[Swift-commit] r4261 - trunk/tests
wozniak at ci.uchicago.edu wozniak at ci.uchicago.edu
Mon Apr 4 12:55:14 CDT 2011
Author: wozniak
Date: 2011-04-04 12:55:14 -0500 (Mon, 04 Apr 2011)
New Revision: 4261
Modified:
   trunk/tests/nightly.sh
Log:
Improve PID mgmt
Modified: trunk/tests/nightly.sh
--- trunk/tests/nightly.sh	2011-04-04 17:54:49 UTC (rev 4260)
+++ trunk/tests/nightly.sh	2011-04-04 17:55:14 UTC (rev 4261)
@@ -194,6 +194,8 @@
 TESTCOUNT=0
+MASTER_PID=$$
 # PIDs to kill if nightly.sh is killed:
 PROCESS_PID=
 MONITOR_PID=
@@ -242,10 +244,9 @@
 shutdown_trap() {
   SHUTDOWN=1
-  printf "\n\nshutdown_trap... $MONITOR_PID $PROCESS_PID\n\n"
-  ps -f
-  kill -INT $MONITOR_PID
-  kill -INT $PROCESS_PID
+  verbose "shutdown_trap... $PROCESS_PID\n\n"
+  verbose "kill: process: $PROCESS_PID"
+  kill $PROCESS_PID
 header() {
@@ -587,13 +588,9 @@
   printf "\nExecuting: $@" >>$LOG
   rm -f $OUTPUT
-  "$@" > $OUTPUT 2>&1 &
-  EXEC_PID=$!
-  trap "process_exec_trap $EXEC_PID" SIGTERM SIGINT
-  wait $EXEC_PID
+  "$@" > $OUTPUT 2>&1
   EXITCODE=$?
   if [ "$EXITCODE" == "127" ]; then
     echo "Command not found: $@" > $OUTPUT
   fi
@@ -604,33 +601,6 @@
   return $EXITCODE
-# Ensure we kill the tested process and any subordinate java processes
-# in case of monitor() timeout
-# Rationale: Killing bin/swift does not kill the Swift java process
-process_exec_trap() {
-  EXEC_PID=$1
-  ps -f
-  echo "process_exec_trap($EXEC_PID)"
-  kill -TERM $EXEC_PID
-  ps -f
-  # killall_swift
-# Kill all subordinate swift/java processes
-killall_swift() {
-  echo "killing all swifts..."
-  set -x
-  echo $$
-  ps -f
-  kill_this $( ps -f | grep $$'.*'java  | grep -v grep )
-  set +x
-# Kill a process given its line output from "ps -f"
-kill_this() {
-  [ -n $2 ] && /bin/kill -KILL $2
 # Execute as part of test set
 # Equivalent to monitored_exec() (but w/o monitoring)
 test_exec() {
@@ -668,6 +638,9 @@
 # If monitor() kills the process, it returns 0
 # Otherwise, return non-zero (as would result from killing
 # this function)
+# sleep can be hard to kill:
+SLEEP_PID=
 monitor() {
   (( $VERBOSE )) && set -x
@@ -677,35 +650,33 @@
   V=$TESTCOUNT
-  # Use background so kill/trap is immediate
-  sleep $TIMEOUT > /dev/null 2>&1 &
+  sleep $TIMEOUT &
   SLEEP_PID=$!
-  trap "monitor_trap $SLEEP_PID" SIGTERM SIGINT
-  wait $SLEEP_PID
+  trap trap_sleep SIGINT SIGQUIT SIGTERM
+  wait
   [ $? != 0 ] && verbose "monitor($V) cancelled" && return 0
   if ps | grep $PID
   then
-    echo "monitor($V): killing test process $PID"
+    verbose "monitor: killing test process $PID"
     touch killed_test
     /bin/kill -INT $PID
     KILLCODE=$?
     if [ $KILLCODE == 0 ]; then
-      echo "monitor($V): killed process_exec (TERM)"
+      verbose "monitor: killed process_exec (INT)"
     fi
   fi
   sleep 1
-  MSG="nightly.sh: monitor($V): killed: exceeded $TIMEOUT seconds"
+  MSG="nightly.sh: monitor: killed: exceeded $TIMEOUT seconds"
   echo "$MSG" >> $OUTPUT
-  # trap
   return 1
-monitor_trap() {
-  SLEEP_PID=$1
-  echo "monitor_trap(SLEEP_PID)..."
-  /bin/kill -INT $SLEEP_PID
+trap_sleep() {
+  verbose "killing sleep: $SLEEP_PID"
+  kill $SLEEP_PID
 # Execute given command line in background with monitor
@@ -723,11 +694,9 @@
   process_exec "$@" &
   PROCESS_PID=$!
-  echo PROCESS_PID: $PROCESS_PID
   monitor $PROCESS_PID $TIMEOUT $OUTPUT &
   MONITOR_PID=$!
-  echo MONITOR_PID: $MONITOR_PID
   wait $PROCESS_PID
   EXITCODE=$?
@@ -736,8 +705,8 @@
   # If the test was killed, monitor() may have work to do
   rm killed_test > /dev/null 2>&1 && sleep 5
-  echo "Killing monitor..."
-  /bin/kill -INT $MONITOR_PID
+  verbose "killing monitor: $MONITOR_PID..."
+  kill $MONITOR_PID
   echo "TOOK: $(( STOP-START ))"
