[Swift-commit] r4262 - trunk/tests
wozniak at ci.uchicago.edu
Mon Apr 4 12:57:09 CDT 2011
Author: wozniak
Date: 2011-04-04 12:57:09 -0500 (Mon, 04 Apr 2011)
New Revision: 4262
Added:
trunk/tests/suite.sh
Removed:
trunk/tests/nightly.sh
Log:
Rename test script
Deleted: trunk/tests/nightly.sh
--- trunk/tests/nightly.sh 2011-04-04 17:55:14 UTC (rev 4261)
+++ trunk/tests/nightly.sh 2011-04-04 17:57:09 UTC (rev 4262)
@@ -1,1089 +0,0 @@
-#!/bin/bash
-# USAGE NOTES:
-# The script will (optionally) checkout Swift, run several tests in a
-# subdirectory called run-DATE, and generate useful HTML output and
-# tests.log
-# Usage: nightly.sh <options>* <GROUPLIST>
-# Run nightly.sh -h for quick help
-# When something goes wrong, find and check tests.log or use -v
-# Code is checked out into TOPDIR (PWD by default) (PATH is not used)
-# The variables COG_VERSION and SWIFT_VERSION must be set for code checkout
-# e.g. COG_VERSION=branches/4.1.8, SWIFT_VERSION=branches/release-0.92
-# Swift is compiled and installed in its source tree
-# The run is executed in RUNDIR (TOPDIR/RUNDIRBASE)
-# The build test is started in TOPDIR
-# Everything for a Swift test is written in its RUNDIR
-# The temporary output always goes to OUTPUT (TOPDIR/exec.out)
-# Each *.swift test may be accompanied by a
-# *.setup.sh, *.check.sh, and/or *.clean.sh script
-# and a *.timeout specifier
-# The scripts may setup and inspect files in RUNDIR including exec.out,
-# which must be accessed in stdout.txt, because the currently running
-# tested process writes to exec.out, stdout.txt is a copy.
-# The GROUP scripts can read the GROUP variable
-# The timeout number in the *.timeout file overrides the default
-# timeout
-# Tests are GROUPed into directories
-# Each GROUP directory has:
-# 1) a list of *.swift tests (plus *.sh scripts)
-# 2) optionally a sites.template.xml
-# 3) optionally a tc.template.data
-# 4) optionally a fs.template.data
-# 5) optionally a swift.properties
-# 6) optionally a title.txt
-# 7) preferably a README.txt
-# 7) optionally a *.timeout
-# template files are lightly processed by sed before use
-# Missing files will be pulled from swift/etc
-# The GROUPLIST is obtained from an external script in the
-# groups/ subdirectory by the name of GROUPLISTFILE.
-# The GROUPLISTFILE:
-# 1) sets the array
-# 2) checks any variables needed by make_sites_sed()
-# OUTPUT is the stdout of the current test
-# stdout.txt retains stdout from the previous test (for *.clean.sh)
-# output_*.txt is the HTML-linked permanent output from a test
-# All timeouts in this script are in seconds
-# PID TREE:
-# Background processes are used so that hung Swift jobs can be killed
-# These are the background processes (PIDs are tracked)
-# Note that PID management has not yet been perfected. Check ps
-# in error cases, especially if you kill nightly.sh .
-# nightly.sh
-# +-monitor()
-# +-sleep
-# +-process_exec()
-# +-bin/swift
-# +-java
-# FAILURE CASES
-# Some cases are designed to cause Swift to crash. These
-# SwiftScripts contain the token THIS-SCRIPT-SHOULD-FAIL somewhere.
-# The response of nightly.sh to the exit code of these Swift
-# executions is reversed.
-# SCHEDULERS
-# Environment must contain PROJECT, QUEUE, and WORK
-# These variables will be incorporated into the sites.xml
-# via make_sites_sed() -> group_sites_xml()
-# Note that some schedulers restrict your choice of RUNDIR
-# NAMING
-# Site-specific test groups are in providers/ .
-# These are named:
-# providers/<provider description>/
-# or:
-# providers/<provider description>/<site>
-# E.g., providers/local-pbs/PADS
-# WARNINGS
-# nightly.sh uses shopt
-shopt -s nullglob
-printhelp() {
- echo "nightly.sh <options> <output>"
- echo ""
- echo "usage:"
- printf "\t -a Do not run ant dist \n"
- printf "\t -c Do not remove dist (clean) \n"
- printf "\t -g Do not run grid tests \n"
- printf "\t -h This message \n"
- printf "\t -k <N> Skip first N tests \n"
- printf "\t -n <N> Run N tests and quit \n"
- printf "\t -p Do not build the package \n"
- printf "\t -s Do not do a fresh svn checkout \n"
- printf "\t -x Do not continue after a failure \n"
- printf "\t -v Verbose (set -x, HTML comments) \n"
- printf "\t -o output Location for output (TOPDIR) \n"
- printf "\t <FILE> GROUPLIST definition file \n"
-# Defaults:
-DEFAULT_TIMEOUT=30 # seconds
-RUN_ANT=1
-CLEAN=1
-SKIP_TESTS=0
-NUMBER_OF_TESTS=1000000 # Run all tests by default
-BUILD_PACKAGE=1
-GRID_TESTS=1
-SKIP_CHECKOUT=0
-ALWAYS_EXITONFAILURE=0
-VERBOSE=0
-# The directory in which to start:
-TOPDIR=$PWD
-while [ $# -gt 0 ]; do
- case $1 in
- -a)
- RUN_ANT=0
- shift;;
- -c)
- CLEAN=0
- shift;;
- -g)
- GRID_TESTS=0
- shift;;
- -h)
- printhelp
- exit 0;;
- -k)
- SKIP_TESTS=$2
- shift 2;;
- -n)
- NUMBER_OF_TESTS=$2
- shift 2;;
- -o)
- TOPDIR=$2
- shift 2;;
- -p)
- BUILD_PACKAGE=0
- shift;;
- -s)
- SKIP_CHECKOUT=1
- shift;;
- -x)
- ALWAYS_EXITONFAILURE=1
- shift;;
- -v)
- VERBOSE=1
- shift;;
- GROUPLISTFILE=$1
- shift;;
- esac
-done
-if (( VERBOSE )); then
- set -x
- HTML_COMMENTS=1
-fi
-# Iterations per test (may want to run each test multiple times?)
-ITERS_LOCAL=1
-LOGCOUNT=0
-SEQ=1
-DATE=$( date +"%Y-%m-%d" )
-TIME=$( date +"%T" )
-RUNDIRBASE="run-$DATE"
-RUNDIR=$TOPDIR/$RUNDIRBASE
-LOGBASE=$RUNDIRBASE/tests.log
-LOG=$TOPDIR/$LOGBASE
-OUTPUT=$RUNDIR/exec.out
-HTMLPATH=$RUNDIRBASE/tests-$DATE.html
-HTML=$TOPDIR/$HTMLPATH
-BRANCH=trunk
-#BRANCH="branches/tests-01"
-SCRIPTDIR=$( cd $( dirname $0 ) ; /bin/pwd )
-TESTCOUNT=0
-MASTER_PID=$$
-# PIDs to kill if nightly.sh is killed:
-PROCESS_PID=
-MONITOR_PID=
-# When true, we should exit:
-SHUTDOWN=0
-echo "RUNNING_IN: $RUNDIR"
-echo "HTML_OUTPUT: $HTML"
-TESTDIR=$TOPDIR/cog/modules/swift/tests
-# Ensure all given variables are set
-checkvars() {
- while (( ${#*} ))
- do
- VAR=$1
- V=$( eval "echo \${${VAR}+1}" )
- [[ $V == 1 ]] || crash "Not set: $VAR"
- shift
- done
- return 0
-checkfail() {
- ERR=$?
