[Swift-commit] r4574 - SwiftApps/Montage/scripts
jonmon at ci.uchicago.edu
Tue Jun 7 13:33:55 CDT 2011
Author: jonmon
Date: 2011-06-07 13:33:55 -0500 (Tue, 07 Jun 2011)
New Revision: 4574
Modified:
SwiftApps/Montage/scripts/Swift_Montage_Apps.swift
SwiftApps/Montage/scripts/Swift_Montage_Batch.swift
Log:
Added fix so that the area file generated by mProject are also mapped for stageout
Modified: SwiftApps/Montage/scripts/Swift_Montage_Apps.swift
--- SwiftApps/Montage/scripts/Swift_Montage_Apps.swift 2011-06-06 20:58:31 UTC (rev 4573)
+++ SwiftApps/Montage/scripts/Swift_Montage_Apps.swift 2011-06-07 18:33:55 UTC (rev 4574)
@@ -72,7 +72,8 @@
-app ( Image proj_img ) mProject( Image raw_img, MosaicData hdr )
+//app ( Image proj_img ) mProject( Image raw_img, MosaicData hdr )
+app ( Image proj_img, Image area_img ) mProject( Image raw_img, MosaicData hdr )
mProject "-X" @raw_img @proj_img @hdr;
Modified: SwiftApps/Montage/scripts/Swift_Montage_Batch.swift
--- SwiftApps/Montage/scripts/Swift_Montage_Batch.swift 2011-06-06 20:58:31 UTC (rev 4573)
+++ SwiftApps/Montage/scripts/Swift_Montage_Batch.swift 2011-06-07 18:33:55 UTC (rev 4574)
@@ -1,4 +1,4 @@
-( Image corr_imgs[] ) mBgBatch( Image bg_imgs[], Table img_tbl, Table corr_tbl )
+( Image corr_imgs[] ) mBackgroundBatch( Image bg_imgs[], Table img_tbl, Table corr_tbl )
Table back_list = Background_list( img_tbl, corr_tbl );
@@ -42,18 +42,18 @@
Status stats[];
Table status_tbl = create_status_table( diff_tbl );
foreach d_entry, i in diffs
Image img_1 <single_file_mapper; file = @strcat( src_dir+"/", @d_entry.plus )>;
Image img_2 <single_file_mapper; file = @strcat( src_dir+"/", @d_entry.minus )>;
Image diff_img <single_file_mapper; file = @strcat( dest_dir+"/", @d_entry.diff )>;
- Status stat <single_file_mapper; file = @strcat( "stat_dir/stat.", @d_entry.diff)>;
+ Status stat <single_file_mapper; file = @strcat( "stat_dir/stat.", @d_entry.diff)>;
( diff_img, stat ) = mDiffFit( img_1, img_2, hdr );
- diff_imgs[ i ] = diff_img;
+ diff_imgs[ i ] = diff_img;
stats[ i ] = stat;
fits_tbl = mConcatFit( status_tbl, stats );
@@ -75,14 +75,17 @@
-( Image proj_imgs[] ) mProjectBatch( Image raw_imgs[], MosaicData hdr )
+( Image proj_imgs[], Image area_imgs[] ) mProjectBatch( Image raw_imgs[], MosaicData hdr )
foreach img, i in raw_imgs
Image proj_img <regexp_mapper; source = @img, match = ".*\\/(.*)", transform = "proj_dir/proj_\\1">;
- proj_img = mProject( img, hdr );
+ Image area_img <regexp_mapper; source = @proj_img, match = "(.*)\\.(.*)", transform = "proj_dir/\\1_area.\\2">;
+// proj_img = mProject( img, hdr );
// proj_img = mProjectPP( img, hdr );
+ ( proj_img, area_img ) = mProject( img, hdr );
proj_imgs[ i ] = proj_img;
+ area_imgs[ i ] = area_img;
More information about the Swift-commit
