[Swift-commit] r3479 - trunk/src/org/griphyn/vdl/engine
noreply at svn.ci.uchicago.edu
Tue Jul 27 20:43:34 CDT 2010
Author: jonmon
Date: 2010-07-27 20:43:34 -0500 (Tue, 27 Jul 2010)
New Revision: 3479
Modified:
trunk/src/org/griphyn/vdl/engine/Karajan.java
Log:
o trunk/src/org/griphyn/vdl/engine/Karajan/java
-- Added a functionality for a SWIFT_LIB enviroment variable. If the import directive cannot find the file to import relatively it then checks the SWIFT_LIB enviroment variable.
Modified: trunk/src/org/griphyn/vdl/engine/Karajan.java
--- trunk/src/org/griphyn/vdl/engine/Karajan.java 2010-07-28 01:11:31 UTC (rev 3478)
+++ trunk/src/org/griphyn/vdl/engine/Karajan.java 2010-07-28 01:43:34 UTC (rev 3479)
@@ -8,12 +8,14 @@
import java.io.PrintStream;
import java.util.ArrayList;
import java.util.LinkedList;
+import java.util.List;
import java.util.Collection;
import java.util.HashMap;
import java.util.HashSet;
import java.util.Iterator;
import java.util.Map;
import java.util.Set;
+import java.util.StringTokenizer;
import javax.xml.namespace.QName;
@@ -43,6 +45,7 @@
import org.griphyn.vdl.karajan.Loader;
import org.griphyn.vdl.karajan.CompilationException;
import org.griphyn.vdl.toolkit.VDLt2VDLx;
+import org.griphyn.vdl.toolkit.VDLt2VDLx.ParsingException;
import org.safehaus.uuid.UUIDGenerator;
import org.w3c.dom.Node;
@@ -162,9 +165,30 @@
// TODO PATH/PERL5LIB-style path handling
//String swiftfilename = "./"+moduleToImport+".swift";
//String xmlfilename = "./"+moduleToImport+".xml";
+ String lib_path = System.getenv("SWIFT_LIB");
String swiftfilename = moduleToImport+".swift";
String xmlfilename = moduleToImport+".xml";
+ File local = new File(swiftfilename);
+ if( !( lib_path == null || local.exists() ) )
+ StringTokenizer st = new StringTokenizer(lib_path, ":");
+ while(st.hasMoreTokens())
+ String path = st.nextToken();
+ String lib_script_location = path + "/" + swiftfilename;
+ File tmp = new File(lib_script_location);
+ if(tmp.exists())
+ swiftfilename = path + "/" + swiftfilename;
+ xmlfilename = path + "/" + xmlfilename;
+ moduleToImport = path + "/" + moduleToImport;
+ break;
try {
VDLt2VDLx.compile(new FileInputStream(swiftfilename),new PrintStream(new FileOutputStream(xmlfilename)));
logger.debug("Compiled. Now reading in compiled XML for "+moduleToImport);
More information about the Swift-commit