- shift
- MSG=${*}
- if [[ $ERR != 0 ]]; then
- echo "FAILED($ERR): $MSG"
- exit $ERR
- fi
-crash() {
- MSG=$1
- echo $MSG
- exit 1
-verbose() {
- MSG="${*}"
- (( $VERBOSE )) && echo $MSG
- return 0
-shutdown_trap() {
- SHUTDOWN=1
- verbose "shutdown_trap... $PROCESS_PID\n\n"
- verbose "kill: process: $PROCESS_PID"
- kill $PROCESS_PID
-header() {
- CURRENT=$SCRIPTDIR/html/current.html
- sed "s at _HTMLBASE_@$HTMLPATH@" < $CURRENT > $TOPDIR/current.html
- HEADER=$SCRIPTDIR/html/header.html
- HOST=$( hostname )
- SEDCMD="s/_DATE_/$DATE/;s/_TIME_/$TIME/;s/_HOST_/$HOST"/
- sed $SEDCMD < $HEADER > $HTML
- FIRSTTEST=1
-html() {
- printf "$@\n" >>$HTML
- [ $? != 0 ] && echo "html(): write error!" && exit 1
-html_h1() {
- TEXT=$1
- html "<h1>$TEXT</h1>"
-html_a_name() {
- NAME=$1
- html "<a name=\"$NAME\">"
-html_a_href() {
- HREF=$1
- TEXT=$2
- html "<a href=\"$HREF\">$TEXT</a>"
-html_table() {
- OPTS=""
- while [[ ${#*} > 0 ]]
- do
- case $1 in
- cellpadding)
- OPTS="${OPTS}cellpadding=\"$2\" "
- shift 2;;
- border)
- OPTS="${OPTS}border=\"$2\" "
- shift 2;;
- esac
- done
- html "<table $OPTS>"
-html_~table() {
- html "</table>"
-html_tr() {
- CLASS=$1
- if [ -n $CLASS ]; then
- html "<tr class=\"$CLASS\">"
- else
- html "<tr>"
- fi
-html_~tr() {
- html "</tr>"
-html_th() {
- COLSPAN=$1
- if [ -n $COLSPAN ]; then
- html "<th colspan=\"$COLSPAN\">"
- else
- html "<th>"
- fi
-html_~th() {
- html "</th>"
-html_td() {
- OPTS=""
- do
- case $1 in
- align)
- OPTS="${OPTS}align=\"$2\" "
- shift 2;;
- class)
- OPTS="${OPTS}class=\"$2\" "
- shift 2;;
- title)
- OPTS="${OPTS}title=\"$2\" "
- shift 2;;
- width)
- OPTS="${OPTS}width=\"$2\" "
- shift 2;;
- esac
- done
- html "<td $OPTS>"
-html_~td() {
- html "</td>"
-html_~body() {
- html "</body>"
-html_~html() {
- html "</html>"
-html_comment() {
- COMMENT=$1
- (( HTML_COMMENTS == 1 )) && html "<!-- $COMMENT -->"
-footer() {
- html "</tr></table></tr></table>"
- html_comment "End of tests"
- MONTHS=("" "Jan" "Feb" "Mar" "Apr" "May" "Jun" \
- "Jul" "Aug" "Sep" "Oct" "Nov" "Dec")
- if [ "$BINPACKAGE" != "" ]; then
- FBP=$RUNDIR/$BINPACKAGE
- SIZE=`ls -hs $FBP`
- SIZE=${SIZE/$FBP}
- cat <<DOH >>$HTML
- <h1>Binary packages</h1>
- <a name="#packages">
- <a href="$BINPACKAGE">$BINPACKAGE</a> ($SIZE)<br>
-DOH
- fi
- LASTYR="00"
- LASTMO="00"
- html "<h1>Older tests</h1>"
- html '<a name="older">'
- html "<table><tr>"
- for OLDER in `ls $OUTDIR/tests-*.html|sort`; do
- O=`basename $OLDER`
- YR=${O:6:2}
- MO=${O:8:2}
- DY=${O:10:2}
- if echo "$DY$MO$YR"|egrep -v "[0-9]{6}"; then
- YR=${O#tests-}
- YR=${YR%.html}
- MO=0
- DY=$YR
- else
- YR="20$YR"
- fi
- if [ $LASTYR != $YR ]; then
- html "</tr></table>"
- html "<h2>$YR</h2>"
- LASTYR=$YR
- fi
- if [ $LASTMO != $MO ]; then
- html "<h3>${MONTHS[$MO]}</h3>"
- html "<table border=\"0\"><tr>"
- LASTMO=$MO
- fi
- SUCCESS=`grep 'class="success"' $OLDER|wc -l`
- FAILURE=`grep 'class="failure"' $OLDER|wc -l`
- if [ "$SUCCESS$FAILURE" == "00" ]; then
- COLOR="#e0e0e0"
- else
- COLOR=`perl -e "printf \"#%02x%02x%02x\", $FAILURE/($SUCCESS+$FAILURE)*220+35, $SUCCESS/($SUCCESS+$FAILURE)*220+35, 40;"`
- fi
- html "<td bgcolor=\"$COLOR\"><a href=\"$O\">$DY</a></td>"
- done
- html "</tr></table><br><br>"
- html_~body
- html_~html
-printlist() {
- while [[ $1 != "" ]]; do
- echo $1
- shift
- done
-outecho() {
- TYPE=$1
- shift
- echo "<$TYPE>$1|$2|$3|$4|$5|$6|$7|$8|$9|"
-# Create HTML output
-out() {
- # echo $@
- TYPE=$1
- if [ "$TYPE" == "test" ]; then
- LABEL="$2" # Text on link to output
- CMD=$3 # Command issued (td title)
- RESULT=$4 # Passed or Failed
- # WIDTH=$( width "$LABEL" )
- if [ "$RESULT" == "Passed" ]; then
- # html "<td class=\"success\" $WIDTH title=\"$CMD\">"
- html_td class "success" width 25 title "$CMD"
- html_a_href $TEST_LOG "$LABEL"
- else
- echo "FAILED"
- cat $RUNDIR/$TEST_LOG < /dev/null
- # html "<td class=\"failure\" $WIDTH title=\"$CMD\">"
- html_td class "failure" width 25 title "$CMD"
- html_a_href $TEST_LOG $LABEL
- fi
- html_~td
- elif [ "$TYPE" == "package" ]; then
- BINPACKAGE=$2
- else
- html $@
- fi
-start_test_results() {
- html_h1 "Test results"
- html_a_name "tests"
- html_a_href "tests.log" "Output log from tests"
- html_table border 0 cellpadding 1
-start_part() {
- PART=$1
- echo
- echo $PART
- echo
- html_tr part
- html_th 3
- html "$PART"
- html_~th
- html_~tr
-start_row() {
- html_tr testline
- html_td align right width 50
- html "<b>$TESTCOUNT</b>"
- html " "
- html_~td
- html " "
- if [[ -n $TESTLINK ]]; then
- html_a_href $TESTLINK $TESTNAME
- else
- html $TESTNAME
- fi
- html " "
- html_~td
- html_td
- html_table
- html_tr
- SEQ=1
-end_row() {
- html_~tr
- html_~table
- html_~td
- html_~tr
-# HTML width of label (for alignment)
-width() {
- LABEL="$1"
- if [ ${#LABEL} -gt 2 ]; then
- WIDTH=""
- else
- WIDTH="width=\"20\""
- fi
- echo $WIDTH
-# TEST_LOG = test log
-test_log() {
- TEST_LOG="output_$LOGCOUNT.txt"
- banner "$LASTCMD" $RUNDIR/$TEST_LOG
- if [ -f $OUTPUT ]; then
- cp $OUTPUT $RUNDIR/$TEST_LOG 2>>$LOG
- cp $OUTPUT $RUNDIR/stdout.txt
- fi
- let "LOGCOUNT=$LOGCOUNT+1"
-stars() {
- for i in {1..90}
- do
- printf "*"
- done
- echo
-banner() {
- MSG=$1
- FILE=$2
- if [ "$FILE" == "" ]; then
- BANNER_OUTPUT=$LOG
- else
- BANNER_OUTPUT=$2
- fi
- echo ""
- # stars
- echo "* $MSG"
- # stars
- } >> $BANNER_OUTPUT
-# Check for early bailout condition
-check_bailout() {
- if [ "$EXITONFAILURE" == "true" ]; then
- if [ "$EXITCODE" != "0" ]; then
- exit $EXITCODE
- fi
- fi
-# Translate (global) test exit code into result (Passed/Failed) string
-result() {
- if [ "$EXITCODE" == "0" ]; then
- echo "Passed"
- else
- echo "Failed"
- fi
-# Execute process in the background
-process_exec() {
- printf "\nExecuting: $@" >>$LOG
- rm -f $OUTPUT
- "$@" > $OUTPUT 2>&1
- EXITCODE=$?
