[Swift-commit] r4765 - SwiftApps/GOSwift/pykoa/tools
jonmon at ci.uchicago.edu
Tue Jul 5 13:01:06 CDT 2011
Author: jonmon
Date: 2011-07-05 13:01:06 -0500 (Tue, 05 Jul 2011)
New Revision: 4765
Modified:
SwiftApps/GOSwift/pykoa/tools/koa_goswift.py
Log:
o the goswift command now parse the swift package file via stdin(and only stdin)
Modified: SwiftApps/GOSwift/pykoa/tools/koa_goswift.py
--- SwiftApps/GOSwift/pykoa/tools/koa_goswift.py 2011-07-05 06:07:34 UTC (rev 4764)
+++ SwiftApps/GOSwift/pykoa/tools/koa_goswift.py 2011-07-05 18:01:06 UTC (rev 4765)
@@ -55,7 +55,97 @@
return (parser, options, args)
-# Do not know what this syntax is
+def parse_stdin():
+ lines = []
+ index = 0
+ while True:
+ try:
+ lines.append( raw_input() )
+ except EOFError:
+ break
+ tc = extract_tc( lines )
+ sites_file = extract_sites( lines )
+ config = extract_config( lines )
+ script = extract_script( lines )
+ return ( tc, sites_file, config, script )
+def extract_tc( lines ):
+ begin_tc = False
+ tc = ""
+ for line in lines:
+ if line == "# begin tc":
+ begin_tc = True
+ elif line == "# end tc":
+ begin_tc = False
+ break
+ elif begin_tc:
+ tc += line + "\n"
+ return tc
+def extract_sites( lines ):
+ begin_sites = False
+ sites = ""
+ if line == "# begin sites":
+ begin_sites = True
+ elif line == "# end sites":
+ break
+ elif begin_sites:
+ sites += line + "\n"
+ return sites
+def extract_config( lines ):
+ begin_config = False
+ config = ""
+ if line == "# begin config":
+ begin_config = True
+ elif line == "# end config":
+ break
+ elif begin_config:
+ config += line + "\n"
+ return config
+def extract_script( lines ):
+ begin_script = False
+ script = ""
+ if line == "# begin script":
+ begin_script = True
+ elif line == "# end script":
+ break
+ elif begin_script:
+ script += line + "\n"
+ return script
+# Do not know what this syntax is but pops up in other pykoa_* files.
@cli_exception_handler
def main( argv=sys.argv[1:] ):
(parser, options, args) = setup_opts(argv)
@@ -72,13 +162,19 @@
parser.print_help()
return 1
+ ( tc, sites_file, config, script ) = parse_stdin()
# get a space seperated list of the sites to execute on
sites=" ".join( map ( str, args ) )
sys.stdout.write( "\nExecuting Swift on: " + sites + "\n" )
# If I do not execute the script, just print out all pertatent information
if options.do_not_execute:
- sys.stdout.write( "swift -sites.file sites.xml -tc.file tc -config cf -cdm.file cdm script.swift\n\n" )
+ sys.stdout.write( "\nTC file: \n" + tc + "\n" )
+ sys.stdout.write( "SITES file: \n" + sites_file + "\n" )
+ sys.stdout.write( "CONFIG file: \n" + config + "\n" )
+ sys.stdout.write( "SWIFTSCRIPT file: \n" + script + "\n" )
+ sys.stdout.write( "swift -sites.file sites.xml -tc.file tc -config cf script.swift\n\n" )
return 0
# Execute the script
More information about the Swift-commit
