[Swift-commit] r4759 - trunk/tests
hategan at ci.uchicago.edu
Mon Jul 4 02:18:15 CDT 2011
Author: hategan
Date: 2011-07-04 02:18:14 -0500 (Mon, 04 Jul 2011)
New Revision: 4759
Modified:
trunk/tests/suite.sh
Log:
test suite updates
Modified: trunk/tests/suite.sh
--- trunk/tests/suite.sh 2011-07-04 06:40:56 UTC (rev 4758)
+++ trunk/tests/suite.sh 2011-07-04 07:18:14 UTC (rev 4759)
@@ -381,6 +381,10 @@
if [ "$RESULT" == "Passed" ]; then
html_td class "success" width 25 title "$CMD"
html_a_href $TEST_LOG "$LABEL"
+ elif [ "$RESULT" == "None" ]; then
+ html_td width 25
+ html " "
+ html_~td
else
echo -e "${RED}FAILED${GRAY}"
cat $RUNDIR/$TEST_LOG < /dev/null
@@ -693,8 +697,8 @@
fi
+ LASTCMD="$@"
test_log
- LASTCMD="$@"
output_report test $SEQ "$LASTCMD" $RESULT $TEST_LOG
check_bailout
@@ -710,7 +714,6 @@
process_exec $SCRIPT
RESULT=$( result )
- test_log
output_report test "$SYMBOL" "$LASTCMD" $RESULT
check_bailout
@@ -720,32 +723,62 @@
GROUP=$1
NAME=$2
+ RESULT="None"
if [ -f $GROUP/$NAME.in ]; then
echo "Copying input: $NAME.in"
- cp $GROUP/$NAME.in .
+ cp -v $GROUP/$NAME.in . 2>&1 >> $OUTPUT
+ if [ "$?" != 0 ]; then
+ RESULT="Failed"
+ fi
+ if [ "$RESULT" == "None" ]; then
+ RESULT="Passed"
+ fi
fi
for INPUT in $GROUP/$NAME.*.in; do
IN=`basename $INPUT`
echo "Copying input: $IN"
- cp $INPUT .
+ cp -v $INPUT . 2>&1 >> $OUTPUT
+ RESULT="Failed"
+ fi
+ RESULT="Passed"
+ fi
done
+ output_report test "s" "setup" $RESULT
+ check_bailout
check_outputs() {
GROUP=$1
NAME=$2
+ RESULT="None"
for EXPECTED in $GROUP/$NAME.*.expected; do
BNE=`basename $EXPECTED .expected`
echo -n "Checking output: $BNE "
diff $BNE $EXPECTED 2>&1 >> $OUTPUT
if [ "$?" != "0" ]; then
RESULT="Failed"
- echo -e "${RED}Failed${GRAY}"
- else
- echo -e "${LGREEN}OK${GRAY}"
fi
+ RESULT="Passed"
+ fi
done
+ html_td width 25
+ html " "
+ html_~td
+ fi
+ output_report test "√" "check" $RESULT
+ check_bailout
# Execute Swift test case w/ setup, check, clean
@@ -753,8 +786,6 @@
SWIFTSCRIPT=$1
NAME=${SWIFTSCRIPT%.swift}
- stage_files $GROUP $NAME
SETUPSCRIPT=$NAME.setup.sh
CHECKSCRIPT=$NAME.check.sh
CLEANSCRIPT=$NAME.clean.sh
@@ -765,9 +796,7 @@
if [ -x $GROUP/$SETUPSCRIPT ]; then
script_exec $GROUP/$SETUPSCRIPT "S"
else
- html_td width 25
- html " "
- html_~td
+ stage_files $GROUP $NAME
fi
ARGS=""
@@ -795,13 +824,10 @@
TEST_SHOULD_FAIL=0
if [ -x $GROUP/$CHECKSCRIPT ]; then
+ export OUTPUT
script_exec $GROUP/$CHECKSCRIPT "√"
else
- html_td width 25
- html " "
- html_~td
- check_outputs $GROUP $NAME
+ check_outputs $GROUP $NAME
fi
if [ -x $GROUP/$CLEANSCRIPT ]; then
More information about the Swift-commit