- if [ "$EXITCODE" == "127" ]; then
- echo "Command not found: $@" > $OUTPUT
- fi
- cat $OUTPUT >> $LOG
- fi
- (( $TEST_SHOULD_FAIL )) && EXITCODE=$(( ! $EXITCODE ))
- return $EXITCODE
-# Execute as part of test set
-# Equivalent to monitored_exec() (but w/o monitoring)
-test_exec() {
- banner "$TEST (part $SEQ)"
- echo "Executing $TEST (part $SEQ)"
- pwd
- rm -f $OUTPUT
- EXITCODE=$?
- fi
- fi
- RESULT=$( result )
- test_log
- out test $SEQ "$LASTCMD" $RESULT $TEST_LOG
- check_bailout
- let "SEQ=$SEQ+1"
- return $EXITCODE
-# Background process monitoring function
-# To be executed in the background as well
-# If the monitored process times out, monitor() kills it and writes
-# a message to OUTPUT
-# If monitor() kills the process, it returns 0
-# Otherwise, return non-zero (as would result from killing
-# this function)
-# sleep can be hard to kill:
-SLEEP_PID=
-monitor() {
- (( $VERBOSE )) && set -x
- PID=$1
- TIMEOUT=$2 # seconds
- OUTPUT=$3
- V=$TESTCOUNT
- sleep $TIMEOUT &
- SLEEP_PID=$!
- trap trap_sleep SIGINT SIGQUIT SIGTERM
- wait
- [ $? != 0 ] && verbose "monitor($V) cancelled" && return 0
- if ps | grep $PID
- then
- verbose "monitor: killing test process $PID"
- touch killed_test
- /bin/kill -INT $PID
- KILLCODE=$?
- if [ $KILLCODE == 0 ]; then
- verbose "monitor: killed process_exec (INT)"
- fi
- fi
- sleep 1
- MSG="nightly.sh: monitor: killed: exceeded $TIMEOUT seconds"
- echo "$MSG" >> $OUTPUT
- return 1
-trap_sleep() {
- verbose "killing sleep: $SLEEP_PID"
- kill $SLEEP_PID
-# Execute given command line in background with monitor
-# Otherwise equivalent to test_exec()
-# usage: monitored_exec <TIMEOUT> <command> <args>*
-monitored_exec()
- TIMEOUT=$1
- shift
- START=$( date +%s )
- process_exec "$@" &
- PROCESS_PID=$!
- monitor $PROCESS_PID $TIMEOUT $OUTPUT &
- MONITOR_PID=$!
- wait $PROCESS_PID
- EXITCODE=$?
- STOP=$( date +%s )
- # If the test was killed, monitor() may have work to do
- rm killed_test > /dev/null 2>&1 && sleep 5
- verbose "killing monitor: $MONITOR_PID..."
- kill $MONITOR_PID
- echo "TOOK: $(( STOP-START ))"
- test_log
- LASTCMD="$@"
- check_bailout
- let "SEQ=$SEQ+1"
-# Execute helper script (setup, check, or clean)
-script_exec() {
- SCRIPT=$1
- SYMBOL="$2"
- process_exec $SCRIPT
- test_log
- out test "$SYMBOL" "$LASTCMD" $RESULT
- check_bailout
-# Execute Swift test case w/ setup, check, clean
-swift_test_case() {
- SWIFTSCRIPT=$1
- SETUPSCRIPT=${SWIFTSCRIPT%.swift}.setup.sh
- CHECKSCRIPT=${SWIFTSCRIPT%.swift}.check.sh
- CLEANSCRIPT=${SWIFTSCRIPT%.swift}.clean.sh
- TIMEOUTFILE=${SWIFTSCRIPT%.swift}.timeout
- TEST_SHOULD_FAIL=0
- if [ -x $GROUP/$SETUPSCRIPT ]; then
- script_exec $GROUP/$SETUPSCRIPT "S"
- fi
- CDM=
- [ -r fs.data ] && CDM="-cdm.file fs.data"
- (( TESTCOUNT++ ))
- TIMEOUT=$( gettimeout $GROUP/$TIMEOUTFILE )
- grep THIS-SCRIPT-SHOULD-FAIL $SWIFTSCRIPT > /dev/null
- TEST_SHOULD_FAIL=$(( ! $? ))
- monitored_exec $TIMEOUT swift \
- -wrapperlog.always.transfer true \
- -config swift.properties \
- -sites.file sites.xml \
- -tc.file tc.data \
- $CDM $SWIFTSCRIPT
- if [ -x $GROUP/$CHECKSCRIPT ]; then
- script_exec $GROUP/$CHECKSCRIPT "√"
- fi
- if [ -x $GROUP/$CLEANSCRIPT ]; then
- script_exec $GROUP/$CLEANSCRIPT "C"
- fi
-# Execute shell test case w/ setup, check, clean
-script_test_case() {
- SHELLSCRIPT=$1
- SETUPSCRIPT=${SHELLSCRIPT%.test.sh}.setup.sh
- CHECKSCRIPT=${SHELLSCRIPT%.test.sh}.check.sh
- CLEANSCRIPT=${SHELLSCRIPT%.test.sh}.clean.sh
- TIMEOUTFILE=${SHELLSCRIPT%.test.sh}.timeout
- fi
- (( TESTCOUNT++ ))
- # Not using background for script tests yet
- # TIMEOUT=$( gettimeout $GROUP/$TIMEOUTFILE )
- fi
- if [ -x $GROUP/$SHELLSCRIPT ]; then
- script_exec $SHELLSCRIPT "X"
- fi
- fi
- fi
-gettimeout() {
- FILE=$1
- if [ -f $FILE ]; then
- cat $FILE
- else
- echo $DEFAULT_TIMEOUT
- fi
- return 0
-ssexec() {
- SEQSAVE=$SEQ
- SEQ=$1
- shift
- aexec "$@"
- ptest
- SEQ=$SEQSAVE
-# Fake exec
-fexec() {
- banner "$TEST (faked)"
- echo "Faking $TEST"
- EXITCODE=0
- LASTCMD=""
- # ptest
-build_package() {
- TEST="Package"
- test_exec cd $SWIFT_HOME/lib
- test_exec rm -f castor*.jar *gt2ft*.jar ant.jar
- test_exec cd $TOPDIR
- test_exec tar -pczf $RUNDIR/swift-$DATE.tar.gz $SWIFT_HOME
- out package "swift-$DATE.tar.gz"
-# Generate the sites.sed file
-make_sites_sed() {
- echo "s at _WORK_@$WORK@"
- echo "s at _HOST_@$GLOBUS_HOSTNAME@"
- echo "s at _PROJECT_@$PROJECT@"
- echo "s at _QUEUE_@$QUEUE@"
- } > $RUNDIR/sites.sed
- return 0
-# Setup coasters variables
-if which ifconfig > /dev/null 2>&1; then
- IFCONFIG=ifconfig
-else
- IFCONFIG=/sbin/ifconfig
-fi
-$IFCONFIG > /dev/null 2>&1 || crash "Cannot run ifconfig!"
