[Swift-commit] r4263 - in trunk/tests: . html mpi persistent-coasters
wozniak at ci.uchicago.edu
Mon Apr 4 13:00:30 CDT 2011
Author: wozniak
Date: 2011-04-04 13:00:30 -0500 (Mon, 04 Apr 2011)
New Revision: 4263
Added:
trunk/tests/run-suite.sh
Removed:
trunk/tests/run-nightly.sh
Modified:
trunk/tests/README
trunk/tests/html/header.html
trunk/tests/meta.sh
trunk/tests/mpi/README.txt
trunk/tests/persistent-coasters/000-sanity.test.sh
trunk/tests/sitetester
trunk/tests/suite.sh
Log:
Rename nightly.sh to suite.sh
Modified: trunk/tests/README
--- trunk/tests/README 2011-04-04 17:57:09 UTC (rev 4262)
+++ trunk/tests/README 2011-04-04 18:00:30 UTC (rev 4263)
@@ -1,13 +1,13 @@
-nightly.sh:
- See nightly.sh for usage
+suite.sh:
+ See suite.sh for usage
-run-nightly.sh:
- wrapper for nightly.sh
+run-suite.sh:
+ wrapper for suite.sh
env variables set may be customized by user
meta.sh:
- wrapper for run-nightly.sh
- used to execute run-nightly/nightly.sh from a remote site using ssh
+ wrapper for run-suite.sh
+ used to execute run-suite/suite.sh from a remote site using ssh
example usage:
meta.sh login.pads.ci.uchicago.edu /home/skenny/swift_runs/tests sites/pads-pbs-coasters.sh
Modified: trunk/tests/html/header.html
--- trunk/tests/html/header.html 2011-04-04 17:57:09 UTC (rev 4262)
+++ trunk/tests/html/header.html 2011-04-04 18:00:30 UTC (rev 4263)
@@ -1,6 +1,6 @@
<html>
<head>
- <title>Swift nightly integration tests and build (_DATE_ _TIME_)
+ <title>Swift integration tests and build (_DATE_ _TIME_)
</title>
<style type="text/css">
a:link {color:black}
@@ -16,7 +16,7 @@
</style>
</head>
<body>
- <h1>Swift nightly integration tests and build</h1>
+ <h1>Swift integration tests and build</h1>
<ul>
<li>Date: _DATE_</li>
<li>Time: _TIME_</li>
Modified: trunk/tests/meta.sh
--- trunk/tests/meta.sh 2011-04-04 17:57:09 UTC (rev 4262)
+++ trunk/tests/meta.sh 2011-04-04 18:00:30 UTC (rev 4263)
@@ -1,6 +1,6 @@
#!/bin/bash
-# runs run-nightly.sh (wrapper for nightly.sh) on a given site based on login
+# runs run-suite.sh (wrapper for suite.sh) on a given site based on login
SITE_LOGIN=$1 # e.g. login.pads.ci.uchicago.edu
@@ -12,7 +12,7 @@
RUNDIR=run-$( date +"%Y-%m-%d" )
-ssh $SITE_LOGIN $DIR/run-nightly.sh $DIR/$TEST
+ssh $SITE_LOGIN $DIR/run-suite.sh $DIR/$TEST
scp -r $SITE_LOGIN:$RUNDIR .
exit 0
Modified: trunk/tests/mpi/README.txt
--- trunk/tests/mpi/README.txt 2011-04-04 17:57:09 UTC (rev 4262)
+++ trunk/tests/mpi/README.txt 2011-04-04 18:00:30 UTC (rev 4263)
@@ -1,6 +1,6 @@
Test MPICH/Coasters integration
-Be sure the correct MPICH is in your PATH before running nightly.sh
+Be sure the correct MPICH is in your PATH before running suite.sh
See: http://www.ci.uchicago.edu/wiki/bin/view/SWFT/CoastersMpi
Modified: trunk/tests/persistent-coasters/000-sanity.test.sh
--- trunk/tests/persistent-coasters/000-sanity.test.sh 2011-04-04 17:57:09 UTC (rev 4262)
+++ trunk/tests/persistent-coasters/000-sanity.test.sh 2011-04-04 18:00:30 UTC (rev 4263)
@@ -1,6 +1,6 @@
#!/bin/bash
-# This is just a sanity check for the nightly.sh shell script test
+# This is just a sanity check for the suite.sh shell script test
# mechanics
echo sane
Deleted: trunk/tests/run-nightly.sh
--- trunk/tests/run-nightly.sh 2011-04-04 17:57:09 UTC (rev 4262)
+++ trunk/tests/run-nightly.sh 2011-04-04 18:00:30 UTC (rev 4263)
@@ -1,23 +0,0 @@
-#!/bin/bash
-# sets up environment and runs nightly.sh
-# given a groupslistfile, will run nightly.sh on that site
-GROUPSLISTFILE=$1 # E.g., groups/group-all-local.sh
-# user-specific variables
-export WORK=$2
-export QUEUE=$3
-export PROJECT=$4
-# branch testing
-export COG_VERSION=$5
-export SWIFT_VERSION=$6
-#$2/nightly.sh -g $GROUPSLISTFILE
-$2/nightly.sh -g $GROUPSLISTFILE
-exit 0
Copied: trunk/tests/run-suite.sh (from rev 4251, trunk/tests/run-nightly.sh)
--- trunk/tests/run-suite.sh (rev 0)
+++ trunk/tests/run-suite.sh 2011-04-04 18:00:30 UTC (rev 4263)
