[Swift-commit] r4760 - trunk/tests/language-behaviour/arrays
hategan at ci.uchicago.edu
Mon Jul 4 02:19:20 CDT 2011
Author: hategan
Date: 2011-07-04 02:19:20 -0500 (Mon, 04 Jul 2011)
New Revision: 4760
Removed:
trunk/tests/language-behaviour/arrays/array_multidimensional_index.check.sh
Modified:
trunk/tests/language-behaviour/arrays/029-array-assignment-sequence.clean.sh
trunk/tests/language-behaviour/arrays/array_multidimensional_index.out.expected
Log:
fixed some array tests
Modified: trunk/tests/language-behaviour/arrays/029-array-assignment-sequence.clean.sh
--- trunk/tests/language-behaviour/arrays/029-array-assignment-sequence.clean.sh 2011-07-04 07:18:14 UTC (rev 4759)
+++ trunk/tests/language-behaviour/arrays/029-array-assignment-sequence.clean.sh 2011-07-04 07:19:20 UTC (rev 4760)
@@ -1,4 +1,4 @@
#!/bin/bash
set -x
-rm 029-array-assignment-* 029-array-assignment.kml 029-array-assignment.xml || exit 1
+rm 029-array-assignment-sequence* || exit 1
exit 0
Deleted: trunk/tests/language-behaviour/arrays/array_multidimensional_index.check.sh
--- trunk/tests/language-behaviour/arrays/array_multidimensional_index.check.sh 2011-07-04 07:18:14 UTC (rev 4759)
+++ trunk/tests/language-behaviour/arrays/array_multidimensional_index.check.sh 2011-07-04 07:19:20 UTC (rev 4760)
@@ -1,4 +0,0 @@
-#!/bin/bash
-set -x
-grep array_multidemnsional_index.out | grep 'left up down' || exit 1
-exit 0
Modified: trunk/tests/language-behaviour/arrays/array_multidimensional_index.out.expected
--- trunk/tests/language-behaviour/arrays/array_multidimensional_index.out.expected 2011-07-04 07:18:14 UTC (rev 4759)
+++ trunk/tests/language-behaviour/arrays/array_multidimensional_index.out.expected 2011-07-04 07:19:20 UTC (rev 4760)
@@ -1 +1 @@
-left up down
+left right up down
More information about the Swift-commit