-GLOBUS_HOSTNAME=$( $IFCONFIG | grep inet | head -1 | cut -d ':' -f 2 | \
- awk '{print $1}' )
-[ $? != 0 ] && crash "Could not obtain GLOBUS_HOSTNAME!"
-# Generate sites.xml
-group_sites_xml() {
- TEMPLATE=$GROUP/sites.template.xml
- if [ -f $TEMPLATE ]; then
- sed -f $RUNDIR/sites.sed < $TEMPLATE > sites.xml
- [ $? != 0 ] && crash "Could not create sites.xml!"
- echo "Using: $GROUP/sites.template.xml"
- else
- sed "s at _WORK_@$PWD/work@" < $TESTDIR/sites/localhost.xml > sites.xml
- echo "Using: $TESTDIR/sites/localhost.xml"
- fi
-# Generate tc.data
-group_tc_data() {
- if [ -f $GROUP/tc.template.data ]; then
- sed "s at _DIR_@$GROUP@" < $GROUP/tc.template.data > tc.data
- [ $? != 0 ] && crash "Could not create tc.data!"
- echo "Using: $GROUP/tc.template.data"
- else
- cp -v $SWIFT_HOME/etc/tc.data .
- [ $? != 0 ] && crash "Could not copy tc.data!"
- fi
-# Generate the CDM file, fs.data
-group_fs_data() {
- if [ -f $GROUP/fs.template.data ]; then
- sed "s at _PWD_@$PWD@" < $GROUP/fs.template.data > fs.data
- [ $? != 0 ] && crash "Could not create fs.data!"
- echo "Using: $GROUP/fs.template.data"
- else
- rm -f fs.data
- fi
-# Generate swift.properties
-group_swift_properties() {
- if [ -f $GROUP/swift.properties ]; then
- cp -v $GROUP/swift.properties .
- [ $? != 0 ] && crash "Could not copy swift.properties!"
- else
- cp -v $SWIFT_HOME/etc/swift.properties .
- fi
-# Obtain the group title
-group_title() {
- if [ -r $GROUP/title.txt ]; then
- cat $GROUP/title.txt
- else
- echo "untitled"
- fi
-# Execute all tests in current GROUP
-test_group() {
- group_sites_xml
- group_tc_data
- group_fs_data
- group_swift_properties
- SWIFTS=$( echo $GROUP/*.swift )
- checkfail "Could not list: $GROUP"
- for TEST in $SWIFTS; do
- (( SKIP_COUNTER++ < SKIP_TESTS )) && continue
- TESTNAME=$( basename $TEST )
- cp -v $GROUP/$TESTNAME .
- TESTLINK=$TESTNAME
- start_row
- for (( i=0; $i<$ITERS_LOCAL; i=$i+1 )); do
- swift_test_case $TESTNAME
- (( $TESTCOUNT >= $NUMBER_OF_TESTS )) && return
- (( $SHUTDOWN )) && return
- done
- end_row
- done
- SCRIPTS=$( echo $GROUP/*.test.sh )
- for TEST in $SCRIPTS; do
- start_row
- for ((i=0; $i<$ITERS_LOCAL; i=$i+1)); do
- script_test_case $TESTNAME
- done
- end_row
- done
-if [[ $WORK == "" ]]
-then
- WORK=$TOPDIR/work
-fi
-checkvars GROUPLISTFILE
-echo "GROUPLISTFILE: $GROUPLISTFILE"
-source $GROUPLISTFILE || exit 1
-cd $TOPDIR
-mkdir -p $RUNDIR
-[ $? != 0 ] && echo "Could not mkdir: $RUNDIR" && exit 1
-date > $LOG
-make_sites_sed
-header
-start_test_results
-cd $TOPDIR
-start_part "Prolog: Build"
-TESTLINK=
-EXITONFAILURE=true
-if [ "$SKIP_CHECKOUT" != "1" ]; then
- TESTNAME="Checkout CoG"
- start_row
- test_exec rm -rf cog
- COG="https://cogkit.svn.sourceforge.net/svnroot/cogkit/$COG_VERSION/src/cog"
- test_exec svn co $COG
- end_row
- TESTNAME="Checkout Swift"
- start_row
- test_exec cd cog/modules
- test_exec rm -rf swift
- test_exec svn co https://svn.ci.uchicago.edu/svn/vdl2/$SWIFT_VERSION swift
- end_row
-fi
-TESTNAME="Compile"
-start_row
-test_exec cd $TOPDIR/cog/modules/swift
-if (( $CLEAN )); then
- test_exec rm -rf dist
-fi
-if (( $RUN_ANT )); then
- test_exec ant -quiet dist
-fi
-SWIFT_HOME=$TOPDIR/cog/modules/swift/dist/swift-svn
-if [ $BUILD_PACKAGE = "1" ]; then
- build_package
-fi
-end_row
-PATH=$SWIFT_HOME/bin:$PATH
-cd $TOPDIR
-echo "USING: $( which swift )"
-cd $RUNDIR
-if [ $ALWAYS_EXITONFAILURE != "1" ]; then
- EXITONFAILURE=false
-fi
-trap "shutdown_trap" SIGINT SIGTERM
-SKIP_COUNTER=0
-GROUPCOUNT=1
-for G in ${GROUPLIST[@]}; do
- export GROUP=$G
- TITLE=$( group_title )
- start_part "Part $GROUPCOUNT: $TITLE"
- test_group
- (( GROUPCOUNT++ ))
- (( $TESTCOUNT >= $NUMBER_OF_TESTS )) && break
- (( $SHUTDOWN )) && break
-done
-if [ $GRID_TESTS == "0" ]; then
- exit 0
-fi
-TESTPART="Appendix G: Grid Tests"
-for TEST in `ls $TESTDIR/*.dtm $TESTDIR/*.swift`; do
- BN=`basename $TEST`
- echo $BN
- cp $TESTDIR/$BN .
