs/newuser-guide/beagle-quickstart.txt	2011-06-07 19:02:50 UTC (rev 4576)
@@ -0,0 +1,49 @@
+PADS Quickstart Guide
+Requesting Access
+If you do not already have a Computation Institute account, you can request
+one at https://www.ci.uchicago.edu/accounts/. This page will give you a list
+of resources you can request access to.
+You already have an existing CI account, but do not have access to Beagle,
+send an email to support at ci.uchicago.edu to request access.
+Connecting to a login node
+Once you have account, you should be able to access a Beagle login
+node with the following command:
+ssh yourusername at login.beagle.ci.uchicago.edu
+Follow the steps outlined below to get started with Swift on Beagle:
+*step 1.* Load the Swift module on Beagle as follows: +module load swift+
+*step 2.* Create and change to a directory where your Swift related work will
+stay. (say, +mkdir swift-lab+, followed by, +cd swift-lab+)
+*step 3.* To get started with a simple example running +/bin/cat+ to read an
+input file +data.txt+ and write to an output file +f.nnn.out+, copy the folder
+at +/home/ketan/catsn+ to the above directory. (+cp -r /home/ketan/catsn
+.+ followed by +cd catsn+).
+*step 4.*  In the sites file: +beagle-coaster.xml+, make the following two
+changes: *1)* change the path of +workdirectory+ to your preferred location
+(say to +/lustre/beagle/$USER/swift-lab/swift.workdir+) and *2)* Change the
+project name to your project (+CI-CCR000013+) . The workdirectory will contain
+execution data related to each run, e.g. wrapper scripts, system information,
+inputs and outputs.
+*step 5.* Run the example using following commandline (also found in run.sh):
++swift -config cf -tc.file tc -sites.file beagle-coaster.xml catsn.swift -n=1+
+. You can further change the value of +-n+ to any arbitrary number to run that
+many number of concurrent +cat+
+*step 6.* Check the output in the generated +outdir+ directory (+ls outdir+)
+Note: Running from sandbox node or requesting 1 hour walltime for upto 3 nodes
+will get fast prioritized execution. Good for small tests.
More information about the Swift-commit