@@ -0,0 +1,23 @@
+#!/bin/bash
+# sets up environment and runs suite.sh
+# given a groupslistfile, will run suite.sh on that site
+GROUPSLISTFILE=$1 # E.g., groups/group-all-local.sh
+# user-specific variables
+export WORK=$2
+export QUEUE=$3
+export PROJECT=$4
+# branch testing
+export COG_VERSION=$5
+export SWIFT_VERSION=$6
+#$2/suite.sh -g $GROUPSLISTFILE
+$2/suite.sh -g $GROUPSLISTFILE
+exit 0
Modified: trunk/tests/sitetester
--- trunk/tests/sitetester 2011-04-04 17:57:09 UTC (rev 4262)
+++ trunk/tests/sitetester 2011-04-04 18:00:30 UTC (rev 4263)
@@ -3,10 +3,10 @@
import commands
import os
-# the workdir for a given site needs to exist on the site you're testing
-# and should contain run-nightly & nightly.sh
-# this script will ssh onto the site, pass run-nightly the necesary variables
-# for running nightly.sh
+# the workdir for a given site needs to exist on the site you're testing
+# and should contain run-suite & suite.sh
+# this script will ssh onto the site, pass run-suite the necesary variables
+# for running suite.sh
class Site:
@@ -18,16 +18,16 @@
self.project = project
def testSite(self,cogv,swiftv,test_type):
- cmdline = self.logintype+" "+self.login+" "+self.workdir+"/run-nightly.sh "+self.workdir+"/"+test_type+" "+self.workdir+" "+self.queue+" "+self.project+" "+cogv+" "+swiftv
+ cmdline = self.logintype+" "+self.login+" "+self.workdir+"/run-suite.sh "+self.workdir+"/"+test_type+" "+self.workdir+" "+self.queue+" "+self.project+" "+cogv+" "+swiftv
print "running......"+cmdline
res = commands.getoutput(cmdline)
print res
cmdline2 = "scp -r "+s+":"+rundir+" ."
res2 = commands.getoutput(cmdline)
#---------------------main--------------------------------------------------------
sites = []
@@ -51,7 +51,7 @@
# loop over all or run single
sites[1].testSite(cogv,swiftv,test_type)
-sites[2].testSite(cogv,swiftv,test_type)
+sites[2].testSite(cogv,swiftv,test_type)
Modified: trunk/tests/suite.sh
--- trunk/tests/suite.sh 2011-04-04 17:57:09 UTC (rev 4262)
+++ trunk/tests/suite.sh 2011-04-04 18:00:30 UTC (rev 4263)
@@ -6,9 +6,9 @@
# subdirectory called run-DATE, and generate useful HTML output and
# tests.log
-# Usage: nightly.sh <options>* <GROUPLIST>
+# Usage: suite.sh <options>* <GROUPLIST>
-# Run nightly.sh -h for quick help
+# Run suite.sh -h for quick help
# When something goes wrong, find and check tests.log or use -v
# Code is checked out into TOPDIR (PWD by default) (PATH is not used)
# The variables COG_VERSION and SWIFT_VERSION must be set for code checkout
@@ -58,9 +58,9 @@
# Background processes are used so that hung Swift jobs can be killed
# These are the background processes (PIDs are tracked)
# Note that PID management has not yet been perfected. Check ps
-# in error cases, especially if you kill nightly.sh .
+# in error cases, especially if you kill suite.sh .
-# nightly.sh
+# suite.sh
# +-monitor()
# +-sleep
# +-process_exec()
@@ -70,7 +70,7 @@
# FAILURE CASES
# Some cases are designed to cause Swift to crash. These
# SwiftScripts contain the token THIS-SCRIPT-SHOULD-FAIL somewhere.
-# The response of nightly.sh to the exit code of these Swift
+# The response of suite.sh to the exit code of these Swift
# executions is reversed.
# SCHEDULERS
@@ -88,12 +88,12 @@
# E.g., providers/local-pbs/PADS
# WARNINGS
-# nightly.sh uses shopt
+# suite.sh uses shopt
shopt -s nullglob
printhelp() {
- echo "nightly.sh <options> <output>"
+ echo "suite.sh <options> <output>"
echo ""
echo "usage:"
printf "\t -a Do not run ant dist \n"
@@ -196,7 +196,7 @@
MASTER_PID=$$
-# PIDs to kill if nightly.sh is killed:
+# PIDs to kill if suite.sh is killed:
PROCESS_PID=
MONITOR_PID=
@@ -668,7 +668,7 @@
fi
sleep 1
- MSG="nightly.sh: monitor: killed: exceeded $TIMEOUT seconds"
+ MSG="suite.sh: monitor: killed: exceeded $TIMEOUT seconds"
echo "$MSG" >> $OUTPUT
return 1
More information about the Swift-commit