- TESTNAME=${BN%.dtm}
- TESTNAME=${TESTNAME%.swift}
- TEST="<a href=\"$RUNDIRBASE/$BN\">$TESTNAME</a>"
- ssexec "Compile" vdlc $BN
- for ((i=0; $i<9; i=$i+1)); do
- test_exec swift -sites.file ~/.vdl2/sites-grid.xml $TESTNAME.kml
- done
-done
-footer
-exit 0
-# Local Variables:
-# sh-basic-offset: 2
-# End:
Copied: trunk/tests/suite.sh (from rev 4261, trunk/tests/nightly.sh)
--- trunk/tests/suite.sh (rev 0)
+++ trunk/tests/suite.sh 2011-04-04 17:57:09 UTC (rev 4262)
@@ -0,0 +1,1089 @@
+#!/bin/bash
+# USAGE NOTES:
+# The script will (optionally) checkout Swift, run several tests in a
+# subdirectory called run-DATE, and generate useful HTML output and
+# tests.log
+# Usage: nightly.sh <options>* <GROUPLIST>
+# Run nightly.sh -h for quick help
+# When something goes wrong, find and check tests.log or use -v
+# Code is checked out into TOPDIR (PWD by default) (PATH is not used)
+# The variables COG_VERSION and SWIFT_VERSION must be set for code checkout
+# e.g. COG_VERSION=branches/4.1.8, SWIFT_VERSION=branches/release-0.92
+# Swift is compiled and installed in its source tree
+# The run is executed in RUNDIR (TOPDIR/RUNDIRBASE)
+# The build test is started in TOPDIR
+# Everything for a Swift test is written in its RUNDIR
+# The temporary output always goes to OUTPUT (TOPDIR/exec.out)
+# Each *.swift test may be accompanied by a
+# *.setup.sh, *.check.sh, and/or *.clean.sh script
+# and a *.timeout specifier
+# The scripts may setup and inspect files in RUNDIR including exec.out,
+# which must be accessed in stdout.txt, because the currently running
+# tested process writes to exec.out, stdout.txt is a copy.
+# The GROUP scripts can read the GROUP variable
+# The timeout number in the *.timeout file overrides the default
+# timeout
+# Tests are GROUPed into directories
+# Each GROUP directory has:
+# 1) a list of *.swift tests (plus *.sh scripts)
+# 2) optionally a sites.template.xml
+# 3) optionally a tc.template.data
+# 4) optionally a fs.template.data
+# 5) optionally a swift.properties
+# 6) optionally a title.txt
+# 7) preferably a README.txt
+# 7) optionally a *.timeout
+# template files are lightly processed by sed before use
+# Missing files will be pulled from swift/etc
+# The GROUPLIST is obtained from an external script in the
+# groups/ subdirectory by the name of GROUPLISTFILE.
+# The GROUPLISTFILE:
+# 1) sets the array
+# 2) checks any variables needed by make_sites_sed()
+# OUTPUT is the stdout of the current test
+# stdout.txt retains stdout from the previous test (for *.clean.sh)
+# output_*.txt is the HTML-linked permanent output from a test
+# All timeouts in this script are in seconds
+# PID TREE:
+# Background processes are used so that hung Swift jobs can be killed
+# These are the background processes (PIDs are tracked)
+# Note that PID management has not yet been perfected. Check ps
+# in error cases, especially if you kill nightly.sh .
+# nightly.sh
+# +-monitor()
+# +-sleep
+# +-process_exec()
+# +-bin/swift
+# +-java
+# FAILURE CASES
+# Some cases are designed to cause Swift to crash. These
+# SwiftScripts contain the token THIS-SCRIPT-SHOULD-FAIL somewhere.
+# The response of nightly.sh to the exit code of these Swift
+# executions is reversed.
+# SCHEDULERS
+# Environment must contain PROJECT, QUEUE, and WORK
+# These variables will be incorporated into the sites.xml
+# via make_sites_sed() -> group_sites_xml()
+# Note that some schedulers restrict your choice of RUNDIR
+# NAMING
+# Site-specific test groups are in providers/ .
+# These are named:
+# providers/<provider description>/
+# or:
+# providers/<provider description>/<site>
+# E.g., providers/local-pbs/PADS
+# WARNINGS
+# nightly.sh uses shopt
+shopt -s nullglob
+printhelp() {
+ echo "nightly.sh <options> <output>"
+ echo ""
+ echo "usage:"
+ printf "\t -a Do not run ant dist \n"
+ printf "\t -c Do not remove dist (clean) \n"
+ printf "\t -g Do not run grid tests \n"
+ printf "\t -h This message \n"
+ printf "\t -k <N> Skip first N tests \n"
+ printf "\t -n <N> Run N tests and quit \n"
+ printf "\t -p Do not build the package \n"
+ printf "\t -s Do not do a fresh svn checkout \n"
+ printf "\t -x Do not continue after a failure \n"
+ printf "\t -v Verbose (set -x, HTML comments) \n"
+ printf "\t -o output Location for output (TOPDIR) \n"
+ printf "\t <FILE> GROUPLIST definition file \n"
+# Defaults:
+DEFAULT_TIMEOUT=30 # seconds
+RUN_ANT=1
+CLEAN=1
+SKIP_TESTS=0
+NUMBER_OF_TESTS=1000000 # Run all tests by default
+BUILD_PACKAGE=1
+GRID_TESTS=1
+SKIP_CHECKOUT=0
+ALWAYS_EXITONFAILURE=0
+VERBOSE=0
+# The directory in which to start:
+TOPDIR=$PWD
+while [ $# -gt 0 ]; do
+ case $1 in
+ -a)
+ RUN_ANT=0
+ shift;;
+ -c)
+ CLEAN=0
+ shift;;
+ -g)
+ GRID_TESTS=0
+ shift;;
+ -h)
+ printhelp
+ exit 0;;
+ -k)
+ SKIP_TESTS=$2
+ shift 2;;
+ -n)
+ NUMBER_OF_TESTS=$2
+ shift 2;;
+ -o)
+ TOPDIR=$2
+ shift 2;;
+ -p)
+ BUILD_PACKAGE=0
+ shift;;
+ -s)
+ SKIP_CHECKOUT=1
+ shift;;
+ -x)
+ ALWAYS_EXITONFAILURE=1
+ shift;;
+ -v)
+ VERBOSE=1
+ shift;;
+ GROUPLISTFILE=$1
+ shift;;
+ esac
+done
+if (( VERBOSE )); then
+ set -x
+ HTML_COMMENTS=1
+fi
+# Iterations per test (may want to run each test multiple times?)
+ITERS_LOCAL=1
+LOGCOUNT=0
+SEQ=1
+DATE=$( date +"%Y-%m-%d" )
+TIME=$( date +"%T" )
+RUNDIRBASE="run-$DATE"
+RUNDIR=$TOPDIR/$RUNDIRBASE
+LOGBASE=$RUNDIRBASE/tests.log
+LOG=$TOPDIR/$LOGBASE
+OUTPUT=$RUNDIR/exec.out
+HTMLPATH=$RUNDIRBASE/tests-$DATE.html
+HTML=$TOPDIR/$HTMLPATH
+BRANCH=trunk
+#BRANCH="branches/tests-01"
+SCRIPTDIR=$( cd $( dirname $0 ) ; /bin/pwd )
+TESTCOUNT=0
+MASTER_PID=$$
+# PIDs to kill if nightly.sh is killed:
+PROCESS_PID=
+MONITOR_PID=
+# When true, we should exit:
+SHUTDOWN=0
+echo "RUNNING_IN: $RUNDIR"
+echo "HTML_OUTPUT: $HTML"
+TESTDIR=$TOPDIR/cog/modules/swift/tests
+# Ensure all given variables are set
+checkvars() {
+ while (( ${#*} ))
+ do
+ VAR=$1
+ V=$( eval "echo \${${VAR}+1}" )
+ [[ $V == 1 ]] || crash "Not set: $VAR"
+ shift
+ done
+ return 0
+checkfail() {
+ ERR=$?
+ shift
+ MSG=${*}
+ if [[ $ERR != 0 ]]; then
+ echo "FAILED($ERR): $MSG"
+ exit $ERR
+ fi
+crash() {
+ MSG=$1
+ echo $MSG
+ exit 1
+verbose() {
+ MSG="${*}"
+ (( $VERBOSE )) && echo $MSG
+ return 0
+shutdown_trap() {
+ SHUTDOWN=1
+ verbose "shutdown_trap... $PROCESS_PID\n\n"
+ verbose "kill: process: $PROCESS_PID"
+ kill $PROCESS_PID
+header() {
+ CURRENT=$SCRIPTDIR/html/current.html
+ sed "s at _HTMLBASE_@$HTMLPATH@" < $CURRENT > $TOPDIR/current.html
+ HEADER=$SCRIPTDIR/html/header.html
+ HOST=$( hostname )
+ SEDCMD="s/_DATE_/$DATE/;s/_TIME_/$TIME/;s/_HOST_/$HOST"/
+ sed $SEDCMD < $HEADER > $HTML
+ FIRSTTEST=1
+html() {
+ printf "$@\n" >>$HTML
+ [ $? != 0 ] && echo "html(): write error!" && exit 1
+html_h1() {
+ TEXT=$1
+ html "<h1>$TEXT</h1>"
+html_a_name() {
+ NAME=$1
+ html "<a name=\"$NAME\">"
+html_a_href() {
+ HREF=$1
+ TEXT=$2
+ html "<a href=\"$HREF\">$TEXT</a>"
+html_table() {
+ OPTS=""
+ while [[ ${#*} > 0 ]]
+ do
+ case $1 in
+ cellpadding)
+ OPTS="${OPTS}cellpadding=\"$2\" "
+ shift 2;;
+ border)
+ OPTS="${OPTS}border=\"$2\" "
+ shift 2;;
+ esac
+ done
+ html "<table $OPTS>"
+html_~table() {
+ html "</table>"
+html_tr() {
+ CLASS=$1
+ if [ -n $CLASS ]; then
+ html "<tr class=\"$CLASS\">"
+ else
+ html "<tr>"
+ fi
+html_~tr() {
+ html "</tr>"
+html_th() {
+ COLSPAN=$1
+ if [ -n $COLSPAN ]; then
+ html "<th colspan=\"$COLSPAN\">"
+ else
+ html "<th>"
+ fi
+html_~th() {
+ html "</th>"
+html_td() {
+ OPTS=""
+ do
+ case $1 in
+ align)
+ OPTS="${OPTS}align=\"$2\" "
+ shift 2;;
+ class)
+ OPTS="${OPTS}class=\"$2\" "
+ shift 2;;
+ title)
+ OPTS="${OPTS}title=\"$2\" "
+ shift 2;;
+ width)
+ OPTS="${OPTS}width=\"$2\" "
+ shift 2;;
+ esac
+ done
+ html "<td $OPTS>"
+html_~td() {
+ html "</td>"
+html_~body() {
+ html "</body>"
+html_~html() {
+ html "</html>"
+html_comment() {
+ COMMENT=$1
+ (( HTML_COMMENTS == 1 )) && html "<!-- $COMMENT -->"
+footer() {
+ html "</tr></table></tr></table>"
+ html_comment "End of tests"
+ MONTHS=("" "Jan" "Feb" "Mar" "Apr" "May" "Jun" \
+ "Jul" "Aug" "Sep" "Oct" "Nov" "Dec")
+ if [ "$BINPACKAGE" != "" ]; then
+ FBP=$RUNDIR/$BINPACKAGE
+ SIZE=`ls -hs $FBP`
+ SIZE=${SIZE/$FBP}
+ cat <<DOH >>$HTML
+ <h1>Binary packages</h1>
+ <a name="#packages">
+ <a href="$BINPACKAGE">$BINPACKAGE</a> ($SIZE)<br>
+DOH
+ fi
+ LASTYR="00"
+ LASTMO="00"
+ html "<h1>Older tests</h1>"
+ html '<a name="older">'
+ html "<table><tr>"
+ for OLDER in `ls $OUTDIR/tests-*.html|sort`; do
+ O=`basename $OLDER`
+ YR=${O:6:2}
+ MO=${O:8:2}
+ DY=${O:10:2}
+ if echo "$DY$MO$YR"|egrep -v "[0-9]{6}"; then
+ YR=${O#tests-}
+ YR=${YR%.html}
+ MO=0
+ DY=$YR
+ else
+ YR="20$YR"
+ fi
+ if [ $LASTYR != $YR ]; then
+ html "</tr></table>"
+ html "<h2>$YR</h2>"
+ LASTYR=$YR
+ fi
+ if [ $LASTMO != $MO ]; then
+ html "<h3>${MONTHS[$MO]}</h3>"
+ html "<table border=\"0\"><tr>"
+ LASTMO=$MO
+ fi
+ SUCCESS=`grep 'class="success"' $OLDER|wc -l`
+ FAILURE=`grep 'class="failure"' $OLDER|wc -l`
+ if [ "$SUCCESS$FAILURE" == "00" ]; then
+ COLOR="#e0e0e0"
+ else
+ COLOR=`perl -e "printf \"#%02x%02x%02x\", $FAILURE/($SUCCESS+$FAILURE)*220+35, $SUCCESS/($SUCCESS+$FAILURE)*220+35, 40;"`
+ fi
+ html "<td bgcolor=\"$COLOR\"><a href=\"$O\">$DY</a></td>"
+ done
+ html "</tr></table><br><br>"
+ html_~body
+ html_~html
+printlist() {
+ while [[ $1 != "" ]]; do
+ echo $1
+ shift
+ done
+outecho() {
+ TYPE=$1
+ shift
+ echo "<$TYPE>$1|$2|$3|$4|$5|$6|$7|$8|$9|"
+# Create HTML output
+out() {
+ # echo $@
+ TYPE=$1
+ if [ "$TYPE" == "test" ]; then
+ LABEL="$2" # Text on link to output
+ CMD=$3 # Command issued (td title)
+ RESULT=$4 # Passed or Failed
+ # WIDTH=$( width "$LABEL" )
+ if [ "$RESULT" == "Passed" ]; then
+ # html "<td class=\"success\" $WIDTH title=\"$CMD\">"
+ html_td class "success" width 25 title "$CMD"
+ html_a_href $TEST_LOG "$LABEL"
+ else
+ echo "FAILED"
+ cat $RUNDIR/$TEST_LOG < /dev/null
+ # html "<td class=\"failure\" $WIDTH title=\"$CMD\">"
+ html_td class "failure" width 25 title "$CMD"
+ html_a_href $TEST_LOG $LABEL
+ fi
+ html_~td
+ elif [ "$TYPE" == "package" ]; then
+ BINPACKAGE=$2
+ else
+ html $@
+ fi
+start_test_results() {
+ html_h1 "Test results"
+ html_a_name "tests"
+ html_a_href "tests.log" "Output log from tests"
+ html_table border 0 cellpadding 1
+start_part() {
+ PART=$1
+ echo
+ echo $PART
+ echo
+ html_tr part
+ html_th 3
+ html "$PART"
+ html_~th
+ html_~tr
+start_row() {
+ html_tr testline
+ html_td align right width 50
+ html "<b>$TESTCOUNT</b>"
+ html " "
+ html_~td
+ html " "
+ if [[ -n $TESTLINK ]]; then
+ html_a_href $TESTLINK $TESTNAME
+ else
+ html $TESTNAME
+ fi
+ html " "
+ html_~td
+ html_td
+ html_table
+ html_tr
+ SEQ=1
+end_row() {
+ html_~tr
+ html_~table
+ html_~td
+ html_~tr
+# HTML width of label (for alignment)
+width() {
+ LABEL="$1"
+ if [ ${#LABEL} -gt 2 ]; then
+ WIDTH=""
+ else
+ WIDTH="width=\"20\""
+ fi
+ echo $WIDTH
+# TEST_LOG = test log
+test_log() {
+ TEST_LOG="output_$LOGCOUNT.txt"
+ banner "$LASTCMD" $RUNDIR/$TEST_LOG
+ if [ -f $OUTPUT ]; then
+ cp $OUTPUT $RUNDIR/$TEST_LOG 2>>$LOG
+ cp $OUTPUT $RUNDIR/stdout.txt
+ fi
+ let "LOGCOUNT=$LOGCOUNT+1"
+stars() {
+ for i in {1..90}
+ do
+ printf "*"
+ done
+ echo
+banner() {
+ MSG=$1
+ FILE=$2
+ if [ "$FILE" == "" ]; then
+ BANNER_OUTPUT=$LOG
+ else
+ BANNER_OUTPUT=$2
+ fi
+ echo ""
+ # stars
+ echo "* $MSG"
+ # stars
+ } >> $BANNER_OUTPUT
+# Check for early bailout condition
+check_bailout() {
+ if [ "$EXITONFAILURE" == "true" ]; then
+ if [ "$EXITCODE" != "0" ]; then
+ exit $EXITCODE
+ fi
+ fi
+# Translate (global) test exit code into result (Passed/Failed) string
+result() {
+ if [ "$EXITCODE" == "0" ]; then
+ echo "Passed"
+ else
+ echo "Failed"
+ fi
+# Execute process in the background
+process_exec() {
+ printf "\nExecuting: $@" >>$LOG
+ rm -f $OUTPUT
+ "$@" > $OUTPUT 2>&1
+ EXITCODE=$?
+ if [ "$EXITCODE" == "127" ]; then
+ echo "Command not found: $@" > $OUTPUT
+ fi
+ cat $OUTPUT >> $LOG
+ fi
+ (( $TEST_SHOULD_FAIL )) && EXITCODE=$(( ! $EXITCODE ))
+ return $EXITCODE
+# Execute as part of test set
+# Equivalent to monitored_exec() (but w/o monitoring)
+test_exec() {
+ banner "$TEST (part $SEQ)"
+ echo "Executing $TEST (part $SEQ)"
+ pwd
+ rm -f $OUTPUT
+ EXITCODE=$?
+ fi
+ fi
+ RESULT=$( result )
+ test_log
+ out test $SEQ "$LASTCMD" $RESULT $TEST_LOG
+ check_bailout
+ let "SEQ=$SEQ+1"
+ return $EXITCODE
+# Background process monitoring function
+# To be executed in the background as well
+# If the monitored process times out, monitor() kills it and writes
+# a message to OUTPUT
+# If monitor() kills the process, it returns 0
+# Otherwise, return non-zero (as would result from killing
+# this function)
+# sleep can be hard to kill:
+SLEEP_PID=
+monitor() {
+ (( $VERBOSE )) && set -x
+ PID=$1
+ TIMEOUT=$2 # seconds
+ OUTPUT=$3
+ V=$TESTCOUNT
+ sleep $TIMEOUT &
+ SLEEP_PID=$!
+ trap trap_sleep SIGINT SIGQUIT SIGTERM
+ wait
+ [ $? != 0 ] && verbose "monitor($V) cancelled" && return 0
+ if ps | grep $PID
+ then
+ verbose "monitor: killing test process $PID"
+ touch killed_test
+ /bin/kill -INT $PID
+ KILLCODE=$?
+ if [ $KILLCODE == 0 ]; then
+ verbose "monitor: killed process_exec (INT)"
+ fi
+ fi
+ sleep 1
+ MSG="nightly.sh: monitor: killed: exceeded $TIMEOUT seconds"
+ echo "$MSG" >> $OUTPUT
+ return 1
+trap_sleep() {
+ verbose "killing sleep: $SLEEP_PID"
+ kill $SLEEP_PID
+# Execute given command line in background with monitor
+# Otherwise equivalent to test_exec()
+# usage: monitored_exec <TIMEOUT> <command> <args>*
+monitored_exec()
+ TIMEOUT=$1
+ shift
+ START=$( date +%s )
+ process_exec "$@" &
+ PROCESS_PID=$!
+ monitor $PROCESS_PID $TIMEOUT $OUTPUT &
+ MONITOR_PID=$!
+ wait $PROCESS_PID
+ EXITCODE=$?
+ STOP=$( date +%s )
+ # If the test was killed, monitor() may have work to do
+ rm killed_test > /dev/null 2>&1 && sleep 5
+ verbose "killing monitor: $MONITOR_PID..."
+ kill $MONITOR_PID
+ echo "TOOK: $(( STOP-START ))"
+ test_log
+ LASTCMD="$@"
+ check_bailout
+ let "SEQ=$SEQ+1"
+# Execute helper script (setup, check, or clean)
+script_exec() {
+ SCRIPT=$1
+ SYMBOL="$2"
+ process_exec $SCRIPT
+ test_log
+ out test "$SYMBOL" "$LASTCMD" $RESULT
+ check_bailout
+# Execute Swift test case w/ setup, check, clean
+swift_test_case() {
+ SWIFTSCRIPT=$1
+ SETUPSCRIPT=${SWIFTSCRIPT%.swift}.setup.sh
+ CHECKSCRIPT=${SWIFTSCRIPT%.swift}.check.sh
+ CLEANSCRIPT=${SWIFTSCRIPT%.swift}.clean.sh
+ TIMEOUTFILE=${SWIFTSCRIPT%.swift}.timeout
+ TEST_SHOULD_FAIL=0
+ if [ -x $GROUP/$SETUPSCRIPT ]; then
+ script_exec $GROUP/$SETUPSCRIPT "S"
+ fi
+ CDM=
+ [ -r fs.data ] && CDM="-cdm.file fs.data"
+ (( TESTCOUNT++ ))
+ TIMEOUT=$( gettimeout $GROUP/$TIMEOUTFILE )
+ grep THIS-SCRIPT-SHOULD-FAIL $SWIFTSCRIPT > /dev/null
+ TEST_SHOULD_FAIL=$(( ! $? ))
+ monitored_exec $TIMEOUT swift \
+ -wrapperlog.always.transfer true \
+ -config swift.properties \
+ -sites.file sites.xml \
+ -tc.file tc.data \
+ $CDM $SWIFTSCRIPT
+ if [ -x $GROUP/$CHECKSCRIPT ]; then
+ script_exec $GROUP/$CHECKSCRIPT "√"
+ fi
+ if [ -x $GROUP/$CLEANSCRIPT ]; then
+ script_exec $GROUP/$CLEANSCRIPT "C"
+ fi
+# Execute shell test case w/ setup, check, clean
+script_test_case() {
+ SHELLSCRIPT=$1
+ SETUPSCRIPT=${SHELLSCRIPT%.test.sh}.setup.sh
+ CHECKSCRIPT=${SHELLSCRIPT%.test.sh}.check.sh
+ CLEANSCRIPT=${SHELLSCRIPT%.test.sh}.clean.sh
+ TIMEOUTFILE=${SHELLSCRIPT%.test.sh}.timeout
+ fi
+ (( TESTCOUNT++ ))
+ # Not using background for script tests yet
+ # TIMEOUT=$( gettimeout $GROUP/$TIMEOUTFILE )
+ fi
+ if [ -x $GROUP/$SHELLSCRIPT ]; then
+ script_exec $SHELLSCRIPT "X"
+ fi
+ fi
+ fi
+gettimeout() {
+ FILE=$1
+ if [ -f $FILE ]; then
+ cat $FILE
+ else
+ echo $DEFAULT_TIMEOUT
+ fi
+ return 0
+ssexec() {
+ SEQSAVE=$SEQ
+ SEQ=$1
+ shift
+ aexec "$@"
+ ptest
+ SEQ=$SEQSAVE
+# Fake exec
+fexec() {
+ banner "$TEST (faked)"
+ echo "Faking $TEST"
+ EXITCODE=0
+ LASTCMD=""
+ # ptest
+build_package() {
+ TEST="Package"
+ test_exec cd $SWIFT_HOME/lib
+ test_exec rm -f castor*.jar *gt2ft*.jar ant.jar
+ test_exec cd $TOPDIR
+ test_exec tar -pczf $RUNDIR/swift-$DATE.tar.gz $SWIFT_HOME
+ out package "swift-$DATE.tar.gz"
+# Generate the sites.sed file
+make_sites_sed() {
+ echo "s at _WORK_@$WORK@"
+ echo "s at _HOST_@$GLOBUS_HOSTNAME@"
+ echo "s at _PROJECT_@$PROJECT@"
+ echo "s at _QUEUE_@$QUEUE@"
+ } > $RUNDIR/sites.sed
+ return 0
+# Setup coasters variables
+if which ifconfig > /dev/null 2>&1; then
+ IFCONFIG=ifconfig
+else
+ IFCONFIG=/sbin/ifconfig
+fi
+$IFCONFIG > /dev/null 2>&1 || crash "Cannot run ifconfig!"
+GLOBUS_HOSTNAME=$( $IFCONFIG | grep inet | head -1 | cut -d ':' -f 2 | \
+ awk '{print $1}' )
+[ $? != 0 ] && crash "Could not obtain GLOBUS_HOSTNAME!"
+# Generate sites.xml
+group_sites_xml() {
+ TEMPLATE=$GROUP/sites.template.xml
+ if [ -f $TEMPLATE ]; then
+ sed -f $RUNDIR/sites.sed < $TEMPLATE > sites.xml
+ [ $? != 0 ] && crash "Could not create sites.xml!"
+ echo "Using: $GROUP/sites.template.xml"
+ else
+ sed "s at _WORK_@$PWD/work@" < $TESTDIR/sites/localhost.xml > sites.xml
+ echo "Using: $TESTDIR/sites/localhost.xml"
+ fi
+# Generate tc.data
+group_tc_data() {
+ if [ -f $GROUP/tc.template.data ]; then
+ sed "s at _DIR_@$GROUP@" < $GROUP/tc.template.data > tc.data
+ [ $? != 0 ] && crash "Could not create tc.data!"
+ echo "Using: $GROUP/tc.template.data"
+ else
+ cp -v $SWIFT_HOME/etc/tc.data .
+ [ $? != 0 ] && crash "Could not copy tc.data!"
+ fi
+# Generate the CDM file, fs.data
+group_fs_data() {
+ if [ -f $GROUP/fs.template.data ]; then
+ sed "s at _PWD_@$PWD@" < $GROUP/fs.template.data > fs.data
+ [ $? != 0 ] && crash "Could not create fs.data!"
+ echo "Using: $GROUP/fs.template.data"
+ else
+ rm -f fs.data
+ fi
+# Generate swift.properties
+group_swift_properties() {
+ if [ -f $GROUP/swift.properties ]; then
+ cp -v $GROUP/swift.properties .
+ [ $? != 0 ] && crash "Could not copy swift.properties!"
+ else
+ cp -v $SWIFT_HOME/etc/swift.properties .
+ fi
+# Obtain the group title
+group_title() {
+ if [ -r $GROUP/title.txt ]; then
+ cat $GROUP/title.txt
+ else
+ echo "untitled"
+ fi
+# Execute all tests in current GROUP
+test_group() {
+ group_sites_xml
+ group_tc_data
+ group_fs_data
+ group_swift_properties
+ SWIFTS=$( echo $GROUP/*.swift )
+ checkfail "Could not list: $GROUP"
+ for TEST in $SWIFTS; do
+ (( SKIP_COUNTER++ < SKIP_TESTS )) && continue
+ TESTNAME=$( basename $TEST )
+ cp -v $GROUP/$TESTNAME .
+ TESTLINK=$TESTNAME
+ start_row
+ for (( i=0; $i<$ITERS_LOCAL; i=$i+1 )); do
+ swift_test_case $TESTNAME
+ (( $TESTCOUNT >= $NUMBER_OF_TESTS )) && return
+ (( $SHUTDOWN )) && return
+ done
+ end_row
+ done
+ SCRIPTS=$( echo $GROUP/*.test.sh )
+ for TEST in $SCRIPTS; do
+ start_row
+ for ((i=0; $i<$ITERS_LOCAL; i=$i+1)); do
+ script_test_case $TESTNAME
+ done
+ end_row
+ done
+if [[ $WORK == "" ]]
+then
+ WORK=$TOPDIR/work
+fi
+checkvars GROUPLISTFILE
+echo "GROUPLISTFILE: $GROUPLISTFILE"
+source $GROUPLISTFILE || exit 1
+cd $TOPDIR
+mkdir -p $RUNDIR
+[ $? != 0 ] && echo "Could not mkdir: $RUNDIR" && exit 1
+date > $LOG
+make_sites_sed
+header
+start_test_results
+cd $TOPDIR
+start_part "Prolog: Build"
+TESTLINK=
+EXITONFAILURE=true
+if [ "$SKIP_CHECKOUT" != "1" ]; then
+ TESTNAME="Checkout CoG"
+ start_row
+ test_exec rm -rf cog
+ COG="https://cogkit.svn.sourceforge.net/svnroot/cogkit/$COG_VERSION/src/cog"
+ test_exec svn co $COG
+ end_row
+ TESTNAME="Checkout Swift"
+ start_row
+ test_exec cd cog/modules
+ test_exec rm -rf swift
+ test_exec svn co https://svn.ci.uchicago.edu/svn/vdl2/$SWIFT_VERSION swift
+ end_row
+fi
+TESTNAME="Compile"
+start_row
+test_exec cd $TOPDIR/cog/modules/swift
+if (( $CLEAN )); then
+ test_exec rm -rf dist
+fi
+if (( $RUN_ANT )); then
+ test_exec ant -quiet dist
+fi
+SWIFT_HOME=$TOPDIR/cog/modules/swift/dist/swift-svn
+if [ $BUILD_PACKAGE = "1" ]; then
+ build_package
+fi
+end_row
+PATH=$SWIFT_HOME/bin:$PATH
+cd $TOPDIR
+echo "USING: $( which swift )"
+cd $RUNDIR
+if [ $ALWAYS_EXITONFAILURE != "1" ]; then
+ EXITONFAILURE=false
+fi
+trap "shutdown_trap" SIGINT SIGTERM
+SKIP_COUNTER=0
+GROUPCOUNT=1
+for G in ${GROUPLIST[@]}; do
+ export GROUP=$G
+ TITLE=$( group_title )
+ start_part "Part $GROUPCOUNT: $TITLE"
+ test_group
+ (( GROUPCOUNT++ ))
+ (( $TESTCOUNT >= $NUMBER_OF_TESTS )) && break
+ (( $SHUTDOWN )) && break
+done
+if [ $GRID_TESTS == "0" ]; then
+ exit 0
+fi
+TESTPART="Appendix G: Grid Tests"
+for TEST in `ls $TESTDIR/*.dtm $TESTDIR/*.swift`; do
+ BN=`basename $TEST`
+ echo $BN
+ cp $TESTDIR/$BN .
+ TESTNAME=${BN%.dtm}
+ TESTNAME=${TESTNAME%.swift}
+ TEST="<a href=\"$RUNDIRBASE/$BN\">$TESTNAME</a>"
+ ssexec "Compile" vdlc $BN
+ for ((i=0; $i<9; i=$i+1)); do
+ test_exec swift -sites.file ~/.vdl2/sites-grid.xml $TESTNAME.kml
+ done
+done
+footer
+exit 0
+# Local Variables:
+# sh-basic-offset: 2
+# End:
More information about the Swift-commit
